[mapguide-commits] r1328 - trunk/MgDev/Oem/gdal-1.4.0
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 21 17:28:21 EDT 2007
Author: stevedang
Date: 2007-03-21 17:28:21 -0400 (Wed, 21 Mar 2007)
New Revision: 1328
Added:
   trunk/MgDev/Oem/gdal-1.4.0/configure
   trunk/MgDev/Oem/gdal-1.4.0/install-sh
Change exec bit.
Added: trunk/MgDev/Oem/gdal-1.4.0/configure
--- trunk/MgDev/Oem/gdal-1.4.0/configure	                        (rev 0)
+++ trunk/MgDev/Oem/gdal-1.4.0/configure	2007-03-21 21:28:21 UTC (rev 1328)
@@ -0,0 +1,29672 @@
+#! /bin/sh
+# Guess values for system-dependent variables and create Makefiles.
+# Generated by GNU Autoconf 2.59.
+# Copyright (C) 2003 Free Software Foundation, Inc.
+# This configure script is free software; the Free Software Foundation
+# gives unlimited permission to copy, distribute and modify it.
+## M4sh Initialization.  ##
+# Be Bourne compatible
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+  emulate sh
+  NULLCMD=:
+  # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '${1+"$@"}'='"$@"'
+elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
+  set -o posix
+fi
+DUALCASE=1; export DUALCASE # for MKS sh
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+  as_unset=unset
+else
+  as_unset=false
+fi
+# Work around bugs in pre-3.0 UWIN ksh.
+$as_unset ENV MAIL MAILPATH
+PS1='$ '
+PS2='> '
+PS4='+ '
+# NLS nuisances.
+for as_var in \
+  LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
+  LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
+  LC_TELEPHONE LC_TIME
+do
+  if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
+    eval $as_var=C; export $as_var
+  else
+    $as_unset $as_var
+  fi
+done
+# Required to use basename.
+if expr a : '\(a\)' >/dev/null 2>&1; then
+  as_expr=expr
+else
+  as_expr=false
+fi
+if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
+  as_basename=basename
+else
+  as_basename=false
+fi
+# Name of the executable.
+as_me=`$as_basename "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+	 X"$0" : 'X\(//\)$' \| \
+	 X"$0" : 'X\(/\)$' \| \
+	 .     : '\(.\)' 2>/dev/null ||
+echo X/"$0" |
+    sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
+  	  /^X\/\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\/\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+# PATH needs CR, and LINENO needs CR and PATH.
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
+# The user is always right.
+if test "${PATH_SEPARATOR+set}" != set; then
+  echo "#! /bin/sh" >conf$$.sh
+  echo  "exit 0"   >>conf$$.sh
+  chmod +x conf$$.sh
+  if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
+    PATH_SEPARATOR=';'
+  else
+    PATH_SEPARATOR=:
+  fi
+  rm -f conf$$.sh
+fi
+  as_lineno_1=$LINENO
+  as_lineno_2=$LINENO
+  as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
+  test "x$as_lineno_1" != "x$as_lineno_2" &&
+  test "x$as_lineno_3"  = "x$as_lineno_2"  || {
+  # Find who we are.  Look in the path if we contain no path at all
+  # relative or not.
+  case $0 in
+    *[\\/]* ) as_myself=$0 ;;
+    *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
+  esac
+  # We did not find ourselves, most probably we were run as `sh COMMAND'
+  # in which case we are not to be found in the path.
+  if test "x$as_myself" = x; then
+    as_myself=$0
+  fi
+  if test ! -f "$as_myself"; then
+    { echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2
+   { (exit 1); exit 1; }; }
+  fi
+  case $CONFIG_SHELL in
+    as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
+do
+  IFS=$as_save_IFS
+  for as_base in sh bash ksh sh5; do
+	 case $as_dir in
+	   if ("$as_dir/$as_base" -c '
+  test "x$as_lineno_3"  = "x$as_lineno_2" ') 2>/dev/null; then
+	     $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
+	     $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
+	     CONFIG_SHELL=$as_dir/$as_base
+	     export CONFIG_SHELL
+	     exec "$CONFIG_SHELL" "$0" ${1+"$@"}
+	   fi;;
+	 esac
+       done
+done
+  esac
+  # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+  # uniformly replaced by the line number.  The first 'sed' inserts a
+  # line-number line before each line; the second 'sed' does the real
+  # work.  The second script uses 'N' to pair each line-number line
+  # with the numbered line, and appends trailing '-' during
+  # substitution so that $LINENO is not a special case at line end.
+  # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+  # second 'sed' script.  Blame Lee E. McMahon for sed's syntax.  :-)
+  sed '=' <$as_myself |
+    sed '
+      N
+      s,$,-,
+      : loop
+      s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
+      t loop
+      s,-$,,
+      s,^['$as_cr_digits']*\n,,
+    ' >$as_me.lineno &&
+  chmod +x $as_me.lineno ||
+    { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+  # Don't try to exec as it changes $[0], causing all sort of problems
+  # (the dirname of $[0] is not the place where we might find the
+  # original and so on.  Autoconf is especially sensible to this).
+  . ./$as_me.lineno
+  # Exit status is that of the last command.
+  exit
+case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
+  *c*,-n*) ECHO_N= ECHO_C='
+' ECHO_T='	' ;;
+  *c*,*  ) ECHO_N=-n ECHO_C= ECHO_T= ;;
+  *)       ECHO_N= ECHO_C='\c' ECHO_T= ;;
+esac
+  as_expr=expr
+else
+  as_expr=false
+fi
+rm -f conf$$ conf$$.exe conf$$.file
+echo >conf$$.file
+if ln -s conf$$.file conf$$ 2>/dev/null; then
+  # We could just check for DJGPP; but this test a) works b) is more generic
+  # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
+  if test -f conf$$.exe; then
+    # Don't use ln at all; we don't have any links
+    as_ln_s='cp -p'
+  else
+    as_ln_s='ln -s'
+  fi
+elif ln conf$$.file conf$$ 2>/dev/null; then
+  as_ln_s=ln
+else
+  as_ln_s='cp -p'
+fi
+if mkdir -p . 2>/dev/null; then
+  as_mkdir_p=:
+else
+  test -d ./-p && rmdir ./-p
+  as_mkdir_p=false
+fi
+as_executable_p="test -f"
+# Sed expression to map a string onto a valid CPP name.
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
+# Sed expression to map a string onto a valid variable name.
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
+# IFS
+# We need space, tab and new line, in precisely that order.
+as_nl='
+IFS=" 	$as_nl"
+# CDPATH.
+$as_unset CDPATH
+# Check that we are running under the correct shell.
+SHELL=${CONFIG_SHELL-/bin/sh}
+case X$ECHO in
+X*--fallback-echo)
+  # Remove one level of quotation (which was required for Make).
+  ECHO=`echo "$ECHO" | sed 's,\\\\\$\\$0,'$0','`
+esac
+echo=${ECHO-echo}
+if test "X$1" = X--no-reexec; then
+  # Discard the --no-reexec flag, and continue.
+  shift
+elif test "X$1" = X--fallback-echo; then
+  # Avoid inline document here, it may be left over
+elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
+  # Yippee, $echo works!
+else
+  # Restart under the correct shell.
+  exec $SHELL "$0" --no-reexec ${1+"$@"}
+fi
+if test "X$1" = X--fallback-echo; then
+  # used as fallback echo
+  shift
+  cat <<EOF
+EOF
+  exit 0
+fi
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+if test -z "$ECHO"; then
+if test "X${echo_test_string+set}" != Xset; then
+# find a string as large as possible, as long as the shell can cope with it
+  for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
+    # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
+    if (echo_test_string=`eval $cmd`) 2>/dev/null &&
+       echo_test_string=`eval $cmd` &&
+       (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
+    then
+      break
+    fi
+  done
+fi
+if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
+   echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
+   test "X$echo_testing_string" = "X$echo_test_string"; then
+else
+  # The Solaris, AIX, and Digital Unix default echo programs unquote
+  # backslashes.  This makes it impossible to quote backslashes using
+  #   echo "$something" | sed 's/\\/\\\\/g'
+  # So, first we look for a working echo in the user's PATH.
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for dir in $PATH /usr/ucb; do
+    IFS="$lt_save_ifs"
+    if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
+       test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
+       echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
+      echo="$dir/echo"
+      break
+    fi
+  done
+  if test "X$echo" = Xecho; then
+    # We didn't find a better echo, so look for alternatives.
+    if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
+       echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
+      # This shell has a builtin print -r that does the trick.
+      echo='print -r'
+    elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
+	 test "X$CONFIG_SHELL" != X/bin/ksh; then
+      # If we have ksh, try running configure again with it.
+      ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
+      export ORIGINAL_CONFIG_SHELL
+      CONFIG_SHELL=/bin/ksh
+      exec $CONFIG_SHELL "$0" --no-reexec ${1+"$@"}
+    else
+      # Try using printf.
+      echo='printf %s\n'
+      if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
+	# Cool, printf works
+      elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
+	   test "X$echo_testing_string" = 'X\t' &&
+	   echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
+	CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
+	SHELL="$CONFIG_SHELL"
+	export SHELL
+	echo="$CONFIG_SHELL $0 --fallback-echo"
+      elif echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
+	   echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
+      else
+	# maybe with a smaller string...
+	prev=:
+	for cmd in 'echo test' 'sed 2q "$0"' 'sed 10q "$0"' 'sed 20q "$0"' 'sed 50q "$0"'; do
+	  if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
+	  then
+	    break
+	  fi
+	  prev="$cmd"
+	done
+	if test "$prev" != 'sed 50q "$0"'; then
+	  echo_test_string=`eval $prev`
+	  export echo_test_string
+	  exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "$0" ${1+"$@"}
+	else
+	  # Oops.  We lost completely, so just stick with echo.
+	  echo=echo
+	fi
+      fi
+    fi
+  fi
+fi
+fi
+# Copy echo and quote the copy suitably for passing to libtool from
+# the Makefile, instead of quoting the original, which is used later.
+ECHO=$echo
+if test "X$ECHO" = "X$CONFIG_SHELL $0 --fallback-echo"; then
+   ECHO="$CONFIG_SHELL \\\$\$0 --fallback-echo"
+fi
+tagnames=${tagnames+${tagnames},}CXX
+tagnames=${tagnames+${tagnames},}F77
+# Name of the host.
+# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
+# so uname gets run too.
+ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
+exec 6>&1
+# Initializations.
+ac_default_prefix=/usr/local
+ac_config_libobj_dir=.
+cross_compiling=no
+subdirs=
+MFLAGS=
+MAKEFLAGS=
+# Maximum number of lines to put in a shell here document.
+# This variable seems obsolete.  It should probably be removed, and
+# only ac_max_sed_lines should be used.
+: ${ac_max_here_lines=38}
+# Identity of this package.
+PACKAGE_NAME=
+PACKAGE_TARNAME=
+PACKAGE_VERSION=
+PACKAGE_STRING=
+PACKAGE_BUGREPORT=
+ac_unique_file="GDALmake.opt.in"
+# Factoring default headers for most tests.
+ac_includes_default="\
+#include <stdio.h>
+#if HAVE_SYS_TYPES_H
+# include <sys/types.h>
+#endif
+#if HAVE_SYS_STAT_H
+# include <sys/stat.h>
+#endif
+#if STDC_HEADERS
+# include <stdlib.h>
+# include <stddef.h>
+#else
+# if HAVE_STDLIB_H
+# endif
+#endif
+#if HAVE_STRING_H
+# if !STDC_HEADERS && HAVE_MEMORY_H
+#  include <memory.h>
+# endif
+# include <string.h>
+#endif
+#if HAVE_STRINGS_H
+# include <strings.h>
+#endif
+#if HAVE_INTTYPES_H
+# include <inttypes.h>
+#else
+# if HAVE_STDINT_H
+#  include <stdint.h>
+# endif
+#endif
+#if HAVE_UNISTD_H
+# include <unistd.h>
+#endif"
+ac_subst_vars='PYTHON_CC PYTHON_OPT PYTHON_SO PYTHON_CFLAGS PYTHON_LIBS PYTHON_LINK SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS build build_cpu build_vendor build_os host host_cpu host_vendor host_os target target_cpu target_vendor target_os CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT CXX CXXFLAGS ac_ct_CXX EGREP LN_S ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB STRIP ac_ct_STRIP DLLTOOL ac_ct_DLLTOOL AS ac_ct_AS OBJDUMP ac_ct_OBJDUMP CPP CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL CXX_PIC C_PIC LD_SHARED SO_EXT HAVE_LIBTOOL LIBZ_SETTING PG_CONFIG HAVE_PG PG_INC PG_LIB GRASS_SETTING GRASS_INCLUDE GRASS_GISBASE HAVE_GRASS FITS_SETTING PCRASTER_SETTING NETCDF_SETTING PNG_SETTING TIFF_SETTING GEOTIFF_SETTING JPEG_SETTING GIF_SETTING HAVE_OGDI OGDI_INCLUDE X_FME_HOME HAVE_HDF4 HDF4_INCLUDE HAVE_HDF5 HDF5_INCLUDE HAVE_JASPER JASPER_FLAGS ECW_SETTING KAKDIR HAVE_MRSID MRSID_INCLUDE MRSID_FLAGS OPT_GDAL_FORMATS OGR_ENABLED MYSQL_CONFIG HAVE_MYSQL MYSQL_INC MYSQL_LIB HAVE_XERCES XERCES_INCLUDE ODBC_SETTING ORACLE_OCI_VERSION ORACLE_OCI_CFLAGS ORACLE_OCI_LDFLAGS HAVE_OCI OCI_INCLUDE DODS_INC LIBCURL_CONFIG CURL_SETTING CURL_INC CURL_LIB SQLITE_INC HAVE_SQLITE DWG_PLT DWGDIRECT HAVE_PANORAMA PANORAMA_INC HAVE_IDB IDB_INC IDB_LIB SDE_ENABLED SDE_INC SDE_LIB GEOS_LIBS GEOS_CFLAGS HAVE_GEOS GEOS_VERSION GEOS_CONFIG PROJ_STATIC PROJ_INCLUDE GDAL_VERSION_MAJOR GDAL_VERSION_MINOR GDAL_VERSION_REV GDAL_VER MACOSX_FRAMEWORK CXX_WFLAGS C_WFLAGS EXTRA_INCLUDES EXE_EXT BINTRUE BINDINGS PYTHON pythondir pyexecdir pymoddir PYTHON_INCLUDES PY_LD_SHARED PY_SO_EXT HAVE_NUMPY NUMPY_FLAG LIBOBJS LTLIBOBJS'
+ac_subst_files=''
+# Initialize some variables set by options.
+ac_init_help=
+ac_init_version=false
+# The variables have the same names as the options, with
+# dashes changed to underlines.
+cache_file=/dev/null
+exec_prefix=NONE
+no_create=
+no_recursion=
+prefix=NONE
+program_prefix=NONE
+program_suffix=NONE
+program_transform_name=s,x,x,
+silent=
+site=
+srcdir=
+verbose=
+x_includes=NONE
+x_libraries=NONE
+# Installation directory options.
+# These are left unexpanded so users can "make install exec_prefix=/foo"
+# and all the variables that are supposed to be based on exec_prefix
+# by default will actually change.
+# Use braces instead of parens because sh, perl, etc. also accept them.
+bindir='${exec_prefix}/bin'
+sbindir='${exec_prefix}/sbin'
+libexecdir='${exec_prefix}/libexec'
+datadir='${prefix}/share'
+sysconfdir='${prefix}/etc'
+sharedstatedir='${prefix}/com'
+localstatedir='${prefix}/var'
+libdir='${exec_prefix}/lib'
+includedir='${prefix}/include'
+oldincludedir='/usr/include'
+infodir='${prefix}/info'
+mandir='${prefix}/man'
+ac_prev=
+for ac_option
+do
+  # If the previous option needs an argument, assign it.
+  if test -n "$ac_prev"; then
+    eval "$ac_prev=\$ac_option"
+    ac_prev=
+    continue
+  fi
+  ac_optarg=`expr "x$ac_option" : 'x[^=]*=\(.*\)'`
+  # Accept the important Cygnus configure options, so we can diagnose typos.
+  case $ac_option in
+  -bindir | --bindir | --bindi | --bind | --bin | --bi)
+    ac_prev=bindir ;;
+  -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
+    bindir=$ac_optarg ;;
+  -build | --build | --buil | --bui | --bu)
+    ac_prev=build_alias ;;
+  -build=* | --build=* | --buil=* | --bui=* | --bu=*)
+    build_alias=$ac_optarg ;;
+  -cache-file | --cache-file | --cache-fil | --cache-fi \
+  | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
+    ac_prev=cache_file ;;
+  -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
+  | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
+    cache_file=$ac_optarg ;;
+  --config-cache | -C)
+    cache_file=config.cache ;;
+  -datadir | --datadir | --datadi | --datad | --data | --dat | --da)
+    ac_prev=datadir ;;
+  -datadir=* | --datadir=* | --datadi=* | --datad=* | --data=* | --dat=* \
+  | --da=*)
+    datadir=$ac_optarg ;;
+  -disable-* | --disable-*)
+    ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
+    # Reject names that are not valid shell variable names.
+    expr "x$ac_feature" : ".*[^-_$as_cr_alnum]" >/dev/null &&
+      { echo "$as_me: error: invalid feature name: $ac_feature" >&2
+    ac_feature=`echo $ac_feature | sed 's/-/_/g'`
+    eval "enable_$ac_feature=no" ;;
+  -enable-* | --enable-*)
+    ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
+      *=*) ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`;;
+      *) ac_optarg=yes ;;
+    esac
+    eval "enable_$ac_feature='$ac_optarg'" ;;
+  -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
+  | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
+  | --exec | --exe | --ex)
+    ac_prev=exec_prefix ;;
+  -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
+  | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
+  | --exec=* | --exe=* | --ex=*)
+    exec_prefix=$ac_optarg ;;
+  -gas | --gas | --ga | --g)
+    # Obsolete; use --with-gas.
+    with_gas=yes ;;
+  -help | --help | --hel | --he | -h)
+    ac_init_help=long ;;
+  -help=r* | --help=r* | --hel=r* | --he=r* | -hr*)
+    ac_init_help=recursive ;;
+  -help=s* | --help=s* | --hel=s* | --he=s* | -hs*)
+    ac_init_help=short ;;
+  -host | --host | --hos | --ho)
+    ac_prev=host_alias ;;
+  -host=* | --host=* | --hos=* | --ho=*)
+    host_alias=$ac_optarg ;;
+  -includedir | --includedir | --includedi | --included | --include \
+  | --includ | --inclu | --incl | --inc)
+    ac_prev=includedir ;;
+  -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
+  | --includ=* | --inclu=* | --incl=* | --inc=*)
+    includedir=$ac_optarg ;;
+  -infodir | --infodir | --infodi | --infod | --info | --inf)
+    ac_prev=infodir ;;
+  -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
+    infodir=$ac_optarg ;;
+  -libdir | --libdir | --libdi | --libd)
+    ac_prev=libdir ;;
+  -libdir=* | --libdir=* | --libdi=* | --libd=*)
+    libdir=$ac_optarg ;;
+  -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
+  | --libexe | --libex | --libe)
+    ac_prev=libexecdir ;;
+  -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
+  | --libexe=* | --libex=* | --libe=*)
+    libexecdir=$ac_optarg ;;
+  -localstatedir | --localstatedir | --localstatedi | --localstated \
+  | --localstate | --localstat | --localsta | --localst \
+  | --locals | --local | --loca | --loc | --lo)
+    ac_prev=localstatedir ;;
+  -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
+  | --localstate=* | --localstat=* | --localsta=* | --localst=* \
+  | --locals=* | --local=* | --loca=* | --loc=* | --lo=*)
+    localstatedir=$ac_optarg ;;
+  -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
+    ac_prev=mandir ;;
+  -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
+    mandir=$ac_optarg ;;
+  -nfp | --nfp | --nf)
+    # Obsolete; use --without-fp.
+    with_fp=no ;;
+  -no-create | --no-create | --no-creat | --no-crea | --no-cre \
+  | --no-cr | --no-c | -n)
+    no_create=yes ;;
+  -no-recursion | --no-recursion | --no-recursio | --no-recursi \
+  | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
+    no_recursion=yes ;;
+  -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
+  | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
+  | --oldin | --oldi | --old | --ol | --o)
+    ac_prev=oldincludedir ;;
+  -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
+  | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
+  | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
+    oldincludedir=$ac_optarg ;;
+  -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
+    ac_prev=prefix ;;
+  -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
+    prefix=$ac_optarg ;;
+  -program-prefix | --program-prefix | --program-prefi | --program-pref \
+  | --program-pre | --program-pr | --program-p)
+    ac_prev=program_prefix ;;
+  -program-prefix=* | --program-prefix=* | --program-prefi=* \
+  | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
+    program_prefix=$ac_optarg ;;
+  -program-suffix | --program-suffix | --program-suffi | --program-suff \
+  | --program-suf | --program-su | --program-s)
+    ac_prev=program_suffix ;;
+  -program-suffix=* | --program-suffix=* | --program-suffi=* \
+  | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
+    program_suffix=$ac_optarg ;;
+  -program-transform-name | --program-transform-name \
+  | --program-transform-nam | --program-transform-na \
+  | --program-transform-n | --program-transform- \
+  | --program-transform | --program-transfor \
+  | --program-transfo | --program-transf \
+  | --program-trans | --program-tran \
+  | --progr-tra | --program-tr | --program-t)
+    ac_prev=program_transform_name ;;
+  -program-transform-name=* | --program-transform-name=* \
+  | --program-transform-nam=* | --program-transform-na=* \
+  | --program-transform-n=* | --program-transform-=* \
+  | --program-transform=* | --program-transfor=* \
+  | --program-transfo=* | --program-transf=* \
+  | --program-trans=* | --program-tran=* \
+  | --progr-tra=* | --program-tr=* | --program-t=*)
+    program_transform_name=$ac_optarg ;;
+  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
+  | -silent | --silent | --silen | --sile | --sil)
+    silent=yes ;;
+  -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
+    ac_prev=sbindir ;;
+  -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
+  | --sbi=* | --sb=*)
+    sbindir=$ac_optarg ;;
+  -sharedstatedir | --sharedstatedir | --sharedstatedi \
+  | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
+  | --sharedst | --shareds | --shared | --share | --shar \
+  | --sha | --sh)
+    ac_prev=sharedstatedir ;;
+  -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
+  | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
+  | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
+  | --sha=* | --sh=*)
+    sharedstatedir=$ac_optarg ;;
+  -site | --site | --sit)
+    ac_prev=site ;;
+  -site=* | --site=* | --sit=*)
+    site=$ac_optarg ;;
+  -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
+    ac_prev=srcdir ;;
+  -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
+    srcdir=$ac_optarg ;;
+  -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
+  | --syscon | --sysco | --sysc | --sys | --sy)
+    ac_prev=sysconfdir ;;
+  -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
+  | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
+    sysconfdir=$ac_optarg ;;
+  -target | --target | --targe | --targ | --tar | --ta | --t)
+    ac_prev=target_alias ;;
+  -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
+    target_alias=$ac_optarg ;;
+  -v | -verbose | --verbose | --verbos | --verbo | --verb)
+    verbose=yes ;;
+  -version | --version | --versio | --versi | --vers | -V)
+    ac_init_version=: ;;
+  -with-* | --with-*)
+    ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
+    expr "x$ac_package" : ".*[^-_$as_cr_alnum]" >/dev/null &&
+      { echo "$as_me: error: invalid package name: $ac_package" >&2
+    ac_package=`echo $ac_package| sed 's/-/_/g'`
+    esac
+    eval "with_$ac_package='$ac_optarg'" ;;
+  -without-* | --without-*)
+    ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'`
+    ac_package=`echo $ac_package | sed 's/-/_/g'`
+    eval "with_$ac_package=no" ;;
+  --x)
+    # Obsolete; use --with-x.
+    with_x=yes ;;
+  -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
+  | --x-incl | --x-inc | --x-in | --x-i)
+    ac_prev=x_includes ;;
+  -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
+  | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
+    x_includes=$ac_optarg ;;
+  -x-libraries | --x-libraries | --x-librarie | --x-librari \
+  | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
+    ac_prev=x_libraries ;;
+  -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
+  | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
+    x_libraries=$ac_optarg ;;
+  -*) { echo "$as_me: error: unrecognized option: $ac_option
+Try \`$0 --help' for more information." >&2
+    ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
+    expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
+      { echo "$as_me: error: invalid variable name: $ac_envvar" >&2
+    ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`
+    eval "$ac_envvar='$ac_optarg'"
+    export $ac_envvar ;;
+    # FIXME: should be removed in autoconf 3.0.
+    echo "$as_me: WARNING: you should use --build, --host, --target" >&2
+    expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
+      echo "$as_me: WARNING: invalid host type: $ac_option" >&2
+    : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
+  esac
+done
+if test -n "$ac_prev"; then
+  ac_option=--`echo $ac_prev | sed 's/_/-/g'`
+  { echo "$as_me: error: missing argument to $ac_option" >&2
+fi
+# Be sure to have absolute paths.
+for ac_var in exec_prefix prefix
+do
+  eval ac_val=$`echo $ac_var`
+  case $ac_val in
+    [\\/$]* | ?:[\\/]* | NONE | '' ) ;;
+    *)  { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
+   { (exit 1); exit 1; }; };;
+  esac
+done
+for ac_var in bindir sbindir libexecdir datadir sysconfdir sharedstatedir \
+	      localstatedir libdir includedir oldincludedir infodir mandir
+do
+  case $ac_val in
+  esac
+done
+# There might be people who depend on the old broken behavior: `$host'
+# used to hold the argument of --host etc.
+# FIXME: To remove some day.
+build=$build_alias
+host=$host_alias
+target=$target_alias
+if test "x$host_alias" != x; then
+  if test "x$build_alias" = x; then
+    cross_compiling=maybe
+    echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
+    If a cross compiler is detected then cross compile mode will be used." >&2
+  elif test "x$build_alias" != "x$host_alias"; then
+    cross_compiling=yes
+  fi
+fi
+ac_tool_prefix=
+test -n "$host_alias" && ac_tool_prefix=$host_alias-
+test "$silent" = yes && exec 6>/dev/null
+# Find the source files, if location was not specified.
+if test -z "$srcdir"; then
+  ac_srcdir_defaulted=yes
+  # Try the directory containing this script, then its parent.
+  ac_confdir=`(dirname "$0") 2>/dev/null ||
+$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$0" : 'X\(//\)[^/]' \| \
+	 X"$0" : 'X\(/\)' \| \
+echo X"$0" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
+  	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
+  	  /^X\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+  srcdir=$ac_confdir
+  if test ! -r $srcdir/$ac_unique_file; then
+    srcdir=..
+  fi
+else
+  ac_srcdir_defaulted=no
+fi
+if test ! -r $srcdir/$ac_unique_file; then
+  if test "$ac_srcdir_defaulted" = yes; then
+    { echo "$as_me: error: cannot find sources ($ac_unique_file) in $ac_confdir or .." >&2
+  else
+    { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
+  fi
+fi
+(cd $srcdir && test -r ./$ac_unique_file) 2>/dev/null ||
+  { echo "$as_me: error: sources are in $srcdir, but \`cd $srcdir' does not work" >&2
+srcdir=`echo "$srcdir" | sed 's%\([^\\/]\)[\\/]*$%\1%'`
+ac_env_build_alias_set=${build_alias+set}
+ac_env_build_alias_value=$build_alias
+ac_cv_env_build_alias_set=${build_alias+set}
+ac_cv_env_build_alias_value=$build_alias
+ac_env_host_alias_set=${host_alias+set}
+ac_env_host_alias_value=$host_alias
+ac_cv_env_host_alias_set=${host_alias+set}
+ac_cv_env_host_alias_value=$host_alias
+ac_env_target_alias_set=${target_alias+set}
+ac_env_target_alias_value=$target_alias
+ac_cv_env_target_alias_set=${target_alias+set}
+ac_cv_env_target_alias_value=$target_alias
+ac_env_CC_set=${CC+set}
+ac_env_CC_value=$CC
+ac_cv_env_CC_set=${CC+set}
+ac_cv_env_CC_value=$CC
+ac_env_CFLAGS_set=${CFLAGS+set}
+ac_env_CFLAGS_value=$CFLAGS
+ac_cv_env_CFLAGS_set=${CFLAGS+set}
+ac_cv_env_CFLAGS_value=$CFLAGS
+ac_env_LDFLAGS_set=${LDFLAGS+set}
+ac_env_LDFLAGS_value=$LDFLAGS
+ac_cv_env_LDFLAGS_set=${LDFLAGS+set}
+ac_cv_env_LDFLAGS_value=$LDFLAGS
+ac_env_CPPFLAGS_set=${CPPFLAGS+set}
+ac_env_CPPFLAGS_value=$CPPFLAGS
+ac_cv_env_CPPFLAGS_set=${CPPFLAGS+set}
+ac_cv_env_CPPFLAGS_value=$CPPFLAGS
+ac_env_CXX_set=${CXX+set}
+ac_env_CXX_value=$CXX
+ac_cv_env_CXX_set=${CXX+set}
+ac_cv_env_CXX_value=$CXX
+ac_env_CXXFLAGS_set=${CXXFLAGS+set}
+ac_env_CXXFLAGS_value=$CXXFLAGS
+ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
+ac_cv_env_CXXFLAGS_value=$CXXFLAGS
+ac_env_CPP_set=${CPP+set}
+ac_env_CPP_value=$CPP
+ac_cv_env_CPP_set=${CPP+set}
+ac_cv_env_CPP_value=$CPP
+ac_env_CXXCPP_set=${CXXCPP+set}
+ac_env_CXXCPP_value=$CXXCPP
+ac_cv_env_CXXCPP_set=${CXXCPP+set}
+ac_cv_env_CXXCPP_value=$CXXCPP
+ac_env_F77_set=${F77+set}
+ac_env_F77_value=$F77
+ac_cv_env_F77_set=${F77+set}
+ac_cv_env_F77_value=$F77
+ac_env_FFLAGS_set=${FFLAGS+set}
+ac_env_FFLAGS_value=$FFLAGS
+ac_cv_env_FFLAGS_set=${FFLAGS+set}
+ac_cv_env_FFLAGS_value=$FFLAGS
+# Report the --help message.
+if test "$ac_init_help" = "long"; then
+  # Omit some internal or obsolete options to make the list less imposing.
+  # This message is too long to be a string in the A/UX 3.1 sh.
+  cat <<_ACEOF
+\`configure' configures this package to adapt to many kinds of systems.
+Usage: $0 [OPTION]... [VAR=VALUE]...
+To assign environment variables (e.g., CC, CFLAGS...), specify them as
+VAR=VALUE.  See below for descriptions of some of the useful variables.
+Defaults for the options are specified in brackets.
+Configuration:
+  -h, --help              display this help and exit
+      --help=short        display options specific to this package
+      --help=recursive    display the short help of all the included packages
+  -V, --version           display version information and exit
+  -q, --quiet, --silent   do not print \`checking...' messages
+      --cache-file=FILE   cache test results in FILE [disabled]
+  -C, --config-cache      alias for \`--cache-file=config.cache'
+  -n, --no-create         do not create output files
+      --srcdir=DIR        find the sources in DIR [configure dir or \`..']
+_ACEOF
+  cat <<_ACEOF
+Installation directories:
+  --prefix=PREFIX         install architecture-independent files in PREFIX
+			  [$ac_default_prefix]
+  --exec-prefix=EPREFIX   install architecture-dependent files in EPREFIX
+			  [PREFIX]
+By default, \`make install' will install all the files in
+\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc.  You can specify
+an installation prefix other than \`$ac_default_prefix' using \`--prefix',
+for instance \`--prefix=\$HOME'.
+For better control, use the options below.
+Fine tuning of the installation directories:
+  --bindir=DIR           user executables [EPREFIX/bin]
+  --sbindir=DIR          system admin executables [EPREFIX/sbin]
+  --libexecdir=DIR       program executables [EPREFIX/libexec]
+  --datadir=DIR          read-only architecture-independent data [PREFIX/share]
+  --sysconfdir=DIR       read-only single-machine data [PREFIX/etc]
+  --sharedstatedir=DIR   modifiable architecture-independent data [PREFIX/com]
+  --localstatedir=DIR    modifiable single-machine data [PREFIX/var]
+  --libdir=DIR           object code libraries [EPREFIX/lib]
+  --includedir=DIR       C header files [PREFIX/include]
+  --oldincludedir=DIR    C header files for non-gcc [/usr/include]
+  --infodir=DIR          info documentation [PREFIX/info]
+  --mandir=DIR           man documentation [PREFIX/man]
+_ACEOF
+  cat <<\_ACEOF
+System types:
+  --build=BUILD     configure for building on BUILD [guessed]
+  --host=HOST       cross-compile to build programs to run on HOST [BUILD]
+  --target=TARGET   configure for building compilers for TARGET [HOST]
+_ACEOF
+fi
+if test -n "$ac_init_help"; then
+  cat <<\_ACEOF
+Optional Features:
+  --disable-FEATURE       do not include FEATURE (same as --enable-FEATURE=no)
+  --enable-FEATURE[=ARG]  include FEATURE [ARG=yes]
+  --enable-shared[=PKGS]
+                          build shared libraries [default=yes]
+  --enable-static[=PKGS]
+                          build static libraries [default=yes]
+  --enable-fast-install[=PKGS]
+                          optimize for fast installation [default=yes]
+  --disable-libtool-lock  avoid locking (might break parallel builds)
+Optional Packages:
+  --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
+  --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
+  --with-gnu-ld           assume the C compiler uses GNU ld [default=no]
+  --with-pic              try to use only PIC/non-PIC objects [default=use
+                          both]
+  --with-tags[=TAGS]
+                          include additional configurations [automatic]
+  --without-libtool     Don't use libtool to build the library
+  --without-ld-shared   Disable shared library support
+  --with-unix-stdio-64=ARG Utilize 64 stdio api (yes/no)
+  --with-local=dir      Include /usr/local or other local tree for INCLUDE/LIBS
+  --with-threads=linkoptInclude thread safe support
+  --with-libz=ARG       Include libz support (ARG=internal or libz directory)
+  --with-pg=ARG         Include PostgreSQL OGR Support (ARG=path to pg_config)
+  --with-grass=ARG      Include GRASS support (GRASS 5.7+, ARG=GRASS install tree dir)
+  --with-libgrass=ARG   Include GRASS support based on libgrass (GRASS 5.0+)
+  --with-cfitsio=ARG    Include FITS support (ARG=no or libcfitsio path)
+  --with-pcraster=ARG   Include PCRaster (libcsf) support (ARG=internal, no or path)
+  --with-netcdf=ARG     Include netCDF support (ARG=no or netCDF tree prefix)
+  --with-png=ARG        Include PNG support (ARG=internal, no or path)
+  --with-libtiff=ARG    Libtiff library to use (ARG=internal, yes or path)
+  --with-geotiff=ARG    Libgeotiff library to use (ARG=internal, yes or path)
+  --with-jpeg=ARG       Include JPEG support (ARG=internal, no or path)
+  --with-gif=ARG        Include GIF support (ARG=internal, no or path)
+  --with-ogdi=ARG       Include OGDI support (ARG=path)
+  --with-fme=ARG        Include FMEObjects support (ARG=FME_HOME path)
+  --with-hdf4=ARG       Include HDF4 support (ARG=path)
+  --with-hdf5=ARG       Include HDF5 support (ARG=path)
+  --with-jasper=ARG     Include JPEG-2000 support via JasPer library (ARG=path)
+  --with-ecw=ARG        Include ECW support (ARG=ECW SDK Path, yes or no)
+  --with-kakadu=ARG     Include Kakadu/JPEG2000 support
+  --with-mrsid=ARG      Include MrSID support (ARG=path to MrSID DSDK or no)
+  --with-jp2mrsid=ARG   Enable MrSID JPEG2000 support (ARG=yes/no)
+  --without-bsb         Disable BSB format (legal issues pending)
+  --without-ogr         Don't build OGR into shared library
+  --with-mysql=ARG      Include MySQL (ARG=path to mysql_config) [default=no]
+  --with-xerces         Include Xerces C++ XML Parser support (for GML)
+  --with-xerces-inc=dir Xerces C++ include directory
+  --with-xerces-lib=opts Xerces C++ link option(s)
+                             ie. -L/usr/local/lib -lxerces-c1_6_0 -lpthread
+  --with-odbc=ARG       Include ODBC support (ARG=no or path)
+  --with-oci=[ARG]  use Oracle OCI API from given Oracle home
+                          (ARG=path); use existing ORACLE_HOME (ARG=yes);
+                          disable Oracle OCI support (ARG=no)
+  --with-oci-include=[DIR]
+                          use Oracle OCI API headers from given path
+  --with-oci-lib=[DIR]
+                          use Oracle OCI API libraries from given path
+  --with-dods-root=ARG  Include DODS support (ARG=no or absolute path)
+  --with-curl=ARG       Include curl for WCS (ARG=path to curl-config.)
+  --with-sqlite=ARG     Include SQLite support (ARG=no or absolute path)
+  --with-dwgdirect=path Include DWG direct support
+  --with-dwg-plt=platform DWGdirect Platform, defaults to lnxX86
+  --with-panorama=ARG   Include "Panorama" GIS support via "Panorama" SDK (ARG=path)
+  --with-idb=DIR        Include Informix DataBlade support (DIR points to Informix root)
+  --with-sde=DIR        Include ESRI SDE support (DIR is SDE's install dir).
+  --with-sde-version=VERSION NUMBER  Set ESRI SDE version number (Default is 80).
+  --with-geos=ARG       Include GEOS support (ARG=yes, no or geos-config path)
+  --with-static-proj4=ARG Compile with PROJ.4 statically (ARG=no or path)
+  --with-gdal-ver=ARG   Override GDAL version
+  --with-macosx-framework         Build and install GDAL as a Mac OS X Framework
+  --with-perl           Enable perl bindings
+  --with-php            Enable php bindings
+  --with-ruby           Enable Ruby bindings
+  --with-ngpython       Enable Next Generation python bindings
+  --with-python         Enable traditional Python bindings
+  --with-pymoddir=ARG   Override Python package install dir
+Some influential environment variables:
+  CC          C compiler command
+  CFLAGS      C compiler flags
+  LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
+              nonstandard directory <lib dir>
+  CPPFLAGS    C/C++ preprocessor flags, e.g. -I<include dir> if you have
+              headers in a nonstandard directory <include dir>
+  CXX         C++ compiler command
+  CXXFLAGS    C++ compiler flags
+  CPP         C preprocessor
+  CXXCPP      C++ preprocessor
+  F77         Fortran 77 compiler command
+  FFLAGS      Fortran 77 compiler flags
+Use these variables to override the choices made by `configure' or to help
+it to find libraries and programs with nonstandard names/locations.
+_ACEOF
+fi
+if test "$ac_init_help" = "recursive"; then
+  # If there are subdirs, report their specific --help.
+  ac_popdir=`pwd`
+  for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
+    test -d $ac_dir || continue
+    ac_builddir=.
+if test "$ac_dir" != .; then
+  ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
+  # A "../" for each directory in $ac_dir_suffix.
+  ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
+else
+  ac_dir_suffix= ac_top_builddir=
+fi
+case $srcdir in
+  .)  # No --srcdir option.  We are building in place.
+    ac_srcdir=.
+    if test -z "$ac_top_builddir"; then
+       ac_top_srcdir=.
+    else
+       ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
+    fi ;;
+  [\\/]* | ?:[\\/]* )  # Absolute path.
+    ac_srcdir=$srcdir$ac_dir_suffix;
+    ac_top_srcdir=$srcdir ;;
+  *) # Relative path.
+    ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
+    ac_top_srcdir=$ac_top_builddir$srcdir ;;
+esac
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+  case "$ac_dir" in
+  .) ac_abs_builddir=`pwd`;;
+  [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+  *) ac_abs_builddir=`pwd`/"$ac_dir";;
+  esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+  case ${ac_top_builddir}. in
+  .) ac_abs_top_builddir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+  *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+  esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+  case $ac_srcdir in
+  .) ac_abs_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+  *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+  esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+  case $ac_top_srcdir in
+  .) ac_abs_top_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+  *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+  esac;;
+esac
+    cd $ac_dir
+    # Check for guested configure; otherwise get Cygnus style configure.
+    if test -f $ac_srcdir/configure.gnu; then
+      echo
+      $SHELL $ac_srcdir/configure.gnu  --help=recursive
+    elif test -f $ac_srcdir/configure; then
+      echo
+      $SHELL $ac_srcdir/configure  --help=recursive
+    elif test -f $ac_srcdir/configure.ac ||
+	   test -f $ac_srcdir/configure.in; then
+      echo
+      $ac_configure --help
+    else
+      echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
+    fi
+    cd $ac_popdir
+  done
+fi
+test -n "$ac_init_help" && exit 0
+if $ac_init_version; then
+  cat <<\_ACEOF
+Copyright (C) 2003 Free Software Foundation, Inc.
+This configure script is free software; the Free Software Foundation
+gives unlimited permission to copy, distribute and modify it.
+_ACEOF
+  exit 0
+fi
+exec 5>config.log
+cat >&5 <<_ACEOF
+This file contains any messages produced by compilers while
+running configure, to aid debugging if configure makes a mistake.
+It was created by $as_me, which was
+generated by GNU Autoconf 2.59.  Invocation command line was
+  $ $0 $@
+_ACEOF
+cat <<_ASUNAME
+## Platform. ##
+hostname = `(hostname || uname -n) 2>/dev/null | sed 1q`
+uname -m = `(uname -m) 2>/dev/null || echo unknown`
+uname -r = `(uname -r) 2>/dev/null || echo unknown`
+uname -s = `(uname -s) 2>/dev/null || echo unknown`
+uname -v = `(uname -v) 2>/dev/null || echo unknown`
+/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown`
+/bin/uname -X     = `(/bin/uname -X) 2>/dev/null     || echo unknown`
+/bin/arch              = `(/bin/arch) 2>/dev/null              || echo unknown`
+/usr/bin/arch -k       = `(/usr/bin/arch -k) 2>/dev/null       || echo unknown`
+/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown`
+hostinfo               = `(hostinfo) 2>/dev/null               || echo unknown`
+/bin/machine           = `(/bin/machine) 2>/dev/null           || echo unknown`
+/usr/bin/oslevel       = `(/usr/bin/oslevel) 2>/dev/null       || echo unknown`
+/bin/universe          = `(/bin/universe) 2>/dev/null          || echo unknown`
+_ASUNAME
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+  echo "PATH: $as_dir"
+done
+} >&5
+cat >&5 <<_ACEOF
+## Core tests. ##
+_ACEOF
+# Keep a trace of the command line.
+# Strip out --no-create and --no-recursion so they do not pile up.
+# Strip out --silent because we don't want to record it for future runs.
+# Also quote any args containing shell meta-characters.
+# Make two passes to allow for proper duplicate-argument suppression.
+ac_configure_args=
+ac_configure_args0=
+ac_configure_args1=
+ac_sep=
+ac_must_keep_next=false
+for ac_pass in 1 2
+do
+  for ac_arg
+  do
+    case $ac_arg in
+    -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;;
+      continue ;;
+      ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
+    esac
+    case $ac_pass in
+    1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
+    2)
+      ac_configure_args1="$ac_configure_args1 '$ac_arg'"
+      if test $ac_must_keep_next = true; then
+	ac_must_keep_next=false # Got value, back to normal.
+      else
+	case $ac_arg in
+	  *=* | --config-cache | -C | -disable-* | --disable-* \
+	  | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
+	  | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
+	  | -with-* | --with-* | -without-* | --without-* | --x)
+	    case "$ac_configure_args0 " in
+	      "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
+	    esac
+	  -* ) ac_must_keep_next=true ;;
+	esac
+      fi
+      ac_configure_args="$ac_configure_args$ac_sep'$ac_arg'"
+      # Get rid of the leading space.
+      ac_sep=" "
+    esac
+  done
+done
+$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
+$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
+# When interrupted or exit'd, cleanup temporary files, and complete
+# config.log.  We remove comments because anyway the quotes in there
+# would cause problems or look ugly.
+# WARNING: Be sure not to use single quotes in there, as some shells,
+# such as our DU 5.0 friend, will then `close' the trap.
+trap 'exit_status=$?
+  # Save into config.log some information that might help in debugging.
+    echo
+    cat <<\_ASBOX
+## Cache variables. ##
+_ASBOX
+    echo
+    # The following way of writing the cache mishandles newlines in values,
+  (set) 2>&1 |
+    case `(ac_space='"'"' '"'"'; set | grep ac_space) 2>&1` in
+    *ac_space=\ *)
+      sed -n \
+	"s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
+	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
+      sed -n \
+	"s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+    esac;
+    echo
+    cat <<\_ASBOX
+## Output variables. ##
+_ASBOX
+    echo
+    for ac_var in $ac_subst_vars
+    do
+      echo "$ac_var='"'"'$ac_val'"'"'"
+    done | sort
+    echo
+    if test -n "$ac_subst_files"; then
+      cat <<\_ASBOX
+## Output files. ##
+_ASBOX
+      echo
+      for ac_var in $ac_subst_files
+      do
+      done | sort
+      echo
+    fi
+    if test -s confdefs.h; then
+      cat <<\_ASBOX
+## confdefs.h. ##
+_ASBOX
+      echo
+      sed "/^$/d" confdefs.h | sort
+      echo
+    fi
+    test "$ac_signal" != 0 &&
+      echo "$as_me: caught signal $ac_signal"
+    echo "$as_me: exit $exit_status"
+  } >&5
+  rm -f core *.core &&
+  rm -rf conftest* confdefs* conf$$* $ac_clean_files &&
+    exit $exit_status
+     ' 0
+for ac_signal in 1 2 13 15; do
+  trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
+done
+ac_signal=0
+# confdefs.h avoids OS command line length limits that DEFS can exceed.
+rm -rf conftest* confdefs.h
+# AIX cpp loses on an empty file, so make sure it contains at least a newline.
+echo >confdefs.h
+# Predefined preprocessor variables.
+cat >>confdefs.h <<_ACEOF
+#define PACKAGE_NAME "$PACKAGE_NAME"
+_ACEOF
+#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
+_ACEOF
+#define PACKAGE_VERSION "$PACKAGE_VERSION"
+_ACEOF
+#define PACKAGE_STRING "$PACKAGE_STRING"
+_ACEOF
+#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
+_ACEOF
+# Let the site file select an alternate cache file if it wants to.
+# Prefer explicitly selected file to automatically selected ones.
+if test -z "$CONFIG_SITE"; then
+  if test "x$prefix" != xNONE; then
+    CONFIG_SITE="$prefix/share/config.site $prefix/etc/config.site"
+  else
+    CONFIG_SITE="$ac_default_prefix/share/config.site $ac_default_prefix/etc/config.site"
+  fi
+fi
+for ac_site_file in $CONFIG_SITE; do
+  if test -r "$ac_site_file"; then
+    { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
+echo "$as_me: loading site script $ac_site_file" >&6;}
+    sed 's/^/| /' "$ac_site_file" >&5
+    . "$ac_site_file"
+  fi
+done
+# Check that the precious variables saved in the cache have kept the same
+# value.
+ac_cache_corrupted=false
+for ac_var in `(set) 2>&1 |
+	       sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
+  eval ac_old_set=\$ac_cv_env_${ac_var}_set
+  eval ac_new_set=\$ac_env_${ac_var}_set
+  eval ac_old_val="\$ac_cv_env_${ac_var}_value"
+  eval ac_new_val="\$ac_env_${ac_var}_value"
+  case $ac_old_set,$ac_new_set in
+    set,)
+      { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
+      ac_cache_corrupted=: ;;
+    ,set)
+      { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
+echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
+      if test "x$ac_old_val" != "x$ac_new_val"; then
+	{ echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
+echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
+	{ echo "$as_me:$LINENO:   former value:  $ac_old_val" >&5
+echo "$as_me:   former value:  $ac_old_val" >&2;}
+	{ echo "$as_me:$LINENO:   current value: $ac_new_val" >&5
+echo "$as_me:   current value: $ac_new_val" >&2;}
+      fi;;
+  esac
+  # Pass precious variables to config.status.
+  if test "$ac_new_set" = set; then
+    case $ac_new_val in
+      ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
+    *) ac_arg=$ac_var=$ac_new_val ;;
+    esac
+    case " $ac_configure_args " in
+      *" '$ac_arg' "*) ;; # Avoid dups.  Use of quotes ensures accuracy.
+      *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
+    esac
+  fi
+done
+if $ac_cache_corrupted; then
+  { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
+echo "$as_me: error: changes in the environment can compromise the build" >&2;}
+  { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
+echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+case m4 in
+  [\\/]* | ?:[\\/]* ) ac_macro_dir=m4         ;;
+  *)                      ac_macro_dir=$srcdir/m4 ;;
+esac
+if test -d "$ac_macro_dir"; then :
+else
+  { { echo "$as_me:$LINENO: error: cannot find macro directory \`m4'" >&5
+echo "$as_me: error: cannot find macro directory \`m4'" >&2;}
+fi
+          ac_config_headers="$ac_config_headers port/cpl_config.h"
+ac_aux_dir=
+for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
+  if test -f $ac_dir/install-sh; then
+    ac_aux_dir=$ac_dir
+    ac_install_sh="$ac_aux_dir/install-sh -c"
+    break
+  elif test -f $ac_dir/install.sh; then
+    ac_install_sh="$ac_aux_dir/install.sh -c"
+    break
+  elif test -f $ac_dir/shtool; then
+    ac_install_sh="$ac_aux_dir/shtool install -c"
+    break
+  fi
+done
+if test -z "$ac_aux_dir"; then
+  { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&5
+echo "$as_me: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&2;}
+fi
+ac_config_guess="$SHELL $ac_aux_dir/config.guess"
+ac_config_sub="$SHELL $ac_aux_dir/config.sub"
+ac_configure="$SHELL $ac_aux_dir/configure" # This should be Cygnus configure.
+# Make sure we can run config.sub.
+$ac_config_sub sun4 >/dev/null 2>&1 ||
+  { { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
+echo "$as_me: error: cannot run $ac_config_sub" >&2;}
+echo "$as_me:$LINENO: checking build system type" >&5
+echo $ECHO_N "checking build system type... $ECHO_C" >&6
+if test "${ac_cv_build+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_cv_build_alias=$build_alias
+test -z "$ac_cv_build_alias" &&
+  ac_cv_build_alias=`$ac_config_guess`
+  { { echo "$as_me:$LINENO: error: cannot guess build type; you must specify one" >&5
+echo "$as_me: error: cannot guess build type; you must specify one" >&2;}
+ac_cv_build=`$ac_config_sub $ac_cv_build_alias` ||
+  { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_build_alias failed" >&5
+echo "$as_me: error: $ac_config_sub $ac_cv_build_alias failed" >&2;}
+fi
+echo "$as_me:$LINENO: result: $ac_cv_build" >&5
+echo "${ECHO_T}$ac_cv_build" >&6
+build=$ac_cv_build
+build_cpu=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
+build_vendor=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
+build_os=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
+echo "$as_me:$LINENO: checking host system type" >&5
+echo $ECHO_N "checking host system type... $ECHO_C" >&6
+if test "${ac_cv_host+set}" = set; then
+else
+  ac_cv_host_alias=$host_alias
+test -z "$ac_cv_host_alias" &&
+  ac_cv_host_alias=$ac_cv_build_alias
+ac_cv_host=`$ac_config_sub $ac_cv_host_alias` ||
+  { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_host_alias failed" >&5
+echo "$as_me: error: $ac_config_sub $ac_cv_host_alias failed" >&2;}
+fi
+echo "$as_me:$LINENO: result: $ac_cv_host" >&5
+echo "${ECHO_T}$ac_cv_host" >&6
+host=$ac_cv_host
+host_cpu=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
+host_vendor=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
+host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
+echo "$as_me:$LINENO: checking target system type" >&5
+echo $ECHO_N "checking target system type... $ECHO_C" >&6
+if test "${ac_cv_target+set}" = set; then
+else
+  ac_cv_target_alias=$target_alias
+test "x$ac_cv_target_alias" = "x" &&
+  ac_cv_target_alias=$ac_cv_host_alias
+ac_cv_target=`$ac_config_sub $ac_cv_target_alias` ||
+  { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_target_alias failed" >&5
+echo "$as_me: error: $ac_config_sub $ac_cv_target_alias failed" >&2;}
+fi
+echo "$as_me:$LINENO: result: $ac_cv_target" >&5
+echo "${ECHO_T}$ac_cv_target" >&6
+target=$ac_cv_target
+target_cpu=`echo $ac_cv_target | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
+target_vendor=`echo $ac_cv_target | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
+target_os=`echo $ac_cv_target | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
+# The aliases save the names the user supplied, while $host etc.
+# will get canonicalized.
+test -n "$target_alias" &&
+  test "$program_prefix$program_suffix$program_transform_name" = \
+    NONENONEs,x,x, &&
+  program_prefix=${target_alias}-
+ac_ext=c
+if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
+set dummy ${ac_tool_prefix}gcc; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_CC+set}" = set; then
+else
+  if test -n "$CC"; then
+  ac_cv_prog_CC="$CC" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+  for ac_exec_ext in '' $ac_executable_extensions; do
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_CC="${ac_tool_prefix}gcc"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+fi
+fi
+CC=$ac_cv_prog_CC
+if test -n "$CC"; then
+  echo "$as_me:$LINENO: result: $CC" >&5
+echo "${ECHO_T}$CC" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+fi
+if test -z "$ac_cv_prog_CC"; then
+  ac_ct_CC=$CC
+  # Extract the first word of "gcc", so it can be a program name with args.
+set dummy gcc; ac_word=$2
+if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
+else
+  if test -n "$ac_ct_CC"; then
+  ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="gcc"
+    break 2
+  fi
+done
+done
+fi
+fi
+ac_ct_CC=$ac_cv_prog_ac_ct_CC
+if test -n "$ac_ct_CC"; then
+  echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
+echo "${ECHO_T}$ac_ct_CC" >&6
+else
+fi
+  CC=$ac_ct_CC
+else
+  CC="$ac_cv_prog_CC"
+fi
+if test -z "$CC"; then
+  if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
+set dummy ${ac_tool_prefix}cc; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_CC="${ac_tool_prefix}cc"
+    break 2
+  fi
+done
+done
+fi
+fi
+CC=$ac_cv_prog_CC
+else
+fi
+fi
+  ac_ct_CC=$CC
+  # Extract the first word of "cc", so it can be a program name with args.
+set dummy cc; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="cc"
+    break 2
+  fi
+done
+done
+fi
+fi
+else
+fi
+  CC=$ac_ct_CC
+else
+fi
+fi
+else
+else
+  ac_prog_rejected=no
+do
+  IFS=$as_save_IFS
+    if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
+       ac_prog_rejected=yes
+       continue
+     fi
+    ac_cv_prog_CC="cc"
+    break 2
+  fi
+done
+done
+if test $ac_prog_rejected = yes; then
+  # We found a bogon in the path, so make sure we never use it.
+  set dummy $ac_cv_prog_CC
+  shift
+  if test $# != 0; then
+    # We chose a different compiler from the bogus one.
+    # However, it has the same basename, so the bogon will be chosen
+    # first if we set CC to just the basename; use the full file name.
+    shift
+    ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
+  fi
+fi
+fi
+fi
+CC=$ac_cv_prog_CC
+else
+fi
+fi
+  for ac_prog in cl
+  do
+    # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
+set dummy $ac_tool_prefix$ac_prog; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+CC=$ac_cv_prog_CC
+else
+fi
+    test -n "$CC" && break
+  done
+fi
+  ac_ct_CC=$CC
+  for ac_prog in cl
+do
+  # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+else
+fi
+  test -n "$ac_ct_CC" && break
+done
+  CC=$ac_ct_CC
+fi
+fi
+test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&5
+echo "$as_me: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&2;}
+# Provide some information about the compiler.
+echo "$as_me:$LINENO:" \
+     "checking for C compiler version" >&5
+ac_compiler=`set X $ac_compile; echo $2`
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
+  (eval $ac_compiler --version </dev/null >&5) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); }
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
+  (eval $ac_compiler -v </dev/null >&5) 2>&5
+  ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
+  (eval $ac_compiler -V </dev/null >&5) 2>&5
+  ac_status=$?
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+ac_clean_files_save=$ac_clean_files
+ac_clean_files="$ac_clean_files a.out a.exe b.out"
+# Try to create an executable without -o first, disregard a.out.
+# It will help us diagnose broken compilers, and finding out an intuition
+# of exeext.
+echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6
+ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
+if { (eval echo "$as_me:$LINENO: \"$ac_link_default\"") >&5
+  (eval $ac_link_default) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; then
+  # Find the output, starting from the most likely.  This scheme is
+# not robust to junk in `.', hence go to wildcards (a.*) only as a last
+# resort.
+# Be careful to initialize this variable, since it used to be cached.
+# Otherwise an old cache value of `no' led to `EXEEXT = no' in a Makefile.
+ac_cv_exeext=
+# b.out is created by i960 compilers.
+for ac_file in a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out
+do
+  test -f "$ac_file" || continue
+  case $ac_file in
+    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj )
+    conftest.$ac_ext )
+	# This is the source file.
+    [ab].out )
+	# We found the default executable, but exeext='' is most
+	# certainly right.
+	break;;
+	ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
+	# FIXME: I believe we export ac_cv_exeext for Libtool,
+	# but it would be cool to find out if it's true.  Does anybody
+	# maintain Libtool? --akim.
+	export ac_cv_exeext
+	break;;
+	break;;
+  esac
+done
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+{ { echo "$as_me:$LINENO: error: C compiler cannot create executables
+echo "$as_me: error: C compiler cannot create executables
+   { (exit 77); exit 77; }; }
+fi
+ac_exeext=$ac_cv_exeext
+echo "$as_me:$LINENO: result: $ac_file" >&5
+echo "${ECHO_T}$ac_file" >&6
+# Check the compiler produces executables we can run.  If not, either
+# the compiler is broken, or we cross compile.
+echo "$as_me:$LINENO: checking whether the C compiler works" >&5
+echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6
+# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
+# If not cross compiling, check that we can run a simple program.
+if test "$cross_compiling" != yes; then
+  if { ac_try='./$ac_file'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; }; then
+    cross_compiling=no
+  else
+    if test "$cross_compiling" = maybe; then
+    else
+	{ { echo "$as_me:$LINENO: error: cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+echo "$as_me: error: cannot run C compiled programs.
+    fi
+  fi
+fi
+echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+rm -f a.out a.exe conftest$ac_cv_exeext b.out
+ac_clean_files=$ac_clean_files_save
+echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
+echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $cross_compiling" >&5
+echo "${ECHO_T}$cross_compiling" >&6
+echo "$as_me:$LINENO: checking for suffix of executables" >&5
+echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  # If both `conftest.exe' and `conftest' are `present' (well, observable)
+# catch `conftest.exe'.  For instance with Cygwin, `ls conftest' will
+# work properly (i.e., refer to `conftest.exe'), while it won't with
+# `rm'.
+for ac_file in conftest.exe conftest conftest.*; do
+  case $ac_file in
+    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj ) ;;
+    *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
+	  break;;
+    * ) break;;
+  esac
+done
+else
+  { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
+echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
+fi
+rm -f conftest$ac_cv_exeext
+echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
+echo "${ECHO_T}$ac_cv_exeext" >&6
+rm -f conftest.$ac_ext
+EXEEXT=$ac_cv_exeext
+ac_exeext=$EXEEXT
+echo "$as_me:$LINENO: checking for suffix of object files" >&5
+echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6
+if test "${ac_cv_objext+set}" = set; then
+else
+  cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.o conftest.obj
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  for ac_file in `(ls conftest.o conftest.obj; ls conftest.*) 2>/dev/null`; do
+  case $ac_file in
+    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg ) ;;
+    *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
+       break;;
+  esac
+done
+else
+{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
+echo "$as_me: error: cannot compute suffix of object files: cannot compile
+fi
+rm -f conftest.$ac_cv_objext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
+echo "${ECHO_T}$ac_cv_objext" >&6
+OBJEXT=$ac_cv_objext
+ac_objext=$OBJEXT
+echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6
+if test "${ac_cv_c_compiler_gnu+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#ifndef __GNUC__
+       choke me
+#endif
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext
+  (eval $ac_compile) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest.$ac_objext'
+  ac_status=$?
+  ac_compiler_gnu=yes
+else
+ac_compiler_gnu=no
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+ac_cv_c_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6
+GCC=`test $ac_compiler_gnu = yes && echo yes`
+ac_test_CFLAGS=${CFLAGS+set}
+ac_save_CFLAGS=$CFLAGS
+CFLAGS="-g"
+echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
+echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_cc_g+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_cc_g=yes
+else
+ac_cv_prog_cc_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
+echo "${ECHO_T}$ac_cv_prog_cc_g" >&6
+if test "$ac_test_CFLAGS" = set; then
+  CFLAGS=$ac_save_CFLAGS
+elif test $ac_cv_prog_cc_g = yes; then
+  if test "$GCC" = yes; then
+    CFLAGS="-g -O2"
+  else
+    CFLAGS="-g"
+  fi
+else
+    CFLAGS="-O2"
+  else
+    CFLAGS=
+  fi
+fi
+echo "$as_me:$LINENO: checking for $CC option to accept ANSI C" >&5
+echo $ECHO_N "checking for $CC option to accept ANSI C... $ECHO_C" >&6
+if test "${ac_cv_prog_cc_stdc+set}" = set; then
+else
+  ac_cv_prog_cc_stdc=no
+ac_save_CC=$CC
+/* confdefs.h.  */
+_ACEOF
+#include <stdarg.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+/* Most of the following tests are stolen from RCS 5.7's src/conf.sh.  */
+struct buf { int x; };
+FILE * (*rcsopen) (struct buf *, struct stat *, int);
+static char *e (p, i)
+     char **p;
+     int i;
+  return p[i];
+static char *f (char * (*g) (char **, int), char **p, ...)
+  char *s;
+  va_list v;
+  va_start (v,p);
+  s = g (p, va_arg (v,int));
+  va_end (v);
+  return s;
+/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default.  It has
+   function prototypes and stuff, but not '\xHH' hex character constants.
+   These don't provoke an error unfortunately, instead are silently treated
+   as 'x'.  The following induces an error, until -std1 is added to get
+   proper ANSI mode.  Curiously '\x00'!='x' always comes out true, for an
+   array size at least.  It's necessary to write '\x00'==0 to get something
+   that's true only with -std1.  */
+int osf4_cc_array ['\x00' == 0 ? 1 : -1];
+int test (int i, double x);
+struct s1 {int (*f) (int a);};
+struct s2 {int (*f) (double a);};
+int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
+int argc;
+char **argv;
+int
+main ()
+return f (e, argv, 0) != argv[0]  ||  f (e, argv, 1) != argv[1];
+  return 0;
+_ACEOF
+# Don't try gcc -ansi; that turns off useful extensions and
+# breaks some systems' header files.
+# AIX			-qlanglvl=ansi
+# Ultrix and OSF/1	-std1
+# HP-UX 10.20 and later	-Ae
+# HP-UX older versions	-Aa -D_HPUX_SOURCE
+# SVR4			-Xc -D__EXTENSIONS__
+for ac_arg in "" -qlanglvl=ansi -std1 -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
+do
+  CC="$ac_save_CC $ac_arg"
+  rm -f conftest.$ac_objext
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_cc_stdc=$ac_arg
+break
+else
+fi
+done
+rm -f conftest.$ac_ext conftest.$ac_objext
+CC=$ac_save_CC
+fi
+case "x$ac_cv_prog_cc_stdc" in
+  x|xno)
+    echo "$as_me:$LINENO: result: none needed" >&5
+echo "${ECHO_T}none needed" >&6 ;;
+    echo "$as_me:$LINENO: result: $ac_cv_prog_cc_stdc" >&5
+echo "${ECHO_T}$ac_cv_prog_cc_stdc" >&6
+    CC="$CC $ac_cv_prog_cc_stdc" ;;
+esac
+# Some people use a C++ compiler to compile C.  Since we use `exit',
+# in C++ we need to declare it.  In case someone uses the same compiler
+# for both compiling C and C++ we need to have the C++ compiler decide
+# the declaration of exit, since it's the most demanding environment.
+#ifndef __cplusplus
+  choke me
+#endif
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  for ac_declaration in \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+#include <stdlib.h>
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  break
+else
+fi
+done
+rm -f conftest*
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
+fi
+ac_ext=c
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+  for ac_prog in $CCC g++ c++ gpp aCC CC cxx cc++ cl FCC KCC RCC xlC_r xlC
+  do
+if test "${ac_cv_prog_CXX+set}" = set; then
+else
+  if test -n "$CXX"; then
+  ac_cv_prog_CXX="$CXX" # Let the user override the test.
+else
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+    ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+CXX=$ac_cv_prog_CXX
+if test -n "$CXX"; then
+  echo "$as_me:$LINENO: result: $CXX" >&5
+echo "${ECHO_T}$CXX" >&6
+else
+fi
+    test -n "$CXX" && break
+  done
+fi
+if test -z "$CXX"; then
+  ac_ct_CXX=$CXX
+do
+if test "${ac_cv_prog_ac_ct_CXX+set}" = set; then
+else
+  if test -n "$ac_ct_CXX"; then
+  ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CXX="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
+if test -n "$ac_ct_CXX"; then
+  echo "$as_me:$LINENO: result: $ac_ct_CXX" >&5
+echo "${ECHO_T}$ac_ct_CXX" >&6
+else
+fi
+  test -n "$ac_ct_CXX" && break
+done
+test -n "$ac_ct_CXX" || ac_ct_CXX="g++"
+  CXX=$ac_ct_CXX
+fi
+     "checking for C++ compiler version" >&5
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+echo "$as_me:$LINENO: checking whether we are using the GNU C++ compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU C++ compiler... $ECHO_C" >&6
+if test "${ac_cv_cxx_compiler_gnu+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#ifndef __GNUC__
+       choke me
+#endif
+  return 0;
+_ACEOF
+  ac_status=$?
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+  ac_status=$?
+  ac_status=$?
+else
+ac_compiler_gnu=no
+fi
+ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_cxx_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_cxx_compiler_gnu" >&6
+GXX=`test $ac_compiler_gnu = yes && echo yes`
+ac_test_CXXFLAGS=${CXXFLAGS+set}
+ac_save_CXXFLAGS=$CXXFLAGS
+CXXFLAGS="-g"
+echo "$as_me:$LINENO: checking whether $CXX accepts -g" >&5
+echo $ECHO_N "checking whether $CXX accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_cxx_g+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_cxx_g=yes
+else
+ac_cv_prog_cxx_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
+echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6
+if test "$ac_test_CXXFLAGS" = set; then
+  CXXFLAGS=$ac_save_CXXFLAGS
+elif test $ac_cv_prog_cxx_g = yes; then
+  if test "$GXX" = yes; then
+    CXXFLAGS="-g -O2"
+  else
+    CXXFLAGS="-g"
+  fi
+else
+    CXXFLAGS="-O2"
+  else
+    CXXFLAGS=
+  fi
+fi
+for ac_declaration in \
+do
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  break
+else
+fi
+done
+rm -f conftest*
+fi
+ac_ext=c
+# Check whether --enable-shared or --disable-shared was given.
+if test "${enable_shared+set}" = set; then
+  enableval="$enable_shared"
+  p=${PACKAGE-default}
+    case $enableval in
+    yes) enable_shared=yes ;;
+    no) enable_shared=no ;;
+      enable_shared=no
+      # Look at the argument we got.  We use all the common list separators.
+      lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+      for pkg in $enableval; do
+	IFS="$lt_save_ifs"
+	if test "X$pkg" = "X$p"; then
+	  enable_shared=yes
+	fi
+      done
+    esac
+else
+  enable_shared=yes
+fi;
+# Check whether --enable-static or --disable-static was given.
+if test "${enable_static+set}" = set; then
+  enableval="$enable_static"
+    yes) enable_static=yes ;;
+    no) enable_static=no ;;
+     enable_static=no
+	  enable_static=yes
+	fi
+      done
+    esac
+else
+  enable_static=yes
+fi;
+# Check whether --enable-fast-install or --disable-fast-install was given.
+if test "${enable_fast_install+set}" = set; then
+  enableval="$enable_fast_install"
+    yes) enable_fast_install=yes ;;
+    no) enable_fast_install=no ;;
+      enable_fast_install=no
+	  enable_fast_install=yes
+	fi
+      done
+    esac
+else
+fi;
+echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
+echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
+if test "${lt_cv_path_SED+set}" = set; then
+else
+  # Loop through the user's path and test for sed and gsed.
+# Then use that list of sed's as ones to test for truncation.
+do
+  IFS=$as_save_IFS
+  for lt_ac_prog in sed gsed; do
+      if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
+        lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
+      fi
+    done
+  done
+done
+lt_ac_max=0
+lt_ac_count=0
+# Add /usr/xpg4/bin/sed as it is typically found on Solaris
+# along with /bin/sed that truncates output.
+for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
+  test ! -f $lt_ac_sed && continue
+  cat /dev/null > conftest.in
+  lt_ac_count=0
+  echo $ECHO_N "0123456789$ECHO_C" >conftest.in
+  # Check for GNU sed and select it if it is found.
+  if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
+    lt_cv_path_SED=$lt_ac_sed
+    break
+  fi
+  while true; do
+    cat conftest.in conftest.in >conftest.tmp
+    mv conftest.tmp conftest.in
+    cp conftest.in conftest.nl
+    echo >>conftest.nl
+    $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
+    cmp -s conftest.out conftest.nl || break
+    # 10000 chars as input seems more than enough
+    test $lt_ac_count -gt 10 && break
+    lt_ac_count=`expr $lt_ac_count + 1`
+    if test $lt_ac_count -gt $lt_ac_max; then
+      lt_ac_max=$lt_ac_count
+    fi
+  done
+done
+fi
+SED=$lt_cv_path_SED
+echo "$as_me:$LINENO: result: $SED" >&5
+echo "${ECHO_T}$SED" >&6
+echo "$as_me:$LINENO: checking for egrep" >&5
+echo $ECHO_N "checking for egrep... $ECHO_C" >&6
+if test "${ac_cv_prog_egrep+set}" = set; then
+else
+  if echo a | (grep -E '(a|b)') >/dev/null 2>&1
+    then ac_cv_prog_egrep='grep -E'
+    else ac_cv_prog_egrep='egrep'
+    fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
+echo "${ECHO_T}$ac_cv_prog_egrep" >&6
+ EGREP=$ac_cv_prog_egrep
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+  withval="$with_gnu_ld"
+  test "$withval" = no || with_gnu_ld=yes
+else
+  with_gnu_ld=no
+fi;
+ac_prog=ld
+if test "$GCC" = yes; then
+  # Check if gcc -print-prog-name=ld gives a path.
+  echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+  case $host in
+  *-*-mingw*)
+    # gcc leaves a trailing carriage return which upsets mingw
+    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
+    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+  esac
+  case $ac_prog in
+    # Accept absolute paths.
+      re_direlt='/[^/][^/]*/\.\./'
+      # Canonicalize the pathname of ld
+      ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+      while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+	ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+      done
+      test -z "$LD" && LD="$ac_prog"
+    # If it fails, then pretend we aren't using GCC.
+    ac_prog=ld
+    # If it is relative, then search for the first ld in PATH.
+    with_gnu_ld=unknown
+  esac
+elif test "$with_gnu_ld" = yes; then
+  echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+  echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+  if test -z "$LD"; then
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for ac_dir in $PATH; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+      lt_cv_path_LD="$ac_dir/$ac_prog"
+      # Check to see if the program is GNU ld.  I'd rather use --version,
+      # but apparently some variants of GNU ld only accept -v.
+      # Break only if it was the GNU/non-GNU ld that we prefer.
+      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+      *GNU* | *'with BFD'*)
+	test "$with_gnu_ld" != no && break
+	test "$with_gnu_ld" != yes && break
+      esac
+    fi
+  done
+else
+  lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+  echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+  lt_cv_prog_gnu_ld=yes
+  lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+echo "$as_me:$LINENO: checking for $LD option to reload object files" >&5
+echo $ECHO_N "checking for $LD option to reload object files... $ECHO_C" >&6
+if test "${lt_cv_ld_reload_flag+set}" = set; then
+else
+  lt_cv_ld_reload_flag='-r'
+fi
+echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
+echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
+reload_flag=$lt_cv_ld_reload_flag
+case $reload_flag in
+*) reload_flag=" $reload_flag" ;;
+esac
+reload_cmds='$LD$reload_flag -o $output$reload_objs'
+case $host_os in
+  darwin*)
+      reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
+    else
+      reload_cmds='$LD$reload_flag -o $output$reload_objs'
+    fi
+esac
+echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
+echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
+if test "${lt_cv_path_NM+set}" = set; then
+else
+  if test -n "$NM"; then
+  # Let the user override the test.
+  lt_cv_path_NM="$NM"
+else
+  lt_nm_to_check="${ac_tool_prefix}nm"
+  if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
+    lt_nm_to_check="$lt_nm_to_check nm"
+  fi
+  for lt_tmp_nm in $lt_nm_to_check; do
+    for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
+      tmp_nm="$ac_dir/$lt_tmp_nm"
+      if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
+	# Check to see if the nm accepts a BSD-compat flag.
+	# Adding the `sed 1q' prevents false positives on HP-UX, which says:
+	#   nm: unknown option "B" ignored
+	# Tru64's nm complains that /dev/null is an invalid object file
+	case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
+	*/dev/null* | *'Invalid file or object type'*)
+	  lt_cv_path_NM="$tmp_nm -B"
+	  break
+	  case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
+	  */dev/null*)
+	    lt_cv_path_NM="$tmp_nm -p"
+	    break
+	    lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
+	    continue # so that we can try to find one that supports BSD flags
+	  esac
+	esac
+      fi
+    done
+  done
+  test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
+fi
+fi
+echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
+echo "${ECHO_T}$lt_cv_path_NM" >&6
+NM="$lt_cv_path_NM"
+echo "$as_me:$LINENO: checking whether ln -s works" >&5
+echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
+LN_S=$as_ln_s
+if test "$LN_S" = "ln -s"; then
+  echo "$as_me:$LINENO: result: yes" >&5
+else
+  echo "$as_me:$LINENO: result: no, using $LN_S" >&5
+echo "${ECHO_T}no, using $LN_S" >&6
+fi
+echo "$as_me:$LINENO: checking how to recognise dependent libraries" >&5
+echo $ECHO_N "checking how to recognise dependent libraries... $ECHO_C" >&6
+if test "${lt_cv_deplibs_check_method+set}" = set; then
+else
+  lt_cv_file_magic_cmd='$MAGIC_CMD'
+lt_cv_file_magic_test_file=
+lt_cv_deplibs_check_method='unknown'
+# Need to set the preceding variable on all platforms that support
+# interlibrary dependencies.
+# 'none' -- dependencies not supported.
+# `unknown' -- same as none, but documents that we really don't know.
+# 'pass_all' -- all dependencies passed with no checks.
+# 'test_compile' -- check by making test program.
+# 'file_magic [[regex]]' -- check by looking for files in library path
+# which responds to the $file_magic_cmd with a given extended regex.
+# If you have `file' or equivalent on your system and you're not sure
+# whether `pass_all' will *always* work, you probably want this one.
+case $host_os in
+aix4* | aix5*)
+  lt_cv_deplibs_check_method=pass_all
+beos*)
+bsdi[45]*)
+  lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
+  lt_cv_file_magic_cmd='/usr/bin/file -L'
+  lt_cv_file_magic_test_file=/shlib/libc.so
+cygwin*)
+  # func_win32_libid is a shell function defined in ltmain.sh
+  lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
+  lt_cv_file_magic_cmd='func_win32_libid'
+mingw* | pw32*)
+  # Base MSYS/MinGW do not provide the 'file' command needed by
+  # func_win32_libid shell function, so use a weaker test based on 'objdump'.
+  lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
+  lt_cv_file_magic_cmd='$OBJDUMP -f'
+darwin* | rhapsody*)
+freebsd* | dragonfly*)
+  if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
+    case $host_cpu in
+    i*86 )
+      # Not sure whether the presence of OpenBSD here was a mistake.
+      # Let's accept both of them until this is cleared up.
+      lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
+      lt_cv_file_magic_cmd=/usr/bin/file
+      lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
+    esac
+  else
+  fi
+gnu*)
+hpux10.20* | hpux11*)
+  case $host_cpu in
+  ia64*)
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
+    lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
+  hppa*64*)
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
+    lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+    lt_cv_file_magic_test_file=/usr/lib/libc.sl
+  esac
+interix3*)
+  # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
+  lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
+irix5* | irix6* | nonstopux*)
+  case $LD in
+  *-32|*"-32 ") libmagic=32-bit;;
+  *-n32|*"-n32 ") libmagic=N32;;
+  *-64|*"-64 ") libmagic=64-bit;;
+  *) libmagic=never-match;;
+  esac
+# This must be Linux ELF.
+linux* | k*bsd*-gnu)
+netbsd* | netbsdelf*-gnu)
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
+  else
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
+  fi
+newos6*)
+  lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (executable|dynamic lib)'
+  lt_cv_file_magic_test_file=/usr/lib/libnls.so
+nto-qnx*)
+  lt_cv_deplibs_check_method=unknown
+openbsd*)
+  if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
+  else
+  fi
+osf3* | osf4* | osf5*)
+solaris*)
+sysv4 | sysv4.3*)
+  case $host_vendor in
+  motorola)
+    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
+    lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
+  ncr)
+  sequent)
+    lt_cv_file_magic_cmd='/bin/file'
+    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )'
+  sni)
+    lt_cv_deplibs_check_method="file_magic ELF [0-9][0-9]*-bit [LM]SB dynamic lib"
+    lt_cv_file_magic_test_file=/lib/libc.so
+  siemens)
+  pc)
+  esac
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_deplibs_check_method" >&5
+echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
+file_magic_cmd=$lt_cv_file_magic_cmd
+deplibs_check_method=$lt_cv_deplibs_check_method
+test -z "$deplibs_check_method" && deplibs_check_method=unknown
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
+if test "${enable_libtool_lock+set}" = set; then
+  enableval="$enable_libtool_lock"
+fi;
+test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
+# Some flags need to be propagated to the compiler or linker for good
+# libtool support.
+case $host in
+ia64-*-hpux*)
+  # Find out which ABI we are using.
+  echo 'int i;' > conftest.$ac_ext
+  if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  ac_status=$?
+    case `/usr/bin/file conftest.$ac_objext` in
+    *ELF-32*)
+      HPUX_IA64_MODE="32"
+    *ELF-64*)
+      HPUX_IA64_MODE="64"
+    esac
+  fi
+  rm -rf conftest*
+*-*-irix6*)
+  echo '#line 3512 "configure"' > conftest.$ac_ext
+  ac_status=$?
+   if test "$lt_cv_prog_gnu_ld" = yes; then
+    *32-bit*)
+      LD="${LD-ld} -melf32bsmip"
+    *N32*)
+      LD="${LD-ld} -melf32bmipn32"
+    *64-bit*)
+      LD="${LD-ld} -melf64bmip"
+    esac
+   else
+    *32-bit*)
+      LD="${LD-ld} -32"
+    *N32*)
+      LD="${LD-ld} -n32"
+    *64-bit*)
+      LD="${LD-ld} -64"
+    esac
+   fi
+  fi
+  rm -rf conftest*
+x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
+  ac_status=$?
+    case `/usr/bin/file conftest.o` in
+    *32-bit*)
+      case $host in
+        x86_64-*linux*)
+          LD="${LD-ld} -m elf_i386"
+        ppc64-*linux*|powerpc64-*linux*)
+          LD="${LD-ld} -m elf32ppclinux"
+        s390x-*linux*)
+          LD="${LD-ld} -m elf_s390"
+        sparc64-*linux*)
+          LD="${LD-ld} -m elf32_sparc"
+      esac
+    *64-bit*)
+      case $host in
+        x86_64-*linux*)
+          LD="${LD-ld} -m elf_x86_64"
+        ppc*-*linux*|powerpc*-*linux*)
+          LD="${LD-ld} -m elf64ppc"
+        s390*-*linux*)
+          LD="${LD-ld} -m elf64_s390"
+        sparc*-*linux*)
+          LD="${LD-ld} -m elf64_sparc"
+      esac
+    esac
+  fi
+  rm -rf conftest*
+*-*-sco3.2v5*)
+  # On SCO OpenServer 5, we need -belf to get full-featured binaries.
+  SAVE_CFLAGS="$CFLAGS"
+  CFLAGS="$CFLAGS -belf"
+  echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
+echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
+if test "${lt_cv_cc_needs_belf+set}" = set; then
+else
+  ac_ext=c
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  ac_status=$?
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  lt_cv_cc_needs_belf=yes
+else
+lt_cv_cc_needs_belf=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+     ac_ext=c
+fi
+echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
+echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
+  if test x"$lt_cv_cc_needs_belf" != x"yes"; then
+    # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
+    CFLAGS="$SAVE_CFLAGS"
+  fi
+sparc*-*solaris*)
+  ac_status=$?
+    *64-bit*)
+      case $lt_cv_prog_gnu_ld in
+      yes*) LD="${LD-ld} -m elf64_sparc" ;;
+      *)    LD="${LD-ld} -64" ;;
+      esac
+    esac
+  fi
+  rm -rf conftest*
+*-*-cygwin* | *-*-mingw* | *-*-pw32*)
+  # Extract the first word of "${ac_tool_prefix}dlltool", so it can be a program name with args.
+set dummy ${ac_tool_prefix}dlltool; ac_word=$2
+if test "${ac_cv_prog_DLLTOOL+set}" = set; then
+else
+  if test -n "$DLLTOOL"; then
+  ac_cv_prog_DLLTOOL="$DLLTOOL" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_DLLTOOL="${ac_tool_prefix}dlltool"
+    break 2
+  fi
+done
+done
+fi
+fi
+DLLTOOL=$ac_cv_prog_DLLTOOL
+if test -n "$DLLTOOL"; then
+  echo "$as_me:$LINENO: result: $DLLTOOL" >&5
+echo "${ECHO_T}$DLLTOOL" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_DLLTOOL"; then
+  ac_ct_DLLTOOL=$DLLTOOL
+  # Extract the first word of "dlltool", so it can be a program name with args.
+set dummy dlltool; ac_word=$2
+if test "${ac_cv_prog_ac_ct_DLLTOOL+set}" = set; then
+else
+  if test -n "$ac_ct_DLLTOOL"; then
+  ac_cv_prog_ac_ct_DLLTOOL="$ac_ct_DLLTOOL" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_DLLTOOL="dlltool"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_DLLTOOL" && ac_cv_prog_ac_ct_DLLTOOL="false"
+fi
+fi
+ac_ct_DLLTOOL=$ac_cv_prog_ac_ct_DLLTOOL
+if test -n "$ac_ct_DLLTOOL"; then
+  echo "$as_me:$LINENO: result: $ac_ct_DLLTOOL" >&5
+echo "${ECHO_T}$ac_ct_DLLTOOL" >&6
+else
+fi
+  DLLTOOL=$ac_ct_DLLTOOL
+else
+  DLLTOOL="$ac_cv_prog_DLLTOOL"
+fi
+  # Extract the first word of "${ac_tool_prefix}as", so it can be a program name with args.
+set dummy ${ac_tool_prefix}as; ac_word=$2
+if test "${ac_cv_prog_AS+set}" = set; then
+else
+  if test -n "$AS"; then
+  ac_cv_prog_AS="$AS" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_AS="${ac_tool_prefix}as"
+    break 2
+  fi
+done
+done
+fi
+fi
+AS=$ac_cv_prog_AS
+if test -n "$AS"; then
+  echo "$as_me:$LINENO: result: $AS" >&5
+echo "${ECHO_T}$AS" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_AS"; then
+  ac_ct_AS=$AS
+  # Extract the first word of "as", so it can be a program name with args.
+set dummy as; ac_word=$2
+if test "${ac_cv_prog_ac_ct_AS+set}" = set; then
+else
+  if test -n "$ac_ct_AS"; then
+  ac_cv_prog_ac_ct_AS="$ac_ct_AS" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_AS="as"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_AS" && ac_cv_prog_ac_ct_AS="false"
+fi
+fi
+ac_ct_AS=$ac_cv_prog_ac_ct_AS
+if test -n "$ac_ct_AS"; then
+  echo "$as_me:$LINENO: result: $ac_ct_AS" >&5
+echo "${ECHO_T}$ac_ct_AS" >&6
+else
+fi
+  AS=$ac_ct_AS
+else
+  AS="$ac_cv_prog_AS"
+fi
+  # Extract the first word of "${ac_tool_prefix}objdump", so it can be a program name with args.
+set dummy ${ac_tool_prefix}objdump; ac_word=$2
+if test "${ac_cv_prog_OBJDUMP+set}" = set; then
+else
+  if test -n "$OBJDUMP"; then
+  ac_cv_prog_OBJDUMP="$OBJDUMP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_OBJDUMP="${ac_tool_prefix}objdump"
+    break 2
+  fi
+done
+done
+fi
+fi
+OBJDUMP=$ac_cv_prog_OBJDUMP
+if test -n "$OBJDUMP"; then
+  echo "$as_me:$LINENO: result: $OBJDUMP" >&5
+echo "${ECHO_T}$OBJDUMP" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_OBJDUMP"; then
+  ac_ct_OBJDUMP=$OBJDUMP
+  # Extract the first word of "objdump", so it can be a program name with args.
+set dummy objdump; ac_word=$2
+if test "${ac_cv_prog_ac_ct_OBJDUMP+set}" = set; then
+else
+  if test -n "$ac_ct_OBJDUMP"; then
+  ac_cv_prog_ac_ct_OBJDUMP="$ac_ct_OBJDUMP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_OBJDUMP="objdump"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_OBJDUMP" && ac_cv_prog_ac_ct_OBJDUMP="false"
+fi
+fi
+ac_ct_OBJDUMP=$ac_cv_prog_ac_ct_OBJDUMP
+if test -n "$ac_ct_OBJDUMP"; then
+  echo "$as_me:$LINENO: result: $ac_ct_OBJDUMP" >&5
+echo "${ECHO_T}$ac_ct_OBJDUMP" >&6
+else
+fi
+  OBJDUMP=$ac_ct_OBJDUMP
+else
+  OBJDUMP="$ac_cv_prog_OBJDUMP"
+fi
+esac
+need_locks="$enable_libtool_lock"
+ac_ext=c
+echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
+# On Suns, sometimes $CPP names a directory.
+if test -n "$CPP" && test -d "$CPP"; then
+  CPP=
+fi
+if test -z "$CPP"; then
+  if test "${ac_cv_prog_CPP+set}" = set; then
+else
+      # Double quotes because CPP needs to be expanded
+    for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
+    do
+      ac_preproc_ok=false
+for ac_c_preproc_warn_flag in '' yes
+do
+  # Use a header file that comes with gcc, so configuring glibc
+  # with a fresh cross-compiler works.
+  # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+  # <limits.h> exists even on freestanding compilers.
+  # On the NeXT, cc -E runs the code through the compiler's parser,
+  # not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+		     Syntax error
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+  (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+  ac_status=$?
+  (exit $ac_status); } >/dev/null; then
+  if test -s conftest.err; then
+    ac_cpp_err=$ac_c_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+else
+  # Broken: fails on valid input.
+continue
+fi
+rm -f conftest.err conftest.$ac_ext
+  # OK, works on sane cases.  Now check whether non-existent headers
+  # can be detected and how.
+/* confdefs.h.  */
+_ACEOF
+#include <ac_nonexistent.h>
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+  # Broken: success on invalid input.
+continue
+else
+  # Passes both tests.
+ac_preproc_ok=:
+break
+fi
+done
+# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
+if $ac_preproc_ok; then
+  break
+fi
+    done
+    ac_cv_prog_CPP=$CPP
+fi
+  CPP=$ac_cv_prog_CPP
+else
+fi
+echo "$as_me:$LINENO: result: $CPP" >&5
+echo "${ECHO_T}$CPP" >&6
+ac_preproc_ok=false
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+  { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
+echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
+   { (exit 1); exit 1; }; }
+fi
+ac_ext=c
+echo "$as_me:$LINENO: checking for ANSI C header files" >&5
+echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
+if test "${ac_cv_header_stdc+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <string.h>
+#include <float.h>
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_header_stdc=yes
+else
+ac_cv_header_stdc=no
+fi
+if test $ac_cv_header_stdc = yes; then
+  # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
+  $EGREP "memchr" >/dev/null 2>&1; then
+else
+  ac_cv_header_stdc=no
+fi
+rm -f conftest*
+fi
+  # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  $EGREP "free" >/dev/null 2>&1; then
+else
+fi
+rm -f conftest*
+fi
+  # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
+  if test "$cross_compiling" = yes; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <ctype.h>
+#if ((' ' & 0x0FF) == 0x020)
+# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
+# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
+#else
+# define ISLOWER(c) \
+		   (('a' <= (c) && (c) <= 'i') \
+		     || ('j' <= (c) && (c) <= 'r') \
+		     || ('s' <= (c) && (c) <= 'z'))
+# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
+#endif
+#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
+int
+main ()
+  int i;
+  for (i = 0; i < 256; i++)
+    if (XOR (islower (i), ISLOWER (i))
+	|| toupper (i) != TOUPPER (i))
+      exit(2);
+  exit (0);
+_ACEOF
+rm -f conftest$ac_exeext
+  ac_status=$?
+  (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+  ac_status=$?
+else
+  echo "$as_me: program exited with status $ac_status" >&5
+echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+fi
+rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+fi
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
+echo "${ECHO_T}$ac_cv_header_stdc" >&6
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
+fi
+# On IRIX 5.3, sys/types and inttypes.h are conflicting.
+for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
+		  inttypes.h stdint.h unistd.h
+do
+as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
+echo "$as_me:$LINENO: checking for $ac_header" >&5
+echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
+if eval "test \"\${$as_ac_Header+set}\" = set"; then
+else
+/* confdefs.h.  */
+_ACEOF
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  eval "$as_ac_Header=yes"
+else
+eval "$as_ac_Header=no"
+fi
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
+if test `eval echo '${'$as_ac_Header'}'` = yes; then
+  cat >>confdefs.h <<_ACEOF
+#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
+_ACEOF
+fi
+done
+for ac_header in dlfcn.h
+do
+  echo "$as_me:$LINENO: checking for $ac_header" >&5
+fi
+else
+  # Is the header compilable?
+echo "$as_me:$LINENO: checking $ac_header usability" >&5
+echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_header_compiler=yes
+else
+ac_header_compiler=no
+fi
+echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+echo "${ECHO_T}$ac_header_compiler" >&6
+# Is the header present?
+echo "$as_me:$LINENO: checking $ac_header presence" >&5
+echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+  ac_header_preproc=yes
+else
+  ac_header_preproc=no
+fi
+echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+echo "${ECHO_T}$ac_header_preproc" >&6
+# So?  What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+  yes:no: )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+  no:yes:* )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $ac_header:     check for missing prerequisite headers?" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+      cat <<\_ASBOX
+## Report this to the AC_PACKAGE_NAME lists.  ##
+_ASBOX
+      sed "s/^/$as_me: WARNING:     /" >&2
+esac
+else
+  eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
+_ACEOF
+fi
+done
+if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+    (test "X$CXX" != "Xg++"))) ; then
+  ac_ext=cc
+echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
+echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
+if test -z "$CXXCPP"; then
+  if test "${ac_cv_prog_CXXCPP+set}" = set; then
+else
+      # Double quotes because CXXCPP needs to be expanded
+    for CXXCPP in "$CXX -E" "/lib/cpp"
+    do
+for ac_cxx_preproc_warn_flag in '' yes
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+    ac_cpp_err=$ac_cxx_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+  break
+fi
+    done
+    ac_cv_prog_CXXCPP=$CXXCPP
+fi
+  CXXCPP=$ac_cv_prog_CXXCPP
+else
+fi
+echo "$as_me:$LINENO: result: $CXXCPP" >&5
+echo "${ECHO_T}$CXXCPP" >&6
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+  { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+fi
+ac_ext=cc
+fi
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+  for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
+  do
+if test "${ac_cv_prog_F77+set}" = set; then
+else
+  if test -n "$F77"; then
+  ac_cv_prog_F77="$F77" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+F77=$ac_cv_prog_F77
+if test -n "$F77"; then
+  echo "$as_me:$LINENO: result: $F77" >&5
+echo "${ECHO_T}$F77" >&6
+else
+fi
+    test -n "$F77" && break
+  done
+fi
+if test -z "$F77"; then
+  ac_ct_F77=$F77
+do
+if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
+else
+  if test -n "$ac_ct_F77"; then
+  ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_F77="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+ac_ct_F77=$ac_cv_prog_ac_ct_F77
+if test -n "$ac_ct_F77"; then
+  echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
+echo "${ECHO_T}$ac_ct_F77" >&6
+else
+fi
+  test -n "$ac_ct_F77" && break
+done
+  F77=$ac_ct_F77
+fi
+echo "$as_me:4889:" \
+     "checking for Fortran 77 compiler version" >&5
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+rm -f a.out
+# If we don't use `.F' as extension, the preprocessor is not run on the
+# input file.  (Note that this only needs to work for GNU compilers.)
+ac_save_ext=$ac_ext
+ac_ext=F
+echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
+if test "${ac_cv_f77_compiler_gnu+set}" = set; then
+else
+      program main
+#ifndef __GNUC__
+       choke me
+#endif
+      end
+_ACEOF
+  ac_status=$?
+	 { ac_try='test -z "$ac_f77_werror_flag"
+  ac_status=$?
+  ac_status=$?
+else
+ac_compiler_gnu=no
+fi
+ac_cv_f77_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
+ac_ext=$ac_save_ext
+ac_test_FFLAGS=${FFLAGS+set}
+ac_save_FFLAGS=$FFLAGS
+FFLAGS=
+echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
+echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_f77_g+set}" = set; then
+else
+  FFLAGS=-g
+      program main
+      end
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_f77_g=yes
+else
+ac_cv_prog_f77_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
+echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
+if test "$ac_test_FFLAGS" = set; then
+  FFLAGS=$ac_save_FFLAGS
+elif test $ac_cv_prog_f77_g = yes; then
+  if test "x$ac_cv_f77_compiler_gnu" = xyes; then
+    FFLAGS="-g -O2"
+  else
+    FFLAGS="-g"
+  fi
+else
+    FFLAGS="-O2"
+  else
+    FFLAGS=
+  fi
+fi
+G77=`test $ac_compiler_gnu = yes && echo yes`
+ac_ext=c
+# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
+# find the maximum length of command line arguments
+echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
+echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
+if test "${lt_cv_sys_max_cmd_len+set}" = set; then
+else
+    i=0
+  teststring="ABCD"
+  case $build_os in
+  msdosdjgpp*)
+    # On DJGPP, this test can blow up pretty badly due to problems in libc
+    # (any single argument exceeding 2000 bytes causes a buffer overrun
+    # during glob expansion).  Even if it were fixed, the result of this
+    # check would be larger than it should be.
+    lt_cv_sys_max_cmd_len=12288;    # 12K is about right
+  gnu*)
+    # Under GNU Hurd, this test is not required because there is
+    # no limit to the length of command line arguments.
+    # Libtool will interpret -1 as no limit whatsoever
+    lt_cv_sys_max_cmd_len=-1;
+  cygwin* | mingw*)
+    # On Win9x/ME, this test blows up -- it succeeds, but takes
+    # about 5 minutes as the teststring grows exponentially.
+    # Worse, since 9x/ME are not pre-emptively multitasking,
+    # you end up with a "frozen" computer, even though with patience
+    # the test eventually succeeds (with a max line length of 256k).
+    # Instead, let's just punt: use the minimum linelength reported by
+    # all of the supported platforms: 8192 (on NT/2K/XP).
+    lt_cv_sys_max_cmd_len=8192;
+  amigaos*)
+    # On AmigaOS with pdksh, this test takes hours, literally.
+    # So we just punt and use a minimum line length of 8192.
+  netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
+    # This has been around since 386BSD, at least.  Likely further.
+    if test -x /sbin/sysctl; then
+      lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
+    elif test -x /usr/sbin/sysctl; then
+      lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
+    else
+      lt_cv_sys_max_cmd_len=65536	# usable default for all BSDs
+    fi
+    # And add a safety zone
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
+  interix*)
+    # We know the value 262144 and hardcode it with a safety zone (like BSD)
+    lt_cv_sys_max_cmd_len=196608
+  osf*)
+    # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
+    # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
+    # nice to cause kernel panics so lets avoid the loop below.
+    # First set a reasonable default.
+    lt_cv_sys_max_cmd_len=16384
+    if test -x /sbin/sysconfig; then
+      case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
+        *1*) lt_cv_sys_max_cmd_len=-1 ;;
+      esac
+    fi
+  sco3.2v5*)
+    lt_cv_sys_max_cmd_len=102400
+  sysv5* | sco5v6* | sysv4.2uw2*)
+    kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
+    if test -n "$kargmax"; then
+      lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ 	]//'`
+    else
+      lt_cv_sys_max_cmd_len=32768
+    fi
+    # If test is not a shell built-in, we'll probably end up computing a
+    # maximum length that is only half of the actual maximum length, but
+    # we can't tell.
+    SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
+    while (test "X"`$SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
+	       = "XX$teststring") >/dev/null 2>&1 &&
+	    new_result=`expr "X$teststring" : ".*" 2>&1` &&
+	    lt_cv_sys_max_cmd_len=$new_result &&
+	    test $i != 17 # 1/2 MB should be enough
+    do
+      i=`expr $i + 1`
+      teststring=$teststring$teststring
+    done
+    teststring=
+    # Add a significant safety factor because C++ compilers can tack on massive
+    # amounts of additional arguments before passing them to the linker.
+    # It appears as though 1/2 is a usable value.
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
+  esac
+fi
+if test -n $lt_cv_sys_max_cmd_len ; then
+  echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
+echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
+else
+  echo "$as_me:$LINENO: result: none" >&5
+echo "${ECHO_T}none" >&6
+fi
+# Check for command to grab the raw symbol name followed by C symbol from nm.
+echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
+echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
+if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
+else
+# These are sane defaults that work on at least a few old systems.
+# [They come from Ultrix.  What could be older than Ultrix?!! ;)]
+# Character class describing NM global symbol codes.
+symcode='[BCDEGRST]'
+# Regexp to match symbols that can be accessed directly from C.
+sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
+# Transform an extracted symbol line into a proper C declaration
+lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
+# Transform an extracted symbol line into symbol name and symbol address
+lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
+# Define system-specific variables.
+case $host_os in
+aix*)
+  symcode='[BCDT]'
+cygwin* | mingw* | pw32*)
+  symcode='[ABCDGISTW]'
+hpux*) # Its linker distinguishes data from code symbols
+  if test "$host_cpu" = ia64; then
+    symcode='[ABCDEGRST]'
+  fi
+  lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
+  lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
+    symcode='[ABCDGIRSTW]'
+  fi
+irix* | nonstopux*)
+  symcode='[BCDEGRST]'
+osf*)
+  symcode='[BCDEGQRST]'
+solaris*)
+  symcode='[BDRT]'
+sco3.2v5*)
+  symcode='[DT]'
+sysv4.2uw2*)
+  symcode='[DT]'
+sysv5* | sco5v6* | unixware* | OpenUNIX*)
+  symcode='[ABDT]'
+sysv4)
+  symcode='[DFNSTU]'
+esac
+# Handle CRLF in mingw tool chain
+opt_cr=
+case $build_os in
+mingw*)
+  opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+esac
+# If we're using GNU nm, then use its standard symbol codes.
+case `$NM -V 2>&1` in
+  symcode='[ABCDGIRSTW]' ;;
+esac
+# Try without a prefix undercore, then with it.
+for ac_symprfx in "" "_"; do
+  # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
+  symxfrm="\\1 $ac_symprfx\\2 \\2"
+  # Write the raw and C identifiers.
+  lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ 	]\($symcode$symcode*\)[ 	][ 	]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
+  # Check to see that the pipe works correctly.
+  pipe_works=no
+  rm -f conftest*
+  cat > conftest.$ac_ext <<EOF
+#ifdef __cplusplus
+extern "C" {
+#endif
+char nm_test_var;
+void nm_test_func(){}
+#ifdef __cplusplus
+#endif
+int main(){nm_test_var='a';nm_test_func();return(0);}
+EOF
+  ac_status=$?
+    # Now try to grab the symbols.
+    nlist=conftest.nm
+    if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
+  (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+  ac_status=$?
+  (exit $ac_status); } && test -s "$nlist"; then
+      # Try sorting and uniquifying the output.
+      if sort "$nlist" | uniq > "$nlist"T; then
+	mv -f "$nlist"T "$nlist"
+      else
+	rm -f "$nlist"T
+      fi
+      # Make sure that we snagged all the symbols we need.
+      if grep ' nm_test_var$' "$nlist" >/dev/null; then
+	if grep ' nm_test_func$' "$nlist" >/dev/null; then
+	  cat <<EOF > conftest.$ac_ext
+#ifdef __cplusplus
+extern "C" {
+#endif
+EOF
+	  # Now generate the symbol file.
+	  eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
+	  cat <<EOF >> conftest.$ac_ext
+#if defined (__STDC__) && __STDC__
+# define lt_ptr_t void *
+#else
+# define lt_ptr_t char *
+# define const
+#endif
+/* The mapping between symbol names and symbols. */
+const struct {
+  const char *name;
+  lt_ptr_t address;
+lt_preloaded_symbols[] =
+EOF
+	  $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/  {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
+	  cat <<\EOF >> conftest.$ac_ext
+  {0, (lt_ptr_t) 0}
+#ifdef __cplusplus
+#endif
+EOF
+	  # Now try linking the two files.
+	  mv conftest.$ac_objext conftstm.$ac_objext
+	  lt_save_LIBS="$LIBS"
+	  lt_save_CFLAGS="$CFLAGS"
+	  LIBS="conftstm.$ac_objext"
+	  CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
+	  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  ac_status=$?
+  (exit $ac_status); } && test -s conftest${ac_exeext}; then
+	    pipe_works=yes
+	  fi
+	  LIBS="$lt_save_LIBS"
+	  CFLAGS="$lt_save_CFLAGS"
+	else
+	  echo "cannot find nm_test_func in $nlist" >&5
+	fi
+      else
+	echo "cannot find nm_test_var in $nlist" >&5
+      fi
+    else
+      echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
+    fi
+  else
+    echo "$progname: failed program was:" >&5
+    cat conftest.$ac_ext >&5
+  fi
+  rm -f conftest* conftst*
+  # Do not use the global_symbol_pipe unless it works.
+  if test "$pipe_works" = yes; then
+    break
+  else
+  fi
+done
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe"; then
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
+  echo "$as_me:$LINENO: result: failed" >&5
+echo "${ECHO_T}failed" >&6
+else
+  echo "$as_me:$LINENO: result: ok" >&5
+echo "${ECHO_T}ok" >&6
+fi
+echo "$as_me:$LINENO: checking for objdir" >&5
+echo $ECHO_N "checking for objdir... $ECHO_C" >&6
+if test "${lt_cv_objdir+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  rm -f .libs 2>/dev/null
+mkdir .libs 2>/dev/null
+if test -d .libs; then
+  lt_cv_objdir=.libs
+else
+  # MS-DOS does not allow filenames that begin with a dot.
+  lt_cv_objdir=_libs
+fi
+rmdir .libs 2>/dev/null
+fi
+echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
+echo "${ECHO_T}$lt_cv_objdir" >&6
+objdir=$lt_cv_objdir
+case $host_os in
+aix3*)
+  # AIX sometimes has problems with the GCC collect2 program.  For some
+  # reason, if we set the COLLECT_NAMES environment variable, the problems
+  # vanish in a puff of smoke.
+  if test "X${COLLECT_NAMES+set}" != Xset; then
+    COLLECT_NAMES=
+    export COLLECT_NAMES
+  fi
+esac
+# Sed substitution that helps us do robust quoting.  It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='sed -e 1s/^X//'
+sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
+# Same as above, but do not quote variable references.
+double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
+# Sed substitution to delay expansion of an escaped shell variable in a
+# double_quote_subst'ed string.
+delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
+# Sed substitution to avoid accidental globbing in evaled expressions
+no_glob_subst='s/\*/\\\*/g'
+# Constants:
+rm="rm -f"
+# Global variables:
+default_ofile=libtool
+can_build_shared=yes
+# All known linkers require a `.a' archive for static linking (except MSVC,
+# which needs '.lib').
+libext=a
+ltmain="$ac_aux_dir/ltmain.sh"
+ofile="$default_ofile"
+with_gnu_ld="$lt_cv_prog_gnu_ld"
+if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ar; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_AR+set}" = set; then
+else
+  if test -n "$AR"; then
+  ac_cv_prog_AR="$AR" # Let the user override the test.
+else
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+  for ac_exec_ext in '' $ac_executable_extensions; do
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_AR="${ac_tool_prefix}ar"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+fi
+fi
+AR=$ac_cv_prog_AR
+if test -n "$AR"; then
+  echo "$as_me:$LINENO: result: $AR" >&5
+echo "${ECHO_T}$AR" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+fi
+if test -z "$ac_cv_prog_AR"; then
+  ac_ct_AR=$AR
+  # Extract the first word of "ar", so it can be a program name with args.
+set dummy ar; ac_word=$2
+if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
+else
+  if test -n "$ac_ct_AR"; then
+  ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_AR="ar"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
+fi
+fi
+ac_ct_AR=$ac_cv_prog_ac_ct_AR
+if test -n "$ac_ct_AR"; then
+  echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
+echo "${ECHO_T}$ac_ct_AR" >&6
+else
+fi
+  AR=$ac_ct_AR
+else
+  AR="$ac_cv_prog_AR"
+fi
+  # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ranlib; ac_word=$2
+if test "${ac_cv_prog_RANLIB+set}" = set; then
+else
+  if test -n "$RANLIB"; then
+  ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
+    break 2
+  fi
+done
+done
+fi
+fi
+RANLIB=$ac_cv_prog_RANLIB
+if test -n "$RANLIB"; then
+  echo "$as_me:$LINENO: result: $RANLIB" >&5
+echo "${ECHO_T}$RANLIB" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_RANLIB"; then
+  ac_ct_RANLIB=$RANLIB
+  # Extract the first word of "ranlib", so it can be a program name with args.
+set dummy ranlib; ac_word=$2
+if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
+else
+  if test -n "$ac_ct_RANLIB"; then
+  ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_RANLIB="ranlib"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_RANLIB" && ac_cv_prog_ac_ct_RANLIB=":"
+fi
+fi
+ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
+if test -n "$ac_ct_RANLIB"; then
+  echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
+echo "${ECHO_T}$ac_ct_RANLIB" >&6
+else
+fi
+  RANLIB=$ac_ct_RANLIB
+else
+  RANLIB="$ac_cv_prog_RANLIB"
+fi
+  # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
+set dummy ${ac_tool_prefix}strip; ac_word=$2
+if test "${ac_cv_prog_STRIP+set}" = set; then
+else
+  if test -n "$STRIP"; then
+  ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_STRIP="${ac_tool_prefix}strip"
+    break 2
+  fi
+done
+done
+fi
+fi
+STRIP=$ac_cv_prog_STRIP
+if test -n "$STRIP"; then
+  echo "$as_me:$LINENO: result: $STRIP" >&5
+echo "${ECHO_T}$STRIP" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_STRIP"; then
+  ac_ct_STRIP=$STRIP
+  # Extract the first word of "strip", so it can be a program name with args.
+set dummy strip; ac_word=$2
+if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
+else
+  if test -n "$ac_ct_STRIP"; then
+  ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_STRIP="strip"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
+fi
+fi
+ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
+if test -n "$ac_ct_STRIP"; then
+  echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
+echo "${ECHO_T}$ac_ct_STRIP" >&6
+else
+fi
+  STRIP=$ac_ct_STRIP
+else
+  STRIP="$ac_cv_prog_STRIP"
+fi
+old_CC="$CC"
+old_CFLAGS="$CFLAGS"
+# Set sane defaults for various variables
+test -z "$AR" && AR=ar
+test -z "$AR_FLAGS" && AR_FLAGS=cru
+test -z "$AS" && AS=as
+test -z "$CC" && CC=cc
+test -z "$LTCC" && LTCC=$CC
+test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
+test -z "$DLLTOOL" && DLLTOOL=dlltool
+test -z "$LD" && LD=ld
+test -z "$LN_S" && LN_S="ln -s"
+test -z "$MAGIC_CMD" && MAGIC_CMD=file
+test -z "$NM" && NM=nm
+test -z "$SED" && SED=sed
+test -z "$OBJDUMP" && OBJDUMP=objdump
+test -z "$RANLIB" && RANLIB=:
+test -z "$STRIP" && STRIP=:
+test -z "$ac_objext" && ac_objext=o
+# Determine commands to create old-style static archives.
+old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
+old_postinstall_cmds='chmod 644 $oldlib'
+old_postuninstall_cmds=
+  case $host_os in
+  openbsd*)
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
+  esac
+  old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
+fi
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# Only perform the check for file, if the check method requires it
+case $deplibs_check_method in
+file_magic*)
+  if test "$file_magic_cmd" = '$MAGIC_CMD'; then
+    echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
+echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
+if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+else
+  case $MAGIC_CMD in
+  lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
+  lt_save_MAGIC_CMD="$MAGIC_CMD"
+  ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
+  for ac_dir in $ac_dummy; do
+    if test -f $ac_dir/${ac_tool_prefix}file; then
+      lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
+      if test -n "$file_magic_test_file"; then
+	case $deplibs_check_method in
+	"file_magic "*)
+	  file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
+	  MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+	  if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
+	    $EGREP "$file_magic_regex" > /dev/null; then
+	  else
+	    cat <<EOF 1>&2
+*** Warning: the command libtool uses to detect shared libraries,
+*** $file_magic_cmd, produces output that libtool cannot recognize.
+*** The result is that libtool may fail to recognize shared libraries
+*** as such.  This will affect the creation of libtool libraries that
+*** depend on shared libraries, but programs linked with such libtool
+*** libraries will work regardless of this problem.  Nevertheless, you
+*** may want to report the problem to your system manager and/or to
+*** bug-libtool at gnu.org
+EOF
+	  fi ;;
+	esac
+      fi
+      break
+    fi
+  done
+  MAGIC_CMD="$lt_save_MAGIC_CMD"
+esac
+fi
+MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+if test -n "$MAGIC_CMD"; then
+  echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
+echo "${ECHO_T}$MAGIC_CMD" >&6
+else
+fi
+if test -z "$lt_cv_path_MAGIC_CMD"; then
+  if test -n "$ac_tool_prefix"; then
+    echo "$as_me:$LINENO: checking for file" >&5
+echo $ECHO_N "checking for file... $ECHO_C" >&6
+else
+    if test -f $ac_dir/file; then
+      lt_cv_path_MAGIC_CMD="$ac_dir/file"
+	"file_magic "*)
+	  else
+	    cat <<EOF 1>&2
+EOF
+	  fi ;;
+	esac
+      fi
+      break
+    fi
+  done
+esac
+fi
+else
+fi
+  else
+    MAGIC_CMD=:
+  fi
+fi
+  fi
+esac
+enable_dlopen=no
+enable_win32_dll=yes
+fi;
+# Check whether --with-pic or --without-pic was given.
+if test "${with_pic+set}" = set; then
+  withval="$with_pic"
+  pic_mode="$withval"
+else
+  pic_mode=default
+fi;
+test -z "$pic_mode" && pic_mode=default
+# Use C for the default configuration in the libtool script
+tagname=
+lt_save_CC="$CC"
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+# Source file extension for C test sources.
+ac_ext=c
+# Object file extension for compiled C test sources.
+objext=o
+objext=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(){return(0);}\n'
+LTCC=${LTCC-"$CC"}
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+## CAVEAT EMPTOR:
+## There is no encapsulation within the following macros, do not change
+## the running order or otherwise move them around unless you know exactly
+## what you are doing...
+lt_prog_compiler_no_builtin_flag=
+  lt_prog_compiler_no_builtin_flag=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+else
+  lt_cv_prog_compiler_rtti_exceptions=no
+  ac_outfile=conftest.$ac_objext
+   printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+   lt_compiler_flag="-fno-rtti -fno-exceptions"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:5956: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:5960: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_rtti_exceptions=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+    lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl=
+lt_prog_compiler_pic=
+lt_prog_compiler_static=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+  if test "$GCC" = yes; then
+    lt_prog_compiler_wl='-Wl,'
+    lt_prog_compiler_static='-static'
+    case $host_os in
+      aix*)
+      # All AIX code is PIC.
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | pw32* | os2*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared=no
+      enable_shared=no
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	lt_prog_compiler_pic=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic='-qnocommon'
+       esac
+    hpux9* | hpux10* | hpux11*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static='${wl}-a ${wl}archive'
+    irix5* | irix6* | nonstopux*)
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic='-KPIC'
+    linux* | k*bsd*-gnu)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+    osf3* | osf4* | osf5*)
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl='-Qoption ld ';;
+	lt_prog_compiler_wl='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+      if test -d /usr/nec ;then
+	lt_prog_compiler_pic='-Kconform_pic'
+      fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works+set}" = set; then
+else
+  lt_prog_compiler_pic_works=no
+   lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
+   (eval echo "\"\$as_me:6224: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:6228: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
+if test x"$lt_prog_compiler_pic_works" = xyes; then
+    case $lt_prog_compiler_pic in
+     *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works+set}" = set; then
+else
+  lt_prog_compiler_static_works=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
+if test x"$lt_prog_compiler_static_works" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:6328: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:6332: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag=
+  enable_shared_with_static_runtimes=no
+  archive_cmds=
+  archive_expsym_cmds=
+  old_archive_From_new_cmds=
+  old_archive_from_expsyms_cmds=
+  export_dynamic_flag_spec=
+  whole_archive_flag_spec=
+  thread_safe_flag_spec=
+  hardcode_libdir_flag_spec=
+  hardcode_libdir_flag_spec_ld=
+  hardcode_libdir_separator=
+  hardcode_direct=no
+  hardcode_minus_L=no
+  hardcode_shlibpath_var=unsupported
+  link_all_deplibs=unknown
+  hardcode_automatic=no
+  module_cmds=
+  module_expsym_cmds=
+  always_export_symbols=no
+  export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+      if test "$host_cpu" != ia64; then
+	ld_shlibs=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec='-L$libdir'
+      hardcode_minus_L=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes=yes
+      export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var=no
+      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+	link_all_deplibs=no
+      else
+	ld_shlibs=no
+      fi
+    netbsd* | netbsdelf*-gnu)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct=yes
+      else
+	ld_shlibs=no
+      fi
+    esac
+    if test "$ld_shlibs" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols=yes
+      archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	# If we're using GNU nm, then we don't want the "-C" option.
+	# -C means demangle to AIX nm, but means don't demangle with GNU nm
+	if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+	  export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds=''
+      hardcode_libdir_separator=':'
+      link_all_deplibs=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag="-z nodefs"
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag=' ${wl}-bernotok'
+	  allow_undefined_flag=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec='$convenience'
+	  archive_cmds_need_lc=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs=no
+    bsdi[45]*)
+      export_dynamic_flag_spec=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      shrext_cmds=".dll"
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc=no
+      hardcode_automatic=yes
+      whole_archive_flag_spec='-all_load $convenience'
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs=no
+      esac
+    fi
+    dgux*)
+      archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | dragonfly*)
+      archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld='+b $libdir'
+	esac
+      fi
+	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
+	archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag=' -expect_unresolved \*'
+	archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag=' -z text'
+	wlarc='${wl}'
+	archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+      case $host_vendor in
+	sni)
+	  hardcode_direct=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec='-Bexport'
+    sysv4*MP*)
+	hardcode_runpath_var=yes
+	ld_shlibs=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag='${wl}-z,text'
+	archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec='${wl}-Bexport'
+	archive_cmds='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs" >&5
+echo "${ECHO_T}$ld_shlibs" >&6
+test "$ld_shlibs" = no && can_build_shared=no
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl
+	pic_flag=$lt_prog_compiler_pic
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag=$lt_save_allow_undefined_flag
+      else
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
+echo "${ECHO_T}$archive_cmds_need_lc" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+library_names_spec=
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+postuninstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+  version_type=windows
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+    shlibpath_overrides_runpath=no
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux* | k*bsd*-gnu)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+netbsdelf*-gnu)
+  need_version=no
+  dynamic_linker='NetBSD ld.elf_so'
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action=
+if test -n "$hardcode_libdir_flag_spec" || \
+   test -n "$runpath_var" || \
+   test "X$hardcode_automatic" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
+     test "$hardcode_minus_L" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action" >&5
+echo "${ECHO_T}$hardcode_action" >&6
+if test "$hardcode_action" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+  test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+  test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+  echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+  case $host_os in
+   darwin*)
+       if test -n "$STRIP" ; then
+         striplib="$STRIP -x"
+       else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+  esac
+fi
+if test "x$enable_dlopen" != xyes; then
+  enable_dlopen=unknown
+  enable_dlopen_self=unknown
+  enable_dlopen_self_static=unknown
+else
+  lt_cv_dlopen=no
+  lt_cv_dlopen_libs=
+  case $host_os in
+  beos*)
+    lt_cv_dlopen="load_add_on"
+    lt_cv_dlopen_self=yes
+  mingw* | pw32*)
+    lt_cv_dlopen="LoadLibrary"
+  cygwin*)
+    lt_cv_dlopen="dlopen"
+  darwin*)
+  # if libdl is installed we need to link against it
+    echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl  $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  (exit $ac_status); } &&
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dl_dlopen=yes
+else
+ac_cv_lib_dl_dlopen=no
+fi
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+    lt_cv_dlopen="dyld"
+fi
+    echo "$as_me:$LINENO: checking for shl_load" >&5
+echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
+if test "${ac_cv_func_shl_load+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
+   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
+#define shl_load innocuous_shl_load
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char shl_load (); below.
+    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+    <limits.h> exists even on freestanding compilers.  */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef shl_load
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_shl_load) || defined (__stub___shl_load)
+choke me
+#else
+char (*f) () = shl_load;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != shl_load;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_shl_load=yes
+else
+ac_cv_func_shl_load=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
+echo "${ECHO_T}$ac_cv_func_shl_load" >&6
+if test $ac_cv_func_shl_load = yes; then
+  lt_cv_dlopen="shl_load"
+else
+  echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
+echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_shl_load+set}" = set; then
+else
+LIBS="-ldld  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+int
+main ()
+shl_load ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dld_shl_load=yes
+else
+ac_cv_lib_dld_shl_load=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
+if test $ac_cv_lib_dld_shl_load = yes; then
+  lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
+else
+  echo "$as_me:$LINENO: checking for dlopen" >&5
+echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
+if test "${ac_cv_func_dlopen+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
+#define dlopen innocuous_dlopen
+    which can conflict with char dlopen (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef dlopen
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+#if defined (__stub_dlopen) || defined (__stub___dlopen)
+choke me
+#else
+char (*f) () = dlopen;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != dlopen;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_dlopen=yes
+else
+ac_cv_func_dlopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
+echo "${ECHO_T}$ac_cv_func_dlopen" >&6
+if test $ac_cv_func_dlopen = yes; then
+else
+else
+LIBS="-ldl  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+else
+  echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
+echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
+if test "${ac_cv_lib_svld_dlopen+set}" = set; then
+else
+LIBS="-lsvld  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_svld_dlopen=yes
+else
+ac_cv_lib_svld_dlopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
+if test $ac_cv_lib_svld_dlopen = yes; then
+  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
+else
+  echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
+echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_dld_link+set}" = set; then
+else
+LIBS="-ldld  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dld_link ();
+int
+main ()
+dld_link ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  cat conftest.err >&5
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dld_dld_link=yes
+else
+ac_cv_lib_dld_dld_link=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
+if test $ac_cv_lib_dld_dld_link = yes; then
+  lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
+fi
+fi
+fi
+fi
+fi
+fi
+  esac
+  if test "x$lt_cv_dlopen" != xno; then
+    enable_dlopen=yes
+  else
+    enable_dlopen=no
+  fi
+  case $lt_cv_dlopen in
+  dlopen)
+    save_CPPFLAGS="$CPPFLAGS"
+    test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
+    wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
+    save_LIBS="$LIBS"
+    LIBS="$lt_cv_dlopen_libs $LIBS"
+    echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
+echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self+set}" = set; then
+else
+  	  if test "$cross_compiling" = yes; then :
+  lt_cv_dlopen_self=cross
+else
+  lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+  lt_status=$lt_dlunknown
+  cat > conftest.$ac_ext <<EOF
+#line 8662 "configure"
+#include "confdefs.h"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+#  define LT_DLGLOBAL		RTLD_GLOBAL
+#else
+#  ifdef DL_GLOBAL
+#    define LT_DLGLOBAL		DL_GLOBAL
+#  else
+#    define LT_DLGLOBAL		0
+#  endif
+#endif
+/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
+   find out it does not work in some platform. */
+#ifndef LT_DLLAZY_OR_NOW
+#  ifdef RTLD_LAZY
+#    define LT_DLLAZY_OR_NOW		RTLD_LAZY
+#  else
+#    ifdef DL_LAZY
+#      define LT_DLLAZY_OR_NOW		DL_LAZY
+#    else
+#      ifdef RTLD_NOW
+#        define LT_DLLAZY_OR_NOW	RTLD_NOW
+#      else
+#        ifdef DL_NOW
+#          define LT_DLLAZY_OR_NOW	DL_NOW
+#        else
+#          define LT_DLLAZY_OR_NOW	0
+#        endif
+#      endif
+#    endif
+#  endif
+#endif
+#ifdef __cplusplus
+extern "C" void exit (int);
+#endif
+void fnord() { int i=42;}
+int main ()
+  void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
+  int status = $lt_dlunknown;
+  if (self)
+      if (dlsym (self,"fnord"))       status = $lt_dlno_uscore;
+      else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
+      /* dlclose (self); */
+  else
+    puts (dlerror ());
+    exit (status);
+EOF
+  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
+    (./conftest; exit; ) >&5 2>/dev/null
+    lt_status=$?
+    case x$lt_status in
+      x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
+      x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
+    esac
+  else :
+    # compilation failed
+    lt_cv_dlopen_self=no
+  fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self" >&6
+    if test "x$lt_cv_dlopen_self" = xyes; then
+      wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
+      echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
+echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self_static+set}" = set; then
+else
+  lt_cv_dlopen_self_static=cross
+else
+#line 8762 "configure"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+#else
+#  ifdef DL_GLOBAL
+#  else
+#  endif
+#endif
+#  ifdef RTLD_LAZY
+#  else
+#    ifdef DL_LAZY
+#    else
+#      ifdef RTLD_NOW
+#      else
+#        ifdef DL_NOW
+#        else
+#        endif
+#      endif
+#    endif
+#  endif
+#endif
+#ifdef __cplusplus
+#endif
+int main ()
+  if (self)
+  else
+    exit (status);
+EOF
+  ac_status=$?
+    lt_status=$?
+      x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
+      x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
+    esac
+  else :
+    lt_cv_dlopen_self_static=no
+  fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
+    fi
+    CPPFLAGS="$save_CPPFLAGS"
+    LIBS="$save_LIBS"
+  esac
+  case $lt_cv_dlopen_self in
+  yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
+  *) enable_dlopen_self=unknown ;;
+  esac
+  case $lt_cv_dlopen_self_static in
+  yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
+  *) enable_dlopen_self_static=unknown ;;
+  esac
+fi
+# Report which library types will actually be built
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+  test "$enable_shared" = yes && enable_static=no
+  if test -n "$RANLIB"; then
+    archive_cmds="$archive_cmds~\$RANLIB \$lib"
+    postinstall_cmds='$RANLIB $lib'
+  fi
+aix4* | aix5*)
+  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+  fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler \
+    CC \
+    LD \
+    lt_prog_compiler_wl \
+    lt_prog_compiler_pic \
+    lt_prog_compiler_static \
+    lt_prog_compiler_no_builtin_flag \
+    export_dynamic_flag_spec \
+    thread_safe_flag_spec \
+    whole_archive_flag_spec \
+    enable_shared_with_static_runtimes \
+    old_archive_cmds \
+    old_archive_from_new_cmds \
+    predep_objects \
+    postdep_objects \
+    predeps \
+    postdeps \
+    compiler_lib_search_path \
+    archive_cmds \
+    archive_expsym_cmds \
+    postinstall_cmds \
+    postuninstall_cmds \
+    old_archive_from_expsyms_cmds \
+    allow_undefined_flag \
+    no_undefined_flag \
+    export_symbols_cmds \
+    hardcode_libdir_flag_spec \
+    hardcode_libdir_flag_spec_ld \
+    hardcode_libdir_separator \
+    hardcode_automatic \
+    module_cmds \
+    module_expsym_cmds \
+    lt_cv_prog_compiler_c_o \
+    exclude_expsyms \
+    include_expsyms; do
+    case $var in
+    old_archive_cmds | \
+    old_archive_from_new_cmds | \
+    archive_cmds | \
+    archive_expsym_cmds | \
+    module_cmds | \
+    module_expsym_cmds | \
+    old_archive_from_expsyms_cmds | \
+    export_symbols_cmds | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="${ofile}T"
+  trap "$rm \"$cfgfile\"; exit 1" 1 2 15
+  $rm -f "$cfgfile"
+  { echo "$as_me:$LINENO: creating $ofile" >&5
+echo "$as_me: creating $ofile" >&6;}
+  cat <<__EOF__ >> "$cfgfile"
+#! $SHELL
+# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
+# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
+# NOTE: Changes made to this file will be lost: look at ltmain.sh.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
+# Free Software Foundation, Inc.
+# This file is part of GNU Libtool:
+# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+# General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+# A sed program that does not truncate output.
+SED=$lt_SED
+# Sed that helps us avoid accidentally triggering echo(1) options like -n.
+Xsed="$SED -e 1s/^X//"
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# The names of the tagged configurations supported by this script.
+available_tags=
+# ### BEGIN LIBTOOL CONFIG
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+shrext='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds
+archive_expsym_cmds=$lt_archive_expsym_cmds
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds
+module_expsym_cmds=$lt_module_expsym_cmds
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects
+# shared library.
+predeps=$lt_predeps
+# shared library.
+postdeps=$lt_postdeps
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms
+# ### END LIBTOOL CONFIG
+__EOF__
+  case $host_os in
+  aix3*)
+    cat <<\EOF >> "$cfgfile"
+# AIX sometimes has problems with the GCC collect2 program.  For some
+# reason, if we set the COLLECT_NAMES environment variable, the problems
+# vanish in a puff of smoke.
+if test "X${COLLECT_NAMES+set}" != Xset; then
+  COLLECT_NAMES=
+  export COLLECT_NAMES
+fi
+EOF
+  esac
+  # We use sed instead of cat because bash on DJGPP gets confused if
+  # if finds mixed CR/LF and LF-only lines.  Since sed operates in
+  # text mode, it properly converts lines to CR/LF.  This bash problem
+  # is reportedly fixed, but why not run on old versions too?
+  sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
+  mv -f "$cfgfile" "$ofile" || \
+    (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
+  chmod +x "$ofile"
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC="$lt_save_CC"
+# Check whether --with-tags or --without-tags was given.
+if test "${with_tags+set}" = set; then
+  withval="$with_tags"
+  tagnames="$withval"
+fi;
+if test -f "$ltmain" && test -n "$tagnames"; then
+  if test ! -f "${ofile}"; then
+    { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
+  fi
+  if test -z "$LTCC"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
+      { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
+    else
+      { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
+echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
+    fi
+  fi
+  if test -z "$LTCFLAGS"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
+  fi
+  # Extract list of available tagged configurations in $ofile.
+  # Note that this assumes the entire list is on one line.
+  available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
+  lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+  for tagname in $tagnames; do
+    IFS="$lt_save_ifs"
+    # Check whether tagname contains only valid characters
+    case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
+    *)  { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
+echo "$as_me: error: invalid tag name: $tagname" >&2;}
+   { (exit 1); exit 1; }; }
+    esac
+    if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
+    then
+      { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
+echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
+    fi
+    # Update the list of available tags.
+    if test -n "$tagname"; then
+      echo appending configuration tag \"$tagname\" to $ofile
+      case $tagname in
+      CXX)
+	if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+	    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+	    (test "X$CXX" != "Xg++"))) ; then
+	  ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+archive_cmds_need_lc_CXX=no
+allow_undefined_flag_CXX=
+always_export_symbols_CXX=no
+archive_expsym_cmds_CXX=
+export_dynamic_flag_spec_CXX=
+hardcode_direct_CXX=no
+hardcode_libdir_flag_spec_CXX=
+hardcode_libdir_flag_spec_ld_CXX=
+hardcode_libdir_separator_CXX=
+hardcode_minus_L_CXX=no
+hardcode_shlibpath_var_CXX=unsupported
+hardcode_automatic_CXX=no
+module_cmds_CXX=
+module_expsym_cmds_CXX=
+link_all_deplibs_CXX=unknown
+old_archive_cmds_CXX=$old_archive_cmds
+no_undefined_flag_CXX=
+whole_archive_flag_spec_CXX=
+enable_shared_with_static_runtimes_CXX=no
+# Dependencies to place before and after the object being linked:
+predep_objects_CXX=
+postdep_objects_CXX=
+predeps_CXX=
+postdeps_CXX=
+compiler_lib_search_path_CXX=
+# Source file extension for C++ test sources.
+ac_ext=cpp
+# Object file extension for compiled C++ test sources.
+objext=o
+objext_CXX=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC=$CC
+lt_save_LD=$LD
+lt_save_GCC=$GCC
+GCC=$GXX
+lt_save_with_gnu_ld=$with_gnu_ld
+lt_save_path_LD=$lt_cv_path_LD
+if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
+  lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
+else
+  $as_unset lt_cv_prog_gnu_ld
+fi
+if test -n "${lt_cv_path_LDCXX+set}"; then
+  lt_cv_path_LD=$lt_cv_path_LDCXX
+else
+  $as_unset lt_cv_path_LD
+fi
+test -z "${LDCXX+set}" || LD=$LDCXX
+CC=${CXX-"c++"}
+compiler=$CC
+compiler_CXX=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# We don't want -fno-exception wen compiling C++ code, so set the
+# no_builtin_flag separately
+if test "$GXX" = yes; then
+  lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
+else
+fi
+  # Set up default GNU C++ configuration
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+  withval="$with_gnu_ld"
+  test "$withval" = no || with_gnu_ld=yes
+else
+  with_gnu_ld=no
+fi;
+ac_prog=ld
+  # Check if gcc -print-prog-name=ld gives a path.
+  echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+  case $host in
+  *-*-mingw*)
+    # gcc leaves a trailing carriage return which upsets mingw
+    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
+    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+  esac
+  case $ac_prog in
+    # Accept absolute paths.
+      re_direlt='/[^/][^/]*/\.\./'
+      # Canonicalize the pathname of ld
+      ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+      while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+	ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+      done
+      test -z "$LD" && LD="$ac_prog"
+    # If it fails, then pretend we aren't using GCC.
+    ac_prog=ld
+    # If it is relative, then search for the first ld in PATH.
+    with_gnu_ld=unknown
+  esac
+elif test "$with_gnu_ld" = yes; then
+  echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+  echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+  if test -z "$LD"; then
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for ac_dir in $PATH; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+      lt_cv_path_LD="$ac_dir/$ac_prog"
+      # Check to see if the program is GNU ld.  I'd rather use --version,
+      # but apparently some variants of GNU ld only accept -v.
+      # Break only if it was the GNU/non-GNU ld that we prefer.
+      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+      *GNU* | *'with BFD'*)
+	test "$with_gnu_ld" != no && break
+	test "$with_gnu_ld" != yes && break
+      esac
+    fi
+  done
+else
+  lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+  echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+  lt_cv_prog_gnu_ld=yes
+  lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+  # Check if GNU C++ uses GNU ld as the underlying linker, since the
+  # archiving commands below assume that GNU ld is being used.
+  if test "$with_gnu_ld" = yes; then
+    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+    hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
+    #     investigate it a little bit more. (MM)
+    wlarc='${wl}'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
+	grep 'no-whole-archive' > /dev/null; then
+      whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+    else
+    fi
+  else
+    with_gnu_ld=no
+    wlarc=
+    # A generic and very simple default shared library creation
+    # command for GNU C++ for the case where it uses the native
+    # linker, instead of GNU ld.  If possible, this setting should
+    # overridden to take advantage of the native linker features on
+    # the platform it is being used on.
+    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+  fi
+  # Commands to make compiler produce verbose output that lists
+  # what "hidden" libraries, object files and flags are used when
+  # linking a shared library.
+  output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
+else
+  GXX=no
+  with_gnu_ld=no
+  wlarc=
+fi
+# PORTME: fill in a description of your system's C++ link characteristics
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ld_shlibs_CXX=yes
+case $host_os in
+  aix3*)
+    # FIXME: insert proper C++ library support
+    ld_shlibs_CXX=no
+  aix4* | aix5*)
+    if test "$host_cpu" = ia64; then
+      # On IA64, the linker does run time linking by default, so we don't
+      # have to do anything special.
+      aix_use_runtimelinking=no
+      exp_sym_flag='-Bexport'
+      no_entry_flag=""
+    else
+      # Test if we are trying to use run time linking or normal
+      # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+      # need to do runtime linking.
+      case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	for ld_flag in $LDFLAGS; do
+	  case $ld_flag in
+	  *-brtl*)
+	    aix_use_runtimelinking=yes
+	    break
+	  esac
+	done
+      esac
+      exp_sym_flag='-bexport'
+      no_entry_flag='-bnoentry'
+    fi
+    # When large executables or shared objects are built, AIX ld can
+    # have problems creating the table of contents.  If linking a library
+    # or program results in "error TOC overflow" add -mminimal-toc to
+    # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+    # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+    archive_cmds_CXX=''
+    hardcode_direct_CXX=yes
+    hardcode_libdir_separator_CXX=':'
+    link_all_deplibs_CXX=yes
+    if test "$GXX" = yes; then
+      case $host_os in aix4.[012]|aix4.[012].*)
+      # We only want to do this on AIX 4.2 and lower, the check
+      # below for broken collect2 doesn't work under 4.3+
+	collect2name=`${CC} -print-prog-name=collect2`
+	if test -f "$collect2name" && \
+	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	then
+	  # We have reworked collect2
+	else
+	  # We have old collect2
+	  hardcode_direct_CXX=unsupported
+	  # It fails to find uninstalled libraries when the uninstalled
+	  # path is not listed in the libpath.  Setting hardcode_minus_L
+	  # to unsupported forces relinking
+	  hardcode_minus_L_CXX=yes
+	  hardcode_libdir_flag_spec_CXX='-L$libdir'
+	fi
+      esac
+      shared_flag='-shared'
+      if test "$aix_use_runtimelinking" = yes; then
+	shared_flag="$shared_flag "'${wl}-G'
+      fi
+    else
+      # not using gcc
+	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+	# chokes on -Wl,-G. The following line is correct:
+	shared_flag='-G'
+      else
+	  shared_flag='${wl}-G'
+	else
+	  shared_flag='${wl}-bM:SRE'
+	fi
+      fi
+    fi
+    # It seems that -bexpall does not export symbols beginning with
+    # underscore (_), so it is better to generate a list of symbols to export.
+    always_export_symbols_CXX=yes
+      # Warning - without using the other runtime loading flags (-brtl),
+      # -berok will link without error, but may produce a broken library.
+      allow_undefined_flag_CXX='-berok'
+      # Determine the default libpath from the value encoded in an empty executable.
+      cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+      hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
+      archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+     else
+	hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
+	allow_undefined_flag_CXX="-z nodefs"
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+      else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	# Warning - without using the other run time loading flags,
+	no_undefined_flag_CXX=' ${wl}-bernotok'
+	allow_undefined_flag_CXX=' ${wl}-berok'
+	# Exported symbols can be pulled into shared objects from archives
+	whole_archive_flag_spec_CXX='$convenience'
+	archive_cmds_need_lc_CXX=yes
+	# This is similar to how AIX traditionally builds its shared libraries.
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+      fi
+    fi
+  beos*)
+    if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      allow_undefined_flag_CXX=unsupported
+      # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+      # support --undefined.  This deserves some investigation.  FIXME
+      archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
+  chorus*)
+    case $cc_basename in
+	ld_shlibs_CXX=no
+    esac
+  cygwin* | mingw* | pw32*)
+    # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
+    # as there is no search path for DLLs.
+    always_export_symbols_CXX=no
+    enable_shared_with_static_runtimes_CXX=yes
+    if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+      archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      # If the export-symbols file already is a .def file (1st line
+      # is EXPORTS), use it as is; otherwise, prepend...
+      archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	cp $export_symbols $output_objdir/$soname.def;
+      else
+	echo EXPORTS > $output_objdir/$soname.def;
+	cat $export_symbols >> $output_objdir/$soname.def;
+      fi~
+      $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
+      darwin* | rhapsody*)
+        case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_CXX='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_CXX='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_CXX='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+        esac
+      archive_cmds_need_lc_CXX=no
+      hardcode_direct_CXX=no
+      hardcode_automatic_CXX=yes
+      hardcode_shlibpath_var_CXX=unsupported
+      whole_archive_flag_spec_CXX='-all_load $convenience'
+    if test "$GXX" = yes ; then
+      lt_int_apple_cc_single_mod=no
+      output_verbose_link_cmd='echo'
+      if $CC -dumpspecs 2>&1 | $EGREP 'single_module' >/dev/null ; then
+       lt_int_apple_cc_single_mod=yes
+      fi
+      if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+       archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      else
+          archive_cmds_CXX='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+        fi
+        module_cmds_CXX='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+        # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+            archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+          else
+            archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+          fi
+            module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      else
+        xlc*)
+          archive_cmds_CXX='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+          archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_CXX=no
+      esac
+      fi
+  dgux*)
+      ec++*)
+	ld_shlibs_CXX=no
+      ghcx*)
+	# Green Hills C++ Compiler
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  freebsd[12]*)
+    # C++ shared libraries reported to be fairly broken before switch to ELF
+    ld_shlibs_CXX=no
+  freebsd-elf*)
+  freebsd* | dragonfly*)
+    # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
+    # conventions
+    ld_shlibs_CXX=yes
+  gnu*)
+  hpux9*)
+    hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+    hardcode_libdir_separator_CXX=:
+    export_dynamic_flag_spec_CXX='${wl}-E'
+    hardcode_minus_L_CXX=yes # Not in the search PATH,
+				# but as the default
+				# location of the library.
+    CC*)
+      ld_shlibs_CXX=no
+    aCC*)
+      archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      # There doesn't appear to be a way to prevent this compiler from
+      # explicitly linking system object files so we need to strip them
+      # from the output so that they don't get included in the library
+      # dependencies.
+      output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "[-]L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+        archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+        ld_shlibs_CXX=no
+      fi
+    esac
+  hpux10*|hpux11*)
+    if test $with_gnu_ld = no; then
+      case $host_cpu in
+      hppa*64*|ia64*)
+	hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
+      esac
+    fi
+    case $host_cpu in
+    hppa*64*|ia64*)
+      hardcode_shlibpath_var_CXX=no
+    esac
+      CC*)
+	ld_shlibs_CXX=no
+      aCC*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	ia64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	esac
+	# dependencies.
+	output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	    case $host_cpu in
+	    hppa*64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    ia64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    esac
+	  fi
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  interix3*)
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
+    # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+    # Instead, shared libraries are loaded at an image base (0x10000000 by
+    # default) and relocated if they conflict, which is a slow very memory
+    # consuming and fragmenting process.  To avoid this, we pick a random,
+    # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+    # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+    archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+  irix5* | irix6*)
+      CC*)
+	# SGI C++
+	archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	# Archives containing C++ object files must be created using
+	# "CC -ar", where "CC" is the IRIX C++ compiler.  This is
+	# necessary to make sure instantiated templates are included
+	# in the archive.
+	old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
+	  if test "$with_gnu_ld" = no; then
+	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	  else
+	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
+	  fi
+	fi
+    esac
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
+  linux* | k*bsd*-gnu)
+      KCC*)
+	# Kuck and Associates, Inc. (KAI) C++ Compiler
+	# KCC will only create a shared library if the output file
+	# ends with ".so" (or ".sl" for HP-UX), so rename the library
+	# to its proper name (with version) after linking.
+	archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
+	archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
+	# "CC -Bstatic", where "CC" is the KAI C++ compiler.
+	old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
+      icpc*)
+	# Intel C++
+	with_gnu_ld=yes
+	# version 8.0 and above of icpc choke on multiply defined symbols
+	# if we add $predep_objects and $postdep_objects, however 7.1 and
+	# earlier do not add the objects themselves.
+	case `$CC -V 2>&1` in
+	*"Version 7."*)
+  	  archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+  	  archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+	*)  # Version 8.0 or newer
+	  tmp_idyn=
+	  case $host_cpu in
+	    ia64*) tmp_idyn=' -i_dynamic';;
+	  esac
+  	  archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	  archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+	esac
+	whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
+      pgCC*)
+        # Portland Group C++ compiler
+	archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
+  	archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
+	whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+      cxx*)
+	# Compaq C++
+	archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname  -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
+	runpath_var=LD_RUN_PATH
+	hardcode_libdir_flag_spec_CXX='-rpath $libdir'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+    esac
+  lynxos*)
+    ld_shlibs_CXX=no
+  m88k*)
+    ld_shlibs_CXX=no
+  mvs*)
+      cxx*)
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  netbsd* | netbsdelf*-gnu)
+    if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+      archive_cmds_CXX='$LD -Bshareable  -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
+      wlarc=
+      hardcode_libdir_flag_spec_CXX='-R$libdir'
+    fi
+    # Workaround some broken pre-1.5 toolchains
+    output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
+  openbsd2*)
+    # C++ shared libraries are fairly broken
+    ld_shlibs_CXX=no
+  openbsd*)
+    archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+    if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+      archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
+    fi
+  osf3*)
+      KCC*)
+      RCC*)
+	# Rational C++ 2.4.1
+	ld_shlibs_CXX=no
+      cxx*)
+	allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	if test "$GXX" = yes && test "$with_gnu_ld" = no; then
+	  archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  osf4* | osf5*)
+      KCC*)
+	# the KAI C++ compiler.
+	old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
+      RCC*)
+	ld_shlibs_CXX=no
+      cxx*)
+	allow_undefined_flag_CXX=' -expect_unresolved \*'
+	archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
+	  echo "-hidden">> $lib.exp~
+	  $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp  `test -n "$verstring" && echo -set_version	$verstring` -update_registry ${output_objdir}/so_locations -o $lib~
+	  $rm $lib.exp'
+	# dependencies.
+	 archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  psos*)
+    ld_shlibs_CXX=no
+  sunos4*)
+      CC*)
+	# Sun C++ 4.x
+	ld_shlibs_CXX=no
+      lcc*)
+	# Lucid
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  solaris*)
+      CC*)
+	# Sun C++ 4.2, 5.x and Centerline C++
+	no_undefined_flag_CXX=' -zdefs'
+	archive_cmds_CXX='$CC -G${allow_undefined_flag}  -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	$CC -G${allow_undefined_flag}  ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	case $host_os in
+	  solaris2.[0-5] | solaris2.[0-5].*) ;;
+	    # The C++ compiler is used as linker so we must use $wl
+	    # flag to pass the commands to the underlying system
+	    # linker. We must also pass each convience library through
+	    # to the system linker between allextract/defaultextract.
+	    # The C++ compiler will combine linker options so we
+	    # cannot just pass the convience library names through
+	    # without $wl.
+	    # Supported since Solaris 2.6 (maybe 2.5.1?)
+	    whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract'
+	esac
+	# "CC -xar", where "CC" is the Sun C++ compiler.  This is
+	# in the archive.
+	old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
+      gcx*)
+	archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+	# The C++ compiler must be used to create the archive.
+	old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
+	# GNU C++ compiler with Solaris linker
+	  no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
+	  if $CC --version | grep -v '^2\.7' > /dev/null; then
+	    archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+		$CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	    output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+	  else
+	    # g++ 2.7 appears to require `-G' NOT `-shared' on this
+	    # platform.
+	    archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+		$CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	    output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+	  fi
+	  hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
+	fi
+    esac
+  sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
+    no_undefined_flag_CXX='${wl}-z,text'
+    runpath_var='LD_RUN_PATH'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+  sysv5* | sco3.2v5* | sco5v6*)
+    # Note: We can NOT use -z defs as we might desire, because we do not
+    # link with -lc, and that would cause any symbols used from libc to
+    # always be unresolved, which means just about no library would
+    # ever link correctly.  If we're not using GNU ld we use -z text
+    # though, which does catch some bad symbols but isn't as heavy-handed
+    # as -z defs.
+    # For security reasons, it is highly recommended that you always
+    # use absolute paths for naming shared libraries, and exclude the
+    # DT_RUNPATH tag from executables and libraries.  But doing so
+    # requires that you compile everything twice, which is a pain.
+    # So that behaviour is only enabled if SCOABSPATH is set to a
+    # non-empty value in the environment.  Most likely only useful for
+    # creating official distributions of packages.
+    # This is a hack until libtool officially supports absolute path
+    # names for shared libraries.
+    allow_undefined_flag_CXX='${wl}-z,nodefs'
+    hardcode_libdir_flag_spec_CXX='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+    export_dynamic_flag_spec_CXX='${wl}-Bexport'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+  tandem*)
+      NCC*)
+	# NonStop-UX NCC 3.20
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  vxworks*)
+    ld_shlibs_CXX=no
+    ld_shlibs_CXX=no
+esac
+echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
+echo "${ECHO_T}$ld_shlibs_CXX" >&6
+test "$ld_shlibs_CXX" = no && can_build_shared=no
+GCC_CXX="$GXX"
+LD_CXX="$LD"
+## CAVEAT EMPTOR:
+## There is no encapsulation within the following macros, do not change
+## the running order or otherwise move them around unless you know exactly
+## what you are doing...
+cat > conftest.$ac_ext <<EOF
+class Foo
+public:
+  Foo (void) { a = 0; }
+private:
+  int a;
+EOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; then
+  # Parse the compiler output and extract the necessary
+  # objects, libraries and library flags.
+  # Sentinel used to keep track of whether or not we are before
+  # the conftest object file.
+  pre_test_object_deps_done=no
+  # The `*' in the case matches for architectures that use `case' in
+  # $output_verbose_cmd can trigger glob expansion during the loop
+  # eval without this substitution.
+  output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
+  for p in `eval $output_verbose_link_cmd`; do
+    case $p in
+    -L* | -R* | -l*)
+       # Some compilers place space between "-{L,R}" and the path.
+       # Remove the space.
+       if test $p = "-L" \
+	  || test $p = "-R"; then
+	 prev=$p
+	 continue
+       else
+	 prev=
+       fi
+       if test "$pre_test_object_deps_done" = no; then
+	 case $p in
+	 -L* | -R*)
+	   # Internal compiler library paths should come after those
+	   # provided the user.  The postdeps already come after the
+	   # user supplied libs so there is no need to process them.
+	   if test -z "$compiler_lib_search_path_CXX"; then
+	     compiler_lib_search_path_CXX="${prev}${p}"
+	   else
+	     compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
+	   fi
+	 # The "-l" case would never come before the object being
+	 # linked, so don't bother handling this case.
+	 esac
+       else
+	 if test -z "$postdeps_CXX"; then
+	   postdeps_CXX="${prev}${p}"
+	 else
+	   postdeps_CXX="${postdeps_CXX} ${prev}${p}"
+	 fi
+       fi
+    *.$objext)
+       # This assumes that the test object file only shows up
+       # once in the compiler output.
+       if test "$p" = "conftest.$objext"; then
+	 pre_test_object_deps_done=yes
+	 continue
+       fi
+	 if test -z "$predep_objects_CXX"; then
+	   predep_objects_CXX="$p"
+	 else
+	   predep_objects_CXX="$predep_objects_CXX $p"
+	 fi
+       else
+	 if test -z "$postdep_objects_CXX"; then
+	   postdep_objects_CXX="$p"
+	 else
+	   postdep_objects_CXX="$postdep_objects_CXX $p"
+	 fi
+       fi
+    *) ;; # Ignore the rest.
+    esac
+  done
+  # Clean up.
+  rm -f a.out a.exe
+else
+  echo "libtool.m4: error: problem compiling CXX test program"
+fi
+$rm -f confest.$objext
+# PORTME: override above test on systems where it is broken
+case $host_os in
+interix3*)
+  # Interix 3.5 installs completely hosed .la files for C++, so rather than
+  # hack all around it, let's just trust "g++" to DTRT.
+  postdeps_CXX=
+solaris*)
+  CC*)
+    # Adding this requires a known-good setup of shared libraries for
+    # Sun compiler versions before 5.6, else PIC objects from an old
+    # archive will be linked into the output, leading to subtle bugs.
+    postdeps_CXX='-lCstd -lCrun'
+  esac
+esac
+case " $postdeps_CXX " in
+*" -lc "*) archive_cmds_need_lc_CXX=no ;;
+esac
+lt_prog_compiler_wl_CXX=
+lt_prog_compiler_pic_CXX=
+lt_prog_compiler_static_CXX=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+  # C++ specific cases for pic, static, wl, etc.
+    lt_prog_compiler_wl_CXX='-Wl,'
+    lt_prog_compiler_static_CXX='-static'
+    case $host_os in
+    aix*)
+      # All AIX code is PIC.
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static_CXX='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | os2* | pw32*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic_CXX='-fno-common'
+    *djgpp*)
+      # DJGPP does not support shared libraries at all
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	lt_prog_compiler_pic_CXX=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	lt_prog_compiler_pic_CXX='-fPIC'
+      esac
+    esac
+  else
+    case $host_os in
+      aix4* | aix5*)
+	else
+	  lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
+	fi
+      chorus*)
+	cxch68*)
+	  # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
+	esac
+       darwin*)
+           xlc*)
+           lt_prog_compiler_pic_CXX='-qnocommon'
+         esac
+      dgux*)
+	  ec++*)
+	    lt_prog_compiler_pic_CXX='-KPIC'
+	  ghcx*)
+	    lt_prog_compiler_pic_CXX='-pic'
+	esac
+	# FreeBSD uses GNU C++
+      hpux9* | hpux10* | hpux11*)
+	  CC*)
+	    lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
+	    if test "$host_cpu" != ia64; then
+	      lt_prog_compiler_pic_CXX='+Z'
+	    fi
+	  aCC*)
+	    case $host_cpu in
+	    hppa*64*|ia64*)
+	      # +Z the default
+	    esac
+	esac
+      interix*)
+	# This is c89, which is MS Visual C++ (no shared libs)
+	# Anyone wants to do a port?
+      irix5* | irix6* | nonstopux*)
+	  CC*)
+	    lt_prog_compiler_static_CXX='-non_shared'
+	    # CC pic flag -KPIC is the default.
+	esac
+	  KCC*)
+	    # KAI C++ Compiler
+	    lt_prog_compiler_wl_CXX='--backend -Wl,'
+	  icpc* | ecpc*)
+	    # Intel C++
+	  pgCC*)
+	    # Portland Group C++ compiler.
+	    lt_prog_compiler_pic_CXX='-fpic'
+	  cxx*)
+	    # Compaq C++
+	    # Make sure the PIC flag is empty.  It appears that all Alpha
+	    # Linux and Compaq Tru64 Unix objects are PIC.
+	esac
+      lynxos*)
+      m88k*)
+      mvs*)
+	  cxx*)
+	    lt_prog_compiler_pic_CXX='-W c,exportall'
+	esac
+      osf3* | osf4* | osf5*)
+	  KCC*)
+	  RCC*)
+	  cxx*)
+	    # Digital/Compaq C++
+	esac
+      psos*)
+      solaris*)
+	  CC*)
+	    lt_prog_compiler_wl_CXX='-Qoption ld '
+	  gcx*)
+	    lt_prog_compiler_pic_CXX='-PIC'
+	esac
+      sunos4*)
+	  CC*)
+	    # Sun C++ 4.x
+	  lcc*)
+	    # Lucid
+	esac
+      tandem*)
+	  NCC*)
+	esac
+      sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+	  CC*)
+	esac
+      vxworks*)
+	lt_prog_compiler_can_build_shared_CXX=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic_CXX"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_prog_compiler_pic_works_CXX=no
+  ac_outfile=conftest.$ac_objext
+   printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+   lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:11107: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:11111: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_prog_compiler_pic_works_CXX=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
+if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
+    case $lt_prog_compiler_pic_CXX in
+     *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_CXX+set}" = set; then
+else
+  lt_prog_compiler_static_works_CXX=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_CXX=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_CXX" >&6
+if test x"$lt_prog_compiler_static_works_CXX" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_CXX=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:11211: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:11215: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o_CXX=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+  export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  case $host_os in
+  aix4* | aix5*)
+    # If we're using GNU nm, then we don't want the "-C" option.
+    # -C means demangle to AIX nm, but means don't demangle with GNU nm
+    if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+      export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+    else
+      export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+    fi
+  pw32*)
+    export_symbols_cmds_CXX="$ltdll_cmds"
+  cygwin* | mingw*)
+    export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/;/^.* __nm__/s/^.* __nm__\([^ ]*\) [^ ]*/\1 DATA/;/^I /d;/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+    link_all_deplibs_CXX=no
+  esac
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_CXX" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_CXX in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_CXX
+	pic_flag=$lt_prog_compiler_pic_CXX
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
+      else
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+  if test "$GCC" = yes; then
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+    shlibpath_overrides_runpath=no
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux* | k*bsd*-gnu)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+netbsdelf*-gnu)
+  need_version=no
+  dynamic_linker='NetBSD ld.elf_so'
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_CXX=
+if test -n "$hardcode_libdir_flag_spec_CXX" || \
+   test -n "$runpath_var_CXX" || \
+   test "X$hardcode_automatic_CXX" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_CXX" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
+     test "$hardcode_minus_L_CXX" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_CXX=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_CXX=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_CXX=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
+echo "${ECHO_T}$hardcode_action_CXX" >&6
+if test "$hardcode_action_CXX" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_CXX \
+    CC_CXX \
+    LD_CXX \
+    lt_prog_compiler_wl_CXX \
+    lt_prog_compiler_pic_CXX \
+    lt_prog_compiler_static_CXX \
+    lt_prog_compiler_no_builtin_flag_CXX \
+    export_dynamic_flag_spec_CXX \
+    thread_safe_flag_spec_CXX \
+    whole_archive_flag_spec_CXX \
+    enable_shared_with_static_runtimes_CXX \
+    old_archive_cmds_CXX \
+    old_archive_from_new_cmds_CXX \
+    predep_objects_CXX \
+    postdep_objects_CXX \
+    predeps_CXX \
+    postdeps_CXX \
+    compiler_lib_search_path_CXX \
+    archive_cmds_CXX \
+    archive_expsym_cmds_CXX \
+    postinstall_cmds_CXX \
+    postuninstall_cmds_CXX \
+    old_archive_from_expsyms_cmds_CXX \
+    allow_undefined_flag_CXX \
+    no_undefined_flag_CXX \
+    export_symbols_cmds_CXX \
+    hardcode_libdir_flag_spec_CXX \
+    hardcode_libdir_flag_spec_ld_CXX \
+    hardcode_libdir_separator_CXX \
+    hardcode_automatic_CXX \
+    module_cmds_CXX \
+    module_expsym_cmds_CXX \
+    lt_cv_prog_compiler_c_o_CXX \
+    exclude_expsyms_CXX \
+    include_expsyms_CXX; do
+    case $var in
+    old_archive_cmds_CXX | \
+    old_archive_from_new_cmds_CXX | \
+    archive_cmds_CXX | \
+    archive_expsym_cmds_CXX | \
+    module_cmds_CXX | \
+    module_expsym_cmds_CXX | \
+    old_archive_from_expsyms_cmds_CXX | \
+    export_symbols_cmds_CXX | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_CXX
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_CXX
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_CXX
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_CXX
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_CXX
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+shrext='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_CXX
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_CXX
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_CXX
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_CXX
+archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_CXX
+module_expsym_cmds=$lt_module_expsym_cmds_CXX
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_CXX
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_CXX
+# shared library.
+predeps=$lt_predeps_CXX
+# shared library.
+postdeps=$lt_postdeps_CXX
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_CXX
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_CXX
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_CXX
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_CXX
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_CXX
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_CXX
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_CXX
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_CXX"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_CXX
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_CXX
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_CXX
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_CXX
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC=$lt_save_CC
+LDCXX=$LD
+LD=$lt_save_LD
+GCC=$lt_save_GCC
+with_gnu_ldcxx=$with_gnu_ld
+with_gnu_ld=$lt_save_with_gnu_ld
+lt_cv_path_LDCXX=$lt_cv_path_LD
+lt_cv_path_LD=$lt_save_path_LD
+lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
+lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
+	else
+	  tagname=""
+	fi
+      F77)
+	if test -n "$F77" && test "X$F77" != "Xno"; then
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+archive_cmds_need_lc_F77=no
+allow_undefined_flag_F77=
+always_export_symbols_F77=no
+archive_expsym_cmds_F77=
+export_dynamic_flag_spec_F77=
+hardcode_direct_F77=no
+hardcode_libdir_flag_spec_F77=
+hardcode_libdir_flag_spec_ld_F77=
+hardcode_libdir_separator_F77=
+hardcode_minus_L_F77=no
+hardcode_automatic_F77=no
+module_cmds_F77=
+module_expsym_cmds_F77=
+link_all_deplibs_F77=unknown
+old_archive_cmds_F77=$old_archive_cmds
+no_undefined_flag_F77=
+whole_archive_flag_spec_F77=
+enable_shared_with_static_runtimes_F77=no
+# Source file extension for f77 test sources.
+ac_ext=f
+# Object file extension for compiled f77 test sources.
+objext=o
+objext_F77=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="      subroutine t\n      return\n      end\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code="      program t\n      end\n"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${F77-"f77"}
+compiler=$CC
+compiler_F77=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+  test "$enable_shared" = yes && enable_static=no
+  if test -n "$RANLIB"; then
+    archive_cmds="$archive_cmds~\$RANLIB \$lib"
+    postinstall_cmds='$RANLIB $lib'
+  fi
+aix4* | aix5*)
+  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+  fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+GCC_F77="$G77"
+LD_F77="$LD"
+lt_prog_compiler_wl_F77=
+lt_prog_compiler_pic_F77=
+lt_prog_compiler_static_F77=
+    lt_prog_compiler_wl_F77='-Wl,'
+    lt_prog_compiler_static_F77='-static'
+    case $host_os in
+      aix*)
+      if test "$host_cpu" = ia64; then
+	lt_prog_compiler_static_F77='-Bstatic'
+      fi
+    amigaos*)
+      # like `-m68040'.
+      lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
+    mingw* | pw32* | os2*)
+      lt_prog_compiler_pic_F77='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      lt_prog_compiler_pic_F77='-fno-common'
+    interix3*)
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared_F77=no
+      enable_shared=no
+    sysv4*MP*)
+	lt_prog_compiler_pic_F77=-Kconform_pic
+      fi
+    hpux*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_F77='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic_F77='-qnocommon'
+       esac
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_F77='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static_F77='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic_F77='-KPIC'
+    linux* | k*bsd*-gnu)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic_F77='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl_F77='-Qoption ld ';;
+	lt_prog_compiler_wl_F77='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic_F77='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+	lt_prog_compiler_pic_F77='-Kconform_pic'
+      fi
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic_F77='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
+if test -n "$lt_prog_compiler_pic_F77"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
+else
+  lt_prog_compiler_pic_works_F77=no
+   lt_compiler_flag="$lt_prog_compiler_pic_F77"
+   (eval echo "\"\$as_me:12773: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:12777: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works_F77=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
+if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
+    case $lt_prog_compiler_pic_F77 in
+     *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  *djgpp*)
+    lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
+esac
+wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
+if test "${lt_prog_compiler_static_works_F77+set}" = set; then
+else
+  lt_prog_compiler_static_works_F77=no
+         lt_prog_compiler_static_works_F77=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_F77" >&6
+if test x"$lt_prog_compiler_static_works_F77" = xyes; then
+else
+fi
+if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_F77=no
+   mkdir conftest
+   cd conftest
+   mkdir out
+   (eval echo "\"\$as_me:12877: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:12881: \$? = $ac_status" >&5
+   then
+       lt_cv_prog_compiler_c_o_F77=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
+if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
+  hard_links=yes
+  $rm conftest*
+  touch conftest.a
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag_F77=
+  enable_shared_with_static_runtimes_F77=no
+  archive_cmds_F77=
+  archive_expsym_cmds_F77=
+  old_archive_From_new_cmds_F77=
+  old_archive_from_expsyms_cmds_F77=
+  export_dynamic_flag_spec_F77=
+  whole_archive_flag_spec_F77=
+  thread_safe_flag_spec_F77=
+  hardcode_libdir_flag_spec_F77=
+  hardcode_libdir_flag_spec_ld_F77=
+  hardcode_libdir_separator_F77=
+  hardcode_direct_F77=no
+  hardcode_minus_L_F77=no
+  hardcode_shlibpath_var_F77=unsupported
+  link_all_deplibs_F77=unknown
+  hardcode_automatic_F77=no
+  module_cmds_F77=
+  module_expsym_cmds_F77=
+  always_export_symbols_F77=no
+  export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms_F77=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs_F77=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_F77='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+	ld_shlibs_F77=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec_F77='-L$libdir'
+      hardcode_minus_L_F77=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs_F77=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag_F77=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs_F77=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes_F77=yes
+      export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs_F77=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var_F77=no
+      hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_F77='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_F77='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_F77='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec_F77='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds_F77='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+	link_all_deplibs_F77=no
+      else
+	ld_shlibs_F77=no
+      fi
+    netbsd* | netbsdelf*-gnu)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs_F77=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs_F77=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_F77=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_F77=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct_F77=yes
+      else
+	ld_shlibs_F77=no
+      fi
+    esac
+    if test "$ld_shlibs_F77" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols_F77=yes
+      archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct_F77=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	  export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds_F77=''
+      hardcode_libdir_separator_F77=':'
+      link_all_deplibs_F77=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag_F77='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+      program main
+      end
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_f77_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag_F77="-z nodefs"
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+      program main
+      end
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag_F77=' ${wl}-bernotok'
+	  allow_undefined_flag_F77=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec_F77='$convenience'
+	  archive_cmds_need_lc_F77=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs_F77=no
+    bsdi[45]*)
+      export_dynamic_flag_spec_F77=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec_F77=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds_F77='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path_F77='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_F77='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_F77='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_F77='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc_F77=no
+      hardcode_automatic_F77=yes
+      whole_archive_flag_spec_F77='-all_load $convenience'
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds_F77='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds_F77='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds_F77='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_F77=no
+      esac
+    fi
+    dgux*)
+      archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs_F77=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec_F77='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | dragonfly*)
+      archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_F77=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld_F77='+b $libdir'
+	esac
+      fi
+    irix5* | irix6* | nonstopux*)
+	archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
+	archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag_F77=' -expect_unresolved \*'
+	archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec_F77='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag_F77=' -z text'
+	wlarc='${wl}'
+	archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec_F77='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+	sni)
+	  hardcode_direct_F77=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds_F77='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec_F77='-Bexport'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs_F77=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_F77='${wl}-z,text'
+	archive_cmds_F77='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_F77='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec_F77='${wl}-Bexport'
+	archive_cmds_F77='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs_F77=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
+echo "${ECHO_T}$ld_shlibs_F77" >&6
+test "$ld_shlibs_F77" = no && can_build_shared=no
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_F77" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_F77 in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_F77
+	pic_flag=$lt_prog_compiler_pic_F77
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_F77
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_F77=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+  if test "$GCC" = yes; then
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+    shlibpath_overrides_runpath=no
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux* | k*bsd*-gnu)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+netbsdelf*-gnu)
+  need_version=no
+  dynamic_linker='NetBSD ld.elf_so'
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_F77=
+if test -n "$hardcode_libdir_flag_spec_F77" || \
+   test -n "$runpath_var_F77" || \
+   test "X$hardcode_automatic_F77" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_F77" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
+     test "$hardcode_minus_L_F77" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_F77=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_F77=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_F77=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
+echo "${ECHO_T}$hardcode_action_F77" >&6
+if test "$hardcode_action_F77" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_F77 \
+    CC_F77 \
+    LD_F77 \
+    lt_prog_compiler_wl_F77 \
+    lt_prog_compiler_pic_F77 \
+    lt_prog_compiler_static_F77 \
+    lt_prog_compiler_no_builtin_flag_F77 \
+    export_dynamic_flag_spec_F77 \
+    thread_safe_flag_spec_F77 \
+    whole_archive_flag_spec_F77 \
+    enable_shared_with_static_runtimes_F77 \
+    old_archive_cmds_F77 \
+    old_archive_from_new_cmds_F77 \
+    predep_objects_F77 \
+    postdep_objects_F77 \
+    predeps_F77 \
+    postdeps_F77 \
+    compiler_lib_search_path_F77 \
+    archive_cmds_F77 \
+    archive_expsym_cmds_F77 \
+    postinstall_cmds_F77 \
+    postuninstall_cmds_F77 \
+    old_archive_from_expsyms_cmds_F77 \
+    allow_undefined_flag_F77 \
+    no_undefined_flag_F77 \
+    export_symbols_cmds_F77 \
+    hardcode_libdir_flag_spec_F77 \
+    hardcode_libdir_flag_spec_ld_F77 \
+    hardcode_libdir_separator_F77 \
+    hardcode_automatic_F77 \
+    module_cmds_F77 \
+    module_expsym_cmds_F77 \
+    lt_cv_prog_compiler_c_o_F77 \
+    exclude_expsyms_F77 \
+    include_expsyms_F77; do
+    case $var in
+    old_archive_cmds_F77 | \
+    old_archive_from_new_cmds_F77 | \
+    archive_cmds_F77 | \
+    archive_expsym_cmds_F77 | \
+    module_cmds_F77 | \
+    module_expsym_cmds_F77 | \
+    old_archive_from_expsyms_cmds_F77 | \
+    export_symbols_cmds_F77 | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_F77
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_F77
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_F77
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_F77
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_F77
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+shrext='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_F77
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_F77
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_F77
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_F77
+archive_expsym_cmds=$lt_archive_expsym_cmds_F77
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_F77
+module_expsym_cmds=$lt_module_expsym_cmds_F77
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_F77
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_F77
+# shared library.
+predeps=$lt_predeps_F77
+# shared library.
+postdeps=$lt_postdeps_F77
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_F77
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_F77
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_F77
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_F77
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_F77
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_F77
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_F77
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_F77
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_F77"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_F77
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_F77
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_F77
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_F77
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC="$lt_save_CC"
+	else
+	  tagname=""
+	fi
+      GCJ)
+	if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
+# Source file extension for Java test sources.
+ac_ext=java
+# Object file extension for compiled Java test sources.
+objext=o
+objext_GCJ=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="class foo {}\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='public class conftest { public static void main(String[] argv) {}; }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${GCJ-"gcj"}
+compiler=$CC
+compiler_GCJ=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# GCJ did not exist at the time GCC didn't implicitly link libc in.
+archive_cmds_need_lc_GCJ=no
+old_archive_cmds_GCJ=$old_archive_cmds
+## CAVEAT EMPTOR:
+## There is no encapsulation within the following macros, do not change
+## the running order or otherwise move them around unless you know exactly
+## what you are doing...
+lt_prog_compiler_no_builtin_flag_GCJ=
+  lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_cv_prog_compiler_rtti_exceptions=no
+  ac_outfile=conftest.$ac_objext
+   lt_compiler_flag="-fno-rtti -fno-exceptions"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:15074: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:15078: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_rtti_exceptions=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+    lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl_GCJ=
+lt_prog_compiler_pic_GCJ=
+lt_prog_compiler_static_GCJ=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+    lt_prog_compiler_wl_GCJ='-Wl,'
+    lt_prog_compiler_static_GCJ='-static'
+    case $host_os in
+      aix*)
+      # All AIX code is PIC.
+      if test "$host_cpu" = ia64; then
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static_GCJ='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | pw32* | os2*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic_GCJ='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared_GCJ=no
+      enable_shared=no
+    sysv4*MP*)
+	lt_prog_compiler_pic_GCJ=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_GCJ='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic_GCJ='-qnocommon'
+       esac
+    hpux9* | hpux10* | hpux11*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_GCJ='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static_GCJ='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic_GCJ='-KPIC'
+    linux* | k*bsd*-gnu)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic_GCJ='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+    osf3* | osf4* | osf5*)
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl_GCJ='-Qoption ld ';;
+	lt_prog_compiler_wl_GCJ='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic_GCJ='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+	lt_prog_compiler_pic_GCJ='-Kconform_pic'
+      fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic_GCJ='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic_GCJ"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
+else
+  lt_prog_compiler_pic_works_GCJ=no
+   lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
+   (eval echo "\"\$as_me:15342: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:15346: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works_GCJ=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
+if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
+    case $lt_prog_compiler_pic_GCJ in
+     *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_GCJ+set}" = set; then
+else
+  lt_prog_compiler_static_works_GCJ=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_GCJ=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_GCJ" >&6
+if test x"$lt_prog_compiler_static_works_GCJ" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_GCJ=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:15446: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:15450: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o_GCJ=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag_GCJ=
+  enable_shared_with_static_runtimes_GCJ=no
+  archive_cmds_GCJ=
+  archive_expsym_cmds_GCJ=
+  old_archive_From_new_cmds_GCJ=
+  old_archive_from_expsyms_cmds_GCJ=
+  export_dynamic_flag_spec_GCJ=
+  whole_archive_flag_spec_GCJ=
+  thread_safe_flag_spec_GCJ=
+  hardcode_libdir_flag_spec_GCJ=
+  hardcode_libdir_flag_spec_ld_GCJ=
+  hardcode_libdir_separator_GCJ=
+  hardcode_direct_GCJ=no
+  hardcode_minus_L_GCJ=no
+  hardcode_shlibpath_var_GCJ=unsupported
+  link_all_deplibs_GCJ=unknown
+  hardcode_automatic_GCJ=no
+  module_cmds_GCJ=
+  module_expsym_cmds_GCJ=
+  always_export_symbols_GCJ=no
+  export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms_GCJ=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs_GCJ=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+      if test "$host_cpu" != ia64; then
+	ld_shlibs_GCJ=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec_GCJ='-L$libdir'
+      hardcode_minus_L_GCJ=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs_GCJ=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag_GCJ=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs_GCJ=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes_GCJ=yes
+      export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs_GCJ=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var_GCJ=no
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_GCJ='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_GCJ='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_GCJ='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec_GCJ='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds_GCJ='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+	link_all_deplibs_GCJ=no
+      else
+	ld_shlibs_GCJ=no
+      fi
+    netbsd* | netbsdelf*-gnu)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs_GCJ=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs_GCJ=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_GCJ=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_GCJ=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct_GCJ=yes
+      else
+	ld_shlibs_GCJ=no
+      fi
+    esac
+    if test "$ld_shlibs_GCJ" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols_GCJ=yes
+      archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct_GCJ=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	# If we're using GNU nm, then we don't want the "-C" option.
+	# -C means demangle to AIX nm, but means don't demangle with GNU nm
+	if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+	  export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds_GCJ=''
+      hardcode_libdir_separator_GCJ=':'
+      link_all_deplibs_GCJ=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag_GCJ='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag_GCJ="-z nodefs"
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag_GCJ=' ${wl}-bernotok'
+	  allow_undefined_flag_GCJ=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec_GCJ='$convenience'
+	  archive_cmds_need_lc_GCJ=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs_GCJ=no
+    bsdi[45]*)
+      export_dynamic_flag_spec_GCJ=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec_GCJ=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds_GCJ='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path_GCJ='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_GCJ='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_GCJ='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_GCJ='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc_GCJ=no
+      hardcode_automatic_GCJ=yes
+      whole_archive_flag_spec_GCJ='-all_load $convenience'
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds_GCJ='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds_GCJ='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds_GCJ='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_GCJ=no
+      esac
+    fi
+    dgux*)
+      archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs_GCJ=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec_GCJ='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | dragonfly*)
+      archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_GCJ=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
+	esac
+      fi
+    irix5* | irix6* | nonstopux*)
+	archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
+	archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag_GCJ=' -expect_unresolved \*'
+	archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag_GCJ=' -z text'
+	wlarc='${wl}'
+	archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec_GCJ='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+	sni)
+	  hardcode_direct_GCJ=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds_GCJ='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec_GCJ='-Bexport'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs_GCJ=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_GCJ='${wl}-z,text'
+      if test "$GCC" = yes; then
+	archive_cmds_GCJ='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_GCJ='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec_GCJ='${wl}-Bexport'
+	archive_cmds_GCJ='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs_GCJ=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
+echo "${ECHO_T}$ld_shlibs_GCJ" >&6
+test "$ld_shlibs_GCJ" = no && can_build_shared=no
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_GCJ" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_GCJ in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_GCJ
+	pic_flag=$lt_prog_compiler_pic_GCJ
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+    shlibpath_overrides_runpath=no
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux* | k*bsd*-gnu)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+netbsdelf*-gnu)
+  need_version=no
+  dynamic_linker='NetBSD ld.elf_so'
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_GCJ=
+if test -n "$hardcode_libdir_flag_spec_GCJ" || \
+   test -n "$runpath_var_GCJ" || \
+   test "X$hardcode_automatic_GCJ" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_GCJ" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
+     test "$hardcode_minus_L_GCJ" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_GCJ=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_GCJ=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_GCJ=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
+echo "${ECHO_T}$hardcode_action_GCJ" >&6
+if test "$hardcode_action_GCJ" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_GCJ \
+    CC_GCJ \
+    LD_GCJ \
+    lt_prog_compiler_wl_GCJ \
+    lt_prog_compiler_pic_GCJ \
+    lt_prog_compiler_static_GCJ \
+    lt_prog_compiler_no_builtin_flag_GCJ \
+    export_dynamic_flag_spec_GCJ \
+    thread_safe_flag_spec_GCJ \
+    whole_archive_flag_spec_GCJ \
+    enable_shared_with_static_runtimes_GCJ \
+    old_archive_cmds_GCJ \
+    old_archive_from_new_cmds_GCJ \
+    predep_objects_GCJ \
+    postdep_objects_GCJ \
+    predeps_GCJ \
+    postdeps_GCJ \
+    compiler_lib_search_path_GCJ \
+    archive_cmds_GCJ \
+    archive_expsym_cmds_GCJ \
+    postinstall_cmds_GCJ \
+    postuninstall_cmds_GCJ \
+    old_archive_from_expsyms_cmds_GCJ \
+    allow_undefined_flag_GCJ \
+    no_undefined_flag_GCJ \
+    export_symbols_cmds_GCJ \
+    hardcode_libdir_flag_spec_GCJ \
+    hardcode_libdir_flag_spec_ld_GCJ \
+    hardcode_libdir_separator_GCJ \
+    hardcode_automatic_GCJ \
+    module_cmds_GCJ \
+    module_expsym_cmds_GCJ \
+    lt_cv_prog_compiler_c_o_GCJ \
+    exclude_expsyms_GCJ \
+    include_expsyms_GCJ; do
+    case $var in
+    old_archive_cmds_GCJ | \
+    old_archive_from_new_cmds_GCJ | \
+    archive_cmds_GCJ | \
+    archive_expsym_cmds_GCJ | \
+    module_cmds_GCJ | \
+    module_expsym_cmds_GCJ | \
+    old_archive_from_expsyms_cmds_GCJ | \
+    export_symbols_cmds_GCJ | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_GCJ
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_GCJ
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_GCJ
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_GCJ
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_GCJ
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+shrext='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_GCJ
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_GCJ
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_GCJ
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_GCJ
+archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_GCJ
+module_expsym_cmds=$lt_module_expsym_cmds_GCJ
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_GCJ
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_GCJ
+# shared library.
+predeps=$lt_predeps_GCJ
+# shared library.
+postdeps=$lt_postdeps_GCJ
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_GCJ
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_GCJ
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_GCJ
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_GCJ
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_GCJ
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_GCJ
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_GCJ
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_GCJ"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_GCJ
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_GCJ
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_GCJ
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_GCJ
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC="$lt_save_CC"
+	else
+	  tagname=""
+	fi
+      RC)
+# Source file extension for RC test sources.
+ac_ext=rc
+# Object file extension for compiled RC test sources.
+objext=o
+objext_RC=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
+# Code to be used in simple link tests
+lt_simple_link_test_code="$lt_simple_compile_test_code"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${RC-"windres"}
+compiler=$CC
+compiler_RC=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+lt_cv_prog_compiler_c_o_RC=yes
+  fi
+    SED SHELL STRIP \
+    compiler_RC \
+    CC_RC \
+    LD_RC \
+    lt_prog_compiler_wl_RC \
+    lt_prog_compiler_pic_RC \
+    lt_prog_compiler_static_RC \
+    lt_prog_compiler_no_builtin_flag_RC \
+    export_dynamic_flag_spec_RC \
+    thread_safe_flag_spec_RC \
+    whole_archive_flag_spec_RC \
+    enable_shared_with_static_runtimes_RC \
+    old_archive_cmds_RC \
+    old_archive_from_new_cmds_RC \
+    predep_objects_RC \
+    postdep_objects_RC \
+    predeps_RC \
+    postdeps_RC \
+    compiler_lib_search_path_RC \
+    archive_cmds_RC \
+    archive_expsym_cmds_RC \
+    postinstall_cmds_RC \
+    postuninstall_cmds_RC \
+    old_archive_from_expsyms_cmds_RC \
+    allow_undefined_flag_RC \
+    no_undefined_flag_RC \
+    export_symbols_cmds_RC \
+    hardcode_libdir_flag_spec_RC \
+    hardcode_libdir_flag_spec_ld_RC \
+    hardcode_libdir_separator_RC \
+    hardcode_automatic_RC \
+    module_cmds_RC \
+    module_expsym_cmds_RC \
+    lt_cv_prog_compiler_c_o_RC \
+    exclude_expsyms_RC \
+    include_expsyms_RC; do
+    case $var in
+    old_archive_cmds_RC | \
+    old_archive_from_new_cmds_RC | \
+    archive_cmds_RC | \
+    archive_expsym_cmds_RC | \
+    module_cmds_RC | \
+    module_expsym_cmds_RC | \
+    old_archive_from_expsyms_cmds_RC | \
+    export_symbols_cmds_RC | \
+    esac
+  done
+  case $lt_echo in
+  esac
+cfgfile="$ofile"
+SHELL=$lt_SHELL
+build_libtool_need_lc=$archive_cmds_need_lc_RC
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
+# The host system.
+host=$host
+host_os=$host_os
+build=$build
+build_os=$build_os
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+# A C compiler.
+LTCC=$lt_LTCC
+CC=$lt_compiler_RC
+with_gcc=$GCC_RC
+# An ERE matcher.
+EGREP=$lt_EGREP
+LD=$lt_LD_RC
+LN_S=$lt_LN_S
+NM=$lt_NM
+STRIP=$lt_STRIP
+DLLTOOL="$DLLTOOL"
+OBJDUMP="$OBJDUMP"
+AS="$AS"
+objdir=$objdir
+wl=$lt_lt_prog_compiler_wl_RC
+libext="$libext"
+exeext="$exeext"
+pic_flag=$lt_lt_prog_compiler_pic_RC
+pic_mode=$pic_mode
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
+link_static_flag=$lt_lt_prog_compiler_static_RC
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_RC
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
+archive_cmds=$lt_archive_cmds_RC
+archive_expsym_cmds=$lt_archive_expsym_cmds_RC
+module_cmds=$lt_module_cmds_RC
+module_expsym_cmds=$lt_module_expsym_cmds_RC
+# shared library.
+predep_objects=$lt_predep_objects_RC
+# shared library.
+postdep_objects=$lt_postdep_objects_RC
+# shared library.
+predeps=$lt_predeps_RC
+# shared library.
+postdeps=$lt_postdeps_RC
+compiler_lib_search_path=$lt_compiler_lib_search_path_RC
+allow_undefined_flag=$lt_allow_undefined_flag_RC
+no_undefined_flag=$lt_no_undefined_flag_RC
+hardcode_action=$hardcode_action_RC
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
+hardcode_direct=$hardcode_direct_RC
+hardcode_minus_L=$hardcode_minus_L_RC
+hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
+hardcode_automatic=$hardcode_automatic_RC
+link_all_deplibs=$link_all_deplibs_RC
+fix_srcfile_path="$fix_srcfile_path_RC"
+always_export_symbols=$always_export_symbols_RC
+export_symbols_cmds=$lt_export_symbols_cmds_RC
+exclude_expsyms=$lt_exclude_expsyms_RC
+include_expsyms=$lt_include_expsyms_RC
+__EOF__
+else
+  fi
+fi
+ac_ext=c
+CC="$lt_save_CC"
+	{ { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
+echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
+   { (exit 1); exit 1; }; }
+      esac
+      # Append the new tag name to the list of available tags.
+      if test -n "$tagname" ; then
+      available_tags="$available_tags $tagname"
+    fi
+    fi
+  done
+  IFS="$lt_save_ifs"
+  # Now substitute the updated list of available tags.
+  if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
+    mv "${ofile}T" "$ofile"
+    chmod +x "$ofile"
+  else
+    rm -f "${ofile}T"
+    { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
+echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
+  fi
+fi
+# This can be used to rebuild libtool when needed
+LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
+# Always use our own libtool.
+LIBTOOL='$(SHELL) $(top_builddir)/libtool'
+# Prevent multiple expansion
+# Check whether --with-libtool or --without-libtool was given.
+if test "${with_libtool+set}" = set; then
+  withval="$with_libtool"
+fi;
+if test "$with_libtool" = "no"; then
+if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ranlib; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_RANLIB+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  if test -n "$RANLIB"; then
+  ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
+else
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  for ac_exec_ext in '' $ac_executable_extensions; do
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+fi
+fi
+RANLIB=$ac_cv_prog_RANLIB
+if test -n "$RANLIB"; then
+  echo "$as_me:$LINENO: result: $RANLIB" >&5
+echo "${ECHO_T}$RANLIB" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+fi
+if test -z "$ac_cv_prog_RANLIB"; then
+  ac_ct_RANLIB=$RANLIB
+  # Extract the first word of "ranlib", so it can be a program name with args.
+set dummy ranlib; ac_word=$2
+if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
+else
+  if test -n "$ac_ct_RANLIB"; then
+  ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_RANLIB="ranlib"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_RANLIB" && ac_cv_prog_ac_ct_RANLIB=":"
+fi
+fi
+ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
+if test -n "$ac_ct_RANLIB"; then
+  echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
+echo "${ECHO_T}$ac_ct_RANLIB" >&6
+else
+fi
+  RANLIB=$ac_ct_RANLIB
+else
+  RANLIB="$ac_cv_prog_RANLIB"
+fi
+	echo 'void f(){}' > conftest.c
+	if test -z "`${CC-cc} -fPIC -c conftest.c 2>&1`"; then
+	  C_PIC=-fPIC
+	else
+	  C_PIC=
+	fi
+	if test -z "`${CXX-g++} -fPIC -c conftest.c 2>&1`"; then
+	  CXX_PIC=-fPIC
+	else
+	  CXX_PIC=
+	fi
+	rm -f conftest*
+	CXX_PIC=$CXX_PIC
+	C_PIC=$C_PIC
+  echo 'void g(); int main(){ g(); return 0; }' > conftest1.c
+  echo '#include <stdio.h>' > conftest2.c
+  echo 'void g(); void g(){printf("");}' >> conftest2.c
+  ${CC} ${C_PIC} -c conftest2.c
+  SO_EXT="so"
+  export SO_EXT
+  LD_SHARED="/bin/true"
+  if test ! -z "`uname -a | grep IRIX`" ; then
+    IRIX_ALL=-all
+  else
+    IRIX_ALL=
+  fi
+# Check whether --with-ld-shared or --without-ld-shared was given.
+if test "${with_ld_shared+set}" = set; then
+  withval="$with_ld_shared"
+fi;
+  if test "$with_ld_shared" != "" ; then
+    if test "$with_ld_shared" = "no" ; then
+      echo "user disabled shared library support."
+    else
+      echo "using user supplied .so link command ... $with_ld_shared"
+    fi
+    LD_SHARED="$with_ld_shared"
+  fi
+  if test ! -z "`uname -a | grep CYGWIN`" \
+        -a "$LD_SHARED" = "/bin/true" \
+	-a -z "`gcc -shared conftest2.o -o libconftest.dll`" ; then
+    if test -z "`${CC} conftest1.c -L./ -lconftest -o conftest1 2>&1`"; then
+      LD_LIBRARY_PATH_OLD="$LD_LIBRARY_PATH"
+      if test -z "$LD_LIBRARY_PATH" ; then
+        LD_LIBRARY_PATH="`pwd`"
+      else
+        LD_LIBRARY_PATH="`pwd`:$LD_LIBRARY_PATH"
+      fi
+      export LD_LIBRARY_PATH
+      if test -z "`./conftest1 2>&1`" ; then
+        echo "checking for Cygwin gcc -shared ... yes"
+        LD_SHARED="c++ -shared"
+        SO_EXT="dll"
+      fi
+      LD_LIBRARY_PATH="$LD_LIBRARY_PATH_OLD"
+    fi
+  fi
+  if test ! -z "`uname | grep Darwin`" \
+          -a -z "`${CXX} -dynamiclib conftest2.o -o libconftest.so 2>&1`" ; then
+    ${CC} -c conftest1.c
+    if test -z "`${CXX} conftest1.o libconftest.so -o conftest1 2>&1`"; then
+      DYLD_LIBRARY_PATH_OLD="$DYLD_LIBRARY_PATH"
+      if test -z "$DYLD_LIBRARY_PATH" ; then
+        DYLD_LIBRARY_PATH="`pwd`"
+      else
+        DYLD_LIBRARY_PATH="`pwd`:$DYLD_LIBRARY_PATH"
+      fi
+      export DYLD_LIBRARY_PATH
+        echo "checking for ${CXX} -dynamiclib ... yes"
+        LD_SHARED="${CXX} -dynamiclib"
+	SO_EXT=dylib
+      fi
+      DYLD_LIBRARY_PATH="$DYLD_LIBRARY_PATH_OLD"
+    fi
+    rm -f conftest1.o
+  fi
+  if test "$LD_SHARED" = "/bin/true" \
+	-a -z "`${CXX} -shared $IRIX_ALL conftest2.o -o libconftest.so 2>&1|grep -v WARNING`" ; then
+    if test -z "`${CC} conftest1.c libconftest.so -o conftest1 2>&1`"; then
+      else
+      fi
+        echo "checking for ${CXX} -shared ... yes"
+        LD_SHARED="${CXX} -shared $IRIX_ALL"
+      else
+        echo "checking for ${CXX} -shared ... no(3)"
+      fi
+    else
+      echo "checking for ${CXX} -shared ... no(2)"
+    fi
+  else
+    if test "$LD_SHARED" = "/bin/true" ; then
+      echo "checking for ${CXX} -shared ... no(1)"
+    fi
+  fi
+          -a -z "`ld -shared conftest2.o -o libconftest.so 2>&1`" ; then
+      else
+      fi
+        echo "checking for ld -shared ... yes"
+        LD_SHARED="ld -shared"
+      fi
+    fi
+  fi
+    echo "checking for ld -shared ... no"
+    if test ! -x /bin/true ; then
+      LD_SHARED=/usr/bin/true
+    fi
+  fi
+  if test "$LD_SHARED" = "no" ; then
+    if test -x /bin/true ; then
+      LD_SHARED=/bin/true
+    else
+    fi
+  fi
+  rm -f conftest* libconftest*
+  LD_SHARED=$LD_SHARED
+  SO_EXT=$SO_EXT
+else
+with_libtool=yes
+fi
+HAVE_LIBTOOL=$with_libtool
+echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl  $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  cat conftest.err >&5
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dl_dlopen=yes
+else
+ac_cv_lib_dl_dlopen=no
+fi
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+  cat >>confdefs.h <<_ACEOF
+#define HAVE_LIBDL 1
+_ACEOF
+  LIBS="-ldl $LIBS"
+fi
+echo "$as_me:$LINENO: checking for nanosleep in -lrt" >&5
+echo $ECHO_N "checking for nanosleep in -lrt... $ECHO_C" >&6
+if test "${ac_cv_lib_rt_nanosleep+set}" = set; then
+else
+LIBS="-lrt  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char nanosleep ();
+int
+main ()
+nanosleep ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_rt_nanosleep=yes
+else
+ac_cv_lib_rt_nanosleep=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_rt_nanosleep" >&5
+echo "${ECHO_T}$ac_cv_lib_rt_nanosleep" >&6
+if test $ac_cv_lib_rt_nanosleep = yes; then
+#define HAVE_LIBRT 1
+_ACEOF
+  LIBS="-lrt $LIBS"
+fi
+case "${host_os}" in
+    cygwin* | mingw32* | beos* | darwin*)
+echo "$as_me:$LINENO: checking for sin in -lm" >&5
+echo $ECHO_N "checking for sin in -lm... $ECHO_C" >&6
+if test "${ac_cv_lib_m_sin+set}" = set; then
+else
+LIBS="-lm  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char sin ();
+int
+main ()
+sin ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_m_sin=yes
+else
+ac_cv_lib_m_sin=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_m_sin" >&5
+echo "${ECHO_T}$ac_cv_lib_m_sin" >&6
+if test $ac_cv_lib_m_sin = yes; then
+#define HAVE_LIBM 1
+_ACEOF
+  LIBS="-lm $LIBS"
+fi
+esac
+echo "$as_me:$LINENO: checking for ANSI C header files" >&5
+echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
+if test "${ac_cv_header_stdc+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <stdlib.h>
+#include <stdarg.h>
+#include <string.h>
+#include <float.h>
+int
+main ()
+  return 0;
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>conftest.er1
+  ac_status=$?
+  ac_status=$?
+	 { ac_try='test -s conftest.$ac_objext'
+  ac_status=$?
+  ac_cv_header_stdc=yes
+else
+ac_cv_header_stdc=no
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+if test $ac_cv_header_stdc = yes; then
+  # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
+  $EGREP "memchr" >/dev/null 2>&1; then
+else
+  ac_cv_header_stdc=no
+fi
+rm -f conftest*
+fi
+  # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  $EGREP "free" >/dev/null 2>&1; then
+else
+fi
+rm -f conftest*
+fi
+  # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
+  if test "$cross_compiling" = yes; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <ctype.h>
+#if ((' ' & 0x0FF) == 0x020)
+# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
+# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
+#else
+# define ISLOWER(c) \
+		   (('a' <= (c) && (c) <= 'i') \
+		     || ('j' <= (c) && (c) <= 'r') \
+		     || ('s' <= (c) && (c) <= 'z'))
+# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
+#endif
+#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
+int
+main ()
+  int i;
+  for (i = 0; i < 256; i++)
+    if (XOR (islower (i), ISLOWER (i))
+	|| toupper (i) != TOUPPER (i))
+      exit(2);
+  exit (0);
+_ACEOF
+rm -f conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; }; then
+else
+  echo "$as_me: program exited with status $ac_status" >&5
+echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+fi
+rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+fi
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
+echo "${ECHO_T}$ac_cv_header_stdc" >&6
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
+fi
+for ac_header in assert.h fcntl.h unistd.h dbmalloc.h dlfcn.h stdint.h limits.h locale.h values.h float.h errno.h direct.h
+do
+as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
+if eval "test \"\${$as_ac_Header+set}\" = set"; then
+  echo "$as_me:$LINENO: checking for $ac_header" >&5
+echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
+else
+  # Is the header compilable?
+echo "$as_me:$LINENO: checking $ac_header usability" >&5
+echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+rm -f conftest.$ac_objext
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  ac_status=$?
+  (exit $ac_status); }; } &&
+  ac_status=$?
+  ac_header_compiler=yes
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+ac_header_compiler=no
+fi
+echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+echo "${ECHO_T}$ac_header_compiler" >&6
+# Is the header present?
+echo "$as_me:$LINENO: checking $ac_header presence" >&5
+echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+  (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+  ac_status=$?
+  (exit $ac_status); } >/dev/null; then
+  if test -s conftest.err; then
+    ac_cpp_err=$ac_c_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+  ac_header_preproc=yes
+else
+  ac_header_preproc=no
+fi
+rm -f conftest.err conftest.$ac_ext
+echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+echo "${ECHO_T}$ac_header_preproc" >&6
+# So?  What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+  yes:no: )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+  no:yes:* )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $ac_header:     check for missing prerequisite headers?" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+      cat <<\_ASBOX
+## Report this to the AC_PACKAGE_NAME lists.  ##
+_ASBOX
+      sed "s/^/$as_me: WARNING:     /" >&2
+esac
+echo "$as_me:$LINENO: checking for $ac_header" >&5
+else
+  eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
+if test `eval echo '${'$as_ac_Header'}'` = yes; then
+#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
+_ACEOF
+fi
+done
+echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5
+echo $ECHO_N "checking whether byte ordering is bigendian... $ECHO_C" >&6
+if test "${ac_cv_c_bigendian+set}" = set; then
+else
+  # See if sys/param.h defines the BYTE_ORDER macro.
+/* confdefs.h.  */
+_ACEOF
+#include <sys/types.h>
+#include <sys/param.h>
+int
+main ()
+#if !BYTE_ORDER || !BIG_ENDIAN || !LITTLE_ENDIAN
+ bogus endian macros
+#endif
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  # It does; now see whether it defined to BIG_ENDIAN or not.
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#if BYTE_ORDER != BIG_ENDIAN
+ not big endian
+#endif
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_c_bigendian=yes
+else
+ac_cv_c_bigendian=no
+fi
+else
+# It does not; compile a test program.
+if test "$cross_compiling" = yes; then
+  # try to guess the endianness by grepping values into an object file
+  ac_cv_c_bigendian=unknown
+  cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+short ascii_mm[] = { 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 };
+short ascii_ii[] = { 0x694C, 0x5454, 0x656C, 0x6E45, 0x6944, 0x6E61, 0 };
+void _ascii () { char *s = (char *) ascii_mm; s = (char *) ascii_ii; }
+short ebcdic_ii[] = { 0x89D3, 0xE3E3, 0x8593, 0x95C5, 0x89C4, 0x9581, 0 };
+short ebcdic_mm[] = { 0xC2C9, 0xC785, 0x95C4, 0x8981, 0x95E2, 0xA8E2, 0 };
+void _ebcdic () { char *s = (char *) ebcdic_mm; s = (char *) ebcdic_ii; }
+int
+main ()
+ _ascii (); _ebcdic ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  if grep BIGenDianSyS conftest.$ac_objext >/dev/null ; then
+fi
+if grep LiTTleEnDian conftest.$ac_objext >/dev/null ; then
+  if test "$ac_cv_c_bigendian" = unknown; then
+    ac_cv_c_bigendian=no
+  else
+    # finding both strings is unlikely to happen, but who knows?
+  fi
+fi
+else
+fi
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  /* Are we little or big endian?  From Harbison&Steele.  */
+  union
+    long l;
+    char c[sizeof (long)];
+  } u;
+  u.l = 1;
+  exit (u.c[sizeof (long) - 1] == 1);
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+else
+ac_cv_c_bigendian=yes
+fi
+fi
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5
+echo "${ECHO_T}$ac_cv_c_bigendian" >&6
+case $ac_cv_c_bigendian in
+  yes)
+#define WORDS_BIGENDIAN 1
+_ACEOF
+  no)
+    { { echo "$as_me:$LINENO: error: unknown endianness
+presetting ac_cv_c_bigendian=no (or yes) will help" >&5
+echo "$as_me: error: unknown endianness
+presetting ac_cv_c_bigendian=no (or yes) will help" >&2;}
+   { (exit 1); exit 1; }; } ;;
+esac
+  echo "$as_me:$LINENO: checking for 64bit integer type" >&5
+echo $ECHO_N "checking for 64bit integer type... $ECHO_C" >&6
+  echo 'int main() { long long off=0; }' >> conftest.c
+  if test -z "`${CC} -o conftest conftest.c 2>&1`" ; then
+#define HAVE_LONG_LONG 1
+_ACEOF
+    echo "$as_me:$LINENO: result: long long" >&5
+echo "${ECHO_T}long long" >&6
+  else
+  fi
+  rm -f conftest*
+# Check whether --with-unix-stdio-64 or --without-unix-stdio-64 was given.
+if test "${with_unix_stdio_64+set}" = set; then
+  withval="$with_unix_stdio_64"
+fi;
+  echo "$as_me:$LINENO: checking for 64bit file io" >&5
+echo $ECHO_N "checking for 64bit file io... $ECHO_C" >&6
+  if test x"$with_unix_stdio_64" = x"yes" ; then
+    VSI_FTELL64=ftell64
+    VSI_FSEEK64=fseek64
+  fi
+  if test x"$with_unix_stdio_64" = x"" ; then
+    echo '#include <stdio.h>' > conftest.cpp
+    echo 'int main() { long long off=0; fseek64(NULL, SEEK_SET, off); off = ftell64(NULL); return 0; }' >> conftest.c
+      with_unix_stdio_64=yes
+    fi
+    rm -f conftest*
+  fi
+    echo 'int main() { long long off=0; fseeko64(NULL, SEEK_SET, off); off = ftello64(NULL); return 0; }' >> conftest.c
+    if test -z "`${CXX} -o conftest conftest.c 2>&1`" ; then
+      VSI_FTELL64=ftello64
+      VSI_FSEEK64=fseeko64
+    fi
+    rm -f conftest*
+  fi
+    echo '#define _LARGEFILE64_SOURCE' > conftest.c
+    echo '#include <stdio.h>' >> conftest.c
+#define VSI_NEED_LARGEFILE64_SOURCE 1
+_ACEOF
+    fi
+    rm -f conftest*
+  fi
+    case "${host_os}" in
+      darwin*)
+    esac
+  fi
+    echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+    echo "$as_me:$LINENO: checking for stat64" >&5
+echo $ECHO_N "checking for stat64... $ECHO_C" >&6
+if test "${ac_cv_func_stat64+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define stat64 to an innocuous variant, in case <limits.h> declares stat64.
+   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
+#define stat64 innocuous_stat64
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char stat64 (); below.
+    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+    <limits.h> exists even on freestanding compilers.  */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef stat64
+#ifdef __cplusplus
+extern "C"
+#endif
+char stat64 ();
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_stat64) || defined (__stub___stat64)
+choke me
+#else
+char (*f) () = stat64;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != stat64;
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  ac_status=$?
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  ac_cv_func_stat64=yes
+else
+ac_cv_func_stat64=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_stat64" >&5
+echo "${ECHO_T}$ac_cv_func_stat64" >&6
+if test $ac_cv_func_stat64 = yes; then
+  VSI_STAT64=stat64 VSI_STAT64_T=stat64
+else
+  VSI_STAT64=stat VSI_STAT64_T=stat
+fi
+    echo "$as_me:$LINENO: checking for fopen64" >&5
+echo $ECHO_N "checking for fopen64... $ECHO_C" >&6
+if test "${ac_cv_func_fopen64+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define fopen64 to an innocuous variant, in case <limits.h> declares fopen64.
+#define fopen64 innocuous_fopen64
+    which can conflict with char fopen64 (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef fopen64
+#ifdef __cplusplus
+extern "C"
+#endif
+char fopen64 ();
+#if defined (__stub_fopen64) || defined (__stub___fopen64)
+choke me
+#else
+char (*f) () = fopen64;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != fopen64;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_fopen64=yes
+else
+ac_cv_func_fopen64=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_fopen64" >&5
+echo "${ECHO_T}$ac_cv_func_fopen64" >&6
+if test $ac_cv_func_fopen64 = yes; then
+  VSI_FOPEN64=fopen64
+else
+  VSI_FOPEN64=fopen
+fi
+#define UNIX_STDIO_64 1
+_ACEOF
+#define VSI_LARGE_API_SUPPORTED 1
+_ACEOF
+    export VSI_FTELL64 VSI_FSEEK64 VSI_STAT64 VSI_STAT64_T VSI_OPEN64
+cat >>confdefs.h <<_ACEOF
+#define VSI_FTELL64 $VSI_FTELL64
+_ACEOF
+#define VSI_FSEEK64 $VSI_FSEEK64
+_ACEOF
+#define VSI_STAT64 $VSI_STAT64
+_ACEOF
+#define VSI_STAT64_T $VSI_STAT64_T
+_ACEOF
+#define VSI_FOPEN64 $VSI_FOPEN64
+_ACEOF
+  else
+  fi
+echo "$as_me:$LINENO: checking for int" >&5
+echo $ECHO_N "checking for int... $ECHO_C" >&6
+if test "${ac_cv_type_int+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+if ((int *) 0)
+  return 0;
+if (sizeof (int))
+  return 0;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_type_int=yes
+else
+ac_cv_type_int=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_type_int" >&5
+echo "${ECHO_T}$ac_cv_type_int" >&6
+echo "$as_me:$LINENO: checking size of int" >&5
+echo $ECHO_N "checking size of int... $ECHO_C" >&6
+if test "${ac_cv_sizeof_int+set}" = set; then
+else
+  if test "$ac_cv_type_int" = yes; then
+  # The cast to unsigned long works around a bug in the HP C Compiler
+  # version HP92453-01 B.11.11.23709.GP, which incorrectly rejects
+  # declarations like `int a3[[(sizeof (unsigned char)) >= 0]];'.
+  # This bug is HP SR number 8606223364.
+  # Depending upon the size, compute the lo and hi bounds.
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (int))) >= 0)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_lo=0 ac_mid=0
+  while :; do
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (int))) <= $ac_mid)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_hi=$ac_mid; break
+else
+ac_lo=`expr $ac_mid + 1`
+		    if test $ac_lo -le $ac_mid; then
+		      ac_lo= ac_hi=
+		      break
+		    fi
+		    ac_mid=`expr 2 '*' $ac_mid + 1`
+fi
+  done
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (int))) < 0)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_hi=-1 ac_mid=-1
+  while :; do
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (int))) >= $ac_mid)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_lo=$ac_mid; break
+else
+ac_hi=`expr '(' $ac_mid ')' - 1`
+		       if test $ac_mid -le $ac_hi; then
+			 ac_lo= ac_hi=
+			 break
+		       fi
+		       ac_mid=`expr 2 '*' $ac_mid`
+fi
+  done
+else
+ac_lo= ac_hi=
+fi
+fi
+# Binary search between lo and hi bounds.
+while test "x$ac_lo" != "x$ac_hi"; do
+  ac_mid=`expr '(' $ac_hi - $ac_lo ')' / 2 + $ac_lo`
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_hi=$ac_mid
+else
+ac_lo=`expr '(' $ac_mid ')' + 1`
+fi
+done
+case $ac_lo in
+?*) ac_cv_sizeof_int=$ac_lo;;
+'') { { echo "$as_me:$LINENO: error: cannot compute sizeof (int), 77
+See \`config.log' for more details." >&5
+echo "$as_me: error: cannot compute sizeof (int), 77
+See \`config.log' for more details." >&2;}
+esac
+else
+  { { echo "$as_me:$LINENO: error: cannot run test program while cross compiling
+echo "$as_me: error: cannot run test program while cross compiling
+else
+/* confdefs.h.  */
+_ACEOF
+long longval () { return (long) (sizeof (int)); }
+unsigned long ulongval () { return (long) (sizeof (int)); }
+#include <stdio.h>
+int
+main ()
+  FILE *f = fopen ("conftest.val", "w");
+  if (! f)
+    exit (1);
+  if (((long) (sizeof (int))) < 0)
+      long i = longval ();
+      if (i != ((long) (sizeof (int))))
+	exit (1);
+      fprintf (f, "%ld\n", i);
+  else
+      unsigned long i = ulongval ();
+	exit (1);
+      fprintf (f, "%lu\n", i);
+  exit (ferror (f) || fclose (f) != 0);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_cv_sizeof_int=`cat conftest.val`
+else
+{ { echo "$as_me:$LINENO: error: cannot compute sizeof (int), 77
+fi
+fi
+fi
+rm -f conftest.val
+else
+  ac_cv_sizeof_int=0
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_sizeof_int" >&5
+echo "${ECHO_T}$ac_cv_sizeof_int" >&6
+#define SIZEOF_INT $ac_cv_sizeof_int
+_ACEOF
+echo "$as_me:$LINENO: checking for long" >&5
+echo $ECHO_N "checking for long... $ECHO_C" >&6
+if test "${ac_cv_type_long+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+if ((long *) 0)
+  return 0;
+if (sizeof (long))
+  return 0;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_type_long=yes
+else
+ac_cv_type_long=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_type_long" >&5
+echo "${ECHO_T}$ac_cv_type_long" >&6
+echo "$as_me:$LINENO: checking size of long" >&5
+echo $ECHO_N "checking size of long... $ECHO_C" >&6
+if test "${ac_cv_sizeof_long+set}" = set; then
+else
+  if test "$ac_cv_type_long" = yes; then
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (long))) >= 0)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_lo=0 ac_mid=0
+  while :; do
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (long))) <= $ac_mid)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+		      ac_lo= ac_hi=
+		      break
+		    fi
+fi
+  done
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (long))) < 0)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  while :; do
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+static int test_array [1 - 2 * !(((long) (sizeof (long))) >= $ac_mid)];
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+			 ac_lo= ac_hi=
+			 break
+		       fi
+fi
+  done
+else
+ac_lo= ac_hi=
+fi
+fi
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+test_array [0] = 0
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_hi=$ac_mid
+else
+fi
+done
+case $ac_lo in
+?*) ac_cv_sizeof_long=$ac_lo;;
+'') { { echo "$as_me:$LINENO: error: cannot compute sizeof (long), 77
+echo "$as_me: error: cannot compute sizeof (long), 77
+esac
+else
+else
+/* confdefs.h.  */
+_ACEOF
+long longval () { return (long) (sizeof (long)); }
+unsigned long ulongval () { return (long) (sizeof (long)); }
+#include <stdio.h>
+int
+main ()
+  if (! f)
+    exit (1);
+  if (((long) (sizeof (long))) < 0)
+      if (i != ((long) (sizeof (long))))
+	exit (1);
+  else
+	exit (1);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_cv_sizeof_long=`cat conftest.val`
+else
+{ { echo "$as_me:$LINENO: error: cannot compute sizeof (long), 77
+fi
+fi
+fi
+rm -f conftest.val
+else
+  ac_cv_sizeof_long=0
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_sizeof_long" >&5
+echo "${ECHO_T}$ac_cv_sizeof_long" >&6
+#define SIZEOF_LONG $ac_cv_sizeof_long
+_ACEOF
+echo "$as_me:$LINENO: checking for int8" >&5
+echo $ECHO_N "checking for int8... $ECHO_C" >&6
+if test "${ac_cv_type_int8+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#if HAVE_INTTYPES_H
+# include <inttypes.h>
+#endif
+int
+main ()
+if ((int8 *) 0)
+  return 0;
+if (sizeof (int8))
+  return 0;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_type_int8=yes
+else
+ac_cv_type_int8=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_type_int8" >&5
+echo "${ECHO_T}$ac_cv_type_int8" >&6
+if test $ac_cv_type_int8 = yes; then
+#define HAVE_INT8 1
+_ACEOF
+fi
+echo "$as_me:$LINENO: checking for int16" >&5
+echo $ECHO_N "checking for int16... $ECHO_C" >&6
+if test "${ac_cv_type_int16+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#endif
+int
+main ()
+if ((int16 *) 0)
+  return 0;
+if (sizeof (int16))
+  return 0;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_type_int16=yes
+else
+ac_cv_type_int16=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_type_int16" >&5
+echo "${ECHO_T}$ac_cv_type_int16" >&6
+if test $ac_cv_type_int16 = yes; then
+#define HAVE_INT16 1
+_ACEOF
+fi
+echo "$as_me:$LINENO: checking for int32" >&5
+echo $ECHO_N "checking for int32... $ECHO_C" >&6
+if test "${ac_cv_type_int32+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#endif
+int
+main ()
+if ((int32 *) 0)
+  return 0;
+if (sizeof (int32))
+  return 0;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_type_int32=yes
+else
+ac_cv_type_int32=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_type_int32" >&5
+echo "${ECHO_T}$ac_cv_type_int32" >&6
+if test $ac_cv_type_int32 = yes; then
+#define HAVE_INT32 1
+_ACEOF
+fi
+HAVE_IEEEFP=1
+#define HAVE_IEEEFP $HAVE_IEEEFP
+_ACEOF
+echo "$as_me:$LINENO: checking native cpu bit order" >&5
+echo $ECHO_N "checking native cpu bit order... $ECHO_C" >&6
+case "$target_cpu" in
+    i*86*)
+        HOST_FILLORDER=FILLORDER_LSB2MSB
+	echo "$as_me:$LINENO: result: lsb2msb" >&5
+echo "${ECHO_T}lsb2msb" >&6
+	HOST_FILLORDER=FILLORDER_MSB2LSB
+	echo "$as_me:$LINENO: result: msb2lsb" >&5
+echo "${ECHO_T}msb2lsb" >&6
+esac
+#define HOST_FILLORDER $HOST_FILLORDER
+_ACEOF
+for ac_func in vprintf
+do
+as_ac_var=`echo "ac_cv_func_$ac_func" | $as_tr_sh`
+echo "$as_me:$LINENO: checking for $ac_func" >&5
+echo $ECHO_N "checking for $ac_func... $ECHO_C" >&6
+if eval "test \"\${$as_ac_var+set}\" = set"; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define $ac_func to an innocuous variant, in case <limits.h> declares $ac_func.
+#define $ac_func innocuous_$ac_func
+    which can conflict with char $ac_func (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef $ac_func
+#ifdef __cplusplus
+extern "C"
+#endif
+char $ac_func ();
+#if defined (__stub_$ac_func) || defined (__stub___$ac_func)
+choke me
+#else
+char (*f) () = $ac_func;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != $ac_func;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  eval "$as_ac_var=yes"
+else
+eval "$as_ac_var=no"
+fi
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_var'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_var'}'`" >&6
+if test `eval echo '${'$as_ac_var'}'` = yes; then
+#define `echo "HAVE_$ac_func" | $as_tr_cpp` 1
+_ACEOF
+echo "$as_me:$LINENO: checking for _doprnt" >&5
+echo $ECHO_N "checking for _doprnt... $ECHO_C" >&6
+if test "${ac_cv_func__doprnt+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define _doprnt to an innocuous variant, in case <limits.h> declares _doprnt.
+#define _doprnt innocuous__doprnt
+    which can conflict with char _doprnt (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef _doprnt
+#ifdef __cplusplus
+extern "C"
+#endif
+char _doprnt ();
+#if defined (__stub__doprnt) || defined (__stub____doprnt)
+choke me
+#else
+char (*f) () = _doprnt;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != _doprnt;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func__doprnt=yes
+else
+ac_cv_func__doprnt=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func__doprnt" >&5
+echo "${ECHO_T}$ac_cv_func__doprnt" >&6
+if test $ac_cv_func__doprnt = yes; then
+#define HAVE_DOPRNT 1
+_ACEOF
+fi
+fi
+done
+for ac_func in snprintf vsnprintf
+do
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+#undef $ac_func
+#ifdef __cplusplus
+extern "C"
+#endif
+char $ac_func ();
+choke me
+#else
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+_ACEOF
+fi
+done
+for ac_func in atoll
+do
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+#undef $ac_func
+#ifdef __cplusplus
+extern "C"
+#endif
+char $ac_func ();
+choke me
+#else
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+_ACEOF
+fi
+done
+for ac_func in copysign copysignf strtof nan nanf
+do
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+#undef $ac_func
+#ifdef __cplusplus
+extern "C"
+#endif
+char $ac_func ();
+choke me
+#else
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+_ACEOF
+fi
+done
+for ac_func in getcwd
+do
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+#undef $ac_func
+#ifdef __cplusplus
+extern "C"
+#endif
+char $ac_func ();
+choke me
+#else
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+_ACEOF
+fi
+done
+echo "$as_me:$LINENO: checking whether nan is declared" >&5
+echo $ECHO_N "checking whether nan is declared... $ECHO_C" >&6
+if test "${ac_cv_have_decl_nan+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#ifndef nan
+  char *p = (char *) nan;
+#endif
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_have_decl_nan=yes
+else
+ac_cv_have_decl_nan=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_have_decl_nan" >&5
+echo "${ECHO_T}$ac_cv_have_decl_nan" >&6
+if test $ac_cv_have_decl_nan = yes; then
+#define HAVE_DECL_NAN 1
+_ACEOF
+else
+#define HAVE_DECL_NAN 0
+_ACEOF
+fi
+echo "$as_me:$LINENO: checking whether nanf is declared" >&5
+echo $ECHO_N "checking whether nanf is declared... $ECHO_C" >&6
+if test "${ac_cv_have_decl_nanf+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#ifndef nanf
+  char *p = (char *) nanf;
+#endif
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_have_decl_nanf=yes
+else
+ac_cv_have_decl_nanf=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_have_decl_nanf" >&5
+echo "${ECHO_T}$ac_cv_have_decl_nanf" >&6
+if test $ac_cv_have_decl_nanf = yes; then
+#define HAVE_DECL_NANF 1
+_ACEOF
+else
+#define HAVE_DECL_NANF 0
+_ACEOF
+fi
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+echo "$as_me:$LINENO: checking for gmtime_r" >&5
+echo $ECHO_N "checking for gmtime_r... $ECHO_C" >&6
+if test "${ac_cv_func_gmtime_r+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <assert.h>
+#include <time.h>
+void test_f()
+  time_t t; struct tm ltime; t = time(0); gmtime_r( &t, &ltime );
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_gmtime_r=yes
+else
+ac_cv_func_gmtime_r=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_gmtime_r" >&5
+echo "${ECHO_T}$ac_cv_func_gmtime_r" >&6
+echo "$as_me:$LINENO: checking for localtime_r" >&5
+echo $ECHO_N "checking for localtime_r... $ECHO_C" >&6
+if test "${ac_cv_func_localtime_r+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <time.h>
+void test_f()
+  time_t t; struct tm ltime; t = time(0); localtime_r( &t, &ltime );
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_localtime_r=yes
+else
+ac_cv_func_localtime_r=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_localtime_r" >&5
+echo "${ECHO_T}$ac_cv_func_localtime_r" >&6
+ac_ext=c
+echo "$as_me:$LINENO: checking for setlocale" >&5
+echo $ECHO_N "checking for setlocale... $ECHO_C" >&6
+if test "${ac_cv_func_setlocale+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define setlocale to an innocuous variant, in case <limits.h> declares setlocale.
+#define setlocale innocuous_setlocale
+    which can conflict with char setlocale (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef setlocale
+#ifdef __cplusplus
+extern "C"
+#endif
+char setlocale ();
+#if defined (__stub_setlocale) || defined (__stub___setlocale)
+choke me
+#else
+char (*f) () = setlocale;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != setlocale;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_setlocale=yes
+else
+ac_cv_func_setlocale=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_setlocale" >&5
+echo "${ECHO_T}$ac_cv_func_setlocale" >&6
+OPT_GDAL_FORMATS=
+EXTRA_INCLUDES=
+echo "$as_me:$LINENO: checking for local include/lib path" >&5
+echo $ECHO_N "checking for local include/lib path... $ECHO_C" >&6
+# Check whether --with-local or --without-local was given.
+if test "${with_local+set}" = set; then
+  withval="$with_local"
+fi;
+if test "$with_local" != "no" -a "$with_local" != "" ; then
+  if test "$with_local" = "yes" ; then
+    ADD_PREFIX=/usr/local
+  else
+    ADD_PREFIX=$with_local
+  fi
+  echo "$as_me:$LINENO: result: adding $ADD_PREFIX" >&5
+echo "${ECHO_T}adding $ADD_PREFIX" >&6
+  LIBS="$LIBS -L$ADD_PREFIX/lib"
+  CPPFLAGS="$CPPFLAGS -I$ADD_PREFIX/include"
+else
+  echo "$as_me:$LINENO: result: none" >&5
+echo "${ECHO_T}none" >&6
+fi
+THREAD_LIB=""
+THREAD_FLAG=""
+# Check whether --with-threads or --without-threads was given.
+if test "${with_threads+set}" = set; then
+  withval="$with_threads"
+fi;
+if test "$with_threads" = "yes" ; then
+  echo "$as_me:$LINENO: checking for pthread_create in -lpthread" >&5
+echo $ECHO_N "checking for pthread_create in -lpthread... $ECHO_C" >&6
+if test "${ac_cv_lib_pthread_pthread_create+set}" = set; then
+else
+LIBS="-lpthread  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pthread_create ();
+int
+main ()
+pthread_create ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_pthread_pthread_create=yes
+else
+ac_cv_lib_pthread_pthread_create=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_pthread_pthread_create" >&5
+echo "${ECHO_T}$ac_cv_lib_pthread_pthread_create" >&6
+if test $ac_cv_lib_pthread_pthread_create = yes; then
+  THREAD_FLAG=CPL_MULTIPROC_PTHREAD
+fi
+  if test -n "$THREAD_FLAG" ; then
+      THREAD_LIB="-lpthread"
+  fi
+elif test -n "$with_threads" -a "$with_threads" != "no" ; then
+  THREAD_LIB="$with_threads"
+  { echo "$as_me:$LINENO: checking whether we should include thread/mutex support......" >&5
+echo "$as_me: checking whether we should include thread/mutex support......" >&6;}
+  echo "$as_me:$LINENO: result:         using threads with link options \"$THREAD_LIB\"." >&5
+echo "${ECHO_T}        using threads with link options \"$THREAD_LIB\"." >&6
+else
+  echo "$as_me:$LINENO: result:         thread safe support disabled." >&5
+echo "${ECHO_T}        thread safe support disabled." >&6
+fi
+if test "$THREAD_FLAG" = "CPL_MULTIPROC_PTHREAD" ; then
+#define CPL_MULTIPROC_PTHREAD 1
+_ACEOF
+fi
+LIBS="$THREAD_LIB $LIBS"
+# Check whether --with-libz or --without-libz was given.
+if test "${with_libz+set}" = set; then
+  withval="$with_libz"
+fi;
+if test "$with_libz" = "external" -o "$with_libz" = "" -o "$with_libz" = "yes" ; then
+  echo "$as_me:$LINENO: checking for deflateInit_ in -lz" >&5
+echo $ECHO_N "checking for deflateInit_ in -lz... $ECHO_C" >&6
+if test "${ac_cv_lib_z_deflateInit_+set}" = set; then
+else
+LIBS="-lz  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char deflateInit_ ();
+int
+main ()
+deflateInit_ ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_z_deflateInit_=yes
+else
+ac_cv_lib_z_deflateInit_=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_z_deflateInit_" >&5
+echo "${ECHO_T}$ac_cv_lib_z_deflateInit_" >&6
+if test $ac_cv_lib_z_deflateInit_ = yes; then
+  LIBZ_SETTING=external
+else
+  LIBZ_SETTING=internal
+fi
+  if test "$LIBZ_SETTING" = "external" ; then
+    echo "$as_me:$LINENO: result: using pre-installed libz" >&5
+echo "${ECHO_T}using pre-installed libz" >&6
+  fi
+elif test "$with_libz" != "no" -a "$with_libz" != "internal" ; then
+  LIBS="-L$with_libz -L$with_libz/lib $LIBS"
+  echo "$as_me:$LINENO: result: using libz library from $with_libz" >&5
+echo "${ECHO_T}using libz library from $with_libz" >&6
+fi
+if test "$LIBZ_SETTING" = "external" ; then
+  LIBS="-lz $LIBS"
+elif test "$with_libz" = "no" ; then
+  LIBZ_SETTING=no
+  echo "$as_me:$LINENO: result: not using libz at all." >&5
+echo "${ECHO_T}not using libz at all." >&6
+else
+  OPT_GDAL_FORMATS="zlib $OPT_GDAL_FORMATS"
+  echo "$as_me:$LINENO: result: using internal libz code." >&5
+echo "${ECHO_T}using internal libz code." >&6
+fi
+LIBZ_SETTING=$LIBZ_SETTING
+PG_CONFIG=no
+# Check whether --with-pg or --without-pg was given.
+if test "${with_pg+set}" = set; then
+  withval="$with_pg"
+fi;
+if test "x$with_pg" = "xyes" -o "x$with_pg" = "x" ; then
+  # Extract the first word of "pg_config", so it can be a program name with args.
+set dummy pg_config; ac_word=$2
+if test "${ac_cv_path_PG_CONFIG+set}" = set; then
+else
+  case $PG_CONFIG in
+  ac_cv_path_PG_CONFIG="$PG_CONFIG" # Let the user override the test with a path.
+  as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+    ac_cv_path_PG_CONFIG="$as_dir/$ac_word$ac_exec_ext"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_path_PG_CONFIG" && ac_cv_path_PG_CONFIG="no"
+esac
+fi
+PG_CONFIG=$ac_cv_path_PG_CONFIG
+if test -n "$PG_CONFIG"; then
+  echo "$as_me:$LINENO: result: $PG_CONFIG" >&5
+echo "${ECHO_T}$PG_CONFIG" >&6
+else
+fi
+else
+  PG_CONFIG=$with_pg
+fi
+echo "$as_me:$LINENO: checking for PostgreSQL" >&5
+echo $ECHO_N "checking for PostgreSQL... $ECHO_C" >&6
+if test "x$PG_CONFIG" = "xno" ; then
+  HAVE_PG=no
+  PG_LIB=
+  PG_INC=
+else
+  if test -d ${PG_CONFIG} ; then
+      { { echo "$as_me:$LINENO: error: --with-pg argument is a directory.  It should be the path to the pg_config script, often somewhere like /usr/local/pgsql/bin/pg_config." >&5
+echo "$as_me: error: --with-pg argument is a directory.  It should be the path to the pg_config script, often somewhere like /usr/local/pgsql/bin/pg_config." >&2;}
+  fi
+  if test \! -x ${PG_CONFIG} ; then
+      { { echo "$as_me:$LINENO: error: --with-pg argument is a not an executable file.  It should be the path to the pg_config script, often somewhere like /usr/local/pgsql/bin/pg_config." >&5
+echo "$as_me: error: --with-pg argument is a not an executable file.  It should be the path to the pg_config script, often somewhere like /usr/local/pgsql/bin/pg_config." >&2;}
+  fi
+  ax_save_LIBS="${LIBS}"
+  LIBS="-L`$PG_CONFIG --libdir` -lpq"
+  echo "$as_me:$LINENO: checking for PQconnectdb in -lpq" >&5
+echo $ECHO_N "checking for PQconnectdb in -lpq... $ECHO_C" >&6
+if test "${ac_cv_lib_pq_PQconnectdb+set}" = set; then
+else
+LIBS="-lpq  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char PQconnectdb ();
+int
+main ()
+PQconnectdb ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_pq_PQconnectdb=yes
+else
+ac_cv_lib_pq_PQconnectdb=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_pq_PQconnectdb" >&5
+echo "${ECHO_T}$ac_cv_lib_pq_PQconnectdb" >&6
+if test $ac_cv_lib_pq_PQconnectdb = yes; then
+  HAVE_PG=yes
+else
+  HAVE_PG=no
+fi
+  LIBS="${ax_save_LIBS}"
+  if test "${HAVE_PG}" = "yes" ; then
+    LIBS="-L`$PG_CONFIG --libdir` -lpq $LIBS"
+    PG_INC="-I`$PG_CONFIG --includedir` -I`$PG_CONFIG --includedir-server`"
+    PG_EXTRA_DEC=""
+echo "$as_me:$LINENO: checking for PQputCopyData in -lpq" >&5
+echo $ECHO_N "checking for PQputCopyData in -lpq... $ECHO_C" >&6
+if test "${ac_cv_lib_pq_PQputCopyData+set}" = set; then
+else
+LIBS="-lpq  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char PQputCopyData ();
+int
+main ()
+PQputCopyData ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_pq_PQputCopyData=yes
+else
+ac_cv_lib_pq_PQputCopyData=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_pq_PQputCopyData" >&5
+echo "${ECHO_T}$ac_cv_lib_pq_PQputCopyData" >&6
+if test $ac_cv_lib_pq_PQputCopyData = yes; then
+#define HAVE_LIBPQ 1
+_ACEOF
+  LIBS="-lpq $LIBS"
+else
+  PG_EXTRA_DEC=-DPG_PRE74
+fi
+    PG_INC="${PG_INC} ${PG_EXTRA_DEC}"
+  fi
+fi
+HAVE_PG=$HAVE_PG
+PG_INC=$PG_INC
+PG_LIB=$PG_LIB
+GRASS_SETTING=no
+GRASS_INCLUDE=
+HAVE_GRASS=no
+export GRASS_INCLUDE GRASS_SETTING
+# Check whether --with-grass or --without-grass was given.
+if test "${with_grass+set}" = set; then
+  withval="$with_grass"
+fi;
+# Check whether --with-libgrass or --without-libgrass was given.
+if test "${with_libgrass+set}" = set; then
+  withval="$with_libgrass"
+fi;
+# default use of grass libraries off since we can't easily auto-find them.
+if test "$with_grass" = "" ; then
+  with_grass=no
+fi
+# Check for GRASS 5.7.0 or later library use.
+# TODO: separate libs for rasters and vectors
+if test "$with_grass" != "yes" -a "$with_grass" != "no" ; then
+  echo "$as_me:$LINENO: checking for G_asprintf in -lgrass_gis" >&5
+echo $ECHO_N "checking for G_asprintf in -lgrass_gis... $ECHO_C" >&6
+if test "${ac_cv_lib_grass_gis_G_asprintf+set}" = set; then
+else
+LIBS="-lgrass_gis -L$with_grass/lib -lgrass_datetime $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char G_asprintf ();
+int
+main ()
+G_asprintf ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_grass_gis_G_asprintf=yes
+else
+ac_cv_lib_grass_gis_G_asprintf=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_grass_gis_G_asprintf" >&5
+echo "${ECHO_T}$ac_cv_lib_grass_gis_G_asprintf" >&6
+if test $ac_cv_lib_grass_gis_G_asprintf = yes; then
+  GRASS_SETTING=grass57+
+else
+  GRASS_SETTING=no
+fi
+  if test "$GRASS_SETTING" = "grass57+" ; then
+    G_RASTLIBS="-lgrass_I"
+    G_VECTLIBS="-lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase"
+    LIBS="-L$with_grass/lib $G_VECTLIBS $G_RASTLIBS -lgrass_gproj -lgrass_vask -lgrass_gmath -lgrass_gis -lgrass_datetime $LIBS"
+    GRASS_INCLUDE="-I$with_grass/include"
+    GRASS_GISBASE="$with_grass"
+    HAVE_GRASS=yes
+  else
+    { { echo "$as_me:$LINENO: error: --with-grass=$with_grass requested, but libraries not found!" >&5
+echo "$as_me: error: --with-grass=$with_grass requested, but libraries not found!" >&2;}
+  fi
+# Check if libgrass is disabled.
+elif test "$with_libgrass" = "no" ; then
+  echo "GRASS support disabled."
+elif test "$with_libgrass" = "yes" -o "$with_libgrass" = "" ; then
+  echo "$as_me:$LINENO: checking for G_gisinit_2 in -lgrass5" >&5
+echo $ECHO_N "checking for G_gisinit_2 in -lgrass5... $ECHO_C" >&6
+if test "${ac_cv_lib_grass5_G_gisinit_2+set}" = set; then
+else
+LIBS="-lgrass5  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char G_gisinit_2 ();
+int
+main ()
+G_gisinit_2 ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_grass5_G_gisinit_2=yes
+else
+ac_cv_lib_grass5_G_gisinit_2=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_grass5_G_gisinit_2" >&5
+echo "${ECHO_T}$ac_cv_lib_grass5_G_gisinit_2" >&6
+if test $ac_cv_lib_grass5_G_gisinit_2 = yes; then
+  GRASS_SETTING=libgrass
+else
+  GRASS_SETTING=no
+fi
+  if test "$GRASS_SETTING" = "libgrass" ; then
+    LIBS="-lgrass5 $LIBS"
+  fi
+else
+else
+LIBS="-lgrass5 -L$with_libgrass/lib $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+G_gisinit_2 ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+else
+  GRASS_SETTING=no
+fi
+    LIBS="-L$with_libgrass -L$with_libgrass/lib -lgrass5 $LIBS"
+    GRASS_INCLUDE="-I$with_libgrass -I$with_libgrass/include $EXTRA_INCLUDES"
+  else
+    { { echo "$as_me:$LINENO: error: --with-libgrass=$with_grass requested, but libgrass5 not found!" >&5
+echo "$as_me: error: --with-libgrass=$with_grass requested, but libgrass5 not found!" >&2;}
+  fi
+fi
+GRASS_SETTING=$GRASS_SETTING
+GRASS_INCLUDE=$GRASS_INCLUDE
+GRASS_GISBASE=$GRASS_GISBASE
+if test "$GRASS_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="grass $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-cfitsio or --without-cfitsio was given.
+if test "${with_cfitsio+set}" = set; then
+  withval="$with_cfitsio"
+fi;
+if test "$with_cfitsio" = "no" ; then
+  FITS_SETTING=no
+  echo "FITS support disabled."
+elif test "$with_cfitsio" = "yes" -o "$with_cfitsio" = "" ; then
+  echo "$as_me:$LINENO: checking for ffopen in -lcfitsio" >&5
+echo $ECHO_N "checking for ffopen in -lcfitsio... $ECHO_C" >&6
+if test "${ac_cv_lib_cfitsio_ffopen+set}" = set; then
+else
+LIBS="-lcfitsio  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char ffopen ();
+int
+main ()
+ffopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_cfitsio_ffopen=yes
+else
+ac_cv_lib_cfitsio_ffopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_cfitsio_ffopen" >&5
+echo "${ECHO_T}$ac_cv_lib_cfitsio_ffopen" >&6
+if test $ac_cv_lib_cfitsio_ffopen = yes; then
+  FITS_SETTING=external
+else
+  FITS_SETTING=no
+fi
+  if test "$FITS_SETTING" = "external" ; then
+    LIBS="-lcfitsio $LIBS"
+    echo "using pre-installed libcfitsio."
+  else
+    echo "libcfitsio not found - FITS support disabled"
+  fi
+else
+  LIBS="-L$with_cfitsio -L$with_cfitsio/lib -lcfitsio $LIBS"
+  EXTRA_INCLUDES="-I$with_cfitsio -I$with_cfitsio/include $EXTRA_INCLUDES"
+  echo "using libcfitsio from $with_cfitsio."
+fi
+FITS_SETTING=$FITS_SETTING
+if test "$FITS_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="fits $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-pcraster or --without-pcraster was given.
+if test "${with_pcraster+set}" = set; then
+  withval="$with_pcraster"
+fi;
+if test "$with_pcraster" = "no" ; then
+  PCRASTER_SETTING=no
+  echo "PCRaster support disabled."
+elif test "$with_pcraster" = "yes" -o "$with_pcraster" = "" ; then
+  echo "$as_me:$LINENO: checking for Mopen in -lcsf" >&5
+echo $ECHO_N "checking for Mopen in -lcsf... $ECHO_C" >&6
+if test "${ac_cv_lib_csf_Mopen+set}" = set; then
+else
+LIBS="-lcsf $LIBS $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char Mopen ();
+int
+main ()
+Mopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_csf_Mopen=yes
+else
+ac_cv_lib_csf_Mopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_csf_Mopen" >&5
+echo "${ECHO_T}$ac_cv_lib_csf_Mopen" >&6
+if test $ac_cv_lib_csf_Mopen = yes; then
+  PCRASTER_SETTING=external
+else
+  PCRASTER_SETTING=internal
+fi
+for ac_header in csf.h
+do
+fi
+else
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+fi
+  yes:no: )
+  no:yes:* )
+      cat <<\_ASBOX
+_ASBOX
+esac
+else
+fi
+fi
+_ACEOF
+fi
+done
+  if test "$PCRASTER_SETTING" = "external" -a "$ac_cv_header_csf_h" = "no" ; then
+  fi
+  if test "$PCRASTER_SETTING" = "external" ; then
+    LIBS="-lcsf $LIBS"
+    echo "using pre-installed libcsf."
+  else
+    echo "using internal csf code."
+  fi
+elif test "$with_pcraster" = "internal" ; then
+else
+  LIBS="-L$with_pcraster/lib -lcsf $LIBS"
+  EXTRA_INCLUDES="-I$with_pcraster/include $EXTRA_INCLUDES"
+  echo "using libcsf from $with_pcraster."
+fi
+PCRASTER_SETTING=$PCRASTER_SETTING
+if test "$PCRASTER_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="pcraster $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-netcdf or --without-netcdf was given.
+if test "${with_netcdf+set}" = set; then
+  withval="$with_netcdf"
+fi;
+if test "$with_netcdf" = "no" ; then
+  NETCDF_SETTING=no
+  echo "netCDF support disabled."
+elif test "$with_netcdf" = "yes" -o "$with_netcdf" = "" ; then
+  echo "$as_me:$LINENO: checking for nc_open in -lnetcdf" >&5
+echo $ECHO_N "checking for nc_open in -lnetcdf... $ECHO_C" >&6
+if test "${ac_cv_lib_netcdf_nc_open+set}" = set; then
+else
+LIBS="-lnetcdf  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char nc_open ();
+int
+main ()
+nc_open ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_netcdf_nc_open=yes
+else
+ac_cv_lib_netcdf_nc_open=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_netcdf_nc_open" >&5
+echo "${ECHO_T}$ac_cv_lib_netcdf_nc_open" >&6
+if test $ac_cv_lib_netcdf_nc_open = yes; then
+  NETCDF_SETTING=yes
+else
+  NETCDF_SETTING=no
+fi
+  if test "$NETCDF_SETTING" = "yes" ; then
+    LIBS="-lnetcdf $LIBS"
+    echo "using pre-installed libnetcdf."
+  else
+    echo "libnetcdf not found - netCDF support disabled"
+  fi
+else
+  LIBS="-L$with_netcdf -L$with_netcdf/lib -lnetcdf $LIBS"
+  EXTRA_INCLUDES="-I$with_netcdf -I$with_netcdf/include $EXTRA_INCLUDES"
+  echo "using libnetcdf from $with_netcdf."
+fi
+NETCDF_SETTING=$NETCDF_SETTING
+if test "$NETCDF_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="netcdf $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-png or --without-png was given.
+if test "${with_png+set}" = set; then
+  withval="$with_png"
+fi;
+if test "$with_png" = "no" ; then
+  PNG_SETTING=no
+  echo "png support disabled."
+elif test "$with_png" = "yes" -o "$with_png" = "" ; then
+  echo "$as_me:$LINENO: checking for png_set_IHDR in -lpng" >&5
+echo $ECHO_N "checking for png_set_IHDR in -lpng... $ECHO_C" >&6
+if test "${ac_cv_lib_png_png_set_IHDR+set}" = set; then
+else
+LIBS="-lpng $LIBS $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char png_set_IHDR ();
+int
+main ()
+png_set_IHDR ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_png_png_set_IHDR=yes
+else
+ac_cv_lib_png_png_set_IHDR=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_png_png_set_IHDR" >&5
+echo "${ECHO_T}$ac_cv_lib_png_png_set_IHDR" >&6
+if test $ac_cv_lib_png_png_set_IHDR = yes; then
+  PNG_SETTING=external
+else
+  PNG_SETTING=internal
+fi
+for ac_header in png.h
+do
+fi
+else
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+fi
+  yes:no: )
+  no:yes:* )
+      cat <<\_ASBOX
+_ASBOX
+esac
+else
+fi
+fi
+_ACEOF
+fi
+done
+  if test "$PNG_SETTING" = "external" -a "$ac_cv_header_png_h" = "no" ; then
+  fi
+  if test "$PNG_SETTING" = "external" ; then
+    LIBS="-lpng $LIBS"
+    echo "using pre-installed libpng."
+  else
+    echo "using internal png code."
+  fi
+elif test "$with_png" = "internal" ; then
+else
+  LIBS="-L$with_png -L$with_png/lib -lpng $LIBS"
+  EXTRA_INCLUDES="-I$with_png -I$with_png/include $EXTRA_INCLUDES"
+  echo "using libpng from $with_png."
+fi
+PNG_SETTING=$PNG_SETTING
+if test "$PNG_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="png $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-libtiff or --without-libtiff was given.
+if test "${with_libtiff+set}" = set; then
+  withval="$with_libtiff"
+fi;
+if test "$with_libtiff" = "yes" -o "$with_libtiff" = "" ; then
+  # We now effectively require libtiff 3.6.0.
+  echo "$as_me:$LINENO: checking for TIFFGetTagListCount in -ltiff" >&5
+echo $ECHO_N "checking for TIFFGetTagListCount in -ltiff... $ECHO_C" >&6
+if test "${ac_cv_lib_tiff_TIFFGetTagListCount+set}" = set; then
+else
+LIBS="-ltiff  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char TIFFGetTagListCount ();
+int
+main ()
+TIFFGetTagListCount ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_tiff_TIFFGetTagListCount=yes
+else
+ac_cv_lib_tiff_TIFFGetTagListCount=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_tiff_TIFFGetTagListCount" >&5
+echo "${ECHO_T}$ac_cv_lib_tiff_TIFFGetTagListCount" >&6
+if test $ac_cv_lib_tiff_TIFFGetTagListCount = yes; then
+  TIFF_SETTING=external
+else
+  TIFF_SETTING=internal
+fi
+        if test "$TIFF_SETTING" = "external" ; then
+    echo "$as_me:$LINENO: checking for _TIFFsetDoubleArray in -ltiff" >&5
+echo $ECHO_N "checking for _TIFFsetDoubleArray in -ltiff... $ECHO_C" >&6
+if test "${ac_cv_lib_tiff__TIFFsetDoubleArray+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char _TIFFsetDoubleArray ();
+int
+main ()
+_TIFFsetDoubleArray ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_tiff__TIFFsetDoubleArray=yes
+else
+ac_cv_lib_tiff__TIFFsetDoubleArray=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_tiff__TIFFsetDoubleArray" >&5
+echo "${ECHO_T}$ac_cv_lib_tiff__TIFFsetDoubleArray" >&6
+if test $ac_cv_lib_tiff__TIFFsetDoubleArray = yes; then
+else
+fi
+  fi
+    LIBS="-ltiff $LIBS"
+    echo "using pre-installed libtiff."
+  else
+    echo "using internal TIFF code."
+  fi
+elif test "$with_libtiff" = "internal" ; then
+else
+  if test -r $with_libtiff/tiff.h ; then
+    LIBS="-L$with_libtiff -ltiff $LIBS"
+    EXTRA_INCLUDES="-I$with_libtiff $EXTRA_INCLUDES"
+  else
+    LIBS="-L$with_libtiff/lib -ltiff $LIBS"
+    EXTRA_INCLUDES="-I$with_libtiff/include $EXTRA_INCLUDES"
+  fi
+  echo "using libtiff from $with_libtiff."
+fi
+TIFF_SETTING=$TIFF_SETTING
+# Check whether --with-geotiff or --without-geotiff was given.
+if test "${with_geotiff+set}" = set; then
+  withval="$with_geotiff"
+fi;
+if test "$with_geotiff" = "yes" -o "$with_geotiff" = "" ; then
+  if test "$TIFF_SETTING" = "internal" ; then
+    GEOTIFF_SETTING=internal
+  else
+        echo "$as_me:$LINENO: checking for XTIFFClientOpen in -lgeotiff" >&5
+echo $ECHO_N "checking for XTIFFClientOpen in -lgeotiff... $ECHO_C" >&6
+if test "${ac_cv_lib_geotiff_XTIFFClientOpen+set}" = set; then
+else
+LIBS="-lgeotiff  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char XTIFFClientOpen ();
+int
+main ()
+XTIFFClientOpen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_geotiff_XTIFFClientOpen=yes
+else
+ac_cv_lib_geotiff_XTIFFClientOpen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_geotiff_XTIFFClientOpen" >&5
+echo "${ECHO_T}$ac_cv_lib_geotiff_XTIFFClientOpen" >&6
+if test $ac_cv_lib_geotiff_XTIFFClientOpen = yes; then
+  GEOTIFF_SETTING=external
+else
+fi
+  fi
+  if test "$GEOTIFF_SETTING" = "external" ; then
+    LIBS="-lgeotiff $LIBS"
+    echo "using pre-installed libgeotiff."
+  else
+    echo "using internal GeoTIFF code."
+  fi
+elif test "$with_geotiff" = "internal" ; then
+else
+else
+LIBS="-lgeotiff -L$with_geotiff/lib $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+else
+  GEOTIFF_SETTING=not_found
+fi
+  if test $GEOTIFF_SETTING = "external" ; then
+    LIBS="-L$with_geotiff/lib -lgeotiff $LIBS"
+    if test  -d $with_geotiff/include ; then
+      EXTRA_INCLUDES="-I$with_geotiff/include $EXTRA_INCLUDES"
+    fi
+  else
+else
+LIBS="-lgeotiff -L$with_geotiff $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+else
+  { { echo "$as_me:$LINENO: error: We require at least GeoTIFF 1.2.1. Consider using the one supplied with GDAL" >&5
+echo "$as_me: error: We require at least GeoTIFF 1.2.1. Consider using the one supplied with GDAL" >&2;}
+fi
+      LIBS="-L$with_geotiff -lgeotiff $LIBS"
+      EXTRA_INCLUDES="-I$with_geotiff $EXTRA_INCLUDES"
+    fi
+  fi
+  echo "using libgeotiff from $with_geotiff."
+fi
+GEOTIFF_SETTING=$GEOTIFF_SETTING
+# Check whether --with-jpeg or --without-jpeg was given.
+if test "${with_jpeg+set}" = set; then
+  withval="$with_jpeg"
+fi;
+if test "$with_jpeg" = "no" ; then
+  JPEG_SETTING=no
+  echo "jpeg support disabled."
+elif test "$with_jpeg" = "yes" -o "$with_jpeg" = "" ; then
+  echo "$as_me:$LINENO: checking for jpeg_read_scanlines in -ljpeg" >&5
+echo $ECHO_N "checking for jpeg_read_scanlines in -ljpeg... $ECHO_C" >&6
+if test "${ac_cv_lib_jpeg_jpeg_read_scanlines+set}" = set; then
+else
+LIBS="-ljpeg  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char jpeg_read_scanlines ();
+int
+main ()
+jpeg_read_scanlines ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_jpeg_jpeg_read_scanlines=yes
+else
+ac_cv_lib_jpeg_jpeg_read_scanlines=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_jpeg_jpeg_read_scanlines" >&5
+echo "${ECHO_T}$ac_cv_lib_jpeg_jpeg_read_scanlines" >&6
+if test $ac_cv_lib_jpeg_jpeg_read_scanlines = yes; then
+  JPEG_SETTING=external
+else
+  JPEG_SETTING=internal
+fi
+for ac_header in jpeglib.h
+do
+fi
+else
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+fi
+  yes:no: )
+  no:yes:* )
+      cat <<\_ASBOX
+_ASBOX
+esac
+else
+fi
+fi
+_ACEOF
+fi
+done
+  if test "$JPEG_SETTING" = "external" -a "$ac_cv_header_jpeglib_h" = "no" ; then
+  fi
+  if test "$JPEG_SETTING" = "external" -a "$TIFF_SETTING" = "internal" ; then
+    echo "$as_me:$LINENO: checking for width_in_blocks in jpeglib.h" >&5
+echo $ECHO_N "checking for width_in_blocks in jpeglib.h... $ECHO_C" >&6
+    rm -f conftest.c
+    echo '#include "jpeglib.h"' >> conftest.c
+    echo 'int main() { jpeg_component_info *comptr=0; int i; i = comptr->width_in_blocks; }' >> conftest.c
+    else
+    fi
+    rm -f conftest*
+  fi
+  if test "$JPEG_SETTING" = "external" ; then
+    LIBS="-ljpeg $LIBS"
+    echo "using pre-installed libjpeg."
+  else
+    echo "using internal jpeg code."
+  fi
+elif test "$with_jpeg" = "internal" ; then
+else
+  LIBS="-L$with_jpeg -L$with_jpeg/lib -ljpeg $LIBS"
+  EXTRA_INCLUDES="-I$with_jpeg -I$with_jpeg/include $EXTRA_INCLUDES"
+  echo "using libjpeg from $with_jpeg."
+fi
+JPEG_SETTING=$JPEG_SETTING
+if test "$JPEG_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="jpeg $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-gif or --without-gif was given.
+if test "${with_gif+set}" = set; then
+  withval="$with_gif"
+fi;
+if test "$with_gif" = "no" ; then
+  GIF_SETTING=no
+  echo "gif support disabled."
+elif test "$with_gif" = "yes" -o "$with_gif" = "" ; then
+  echo "$as_me:$LINENO: checking for DGifOpenFileName in -lgif" >&5
+echo $ECHO_N "checking for DGifOpenFileName in -lgif... $ECHO_C" >&6
+if test "${ac_cv_lib_gif_DGifOpenFileName+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+LIBS="-lgif  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char DGifOpenFileName ();
+int
+main ()
+DGifOpenFileName ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_gif_DGifOpenFileName=yes
+else
+ac_cv_lib_gif_DGifOpenFileName=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_gif_DGifOpenFileName" >&5
+echo "${ECHO_T}$ac_cv_lib_gif_DGifOpenFileName" >&6
+if test $ac_cv_lib_gif_DGifOpenFileName = yes; then
+  GIF_SETTING=external
+else
+  GIF_SETTING=internal
+fi
+  if test "$GIF_SETTING" = "external" ; then
+    LIBS="-lgif $LIBS"
+    echo "using pre-installed libgif."
+  else
+    echo "using internal gif code."
+  fi
+elif test "$with_gif" = "internal" ; then
+else
+  LIBS="-L$with_gif -L$with_gif/lib -lgif $LIBS"
+  EXTRA_INCLUDES="-I$with_gif -I$with_gif/include $EXTRA_INCLUDES"
+  echo "using libgif from $with_gif."
+fi
+GIF_SETTING=$GIF_SETTING
+if test "$GIF_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="gif $OPT_GDAL_FORMATS"
+fi
+OGDI_INCLUDE=
+export OGDI_INCLUDE
+# Check whether --with-ogdi or --without-ogdi was given.
+if test "${with_ogdi+set}" = set; then
+  withval="$with_ogdi"
+fi;
+if test "$with_ogdi" = "no" ; then
+  HAVE_OGDI=no
+  echo "ogdi support disabled."
+elif test "$with_ogdi" = "yes" -o "$with_ogdi" = "" ; then
+  echo "$as_me:$LINENO: checking for cln_GetLayerCapabilities in -logdi31" >&5
+echo $ECHO_N "checking for cln_GetLayerCapabilities in -logdi31... $ECHO_C" >&6
+if test "${ac_cv_lib_ogdi31_cln_GetLayerCapabilities+set}" = set; then
+else
+LIBS="-logdi31  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char cln_GetLayerCapabilities ();
+int
+main ()
+cln_GetLayerCapabilities ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_ogdi31_cln_GetLayerCapabilities=yes
+else
+ac_cv_lib_ogdi31_cln_GetLayerCapabilities=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_ogdi31_cln_GetLayerCapabilities" >&5
+echo "${ECHO_T}$ac_cv_lib_ogdi31_cln_GetLayerCapabilities" >&6
+if test $ac_cv_lib_ogdi31_cln_GetLayerCapabilities = yes; then
+  HAVE_OGDI=yes
+else
+  HAVE_OGDI=no
+fi
+  if test "$HAVE_OGDI" = "yes" ; then
+    LIBS="-logdi31 $LIBS"
+  fi
+else
+  HAVE_OGDI=yes
+  LIBS="-L$with_ogdi -L$with_ogdi/lib -logdi31 $LIBS"
+  OGDI_INCLUDE="-I$with_ogdi -I$with_ogdi/include"
+  echo "using libogdi31 from $with_ogdi."
+fi
+HAVE_OGDI=$HAVE_OGDI
+OGDI_INCLUDE=$OGDI_INCLUDE
+if test "$HAVE_OGDI" != "no" ; then
+  OPT_GDAL_FORMATS="ogdi $OPT_GDAL_FORMATS"
+fi
+X_FME_HOME=
+export X_FME_HOME
+# Check whether --with-fme or --without-fme was given.
+if test "${with_fme+set}" = set; then
+  withval="$with_fme"
+fi;
+echo "$as_me:$LINENO: checking for FMEObjects" >&5
+echo $ECHO_N "checking for FMEObjects... $ECHO_C" >&6
+if test "$with_fme" = "no" ; then
+  echo "$as_me:$LINENO: result: disabled by user" >&5
+echo "${ECHO_T}disabled by user" >&6
+elif test "$with_fme" = "yes" ; then
+  if test "$FME_HOME" = "" ; then
+    { { echo "$as_me:$LINENO: error: no, FME_HOME not defined!" >&5
+echo "$as_me: error: no, FME_HOME not defined!" >&2;}
+  elif test -f $FME_HOME/fmeobjects/cpp/isession.h ; then
+    X_FME_HOME=$FME_HOME
+  else
+    { { echo "$as_me:$LINENO: error: FME_HOME defined, but $FME_HOME/fmeobjects/cpp/issesion.h not found." >&5
+echo "$as_me: error: FME_HOME defined, but $FME_HOME/fmeobjects/cpp/issesion.h not found." >&2;}
+  fi
+elif test "$with_fme" = "" ; then
+    echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+  else
+    echo "$as_me:$LINENO: result: no, FME_HOME defined, but $FME_HOME/fmeobjects/cpp/issesion.h not found." >&5
+echo "${ECHO_T}no, FME_HOME defined, but $FME_HOME/fmeobjects/cpp/issesion.h not found." >&6
+  fi
+else
+  if test -f $with_fme/fmeobjects/cpp/isession.h ; then
+    X_FME_HOME=$with_fme
+  else
+    { { echo "$as_me:$LINENO: error: $with_fme/fmeobjects/cpp/issesion.h not found!" >&5
+echo "$as_me: error: $with_fme/fmeobjects/cpp/issesion.h not found!" >&2;}
+  fi
+fi
+X_FME_HOME=$X_FME_HOME
+HDF4_INCLUDE=
+export HDF4_INCLUDE
+# Check whether --with-hdf4 or --without-hdf4 was given.
+if test "${with_hdf4+set}" = set; then
+  withval="$with_hdf4"
+fi;
+if test "$with_hdf4" = "no" ; then
+  HAVE_HDF4=no
+  echo "hdf4 support disabled."
+elif test "$with_hdf4" = "yes" -o "$with_hdf4" = "" ; then
+  echo "$as_me:$LINENO: checking for SDreaddata in -lmfhdf" >&5
+echo $ECHO_N "checking for SDreaddata in -lmfhdf... $ECHO_C" >&6
+if test "${ac_cv_lib_mfhdf_SDreaddata+set}" = set; then
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-lmfhdf -ldf $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char SDreaddata ();
+int
+main ()
+SDreaddata ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  cat conftest.err >&5
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_mfhdf_SDreaddata=yes
+else
+ac_cv_lib_mfhdf_SDreaddata=no
+fi
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_mfhdf_SDreaddata" >&5
+echo "${ECHO_T}$ac_cv_lib_mfhdf_SDreaddata" >&6
+if test $ac_cv_lib_mfhdf_SDreaddata = yes; then
+  HAVE_HDF4=yes
+else
+  HAVE_HDF4=no
+fi
+  if test "$HAVE_HDF4" = "yes" ; then
+    LIBS="-lmfhdf -ldf $LIBS"
+  fi
+  if test "$HAVE_HDF4" = "yes" -a -r /usr/include/hdf/hdf.h ; then
+    HDF4_INCLUDE="-I/usr/include/hdf"
+  fi
+else
+  if test -d $with_hdf4/lib ; then
+    HDF_LIB_DIR=$with_hdf4/lib
+  else
+  fi
+  ORIG_LIBS="$LIBS"
+  LIBS="-L$HDF_LIB_DIR $LIBS"
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+SDreaddata ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  HDF_LIB_NAME="-lmfhdf -ldf"
+else
+  HDF_LIB_NAME=missing
+fi
+  if test "$HDF_LIB_NAME" = "missing" ; then
+    echo "$as_me:$LINENO: checking for SDreaddata in -lhdf4" >&5
+echo $ECHO_N "checking for SDreaddata in -lhdf4... $ECHO_C" >&6
+if test "${ac_cv_lib_hdf4_SDreaddata+set}" = set; then
+else
+LIBS="-lhdf4  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+SDreaddata ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_hdf4_SDreaddata=yes
+else
+ac_cv_lib_hdf4_SDreaddata=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_hdf4_SDreaddata" >&5
+echo "${ECHO_T}$ac_cv_lib_hdf4_SDreaddata" >&6
+if test $ac_cv_lib_hdf4_SDreaddata = yes; then
+  HDF_LIB_NAME=-lhdf4
+else
+fi
+  fi
+    unset ac_cv_lib_mfhdf_SDreaddata
+else
+LIBS="-lmfhdf -ldf -ljpeg -lz $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+SDreaddata ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+else
+fi
+  fi
+else
+LIBS="-lmfhdf -ldf -lsz -ljpeg -lz $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+SDreaddata ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  HDF_LIB_NAME="-lmfhdf -ldf -lsz"
+else
+fi
+  fi
+    { { echo "$as_me:$LINENO: error: HDF4 support requested with arg $with_hdf4, but neither hdf4 nor mfhdf lib found" >&5
+echo "$as_me: error: HDF4 support requested with arg $with_hdf4, but neither hdf4 nor mfhdf lib found" >&2;}
+  fi
+  LIBS="-L$HDF_LIB_DIR $HDF_LIB_NAME $ORIG_LIBS"
+  if test -r "$with_hdf4/hdf/hdf.h" ; then
+    HDF4_INCLUDE="-I$with_hdf4/hdf"
+  elif test -r "$with_hdf4/include/hdf/hdf.h" ; then
+    HDF4_INCLUDE="-I$with_hdf4/include/hdf"
+  elif test -r "$with_hdf4/include/hdf.h" ; then
+    HDF4_INCLUDE="-I$with_hdf4/include"
+  elif test -r "$with_hdf4/hdf.h" ; then
+    HDF4_INCLUDE="-I$wHDF4_INCLUDEith_hdf4"
+  fi
+  HAVE_HDF4=yes
+fi
+HAVE_HDF4=$HAVE_HDF4
+HDF4_INCLUDE=$HDF4_INCLUDE
+if test "$HAVE_HDF4" != "no" ; then
+  OPT_GDAL_FORMATS="hdf4 $OPT_GDAL_FORMATS"
+fi
+HDF5_INCLUDE=
+export HDF5_INCLUDE
+# Check whether --with-hdf5 or --without-hdf5 was given.
+if test "${with_hdf5+set}" = set; then
+  withval="$with_hdf5"
+fi;
+if test "$with_hdf5" = "no" ; then
+  HAVE_HDF5=no
+  echo "hdf5 support disabled."
+elif test "$with_hdf5" = "yes" -o "$with_hdf5" = "" ; then
+  echo "$as_me:$LINENO: checking for H5Fopen in -lhdf5" >&5
+echo $ECHO_N "checking for H5Fopen in -lhdf5... $ECHO_C" >&6
+if test "${ac_cv_lib_hdf5_H5Fopen+set}" = set; then
+else
+LIBS="-lhdf5  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char H5Fopen ();
+int
+main ()
+H5Fopen ();
+  return 0;
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  ac_status=$?
+  (exit $ac_status); }; }; then
+  ac_cv_lib_hdf5_H5Fopen=yes
+else
+ac_cv_lib_hdf5_H5Fopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_hdf5_H5Fopen" >&5
+echo "${ECHO_T}$ac_cv_lib_hdf5_H5Fopen" >&6
+if test $ac_cv_lib_hdf5_H5Fopen = yes; then
+  HAVE_HDF5=yes
+else
+  HAVE_HDF5=no
+fi
+  if test "$HAVE_HDF5" = "yes" ; then
+    LIBS="-lhdf5 $LIBS"
+  fi
+  if test "$HAVE_HDF5" = "yes" -a -r /usr/include/hdf5.h ; then
+    HDF5_INCLUDE="-I/usr/include"
+  fi
+else
+  if test -d $with_hdf5/lib ; then
+    HDF5_LIB_DIR=$with_hdf5/lib
+  else
+  fi
+  ORIG_LIBS="$LIBS"
+  LIBS="-L$HDF5_LIB_DIR $LIBS -lhdf5"
+else
+LIBS="-lhdf5 -lhdf5 $LIBS"
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+char H5Fopen ();
+int
+main ()
+H5Fopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  ac_status=$?
+  (exit $ac_status); }; } &&
+  ac_status=$?
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+fi
+  HDF5_LIB_NAME="-lhdf5 "
+else
+  HDF5_LIB_NAME=missing
+fi
+  fi
+  LIBS="-L$HDF5_LIB_DIR $HDF5_LIB_NAME $ORIG_LIBS"
+  if test -r "$with_hdf5/hdf5/hdf5.h" ; then
+    HDF5_INCLUDE="-I$with_hdf5/hdf5"
+  elif test -r "$with_hdf5/include/hdf5/hdf5.h" ; then
+    HDF5_INCLUDE="-I$with_hdf5/include/hdf5"
+  elif test -r "$with_hdf5/include/hdf5.h" ; then
+    HDF5_INCLUDE="-I$with_hdf5/include"
+  elif test -r "$with_hdf5/hdf.h" ; then
+    HDF5_INCLUDE="-I$with_hdf5"
+  fi
+  HAVE_HDF5=yes
+fi
+HAVE_HDF5=$HAVE_HDF5
+HDF5_INCLUDE=$HDF5_INCLUDE
+if test "$HAVE_HDF5" != "no" ; then
+  OPT_GDAL_FORMATS="hdf5 $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-jasper or --without-jasper was given.
+if test "${with_jasper+set}" = set; then
+  withval="$with_jasper"
+fi;
+if test "$with_jasper" = "no" ; then
+  HAVE_JASPER=no
+  { echo "$as_me:$LINENO: JasPer (JPEG2000) support disabled." >&5
+echo "$as_me: JasPer (JPEG2000) support disabled." >&6;}
+elif test "$with_jasper" = "yes" -o "$with_jasper" = "" ; then
+  echo "$as_me:$LINENO: checking for jpc_decode in -ljasper" >&5
+echo $ECHO_N "checking for jpc_decode in -ljasper... $ECHO_C" >&6
+if test "${ac_cv_lib_jasper_jpc_decode+set}" = set; then
+else
+LIBS="-ljasper  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char jpc_decode ();
+int
+main ()
+jpc_decode ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_jasper_jpc_decode=yes
+else
+ac_cv_lib_jasper_jpc_decode=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_jasper_jpc_decode" >&5
+echo "${ECHO_T}$ac_cv_lib_jasper_jpc_decode" >&6
+if test $ac_cv_lib_jasper_jpc_decode = yes; then
+  HAVE_JASPER=yes
+else
+  HAVE_JASPER=no
+fi
+  echo "$as_me:$LINENO: checking for jp2_decode in -ljasper" >&5
+echo $ECHO_N "checking for jp2_decode in -ljasper... $ECHO_C" >&6
+if test "${ac_cv_lib_jasper_jp2_decode+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char jp2_decode ();
+int
+main ()
+jp2_decode ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_jasper_jp2_decode=yes
+else
+ac_cv_lib_jasper_jp2_decode=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_jasper_jp2_decode" >&5
+echo "${ECHO_T}$ac_cv_lib_jasper_jp2_decode" >&6
+if test $ac_cv_lib_jasper_jp2_decode = yes; then
+  HAVE_JASPER=yes
+else
+  HAVE_JASPER=no
+fi
+  echo "$as_me:$LINENO: checking for pgx_decode in -ljasper" >&5
+echo $ECHO_N "checking for pgx_decode in -ljasper... $ECHO_C" >&6
+if test "${ac_cv_lib_jasper_pgx_decode+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pgx_decode ();
+int
+main ()
+pgx_decode ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_jasper_pgx_decode=yes
+else
+ac_cv_lib_jasper_pgx_decode=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_jasper_pgx_decode" >&5
+echo "${ECHO_T}$ac_cv_lib_jasper_pgx_decode" >&6
+if test $ac_cv_lib_jasper_pgx_decode = yes; then
+  HAVE_JASPER=yes
+else
+  HAVE_JASPER=no
+fi
+  if test "$HAVE_JASPER" = "yes" ; then
+    LIBS="-ljasper $LIBS"
+  fi
+else
+  HAVE_JASPER=yes
+  LIBS="-L$with_jasper -L$with_jasper/lib -ljasper $LIBS"
+  EXTRA_INCLUDES="-I$with_jasper -I$with_jasper/include $EXTRA_INCLUDES"
+  { echo "$as_me:$LINENO: using JasPer library from $with_jasper." >&5
+echo "$as_me: using JasPer library from $with_jasper." >&6;}
+fi
+if test "$HAVE_JASPER" != "no" ; then
+  OPT_GDAL_FORMATS="jpeg2000 $OPT_GDAL_FORMATS"
+  echo "$as_me:$LINENO: checking for jp2_encode_uuid in -ljasper" >&5
+echo $ECHO_N "checking for jp2_encode_uuid in -ljasper... $ECHO_C" >&6
+if test "${ac_cv_lib_jasper_jp2_encode_uuid+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char jp2_encode_uuid ();
+int
+main ()
+jp2_encode_uuid ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_jasper_jp2_encode_uuid=yes
+else
+ac_cv_lib_jasper_jp2_encode_uuid=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_jasper_jp2_encode_uuid" >&5
+echo "${ECHO_T}$ac_cv_lib_jasper_jp2_encode_uuid" >&6
+if test $ac_cv_lib_jasper_jp2_encode_uuid = yes; then
+  HAVE_JASPER_UUID=yes
+else
+  HAVE_JASPER_UUID=no
+fi
+  if test "$HAVE_JASPER_UUID" = "yes" ; then
+    { echo "$as_me:$LINENO: hacked JasPer version found (JasPer UUID), GeoJP2 enabled." >&5
+echo "$as_me: hacked JasPer version found (JasPer UUID), GeoJP2 enabled." >&6;}
+    JASPER_FLAGS=-DHAVE_JASPER_UUID
+  else
+    { echo "$as_me:$LINENO: hacked JasPer version not found, GeoJP2 disabled." >&5
+echo "$as_me: hacked JasPer version not found, GeoJP2 disabled." >&6;}
+  fi
+fi
+HAVE_JASPER=$HAVE_JASPER
+JASPER_FLAGS=$JASPER_FLAGS
+# Check whether --with-ecw or --without-ecw was given.
+if test "${with_ecw+set}" = set; then
+  withval="$with_ecw"
+fi;
+if test ! -z "`uname | grep Darwin`" ; then
+  CARBON_FRAMEWORK="-framework Carbon"
+else
+  CARBON_FRAMEWORK=
+fi
+if test "$with_ecw" = "no" ; then
+  ECW_SETTING=no
+  echo "ECW support disabled."
+elif test "$with_ecw" = "yes" -o "$with_ecw" = "" ; then
+  echo "$as_me:$LINENO: checking for NCScbmOpenFileView in -lNCSEcw" >&5
+echo $ECHO_N "checking for NCScbmOpenFileView in -lNCSEcw... $ECHO_C" >&6
+if test "${ac_cv_lib_NCSEcw_NCScbmOpenFileView+set}" = set; then
+else
+LIBS="-lNCSEcw -lNCSCnet -lNCSUtil $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char NCScbmOpenFileView ();
+int
+main ()
+NCScbmOpenFileView ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_NCSEcw_NCScbmOpenFileView=yes
+else
+ac_cv_lib_NCSEcw_NCScbmOpenFileView=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_NCSEcw_NCScbmOpenFileView" >&5
+echo "${ECHO_T}$ac_cv_lib_NCSEcw_NCScbmOpenFileView" >&6
+if test $ac_cv_lib_NCSEcw_NCScbmOpenFileView = yes; then
+  ECW_SETTING=yes
+else
+  ECW_SETTING=no
+fi
+  if test "$ECW_SETTING" = "yes" ; then
+    LIBS="-lNCSEcw -lNCSCnet -lNCSUtil $LIBS"
+  fi
+  if test "$ECW_SETTING" = "no" ; then
+    echo "$as_me:$LINENO: checking for NCScbmOpenFileView in -lecwj2" >&5
+echo $ECHO_N "checking for NCScbmOpenFileView in -lecwj2... $ECHO_C" >&6
+if test "${ac_cv_lib_ecwj2_NCScbmOpenFileView+set}" = set; then
+else
+LIBS="-lecwj2 $CARBON_FRAMEWORK $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_ecwj2_NCScbmOpenFileView=yes
+else
+ac_cv_lib_ecwj2_NCScbmOpenFileView=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_ecwj2_NCScbmOpenFileView" >&5
+echo "${ECHO_T}$ac_cv_lib_ecwj2_NCScbmOpenFileView" >&6
+if test $ac_cv_lib_ecwj2_NCScbmOpenFileView = yes; then
+  ECW_SETTING=yes
+else
+  ECW_SETTING=no
+fi
+      LIBS="-lecwj2 $CARBON_FRAMEWORK $LIBS"
+    fi
+  fi
+else
+  echo "$as_me:$LINENO: checking for libNCSEcw.so or libecwj2" >&5
+echo $ECHO_N "checking for libNCSEcw.so or libecwj2... $ECHO_C" >&6
+  ECW_SETTING=yes
+  if test -r $with_ecw/lib/libNCSCnet.so ; then
+    LIBS="-L$with_ecw/lib -lNCSEcw -lNCSCnet -lNCSUtil $LIBS"
+    echo "$as_me:$LINENO: result: found in $with_ecw/lib." >&5
+echo "${ECHO_T}found in $with_ecw/lib." >&6
+  elif test -r $with_ecw/lib/libNCSCNet.so ; then
+    LIBS="-L$with_ecw/lib -lNCSEcw -lNCSCNet -lNCSUtil $LIBS"
+  elif test -r $with_ecw/bin/libNCSEcw.so ; then
+    LIBS="-L$with_ecw/bin -lNCSEcw -lNCSEcw -lNCSCnet $LIBS"
+    echo "$as_me:$LINENO: result: found in $with_ecw/bin." >&5
+echo "${ECHO_T}found in $with_ecw/bin." >&6
+  elif test -r $with_ecw/lib/libecwj2.dylib ; then
+    LIBS="-L$with_ecw/lib -lecwj2 $CARBON_FRAMEWORK $LIBS"
+    echo "$as_me:$LINENO: result: found libecwj2 in $with_ecw/lib." >&5
+echo "${ECHO_T}found libecwj2 in $with_ecw/lib." >&6
+  else
+    { { echo "$as_me:$LINENO: error: not found in $with_ecw/lib or $with_ecw/bin." >&5
+echo "$as_me: error: not found in $with_ecw/lib or $with_ecw/bin." >&2;}
+   { (exit 1); exit 1; }; }
+  fi
+  echo "$as_me:$LINENO: checking for NCSECWClient.h in $with_ecw/include" >&5
+echo $ECHO_N "checking for NCSECWClient.h in $with_ecw/include... $ECHO_C" >&6
+  if test -r $with_ecw/include/NCSECWClient.h ; then
+    echo "$as_me:$LINENO: result: found." >&5
+echo "${ECHO_T}found." >&6
+    EXTRA_INCLUDES="-I$with_ecw/include $EXTRA_INCLUDES"
+  else
+    { { echo "$as_me:$LINENO: error: not found." >&5
+echo "$as_me: error: not found." >&2;}
+  fi
+fi
+ECW_SETTING=$ECW_SETTING
+if test "$ECW_SETTING" != "no" ; then
+  OPT_GDAL_FORMATS="ecw $OPT_GDAL_FORMATS"
+fi
+echo "$as_me:$LINENO: checking for Kakadu JPEG2000 support" >&5
+echo $ECHO_N "checking for Kakadu JPEG2000 support... $ECHO_C" >&6
+# Check whether --with-kakadu or --without-kakadu was given.
+if test "${with_kakadu+set}" = set; then
+  withval="$with_kakadu"
+fi;
+if test "$with_kakadu" = "no" -o "$with_kakadu" = "" ; then
+  KAKDIR=
+  echo "$as_me:$LINENO: result: not requested." >&5
+echo "${ECHO_T}not requested." >&6
+  HAVE_KAKADU=no
+elif test "$with_kakadu" = "yes" ; then
+For JPEG2000 support using Kakadu you need provide the path to the Kakadu
+build directory.  Note that Kakadu is *not* free software." >&5
+build directory.  Note that Kakadu is *not* free software." >&2;}
+else
+  KAKDIR=$with_kakadu
+  OPT_GDAL_FORMATS="jp2kak $OPT_GDAL_FORMATS"
+  LIBS="$LIBS -L$with_kakadu/lib -lkdu"
+  echo "$as_me:$LINENO: result: requested." >&5
+echo "${ECHO_T}requested." >&6
+  HAVE_KAKADU=yes
+fi
+KAKDIR=$KAKDIR
+MRSID_FLAGS=
+# Check whether --with-mrsid or --without-mrsid was given.
+if test "${with_mrsid+set}" = set; then
+  withval="$with_mrsid"
+fi;
+# Check whether --with-jp2mrsid or --without-jp2mrsid was given.
+if test "${with_jp2mrsid+set}" = set; then
+  withval="$with_jp2mrsid"
+fi;
+if test "x$with_mrsid" = "xno"  -o "x$with_mrsid" = "x" ; then
+  HAVE_MRSID=no
+  { echo "$as_me:$LINENO: MrSID support disabled." >&5
+echo "$as_me: MrSID support disabled." >&6;}
+else
+  echo "$as_me:$LINENO: checking for lt_base.h in $with_mrsid/include/support" >&5
+echo $ECHO_N "checking for lt_base.h in $with_mrsid/include/support... $ECHO_C" >&6
+  if test -r "$with_mrsid/include/support/lt_base.h" ; then
+    echo "$as_me:$LINENO: result: found MrSID DSDK version 4.x or newer." >&5
+echo "${ECHO_T}found MrSID DSDK version 4.x or newer." >&6
+    HAVE_MRSID=yes
+    MRSID_INCLUDE="-I$with_mrsid/include/base -I$with_mrsid/include/metadata -I$with_mrsid/include/mrsid_readers -I$with_mrsid/include/j2k_readers -I$with_mrsid/include/support"
+    MRSID_LIBS="-lltidsdk -lpthread"
+    echo "$as_me:$LINENO: checking for MG3ImageWriter.h in $with_mrsid/include/mrsid_writers" >&5
+echo $ECHO_N "checking for MG3ImageWriter.h in $with_mrsid/include/mrsid_writers... $ECHO_C" >&6
+    if test -r "$with_mrsid/include/mrsid_writers/MG3ImageWriter.h" ; then
+      echo "$as_me:$LINENO: result: found MrSID ESDK version 4.x or newer." >&5
+echo "${ECHO_T}found MrSID ESDK version 4.x or newer." >&6
+      MRSID_FLAGS="-DMRSID_ESDK $MRSID_FLAGS"
+      MRSID_INCLUDE="-I$with_mrsid/include/mrsid_writers -I$with_mrsid/include/j2k_writers $MRSID_INCLUDE"
+      if test -r $with_mrsid/3rd-party/lib/Release/libcryptopp.a ; then
+        MRSID_LIBS="-lltiesdk -lcryptopp -lxmlparse $MRSID_LIBS"
+      else
+        MRSID_LIBS="-lltiesdk -lxmlparse $MRSID_LIBS"
+      fi
+    else
+      echo "$as_me:$LINENO: result: no encoding support." >&5
+echo "${ECHO_T}no encoding support." >&6
+    fi
+    echo "$as_me:$LINENO: checking for MrSID JPEG2000 support" >&5
+echo $ECHO_N "checking for MrSID JPEG2000 support... $ECHO_C" >&6
+    if test "x$with_jp2mrsid" = "xyes" -a "$HAVE_KAKADU" = "yes" ; then
+      { { echo "$as_me:$LINENO: error: MrSID JPEG2000 support requested, but this is incompatible with use of standalone Kakadu" >&5
+echo "$as_me: error: MrSID JPEG2000 support requested, but this is incompatible with use of standalone Kakadu" >&2;}
+    fi
+    if test "x$with_jp2mrsid" = "x" -a "$HAVE_KAKADU" = "no" \
+            -a -r $with_mrsid/3rd-party/lib/Release/libltikdu.a ; then
+      with_jp2mrsid=yes
+    fi
+    if test "x$with_jp2mrsid" = "xyes" \
+            -a ! -r $with_mrsid/3rd-party/lib/Release/libltikdu.a ; then
+      { { echo "$as_me:$LINENO: error: MrSID JPEG2000 support requested, but libltikdu.a not found." >&5
+echo "$as_me: error: MrSID JPEG2000 support requested, but libltikdu.a not found." >&2;}
+    fi
+    if test "x$with_jp2mrsid" = "xyes" ; then
+      MRSID_LIBS="$MRSID_LIBS -lltikdu"
+      MRSID_FLAGS="-DMRSID_J2K $MRSID_FLAGS"
+      echo "$as_me:$LINENO: result: enabled" >&5
+echo "${ECHO_T}enabled" >&6
+    else
+      echo "$as_me:$LINENO: result: disabled" >&5
+echo "${ECHO_T}disabled" >&6
+    fi
+    if test -r "$with_mrsid/lib/libltidsdk.a" ; then
+      MRSID_LIBS="-L$with_mrsid/lib -L$with_mrsid/3rd-party/lib $MRSID_LIBS"
+    else
+      MRSID_LIBS="-L$with_mrsid/lib/Release -L$with_mrsid/3rd-party/lib/Release $MRSID_LIBS"
+    fi
+    LIBS="$MRSID_LIBS $LIBS"
+  else
+    HAVE_MRSID=no
+    echo "$as_me:$LINENO: result: not found." >&5
+echo "${ECHO_T}not found." >&6
+    { { echo "$as_me:$LINENO: error:   MrSID requested, but components not found." >&5
+echo "$as_me: error:   MrSID requested, but components not found." >&2;}
+  fi
+fi
+HAVE_MRSID=$HAVE_MRSID
+MRSID_INCLUDE=$MRSID_INCLUDE
+MRSID_FLAGS=$MRSID_FLAGS
+if test "$HAVE_MRSID" != "no" ; then
+  CPPFLAGS="-D_REENTRANT $CPPFLAGS"
+  OPT_GDAL_FORMATS="mrsid $OPT_GDAL_FORMATS"
+fi
+# Check whether --with-bsb or --without-bsb was given.
+if test "${with_bsb+set}" = set; then
+  withval="$with_bsb"
+fi;
+if test "$with_bsb" = yes -o x"$with_bsb" = x ; then
+  echo checking for BSB ... enabled
+  OPT_GDAL_FORMATS="bsb $OPT_GDAL_FORMATS"
+else
+  echo checking for BSB ... disabled by user
+fi
+OPT_GDAL_FORMATS=$OPT_GDAL_FORMATS
+# Check whether --with-ogr or --without-ogr was given.
+if test "${with_ogr+set}" = set; then
+  withval="$with_ogr"
+fi;
+if test "$with_ogr" = yes -o x"$with_ogr" = x ; then
+  echo checking for OGR ... enabled
+  OGR_ENABLED=yes
+else
+  echo checking for OGR ... disabled by user
+  OGR_ENABLED=no
+fi
+OGR_ENABLED=$OGR_ENABLED
+MYSQL_CONFIG=no
+# Check whether --with-mysql or --without-mysql was given.
+if test "${with_mysql+set}" = set; then
+  withval="$with_mysql"
+fi;
+if test "$with_mysql" = "yes" ; then
+  # Extract the first word of "mysql_config", so it can be a program name with args.
+set dummy mysql_config; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_path_MYSQL_CONFIG+set}" = set; then
+else
+  case $MYSQL_CONFIG in
+  ac_cv_path_MYSQL_CONFIG="$MYSQL_CONFIG" # Let the user override the test with a path.
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  for ac_exec_ext in '' $ac_executable_extensions; do
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_path_MYSQL_CONFIG="$as_dir/$ac_word$ac_exec_ext"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_path_MYSQL_CONFIG" && ac_cv_path_MYSQL_CONFIG="no"
+esac
+fi
+MYSQL_CONFIG=$ac_cv_path_MYSQL_CONFIG
+if test -n "$MYSQL_CONFIG"; then
+  echo "$as_me:$LINENO: result: $MYSQL_CONFIG" >&5
+echo "${ECHO_T}$MYSQL_CONFIG" >&6
+else
+fi
+else
+    if test "x$with_mysql" != "x" ; then
+      MYSQL_CONFIG=$with_mysql
+    fi
+fi
+echo "$as_me:$LINENO: checking for MySQL" >&5
+echo $ECHO_N "checking for MySQL... $ECHO_C" >&6
+if test "$MYSQL_CONFIG" = "no" ; then
+  HAVE_MYSQL=no
+  MYSQL_LIB=
+  MYSQL_INC=
+else
+  if test -d $MYSQL_CONFIG ; then
+      { { echo "$as_me:$LINENO: error: --with-mysql argument is a directory.  It should be the path to the mysql_config script, often somewhere like /usr/local/bin/mysql_config." >&5
+echo "$as_me: error: --with-mysql argument is a directory.  It should be the path to the mysql_config script, often somewhere like /usr/local/bin/mysql_config." >&2;}
+  fi
+  if test \! -x $MYSQL_CONFIG ; then
+      { { echo "$as_me:$LINENO: error: --with-mysql argument is a not an executable file.  It should be the path to the mysql_config script, often somewhere like /usr/local/bin/mysql_config." >&5
+echo "$as_me: error: --with-mysql argument is a not an executable file.  It should be the path to the mysql_config script, often somewhere like /usr/local/bin/mysql_config." >&2;}
+  fi
+  MYSQL_VERSION="`$MYSQL_CONFIG --version`"
+  case ${MYSQL_VERSION} in
+    [0-3]*)
+      HAVE_MYSQL=no
+      echo "$as_me:$LINENO: result: no, mysql is pre-4.x" >&5
+echo "${ECHO_T}no, mysql is pre-4.x" >&6
+      HAVE_MYSQL=yes
+      MYSQL_LIB="`$MYSQL_CONFIG --libs`"
+      MYSQL_INC="`$MYSQL_CONFIG --include`"
+      echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+  esac
+fi
+HAVE_MYSQL=$HAVE_MYSQL
+MYSQL_INC=$MYSQL_INC
+MYSQL_LIB=$MYSQL_LIB
+HAVE_XERCES=no
+echo "$as_me:$LINENO: checking for Xerces C++" >&5
+echo $ECHO_N "checking for Xerces C++... $ECHO_C" >&6
+# Check whether --with-xerces or --without-xerces was given.
+if test "${with_xerces+set}" = set; then
+  withval="$with_xerces"
+fi;
+# Check whether --with-xerces_inc or --without-xerces_inc was given.
+if test "${with_xerces_inc+set}" = set; then
+  withval="$with_xerces_inc"
+fi;
+# Check whether --with-xerces_lib or --without-xerces_lib was given.
+if test "${with_xerces_lib+set}" = set; then
+  withval="$with_xerces_lib"
+fi;
+if test "$with_xerces" = "" -o "$with_xerces" = "no" ; then
+else
+  if test "$with_xerces" = "yes" ; then
+    if test -d /usr/local/include/xercesc ; then
+      with_xerces=/usr/local
+    else
+      with_xerces=/usr
+    fi
+  fi
+  if test "$with_xerces_lib" != "" ; then
+    LIBS="$with_xerces_lib $LIBS"
+  else
+    if test -f $with_xerces/lib/libxerces-c.so ; then
+      LIBS="-L$with_xerces/lib -lxerces-c -lpthread $LIBS"
+    elif test -f $with_xerces/lib/libxerces-c1_6_0.so ; then
+      LIBS="-lxerces-c1_6_0 -lpthread $LIBS"
+      LIBS="-L$with_xerces/lib $LIBS"
+    else
+    fi
+  fi
+  if test "$with_xerces_inc" != "" ; then
+    XERCES_INCLUDE="-I$with_xerces_inc -I$with_xerces_inc/xercesc"
+  else
+    XERCES_INCLUDE="-I$with_xerces/include -I$with_xerces/include/xercesc"
+  fi
+  echo '#include <util/XercesDefs.hpp>' >> conftest.cpp
+  echo '#include <util/PlatformUtils.hpp>' >> conftest.cpp
+  echo '#if (_XERCES_VERSION >= 20200)' >> conftest.cpp
+  echo '    XERCES_CPP_NAMESPACE_USE' >> conftest.cpp
+  echo '#endif' >> conftest.cpp
+  echo 'int main() {  XMLPlatformUtils::Initialize(); }' >> conftest.cpp
+  CMD="${CXX} ${XERCES_INCLUDE} ${CPPFLAGS} -o conftest conftest.cpp $LIBS"
+  if test -z "`$CMD 2>&1 | grep -v warning | grep -v skipping`" ; then
+    HAVE_XERCES=yes
+  else
+    echo "$as_me:$LINENO: result: requested, but compile or link fails!" >&5
+echo "${ECHO_T}requested, but compile or link fails!" >&6
+    echo
+    echo $CMD
+    echo
+    $CMD
+    echo
+    echo cat conftest.cpp
+    cat conftest.cpp
+    { { echo "$as_me:$LINENO: error: Please correct Xerces options, or don't enable Xerces." >&5
+echo "$as_me: error: Please correct Xerces options, or don't enable Xerces." >&2;}
+  fi
+  rm -f conftest*
+fi
+HAVE_XERCES=$HAVE_XERCES
+XERCES_INCLUDE=$XERCES_INCLUDE
+# Check whether --with-odbc or --without-odbc was given.
+if test "${with_odbc+set}" = set; then
+  withval="$with_odbc"
+fi;
+if test "$with_odbc" = "no" ; then
+  ODBC_SETTING=no
+  echo "ODBC support disabled."
+elif test "$with_odbc" = "yes" -o "$with_odbc" = "" ; then
+  echo "$as_me:$LINENO: checking for SQLConnect in -lodbc" >&5
+echo $ECHO_N "checking for SQLConnect in -lodbc... $ECHO_C" >&6
+if test "${ac_cv_lib_odbc_SQLConnect+set}" = set; then
+else
+LIBS="-lodbc  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char SQLConnect ();
+int
+main ()
+SQLConnect ();
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  ac_status=$?
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  ac_cv_lib_odbc_SQLConnect=yes
+else
+ac_cv_lib_odbc_SQLConnect=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_odbc_SQLConnect" >&5
+echo "${ECHO_T}$ac_cv_lib_odbc_SQLConnect" >&6
+if test $ac_cv_lib_odbc_SQLConnect = yes; then
+  ODBC_SETTING=yes
+else
+  ODBC_SETTING=no
+fi
+  echo "$as_me:$LINENO: checking for SQLInstallDriverEx in -lodbcinst" >&5
+echo $ECHO_N "checking for SQLInstallDriverEx in -lodbcinst... $ECHO_C" >&6
+if test "${ac_cv_lib_odbcinst_SQLInstallDriverEx+set}" = set; then
+else
+LIBS="-lodbcinst  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char SQLInstallDriverEx ();
+int
+main ()
+SQLInstallDriverEx ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_odbcinst_SQLInstallDriverEx=yes
+else
+ac_cv_lib_odbcinst_SQLInstallDriverEx=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_odbcinst_SQLInstallDriverEx" >&5
+echo "${ECHO_T}$ac_cv_lib_odbcinst_SQLInstallDriverEx" >&6
+if test $ac_cv_lib_odbcinst_SQLInstallDriverEx = yes; then
+  ODBC_SETTING=yes
+else
+  ODBC_SETTING=no
+fi
+  if test "$ODBC_SETTING" = "yes" ; then
+    if test -f /usr/local/include/sql.h -o -f /usr/include/sql.h ; then
+      ODBC_SETTING=yes
+    else
+      echo "odbc library found, but sql.h missing, ODBC support disabled."
+      ODBC_SETTING=no
+    fi
+  fi
+    LIBS="-lodbc -lodbcinst $LIBS"
+  fi
+else
+  ODBC_SETTING=yes
+  LIBS="-L$with_odbc -L$with_odbc/lib -lodbc -lodbcinst $LIBS"
+  EXTRA_INCLUDES="-I$with_odbc -I$with_odbc/include $EXTRA_INCLUDES"
+  echo "using odbc library from $with_odbc."
+fi
+ODBC_SETTING=$ODBC_SETTING
+ORACLE_OCI_REQ_VERSION="8.1.7"
+# Check whether --with-oci or --without-oci was given.
+if test "${with_oci+set}" = set; then
+  withval="$with_oci"
+        if test "$withval" = "yes"; then
+            if test -n "$ORACLE_HOME"; then
+                oracle_home_dir="$ORACLE_HOME"
+            else
+                oracle_home_dir=""
+            fi
+        elif test -d "$withval"; then
+            oracle_home_dir="$withval"
+        else
+        fi
+else
+        else
+        fi
+fi;
+# Check whether --with-oci-include or --without-oci-include was given.
+if test "${with_oci_include+set}" = set; then
+  withval="$with_oci_include"
+  oracle_home_include_dir="$withval"
+else
+  oracle_home_include_dir=""
+fi;
+# Check whether --with-oci-lib or --without-oci-lib was given.
+if test "${with_oci_lib+set}" = set; then
+  withval="$with_oci_lib"
+  oracle_home_lib_dir="$withval"
+else
+  oracle_home_lib_dir=""
+fi;
+    ORACLE_OCI_CFLAGS=""
+    ORACLE_OCI_LDFLAGS=""
+    ORACLE_OCI_VERSION=""
+                want_oracle_but_no_path="no"
+    if test -n "$oracle_home_dir"; then
+        if test "$oracle_home_dir" != "no" -a "$oracle_home_dir" != "yes"; then
+                        oracle_include_dir="$oracle_home_dir/rdbms/public"
+            oracle_lib_dir="$oracle_home_dir/lib"
+        elif test "$oracle_home_dir" = "yes"; then
+            want_oracle_but_no_path="yes"
+        fi
+    elif test -n "$oracle_home_include_dir" -o -n "$oracle_home_lib_dir"; then
+        if test "$oracle_home_include_dir" != "no" -a "$oracle_home_include_dir" != "yes"; then
+            oracle_include_dir="$oracle_home_include_dir"
+        elif test "$oracle_home_include_dir" = "yes"; then
+        fi
+        if test "$oracle_home_lib_dir" != "no" -a "$oracle_home_lib_dir" != "yes"; then
+            oracle_lib_dir="$oracle_home_lib_dir"
+        elif test "$oracle_home_lib_dir" = "yes"; then
+        fi
+    fi
+    if test "$want_oracle_but_no_path" = "yes"; then
+        { echo "$as_me:$LINENO: WARNING: Oracle support is requested but no Oracle paths have been provided. \
+Please, locate Oracle directories using --with-oci or \
+--with-oci-include and --with-oci-lib options." >&5
+echo "$as_me: WARNING: Oracle support is requested but no Oracle paths have been provided. \
+--with-oci-include and --with-oci-lib options." >&2;}
+    fi
+                if test -n "$oracle_include_dir" -a -n "$oracle_lib_dir"; then
+        saved_CPPFLAGS="$CPPFLAGS"
+        CPPFLAGS="$CPPFLAGS -I$oracle_include_dir"
+                        saved_LDFLAGS="$LDFLAGS"
+        oci_ldflags="-L$oracle_lib_dir -lclntsh"
+        LDFLAGS="$LDFLAGS $oci_ldflags -lnnz10"
+                                echo "$as_me:$LINENO: checking for Oracle OCI headers in $oracle_include_dir" >&5
+echo $ECHO_N "checking for Oracle OCI headers in $oracle_include_dir... $ECHO_C" >&6
+        ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+        cat >conftest.$ac_ext <<_ACEOF
+            /* confdefs.h.  */
+_ACEOF
+#include <oci.h>
+int
+main ()
+#if defined(OCI_MAJOR_VERSION)
+#if OCI_MAJOR_VERSION == 10 && OCI_MINOR_VERSION == 2
+// Oracle 10.2 detected
+#endif
+#elif defined(OCI_V7_SYNTAX)
+// OK, older Oracle detected
+// TODO - mloskot: find better macro to check for older versions;
+#else
+#  error Oracle oci.h header not found
+#endif
+  return 0;
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>conftest.er1
+  ac_status=$?
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+  ac_status=$?
+	 { ac_try='test -s conftest.$ac_objext'
+  ac_status=$?
+            ORACLE_OCI_CFLAGS="-I$oracle_include_dir"
+            oci_header_found="yes"
+else
+            oci_header_found="no"
+            echo "$as_me:$LINENO: result: not found" >&5
+echo "${ECHO_T}not found" >&6
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+        ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+                                if test "$oci_header_found" = "yes"; then
+            echo "$as_me:$LINENO: checking for Oracle OCI libraries in $oracle_lib_dir" >&5
+echo $ECHO_N "checking for Oracle OCI libraries in $oracle_lib_dir... $ECHO_C" >&6
+            ac_ext=cc
+                /* confdefs.h.  */
+_ACEOF
+#include <oci.h>
+int
+main ()
+OCIEnv* envh = 0;
+OCIEnvCreate(&envh, OCI_DEFAULT, 0, 0, 0, 0, 0, 0);
+if (envh) OCIHandleFree(envh, OCI_HTYPE_ENV);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+                ORACLE_OCI_LDFLAGS="$oci_ldflags"
+                oci_lib_found="yes"
+else
+                oci_lib_found="no"
+fi
+            ac_ext=c
+        fi
+        CPPFLAGS="$saved_CPPFLAGS"
+        LDFLAGS="$saved_LDFLAGS"
+    fi
+                oracle_version_req=$ORACLE_OCI_REQ_VERSION
+    if test "$oci_header_found" = "yes" -a "$oci_lib_found" = "yes" -a \
+        -n "$oracle_version_req"; then
+        oracle_version_major=`cat $oracle_include_dir/oci.h \
+                             | grep '#define.*OCI_MAJOR_VERSION.*' \
+                             | sed -e 's/#define OCI_MAJOR_VERSION  *//' \
+                             | sed -e 's/  *\/\*.*\*\///'`
+        oracle_version_minor=`cat $oracle_include_dir/oci.h \
+                             | grep '#define.*OCI_MINOR_VERSION.*' \
+                             | sed -e 's/#define OCI_MINOR_VERSION  *//' \
+        echo "$as_me:$LINENO: checking if Oracle OCI version is >= $oracle_version_req" >&5
+echo $ECHO_N "checking if Oracle OCI version is >= $oracle_version_req... $ECHO_C" >&6
+        if test -n "$oracle_version_major" -a -n $"oracle_version_minor"; then
+            ORACLE_OCI_VERSION="$oracle_version_major.$oracle_version_minor"
+                                    oracle_version_req_major=`expr $oracle_version_req : '\([0-9]*\)'`
+            oracle_version_req_minor=`expr $oracle_version_req : '[0-9]*\.\([0-9]*\)'`
+            oracle_version_req_number=`expr $oracle_version_req_major \* 1000000 \
+                                       \+ $oracle_version_req_minor \* 1000`
+                        oracle_version_number=`expr $oracle_version_major \* 1000000 \
+                                  \+ $oracle_version_minor \* 1000`
+            oracle_version_check=`expr $oracle_version_number \>\= $oracle_version_req_number`
+            if test "$oracle_version_check" = "1"; then
+                oracle_version_checked="yes"
+                                echo "$as_me:$LINENO: checking for Oracle version >= 10.x to use -lnnz10 flag" >&5
+echo $ECHO_N "checking for Oracle version >= 10.x to use -lnnz10 flag... $ECHO_C" >&6
+                oracle_nnz10_check=`expr $oracle_version_number \>\= 10 \* 1000000`
+                if test "$oracle_nnz10_check" = "1"; then
+                    ORACLE_OCI_LDFLAGS="$ORACLE_OCI_LDFLAGS -lnnz10"
+                else
+                fi
+            else
+                oracle_version_checked="no"
+                { { echo "$as_me:$LINENO: error: Oracle $ORACLE_OCI_VERSION found, but required version is $oracle_version_req" >&5
+echo "$as_me: error: Oracle $ORACLE_OCI_VERSION found, but required version is $oracle_version_req" >&2;}
+            fi
+        else
+            ORACLE_OCI_VERSION="UNKNOWN"
+            { echo "$as_me:$LINENO: WARNING: Oracle version unknown, probably OCI older than 10.2 is available" >&5
+echo "$as_me: WARNING: Oracle version unknown, probably OCI older than 10.2 is available" >&2;}
+        fi
+    fi
+    echo "$as_me:$LINENO: checking if Oracle support is enabled" >&5
+echo $ECHO_N "checking if Oracle support is enabled... $ECHO_C" >&6
+    if test "$oci_header_found" = "yes" -a "$oci_lib_found" = "yes"; then
+        HAVE_ORACLE_OCI="yes"
+    else
+        HAVE_ORACLE_OCI="no"
+    fi
+    echo "$as_me:$LINENO: result: $HAVE_ORACLE_OCI" >&5
+echo "${ECHO_T}$HAVE_ORACLE_OCI" >&6
+if test "$HAVE_ORACLE_OCI" = "yes"; then
+    OCI_INCLUDE="$ORACLE_OCI_CFLAGS"
+    LIBS="$ORACLE_OCI_LDFLAGS $LIBS"
+fi
+HAVE_OCI=$HAVE_ORACLE_OCI
+OCI_INCLUDE=$OCI_INCLUDE
+HAVE_DODS=no
+echo "$as_me:$LINENO: checking Checking for DODS" >&5
+echo $ECHO_N "checking Checking for DODS... $ECHO_C" >&6
+# Check whether --with-dods_root or --without-dods_root was given.
+if test "${with_dods_root+set}" = set; then
+  withval="$with_dods_root"
+fi;
+if test -z "$with_dods_root" -o "$with_dods_root" = "no"; then
+elif test "$with_dods_root" = "yes" ; then
+    { { echo "$as_me:$LINENO: error: --with-dods-root requires path to dods root as argument" >&5
+echo "$as_me: error: --with-dods-root requires path to dods root as argument" >&2;}
+else
+    DODS_LIB=$with_dods_root/lib
+    DODS_INC="-I$with_dods_root/include -I$with_dods_root/include/libdap -I$with_dods_root/include/dap"
+    DODS_BIN=$with_dods_root/bin
+        if test -x $DODS_BIN/opendap-config ; then
+            LIBS="$LIBS `$DODS_BIN/opendap-config --libs`"
+    elif test -x $DODS_BIN/dap-config ; then
+            LIBS="$LIBS `$DODS_BIN/dap-config --libs`"
+    else
+            LIBS="$LIBS -L$DODS_LIB -ldap++ -lpthread -lrx"
+            if test -x $DODS_BIN/curl-config; then
+          LIBS="$LIBS  `$DODS_BIN/curl-config --libs`"
+      elif which curl-config > /dev/null 2>&1; then
+          LIBS="$LIBS  `curl-config --libs`"
+      else
+          { { echo "$as_me:$LINENO: error: You gave a dods root, but I can't find curl!" >&5
+echo "$as_me: error: You gave a dods root, but I can't find curl!" >&2;}
+      fi
+      if test -x $DODS_BIN/xml2-config; then
+          LIBS="$LIBS `$DODS_BIN/xml2-config --libs`"
+      elif which xml2-config > /dev/null 2>&1; then
+          LIBS="$LIBS  `xml2-config --libs`"
+      else
+          { { echo "$as_me:$LINENO: error: You gave a dods root, but I can't find xml2!" >&5
+echo "$as_me: error: You gave a dods root, but I can't find xml2!" >&2;}
+      fi
+    fi
+    OPT_GDAL_FORMATS="dods $OPT_GDAL_FORMATS"
+    DODSDEF=-DFRMT_dods
+    echo "$as_me:$LINENO: result: setting DODS root directory to $with_dods_root" >&5
+echo "${ECHO_T}setting DODS root directory to $with_dods_root" >&6
+    HAVE_DODS=yes
+fi
+# Check whether --with-curl or --without-curl was given.
+if test "${with_curl+set}" = set; then
+  withval="$with_curl"
+fi;
+unset ac_cv_path_LIBCURL
+if test "`basename xx/$with_curl`" = "curl-config" ; then
+  LIBCURL_CONFIG="$with_curl"
+elif test "$with_curl" = "no" ; then
+  LIBCURL_CONFIG=no
+else
+  # Extract the first word of "curl-config", so it can be a program name with args.
+set dummy curl-config; ac_word=$2
+if test "${ac_cv_path_LIBCURL_CONFIG+set}" = set; then
+else
+  case $LIBCURL_CONFIG in
+  ac_cv_path_LIBCURL_CONFIG="$LIBCURL_CONFIG" # Let the user override the test with a path.
+  as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+    ac_cv_path_LIBCURL_CONFIG="$as_dir/$ac_word$ac_exec_ext"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_path_LIBCURL_CONFIG" && ac_cv_path_LIBCURL_CONFIG="no"
+esac
+fi
+LIBCURL_CONFIG=$ac_cv_path_LIBCURL_CONFIG
+if test -n "$LIBCURL_CONFIG"; then
+  echo "$as_me:$LINENO: result: $LIBCURL_CONFIG" >&5
+echo "${ECHO_T}$LIBCURL_CONFIG" >&6
+else
+fi
+fi
+if test "$LIBCURL_CONFIG" != "no" ; then
+  CURL_VERNUM=`$LIBCURL_CONFIG --vernum`
+  CURL_VER=`$LIBCURL_CONFIG --version | awk '{print $2}'`
+  echo "$as_me:$LINENO: result:         found libcurl version $CURL_VER" >&5
+echo "${ECHO_T}        found libcurl version $CURL_VER" >&6
+  CURL_INC=`$LIBCURL_CONFIG --cflags`
+  CURL_LIB=`$LIBCURL_CONFIG --libs`
+  CURL_SETTING=yes
+  OPT_GDAL_FORMATS="wcs $OPT_GDAL_FORMATS"
+else
+  CURL_SETTING=no
+  CURL_INC=
+  CURL_LIB=
+fi
+CURL_SETTING=$CURL_SETTING
+CURL_INC=$CURL_INC
+CURL_LIB=$CURL_LIB
+HAVE_SQLITE=no
+echo "$as_me:$LINENO: checking Checking for SQLite" >&5
+echo $ECHO_N "checking Checking for SQLite... $ECHO_C" >&6
+# Check whether --with-sqlite or --without-sqlite was given.
+if test "${with_sqlite+set}" = set; then
+  withval="$with_sqlite"
+fi;
+if test -z "$with_sqlite" -o "$with_sqlite" = "no"; then
+else
+    if test "$with_sqlite" = "yes" ; then
+        LIBS="$LIBS -lsqlite3"
+        SQLITE_INC=""
+    else
+        LIBS="$LIBS -L$with_sqlite/lib -lsqlite3"
+        SQLITE_INC="-I$with_sqlite/include"
+        echo "$as_me:$LINENO: result: setting DODS root directory to $with_sqlite" >&5
+echo "${ECHO_T}setting DODS root directory to $with_sqlite" >&6
+    fi
+    HAVE_SQLITE=yes
+fi
+DWGDIRECT=
+DWG_PLT=
+echo "$as_me:$LINENO: checking Checking for DWGdirect" >&5
+echo $ECHO_N "checking Checking for DWGdirect... $ECHO_C" >&6
+# Check whether --with-dwgdirect or --without-dwgdirect was given.
+if test "${with_dwgdirect+set}" = set; then
+  withval="$with_dwgdirect"
+fi;
+if test -z "$with_dwgdirect" -o "$with_dwgdirect" = "no"; then
+    HAVE_DWGDIRECT=no
+else
+fi;
+    if test "x$with_dwg_plt" != "x" ; then
+        DWG_PLT=$with_dwg_plt
+    else
+        DWG_PLT=lnxX86
+    fi
+    DWGDIRECT=$with_dwgdirect
+    HAVE_DWGDIRECT=yes
+fi
+HAVE_PANORAMA=no
+# Check whether --with-panorama or --without-panorama was given.
+if test "${with_panorama+set}" = set; then
+  withval="$with_panorama"
+fi;
+if test "$with_panorama" = "no" ; then
+  { echo "$as_me:$LINENO: \"Panorama\" GIS support disabled." >&5
+echo "$as_me: \"Panorama\" GIS support disabled." >&6;}
+else
+  if test -r "$with_panorama/include/mapapi.h" ; then
+    HAVE_PANORAMA=yes
+    PANORAMA_INC="-I$with_panorama/include $EXTRA_INCLUDES"
+    { echo "$as_me:$LINENO: using \"Panorama\" GIS library from $with_panorama." >&5
+echo "$as_me: using \"Panorama\" GIS library from $with_panorama." >&6;}
+  fi
+fi
+HAVE_PANORAMA=$HAVE_PANORAMA
+PANORAMA_INC=$PANORAMA_INC
+HAVE_IDB=no
+# Check whether --with-idb or --without-idb was given.
+if test "${with_idb+set}" = set; then
+  withval="$with_idb"
+fi;
+if test "$with_idb" = "no" ; then
+  { echo "$as_me:$LINENO: \"IBM Informix DataBlade support disabled." >&5
+echo "$as_me: \"IBM Informix DataBlade support disabled." >&6;}
+else
+  if test xx"$with_idb" = "xx"; then
+    with_idb=$INFORMIXDIR
+  fi
+  if test -e "$with_idb/incl/c++/it.h" ; then
+    HAVE_IDB=yes
+    LIBS_DIRS="-L$with_idb/lib/ -L$with_idb/lib/esql"
+    LIBS_ESQL="-lifsql -lifasf -lifgen -lifos -lifgls -lifglx $with_idb/lib/esql/checkapi.o"
+    LIBS_LIBMI="-L$with_idb/lib/dmi -lifdmi"
+    LIBS_CPPIF="-L$with_idb/lib/c++ -lifc++"
+    IDB_INC="-I$with_idb/incl/ -I$with_idb/incl/dmi -I$with_idb/incl/c++"
+    IDB_LIB="$LIBS_DIRS $LIBS_ESQL $LIBS_LIBMI $LIBS_CPPIF"
+    { echo "$as_me:$LINENO: using Informix C++ client library from $with_idb." >&5
+echo "$as_me: using Informix C++ client library from $with_idb." >&6;}
+  else
+    { echo "$as_me:$LINENO: IBM Informix DataBlade not supported." >&5
+echo "$as_me: IBM Informix DataBlade not supported." >&6;}
+  fi
+fi
+HAVE_IDB=$HAVE_IDB
+IDB_INC=$IDB_INC
+IDB_LIB=$IDB_LIB
+SDE_ENABLED=no
+{ echo "$as_me:$LINENO: checking whether we should include ESRI SDE support..." >&5
+echo "$as_me: checking whether we should include ESRI SDE support..." >&6;}
+# Check whether --with-sde or --without-sde was given.
+if test "${with_sde+set}" = set; then
+  withval="$with_sde"
+fi;
+# Check whether --with-sde-version or --without-sde-version was given.
+if test "${with_sde_version+set}" = set; then
+  withval="$with_sde_version"
+  SDE_VERSION=$with_sde_version
+else
+  SDE_VERSION=80
+fi;
+if test "$with_sde" = "yes" ; then
+  as_ac_Lib=`echo "ac_cv_lib_sde$SDE_VERSION''_SE_connection_create" | $as_tr_sh`
+echo "$as_me:$LINENO: checking for SE_connection_create in -lsde$SDE_VERSION" >&5
+echo $ECHO_N "checking for SE_connection_create in -lsde$SDE_VERSION... $ECHO_C" >&6
+if eval "test \"\${$as_ac_Lib+set}\" = set"; then
+else
+LIBS="-lsde$SDE_VERSION  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char SE_connection_create ();
+int
+main ()
+SE_connection_create ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  eval "$as_ac_Lib=yes"
+else
+eval "$as_ac_Lib=no"
+fi
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Lib'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_Lib'}'`" >&6
+if test `eval echo '${'$as_ac_Lib'}'` = yes; then
+  SDE_ENABLED=yes
+fi
+  if test -n "$SDE_ENABLED" ; then
+      SDE_LIB="-lsde$SDE_VERSION -lpe$SDE_VERSION -lsg$SDE_VERSION"
+      echo "$as_me:$LINENO: checking for main in -lpthread" >&5
+echo $ECHO_N "checking for main in -lpthread... $ECHO_C" >&6
+if test "${ac_cv_lib_pthread_main+set}" = set; then
+else
+LIBS="-lpthread  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+main ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_pthread_main=yes
+else
+ac_cv_lib_pthread_main=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_pthread_main" >&5
+echo "${ECHO_T}$ac_cv_lib_pthread_main" >&6
+if test $ac_cv_lib_pthread_main = yes; then
+  SDE_LIB="$SDE_LIB -lpthread"
+fi
+      echo "$as_me:$LINENO: checking for main in -lsocket" >&5
+echo $ECHO_N "checking for main in -lsocket... $ECHO_C" >&6
+if test "${ac_cv_lib_socket_main+set}" = set; then
+else
+LIBS="-lsocket  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+main ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_socket_main=yes
+else
+ac_cv_lib_socket_main=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_socket_main" >&5
+echo "${ECHO_T}$ac_cv_lib_socket_main" >&6
+if test $ac_cv_lib_socket_main = yes; then
+  SDE_LIB="$SDE_LIB -lsocket"
+fi
+      echo "$as_me:$LINENO: checking for main in -ldl" >&5
+echo $ECHO_N "checking for main in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_main+set}" = set; then
+else
+LIBS="-ldl  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+main ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dl_main=yes
+else
+ac_cv_lib_dl_main=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_main" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_main" >&6
+if test $ac_cv_lib_dl_main = yes; then
+  SDE_LIB="$SDE_LIB -ldl"
+fi
+      echo "$as_me:$LINENO: result:         using ESRI SDE from system libs." >&5
+echo "${ECHO_T}        using ESRI SDE from system libs." >&6
+  else
+      { echo "$as_me:$LINENO: WARNING:         ESRI SDE not found in system libs... use --with-sde=DIR." >&5
+echo "$as_me: WARNING:         ESRI SDE not found in system libs... use --with-sde=DIR." >&2;}
+  fi
+elif test -n "$with_sde" -a "$with_sde" != "no" ; then
+  SDE_DIR=$with_sde
+  test -f $SDE_DIR/arcsde/coverages/include/sdetype.h && SDE_INCDIR="$SDE_DIR/arcsde/coverages/include"
+  test -f $SDE_DIR/include/sdetype.h && SDE_INCDIR="$SDE_DIR/include"
+  test -f $SDE_DIR/sdetype.h && SDE_INCDIR="$SDE_DIR"
+  test -f $SDE_DIR/lib/libsde$SDE_VERSION.a && SDE_LIBDIR="$SDE_DIR/lib"
+  test -f $SDE_DIR/lib64/libsde$SDE_VERSION.a && SDE_LIBDIR="$SDE_DIR/lib64"
+  test -f $SDE_DIR/libsde$SDE_VERSION.a && SDE_LIBDIR="$SDE_DIR"
+  test -f $SDE_DIR/lib/libsde$SDE_VERSION.so -o -f $SDE_DIR/lib/libsde$SDE_VERSION.sl && SDE_LIBDIR="$SDE_DIR/lib"
+  test -f $SDE_DIR/lib64/libsde$SDE_VERSION.so -o -f $SDE_DIR/lib64/libsde$SDE_VERSION.sl && SDE_LIBDIR="$SDE_DIR/lib64"
+  test -f $SDE_DIR/libsde$SDE_VERSION.so -o -f $SDE_DIR/libsde$SDE_VERSION.sl && SDE_LIBDIR="$SDE_DIR"
+  if test -n "$SDE_INCDIR" -a -n "$SDE_LIBDIR" ; then
+      SDE_INC=-I$SDE_INCDIR
+      SDE_LIB="-L$SDE_LIBDIR -lsde$SDE_VERSION -lpe$SDE_VERSION -lsg$SDE_VERSION"
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+main ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+fi
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+main ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+fi
+else
+LIBS="-ldl  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+main ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+fi
+  else
+      { { echo "$as_me:$LINENO: error: \"Could not find sdetype.h or libsde$SDE_VERSION.a/libsde$SDE_VERSION.so in $SDE_DIR.\"" >&5
+echo "$as_me: error: \"Could not find sdetype.h or libsde$SDE_VERSION.a/libsde$SDE_VERSION.so in $SDE_DIR.\"" >&2;}
+  fi
+  SDE_ENABLED=yes
+  echo "$as_me:$LINENO: result:         using ESRI SDE from $SDE_DIR." >&5
+echo "${ECHO_T}        using ESRI SDE from $SDE_DIR." >&6
+else
+  echo "$as_me:$LINENO: result:         ESRI SDE support not requested." >&5
+echo "${ECHO_T}        ESRI SDE support not requested." >&6
+fi
+SDE_ENABLED=$SDE_ENABLED
+SDE_INC=$SDE_INC
+SDE_LIB=$SDE_LIB
+# Check whether --with-geos or --without-geos was given.
+if test "${with_geos+set}" = set; then
+  withval="$with_geos"
+fi;
+  if test x"$with_geos" = x"no" ; then
+    echo "$as_me:$LINENO: result: GEOS support disabled" >&5
+echo "${ECHO_T}GEOS support disabled" >&6
+    GEOS_CONFIG=no
+  elif test x"$with_geos" = x"yes" -o x"$with_geos" = x"" ; then
+    # Extract the first word of "geos-config", so it can be a program name with args.
+set dummy geos-config; ac_word=$2
+if test "${ac_cv_path_GEOS_CONFIG+set}" = set; then
+else
+  case $GEOS_CONFIG in
+  ac_cv_path_GEOS_CONFIG="$GEOS_CONFIG" # Let the user override the test with a path.
+do
+  IFS=$as_save_IFS
+    ac_cv_path_GEOS_CONFIG="$as_dir/$ac_word$ac_exec_ext"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_path_GEOS_CONFIG" && ac_cv_path_GEOS_CONFIG="no"
+esac
+fi
+GEOS_CONFIG=$ac_cv_path_GEOS_CONFIG
+if test -n "$GEOS_CONFIG"; then
+  echo "$as_me:$LINENO: result: $GEOS_CONFIG" >&5
+echo "${ECHO_T}$GEOS_CONFIG" >&6
+else
+fi
+  else
+   ac_geos_config=`basename $with_geos`
+   ac_geos_config_dir=`(dirname "$with_geos") 2>/dev/null ||
+$as_expr X"$with_geos" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$with_geos" : 'X\(//\)[^/]' \| \
+	 X"$with_geos" : 'X\(//\)$' \| \
+	 X"$with_geos" : 'X\(/\)' \| \
+	 .     : '\(.\)' 2>/dev/null ||
+echo X"$with_geos" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
+  	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
+  	  /^X\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+   # Extract the first word of "$ac_geos_config", so it can be a program name with args.
+set dummy $ac_geos_config; ac_word=$2
+if test "${ac_cv_prog_GEOS_CONFIG+set}" = set; then
+else
+  if test -n "$GEOS_CONFIG"; then
+  ac_cv_prog_GEOS_CONFIG="$GEOS_CONFIG" # Let the user override the test.
+else
+  ac_prog_rejected=no
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $ac_geos_config_dir
+do
+  IFS=$as_save_IFS
+    if test "$as_dir/$ac_word$ac_exec_ext" = "
+   "; then
+       ac_prog_rejected=yes
+       continue
+     fi
+    ac_cv_prog_GEOS_CONFIG="$with_geos"
+    break 2
+  fi
+done
+done
+if test $ac_prog_rejected = yes; then
+  # We found a bogon in the path, so make sure we never use it.
+  set dummy $ac_cv_prog_GEOS_CONFIG
+  shift
+  if test $# != 0; then
+    # We chose a different compiler from the bogus one.
+    # However, it has the same basename, so the bogon will be chosen
+    # first if we set GEOS_CONFIG to just the basename; use the full file name.
+    shift
+    ac_cv_prog_GEOS_CONFIG="$as_dir/$ac_word${1+' '}$@"
+  fi
+fi
+  test -z "$ac_cv_prog_GEOS_CONFIG" && ac_cv_prog_GEOS_CONFIG="no"
+fi
+fi
+GEOS_CONFIG=$ac_cv_prog_GEOS_CONFIG
+else
+fi
+  fi
+  if test x"$GEOS_CONFIG" != x"no" ; then
+    min_geos_version=2.2.0
+    echo "$as_me:$LINENO: checking for GEOS version >= $min_geos_version" >&5
+echo $ECHO_N "checking for GEOS version >= $min_geos_version... $ECHO_C" >&6
+    geos_major_version=`$GEOS_CONFIG --version | \
+       sed 's/\([0-9]*\)\.\([0-9]*\)\.\([0-9]*\).*/\1/'`
+    geos_minor_version=`$GEOS_CONFIG --version | \
+       sed 's/\([0-9]*\)\.\([0-9]*\)\.\([0-9]*\).*/\2/'`
+    geos_micro_version=`$GEOS_CONFIG --version | \
+       sed 's/\([0-9]*\)\.\([0-9]*\)\.\([0-9]*\).*/\3/'`
+    req_major=`echo $min_geos_version | \
+    req_minor=`echo $min_geos_version | \
+    req_micro=`echo $min_geos_version | \
+    version_ok="no"
+    ac_req_version=`expr $req_major \* 100000 \+  $req_minor \* 100 \+ $req_micro`
+    ac_geos_version=`expr $geos_major_version \* 100000 \+  $geos_minor_version \* 100 \+ $geos_micro_version`
+    if test $ac_req_version -le $ac_geos_version; then
+        version_ok="yes"
+    fi
+    if test $version_ok = "no"; then
+       HAVE_GEOS="no"
+       { { echo "$as_me:$LINENO: error: geos-config reports version ${geos_major_version}.${geos_minor_version}.${geos_micro_version}, need at least $min_geos_version or configure --without-geos" >&5
+echo "$as_me: error: geos-config reports version ${geos_major_version}.${geos_minor_version}.${geos_micro_version}, need at least $min_geos_version or configure --without-geos" >&2;}
+    else
+      HAVE_GEOS="no"
+      GEOS_LIBS="`${GEOS_CONFIG} --libs` -lgeos_c"
+      GEOS_CFLAGS="`${GEOS_CONFIG} --cflags`"
+      GEOS_VERSION="`${GEOS_CONFIG} --version`"
+      ax_save_LIBS="${LIBS}"
+      LIBS=${GEOS_LIBS}
+      ax_save_CFLAGS="${CFLAGS}"
+      CFLAGS="${GEOS_CFLAGS}"
+      echo "$as_me:$LINENO: checking for GEOSversion in -lgeos_c" >&5
+echo $ECHO_N "checking for GEOSversion in -lgeos_c... $ECHO_C" >&6
+if test "${ac_cv_lib_geos_c_GEOSversion+set}" = set; then
+else
+LIBS="-lgeos_c
+       $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char GEOSversion ();
+int
+main ()
+GEOSversion ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_geos_c_GEOSversion=yes
+else
+ac_cv_lib_geos_c_GEOSversion=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_geos_c_GEOSversion" >&5
+echo "${ECHO_T}$ac_cv_lib_geos_c_GEOSversion" >&6
+if test $ac_cv_lib_geos_c_GEOSversion = yes; then
+  HAVE_GEOS="yes"
+else
+  HAVE_GEOS="no"
+fi
+      CFLAGS="${ax_save_CFLAGS}"
+      LIBS="${ax_save_LIBS}"
+    fi
+  fi
+if test "${HAVE_GEOS}" = "yes" ; then
+  { echo "$as_me:$LINENO: using GEOS 2.2.x+ C API" >&5
+echo "$as_me: using GEOS 2.2.x+ C API" >&6;}
+  LIBS="${GEOS_LIBS} ${LIBS}"
+fi
+echo "$as_me:$LINENO: checking how to link PROJ.4 library" >&5
+echo $ECHO_N "checking how to link PROJ.4 library... $ECHO_C" >&6
+# Check whether --with-static_proj4 or --without-static_proj4 was given.
+if test "${with_static_proj4+set}" = set; then
+  withval="$with_static_proj4"
+fi;
+if test "x$with_static_proj4" = "xno" -o "x$with_static_proj4" = "x"; then
+  PROJ_STATIC=no
+  echo "$as_me:$LINENO: result: link dynamically." >&5
+echo "${ECHO_T}link dynamically." >&6
+else
+  PROJ_STATIC=yes
+  echo "$as_me:$LINENO: result: link statically." >&5
+echo "${ECHO_T}link statically." >&6
+  ORIG_LIBS="$LIBS"
+  PROJ_LIB="-lproj"
+  if test "x$with_static_proj4" = "xyes" ; then
+    LIBS="$PROJ_LIB $ORIG_LIBS"
+    echo "$as_me:$LINENO: checking for pj_init in -lproj" >&5
+echo $ECHO_N "checking for pj_init in -lproj... $ECHO_C" >&6
+if test "${ac_cv_lib_proj_pj_init+set}" = set; then
+else
+LIBS="-lproj  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pj_init ();
+int
+main ()
+pj_init ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_proj_pj_init=yes
+else
+ac_cv_lib_proj_pj_init=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_proj_pj_init" >&5
+echo "${ECHO_T}$ac_cv_lib_proj_pj_init" >&6
+if test $ac_cv_lib_proj_pj_init = yes; then
+  PROJ_STATIC=yes
+else
+  PROJ_STATIC=no
+fi
+  else
+    LIBS="-L$with_static_proj4/src $PROJ_LIB $ORIG_LIBS"
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pj_init ();
+int
+main ()
+pj_init ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  PROJ_STATIC=yes
+else
+  PROJ_STATIC=no
+fi
+    if test "$PROJ_STATIC" = "no"; then
+      unset ac_cv_lib_proj_pj_init
+      LIBS="-L$with_static_proj4/lib $PROJ_LIB $ORIG_LIBS"
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pj_init ();
+int
+main ()
+pj_init ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  PROJ_STATIC=yes
+else
+  PROJ_STATIC=no
+fi
+    fi
+      LIBS="-L$with_static_proj4/src/.libs $PROJ_LIB $ORIG_LIBS"
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pj_init ();
+int
+main ()
+pj_init ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  PROJ_STATIC=yes
+else
+  PROJ_STATIC=no
+fi
+    fi
+      LIBS="-L$with_static_proj4 $PROJ_LIB $ORIG_LIBS"
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pj_init ();
+int
+main ()
+pj_init ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  PROJ_STATIC=yes
+else
+  PROJ_STATIC=no
+fi
+    fi
+else
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char pj_init ();
+int
+main ()
+pj_init ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+  PROJ_STATIC=yes
+else
+  PROJ_STATIC=no
+fi
+    fi
+  fi
+    LIBS="$ORIG_LIBS"
+  fi
+  if test -r "$with_static_proj4/src/proj_api.h" ; then
+    PROJ_INCLUDE="-I$with_static_proj4/src"
+  elif test -r "$with_static_proj4/include/proj_api.h" ; then
+    PROJ_INCLUDE="-I$with_static_proj4/include"
+  elif test -r "$with_static_proj4/proj_api.h" ; then
+    PROJ_INCLUDE="-I$with_static_proj4"
+  fi
+fi
+# Check whether --with-gdal-ver or --without-gdal-ver was given.
+if test "${with_gdal_ver+set}" = set; then
+  withval="$with_gdal_ver"
+fi;
+GDAL_VERSION_MAJOR=`grep "#*define.GDAL_VERSION_MAJOR.*" gcore/gdal_version.h | awk '{print $4}'`
+GDAL_VERSION_MINOR=`grep "#*define.GDAL_VERSION_MINOR.*" gcore/gdal_version.h | awk '{print $4}'`
+GDAL_VERSION_REV=`grep "#*define.GDAL_VERSION_REV.*" gcore/gdal_version.h | awk '{print $4}'`
+echo "$as_me:$LINENO: result: checking GDAL version information from gdal_version.h: $GDAL_VERSION_MAJOR.$GDAL_VERSION_MINOR.$GDAL_VERSION_REV" >&5
+echo "${ECHO_T}checking GDAL version information from gdal_version.h: $GDAL_VERSION_MAJOR.$GDAL_VERSION_MINOR.$GDAL_VERSION_REV" >&6
+GDAL_VERSION_MAJOR="$GDAL_VERSION_MAJOR"
+GDAL_VERSION_MINOR="$GDAL_VERSION_MINOR"
+GDAL_VERSION_REV="$GDAL_VERSION_REV"
+if test "x$with_gdal_ver" != "x"; then
+  GDAL_VER=$with_gdal_ver
+  echo "$as_me:$LINENO: result:   overridden GDAL version: $GDAL_VER" >&5
+echo "${ECHO_T}  overridden GDAL version: $GDAL_VER" >&6
+else
+  GDAL_VER=$GDAL_VERSION_MAJOR.$GDAL_VERSION_MINOR.$GDAL_VERSION_REV
+fi
+GDAL_VER=$GDAL_VER
+echo $GDAL_VER > VERSION
+  MACOSX_FRAMEWORK=no
+# Check whether --with- or --without- was given.
+if test "${with_+set}" = set; then
+  withval="$with_"
+fi;
+  echo "$as_me:$LINENO: checking for Mac OS X Framework build" >&5
+echo $ECHO_N "checking for Mac OS X Framework build... $ECHO_C" >&6
+  if test "$with_macosx_framework" = yes ; then
+    MACOSX_FRAMEWORK=yes
+cat >>confdefs.h <<_ACEOF
+#define MACOSX_FRAMEWORK 1
+_ACEOF
+    prefix='/Library/Frameworks/GDAL.framework/Versions/${GDAL_VERSION_MAJOR}.${GDAL_VERSION_MINOR}'
+    exec_prefix='${prefix}'
+    includedir='${prefix}/Headers'
+    datadir='${prefix}/Resources/gdal'
+    libdir='${exec_prefix}'
+    bindir='${exec_prefix}/Programs'
+    docdir='${prefix}/Resources/doc'
+    mandir='${prefix}/Resources/man'
+  else
+  fi
+  MACOSX_FRAMEWORK=$MACOSX_FRAMEWORK
+fi
+	# Remove -g from compile flags, we will add via CFG variable if
+	# we need it.
+	CXXFLAGS=`echo "$CXXFLAGS " | sed "s/-g //"`
+	CFLAGS=`echo "$CFLAGS " | sed "s/-g //"`
+	# check for GNU compiler, and use -Wall
+	if test "$GCC" = "yes"; then
+		C_WFLAGS="-Wall"
+cat >>confdefs.h <<\_ACEOF
+#define USE_GNUCC 1
+_ACEOF
+	fi
+	if test "$GXX" = "yes"; then
+		CXX_WFLAGS="-Wall"
+_ACEOF
+	fi
+	CXX_WFLAGS=$CXX_WFLAGS
+	C_WFLAGS=$C_WFLAGS
+EXTRA_INCLUDES=$EXTRA_INCLUDES
+if test -f /bin/true.exe ; then
+  EXE_EXT=.exe
+  SO_EXT=dll
+else
+  EXE_EXT=
+fi
+export EXE_EXT
+EXE_EXT=$EXE_EXT
+BINTRUE=/bin/true
+  BINTRUE=/bin/true.exe
+fi
+if test -f /usr/bin/true ; then
+  BINTRUE=/usr/bin/true
+fi
+export BINTRUE
+BINTRUE=$BINTRUE
+if test "$datadir" = '${prefix}/share' ; then
+  datadir='${prefix}/share/gdal'
+fi
+if test "$prefix" = "NONE" ; then
+  GDAL_PREFIX=/usr/local
+else
+  GDAL_PREFIX=${prefix}
+fi
+export GDAL_PREFIX
+#define GDAL_PREFIX "$GDAL_PREFIX"
+_ACEOF
+BINDINGS=
+# Check whether --with-perl or --without-perl was given.
+if test "${with_perl+set}" = set; then
+  withval="$with_perl"
+fi;
+echo "$as_me:$LINENO: checking for SWIG perl bindings" >&5
+echo $ECHO_N "checking for SWIG perl bindings... $ECHO_C" >&6
+if test "$with_perl" = "yes" ; then
+  BINDINGS="perl $BINDINGS"
+else
+fi
+# Check whether --with-php or --without-php was given.
+if test "${with_php+set}" = set; then
+  withval="$with_php"
+fi;
+echo "$as_me:$LINENO: checking for SWIG php bindings" >&5
+echo $ECHO_N "checking for SWIG php bindings... $ECHO_C" >&6
+if test "$with_php" = "yes" ; then
+  BINDINGS="php $BINDINGS"
+else
+fi
+# Check whether --with-ruby or --without-ruby was given.
+if test "${with_ruby+set}" = set; then
+  withval="$with_ruby"
+fi;
+echo "$as_me:$LINENO: checking for SWIG ruby bindings" >&5
+echo $ECHO_N "checking for SWIG ruby bindings... $ECHO_C" >&6
+if test "$with_ruby" = "yes" ; then
+  BINDINGS="ruby $BINDINGS"
+else
+fi
+# Check whether --with-ngpython or --without-ngpython was given.
+if test "${with_ngpython+set}" = set; then
+  withval="$with_ngpython"
+fi;
+echo "$as_me:$LINENO: checking for NG SWIG python bindings" >&5
+echo $ECHO_N "checking for NG SWIG python bindings... $ECHO_C" >&6
+if test "$with_ngpython" = "yes" ; then
+  BINDINGS="python $BINDINGS"
+else
+fi
+# Check whether --with-python or --without-python was given.
+if test "${with_python+set}" = set; then
+  withval="$with_python"
+fi;
+for ac_prog in python python1.5 python1.4 python1.3
+do
+  # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+if test "${ac_cv_prog_PYTHON+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  if test -n "$PYTHON"; then
+  ac_cv_prog_PYTHON="$PYTHON" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_PYTHON="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+PYTHON=$ac_cv_prog_PYTHON
+if test -n "$PYTHON"; then
+  echo "$as_me:$LINENO: result: $PYTHON" >&5
+echo "${ECHO_T}$PYTHON" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+  test -n "$PYTHON" && break
+done
+test -n "$PYTHON" || PYTHON="no"
+  if test "$with_python" = no ; then
+     echo "python support disabled"
+     PYTHON=no
+  fi
+  if test "x$with_ngpython" != xno -a "x$with_ngpython" != "x" ; then
+     echo "python support disabled since ngpython enabled."
+     PYTHON=no
+  fi
+  ARCH=`uname -i 2>/dev/null`
+  PYLIB=lib
+  if test "$ARCH" = "x86_64" ; then
+    PYLIB=lib64
+  fi
+  if test "$PYTHON" != no ; then
+    echo "$as_me:$LINENO: checking where python Makefiles are" >&5
+echo $ECHO_N "checking where python Makefiles are... $ECHO_C" >&6
+    python_prefix="`$PYTHON -c '
+import sys
+print sys.prefix'`"
+    python_execprefix="`$PYTHON -c '
+import sys
+    python_version="`$PYTHON -c '
+import sys
+print sys.version[:3]'`"
+    pythondir=$python_prefix/$PYLIB/python${python_version}/site-packages
+    pyexecdir=$python_execprefix/$PYLIB/python${python_version}/site-packages
+    echo "$as_me:$LINENO: result: found" >&5
+echo "${ECHO_T}found" >&6
+    echo "$as_me:$LINENO: checking Python makefile" >&5
+echo $ECHO_N "checking Python makefile... $ECHO_C" >&6
+    py_mf=$python_execprefix/$PYLIB/python${python_version}/config/Makefile
+    if test -f $py_mf ; then
+    else
+      echo "$as_me:$LINENO: result: missing, python disabled." >&5
+echo "${ECHO_T}missing, python disabled." >&6
+      PYTHON=no
+    fi
+  else
+    # these defaults are version independent ...
+    pythondir='$(prefix)/lib/site-python'
+    pyexecdir='$(exec_prefix)/lib/site-python'
+  fi
+# Check whether --with-pymoddir or --without-pymoddir was given.
+if test "${with_pymoddir+set}" = set; then
+  withval="$with_pymoddir"
+fi;
+  if test "$PYTHON" != "no" ; then
+    echo "$as_me:$LINENO: checking where .py files should go" >&5
+echo $ECHO_N "checking where .py files should go... $ECHO_C" >&6
+    if test "$with_pymoddir" = "" ; then
+       pymoddir=$pyexecdir
+    else
+       pymoddir=$with_pymoddir
+    fi
+    export pymoddir
+    echo "$as_me:$LINENO: result: $pymoddir" >&5
+echo "${ECHO_T}$pymoddir" >&6
+  fi
+PYTHON_LIBS=""
+if test "$PYTHON" != no ; then
+  echo "$as_me:$LINENO: checking for python headers" >&5
+echo $ECHO_N "checking for python headers... $ECHO_C" >&6
+  if test "${am_cv_python_includes+set}" = set; then
+else
+      am_cv_python_includes="`$PYTHON -c '
+import sys
+includepy = \"%s/include/python%s\" % (sys.prefix, sys.version[:3])
+if sys.version[0] > \"1\" or sys.version[2] > \"4\":
+  libpl = \"%s/include/python%s\" % (sys.exec_prefix, sys.version[:3])
+else:
+  libpl = \"%s/'$PYLIB'/python%s/config\" % (sys.exec_prefix, sys.version[:3])
+print \"-I%s -I%s\" % (includepy, libpl)'`"
+fi
+  PYTHON_INCLUDES="$am_cv_python_includes"
+  echo "$as_me:$LINENO: checking definitions from Python makefile" >&5
+echo $ECHO_N "checking definitions from Python makefile... $ECHO_C" >&6
+  if test "${am_cv_python_makefile+set}" = set; then
+else
+      if test ! -z "`uname -a | grep CYGWIN`" ; then
+      PYTHON_LIBS="`$PYTHON -c '
+import sys
+print \"-L%s/'$PYLIB'/python%s/config -lpython%s.dll\" % (sys.prefix, sys.version[:3], sys.version[:3])'`"
+    fi
+    py_makefile="`$PYTHON -c '
+import sys
+print \"%s/'$PYLIB'/python%s/config/Makefile\"%(sys.exec_prefix, sys.version[:3])'`"
+    if test ! -f "$py_makefile"; then
+      echo Could not find the python config makefile.  Maybe you are;
+      echo missing the development portion of the python installation;
+      exit;
+    fi
+    eval `sed -n \
+-e "s/^CC=[ 	]*\(.*\)/am_cv_python_CC='\1'/p" \
+-e "s/^OPT=[ 	]*\(.*\)/am_cv_python_OPT='\1'/p" \
+-e "s/^CCSHARED=[ 	]*\(.*\)/am_cv_python_CCSHARED='\1'/p" \
+-e "s/^LDSHARED=[ 	]*\(.*\)/am_cv_python_LDSHARED='\1'/p" \
+-e "s/^SO=[ 	]*\(.*\)/am_cv_python_SO='\1'/p" \
+    $py_makefile`
+    am_cv_python_makefile=found
+fi
+  echo "$as_me:$LINENO: result: done" >&5
+echo "${ECHO_T}done" >&6
+  PYTHON_CC="$am_cv_python_CC"
+  PYTHON_OPT="$am_cv_python_OPT"
+  PYTHON_SO="$am_cv_python_SO"
+  PYTHON_CFLAGS="$am_cv_python_CCSHARED \$(OPT)"
+  PYTHON_LINK="$am_cv_python_LDSHARED -o \$@"
+else
+  PYTHON_CC=""
+  PYTHON_OPT=""
+  PYTHON_SO=""
+  PYTHON_CFLAGS=""
+  PYTHON_LINK=""
+fi
+echo "$as_me:$LINENO: checking for special pymod link hacks" >&5
+echo $ECHO_N "checking for special pymod link hacks... $ECHO_C" >&6
+if test ! -z "`uname | grep Darwin`" -a ${with_libtool} == no ; then
+    echo "$as_me:$LINENO: result: darwin-nonlibtool" >&5
+echo "${ECHO_T}darwin-nonlibtool" >&6
+    PY_LD_SHARED='g++ -bundle -framework Python'
+    PY_SO_EXT='so'
+elif test ! -z "`uname | grep Darwin`" -a ${with_libtool} == yes ; then
+    echo "$as_me:$LINENO: result: darwin-libtool" >&5
+echo "${ECHO_T}darwin-libtool" >&6
+    PYTHON_LIBS='-XCClinker -framework -XCClinker Python $(LIBS)'
+    PY_LD_SHARED='$(LD_SHARED)'
+    PY_SO_EXT='$(SO_EXT)'
+else
+    echo "$as_me:$LINENO: result: default" >&5
+echo "${ECHO_T}default" >&6
+fi
+export PY_LD_SHARED PY_SO_EXT
+  echo "$as_me:$LINENO: checking for NumPy include files" >&5
+echo $ECHO_N "checking for NumPy include files... $ECHO_C" >&6
+  echo '#include "Python.h"' > conftest.c
+  echo '#include "Numeric/arrayobject.h"' >> conftest.c
+  if test -z "`${CC-cc} $PYTHON_INCLUDES -c conftest.c 2>&1`"; then
+    HAVE_NUMPY=yes
+  else
+    HAVE_NUMPY=no
+    echo "$as_me:$LINENO: result: missing" >&5
+echo "${ECHO_T}missing" >&6
+  fi
+  export HAVE_NUMPY
+  rm -f conftest.c
+  if test "$HAVE_NUMPY" = "yes" ; then
+    NUMPY_FLAG=-DHAVE_NUMPY
+  else
+    NUMPY_FLAG=
+  fi
+  export NUMPY_FLAG
+  echo "$as_me:$LINENO: checking if local/include already standard" >&5
+echo $ECHO_N "checking if local/include already standard... $ECHO_C" >&6
+  rm -f comp.out
+  echo 'int main() { int i = 1; if( *((unsigned char *) &i) == 0 ) printf( "BIGENDIAN"); return 0; }' >> conftest.c
+  ${CC} $CPPFLAGS $EXTRA_INCLUDES -o conftest conftest.c 2> comp.out
+  COMP_CHECK=`grep "system directory" comp.out | grep /usr/local/include`
+  if test -z "$COMP_CHECK" ; then
+     echo "$as_me:$LINENO: result: no, everything is ok" >&5
+echo "${ECHO_T}no, everything is ok" >&6
+  else
+     echo "$as_me:$LINENO: result: yes, stripping extras" >&5
+echo "${ECHO_T}yes, stripping extras" >&6
+     CXXFLAGS=`echo "$CXXFLAGS " | sed "s/-I\/usr\/local\/include //"`
+     CFLAGS=`echo "$CFLAGS " | sed "s/-I\/usr\/local\/include //"`
+     EXTRA_INCLUDES=`echo "$EXTRA_INCLUDES " | sed "s/-I\/usr\/local\/include //"`
+  fi
+  rm -f comp.out
+rm -f conftest*
+          ac_config_files="$ac_config_files GDALmake.opt"
+test "x$prefix" = xNONE && prefix=$ac_default_prefix
+# Let make expand exec_prefix.
+test "x$exec_prefix" = xNONE && exec_prefix='${prefix}'
+# VPATH may cause trouble with some makes, so we remove $(srcdir),
+# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
+# trailing colons and then remove the whole line if VPATH becomes empty
+# (actually we leave an empty line to preserve line numbers).
+if test "x$srcdir" = x.; then
+  ac_vpsub='/^[	 ]*VPATH[	 ]*=/{
+s/:*\$(srcdir):*/:/;
+s/:*\${srcdir}:*/:/;
+s/:*@srcdir@:*/:/;
+s/^\([^=]*=[	 ]*\):*/\1/;
+s/:*$//;
+s/^[^=]*=[	 ]*$//;
+fi
+DEFS=-DHAVE_CONFIG_H
+ac_libobjs=
+ac_ltlibobjs=
+for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
+  # 1. Remove the extension, and $U if already installed.
+  ac_i=`echo "$ac_i" |
+	 sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
+  # 2. Add them.
+  ac_libobjs="$ac_libobjs $ac_i\$U.$ac_objext"
+  ac_ltlibobjs="$ac_ltlibobjs $ac_i"'$U.lo'
+done
+LIBOBJS=$ac_libobjs
+LTLIBOBJS=$ac_ltlibobjs
+: ${CONFIG_STATUS=./config.status}
+ac_clean_files_save=$ac_clean_files
+ac_clean_files="$ac_clean_files $CONFIG_STATUS"
+{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
+echo "$as_me: creating $CONFIG_STATUS" >&6;}
+cat >$CONFIG_STATUS <<_ACEOF
+#! $SHELL
+# Generated by $as_me.
+# Run this file to recreate the current configuration.
+# Compiler output produced by configure, useful for debugging
+# configure, is in config.log if it exists.
+debug=false
+ac_cs_recheck=false
+ac_cs_silent=false
+SHELL=\${CONFIG_SHELL-$SHELL}
+_ACEOF
+cat >>$CONFIG_STATUS <<\_ACEOF
+## M4sh Initialization.  ##
+# Be Bourne compatible
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+  emulate sh
+  NULLCMD=:
+  # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '${1+"$@"}'='"$@"'
+elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
+  set -o posix
+fi
+DUALCASE=1; export DUALCASE # for MKS sh
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+  as_unset=unset
+else
+  as_unset=false
+fi
+# Work around bugs in pre-3.0 UWIN ksh.
+$as_unset ENV MAIL MAILPATH
+PS1='$ '
+PS2='> '
+PS4='+ '
+# NLS nuisances.
+for as_var in \
+  LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
+  LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
+  LC_TELEPHONE LC_TIME
+do
+  if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
+    eval $as_var=C; export $as_var
+  else
+    $as_unset $as_var
+  fi
+done
+# Required to use basename.
+if expr a : '\(a\)' >/dev/null 2>&1; then
+  as_expr=expr
+else
+  as_expr=false
+fi
+if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
+  as_basename=basename
+else
+  as_basename=false
+fi
+# Name of the executable.
+as_me=`$as_basename "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+	 X"$0" : 'X\(//\)$' \| \
+	 X"$0" : 'X\(/\)$' \| \
+echo X/"$0" |
+    sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
+  	  /^X\/\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\/\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+# PATH needs CR, and LINENO needs CR and PATH.
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
+# The user is always right.
+if test "${PATH_SEPARATOR+set}" != set; then
+  echo "#! /bin/sh" >conf$$.sh
+  echo  "exit 0"   >>conf$$.sh
+  chmod +x conf$$.sh
+  if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
+    PATH_SEPARATOR=';'
+  else
+    PATH_SEPARATOR=:
+  fi
+  rm -f conf$$.sh
+fi
+  as_lineno_1=$LINENO
+  as_lineno_2=$LINENO
+  as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
+  test "x$as_lineno_1" != "x$as_lineno_2" &&
+  test "x$as_lineno_3"  = "x$as_lineno_2"  || {
+  # Find who we are.  Look in the path if we contain no path at all
+  # relative or not.
+  case $0 in
+    *[\\/]* ) as_myself=$0 ;;
+    *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+  test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
+  esac
+  # We did not find ourselves, most probably we were run as `sh COMMAND'
+  # in which case we are not to be found in the path.
+  if test "x$as_myself" = x; then
+    as_myself=$0
+  fi
+  if test ! -f "$as_myself"; then
+    { { echo "$as_me:$LINENO: error: cannot find myself; rerun with an absolute path" >&5
+echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2;}
+  fi
+  case $CONFIG_SHELL in
+for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
+do
+  IFS=$as_save_IFS
+  for as_base in sh bash ksh sh5; do
+	 case $as_dir in
+	   if ("$as_dir/$as_base" -c '
+  test "x$as_lineno_3"  = "x$as_lineno_2" ') 2>/dev/null; then
+	     $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
+	     $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
+	     CONFIG_SHELL=$as_dir/$as_base
+	     export CONFIG_SHELL
+	     exec "$CONFIG_SHELL" "$0" ${1+"$@"}
+	   fi;;
+	 esac
+       done
+done
+  esac
+  # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+  # uniformly replaced by the line number.  The first 'sed' inserts a
+  # line-number line before each line; the second 'sed' does the real
+  # work.  The second script uses 'N' to pair each line-number line
+  # with the numbered line, and appends trailing '-' during
+  # substitution so that $LINENO is not a special case at line end.
+  # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+  # second 'sed' script.  Blame Lee E. McMahon for sed's syntax.  :-)
+  sed '=' <$as_myself |
+    sed '
+      N
+      s,$,-,
+      : loop
+      s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
+      t loop
+      s,-$,,
+      s,^['$as_cr_digits']*\n,,
+    ' >$as_me.lineno &&
+  chmod +x $as_me.lineno ||
+    { { echo "$as_me:$LINENO: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&5
+echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2;}
+  # Don't try to exec as it changes $[0], causing all sort of problems
+  # (the dirname of $[0] is not the place where we might find the
+  # original and so on.  Autoconf is especially sensible to this).
+  . ./$as_me.lineno
+  # Exit status is that of the last command.
+  exit
+case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
+  *c*,-n*) ECHO_N= ECHO_C='
+' ECHO_T='	' ;;
+  *c*,*  ) ECHO_N=-n ECHO_C= ECHO_T= ;;
+  *)       ECHO_N= ECHO_C='\c' ECHO_T= ;;
+esac
+  as_expr=expr
+else
+  as_expr=false
+fi
+rm -f conf$$ conf$$.exe conf$$.file
+echo >conf$$.file
+if ln -s conf$$.file conf$$ 2>/dev/null; then
+  # We could just check for DJGPP; but this test a) works b) is more generic
+  # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
+  if test -f conf$$.exe; then
+    # Don't use ln at all; we don't have any links
+    as_ln_s='cp -p'
+  else
+    as_ln_s='ln -s'
+  fi
+elif ln conf$$.file conf$$ 2>/dev/null; then
+  as_ln_s=ln
+else
+  as_ln_s='cp -p'
+fi
+if mkdir -p . 2>/dev/null; then
+  as_mkdir_p=:
+else
+  test -d ./-p && rmdir ./-p
+  as_mkdir_p=false
+fi
+as_executable_p="test -f"
+# Sed expression to map a string onto a valid CPP name.
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
+# Sed expression to map a string onto a valid variable name.
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
+# IFS
+# We need space, tab and new line, in precisely that order.
+as_nl='
+IFS=" 	$as_nl"
+# CDPATH.
+$as_unset CDPATH
+exec 6>&1
+# Open the log real soon, to keep \$[0] and so on meaningful, and to
+# report actual input values of CONFIG_FILES etc. instead of their
+# values after options handling.  Logging --version etc. is OK.
+exec 5>>config.log
+  echo
+  sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
+## Running $as_me. ##
+_ASBOX
+} >&5
+cat >&5 <<_CSEOF
+This file was extended by $as_me, which was
+generated by GNU Autoconf 2.59.  Invocation command line was
+  CONFIG_FILES    = $CONFIG_FILES
+  CONFIG_HEADERS  = $CONFIG_HEADERS
+  CONFIG_LINKS    = $CONFIG_LINKS
+  CONFIG_COMMANDS = $CONFIG_COMMANDS
+  $ $0 $@
+_CSEOF
+echo "on `(hostname || uname -n) 2>/dev/null | sed 1q`" >&5
+echo >&5
+_ACEOF
+# Files that config.status was made for.
+if test -n "$ac_config_files"; then
+  echo "config_files=\"$ac_config_files\"" >>$CONFIG_STATUS
+fi
+if test -n "$ac_config_headers"; then
+  echo "config_headers=\"$ac_config_headers\"" >>$CONFIG_STATUS
+fi
+if test -n "$ac_config_links"; then
+  echo "config_links=\"$ac_config_links\"" >>$CONFIG_STATUS
+fi
+if test -n "$ac_config_commands"; then
+  echo "config_commands=\"$ac_config_commands\"" >>$CONFIG_STATUS
+fi
+ac_cs_usage="\
+\`$as_me' instantiates files from templates according to the
+current configuration.
+Usage: $0 [OPTIONS] [FILE]...
+  -h, --help       print this help, then exit
+  -V, --version    print version number, then exit
+  -q, --quiet      do not print progress messages
+  -d, --debug      don't remove temporary files
+      --recheck    update $as_me by reconfiguring in the same conditions
+  --file=FILE[:TEMPLATE]
+		   instantiate the configuration file FILE
+  --header=FILE[:TEMPLATE]
+		   instantiate the configuration header FILE
+Configuration files:
+$config_files
+Configuration headers:
+$config_headers
+Report bugs to <bug-autoconf at gnu.org>."
+_ACEOF
+cat >>$CONFIG_STATUS <<_ACEOF
+ac_cs_version="\\
+config.status
+configured by $0, generated by GNU Autoconf 2.59,
+  with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
+Copyright (C) 2003 Free Software Foundation, Inc.
+This config.status script is free software; the Free Software Foundation
+gives unlimited permission to copy, distribute and modify it."
+srcdir=$srcdir
+_ACEOF
+# If no file are specified by the user, then we need to provide default
+# value.  By we need to know if files were specified by the user.
+ac_need_defaults=:
+while test $# != 0
+do
+  case $1 in
+    ac_option=`expr "x$1" : 'x\([^=]*\)='`
+    ac_optarg=`expr "x$1" : 'x[^=]*=\(.*\)'`
+    ac_shift=:
+    ac_option=$1
+    ac_optarg=$2
+    ac_shift=shift
+  *) # This is not an option, so the user has probably given explicit
+     # arguments.
+     ac_option=$1
+     ac_need_defaults=false;;
+  esac
+  case $ac_option in
+  # Handling of the options.
+_ACEOF
+  -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
+    ac_cs_recheck=: ;;
+  --version | --vers* | -V )
+    echo "$ac_cs_version"; exit 0 ;;
+  --he | --h)
+    # Conflict between --help and --header
+    { { echo "$as_me:$LINENO: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&5
+echo "$as_me: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&2;}
+   { (exit 1); exit 1; }; };;
+  --help | --hel | -h )
+    echo "$ac_cs_usage"; exit 0 ;;
+  --debug | --d* | -d )
+    debug=: ;;
+  --file | --fil | --fi | --f )
+    $ac_shift
+    CONFIG_FILES="$CONFIG_FILES $ac_optarg"
+  --header | --heade | --head | --hea )
+    $ac_shift
+    CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg"
+  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
+  | -silent | --silent | --silen | --sile | --sil | --si | --s)
+    ac_cs_silent=: ;;
+  # This is an error.
+  -*) { { echo "$as_me:$LINENO: error: unrecognized option: $1
+echo "$as_me: error: unrecognized option: $1
+   { (exit 1); exit 1; }; } ;;
+  *) ac_config_targets="$ac_config_targets $1" ;;
+  esac
+  shift
+done
+ac_configure_extra_args=
+if $ac_cs_silent; then
+  exec 6>/dev/null
+  ac_configure_extra_args="$ac_configure_extra_args --silent"
+fi
+_ACEOF
+if \$ac_cs_recheck; then
+  echo "running $SHELL $0 " $ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6
+  exec $SHELL $0 $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+fi
+_ACEOF
+for ac_config_target in $ac_config_targets
+do
+  case "$ac_config_target" in
+  # Handling of arguments.
+  "GDALmake.opt" ) CONFIG_FILES="$CONFIG_FILES GDALmake.opt" ;;
+  "port/cpl_config.h" ) CONFIG_HEADERS="$CONFIG_HEADERS port/cpl_config.h" ;;
+  *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
+echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
+  esac
+done
+# If the user did not use the arguments to specify the items to instantiate,
+# then the envvar interface is used.  Set only those that are not.
+# We use the long form for the default assignment because of an extremely
+# bizarre bug on SunOS 4.1.3.
+if $ac_need_defaults; then
+  test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
+  test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers
+fi
+# Have a temporary directory for convenience.  Make it in the build tree
+# simply because there is no reason to put it here, and in addition,
+# creating and moving files from /tmp can sometimes cause problems.
+# Create a temporary directory, and hook for its removal unless debugging.
+$debug ||
+  trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
+  trap '{ (exit 1); exit 1; }' 1 2 13 15
+# Create a (secure) tmp directory for tmp files.
+  tmp=`(umask 077 && mktemp -d -q "./confstatXXXXXX") 2>/dev/null` &&
+  test -n "$tmp" && test -d "$tmp"
+  tmp=./confstat$$-$RANDOM
+  (umask 077 && mkdir $tmp)
+   echo "$me: cannot create a temporary directory in ." >&2
+_ACEOF
+# CONFIG_FILES section.
+# No need to generate the scripts if there are no CONFIG_FILES.
+# This happens for instance when ./config.status config.h
+if test -n "\$CONFIG_FILES"; then
+  # Protect against being on the right side of a sed subst in config.status.
+  sed 's/,@/@@/; s/@,/@@/; s/,;t t\$/@;t t/; /@;t t\$/s/[\\\\&,]/\\\\&/g;
+   s/@@/,@/; s/@@/@,/; s/@;t t\$/,;t t/' >\$tmp/subs.sed <<\\CEOF
+s, at PYTHON_CC@,$PYTHON_CC,;t t
+s, at PYTHON_OPT@,$PYTHON_OPT,;t t
+s, at PYTHON_SO@,$PYTHON_SO,;t t
+s, at PYTHON_CFLAGS@,$PYTHON_CFLAGS,;t t
+s, at PYTHON_LIBS@,$PYTHON_LIBS,;t t
+s, at PYTHON_LINK@,$PYTHON_LINK,;t t
+s, at SHELL@,$SHELL,;t t
+s, at PATH_SEPARATOR@,$PATH_SEPARATOR,;t t
+s, at PACKAGE_NAME@,$PACKAGE_NAME,;t t
+s, at PACKAGE_TARNAME@,$PACKAGE_TARNAME,;t t
+s, at PACKAGE_VERSION@,$PACKAGE_VERSION,;t t
+s, at PACKAGE_STRING@,$PACKAGE_STRING,;t t
+s, at PACKAGE_BUGREPORT@,$PACKAGE_BUGREPORT,;t t
+s, at exec_prefix@,$exec_prefix,;t t
+s, at prefix@,$prefix,;t t
+s, at program_transform_name@,$program_transform_name,;t t
+s, at bindir@,$bindir,;t t
+s, at sbindir@,$sbindir,;t t
+s, at libexecdir@,$libexecdir,;t t
+s, at datadir@,$datadir,;t t
+s, at sysconfdir@,$sysconfdir,;t t
+s, at sharedstatedir@,$sharedstatedir,;t t
+s, at localstatedir@,$localstatedir,;t t
+s, at libdir@,$libdir,;t t
+s, at includedir@,$includedir,;t t
+s, at oldincludedir@,$oldincludedir,;t t
+s, at infodir@,$infodir,;t t
+s, at mandir@,$mandir,;t t
+s, at build_alias@,$build_alias,;t t
+s, at host_alias@,$host_alias,;t t
+s, at target_alias@,$target_alias,;t t
+s, at DEFS@,$DEFS,;t t
+s, at ECHO_C@,$ECHO_C,;t t
+s, at ECHO_N@,$ECHO_N,;t t
+s, at ECHO_T@,$ECHO_T,;t t
+s, at LIBS@,$LIBS,;t t
+s, at build@,$build,;t t
+s, at build_cpu@,$build_cpu,;t t
+s, at build_vendor@,$build_vendor,;t t
+s, at build_os@,$build_os,;t t
+s, at host@,$host,;t t
+s, at host_cpu@,$host_cpu,;t t
+s, at host_vendor@,$host_vendor,;t t
+s, at host_os@,$host_os,;t t
+s, at target@,$target,;t t
+s, at target_cpu@,$target_cpu,;t t
+s, at target_vendor@,$target_vendor,;t t
+s, at target_os@,$target_os,;t t
+s, at CC@,$CC,;t t
+s, at CFLAGS@,$CFLAGS,;t t
+s, at LDFLAGS@,$LDFLAGS,;t t
+s, at CPPFLAGS@,$CPPFLAGS,;t t
+s, at ac_ct_CC@,$ac_ct_CC,;t t
+s, at EXEEXT@,$EXEEXT,;t t
+s, at OBJEXT@,$OBJEXT,;t t
+s, at CXX@,$CXX,;t t
+s, at CXXFLAGS@,$CXXFLAGS,;t t
+s, at ac_ct_CXX@,$ac_ct_CXX,;t t
+s, at EGREP@,$EGREP,;t t
+s, at LN_S@,$LN_S,;t t
+s, at ECHO@,$ECHO,;t t
+s, at AR@,$AR,;t t
+s, at ac_ct_AR@,$ac_ct_AR,;t t
+s, at RANLIB@,$RANLIB,;t t
+s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
+s, at STRIP@,$STRIP,;t t
+s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
+s, at DLLTOOL@,$DLLTOOL,;t t
+s, at ac_ct_DLLTOOL@,$ac_ct_DLLTOOL,;t t
+s, at AS@,$AS,;t t
+s, at ac_ct_AS@,$ac_ct_AS,;t t
+s, at OBJDUMP@,$OBJDUMP,;t t
+s, at ac_ct_OBJDUMP@,$ac_ct_OBJDUMP,;t t
+s, at CPP@,$CPP,;t t
+s, at CXXCPP@,$CXXCPP,;t t
+s, at F77@,$F77,;t t
+s, at FFLAGS@,$FFLAGS,;t t
+s, at ac_ct_F77@,$ac_ct_F77,;t t
+s, at LIBTOOL@,$LIBTOOL,;t t
+s, at CXX_PIC@,$CXX_PIC,;t t
+s, at C_PIC@,$C_PIC,;t t
+s, at LD_SHARED@,$LD_SHARED,;t t
+s, at SO_EXT@,$SO_EXT,;t t
+s, at HAVE_LIBTOOL@,$HAVE_LIBTOOL,;t t
+s, at LIBZ_SETTING@,$LIBZ_SETTING,;t t
+s, at PG_CONFIG@,$PG_CONFIG,;t t
+s, at HAVE_PG@,$HAVE_PG,;t t
+s, at PG_INC@,$PG_INC,;t t
+s, at PG_LIB@,$PG_LIB,;t t
+s, at GRASS_SETTING@,$GRASS_SETTING,;t t
+s, at GRASS_INCLUDE@,$GRASS_INCLUDE,;t t
+s, at GRASS_GISBASE@,$GRASS_GISBASE,;t t
+s, at HAVE_GRASS@,$HAVE_GRASS,;t t
+s, at FITS_SETTING@,$FITS_SETTING,;t t
+s, at PCRASTER_SETTING@,$PCRASTER_SETTING,;t t
+s, at NETCDF_SETTING@,$NETCDF_SETTING,;t t
+s, at PNG_SETTING@,$PNG_SETTING,;t t
+s, at TIFF_SETTING@,$TIFF_SETTING,;t t
+s, at GEOTIFF_SETTING@,$GEOTIFF_SETTING,;t t
+s, at JPEG_SETTING@,$JPEG_SETTING,;t t
+s, at GIF_SETTING@,$GIF_SETTING,;t t
+s, at HAVE_OGDI@,$HAVE_OGDI,;t t
+s, at OGDI_INCLUDE@,$OGDI_INCLUDE,;t t
+s, at X_FME_HOME@,$X_FME_HOME,;t t
+s, at HAVE_HDF4@,$HAVE_HDF4,;t t
+s, at HDF4_INCLUDE@,$HDF4_INCLUDE,;t t
+s, at HAVE_HDF5@,$HAVE_HDF5,;t t
+s, at HDF5_INCLUDE@,$HDF5_INCLUDE,;t t
+s, at HAVE_JASPER@,$HAVE_JASPER,;t t
+s, at JASPER_FLAGS@,$JASPER_FLAGS,;t t
+s, at ECW_SETTING@,$ECW_SETTING,;t t
+s, at KAKDIR@,$KAKDIR,;t t
+s, at HAVE_MRSID@,$HAVE_MRSID,;t t
+s, at MRSID_INCLUDE@,$MRSID_INCLUDE,;t t
+s, at MRSID_FLAGS@,$MRSID_FLAGS,;t t
+s, at OPT_GDAL_FORMATS@,$OPT_GDAL_FORMATS,;t t
+s, at OGR_ENABLED@,$OGR_ENABLED,;t t
+s, at MYSQL_CONFIG@,$MYSQL_CONFIG,;t t
+s, at HAVE_MYSQL@,$HAVE_MYSQL,;t t
+s, at MYSQL_INC@,$MYSQL_INC,;t t
+s, at MYSQL_LIB@,$MYSQL_LIB,;t t
+s, at HAVE_XERCES@,$HAVE_XERCES,;t t
+s, at XERCES_INCLUDE@,$XERCES_INCLUDE,;t t
+s, at ODBC_SETTING@,$ODBC_SETTING,;t t
+s, at ORACLE_OCI_VERSION@,$ORACLE_OCI_VERSION,;t t
+s, at ORACLE_OCI_CFLAGS@,$ORACLE_OCI_CFLAGS,;t t
+s, at ORACLE_OCI_LDFLAGS@,$ORACLE_OCI_LDFLAGS,;t t
+s, at HAVE_OCI@,$HAVE_OCI,;t t
+s, at OCI_INCLUDE@,$OCI_INCLUDE,;t t
+s, at DODS_INC@,$DODS_INC,;t t
+s, at LIBCURL_CONFIG@,$LIBCURL_CONFIG,;t t
+s, at CURL_SETTING@,$CURL_SETTING,;t t
+s, at CURL_INC@,$CURL_INC,;t t
+s, at CURL_LIB@,$CURL_LIB,;t t
+s, at SQLITE_INC@,$SQLITE_INC,;t t
+s, at HAVE_SQLITE@,$HAVE_SQLITE,;t t
+s, at DWG_PLT@,$DWG_PLT,;t t
+s, at DWGDIRECT@,$DWGDIRECT,;t t
+s, at HAVE_PANORAMA@,$HAVE_PANORAMA,;t t
+s, at PANORAMA_INC@,$PANORAMA_INC,;t t
+s, at HAVE_IDB@,$HAVE_IDB,;t t
+s, at IDB_INC@,$IDB_INC,;t t
+s, at IDB_LIB@,$IDB_LIB,;t t
+s, at SDE_ENABLED@,$SDE_ENABLED,;t t
+s, at SDE_INC@,$SDE_INC,;t t
+s, at SDE_LIB@,$SDE_LIB,;t t
+s, at GEOS_LIBS@,$GEOS_LIBS,;t t
+s, at GEOS_CFLAGS@,$GEOS_CFLAGS,;t t
+s, at HAVE_GEOS@,$HAVE_GEOS,;t t
+s, at GEOS_VERSION@,$GEOS_VERSION,;t t
+s, at GEOS_CONFIG@,$GEOS_CONFIG,;t t
+s, at PROJ_STATIC@,$PROJ_STATIC,;t t
+s, at PROJ_INCLUDE@,$PROJ_INCLUDE,;t t
+s, at GDAL_VERSION_MAJOR@,$GDAL_VERSION_MAJOR,;t t
+s, at GDAL_VERSION_MINOR@,$GDAL_VERSION_MINOR,;t t
+s, at GDAL_VERSION_REV@,$GDAL_VERSION_REV,;t t
+s, at GDAL_VER@,$GDAL_VER,;t t
+s, at MACOSX_FRAMEWORK@,$MACOSX_FRAMEWORK,;t t
+s, at CXX_WFLAGS@,$CXX_WFLAGS,;t t
+s, at C_WFLAGS@,$C_WFLAGS,;t t
+s, at EXTRA_INCLUDES@,$EXTRA_INCLUDES,;t t
+s, at EXE_EXT@,$EXE_EXT,;t t
+s, at BINTRUE@,$BINTRUE,;t t
+s, at BINDINGS@,$BINDINGS,;t t
+s, at PYTHON@,$PYTHON,;t t
+s, at pythondir@,$pythondir,;t t
+s, at pyexecdir@,$pyexecdir,;t t
+s, at pymoddir@,$pymoddir,;t t
+s, at PYTHON_INCLUDES@,$PYTHON_INCLUDES,;t t
+s, at PY_LD_SHARED@,$PY_LD_SHARED,;t t
+s, at PY_SO_EXT@,$PY_SO_EXT,;t t
+s, at HAVE_NUMPY@,$HAVE_NUMPY,;t t
+s, at NUMPY_FLAG@,$NUMPY_FLAG,;t t
+s, at LIBOBJS@,$LIBOBJS,;t t
+s, at LTLIBOBJS@,$LTLIBOBJS,;t t
+CEOF
+_ACEOF
+  cat >>$CONFIG_STATUS <<\_ACEOF
+  # Split the substitutions into bite-sized pieces for seds with
+  # small command number limits, like on Digital OSF/1 and HP-UX.
+  ac_max_sed_lines=48
+  ac_sed_frag=1 # Number of current file.
+  ac_beg=1 # First line for current file.
+  ac_end=$ac_max_sed_lines # Line after last line for current file.
+  ac_more_lines=:
+  ac_sed_cmds=
+  while $ac_more_lines; do
+    if test $ac_beg -gt 1; then
+      sed "1,${ac_beg}d; ${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
+    else
+      sed "${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
+    fi
+    if test ! -s $tmp/subs.frag; then
+      ac_more_lines=false
+    else
+      # The purpose of the label and of the branching condition is to
+      # speed up the sed processing (if there are no `@' at all, there
+      # is no need to browse any of the substitutions).
+      # These are the two extra sed commands mentioned above.
+      (echo ':t
+  /@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag) >$tmp/subs-$ac_sed_frag.sed
+      if test -z "$ac_sed_cmds"; then
+	ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
+      else
+	ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
+      fi
+      ac_sed_frag=`expr $ac_sed_frag + 1`
+      ac_beg=$ac_end
+      ac_end=`expr $ac_end + $ac_max_sed_lines`
+    fi
+  done
+    ac_sed_cmds=cat
+  fi
+fi # test -n "$CONFIG_FILES"
+_ACEOF
+for ac_file in : $CONFIG_FILES; do test "x$ac_file" = x: && continue
+  # Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
+  case $ac_file in
+  - | *:- | *:-:* ) # input from stdin
+	cat >$tmp/stdin
+	ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
+	ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
+  *:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
+  * )   ac_file_in=$ac_file.in ;;
+  esac
+  # Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
+  ac_dir=`(dirname "$ac_file") 2>/dev/null ||
+$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$ac_file" : 'X\(//\)[^/]' \| \
+	 X"$ac_file" : 'X\(//\)$' \| \
+	 X"$ac_file" : 'X\(/\)' \| \
+echo X"$ac_file" |
+  	  s/.*/./; q'`
+  { if $as_mkdir_p; then
+    mkdir -p "$ac_dir"
+  else
+    as_dir="$ac_dir"
+    as_dirs=
+    while test ! -d "$as_dir"; do
+      as_dirs="$as_dir $as_dirs"
+      as_dir=`(dirname "$as_dir") 2>/dev/null ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$as_dir" : 'X\(//\)[^/]' \| \
+	 X"$as_dir" : 'X\(//\)$' \| \
+	 X"$as_dir" : 'X\(/\)' \| \
+echo X"$as_dir" |
+  	  s/.*/./; q'`
+    done
+    test ! -n "$as_dirs" || mkdir $as_dirs
+  fi || { { echo "$as_me:$LINENO: error: cannot create directory \"$ac_dir\"" >&5
+echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
+   { (exit 1); exit 1; }; }; }
+  ac_builddir=.
+if test "$ac_dir" != .; then
+  ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
+  # A "../" for each directory in $ac_dir_suffix.
+  ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
+else
+  ac_dir_suffix= ac_top_builddir=
+fi
+case $srcdir in
+  .)  # No --srcdir option.  We are building in place.
+    ac_srcdir=.
+    if test -z "$ac_top_builddir"; then
+       ac_top_srcdir=.
+    else
+       ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
+    fi ;;
+  [\\/]* | ?:[\\/]* )  # Absolute path.
+    ac_srcdir=$srcdir$ac_dir_suffix;
+    ac_top_srcdir=$srcdir ;;
+  *) # Relative path.
+    ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
+    ac_top_srcdir=$ac_top_builddir$srcdir ;;
+esac
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+  case "$ac_dir" in
+  .) ac_abs_builddir=`pwd`;;
+  [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+  *) ac_abs_builddir=`pwd`/"$ac_dir";;
+  esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+  case ${ac_top_builddir}. in
+  .) ac_abs_top_builddir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+  *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+  esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+  case $ac_srcdir in
+  .) ac_abs_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+  *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+  esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+  case $ac_top_srcdir in
+  .) ac_abs_top_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+  *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+  esac;;
+esac
+  if test x"$ac_file" != x-; then
+    { echo "$as_me:$LINENO: creating $ac_file" >&5
+echo "$as_me: creating $ac_file" >&6;}
+    rm -f "$ac_file"
+  fi
+  # Let's still pretend it is `configure' which instantiates (i.e., don't
+  # use $as_me), people would be surprised to read:
+  #    /* config.h.  Generated by config.status.  */
+  if test x"$ac_file" = x-; then
+    configure_input=
+  else
+    configure_input="$ac_file.  "
+  fi
+  configure_input=$configure_input"Generated from `echo $ac_file_in |
+				     sed 's,.*/,,'` by configure."
+  # First look for the input files in the build tree, otherwise in the
+  # src tree.
+  ac_file_inputs=`IFS=:
+    for f in $ac_file_in; do
+      case $f in
+      -) echo $tmp/stdin ;;
+	 # Absolute (can't be DOS-style, as IFS=:)
+	 test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+echo "$as_me: error: cannot find input file: $f" >&2;}
+	 echo "$f";;
+      *) # Relative
+	 if test -f "$f"; then
+	   # Build tree
+	   echo "$f"
+	 elif test -f "$srcdir/$f"; then
+	   # Source tree
+	   echo "$srcdir/$f"
+	 else
+	   # /dev/null tree
+	   { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+	 fi;;
+      esac
+    done` || { (exit 1); exit 1; }
+_ACEOF
+  sed "$ac_vpsub
+$extrasub
+_ACEOF
+:t
+/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
+s, at configure_input@,$configure_input,;t t
+s, at srcdir@,$ac_srcdir,;t t
+s, at abs_srcdir@,$ac_abs_srcdir,;t t
+s, at top_srcdir@,$ac_top_srcdir,;t t
+s, at abs_top_srcdir@,$ac_abs_top_srcdir,;t t
+s, at builddir@,$ac_builddir,;t t
+s, at abs_builddir@,$ac_abs_builddir,;t t
+s, at top_builddir@,$ac_top_builddir,;t t
+s, at abs_top_builddir@,$ac_abs_top_builddir,;t t
+" $ac_file_inputs | (eval "$ac_sed_cmds") >$tmp/out
+  rm -f $tmp/stdin
+    mv $tmp/out $ac_file
+  else
+    cat $tmp/out
+    rm -f $tmp/out
+  fi
+done
+_ACEOF
+# CONFIG_HEADER section.
+# These sed commands are passed to sed as "A NAME B NAME C VALUE D", where
+# NAME is the cpp macro being defined and VALUE is the value it is being given.
+# ac_d sets the value in "#define NAME VALUE" lines.
+ac_dA='s,^\([	 ]*\)#\([	 ]*define[	 ][	 ]*\)'
+ac_dB='[	 ].*$,\1#\2'
+ac_dC=' '
+ac_dD=',;t'
+# ac_u turns "#undef NAME" without trailing blanks into "#define NAME VALUE".
+ac_uA='s,^\([	 ]*\)#\([	 ]*\)undef\([	 ][	 ]*\)'
+ac_uB='$,\1#\2define\3'
+ac_uC=' '
+ac_uD=',;t'
+for ac_file in : $CONFIG_HEADERS; do test "x$ac_file" = x: && continue
+  case $ac_file in
+	cat >$tmp/stdin
+  esac
+  test x"$ac_file" != x- && { echo "$as_me:$LINENO: creating $ac_file" >&5
+  # src tree.
+      case $f in
+	 # Do quote $f, to prevent DOS paths from being IFS'd.
+	 echo "$f";;
+      *) # Relative
+	   # Build tree
+	   echo "$f"
+	   # Source tree
+	   echo "$srcdir/$f"
+	 else
+	   # /dev/null tree
+	 fi;;
+      esac
+  # Remove the trailing spaces.
+  sed 's/[	 ]*$//' $ac_file_inputs >$tmp/in
+_ACEOF
+# Transform confdefs.h into two sed scripts, `conftest.defines' and
+# `conftest.undefs', that substitutes the proper values into
+# config.h.in to produce config.h.  The first handles `#define'
+# templates, and the second `#undef' templates.
+# And first: Protect against being on the right side of a sed subst in
+# config.status.  Protect against being in an unquoted here document
+# in config.status.
+rm -f conftest.defines conftest.undefs
+# Using a here document instead of a string reduces the quoting nightmare.
+# Putting comments in sed scripts is not portable.
+# `end' is used to avoid that the second main sed command (meant for
+# 0-ary CPP macros) applies to n-ary macro definitions.
+# See the Autoconf documentation for `clear'.
+cat >confdef2sed.sed <<\_ACEOF
+s/[\\&,]/\\&/g
+s,[\\$`],\\&,g
+t clear
+: clear
+s,^[	 ]*#[	 ]*define[	 ][	 ]*\([^	 (][^	 (]*\)\(([^)]*)\)[	 ]*\(.*\)$,${ac_dA}\1${ac_dB}\1\2${ac_dC}\3${ac_dD},gp
+t end
+s,^[	 ]*#[	 ]*define[	 ][	 ]*\([^	 ][^	 ]*\)[	 ]*\(.*\)$,${ac_dA}\1${ac_dB}\1${ac_dC}\2${ac_dD},gp
+: end
+_ACEOF
+# If some macros were called several times there might be several times
+# the same #defines, which is useless.  Nevertheless, we may not want to
+# sort them, since we want the *last* AC-DEFINE to be honored.
+uniq confdefs.h | sed -n -f confdef2sed.sed >conftest.defines
+sed 's/ac_d/ac_u/g' conftest.defines >conftest.undefs
+rm -f confdef2sed.sed
+# This sed command replaces #undef with comments.  This is necessary, for
+# example, in the case of _POSIX_SOURCE, which is predefined and required
+# on some systems where configure will not decide to define it.
+cat >>conftest.undefs <<\_ACEOF
+s,^[	 ]*#[	 ]*undef[	 ][	 ]*[a-zA-Z_][a-zA-Z_0-9]*,/* & */,
+_ACEOF
+# Break up conftest.defines because some shells have a limit on the size
+# of here documents, and old seds have small limits too (100 cmds).
+echo '  # Handle all the #define templates only if necessary.' >>$CONFIG_STATUS
+echo '  if grep "^[	 ]*#[	 ]*define" $tmp/in >/dev/null; then' >>$CONFIG_STATUS
+echo '  # If there are no defines, we may have an empty if/fi' >>$CONFIG_STATUS
+echo '  :' >>$CONFIG_STATUS
+rm -f conftest.tail
+while grep . conftest.defines >/dev/null
+do
+  # Write a limited-size here document to $tmp/defines.sed.
+  echo '  cat >$tmp/defines.sed <<CEOF' >>$CONFIG_STATUS
+  # Speed up: don't consider the non `#define' lines.
+  echo '/^[	 ]*#[	 ]*define/!b' >>$CONFIG_STATUS
+  # Work around the forget-to-reset-the-flag bug.
+  echo 't clr' >>$CONFIG_STATUS
+  echo ': clr' >>$CONFIG_STATUS
+  sed ${ac_max_here_lines}q conftest.defines >>$CONFIG_STATUS
+  echo 'CEOF
+  sed -f $tmp/defines.sed $tmp/in >$tmp/out
+  rm -f $tmp/in
+  mv $tmp/out $tmp/in
+' >>$CONFIG_STATUS
+  sed 1,${ac_max_here_lines}d conftest.defines >conftest.tail
+  rm -f conftest.defines
+  mv conftest.tail conftest.defines
+done
+echo '  fi # grep' >>$CONFIG_STATUS
+echo >>$CONFIG_STATUS
+# Break up conftest.undefs because some shells have a limit on the size
+echo '  # Handle all the #undef templates' >>$CONFIG_STATUS
+while grep . conftest.undefs >/dev/null
+do
+  # Write a limited-size here document to $tmp/undefs.sed.
+  echo '  cat >$tmp/undefs.sed <<CEOF' >>$CONFIG_STATUS
+  # Speed up: don't consider the non `#undef'
+  echo '/^[	 ]*#[	 ]*undef/!b' >>$CONFIG_STATUS
+  sed ${ac_max_here_lines}q conftest.undefs >>$CONFIG_STATUS
+  echo 'CEOF
+  sed -f $tmp/undefs.sed $tmp/in >$tmp/out
+  rm -f $tmp/in
+' >>$CONFIG_STATUS
+  sed 1,${ac_max_here_lines}d conftest.undefs >conftest.tail
+  rm -f conftest.undefs
+  mv conftest.tail conftest.undefs
+done
+rm -f conftest.undefs
+    echo "/* Generated by configure.  */" >$tmp/config.h
+  else
+    echo "/* $ac_file.  Generated by configure.  */" >$tmp/config.h
+  fi
+  cat $tmp/in >>$tmp/config.h
+  rm -f $tmp/in
+    if diff $ac_file $tmp/config.h >/dev/null 2>&1; then
+      { echo "$as_me:$LINENO: $ac_file is unchanged" >&5
+echo "$as_me: $ac_file is unchanged" >&6;}
+    else
+echo X"$ac_file" |
+  	  s/.*/./; q'`
+  else
+    as_dir="$ac_dir"
+    as_dirs=
+echo X"$as_dir" |
+  	  s/.*/./; q'`
+    done
+      rm -f $ac_file
+      mv $tmp/config.h $ac_file
+    fi
+  else
+    cat $tmp/config.h
+    rm -f $tmp/config.h
+  fi
+done
+_ACEOF
+{ (exit 0); exit 0; }
+_ACEOF
+chmod +x $CONFIG_STATUS
+ac_clean_files=$ac_clean_files_save
+# configure is writing to config.log, and then calls config.status.
+# config.status does its own redirection, appending to config.log.
+# Unfortunately, on DOS this fails, as config.log is still kept open
+# by configure, so config.status won't be able to write to it; its
+# output is simply discarded.  So we exec the FD to /dev/null,
+# effectively closing config.log, so it can be properly (re)opened and
+# appended to by config.status.  When coming back to configure, we
+# need to make the FD available again.
+if test "$no_create" != yes; then
+  ac_cs_success=:
+  ac_config_status_args=
+  test "$silent" = yes &&
+    ac_config_status_args="$ac_config_status_args --quiet"
+  exec 5>/dev/null
+  $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false
+  exec 5>>config.log
+  # Use ||, not &&, to avoid exiting from the if with $? = 1, which
+  # would make configure fail if this is the last instruction.
+  $ac_cs_success || { (exit 1); exit 1; }
+fi
+if test "$PYTHON" != "no" ; then
+  HAVE_PYTHON=yes
+else
+  HAVE_PYTHON=no
+fi
+echo ""
+echo "GDAL is now configured for ${host}"
+echo ""
+echo "  Installation directory:    ${prefix}"
+echo "  C compiler:                ${CC} ${CFLAGS}"
+echo "  C++ compiler:              ${CXX} ${CXXFLAGS}"
+echo ""
+echo "  LIBTOOL support:           ${with_libtool}"
+echo ""
+echo "  LIBZ support:              ${LIBZ_SETTING}"
+echo "  GRASS support:             ${GRASS_SETTING}"
+echo "  CFITSIO support:           ${FITS_SETTING}"
+echo "  PCRaster support:          ${PCRASTER_SETTING}"
+echo "  NETCDF support:            ${NETCDF_SETTING}"
+echo "  LIBPNG support:            ${PNG_SETTING}"
+echo "  LIBTIFF support:           ${TIFF_SETTING}"
+echo "  LIBGEOTIFF support:        ${GEOTIFF_SETTING}"
+echo "  LIBJPEG support:           ${JPEG_SETTING}"
+echo "  LIBGIF support:            ${GIF_SETTING}"
+echo "  OGDI support:              ${HAVE_OGDI}"
+echo "  HDF4 support:              ${HAVE_HDF4}"
+echo "  HDF5 support:              ${HAVE_HDF5}"
+echo "  KAKADU support:            ${HAVE_KAKADU}"
+if test "x$HAVE_JASPER_UUID" != "x" ; then
+echo "  JASPER support:            ${HAVE_JASPER} (GeoJP2=${HAVE_JASPER_UUID})"
+else
+echo "  JASPER support:            ${HAVE_JASPER}"
+fi
+echo "  ECW support:               ${ECW_SETTING}"
+echo "  MrSID support:             ${HAVE_MRSID}"
+echo "  CURL support (wcs):        ${CURL_SETTING}"
+echo "  POSTGRESQL support:        ${HAVE_PG}"
+echo "  MySQL support:             ${HAVE_MYSQL}"
+echo "  XERCES support:            ${HAVE_XERCES}"
+echo "  ODBC support:              ${ODBC_SETTING}"
+echo "  PGEO support:              ${ODBC_SETTING}"
+echo "  OCI support:               ${HAVE_OCI}"
+echo "  SDE support:               ${SDE_ENABLED}"
+echo "  DODS support:              ${HAVE_DODS}"
+echo "  SQLite support:            ${HAVE_SQLITE}"
+echo "  DWGdirect support          ${HAVE_DWGDIRECT}"
+echo "  PANORAMA GIS support:      ${HAVE_PANORAMA}"
+echo "  INFORMIX DataBlade support:${HAVE_IDB}"
+echo "  GEOS support:              ${HAVE_GEOS}"
+echo ""
+echo "  Statically link PROJ.4:    ${PROJ_STATIC}"
+if test ! -z "`uname | grep Darwin`" ; then
+echo "  Mac OS X Framework :       ${MACOSX_FRAMEWORK}"
+fi
+echo ""
+echo "  Traditional Python:        ${HAVE_PYTHON}"
+echo "  NG SWIG Bindings:          ${BINDINGS}"
+echo ""
+echo "  enable OGR building:       ${OGR_ENABLED}"
+echo ""
Property changes on: trunk/MgDev/Oem/gdal-1.4.0/configure
___________________________________________________________________
Added: trunk/MgDev/Oem/gdal-1.4.0/install-sh
--- trunk/MgDev/Oem/gdal-1.4.0/install-sh	                        (rev 0)
+++ trunk/MgDev/Oem/gdal-1.4.0/install-sh	2007-03-21 21:28:21 UTC (rev 1328)
@@ -0,0 +1,256 @@
+#!/bin/sh
+# install - install a program, script, or datafile
+# This comes from X11R5 (mit/util/scripts/install.sh).
+# Copyright 1991 by the Massachusetts Institute of Technology
+# Permission to use, copy, modify, distribute, and sell this software and its
+# documentation for any purpose is hereby granted without fee, provided that
+# the above copyright notice appear in all copies and that both that
+# copyright notice and this permission notice appear in supporting
+# documentation, and that the name of M.I.T. not be used in advertising or
+# publicity pertaining to distribution of the software without specific,
+# written prior permission.  M.I.T. makes no representations about the
+# suitability of this software for any purpose.  It is provided "as is"
+# without express or implied warranty.
+# Calling this script install-sh is preferred over install.sh, to prevent
+# `make' implicit rules from creating a file called install from it
+# when there is no Makefile.
+# This script is compatible with the BSD install script, but was written
+# from scratch.  It can only install one file at a time, a restriction
+# shared with many OS's install programs.
+# set DOITPROG to echo to test this script
+# Don't use :- since 4.3BSD and earlier shells don't like it.
+doit="${DOITPROG-}"
+# put in absolute paths if you don't have them in your path; or use env. vars.
+mvprog="${MVPROG-mv}"
+cpprog="${CPPROG-cp}"
+chmodprog="${CHMODPROG-chmod}"
+chownprog="${CHOWNPROG-chown}"
+chgrpprog="${CHGRPPROG-chgrp}"
+stripprog="${STRIPPROG-strip}"
+rmprog="${RMPROG-rm}"
+mkdirprog="${MKDIRPROG-mkdir}"
+transformbasename=""
+transform_arg=""
+instcmd="$mvprog"
+chmodcmd="$chmodprog 0755"
+chowncmd=""
+chgrpcmd=""
+stripcmd=""
+rmcmd="$rmprog -f"
+mvcmd="$mvprog"
+src=""
+dst=""
+dir_arg=""
+while [ x"$1" != x ]; do
+    case $1 in
+	-c) instcmd="$cpprog"
+	    shift
+	    continue;;
+	-d) dir_arg=true
+	    shift
+	    continue;;
+	-m) chmodcmd="$chmodprog $2"
+	    shift
+	    shift
+	    continue;;
+	-o) chowncmd="$chownprog $2"
+	    shift
+	    shift
+	    continue;;
+	-g) chgrpcmd="$chgrpprog $2"
+	    shift
+	    shift
+	    continue;;
+	-s) stripcmd="$stripprog"
+	    shift
+	    continue;;
+	-t=*) transformarg=`echo $1 | sed 's/-t=//'`
+	    shift
+	    continue;;
+	-b=*) transformbasename=`echo $1 | sed 's/-b=//'`
+	    shift
+	    continue;;
+	*)  if [ x"$src" = x ]
+	    then
+		src=$1
+	    else
+		# this colon is to work around a 386BSD /bin/sh bug
+		dst=$1
+	    fi
+	    shift
+	    continue;;
+    esac
+done
+if [ x"$src" = x ]
+then
+	echo "install:	no input file specified"
+	exit 1
+else
+	true
+fi
+if [ -x "$src".exe ] ; then
+  src=${src}.exe
+  echo "Cygwin hack - actually installing "$src
+fi
+if [ x"$dir_arg" != x ]; then
+	dst=$src
+	src=""
+	if [ -d $dst ]; then
+		instcmd=:
+		chmodcmd=""
+	else
+		instcmd=mkdir
+	fi
+else
+# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
+# might cause directories to be created, which would be especially bad
+# if $src (and thus $dsttmp) contains '*'.
+	if [ -f $src -o -d $src ]
+	then
+		true
+	else
+		echo "install:  $src does not exist"
+		exit 1
+	fi
+	if [ x"$dst" = x ]
+	then
+		echo "install:	no destination specified"
+		exit 1
+	else
+		true
+	fi
+# If destination is a directory, append the input filename; if your system
+# does not like double slashes in filenames, you may need to add some logic
+	if [ -d $dst ]
+	then
+		dst="$dst"/`basename $src`
+	else
+		true
+	fi
+fi
+## this sed command emulates the dirname command
+dstdir=`echo $dst | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
+# Make sure that the destination directory exists.
+#  this part is taken from Noah Friedman's mkinstalldirs script
+# Skip lots of stat calls in the usual case.
+if [ ! -d "$dstdir" ]; then
+defaultIFS='
+IFS="${IFS-${defaultIFS}}"
+oIFS="${IFS}"
+# Some sh's can't handle IFS=/ for some reason.
+IFS='%'
+set - `echo ${dstdir} | sed -e 's@/@%@g' -e 's@^%@/@'`
+IFS="${oIFS}"
+pathcomp=''
+while [ $# -ne 0 ] ; do
+	pathcomp="${pathcomp}${1}"
+	shift
+	if [ ! -d "${pathcomp}" ] ;
+        then
+		$mkdirprog "${pathcomp}"
+	else
+		true
+	fi
+	pathcomp="${pathcomp}/"
+done
+fi
+then
+	$doit $instcmd $dst &&
+	if [ x"$chowncmd" != x ]; then $doit $chowncmd $dst; else true ; fi &&
+	if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dst; else true ; fi &&
+	if [ x"$stripcmd" != x ]; then $doit $stripcmd $dst; else true ; fi &&
+	if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dst; else true ; fi
+else
+# If we're going to rename the final executable, determine the name now.
+	if [ x"$transformarg" = x ]
+	then
+		dstfile=`basename $dst`
+	else
+		dstfile=`basename $dst $transformbasename |
+			sed $transformarg`$transformbasename
+	fi
+# don't allow the sed command to completely eliminate the filename
+	if [ x"$dstfile" = x ]
+	then
+	else
+		true
+	fi
+# Make a temp file name in the proper directory.
+	dsttmp=$dstdir/#inst.$$#
+# Move or copy the file name to the temp name
+	$doit $instcmd $src $dsttmp &&
+	trap "rm -f ${dsttmp}" 0 &&
+# and set any options; do chmod last to preserve setuid bits
+# If any of these fail, we abort the whole thing.  If we want to
+# ignore errors from any of these, just make sure not to ignore
+# errors from the above "$doit $instcmd $src $dsttmp" command.
+	if [ x"$chowncmd" != x ]; then $doit $chowncmd $dsttmp; else true;fi &&
+	if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dsttmp; else true;fi &&
+	if [ x"$stripcmd" != x ]; then $doit $stripcmd $dsttmp; else true;fi &&
+	if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dsttmp; else true;fi &&
+# Now rename the file to the real destination.
+	$doit $rmcmd -f $dstdir/$dstfile &&
+	$doit $mvcmd $dsttmp $dstdir/$dstfile
+fi &&
+exit 0
Property changes on: trunk/MgDev/Oem/gdal-1.4.0/install-sh
More information about the mapguide-commits mailing list
