[Mapbender-users] How can install Mapbender to a standard cPanel account - withouth root access
Székely Dénes denes at webgobe.ro
Thu Mar 14 08:53:21 PDT 2024
Passwords changed ;) Well, I did not done anything, but unpacked the
downloaded package!
No database configuration, nothing else. Thanks, anyway!
Will get back to you with any questions I might have *probably will have
Denes
2024. 03. 14. 14:34 keltezéssel, Thorsten Hildebrand (WhereGroup) írta:
> Hi Dénes,
> your Mapbender installation is already working:
> http://satelitnt.ro/mapbender/web/app.php
> http://satelitnt.ro/mapbender/web/app.php/application/mapbender_user
> However, you must ensure that the configuration files and code are not
> publicly accessible.
> Best regards,
> Thorsten
> Am 14.03.2024 um 12:44 schrieb Székely Dénes via Mapbender_users:
>> Thanks, Connor, but this is not helping me. The server in case is a
>> shared hosting environment, and the sysadmin does not grant me extra
>> privileges and turned me down to offer support above what they
>> usually give to their customers.
>> What I have access to is this:
>> I can access the WEBROOT directory where the clients domain is
>> pointed, I can put there anything I want, I can create and configure
>> the database, add a database user and tweak his privileges, I can
>> tweak the PHP environment (PHP version, config items) and basically
>> here's the end of story.
>> Basically can't touch the webserver otherwhise than what is allowed
>> to me to do by .htaccess commands
>> cPanel is basically a shell to assist the clients to manage their
>> allocated webserver space, withouth access to command line and
>> obviously withouth root level privileges. It is the de facto standard
>> in shared web hosting.
>> So, basically I am wondering, if it is even possible to install
>> mapbender by using these.
>> Right now from web you can see this:
>> The mapbender package is there, here should go the final, working
>> MapBendet installation.
>> Dénes
>> 2024. 03. 14. 12:49 keltezéssel, Härtel, Connor via Mapbender_users
>> írta:
>>> Hi Denes,
>>> which instructions are you referring to?
>>> First off, I am not familiar with cPanel.
>>> If, however, the general problem is missing access to the command
>>> line you could try and build a docker image with Mapbender, in which
>>> all required installation instructions are taken care of. You could
>>> base your image off of a php-apache image (php 7.4, unsure about 8.x
>>> support for Mapbender) from https://hub.docker.com/_/php, which
>>> already has a webserver built in.
>>> Docker would have to be installed on your system, also it generally
>>> requires root permissions, so I am not sure if this would be
>>> feasible in your case.
>>> Regarding the terminal/root access, you would have to resolve that
>>> with whoever administrates the system.
>>> Sincerely,
>>> Connor Härtel
>>> *Von:* Mapbender_users <mapbender_users-bounces at lists.osgeo.org> *Im
>>> Auftrag von *Székely Dénes via Mapbender_users
>>> *Gesendet:* Donnerstag, 14. März 2024 08:38
>>> *An:* mapbender_users at lists.osgeo.org
>>> *Cc:* Székely Dénes <denes at webgobe.ro>
>>> *Betreff:* [Mapbender-users] How can install Mapbender to a standard
>>> I need to install MapBender for someone who purchased a cPanel account
>>> withouth root/command line acces, but otherwhise have all the other
>>> requirements (postgres database, PHP correctly configured with needed
>>> libraries, etc)
>>> The installation instructions I found all require command line/root
>>> access which is impossible to obtain with his account. Any help
>>> would be
>>> greatly appreciated.
>>> Denes Szekely
>>> Mapbender_users mailing list
>>> Mapbender_users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapbender_users
>> For your hosting needs we recommend LiquidWeb
>> <https://liquidweb.grsm.io/ntjsdmamefzt> with their legendary Heroic
>> Support.
Support.
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/a863c745/attachment-0001.htm>
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/a863c745/attachment-0001.key>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapbender_users/attachments/20240314/a863c745/attachment-0001.sig>
More information about the Mapbender_users mailing list
