[Mapbender-users] How can install Mapbender to a standard cPanel account - withouth root access
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Thu Mar 14 05:15:10 PDT 2024
Hello Dénes,
I guess you wil need the cPanel Terminal at some point.
Or you need a service provider who confighures some of the settings for
you.
https://docs.cpanel.net/cpanel/advanced/terminal-in-cpanel/
The tar.gz donwload package already contains symbolic links to the
web-directory. But you have to create the Alias for Apache and set the
ownership for the files.
If that is not a problem you could prepare the postgreSQL  database
localy and restore it on the server.
https://mapbender.org/builds/3.3.5/
Astrid
Am 2024-03-14 12:44, schrieb Székely Dénes via Mapbender_users:
> Thanks, Connor, but this is not helping me. The server in case is a
> shared hosting environment, and the sysadmin does not grant me extra
> privileges and turned me down to offer support above what they usually
> give to their customers.
> What I have access to is this:
> I can access the WEBROOT directory where the clients domain is
> pointed, I can put there anything I want, I can create and configure
> the database, add a database user and tweak his privileges, I can
> tweak the PHP environment (PHP version, config items) and basically
> here's the end of story.
> Basically can't touch the webserver otherwhise than what is allowed to
> me to do by .htaccess commands
> cPanel is basically a shell to assist the clients to manage their
> allocated webserver space, withouth access to command line and
> obviously withouth root level privileges. It is the de facto standard
> in shared web hosting.
> So, basically I am wondering, if it is even possible to install
> mapbender by using these.
> Right now from web you can see this:
> http://satelitnt.ro/
> The mapbender package is there, here should go the final, working
> MapBendet installation.
> Dénes
> 2024. 03. 14. 12:49 keltezéssel, Härtel, Connor via Mapbender_users
> írta:
>> Hi Denes,
>> which instructions are you referring to?
>> First off, I am not familiar with cPanel.
>> If, however, the general problem is missing access to the command
>> line you could try and build a docker image with Mapbender, in which
>> all required installation instructions are taken care of. You could
>> base your image off of a php-apache image (php 7.4, unsure about 8.x
>> support for Mapbender) from https://hub.docker.com/_/php, which
>> already has a webserver built in.
>> Docker would have to be installed on your system, also it generally
>> requires root permissions, so I am not sure if this would be
>> feasible in your case.
>> Regarding the terminal/root access, you would have to resolve that
>> with whoever administrates the system.
>> Sincerely,
>> Connor Härtel
>> Von: Mapbender_users <mapbender_users-bounces at lists.osgeo.org> Im
>> Auftrag von Székely Dénes via Mapbender_users
>> Gesendet: Donnerstag, 14. März 2024 08:38
>> An: mapbender_users at lists.osgeo.org
>> Cc: Székely Dénes <denes at webgobe.ro>
>> Betreff: [Mapbender-users] How can install Mapbender to a standard
>> I need to install MapBender for someone who purchased a cPanel
>> account
>> withouth root/command line acces, but otherwhise have all the other
>> requirements (postgres database, PHP correctly configured with
>> needed
>> libraries, etc)
>> The installation instructions I found all require command line/root
>> access which is impossible to obtain with his account. Any help
>> would be
>> greatly appreciated.
>> Denes Szekely
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> For your hosting needs we recommend LiquidWeb [1] with their legendary
> Heroic Support.
> Links:
> [1] https://liquidweb.grsm.io/ntjsdmamefzt
Mit freundlichen Grüßen
Astrid Emde
GIS-Consultant
FOSSGIS Konferenz
20.-23. März 2024 in Hamburg
https://www.fossgis-konferenz.de/2024/
WhereGroup-Beiträge auf der FOSSGIS
https://wheregroup.com/unternehmen/aktuelles/
   Astrid Emde
   WhereGroup GmbH
   Eifelstraße 7
   53119 Bonn
   Germany
   Tel: +49(0)228 90 90 38 - 22
   Fax: +49(0)228 90 90 38 - 11
   www.wheregroup.com
   Meinen PGP Public-Key können Sie unter pgp.mit.edu herunterladen:
https://keys.openpgp.org/vks/v1/by-fingerprint/01F8152D36FC07C25EADDE86C5084ACC1C287CCB
   Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
   Folgen Sie der WhereGroup auf twitter:
   http://twitter.com/WhereGroup_com
   Geschäftsführer:
   Olaf Knopp, Peter Stamm
   Amtsgericht Bonn, HRB 9885
Type: application/pgp-keys
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/eb5a32d1/attachment.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/eb5a32d1/attachment.sig>
More information about the Mapbender_users mailing list
