[Mapbender-users] Can't add a new source or update an existing source
Joel Blizzard jrpblizz at gmail.com
Tue Mar 5 10:56:02 PST 2024
I've done both of those things, my application folder is empty, but still
they show up? Is there a different place these could be pulled from?
They don't appear once I am logged into Mapbender, but on the Applications
page which is displayed before logging in I see them. Is that normal? No
way to remove them from that initial page?
On Tue, Mar 5, 2024 at 11:25 AM Astrid Emde (WhereGroup) via
Mapbender_users <mapbender_users at lists.osgeo.org> wrote:
> Hello,
> you could remove the files from the applications folder.
> Maybe keep the files somewhere so if you need them you can restore them.
> In the yml files you find  published: true (see row 7). Here you could
> change the setting to false.
> See you Astrid
> Am 2024-03-05 17:43, schrieb Joel Blizzard:
> > That seems to have resolved the issue.
> > Although after the upgrade, I cannot seem to disable the demo
> > applications from the applications list (prior to logging in). I have
> > changed visibility to false in the yml files, cleared prod cache, and
> > then even deleted the .yml files from /app/config/applications, and
> > still they show up. Is there a different way to disable these now? I
> > don't want them showing up in the list of applications.
> > Thanks,
> > -Joel
> > On Wed, Feb 28, 2024 at 7:54 AM Astrid Emde (WhereGroup)
> > <astrid.emde at wheregroup.com> wrote:
> >> Hallo,
> >> es gab mal einen Bug in der Richtung
> >> https://github.com/mapbender/mapbender/issues/1441
> >> Am Besten du aktualisierst auf die Version 3.3.5
> >> https://doc.mapbender.org/de/installation/installation_update.html
> >> Viele Grüße
> >> Astrid Emde
> >> Am 2024-02-28 14:45, schrieb Joel Blizzard:
> >>> I am running 3.3.3. Is this some kind of bug related to this
> >> version?
> >>> On Wed, Feb 28, 2024 at 2:13 AM Astrid Emde (WhereGroup)
> >>>> Hello Joel,
> >>>> which version of Mapbender do you use?
> >>>> The error should not occur with Mapbender 3.3.5.
> >>>> See you Astrid
> >>>> Am 2024-02-27 23:21, schrieb Joel Blizzard via Mapbender_users:
> >>>>> Hello,
> >>>>> When I go into the sources section of Mapbender and try to add a
> >>>> new
> >>>>> source I get the message:
> >>>>> Unrecognized boolean literal "
> >>>>> When I go into dev mode to look at the messages after I get this
> >>>>> error, it says there are 4 missing messages
> >>>>> (These messages are not available for the given locale and
> >> cannot
> >>>> be
> >>>>> found in the fallback locales. Add them to the translation
> >>>> catalogue
> >>>>> to avoid Symfony outputting untranslated contents. )
> >>>>> en
> >>>>> messages
> >>>>> 1
> >>>>> Unrecognized boolean literal ''
> >>>>> en
> >>>>> messages
> >>>>> 3
> >>>>> OGC WMS
> >>>>> OGC WMS
> >>>>> en
> >>>>> messages
> >>>>> 2
> >>>>> OGC WMTS / TMS
> >>>>> OGC WMTS / TMS
> >>>>> en
> >>>>> messages
> >>>>> 1
> >>>>> The GetCapabilities url
> >>>>> Does anyone know what might be happening here? Maybe there is a
> >>>> more
> >>>>> comprehensive way I could be using Dev mode?
> >>>>> _______________________________________________
> >>>>> Mapbender_users mailing list
> >>>>> Mapbender_users at lists.osgeo.org
> >>>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> >>>> Mit freundlichen Grüßen
> >>>> Astrid Emde
> >>>> GIS-Consultant
> >>>> FOSSGIS Konferenz
> >>>> 20.-23. März 2024 in Hamburg
> >>>> https://www.fossgis-konferenz.de/2024/
> >>>> WhereGroup-Beiträge auf der FOSSGIS
> >>>> https://wheregroup.com/unternehmen/aktuelles/
> >>>> Astrid Emde
> >>>> WhereGroup GmbH
> >>>> Eifelstraße 7
> >>>> 53119 Bonn
> >>>> Germany
> >>>> Tel: +49(0)228 90 90 38 - 22
> >>>> Fax: +49(0)228 90 90 38 - 11
> >>>> www.wheregroup.com [1] [1]
> >>>> Meinen PGP Public-Key können Sie unter pgp.mit.edu [2] [2]
> >>>> herunterladen:
> https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
> >>>> Signierte und/oder verschlüsselte Nachrichten sind sehr
> >>>> willkommen
> >>>> Folgen Sie der WhereGroup auf twitter:
> >>>> http://twitter.com/WhereGroup_com
> >>>> Geschäftsführer:
> >>>> Olaf Knopp, Peter Stamm
> >>>> Amtsgericht Bonn, HRB 9885
> >>> Links:
> >>> [1] http://www.wheregroup.com
> >>> [2] http://pgp.mit.edu
> >> Astrid Emde
> >> GIS-Consultant
> >> FOSSGIS Konferenz
> >> Astrid Emde
> >> WhereGroup GmbH
> >> Eifelstraße 7
> >> 53119 Bonn
> >> Germany
> >> herunterladen:
> >> willkommen
> >> Geschäftsführer:
> > Links:
> Astrid Emde
> GIS-Consultant
> FOSSGIS Konferenz
>    Astrid Emde
>    WhereGroup GmbH
>    Eifelstraße 7
>    53119 Bonn
>    Germany
>    www.wheregroup.com
>    Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
>    Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
>    Geschäftsführer:
> -------------------------------_______________________________________________
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240305/d0788708/attachment-0001.htm>
More information about the Mapbender_users mailing list
