[Mapbender-users] Can't add a new source or update an existing source
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Tue Mar 5 09:25:20 PST 2024
Hello,
you could remove the files from the applications folder.
Maybe keep the files somewhere so if you need them you can restore them.
In the yml files you find  published: true (see row 7). Here you could
change the setting to false.
See you Astrid
Am 2024-03-05 17:43, schrieb Joel Blizzard:
> That seems to have resolved the issue.
> Although after the upgrade, I cannot seem to disable the demo
> applications from the applications list (prior to logging in). I have
> changed visibility to false in the yml files, cleared prod cache, and
> then even deleted the .yml files from /app/config/applications, and
> still they show up. Is there a different way to disable these now? I
> don't want them showing up in the list of applications.
> Thanks,
> -Joel
> On Wed, Feb 28, 2024 at 7:54 AM Astrid Emde (WhereGroup)
> <astrid.emde at wheregroup.com> wrote:
>> Hallo,
>> es gab mal einen Bug in der Richtung
>> https://github.com/mapbender/mapbender/issues/1441
>> Am Besten du aktualisierst auf die Version 3.3.5
>> https://doc.mapbender.org/de/installation/installation_update.html
>> Viele Grüße
>> Astrid Emde
>> Am 2024-02-28 14:45, schrieb Joel Blizzard:
>>> I am running 3.3.3. Is this some kind of bug related to this
>> version?
>>> On Wed, Feb 28, 2024 at 2:13 AM Astrid Emde (WhereGroup)
>>>> Hello Joel,
>>>> which version of Mapbender do you use?
>>>> The error should not occur with Mapbender 3.3.5.
>>>> See you Astrid
>>>> Am 2024-02-27 23:21, schrieb Joel Blizzard via Mapbender_users:
>>>>> Hello,
>>>>> When I go into the sources section of Mapbender and try to add a
>>>> new
>>>>> source I get the message:
>>>>> Unrecognized boolean literal "
>>>>> When I go into dev mode to look at the messages after I get this
>>>>> error, it says there are 4 missing messages
>>>>> (These messages are not available for the given locale and
>> cannot
>>>> be
>>>>> found in the fallback locales. Add them to the translation
>>>> catalogue
>>>>> to avoid Symfony outputting untranslated contents. )
>>>>> en
>>>>> messages
>>>>> 1
>>>>> Unrecognized boolean literal ''
>>>>> en
>>>>> messages
>>>>> 3
>>>>> OGC WMS
>>>>> OGC WMS
>>>>> en
>>>>> messages
>>>>> 2
>>>>> OGC WMTS / TMS
>>>>> OGC WMTS / TMS
>>>>> en
>>>>> messages
>>>>> 1
>>>>> The GetCapabilities url
>>>>> Does anyone know what might be happening here? Maybe there is a
>>>> more
>>>>> comprehensive way I could be using Dev mode?
>>>>> _______________________________________________
>>>>> Mapbender_users mailing list
>>>>> Mapbender_users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>>>> Mit freundlichen Grüßen
>>>> Astrid Emde
>>>> GIS-Consultant
>>>> FOSSGIS Konferenz
>>>> 20.-23. März 2024 in Hamburg
>>>> https://www.fossgis-konferenz.de/2024/
>>>> WhereGroup-Beiträge auf der FOSSGIS
>>>> https://wheregroup.com/unternehmen/aktuelles/
>>>> Astrid Emde
>>>> WhereGroup GmbH
>>>> Eifelstraße 7
>>>> 53119 Bonn
>>>> Germany
>>>> Tel: +49(0)228 90 90 38 - 22
>>>> Fax: +49(0)228 90 90 38 - 11
>>>> www.wheregroup.com [1] [1]
>>>> Meinen PGP Public-Key können Sie unter pgp.mit.edu [2] [2]
>>>> herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
>>>> Signierte und/oder verschlüsselte Nachrichten sind sehr
>>>> willkommen
>>>> Folgen Sie der WhereGroup auf twitter:
>>>> http://twitter.com/WhereGroup_com
>>>> Geschäftsführer:
>>>> Olaf Knopp, Peter Stamm
>>>> Amtsgericht Bonn, HRB 9885
>>> Links:
>>> [1] http://www.wheregroup.com
>>> [2] http://pgp.mit.edu
>> Astrid Emde
>> GIS-Consultant
>> FOSSGIS Konferenz
>> Astrid Emde
>> WhereGroup GmbH
>> Eifelstraße 7
>> 53119 Bonn
>> Germany
>> herunterladen:
>> willkommen
>> Geschäftsführer:
> Links:
Astrid Emde
GIS-Consultant
FOSSGIS Konferenz
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Geschäftsführer:
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240305/209b70aa/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240305/209b70aa/attachment.sig>
More information about the Mapbender_users mailing list
