[mapguide-commits] r1329 - trunk/MgDev/Oem/proj-4.5.0
svn_mapguide at osgeo.org
Wed Mar 21 17:34:22 EDT 2007
Author: stevedang
Date: 2007-03-21 17:34:22 -0400 (Wed, 21 Mar 2007)
New Revision: 1329
Removed:
trunk/MgDev/Oem/proj-4.5.0/configure
trunk/MgDev/Oem/proj-4.5.0/install-sh
trunk/MgDev/Oem/proj-4.5.0/Makefile.in
Disable check target.
Modified: trunk/MgDev/Oem/proj-4.5.0/Makefile.in
--- trunk/MgDev/Oem/proj-4.5.0/Makefile.in 2007-03-21 21:28:21 UTC (rev 1328)
+++ trunk/MgDev/Oem/proj-4.5.0/Makefile.in 2007-03-21 21:34:22 UTC (rev 1329)
@@ -495,7 +495,7 @@
$(distcleancheck_listfiles) ; \
exit 1; } >&2
check-am: all-am
-check: check-recursive
+check:
all-am: Makefile
installdirs: installdirs-recursive
installdirs-am:
Deleted: trunk/MgDev/Oem/proj-4.5.0/configure
--- trunk/MgDev/Oem/proj-4.5.0/configure 2007-03-21 21:28:21 UTC (rev 1328)
+++ trunk/MgDev/Oem/proj-4.5.0/configure 2007-03-21 21:34:22 UTC (rev 1329)
@@ -1,20574 +0,0 @@
-#! /bin/sh
-# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.59 for PROJ.4 Projections 4.5.0.
-# Report bugs to <warmerdam at pobox.com>.
-# Copyright (C) 2003 Free Software Foundation, Inc.
-# This configure script is free software; the Free Software Foundation
-# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
-# Be Bourne compatible
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
-elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
- set -o posix
-fi
-DUALCASE=1; export DUALCASE # for MKS sh
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
-fi
-# Work around bugs in pre-3.0 UWIN ksh.
-$as_unset ENV MAIL MAILPATH
-PS1='$ '
-PS2='> '
-PS4='+ '
-# NLS nuisances.
-for as_var in \
- LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
- LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
- LC_TELEPHONE LC_TIME
-do
- if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
- eval $as_var=C; export $as_var
- else
- $as_unset $as_var
- fi
-done
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)$' \| \
- . : '\(.\)' 2>/dev/null ||
-echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
- /^X\/\(\/\/\)$/{ s//\1/; q; }
- /^X\/\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
-# PATH needs CR, and LINENO needs CR and PATH.
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- echo "#! /bin/sh" >conf$$.sh
- echo "exit 0" >>conf$$.sh
- chmod +x conf$$.sh
- if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
- PATH_SEPARATOR=';'
- else
- PATH_SEPARATOR=:
- fi
- rm -f conf$$.sh
-fi
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x$as_lineno_3" = "x$as_lineno_2" || {
- # Find who we are. Look in the path if we contain no path at all
- # relative or not.
- case $0 in
- *[\\/]* ) as_myself=$0 ;;
- *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
- esac
- # We did not find ourselves, most probably we were run as `sh COMMAND'
- # in which case we are not to be found in the path.
- if test "x$as_myself" = x; then
- as_myself=$0
- fi
- if test ! -f "$as_myself"; then
- { echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2
- { (exit 1); exit 1; }; }
- fi
- case $CONFIG_SHELL in
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
-do
- IFS=$as_save_IFS
- for as_base in sh bash ksh sh5; do
- case $as_dir in
- if ("$as_dir/$as_base" -c '
- test "x$as_lineno_3" = "x$as_lineno_2" ') 2>/dev/null; then
- $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
- $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
- CONFIG_SHELL=$as_dir/$as_base
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$0" ${1+"$@"}
- fi;;
- esac
- done
-done
- esac
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line before each line; the second 'sed' does the real
- # work. The second script uses 'N' to pair each line-number line
- # with the numbered line, and appends trailing '-' during
- # substitution so that $LINENO is not a special case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # second 'sed' script. Blame Lee E. McMahon for sed's syntax. :-)
- sed '=' <$as_myself |
- sed '
- N
- s,$,-,
- : loop
- s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
- t loop
- s,-$,,
- s,^['$as_cr_digits']*\n,,
- ' >$as_me.lineno &&
- chmod +x $as_me.lineno ||
- { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensible to this).
- . ./$as_me.lineno
- # Exit status is that of the last command.
- exit
-case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
- *c*,-n*) ECHO_N= ECHO_C='
-' ECHO_T=' ' ;;
- *c*,* ) ECHO_N=-n ECHO_C= ECHO_T= ;;
- *) ECHO_N= ECHO_C='\c' ECHO_T= ;;
-esac
- as_expr=expr
-else
- as_expr=false
-fi
-rm -f conf$$ conf$$.exe conf$$.file
-echo >conf$$.file
-if ln -s conf$$.file conf$$ 2>/dev/null; then
- # We could just check for DJGPP; but this test a) works b) is more generic
- # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
- if test -f conf$$.exe; then
- # Don't use ln at all; we don't have any links
- as_ln_s='cp -p'
- else
- as_ln_s='ln -s'
- fi
-elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
-else
- as_ln_s='cp -p'
-fi
-if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
-else
- test -d ./-p && rmdir ./-p
- as_mkdir_p=false
-fi
-as_executable_p="test -f"
-# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-# Sed expression to map a string onto a valid variable name.
-as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-# IFS
-# We need space, tab and new line, in precisely that order.
-as_nl='
-IFS=" $as_nl"
-# CDPATH.
-$as_unset CDPATH
-# Check that we are running under the correct shell.
-SHELL=${CONFIG_SHELL-/bin/sh}
-case X$ECHO in
-X*--fallback-echo)
- # Remove one level of quotation (which was required for Make).
- ECHO=`echo "$ECHO" | sed 's,\\\\\$\\$0,'$0','`
-esac
-echo=${ECHO-echo}
-if test "X$1" = X--no-reexec; then
- # Discard the --no-reexec flag, and continue.
- shift
-elif test "X$1" = X--fallback-echo; then
- # Avoid inline document here, it may be left over
-elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
- # Yippee, $echo works!
-else
- # Restart under the correct shell.
- exec $SHELL "$0" --no-reexec ${1+"$@"}
-fi
-if test "X$1" = X--fallback-echo; then
- # used as fallback echo
- shift
- cat <<EOF
-EOF
- exit 0
-fi
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-if test -z "$ECHO"; then
-if test "X${echo_test_string+set}" != Xset; then
-# find a string as large as possible, as long as the shell can cope with it
- for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
- # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
- if (echo_test_string=`eval $cmd`) 2>/dev/null &&
- echo_test_string=`eval $cmd` &&
- (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
- then
- break
- fi
- done
-fi
-if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
- test "X$echo_testing_string" = "X$echo_test_string"; then
-else
- # The Solaris, AIX, and Digital Unix default echo programs unquote
- # backslashes. This makes it impossible to quote backslashes using
- # echo "$something" | sed 's/\\/\\\\/g'
- # So, first we look for a working echo in the user's PATH.
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for dir in $PATH /usr/ucb; do
- IFS="$lt_save_ifs"
- if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
- test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
- echo="$dir/echo"
- break
- fi
- done
- if test "X$echo" = Xecho; then
- # We didn't find a better echo, so look for alternatives.
- if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
- echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
- # This shell has a builtin print -r that does the trick.
- echo='print -r'
- elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
- test "X$CONFIG_SHELL" != X/bin/ksh; then
- # If we have ksh, try running configure again with it.
- ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
- export ORIGINAL_CONFIG_SHELL
- CONFIG_SHELL=/bin/ksh
- exec $CONFIG_SHELL "$0" --no-reexec ${1+"$@"}
- else
- # Try using printf.
- echo='printf %s\n'
- if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
- # Cool, printf works
- elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
- test "X$echo_testing_string" = 'X\t' &&
- echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
- SHELL="$CONFIG_SHELL"
- export SHELL
- echo="$CONFIG_SHELL $0 --fallback-echo"
- elif echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
- echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
- else
- # maybe with a smaller string...
- prev=:
- for cmd in 'echo test' 'sed 2q "$0"' 'sed 10q "$0"' 'sed 20q "$0"' 'sed 50q "$0"'; do
- if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
- then
- break
- fi
- prev="$cmd"
- done
- if test "$prev" != 'sed 50q "$0"'; then
- echo_test_string=`eval $prev`
- export echo_test_string
- exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "$0" ${1+"$@"}
- else
- # Oops. We lost completely, so just stick with echo.
- echo=echo
- fi
- fi
- fi
- fi
-fi
-fi
-# Copy echo and quote the copy suitably for passing to libtool from
-# the Makefile, instead of quoting the original, which is used later.
-ECHO=$echo
-if test "X$ECHO" = "X$CONFIG_SHELL $0 --fallback-echo"; then
- ECHO="$CONFIG_SHELL \\\$\$0 --fallback-echo"
-fi
-tagnames=${tagnames+${tagnames},}CXX
-tagnames=${tagnames+${tagnames},}F77
-# Name of the host.
-# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
-# so uname gets run too.
-ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
-exec 6>&1
-# Initializations.
-ac_default_prefix=/usr/local
-ac_config_libobj_dir=.
-cross_compiling=no
-subdirs=
-MFLAGS=
-MAKEFLAGS=
-# Maximum number of lines to put in a shell here document.
-# This variable seems obsolete. It should probably be removed, and
-# only ac_max_sed_lines should be used.
-: ${ac_max_here_lines=38}
-# Identity of this package.
-PACKAGE_NAME='PROJ.4 Projections'
-PACKAGE_TARNAME='proj'
-PACKAGE_VERSION='4.5.0'
-PACKAGE_STRING='PROJ.4 Projections 4.5.0'
-PACKAGE_BUGREPORT='warmerdam at pobox.com'
-# Factoring default headers for most tests.
-ac_includes_default="\
-#include <stdio.h>
-#if HAVE_SYS_TYPES_H
-# include <sys/types.h>
-#endif
-#if HAVE_SYS_STAT_H
-# include <sys/stat.h>
-#endif
-#if STDC_HEADERS
-# include <stdlib.h>
-# include <stddef.h>
-#else
-# if HAVE_STDLIB_H
-# endif
-#endif
-#if HAVE_STRING_H
-# if !STDC_HEADERS && HAVE_MEMORY_H
-# include <memory.h>
-# endif
-# include <string.h>
-#endif
-#if HAVE_STRINGS_H
-# include <strings.h>
-#endif
-#if HAVE_INTTYPES_H
-# include <inttypes.h>
-#else
-# if HAVE_STDINT_H
-# include <stdint.h>
-# endif
-#endif
-#if HAVE_UNISTD_H
-# include <unistd.h>
-#endif"
-ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA CYGPATH_W PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM mkdir_p AWK SET_MAKE am__leading_dot AMTAR am__tar am__untar MAINTAINER_MODE_TRUE MAINTAINER_MODE_FALSE MAINT CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE am__fastdepCC_TRUE am__fastdepCC_FALSE LN_S build build_cpu build_vendor build_os host host_cpu host_vendor host_os EGREP ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB CPP CXX CXXFLAGS ac_ct_CXX CXXDEPMODE am__fastdepCXX_TRUE am__fastdepCXX_FALSE CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL JNI_INCLUDE LIBOBJS LTLIBOBJS'
-ac_subst_files=''
-# Initialize some variables set by options.
-ac_init_help=
-ac_init_version=false
-# The variables have the same names as the options, with
-# dashes changed to underlines.
-cache_file=/dev/null
-exec_prefix=NONE
-no_create=
-no_recursion=
-prefix=NONE
-program_prefix=NONE
-program_suffix=NONE
-program_transform_name=s,x,x,
-silent=
-site=
-srcdir=
-verbose=
-x_includes=NONE
-x_libraries=NONE
-# Installation directory options.
-# These are left unexpanded so users can "make install exec_prefix=/foo"
-# and all the variables that are supposed to be based on exec_prefix
-# by default will actually change.
-# Use braces instead of parens because sh, perl, etc. also accept them.
-bindir='${exec_prefix}/bin'
-sbindir='${exec_prefix}/sbin'
-libexecdir='${exec_prefix}/libexec'
-datadir='${prefix}/share'
-sysconfdir='${prefix}/etc'
-sharedstatedir='${prefix}/com'
-localstatedir='${prefix}/var'
-libdir='${exec_prefix}/lib'
-includedir='${prefix}/include'
-oldincludedir='/usr/include'
-infodir='${prefix}/info'
-mandir='${prefix}/man'
-ac_prev=
-for ac_option
-do
- # If the previous option needs an argument, assign it.
- if test -n "$ac_prev"; then
- eval "$ac_prev=\$ac_option"
- ac_prev=
- continue
- fi
- ac_optarg=`expr "x$ac_option" : 'x[^=]*=\(.*\)'`
- # Accept the important Cygnus configure options, so we can diagnose typos.
- case $ac_option in
- -bindir | --bindir | --bindi | --bind | --bin | --bi)
- ac_prev=bindir ;;
- -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
- bindir=$ac_optarg ;;
- -build | --build | --buil | --bui | --bu)
- ac_prev=build_alias ;;
- -build=* | --build=* | --buil=* | --bui=* | --bu=*)
- build_alias=$ac_optarg ;;
- -cache-file | --cache-file | --cache-fil | --cache-fi \
- | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
- ac_prev=cache_file ;;
- -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
- | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
- cache_file=$ac_optarg ;;
- --config-cache | -C)
- cache_file=config.cache ;;
- -datadir | --datadir | --datadi | --datad | --data | --dat | --da)
- ac_prev=datadir ;;
- -datadir=* | --datadir=* | --datadi=* | --datad=* | --data=* | --dat=* \
- | --da=*)
- datadir=$ac_optarg ;;
- -disable-* | --disable-*)
- ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
- # Reject names that are not valid shell variable names.
- expr "x$ac_feature" : ".*[^-_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid feature name: $ac_feature" >&2
- ac_feature=`echo $ac_feature | sed 's/-/_/g'`
- eval "enable_$ac_feature=no" ;;
- -enable-* | --enable-*)
- ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
- *=*) ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`;;
- *) ac_optarg=yes ;;
- esac
- eval "enable_$ac_feature='$ac_optarg'" ;;
- -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
- | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
- | --exec | --exe | --ex)
- ac_prev=exec_prefix ;;
- -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
- | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
- | --exec=* | --exe=* | --ex=*)
- exec_prefix=$ac_optarg ;;
- -gas | --gas | --ga | --g)
- # Obsolete; use --with-gas.
- with_gas=yes ;;
- -help | --help | --hel | --he | -h)
- ac_init_help=long ;;
- -help=r* | --help=r* | --hel=r* | --he=r* | -hr*)
- ac_init_help=recursive ;;
- -help=s* | --help=s* | --hel=s* | --he=s* | -hs*)
- ac_init_help=short ;;
- -host | --host | --hos | --ho)
- ac_prev=host_alias ;;
- -host=* | --host=* | --hos=* | --ho=*)
- host_alias=$ac_optarg ;;
- -includedir | --includedir | --includedi | --included | --include \
- | --includ | --inclu | --incl | --inc)
- ac_prev=includedir ;;
- -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
- | --includ=* | --inclu=* | --incl=* | --inc=*)
- includedir=$ac_optarg ;;
- -infodir | --infodir | --infodi | --infod | --info | --inf)
- ac_prev=infodir ;;
- -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
- infodir=$ac_optarg ;;
- -libdir | --libdir | --libdi | --libd)
- ac_prev=libdir ;;
- -libdir=* | --libdir=* | --libdi=* | --libd=*)
- libdir=$ac_optarg ;;
- -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
- | --libexe | --libex | --libe)
- ac_prev=libexecdir ;;
- -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
- | --libexe=* | --libex=* | --libe=*)
- libexecdir=$ac_optarg ;;
- -localstatedir | --localstatedir | --localstatedi | --localstated \
- | --localstate | --localstat | --localsta | --localst \
- | --locals | --local | --loca | --loc | --lo)
- ac_prev=localstatedir ;;
- -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
- | --localstate=* | --localstat=* | --localsta=* | --localst=* \
- | --locals=* | --local=* | --loca=* | --loc=* | --lo=*)
- localstatedir=$ac_optarg ;;
- -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
- ac_prev=mandir ;;
- -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
- mandir=$ac_optarg ;;
- -nfp | --nfp | --nf)
- # Obsolete; use --without-fp.
- with_fp=no ;;
- -no-create | --no-create | --no-creat | --no-crea | --no-cre \
- | --no-cr | --no-c | -n)
- no_create=yes ;;
- -no-recursion | --no-recursion | --no-recursio | --no-recursi \
- | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
- no_recursion=yes ;;
- -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
- | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
- | --oldin | --oldi | --old | --ol | --o)
- ac_prev=oldincludedir ;;
- -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
- | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
- | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
- oldincludedir=$ac_optarg ;;
- -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
- ac_prev=prefix ;;
- -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
- prefix=$ac_optarg ;;
- -program-prefix | --program-prefix | --program-prefi | --program-pref \
- | --program-pre | --program-pr | --program-p)
- ac_prev=program_prefix ;;
- -program-prefix=* | --program-prefix=* | --program-prefi=* \
- | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
- program_prefix=$ac_optarg ;;
- -program-suffix | --program-suffix | --program-suffi | --program-suff \
- | --program-suf | --program-su | --program-s)
- ac_prev=program_suffix ;;
- -program-suffix=* | --program-suffix=* | --program-suffi=* \
- | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
- program_suffix=$ac_optarg ;;
- -program-transform-name | --program-transform-name \
- | --program-transform-nam | --program-transform-na \
- | --program-transform-n | --program-transform- \
- | --program-transform | --program-transfor \
- | --program-transfo | --program-transf \
- | --program-trans | --program-tran \
- | --progr-tra | --program-tr | --program-t)
- ac_prev=program_transform_name ;;
- -program-transform-name=* | --program-transform-name=* \
- | --program-transform-nam=* | --program-transform-na=* \
- | --program-transform-n=* | --program-transform-=* \
- | --program-transform=* | --program-transfor=* \
- | --program-transfo=* | --program-transf=* \
- | --program-trans=* | --program-tran=* \
- | --progr-tra=* | --program-tr=* | --program-t=*)
- program_transform_name=$ac_optarg ;;
- -q | -quiet | --quiet | --quie | --qui | --qu | --q \
- | -silent | --silent | --silen | --sile | --sil)
- silent=yes ;;
- -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
- ac_prev=sbindir ;;
- -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
- | --sbi=* | --sb=*)
- sbindir=$ac_optarg ;;
- -sharedstatedir | --sharedstatedir | --sharedstatedi \
- | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
- | --sharedst | --shareds | --shared | --share | --shar \
- | --sha | --sh)
- ac_prev=sharedstatedir ;;
- -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
- | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
- | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
- | --sha=* | --sh=*)
- sharedstatedir=$ac_optarg ;;
- -site | --site | --sit)
- ac_prev=site ;;
- -site=* | --site=* | --sit=*)
- site=$ac_optarg ;;
- -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
- ac_prev=srcdir ;;
- -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
- srcdir=$ac_optarg ;;
- -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
- | --syscon | --sysco | --sysc | --sys | --sy)
- ac_prev=sysconfdir ;;
- -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
- | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
- sysconfdir=$ac_optarg ;;
- -target | --target | --targe | --targ | --tar | --ta | --t)
- ac_prev=target_alias ;;
- -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
- target_alias=$ac_optarg ;;
- -v | -verbose | --verbose | --verbos | --verbo | --verb)
- verbose=yes ;;
- -version | --version | --versio | --versi | --vers | -V)
- ac_init_version=: ;;
- -with-* | --with-*)
- ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- expr "x$ac_package" : ".*[^-_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid package name: $ac_package" >&2
- ac_package=`echo $ac_package| sed 's/-/_/g'`
- esac
- eval "with_$ac_package='$ac_optarg'" ;;
- -without-* | --without-*)
- ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'`
- ac_package=`echo $ac_package | sed 's/-/_/g'`
- eval "with_$ac_package=no" ;;
- --x)
- # Obsolete; use --with-x.
- with_x=yes ;;
- -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
- | --x-incl | --x-inc | --x-in | --x-i)
- ac_prev=x_includes ;;
- -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
- | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
- x_includes=$ac_optarg ;;
- -x-libraries | --x-libraries | --x-librarie | --x-librari \
- | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
- ac_prev=x_libraries ;;
- -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
- | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
- x_libraries=$ac_optarg ;;
- -*) { echo "$as_me: error: unrecognized option: $ac_option
-Try \`$0 --help' for more information." >&2
- ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
- { echo "$as_me: error: invalid variable name: $ac_envvar" >&2
- ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`
- eval "$ac_envvar='$ac_optarg'"
- export $ac_envvar ;;
- # FIXME: should be removed in autoconf 3.0.
- echo "$as_me: WARNING: you should use --build, --host, --target" >&2
- expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
- echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
- esac
-done
-if test -n "$ac_prev"; then
- ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- { echo "$as_me: error: missing argument to $ac_option" >&2
-fi
-# Be sure to have absolute paths.
-for ac_var in exec_prefix prefix
-do
- eval ac_val=$`echo $ac_var`
- case $ac_val in
- [\\/$]* | ?:[\\/]* | NONE | '' ) ;;
- *) { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
- { (exit 1); exit 1; }; };;
- esac
-done
-for ac_var in bindir sbindir libexecdir datadir sysconfdir sharedstatedir \
- localstatedir libdir includedir oldincludedir infodir mandir
-do
- case $ac_val in
- esac
-done
-# There might be people who depend on the old broken behavior: `$host'
-# used to hold the argument of --host etc.
-# FIXME: To remove some day.
-build=$build_alias
-host=$host_alias
-target=$target_alias
-if test "x$host_alias" != x; then
- if test "x$build_alias" = x; then
- cross_compiling=maybe
- echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
- If a cross compiler is detected then cross compile mode will be used." >&2
- elif test "x$build_alias" != "x$host_alias"; then
- cross_compiling=yes
- fi
-fi
-ac_tool_prefix=
-test -n "$host_alias" && ac_tool_prefix=$host_alias-
-test "$silent" = yes && exec 6>/dev/null
-# Find the source files, if location was not specified.
-if test -z "$srcdir"; then
- ac_srcdir_defaulted=yes
- # Try the directory containing this script, then its parent.
- ac_confdir=`(dirname "$0") 2>/dev/null ||
-$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$0" : 'X\(//\)[^/]' \| \
- X"$0" : 'X\(/\)' \| \
-echo X"$0" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
- /^X\(\/\/\)[^/].*/{ s//\1/; q; }
- /^X\(\/\/\)$/{ s//\1/; q; }
- /^X\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
- srcdir=$ac_confdir
- if test ! -r $srcdir/$ac_unique_file; then
- srcdir=..
- fi
-else
- ac_srcdir_defaulted=no
-fi
-if test ! -r $srcdir/$ac_unique_file; then
- if test "$ac_srcdir_defaulted" = yes; then
- { echo "$as_me: error: cannot find sources ($ac_unique_file) in $ac_confdir or .." >&2
- else
- { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
- fi
-fi
-(cd $srcdir && test -r ./$ac_unique_file) 2>/dev/null ||
- { echo "$as_me: error: sources are in $srcdir, but \`cd $srcdir' does not work" >&2
-srcdir=`echo "$srcdir" | sed 's%\([^\\/]\)[\\/]*$%\1%'`
-ac_env_build_alias_set=${build_alias+set}
-ac_env_build_alias_value=$build_alias
-ac_cv_env_build_alias_set=${build_alias+set}
-ac_cv_env_build_alias_value=$build_alias
-ac_env_host_alias_set=${host_alias+set}
-ac_env_host_alias_value=$host_alias
-ac_cv_env_host_alias_set=${host_alias+set}
-ac_cv_env_host_alias_value=$host_alias
-ac_env_target_alias_set=${target_alias+set}
-ac_env_target_alias_value=$target_alias
-ac_cv_env_target_alias_set=${target_alias+set}
-ac_cv_env_target_alias_value=$target_alias
-ac_env_CC_set=${CC+set}
-ac_env_CC_value=$CC
-ac_cv_env_CC_set=${CC+set}
-ac_cv_env_CC_value=$CC
-ac_env_CFLAGS_set=${CFLAGS+set}
-ac_env_CFLAGS_value=$CFLAGS
-ac_cv_env_CFLAGS_set=${CFLAGS+set}
-ac_cv_env_CFLAGS_value=$CFLAGS
-ac_env_LDFLAGS_set=${LDFLAGS+set}
-ac_env_LDFLAGS_value=$LDFLAGS
-ac_cv_env_LDFLAGS_set=${LDFLAGS+set}
-ac_cv_env_LDFLAGS_value=$LDFLAGS
-ac_env_CPPFLAGS_set=${CPPFLAGS+set}
-ac_env_CPPFLAGS_value=$CPPFLAGS
-ac_cv_env_CPPFLAGS_set=${CPPFLAGS+set}
-ac_cv_env_CPPFLAGS_value=$CPPFLAGS
-ac_env_CPP_set=${CPP+set}
-ac_env_CPP_value=$CPP
-ac_cv_env_CPP_set=${CPP+set}
-ac_cv_env_CPP_value=$CPP
-ac_env_CXX_set=${CXX+set}
-ac_env_CXX_value=$CXX
-ac_cv_env_CXX_set=${CXX+set}
-ac_cv_env_CXX_value=$CXX
-ac_env_CXXFLAGS_set=${CXXFLAGS+set}
-ac_env_CXXFLAGS_value=$CXXFLAGS
-ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
-ac_cv_env_CXXFLAGS_value=$CXXFLAGS
-ac_env_CXXCPP_set=${CXXCPP+set}
-ac_env_CXXCPP_value=$CXXCPP
-ac_cv_env_CXXCPP_set=${CXXCPP+set}
-ac_cv_env_CXXCPP_value=$CXXCPP
-ac_env_F77_set=${F77+set}
-ac_env_F77_value=$F77
-ac_cv_env_F77_set=${F77+set}
-ac_cv_env_F77_value=$F77
-ac_env_FFLAGS_set=${FFLAGS+set}
-ac_env_FFLAGS_value=$FFLAGS
-ac_cv_env_FFLAGS_set=${FFLAGS+set}
-ac_cv_env_FFLAGS_value=$FFLAGS
-# Report the --help message.
-if test "$ac_init_help" = "long"; then
- # Omit some internal or obsolete options to make the list less imposing.
- # This message is too long to be a string in the A/UX 3.1 sh.
- cat <<_ACEOF
-\`configure' configures PROJ.4 Projections 4.5.0 to adapt to many kinds of systems.
-Usage: $0 [OPTION]... [VAR=VALUE]...
-To assign environment variables (e.g., CC, CFLAGS...), specify them as
-VAR=VALUE. See below for descriptions of some of the useful variables.
-Defaults for the options are specified in brackets.
-Configuration:
- -h, --help display this help and exit
- --help=short display options specific to this package
- --help=recursive display the short help of all the included packages
- -V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking...' messages
- --cache-file=FILE cache test results in FILE [disabled]
- -C, --config-cache alias for \`--cache-file=config.cache'
- -n, --no-create do not create output files
- --srcdir=DIR find the sources in DIR [configure dir or \`..']
-_ACEOF
- cat <<_ACEOF
-Installation directories:
- --prefix=PREFIX install architecture-independent files in PREFIX
- [$ac_default_prefix]
- --exec-prefix=EPREFIX install architecture-dependent files in EPREFIX
- [PREFIX]
-By default, \`make install' will install all the files in
-\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc. You can specify
-an installation prefix other than \`$ac_default_prefix' using \`--prefix',
-for instance \`--prefix=\$HOME'.
-For better control, use the options below.
-Fine tuning of the installation directories:
- --bindir=DIR user executables [EPREFIX/bin]
- --sbindir=DIR system admin executables [EPREFIX/sbin]
- --libexecdir=DIR program executables [EPREFIX/libexec]
- --datadir=DIR read-only architecture-independent data [PREFIX/share]
- --sysconfdir=DIR read-only single-machine data [PREFIX/etc]
- --sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
- --localstatedir=DIR modifiable single-machine data [PREFIX/var]
- --libdir=DIR object code libraries [EPREFIX/lib]
- --includedir=DIR C header files [PREFIX/include]
- --oldincludedir=DIR C header files for non-gcc [/usr/include]
- --infodir=DIR info documentation [PREFIX/info]
- --mandir=DIR man documentation [PREFIX/man]
-_ACEOF
- cat <<\_ACEOF
-Program names:
- --program-prefix=PREFIX prepend PREFIX to installed program names
- --program-suffix=SUFFIX append SUFFIX to installed program names
- --program-transform-name=PROGRAM run sed PROGRAM on installed program names
-System types:
- --build=BUILD configure for building on BUILD [guessed]
- --host=HOST cross-compile to build programs to run on HOST [BUILD]
-_ACEOF
-fi
-if test -n "$ac_init_help"; then
- case $ac_init_help in
- short | recursive ) echo "Configuration of PROJ.4 Projections 4.5.0:";;
- esac
- cat <<\_ACEOF
-Optional Features:
- --disable-FEATURE do not include FEATURE (same as --enable-FEATURE=no)
- --enable-FEATURE[=ARG] include FEATURE [ARG=yes]
- --enable-maintainer-mode enable make rules and dependencies not useful
- (and sometimes confusing) to the casual installer
- --disable-dependency-tracking speeds up one-time build
- --enable-dependency-tracking do not reject slow dependency extractors
- --enable-shared[=PKGS]
- build shared libraries [default=yes]
- --enable-static[=PKGS]
- build static libraries [default=yes]
- --enable-fast-install[=PKGS]
- optimize for fast installation [default=yes]
- --disable-libtool-lock avoid locking (might break parallel builds)
-Optional Packages:
- --with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
- --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-gnu-ld assume the C compiler uses GNU ld [default=no]
- --with-pic try to use only PIC/non-PIC objects [default=use
- both]
- --with-tags[=TAGS]
- include additional configurations [automatic]
- --with-jni=dir Include Java/JNI support, add optional include dir
-Some influential environment variables:
- CC C compiler command
- CFLAGS C compiler flags
- LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
- nonstandard directory <lib dir>
- CPPFLAGS C/C++ preprocessor flags, e.g. -I<include dir> if you have
- headers in a nonstandard directory <include dir>
- CPP C preprocessor
- CXX C++ compiler command
- CXXFLAGS C++ compiler flags
- CXXCPP C++ preprocessor
- F77 Fortran 77 compiler command
- FFLAGS Fortran 77 compiler flags
-Use these variables to override the choices made by `configure' or to help
-it to find libraries and programs with nonstandard names/locations.
-Report bugs to <warmerdam at pobox.com>.
-_ACEOF
-fi
-if test "$ac_init_help" = "recursive"; then
- # If there are subdirs, report their specific --help.
- ac_popdir=`pwd`
- for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
- test -d $ac_dir || continue
- ac_builddir=.
-if test "$ac_dir" != .; then
- ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
- # A "../" for each directory in $ac_dir_suffix.
- ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
-else
- ac_dir_suffix= ac_top_builddir=
-fi
-case $srcdir in
- .) # No --srcdir option. We are building in place.
- ac_srcdir=.
- if test -z "$ac_top_builddir"; then
- ac_top_srcdir=.
- else
- ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
- fi ;;
- [\\/]* | ?:[\\/]* ) # Absolute path.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir ;;
- *) # Relative path.
- ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_builddir$srcdir ;;
-esac
-# Do not use `cd foo && pwd` to compute absolute paths, because
-# the directories may not exist.
-case `pwd` in
-.) ac_abs_builddir="$ac_dir";;
- case "$ac_dir" in
- .) ac_abs_builddir=`pwd`;;
- [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
- *) ac_abs_builddir=`pwd`/"$ac_dir";;
- esac;;
-esac
-case $ac_abs_builddir in
-.) ac_abs_top_builddir=${ac_top_builddir}.;;
- case ${ac_top_builddir}. in
- .) ac_abs_top_builddir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
- *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
- esac;;
-esac
-.) ac_abs_srcdir=$ac_srcdir;;
- case $ac_srcdir in
- .) ac_abs_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
- *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
- esac;;
-esac
-.) ac_abs_top_srcdir=$ac_top_srcdir;;
- case $ac_top_srcdir in
- .) ac_abs_top_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
- *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
- esac;;
-esac
- cd $ac_dir
- # Check for guested configure; otherwise get Cygnus style configure.
- if test -f $ac_srcdir/configure.gnu; then
- echo
- $SHELL $ac_srcdir/configure.gnu --help=recursive
- elif test -f $ac_srcdir/configure; then
- echo
- $SHELL $ac_srcdir/configure --help=recursive
- elif test -f $ac_srcdir/configure.ac ||
- test -f $ac_srcdir/configure.in; then
- echo
- $ac_configure --help
- else
- echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
- fi
- cd $ac_popdir
- done
-fi
-test -n "$ac_init_help" && exit 0
-if $ac_init_version; then
- cat <<\_ACEOF
-PROJ.4 Projections configure 4.5.0
-generated by GNU Autoconf 2.59
-Copyright (C) 2003 Free Software Foundation, Inc.
-This configure script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it.
-_ACEOF
- exit 0
-fi
-exec 5>config.log
-cat >&5 <<_ACEOF
-This file contains any messages produced by compilers while
-running configure, to aid debugging if configure makes a mistake.
-It was created by PROJ.4 Projections $as_me 4.5.0, which was
-generated by GNU Autoconf 2.59. Invocation command line was
- $ $0 $@
-_ACEOF
-cat <<_ASUNAME
-## Platform. ##
-hostname = `(hostname || uname -n) 2>/dev/null | sed 1q`
-uname -m = `(uname -m) 2>/dev/null || echo unknown`
-uname -r = `(uname -r) 2>/dev/null || echo unknown`
-uname -s = `(uname -s) 2>/dev/null || echo unknown`
-uname -v = `(uname -v) 2>/dev/null || echo unknown`
-/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown`
-/bin/uname -X = `(/bin/uname -X) 2>/dev/null || echo unknown`
-/bin/arch = `(/bin/arch) 2>/dev/null || echo unknown`
-/usr/bin/arch -k = `(/usr/bin/arch -k) 2>/dev/null || echo unknown`
-/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown`
-hostinfo = `(hostinfo) 2>/dev/null || echo unknown`
-/bin/machine = `(/bin/machine) 2>/dev/null || echo unknown`
-/usr/bin/oslevel = `(/usr/bin/oslevel) 2>/dev/null || echo unknown`
-/bin/universe = `(/bin/universe) 2>/dev/null || echo unknown`
-_ASUNAME
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- echo "PATH: $as_dir"
-done
-} >&5
-cat >&5 <<_ACEOF
-## Core tests. ##
-_ACEOF
-# Keep a trace of the command line.
-# Strip out --no-create and --no-recursion so they do not pile up.
-# Strip out --silent because we don't want to record it for future runs.
-# Also quote any args containing shell meta-characters.
-# Make two passes to allow for proper duplicate-argument suppression.
-ac_configure_args=
-ac_configure_args0=
-ac_configure_args1=
-ac_sep=
-ac_must_keep_next=false
-for ac_pass in 1 2
-do
- for ac_arg
- do
- case $ac_arg in
- -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;;
- continue ;;
- ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
- esac
- case $ac_pass in
- 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
- 2)
- ac_configure_args1="$ac_configure_args1 '$ac_arg'"
- if test $ac_must_keep_next = true; then
- ac_must_keep_next=false # Got value, back to normal.
- else
- case $ac_arg in
- *=* | --config-cache | -C | -disable-* | --disable-* \
- | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
- | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
- | -with-* | --with-* | -without-* | --without-* | --x)
- case "$ac_configure_args0 " in
- "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
- esac
- -* ) ac_must_keep_next=true ;;
- esac
- fi
- ac_configure_args="$ac_configure_args$ac_sep'$ac_arg'"
- # Get rid of the leading space.
- ac_sep=" "
- esac
- done
-done
-$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
-$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
-# When interrupted or exit'd, cleanup temporary files, and complete
-# config.log. We remove comments because anyway the quotes in there
-# would cause problems or look ugly.
-# WARNING: Be sure not to use single quotes in there, as some shells,
-# such as our DU 5.0 friend, will then `close' the trap.
-trap 'exit_status=$?
- # Save into config.log some information that might help in debugging.
- echo
- cat <<\_ASBOX
-## Cache variables. ##
-_ASBOX
- echo
- # The following way of writing the cache mishandles newlines in values,
- (set) 2>&1 |
- case `(ac_space='"'"' '"'"'; set | grep ac_space) 2>&1` in
- *ac_space=\ *)
- sed -n \
- "s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
- sed -n \
- "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
- esac;
- echo
- cat <<\_ASBOX
-## Output variables. ##
-_ASBOX
- echo
- for ac_var in $ac_subst_vars
- do
- echo "$ac_var='"'"'$ac_val'"'"'"
- done | sort
- echo
- if test -n "$ac_subst_files"; then
- cat <<\_ASBOX
-## Output files. ##
-_ASBOX
- echo
- for ac_var in $ac_subst_files
- do
- done | sort
- echo
- fi
- if test -s confdefs.h; then
- cat <<\_ASBOX
-## confdefs.h. ##
-_ASBOX
- echo
- sed "/^$/d" confdefs.h | sort
- echo
- fi
- test "$ac_signal" != 0 &&
- echo "$as_me: caught signal $ac_signal"
- echo "$as_me: exit $exit_status"
- } >&5
- rm -f core *.core &&
- rm -rf conftest* confdefs* conf$$* $ac_clean_files &&
- exit $exit_status
- ' 0
-for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
-done
-ac_signal=0
-# confdefs.h avoids OS command line length limits that DEFS can exceed.
-rm -rf conftest* confdefs.h
-# AIX cpp loses on an empty file, so make sure it contains at least a newline.
-echo >confdefs.h
-# Predefined preprocessor variables.
-cat >>confdefs.h <<_ACEOF
-#define PACKAGE_NAME "$PACKAGE_NAME"
-_ACEOF
-#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
-_ACEOF
-#define PACKAGE_VERSION "$PACKAGE_VERSION"
-_ACEOF
-#define PACKAGE_STRING "$PACKAGE_STRING"
-_ACEOF
-#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
-_ACEOF
-# Let the site file select an alternate cache file if it wants to.
-# Prefer explicitly selected file to automatically selected ones.
-if test -z "$CONFIG_SITE"; then
- if test "x$prefix" != xNONE; then
- CONFIG_SITE="$prefix/share/config.site $prefix/etc/config.site"
- else
- CONFIG_SITE="$ac_default_prefix/share/config.site $ac_default_prefix/etc/config.site"
- fi
-fi
-for ac_site_file in $CONFIG_SITE; do
- if test -r "$ac_site_file"; then
- { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
-echo "$as_me: loading site script $ac_site_file" >&6;}
- sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file"
- fi
-done
-if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special
- # files actually), so we avoid doing that.
- if test -f "$cache_file"; then
- { echo "$as_me:$LINENO: loading cache $cache_file" >&5
-echo "$as_me: loading cache $cache_file" >&6;}
- case $cache_file in
- [\\/]* | ?:[\\/]* ) . $cache_file;;
- *) . ./$cache_file;;
- esac
- fi
-else
- { echo "$as_me:$LINENO: creating cache $cache_file" >&5
-echo "$as_me: creating cache $cache_file" >&6;}
- >$cache_file
-fi
-# Check that the precious variables saved in the cache have kept the same
-# value.
-ac_cache_corrupted=false
-for ac_var in `(set) 2>&1 |
- sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
- eval ac_old_set=\$ac_cv_env_${ac_var}_set
- eval ac_new_set=\$ac_env_${ac_var}_set
- eval ac_old_val="\$ac_cv_env_${ac_var}_value"
- eval ac_new_val="\$ac_env_${ac_var}_value"
- case $ac_old_set,$ac_new_set in
- set,)
- { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
-echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
- ac_cache_corrupted=: ;;
- ,set)
- { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
-echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
- if test "x$ac_old_val" != "x$ac_new_val"; then
- { echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
-echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
- { echo "$as_me:$LINENO: former value: $ac_old_val" >&5
-echo "$as_me: former value: $ac_old_val" >&2;}
- { echo "$as_me:$LINENO: current value: $ac_new_val" >&5
-echo "$as_me: current value: $ac_new_val" >&2;}
- fi;;
- esac
- # Pass precious variables to config.status.
- if test "$ac_new_set" = set; then
- case $ac_new_val in
- ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
- *) ac_arg=$ac_var=$ac_new_val ;;
- esac
- case " $ac_configure_args " in
- *" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
- esac
- fi
-done
-if $ac_cache_corrupted; then
- { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
-echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
-echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-ac_ext=c
-am__api_version="1.9"
-ac_aux_dir=
-for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
- if test -f $ac_dir/install-sh; then
- ac_aux_dir=$ac_dir
- ac_install_sh="$ac_aux_dir/install-sh -c"
- break
- elif test -f $ac_dir/install.sh; then
- ac_install_sh="$ac_aux_dir/install.sh -c"
- break
- elif test -f $ac_dir/shtool; then
- ac_install_sh="$ac_aux_dir/shtool install -c"
- break
- fi
-done
-if test -z "$ac_aux_dir"; then
- { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&5
-echo "$as_me: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&2;}
-fi
-ac_config_guess="$SHELL $ac_aux_dir/config.guess"
-ac_config_sub="$SHELL $ac_aux_dir/config.sub"
-ac_configure="$SHELL $ac_aux_dir/configure" # This should be Cygnus configure.
-# Find a good install program. We prefer a C program (faster),
-# so one script is as good as another. But avoid the broken or
-# incompatible versions:
-# SysV /etc/install, /usr/sbin/install
-# SunOS /usr/etc/install
-# IRIX /sbin/install
-# AIX /bin/install
-# AmigaOS /C/install, which installs bootblocks on floppy discs
-# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
-# AFS /usr/afsws/bin/install, which mishandles nonexistent args
-# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
-# OS/2's system install, which has a completely different semantic
-# ./install, which can be erroneously created by make from ./install.sh.
-echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
-echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6
-if test -z "$INSTALL"; then
-if test "${ac_cv_path_install+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
-do
- IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in
- ./ | .// | /cC/* | \
- /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
- /usr/ucb/* ) ;;
- # OSF1 and SCO ODT 3.0 have their own names for install.
- # Don't use installbsd from OSF since it installs stuff as root
- # by default.
- for ac_prog in ginstall scoinst install; do
- for ac_exec_ext in '' $ac_executable_extensions; do
- if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
- if test $ac_prog = install &&
- grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # AIX install. It has an incompatible calling convention.
- elif test $ac_prog = install &&
- grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
- # program-specific install script used by HP pwplus--don't use.
- else
- ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
- break 3
- fi
- fi
- done
- done
-esac
-done
-fi
- if test "${ac_cv_path_install+set}" = set; then
- INSTALL=$ac_cv_path_install
- else
- # As a last resort, use the slow shell script. We don't cache a
- # path for INSTALL within a source directory, because that will
- # break other packages using the cache if that directory is
- # removed, or if the path is relative.
- INSTALL=$ac_install_sh
- fi
-fi
-echo "$as_me:$LINENO: result: $INSTALL" >&5
-echo "${ECHO_T}$INSTALL" >&6
-# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
-# It thinks the first close brace ends the variable substitution.
-test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
-test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
-test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-echo "$as_me:$LINENO: checking whether build environment is sane" >&5
-echo $ECHO_N "checking whether build environment is sane... $ECHO_C" >&6
-# Just in case
-sleep 1
-echo timestamp > conftest.file
-# Do `set' in a subshell so we don't clobber the current shell's
-# arguments. Must try -L first in case configure is actually a
-# symlink; some systems play weird games with the mod time of symlinks
-# (eg FreeBSD returns the mod time of the symlink's containing
-# directory).
-if (
- set X `ls -Lt $srcdir/configure conftest.file 2> /dev/null`
- if test "$*" = "X"; then
- # -L didn't work.
- set X `ls -t $srcdir/configure conftest.file`
- fi
- rm -f conftest.file
- if test "$*" != "X $srcdir/configure conftest.file" \
- && test "$*" != "X conftest.file $srcdir/configure"; then
- # If neither matched, then we have a broken ls. This can happen
- # if, for instance, CONFIG_SHELL is bash and it inherits a
- # broken ls alias from the environment. This has actually
- # happened. Such a system could not be considered "sane".
- { { echo "$as_me:$LINENO: error: ls -t appears to fail. Make sure there is not a broken
-alias in your environment" >&5
-echo "$as_me: error: ls -t appears to fail. Make sure there is not a broken
-alias in your environment" >&2;}
- fi
- test "$2" = conftest.file
-then
- # Ok.
-else
- { { echo "$as_me:$LINENO: error: newly created file is older than distributed files!
-Check your system clock" >&5
-echo "$as_me: error: newly created file is older than distributed files!
-Check your system clock" >&2;}
-fi
-echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-test "$program_prefix" != NONE &&
- program_transform_name="s,^,$program_prefix,;$program_transform_name"
-# Use a double $ so make ignores it.
-test "$program_suffix" != NONE &&
- program_transform_name="s,\$,$program_suffix,;$program_transform_name"
-# Double any \ or $. echo might interpret backslashes.
-# By default was `s,x,x', remove it if useless.
-cat <<\_ACEOF >conftest.sed
-s/[\\$]/&&/g;s/;s,x,x,$//
-_ACEOF
-program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
-rm conftest.sed
-# expand $ac_aux_dir to an absolute path
-am_aux_dir=`cd $ac_aux_dir && pwd`
-test x"${MISSING+set}" = xset || MISSING="\${SHELL} $am_aux_dir/missing"
-# Use eval to expand $SHELL
-if eval "$MISSING --run true"; then
- am_missing_run="$MISSING --run "
-else
- am_missing_run=
- { echo "$as_me:$LINENO: WARNING: \`missing' script is too old or missing" >&5
-echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
-fi
-if mkdir -p --version . >/dev/null 2>&1 && test ! -d ./--version; then
- # We used to keeping the `.' as first argument, in order to
- # allow $(mkdir_p) to be used without argument. As in
- # $(mkdir_p) $(somedir)
- # where $(somedir) is conditionally defined. However this is wrong
- # for two reasons:
- # 1. if the package is installed by a user who cannot write `.'
- # make install will fail,
- # 2. the above comment should most certainly read
- # $(mkdir_p) $(DESTDIR)$(somedir)
- # so it does not work when $(somedir) is undefined and
- # $(DESTDIR) is not.
- # To support the latter case, we have to write
- # test -z "$(somedir)" || $(mkdir_p) $(DESTDIR)$(somedir),
- # so the `.' trick is pointless.
- mkdir_p='mkdir -p --'
-else
- # On NextStep and OpenStep, the `mkdir' command does not
- # recognize any option. It will interpret all options as
- # directories to create, and then abort because `.' already
- # exists.
- for d in ./-p ./--version;
- do
- test -d $d && rmdir $d
- done
- # $(mkinstalldirs) is defined by Automake if mkinstalldirs exists.
- if test -f "$ac_aux_dir/mkinstalldirs"; then
- mkdir_p='$(mkinstalldirs)'
- else
- mkdir_p='$(install_sh) -d'
- fi
-fi
-for ac_prog in gawk mawk nawk awk
-do
- # Extract the first word of "$ac_prog", so it can be a program name with args.
-set dummy $ac_prog; ac_word=$2
-echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
-if test "${ac_cv_prog_AWK+set}" = set; then
-else
- if test -n "$AWK"; then
- ac_cv_prog_AWK="$AWK" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
- ac_cv_prog_AWK="$ac_prog"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
-done
-fi
-fi
-AWK=$ac_cv_prog_AWK
-if test -n "$AWK"; then
- echo "$as_me:$LINENO: result: $AWK" >&5
-echo "${ECHO_T}$AWK" >&6
-else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
- test -n "$AWK" && break
-done
-echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
-echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6
-set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,:./+-,___p_,'`
-if eval "test \"\${ac_cv_prog_make_${ac_make}_set+set}\" = set"; then
-else
- cat >conftest.make <<\_ACEOF
-all:
- @echo 'ac_maketemp="$(MAKE)"'
-_ACEOF
-# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
-eval `${MAKE-make} -f conftest.make 2>/dev/null | grep temp=`
-if test -n "$ac_maketemp"; then
- eval ac_cv_prog_make_${ac_make}_set=yes
-else
- eval ac_cv_prog_make_${ac_make}_set=no
-fi
-rm -f conftest.make
-fi
-if eval "test \"`echo '$ac_cv_prog_make_'${ac_make}_set`\" = yes"; then
- echo "$as_me:$LINENO: result: yes" >&5
- SET_MAKE=
-else
- SET_MAKE="MAKE=${MAKE-make}"
-fi
-rm -rf .tst 2>/dev/null
-mkdir .tst 2>/dev/null
-if test -d .tst; then
- am__leading_dot=.
-else
- am__leading_dot=_
-fi
-rmdir .tst 2>/dev/null
-# test to see if srcdir already configured
-if test "`cd $srcdir && pwd`" != "`pwd`" &&
- test -f $srcdir/config.status; then
- { { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
-echo "$as_me: error: source directory already configured; run \"make distclean\" there first" >&2;}
-fi
-# test whether we have cygpath
-if test -z "$CYGPATH_W"; then
- if (cygpath --version) >/dev/null 2>/dev/null; then
- CYGPATH_W='cygpath -w'
- else
- CYGPATH_W=echo
- fi
-fi
-# Define the identity of the package.
- PACKAGE='proj'
- VERSION='4.5.0'
-#define PACKAGE "$PACKAGE"
-_ACEOF
-#define VERSION "$VERSION"
-_ACEOF
-# Some tools Automake needs.
-ACLOCAL=${ACLOCAL-"${am_missing_run}aclocal-${am__api_version}"}
-AUTOCONF=${AUTOCONF-"${am_missing_run}autoconf"}
-AUTOMAKE=${AUTOMAKE-"${am_missing_run}automake-${am__api_version}"}
-AUTOHEADER=${AUTOHEADER-"${am_missing_run}autoheader"}
-MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
-install_sh=${install_sh-"$am_aux_dir/install-sh"}
-# Installed binaries are usually stripped using `strip' when the user
-# run `make install-strip'. However `strip' might not be the right
-# tool to use in cross-compilation environments, therefore Automake
-# will honor the `STRIP' environment variable to overrule this program.
-if test "$cross_compiling" != no; then
- if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
-set dummy ${ac_tool_prefix}strip; ac_word=$2
-if test "${ac_cv_prog_STRIP+set}" = set; then
-else
- if test -n "$STRIP"; then
- ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_STRIP="${ac_tool_prefix}strip"
- break 2
- fi
-done
-done
-fi
-fi
-STRIP=$ac_cv_prog_STRIP
-if test -n "$STRIP"; then
- echo "$as_me:$LINENO: result: $STRIP" >&5
-echo "${ECHO_T}$STRIP" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_STRIP"; then
- ac_ct_STRIP=$STRIP
- # Extract the first word of "strip", so it can be a program name with args.
-set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
-else
- if test -n "$ac_ct_STRIP"; then
- ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_STRIP="strip"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
-fi
-fi
-ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
-if test -n "$ac_ct_STRIP"; then
- echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
-echo "${ECHO_T}$ac_ct_STRIP" >&6
-else
-fi
- STRIP=$ac_ct_STRIP
-else
- STRIP="$ac_cv_prog_STRIP"
-fi
-fi
-INSTALL_STRIP_PROGRAM="\${SHELL} \$(install_sh) -c -s"
-# We need awk for the "check" target. The system "awk" is bad on
-# some platforms.
-# Always define AMTAR for backward compatibility.
-AMTAR=${AMTAR-"${am_missing_run}tar"}
-am__tar='${AMTAR} chof - "$$tardir"'; am__untar='${AMTAR} xf -'
-echo "$as_me:$LINENO: checking whether to enable maintainer-specific portions of Makefiles" >&5
-echo $ECHO_N "checking whether to enable maintainer-specific portions of Makefiles... $ECHO_C" >&6
- # Check whether --enable-maintainer-mode or --disable-maintainer-mode was given.
-if test "${enable_maintainer_mode+set}" = set; then
- enableval="$enable_maintainer_mode"
- USE_MAINTAINER_MODE=$enableval
-else
- USE_MAINTAINER_MODE=no
-fi;
- echo "$as_me:$LINENO: result: $USE_MAINTAINER_MODE" >&5
-echo "${ECHO_T}$USE_MAINTAINER_MODE" >&6
-if test $USE_MAINTAINER_MODE = yes; then
- MAINTAINER_MODE_TRUE=
- MAINTAINER_MODE_FALSE='#'
-else
- MAINTAINER_MODE_TRUE='#'
-fi
- MAINT=$MAINTAINER_MODE_TRUE
- ac_config_headers="$ac_config_headers src/proj_config.h"
-ac_ext=c
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}gcc; ac_word=$2
-if test "${ac_cv_prog_CC+set}" = set; then
-else
- if test -n "$CC"; then
- ac_cv_prog_CC="$CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}gcc"
- break 2
- fi
-done
-done
-fi
-fi
-CC=$ac_cv_prog_CC
-if test -n "$CC"; then
- echo "$as_me:$LINENO: result: $CC" >&5
-echo "${ECHO_T}$CC" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_CC"; then
- ac_ct_CC=$CC
- # Extract the first word of "gcc", so it can be a program name with args.
-set dummy gcc; ac_word=$2
-if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
-else
- if test -n "$ac_ct_CC"; then
- ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="gcc"
- break 2
- fi
-done
-done
-fi
-fi
-ac_ct_CC=$ac_cv_prog_ac_ct_CC
-if test -n "$ac_ct_CC"; then
- echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
-echo "${ECHO_T}$ac_ct_CC" >&6
-else
-fi
- CC=$ac_ct_CC
-else
- CC="$ac_cv_prog_CC"
-fi
-if test -z "$CC"; then
- # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
-set dummy ${ac_tool_prefix}cc; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="${ac_tool_prefix}cc"
- break 2
- fi
-done
-done
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
-fi
- ac_ct_CC=$CC
- # Extract the first word of "cc", so it can be a program name with args.
-set dummy cc; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="cc"
- break 2
- fi
-done
-done
-fi
-fi
-else
-fi
- CC=$ac_ct_CC
-else
-fi
-fi
-else
-else
- ac_prog_rejected=no
-do
- IFS=$as_save_IFS
- if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
- ac_prog_rejected=yes
- continue
- fi
- ac_cv_prog_CC="cc"
- break 2
- fi
-done
-done
-if test $ac_prog_rejected = yes; then
- # We found a bogon in the path, so make sure we never use it.
- set dummy $ac_cv_prog_CC
- shift
- if test $# != 0; then
- # We chose a different compiler from the bogus one.
- # However, it has the same basename, so the bogon will be chosen
- # first if we set CC to just the basename; use the full file name.
- shift
- ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
- fi
-fi
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
-fi
- for ac_prog in cl
- do
- # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
-set dummy $ac_tool_prefix$ac_prog; ac_word=$2
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-CC=$ac_cv_prog_CC
-else
-fi
- test -n "$CC" && break
- done
-fi
- ac_ct_CC=$CC
- for ac_prog in cl
-do
-else
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CC="$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-else
-fi
- test -n "$ac_ct_CC" && break
-done
- CC=$ac_ct_CC
-fi
-fi
-test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&5
-echo "$as_me: error: no acceptable C compiler found in \$PATH
-See \`config.log' for more details." >&2;}
-# Provide some information about the compiler.
-echo "$as_me:$LINENO:" \
- "checking for C compiler version" >&5
-ac_compiler=`set X $ac_compile; echo $2`
-{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
- (eval $ac_compiler --version </dev/null >&5) 2>&5
- ac_status=$?
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); }
-{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
- (eval $ac_compiler -v </dev/null >&5) 2>&5
- ac_status=$?
-{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
- (eval $ac_compiler -V </dev/null >&5) 2>&5
- ac_status=$?
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files a.out a.exe b.out"
-# Try to create an executable without -o first, disregard a.out.
-# It will help us diagnose broken compilers, and finding out an intuition
-# of exeext.
-echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
-echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6
-ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
-if { (eval echo "$as_me:$LINENO: \"$ac_link_default\"") >&5
- (eval $ac_link_default) 2>&5
- ac_status=$?
- (exit $ac_status); }; then
- # Find the output, starting from the most likely. This scheme is
-# not robust to junk in `.', hence go to wildcards (a.*) only as a last
-# resort.
-# Be careful to initialize this variable, since it used to be cached.
-# Otherwise an old cache value of `no' led to `EXEEXT = no' in a Makefile.
-ac_cv_exeext=
-# b.out is created by i960 compilers.
-for ac_file in a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out
-do
- test -f "$ac_file" || continue
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj )
- conftest.$ac_ext )
- # This is the source file.
- [ab].out )
- # We found the default executable, but exeext='' is most
- # certainly right.
- break;;
- ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- # FIXME: I believe we export ac_cv_exeext for Libtool,
- # but it would be cool to find out if it's true. Does anybody
- # maintain Libtool? --akim.
- export ac_cv_exeext
- break;;
- break;;
- esac
-done
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-{ { echo "$as_me:$LINENO: error: C compiler cannot create executables
-echo "$as_me: error: C compiler cannot create executables
- { (exit 77); exit 77; }; }
-fi
-ac_exeext=$ac_cv_exeext
-echo "$as_me:$LINENO: result: $ac_file" >&5
-echo "${ECHO_T}$ac_file" >&6
-# Check the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-echo "$as_me:$LINENO: checking whether the C compiler works" >&5
-echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6
-# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
-# If not cross compiling, check that we can run a simple program.
-if test "$cross_compiling" != yes; then
- if { ac_try='./$ac_file'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; }; then
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- else
- { { echo "$as_me:$LINENO: error: cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
-echo "$as_me: error: cannot run C compiled programs.
- fi
- fi
-fi
-rm -f a.out a.exe conftest$ac_cv_exeext b.out
-ac_clean_files=$ac_clean_files_save
-echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
-echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $cross_compiling" >&5
-echo "${ECHO_T}$cross_compiling" >&6
-echo "$as_me:$LINENO: checking for suffix of executables" >&5
-echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- # If both `conftest.exe' and `conftest' are `present' (well, observable)
-# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
-# work properly (i.e., refer to `conftest.exe'), while it won't with
-# `rm'.
-for ac_file in conftest.exe conftest conftest.*; do
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj ) ;;
- *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
- break;;
- * ) break;;
- esac
-done
-else
- { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
-echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
-fi
-rm -f conftest$ac_cv_exeext
-echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
-echo "${ECHO_T}$ac_cv_exeext" >&6
-rm -f conftest.$ac_ext
-EXEEXT=$ac_cv_exeext
-ac_exeext=$EXEEXT
-echo "$as_me:$LINENO: checking for suffix of object files" >&5
-echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6
-if test "${ac_cv_objext+set}" = set; then
-else
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.o conftest.obj
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- for ac_file in `(ls conftest.o conftest.obj; ls conftest.*) 2>/dev/null`; do
- case $ac_file in
- *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg ) ;;
- *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
- break;;
- esac
-done
-else
-{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
-echo "$as_me: error: cannot compute suffix of object files: cannot compile
-fi
-rm -f conftest.$ac_cv_objext conftest.$ac_ext
-fi
-echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
-echo "${ECHO_T}$ac_cv_objext" >&6
-OBJEXT=$ac_cv_objext
-ac_objext=$OBJEXT
-echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6
-if test "${ac_cv_c_compiler_gnu+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext
- (eval $ac_compile) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- cat conftest.err >&5
- (exit $ac_status); } &&
- { ac_try='test -z "$ac_c_werror_flag"
- || test ! -s conftest.err'
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest.$ac_objext'
- ac_status=$?
- ac_compiler_gnu=yes
-else
-ac_compiler_gnu=no
-fi
-rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
-ac_cv_c_compiler_gnu=$ac_compiler_gnu
-fi
-echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6
-GCC=`test $ac_compiler_gnu = yes && echo yes`
-ac_test_CFLAGS=${CFLAGS+set}
-ac_save_CFLAGS=$CFLAGS
-CFLAGS="-g"
-echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
-echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6
-if test "${ac_cv_prog_cc_g+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_cc_g=yes
-else
-ac_cv_prog_cc_g=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
-echo "${ECHO_T}$ac_cv_prog_cc_g" >&6
-if test "$ac_test_CFLAGS" = set; then
- CFLAGS=$ac_save_CFLAGS
-elif test $ac_cv_prog_cc_g = yes; then
- if test "$GCC" = yes; then
- CFLAGS="-g -O2"
- else
- CFLAGS="-g"
- fi
-else
- CFLAGS="-O2"
- else
- CFLAGS=
- fi
-fi
-echo "$as_me:$LINENO: checking for $CC option to accept ANSI C" >&5
-echo $ECHO_N "checking for $CC option to accept ANSI C... $ECHO_C" >&6
-if test "${ac_cv_prog_cc_stdc+set}" = set; then
-else
- ac_cv_prog_cc_stdc=no
-ac_save_CC=$CC
-/* confdefs.h. */
-_ACEOF
-#include <stdarg.h>
-#include <stdio.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
-struct buf { int x; };
-FILE * (*rcsopen) (struct buf *, struct stat *, int);
-static char *e (p, i)
- char **p;
- int i;
- return p[i];
-static char *f (char * (*g) (char **, int), char **p, ...)
- char *s;
- va_list v;
- va_start (v,p);
- s = g (p, va_arg (v,int));
- va_end (v);
- return s;
-/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default. It has
- function prototypes and stuff, but not '\xHH' hex character constants.
- These don't provoke an error unfortunately, instead are silently treated
- as 'x'. The following induces an error, until -std1 is added to get
- proper ANSI mode. Curiously '\x00'!='x' always comes out true, for an
- array size at least. It's necessary to write '\x00'==0 to get something
- that's true only with -std1. */
-int osf4_cc_array ['\x00' == 0 ? 1 : -1];
-int test (int i, double x);
-struct s1 {int (*f) (int a);};
-struct s2 {int (*f) (double a);};
-int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
-int argc;
-char **argv;
-int
-main ()
-return f (e, argv, 0) != argv[0] || f (e, argv, 1) != argv[1];
- return 0;
-_ACEOF
-# Don't try gcc -ansi; that turns off useful extensions and
-# breaks some systems' header files.
-# AIX -qlanglvl=ansi
-# Ultrix and OSF/1 -std1
-# HP-UX 10.20 and later -Ae
-# HP-UX older versions -Aa -D_HPUX_SOURCE
-# SVR4 -Xc -D__EXTENSIONS__
-for ac_arg in "" -qlanglvl=ansi -std1 -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
-do
- CC="$ac_save_CC $ac_arg"
- rm -f conftest.$ac_objext
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_cc_stdc=$ac_arg
-break
-else
-fi
-done
-rm -f conftest.$ac_ext conftest.$ac_objext
-CC=$ac_save_CC
-fi
-case "x$ac_cv_prog_cc_stdc" in
- x|xno)
- echo "$as_me:$LINENO: result: none needed" >&5
-echo "${ECHO_T}none needed" >&6 ;;
- echo "$as_me:$LINENO: result: $ac_cv_prog_cc_stdc" >&5
-echo "${ECHO_T}$ac_cv_prog_cc_stdc" >&6
- CC="$CC $ac_cv_prog_cc_stdc" ;;
-esac
-# Some people use a C++ compiler to compile C. Since we use `exit',
-# in C++ we need to declare it. In case someone uses the same compiler
-# for both compiling C and C++ we need to have the C++ compiler decide
-# the declaration of exit, since it's the most demanding environment.
-#ifndef __cplusplus
- choke me
-#endif
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- for ac_declaration in \
- 'extern "C" void std::exit (int) throw (); using std::exit;' \
- 'extern "C" void std::exit (int); using std::exit;' \
- 'extern "C" void exit (int) throw ();' \
- 'extern "C" void exit (int);' \
- 'void exit (int);'
-do
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-#include <stdlib.h>
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- break
-else
-fi
-done
-rm -f conftest*
-if test -n "$ac_declaration"; then
- echo '#ifdef __cplusplus' >>confdefs.h
- echo $ac_declaration >>confdefs.h
- echo '#endif' >>confdefs.h
-fi
-else
-fi
-ac_ext=c
-DEPDIR="${am__leading_dot}deps"
- ac_config_commands="$ac_config_commands depfiles"
-am_make=${MAKE-make}
-cat > confinc << 'END'
-am__doit:
- @echo done
-.PHONY: am__doit
-END
-# If we don't find an include directive, just comment out the code.
-echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
-echo $ECHO_N "checking for style of include used by $am_make... $ECHO_C" >&6
-am__include="#"
-am__quote=
-_am_result=none
-# First try GNU make style include.
-echo "include confinc" > confmf
-# We grep out `Entering directory' and `Leaving directory'
-# messages which can occur if `w' ends up in MAKEFLAGS.
-# In particular we don't look at `^make:' because GNU make might
-# be invoked under some other name (usually "gmake"), in which
-# case it prints its new name instead of `make'.
-if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
- am__include=include
- am__quote=
- _am_result=GNU
-fi
-# Now try BSD make style include.
-if test "$am__include" = "#"; then
- echo '.include "confinc"' > confmf
- if test "`$am_make -s -f confmf 2> /dev/null`" = "done"; then
- am__include=.include
- am__quote="\""
- _am_result=BSD
- fi
-fi
-echo "$as_me:$LINENO: result: $_am_result" >&5
-echo "${ECHO_T}$_am_result" >&6
-rm -f confinc confmf
-# Check whether --enable-dependency-tracking or --disable-dependency-tracking was given.
-if test "${enable_dependency_tracking+set}" = set; then
- enableval="$enable_dependency_tracking"
-fi;
-if test "x$enable_dependency_tracking" != xno; then
- am_depcomp="$ac_aux_dir/depcomp"
- AMDEPBACKSLASH='\'
-fi
- AMDEP_TRUE=
- AMDEP_FALSE='#'
-else
- AMDEP_TRUE='#'
- AMDEP_FALSE=
-fi
-depcc="$CC" am_compiler_list=
-echo "$as_me:$LINENO: checking dependency style of $depcc" >&5
-echo $ECHO_N "checking dependency style of $depcc... $ECHO_C" >&6
-if test "${am_cv_CC_dependencies_compiler_type+set}" = set; then
-else
- if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
- # We make a subdir and do the tests there. Otherwise we can end up
- # making bogus files that we don't know about and never remove. For
- # instance it was reported that on HP-UX the gcc test will end up
- # making a dummy file named `D' -- because `-MD' means `put the output
- # in D'.
- mkdir conftest.dir
- # Copy depcomp to subdir because otherwise we won't find it if we're
- # using a relative directory.
- cp "$am_depcomp" conftest.dir
- cd conftest.dir
- # We will build objects and dependencies in a subdirectory because
- # it helps to detect inapplicable dependency modes. For instance
- # both Tru64's cc and ICC support -MD to output dependencies as a
- # side effect of compilation, but ICC will put the dependencies in
- # the current directory while Tru64 will put them in the object
- # directory.
- mkdir sub
- am_cv_CC_dependencies_compiler_type=none
- if test "$am_compiler_list" = ""; then
- am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
- fi
- for depmode in $am_compiler_list; do
- # Setup a source with many dependencies, because some compilers
- # like to wrap large dependency lists on column 80 (with \), and
- # we should not choose a depcomp mode which is confused by this.
- # We need to recreate these files for each test, as the compiler may
- # overwrite some of them when testing with obscure command lines.
- # This happens at least with the AIX C compiler.
- : > sub/conftest.c
- for i in 1 2 3 4 5 6; do
- echo '#include "conftst'$i'.h"' >> sub/conftest.c
- # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
- # Solaris 8's {/usr,}/bin/sh.
- touch sub/conftst$i.h
- done
- echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
- case $depmode in
- nosideeffect)
- # after this tag, mechanisms are not by side-effect, so they'll
- # only be used when explicitly requested
- if test "x$enable_dependency_tracking" = xyes; then
- continue
- else
- break
- fi
- none) break ;;
- esac
- # We check with `-c' and `-o' for the sake of the "dashmstdout"
- # mode. It turns out that the SunPro C++ compiler does not properly
- # handle `-M -o', and we need to detect this.
- if depmode=$depmode \
- source=sub/conftest.c object=sub/conftest.${OBJEXT-o} \
- depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
- $SHELL ./depcomp $depcc -c -o sub/conftest.${OBJEXT-o} sub/conftest.c \
- >/dev/null 2>conftest.err &&
- grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
- grep sub/conftest.${OBJEXT-o} sub/conftest.Po > /dev/null 2>&1 &&
- ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
- # icc doesn't choke on unknown options, it will just issue warnings
- # or remarks (even with -Werror). So we grep stderr for any message
- # that says an option was ignored or not supported.
- # When given -MP, icc 7.0 and 7.1 complain thusly:
- # icc: Command line warning: ignoring option '-M'; no argument required
- # The diagnosis changed in icc 8.0:
- # icc: Command line remark: option '-MP' not supported
- if (grep 'ignoring option' conftest.err ||
- grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
- am_cv_CC_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
- rm -rf conftest.dir
-else
-fi
-fi
-echo "$as_me:$LINENO: result: $am_cv_CC_dependencies_compiler_type" >&5
-echo "${ECHO_T}$am_cv_CC_dependencies_compiler_type" >&6
-CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
-if
- test "x$enable_dependency_tracking" != xno \
- && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
- am__fastdepCC_TRUE=
- am__fastdepCC_FALSE='#'
-else
- am__fastdepCC_TRUE='#'
-fi
-# AIX /bin/install
-else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
-case $as_dir/ in
- /usr/ucb/* ) ;;
- # by default.
- else
- break 3
- fi
- fi
- done
- done
-esac
-done
-fi
- else
- fi
-fi
-echo "$as_me:$LINENO: checking whether ln -s works" >&5
-echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
-LN_S=$as_ln_s
-if test "$LN_S" = "ln -s"; then
-else
- echo "$as_me:$LINENO: result: no, using $LN_S" >&5
-echo "${ECHO_T}no, using $LN_S" >&6
-fi
-else
-all:
-_ACEOF
-else
-fi
-fi
- SET_MAKE=
-else
-fi
-# Check whether --enable-shared or --disable-shared was given.
-if test "${enable_shared+set}" = set; then
- enableval="$enable_shared"
- p=${PACKAGE-default}
- case $enableval in
- yes) enable_shared=yes ;;
- no) enable_shared=no ;;
- enable_shared=no
- # Look at the argument we got. We use all the common list separators.
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for pkg in $enableval; do
- IFS="$lt_save_ifs"
- if test "X$pkg" = "X$p"; then
- enable_shared=yes
- fi
- done
- esac
-else
- enable_shared=yes
-fi;
-# Check whether --enable-static or --disable-static was given.
-if test "${enable_static+set}" = set; then
- enableval="$enable_static"
- yes) enable_static=yes ;;
- no) enable_static=no ;;
- enable_static=no
- enable_static=yes
- fi
- done
- esac
-else
- enable_static=yes
-fi;
-# Check whether --enable-fast-install or --disable-fast-install was given.
-if test "${enable_fast_install+set}" = set; then
- enableval="$enable_fast_install"
- yes) enable_fast_install=yes ;;
- no) enable_fast_install=no ;;
- enable_fast_install=no
- enable_fast_install=yes
- fi
- done
- esac
-else
-fi;
-# Make sure we can run config.sub.
-$ac_config_sub sun4 >/dev/null 2>&1 ||
- { { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
-echo "$as_me: error: cannot run $ac_config_sub" >&2;}
-echo "$as_me:$LINENO: checking build system type" >&5
-echo $ECHO_N "checking build system type... $ECHO_C" >&6
-if test "${ac_cv_build+set}" = set; then
-else
- ac_cv_build_alias=$build_alias
-test -z "$ac_cv_build_alias" &&
- ac_cv_build_alias=`$ac_config_guess`
- { { echo "$as_me:$LINENO: error: cannot guess build type; you must specify one" >&5
-echo "$as_me: error: cannot guess build type; you must specify one" >&2;}
-ac_cv_build=`$ac_config_sub $ac_cv_build_alias` ||
- { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_build_alias failed" >&5
-echo "$as_me: error: $ac_config_sub $ac_cv_build_alias failed" >&2;}
-fi
-echo "$as_me:$LINENO: result: $ac_cv_build" >&5
-echo "${ECHO_T}$ac_cv_build" >&6
-build=$ac_cv_build
-build_cpu=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
-build_vendor=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
-build_os=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
-echo "$as_me:$LINENO: checking host system type" >&5
-echo $ECHO_N "checking host system type... $ECHO_C" >&6
-if test "${ac_cv_host+set}" = set; then
-else
- ac_cv_host_alias=$host_alias
-test -z "$ac_cv_host_alias" &&
- ac_cv_host_alias=$ac_cv_build_alias
-ac_cv_host=`$ac_config_sub $ac_cv_host_alias` ||
- { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_host_alias failed" >&5
-echo "$as_me: error: $ac_config_sub $ac_cv_host_alias failed" >&2;}
-fi
-echo "$as_me:$LINENO: result: $ac_cv_host" >&5
-echo "${ECHO_T}$ac_cv_host" >&6
-host=$ac_cv_host
-host_cpu=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
-host_vendor=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
-host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
-echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
-echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
-if test "${lt_cv_path_SED+set}" = set; then
-else
- # Loop through the user's path and test for sed and gsed.
-# Then use that list of sed's as ones to test for truncation.
-do
- IFS=$as_save_IFS
- for lt_ac_prog in sed gsed; do
- if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
- lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
- fi
- done
- done
-done
-lt_ac_max=0
-lt_ac_count=0
-# Add /usr/xpg4/bin/sed as it is typically found on Solaris
-# along with /bin/sed that truncates output.
-for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
- test ! -f $lt_ac_sed && continue
- cat /dev/null > conftest.in
- lt_ac_count=0
- echo $ECHO_N "0123456789$ECHO_C" >conftest.in
- # Check for GNU sed and select it if it is found.
- if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
- lt_cv_path_SED=$lt_ac_sed
- break
- fi
- while true; do
- cat conftest.in conftest.in >conftest.tmp
- mv conftest.tmp conftest.in
- cp conftest.in conftest.nl
- echo >>conftest.nl
- $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
- cmp -s conftest.out conftest.nl || break
- # 10000 chars as input seems more than enough
- test $lt_ac_count -gt 10 && break
- lt_ac_count=`expr $lt_ac_count + 1`
- if test $lt_ac_count -gt $lt_ac_max; then
- lt_ac_max=$lt_ac_count
- fi
- done
-done
-fi
-SED=$lt_cv_path_SED
-echo "$as_me:$LINENO: result: $SED" >&5
-echo "${ECHO_T}$SED" >&6
-echo "$as_me:$LINENO: checking for egrep" >&5
-echo $ECHO_N "checking for egrep... $ECHO_C" >&6
-if test "${ac_cv_prog_egrep+set}" = set; then
-else
- if echo a | (grep -E '(a|b)') >/dev/null 2>&1
- then ac_cv_prog_egrep='grep -E'
- else ac_cv_prog_egrep='egrep'
- fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
-echo "${ECHO_T}$ac_cv_prog_egrep" >&6
- EGREP=$ac_cv_prog_egrep
-# Check whether --with-gnu-ld or --without-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then
- withval="$with_gnu_ld"
- test "$withval" = no || with_gnu_ld=yes
-else
- with_gnu_ld=no
-fi;
-ac_prog=ld
-if test "$GCC" = yes; then
- # Check if gcc -print-prog-name=ld gives a path.
- echo "$as_me:$LINENO: checking for ld used by $CC" >&5
-echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- echo "$as_me:$LINENO: checking for GNU ld" >&5
-echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
-else
- echo "$as_me:$LINENO: checking for non-GNU ld" >&5
-echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
-fi
-if test "${lt_cv_path_LD+set}" = set; then
-else
- if test -z "$LD"; then
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- test -z "$ac_dir" && ac_dir=.
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some variants of GNU ld only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi
-fi
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- echo "$as_me:$LINENO: result: $LD" >&5
-echo "${ECHO_T}$LD" >&6
-else
-fi
-test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
-echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
- { (exit 1); exit 1; }; }
-echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
-echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
-if test "${lt_cv_prog_gnu_ld+set}" = set; then
-else
- # I'd rather use --version here, but apparently some GNU lds only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
-echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
-with_gnu_ld=$lt_cv_prog_gnu_ld
-echo "$as_me:$LINENO: checking for $LD option to reload object files" >&5
-echo $ECHO_N "checking for $LD option to reload object files... $ECHO_C" >&6
-if test "${lt_cv_ld_reload_flag+set}" = set; then
-else
- lt_cv_ld_reload_flag='-r'
-fi
-echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
-echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
-reload_flag=$lt_cv_ld_reload_flag
-case $reload_flag in
-*) reload_flag=" $reload_flag" ;;
-esac
-reload_cmds='$LD$reload_flag -o $output$reload_objs'
-case $host_os in
- darwin*)
- reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
- else
- reload_cmds='$LD$reload_flag -o $output$reload_objs'
- fi
-esac
-echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
-echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
-if test "${lt_cv_path_NM+set}" = set; then
-else
- if test -n "$NM"; then
- # Let the user override the test.
- lt_cv_path_NM="$NM"
-else
- lt_nm_to_check="${ac_tool_prefix}nm"
- if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
- lt_nm_to_check="$lt_nm_to_check nm"
- fi
- for lt_tmp_nm in $lt_nm_to_check; do
- for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
- tmp_nm="$ac_dir/$lt_tmp_nm"
- if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
- # Check to see if the nm accepts a BSD-compat flag.
- # Adding the `sed 1q' prevents false positives on HP-UX, which says:
- # nm: unknown option "B" ignored
- # Tru64's nm complains that /dev/null is an invalid object file
- case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
- */dev/null* | *'Invalid file or object type'*)
- lt_cv_path_NM="$tmp_nm -B"
- break
- case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
- */dev/null*)
- lt_cv_path_NM="$tmp_nm -p"
- break
- lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
- continue # so that we can try to find one that supports BSD flags
- esac
- esac
- fi
- done
- done
- test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
-fi
-fi
-echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
-echo "${ECHO_T}$lt_cv_path_NM" >&6
-NM="$lt_cv_path_NM"
-echo "$as_me:$LINENO: checking how to recognise dependent libraries" >&5
-echo $ECHO_N "checking how to recognise dependent libraries... $ECHO_C" >&6
-if test "${lt_cv_deplibs_check_method+set}" = set; then
-else
- lt_cv_file_magic_cmd='$MAGIC_CMD'
-lt_cv_file_magic_test_file=
-lt_cv_deplibs_check_method='unknown'
-# Need to set the preceding variable on all platforms that support
-# interlibrary dependencies.
-# 'none' -- dependencies not supported.
-# `unknown' -- same as none, but documents that we really don't know.
-# 'pass_all' -- all dependencies passed with no checks.
-# 'test_compile' -- check by making test program.
-# 'file_magic [[regex]]' -- check by looking for files in library path
-# which responds to the $file_magic_cmd with a given extended regex.
-# If you have `file' or equivalent on your system and you're not sure
-# whether `pass_all' will *always* work, you probably want this one.
-case $host_os in
-aix4* | aix5*)
- lt_cv_deplibs_check_method=pass_all
-beos*)
-bsdi[45]*)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
- lt_cv_file_magic_cmd='/usr/bin/file -L'
- lt_cv_file_magic_test_file=/shlib/libc.so
-cygwin*)
- # func_win32_libid is a shell function defined in ltmain.sh
- lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
- lt_cv_file_magic_cmd='func_win32_libid'
-mingw* | pw32*)
- # Base MSYS/MinGW do not provide the 'file' command needed by
- # func_win32_libid shell function, so use a weaker test based on 'objdump'.
- lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
- lt_cv_file_magic_cmd='$OBJDUMP -f'
-darwin* | rhapsody*)
-freebsd* | kfreebsd*-gnu | dragonfly*)
- if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
- case $host_cpu in
- i*86 )
- # Not sure whether the presence of OpenBSD here was a mistake.
- # Let's accept both of them until this is cleared up.
- lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
- lt_cv_file_magic_cmd=/usr/bin/file
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
- esac
- else
- fi
-gnu*)
-hpux10.20* | hpux11*)
- case $host_cpu in
- ia64*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
- lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
- hppa*64*)
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
- lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
- lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
- lt_cv_file_magic_test_file=/usr/lib/libc.sl
- esac
-interix3*)
- # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
-irix5* | irix6* | nonstopux*)
- case $LD in
- *-32|*"-32 ") libmagic=32-bit;;
- *-n32|*"-n32 ") libmagic=N32;;
- *-64|*"-64 ") libmagic=64-bit;;
- *) libmagic=never-match;;
- esac
-# This must be Linux ELF.
-linux*)
-netbsd*)
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
- else
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
- fi
-newos6*)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (executable|dynamic lib)'
- lt_cv_file_magic_test_file=/usr/lib/libnls.so
-nto-qnx*)
- lt_cv_deplibs_check_method=unknown
-openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
- else
- fi
-osf3* | osf4* | osf5*)
-solaris*)
-sysv4 | sysv4.3*)
- case $host_vendor in
- motorola)
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
- lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
- ncr)
- sequent)
- lt_cv_file_magic_cmd='/bin/file'
- lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )'
- sni)
- lt_cv_deplibs_check_method="file_magic ELF [0-9][0-9]*-bit [LM]SB dynamic lib"
- lt_cv_file_magic_test_file=/lib/libc.so
- siemens)
- pc)
- esac
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
-esac
-fi
-echo "$as_me:$LINENO: result: $lt_cv_deplibs_check_method" >&5
-echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
-file_magic_cmd=$lt_cv_file_magic_cmd
-deplibs_check_method=$lt_cv_deplibs_check_method
-test -z "$deplibs_check_method" && deplibs_check_method=unknown
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
-if test "${enable_libtool_lock+set}" = set; then
- enableval="$enable_libtool_lock"
-fi;
-test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
-# Some flags need to be propagated to the compiler or linker for good
-# libtool support.
-case $host in
-ia64-*-hpux*)
- # Find out which ABI we are using.
- echo 'int i;' > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- ac_status=$?
- case `/usr/bin/file conftest.$ac_objext` in
- *ELF-32*)
- HPUX_IA64_MODE="32"
- *ELF-64*)
- HPUX_IA64_MODE="64"
- esac
- fi
- rm -rf conftest*
-*-*-irix6*)
- echo '#line 3818 "configure"' > conftest.$ac_ext
- ac_status=$?
- if test "$lt_cv_prog_gnu_ld" = yes; then
- *32-bit*)
- LD="${LD-ld} -melf32bsmip"
- *N32*)
- LD="${LD-ld} -melf32bmipn32"
- *64-bit*)
- LD="${LD-ld} -melf64bmip"
- esac
- else
- *32-bit*)
- LD="${LD-ld} -32"
- *N32*)
- LD="${LD-ld} -n32"
- *64-bit*)
- LD="${LD-ld} -64"
- esac
- fi
- fi
- rm -rf conftest*
-x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
- ac_status=$?
- case `/usr/bin/file conftest.o` in
- *32-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_i386"
- ppc64-*linux*|powerpc64-*linux*)
- LD="${LD-ld} -m elf32ppclinux"
- s390x-*linux*)
- LD="${LD-ld} -m elf_s390"
- sparc64-*linux*)
- LD="${LD-ld} -m elf32_sparc"
- esac
- *64-bit*)
- case $host in
- x86_64-*linux*)
- LD="${LD-ld} -m elf_x86_64"
- ppc*-*linux*|powerpc*-*linux*)
- LD="${LD-ld} -m elf64ppc"
- s390*-*linux*)
- LD="${LD-ld} -m elf64_s390"
- sparc*-*linux*)
- LD="${LD-ld} -m elf64_sparc"
- esac
- esac
- fi
- rm -rf conftest*
-*-*-sco3.2v5*)
- # On SCO OpenServer 5, we need -belf to get full-featured binaries.
- SAVE_CFLAGS="$CFLAGS"
- CFLAGS="$CFLAGS -belf"
- echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
-echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
-if test "${lt_cv_cc_needs_belf+set}" = set; then
-else
- ac_ext=c
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- ac_status=$?
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- lt_cv_cc_needs_belf=yes
-else
-lt_cv_cc_needs_belf=no
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
- ac_ext=c
-fi
-echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
-echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
- if test x"$lt_cv_cc_needs_belf" != x"yes"; then
- # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
- CFLAGS="$SAVE_CFLAGS"
- fi
-sparc*-*solaris*)
- ac_status=$?
- *64-bit*)
- case $lt_cv_prog_gnu_ld in
- yes*) LD="${LD-ld} -m elf64_sparc" ;;
- *) LD="${LD-ld} -64" ;;
- esac
- esac
- fi
- rm -rf conftest*
-esac
-need_locks="$enable_libtool_lock"
-ac_ext=c
-echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
-echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
-# On Suns, sometimes $CPP names a directory.
-if test -n "$CPP" && test -d "$CPP"; then
- CPP=
-fi
-if test -z "$CPP"; then
- if test "${ac_cv_prog_CPP+set}" = set; then
-else
- # Double quotes because CPP needs to be expanded
- for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
- do
- ac_preproc_ok=false
-for ac_c_preproc_warn_flag in '' yes
-do
- # Use a header file that comes with gcc, so configuring glibc
- # with a fresh cross-compiler works.
- # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- # <limits.h> exists even on freestanding compilers.
- # On the NeXT, cc -E runs the code through the compiler's parser,
- # not just through cpp. "Syntax error" is here to catch this case.
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
- Syntax error
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
- (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null; then
- if test -s conftest.err; then
- ac_cpp_err=$ac_c_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-if test -z "$ac_cpp_err"; then
-else
- # Broken: fails on valid input.
-continue
-fi
-rm -f conftest.err conftest.$ac_ext
- # OK, works on sane cases. Now check whether non-existent headers
- # can be detected and how.
-/* confdefs.h. */
-_ACEOF
-#include <ac_nonexistent.h>
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
- # Broken: success on invalid input.
-continue
-else
- # Passes both tests.
-ac_preproc_ok=:
-break
-fi
-done
-# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-if $ac_preproc_ok; then
- break
-fi
- done
- ac_cv_prog_CPP=$CPP
-fi
- CPP=$ac_cv_prog_CPP
-else
-fi
-echo "$as_me:$LINENO: result: $CPP" >&5
-echo "${ECHO_T}$CPP" >&6
-ac_preproc_ok=false
-do
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
-echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
-fi
-ac_ext=c
-echo "$as_me:$LINENO: checking for ANSI C header files" >&5
-echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
-if test "${ac_cv_header_stdc+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-#include <string.h>
-#include <float.h>
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_header_stdc=yes
-else
-ac_cv_header_stdc=no
-fi
-if test $ac_cv_header_stdc = yes; then
- # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
-else
- ac_cv_header_stdc=no
-fi
-rm -f conftest*
-fi
- # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
-else
-fi
-rm -f conftest*
-fi
- # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then
-else
-/* confdefs.h. */
-_ACEOF
-#include <ctype.h>
-#if ((' ' & 0x0FF) == 0x020)
-# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
-# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
-#else
-# define ISLOWER(c) \
- (('a' <= (c) && (c) <= 'i') \
- || ('j' <= (c) && (c) <= 'r') \
- || ('s' <= (c) && (c) <= 'z'))
-# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
-#endif
-#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
-int
-main ()
- int i;
- for (i = 0; i < 256; i++)
- if (XOR (islower (i), ISLOWER (i))
- || toupper (i) != TOUPPER (i))
- exit(2);
- exit (0);
-_ACEOF
-rm -f conftest$ac_exeext
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
- ac_status=$?
-else
- echo "$as_me: program exited with status $ac_status" >&5
-echo "$as_me: failed program was:" >&5
-( exit $ac_status )
-fi
-rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
-fi
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
-echo "${ECHO_T}$ac_cv_header_stdc" >&6
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
-fi
-# On IRIX 5.3, sys/types and inttypes.h are conflicting.
-for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
- inttypes.h stdint.h unistd.h
-do
-as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
-echo "$as_me:$LINENO: checking for $ac_header" >&5
-echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
-if eval "test \"\${$as_ac_Header+set}\" = set"; then
-else
-/* confdefs.h. */
-_ACEOF
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- eval "$as_ac_Header=yes"
-else
-eval "$as_ac_Header=no"
-fi
-fi
-echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
-echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
-if test `eval echo '${'$as_ac_Header'}'` = yes; then
- cat >>confdefs.h <<_ACEOF
-#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
-for ac_header in dlfcn.h
-do
- echo "$as_me:$LINENO: checking for $ac_header" >&5
-fi
-else
- # Is the header compilable?
-echo "$as_me:$LINENO: checking $ac_header usability" >&5
-echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_header_compiler=yes
-else
-ac_header_compiler=no
-fi
-echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-echo "${ECHO_T}$ac_header_compiler" >&6
-# Is the header present?
-echo "$as_me:$LINENO: checking $ac_header presence" >&5
-echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-echo "${ECHO_T}$ac_header_preproc" >&6
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
- yes:no: )
- { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
- cat <<\_ASBOX
-## Report this to warmerdam at pobox.com ##
-_ASBOX
- sed "s/^/$as_me: WARNING: /" >&2
-esac
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
-_ACEOF
-fi
-done
-ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
- for ac_prog in $CCC g++ c++ gpp aCC CC cxx cc++ cl FCC KCC RCC xlC_r xlC
- do
-if test "${ac_cv_prog_CXX+set}" = set; then
-else
- if test -n "$CXX"; then
- ac_cv_prog_CXX="$CXX" # Let the user override the test.
-else
-as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-do
- IFS=$as_save_IFS
- ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-CXX=$ac_cv_prog_CXX
-if test -n "$CXX"; then
- echo "$as_me:$LINENO: result: $CXX" >&5
-echo "${ECHO_T}$CXX" >&6
-else
-fi
- test -n "$CXX" && break
- done
-fi
-if test -z "$CXX"; then
- ac_ct_CXX=$CXX
-do
-if test "${ac_cv_prog_ac_ct_CXX+set}" = set; then
-else
- if test -n "$ac_ct_CXX"; then
- ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_CXX="$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
-if test -n "$ac_ct_CXX"; then
- echo "$as_me:$LINENO: result: $ac_ct_CXX" >&5
-echo "${ECHO_T}$ac_ct_CXX" >&6
-else
-fi
- test -n "$ac_ct_CXX" && break
-done
-test -n "$ac_ct_CXX" || ac_ct_CXX="g++"
- CXX=$ac_ct_CXX
-fi
- "checking for C++ compiler version" >&5
- ac_status=$?
- ac_status=$?
- ac_status=$?
-echo "$as_me:$LINENO: checking whether we are using the GNU C++ compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU C++ compiler... $ECHO_C" >&6
-if test "${ac_cv_cxx_compiler_gnu+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
-#ifndef __GNUC__
- choke me
-#endif
- return 0;
-_ACEOF
- ac_status=$?
- { ac_try='test -z "$ac_cxx_werror_flag"
- ac_status=$?
- ac_status=$?
-else
-ac_compiler_gnu=no
-fi
-ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
-fi
-echo "$as_me:$LINENO: result: $ac_cv_cxx_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_cxx_compiler_gnu" >&6
-GXX=`test $ac_compiler_gnu = yes && echo yes`
-ac_test_CXXFLAGS=${CXXFLAGS+set}
-ac_save_CXXFLAGS=$CXXFLAGS
-CXXFLAGS="-g"
-echo "$as_me:$LINENO: checking whether $CXX accepts -g" >&5
-echo $ECHO_N "checking whether $CXX accepts -g... $ECHO_C" >&6
-if test "${ac_cv_prog_cxx_g+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_cxx_g=yes
-else
-ac_cv_prog_cxx_g=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
-echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6
-if test "$ac_test_CXXFLAGS" = set; then
- CXXFLAGS=$ac_save_CXXFLAGS
-elif test $ac_cv_prog_cxx_g = yes; then
- if test "$GXX" = yes; then
- CXXFLAGS="-g -O2"
- else
- CXXFLAGS="-g"
- fi
-else
- CXXFLAGS="-O2"
- else
- CXXFLAGS=
- fi
-fi
-for ac_declaration in \
-do
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-$ac_declaration
-int
-main ()
-exit (42);
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- break
-else
-fi
-done
-rm -f conftest*
-fi
-ac_ext=cc
-depcc="$CXX" am_compiler_list=
-if test "${am_cv_CXX_dependencies_compiler_type+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- # in D'.
- cd conftest.dir
- # directory.
- mkdir sub
- am_cv_CXX_dependencies_compiler_type=none
- fi
- done
- case $depmode in
- nosideeffect)
- continue
- else
- break
- fi
- none) break ;;
- esac
- am_cv_CXX_dependencies_compiler_type=$depmode
- break
- fi
- fi
- done
- cd ..
-else
-fi
-fi
-echo "$as_me:$LINENO: result: $am_cv_CXX_dependencies_compiler_type" >&5
-echo "${ECHO_T}$am_cv_CXX_dependencies_compiler_type" >&6
-CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
-if
- && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
- am__fastdepCXX_TRUE=
- am__fastdepCXX_FALSE='#'
-else
- am__fastdepCXX_TRUE='#'
-fi
-if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
- ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
- (test "X$CXX" != "Xg++"))) ; then
- ac_ext=cc
-echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
-echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
-if test -z "$CXXCPP"; then
- if test "${ac_cv_prog_CXXCPP+set}" = set; then
-else
- # Double quotes because CXXCPP needs to be expanded
- for CXXCPP in "$CXX -E" "/lib/cpp"
- do
-for ac_cxx_preproc_warn_flag in '' yes
-do
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
- ac_status=$?
- ac_cpp_err=$ac_cxx_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
- break
-fi
- done
- ac_cv_prog_CXXCPP=$CXXCPP
-fi
- CXXCPP=$ac_cv_prog_CXXCPP
-else
-fi
-echo "$as_me:$LINENO: result: $CXXCPP" >&5
-echo "${ECHO_T}$CXXCPP" >&6
-do
-/* confdefs.h. */
-_ACEOF
-#ifdef __STDC__
-#else
-#endif
- Syntax error
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-else
-continue
-fi
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- ac_status=$?
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-continue
-else
-ac_preproc_ok=:
-break
-fi
-done
-else
- { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
-echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
-fi
-ac_ext=cc
-fi
-ac_ext=f
-ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
-ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_f77_compiler_gnu
- for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
- do
-if test "${ac_cv_prog_F77+set}" = set; then
-else
- if test -n "$F77"; then
- ac_cv_prog_F77="$F77" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-F77=$ac_cv_prog_F77
-if test -n "$F77"; then
- echo "$as_me:$LINENO: result: $F77" >&5
-echo "${ECHO_T}$F77" >&6
-else
-fi
- test -n "$F77" && break
- done
-fi
-if test -z "$F77"; then
- ac_ct_F77=$F77
-do
-if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
-else
- if test -n "$ac_ct_F77"; then
- ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_F77="$ac_prog"
- break 2
- fi
-done
-done
-fi
-fi
-ac_ct_F77=$ac_cv_prog_ac_ct_F77
-if test -n "$ac_ct_F77"; then
- echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
-echo "${ECHO_T}$ac_ct_F77" >&6
-else
-fi
- test -n "$ac_ct_F77" && break
-done
- F77=$ac_ct_F77
-fi
-echo "$as_me:5417:" \
- "checking for Fortran 77 compiler version" >&5
- ac_status=$?
- ac_status=$?
- ac_status=$?
-rm -f a.out
-# If we don't use `.F' as extension, the preprocessor is not run on the
-# input file. (Note that this only needs to work for GNU compilers.)
-ac_save_ext=$ac_ext
-ac_ext=F
-echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
-echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
-if test "${ac_cv_f77_compiler_gnu+set}" = set; then
-else
- program main
-#ifndef __GNUC__
- choke me
-#endif
- end
-_ACEOF
- ac_status=$?
- { ac_try='test -z "$ac_f77_werror_flag"
- ac_status=$?
- ac_status=$?
-else
-ac_compiler_gnu=no
-fi
-ac_cv_f77_compiler_gnu=$ac_compiler_gnu
-fi
-echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
-echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
-ac_ext=$ac_save_ext
-ac_test_FFLAGS=${FFLAGS+set}
-ac_save_FFLAGS=$FFLAGS
-FFLAGS=
-echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
-echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
-if test "${ac_cv_prog_f77_g+set}" = set; then
-else
- FFLAGS=-g
- program main
- end
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_prog_f77_g=yes
-else
-ac_cv_prog_f77_g=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
-echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
-if test "$ac_test_FFLAGS" = set; then
- FFLAGS=$ac_save_FFLAGS
-elif test $ac_cv_prog_f77_g = yes; then
- if test "x$ac_cv_f77_compiler_gnu" = xyes; then
- FFLAGS="-g -O2"
- else
- FFLAGS="-g"
- fi
-else
- FFLAGS="-O2"
- else
- FFLAGS=
- fi
-fi
-G77=`test $ac_compiler_gnu = yes && echo yes`
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
-# find the maximum length of command line arguments
-echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
-echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
-if test "${lt_cv_sys_max_cmd_len+set}" = set; then
-else
- i=0
- teststring="ABCD"
- case $build_os in
- msdosdjgpp*)
- # On DJGPP, this test can blow up pretty badly due to problems in libc
- # (any single argument exceeding 2000 bytes causes a buffer overrun
- # during glob expansion). Even if it were fixed, the result of this
- # check would be larger than it should be.
- lt_cv_sys_max_cmd_len=12288; # 12K is about right
- gnu*)
- # Under GNU Hurd, this test is not required because there is
- # no limit to the length of command line arguments.
- # Libtool will interpret -1 as no limit whatsoever
- lt_cv_sys_max_cmd_len=-1;
- cygwin* | mingw*)
- # On Win9x/ME, this test blows up -- it succeeds, but takes
- # about 5 minutes as the teststring grows exponentially.
- # Worse, since 9x/ME are not pre-emptively multitasking,
- # you end up with a "frozen" computer, even though with patience
- # the test eventually succeeds (with a max line length of 256k).
- # Instead, let's just punt: use the minimum linelength reported by
- # all of the supported platforms: 8192 (on NT/2K/XP).
- lt_cv_sys_max_cmd_len=8192;
- amigaos*)
- # On AmigaOS with pdksh, this test takes hours, literally.
- # So we just punt and use a minimum line length of 8192.
- netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
- # This has been around since 386BSD, at least. Likely further.
- if test -x /sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
- elif test -x /usr/sbin/sysctl; then
- lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
- else
- lt_cv_sys_max_cmd_len=65536 # usable default for all BSDs
- fi
- # And add a safety zone
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
- interix*)
- # We know the value 262144 and hardcode it with a safety zone (like BSD)
- lt_cv_sys_max_cmd_len=196608
- osf*)
- # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
- # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
- # nice to cause kernel panics so lets avoid the loop below.
- # First set a reasonable default.
- lt_cv_sys_max_cmd_len=16384
- if test -x /sbin/sysconfig; then
- case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
- *1*) lt_cv_sys_max_cmd_len=-1 ;;
- esac
- fi
- sco3.2v5*)
- lt_cv_sys_max_cmd_len=102400
- sysv5* | sco5v6* | sysv4.2uw2*)
- kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
- if test -n "$kargmax"; then
- lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ ]//'`
- else
- lt_cv_sys_max_cmd_len=32768
- fi
- # If test is not a shell built-in, we'll probably end up computing a
- # maximum length that is only half of the actual maximum length, but
- # we can't tell.
- SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
- while (test "X"`$SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
- = "XX$teststring") >/dev/null 2>&1 &&
- new_result=`expr "X$teststring" : ".*" 2>&1` &&
- lt_cv_sys_max_cmd_len=$new_result &&
- test $i != 17 # 1/2 MB should be enough
- do
- i=`expr $i + 1`
- teststring=$teststring$teststring
- done
- teststring=
- # Add a significant safety factor because C++ compilers can tack on massive
- # amounts of additional arguments before passing them to the linker.
- # It appears as though 1/2 is a usable value.
- lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
- esac
-fi
-if test -n $lt_cv_sys_max_cmd_len ; then
- echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
-echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
-else
- echo "$as_me:$LINENO: result: none" >&5
-echo "${ECHO_T}none" >&6
-fi
-# Check for command to grab the raw symbol name followed by C symbol from nm.
-echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
-echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
-if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
-else
-# These are sane defaults that work on at least a few old systems.
-# [They come from Ultrix. What could be older than Ultrix?!! ;)]
-# Character class describing NM global symbol codes.
-symcode='[BCDEGRST]'
-# Regexp to match symbols that can be accessed directly from C.
-sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
-# Transform an extracted symbol line into a proper C declaration
-lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
-# Transform an extracted symbol line into symbol name and symbol address
-lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-# Define system-specific variables.
-case $host_os in
-aix*)
- symcode='[BCDT]'
-cygwin* | mingw* | pw32*)
- symcode='[ABCDGISTW]'
-hpux*) # Its linker distinguishes data from code symbols
- if test "$host_cpu" = ia64; then
- symcode='[ABCDEGRST]'
- fi
- lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
- lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/ {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/ {\"\2\", (lt_ptr) \&\2},/p'"
-linux*)
- symcode='[ABCDGIRSTW]'
- fi
-irix* | nonstopux*)
- symcode='[BCDEGRST]'
-osf*)
- symcode='[BCDEGQRST]'
-solaris*)
- symcode='[BDRT]'
-sco3.2v5*)
- symcode='[DT]'
-sysv4.2uw2*)
- symcode='[DT]'
-sysv5* | sco5v6* | unixware* | OpenUNIX*)
- symcode='[ABDT]'
-sysv4)
- symcode='[DFNSTU]'
-esac
-# Handle CRLF in mingw tool chain
-opt_cr=
-case $build_os in
-mingw*)
- opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
-esac
-# If we're using GNU nm, then use its standard symbol codes.
-case `$NM -V 2>&1` in
- symcode='[ABCDGIRSTW]' ;;
-esac
-# Try without a prefix undercore, then with it.
-for ac_symprfx in "" "_"; do
- # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
- symxfrm="\\1 $ac_symprfx\\2 \\2"
- # Write the raw and C identifiers.
- lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ ]\($symcode$symcode*\)[ ][ ]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
- # Check to see that the pipe works correctly.
- pipe_works=no
- rm -f conftest*
- cat > conftest.$ac_ext <<EOF
-#ifdef __cplusplus
-extern "C" {
-#endif
-char nm_test_var;
-void nm_test_func(){}
-#ifdef __cplusplus
-#endif
-int main(){nm_test_var='a';nm_test_func();return(0);}
-EOF
- ac_status=$?
- # Now try to grab the symbols.
- nlist=conftest.nm
- if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
- (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
- ac_status=$?
- (exit $ac_status); } && test -s "$nlist"; then
- # Try sorting and uniquifying the output.
- if sort "$nlist" | uniq > "$nlist"T; then
- mv -f "$nlist"T "$nlist"
- else
- rm -f "$nlist"T
- fi
- # Make sure that we snagged all the symbols we need.
- if grep ' nm_test_var$' "$nlist" >/dev/null; then
- if grep ' nm_test_func$' "$nlist" >/dev/null; then
- cat <<EOF > conftest.$ac_ext
-#ifdef __cplusplus
-extern "C" {
-#endif
-EOF
- # Now generate the symbol file.
- eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
- cat <<EOF >> conftest.$ac_ext
-#if defined (__STDC__) && __STDC__
-# define lt_ptr_t void *
-#else
-# define lt_ptr_t char *
-# define const
-#endif
-/* The mapping between symbol names and symbols. */
-const struct {
- const char *name;
- lt_ptr_t address;
-lt_preloaded_symbols[] =
-EOF
- $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/ {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
- cat <<\EOF >> conftest.$ac_ext
- {0, (lt_ptr_t) 0}
-#ifdef __cplusplus
-#endif
-EOF
- # Now try linking the two files.
- mv conftest.$ac_objext conftstm.$ac_objext
- lt_save_LIBS="$LIBS"
- lt_save_CFLAGS="$CFLAGS"
- LIBS="conftstm.$ac_objext"
- CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext}; then
- pipe_works=yes
- fi
- LIBS="$lt_save_LIBS"
- CFLAGS="$lt_save_CFLAGS"
- else
- echo "cannot find nm_test_func in $nlist" >&5
- fi
- else
- echo "cannot find nm_test_var in $nlist" >&5
- fi
- else
- echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
- fi
- else
- echo "$progname: failed program was:" >&5
- cat conftest.$ac_ext >&5
- fi
- rm -f conftest* conftst*
- # Do not use the global_symbol_pipe unless it works.
- if test "$pipe_works" = yes; then
- break
- else
- fi
-done
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe"; then
-fi
-if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
- echo "$as_me:$LINENO: result: failed" >&5
-echo "${ECHO_T}failed" >&6
-else
- echo "$as_me:$LINENO: result: ok" >&5
-echo "${ECHO_T}ok" >&6
-fi
-echo "$as_me:$LINENO: checking for objdir" >&5
-echo $ECHO_N "checking for objdir... $ECHO_C" >&6
-if test "${lt_cv_objdir+set}" = set; then
-else
- rm -f .libs 2>/dev/null
-mkdir .libs 2>/dev/null
-if test -d .libs; then
- lt_cv_objdir=.libs
-else
- # MS-DOS does not allow filenames that begin with a dot.
- lt_cv_objdir=_libs
-fi
-rmdir .libs 2>/dev/null
-fi
-echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
-echo "${ECHO_T}$lt_cv_objdir" >&6
-objdir=$lt_cv_objdir
-case $host_os in
-aix3*)
- # AIX sometimes has problems with the GCC collect2 program. For some
- # reason, if we set the COLLECT_NAMES environment variable, the problems
- # vanish in a puff of smoke.
- if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
- fi
-esac
-# Sed substitution that helps us do robust quoting. It backslashifies
-# metacharacters that are still active within double-quoted strings.
-Xsed='sed -e 1s/^X//'
-sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
-# Same as above, but do not quote variable references.
-double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
-# Sed substitution to delay expansion of an escaped shell variable in a
-# double_quote_subst'ed string.
-delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
-# Sed substitution to avoid accidental globbing in evaled expressions
-no_glob_subst='s/\*/\\\*/g'
-# Constants:
-rm="rm -f"
-# Global variables:
-default_ofile=libtool
-can_build_shared=yes
-# All known linkers require a `.a' archive for static linking (except MSVC,
-# which needs '.lib').
-libext=a
-ltmain="$ac_aux_dir/ltmain.sh"
-ofile="$default_ofile"
-with_gnu_ld="$lt_cv_prog_gnu_ld"
-if test -n "$ac_tool_prefix"; then
- # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
-set dummy ${ac_tool_prefix}ar; ac_word=$2
-echo "$as_me:$LINENO: checking for $ac_word" >&5
-echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
-if test "${ac_cv_prog_AR+set}" = set; then
-else
- if test -n "$AR"; then
- ac_cv_prog_AR="$AR" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
- ac_cv_prog_AR="${ac_tool_prefix}ar"
- echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
- break 2
- fi
-done
-done
-fi
-fi
-AR=$ac_cv_prog_AR
-if test -n "$AR"; then
- echo "$as_me:$LINENO: result: $AR" >&5
-echo "${ECHO_T}$AR" >&6
-else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
-fi
-if test -z "$ac_cv_prog_AR"; then
- ac_ct_AR=$AR
- # Extract the first word of "ar", so it can be a program name with args.
-set dummy ar; ac_word=$2
-if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
-else
- if test -n "$ac_ct_AR"; then
- ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_AR="ar"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
-fi
-fi
-ac_ct_AR=$ac_cv_prog_ac_ct_AR
-if test -n "$ac_ct_AR"; then
- echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
-echo "${ECHO_T}$ac_ct_AR" >&6
-else
-fi
- AR=$ac_ct_AR
-else
- AR="$ac_cv_prog_AR"
-fi
- # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
-set dummy ${ac_tool_prefix}ranlib; ac_word=$2
-if test "${ac_cv_prog_RANLIB+set}" = set; then
-else
- if test -n "$RANLIB"; then
- ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
- break 2
- fi
-done
-done
-fi
-fi
-RANLIB=$ac_cv_prog_RANLIB
-if test -n "$RANLIB"; then
- echo "$as_me:$LINENO: result: $RANLIB" >&5
-echo "${ECHO_T}$RANLIB" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_RANLIB"; then
- ac_ct_RANLIB=$RANLIB
- # Extract the first word of "ranlib", so it can be a program name with args.
-set dummy ranlib; ac_word=$2
-if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
-else
- if test -n "$ac_ct_RANLIB"; then
- ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_RANLIB="ranlib"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_RANLIB" && ac_cv_prog_ac_ct_RANLIB=":"
-fi
-fi
-ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
-if test -n "$ac_ct_RANLIB"; then
- echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
-echo "${ECHO_T}$ac_ct_RANLIB" >&6
-else
-fi
- RANLIB=$ac_ct_RANLIB
-else
- RANLIB="$ac_cv_prog_RANLIB"
-fi
- # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
-set dummy ${ac_tool_prefix}strip; ac_word=$2
-if test "${ac_cv_prog_STRIP+set}" = set; then
-else
- if test -n "$STRIP"; then
- ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_STRIP="${ac_tool_prefix}strip"
- break 2
- fi
-done
-done
-fi
-fi
-STRIP=$ac_cv_prog_STRIP
-if test -n "$STRIP"; then
- echo "$as_me:$LINENO: result: $STRIP" >&5
-echo "${ECHO_T}$STRIP" >&6
-else
-fi
-fi
-if test -z "$ac_cv_prog_STRIP"; then
- ac_ct_STRIP=$STRIP
- # Extract the first word of "strip", so it can be a program name with args.
-set dummy strip; ac_word=$2
-if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
-else
- if test -n "$ac_ct_STRIP"; then
- ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
-else
-do
- IFS=$as_save_IFS
- ac_cv_prog_ac_ct_STRIP="strip"
- break 2
- fi
-done
-done
- test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
-fi
-fi
-ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
-if test -n "$ac_ct_STRIP"; then
- echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
-echo "${ECHO_T}$ac_ct_STRIP" >&6
-else
-fi
- STRIP=$ac_ct_STRIP
-else
- STRIP="$ac_cv_prog_STRIP"
-fi
-old_CC="$CC"
-old_CFLAGS="$CFLAGS"
-# Set sane defaults for various variables
-test -z "$AR" && AR=ar
-test -z "$AR_FLAGS" && AR_FLAGS=cru
-test -z "$AS" && AS=as
-test -z "$CC" && CC=cc
-test -z "$LTCC" && LTCC=$CC
-test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
-test -z "$DLLTOOL" && DLLTOOL=dlltool
-test -z "$LD" && LD=ld
-test -z "$LN_S" && LN_S="ln -s"
-test -z "$MAGIC_CMD" && MAGIC_CMD=file
-test -z "$NM" && NM=nm
-test -z "$SED" && SED=sed
-test -z "$OBJDUMP" && OBJDUMP=objdump
-test -z "$RANLIB" && RANLIB=:
-test -z "$STRIP" && STRIP=:
-test -z "$ac_objext" && ac_objext=o
-# Determine commands to create old-style static archives.
-old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
-old_postinstall_cmds='chmod 644 $oldlib'
-old_postuninstall_cmds=
- case $host_os in
- openbsd*)
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
- old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
- esac
- old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
-fi
-for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-# Only perform the check for file, if the check method requires it
-case $deplibs_check_method in
-file_magic*)
- if test "$file_magic_cmd" = '$MAGIC_CMD'; then
- echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
-echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
-if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
-else
- case $MAGIC_CMD in
- lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
- lt_save_MAGIC_CMD="$MAGIC_CMD"
- ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
- for ac_dir in $ac_dummy; do
- if test -f $ac_dir/${ac_tool_prefix}file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
- if test -n "$file_magic_test_file"; then
- case $deplibs_check_method in
- "file_magic "*)
- file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
- MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
- if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
- $EGREP "$file_magic_regex" > /dev/null; then
- else
- cat <<EOF 1>&2
-*** Warning: the command libtool uses to detect shared libraries,
-*** $file_magic_cmd, produces output that libtool cannot recognize.
-*** The result is that libtool may fail to recognize shared libraries
-*** as such. This will affect the creation of libtool libraries that
-*** depend on shared libraries, but programs linked with such libtool
-*** libraries will work regardless of this problem. Nevertheless, you
-*** may want to report the problem to your system manager and/or to
-*** bug-libtool at gnu.org
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
- MAGIC_CMD="$lt_save_MAGIC_CMD"
-esac
-fi
-MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
-if test -n "$MAGIC_CMD"; then
- echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
-echo "${ECHO_T}$MAGIC_CMD" >&6
-else
-fi
-if test -z "$lt_cv_path_MAGIC_CMD"; then
- if test -n "$ac_tool_prefix"; then
- echo "$as_me:$LINENO: checking for file" >&5
-echo $ECHO_N "checking for file... $ECHO_C" >&6
-else
- if test -f $ac_dir/file; then
- lt_cv_path_MAGIC_CMD="$ac_dir/file"
- "file_magic "*)
- else
- cat <<EOF 1>&2
-EOF
- fi ;;
- esac
- fi
- break
- fi
- done
-esac
-fi
-else
-fi
- else
- MAGIC_CMD=:
- fi
-fi
- fi
-esac
-enable_dlopen=no
-enable_win32_dll=no
-fi;
-# Check whether --with-pic or --without-pic was given.
-if test "${with_pic+set}" = set; then
- withval="$with_pic"
- pic_mode="$withval"
-else
- pic_mode=default
-fi;
-test -z "$pic_mode" && pic_mode=default
-# Use C for the default configuration in the libtool script
-tagname=
-lt_save_CC="$CC"
-ac_ext=c
-# Source file extension for C test sources.
-ac_ext=c
-# Object file extension for compiled C test sources.
-objext=o
-objext=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(){return(0);}\n'
-LTCC=${LTCC-"$CC"}
-compiler=$CC
-# save warnings/boilerplate of simple test code
-ac_outfile=conftest.$ac_objext
-printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$rm conftest*
-printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$rm conftest*
-lt_prog_compiler_no_builtin_flag=
- lt_prog_compiler_no_builtin_flag=' -fno-builtin'
-echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
-else
- lt_cv_prog_compiler_rtti_exceptions=no
- ac_outfile=conftest.$ac_objext
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="-fno-rtti -fno-exceptions"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:6480: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:6484: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_rtti_exceptions=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
-if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
- lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
-else
-fi
-fi
-lt_prog_compiler_wl=
-lt_prog_compiler_pic=
-lt_prog_compiler_static=
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- if test "$GCC" = yes; then
- lt_prog_compiler_wl='-Wl,'
- lt_prog_compiler_static='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_prog_compiler_pic='-DDLL_EXPORT'
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic='-fno-common'
- interix3*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared=no
- enable_shared=no
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_prog_compiler_pic=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic='-fPIC'
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
- fi
- darwin*)
- case $cc_basename in
- xlc*)
- lt_prog_compiler_pic='-qnocommon'
- esac
- hpux9* | hpux10* | hpux11*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static='${wl}-a ${wl}archive'
- irix5* | irix6* | nonstopux*)
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static='-non_shared'
- newsos6)
- lt_prog_compiler_pic='-KPIC'
- linux*)
- icc* | ecc*)
- pgcc* | pgf77* | pgf90* | pgf95*)
- # Portland Group compilers (*not* the Pentium gcc compiler,
- # which looks to be a dead project)
- lt_prog_compiler_pic='-fpic'
- ccc*)
- # All Alpha code is PIC.
- esac
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- solaris*)
- f77* | f90* | f95*)
- lt_prog_compiler_wl='-Qoption ld ';;
- lt_prog_compiler_wl='-Wl,';;
- esac
- sunos4*)
- lt_prog_compiler_pic='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3*)
- sysv4*MP*)
- if test -d /usr/nec ;then
- lt_prog_compiler_pic='-Kconform_pic'
- fi
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- unicos*)
- uts4*)
- lt_prog_compiler_pic='-pic'
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic" >&6
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works+set}" = set; then
-else
- lt_prog_compiler_pic_works=no
- lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
- (eval echo "\"\$as_me:6748: $lt_compile\"" >&5)
- ac_status=$?
- echo "$as_me:6752: \$? = $ac_status" >&5
- lt_prog_compiler_pic_works=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
-if test x"$lt_prog_compiler_pic_works" = xyes; then
- case $lt_prog_compiler_pic in
- *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
- esac
-else
-fi
-fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
-esac
-# Check to make sure the static flag actually works.
-wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
-if test "${lt_prog_compiler_static_works+set}" = set; then
-else
- lt_prog_compiler_static_works=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
- printf "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- # Append any errors to the config.log.
- cat conftest.err 1>&5
- $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- lt_prog_compiler_static_works=yes
- fi
- else
- fi
- fi
- $rm conftest*
- LDFLAGS="$save_LDFLAGS"
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
-echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
-if test x"$lt_prog_compiler_static_works" = xyes; then
-else
-fi
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_c_o+set}" = set; then
-else
- lt_cv_prog_compiler_c_o=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval echo "\"\$as_me:6852: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- echo "$as_me:6856: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_c_o=yes
- fi
- fi
- chmod u+w . 2>&5
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
- runpath_var=
- allow_undefined_flag=
- enable_shared_with_static_runtimes=no
- archive_cmds=
- archive_expsym_cmds=
- old_archive_From_new_cmds=
- old_archive_from_expsyms_cmds=
- export_dynamic_flag_spec=
- whole_archive_flag_spec=
- thread_safe_flag_spec=
- hardcode_libdir_flag_spec=
- hardcode_libdir_flag_spec_ld=
- hardcode_libdir_separator=
- hardcode_direct=no
- hardcode_minus_L=no
- hardcode_shlibpath_var=unsupported
- link_all_deplibs=unknown
- hardcode_automatic=no
- module_cmds=
- module_expsym_cmds=
- always_export_symbols=no
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- # Just being paranoid about ensuring that cc_basename is set.
- for cc_temp in $compiler""; do
- case $cc_temp in
- *) break;;
- esac
-done
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- interix*)
- # we just hope/assume this is gcc and not c89 (= MSVC++)
- with_gnu_ld=yes
- openbsd*)
- with_gnu_ld=no
- esac
- ld_shlibs=yes
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # Set some defaults for GNU ld with shared library support. These
- # are reset later if shared libraries are not supported. Putting them
- # here allows them to be overridden if necessary.
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- if test "$host_cpu" != ia64; then
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec='-L$libdir'
- hardcode_minus_L=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- ld_shlibs=no
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs=no
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
- # as there is no search path for DLLs.
- enable_shared_with_static_runtimes=yes
- export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- ld_shlibs=no
- fi
- interix3*)
- hardcode_shlibpath_var=no
- hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
- export_dynamic_flag_spec='${wl}-E'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- linux*)
- tmp_addflag=
- case $cc_basename,$host_cpu in
- pgcc*) # Portland Group C compiler
- whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
- tmp_addflag=' $pic_flag'
- pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
- tmp_addflag=' $pic_flag -Mnomain' ;;
- ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
- tmp_addflag=' -i_dynamic' ;;
- efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
- tmp_addflag=' -i_dynamic -nofor_main' ;;
- ifc* | ifort*) # Intel Fortran compiler
- tmp_addflag=' -nofor_main' ;;
- esac
- archive_cmds='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test $supports_anon_versioning = yes; then
- archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- $echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- else
- ld_shlibs=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- ld_shlibs=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs=no
- fi
- sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
- case `$LD -v 2>&1` in
- *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
- ld_shlibs=no
- cat <<_LT_EOF 1>&2
-*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
-*** reliably create shared libraries on SCO systems. Therefore, libtool
-*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
-_LT_EOF
- hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
- archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
- else
- ld_shlibs=no
- fi
- esac
- sunos4*)
- archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct=yes
- else
- ld_shlibs=no
- fi
- esac
- if test "$ld_shlibs" = no; then
- runpath_var=
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols=yes
- archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds=''
- hardcode_libdir_separator=':'
- link_all_deplibs=yes
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- { ac_try='test -z "$ac_c_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag="-z nodefs"
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag=' ${wl}-bernotok'
- allow_undefined_flag=' ${wl}-berok'
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec='$convenience'
- archive_cmds_need_lc=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs=no
- bsdi[45]*)
- export_dynamic_flag_spec=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- shrext_cmds=".dll"
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_From_new_cmds='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path='`cygpath -w "$srcfile"`'
- case $host_os in
- rhapsody* | darwin1.[012])
- allow_undefined_flag='${wl}-undefined ${wl}suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag='${wl}-undefined ${wl}dynamic_lookup'
- esac
- fi
- esac
- archive_cmds_need_lc=no
- hardcode_automatic=yes
- whole_archive_flag_spec=''
- if test "$GCC" = yes ; then
- output_verbose_link_cmd='echo'
- archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
- archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- module_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- xlc*)
- archive_cmds='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
- archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- ld_shlibs=no
- esac
- fi
- dgux*)
- archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- ld_shlibs=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu | dragonfly*)
- archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- fi
- if test "$with_gnu_ld" = no; then
- fi
- hpux11*)
- case $host_cpu in
- hppa*64*)
- archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- case $host_cpu in
- hppa*64*)
- archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- hardcode_libdir_flag_spec_ld='+b $libdir'
- esac
- fi
- archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec_ld='-rpath $libdir'
- fi
- hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
- netbsd*)
- archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- os2*)
- archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag=' -expect_unresolved \*'
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec='-rpath $libdir'
- fi
- solaris*)
- no_undefined_flag=' -z text'
- wlarc='${wl}'
- archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- wlarc=''
- archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The compiler driver will combine linker options so we
- # cannot just pass the convience library names through
- # without $wl, iff we do not link with $LD.
- # Luckily, gcc supports the same syntax we need for Sun Studio.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- case $wlarc in
- whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
- whole_archive_flag_spec='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
- esac ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- case $host_vendor in
- sni)
- hardcode_direct=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec='-Bexport'
- sysv4*MP*)
- hardcode_runpath_var=yes
- ld_shlibs=yes
- fi
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
- no_undefined_flag='${wl}-z,text'
- archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- allow_undefined_flag='${wl}-z,nodefs'
- hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
- export_dynamic_flag_spec='${wl}-Bexport'
- archive_cmds='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- uts4*)
- ld_shlibs=no
- esac
- fi
-echo "$as_me:$LINENO: result: $ld_shlibs" >&5
-echo "${ECHO_T}$ld_shlibs" >&6
-test "$ld_shlibs" = no && can_build_shared=no
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl
- pic_flag=$lt_prog_compiler_pic
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag=$lt_save_allow_undefined_flag
- else
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
-echo "${ECHO_T}$archive_cmds_need_lc" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-library_names_spec=
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-postuninstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[45]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
- version_type=windows
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[123]*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
- freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
- freebsd*) # from 4.6 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-interix3*)
- need_version=no
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action=
-if test -n "$hardcode_libdir_flag_spec" || \
- test -n "$runpath_var" || \
- test "X$hardcode_automatic" = "Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
- test "$hardcode_minus_L" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action" >&5
-echo "${ECHO_T}$hardcode_action" >&6
-if test "$hardcode_action" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-striplib=
-old_striplib=
-echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
-echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
-if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
- test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
- test -z "$striplib" && striplib="$STRIP --strip-unneeded"
- echo "$as_me:$LINENO: result: yes" >&5
-echo "${ECHO_T}yes" >&6
-else
-# FIXME - insert some real tests, host_os isn't really good enough
- case $host_os in
- darwin*)
- if test -n "$STRIP" ; then
- striplib="$STRIP -x"
- else
- echo "$as_me:$LINENO: result: no" >&5
-echo "${ECHO_T}no" >&6
-fi
- esac
-fi
-if test "x$enable_dlopen" != xyes; then
- enable_dlopen=unknown
- enable_dlopen_self=unknown
- enable_dlopen_self_static=unknown
-else
- lt_cv_dlopen=no
- lt_cv_dlopen_libs=
- case $host_os in
- beos*)
- lt_cv_dlopen="load_add_on"
- lt_cv_dlopen_self=yes
- mingw* | pw32*)
- lt_cv_dlopen="LoadLibrary"
- cygwin*)
- lt_cv_dlopen="dlopen"
- darwin*)
- # if libdl is installed we need to link against it
- echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
-echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
-if test "${ac_cv_lib_dl_dlopen+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-ldl $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-/* Override any gcc2 internal prototype to avoid an error. */
-#ifdef __cplusplus
-extern "C"
-#endif
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- (exit $ac_status); } &&
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dl_dlopen=yes
-else
-ac_cv_lib_dl_dlopen=no
-fi
-LIBS=$ac_check_lib_save_LIBS
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
-if test $ac_cv_lib_dl_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
-else
- lt_cv_dlopen="dyld"
-fi
- echo "$as_me:$LINENO: checking for shl_load" >&5
-echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
-if test "${ac_cv_func_shl_load+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
- For example, HP-UX 11i <limits.h> declares gettimeofday. */
-#define shl_load innocuous_shl_load
-/* System header to define __stub macros and hopefully few prototypes,
- which can conflict with char shl_load (); below.
- Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
- <limits.h> exists even on freestanding compilers. */
-#ifdef __STDC__
-# include <limits.h>
-#else
-# include <assert.h>
-#endif
-#undef shl_load
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-/* The GNU C library defines this for functions which it implements
- to always fail with ENOSYS. Some functions are actually named
- something starting with __ and the normal name is an alias. */
-#if defined (__stub_shl_load) || defined (__stub___shl_load)
-choke me
-#else
-char (*f) () = shl_load;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != shl_load;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_shl_load=yes
-else
-ac_cv_func_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
-echo "${ECHO_T}$ac_cv_func_shl_load" >&6
-if test $ac_cv_func_shl_load = yes; then
- lt_cv_dlopen="shl_load"
-else
- echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
-echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_shl_load+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char shl_load ();
-int
-main ()
-shl_load ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_shl_load=yes
-else
-ac_cv_lib_dld_shl_load=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
-if test $ac_cv_lib_dld_shl_load = yes; then
- lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
-else
- echo "$as_me:$LINENO: checking for dlopen" >&5
-echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
-if test "${ac_cv_func_dlopen+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
-#define dlopen innocuous_dlopen
- which can conflict with char dlopen (); below.
-#ifdef __STDC__
-#else
-#endif
-#undef dlopen
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-#if defined (__stub_dlopen) || defined (__stub___dlopen)
-choke me
-#else
-char (*f) () = dlopen;
-#endif
-#ifdef __cplusplus
-#endif
-int
-main ()
-return f != dlopen;
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_func_dlopen=yes
-else
-ac_cv_func_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
-echo "${ECHO_T}$ac_cv_func_dlopen" >&6
-if test $ac_cv_func_dlopen = yes; then
-else
-else
-LIBS="-ldl $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-else
-fi
-fi
-else
- echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
-echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
-if test "${ac_cv_lib_svld_dlopen+set}" = set; then
-else
-LIBS="-lsvld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dlopen ();
-int
-main ()
-dlopen ();
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_cv_lib_svld_dlopen=yes
-else
-ac_cv_lib_svld_dlopen=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
-echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
-if test $ac_cv_lib_svld_dlopen = yes; then
- lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
-else
- echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
-echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
-if test "${ac_cv_lib_dld_dld_link+set}" = set; then
-else
-LIBS="-ldld $LIBS"
-/* confdefs.h. */
-_ACEOF
-#ifdef __cplusplus
-extern "C"
-#endif
-char dld_link ();
-int
-main ()
-dld_link ();
- return 0;
-_ACEOF
- ac_status=$?
- cat conftest.err >&5
- ac_status=$?
- ac_status=$?
- ac_cv_lib_dld_dld_link=yes
-else
-ac_cv_lib_dld_dld_link=no
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
-echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
-if test $ac_cv_lib_dld_dld_link = yes; then
- lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
-fi
-fi
-fi
-fi
-fi
-fi
- esac
- if test "x$lt_cv_dlopen" != xno; then
- enable_dlopen=yes
- else
- enable_dlopen=no
- fi
- case $lt_cv_dlopen in
- dlopen)
- save_CPPFLAGS="$CPPFLAGS"
- test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
- save_LIBS="$LIBS"
- LIBS="$lt_cv_dlopen_libs $LIBS"
- echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
-echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self+set}" = set; then
-else
- if test "$cross_compiling" = yes; then :
- lt_cv_dlopen_self=cross
-else
- lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
- lt_status=$lt_dlunknown
- cat > conftest.$ac_ext <<EOF
-#line 9197 "configure"
-#include "confdefs.h"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-# define LT_DLGLOBAL RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# define LT_DLGLOBAL DL_GLOBAL
-# else
-# define LT_DLGLOBAL 0
-# endif
-#endif
-/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
- find out it does not work in some platform. */
-#ifndef LT_DLLAZY_OR_NOW
-# ifdef RTLD_LAZY
-# define LT_DLLAZY_OR_NOW RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# define LT_DLLAZY_OR_NOW DL_LAZY
-# else
-# ifdef RTLD_NOW
-# define LT_DLLAZY_OR_NOW RTLD_NOW
-# else
-# ifdef DL_NOW
-# define LT_DLLAZY_OR_NOW DL_NOW
-# else
-# define LT_DLLAZY_OR_NOW 0
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-extern "C" void exit (int);
-#endif
-void fnord() { int i=42;}
-int main ()
- void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
- int status = $lt_dlunknown;
- if (self)
- if (dlsym (self,"fnord")) status = $lt_dlno_uscore;
- else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
- /* dlclose (self); */
- else
- puts (dlerror ());
- exit (status);
-EOF
- if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>&5
- ac_status=$?
- (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
- (./conftest; exit; ) >&5 2>/dev/null
- lt_status=$?
- case x$lt_status in
- x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
- x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
- esac
- else :
- # compilation failed
- lt_cv_dlopen_self=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self" >&6
- if test "x$lt_cv_dlopen_self" = xyes; then
- wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
- echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
-echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
-if test "${lt_cv_dlopen_self_static+set}" = set; then
-else
- lt_cv_dlopen_self_static=cross
-else
-#line 9297 "configure"
-#if HAVE_DLFCN_H
-#include <dlfcn.h>
-#endif
-#include <stdio.h>
-#ifdef RTLD_GLOBAL
-#else
-# ifdef DL_GLOBAL
-# else
-# endif
-#endif
-# ifdef RTLD_LAZY
-# else
-# ifdef DL_LAZY
-# else
-# ifdef RTLD_NOW
-# else
-# ifdef DL_NOW
-# else
-# endif
-# endif
-# endif
-# endif
-#endif
-#ifdef __cplusplus
-#endif
-int main ()
- if (self)
- else
- exit (status);
-EOF
- ac_status=$?
- lt_status=$?
- x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
- x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
- esac
- else :
- lt_cv_dlopen_self_static=no
- fi
-fi
-rm -fr conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
-echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
- fi
- CPPFLAGS="$save_CPPFLAGS"
- LIBS="$save_LIBS"
- esac
- case $lt_cv_dlopen_self in
- yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
- *) enable_dlopen_self=unknown ;;
- esac
- case $lt_cv_dlopen_self_static in
- yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
- *) enable_dlopen_self_static=unknown ;;
- esac
-fi
-# Report which library types will actually be built
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case $host_os in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4* | aix5*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler \
- CC \
- LD \
- lt_prog_compiler_wl \
- lt_prog_compiler_pic \
- lt_prog_compiler_static \
- lt_prog_compiler_no_builtin_flag \
- export_dynamic_flag_spec \
- thread_safe_flag_spec \
- whole_archive_flag_spec \
- enable_shared_with_static_runtimes \
- old_archive_cmds \
- old_archive_from_new_cmds \
- predep_objects \
- postdep_objects \
- predeps \
- postdeps \
- compiler_lib_search_path \
- archive_cmds \
- archive_expsym_cmds \
- postinstall_cmds \
- postuninstall_cmds \
- old_archive_from_expsyms_cmds \
- allow_undefined_flag \
- no_undefined_flag \
- export_symbols_cmds \
- hardcode_libdir_flag_spec \
- hardcode_libdir_flag_spec_ld \
- hardcode_libdir_separator \
- hardcode_automatic \
- module_cmds \
- module_expsym_cmds \
- lt_cv_prog_compiler_c_o \
- exclude_expsyms \
- include_expsyms; do
- case $var in
- old_archive_cmds | \
- old_archive_from_new_cmds | \
- archive_cmds | \
- archive_expsym_cmds | \
- module_cmds | \
- module_expsym_cmds | \
- old_archive_from_expsyms_cmds | \
- export_symbols_cmds | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="${ofile}T"
- trap "$rm \"$cfgfile\"; exit 1" 1 2 15
- $rm -f "$cfgfile"
- { echo "$as_me:$LINENO: creating $ofile" >&5
-echo "$as_me: creating $ofile" >&6;}
- cat <<__EOF__ >> "$cfgfile"
-#! $SHELL
-# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
-# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
-# NOTE: Changes made to this file will be lost: look at ltmain.sh.
-# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
-# Free Software Foundation, Inc.
-# This file is part of GNU Libtool:
-# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful, but
-# WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
-# General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
-# As a special exception to the GNU General Public License, if you
-# distribute this file as part of a program that contains a
-# configuration script generated by Autoconf, you may include it under
-# the same distribution terms that you use for the rest of that program.
-# A sed program that does not truncate output.
-SED=$lt_SED
-# Sed that helps us avoid accidentally triggering echo(1) options like -n.
-Xsed="$SED -e 1s/^X//"
-# The HP-UX ksh and POSIX shell print the target directory to stdout
-# if CDPATH is set.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# The names of the tagged configurations supported by this script.
-available_tags=
-# ### BEGIN LIBTOOL CONFIG
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-host_os=$host_os
-# The build system.
-build_alias=$build_alias
-build=$build
-build_os=$build_os
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# LTCC compiler flags.
-LTCFLAGS=$lt_LTCFLAGS
-# A language-specific compiler.
-CC=$lt_compiler
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o
-# Must we lock files when doing compilation?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds
-archive_expsym_cmds=$lt_archive_expsym_cmds
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds
-module_expsym_cmds=$lt_module_expsym_cmds
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects
-# shared library.
-predeps=$lt_predeps
-# shared library.
-postdeps=$lt_postdeps
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms
-# ### END LIBTOOL CONFIG
-__EOF__
- case $host_os in
- aix3*)
- cat <<\EOF >> "$cfgfile"
-# AIX sometimes has problems with the GCC collect2 program. For some
-# reason, if we set the COLLECT_NAMES environment variable, the problems
-# vanish in a puff of smoke.
-if test "X${COLLECT_NAMES+set}" != Xset; then
- COLLECT_NAMES=
- export COLLECT_NAMES
-fi
-EOF
- esac
- # We use sed instead of cat because bash on DJGPP gets confused if
- # if finds mixed CR/LF and LF-only lines. Since sed operates in
- # text mode, it properly converts lines to CR/LF. This bash problem
- # is reportedly fixed, but why not run on old versions too?
- sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
- mv -f "$cfgfile" "$ofile" || \
- (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
- chmod +x "$ofile"
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-CC="$lt_save_CC"
-# Check whether --with-tags or --without-tags was given.
-if test "${with_tags+set}" = set; then
- withval="$with_tags"
- tagnames="$withval"
-fi;
-if test -f "$ltmain" && test -n "$tagnames"; then
- if test ! -f "${ofile}"; then
- { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
-echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
- fi
- if test -z "$LTCC"; then
- eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
- { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
-echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
- else
- { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
-echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
- fi
- fi
- if test -z "$LTCFLAGS"; then
- eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
- fi
- # Extract list of available tagged configurations in $ofile.
- # Note that this assumes the entire list is on one line.
- available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
- lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
- for tagname in $tagnames; do
- IFS="$lt_save_ifs"
- # Check whether tagname contains only valid characters
- case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
- *) { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
-echo "$as_me: error: invalid tag name: $tagname" >&2;}
- { (exit 1); exit 1; }; }
- esac
- if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
- then
- { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
-echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
- fi
- # Update the list of available tags.
- if test -n "$tagname"; then
- echo appending configuration tag \"$tagname\" to $ofile
- case $tagname in
- CXX)
- if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
- ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
- (test "X$CXX" != "Xg++"))) ; then
- ac_ext=cc
-ac_cpp='$CXXCPP $CPPFLAGS'
-ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
-archive_cmds_need_lc_CXX=no
-allow_undefined_flag_CXX=
-always_export_symbols_CXX=no
-archive_expsym_cmds_CXX=
-export_dynamic_flag_spec_CXX=
-hardcode_direct_CXX=no
-hardcode_libdir_flag_spec_CXX=
-hardcode_libdir_flag_spec_ld_CXX=
-hardcode_libdir_separator_CXX=
-hardcode_minus_L_CXX=no
-hardcode_shlibpath_var_CXX=unsupported
-hardcode_automatic_CXX=no
-module_cmds_CXX=
-module_expsym_cmds_CXX=
-link_all_deplibs_CXX=unknown
-old_archive_cmds_CXX=$old_archive_cmds
-no_undefined_flag_CXX=
-whole_archive_flag_spec_CXX=
-enable_shared_with_static_runtimes_CXX=no
-# Dependencies to place before and after the object being linked:
-predep_objects_CXX=
-postdep_objects_CXX=
-predeps_CXX=
-postdeps_CXX=
-compiler_lib_search_path_CXX=
-# Source file extension for C++ test sources.
-ac_ext=cpp
-# Object file extension for compiled C++ test sources.
-objext=o
-objext_CXX=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="int some_variable = 0;\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# save warnings/boilerplate of simple test code
-ac_outfile=conftest.$ac_objext
-printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$rm conftest*
-printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$rm conftest*
-lt_save_CC=$CC
-lt_save_LD=$LD
-lt_save_GCC=$GCC
-GCC=$GXX
-lt_save_with_gnu_ld=$with_gnu_ld
-lt_save_path_LD=$lt_cv_path_LD
-if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
- lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
-else
- $as_unset lt_cv_prog_gnu_ld
-fi
-if test -n "${lt_cv_path_LDCXX+set}"; then
- lt_cv_path_LD=$lt_cv_path_LDCXX
-else
- $as_unset lt_cv_path_LD
-fi
-test -z "${LDCXX+set}" || LD=$LDCXX
-CC=${CXX-"c++"}
-compiler=$CC
-compiler_CXX=$CC
-for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-# We don't want -fno-exception wen compiling C++ code, so set the
-# no_builtin_flag separately
-if test "$GXX" = yes; then
- lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
-else
-fi
- # Set up default GNU C++ configuration
-# Check whether --with-gnu-ld or --without-gnu-ld was given.
-if test "${with_gnu_ld+set}" = set; then
- withval="$with_gnu_ld"
- test "$withval" = no || with_gnu_ld=yes
-else
- with_gnu_ld=no
-fi;
-ac_prog=ld
- # Check if gcc -print-prog-name=ld gives a path.
- echo "$as_me:$LINENO: checking for ld used by $CC" >&5
-echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
- case $host in
- *-*-mingw*)
- # gcc leaves a trailing carriage return which upsets mingw
- ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
- ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
- esac
- case $ac_prog in
- # Accept absolute paths.
- re_direlt='/[^/][^/]*/\.\./'
- # Canonicalize the pathname of ld
- ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
- while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
- ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
- done
- test -z "$LD" && LD="$ac_prog"
- # If it fails, then pretend we aren't using GCC.
- ac_prog=ld
- # If it is relative, then search for the first ld in PATH.
- with_gnu_ld=unknown
- esac
-elif test "$with_gnu_ld" = yes; then
- echo "$as_me:$LINENO: checking for GNU ld" >&5
-echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
-else
- echo "$as_me:$LINENO: checking for non-GNU ld" >&5
-echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
-fi
-if test "${lt_cv_path_LD+set}" = set; then
-else
- if test -z "$LD"; then
- lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
- for ac_dir in $PATH; do
- test -z "$ac_dir" && ac_dir=.
- if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
- lt_cv_path_LD="$ac_dir/$ac_prog"
- # Check to see if the program is GNU ld. I'd rather use --version,
- # but apparently some variants of GNU ld only accept -v.
- # Break only if it was the GNU/non-GNU ld that we prefer.
- case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
- *GNU* | *'with BFD'*)
- test "$with_gnu_ld" != no && break
- test "$with_gnu_ld" != yes && break
- esac
- fi
- done
-else
- lt_cv_path_LD="$LD" # Let the user override the test with a path.
-fi
-fi
-LD="$lt_cv_path_LD"
-if test -n "$LD"; then
- echo "$as_me:$LINENO: result: $LD" >&5
-echo "${ECHO_T}$LD" >&6
-else
-fi
-test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
-echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
-echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
-echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
-if test "${lt_cv_prog_gnu_ld+set}" = set; then
-else
- # I'd rather use --version here, but apparently some GNU lds only accept -v.
-case `$LD -v 2>&1 </dev/null` in
-*GNU* | *'with BFD'*)
- lt_cv_prog_gnu_ld=yes
- lt_cv_prog_gnu_ld=no
-esac
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
-echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
-with_gnu_ld=$lt_cv_prog_gnu_ld
- # Check if GNU C++ uses GNU ld as the underlying linker, since the
- # archiving commands below assume that GNU ld is being used.
- if test "$with_gnu_ld" = yes; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
- # If archive_cmds runs LD, not CC, wlarc should be empty
- # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
- # investigate it a little bit more. (MM)
- wlarc='${wl}'
- # ancient GNU ld didn't support --whole-archive et. al.
- if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
- grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- else
- with_gnu_ld=no
- wlarc=
- # A generic and very simple default shared library creation
- # command for GNU C++ for the case where it uses the native
- # linker, instead of GNU ld. If possible, this setting should
- # overridden to take advantage of the native linker features on
- # the platform it is being used on.
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- fi
- # Commands to make compiler produce verbose output that lists
- # what "hidden" libraries, object files and flags are used when
- # linking a shared library.
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
-else
- GXX=no
- with_gnu_ld=no
- wlarc=
-fi
-# PORTME: fill in a description of your system's C++ link characteristics
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
-ld_shlibs_CXX=yes
-case $host_os in
- aix3*)
- # FIXME: insert proper C++ library support
- ld_shlibs_CXX=no
- aix4* | aix5*)
- if test "$host_cpu" = ia64; then
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- case $ld_flag in
- *-brtl*)
- aix_use_runtimelinking=yes
- break
- esac
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_CXX=''
- hardcode_direct_CXX=yes
- hardcode_libdir_separator_CXX=':'
- link_all_deplibs_CXX=yes
- if test "$GXX" = yes; then
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- hardcode_direct_CXX=unsupported
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- hardcode_minus_L_CXX=yes
- hardcode_libdir_flag_spec_CXX='-L$libdir'
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- always_export_symbols_CXX=yes
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_CXX='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- { ac_try='test -z "$ac_cxx_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_CXX="-z nodefs"
- archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_CXX=' ${wl}-bernotok'
- allow_undefined_flag_CXX=' ${wl}-berok'
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_CXX='$convenience'
- archive_cmds_need_lc_CXX=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag_CXX=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs_CXX=no
- fi
- chorus*)
- case $cc_basename in
- ld_shlibs_CXX=no
- esac
- cygwin* | mingw* | pw32*)
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
- # as there is no search path for DLLs.
- always_export_symbols_CXX=no
- enable_shared_with_static_runtimes_CXX=yes
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- ld_shlibs_CXX=no
- fi
- darwin* | rhapsody*)
- case $host_os in
- rhapsody* | darwin1.[012])
- allow_undefined_flag_CXX='${wl}-undefined ${wl}suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag_CXX='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag_CXX='${wl}-undefined ${wl}dynamic_lookup'
- esac
- fi
- esac
- archive_cmds_need_lc_CXX=no
- hardcode_direct_CXX=no
- hardcode_automatic_CXX=yes
- hardcode_shlibpath_var_CXX=unsupported
- whole_archive_flag_spec_CXX=''
- if test "$GXX" = yes ; then
- lt_int_apple_cc_single_mod=no
- output_verbose_link_cmd='echo'
- if $CC -dumpspecs 2>&1 | $EGREP 'single_module' >/dev/null ; then
- lt_int_apple_cc_single_mod=yes
- fi
- if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
- archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- else
- archive_cmds_CXX='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- fi
- module_cmds_CXX='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
- archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- fi
- module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- xlc*)
- archive_cmds_CXX='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
- archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- ld_shlibs_CXX=no
- esac
- fi
- dgux*)
- ec++*)
- ld_shlibs_CXX=no
- ghcx*)
- # Green Hills C++ Compiler
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- freebsd[12]*)
- # C++ shared libraries reported to be fairly broken before switch to ELF
- ld_shlibs_CXX=no
- freebsd-elf*)
- freebsd* | kfreebsd*-gnu | dragonfly*)
- # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
- # conventions
- ld_shlibs_CXX=yes
- gnu*)
- hpux9*)
- hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_CXX=:
- export_dynamic_flag_spec_CXX='${wl}-E'
- hardcode_minus_L_CXX=yes # Not in the search PATH,
- # but as the default
- # location of the library.
- CC*)
- ld_shlibs_CXX=no
- aCC*)
- archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- # There doesn't appear to be a way to prevent this compiler from
- # explicitly linking system object files so we need to strip them
- # from the output so that they don't get included in the library
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "[-]L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- hpux10*|hpux11*)
- if test $with_gnu_ld = no; then
- case $host_cpu in
- hppa*64*|ia64*)
- hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- hardcode_shlibpath_var_CXX=no
- esac
- CC*)
- ld_shlibs_CXX=no
- aCC*)
- case $host_cpu in
- hppa*64*)
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- # dependencies.
- output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- case $host_cpu in
- hppa*64*)
- archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- ia64*)
- archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- esac
- fi
- else
- ld_shlibs_CXX=no
- fi
- esac
- interix3*)
- hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- irix5* | irix6*)
- CC*)
- # SGI C++
- archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- # Archives containing C++ object files must be created using
- # "CC -ar", where "CC" is the IRIX C++ compiler. This is
- # necessary to make sure instantiated templates are included
- # in the archive.
- old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
- if test "$with_gnu_ld" = no; then
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
- fi
- fi
- esac
- hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
- linux*)
- KCC*)
- # Kuck and Associates, Inc. (KAI) C++ Compiler
- # KCC will only create a shared library if the output file
- # ends with ".so" (or ".sl" for HP-UX), so rename the library
- # to its proper name (with version) after linking.
- archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
- archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
- # "CC -Bstatic", where "CC" is the KAI C++ compiler.
- old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
- icpc*)
- # Intel C++
- with_gnu_ld=yes
- # version 8.0 and above of icpc choke on multiply defined symbols
- # if we add $predep_objects and $postdep_objects, however 7.1 and
- # earlier do not add the objects themselves.
- case `$CC -V 2>&1` in
- *"Version 7."*)
- archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- *) # Version 8.0 or newer
- tmp_idyn=
- case $host_cpu in
- ia64*) tmp_idyn=' -i_dynamic';;
- esac
- archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- esac
- whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
- pgCC*)
- # Portland Group C++ compiler
- archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
- archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
- whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
- cxx*)
- # Compaq C++
- archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_CXX='-rpath $libdir'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- esac
- lynxos*)
- ld_shlibs_CXX=no
- m88k*)
- ld_shlibs_CXX=no
- mvs*)
- cxx*)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds_CXX='$LD -Bshareable -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
- wlarc=
- hardcode_libdir_flag_spec_CXX='-R$libdir'
- fi
- # Workaround some broken pre-1.5 toolchains
- output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
- openbsd2*)
- # C++ shared libraries are fairly broken
- ld_shlibs_CXX=no
- openbsd*)
- archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
- fi
- osf3*)
- KCC*)
- RCC*)
- # Rational C++ 2.4.1
- ld_shlibs_CXX=no
- cxx*)
- allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- # dependencies.
- output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
- if test "$GXX" = yes && test "$with_gnu_ld" = no; then
- archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- osf4* | osf5*)
- KCC*)
- # the KAI C++ compiler.
- old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
- RCC*)
- ld_shlibs_CXX=no
- cxx*)
- allow_undefined_flag_CXX=' -expect_unresolved \*'
- archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
- echo "-hidden">> $lib.exp~
- $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~
- $rm $lib.exp'
- # dependencies.
- archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- ld_shlibs_CXX=no
- fi
- esac
- psos*)
- ld_shlibs_CXX=no
- sunos4*)
- CC*)
- # Sun C++ 4.x
- ld_shlibs_CXX=no
- lcc*)
- # Lucid
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- solaris*)
- CC*)
- # Sun C++ 4.2, 5.x and Centerline C++
- no_undefined_flag_CXX=' -zdefs'
- archive_cmds_CXX='$CC -G${allow_undefined_flag} -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
- archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -G${allow_undefined_flag} ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The C++ compiler is used as linker so we must use $wl
- # flag to pass the commands to the underlying system
- # linker. We must also pass each convience library through
- # to the system linker between allextract/defaultextract.
- # The C++ compiler will combine linker options so we
- # cannot just pass the convience library names through
- # without $wl.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract'
- esac
- # "CC -xar", where "CC" is the Sun C++ compiler. This is
- # in the archive.
- old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
- gcx*)
- archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- # The C++ compiler must be used to create the archive.
- old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
- # GNU C++ compiler with Solaris linker
- no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
- if $CC --version | grep -v '^2\.7' > /dev/null; then
- archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- else
- # g++ 2.7 appears to require `-G' NOT `-shared' on this
- # platform.
- archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
- $CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
- output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
- fi
- hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
- fi
- esac
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
- no_undefined_flag_CXX='${wl}-z,text'
- runpath_var='LD_RUN_PATH'
- CC*)
- archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- esac
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- # For security reasons, it is highly recommended that you always
- # use absolute paths for naming shared libraries, and exclude the
- # DT_RUNPATH tag from executables and libraries. But doing so
- # requires that you compile everything twice, which is a pain.
- # So that behaviour is only enabled if SCOABSPATH is set to a
- # non-empty value in the environment. Most likely only useful for
- # creating official distributions of packages.
- # This is a hack until libtool officially supports absolute path
- # names for shared libraries.
- allow_undefined_flag_CXX='${wl}-z,nodefs'
- hardcode_libdir_flag_spec_CXX='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
- export_dynamic_flag_spec_CXX='${wl}-Bexport'
- CC*)
- archive_cmds_CXX='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_CXX='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- esac
- tandem*)
- NCC*)
- # NonStop-UX NCC 3.20
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
- esac
- vxworks*)
- ld_shlibs_CXX=no
- ld_shlibs_CXX=no
-esac
-echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
-echo "${ECHO_T}$ld_shlibs_CXX" >&6
-test "$ld_shlibs_CXX" = no && can_build_shared=no
-GCC_CXX="$GXX"
-LD_CXX="$LD"
-cat > conftest.$ac_ext <<EOF
-class Foo
-public:
- Foo (void) { a = 0; }
-private:
- int a;
-EOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); }; then
- # Parse the compiler output and extract the necessary
- # objects, libraries and library flags.
- # Sentinel used to keep track of whether or not we are before
- # the conftest object file.
- pre_test_object_deps_done=no
- # The `*' in the case matches for architectures that use `case' in
- # $output_verbose_cmd can trigger glob expansion during the loop
- # eval without this substitution.
- output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
- for p in `eval $output_verbose_link_cmd`; do
- case $p in
- -L* | -R* | -l*)
- # Some compilers place space between "-{L,R}" and the path.
- # Remove the space.
- if test $p = "-L" \
- || test $p = "-R"; then
- prev=$p
- continue
- else
- prev=
- fi
- if test "$pre_test_object_deps_done" = no; then
- case $p in
- -L* | -R*)
- # Internal compiler library paths should come after those
- # provided the user. The postdeps already come after the
- # user supplied libs so there is no need to process them.
- if test -z "$compiler_lib_search_path_CXX"; then
- compiler_lib_search_path_CXX="${prev}${p}"
- else
- compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
- fi
- # The "-l" case would never come before the object being
- # linked, so don't bother handling this case.
- esac
- else
- if test -z "$postdeps_CXX"; then
- postdeps_CXX="${prev}${p}"
- else
- postdeps_CXX="${postdeps_CXX} ${prev}${p}"
- fi
- fi
- *.$objext)
- # This assumes that the test object file only shows up
- # once in the compiler output.
- if test "$p" = "conftest.$objext"; then
- pre_test_object_deps_done=yes
- continue
- fi
- if test -z "$predep_objects_CXX"; then
- predep_objects_CXX="$p"
- else
- predep_objects_CXX="$predep_objects_CXX $p"
- fi
- else
- if test -z "$postdep_objects_CXX"; then
- postdep_objects_CXX="$p"
- else
- postdep_objects_CXX="$postdep_objects_CXX $p"
- fi
- fi
- *) ;; # Ignore the rest.
- esac
- done
- # Clean up.
- rm -f a.out a.exe
-else
- echo "libtool.m4: error: problem compiling CXX test program"
-fi
-$rm -f confest.$objext
-# PORTME: override above test on systems where it is broken
-case $host_os in
-interix3*)
- # Interix 3.5 installs completely hosed .la files for C++, so rather than
- # hack all around it, let's just trust "g++" to DTRT.
- postdeps_CXX=
-solaris*)
- CC*)
- # Adding this requires a known-good setup of shared libraries for
- # Sun compiler versions before 5.6, else PIC objects from an old
- # archive will be linked into the output, leading to subtle bugs.
- postdeps_CXX='-lCstd -lCrun'
- esac
-esac
-case " $postdeps_CXX " in
-*" -lc "*) archive_cmds_need_lc_CXX=no ;;
-esac
-lt_prog_compiler_wl_CXX=
-lt_prog_compiler_pic_CXX=
-lt_prog_compiler_static_CXX=
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- # C++ specific cases for pic, static, wl, etc.
- lt_prog_compiler_wl_CXX='-Wl,'
- lt_prog_compiler_static_CXX='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static_CXX='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | os2* | pw32*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic_CXX='-fno-common'
- *djgpp*)
- # DJGPP does not support shared libraries at all
- interix3*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- sysv4*MP*)
- if test -d /usr/nec; then
- lt_prog_compiler_pic_CXX=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case $host_cpu in
- hppa*64*|ia64*)
- lt_prog_compiler_pic_CXX='-fPIC'
- esac
- esac
- else
- case $host_os in
- aix4* | aix5*)
- else
- lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
- fi
- chorus*)
- cxch68*)
- # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
- esac
- darwin*)
- xlc*)
- lt_prog_compiler_pic_CXX='-qnocommon'
- esac
- dgux*)
- ec++*)
- lt_prog_compiler_pic_CXX='-KPIC'
- ghcx*)
- lt_prog_compiler_pic_CXX='-pic'
- esac
- # FreeBSD uses GNU C++
- hpux9* | hpux10* | hpux11*)
- CC*)
- lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
- if test "$host_cpu" != ia64; then
- lt_prog_compiler_pic_CXX='+Z'
- fi
- aCC*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- esac
- esac
- interix*)
- # This is c89, which is MS Visual C++ (no shared libs)
- # Anyone wants to do a port?
- irix5* | irix6* | nonstopux*)
- CC*)
- lt_prog_compiler_static_CXX='-non_shared'
- # CC pic flag -KPIC is the default.
- esac
- linux*)
- KCC*)
- # KAI C++ Compiler
- lt_prog_compiler_wl_CXX='--backend -Wl,'
- icpc* | ecpc*)
- # Intel C++
- pgCC*)
- # Portland Group C++ compiler.
- lt_prog_compiler_pic_CXX='-fpic'
- cxx*)
- # Compaq C++
- # Make sure the PIC flag is empty. It appears that all Alpha
- # Linux and Compaq Tru64 Unix objects are PIC.
- esac
- lynxos*)
- m88k*)
- mvs*)
- cxx*)
- lt_prog_compiler_pic_CXX='-W c,exportall'
- esac
- netbsd*)
- osf3* | osf4* | osf5*)
- KCC*)
- RCC*)
- cxx*)
- # Digital/Compaq C++
- esac
- psos*)
- solaris*)
- CC*)
- lt_prog_compiler_wl_CXX='-Qoption ld '
- gcx*)
- lt_prog_compiler_pic_CXX='-PIC'
- esac
- sunos4*)
- CC*)
- # Sun C++ 4.x
- lcc*)
- # Lucid
- esac
- tandem*)
- NCC*)
- esac
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- CC*)
- esac
- vxworks*)
- lt_prog_compiler_can_build_shared_CXX=no
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic_CXX"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- lt_prog_compiler_pic_works_CXX=no
- ac_outfile=conftest.$ac_objext
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:11637: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:11641: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- lt_prog_compiler_pic_works_CXX=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
-if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
- case $lt_prog_compiler_pic_CXX in
- *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
- esac
-else
-fi
-fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
-esac
-# Check to make sure the static flag actually works.
-wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
-if test "${lt_prog_compiler_static_works_CXX+set}" = set; then
-else
- lt_prog_compiler_static_works_CXX=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
- printf "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- if test -s conftest.err; then
- # Append any errors to the config.log.
- cat conftest.err 1>&5
- $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- lt_prog_compiler_static_works_CXX=yes
- fi
- else
- fi
- fi
- $rm conftest*
- LDFLAGS="$save_LDFLAGS"
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_CXX" >&5
-echo "${ECHO_T}$lt_prog_compiler_static_works_CXX" >&6
-if test x"$lt_prog_compiler_static_works_CXX" = xyes; then
-else
-fi
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
-else
- lt_cv_prog_compiler_c_o_CXX=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval echo "\"\$as_me:11741: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- echo "$as_me:11745: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_c_o_CXX=yes
- fi
- fi
- chmod u+w . 2>&5
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
- export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- case $host_os in
- aix4* | aix5*)
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- pw32*)
- export_symbols_cmds_CXX="$ltdll_cmds"
- cygwin* | mingw*)
- export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/;/^.* __nm__/s/^.* __nm__\([^ ]*\) [^ ]*/\1 DATA/;/^I /d;/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- esac
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_CXX" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_CXX in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- ac_status=$?
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_CXX
- pic_flag=$lt_prog_compiler_pic_CXX
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
- else
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[45]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[123]*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
- freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
- freebsd*) # from 4.6 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-interix3*)
- need_version=no
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action_CXX=
-if test -n "$hardcode_libdir_flag_spec_CXX" || \
- test -n "$runpath_var_CXX" || \
- test "X$hardcode_automatic_CXX" = "Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct_CXX" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
- test "$hardcode_minus_L_CXX" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_CXX=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_CXX=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_CXX=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
-echo "${ECHO_T}$hardcode_action_CXX" >&6
-if test "$hardcode_action_CXX" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler_CXX \
- CC_CXX \
- LD_CXX \
- lt_prog_compiler_wl_CXX \
- lt_prog_compiler_pic_CXX \
- lt_prog_compiler_static_CXX \
- lt_prog_compiler_no_builtin_flag_CXX \
- export_dynamic_flag_spec_CXX \
- thread_safe_flag_spec_CXX \
- whole_archive_flag_spec_CXX \
- enable_shared_with_static_runtimes_CXX \
- old_archive_cmds_CXX \
- old_archive_from_new_cmds_CXX \
- predep_objects_CXX \
- postdep_objects_CXX \
- predeps_CXX \
- postdeps_CXX \
- compiler_lib_search_path_CXX \
- archive_cmds_CXX \
- archive_expsym_cmds_CXX \
- postinstall_cmds_CXX \
- postuninstall_cmds_CXX \
- old_archive_from_expsyms_cmds_CXX \
- allow_undefined_flag_CXX \
- no_undefined_flag_CXX \
- export_symbols_cmds_CXX \
- hardcode_libdir_flag_spec_CXX \
- hardcode_libdir_flag_spec_ld_CXX \
- hardcode_libdir_separator_CXX \
- hardcode_automatic_CXX \
- module_cmds_CXX \
- module_expsym_cmds_CXX \
- lt_cv_prog_compiler_c_o_CXX \
- exclude_expsyms_CXX \
- include_expsyms_CXX; do
- case $var in
- old_archive_cmds_CXX | \
- old_archive_from_new_cmds_CXX | \
- archive_cmds_CXX | \
- archive_expsym_cmds_CXX | \
- module_cmds_CXX | \
- module_expsym_cmds_CXX | \
- old_archive_from_expsyms_cmds_CXX | \
- export_symbols_cmds_CXX | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="$ofile"
- cat <<__EOF__ >> "$cfgfile"
-# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc_CXX
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-host_os=$host_os
-# The build system.
-build_alias=$build_alias
-build=$build
-build_os=$build_os
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# LTCC compiler flags.
-LTCFLAGS=$lt_LTCFLAGS
-# A language-specific compiler.
-CC=$lt_compiler_CXX
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC_CXX
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD_CXX
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl_CXX
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic_CXX
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
-# Must we lock files when doing compilation?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static_CXX
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_CXX
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds_CXX
-archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds_CXX
-module_expsym_cmds=$lt_module_expsym_cmds_CXX
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects_CXX
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects_CXX
-# shared library.
-predeps=$lt_predeps_CXX
-# shared library.
-postdeps=$lt_postdeps_CXX
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag_CXX
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag_CXX
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action_CXX
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct_CXX
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L_CXX
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic_CXX
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs_CXX
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path_CXX"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols_CXX
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds_CXX
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms_CXX
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms_CXX
-# ### END LIBTOOL TAG CONFIG: $tagname
-__EOF__
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-CC=$lt_save_CC
-LDCXX=$LD
-LD=$lt_save_LD
-GCC=$lt_save_GCC
-with_gnu_ldcxx=$with_gnu_ld
-with_gnu_ld=$lt_save_with_gnu_ld
-lt_cv_path_LDCXX=$lt_cv_path_LD
-lt_cv_path_LD=$lt_save_path_LD
-lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
-lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
- else
- tagname=""
- fi
- F77)
- if test -n "$F77" && test "X$F77" != "Xno"; then
-ac_ext=f
-ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
-ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_f77_compiler_gnu
-archive_cmds_need_lc_F77=no
-allow_undefined_flag_F77=
-always_export_symbols_F77=no
-archive_expsym_cmds_F77=
-export_dynamic_flag_spec_F77=
-hardcode_direct_F77=no
-hardcode_libdir_flag_spec_F77=
-hardcode_libdir_flag_spec_ld_F77=
-hardcode_libdir_separator_F77=
-hardcode_minus_L_F77=no
-hardcode_automatic_F77=no
-module_cmds_F77=
-module_expsym_cmds_F77=
-link_all_deplibs_F77=unknown
-old_archive_cmds_F77=$old_archive_cmds
-no_undefined_flag_F77=
-whole_archive_flag_spec_F77=
-enable_shared_with_static_runtimes_F77=no
-# Source file extension for f77 test sources.
-ac_ext=f
-# Object file extension for compiled f77 test sources.
-objext=o
-objext_F77=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code=" subroutine t\n return\n end\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code=" program t\n end\n"
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# save warnings/boilerplate of simple test code
-ac_outfile=conftest.$ac_objext
-printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$rm conftest*
-printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$rm conftest*
-lt_save_CC="$CC"
-CC=${F77-"f77"}
-compiler=$CC
-compiler_F77=$CC
-for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
-echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
-echo "$as_me:$LINENO: result: $can_build_shared" >&5
-echo "${ECHO_T}$can_build_shared" >&6
-echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
-echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
-test "$can_build_shared" = "no" && enable_shared=no
-# On AIX, shared libraries and static libraries use the same namespace, and
-# are all built from PIC.
-case $host_os in
-aix3*)
- test "$enable_shared" = yes && enable_static=no
- if test -n "$RANLIB"; then
- archive_cmds="$archive_cmds~\$RANLIB \$lib"
- postinstall_cmds='$RANLIB $lib'
- fi
-aix4* | aix5*)
- if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
- fi
-esac
-echo "$as_me:$LINENO: result: $enable_shared" >&5
-echo "${ECHO_T}$enable_shared" >&6
-echo "$as_me:$LINENO: checking whether to build static libraries" >&5
-echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
-# Make sure either enable_shared or enable_static is yes.
-test "$enable_shared" = yes || enable_static=yes
-echo "$as_me:$LINENO: result: $enable_static" >&5
-echo "${ECHO_T}$enable_static" >&6
-GCC_F77="$G77"
-LD_F77="$LD"
-lt_prog_compiler_wl_F77=
-lt_prog_compiler_pic_F77=
-lt_prog_compiler_static_F77=
- lt_prog_compiler_wl_F77='-Wl,'
- lt_prog_compiler_static_F77='-static'
- case $host_os in
- aix*)
- if test "$host_cpu" = ia64; then
- lt_prog_compiler_static_F77='-Bstatic'
- fi
- amigaos*)
- # like `-m68040'.
- lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
- mingw* | pw32* | os2*)
- lt_prog_compiler_pic_F77='-DDLL_EXPORT'
- darwin* | rhapsody*)
- lt_prog_compiler_pic_F77='-fno-common'
- interix3*)
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared_F77=no
- enable_shared=no
- sysv4*MP*)
- lt_prog_compiler_pic_F77=-Kconform_pic
- fi
- hpux*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_F77='-fPIC'
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
- fi
- darwin*)
- case $cc_basename in
- xlc*)
- lt_prog_compiler_pic_F77='-qnocommon'
- esac
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_F77='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static_F77='-non_shared'
- newsos6)
- lt_prog_compiler_pic_F77='-KPIC'
- linux*)
- icc* | ecc*)
- pgcc* | pgf77* | pgf90* | pgf95*)
- # Portland Group compilers (*not* the Pentium gcc compiler,
- # which looks to be a dead project)
- lt_prog_compiler_pic_F77='-fpic'
- ccc*)
- # All Alpha code is PIC.
- esac
- # All OSF/1 code is PIC.
- solaris*)
- f77* | f90* | f95*)
- lt_prog_compiler_wl_F77='-Qoption ld ';;
- lt_prog_compiler_wl_F77='-Wl,';;
- esac
- sunos4*)
- lt_prog_compiler_pic_F77='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3*)
- sysv4*MP*)
- lt_prog_compiler_pic_F77='-Kconform_pic'
- fi
- unicos*)
- uts4*)
- lt_prog_compiler_pic_F77='-pic'
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
-if test -n "$lt_prog_compiler_pic_F77"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
-else
- lt_prog_compiler_pic_works_F77=no
- lt_compiler_flag="$lt_prog_compiler_pic_F77"
- (eval echo "\"\$as_me:13311: $lt_compile\"" >&5)
- ac_status=$?
- echo "$as_me:13315: \$? = $ac_status" >&5
- lt_prog_compiler_pic_works_F77=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
-if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
- case $lt_prog_compiler_pic_F77 in
- *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
- esac
-else
-fi
-fi
-case $host_os in
- *djgpp*)
- lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
-esac
-wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
-if test "${lt_prog_compiler_static_works_F77+set}" = set; then
-else
- lt_prog_compiler_static_works_F77=no
- lt_prog_compiler_static_works_F77=yes
- fi
- else
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_F77" >&5
-echo "${ECHO_T}$lt_prog_compiler_static_works_F77" >&6
-if test x"$lt_prog_compiler_static_works_F77" = xyes; then
-else
-fi
-if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
-else
- lt_cv_prog_compiler_c_o_F77=no
- mkdir conftest
- cd conftest
- mkdir out
- (eval echo "\"\$as_me:13415: $lt_compile\"" >&5)
- ac_status=$?
- echo "$as_me:13419: \$? = $ac_status" >&5
- then
- lt_cv_prog_compiler_c_o_F77=yes
- fi
- fi
- chmod u+w . 2>&5
- $rm conftest*
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
-if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
- hard_links=yes
- $rm conftest*
- touch conftest.a
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
- runpath_var=
- allow_undefined_flag_F77=
- enable_shared_with_static_runtimes_F77=no
- archive_cmds_F77=
- archive_expsym_cmds_F77=
- old_archive_From_new_cmds_F77=
- old_archive_from_expsyms_cmds_F77=
- export_dynamic_flag_spec_F77=
- whole_archive_flag_spec_F77=
- thread_safe_flag_spec_F77=
- hardcode_libdir_flag_spec_F77=
- hardcode_libdir_flag_spec_ld_F77=
- hardcode_libdir_separator_F77=
- hardcode_direct_F77=no
- hardcode_minus_L_F77=no
- hardcode_shlibpath_var_F77=unsupported
- link_all_deplibs_F77=unknown
- hardcode_automatic_F77=no
- module_cmds_F77=
- module_expsym_cmds_F77=
- always_export_symbols_F77=no
- export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms_F77=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- # Just being paranoid about ensuring that cc_basename is set.
- for cc_temp in $compiler""; do
- case $cc_temp in
- *) break;;
- esac
-done
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- interix*)
- # we just hope/assume this is gcc and not c89 (= MSVC++)
- with_gnu_ld=yes
- openbsd*)
- with_gnu_ld=no
- esac
- ld_shlibs_F77=yes
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # Set some defaults for GNU ld with shared library support. These
- # are reset later if shared libraries are not supported. Putting them
- # here allows them to be overridden if necessary.
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec_F77='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- ld_shlibs_F77=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec_F77='-L$libdir'
- hardcode_minus_L_F77=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- ld_shlibs_F77=no
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag_F77=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs_F77=no
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
- # as there is no search path for DLLs.
- enable_shared_with_static_runtimes_F77=yes
- export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- ld_shlibs_F77=no
- fi
- interix3*)
- hardcode_shlibpath_var_F77=no
- hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
- export_dynamic_flag_spec_F77='${wl}-E'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- archive_cmds_F77='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- archive_expsym_cmds_F77='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- linux*)
- tmp_addflag=
- case $cc_basename,$host_cpu in
- pgcc*) # Portland Group C compiler
- whole_archive_flag_spec_F77='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
- tmp_addflag=' $pic_flag'
- pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
- tmp_addflag=' $pic_flag -Mnomain' ;;
- ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
- tmp_addflag=' -i_dynamic' ;;
- efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
- tmp_addflag=' -i_dynamic -nofor_main' ;;
- ifc* | ifort*) # Intel Fortran compiler
- tmp_addflag=' -nofor_main' ;;
- esac
- archive_cmds_F77='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test $supports_anon_versioning = yes; then
- archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- $echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- else
- ld_shlibs_F77=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- ld_shlibs_F77=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs_F77=no
- fi
- sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
- case `$LD -v 2>&1` in
- *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
- ld_shlibs_F77=no
- cat <<_LT_EOF 1>&2
-*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
-*** reliably create shared libraries on SCO systems. Therefore, libtool
-*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
-_LT_EOF
- hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
- archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
- else
- ld_shlibs_F77=no
- fi
- esac
- sunos4*)
- archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct_F77=yes
- else
- ld_shlibs_F77=no
- fi
- esac
- if test "$ld_shlibs_F77" = no; then
- runpath_var=
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols_F77=yes
- archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct_F77=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_F77=''
- hardcode_libdir_separator_F77=':'
- link_all_deplibs_F77=yes
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_F77='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
- program main
- end
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } &&
- { ac_try='test -z "$ac_f77_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_F77="-z nodefs"
- archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
- program main
- end
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_F77=' ${wl}-bernotok'
- allow_undefined_flag_F77=' ${wl}-berok'
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_F77='$convenience'
- archive_cmds_need_lc_F77=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs_F77=no
- bsdi[45]*)
- export_dynamic_flag_spec_F77=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec_F77=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_From_new_cmds_F77='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path_F77='`cygpath -w "$srcfile"`'
- case $host_os in
- rhapsody* | darwin1.[012])
- allow_undefined_flag_F77='${wl}-undefined ${wl}suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag_F77='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag_F77='${wl}-undefined ${wl}dynamic_lookup'
- esac
- fi
- esac
- archive_cmds_need_lc_F77=no
- hardcode_automatic_F77=yes
- whole_archive_flag_spec_F77=''
- if test "$GCC" = yes ; then
- output_verbose_link_cmd='echo'
- archive_cmds_F77='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- module_cmds_F77='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
- archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- xlc*)
- archive_cmds_F77='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
- archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- ld_shlibs_F77=no
- esac
- fi
- dgux*)
- archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- ld_shlibs_F77=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec_F77='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu | dragonfly*)
- archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_F77=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- fi
- if test "$with_gnu_ld" = no; then
- fi
- hpux11*)
- case $host_cpu in
- hppa*64*)
- archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- case $host_cpu in
- hppa*64*)
- archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- hardcode_libdir_flag_spec_ld_F77='+b $libdir'
- esac
- fi
- irix5* | irix6* | nonstopux*)
- archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
- fi
- hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
- netbsd*)
- archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- os2*)
- archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag_F77=' -expect_unresolved \*'
- archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec_F77='-rpath $libdir'
- fi
- solaris*)
- no_undefined_flag_F77=' -z text'
- wlarc='${wl}'
- archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- wlarc=''
- archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The compiler driver will combine linker options so we
- # cannot just pass the convience library names through
- # without $wl, iff we do not link with $LD.
- # Luckily, gcc supports the same syntax we need for Sun Studio.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- case $wlarc in
- whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
- whole_archive_flag_spec_F77='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
- esac ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- sni)
- hardcode_direct_F77=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds_F77='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec_F77='-Bexport'
- sysv4*MP*)
- if test -d /usr/nec; then
- hardcode_runpath_var=yes
- ld_shlibs_F77=yes
- fi
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
- no_undefined_flag_F77='${wl}-z,text'
- archive_cmds_F77='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_F77='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- allow_undefined_flag_F77='${wl}-z,nodefs'
- hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
- export_dynamic_flag_spec_F77='${wl}-Bexport'
- archive_cmds_F77='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_F77='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- uts4*)
- ld_shlibs_F77=no
- esac
- fi
-echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
-echo "${ECHO_T}$ld_shlibs_F77" >&6
-test "$ld_shlibs_F77" = no && can_build_shared=no
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_F77" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_F77 in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_F77
- pic_flag=$lt_prog_compiler_pic_F77
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_F77
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag_F77=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[45]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- shlibpath_var=LD_LIBRARY_PATH
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[123]*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
- freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
- freebsd*) # from 4.6 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-interix3*)
- need_version=no
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action_F77=
-if test -n "$hardcode_libdir_flag_spec_F77" || \
- test -n "$runpath_var_F77" || \
- test "X$hardcode_automatic_F77" = "Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct_F77" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
- test "$hardcode_minus_L_F77" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_F77=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_F77=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_F77=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
-echo "${ECHO_T}$hardcode_action_F77" >&6
-if test "$hardcode_action_F77" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler_F77 \
- CC_F77 \
- LD_F77 \
- lt_prog_compiler_wl_F77 \
- lt_prog_compiler_pic_F77 \
- lt_prog_compiler_static_F77 \
- lt_prog_compiler_no_builtin_flag_F77 \
- export_dynamic_flag_spec_F77 \
- thread_safe_flag_spec_F77 \
- whole_archive_flag_spec_F77 \
- enable_shared_with_static_runtimes_F77 \
- old_archive_cmds_F77 \
- old_archive_from_new_cmds_F77 \
- predep_objects_F77 \
- postdep_objects_F77 \
- predeps_F77 \
- postdeps_F77 \
- compiler_lib_search_path_F77 \
- archive_cmds_F77 \
- archive_expsym_cmds_F77 \
- postinstall_cmds_F77 \
- postuninstall_cmds_F77 \
- old_archive_from_expsyms_cmds_F77 \
- allow_undefined_flag_F77 \
- no_undefined_flag_F77 \
- export_symbols_cmds_F77 \
- hardcode_libdir_flag_spec_F77 \
- hardcode_libdir_flag_spec_ld_F77 \
- hardcode_libdir_separator_F77 \
- hardcode_automatic_F77 \
- module_cmds_F77 \
- module_expsym_cmds_F77 \
- lt_cv_prog_compiler_c_o_F77 \
- exclude_expsyms_F77 \
- include_expsyms_F77; do
- case $var in
- old_archive_cmds_F77 | \
- old_archive_from_new_cmds_F77 | \
- archive_cmds_F77 | \
- archive_expsym_cmds_F77 | \
- module_cmds_F77 | \
- module_expsym_cmds_F77 | \
- old_archive_from_expsyms_cmds_F77 | \
- export_symbols_cmds_F77 | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="$ofile"
- cat <<__EOF__ >> "$cfgfile"
-# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc_F77
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-host_os=$host_os
-# The build system.
-build_alias=$build_alias
-build=$build
-build_os=$build_os
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# LTCC compiler flags.
-LTCFLAGS=$lt_LTCFLAGS
-# A language-specific compiler.
-CC=$lt_compiler_F77
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC_F77
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD_F77
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl_F77
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic_F77
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
-# Must we lock files when doing compilation?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static_F77
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_F77
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds_F77
-archive_expsym_cmds=$lt_archive_expsym_cmds_F77
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds_F77
-module_expsym_cmds=$lt_module_expsym_cmds_F77
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects_F77
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects_F77
-# shared library.
-predeps=$lt_predeps_F77
-# shared library.
-postdeps=$lt_postdeps_F77
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path_F77
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag_F77
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag_F77
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action_F77
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct_F77
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L_F77
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic_F77
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs_F77
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path_F77"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols_F77
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds_F77
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms_F77
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms_F77
-# ### END LIBTOOL TAG CONFIG: $tagname
-__EOF__
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-CC="$lt_save_CC"
- else
- tagname=""
- fi
- GCJ)
- if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
-# Source file extension for Java test sources.
-ac_ext=java
-# Object file extension for compiled Java test sources.
-objext=o
-objext_GCJ=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code="class foo {}\n"
-# Code to be used in simple link tests
-lt_simple_link_test_code='public class conftest { public static void main(String[] argv) {}; }\n'
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# save warnings/boilerplate of simple test code
-ac_outfile=conftest.$ac_objext
-printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$rm conftest*
-printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$rm conftest*
-lt_save_CC="$CC"
-CC=${GCJ-"gcj"}
-compiler=$CC
-compiler_GCJ=$CC
-for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-# GCJ did not exist at the time GCC didn't implicitly link libc in.
-archive_cmds_need_lc_GCJ=no
-old_archive_cmds_GCJ=$old_archive_cmds
-lt_prog_compiler_no_builtin_flag_GCJ=
- lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
-echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
-echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- lt_cv_prog_compiler_rtti_exceptions=no
- ac_outfile=conftest.$ac_objext
- lt_compiler_flag="-fno-rtti -fno-exceptions"
- # Insert the option either (1) after the last *FLAGS variable, or
- # (2) before a word containing "conftest.", or (3) at the end.
- # Note that $ac_compile itself does not contain backslashes and begins
- # with a dollar sign (not a hyphen), so the echo should work correctly.
- # The option is referenced via a variable to avoid confusing sed.
- lt_compile=`echo "$ac_compile" | $SED \
- -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
- -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
- -e 's:$: $lt_compiler_flag:'`
- (eval echo "\"\$as_me:15618: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>conftest.err)
- ac_status=$?
- cat conftest.err >&5
- echo "$as_me:15622: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s "$ac_outfile"; then
- # The compiler can only warn and ignore the option if not recognized
- # So say no if there are warnings other than the usual output.
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
- $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
- if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_rtti_exceptions=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
-if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
- lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
-else
-fi
-fi
-lt_prog_compiler_wl_GCJ=
-lt_prog_compiler_pic_GCJ=
-lt_prog_compiler_static_GCJ=
-echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
-echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
- lt_prog_compiler_wl_GCJ='-Wl,'
- lt_prog_compiler_static_GCJ='-static'
- case $host_os in
- aix*)
- # All AIX code is PIC.
- if test "$host_cpu" = ia64; then
- # AIX 5 now supports IA64 processor
- lt_prog_compiler_static_GCJ='-Bstatic'
- fi
- amigaos*)
- # FIXME: we need at least 68020 code to build shared libraries, but
- # adding the `-m68020' flag to GCC prevents building anything better,
- # like `-m68040'.
- lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
- beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
- # PIC is the default for these OSes.
- mingw* | pw32* | os2*)
- # This hack is so that the source file can tell whether it is being
- # built for inclusion in a dll (and should export symbols for example).
- lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
- darwin* | rhapsody*)
- # PIC is the default on this platform
- # Common symbols not allowed in MH_DYLIB files
- lt_prog_compiler_pic_GCJ='-fno-common'
- interix3*)
- # Interix 3.x gcc -fpic/-fPIC options generate broken code.
- # Instead, we relocate shared libraries at runtime.
- msdosdjgpp*)
- # Just because we use GCC doesn't mean we suddenly get shared libraries
- # on systems that don't support them.
- lt_prog_compiler_can_build_shared_GCJ=no
- enable_shared=no
- sysv4*MP*)
- lt_prog_compiler_pic_GCJ=-Kconform_pic
- fi
- hpux*)
- # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
- # not for PA HP-UX.
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_GCJ='-fPIC'
- esac
- esac
- else
- # PORTME Check for flag to pass linker flags through the system compiler.
- case $host_os in
- aix*)
- else
- lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
- fi
- darwin*)
- case $cc_basename in
- xlc*)
- lt_prog_compiler_pic_GCJ='-qnocommon'
- esac
- hpux9* | hpux10* | hpux11*)
- case $host_cpu in
- hppa*64*|ia64*)
- # +Z the default
- lt_prog_compiler_pic_GCJ='+Z'
- esac
- # Is there a better lt_prog_compiler_static that works with the bundled CC?
- lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
- # PIC (with -KPIC) is the default.
- lt_prog_compiler_static_GCJ='-non_shared'
- newsos6)
- lt_prog_compiler_pic_GCJ='-KPIC'
- linux*)
- icc* | ecc*)
- pgcc* | pgf77* | pgf90* | pgf95*)
- # Portland Group compilers (*not* the Pentium gcc compiler,
- # which looks to be a dead project)
- lt_prog_compiler_pic_GCJ='-fpic'
- ccc*)
- # All Alpha code is PIC.
- esac
- osf3* | osf4* | osf5*)
- # All OSF/1 code is PIC.
- solaris*)
- f77* | f90* | f95*)
- lt_prog_compiler_wl_GCJ='-Qoption ld ';;
- lt_prog_compiler_wl_GCJ='-Wl,';;
- esac
- sunos4*)
- lt_prog_compiler_pic_GCJ='-PIC'
- sysv4 | sysv4.2uw2* | sysv4.3*)
- sysv4*MP*)
- lt_prog_compiler_pic_GCJ='-Kconform_pic'
- fi
- sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
- unicos*)
- uts4*)
- lt_prog_compiler_pic_GCJ='-pic'
- esac
- fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
-# Check to make sure the PIC flag actually works.
-if test -n "$lt_prog_compiler_pic_GCJ"; then
-echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
-echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
-if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
-else
- lt_prog_compiler_pic_works_GCJ=no
- lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
- (eval echo "\"\$as_me:15886: $lt_compile\"" >&5)
- ac_status=$?
- echo "$as_me:15890: \$? = $ac_status" >&5
- lt_prog_compiler_pic_works_GCJ=yes
- fi
- fi
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
-echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
-if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
- case $lt_prog_compiler_pic_GCJ in
- *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
- esac
-else
-fi
-fi
-case $host_os in
- # For platforms which do not support PIC, -DPIC is meaningless:
- *djgpp*)
- lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
-esac
-# Check to make sure the static flag actually works.
-wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
-echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
-echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
-if test "${lt_prog_compiler_static_works_GCJ+set}" = set; then
-else
- lt_prog_compiler_static_works_GCJ=no
- save_LDFLAGS="$LDFLAGS"
- LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
- printf "$lt_simple_link_test_code" > conftest.$ac_ext
- if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
- # The linker can only warn and ignore the option if not recognized
- if test -s conftest.err; then
- # Append any errors to the config.log.
- $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
- if diff conftest.exp conftest.er2 >/dev/null; then
- lt_prog_compiler_static_works_GCJ=yes
- fi
- else
- fi
- fi
- $rm conftest*
- LDFLAGS="$save_LDFLAGS"
-fi
-echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_GCJ" >&5
-echo "${ECHO_T}$lt_prog_compiler_static_works_GCJ" >&6
-if test x"$lt_prog_compiler_static_works_GCJ" = xyes; then
-else
-fi
-echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
-echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
-if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
-else
- lt_cv_prog_compiler_c_o_GCJ=no
- $rm -r conftest 2>/dev/null
- mkdir conftest
- cd conftest
- mkdir out
- lt_compiler_flag="-o out/conftest2.$ac_objext"
- (eval echo "\"\$as_me:15990: $lt_compile\"" >&5)
- (eval "$lt_compile" 2>out/conftest.err)
- ac_status=$?
- cat out/conftest.err >&5
- echo "$as_me:15994: \$? = $ac_status" >&5
- if (exit $ac_status) && test -s out/conftest2.$ac_objext
- then
- $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
- $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
- if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
- lt_cv_prog_compiler_c_o_GCJ=yes
- fi
- fi
- chmod u+w . 2>&5
- $rm conftest*
- # SGI C++ compiler will create directory out/ii_files/ for
- # template instantiation
- test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
- $rm out/* && rmdir out
- cd ..
- rmdir conftest
- $rm conftest*
-fi
-echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
-echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
-hard_links="nottested"
-if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
- # do not overwrite the value of need_locks provided by the user
- echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
-echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
- hard_links=yes
- $rm conftest*
- ln conftest.a conftest.b 2>/dev/null && hard_links=no
- touch conftest.a
- ln conftest.a conftest.b 2>&5 || hard_links=no
- echo "$as_me:$LINENO: result: $hard_links" >&5
-echo "${ECHO_T}$hard_links" >&6
- if test "$hard_links" = no; then
- { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
-echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
- need_locks=warn
- fi
-else
- need_locks=no
-fi
-echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
-echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
- runpath_var=
- allow_undefined_flag_GCJ=
- enable_shared_with_static_runtimes_GCJ=no
- archive_cmds_GCJ=
- archive_expsym_cmds_GCJ=
- old_archive_From_new_cmds_GCJ=
- old_archive_from_expsyms_cmds_GCJ=
- export_dynamic_flag_spec_GCJ=
- whole_archive_flag_spec_GCJ=
- thread_safe_flag_spec_GCJ=
- hardcode_libdir_flag_spec_GCJ=
- hardcode_libdir_flag_spec_ld_GCJ=
- hardcode_libdir_separator_GCJ=
- hardcode_direct_GCJ=no
- hardcode_minus_L_GCJ=no
- hardcode_shlibpath_var_GCJ=unsupported
- link_all_deplibs_GCJ=unknown
- hardcode_automatic_GCJ=no
- module_cmds_GCJ=
- module_expsym_cmds_GCJ=
- always_export_symbols_GCJ=no
- export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
- # include_expsyms should be a list of space-separated symbols to be *always*
- # included in the symbol list
- include_expsyms_GCJ=
- # exclude_expsyms can be an extended regexp of symbols to exclude
- # it will be wrapped by ` (' and `)$', so one must not match beginning or
- # end of line. Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
- # as well as any symbol that contains `d'.
- exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
- # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
- # platforms (ab)use it in PIC code, but their linkers get confused if
- # the symbol is explicitly referenced. Since portable code cannot
- # rely on this symbol name, it's probably fine to never include it in
- # preloaded symbol tables.
- extract_expsyms_cmds=
- # Just being paranoid about ensuring that cc_basename is set.
- for cc_temp in $compiler""; do
- case $cc_temp in
- *) break;;
- esac
-done
- case $host_os in
- cygwin* | mingw* | pw32*)
- # FIXME: the MSVC++ port hasn't been tested in a loooong time
- # When not using gcc, we currently assume that we are using
- # Microsoft Visual C++.
- if test "$GCC" != yes; then
- with_gnu_ld=no
- fi
- interix*)
- # we just hope/assume this is gcc and not c89 (= MSVC++)
- with_gnu_ld=yes
- openbsd*)
- with_gnu_ld=no
- esac
- ld_shlibs_GCJ=yes
- if test "$with_gnu_ld" = yes; then
- # If archive_cmds runs LD, not CC, wlarc should be empty
- wlarc='${wl}'
- # Set some defaults for GNU ld with shared library support. These
- # are reset later if shared libraries are not supported. Putting them
- # here allows them to be overridden if necessary.
- runpath_var=LD_RUN_PATH
- hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
- export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
- # ancient GNU ld didn't support --whole-archive et. al.
- if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
- whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
- else
- fi
- supports_anon_versioning=no
- case `$LD -v 2>/dev/null` in
- *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
- *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
- *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
- *\ 2.11.*) ;; # other 2.11 versions
- *) supports_anon_versioning=yes ;;
- esac
- # See if GNU ld supports shared libraries.
- case $host_os in
- aix3* | aix4* | aix5*)
- # On AIX/PPC, the GNU linker is very broken
- if test "$host_cpu" != ia64; then
- ld_shlibs_GCJ=no
- cat <<EOF 1>&2
-*** Warning: the GNU linker, at least up to release 2.9.1, is reported
-*** to be unable to reliably create shared libraries on AIX.
-*** Therefore, libtool is disabling shared libraries support. If you
-*** really care for shared libraries, you may want to modify your PATH
-*** so that a non-GNU linker is found, and then restart.
-EOF
- fi
- amigaos*)
- archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
- hardcode_libdir_flag_spec_GCJ='-L$libdir'
- hardcode_minus_L_GCJ=yes
- # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
- # that the semantics of dynamic libraries on AmigaOS, at least up
- # to version 4, is to share data among multiple programs linked
- # with the same dynamic library. Since this doesn't match the
- # behavior of shared libraries on other platforms, we can't use
- # them.
- ld_shlibs_GCJ=no
- beos*)
- if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- allow_undefined_flag_GCJ=unsupported
- # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
- # support --undefined. This deserves some investigation. FIXME
- archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- else
- ld_shlibs_GCJ=no
- fi
- # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
- # as there is no search path for DLLs.
- enable_shared_with_static_runtimes_GCJ=yes
- export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
- if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- # If the export-symbols file already is a .def file (1st line
- # is EXPORTS), use it as is; otherwise, prepend...
- archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
- cp $export_symbols $output_objdir/$soname.def;
- else
- echo EXPORTS > $output_objdir/$soname.def;
- cat $export_symbols >> $output_objdir/$soname.def;
- fi~
- $CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
- else
- ld_shlibs_GCJ=no
- fi
- interix3*)
- hardcode_shlibpath_var_GCJ=no
- hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
- export_dynamic_flag_spec_GCJ='${wl}-E'
- # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
- # Instead, shared libraries are loaded at an image base (0x10000000 by
- # default) and relocated if they conflict, which is a slow very memory
- # consuming and fragmenting process. To avoid this, we pick a random,
- # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
- # time. Moving up from 0x10000000 also allows more sbrk(2) space.
- archive_cmds_GCJ='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- archive_expsym_cmds_GCJ='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
- linux*)
- tmp_addflag=
- case $cc_basename,$host_cpu in
- pgcc*) # Portland Group C compiler
- whole_archive_flag_spec_GCJ='${wl}--whole-archive`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
- tmp_addflag=' $pic_flag'
- pgf77* | pgf90* | pgf95*) # Portland Group f77 and f90 compilers
- tmp_addflag=' $pic_flag -Mnomain' ;;
- ecc*,ia64* | icc*,ia64*) # Intel C compiler on ia64
- tmp_addflag=' -i_dynamic' ;;
- efc*,ia64* | ifort*,ia64*) # Intel Fortran compiler on ia64
- tmp_addflag=' -i_dynamic -nofor_main' ;;
- ifc* | ifort*) # Intel Fortran compiler
- tmp_addflag=' -nofor_main' ;;
- esac
- archive_cmds_GCJ='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- if test $supports_anon_versioning = yes; then
- archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
- cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
- $echo "local: *; };" >> $output_objdir/$libname.ver~
- $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
- fi
- else
- ld_shlibs_GCJ=no
- fi
- netbsd*)
- if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
- archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
- wlarc=
- else
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
- archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
- fi
- solaris*)
- if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
- ld_shlibs_GCJ=no
- cat <<EOF 1>&2
-*** Warning: The releases 2.8.* of the GNU linker cannot reliably
-*** create shared libraries on Solaris systems. Therefore, libtool
-*** is disabling shared libraries support. We urge you to upgrade GNU
-*** binutils to release 2.9.1 or newer. Another option is to modify
-*** your PATH or compiler configuration so that the native linker is
-*** used, and then restart.
-EOF
- elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
- else
- ld_shlibs_GCJ=no
- fi
- sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
- case `$LD -v 2>&1` in
- *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
- ld_shlibs_GCJ=no
- cat <<_LT_EOF 1>&2
-*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
-*** reliably create shared libraries on SCO systems. Therefore, libtool
-*** binutils to release 2.16.91.0.3 or newer. Another option is to modify
-_LT_EOF
- hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
- archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
- else
- ld_shlibs_GCJ=no
- fi
- esac
- sunos4*)
- archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- wlarc=
- hardcode_direct_GCJ=yes
- else
- ld_shlibs_GCJ=no
- fi
- esac
- if test "$ld_shlibs_GCJ" = no; then
- runpath_var=
- fi
- else
- # PORTME fill in a description of your system's linker (not GNU ld)
- case $host_os in
- aix3*)
- always_export_symbols_GCJ=yes
- archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
- # Note: this linker hardcodes the directories in LIBPATH if there
- # are no directories specified by -L.
- if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
- # Neither direct hardcoding nor static linking is supported with a
- # broken collect2.
- hardcode_direct_GCJ=unsupported
- fi
- aix4* | aix5*)
- # On IA64, the linker does run time linking by default, so we don't
- # have to do anything special.
- aix_use_runtimelinking=no
- exp_sym_flag='-Bexport'
- no_entry_flag=""
- else
- # If we're using GNU nm, then we don't want the "-C" option.
- # -C means demangle to AIX nm, but means don't demangle with GNU nm
- if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
- export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- else
- export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
- fi
- # Test if we are trying to use run time linking or normal
- # AIX style linking. If -brtl is somewhere in LDFLAGS, we
- # need to do runtime linking.
- case $host_os in aix4.[23]|aix4.[23].*|aix5*)
- for ld_flag in $LDFLAGS; do
- if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
- aix_use_runtimelinking=yes
- break
- fi
- done
- esac
- exp_sym_flag='-bexport'
- no_entry_flag='-bnoentry'
- fi
- # When large executables or shared objects are built, AIX ld can
- # have problems creating the table of contents. If linking a library
- # or program results in "error TOC overflow" add -mminimal-toc to
- # CXXFLAGS/CFLAGS for g++/gcc. In the cases where that is not
- # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
- archive_cmds_GCJ=''
- hardcode_libdir_separator_GCJ=':'
- link_all_deplibs_GCJ=yes
- case $host_os in aix4.[012]|aix4.[012].*)
- # We only want to do this on AIX 4.2 and lower, the check
- # below for broken collect2 doesn't work under 4.3+
- collect2name=`${CC} -print-prog-name=collect2`
- if test -f "$collect2name" && \
- strings "$collect2name" | grep resolve_lib_name >/dev/null
- then
- # We have reworked collect2
- else
- # We have old collect2
- # It fails to find uninstalled libraries when the uninstalled
- # path is not listed in the libpath. Setting hardcode_minus_L
- # to unsupported forces relinking
- fi
- esac
- shared_flag='-shared'
- if test "$aix_use_runtimelinking" = yes; then
- shared_flag="$shared_flag "'${wl}-G'
- fi
- else
- # not using gcc
- # VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
- # chokes on -Wl,-G. The following line is correct:
- shared_flag='-G'
- else
- shared_flag='${wl}-G'
- else
- shared_flag='${wl}-bM:SRE'
- fi
- fi
- fi
- # It seems that -bexpall does not export symbols beginning with
- # underscore (_), so it is better to generate a list of symbols to export.
- # Warning - without using the other runtime loading flags (-brtl),
- # -berok will link without error, but may produce a broken library.
- allow_undefined_flag_GCJ='-berok'
- # Determine the default libpath from the value encoded in an empty executable.
- cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-cat confdefs.h >>conftest.$ac_ext
-cat >>conftest.$ac_ext <<_ACEOF
-/* end confdefs.h. */
-int
-main ()
- return 0;
-_ACEOF
-rm -f conftest.$ac_objext conftest$ac_exeext
-if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
- (eval $ac_link) 2>conftest.er1
- ac_status=$?
- grep -v '^ *+' conftest.er1 >conftest.err
- rm -f conftest.er1
- echo "$as_me:$LINENO: \$? = $ac_status" >&5
- (exit $ac_status); } &&
- { ac_try='test -z "$ac_c_werror_flag"
- || test ! -s conftest.err'
- { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
- (eval $ac_try) 2>&5
- ac_status=$?
- (exit $ac_status); }; } &&
- { ac_try='test -s conftest$ac_exeext'
- ac_status=$?
- (exit $ac_status); }; }; then
-aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-# Check for a 64-bit object if we didn't find anything.
-if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0 *\(.*\)$/\1/; p; }
-}'`; fi
-else
- echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
-fi
-rm -f conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
-if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
- hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
- archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
- else
- hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
- allow_undefined_flag_GCJ="-z nodefs"
- archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
- else
-/* confdefs.h. */
-_ACEOF
-int
-main ()
- return 0;
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
-}'`; fi
-else
-fi
- # Warning - without using the other run time loading flags,
- no_undefined_flag_GCJ=' ${wl}-bernotok'
- allow_undefined_flag_GCJ=' ${wl}-berok'
- # Exported symbols can be pulled into shared objects from archives
- whole_archive_flag_spec_GCJ='$convenience'
- archive_cmds_need_lc_GCJ=yes
- # This is similar to how AIX traditionally builds its shared libraries.
- archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
- fi
- fi
- amigaos*)
- # see comment about different semantics on the GNU ld section
- ld_shlibs_GCJ=no
- bsdi[45]*)
- export_dynamic_flag_spec_GCJ=-rdynamic
- # hardcode_libdir_flag_spec is actually meaningless, as there is
- # no search path for DLLs.
- hardcode_libdir_flag_spec_GCJ=' '
- # Tell ltmain to make .lib files, not .a files.
- libext=lib
- # Tell ltmain to make .dll files, not .so files.
- # FIXME: Setting linknames here is a bad hack.
- archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
- # The linker will automatically build a .lib file if we build a DLL.
- old_archive_From_new_cmds_GCJ='true'
- # FIXME: Should let the user specify the lib program.
- old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
- fix_srcfile_path_GCJ='`cygpath -w "$srcfile"`'
- case $host_os in
- rhapsody* | darwin1.[012])
- allow_undefined_flag_GCJ='${wl}-undefined ${wl}suppress'
- *) # Darwin 1.3 on
- if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
- allow_undefined_flag_GCJ='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
- else
- case ${MACOSX_DEPLOYMENT_TARGET} in
- 10.[012])
- 10.*)
- allow_undefined_flag_GCJ='${wl}-undefined ${wl}dynamic_lookup'
- esac
- fi
- esac
- archive_cmds_need_lc_GCJ=no
- hardcode_automatic_GCJ=yes
- whole_archive_flag_spec_GCJ=''
- if test "$GCC" = yes ; then
- output_verbose_link_cmd='echo'
- archive_cmds_GCJ='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
- module_cmds_GCJ='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
- # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
- archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- else
- xlc*)
- archive_cmds_GCJ='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
- archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[ ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
- ld_shlibs_GCJ=no
- esac
- fi
- dgux*)
- archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
- freebsd1*)
- ld_shlibs_GCJ=no
- # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
- # support. Future versions do this automatically, but an explicit c++rt0.o
- # does not break anything, and helps significantly (at the cost of a little
- # extra space).
- freebsd2.2*)
- archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
- hardcode_libdir_flag_spec_GCJ='-R$libdir'
- # Unfortunately, older versions of FreeBSD 2 do not have this feature.
- freebsd2*)
- archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
- # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
- freebsd* | kfreebsd*-gnu | dragonfly*)
- archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
- hpux9*)
- archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- else
- archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
- fi
- hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
- hardcode_libdir_separator_GCJ=:
- # hardcode_minus_L: Not really in the search PATH,
- # but as the default location of the library.
- hpux10*)
- if test "$GCC" = yes -a "$with_gnu_ld" = no; then
- archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
- fi
- if test "$with_gnu_ld" = no; then
- fi
- hpux11*)
- case $host_cpu in
- hppa*64*)
- archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- esac
- else
- case $host_cpu in
- hppa*64*)
- archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- ia64*)
- archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
- archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
- esac
- fi
- case $host_cpu in
- hppa*64*|ia64*)
- hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
- esac
- fi
- irix5* | irix6* | nonstopux*)
- archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
- fi
- hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
- netbsd*)
- archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags' # a.out
- else
- archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags' # ELF
- fi
- newsos6)
- openbsd*)
- if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
- archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
- else
- case $host_os in
- openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
- esac
- fi
- os2*)
- archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
- old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
- osf3*)
- allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
- archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- allow_undefined_flag_GCJ=' -expect_unresolved \*'
- archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- fi
- osf4* | osf5*) # as osf3* with the addition of -msym flag
- archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
- else
- archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
- archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
- $LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
- # Both c and cxx compiler support -rpath directly
- hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
- fi
- solaris*)
- no_undefined_flag_GCJ=' -z text'
- wlarc='${wl}'
- archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
- $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
- else
- wlarc=''
- archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
- $LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
- fi
- case $host_os in
- solaris2.[0-5] | solaris2.[0-5].*) ;;
- # The compiler driver will combine linker options so we
- # cannot just pass the convience library names through
- # without $wl, iff we do not link with $LD.
- # Luckily, gcc supports the same syntax we need for Sun Studio.
- # Supported since Solaris 2.6 (maybe 2.5.1?)
- case $wlarc in
- whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
- whole_archive_flag_spec_GCJ='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
- esac ;;
- esac
- sunos4*)
- if test "x$host_vendor" = xsequent; then
- # Use $CC to link under sequent, because it throws in some extra .o
- # files that make .init and .fini sections work.
- archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
- fi
- sysv4)
- sni)
- hardcode_direct_GCJ=yes # is this really true???
- siemens)
- ## LD is ld it makes a PLAMLIB
- ## CC just makes a GrossModule.
- archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
- reload_cmds_GCJ='$CC -r -o $output$reload_objs'
- motorola)
- hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
- esac
- runpath_var='LD_RUN_PATH'
- sysv4.3*)
- export_dynamic_flag_spec_GCJ='-Bexport'
- sysv4*MP*)
- if test -d /usr/nec; then
- hardcode_runpath_var=yes
- ld_shlibs_GCJ=yes
- fi
- sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
- no_undefined_flag_GCJ='${wl}-z,text'
- if test "$GCC" = yes; then
- archive_cmds_GCJ='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_GCJ='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- sysv5* | sco3.2v5* | sco5v6*)
- # Note: We can NOT use -z defs as we might desire, because we do not
- # link with -lc, and that would cause any symbols used from libc to
- # always be unresolved, which means just about no library would
- # ever link correctly. If we're not using GNU ld we use -z text
- # though, which does catch some bad symbols but isn't as heavy-handed
- # as -z defs.
- allow_undefined_flag_GCJ='${wl}-z,nodefs'
- hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
- export_dynamic_flag_spec_GCJ='${wl}-Bexport'
- archive_cmds_GCJ='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- else
- archive_cmds_GCJ='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
- fi
- uts4*)
- ld_shlibs_GCJ=no
- esac
- fi
-echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
-echo "${ECHO_T}$ld_shlibs_GCJ" >&6
-test "$ld_shlibs_GCJ" = no && can_build_shared=no
-# Do we need to explicitly link libc?
-case "x$archive_cmds_need_lc_GCJ" in
-x|xyes)
- # Assume -lc should be added
- if test "$enable_shared" = yes && test "$GCC" = yes; then
- case $archive_cmds_GCJ in
- # FIXME: we may have to deal with multi-command sequences.
- '$CC '*)
- # Test whether the compiler implicitly links with -lc since on some
- # systems, -lgcc has to come before -lc. If gcc already passes -lc
- # to ld, don't add -lc before -lgcc.
- echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
-echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
- $rm conftest*
- printf "$lt_simple_compile_test_code" > conftest.$ac_ext
- if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>&5
- ac_status=$?
- (exit $ac_status); } 2>conftest.err; then
- soname=conftest
- lib=conftest
- libobjs=conftest.$ac_objext
- deplibs=
- wl=$lt_prog_compiler_wl_GCJ
- pic_flag=$lt_prog_compiler_pic_GCJ
- compiler_flags=-v
- linker_flags=-v
- verstring=
- output_objdir=.
- libname=conftest
- lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
- if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
- (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
- ac_status=$?
- then
- else
- fi
- allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
- else
- cat conftest.err 1>&5
- fi
- $rm conftest*
- echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
-echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
- esac
- fi
-esac
-echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
-echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
-libname_spec='lib$name'
-soname_spec=
-shrext_cmds=".so"
-postinstall_cmds=
-finish_cmds=
-finish_eval=
-shlibpath_var=
-shlibpath_overrides_runpath=unknown
-version_type=none
-dynamic_linker="$host_os ld.so"
-sys_lib_dlsearch_path_spec="/lib /usr/lib"
-if test "$GCC" = yes; then
- sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
- if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
- # if the path contains ";" then we assume it to be the separator
- # otherwise default to the standard path separator (i.e. ":") - it is
- # assumed that no part of a normal pathname contains ";" but that should
- # okay in the real world where ";" in dirpaths is itself problematic.
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
- else
- sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e "s/$PATH_SEPARATOR/ /g"`
- fi
-else
- sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
-fi
-need_lib_prefix=unknown
-hardcode_into_libs=no
-# when you set need_version to no, make sure it does not cause -set_version
-# flags to be left without arguments
-need_version=unknown
-case $host_os in
-aix3*)
- version_type=linux
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
- shlibpath_var=LIBPATH
- # AIX 3 has no versioning support, so we append a major version to the name.
- soname_spec='${libname}${release}${shared_ext}$major'
-aix4* | aix5*)
- need_lib_prefix=no
- need_version=no
- hardcode_into_libs=yes
- # AIX 5 supports IA64
- library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
- shlibpath_var=LD_LIBRARY_PATH
- else
- # With GCC up to 2.95.x, collect2 would create an import file
- # for dependence libraries. The import file would start with
- # the line `#! .'. This would cause the generated library to
- # depend on `.', always an invalid library. This was fixed in
- # development snapshots of GCC prior to 3.0.
- case $host_os in
- aix4 | aix4.[01] | aix4.[01].*)
- if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
- echo ' yes '
- echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
- else
- can_build_shared=no
- fi
- esac
- # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
- # soname into executable. Probably we can add versioning support to
- # collect2, so additional links can be useful in future.
- # If using run time linking (on AIX 4.2 or later) use lib<name>.so
- # instead of lib<name>.a to let people know that these are not
- # typical AIX shared libraries.
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
- else
- # We preserve .a as extension for shared libraries through AIX4.2
- # and later when we are not doing run time linking.
- library_names_spec='${libname}${release}.a $libname.a'
- fi
- fi
-amigaos*)
- library_names_spec='$libname.ixlibrary $libname.a'
- # Create ${libname}_ixlibrary.a entries in /sys/libs.
- finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
-beos*)
- library_names_spec='${libname}${shared_ext}'
- dynamic_linker="$host_os ld.so"
- shlibpath_var=LIBRARY_PATH
-bsdi[45]*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
- sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
- sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
- # the default ld.so.conf also contains /usr/contrib/lib and
- # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
- # libtool to hard-code these into programs
-cygwin* | mingw* | pw32*)
- version_type=windows
- shrext_cmds=".dll"
- need_version=no
- case $GCC,$host_os in
- yes,cygwin* | yes,mingw* | yes,pw32*)
- library_names_spec='$libname.dll.a'
- # DLL is installed to $(libdir)/../bin by postinstall_cmds
- postinstall_cmds='base_file=`basename \${file}`~
- dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
- dldir=$destdir/`dirname \$dlpath`~
- test -d \$dldir || mkdir -p \$dldir~
- $install_prog $dir/$dlname \$dldir/$dlname~
- chmod a+x \$dldir/$dlname'
- postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
- dlpath=$dir/\$dldll~
- $rm \$dlpath'
- shlibpath_overrides_runpath=yes
- case $host_os in
- cygwin*)
- # Cygwin DLLs use 'cyg' prefix rather than 'lib'
- soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
- mingw*)
- # MinGW DLLs use traditional 'lib' prefix
- soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
- # It is most probably a Windows format PATH printed by
- # mingw gcc, but we are running on Cygwin. Gcc prints its search
- # path with ; separators, and with drive letters. We can handle the
- # drive letters (cygwin fileutils understands them), so leave them,
- # especially as we might pass files found there to a mingw objdump,
- # which wouldn't understand a cygwinified path. Ahh.
- else
- fi
- pw32*)
- # pw32 DLLs use 'pw' prefix rather than 'lib'
- library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
- esac
- library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
- esac
- dynamic_linker='Win32 ld.exe'
- # FIXME: first we should search . and the directory the executable is in
- shlibpath_var=PATH
-darwin* | rhapsody*)
- dynamic_linker="$host_os dyld"
- version_type=darwin
- need_version=no
- library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
- soname_spec='${libname}${release}${major}$shared_ext'
- shlibpath_var=DYLD_LIBRARY_PATH
- shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
- # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
- sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
- else
- sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
- fi
- sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
-dgux*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
-freebsd1*)
- dynamic_linker=no
-kfreebsd*-gnu)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
- shlibpath_overrides_runpath=no
- dynamic_linker='GNU ld.so'
-freebsd* | dragonfly*)
- # DragonFly does not have aout. When/if they implement a new
- # versioning mechanism, adjust this.
- if test -x /usr/bin/objformat; then
- objformat=`/usr/bin/objformat`
- else
- case $host_os in
- freebsd[123]*) objformat=aout ;;
- *) objformat=elf ;;
- esac
- fi
- version_type=freebsd-$objformat
- case $version_type in
- freebsd-elf*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
- need_version=no
- freebsd-*)
- library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
- need_version=yes
- esac
- case $host_os in
- freebsd2*)
- freebsd3.[01]* | freebsdelf3.[01]*)
- freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
- freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
- freebsd*) # from 4.6 on
- esac
-gnu*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
-hpux9* | hpux10* | hpux11*)
- # Give a soname corresponding to the major version so that dld.sl refuses to
- # link against other versions.
- version_type=sunos
- need_version=no
- case $host_cpu in
- ia64*)
- shrext_cmds='.so'
- dynamic_linker="$host_os dld.so"
- shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
- if test "X$HPUX_IA64_MODE" = X32; then
- sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
- else
- sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
- fi
- sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
- hppa*64*)
- shrext_cmds='.sl'
- dynamic_linker="$host_os dld.sl"
- shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
- sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
- shrext_cmds='.sl'
- shlibpath_var=SHLIB_PATH
- shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
- esac
- # HP-UX runs *really* slowly unless shared libraries are mode 555.
- postinstall_cmds='chmod 555 $lib'
-interix3*)
- need_version=no
- dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
-irix5* | irix6* | nonstopux*)
- case $host_os in
- nonstopux*) version_type=nonstopux ;;
- if test "$lt_cv_prog_gnu_ld" = yes; then
- else
- version_type=irix
- fi ;;
- esac
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
- case $host_os in
- irix5* | nonstopux*)
- libsuff= shlibsuff=
- case $LD in # libtool.m4 will add one of these switches to LD
- *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
- libsuff= shlibsuff= libmagic=32-bit;;
- *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
- libsuff=32 shlibsuff=N32 libmagic=N32;;
- *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
- libsuff=64 shlibsuff=64 libmagic=64-bit;;
- *) libsuff= shlibsuff= libmagic=never-match;;
- esac
- esac
- shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
- sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
- sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
-# No shared lib support for Linux oldld, aout, or coff.
-linux*oldld* | linux*aout* | linux*coff*)
- dynamic_linker=no
-# This must be Linux ELF.
-linux*)
- need_version=no
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
- # This implies no fast_install, which is unacceptable.
- # Some rework will be needed to allow for fast_install
- # before this can be enabled.
- # Append ld.so.conf contents to the search path
- if test -f /etc/ld.so.conf; then
- lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:, ]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
- sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
- fi
- # We used to test for /lib/ld.so.1 and disable shared libraries on
- # powerpc, because MkLinux only supported shared libraries with the
- # GNU dynamic linker. Since this was broken with cross compilers,
- # most powerpc-linux boxes support dynamic linking these days and
- # people can always --disable-shared, the test was removed, and we
- # assume the GNU/Linux dynamic linker is in use.
- dynamic_linker='GNU/Linux ld.so'
-knetbsd*-gnu)
- need_version=no
-netbsd*)
- need_version=no
- library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
- finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
- dynamic_linker='NetBSD (a.out) ld.so'
- else
- dynamic_linker='NetBSD ld.elf_so'
- fi
-newsos6)
-nto-qnx*)
- need_version=no
-openbsd*)
- sys_lib_dlsearch_path_spec="/usr/lib"
- # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
- case $host_os in
- openbsd3.3 | openbsd3.3.*) need_version=yes ;;
- *) need_version=no ;;
- esac
- case $host_os in
- openbsd2.[89] | openbsd2.[89].*)
- esac
- else
- fi
-os2*)
- libname_spec='$name'
- library_names_spec='$libname${shared_ext} $libname.a'
- dynamic_linker='OS/2 ld.exe'
-osf3* | osf4* | osf5*)
- version_type=osf
- need_version=no
- sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
- sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
-solaris*)
- need_version=no
- # ldd complains unless libraries are executable
- postinstall_cmds='chmod +x $lib'
-sunos4*)
- finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
- fi
- need_version=yes
-sysv4 | sysv4.3*)
- case $host_vendor in
- sni)
- export_dynamic_flag_spec='${wl}-Blargedynsym'
- siemens)
- motorola)
- need_version=no
- sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
- esac
-sysv4*MP*)
- if test -d /usr/nec ;then
- library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
- soname_spec='$libname${shared_ext}.$major'
- fi
-sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
- version_type=freebsd-elf
- need_version=no
- sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
- else
- sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
- case $host_os in
- sco3.2v5*)
- sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
- esac
- fi
- sys_lib_dlsearch_path_spec='/usr/lib'
-uts4*)
- dynamic_linker=no
-esac
-echo "$as_me:$LINENO: result: $dynamic_linker" >&5
-echo "${ECHO_T}$dynamic_linker" >&6
-test "$dynamic_linker" = no && can_build_shared=no
-variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
- variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
-fi
-echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
-echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
-hardcode_action_GCJ=
-if test -n "$hardcode_libdir_flag_spec_GCJ" || \
- test -n "$runpath_var_GCJ" || \
- test "X$hardcode_automatic_GCJ" = "Xyes" ; then
- # We can hardcode non-existant directories.
- if test "$hardcode_direct_GCJ" != no &&
- # If the only mechanism to avoid hardcoding is shlibpath_var, we
- # have to relink, otherwise we might link with an installed library
- # when we should be linking with a yet-to-be-installed one
- ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
- test "$hardcode_minus_L_GCJ" != no; then
- # Linking always hardcodes the temporary library directory.
- hardcode_action_GCJ=relink
- else
- # We can link without hardcoding, and we can hardcode nonexisting dirs.
- hardcode_action_GCJ=immediate
- fi
-else
- # We cannot hardcode anything, or else we can only hardcode existing
- # directories.
- hardcode_action_GCJ=unsupported
-fi
-echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
-echo "${ECHO_T}$hardcode_action_GCJ" >&6
-if test "$hardcode_action_GCJ" = relink; then
- # Fast installation is not supported
- enable_fast_install=no
-elif test "$shlibpath_overrides_runpath" = yes ||
- test "$enable_shared" = no; then
- # Fast installation is not necessary
- enable_fast_install=needless
-fi
-# The else clause should only fire when bootstrapping the
-# libtool distribution, otherwise you forgot to ship ltmain.sh
-# with your package, and you will get complaints that there are
-# no rules to generate ltmain.sh.
-if test -f "$ltmain"; then
- # See if we are running on zsh, and set the options which allow our commands through
- # without removal of \ escapes.
- if test -n "${ZSH_VERSION+set}" ; then
- setopt NO_GLOB_SUBST
- fi
- # Now quote all the things that may contain metacharacters while being
- # careful not to overquote the AC_SUBSTed values. We take copies of the
- # variables and quote the copies for generation of the libtool script.
- for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
- SED SHELL STRIP \
- libname_spec library_names_spec soname_spec extract_expsyms_cmds \
- old_striplib striplib file_magic_cmd finish_cmds finish_eval \
- deplibs_check_method reload_flag reload_cmds need_locks \
- lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
- lt_cv_sys_global_symbol_to_c_name_address \
- sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
- old_postinstall_cmds old_postuninstall_cmds \
- compiler_GCJ \
- CC_GCJ \
- LD_GCJ \
- lt_prog_compiler_wl_GCJ \
- lt_prog_compiler_pic_GCJ \
- lt_prog_compiler_static_GCJ \
- lt_prog_compiler_no_builtin_flag_GCJ \
- export_dynamic_flag_spec_GCJ \
- thread_safe_flag_spec_GCJ \
- whole_archive_flag_spec_GCJ \
- enable_shared_with_static_runtimes_GCJ \
- old_archive_cmds_GCJ \
- old_archive_from_new_cmds_GCJ \
- predep_objects_GCJ \
- postdep_objects_GCJ \
- predeps_GCJ \
- postdeps_GCJ \
- compiler_lib_search_path_GCJ \
- archive_cmds_GCJ \
- archive_expsym_cmds_GCJ \
- postinstall_cmds_GCJ \
- postuninstall_cmds_GCJ \
- old_archive_from_expsyms_cmds_GCJ \
- allow_undefined_flag_GCJ \
- no_undefined_flag_GCJ \
- export_symbols_cmds_GCJ \
- hardcode_libdir_flag_spec_GCJ \
- hardcode_libdir_flag_spec_ld_GCJ \
- hardcode_libdir_separator_GCJ \
- hardcode_automatic_GCJ \
- module_cmds_GCJ \
- module_expsym_cmds_GCJ \
- lt_cv_prog_compiler_c_o_GCJ \
- exclude_expsyms_GCJ \
- include_expsyms_GCJ; do
- case $var in
- old_archive_cmds_GCJ | \
- old_archive_from_new_cmds_GCJ | \
- archive_cmds_GCJ | \
- archive_expsym_cmds_GCJ | \
- module_cmds_GCJ | \
- module_expsym_cmds_GCJ | \
- old_archive_from_expsyms_cmds_GCJ | \
- export_symbols_cmds_GCJ | \
- extract_expsyms_cmds | reload_cmds | finish_cmds | \
- postinstall_cmds | postuninstall_cmds | \
- old_postinstall_cmds | old_postuninstall_cmds | \
- sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
- # Double-quote double-evaled strings.
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
- eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
- esac
- done
- case $lt_echo in
- *'\$0 --fallback-echo"')
- lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
- esac
-cfgfile="$ofile"
- cat <<__EOF__ >> "$cfgfile"
-# ### BEGIN LIBTOOL TAG CONFIG: $tagname
-# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
-# Shell to use when invoking shell scripts.
-SHELL=$lt_SHELL
-# Whether or not to build shared libraries.
-build_libtool_libs=$enable_shared
-# Whether or not to build static libraries.
-build_old_libs=$enable_static
-# Whether or not to add -lc for building shared libraries.
-build_libtool_need_lc=$archive_cmds_need_lc_GCJ
-# Whether or not to disallow shared libs when runtime libs are static
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
-# Whether or not to optimize for fast installation.
-fast_install=$enable_fast_install
-# The host system.
-host_alias=$host_alias
-host=$host
-host_os=$host_os
-# The build system.
-build_alias=$build_alias
-build=$build
-build_os=$build_os
-# An echo program that does not interpret backslashes.
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-AR_FLAGS=$lt_AR_FLAGS
-# A C compiler.
-LTCC=$lt_LTCC
-# LTCC compiler flags.
-LTCFLAGS=$lt_LTCFLAGS
-# A language-specific compiler.
-CC=$lt_compiler_GCJ
-# Is the compiler the GNU C compiler?
-with_gcc=$GCC_GCJ
-# An ERE matcher.
-EGREP=$lt_EGREP
-# The linker used to build libraries.
-LD=$lt_LD_GCJ
-# Whether we need hard or soft links.
-LN_S=$lt_LN_S
-# A BSD-compatible nm program.
-NM=$lt_NM
-# A symbol stripping program
-STRIP=$lt_STRIP
-# Used to examine libraries when file_magic_cmd begins "file"
-MAGIC_CMD=$MAGIC_CMD
-# Used on cygwin: DLL creation program.
-DLLTOOL="$DLLTOOL"
-# Used on cygwin: object dumper.
-OBJDUMP="$OBJDUMP"
-# Used on cygwin: assembler.
-AS="$AS"
-# The name of the directory that contains temporary libtool files.
-objdir=$objdir
-# How to create reloadable object files.
-reload_flag=$lt_reload_flag
-reload_cmds=$lt_reload_cmds
-# How to pass a linker flag through the compiler.
-wl=$lt_lt_prog_compiler_wl_GCJ
-# Object file suffix (normally "o").
-objext="$ac_objext"
-# Old archive suffix (normally "a").
-libext="$libext"
-# Shared library suffix (normally ".so").
-shrext_cmds='$shrext_cmds'
-# Executable file suffix (normally "").
-exeext="$exeext"
-# Additional compiler flags for building library objects.
-pic_flag=$lt_lt_prog_compiler_pic_GCJ
-pic_mode=$pic_mode
-# What is the maximum length of a command?
-max_cmd_len=$lt_cv_sys_max_cmd_len
-# Does compiler simultaneously support -c and -o options?
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
-# Must we lock files when doing compilation?
-need_locks=$lt_need_locks
-# Do we need the lib prefix for modules?
-need_lib_prefix=$need_lib_prefix
-# Do we need a version for libraries?
-need_version=$need_version
-# Whether dlopen is supported.
-dlopen_support=$enable_dlopen
-# Whether dlopen of programs is supported.
-dlopen_self=$enable_dlopen_self
-# Whether dlopen of statically linked programs is supported.
-dlopen_self_static=$enable_dlopen_self_static
-# Compiler flag to prevent dynamic linking.
-link_static_flag=$lt_lt_prog_compiler_static_GCJ
-# Compiler flag to turn off builtin functions.
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
-# Compiler flag to allow reflexive dlopens.
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
-# Compiler flag to generate shared objects directly from archives.
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
-# Compiler flag to generate thread-safe objects.
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
-# Library versioning type.
-version_type=$version_type
-# Format of library name prefix.
-libname_spec=$lt_libname_spec
-# List of archive names. First name is the real one, the rest are links.
-# The last name is the one that the linker finds with -lNAME.
-library_names_spec=$lt_library_names_spec
-# The coded name of the library, if different from the real name.
-soname_spec=$lt_soname_spec
-# Commands used to build and install an old-style archive.
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_GCJ
-old_postinstall_cmds=$lt_old_postinstall_cmds
-old_postuninstall_cmds=$lt_old_postuninstall_cmds
-# Create an old-style archive from a shared archive.
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
-# Create a temporary old-style archive to link instead of a shared archive.
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
-# Commands used to build and install a shared archive.
-archive_cmds=$lt_archive_cmds_GCJ
-archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
-postinstall_cmds=$lt_postinstall_cmds
-postuninstall_cmds=$lt_postuninstall_cmds
-# Commands used to build a loadable module (assumed same as above if empty)
-module_cmds=$lt_module_cmds_GCJ
-module_expsym_cmds=$lt_module_expsym_cmds_GCJ
-# Commands to strip libraries.
-old_striplib=$lt_old_striplib
-striplib=$lt_striplib
-# Dependencies to place before the objects being linked to create a
-# shared library.
-predep_objects=$lt_predep_objects_GCJ
-# Dependencies to place after the objects being linked to create a
-# shared library.
-postdep_objects=$lt_postdep_objects_GCJ
-# shared library.
-predeps=$lt_predeps_GCJ
-# shared library.
-postdeps=$lt_postdeps_GCJ
-# The library search path used internally by the compiler when linking
-# a shared library.
-compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
-# Method to check whether dependent libraries are shared objects.
-deplibs_check_method=$lt_deplibs_check_method
-# Command to use when deplibs_check_method == file_magic.
-file_magic_cmd=$lt_file_magic_cmd
-# Flag that allows shared libraries with undefined symbols to be built.
-allow_undefined_flag=$lt_allow_undefined_flag_GCJ
-# Flag that forces no undefined symbols.
-no_undefined_flag=$lt_no_undefined_flag_GCJ
-# Commands used to finish a libtool library installation in a directory.
-finish_cmds=$lt_finish_cmds
-# Same as above, but a single script fragment to be evaled but not shown.
-finish_eval=$lt_finish_eval
-# Take the output of nm and produce a listing of raw symbols and C names.
-global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
-# Transform the output of nm in a proper C declaration
-global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
-# Transform the output of nm in a C name address pair
-global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
-# This is the shared library runtime path variable.
-runpath_var=$runpath_var
-# This is the shared library path variable.
-shlibpath_var=$shlibpath_var
-# Is shlibpath searched before the hard-coded library search path?
-shlibpath_overrides_runpath=$shlibpath_overrides_runpath
-# How to hardcode a shared library path into an executable.
-hardcode_action=$hardcode_action_GCJ
-# Whether we should hardcode library paths into libraries.
-hardcode_into_libs=$hardcode_into_libs
-# Flag to hardcode \$libdir into a binary during linking.
-# This must work even if \$libdir does not exist.
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
-# If ld is used when linking, flag to hardcode \$libdir into
-# a binary during linking. This must work even if \$libdir does
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
-# Whether we need a single -rpath flag with a separated argument.
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
-# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
-# resulting binary.
-hardcode_direct=$hardcode_direct_GCJ
-# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
-hardcode_minus_L=$hardcode_minus_L_GCJ
-# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
-# the resulting binary.
-hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
-# Set to yes if building a shared library automatically hardcodes DIR into the library
-# and all subsequent libraries and executables linked against it.
-hardcode_automatic=$hardcode_automatic_GCJ
-# Variables whose values should be saved in libtool wrapper scripts and
-# restored at relink time.
-variables_saved_for_relink="$variables_saved_for_relink"
-# Whether libtool must link a program against all its dependency libraries.
-link_all_deplibs=$link_all_deplibs_GCJ
-# Compile-time system search path for libraries
-sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
-# Run-time system search path for libraries
-sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
-# Fix the shell variable \$srcfile for the compiler.
-fix_srcfile_path="$fix_srcfile_path_GCJ"
-# Set to yes if exported symbols are required.
-always_export_symbols=$always_export_symbols_GCJ
-# The commands to list exported symbols.
-export_symbols_cmds=$lt_export_symbols_cmds_GCJ
-# The commands to extract the exported symbol list from a shared archive.
-extract_expsyms_cmds=$lt_extract_expsyms_cmds
-# Symbols that should not be listed in the preloaded symbols.
-exclude_expsyms=$lt_exclude_expsyms_GCJ
-# Symbols that must always be exported.
-include_expsyms=$lt_include_expsyms_GCJ
-# ### END LIBTOOL TAG CONFIG: $tagname
-__EOF__
-else
- # If there is no Makefile yet, we rely on a make rule to execute
- # `config.status --recheck' to rerun these tests and create the
- # libtool script then.
- ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
- if test -f "$ltmain_in"; then
- test -f Makefile && make "$ltmain"
- fi
-fi
-ac_ext=c
-ac_cpp='$CPP $CPPFLAGS'
-ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
-ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-ac_compiler_gnu=$ac_cv_c_compiler_gnu
-CC="$lt_save_CC"
- else
- tagname=""
- fi
- RC)
-# Source file extension for RC test sources.
-ac_ext=rc
-# Object file extension for compiled RC test sources.
-objext=o
-objext_RC=$objext
-# Code to be used in simple compile tests
-lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
-# Code to be used in simple link tests
-lt_simple_link_test_code="$lt_simple_compile_test_code"
-# ltmain only uses $CC for tagged configurations so make sure $CC is set.
-# If no C compiler was specified, use CC.
-LTCC=${LTCC-"$CC"}
-# If no C compiler flags were specified, use CFLAGS.
-LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
-# Allow CC to be a program name with arguments.
-compiler=$CC
-# save warnings/boilerplate of simple test code
-ac_outfile=conftest.$ac_objext
-printf "$lt_simple_compile_test_code" >conftest.$ac_ext
-eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_compiler_boilerplate=`cat conftest.err`
-$rm conftest*
-printf "$lt_simple_link_test_code" >conftest.$ac_ext
-eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
-_lt_linker_boilerplate=`cat conftest.err`
-$rm conftest*
-lt_save_CC="$CC"
-CC=${RC-"windres"}
-compiler=$CC
-compiler_RC=$CC
-for cc_temp in $compiler""; do
- case $cc_temp in
- compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
- distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
- *) break;;
- esac
-done
-cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
-lt_cv_prog_compiler_c_o_RC=yes
- fi
- SED SHELL STRIP \
- compiler_RC \
- CC_RC \
- LD_RC \
- lt_prog_compiler_wl_RC \
- lt_prog_compiler_pic_RC \
- lt_prog_compiler_static_RC \
- lt_prog_compiler_no_builtin_flag_RC \
- export_dynamic_flag_spec_RC \
- thread_safe_flag_spec_RC \
- whole_archive_flag_spec_RC \
- enable_shared_with_static_runtimes_RC \
- old_archive_cmds_RC \
- old_archive_from_new_cmds_RC \
- predep_objects_RC \
- postdep_objects_RC \
- predeps_RC \
- postdeps_RC \
- compiler_lib_search_path_RC \
- archive_cmds_RC \
- archive_expsym_cmds_RC \
- postinstall_cmds_RC \
- postuninstall_cmds_RC \
- old_archive_from_expsyms_cmds_RC \
- allow_undefined_flag_RC \
- no_undefined_flag_RC \
- export_symbols_cmds_RC \
- hardcode_libdir_flag_spec_RC \
- hardcode_libdir_flag_spec_ld_RC \
- hardcode_libdir_separator_RC \
- hardcode_automatic_RC \
- module_cmds_RC \
- module_expsym_cmds_RC \
- lt_cv_prog_compiler_c_o_RC \
- exclude_expsyms_RC \
- include_expsyms_RC; do
- case $var in
- old_archive_cmds_RC | \
- old_archive_from_new_cmds_RC | \
- archive_cmds_RC | \
- archive_expsym_cmds_RC | \
- module_cmds_RC | \
- module_expsym_cmds_RC | \
- old_archive_from_expsyms_cmds_RC | \
- export_symbols_cmds_RC | \
- esac
- done
- case $lt_echo in
- esac
-cfgfile="$ofile"
-SHELL=$lt_SHELL
-build_libtool_need_lc=$archive_cmds_need_lc_RC
-allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
-# The host system.
-host=$host
-host_os=$host_os
-build=$build
-build_os=$build_os
-echo=$lt_echo
-# The archiver.
-AR=$lt_AR
-# A C compiler.
-LTCC=$lt_LTCC
-CC=$lt_compiler_RC
-with_gcc=$GCC_RC
-# An ERE matcher.
-EGREP=$lt_EGREP
-LD=$lt_LD_RC
-LN_S=$lt_LN_S
-NM=$lt_NM
-STRIP=$lt_STRIP
-DLLTOOL="$DLLTOOL"
-OBJDUMP="$OBJDUMP"
-AS="$AS"
-objdir=$objdir
-wl=$lt_lt_prog_compiler_wl_RC
-libext="$libext"
-exeext="$exeext"
-pic_flag=$lt_lt_prog_compiler_pic_RC
-pic_mode=$pic_mode
-compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
-link_static_flag=$lt_lt_prog_compiler_static_RC
-no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
-export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
-whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
-thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
-RANLIB=$lt_RANLIB
-old_archive_cmds=$lt_old_archive_cmds_RC
-old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
-old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
-archive_cmds=$lt_archive_cmds_RC
-archive_expsym_cmds=$lt_archive_expsym_cmds_RC
-module_cmds=$lt_module_cmds_RC
-module_expsym_cmds=$lt_module_expsym_cmds_RC
-# shared library.
-predep_objects=$lt_predep_objects_RC
-# shared library.
-postdep_objects=$lt_postdep_objects_RC
-# shared library.
-predeps=$lt_predeps_RC
-# shared library.
-postdeps=$lt_postdeps_RC
-compiler_lib_search_path=$lt_compiler_lib_search_path_RC
-allow_undefined_flag=$lt_allow_undefined_flag_RC
-no_undefined_flag=$lt_no_undefined_flag_RC
-hardcode_action=$hardcode_action_RC
-hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
-# not exist.
-hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
-hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
-hardcode_direct=$hardcode_direct_RC
-hardcode_minus_L=$hardcode_minus_L_RC
-hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
-hardcode_automatic=$hardcode_automatic_RC
-link_all_deplibs=$link_all_deplibs_RC
-fix_srcfile_path="$fix_srcfile_path_RC"
-always_export_symbols=$always_export_symbols_RC
-export_symbols_cmds=$lt_export_symbols_cmds_RC
-exclude_expsyms=$lt_exclude_expsyms_RC
-include_expsyms=$lt_include_expsyms_RC
-__EOF__
-else
- fi
-fi
-ac_ext=c
-CC="$lt_save_CC"
- { { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
-echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
- { (exit 1); exit 1; }; }
- esac
- # Append the new tag name to the list of available tags.
- if test -n "$tagname" ; then
- available_tags="$available_tags $tagname"
- fi
- fi
- done
- IFS="$lt_save_ifs"
- # Now substitute the updated list of available tags.
- if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
- mv "${ofile}T" "$ofile"
- chmod +x "$ofile"
- else
- rm -f "${ofile}T"
- { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
-echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
- fi
-fi
-# This can be used to rebuild libtool when needed
-LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
-# Always use our own libtool.
-LIBTOOL='$(SHELL) $(top_builddir)/libtool'
-# Prevent multiple expansion
-echo "$as_me:$LINENO: checking for exp in -lm" >&5
-echo $ECHO_N "checking for exp in -lm... $ECHO_C" >&6
-if test "${ac_cv_lib_m_exp+set}" = set; then
- echo $ECHO_N "(cached) $ECHO_C" >&6
-else
- ac_check_lib_save_LIBS=$LIBS
-LIBS="-lm $LIBS"
-cat >conftest.$ac_ext <<_ACEOF
-/* confdefs.h. */
-_ACEOF
-/* Override any gcc2 internal prototype to avoid an error. */
-#ifdef __cplusplus
-extern "C"
-#endif
-/* We use char because int might match the return type of a gcc2
- builtin and then its argument prototype would still apply. */
-char exp ();
-int
-main ()
-exp ();
- return 0;
-_ACEOF
- ac_status=$?
- cat conftest.err >&5
- ac_status=$?
- ac_status=$?
- ac_cv_lib_m_exp=yes
-else
-ac_cv_lib_m_exp=no
-fi
-LIBS=$ac_check_lib_save_LIBS
-fi
-echo "$as_me:$LINENO: result: $ac_cv_lib_m_exp" >&5
-echo "${ECHO_T}$ac_cv_lib_m_exp" >&6
-if test $ac_cv_lib_m_exp = yes; then
- cat >>confdefs.h <<_ACEOF
-#define HAVE_LIBM 1
-_ACEOF
- LIBS="-lm $LIBS"
-fi
-echo "$as_me:$LINENO: checking for ANSI C header files" >&5
-echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
-if test "${ac_cv_header_stdc+set}" = set; then
-else
-/* confdefs.h. */
-_ACEOF
-#include <stdlib.h>
-#include <stdarg.h>
-#include <string.h>
-#include <float.h>
-int
-main ()
- return 0;
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
- (eval $ac_compile) 2>conftest.er1
- ac_status=$?
- ac_status=$?
- { ac_try='test -s conftest.$ac_objext'
- ac_status=$?
- ac_cv_header_stdc=yes
-else
-ac_cv_header_stdc=no
-fi
-rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
-if test $ac_cv_header_stdc = yes; then
- # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then
-else
- ac_cv_header_stdc=no
-fi
-rm -f conftest*
-fi
- # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-/* confdefs.h. */
-_ACEOF
-_ACEOF
- $EGREP "free" >/dev/null 2>&1; then
-else
-fi
-rm -f conftest*
-fi
- # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then
-else
-/* confdefs.h. */
-_ACEOF
-#include <ctype.h>
-#if ((' ' & 0x0FF) == 0x020)
-# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
-# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
-#else
-# define ISLOWER(c) \
- (('a' <= (c) && (c) <= 'i') \
- || ('j' <= (c) && (c) <= 'r') \
- || ('s' <= (c) && (c) <= 'z'))
-# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
-#endif
-#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
-int
-main ()
- int i;
- for (i = 0; i < 256; i++)
- if (XOR (islower (i), ISLOWER (i))
- || toupper (i) != TOUPPER (i))
- exit(2);
- exit (0);
-_ACEOF
-rm -f conftest$ac_exeext
- (eval $ac_link) 2>&5
- ac_status=$?
- (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
- ac_status=$?
-else
- echo "$as_me: program exited with status $ac_status" >&5
-echo "$as_me: failed program was:" >&5
-( exit $ac_status )
-fi
-rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
-fi
-fi
-fi
-echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
-echo "${ECHO_T}$ac_cv_header_stdc" >&6
-cat >>confdefs.h <<\_ACEOF
-#define STDC_HEADERS 1
-_ACEOF
-fi
-JNI_INCLUDE=
-export JNI_INCLUDE
-# Check whether --with-jni or --without-jni was given.
-if test "${with_jni+set}" = set; then
- withval="$with_jni"
-fi;
-if test "$with_jni" = "yes" ; then
-#define JNI_ENABLED 1
-_ACEOF
- echo "$as_me:$LINENO: checking whether to enable Java/JNI support" >&5
-echo $ECHO_N "checking whether to enable Java/JNI support... $ECHO_C" >&6
- echo "$as_me:$LINENO: result: enabled" >&5
-echo "${ECHO_T}enabled" >&6
-elif test "$with_jni" != "no" -a "$with_jni" != "" ; then
- if test \! -r "$with_jni/jni.h" ; then
- { { echo "$as_me:$LINENO: error: Did not find $with_jni/jni.h" >&5
-echo "$as_me: error: Did not find $with_jni/jni.h" >&2;}
- fi
-_ACEOF
- JNI_INCLUDE="-I$with_jni"
-elif test "$with_jni" = "" ; then
-for ac_header in jni.h
-do
-as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
-if eval "test \"\${$as_ac_Header+set}\" = set"; then
- echo "$as_me:$LINENO: checking for $ac_header" >&5
-echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
-fi
-echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
-echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
-else
- # Is the header compilable?
-echo "$as_me:$LINENO: checking $ac_header usability" >&5
-echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-$ac_includes_default
-#include <$ac_header>
-_ACEOF
- ac_status=$?
- ac_status=$?
- ac_status=$?
- ac_header_compiler=yes
-else
-ac_header_compiler=no
-fi
-echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
-echo "${ECHO_T}$ac_header_compiler" >&6
-# Is the header present?
-echo "$as_me:$LINENO: checking $ac_header presence" >&5
-echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
-/* confdefs.h. */
-_ACEOF
-_ACEOF
-if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
- (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
- ac_status=$?
- (exit $ac_status); } >/dev/null; then
- if test -s conftest.err; then
- ac_cpp_err=$ac_c_preproc_warn_flag
- ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
- else
- ac_cpp_err=
- fi
-else
- ac_cpp_err=yes
-fi
-if test -z "$ac_cpp_err"; then
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.$ac_ext
-echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
-echo "${ECHO_T}$ac_header_preproc" >&6
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
- yes:no: )
- { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
-echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
-echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
-echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
-echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
-echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
-echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
- { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
-echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
- cat <<\_ASBOX
-## Report this to warmerdam at pobox.com ##
-_ASBOX
- sed "s/^/$as_me: WARNING: /" >&2
-esac
-echo "$as_me:$LINENO: checking for $ac_header" >&5
-else
- eval "$as_ac_Header=\$ac_header_preproc"
-fi
-fi
-if test `eval echo '${'$as_ac_Header'}'` = yes; then
-#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
-_ACEOF
-fi
-done
- if test "$ac_cv_header_jni_h" = "no" ; then
- echo "$as_me:$LINENO: result: disabled" >&5
-echo "${ECHO_T}disabled" >&6
- else
-_ACEOF
- fi
-else
-fi
-JNI_INCLUDE=$JNI_INCLUDE
- ac_config_files="$ac_config_files Makefile src/Makefile man/Makefile man/man1/Makefile man/man3/Makefile nad/Makefile jniwrap/Makefile jniwrap/org/Makefile jniwrap/org/proj4/Makefile"
-cat >confcache <<\_ACEOF
-# This file is a shell script that caches the results of configure
-# tests run on this system so they can be shared between configure
-# scripts and configure runs, see configure's option --config-cache.
-# It is not useful on other systems. If it contains results you don't
-# want to keep, you may remove or edit it.
-# config.status only pays attention to the cache file if you give it
-# the --recheck option to rerun configure.
-# `ac_cv_env_foo' variables (set or unset) will be overridden when
-# loading this file, other *unset* `ac_cv_foo' will be assigned the
-# following values.
-_ACEOF
-# The following way of writing the cache mishandles newlines in values,
-# but we know of no workaround that is simple, portable, and efficient.
-# So, don't put newlines in cache variables' values.
-# Ultrix sh set writes to stderr and can't be redirected directly,
-# and sets the high bit in the cache file unless we assign to the vars.
- (set) 2>&1 |
- case `(ac_space=' '; set | grep ac_space) 2>&1` in
- *ac_space=\ *)
- # `set' does not quote correctly, so add quotes (double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \).
- sed -n \
- "s/'/'\\\\''/g;
- s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
- # `set' quotes correctly as required by POSIX, so do not add quotes.
- sed -n \
- "s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
- esac;
- sed '
- t clear
- : clear
- s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/
- t end
- /^ac_cv_env/!s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/
- : end' >>confcache
-if diff $cache_file confcache >/dev/null 2>&1; then :; else
- if test -w $cache_file; then
- test "x$cache_file" != "x/dev/null" && echo "updating cache $cache_file"
- cat confcache >$cache_file
- else
- echo "not updating unwritable cache $cache_file"
- fi
-fi
-rm -f confcache
-test "x$prefix" = xNONE && prefix=$ac_default_prefix
-# Let make expand exec_prefix.
-test "x$exec_prefix" = xNONE && exec_prefix='${prefix}'
-# VPATH may cause trouble with some makes, so we remove $(srcdir),
-# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
-# trailing colons and then remove the whole line if VPATH becomes empty
-# (actually we leave an empty line to preserve line numbers).
-if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=/{
-s/:*\$(srcdir):*/:/;
-s/:*\${srcdir}:*/:/;
-s/:*@srcdir@:*/:/;
-s/^\([^=]*=[ ]*\):*/\1/;
-s/:*$//;
-s/^[^=]*=[ ]*$//;
-fi
-DEFS=-DHAVE_CONFIG_H
-ac_libobjs=
-ac_ltlibobjs=
-for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
- # 1. Remove the extension, and $U if already installed.
- ac_i=`echo "$ac_i" |
- sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
- # 2. Add them.
- ac_libobjs="$ac_libobjs $ac_i\$U.$ac_objext"
- ac_ltlibobjs="$ac_ltlibobjs $ac_i"'$U.lo'
-done
-LIBOBJS=$ac_libobjs
-LTLIBOBJS=$ac_ltlibobjs
-if test -z "${MAINTAINER_MODE_TRUE}" && test -z "${MAINTAINER_MODE_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"MAINTAINER_MODE\" was never defined.
-Usually this means the macro was only invoked conditionally." >&5
-echo "$as_me: error: conditional \"MAINTAINER_MODE\" was never defined.
-Usually this means the macro was only invoked conditionally." >&2;}
-fi
-if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"AMDEP\" was never defined.
-echo "$as_me: error: conditional \"AMDEP\" was never defined.
-fi
-if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
-echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
-fi
-if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
- { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
-echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
-fi
-: ${CONFIG_STATUS=./config.status}
-ac_clean_files_save=$ac_clean_files
-ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
-echo "$as_me: creating $CONFIG_STATUS" >&6;}
-cat >$CONFIG_STATUS <<_ACEOF
-#! $SHELL
-# Generated by $as_me.
-# Run this file to recreate the current configuration.
-# Compiler output produced by configure, useful for debugging
-# configure, is in config.log if it exists.
-debug=false
-ac_cs_recheck=false
-ac_cs_silent=false
-SHELL=\${CONFIG_SHELL-$SHELL}
-_ACEOF
-cat >>$CONFIG_STATUS <<\_ACEOF
-## M4sh Initialization. ##
-# Be Bourne compatible
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
- emulate sh
- NULLCMD=:
- # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '${1+"$@"}'='"$@"'
-elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
- set -o posix
-fi
-DUALCASE=1; export DUALCASE # for MKS sh
-# Support unset when possible.
-if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
- as_unset=unset
-else
- as_unset=false
-fi
-# Work around bugs in pre-3.0 UWIN ksh.
-$as_unset ENV MAIL MAILPATH
-PS1='$ '
-PS2='> '
-PS4='+ '
-# NLS nuisances.
-for as_var in \
- LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
- LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
- LC_TELEPHONE LC_TIME
-do
- if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
- eval $as_var=C; export $as_var
- else
- $as_unset $as_var
- fi
-done
-# Required to use basename.
-if expr a : '\(a\)' >/dev/null 2>&1; then
- as_expr=expr
-else
- as_expr=false
-fi
-if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
- as_basename=basename
-else
- as_basename=false
-fi
-# Name of the executable.
-as_me=`$as_basename "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)$' \| \
- . : '\(.\)' 2>/dev/null ||
-echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
- /^X\/\(\/\/\)$/{ s//\1/; q; }
- /^X\/\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
-# PATH needs CR, and LINENO needs CR and PATH.
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
-# The user is always right.
-if test "${PATH_SEPARATOR+set}" != set; then
- echo "#! /bin/sh" >conf$$.sh
- echo "exit 0" >>conf$$.sh
- chmod +x conf$$.sh
- if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
- PATH_SEPARATOR=';'
- else
- PATH_SEPARATOR=:
- fi
- rm -f conf$$.sh
-fi
- as_lineno_1=$LINENO
- as_lineno_2=$LINENO
- as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
- test "x$as_lineno_1" != "x$as_lineno_2" &&
- test "x$as_lineno_3" = "x$as_lineno_2" || {
- # Find who we are. Look in the path if we contain no path at all
- # relative or not.
- case $0 in
- *[\\/]* ) as_myself=$0 ;;
- *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in $PATH
-do
- IFS=$as_save_IFS
- test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
-done
- esac
- # We did not find ourselves, most probably we were run as `sh COMMAND'
- # in which case we are not to be found in the path.
- if test "x$as_myself" = x; then
- as_myself=$0
- fi
- if test ! -f "$as_myself"; then
- { { echo "$as_me:$LINENO: error: cannot find myself; rerun with an absolute path" >&5
-echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2;}
- fi
- case $CONFIG_SHELL in
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
-do
- IFS=$as_save_IFS
- for as_base in sh bash ksh sh5; do
- case $as_dir in
- if ("$as_dir/$as_base" -c '
- test "x$as_lineno_3" = "x$as_lineno_2" ') 2>/dev/null; then
- $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
- $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
- CONFIG_SHELL=$as_dir/$as_base
- export CONFIG_SHELL
- exec "$CONFIG_SHELL" "$0" ${1+"$@"}
- fi;;
- esac
- done
-done
- esac
- # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
- # uniformly replaced by the line number. The first 'sed' inserts a
- # line-number line before each line; the second 'sed' does the real
- # work. The second script uses 'N' to pair each line-number line
- # with the numbered line, and appends trailing '-' during
- # substitution so that $LINENO is not a special case at line end.
- # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
- # second 'sed' script. Blame Lee E. McMahon for sed's syntax. :-)
- sed '=' <$as_myself |
- sed '
- N
- s,$,-,
- : loop
- s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
- t loop
- s,-$,,
- s,^['$as_cr_digits']*\n,,
- ' >$as_me.lineno &&
- chmod +x $as_me.lineno ||
- { { echo "$as_me:$LINENO: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&5
-echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2;}
- # Don't try to exec as it changes $[0], causing all sort of problems
- # (the dirname of $[0] is not the place where we might find the
- # original and so on. Autoconf is especially sensible to this).
- . ./$as_me.lineno
- # Exit status is that of the last command.
- exit
-case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
- *c*,-n*) ECHO_N= ECHO_C='
-' ECHO_T=' ' ;;
- *c*,* ) ECHO_N=-n ECHO_C= ECHO_T= ;;
- *) ECHO_N= ECHO_C='\c' ECHO_T= ;;
-esac
- as_expr=expr
-else
- as_expr=false
-fi
-rm -f conf$$ conf$$.exe conf$$.file
-echo >conf$$.file
-if ln -s conf$$.file conf$$ 2>/dev/null; then
- # We could just check for DJGPP; but this test a) works b) is more generic
- # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
- if test -f conf$$.exe; then
- # Don't use ln at all; we don't have any links
- as_ln_s='cp -p'
- else
- as_ln_s='ln -s'
- fi
-elif ln conf$$.file conf$$ 2>/dev/null; then
- as_ln_s=ln
-else
- as_ln_s='cp -p'
-fi
-if mkdir -p . 2>/dev/null; then
- as_mkdir_p=:
-else
- test -d ./-p && rmdir ./-p
- as_mkdir_p=false
-fi
-as_executable_p="test -f"
-# Sed expression to map a string onto a valid CPP name.
-as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
-# Sed expression to map a string onto a valid variable name.
-as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-# IFS
-# We need space, tab and new line, in precisely that order.
-as_nl='
-IFS=" $as_nl"
-# CDPATH.
-$as_unset CDPATH
-exec 6>&1
-# Open the log real soon, to keep \$[0] and so on meaningful, and to
-# report actual input values of CONFIG_FILES etc. instead of their
-# values after options handling. Logging --version etc. is OK.
-exec 5>>config.log
- echo
- sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
-## Running $as_me. ##
-_ASBOX
-} >&5
-cat >&5 <<_CSEOF
-This file was extended by PROJ.4 Projections $as_me 4.5.0, which was
-generated by GNU Autoconf 2.59. Invocation command line was
- CONFIG_FILES = $CONFIG_FILES
- CONFIG_HEADERS = $CONFIG_HEADERS
- CONFIG_LINKS = $CONFIG_LINKS
- CONFIG_COMMANDS = $CONFIG_COMMANDS
- $ $0 $@
-_CSEOF
-echo "on `(hostname || uname -n) 2>/dev/null | sed 1q`" >&5
-echo >&5
-_ACEOF
-# Files that config.status was made for.
-if test -n "$ac_config_files"; then
- echo "config_files=\"$ac_config_files\"" >>$CONFIG_STATUS
-fi
-if test -n "$ac_config_headers"; then
- echo "config_headers=\"$ac_config_headers\"" >>$CONFIG_STATUS
-fi
-if test -n "$ac_config_links"; then
- echo "config_links=\"$ac_config_links\"" >>$CONFIG_STATUS
-fi
-if test -n "$ac_config_commands"; then
- echo "config_commands=\"$ac_config_commands\"" >>$CONFIG_STATUS
-fi
-ac_cs_usage="\
-\`$as_me' instantiates files from templates according to the
-current configuration.
-Usage: $0 [OPTIONS] [FILE]...
- -h, --help print this help, then exit
- -V, --version print version number, then exit
- -q, --quiet do not print progress messages
- -d, --debug don't remove temporary files
- --recheck update $as_me by reconfiguring in the same conditions
- --file=FILE[:TEMPLATE]
- instantiate the configuration file FILE
- --header=FILE[:TEMPLATE]
- instantiate the configuration header FILE
-Configuration files:
-$config_files
-Configuration headers:
-$config_headers
-Configuration commands:
-$config_commands
-Report bugs to <bug-autoconf at gnu.org>."
-_ACEOF
-cat >>$CONFIG_STATUS <<_ACEOF
-ac_cs_version="\\
-PROJ.4 Projections config.status 4.5.0
-configured by $0, generated by GNU Autoconf 2.59,
- with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
-Copyright (C) 2003 Free Software Foundation, Inc.
-This config.status script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it."
-srcdir=$srcdir
-INSTALL="$INSTALL"
-_ACEOF
-# If no file are specified by the user, then we need to provide default
-# value. By we need to know if files were specified by the user.
-ac_need_defaults=:
-while test $# != 0
-do
- case $1 in
- ac_option=`expr "x$1" : 'x\([^=]*\)='`
- ac_optarg=`expr "x$1" : 'x[^=]*=\(.*\)'`
- ac_shift=:
- ac_option=$1
- ac_optarg=$2
- ac_shift=shift
- *) # This is not an option, so the user has probably given explicit
- # arguments.
- ac_option=$1
- ac_need_defaults=false;;
- esac
- case $ac_option in
- # Handling of the options.
-_ACEOF
- -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
- ac_cs_recheck=: ;;
- --version | --vers* | -V )
- echo "$ac_cs_version"; exit 0 ;;
- --he | --h)
- # Conflict between --help and --header
- { { echo "$as_me:$LINENO: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&5
-echo "$as_me: error: ambiguous option: $1
-Try \`$0 --help' for more information." >&2;}
- { (exit 1); exit 1; }; };;
- --help | --hel | -h )
- echo "$ac_cs_usage"; exit 0 ;;
- --debug | --d* | -d )
- debug=: ;;
- --file | --fil | --fi | --f )
- $ac_shift
- CONFIG_FILES="$CONFIG_FILES $ac_optarg"
- --header | --heade | --head | --hea )
- $ac_shift
- CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg"
- -q | -quiet | --quiet | --quie | --qui | --qu | --q \
- | -silent | --silent | --silen | --sile | --sil | --si | --s)
- ac_cs_silent=: ;;
- # This is an error.
- -*) { { echo "$as_me:$LINENO: error: unrecognized option: $1
-echo "$as_me: error: unrecognized option: $1
- { (exit 1); exit 1; }; } ;;
- *) ac_config_targets="$ac_config_targets $1" ;;
- esac
- shift
-done
-ac_configure_extra_args=
-if $ac_cs_silent; then
- exec 6>/dev/null
- ac_configure_extra_args="$ac_configure_extra_args --silent"
-fi
-_ACEOF
-if \$ac_cs_recheck; then
- echo "running $SHELL $0 " $ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6
- exec $SHELL $0 $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
-fi
-_ACEOF
-# INIT-COMMANDS section.
-AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"
-_ACEOF
-for ac_config_target in $ac_config_targets
-do
- case "$ac_config_target" in
- # Handling of arguments.
- "Makefile" ) CONFIG_FILES="$CONFIG_FILES Makefile" ;;
- "src/Makefile" ) CONFIG_FILES="$CONFIG_FILES src/Makefile" ;;
- "man/Makefile" ) CONFIG_FILES="$CONFIG_FILES man/Makefile" ;;
- "man/man1/Makefile" ) CONFIG_FILES="$CONFIG_FILES man/man1/Makefile" ;;
- "man/man3/Makefile" ) CONFIG_FILES="$CONFIG_FILES man/man3/Makefile" ;;
- "nad/Makefile" ) CONFIG_FILES="$CONFIG_FILES nad/Makefile" ;;
- "jniwrap/Makefile" ) CONFIG_FILES="$CONFIG_FILES jniwrap/Makefile" ;;
- "jniwrap/org/Makefile" ) CONFIG_FILES="$CONFIG_FILES jniwrap/org/Makefile" ;;
- "jniwrap/org/proj4/Makefile" ) CONFIG_FILES="$CONFIG_FILES jniwrap/org/proj4/Makefile" ;;
- "depfiles" ) CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
- "src/proj_config.h" ) CONFIG_HEADERS="$CONFIG_HEADERS src/proj_config.h" ;;
- *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
-echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
- esac
-done
-# If the user did not use the arguments to specify the items to instantiate,
-# then the envvar interface is used. Set only those that are not.
-# We use the long form for the default assignment because of an extremely
-# bizarre bug on SunOS 4.1.3.
-if $ac_need_defaults; then
- test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
- test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers
- test "${CONFIG_COMMANDS+set}" = set || CONFIG_COMMANDS=$config_commands
-fi
-# Have a temporary directory for convenience. Make it in the build tree
-# simply because there is no reason to put it here, and in addition,
-# creating and moving files from /tmp can sometimes cause problems.
-# Create a temporary directory, and hook for its removal unless debugging.
-$debug ||
- trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
- trap '{ (exit 1); exit 1; }' 1 2 13 15
-# Create a (secure) tmp directory for tmp files.
- tmp=`(umask 077 && mktemp -d -q "./confstatXXXXXX") 2>/dev/null` &&
- test -n "$tmp" && test -d "$tmp"
- tmp=./confstat$$-$RANDOM
- (umask 077 && mkdir $tmp)
- echo "$me: cannot create a temporary directory in ." >&2
-_ACEOF
-# CONFIG_FILES section.
-# No need to generate the scripts if there are no CONFIG_FILES.
-# This happens for instance when ./config.status config.h
-if test -n "\$CONFIG_FILES"; then
- # Protect against being on the right side of a sed subst in config.status.
- sed 's/,@/@@/; s/@,/@@/; s/,;t t\$/@;t t/; /@;t t\$/s/[\\\\&,]/\\\\&/g;
- s/@@/,@/; s/@@/@,/; s/@;t t\$/,;t t/' >\$tmp/subs.sed <<\\CEOF
-s, at SHELL@,$SHELL,;t t
-s, at PATH_SEPARATOR@,$PATH_SEPARATOR,;t t
-s, at PACKAGE_NAME@,$PACKAGE_NAME,;t t
-s, at PACKAGE_TARNAME@,$PACKAGE_TARNAME,;t t
-s, at PACKAGE_VERSION@,$PACKAGE_VERSION,;t t
-s, at PACKAGE_STRING@,$PACKAGE_STRING,;t t
-s, at PACKAGE_BUGREPORT@,$PACKAGE_BUGREPORT,;t t
-s, at exec_prefix@,$exec_prefix,;t t
-s, at prefix@,$prefix,;t t
-s, at program_transform_name@,$program_transform_name,;t t
-s, at bindir@,$bindir,;t t
-s, at sbindir@,$sbindir,;t t
-s, at libexecdir@,$libexecdir,;t t
-s, at datadir@,$datadir,;t t
-s, at sysconfdir@,$sysconfdir,;t t
-s, at sharedstatedir@,$sharedstatedir,;t t
-s, at localstatedir@,$localstatedir,;t t
-s, at libdir@,$libdir,;t t
-s, at includedir@,$includedir,;t t
-s, at oldincludedir@,$oldincludedir,;t t
-s, at infodir@,$infodir,;t t
-s, at mandir@,$mandir,;t t
-s, at build_alias@,$build_alias,;t t
-s, at host_alias@,$host_alias,;t t
-s, at target_alias@,$target_alias,;t t
-s, at DEFS@,$DEFS,;t t
-s, at ECHO_C@,$ECHO_C,;t t
-s, at ECHO_N@,$ECHO_N,;t t
-s, at ECHO_T@,$ECHO_T,;t t
-s, at LIBS@,$LIBS,;t t
-s, at INSTALL_PROGRAM@,$INSTALL_PROGRAM,;t t
-s, at INSTALL_SCRIPT@,$INSTALL_SCRIPT,;t t
-s, at INSTALL_DATA@,$INSTALL_DATA,;t t
-s, at CYGPATH_W@,$CYGPATH_W,;t t
-s, at PACKAGE@,$PACKAGE,;t t
-s, at VERSION@,$VERSION,;t t
-s, at ACLOCAL@,$ACLOCAL,;t t
-s, at AUTOCONF@,$AUTOCONF,;t t
-s, at AUTOMAKE@,$AUTOMAKE,;t t
-s, at AUTOHEADER@,$AUTOHEADER,;t t
-s, at MAKEINFO@,$MAKEINFO,;t t
-s, at install_sh@,$install_sh,;t t
-s, at STRIP@,$STRIP,;t t
-s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
-s, at INSTALL_STRIP_PROGRAM@,$INSTALL_STRIP_PROGRAM,;t t
-s, at mkdir_p@,$mkdir_p,;t t
-s, at AWK@,$AWK,;t t
-s, at SET_MAKE@,$SET_MAKE,;t t
-s, at am__leading_dot@,$am__leading_dot,;t t
-s, at AMTAR@,$AMTAR,;t t
-s, at am__tar@,$am__tar,;t t
-s, at am__untar@,$am__untar,;t t
-s, at MAINTAINER_MODE_TRUE@,$MAINTAINER_MODE_TRUE,;t t
-s, at MAINTAINER_MODE_FALSE@,$MAINTAINER_MODE_FALSE,;t t
-s, at MAINT@,$MAINT,;t t
-s, at CC@,$CC,;t t
-s, at CFLAGS@,$CFLAGS,;t t
-s, at LDFLAGS@,$LDFLAGS,;t t
-s, at CPPFLAGS@,$CPPFLAGS,;t t
-s, at ac_ct_CC@,$ac_ct_CC,;t t
-s, at EXEEXT@,$EXEEXT,;t t
-s, at OBJEXT@,$OBJEXT,;t t
-s, at DEPDIR@,$DEPDIR,;t t
-s, at am__include@,$am__include,;t t
-s, at am__quote@,$am__quote,;t t
-s, at AMDEP_TRUE@,$AMDEP_TRUE,;t t
-s, at AMDEP_FALSE@,$AMDEP_FALSE,;t t
-s, at AMDEPBACKSLASH@,$AMDEPBACKSLASH,;t t
-s, at CCDEPMODE@,$CCDEPMODE,;t t
-s, at am__fastdepCC_TRUE@,$am__fastdepCC_TRUE,;t t
-s, at am__fastdepCC_FALSE@,$am__fastdepCC_FALSE,;t t
-s, at LN_S@,$LN_S,;t t
-s, at build@,$build,;t t
-s, at build_cpu@,$build_cpu,;t t
-s, at build_vendor@,$build_vendor,;t t
-s, at build_os@,$build_os,;t t
-s, at host@,$host,;t t
-s, at host_cpu@,$host_cpu,;t t
-s, at host_vendor@,$host_vendor,;t t
-s, at host_os@,$host_os,;t t
-s, at EGREP@,$EGREP,;t t
-s, at ECHO@,$ECHO,;t t
-s, at AR@,$AR,;t t
-s, at ac_ct_AR@,$ac_ct_AR,;t t
-s, at RANLIB@,$RANLIB,;t t
-s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
-s, at CPP@,$CPP,;t t
-s, at CXX@,$CXX,;t t
-s, at CXXFLAGS@,$CXXFLAGS,;t t
-s, at ac_ct_CXX@,$ac_ct_CXX,;t t
-s, at CXXDEPMODE@,$CXXDEPMODE,;t t
-s, at am__fastdepCXX_TRUE@,$am__fastdepCXX_TRUE,;t t
-s, at am__fastdepCXX_FALSE@,$am__fastdepCXX_FALSE,;t t
-s, at CXXCPP@,$CXXCPP,;t t
-s, at F77@,$F77,;t t
-s, at FFLAGS@,$FFLAGS,;t t
-s, at ac_ct_F77@,$ac_ct_F77,;t t
-s, at LIBTOOL@,$LIBTOOL,;t t
-s, at JNI_INCLUDE@,$JNI_INCLUDE,;t t
-s, at LIBOBJS@,$LIBOBJS,;t t
-s, at LTLIBOBJS@,$LTLIBOBJS,;t t
-CEOF
-_ACEOF
- cat >>$CONFIG_STATUS <<\_ACEOF
- # Split the substitutions into bite-sized pieces for seds with
- # small command number limits, like on Digital OSF/1 and HP-UX.
- ac_max_sed_lines=48
- ac_sed_frag=1 # Number of current file.
- ac_beg=1 # First line for current file.
- ac_end=$ac_max_sed_lines # Line after last line for current file.
- ac_more_lines=:
- ac_sed_cmds=
- while $ac_more_lines; do
- if test $ac_beg -gt 1; then
- sed "1,${ac_beg}d; ${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
- else
- sed "${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
- fi
- if test ! -s $tmp/subs.frag; then
- ac_more_lines=false
- else
- # The purpose of the label and of the branching condition is to
- # speed up the sed processing (if there are no `@' at all, there
- # is no need to browse any of the substitutions).
- # These are the two extra sed commands mentioned above.
- (echo ':t
- /@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag) >$tmp/subs-$ac_sed_frag.sed
- if test -z "$ac_sed_cmds"; then
- ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
- else
- ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
- fi
- ac_sed_frag=`expr $ac_sed_frag + 1`
- ac_beg=$ac_end
- ac_end=`expr $ac_end + $ac_max_sed_lines`
- fi
- done
- ac_sed_cmds=cat
- fi
-fi # test -n "$CONFIG_FILES"
-_ACEOF
-for ac_file in : $CONFIG_FILES; do test "x$ac_file" = x: && continue
- # Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
- case $ac_file in
- - | *:- | *:-:* ) # input from stdin
- cat >$tmp/stdin
- ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
- ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
- *:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
- * ) ac_file_in=$ac_file.in ;;
- esac
- # Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
- ac_dir=`(dirname "$ac_file") 2>/dev/null ||
-$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_file" : 'X\(//\)[^/]' \| \
- X"$ac_file" : 'X\(//\)$' \| \
- X"$ac_file" : 'X\(/\)' \| \
-echo X"$ac_file" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
- /^X\(\/\/\)[^/].*/{ s//\1/; q; }
- /^X\(\/\/\)$/{ s//\1/; q; }
- /^X\(\/\).*/{ s//\1/; q; }
- s/.*/./; q'`
- { if $as_mkdir_p; then
- mkdir -p "$ac_dir"
- else
- as_dir="$ac_dir"
- as_dirs=
- while test ! -d "$as_dir"; do
- as_dirs="$as_dir $as_dirs"
- as_dir=`(dirname "$as_dir") 2>/dev/null ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| \
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- test ! -n "$as_dirs" || mkdir $as_dirs
- fi || { { echo "$as_me:$LINENO: error: cannot create directory \"$ac_dir\"" >&5
-echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
- { (exit 1); exit 1; }; }; }
- ac_builddir=.
-if test "$ac_dir" != .; then
- ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
- # A "../" for each directory in $ac_dir_suffix.
- ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
-else
- ac_dir_suffix= ac_top_builddir=
-fi
-case $srcdir in
- .) # No --srcdir option. We are building in place.
- ac_srcdir=.
- if test -z "$ac_top_builddir"; then
- ac_top_srcdir=.
- else
- ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
- fi ;;
- [\\/]* | ?:[\\/]* ) # Absolute path.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir ;;
- *) # Relative path.
- ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_builddir$srcdir ;;
-esac
-# Do not use `cd foo && pwd` to compute absolute paths, because
-# the directories may not exist.
-case `pwd` in
-.) ac_abs_builddir="$ac_dir";;
- case "$ac_dir" in
- .) ac_abs_builddir=`pwd`;;
- [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
- *) ac_abs_builddir=`pwd`/"$ac_dir";;
- esac;;
-esac
-case $ac_abs_builddir in
-.) ac_abs_top_builddir=${ac_top_builddir}.;;
- case ${ac_top_builddir}. in
- .) ac_abs_top_builddir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
- *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
- esac;;
-esac
-.) ac_abs_srcdir=$ac_srcdir;;
- case $ac_srcdir in
- .) ac_abs_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
- *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
- esac;;
-esac
-.) ac_abs_top_srcdir=$ac_top_srcdir;;
- case $ac_top_srcdir in
- .) ac_abs_top_srcdir=$ac_abs_builddir;;
- [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
- *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
- esac;;
-esac
- case $INSTALL in
- [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
- *) ac_INSTALL=$ac_top_builddir$INSTALL ;;
- esac
- if test x"$ac_file" != x-; then
- { echo "$as_me:$LINENO: creating $ac_file" >&5
-echo "$as_me: creating $ac_file" >&6;}
- rm -f "$ac_file"
- fi
- # Let's still pretend it is `configure' which instantiates (i.e., don't
- # use $as_me), people would be surprised to read:
- # /* config.h. Generated by config.status. */
- if test x"$ac_file" = x-; then
- configure_input=
- else
- configure_input="$ac_file. "
- fi
- configure_input=$configure_input"Generated from `echo $ac_file_in |
- sed 's,.*/,,'` by configure."
- # First look for the input files in the build tree, otherwise in the
- # src tree.
- ac_file_inputs=`IFS=:
- for f in $ac_file_in; do
- case $f in
- -) echo $tmp/stdin ;;
- # Absolute (can't be DOS-style, as IFS=:)
- test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
-echo "$as_me: error: cannot find input file: $f" >&2;}
- echo "$f";;
- *) # Relative
- if test -f "$f"; then
- # Build tree
- echo "$f"
- elif test -f "$srcdir/$f"; then
- # Source tree
- echo "$srcdir/$f"
- else
- # /dev/null tree
- { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
- fi;;
- esac
- done` || { (exit 1); exit 1; }
-_ACEOF
- sed "$ac_vpsub
-$extrasub
-_ACEOF
-:t
-/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
-s, at configure_input@,$configure_input,;t t
-s, at srcdir@,$ac_srcdir,;t t
-s, at abs_srcdir@,$ac_abs_srcdir,;t t
-s, at top_srcdir@,$ac_top_srcdir,;t t
-s, at abs_top_srcdir@,$ac_abs_top_srcdir,;t t
-s, at builddir@,$ac_builddir,;t t
-s, at abs_builddir@,$ac_abs_builddir,;t t
-s, at top_builddir@,$ac_top_builddir,;t t
-s, at abs_top_builddir@,$ac_abs_top_builddir,;t t
-s, at INSTALL@,$ac_INSTALL,;t t
-" $ac_file_inputs | (eval "$ac_sed_cmds") >$tmp/out
- rm -f $tmp/stdin
- mv $tmp/out $ac_file
- else
- cat $tmp/out
- rm -f $tmp/out
- fi
-done
-_ACEOF
-# CONFIG_HEADER section.
-# These sed commands are passed to sed as "A NAME B NAME C VALUE D", where
-# NAME is the cpp macro being defined and VALUE is the value it is being given.
-# ac_d sets the value in "#define NAME VALUE" lines.
-ac_dA='s,^\([ ]*\)#\([ ]*define[ ][ ]*\)'
-ac_dB='[ ].*$,\1#\2'
-ac_dC=' '
-ac_dD=',;t'
-# ac_u turns "#undef NAME" without trailing blanks into "#define NAME VALUE".
-ac_uA='s,^\([ ]*\)#\([ ]*\)undef\([ ][ ]*\)'
-ac_uB='$,\1#\2define\3'
-ac_uC=' '
-ac_uD=',;t'
-for ac_file in : $CONFIG_HEADERS; do test "x$ac_file" = x: && continue
- case $ac_file in
- cat >$tmp/stdin
- esac
- test x"$ac_file" != x- && { echo "$as_me:$LINENO: creating $ac_file" >&5
- # src tree.
- case $f in
- # Do quote $f, to prevent DOS paths from being IFS'd.
- echo "$f";;
- *) # Relative
- # Build tree
- echo "$f"
- # Source tree
- echo "$srcdir/$f"
- else
- # /dev/null tree
- fi;;
- esac
- # Remove the trailing spaces.
- sed 's/[ ]*$//' $ac_file_inputs >$tmp/in
-_ACEOF
-# Transform confdefs.h into two sed scripts, `conftest.defines' and
-# `conftest.undefs', that substitutes the proper values into
-# config.h.in to produce config.h. The first handles `#define'
-# templates, and the second `#undef' templates.
-# And first: Protect against being on the right side of a sed subst in
-# config.status. Protect against being in an unquoted here document
-# in config.status.
-rm -f conftest.defines conftest.undefs
-# Using a here document instead of a string reduces the quoting nightmare.
-# Putting comments in sed scripts is not portable.
-# `end' is used to avoid that the second main sed command (meant for
-# 0-ary CPP macros) applies to n-ary macro definitions.
-# See the Autoconf documentation for `clear'.
-cat >confdef2sed.sed <<\_ACEOF
-s/[\\&,]/\\&/g
-s,[\\$`],\\&,g
-t clear
-: clear
-s,^[ ]*#[ ]*define[ ][ ]*\([^ (][^ (]*\)\(([^)]*)\)[ ]*\(.*\)$,${ac_dA}\1${ac_dB}\1\2${ac_dC}\3${ac_dD},gp
-t end
-s,^[ ]*#[ ]*define[ ][ ]*\([^ ][^ ]*\)[ ]*\(.*\)$,${ac_dA}\1${ac_dB}\1${ac_dC}\2${ac_dD},gp
-: end
-_ACEOF
-# If some macros were called several times there might be several times
-# the same #defines, which is useless. Nevertheless, we may not want to
-# sort them, since we want the *last* AC-DEFINE to be honored.
-uniq confdefs.h | sed -n -f confdef2sed.sed >conftest.defines
-sed 's/ac_d/ac_u/g' conftest.defines >conftest.undefs
-rm -f confdef2sed.sed
-# This sed command replaces #undef with comments. This is necessary, for
-# example, in the case of _POSIX_SOURCE, which is predefined and required
-# on some systems where configure will not decide to define it.
-cat >>conftest.undefs <<\_ACEOF
-s,^[ ]*#[ ]*undef[ ][ ]*[a-zA-Z_][a-zA-Z_0-9]*,/* & */,
-_ACEOF
-# Break up conftest.defines because some shells have a limit on the size
-# of here documents, and old seds have small limits too (100 cmds).
-echo ' # Handle all the #define templates only if necessary.' >>$CONFIG_STATUS
-echo ' if grep "^[ ]*#[ ]*define" $tmp/in >/dev/null; then' >>$CONFIG_STATUS
-echo ' # If there are no defines, we may have an empty if/fi' >>$CONFIG_STATUS
-echo ' :' >>$CONFIG_STATUS
-rm -f conftest.tail
-while grep . conftest.defines >/dev/null
-do
- # Write a limited-size here document to $tmp/defines.sed.
- echo ' cat >$tmp/defines.sed <<CEOF' >>$CONFIG_STATUS
- # Speed up: don't consider the non `#define' lines.
- echo '/^[ ]*#[ ]*define/!b' >>$CONFIG_STATUS
- # Work around the forget-to-reset-the-flag bug.
- echo 't clr' >>$CONFIG_STATUS
- echo ': clr' >>$CONFIG_STATUS
- sed ${ac_max_here_lines}q conftest.defines >>$CONFIG_STATUS
- echo 'CEOF
- sed -f $tmp/defines.sed $tmp/in >$tmp/out
- rm -f $tmp/in
- mv $tmp/out $tmp/in
-' >>$CONFIG_STATUS
- sed 1,${ac_max_here_lines}d conftest.defines >conftest.tail
- rm -f conftest.defines
- mv conftest.tail conftest.defines
-done
-echo ' fi # grep' >>$CONFIG_STATUS
-echo >>$CONFIG_STATUS
-# Break up conftest.undefs because some shells have a limit on the size
-echo ' # Handle all the #undef templates' >>$CONFIG_STATUS
-while grep . conftest.undefs >/dev/null
-do
- # Write a limited-size here document to $tmp/undefs.sed.
- echo ' cat >$tmp/undefs.sed <<CEOF' >>$CONFIG_STATUS
- # Speed up: don't consider the non `#undef'
- echo '/^[ ]*#[ ]*undef/!b' >>$CONFIG_STATUS
- sed ${ac_max_here_lines}q conftest.undefs >>$CONFIG_STATUS
- echo 'CEOF
- sed -f $tmp/undefs.sed $tmp/in >$tmp/out
- rm -f $tmp/in
-' >>$CONFIG_STATUS
- sed 1,${ac_max_here_lines}d conftest.undefs >conftest.tail
- rm -f conftest.undefs
- mv conftest.tail conftest.undefs
-done
-rm -f conftest.undefs
- echo "/* Generated by configure. */" >$tmp/config.h
- else
- echo "/* $ac_file. Generated by configure. */" >$tmp/config.h
- fi
- cat $tmp/in >>$tmp/config.h
- rm -f $tmp/in
- if diff $ac_file $tmp/config.h >/dev/null 2>&1; then
- { echo "$as_me:$LINENO: $ac_file is unchanged" >&5
-echo "$as_me: $ac_file is unchanged" >&6;}
- else
-echo X"$ac_file" |
- s/.*/./; q'`
- else
- as_dir="$ac_dir"
- as_dirs=
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- rm -f $ac_file
- mv $tmp/config.h $ac_file
- fi
- else
- cat $tmp/config.h
- rm -f $tmp/config.h
- fi
-# Compute $ac_file's index in $config_headers.
-_am_stamp_count=1
-for _am_header in $config_headers :; do
- case $_am_header in
- $ac_file | $ac_file:* )
- break ;;
- _am_stamp_count=`expr $_am_stamp_count + 1` ;;
- esac
-done
-echo "timestamp for $ac_file" >`(dirname $ac_file) 2>/dev/null ||
-$as_expr X$ac_file : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X$ac_file : 'X\(//\)[^/]' \| \
- X$ac_file : 'X\(//\)$' \| \
- X$ac_file : 'X\(/\)' \| \
-echo X$ac_file |
- s/.*/./; q'`/stamp-h$_am_stamp_count
-done
-_ACEOF
-# CONFIG_COMMANDS section.
-for ac_file in : $CONFIG_COMMANDS; do test "x$ac_file" = x: && continue
- ac_dest=`echo "$ac_file" | sed 's,:.*,,'`
- ac_source=`echo "$ac_file" | sed 's,[^:]*:,,'`
- ac_dir=`(dirname "$ac_dest") 2>/dev/null ||
-$as_expr X"$ac_dest" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$ac_dest" : 'X\(//\)[^/]' \| \
- X"$ac_dest" : 'X\(//\)$' \| \
- X"$ac_dest" : 'X\(/\)' \| \
-echo X"$ac_dest" |
- s/.*/./; q'`
- else
- as_dir="$ac_dir"
- as_dirs=
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- ac_builddir=.
-else
-fi
-case $srcdir in
- ac_srcdir=.
- ac_top_srcdir=.
- else
- fi ;;
-esac
-case `pwd` in
- case "$ac_dir" in
- esac;;
-esac
- esac;;
-esac
- esac;;
-esac
- esac;;
-esac
- { echo "$as_me:$LINENO: executing $ac_dest commands" >&5
-echo "$as_me: executing $ac_dest commands" >&6;}
- case $ac_dest in
- depfiles ) test x"$AMDEP_TRUE" != x"" || for mf in $CONFIG_FILES; do
- # Strip MF so we end up with the name of the file.
- mf=`echo "$mf" | sed -e 's/:.*$//'`
- # Check whether this is an Automake generated Makefile or not.
- # We used to match only the files named `Makefile.in', but
- # some people rename them; so instead we look at the file content.
- # Grep'ing the first line is not enough: some people post-process
- # each Makefile.in and add a new line on top of each file to say so.
- # So let's grep whole file.
- if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
- dirpart=`(dirname "$mf") 2>/dev/null ||
-$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$mf" : 'X\(//\)[^/]' \| \
- X"$mf" : 'X\(//\)$' \| \
- X"$mf" : 'X\(/\)' \| \
-echo X"$mf" |
- s/.*/./; q'`
- else
- continue
- fi
- # Extract the definition of DEPDIR, am__include, and am__quote
- # from the Makefile without running `make'.
- DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
- test -z "$DEPDIR" && continue
- am__include=`sed -n 's/^am__include = //p' < "$mf"`
- test -z "am__include" && continue
- am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
- # When using ansi2knr, U may be empty or an underscore; expand it
- U=`sed -n 's/^U = //p' < "$mf"`
- # Find all dependency output files, they are included files with
- # $(DEPDIR) in their names. We invoke sed twice because it is the
- # simplest approach to changing $(DEPDIR) to its actual value in the
- # expansion.
- for file in `sed -n "
- s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
- sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
- # Make sure the directory exists.
- test -f "$dirpart/$file" && continue
- fdir=`(dirname "$file") 2>/dev/null ||
-$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$file" : 'X\(//\)[^/]' \| \
- X"$file" : 'X\(//\)$' \| \
- X"$file" : 'X\(/\)' \| \
-echo X"$file" |
- s/.*/./; q'`
- mkdir -p $dirpart/$fdir
- else
- as_dir=$dirpart/$fdir
- as_dirs=
-echo X"$as_dir" |
- s/.*/./; q'`
- done
- fi || { { echo "$as_me:$LINENO: error: cannot create directory $dirpart/$fdir" >&5
-echo "$as_me: error: cannot create directory $dirpart/$fdir" >&2;}
- # echo "creating $dirpart/$file"
- echo '# dummy' > "$dirpart/$file"
- done
-done
- esac
-done
-_ACEOF
-{ (exit 0); exit 0; }
-_ACEOF
-chmod +x $CONFIG_STATUS
-ac_clean_files=$ac_clean_files_save
-# configure is writing to config.log, and then calls config.status.
-# config.status does its own redirection, appending to config.log.
-# Unfortunately, on DOS this fails, as config.log is still kept open
-# by configure, so config.status won't be able to write to it; its
-# output is simply discarded. So we exec the FD to /dev/null,
-# effectively closing config.log, so it can be properly (re)opened and
-# appended to by config.status. When coming back to configure, we
-# need to make the FD available again.
-if test "$no_create" != yes; then
- ac_cs_success=:
- ac_config_status_args=
- test "$silent" = yes &&
- ac_config_status_args="$ac_config_status_args --quiet"
- exec 5>/dev/null
- $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false
- exec 5>>config.log
- # Use ||, not &&, to avoid exiting from the if with $? = 1, which
- # would make configure fail if this is the last instruction.
- $ac_cs_success || { (exit 1); exit 1; }
-fi
Deleted: trunk/MgDev/Oem/proj-4.5.0/install-sh
--- trunk/MgDev/Oem/proj-4.5.0/install-sh 2007-03-21 21:28:21 UTC (rev 1328)
+++ trunk/MgDev/Oem/proj-4.5.0/install-sh 2007-03-21 21:34:22 UTC (rev 1329)
@@ -1,251 +0,0 @@
-#!/bin/sh
-# install - install a program, script, or datafile
-# This comes from X11R5 (mit/util/scripts/install.sh).
-# Copyright 1991 by the Massachusetts Institute of Technology
-# Permission to use, copy, modify, distribute, and sell this software and its
-# documentation for any purpose is hereby granted without fee, provided that
-# the above copyright notice appear in all copies and that both that
-# copyright notice and this permission notice appear in supporting
-# documentation, and that the name of M.I.T. not be used in advertising or
-# publicity pertaining to distribution of the software without specific,
-# written prior permission. M.I.T. makes no representations about the
-# suitability of this software for any purpose. It is provided "as is"
-# without express or implied warranty.
-# Calling this script install-sh is preferred over install.sh, to prevent
-# `make' implicit rules from creating a file called install from it
-# when there is no Makefile.
-# This script is compatible with the BSD install script, but was written
-# from scratch. It can only install one file at a time, a restriction
-# shared with many OS's install programs.
-# set DOITPROG to echo to test this script
-# Don't use :- since 4.3BSD and earlier shells don't like it.
-doit="${DOITPROG-}"
-# put in absolute paths if you don't have them in your path; or use env. vars.
-mvprog="${MVPROG-mv}"
-cpprog="${CPPROG-cp}"
-chmodprog="${CHMODPROG-chmod}"
-chownprog="${CHOWNPROG-chown}"
-chgrpprog="${CHGRPPROG-chgrp}"
-stripprog="${STRIPPROG-strip}"
-rmprog="${RMPROG-rm}"
-mkdirprog="${MKDIRPROG-mkdir}"
-transformbasename=""
-transform_arg=""
-instcmd="$mvprog"
-chmodcmd="$chmodprog 0755"
-chowncmd=""
-chgrpcmd=""
-stripcmd=""
-rmcmd="$rmprog -f"
-mvcmd="$mvprog"
-src=""
-dst=""
-dir_arg=""
-while [ x"$1" != x ]; do
- case $1 in
- -c) instcmd="$cpprog"
- shift
- continue;;
- -d) dir_arg=true
- shift
- continue;;
- -m) chmodcmd="$chmodprog $2"
- shift
- shift
- continue;;
- -o) chowncmd="$chownprog $2"
- shift
- shift
- continue;;
- -g) chgrpcmd="$chgrpprog $2"
- shift
- shift
- continue;;
- -s) stripcmd="$stripprog"
- shift
- continue;;
- -t=*) transformarg=`echo $1 | sed 's/-t=//'`
- shift
- continue;;
- -b=*) transformbasename=`echo $1 | sed 's/-b=//'`
- shift
- continue;;
- *) if [ x"$src" = x ]
- then
- src=$1
- else
- # this colon is to work around a 386BSD /bin/sh bug
- dst=$1
- fi
- shift
- continue;;
- esac
-done
-if [ x"$src" = x ]
-then
- echo "install: no input file specified"
- exit 1
-else
- true
-fi
-if [ x"$dir_arg" != x ]; then
- dst=$src
- src=""
- if [ -d $dst ]; then
- instcmd=:
- chmodcmd=""
- else
- instcmd=mkdir
- fi
-else
-# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
-# might cause directories to be created, which would be especially bad
-# if $src (and thus $dsttmp) contains '*'.
- if [ -f $src -o -d $src ]
- then
- true
- else
- echo "install: $src does not exist"
- exit 1
- fi
- if [ x"$dst" = x ]
- then
- echo "install: no destination specified"
- exit 1
- else
- true
- fi
-# If destination is a directory, append the input filename; if your system
-# does not like double slashes in filenames, you may need to add some logic
- if [ -d $dst ]
- then
- dst="$dst"/`basename $src`
- else
- true
- fi
-fi
-## this sed command emulates the dirname command
-dstdir=`echo $dst | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
-# Make sure that the destination directory exists.
-# this part is taken from Noah Friedman's mkinstalldirs script
-# Skip lots of stat calls in the usual case.
-if [ ! -d "$dstdir" ]; then
-defaultIFS='
-IFS="${IFS-${defaultIFS}}"
-oIFS="${IFS}"
-# Some sh's can't handle IFS=/ for some reason.
-IFS='%'
-set - `echo ${dstdir} | sed -e 's@/@%@g' -e 's@^%@/@'`
-IFS="${oIFS}"
-pathcomp=''
-while [ $# -ne 0 ] ; do
- pathcomp="${pathcomp}${1}"
- shift
- if [ ! -d "${pathcomp}" ] ;
- then
- $mkdirprog "${pathcomp}"
- else
- true
- fi
- pathcomp="${pathcomp}/"
-done
-fi
-then
- $doit $instcmd $dst &&
- if [ x"$chowncmd" != x ]; then $doit $chowncmd $dst; else true ; fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dst; else true ; fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd $dst; else true ; fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dst; else true ; fi
-else
-# If we're going to rename the final executable, determine the name now.
- if [ x"$transformarg" = x ]
- then
- dstfile=`basename $dst`
- else
- dstfile=`basename $dst $transformbasename |
- sed $transformarg`$transformbasename
- fi
-# don't allow the sed command to completely eliminate the filename
- if [ x"$dstfile" = x ]
- then
- else
- true
- fi
-# Make a temp file name in the proper directory.
- dsttmp=$dstdir/#inst.$$#
-# Move or copy the file name to the temp name
- $doit $instcmd $src $dsttmp &&
- trap "rm -f ${dsttmp}" 0 &&
-# and set any options; do chmod last to preserve setuid bits
-# If any of these fail, we abort the whole thing. If we want to
-# ignore errors from any of these, just make sure not to ignore
-# errors from the above "$doit $instcmd $src $dsttmp" command.
- if [ x"$chowncmd" != x ]; then $doit $chowncmd $dsttmp; else true;fi &&
- if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dsttmp; else true;fi &&
- if [ x"$stripcmd" != x ]; then $doit $stripcmd $dsttmp; else true;fi &&
- if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dsttmp; else true;fi &&
-# Now rename the file to the real destination.
- $doit $rmcmd -f $dstdir/$dstfile &&
- $doit $mvcmd $dsttmp $dstdir/$dstfile
-fi &&
-exit 0
More information about the mapguide-commits
