[Mapbender-users] Feature Info Problem (in mobile template)
Astrid Emde astrid.emde at wheregroup.com
Tue May 30 23:19:23 PDT 2017
Hello Patrick,
(sorry for the late answer...)
have a look at the last version of the mobile application. The problem
does not show up there.
https://demo.mapbender3.org/application/mapbender_mobile
Maybe you can compare your application with the mapbender_mobile
application.
Best regards Astrid
Am 2017-05-15 10:10, schrieb Patrick Meis:
> Hallo list,
> I'm fighting with a feature info problem in the mobile version of
> mapbender3.
> I checked the autoopen-option, since I don't want to hit any extra
> button to activate feature info.
> Similarly I unchecked  "Deactivate on close", so it would remain
> activated even after I close the
> feature info popup.
> Now for the request it works alright. The popup opens with the
> expected info.
> I can now hit another element in the map and the info in the popup
> changes accordingly.
> But if I close the info-popup and then try to request another feature,
> the info-popup is not opening
> again.
> I can see that Mapbender works shortly, and in the Firefox Developer
> Tools I see the request goes
> out, and even the right answer comes.
> Just the popup is not opening again. Only after I reload the whole
> application again.
> Any thoughts on that?
> Thanks in advance
> Patrick
> ___________________________________________________
> Stadt Münster
> Der Oberbürgermeister
> Vermessungs- und Katasteramt
> Albersloher Weg 33
> 48155 Münster
> Tel.: 0251 / 492 6263
> E-Mail: meis at stadt-muenster.de
> Internet: http://www.muenster.de/
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Qualifizierte OpenSource-GIS-Schulungen
bei der www.foss-academy.com
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Eifelstraße 7
  53119 Bonn
  Germany
  Fon: +49(0)228 90 90 38 - 22
  Fax: +49(0)228 90 90 38 - 11
  www.wheregroup.com
  Folgen Sie der WhereGroup auf twitter:
http://twitter.com/WhereGroup_com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
