[Mapbender-users] Tipps and Tricks Mapbender - BaseSourceSwitcher (german and english version)
Charlotte Toma charlotte.toma at wheregroup.com
Tue May 16 00:37:00 PDT 2017
----- English
Hello Mapbender User,
For the particularly nice integration of the BaseSourceSwitcher [1] into
the application, we have written a small tutorial.
After the configuration, the BaseSourceSwitcher is integrated in the
sidepane with a preview of the background-map, as in the the city map
application [2] of the Metropole Ruhr.
For the configuration the styling of the application is adapted via CSS.
As a preparation you have to create screenshots with the size 110x110px
of the background maps and place them in the web-folder (screenshots
must be accessible from the outside). After this, you must include the
BaseSourceSwitcher in the sidepane, not in the toolbar, as mentioned in
the documentation.
Remove all groups, if you have previously used them.
Now insert the CSS-definition in your application under the CSS-tab.
After the integration you have to adjust the number of the
data-sourceset and the path of the image for each service.
The numbers for the data-sourceset can be found in the Layerset under ID
(here you can use the InstanceID).
The detailed documentation on the official documentation page for the
element is still in progress.
This tip was created in kind support of Ms. Bast (RVR), Mr. Schepers
(RVR) and Mr. Schaefer (Mapbender3)!
[1]
http://doc.mapbender3.org/en/bundles/Mapbender/CoreBundle/elements/basesourceswitcher.html
[2] https://stadtplan.geoportal.ruhr/
----- German
Hallo Mapbender Nutzer,
für die besonders schöne Einbindung des Hintergrundwechslers [1] in die
Anwendung haben wir hier eine kleine Anleitung geschrieben.
Nach der Anpassung ist der Hintergrundwechsler wie bei der Anwendung für
den Stadtplan [2] der Metropole Ruhr in der Seitenleiste mit
Kartenvorschau eingebunden.
Für die Konfiguration wird das Styling der Anwendung über CSS angepasst.
Als Vorbereitung müssen Sie Screenshots mit der Größe 110x110px von den
Hintergrundkarten erstellen und im web-Verzeichnis ablegen (Screenshots
müssen von Außen erreichbar sein).
Danach müssen Sie den BaseSourceSwitcher nach der Anleitung in der
Dokumentation nicht in die Toolbar, sondern in die Sidepane einbinden.
Entfernen Sie alle Gruppierungen, falls Sie vorher Gruppierungen genutzt
haben.
Fügen Sie nun die CSS-Vorlage in Ihrer Anwendung unter dem Tab CSS ein.
Nach der Einbindung müssen Sie noch die Nummer des data-sourceset und
den Pfad des Bildes je Dienst anpassen.
Die passenden Nummern für das Layerset finden Sie in dem Tab Layerset
unter ID (Nehmen Sie hier die InstanceID).
Die ausführliche Dokumentation auf der offiziellen Dokumentationsseite
zum Element wird noch nachgetragen.
Dieser Tipp wurde in freundlicher Unterstützung von Frau Bast (RVR),
Herr Schepers (RVR) und Herr Schaefer (Mapbender3) erstellt!
[1]
http://doc.mapbender3.org/de/bundles/Mapbender/CoreBundle/elements/basesourceswitcher.html
Mit freundlichen Grüßen
Charlotte Toma
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-GIS-Schulungen
bei der www.foss-academy.com
 Charlotte Toma
 WhereGroup GmbH & Co.KG
 Eifelstraße 7
 53119 Bonn
 Germany
 Fon: +49(0)228 90 90 38 - 24
 Fax: +49(0)228 90 90 38 - 11
 www.wheregroup.com
 Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Type: text/css
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20170516/cd7d6175/attachment.css>
More information about the Mapbender_users mailing list
