[Mapbender-users] How can install Mapbender to a standard cPanel account - withouth root access
Härtel, Connor Connor.Haertel at itebo.de
Thu Mar 14 03:49:39 PDT 2024
Hi Denes,
which instructions are you referring to?
First off, I am not familiar with cPanel.
If, however, the general problem is missing access to the command line you could try and build a docker image with Mapbender, in which all required installation instructions are taken care of. You could base your image off of a php-apache image (php 7.4, unsure about 8.x support for Mapbender) from https://hub.docker.com/_/php, which already has a webserver built in.
Docker would have to be installed on your system, also it generally requires root permissions, so I am not sure if this would be feasible in your case.
Regarding the terminal/root access, you would have to resolve that with whoever administrates the system.
Sincerely,
Connor Härtel
Von: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Im Auftrag von Székely Dénes via Mapbender_users
Gesendet: Donnerstag, 14. März 2024 08:38
An: mapbender_users at lists.osgeo.org
Cc: Székely Dénes <denes at webgobe.ro>
Betreff: [Mapbender-users] How can install Mapbender to a standard cPanel account - withouth root access
I need to install MapBender for someone who purchased a cPanel account
withouth root/command line acces, but otherwhise have all the other
requirements (postgres database, PHP correctly configured with needed
libraries, etc)
The installation instructions I found all require command line/root
access which is impossible to obtain with his account. Any help would be
greatly appreciated.
Denes Szekely
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/d776b2b5/attachment.htm>
More information about the Mapbender_users mailing list
