[Mapbender-users] How can install Mapbender to a standard cPanel account - withouth root access
Székely Dénes denes at webgobe.ro
Thu Mar 14 04:44:55 PDT 2024
Thanks, Connor, but this is not helping me. The server in case is a
shared hosting environment, and the sysadmin does not grant me extra
privileges and turned me down to offer support above what they usually
give to their customers.
What I have access to is this:
I can access the WEBROOT directory where the clients domain is pointed,
I can put there anything I want, I can create and configure the
database, add a database user and tweak his privileges, I can tweak the
PHP environment (PHP version, config items) and basically here's the end
of story.
Basically can't touch the webserver otherwhise than what is allowed to
me to do by .htaccess commands
cPanel is basically a shell to assist the clients to manage their
allocated webserver space, withouth access to command line and obviously
withouth root level privileges. It is the de facto standard in shared
web hosting.
So, basically I am wondering, if it is even possible to install
mapbender by using these.
Right now from web you can see this:
http://satelitnt.ro/
The mapbender package is there, here should go the final, working
MapBendet installation.
Dénes
2024. 03. 14. 12:49 keltezéssel, Härtel, Connor via Mapbender_users írta:
> Hi Denes,
> which instructions are you referring to?
> First off, I am not familiar with cPanel.
> If, however, the general problem is missing access to the command line
> you could try and build a docker image with Mapbender, in which all
> required installation instructions are taken care of. You could base
> your image off of a php-apache image (php 7.4, unsure about 8.x
> support for Mapbender) from https://hub.docker.com/_/php, which
> already has a webserver built in.
> Docker would have to be installed on your system, also it generally
> requires root permissions, so I am not sure if this would be feasible
> in your case.
> Regarding the terminal/root access, you would have to resolve that
> with whoever administrates the system.
> Sincerely,
> Connor Härtel
> *Von:* Mapbender_users <mapbender_users-bounces at lists.osgeo.org> *Im
> Auftrag von *Székely Dénes via Mapbender_users
> *Gesendet:* Donnerstag, 14. März 2024 08:38
> *An:* mapbender_users at lists.osgeo.org
> *Cc:* Székely Dénes <denes at webgobe.ro>
> *Betreff:* [Mapbender-users] How can install Mapbender to a standard
> I need to install MapBender for someone who purchased a cPanel account
> withouth root/command line acces, but otherwhise have all the other
> requirements (postgres database, PHP correctly configured with needed
> libraries, etc)
> The installation instructions I found all require command line/root
> access which is impossible to obtain with his account. Any help would be
> greatly appreciated.
> Denes Szekely
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapbender_users
For your hosting needs we recommend LiquidWeb
<https://liquidweb.grsm.io/ntjsdmamefzt> with their legendary Heroic
Support.
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/2ef1d2b3/attachment-0001.htm>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/2ef1d2b3/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/2ef1d2b3/attachment-0001.sig>
More information about the Mapbender_users mailing list
