[Mapbender-users] How can install Mapbender to a standard cPanel account - withouth root access
Thorsten Hildebrand (WhereGroup) thorsten.hildebrand at wheregroup.com
Thu Mar 14 05:34:15 PDT 2024
Hi Dénes,
your Mapbender installation is already working:
http://satelitnt.ro/mapbender/web/app.php
http://satelitnt.ro/mapbender/web/app.php/application/mapbender_user
However, you must ensure that the configuration files and code are not
publicly accessible.
Best regards,
Thorsten
Am 14.03.2024 um 12:44 schrieb Székely Dénes via Mapbender_users:
> Thanks, Connor, but this is not helping me. The server in case is a
> shared hosting environment, and the sysadmin does not grant me extra
> privileges and turned me down to offer support above what they usually
> give to their customers.
> What I have access to is this:
> I can access the WEBROOT directory where the clients domain is pointed,
> I can put there anything I want, I can create and configure the
> database, add a database user and tweak his privileges, I can tweak the
> PHP environment (PHP version, config items) and basically here's the end
> of story.
> Basically can't touch the webserver otherwhise than what is allowed to
> me to do by .htaccess commands
> cPanel is basically a shell to assist the clients to manage their
> allocated webserver space, withouth access to command line and obviously
> withouth root level privileges. It is the de facto standard in shared
> web hosting.
> So, basically I am wondering, if it is even possible to install
> mapbender by using these.
> Right now from web you can see this:
> The mapbender package is there, here should go the final, working
> MapBendet installation.
> Dénes
> 2024. 03. 14. 12:49 keltezéssel, Härtel, Connor via Mapbender_users írta:
>> Hi Denes,
>> which instructions are you referring to?
>> First off, I am not familiar with cPanel.
>> If, however, the general problem is missing access to the command line
>> you could try and build a docker image with Mapbender, in which all
>> required installation instructions are taken care of. You could base
>> your image off of a php-apache image (php 7.4, unsure about 8.x
>> support for Mapbender) from https://hub.docker.com/_/php, which
>> already has a webserver built in.
>> Docker would have to be installed on your system, also it generally
>> requires root permissions, so I am not sure if this would be feasible
>> in your case.
>> Regarding the terminal/root access, you would have to resolve that
>> with whoever administrates the system.
>> Sincerely,
>> Connor Härtel
>> *Von:* Mapbender_users <mapbender_users-bounces at lists.osgeo.org> *Im
>> Auftrag von *Székely Dénes via Mapbender_users
>> *Gesendet:* Donnerstag, 14. März 2024 08:38
>> *An:* mapbender_users at lists.osgeo.org
>> *Cc:* Székely Dénes <denes at webgobe.ro>
>> *Betreff:* [Mapbender-users] How can install Mapbender to a standard
>> I need to install MapBender for someone who purchased a cPanel account
>> withouth root/command line acces, but otherwhise have all the other
>> requirements (postgres database, PHP correctly configured with needed
>> libraries, etc)
>> The installation instructions I found all require command line/root
>> access which is impossible to obtain with his account. Any help would be
>> greatly appreciated.
>> Denes Szekely
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
> For your hosting needs we recommend LiquidWeb
> <https://liquidweb.grsm.io/ntjsdmamefzt> with their legendary Heroic
> Support.
More information about the Mapbender_users mailing list
