[Mapbender-users] Digital forest fire operation map
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Fri Jul 14 00:11:34 PDT 2023
Hello Friedrich,
Am 2023-07-13 21:54, schrieb Friedrich Krone:
> Hallo,
> I am member of the Wennigsen (Deister) volunteer fire brigade and work
> on forest fire maps on a voluntary basis. A few years ago, the Lower
> Saxony Ministry of the Interior (MI) procured the Mapbender program
> for the digital forest fire operation map of Lower Saxony (WBEK).
> However, this program requires an Internet connection, which is not
> available in many emergency vehicles and cannot be received at some
> points in the forest. Allegedly it's not technically possible to use
> this app offline because it has to access the database.
> Question: How can I use Mapbender offline and still integrate the
> database?
Mapbender is a web application so Internet is needed. Alternatively you
could provide a mobile device (Tablet) and install everything on the
decive.
For Offline solutions that can be installed as apps on mobile devices
you could use software like
qField https://qfield.org/
merginMaps https://merginmaps.com
> Another problem is the GPS point, which is not centered but drifts off
> the map when the vehicle moves. This is particularly important when
> working in the forest, in order to be able to read one's location at
> any time.
> Question: How to center the GPS point on the map so you can read your
> location at any time?
GPS Element offers the option follow. Then the position should always be
visible on the map.
https://doc.mapbender.org/de/functions/misc/gpsposition.html
> Editing is very cumbersome. Each path segment or symbol must be
> selected individually for editing.
> Question: Is there a way to combine path segments or symbols for
> deletion in order to be able to remove them in groups?
This is not possible in digitizer at the moment. It would be a
functionality that would be useful. If we have financial support for
this feature it could be implemented.
Hope that helps.
Thanks for your work in the Freiwillige Feuerwehr
Astrid Emde
> I would be very grateful for a brief answer to my questions.
> Best regards
> Friedrich Krone
> Feuerwehr Wennigsen (Deister)
> Linderter Str. 16
> 30974 Wennigsen-Holtensen
> Frkrone at gmx.de
> 0175-8245747
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
Aufwind durch Wissen!
Web-Seminare und Online-Schulungen
bei der www.foss-academy.com/
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230714/3cfae3ee/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20230714/3cfae3ee/attachment.sig>
More information about the Mapbender_users mailing list
