[Mapbender-users] Can't add a new source or update an existing source
Joel Blizzard jrpblizz at gmail.com
Tue Mar 5 08:43:30 PST 2024
That seems to have resolved the issue.
Although after the upgrade, I cannot seem to disable the demo applications
from the applications list (prior to logging in). I have changed visibility
to false in the yml files, cleared prod cache, and then even deleted the
.yml files from /app/config/applications, and still they show up. Is there
a different way to disable these now? I don't want them showing up in the
list of applications.
Thanks,
-Joel
On Wed, Feb 28, 2024 at 7:54 AM Astrid Emde (WhereGroup) <
astrid.emde at wheregroup.com> wrote:
> Hallo,
> es gab mal einen Bug in der Richtung
> https://github.com/mapbender/mapbender/issues/1441
> Am Besten du aktualisierst auf die Version 3.3.5
> https://doc.mapbender.org/de/installation/installation_update.html
> Viele Grüße
> Astrid Emde
> Am 2024-02-28 14:45, schrieb Joel Blizzard:
> > I am running 3.3.3. Is this some kind of bug related to this version?
> > On Wed, Feb 28, 2024 at 2:13 AM Astrid Emde (WhereGroup)
> > <astrid.emde at wheregroup.com> wrote:
> >> Hello Joel,
> >> which version of Mapbender do you use?
> >> The error should not occur with Mapbender 3.3.5.
> >> See you Astrid
> >> Am 2024-02-27 23:21, schrieb Joel Blizzard via Mapbender_users:
> >>> Hello,
> >>> When I go into the sources section of Mapbender and try to add a
> >> new
> >>> source I get the message:
> >>> Unrecognized boolean literal "
> >>> When I go into dev mode to look at the messages after I get this
> >>> error, it says there are 4 missing messages
> >>> (These messages are not available for the given locale and cannot
> >> be
> >>> found in the fallback locales. Add them to the translation
> >> catalogue
> >>> to avoid Symfony outputting untranslated contents. )
> >>> en
> >>> messages
> >>> 1
> >>> Unrecognized boolean literal ''
> >>> en
> >>> messages
> >>> 3
> >>> OGC WMS
> >>> OGC WMS
> >>> en
> >>> messages
> >>> 2
> >>> OGC WMTS / TMS
> >>> OGC WMTS / TMS
> >>> en
> >>> messages
> >>> 1
> >>> The GetCapabilities url
> >>> Does anyone know what might be happening here? Maybe there is a
> >> more
> >>> comprehensive way I could be using Dev mode?
> >>> _______________________________________________
> >>> Mapbender_users mailing list
> >>> Mapbender_users at lists.osgeo.org
> >>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> >> Mit freundlichen Grüßen
> >> Astrid Emde
> >> GIS-Consultant
> >> FOSSGIS Konferenz
> >> 20.-23. März 2024 in Hamburg
> >> https://www.fossgis-konferenz.de/2024/
> >> WhereGroup-Beiträge auf der FOSSGIS
> >> https://wheregroup.com/unternehmen/aktuelles/
> >> Astrid Emde
> >> WhereGroup GmbH
> >> Eifelstraße 7
> >> 53119 Bonn
> >> Germany
> >> Tel: +49(0)228 90 90 38 - 22
> >> Fax: +49(0)228 90 90 38 - 11
> >> www.wheregroup.com [1]
> >> Meinen PGP Public-Key können Sie unter pgp.mit.edu [2]
> >> herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> >> Signierte und/oder verschlüsselte Nachrichten sind sehr
> >> willkommen
> >> Folgen Sie der WhereGroup auf twitter:
> >> http://twitter.com/WhereGroup_com
> >> Geschäftsführer:
> >> Olaf Knopp, Peter Stamm
> >> Amtsgericht Bonn, HRB 9885
> > Links:
> > [1] http://www.wheregroup.com
> > [2] http://pgp.mit.edu
> Astrid Emde
> GIS-Consultant
> FOSSGIS Konferenz
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    www.wheregroup.com
>    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>    Geschäftsführer:
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240305/e23f94d5/attachment.htm>
More information about the Mapbender_users mailing list
