[mapguide-commits] r1330 - trunk/MgDev/Oem/proj-4.5.0
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Mar 21 17:36:34 EDT 2007
Author: stevedang
Date: 2007-03-21 17:36:34 -0400 (Wed, 21 Mar 2007)
New Revision: 1330
Added:
   trunk/MgDev/Oem/proj-4.5.0/configure
   trunk/MgDev/Oem/proj-4.5.0/install-sh
Change exec bit.
Added: trunk/MgDev/Oem/proj-4.5.0/configure
--- trunk/MgDev/Oem/proj-4.5.0/configure	                        (rev 0)
+++ trunk/MgDev/Oem/proj-4.5.0/configure	2007-03-21 21:36:34 UTC (rev 1330)
@@ -0,0 +1,20574 @@
+#! /bin/sh
+# Guess values for system-dependent variables and create Makefiles.
+# Generated by GNU Autoconf 2.59 for PROJ.4 Projections 4.5.0.
+# Report bugs to <warmerdam at pobox.com>.
+# Copyright (C) 2003 Free Software Foundation, Inc.
+# This configure script is free software; the Free Software Foundation
+# gives unlimited permission to copy, distribute and modify it.
+## M4sh Initialization.  ##
+# Be Bourne compatible
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+  emulate sh
+  NULLCMD=:
+  # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '${1+"$@"}'='"$@"'
+elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
+  set -o posix
+fi
+DUALCASE=1; export DUALCASE # for MKS sh
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+  as_unset=unset
+else
+  as_unset=false
+fi
+# Work around bugs in pre-3.0 UWIN ksh.
+$as_unset ENV MAIL MAILPATH
+PS1='$ '
+PS2='> '
+PS4='+ '
+# NLS nuisances.
+for as_var in \
+  LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
+  LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
+  LC_TELEPHONE LC_TIME
+do
+  if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
+    eval $as_var=C; export $as_var
+  else
+    $as_unset $as_var
+  fi
+done
+# Required to use basename.
+if expr a : '\(a\)' >/dev/null 2>&1; then
+  as_expr=expr
+else
+  as_expr=false
+fi
+if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
+  as_basename=basename
+else
+  as_basename=false
+fi
+# Name of the executable.
+as_me=`$as_basename "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+	 X"$0" : 'X\(//\)$' \| \
+	 X"$0" : 'X\(/\)$' \| \
+	 .     : '\(.\)' 2>/dev/null ||
+echo X/"$0" |
+    sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
+  	  /^X\/\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\/\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+# PATH needs CR, and LINENO needs CR and PATH.
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
+# The user is always right.
+if test "${PATH_SEPARATOR+set}" != set; then
+  echo "#! /bin/sh" >conf$$.sh
+  echo  "exit 0"   >>conf$$.sh
+  chmod +x conf$$.sh
+  if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
+    PATH_SEPARATOR=';'
+  else
+    PATH_SEPARATOR=:
+  fi
+  rm -f conf$$.sh
+fi
+  as_lineno_1=$LINENO
+  as_lineno_2=$LINENO
+  as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
+  test "x$as_lineno_1" != "x$as_lineno_2" &&
+  test "x$as_lineno_3"  = "x$as_lineno_2"  || {
+  # Find who we are.  Look in the path if we contain no path at all
+  # relative or not.
+  case $0 in
+    *[\\/]* ) as_myself=$0 ;;
+    *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
+  esac
+  # We did not find ourselves, most probably we were run as `sh COMMAND'
+  # in which case we are not to be found in the path.
+  if test "x$as_myself" = x; then
+    as_myself=$0
+  fi
+  if test ! -f "$as_myself"; then
+    { echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2
+   { (exit 1); exit 1; }; }
+  fi
+  case $CONFIG_SHELL in
+    as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
+do
+  IFS=$as_save_IFS
+  for as_base in sh bash ksh sh5; do
+	 case $as_dir in
+	   if ("$as_dir/$as_base" -c '
+  test "x$as_lineno_3"  = "x$as_lineno_2" ') 2>/dev/null; then
+	     $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
+	     $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
+	     CONFIG_SHELL=$as_dir/$as_base
+	     export CONFIG_SHELL
+	     exec "$CONFIG_SHELL" "$0" ${1+"$@"}
+	   fi;;
+	 esac
+       done
+done
+  esac
+  # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+  # uniformly replaced by the line number.  The first 'sed' inserts a
+  # line-number line before each line; the second 'sed' does the real
+  # work.  The second script uses 'N' to pair each line-number line
+  # with the numbered line, and appends trailing '-' during
+  # substitution so that $LINENO is not a special case at line end.
+  # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+  # second 'sed' script.  Blame Lee E. McMahon for sed's syntax.  :-)
+  sed '=' <$as_myself |
+    sed '
+      N
+      s,$,-,
+      : loop
+      s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
+      t loop
+      s,-$,,
+      s,^['$as_cr_digits']*\n,,
+    ' >$as_me.lineno &&
+  chmod +x $as_me.lineno ||
+    { echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+  # Don't try to exec as it changes $[0], causing all sort of problems
+  # (the dirname of $[0] is not the place where we might find the
+  # original and so on.  Autoconf is especially sensible to this).
+  . ./$as_me.lineno
+  # Exit status is that of the last command.
+  exit
+case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
+  *c*,-n*) ECHO_N= ECHO_C='
+' ECHO_T='	' ;;
+  *c*,*  ) ECHO_N=-n ECHO_C= ECHO_T= ;;
+  *)       ECHO_N= ECHO_C='\c' ECHO_T= ;;
+esac
+  as_expr=expr
+else
+  as_expr=false
+fi
+rm -f conf$$ conf$$.exe conf$$.file
+echo >conf$$.file
+if ln -s conf$$.file conf$$ 2>/dev/null; then
+  # We could just check for DJGPP; but this test a) works b) is more generic
+  # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
+  if test -f conf$$.exe; then
+    # Don't use ln at all; we don't have any links
+    as_ln_s='cp -p'
+  else
+    as_ln_s='ln -s'
+  fi
+elif ln conf$$.file conf$$ 2>/dev/null; then
+  as_ln_s=ln
+else
+  as_ln_s='cp -p'
+fi
+if mkdir -p . 2>/dev/null; then
+  as_mkdir_p=:
+else
+  test -d ./-p && rmdir ./-p
+  as_mkdir_p=false
+fi
+as_executable_p="test -f"
+# Sed expression to map a string onto a valid CPP name.
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
+# Sed expression to map a string onto a valid variable name.
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
+# IFS
+# We need space, tab and new line, in precisely that order.
+as_nl='
+IFS=" 	$as_nl"
+# CDPATH.
+$as_unset CDPATH
+# Check that we are running under the correct shell.
+SHELL=${CONFIG_SHELL-/bin/sh}
+case X$ECHO in
+X*--fallback-echo)
+  # Remove one level of quotation (which was required for Make).
+  ECHO=`echo "$ECHO" | sed 's,\\\\\$\\$0,'$0','`
+esac
+echo=${ECHO-echo}
+if test "X$1" = X--no-reexec; then
+  # Discard the --no-reexec flag, and continue.
+  shift
+elif test "X$1" = X--fallback-echo; then
+  # Avoid inline document here, it may be left over
+elif test "X`($echo '\t') 2>/dev/null`" = 'X\t' ; then
+  # Yippee, $echo works!
+else
+  # Restart under the correct shell.
+  exec $SHELL "$0" --no-reexec ${1+"$@"}
+fi
+if test "X$1" = X--fallback-echo; then
+  # used as fallback echo
+  shift
+  cat <<EOF
+EOF
+  exit 0
+fi
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+if test -z "$ECHO"; then
+if test "X${echo_test_string+set}" != Xset; then
+# find a string as large as possible, as long as the shell can cope with it
+  for cmd in 'sed 50q "$0"' 'sed 20q "$0"' 'sed 10q "$0"' 'sed 2q "$0"' 'echo test'; do
+    # expected sizes: less than 2Kb, 1Kb, 512 bytes, 16 bytes, ...
+    if (echo_test_string=`eval $cmd`) 2>/dev/null &&
+       echo_test_string=`eval $cmd` &&
+       (test "X$echo_test_string" = "X$echo_test_string") 2>/dev/null
+    then
+      break
+    fi
+  done
+fi
+if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
+   echo_testing_string=`($echo "$echo_test_string") 2>/dev/null` &&
+   test "X$echo_testing_string" = "X$echo_test_string"; then
+else
+  # The Solaris, AIX, and Digital Unix default echo programs unquote
+  # backslashes.  This makes it impossible to quote backslashes using
+  #   echo "$something" | sed 's/\\/\\\\/g'
+  # So, first we look for a working echo in the user's PATH.
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for dir in $PATH /usr/ucb; do
+    IFS="$lt_save_ifs"
+    if (test -f $dir/echo || test -f $dir/echo$ac_exeext) &&
+       test "X`($dir/echo '\t') 2>/dev/null`" = 'X\t' &&
+       echo_testing_string=`($dir/echo "$echo_test_string") 2>/dev/null` &&
+      echo="$dir/echo"
+      break
+    fi
+  done
+  if test "X$echo" = Xecho; then
+    # We didn't find a better echo, so look for alternatives.
+    if test "X`(print -r '\t') 2>/dev/null`" = 'X\t' &&
+       echo_testing_string=`(print -r "$echo_test_string") 2>/dev/null` &&
+      # This shell has a builtin print -r that does the trick.
+      echo='print -r'
+    elif (test -f /bin/ksh || test -f /bin/ksh$ac_exeext) &&
+	 test "X$CONFIG_SHELL" != X/bin/ksh; then
+      # If we have ksh, try running configure again with it.
+      ORIGINAL_CONFIG_SHELL=${CONFIG_SHELL-/bin/sh}
+      export ORIGINAL_CONFIG_SHELL
+      CONFIG_SHELL=/bin/ksh
+      exec $CONFIG_SHELL "$0" --no-reexec ${1+"$@"}
+    else
+      # Try using printf.
+      echo='printf %s\n'
+      if test "X`($echo '\t') 2>/dev/null`" = 'X\t' &&
+	# Cool, printf works
+      elif echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
+	   test "X$echo_testing_string" = 'X\t' &&
+	   echo_testing_string=`($ORIGINAL_CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
+	CONFIG_SHELL=$ORIGINAL_CONFIG_SHELL
+	SHELL="$CONFIG_SHELL"
+	export SHELL
+	echo="$CONFIG_SHELL $0 --fallback-echo"
+      elif echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo '\t') 2>/dev/null` &&
+	   echo_testing_string=`($CONFIG_SHELL "$0" --fallback-echo "$echo_test_string") 2>/dev/null` &&
+      else
+	# maybe with a smaller string...
+	prev=:
+	for cmd in 'echo test' 'sed 2q "$0"' 'sed 10q "$0"' 'sed 20q "$0"' 'sed 50q "$0"'; do
+	  if (test "X$echo_test_string" = "X`eval $cmd`") 2>/dev/null
+	  then
+	    break
+	  fi
+	  prev="$cmd"
+	done
+	if test "$prev" != 'sed 50q "$0"'; then
+	  echo_test_string=`eval $prev`
+	  export echo_test_string
+	  exec ${ORIGINAL_CONFIG_SHELL-${CONFIG_SHELL-/bin/sh}} "$0" ${1+"$@"}
+	else
+	  # Oops.  We lost completely, so just stick with echo.
+	  echo=echo
+	fi
+      fi
+    fi
+  fi
+fi
+fi
+# Copy echo and quote the copy suitably for passing to libtool from
+# the Makefile, instead of quoting the original, which is used later.
+ECHO=$echo
+if test "X$ECHO" = "X$CONFIG_SHELL $0 --fallback-echo"; then
+   ECHO="$CONFIG_SHELL \\\$\$0 --fallback-echo"
+fi
+tagnames=${tagnames+${tagnames},}CXX
+tagnames=${tagnames+${tagnames},}F77
+# Name of the host.
+# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
+# so uname gets run too.
+ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
+exec 6>&1
+# Initializations.
+ac_default_prefix=/usr/local
+ac_config_libobj_dir=.
+cross_compiling=no
+subdirs=
+MFLAGS=
+MAKEFLAGS=
+# Maximum number of lines to put in a shell here document.
+# This variable seems obsolete.  It should probably be removed, and
+# only ac_max_sed_lines should be used.
+: ${ac_max_here_lines=38}
+# Identity of this package.
+PACKAGE_NAME='PROJ.4 Projections'
+PACKAGE_TARNAME='proj'
+PACKAGE_VERSION='4.5.0'
+PACKAGE_STRING='PROJ.4 Projections 4.5.0'
+PACKAGE_BUGREPORT='warmerdam at pobox.com'
+# Factoring default headers for most tests.
+ac_includes_default="\
+#include <stdio.h>
+#if HAVE_SYS_TYPES_H
+# include <sys/types.h>
+#endif
+#if HAVE_SYS_STAT_H
+# include <sys/stat.h>
+#endif
+#if STDC_HEADERS
+# include <stdlib.h>
+# include <stddef.h>
+#else
+# if HAVE_STDLIB_H
+# endif
+#endif
+#if HAVE_STRING_H
+# if !STDC_HEADERS && HAVE_MEMORY_H
+#  include <memory.h>
+# endif
+# include <string.h>
+#endif
+#if HAVE_STRINGS_H
+# include <strings.h>
+#endif
+#if HAVE_INTTYPES_H
+# include <inttypes.h>
+#else
+# if HAVE_STDINT_H
+#  include <stdint.h>
+# endif
+#endif
+#if HAVE_UNISTD_H
+# include <unistd.h>
+#endif"
+ac_subst_vars='SHELL PATH_SEPARATOR PACKAGE_NAME PACKAGE_TARNAME PACKAGE_VERSION PACKAGE_STRING PACKAGE_BUGREPORT exec_prefix prefix program_transform_name bindir sbindir libexecdir datadir sysconfdir sharedstatedir localstatedir libdir includedir oldincludedir infodir mandir build_alias host_alias target_alias DEFS ECHO_C ECHO_N ECHO_T LIBS INSTALL_PROGRAM INSTALL_SCRIPT INSTALL_DATA CYGPATH_W PACKAGE VERSION ACLOCAL AUTOCONF AUTOMAKE AUTOHEADER MAKEINFO install_sh STRIP ac_ct_STRIP INSTALL_STRIP_PROGRAM mkdir_p AWK SET_MAKE am__leading_dot AMTAR am__tar am__untar MAINTAINER_MODE_TRUE MAINTAINER_MODE_FALSE MAINT CC CFLAGS LDFLAGS CPPFLAGS ac_ct_CC EXEEXT OBJEXT DEPDIR am__include am__quote AMDEP_TRUE AMDEP_FALSE AMDEPBACKSLASH CCDEPMODE am__fastdepCC_TRUE am__fastdepCC_FALSE LN_S build build_cpu build_vendor build_os host host_cpu host_vendor host_os EGREP ECHO AR ac_ct_AR RANLIB ac_ct_RANLIB CPP CXX CXXFLAGS ac_ct_CXX CXXDEPMODE am__fastdepCXX_TRUE am__fastdepCXX_FALSE CXXCPP F77 FFLAGS ac_ct_F77 LIBTOOL JNI_INCLUDE LIBOBJS LTLIBOBJS'
+ac_subst_files=''
+# Initialize some variables set by options.
+ac_init_help=
+ac_init_version=false
+# The variables have the same names as the options, with
+# dashes changed to underlines.
+cache_file=/dev/null
+exec_prefix=NONE
+no_create=
+no_recursion=
+prefix=NONE
+program_prefix=NONE
+program_suffix=NONE
+program_transform_name=s,x,x,
+silent=
+site=
+srcdir=
+verbose=
+x_includes=NONE
+x_libraries=NONE
+# Installation directory options.
+# These are left unexpanded so users can "make install exec_prefix=/foo"
+# and all the variables that are supposed to be based on exec_prefix
+# by default will actually change.
+# Use braces instead of parens because sh, perl, etc. also accept them.
+bindir='${exec_prefix}/bin'
+sbindir='${exec_prefix}/sbin'
+libexecdir='${exec_prefix}/libexec'
+datadir='${prefix}/share'
+sysconfdir='${prefix}/etc'
+sharedstatedir='${prefix}/com'
+localstatedir='${prefix}/var'
+libdir='${exec_prefix}/lib'
+includedir='${prefix}/include'
+oldincludedir='/usr/include'
+infodir='${prefix}/info'
+mandir='${prefix}/man'
+ac_prev=
+for ac_option
+do
+  # If the previous option needs an argument, assign it.
+  if test -n "$ac_prev"; then
+    eval "$ac_prev=\$ac_option"
+    ac_prev=
+    continue
+  fi
+  ac_optarg=`expr "x$ac_option" : 'x[^=]*=\(.*\)'`
+  # Accept the important Cygnus configure options, so we can diagnose typos.
+  case $ac_option in
+  -bindir | --bindir | --bindi | --bind | --bin | --bi)
+    ac_prev=bindir ;;
+  -bindir=* | --bindir=* | --bindi=* | --bind=* | --bin=* | --bi=*)
+    bindir=$ac_optarg ;;
+  -build | --build | --buil | --bui | --bu)
+    ac_prev=build_alias ;;
+  -build=* | --build=* | --buil=* | --bui=* | --bu=*)
+    build_alias=$ac_optarg ;;
+  -cache-file | --cache-file | --cache-fil | --cache-fi \
+  | --cache-f | --cache- | --cache | --cach | --cac | --ca | --c)
+    ac_prev=cache_file ;;
+  -cache-file=* | --cache-file=* | --cache-fil=* | --cache-fi=* \
+  | --cache-f=* | --cache-=* | --cache=* | --cach=* | --cac=* | --ca=* | --c=*)
+    cache_file=$ac_optarg ;;
+  --config-cache | -C)
+    cache_file=config.cache ;;
+  -datadir | --datadir | --datadi | --datad | --data | --dat | --da)
+    ac_prev=datadir ;;
+  -datadir=* | --datadir=* | --datadi=* | --datad=* | --data=* | --dat=* \
+  | --da=*)
+    datadir=$ac_optarg ;;
+  -disable-* | --disable-*)
+    ac_feature=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
+    # Reject names that are not valid shell variable names.
+    expr "x$ac_feature" : ".*[^-_$as_cr_alnum]" >/dev/null &&
+      { echo "$as_me: error: invalid feature name: $ac_feature" >&2
+    ac_feature=`echo $ac_feature | sed 's/-/_/g'`
+    eval "enable_$ac_feature=no" ;;
+  -enable-* | --enable-*)
+    ac_feature=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
+      *=*) ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`;;
+      *) ac_optarg=yes ;;
+    esac
+    eval "enable_$ac_feature='$ac_optarg'" ;;
+  -exec-prefix | --exec_prefix | --exec-prefix | --exec-prefi \
+  | --exec-pref | --exec-pre | --exec-pr | --exec-p | --exec- \
+  | --exec | --exe | --ex)
+    ac_prev=exec_prefix ;;
+  -exec-prefix=* | --exec_prefix=* | --exec-prefix=* | --exec-prefi=* \
+  | --exec-pref=* | --exec-pre=* | --exec-pr=* | --exec-p=* | --exec-=* \
+  | --exec=* | --exe=* | --ex=*)
+    exec_prefix=$ac_optarg ;;
+  -gas | --gas | --ga | --g)
+    # Obsolete; use --with-gas.
+    with_gas=yes ;;
+  -help | --help | --hel | --he | -h)
+    ac_init_help=long ;;
+  -help=r* | --help=r* | --hel=r* | --he=r* | -hr*)
+    ac_init_help=recursive ;;
+  -help=s* | --help=s* | --hel=s* | --he=s* | -hs*)
+    ac_init_help=short ;;
+  -host | --host | --hos | --ho)
+    ac_prev=host_alias ;;
+  -host=* | --host=* | --hos=* | --ho=*)
+    host_alias=$ac_optarg ;;
+  -includedir | --includedir | --includedi | --included | --include \
+  | --includ | --inclu | --incl | --inc)
+    ac_prev=includedir ;;
+  -includedir=* | --includedir=* | --includedi=* | --included=* | --include=* \
+  | --includ=* | --inclu=* | --incl=* | --inc=*)
+    includedir=$ac_optarg ;;
+  -infodir | --infodir | --infodi | --infod | --info | --inf)
+    ac_prev=infodir ;;
+  -infodir=* | --infodir=* | --infodi=* | --infod=* | --info=* | --inf=*)
+    infodir=$ac_optarg ;;
+  -libdir | --libdir | --libdi | --libd)
+    ac_prev=libdir ;;
+  -libdir=* | --libdir=* | --libdi=* | --libd=*)
+    libdir=$ac_optarg ;;
+  -libexecdir | --libexecdir | --libexecdi | --libexecd | --libexec \
+  | --libexe | --libex | --libe)
+    ac_prev=libexecdir ;;
+  -libexecdir=* | --libexecdir=* | --libexecdi=* | --libexecd=* | --libexec=* \
+  | --libexe=* | --libex=* | --libe=*)
+    libexecdir=$ac_optarg ;;
+  -localstatedir | --localstatedir | --localstatedi | --localstated \
+  | --localstate | --localstat | --localsta | --localst \
+  | --locals | --local | --loca | --loc | --lo)
+    ac_prev=localstatedir ;;
+  -localstatedir=* | --localstatedir=* | --localstatedi=* | --localstated=* \
+  | --localstate=* | --localstat=* | --localsta=* | --localst=* \
+  | --locals=* | --local=* | --loca=* | --loc=* | --lo=*)
+    localstatedir=$ac_optarg ;;
+  -mandir | --mandir | --mandi | --mand | --man | --ma | --m)
+    ac_prev=mandir ;;
+  -mandir=* | --mandir=* | --mandi=* | --mand=* | --man=* | --ma=* | --m=*)
+    mandir=$ac_optarg ;;
+  -nfp | --nfp | --nf)
+    # Obsolete; use --without-fp.
+    with_fp=no ;;
+  -no-create | --no-create | --no-creat | --no-crea | --no-cre \
+  | --no-cr | --no-c | -n)
+    no_create=yes ;;
+  -no-recursion | --no-recursion | --no-recursio | --no-recursi \
+  | --no-recurs | --no-recur | --no-recu | --no-rec | --no-re | --no-r)
+    no_recursion=yes ;;
+  -oldincludedir | --oldincludedir | --oldincludedi | --oldincluded \
+  | --oldinclude | --oldinclud | --oldinclu | --oldincl | --oldinc \
+  | --oldin | --oldi | --old | --ol | --o)
+    ac_prev=oldincludedir ;;
+  -oldincludedir=* | --oldincludedir=* | --oldincludedi=* | --oldincluded=* \
+  | --oldinclude=* | --oldinclud=* | --oldinclu=* | --oldincl=* | --oldinc=* \
+  | --oldin=* | --oldi=* | --old=* | --ol=* | --o=*)
+    oldincludedir=$ac_optarg ;;
+  -prefix | --prefix | --prefi | --pref | --pre | --pr | --p)
+    ac_prev=prefix ;;
+  -prefix=* | --prefix=* | --prefi=* | --pref=* | --pre=* | --pr=* | --p=*)
+    prefix=$ac_optarg ;;
+  -program-prefix | --program-prefix | --program-prefi | --program-pref \
+  | --program-pre | --program-pr | --program-p)
+    ac_prev=program_prefix ;;
+  -program-prefix=* | --program-prefix=* | --program-prefi=* \
+  | --program-pref=* | --program-pre=* | --program-pr=* | --program-p=*)
+    program_prefix=$ac_optarg ;;
+  -program-suffix | --program-suffix | --program-suffi | --program-suff \
+  | --program-suf | --program-su | --program-s)
+    ac_prev=program_suffix ;;
+  -program-suffix=* | --program-suffix=* | --program-suffi=* \
+  | --program-suff=* | --program-suf=* | --program-su=* | --program-s=*)
+    program_suffix=$ac_optarg ;;
+  -program-transform-name | --program-transform-name \
+  | --program-transform-nam | --program-transform-na \
+  | --program-transform-n | --program-transform- \
+  | --program-transform | --program-transfor \
+  | --program-transfo | --program-transf \
+  | --program-trans | --program-tran \
+  | --progr-tra | --program-tr | --program-t)
+    ac_prev=program_transform_name ;;
+  -program-transform-name=* | --program-transform-name=* \
+  | --program-transform-nam=* | --program-transform-na=* \
+  | --program-transform-n=* | --program-transform-=* \
+  | --program-transform=* | --program-transfor=* \
+  | --program-transfo=* | --program-transf=* \
+  | --program-trans=* | --program-tran=* \
+  | --progr-tra=* | --program-tr=* | --program-t=*)
+    program_transform_name=$ac_optarg ;;
+  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
+  | -silent | --silent | --silen | --sile | --sil)
+    silent=yes ;;
+  -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
+    ac_prev=sbindir ;;
+  -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
+  | --sbi=* | --sb=*)
+    sbindir=$ac_optarg ;;
+  -sharedstatedir | --sharedstatedir | --sharedstatedi \
+  | --sharedstated | --sharedstate | --sharedstat | --sharedsta \
+  | --sharedst | --shareds | --shared | --share | --shar \
+  | --sha | --sh)
+    ac_prev=sharedstatedir ;;
+  -sharedstatedir=* | --sharedstatedir=* | --sharedstatedi=* \
+  | --sharedstated=* | --sharedstate=* | --sharedstat=* | --sharedsta=* \
+  | --sharedst=* | --shareds=* | --shared=* | --share=* | --shar=* \
+  | --sha=* | --sh=*)
+    sharedstatedir=$ac_optarg ;;
+  -site | --site | --sit)
+    ac_prev=site ;;
+  -site=* | --site=* | --sit=*)
+    site=$ac_optarg ;;
+  -srcdir | --srcdir | --srcdi | --srcd | --src | --sr)
+    ac_prev=srcdir ;;
+  -srcdir=* | --srcdir=* | --srcdi=* | --srcd=* | --src=* | --sr=*)
+    srcdir=$ac_optarg ;;
+  -sysconfdir | --sysconfdir | --sysconfdi | --sysconfd | --sysconf \
+  | --syscon | --sysco | --sysc | --sys | --sy)
+    ac_prev=sysconfdir ;;
+  -sysconfdir=* | --sysconfdir=* | --sysconfdi=* | --sysconfd=* | --sysconf=* \
+  | --syscon=* | --sysco=* | --sysc=* | --sys=* | --sy=*)
+    sysconfdir=$ac_optarg ;;
+  -target | --target | --targe | --targ | --tar | --ta | --t)
+    ac_prev=target_alias ;;
+  -target=* | --target=* | --targe=* | --targ=* | --tar=* | --ta=* | --t=*)
+    target_alias=$ac_optarg ;;
+  -v | -verbose | --verbose | --verbos | --verbo | --verb)
+    verbose=yes ;;
+  -version | --version | --versio | --versi | --vers | -V)
+    ac_init_version=: ;;
+  -with-* | --with-*)
+    ac_package=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
+    expr "x$ac_package" : ".*[^-_$as_cr_alnum]" >/dev/null &&
+      { echo "$as_me: error: invalid package name: $ac_package" >&2
+    ac_package=`echo $ac_package| sed 's/-/_/g'`
+    esac
+    eval "with_$ac_package='$ac_optarg'" ;;
+  -without-* | --without-*)
+    ac_package=`expr "x$ac_option" : 'x-*without-\(.*\)'`
+    ac_package=`echo $ac_package | sed 's/-/_/g'`
+    eval "with_$ac_package=no" ;;
+  --x)
+    # Obsolete; use --with-x.
+    with_x=yes ;;
+  -x-includes | --x-includes | --x-include | --x-includ | --x-inclu \
+  | --x-incl | --x-inc | --x-in | --x-i)
+    ac_prev=x_includes ;;
+  -x-includes=* | --x-includes=* | --x-include=* | --x-includ=* | --x-inclu=* \
+  | --x-incl=* | --x-inc=* | --x-in=* | --x-i=*)
+    x_includes=$ac_optarg ;;
+  -x-libraries | --x-libraries | --x-librarie | --x-librari \
+  | --x-librar | --x-libra | --x-libr | --x-lib | --x-li | --x-l)
+    ac_prev=x_libraries ;;
+  -x-libraries=* | --x-libraries=* | --x-librarie=* | --x-librari=* \
+  | --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
+    x_libraries=$ac_optarg ;;
+  -*) { echo "$as_me: error: unrecognized option: $ac_option
+Try \`$0 --help' for more information." >&2
+    ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
+    expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
+      { echo "$as_me: error: invalid variable name: $ac_envvar" >&2
+    ac_optarg=`echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"`
+    eval "$ac_envvar='$ac_optarg'"
+    export $ac_envvar ;;
+    # FIXME: should be removed in autoconf 3.0.
+    echo "$as_me: WARNING: you should use --build, --host, --target" >&2
+    expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
+      echo "$as_me: WARNING: invalid host type: $ac_option" >&2
+    : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
+  esac
+done
+if test -n "$ac_prev"; then
+  ac_option=--`echo $ac_prev | sed 's/_/-/g'`
+  { echo "$as_me: error: missing argument to $ac_option" >&2
+fi
+# Be sure to have absolute paths.
+for ac_var in exec_prefix prefix
+do
+  eval ac_val=$`echo $ac_var`
+  case $ac_val in
+    [\\/$]* | ?:[\\/]* | NONE | '' ) ;;
+    *)  { echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
+   { (exit 1); exit 1; }; };;
+  esac
+done
+for ac_var in bindir sbindir libexecdir datadir sysconfdir sharedstatedir \
+	      localstatedir libdir includedir oldincludedir infodir mandir
+do
+  case $ac_val in
+  esac
+done
+# There might be people who depend on the old broken behavior: `$host'
+# used to hold the argument of --host etc.
+# FIXME: To remove some day.
+build=$build_alias
+host=$host_alias
+target=$target_alias
+if test "x$host_alias" != x; then
+  if test "x$build_alias" = x; then
+    cross_compiling=maybe
+    echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
+    If a cross compiler is detected then cross compile mode will be used." >&2
+  elif test "x$build_alias" != "x$host_alias"; then
+    cross_compiling=yes
+  fi
+fi
+ac_tool_prefix=
+test -n "$host_alias" && ac_tool_prefix=$host_alias-
+test "$silent" = yes && exec 6>/dev/null
+# Find the source files, if location was not specified.
+if test -z "$srcdir"; then
+  ac_srcdir_defaulted=yes
+  # Try the directory containing this script, then its parent.
+  ac_confdir=`(dirname "$0") 2>/dev/null ||
+$as_expr X"$0" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$0" : 'X\(//\)[^/]' \| \
+	 X"$0" : 'X\(/\)' \| \
+echo X"$0" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
+  	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
+  	  /^X\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+  srcdir=$ac_confdir
+  if test ! -r $srcdir/$ac_unique_file; then
+    srcdir=..
+  fi
+else
+  ac_srcdir_defaulted=no
+fi
+if test ! -r $srcdir/$ac_unique_file; then
+  if test "$ac_srcdir_defaulted" = yes; then
+    { echo "$as_me: error: cannot find sources ($ac_unique_file) in $ac_confdir or .." >&2
+  else
+    { echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
+  fi
+fi
+(cd $srcdir && test -r ./$ac_unique_file) 2>/dev/null ||
+  { echo "$as_me: error: sources are in $srcdir, but \`cd $srcdir' does not work" >&2
+srcdir=`echo "$srcdir" | sed 's%\([^\\/]\)[\\/]*$%\1%'`
+ac_env_build_alias_set=${build_alias+set}
+ac_env_build_alias_value=$build_alias
+ac_cv_env_build_alias_set=${build_alias+set}
+ac_cv_env_build_alias_value=$build_alias
+ac_env_host_alias_set=${host_alias+set}
+ac_env_host_alias_value=$host_alias
+ac_cv_env_host_alias_set=${host_alias+set}
+ac_cv_env_host_alias_value=$host_alias
+ac_env_target_alias_set=${target_alias+set}
+ac_env_target_alias_value=$target_alias
+ac_cv_env_target_alias_set=${target_alias+set}
+ac_cv_env_target_alias_value=$target_alias
+ac_env_CC_set=${CC+set}
+ac_env_CC_value=$CC
+ac_cv_env_CC_set=${CC+set}
+ac_cv_env_CC_value=$CC
+ac_env_CFLAGS_set=${CFLAGS+set}
+ac_env_CFLAGS_value=$CFLAGS
+ac_cv_env_CFLAGS_set=${CFLAGS+set}
+ac_cv_env_CFLAGS_value=$CFLAGS
+ac_env_LDFLAGS_set=${LDFLAGS+set}
+ac_env_LDFLAGS_value=$LDFLAGS
+ac_cv_env_LDFLAGS_set=${LDFLAGS+set}
+ac_cv_env_LDFLAGS_value=$LDFLAGS
+ac_env_CPPFLAGS_set=${CPPFLAGS+set}
+ac_env_CPPFLAGS_value=$CPPFLAGS
+ac_cv_env_CPPFLAGS_set=${CPPFLAGS+set}
+ac_cv_env_CPPFLAGS_value=$CPPFLAGS
+ac_env_CPP_set=${CPP+set}
+ac_env_CPP_value=$CPP
+ac_cv_env_CPP_set=${CPP+set}
+ac_cv_env_CPP_value=$CPP
+ac_env_CXX_set=${CXX+set}
+ac_env_CXX_value=$CXX
+ac_cv_env_CXX_set=${CXX+set}
+ac_cv_env_CXX_value=$CXX
+ac_env_CXXFLAGS_set=${CXXFLAGS+set}
+ac_env_CXXFLAGS_value=$CXXFLAGS
+ac_cv_env_CXXFLAGS_set=${CXXFLAGS+set}
+ac_cv_env_CXXFLAGS_value=$CXXFLAGS
+ac_env_CXXCPP_set=${CXXCPP+set}
+ac_env_CXXCPP_value=$CXXCPP
+ac_cv_env_CXXCPP_set=${CXXCPP+set}
+ac_cv_env_CXXCPP_value=$CXXCPP
+ac_env_F77_set=${F77+set}
+ac_env_F77_value=$F77
+ac_cv_env_F77_set=${F77+set}
+ac_cv_env_F77_value=$F77
+ac_env_FFLAGS_set=${FFLAGS+set}
+ac_env_FFLAGS_value=$FFLAGS
+ac_cv_env_FFLAGS_set=${FFLAGS+set}
+ac_cv_env_FFLAGS_value=$FFLAGS
+# Report the --help message.
+if test "$ac_init_help" = "long"; then
+  # Omit some internal or obsolete options to make the list less imposing.
+  # This message is too long to be a string in the A/UX 3.1 sh.
+  cat <<_ACEOF
+\`configure' configures PROJ.4 Projections 4.5.0 to adapt to many kinds of systems.
+Usage: $0 [OPTION]... [VAR=VALUE]...
+To assign environment variables (e.g., CC, CFLAGS...), specify them as
+VAR=VALUE.  See below for descriptions of some of the useful variables.
+Defaults for the options are specified in brackets.
+Configuration:
+  -h, --help              display this help and exit
+      --help=short        display options specific to this package
+      --help=recursive    display the short help of all the included packages
+  -V, --version           display version information and exit
+  -q, --quiet, --silent   do not print \`checking...' messages
+      --cache-file=FILE   cache test results in FILE [disabled]
+  -C, --config-cache      alias for \`--cache-file=config.cache'
+  -n, --no-create         do not create output files
+      --srcdir=DIR        find the sources in DIR [configure dir or \`..']
+_ACEOF
+  cat <<_ACEOF
+Installation directories:
+  --prefix=PREFIX         install architecture-independent files in PREFIX
+			  [$ac_default_prefix]
+  --exec-prefix=EPREFIX   install architecture-dependent files in EPREFIX
+			  [PREFIX]
+By default, \`make install' will install all the files in
+\`$ac_default_prefix/bin', \`$ac_default_prefix/lib' etc.  You can specify
+an installation prefix other than \`$ac_default_prefix' using \`--prefix',
+for instance \`--prefix=\$HOME'.
+For better control, use the options below.
+Fine tuning of the installation directories:
+  --bindir=DIR           user executables [EPREFIX/bin]
+  --sbindir=DIR          system admin executables [EPREFIX/sbin]
+  --libexecdir=DIR       program executables [EPREFIX/libexec]
+  --datadir=DIR          read-only architecture-independent data [PREFIX/share]
+  --sysconfdir=DIR       read-only single-machine data [PREFIX/etc]
+  --sharedstatedir=DIR   modifiable architecture-independent data [PREFIX/com]
+  --localstatedir=DIR    modifiable single-machine data [PREFIX/var]
+  --libdir=DIR           object code libraries [EPREFIX/lib]
+  --includedir=DIR       C header files [PREFIX/include]
+  --oldincludedir=DIR    C header files for non-gcc [/usr/include]
+  --infodir=DIR          info documentation [PREFIX/info]
+  --mandir=DIR           man documentation [PREFIX/man]
+_ACEOF
+  cat <<\_ACEOF
+Program names:
+  --program-prefix=PREFIX            prepend PREFIX to installed program names
+  --program-suffix=SUFFIX            append SUFFIX to installed program names
+  --program-transform-name=PROGRAM   run sed PROGRAM on installed program names
+System types:
+  --build=BUILD     configure for building on BUILD [guessed]
+  --host=HOST       cross-compile to build programs to run on HOST [BUILD]
+_ACEOF
+fi
+if test -n "$ac_init_help"; then
+  case $ac_init_help in
+     short | recursive ) echo "Configuration of PROJ.4 Projections 4.5.0:";;
+   esac
+  cat <<\_ACEOF
+Optional Features:
+  --disable-FEATURE       do not include FEATURE (same as --enable-FEATURE=no)
+  --enable-FEATURE[=ARG]  include FEATURE [ARG=yes]
+  --enable-maintainer-mode  enable make rules and dependencies not useful
+			  (and sometimes confusing) to the casual installer
+  --disable-dependency-tracking  speeds up one-time build
+  --enable-dependency-tracking   do not reject slow dependency extractors
+  --enable-shared[=PKGS]
+                          build shared libraries [default=yes]
+  --enable-static[=PKGS]
+                          build static libraries [default=yes]
+  --enable-fast-install[=PKGS]
+                          optimize for fast installation [default=yes]
+  --disable-libtool-lock  avoid locking (might break parallel builds)
+Optional Packages:
+  --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
+  --without-PACKAGE       do not use PACKAGE (same as --with-PACKAGE=no)
+  --with-gnu-ld           assume the C compiler uses GNU ld [default=no]
+  --with-pic              try to use only PIC/non-PIC objects [default=use
+                          both]
+  --with-tags[=TAGS]
+                          include additional configurations [automatic]
+  --with-jni=dir          Include Java/JNI support, add optional include dir
+Some influential environment variables:
+  CC          C compiler command
+  CFLAGS      C compiler flags
+  LDFLAGS     linker flags, e.g. -L<lib dir> if you have libraries in a
+              nonstandard directory <lib dir>
+  CPPFLAGS    C/C++ preprocessor flags, e.g. -I<include dir> if you have
+              headers in a nonstandard directory <include dir>
+  CPP         C preprocessor
+  CXX         C++ compiler command
+  CXXFLAGS    C++ compiler flags
+  CXXCPP      C++ preprocessor
+  F77         Fortran 77 compiler command
+  FFLAGS      Fortran 77 compiler flags
+Use these variables to override the choices made by `configure' or to help
+it to find libraries and programs with nonstandard names/locations.
+Report bugs to <warmerdam at pobox.com>.
+_ACEOF
+fi
+if test "$ac_init_help" = "recursive"; then
+  # If there are subdirs, report their specific --help.
+  ac_popdir=`pwd`
+  for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
+    test -d $ac_dir || continue
+    ac_builddir=.
+if test "$ac_dir" != .; then
+  ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
+  # A "../" for each directory in $ac_dir_suffix.
+  ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
+else
+  ac_dir_suffix= ac_top_builddir=
+fi
+case $srcdir in
+  .)  # No --srcdir option.  We are building in place.
+    ac_srcdir=.
+    if test -z "$ac_top_builddir"; then
+       ac_top_srcdir=.
+    else
+       ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
+    fi ;;
+  [\\/]* | ?:[\\/]* )  # Absolute path.
+    ac_srcdir=$srcdir$ac_dir_suffix;
+    ac_top_srcdir=$srcdir ;;
+  *) # Relative path.
+    ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
+    ac_top_srcdir=$ac_top_builddir$srcdir ;;
+esac
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+  case "$ac_dir" in
+  .) ac_abs_builddir=`pwd`;;
+  [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+  *) ac_abs_builddir=`pwd`/"$ac_dir";;
+  esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+  case ${ac_top_builddir}. in
+  .) ac_abs_top_builddir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+  *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+  esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+  case $ac_srcdir in
+  .) ac_abs_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+  *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+  esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+  case $ac_top_srcdir in
+  .) ac_abs_top_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+  *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+  esac;;
+esac
+    cd $ac_dir
+    # Check for guested configure; otherwise get Cygnus style configure.
+    if test -f $ac_srcdir/configure.gnu; then
+      echo
+      $SHELL $ac_srcdir/configure.gnu  --help=recursive
+    elif test -f $ac_srcdir/configure; then
+      echo
+      $SHELL $ac_srcdir/configure  --help=recursive
+    elif test -f $ac_srcdir/configure.ac ||
+	   test -f $ac_srcdir/configure.in; then
+      echo
+      $ac_configure --help
+    else
+      echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
+    fi
+    cd $ac_popdir
+  done
+fi
+test -n "$ac_init_help" && exit 0
+if $ac_init_version; then
+  cat <<\_ACEOF
+PROJ.4 Projections configure 4.5.0
+generated by GNU Autoconf 2.59
+Copyright (C) 2003 Free Software Foundation, Inc.
+This configure script is free software; the Free Software Foundation
+gives unlimited permission to copy, distribute and modify it.
+_ACEOF
+  exit 0
+fi
+exec 5>config.log
+cat >&5 <<_ACEOF
+This file contains any messages produced by compilers while
+running configure, to aid debugging if configure makes a mistake.
+It was created by PROJ.4 Projections $as_me 4.5.0, which was
+generated by GNU Autoconf 2.59.  Invocation command line was
+  $ $0 $@
+_ACEOF
+cat <<_ASUNAME
+## Platform. ##
+hostname = `(hostname || uname -n) 2>/dev/null | sed 1q`
+uname -m = `(uname -m) 2>/dev/null || echo unknown`
+uname -r = `(uname -r) 2>/dev/null || echo unknown`
+uname -s = `(uname -s) 2>/dev/null || echo unknown`
+uname -v = `(uname -v) 2>/dev/null || echo unknown`
+/usr/bin/uname -p = `(/usr/bin/uname -p) 2>/dev/null || echo unknown`
+/bin/uname -X     = `(/bin/uname -X) 2>/dev/null     || echo unknown`
+/bin/arch              = `(/bin/arch) 2>/dev/null              || echo unknown`
+/usr/bin/arch -k       = `(/usr/bin/arch -k) 2>/dev/null       || echo unknown`
+/usr/convex/getsysinfo = `(/usr/convex/getsysinfo) 2>/dev/null || echo unknown`
+hostinfo               = `(hostinfo) 2>/dev/null               || echo unknown`
+/bin/machine           = `(/bin/machine) 2>/dev/null           || echo unknown`
+/usr/bin/oslevel       = `(/usr/bin/oslevel) 2>/dev/null       || echo unknown`
+/bin/universe          = `(/bin/universe) 2>/dev/null          || echo unknown`
+_ASUNAME
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+  echo "PATH: $as_dir"
+done
+} >&5
+cat >&5 <<_ACEOF
+## Core tests. ##
+_ACEOF
+# Keep a trace of the command line.
+# Strip out --no-create and --no-recursion so they do not pile up.
+# Strip out --silent because we don't want to record it for future runs.
+# Also quote any args containing shell meta-characters.
+# Make two passes to allow for proper duplicate-argument suppression.
+ac_configure_args=
+ac_configure_args0=
+ac_configure_args1=
+ac_sep=
+ac_must_keep_next=false
+for ac_pass in 1 2
+do
+  for ac_arg
+  do
+    case $ac_arg in
+    -no-create | --no-c* | -n | -no-recursion | --no-r*) continue ;;
+      continue ;;
+      ac_arg=`echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
+    esac
+    case $ac_pass in
+    1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
+    2)
+      ac_configure_args1="$ac_configure_args1 '$ac_arg'"
+      if test $ac_must_keep_next = true; then
+	ac_must_keep_next=false # Got value, back to normal.
+      else
+	case $ac_arg in
+	  *=* | --config-cache | -C | -disable-* | --disable-* \
+	  | -enable-* | --enable-* | -gas | --g* | -nfp | --nf* \
+	  | -q | -quiet | --q* | -silent | --sil* | -v | -verb* \
+	  | -with-* | --with-* | -without-* | --without-* | --x)
+	    case "$ac_configure_args0 " in
+	      "$ac_configure_args1"*" '$ac_arg' "* ) continue ;;
+	    esac
+	  -* ) ac_must_keep_next=true ;;
+	esac
+      fi
+      ac_configure_args="$ac_configure_args$ac_sep'$ac_arg'"
+      # Get rid of the leading space.
+      ac_sep=" "
+    esac
+  done
+done
+$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
+$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
+# When interrupted or exit'd, cleanup temporary files, and complete
+# config.log.  We remove comments because anyway the quotes in there
+# would cause problems or look ugly.
+# WARNING: Be sure not to use single quotes in there, as some shells,
+# such as our DU 5.0 friend, will then `close' the trap.
+trap 'exit_status=$?
+  # Save into config.log some information that might help in debugging.
+    echo
+    cat <<\_ASBOX
+## Cache variables. ##
+_ASBOX
+    echo
+    # The following way of writing the cache mishandles newlines in values,
+  (set) 2>&1 |
+    case `(ac_space='"'"' '"'"'; set | grep ac_space) 2>&1` in
+    *ac_space=\ *)
+      sed -n \
+	"s/'"'"'/'"'"'\\\\'"'"''"'"'/g;
+	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='"'"'\\2'"'"'/p"
+      sed -n \
+	"s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+    esac;
+    echo
+    cat <<\_ASBOX
+## Output variables. ##
+_ASBOX
+    echo
+    for ac_var in $ac_subst_vars
+    do
+      echo "$ac_var='"'"'$ac_val'"'"'"
+    done | sort
+    echo
+    if test -n "$ac_subst_files"; then
+      cat <<\_ASBOX
+## Output files. ##
+_ASBOX
+      echo
+      for ac_var in $ac_subst_files
+      do
+      done | sort
+      echo
+    fi
+    if test -s confdefs.h; then
+      cat <<\_ASBOX
+## confdefs.h. ##
+_ASBOX
+      echo
+      sed "/^$/d" confdefs.h | sort
+      echo
+    fi
+    test "$ac_signal" != 0 &&
+      echo "$as_me: caught signal $ac_signal"
+    echo "$as_me: exit $exit_status"
+  } >&5
+  rm -f core *.core &&
+  rm -rf conftest* confdefs* conf$$* $ac_clean_files &&
+    exit $exit_status
+     ' 0
+for ac_signal in 1 2 13 15; do
+  trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
+done
+ac_signal=0
+# confdefs.h avoids OS command line length limits that DEFS can exceed.
+rm -rf conftest* confdefs.h
+# AIX cpp loses on an empty file, so make sure it contains at least a newline.
+echo >confdefs.h
+# Predefined preprocessor variables.
+cat >>confdefs.h <<_ACEOF
+#define PACKAGE_NAME "$PACKAGE_NAME"
+_ACEOF
+#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
+_ACEOF
+#define PACKAGE_VERSION "$PACKAGE_VERSION"
+_ACEOF
+#define PACKAGE_STRING "$PACKAGE_STRING"
+_ACEOF
+#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
+_ACEOF
+# Let the site file select an alternate cache file if it wants to.
+# Prefer explicitly selected file to automatically selected ones.
+if test -z "$CONFIG_SITE"; then
+  if test "x$prefix" != xNONE; then
+    CONFIG_SITE="$prefix/share/config.site $prefix/etc/config.site"
+  else
+    CONFIG_SITE="$ac_default_prefix/share/config.site $ac_default_prefix/etc/config.site"
+  fi
+fi
+for ac_site_file in $CONFIG_SITE; do
+  if test -r "$ac_site_file"; then
+    { echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
+echo "$as_me: loading site script $ac_site_file" >&6;}
+    sed 's/^/| /' "$ac_site_file" >&5
+    . "$ac_site_file"
+  fi
+done
+if test -r "$cache_file"; then
+  # Some versions of bash will fail to source /dev/null (special
+  # files actually), so we avoid doing that.
+  if test -f "$cache_file"; then
+    { echo "$as_me:$LINENO: loading cache $cache_file" >&5
+echo "$as_me: loading cache $cache_file" >&6;}
+    case $cache_file in
+      [\\/]* | ?:[\\/]* ) . $cache_file;;
+      *)                      . ./$cache_file;;
+    esac
+  fi
+else
+  { echo "$as_me:$LINENO: creating cache $cache_file" >&5
+echo "$as_me: creating cache $cache_file" >&6;}
+  >$cache_file
+fi
+# Check that the precious variables saved in the cache have kept the same
+# value.
+ac_cache_corrupted=false
+for ac_var in `(set) 2>&1 |
+	       sed -n 's/^ac_env_\([a-zA-Z_0-9]*\)_set=.*/\1/p'`; do
+  eval ac_old_set=\$ac_cv_env_${ac_var}_set
+  eval ac_new_set=\$ac_env_${ac_var}_set
+  eval ac_old_val="\$ac_cv_env_${ac_var}_value"
+  eval ac_new_val="\$ac_env_${ac_var}_value"
+  case $ac_old_set,$ac_new_set in
+    set,)
+      { echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
+      ac_cache_corrupted=: ;;
+    ,set)
+      { echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
+echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
+      if test "x$ac_old_val" != "x$ac_new_val"; then
+	{ echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
+echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
+	{ echo "$as_me:$LINENO:   former value:  $ac_old_val" >&5
+echo "$as_me:   former value:  $ac_old_val" >&2;}
+	{ echo "$as_me:$LINENO:   current value: $ac_new_val" >&5
+echo "$as_me:   current value: $ac_new_val" >&2;}
+      fi;;
+  esac
+  # Pass precious variables to config.status.
+  if test "$ac_new_set" = set; then
+    case $ac_new_val in
+      ac_arg=$ac_var=`echo "$ac_new_val" | sed "s/'/'\\\\\\\\''/g"` ;;
+    *) ac_arg=$ac_var=$ac_new_val ;;
+    esac
+    case " $ac_configure_args " in
+      *" '$ac_arg' "*) ;; # Avoid dups.  Use of quotes ensures accuracy.
+      *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
+    esac
+  fi
+done
+if $ac_cache_corrupted; then
+  { echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
+echo "$as_me: error: changes in the environment can compromise the build" >&2;}
+  { { echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
+echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+ac_ext=c
+am__api_version="1.9"
+ac_aux_dir=
+for ac_dir in $srcdir $srcdir/.. $srcdir/../..; do
+  if test -f $ac_dir/install-sh; then
+    ac_aux_dir=$ac_dir
+    ac_install_sh="$ac_aux_dir/install-sh -c"
+    break
+  elif test -f $ac_dir/install.sh; then
+    ac_install_sh="$ac_aux_dir/install.sh -c"
+    break
+  elif test -f $ac_dir/shtool; then
+    ac_install_sh="$ac_aux_dir/shtool install -c"
+    break
+  fi
+done
+if test -z "$ac_aux_dir"; then
+  { { echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&5
+echo "$as_me: error: cannot find install-sh or install.sh in $srcdir $srcdir/.. $srcdir/../.." >&2;}
+fi
+ac_config_guess="$SHELL $ac_aux_dir/config.guess"
+ac_config_sub="$SHELL $ac_aux_dir/config.sub"
+ac_configure="$SHELL $ac_aux_dir/configure" # This should be Cygnus configure.
+# Find a good install program.  We prefer a C program (faster),
+# so one script is as good as another.  But avoid the broken or
+# incompatible versions:
+# SysV /etc/install, /usr/sbin/install
+# SunOS /usr/etc/install
+# IRIX /sbin/install
+# AIX /bin/install
+# AmigaOS /C/install, which installs bootblocks on floppy discs
+# AIX 4 /usr/bin/installbsd, which doesn't work without a -g flag
+# AFS /usr/afsws/bin/install, which mishandles nonexistent args
+# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
+# OS/2's system install, which has a completely different semantic
+# ./install, which can be erroneously created by make from ./install.sh.
+echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
+echo $ECHO_N "checking for a BSD-compatible install... $ECHO_C" >&6
+if test -z "$INSTALL"; then
+if test "${ac_cv_path_install+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+do
+  IFS=$as_save_IFS
+  # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in
+  ./ | .// | /cC/* | \
+  /etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
+  ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
+  /usr/ucb/* ) ;;
+    # OSF1 and SCO ODT 3.0 have their own names for install.
+    # Don't use installbsd from OSF since it installs stuff as root
+    # by default.
+    for ac_prog in ginstall scoinst install; do
+      for ac_exec_ext in '' $ac_executable_extensions; do
+	if $as_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+	  if test $ac_prog = install &&
+	    grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
+	    # AIX install.  It has an incompatible calling convention.
+	  elif test $ac_prog = install &&
+	    grep pwplus "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
+	    # program-specific install script used by HP pwplus--don't use.
+	  else
+	    ac_cv_path_install="$as_dir/$ac_prog$ac_exec_ext -c"
+	    break 3
+	  fi
+	fi
+      done
+    done
+esac
+done
+fi
+  if test "${ac_cv_path_install+set}" = set; then
+    INSTALL=$ac_cv_path_install
+  else
+    # As a last resort, use the slow shell script.  We don't cache a
+    # path for INSTALL within a source directory, because that will
+    # break other packages using the cache if that directory is
+    # removed, or if the path is relative.
+    INSTALL=$ac_install_sh
+  fi
+fi
+echo "$as_me:$LINENO: result: $INSTALL" >&5
+echo "${ECHO_T}$INSTALL" >&6
+# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
+# It thinks the first close brace ends the variable substitution.
+test -z "$INSTALL_PROGRAM" && INSTALL_PROGRAM='${INSTALL}'
+test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
+test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
+echo "$as_me:$LINENO: checking whether build environment is sane" >&5
+echo $ECHO_N "checking whether build environment is sane... $ECHO_C" >&6
+# Just in case
+sleep 1
+echo timestamp > conftest.file
+# Do `set' in a subshell so we don't clobber the current shell's
+# arguments.  Must try -L first in case configure is actually a
+# symlink; some systems play weird games with the mod time of symlinks
+# (eg FreeBSD returns the mod time of the symlink's containing
+# directory).
+if (
+   set X `ls -Lt $srcdir/configure conftest.file 2> /dev/null`
+   if test "$*" = "X"; then
+      # -L didn't work.
+      set X `ls -t $srcdir/configure conftest.file`
+   fi
+   rm -f conftest.file
+   if test "$*" != "X $srcdir/configure conftest.file" \
+      && test "$*" != "X conftest.file $srcdir/configure"; then
+      # If neither matched, then we have a broken ls.  This can happen
+      # if, for instance, CONFIG_SHELL is bash and it inherits a
+      # broken ls alias from the environment.  This has actually
+      # happened.  Such a system could not be considered "sane".
+      { { echo "$as_me:$LINENO: error: ls -t appears to fail.  Make sure there is not a broken
+alias in your environment" >&5
+echo "$as_me: error: ls -t appears to fail.  Make sure there is not a broken
+alias in your environment" >&2;}
+   fi
+   test "$2" = conftest.file
+then
+   # Ok.
+else
+   { { echo "$as_me:$LINENO: error: newly created file is older than distributed files!
+Check your system clock" >&5
+echo "$as_me: error: newly created file is older than distributed files!
+Check your system clock" >&2;}
+fi
+echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+test "$program_prefix" != NONE &&
+  program_transform_name="s,^,$program_prefix,;$program_transform_name"
+# Use a double $ so make ignores it.
+test "$program_suffix" != NONE &&
+  program_transform_name="s,\$,$program_suffix,;$program_transform_name"
+# Double any \ or $.  echo might interpret backslashes.
+# By default was `s,x,x', remove it if useless.
+cat <<\_ACEOF >conftest.sed
+s/[\\$]/&&/g;s/;s,x,x,$//
+_ACEOF
+program_transform_name=`echo $program_transform_name | sed -f conftest.sed`
+rm conftest.sed
+# expand $ac_aux_dir to an absolute path
+am_aux_dir=`cd $ac_aux_dir && pwd`
+test x"${MISSING+set}" = xset || MISSING="\${SHELL} $am_aux_dir/missing"
+# Use eval to expand $SHELL
+if eval "$MISSING --run true"; then
+  am_missing_run="$MISSING --run "
+else
+  am_missing_run=
+  { echo "$as_me:$LINENO: WARNING: \`missing' script is too old or missing" >&5
+echo "$as_me: WARNING: \`missing' script is too old or missing" >&2;}
+fi
+if mkdir -p --version . >/dev/null 2>&1 && test ! -d ./--version; then
+  # We used to keeping the `.' as first argument, in order to
+  # allow $(mkdir_p) to be used without argument.  As in
+  #   $(mkdir_p) $(somedir)
+  # where $(somedir) is conditionally defined.  However this is wrong
+  # for two reasons:
+  #  1. if the package is installed by a user who cannot write `.'
+  #     make install will fail,
+  #  2. the above comment should most certainly read
+  #     $(mkdir_p) $(DESTDIR)$(somedir)
+  #     so it does not work when $(somedir) is undefined and
+  #     $(DESTDIR) is not.
+  #  To support the latter case, we have to write
+  #     test -z "$(somedir)" || $(mkdir_p) $(DESTDIR)$(somedir),
+  #  so the `.' trick is pointless.
+  mkdir_p='mkdir -p --'
+else
+  # On NextStep and OpenStep, the `mkdir' command does not
+  # recognize any option.  It will interpret all options as
+  # directories to create, and then abort because `.' already
+  # exists.
+  for d in ./-p ./--version;
+  do
+    test -d $d && rmdir $d
+  done
+  # $(mkinstalldirs) is defined by Automake if mkinstalldirs exists.
+  if test -f "$ac_aux_dir/mkinstalldirs"; then
+    mkdir_p='$(mkinstalldirs)'
+  else
+    mkdir_p='$(install_sh) -d'
+  fi
+fi
+for ac_prog in gawk mawk nawk awk
+do
+  # Extract the first word of "$ac_prog", so it can be a program name with args.
+set dummy $ac_prog; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_AWK+set}" = set; then
+else
+  if test -n "$AWK"; then
+  ac_cv_prog_AWK="$AWK" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_AWK="$ac_prog"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+fi
+fi
+AWK=$ac_cv_prog_AWK
+if test -n "$AWK"; then
+  echo "$as_me:$LINENO: result: $AWK" >&5
+echo "${ECHO_T}$AWK" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+  test -n "$AWK" && break
+done
+echo "$as_me:$LINENO: checking whether ${MAKE-make} sets \$(MAKE)" >&5
+echo $ECHO_N "checking whether ${MAKE-make} sets \$(MAKE)... $ECHO_C" >&6
+set dummy ${MAKE-make}; ac_make=`echo "$2" | sed 'y,:./+-,___p_,'`
+if eval "test \"\${ac_cv_prog_make_${ac_make}_set+set}\" = set"; then
+else
+  cat >conftest.make <<\_ACEOF
+all:
+	@echo 'ac_maketemp="$(MAKE)"'
+_ACEOF
+# GNU make sometimes prints "make[1]: Entering...", which would confuse us.
+eval `${MAKE-make} -f conftest.make 2>/dev/null | grep temp=`
+if test -n "$ac_maketemp"; then
+  eval ac_cv_prog_make_${ac_make}_set=yes
+else
+  eval ac_cv_prog_make_${ac_make}_set=no
+fi
+rm -f conftest.make
+fi
+if eval "test \"`echo '$ac_cv_prog_make_'${ac_make}_set`\" = yes"; then
+  echo "$as_me:$LINENO: result: yes" >&5
+  SET_MAKE=
+else
+  SET_MAKE="MAKE=${MAKE-make}"
+fi
+rm -rf .tst 2>/dev/null
+mkdir .tst 2>/dev/null
+if test -d .tst; then
+  am__leading_dot=.
+else
+  am__leading_dot=_
+fi
+rmdir .tst 2>/dev/null
+# test to see if srcdir already configured
+if test "`cd $srcdir && pwd`" != "`pwd`" &&
+   test -f $srcdir/config.status; then
+  { { echo "$as_me:$LINENO: error: source directory already configured; run \"make distclean\" there first" >&5
+echo "$as_me: error: source directory already configured; run \"make distclean\" there first" >&2;}
+fi
+# test whether we have cygpath
+if test -z "$CYGPATH_W"; then
+  if (cygpath --version) >/dev/null 2>/dev/null; then
+    CYGPATH_W='cygpath -w'
+  else
+    CYGPATH_W=echo
+  fi
+fi
+# Define the identity of the package.
+ PACKAGE='proj'
+ VERSION='4.5.0'
+#define PACKAGE "$PACKAGE"
+_ACEOF
+#define VERSION "$VERSION"
+_ACEOF
+# Some tools Automake needs.
+ACLOCAL=${ACLOCAL-"${am_missing_run}aclocal-${am__api_version}"}
+AUTOCONF=${AUTOCONF-"${am_missing_run}autoconf"}
+AUTOMAKE=${AUTOMAKE-"${am_missing_run}automake-${am__api_version}"}
+AUTOHEADER=${AUTOHEADER-"${am_missing_run}autoheader"}
+MAKEINFO=${MAKEINFO-"${am_missing_run}makeinfo"}
+install_sh=${install_sh-"$am_aux_dir/install-sh"}
+# Installed binaries are usually stripped using `strip' when the user
+# run `make install-strip'.  However `strip' might not be the right
+# tool to use in cross-compilation environments, therefore Automake
+# will honor the `STRIP' environment variable to overrule this program.
+if test "$cross_compiling" != no; then
+  if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
+set dummy ${ac_tool_prefix}strip; ac_word=$2
+if test "${ac_cv_prog_STRIP+set}" = set; then
+else
+  if test -n "$STRIP"; then
+  ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_STRIP="${ac_tool_prefix}strip"
+    break 2
+  fi
+done
+done
+fi
+fi
+STRIP=$ac_cv_prog_STRIP
+if test -n "$STRIP"; then
+  echo "$as_me:$LINENO: result: $STRIP" >&5
+echo "${ECHO_T}$STRIP" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_STRIP"; then
+  ac_ct_STRIP=$STRIP
+  # Extract the first word of "strip", so it can be a program name with args.
+set dummy strip; ac_word=$2
+if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
+else
+  if test -n "$ac_ct_STRIP"; then
+  ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_STRIP="strip"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
+fi
+fi
+ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
+if test -n "$ac_ct_STRIP"; then
+  echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
+echo "${ECHO_T}$ac_ct_STRIP" >&6
+else
+fi
+  STRIP=$ac_ct_STRIP
+else
+  STRIP="$ac_cv_prog_STRIP"
+fi
+fi
+INSTALL_STRIP_PROGRAM="\${SHELL} \$(install_sh) -c -s"
+# We need awk for the "check" target.  The system "awk" is bad on
+# some platforms.
+# Always define AMTAR for backward compatibility.
+AMTAR=${AMTAR-"${am_missing_run}tar"}
+am__tar='${AMTAR} chof - "$$tardir"'; am__untar='${AMTAR} xf -'
+echo "$as_me:$LINENO: checking whether to enable maintainer-specific portions of Makefiles" >&5
+echo $ECHO_N "checking whether to enable maintainer-specific portions of Makefiles... $ECHO_C" >&6
+    # Check whether --enable-maintainer-mode or --disable-maintainer-mode was given.
+if test "${enable_maintainer_mode+set}" = set; then
+  enableval="$enable_maintainer_mode"
+  USE_MAINTAINER_MODE=$enableval
+else
+  USE_MAINTAINER_MODE=no
+fi;
+  echo "$as_me:$LINENO: result: $USE_MAINTAINER_MODE" >&5
+echo "${ECHO_T}$USE_MAINTAINER_MODE" >&6
+if test $USE_MAINTAINER_MODE = yes; then
+  MAINTAINER_MODE_TRUE=
+  MAINTAINER_MODE_FALSE='#'
+else
+  MAINTAINER_MODE_TRUE='#'
+fi
+  MAINT=$MAINTAINER_MODE_TRUE
+          ac_config_headers="$ac_config_headers src/proj_config.h"
+ac_ext=c
+if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
+set dummy ${ac_tool_prefix}gcc; ac_word=$2
+if test "${ac_cv_prog_CC+set}" = set; then
+else
+  if test -n "$CC"; then
+  ac_cv_prog_CC="$CC" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_CC="${ac_tool_prefix}gcc"
+    break 2
+  fi
+done
+done
+fi
+fi
+CC=$ac_cv_prog_CC
+if test -n "$CC"; then
+  echo "$as_me:$LINENO: result: $CC" >&5
+echo "${ECHO_T}$CC" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_CC"; then
+  ac_ct_CC=$CC
+  # Extract the first word of "gcc", so it can be a program name with args.
+set dummy gcc; ac_word=$2
+if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
+else
+  if test -n "$ac_ct_CC"; then
+  ac_cv_prog_ac_ct_CC="$ac_ct_CC" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="gcc"
+    break 2
+  fi
+done
+done
+fi
+fi
+ac_ct_CC=$ac_cv_prog_ac_ct_CC
+if test -n "$ac_ct_CC"; then
+  echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
+echo "${ECHO_T}$ac_ct_CC" >&6
+else
+fi
+  CC=$ac_ct_CC
+else
+  CC="$ac_cv_prog_CC"
+fi
+if test -z "$CC"; then
+  # Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
+set dummy ${ac_tool_prefix}cc; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_CC="${ac_tool_prefix}cc"
+    break 2
+  fi
+done
+done
+fi
+fi
+CC=$ac_cv_prog_CC
+else
+fi
+fi
+  ac_ct_CC=$CC
+  # Extract the first word of "cc", so it can be a program name with args.
+set dummy cc; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="cc"
+    break 2
+  fi
+done
+done
+fi
+fi
+else
+fi
+  CC=$ac_ct_CC
+else
+fi
+fi
+else
+else
+  ac_prog_rejected=no
+do
+  IFS=$as_save_IFS
+    if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
+       ac_prog_rejected=yes
+       continue
+     fi
+    ac_cv_prog_CC="cc"
+    break 2
+  fi
+done
+done
+if test $ac_prog_rejected = yes; then
+  # We found a bogon in the path, so make sure we never use it.
+  set dummy $ac_cv_prog_CC
+  shift
+  if test $# != 0; then
+    # We chose a different compiler from the bogus one.
+    # However, it has the same basename, so the bogon will be chosen
+    # first if we set CC to just the basename; use the full file name.
+    shift
+    ac_cv_prog_CC="$as_dir/$ac_word${1+' '}$@"
+  fi
+fi
+fi
+fi
+CC=$ac_cv_prog_CC
+else
+fi
+fi
+  for ac_prog in cl
+  do
+    # Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
+set dummy $ac_tool_prefix$ac_prog; ac_word=$2
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+CC=$ac_cv_prog_CC
+else
+fi
+    test -n "$CC" && break
+  done
+fi
+  ac_ct_CC=$CC
+  for ac_prog in cl
+do
+else
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CC="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+else
+fi
+  test -n "$ac_ct_CC" && break
+done
+  CC=$ac_ct_CC
+fi
+fi
+test -z "$CC" && { { echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&5
+echo "$as_me: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&2;}
+# Provide some information about the compiler.
+echo "$as_me:$LINENO:" \
+     "checking for C compiler version" >&5
+ac_compiler=`set X $ac_compile; echo $2`
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler --version </dev/null >&5\"") >&5
+  (eval $ac_compiler --version </dev/null >&5) 2>&5
+  ac_status=$?
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); }
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -v </dev/null >&5\"") >&5
+  (eval $ac_compiler -v </dev/null >&5) 2>&5
+  ac_status=$?
+{ (eval echo "$as_me:$LINENO: \"$ac_compiler -V </dev/null >&5\"") >&5
+  (eval $ac_compiler -V </dev/null >&5) 2>&5
+  ac_status=$?
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+ac_clean_files_save=$ac_clean_files
+ac_clean_files="$ac_clean_files a.out a.exe b.out"
+# Try to create an executable without -o first, disregard a.out.
+# It will help us diagnose broken compilers, and finding out an intuition
+# of exeext.
+echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+echo $ECHO_N "checking for C compiler default output file name... $ECHO_C" >&6
+ac_link_default=`echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
+if { (eval echo "$as_me:$LINENO: \"$ac_link_default\"") >&5
+  (eval $ac_link_default) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; then
+  # Find the output, starting from the most likely.  This scheme is
+# not robust to junk in `.', hence go to wildcards (a.*) only as a last
+# resort.
+# Be careful to initialize this variable, since it used to be cached.
+# Otherwise an old cache value of `no' led to `EXEEXT = no' in a Makefile.
+ac_cv_exeext=
+# b.out is created by i960 compilers.
+for ac_file in a_out.exe a.exe conftest.exe a.out conftest a.* conftest.* b.out
+do
+  test -f "$ac_file" || continue
+  case $ac_file in
+    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj )
+    conftest.$ac_ext )
+	# This is the source file.
+    [ab].out )
+	# We found the default executable, but exeext='' is most
+	# certainly right.
+	break;;
+	ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
+	# FIXME: I believe we export ac_cv_exeext for Libtool,
+	# but it would be cool to find out if it's true.  Does anybody
+	# maintain Libtool? --akim.
+	export ac_cv_exeext
+	break;;
+	break;;
+  esac
+done
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+{ { echo "$as_me:$LINENO: error: C compiler cannot create executables
+echo "$as_me: error: C compiler cannot create executables
+   { (exit 77); exit 77; }; }
+fi
+ac_exeext=$ac_cv_exeext
+echo "$as_me:$LINENO: result: $ac_file" >&5
+echo "${ECHO_T}$ac_file" >&6
+# Check the compiler produces executables we can run.  If not, either
+# the compiler is broken, or we cross compile.
+echo "$as_me:$LINENO: checking whether the C compiler works" >&5
+echo $ECHO_N "checking whether the C compiler works... $ECHO_C" >&6
+# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
+# If not cross compiling, check that we can run a simple program.
+if test "$cross_compiling" != yes; then
+  if { ac_try='./$ac_file'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; }; then
+    cross_compiling=no
+  else
+    if test "$cross_compiling" = maybe; then
+    else
+	{ { echo "$as_me:$LINENO: error: cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+echo "$as_me: error: cannot run C compiled programs.
+    fi
+  fi
+fi
+rm -f a.out a.exe conftest$ac_cv_exeext b.out
+ac_clean_files=$ac_clean_files_save
+echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
+echo $ECHO_N "checking whether we are cross compiling... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $cross_compiling" >&5
+echo "${ECHO_T}$cross_compiling" >&6
+echo "$as_me:$LINENO: checking for suffix of executables" >&5
+echo $ECHO_N "checking for suffix of executables... $ECHO_C" >&6
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  # If both `conftest.exe' and `conftest' are `present' (well, observable)
+# catch `conftest.exe'.  For instance with Cygwin, `ls conftest' will
+# work properly (i.e., refer to `conftest.exe'), while it won't with
+# `rm'.
+for ac_file in conftest.exe conftest conftest.*; do
+  case $ac_file in
+    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg | *.o | *.obj ) ;;
+    *.* ) ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
+	  break;;
+    * ) break;;
+  esac
+done
+else
+  { { echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
+echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
+fi
+rm -f conftest$ac_cv_exeext
+echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
+echo "${ECHO_T}$ac_cv_exeext" >&6
+rm -f conftest.$ac_ext
+EXEEXT=$ac_cv_exeext
+ac_exeext=$EXEEXT
+echo "$as_me:$LINENO: checking for suffix of object files" >&5
+echo $ECHO_N "checking for suffix of object files... $ECHO_C" >&6
+if test "${ac_cv_objext+set}" = set; then
+else
+  cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.o conftest.obj
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  for ac_file in `(ls conftest.o conftest.obj; ls conftest.*) 2>/dev/null`; do
+  case $ac_file in
+    *.$ac_ext | *.xcoff | *.tds | *.d | *.pdb | *.xSYM | *.bb | *.bbg ) ;;
+    *) ac_cv_objext=`expr "$ac_file" : '.*\.\(.*\)'`
+       break;;
+  esac
+done
+else
+{ { echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
+echo "$as_me: error: cannot compute suffix of object files: cannot compile
+fi
+rm -f conftest.$ac_cv_objext conftest.$ac_ext
+fi
+echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
+echo "${ECHO_T}$ac_cv_objext" >&6
+OBJEXT=$ac_cv_objext
+ac_objext=$OBJEXT
+echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU C compiler... $ECHO_C" >&6
+if test "${ac_cv_c_compiler_gnu+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#ifndef __GNUC__
+       choke me
+#endif
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext
+  (eval $ac_compile) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  cat conftest.err >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest.$ac_objext'
+  ac_status=$?
+  ac_compiler_gnu=yes
+else
+ac_compiler_gnu=no
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+ac_cv_c_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_c_compiler_gnu" >&6
+GCC=`test $ac_compiler_gnu = yes && echo yes`
+ac_test_CFLAGS=${CFLAGS+set}
+ac_save_CFLAGS=$CFLAGS
+CFLAGS="-g"
+echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
+echo $ECHO_N "checking whether $CC accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_cc_g+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_cc_g=yes
+else
+ac_cv_prog_cc_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
+echo "${ECHO_T}$ac_cv_prog_cc_g" >&6
+if test "$ac_test_CFLAGS" = set; then
+  CFLAGS=$ac_save_CFLAGS
+elif test $ac_cv_prog_cc_g = yes; then
+  if test "$GCC" = yes; then
+    CFLAGS="-g -O2"
+  else
+    CFLAGS="-g"
+  fi
+else
+    CFLAGS="-O2"
+  else
+    CFLAGS=
+  fi
+fi
+echo "$as_me:$LINENO: checking for $CC option to accept ANSI C" >&5
+echo $ECHO_N "checking for $CC option to accept ANSI C... $ECHO_C" >&6
+if test "${ac_cv_prog_cc_stdc+set}" = set; then
+else
+  ac_cv_prog_cc_stdc=no
+ac_save_CC=$CC
+/* confdefs.h.  */
+_ACEOF
+#include <stdarg.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+/* Most of the following tests are stolen from RCS 5.7's src/conf.sh.  */
+struct buf { int x; };
+FILE * (*rcsopen) (struct buf *, struct stat *, int);
+static char *e (p, i)
+     char **p;
+     int i;
+  return p[i];
+static char *f (char * (*g) (char **, int), char **p, ...)
+  char *s;
+  va_list v;
+  va_start (v,p);
+  s = g (p, va_arg (v,int));
+  va_end (v);
+  return s;
+/* OSF 4.0 Compaq cc is some sort of almost-ANSI by default.  It has
+   function prototypes and stuff, but not '\xHH' hex character constants.
+   These don't provoke an error unfortunately, instead are silently treated
+   as 'x'.  The following induces an error, until -std1 is added to get
+   proper ANSI mode.  Curiously '\x00'!='x' always comes out true, for an
+   array size at least.  It's necessary to write '\x00'==0 to get something
+   that's true only with -std1.  */
+int osf4_cc_array ['\x00' == 0 ? 1 : -1];
+int test (int i, double x);
+struct s1 {int (*f) (int a);};
+struct s2 {int (*f) (double a);};
+int pairnames (int, char **, FILE *(*)(struct buf *, struct stat *, int), int, int);
+int argc;
+char **argv;
+int
+main ()
+return f (e, argv, 0) != argv[0]  ||  f (e, argv, 1) != argv[1];
+  return 0;
+_ACEOF
+# Don't try gcc -ansi; that turns off useful extensions and
+# breaks some systems' header files.
+# AIX			-qlanglvl=ansi
+# Ultrix and OSF/1	-std1
+# HP-UX 10.20 and later	-Ae
+# HP-UX older versions	-Aa -D_HPUX_SOURCE
+# SVR4			-Xc -D__EXTENSIONS__
+for ac_arg in "" -qlanglvl=ansi -std1 -Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
+do
+  CC="$ac_save_CC $ac_arg"
+  rm -f conftest.$ac_objext
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_cc_stdc=$ac_arg
+break
+else
+fi
+done
+rm -f conftest.$ac_ext conftest.$ac_objext
+CC=$ac_save_CC
+fi
+case "x$ac_cv_prog_cc_stdc" in
+  x|xno)
+    echo "$as_me:$LINENO: result: none needed" >&5
+echo "${ECHO_T}none needed" >&6 ;;
+    echo "$as_me:$LINENO: result: $ac_cv_prog_cc_stdc" >&5
+echo "${ECHO_T}$ac_cv_prog_cc_stdc" >&6
+    CC="$CC $ac_cv_prog_cc_stdc" ;;
+esac
+# Some people use a C++ compiler to compile C.  Since we use `exit',
+# in C++ we need to declare it.  In case someone uses the same compiler
+# for both compiling C and C++ we need to have the C++ compiler decide
+# the declaration of exit, since it's the most demanding environment.
+#ifndef __cplusplus
+  choke me
+#endif
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  for ac_declaration in \
+   'extern "C" void std::exit (int) throw (); using std::exit;' \
+   'extern "C" void std::exit (int); using std::exit;' \
+   'extern "C" void exit (int) throw ();' \
+   'extern "C" void exit (int);' \
+   'void exit (int);'
+do
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+#include <stdlib.h>
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  break
+else
+fi
+done
+rm -f conftest*
+if test -n "$ac_declaration"; then
+  echo '#ifdef __cplusplus' >>confdefs.h
+  echo $ac_declaration      >>confdefs.h
+  echo '#endif'             >>confdefs.h
+fi
+else
+fi
+ac_ext=c
+DEPDIR="${am__leading_dot}deps"
+          ac_config_commands="$ac_config_commands depfiles"
+am_make=${MAKE-make}
+cat > confinc << 'END'
+am__doit:
+	@echo done
+.PHONY: am__doit
+END
+# If we don't find an include directive, just comment out the code.
+echo "$as_me:$LINENO: checking for style of include used by $am_make" >&5
+echo $ECHO_N "checking for style of include used by $am_make... $ECHO_C" >&6
+am__include="#"
+am__quote=
+_am_result=none
+# First try GNU make style include.
+echo "include confinc" > confmf
+# We grep out `Entering directory' and `Leaving directory'
+# messages which can occur if `w' ends up in MAKEFLAGS.
+# In particular we don't look at `^make:' because GNU make might
+# be invoked under some other name (usually "gmake"), in which
+# case it prints its new name instead of `make'.
+if test "`$am_make -s -f confmf 2> /dev/null | grep -v 'ing directory'`" = "done"; then
+   am__include=include
+   am__quote=
+   _am_result=GNU
+fi
+# Now try BSD make style include.
+if test "$am__include" = "#"; then
+   echo '.include "confinc"' > confmf
+   if test "`$am_make -s -f confmf 2> /dev/null`" = "done"; then
+      am__include=.include
+      am__quote="\""
+      _am_result=BSD
+   fi
+fi
+echo "$as_me:$LINENO: result: $_am_result" >&5
+echo "${ECHO_T}$_am_result" >&6
+rm -f confinc confmf
+# Check whether --enable-dependency-tracking or --disable-dependency-tracking was given.
+if test "${enable_dependency_tracking+set}" = set; then
+  enableval="$enable_dependency_tracking"
+fi;
+if test "x$enable_dependency_tracking" != xno; then
+  am_depcomp="$ac_aux_dir/depcomp"
+  AMDEPBACKSLASH='\'
+fi
+  AMDEP_TRUE=
+  AMDEP_FALSE='#'
+else
+  AMDEP_TRUE='#'
+  AMDEP_FALSE=
+fi
+depcc="$CC"   am_compiler_list=
+echo "$as_me:$LINENO: checking dependency style of $depcc" >&5
+echo $ECHO_N "checking dependency style of $depcc... $ECHO_C" >&6
+if test "${am_cv_CC_dependencies_compiler_type+set}" = set; then
+else
+  if test -z "$AMDEP_TRUE" && test -f "$am_depcomp"; then
+  # We make a subdir and do the tests there.  Otherwise we can end up
+  # making bogus files that we don't know about and never remove.  For
+  # instance it was reported that on HP-UX the gcc test will end up
+  # making a dummy file named `D' -- because `-MD' means `put the output
+  # in D'.
+  mkdir conftest.dir
+  # Copy depcomp to subdir because otherwise we won't find it if we're
+  # using a relative directory.
+  cp "$am_depcomp" conftest.dir
+  cd conftest.dir
+  # We will build objects and dependencies in a subdirectory because
+  # it helps to detect inapplicable dependency modes.  For instance
+  # both Tru64's cc and ICC support -MD to output dependencies as a
+  # side effect of compilation, but ICC will put the dependencies in
+  # the current directory while Tru64 will put them in the object
+  # directory.
+  mkdir sub
+  am_cv_CC_dependencies_compiler_type=none
+  if test "$am_compiler_list" = ""; then
+     am_compiler_list=`sed -n 's/^#*\([a-zA-Z0-9]*\))$/\1/p' < ./depcomp`
+  fi
+  for depmode in $am_compiler_list; do
+    # Setup a source with many dependencies, because some compilers
+    # like to wrap large dependency lists on column 80 (with \), and
+    # we should not choose a depcomp mode which is confused by this.
+    # We need to recreate these files for each test, as the compiler may
+    # overwrite some of them when testing with obscure command lines.
+    # This happens at least with the AIX C compiler.
+    : > sub/conftest.c
+    for i in 1 2 3 4 5 6; do
+      echo '#include "conftst'$i'.h"' >> sub/conftest.c
+      # Using `: > sub/conftst$i.h' creates only sub/conftst1.h with
+      # Solaris 8's {/usr,}/bin/sh.
+      touch sub/conftst$i.h
+    done
+    echo "${am__include} ${am__quote}sub/conftest.Po${am__quote}" > confmf
+    case $depmode in
+    nosideeffect)
+      # after this tag, mechanisms are not by side-effect, so they'll
+      # only be used when explicitly requested
+      if test "x$enable_dependency_tracking" = xyes; then
+	continue
+      else
+	break
+      fi
+    none) break ;;
+    esac
+    # We check with `-c' and `-o' for the sake of the "dashmstdout"
+    # mode.  It turns out that the SunPro C++ compiler does not properly
+    # handle `-M -o', and we need to detect this.
+    if depmode=$depmode \
+       source=sub/conftest.c object=sub/conftest.${OBJEXT-o} \
+       depfile=sub/conftest.Po tmpdepfile=sub/conftest.TPo \
+       $SHELL ./depcomp $depcc -c -o sub/conftest.${OBJEXT-o} sub/conftest.c \
+         >/dev/null 2>conftest.err &&
+       grep sub/conftst6.h sub/conftest.Po > /dev/null 2>&1 &&
+       grep sub/conftest.${OBJEXT-o} sub/conftest.Po > /dev/null 2>&1 &&
+       ${MAKE-make} -s -f confmf > /dev/null 2>&1; then
+      # icc doesn't choke on unknown options, it will just issue warnings
+      # or remarks (even with -Werror).  So we grep stderr for any message
+      # that says an option was ignored or not supported.
+      # When given -MP, icc 7.0 and 7.1 complain thusly:
+      #   icc: Command line warning: ignoring option '-M'; no argument required
+      # The diagnosis changed in icc 8.0:
+      #   icc: Command line remark: option '-MP' not supported
+      if (grep 'ignoring option' conftest.err ||
+          grep 'not supported' conftest.err) >/dev/null 2>&1; then :; else
+        am_cv_CC_dependencies_compiler_type=$depmode
+        break
+      fi
+    fi
+  done
+  cd ..
+  rm -rf conftest.dir
+else
+fi
+fi
+echo "$as_me:$LINENO: result: $am_cv_CC_dependencies_compiler_type" >&5
+echo "${ECHO_T}$am_cv_CC_dependencies_compiler_type" >&6
+CCDEPMODE=depmode=$am_cv_CC_dependencies_compiler_type
+if
+  test "x$enable_dependency_tracking" != xno \
+  && test "$am_cv_CC_dependencies_compiler_type" = gcc3; then
+  am__fastdepCC_TRUE=
+  am__fastdepCC_FALSE='#'
+else
+  am__fastdepCC_TRUE='#'
+fi
+# AIX /bin/install
+else
+  as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+case $as_dir/ in
+  /usr/ucb/* ) ;;
+    # by default.
+	  else
+	    break 3
+	  fi
+	fi
+      done
+    done
+esac
+done
+fi
+  else
+  fi
+fi
+echo "$as_me:$LINENO: checking whether ln -s works" >&5
+echo $ECHO_N "checking whether ln -s works... $ECHO_C" >&6
+LN_S=$as_ln_s
+if test "$LN_S" = "ln -s"; then
+else
+  echo "$as_me:$LINENO: result: no, using $LN_S" >&5
+echo "${ECHO_T}no, using $LN_S" >&6
+fi
+else
+all:
+_ACEOF
+else
+fi
+fi
+  SET_MAKE=
+else
+fi
+# Check whether --enable-shared or --disable-shared was given.
+if test "${enable_shared+set}" = set; then
+  enableval="$enable_shared"
+  p=${PACKAGE-default}
+    case $enableval in
+    yes) enable_shared=yes ;;
+    no) enable_shared=no ;;
+      enable_shared=no
+      # Look at the argument we got.  We use all the common list separators.
+      lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+      for pkg in $enableval; do
+	IFS="$lt_save_ifs"
+	if test "X$pkg" = "X$p"; then
+	  enable_shared=yes
+	fi
+      done
+    esac
+else
+  enable_shared=yes
+fi;
+# Check whether --enable-static or --disable-static was given.
+if test "${enable_static+set}" = set; then
+  enableval="$enable_static"
+    yes) enable_static=yes ;;
+    no) enable_static=no ;;
+     enable_static=no
+	  enable_static=yes
+	fi
+      done
+    esac
+else
+  enable_static=yes
+fi;
+# Check whether --enable-fast-install or --disable-fast-install was given.
+if test "${enable_fast_install+set}" = set; then
+  enableval="$enable_fast_install"
+    yes) enable_fast_install=yes ;;
+    no) enable_fast_install=no ;;
+      enable_fast_install=no
+	  enable_fast_install=yes
+	fi
+      done
+    esac
+else
+fi;
+# Make sure we can run config.sub.
+$ac_config_sub sun4 >/dev/null 2>&1 ||
+  { { echo "$as_me:$LINENO: error: cannot run $ac_config_sub" >&5
+echo "$as_me: error: cannot run $ac_config_sub" >&2;}
+echo "$as_me:$LINENO: checking build system type" >&5
+echo $ECHO_N "checking build system type... $ECHO_C" >&6
+if test "${ac_cv_build+set}" = set; then
+else
+  ac_cv_build_alias=$build_alias
+test -z "$ac_cv_build_alias" &&
+  ac_cv_build_alias=`$ac_config_guess`
+  { { echo "$as_me:$LINENO: error: cannot guess build type; you must specify one" >&5
+echo "$as_me: error: cannot guess build type; you must specify one" >&2;}
+ac_cv_build=`$ac_config_sub $ac_cv_build_alias` ||
+  { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_build_alias failed" >&5
+echo "$as_me: error: $ac_config_sub $ac_cv_build_alias failed" >&2;}
+fi
+echo "$as_me:$LINENO: result: $ac_cv_build" >&5
+echo "${ECHO_T}$ac_cv_build" >&6
+build=$ac_cv_build
+build_cpu=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
+build_vendor=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
+build_os=`echo $ac_cv_build | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
+echo "$as_me:$LINENO: checking host system type" >&5
+echo $ECHO_N "checking host system type... $ECHO_C" >&6
+if test "${ac_cv_host+set}" = set; then
+else
+  ac_cv_host_alias=$host_alias
+test -z "$ac_cv_host_alias" &&
+  ac_cv_host_alias=$ac_cv_build_alias
+ac_cv_host=`$ac_config_sub $ac_cv_host_alias` ||
+  { { echo "$as_me:$LINENO: error: $ac_config_sub $ac_cv_host_alias failed" >&5
+echo "$as_me: error: $ac_config_sub $ac_cv_host_alias failed" >&2;}
+fi
+echo "$as_me:$LINENO: result: $ac_cv_host" >&5
+echo "${ECHO_T}$ac_cv_host" >&6
+host=$ac_cv_host
+host_cpu=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\1/'`
+host_vendor=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\2/'`
+host_os=`echo $ac_cv_host | sed 's/^\([^-]*\)-\([^-]*\)-\(.*\)$/\3/'`
+echo "$as_me:$LINENO: checking for a sed that does not truncate output" >&5
+echo $ECHO_N "checking for a sed that does not truncate output... $ECHO_C" >&6
+if test "${lt_cv_path_SED+set}" = set; then
+else
+  # Loop through the user's path and test for sed and gsed.
+# Then use that list of sed's as ones to test for truncation.
+do
+  IFS=$as_save_IFS
+  for lt_ac_prog in sed gsed; do
+      if $as_executable_p "$as_dir/$lt_ac_prog$ac_exec_ext"; then
+        lt_ac_sed_list="$lt_ac_sed_list $as_dir/$lt_ac_prog$ac_exec_ext"
+      fi
+    done
+  done
+done
+lt_ac_max=0
+lt_ac_count=0
+# Add /usr/xpg4/bin/sed as it is typically found on Solaris
+# along with /bin/sed that truncates output.
+for lt_ac_sed in $lt_ac_sed_list /usr/xpg4/bin/sed; do
+  test ! -f $lt_ac_sed && continue
+  cat /dev/null > conftest.in
+  lt_ac_count=0
+  echo $ECHO_N "0123456789$ECHO_C" >conftest.in
+  # Check for GNU sed and select it if it is found.
+  if "$lt_ac_sed" --version 2>&1 < /dev/null | grep 'GNU' > /dev/null; then
+    lt_cv_path_SED=$lt_ac_sed
+    break
+  fi
+  while true; do
+    cat conftest.in conftest.in >conftest.tmp
+    mv conftest.tmp conftest.in
+    cp conftest.in conftest.nl
+    echo >>conftest.nl
+    $lt_ac_sed -e 's/a$//' < conftest.nl >conftest.out || break
+    cmp -s conftest.out conftest.nl || break
+    # 10000 chars as input seems more than enough
+    test $lt_ac_count -gt 10 && break
+    lt_ac_count=`expr $lt_ac_count + 1`
+    if test $lt_ac_count -gt $lt_ac_max; then
+      lt_ac_max=$lt_ac_count
+    fi
+  done
+done
+fi
+SED=$lt_cv_path_SED
+echo "$as_me:$LINENO: result: $SED" >&5
+echo "${ECHO_T}$SED" >&6
+echo "$as_me:$LINENO: checking for egrep" >&5
+echo $ECHO_N "checking for egrep... $ECHO_C" >&6
+if test "${ac_cv_prog_egrep+set}" = set; then
+else
+  if echo a | (grep -E '(a|b)') >/dev/null 2>&1
+    then ac_cv_prog_egrep='grep -E'
+    else ac_cv_prog_egrep='egrep'
+    fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_egrep" >&5
+echo "${ECHO_T}$ac_cv_prog_egrep" >&6
+ EGREP=$ac_cv_prog_egrep
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+  withval="$with_gnu_ld"
+  test "$withval" = no || with_gnu_ld=yes
+else
+  with_gnu_ld=no
+fi;
+ac_prog=ld
+if test "$GCC" = yes; then
+  # Check if gcc -print-prog-name=ld gives a path.
+  echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+  case $host in
+  *-*-mingw*)
+    # gcc leaves a trailing carriage return which upsets mingw
+    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
+    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+  esac
+  case $ac_prog in
+    # Accept absolute paths.
+      re_direlt='/[^/][^/]*/\.\./'
+      # Canonicalize the pathname of ld
+      ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+      while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+	ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+      done
+      test -z "$LD" && LD="$ac_prog"
+    # If it fails, then pretend we aren't using GCC.
+    ac_prog=ld
+    # If it is relative, then search for the first ld in PATH.
+    with_gnu_ld=unknown
+  esac
+elif test "$with_gnu_ld" = yes; then
+  echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+  echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+  if test -z "$LD"; then
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for ac_dir in $PATH; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+      lt_cv_path_LD="$ac_dir/$ac_prog"
+      # Check to see if the program is GNU ld.  I'd rather use --version,
+      # but apparently some variants of GNU ld only accept -v.
+      # Break only if it was the GNU/non-GNU ld that we prefer.
+      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+      *GNU* | *'with BFD'*)
+	test "$with_gnu_ld" != no && break
+	test "$with_gnu_ld" != yes && break
+      esac
+    fi
+  done
+else
+  lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+  echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+   { (exit 1); exit 1; }; }
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+  lt_cv_prog_gnu_ld=yes
+  lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+echo "$as_me:$LINENO: checking for $LD option to reload object files" >&5
+echo $ECHO_N "checking for $LD option to reload object files... $ECHO_C" >&6
+if test "${lt_cv_ld_reload_flag+set}" = set; then
+else
+  lt_cv_ld_reload_flag='-r'
+fi
+echo "$as_me:$LINENO: result: $lt_cv_ld_reload_flag" >&5
+echo "${ECHO_T}$lt_cv_ld_reload_flag" >&6
+reload_flag=$lt_cv_ld_reload_flag
+case $reload_flag in
+*) reload_flag=" $reload_flag" ;;
+esac
+reload_cmds='$LD$reload_flag -o $output$reload_objs'
+case $host_os in
+  darwin*)
+      reload_cmds='$LTCC $LTCFLAGS -nostdlib ${wl}-r -o $output$reload_objs'
+    else
+      reload_cmds='$LD$reload_flag -o $output$reload_objs'
+    fi
+esac
+echo "$as_me:$LINENO: checking for BSD-compatible nm" >&5
+echo $ECHO_N "checking for BSD-compatible nm... $ECHO_C" >&6
+if test "${lt_cv_path_NM+set}" = set; then
+else
+  if test -n "$NM"; then
+  # Let the user override the test.
+  lt_cv_path_NM="$NM"
+else
+  lt_nm_to_check="${ac_tool_prefix}nm"
+  if test -n "$ac_tool_prefix" && test "$build" = "$host"; then
+    lt_nm_to_check="$lt_nm_to_check nm"
+  fi
+  for lt_tmp_nm in $lt_nm_to_check; do
+    for ac_dir in $PATH /usr/ccs/bin/elf /usr/ccs/bin /usr/ucb /bin; do
+      tmp_nm="$ac_dir/$lt_tmp_nm"
+      if test -f "$tmp_nm" || test -f "$tmp_nm$ac_exeext" ; then
+	# Check to see if the nm accepts a BSD-compat flag.
+	# Adding the `sed 1q' prevents false positives on HP-UX, which says:
+	#   nm: unknown option "B" ignored
+	# Tru64's nm complains that /dev/null is an invalid object file
+	case `"$tmp_nm" -B /dev/null 2>&1 | sed '1q'` in
+	*/dev/null* | *'Invalid file or object type'*)
+	  lt_cv_path_NM="$tmp_nm -B"
+	  break
+	  case `"$tmp_nm" -p /dev/null 2>&1 | sed '1q'` in
+	  */dev/null*)
+	    lt_cv_path_NM="$tmp_nm -p"
+	    break
+	    lt_cv_path_NM=${lt_cv_path_NM="$tmp_nm"} # keep the first match, but
+	    continue # so that we can try to find one that supports BSD flags
+	  esac
+	esac
+      fi
+    done
+  done
+  test -z "$lt_cv_path_NM" && lt_cv_path_NM=nm
+fi
+fi
+echo "$as_me:$LINENO: result: $lt_cv_path_NM" >&5
+echo "${ECHO_T}$lt_cv_path_NM" >&6
+NM="$lt_cv_path_NM"
+echo "$as_me:$LINENO: checking how to recognise dependent libraries" >&5
+echo $ECHO_N "checking how to recognise dependent libraries... $ECHO_C" >&6
+if test "${lt_cv_deplibs_check_method+set}" = set; then
+else
+  lt_cv_file_magic_cmd='$MAGIC_CMD'
+lt_cv_file_magic_test_file=
+lt_cv_deplibs_check_method='unknown'
+# Need to set the preceding variable on all platforms that support
+# interlibrary dependencies.
+# 'none' -- dependencies not supported.
+# `unknown' -- same as none, but documents that we really don't know.
+# 'pass_all' -- all dependencies passed with no checks.
+# 'test_compile' -- check by making test program.
+# 'file_magic [[regex]]' -- check by looking for files in library path
+# which responds to the $file_magic_cmd with a given extended regex.
+# If you have `file' or equivalent on your system and you're not sure
+# whether `pass_all' will *always* work, you probably want this one.
+case $host_os in
+aix4* | aix5*)
+  lt_cv_deplibs_check_method=pass_all
+beos*)
+bsdi[45]*)
+  lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib)'
+  lt_cv_file_magic_cmd='/usr/bin/file -L'
+  lt_cv_file_magic_test_file=/shlib/libc.so
+cygwin*)
+  # func_win32_libid is a shell function defined in ltmain.sh
+  lt_cv_deplibs_check_method='file_magic ^x86 archive import|^x86 DLL'
+  lt_cv_file_magic_cmd='func_win32_libid'
+mingw* | pw32*)
+  # Base MSYS/MinGW do not provide the 'file' command needed by
+  # func_win32_libid shell function, so use a weaker test based on 'objdump'.
+  lt_cv_deplibs_check_method='file_magic file format pei*-i386(.*architecture: i386)?'
+  lt_cv_file_magic_cmd='$OBJDUMP -f'
+darwin* | rhapsody*)
+freebsd* | kfreebsd*-gnu | dragonfly*)
+  if echo __ELF__ | $CC -E - | grep __ELF__ > /dev/null; then
+    case $host_cpu in
+    i*86 )
+      # Not sure whether the presence of OpenBSD here was a mistake.
+      # Let's accept both of them until this is cleared up.
+      lt_cv_deplibs_check_method='file_magic (FreeBSD|OpenBSD|DragonFly)/i[3-9]86 (compact )?demand paged shared library'
+      lt_cv_file_magic_cmd=/usr/bin/file
+      lt_cv_file_magic_test_file=`echo /usr/lib/libc.so.*`
+    esac
+  else
+  fi
+gnu*)
+hpux10.20* | hpux11*)
+  case $host_cpu in
+  ia64*)
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - IA64'
+    lt_cv_file_magic_test_file=/usr/lib/hpux32/libc.so
+  hppa*64*)
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|ELF-[0-9][0-9]) shared object file - PA-RISC [0-9].[0-9]'
+    lt_cv_file_magic_test_file=/usr/lib/pa20_64/libc.sl
+    lt_cv_deplibs_check_method='file_magic (s[0-9][0-9][0-9]|PA-RISC[0-9].[0-9]) shared library'
+    lt_cv_file_magic_test_file=/usr/lib/libc.sl
+  esac
+interix3*)
+  # PIC code is broken on Interix 3.x, that's why |\.a not |_pic\.a here
+  lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|\.a)$'
+irix5* | irix6* | nonstopux*)
+  case $LD in
+  *-32|*"-32 ") libmagic=32-bit;;
+  *-n32|*"-n32 ") libmagic=N32;;
+  *-64|*"-64 ") libmagic=64-bit;;
+  *) libmagic=never-match;;
+  esac
+# This must be Linux ELF.
+linux*)
+netbsd*)
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|_pic\.a)$'
+  else
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so|_pic\.a)$'
+  fi
+newos6*)
+  lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (executable|dynamic lib)'
+  lt_cv_file_magic_test_file=/usr/lib/libnls.so
+nto-qnx*)
+  lt_cv_deplibs_check_method=unknown
+openbsd*)
+  if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+    lt_cv_deplibs_check_method='match_pattern /lib[^/]+(\.so\.[0-9]+\.[0-9]+|\.so|_pic\.a)$'
+  else
+  fi
+osf3* | osf4* | osf5*)
+solaris*)
+sysv4 | sysv4.3*)
+  case $host_vendor in
+  motorola)
+    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [ML]SB (shared object|dynamic lib) M[0-9][0-9]* Version [0-9]'
+    lt_cv_file_magic_test_file=`echo /usr/lib/libc.so*`
+  ncr)
+  sequent)
+    lt_cv_file_magic_cmd='/bin/file'
+    lt_cv_deplibs_check_method='file_magic ELF [0-9][0-9]*-bit [LM]SB (shared object|dynamic lib )'
+  sni)
+    lt_cv_deplibs_check_method="file_magic ELF [0-9][0-9]*-bit [LM]SB dynamic lib"
+    lt_cv_file_magic_test_file=/lib/libc.so
+  siemens)
+  pc)
+  esac
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_deplibs_check_method" >&5
+echo "${ECHO_T}$lt_cv_deplibs_check_method" >&6
+file_magic_cmd=$lt_cv_file_magic_cmd
+deplibs_check_method=$lt_cv_deplibs_check_method
+test -z "$deplibs_check_method" && deplibs_check_method=unknown
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# Check whether --enable-libtool-lock or --disable-libtool-lock was given.
+if test "${enable_libtool_lock+set}" = set; then
+  enableval="$enable_libtool_lock"
+fi;
+test "x$enable_libtool_lock" != xno && enable_libtool_lock=yes
+# Some flags need to be propagated to the compiler or linker for good
+# libtool support.
+case $host in
+ia64-*-hpux*)
+  # Find out which ABI we are using.
+  echo 'int i;' > conftest.$ac_ext
+  if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  ac_status=$?
+    case `/usr/bin/file conftest.$ac_objext` in
+    *ELF-32*)
+      HPUX_IA64_MODE="32"
+    *ELF-64*)
+      HPUX_IA64_MODE="64"
+    esac
+  fi
+  rm -rf conftest*
+*-*-irix6*)
+  echo '#line 3818 "configure"' > conftest.$ac_ext
+  ac_status=$?
+   if test "$lt_cv_prog_gnu_ld" = yes; then
+    *32-bit*)
+      LD="${LD-ld} -melf32bsmip"
+    *N32*)
+      LD="${LD-ld} -melf32bmipn32"
+    *64-bit*)
+      LD="${LD-ld} -melf64bmip"
+    esac
+   else
+    *32-bit*)
+      LD="${LD-ld} -32"
+    *N32*)
+      LD="${LD-ld} -n32"
+    *64-bit*)
+      LD="${LD-ld} -64"
+    esac
+   fi
+  fi
+  rm -rf conftest*
+x86_64-*linux*|ppc*-*linux*|powerpc*-*linux*|s390*-*linux*|sparc*-*linux*)
+  ac_status=$?
+    case `/usr/bin/file conftest.o` in
+    *32-bit*)
+      case $host in
+        x86_64-*linux*)
+          LD="${LD-ld} -m elf_i386"
+        ppc64-*linux*|powerpc64-*linux*)
+          LD="${LD-ld} -m elf32ppclinux"
+        s390x-*linux*)
+          LD="${LD-ld} -m elf_s390"
+        sparc64-*linux*)
+          LD="${LD-ld} -m elf32_sparc"
+      esac
+    *64-bit*)
+      case $host in
+        x86_64-*linux*)
+          LD="${LD-ld} -m elf_x86_64"
+        ppc*-*linux*|powerpc*-*linux*)
+          LD="${LD-ld} -m elf64ppc"
+        s390*-*linux*)
+          LD="${LD-ld} -m elf64_s390"
+        sparc*-*linux*)
+          LD="${LD-ld} -m elf64_sparc"
+      esac
+    esac
+  fi
+  rm -rf conftest*
+*-*-sco3.2v5*)
+  # On SCO OpenServer 5, we need -belf to get full-featured binaries.
+  SAVE_CFLAGS="$CFLAGS"
+  CFLAGS="$CFLAGS -belf"
+  echo "$as_me:$LINENO: checking whether the C compiler needs -belf" >&5
+echo $ECHO_N "checking whether the C compiler needs -belf... $ECHO_C" >&6
+if test "${lt_cv_cc_needs_belf+set}" = set; then
+else
+  ac_ext=c
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  ac_status=$?
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  lt_cv_cc_needs_belf=yes
+else
+lt_cv_cc_needs_belf=no
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+     ac_ext=c
+fi
+echo "$as_me:$LINENO: result: $lt_cv_cc_needs_belf" >&5
+echo "${ECHO_T}$lt_cv_cc_needs_belf" >&6
+  if test x"$lt_cv_cc_needs_belf" != x"yes"; then
+    # this is probably gcc 2.8.0, egcs 1.0 or newer; no need for -belf
+    CFLAGS="$SAVE_CFLAGS"
+  fi
+sparc*-*solaris*)
+  ac_status=$?
+    *64-bit*)
+      case $lt_cv_prog_gnu_ld in
+      yes*) LD="${LD-ld} -m elf64_sparc" ;;
+      *)    LD="${LD-ld} -64" ;;
+      esac
+    esac
+  fi
+  rm -rf conftest*
+esac
+need_locks="$enable_libtool_lock"
+ac_ext=c
+echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
+echo $ECHO_N "checking how to run the C preprocessor... $ECHO_C" >&6
+# On Suns, sometimes $CPP names a directory.
+if test -n "$CPP" && test -d "$CPP"; then
+  CPP=
+fi
+if test -z "$CPP"; then
+  if test "${ac_cv_prog_CPP+set}" = set; then
+else
+      # Double quotes because CPP needs to be expanded
+    for CPP in "$CC -E" "$CC -E -traditional-cpp" "/lib/cpp"
+    do
+      ac_preproc_ok=false
+for ac_c_preproc_warn_flag in '' yes
+do
+  # Use a header file that comes with gcc, so configuring glibc
+  # with a fresh cross-compiler works.
+  # Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+  # <limits.h> exists even on freestanding compilers.
+  # On the NeXT, cc -E runs the code through the compiler's parser,
+  # not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+		     Syntax error
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+  (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+  ac_status=$?
+  (exit $ac_status); } >/dev/null; then
+  if test -s conftest.err; then
+    ac_cpp_err=$ac_c_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+else
+  # Broken: fails on valid input.
+continue
+fi
+rm -f conftest.err conftest.$ac_ext
+  # OK, works on sane cases.  Now check whether non-existent headers
+  # can be detected and how.
+/* confdefs.h.  */
+_ACEOF
+#include <ac_nonexistent.h>
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+  # Broken: success on invalid input.
+continue
+else
+  # Passes both tests.
+ac_preproc_ok=:
+break
+fi
+done
+# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
+if $ac_preproc_ok; then
+  break
+fi
+    done
+    ac_cv_prog_CPP=$CPP
+fi
+  CPP=$ac_cv_prog_CPP
+else
+fi
+echo "$as_me:$LINENO: result: $CPP" >&5
+echo "${ECHO_T}$CPP" >&6
+ac_preproc_ok=false
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+  { { echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
+echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
+fi
+ac_ext=c
+echo "$as_me:$LINENO: checking for ANSI C header files" >&5
+echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
+if test "${ac_cv_header_stdc+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <string.h>
+#include <float.h>
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_header_stdc=yes
+else
+ac_cv_header_stdc=no
+fi
+if test $ac_cv_header_stdc = yes; then
+  # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
+  $EGREP "memchr" >/dev/null 2>&1; then
+else
+  ac_cv_header_stdc=no
+fi
+rm -f conftest*
+fi
+  # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  $EGREP "free" >/dev/null 2>&1; then
+else
+fi
+rm -f conftest*
+fi
+  # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
+  if test "$cross_compiling" = yes; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <ctype.h>
+#if ((' ' & 0x0FF) == 0x020)
+# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
+# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
+#else
+# define ISLOWER(c) \
+		   (('a' <= (c) && (c) <= 'i') \
+		     || ('j' <= (c) && (c) <= 'r') \
+		     || ('s' <= (c) && (c) <= 'z'))
+# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
+#endif
+#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
+int
+main ()
+  int i;
+  for (i = 0; i < 256; i++)
+    if (XOR (islower (i), ISLOWER (i))
+	|| toupper (i) != TOUPPER (i))
+      exit(2);
+  exit (0);
+_ACEOF
+rm -f conftest$ac_exeext
+  ac_status=$?
+  (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+  ac_status=$?
+else
+  echo "$as_me: program exited with status $ac_status" >&5
+echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+fi
+rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+fi
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
+echo "${ECHO_T}$ac_cv_header_stdc" >&6
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
+fi
+# On IRIX 5.3, sys/types and inttypes.h are conflicting.
+for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
+		  inttypes.h stdint.h unistd.h
+do
+as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
+echo "$as_me:$LINENO: checking for $ac_header" >&5
+echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
+if eval "test \"\${$as_ac_Header+set}\" = set"; then
+else
+/* confdefs.h.  */
+_ACEOF
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  eval "$as_ac_Header=yes"
+else
+eval "$as_ac_Header=no"
+fi
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
+if test `eval echo '${'$as_ac_Header'}'` = yes; then
+  cat >>confdefs.h <<_ACEOF
+#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
+_ACEOF
+fi
+done
+for ac_header in dlfcn.h
+do
+  echo "$as_me:$LINENO: checking for $ac_header" >&5
+fi
+else
+  # Is the header compilable?
+echo "$as_me:$LINENO: checking $ac_header usability" >&5
+echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_header_compiler=yes
+else
+ac_header_compiler=no
+fi
+echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+echo "${ECHO_T}$ac_header_compiler" >&6
+# Is the header present?
+echo "$as_me:$LINENO: checking $ac_header presence" >&5
+echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+  ac_header_preproc=yes
+else
+  ac_header_preproc=no
+fi
+echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+echo "${ECHO_T}$ac_header_preproc" >&6
+# So?  What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+  yes:no: )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+  no:yes:* )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $ac_header:     check for missing prerequisite headers?" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+      cat <<\_ASBOX
+## Report this to warmerdam at pobox.com ##
+_ASBOX
+      sed "s/^/$as_me: WARNING:     /" >&2
+esac
+else
+  eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
+_ACEOF
+fi
+done
+ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+  for ac_prog in $CCC g++ c++ gpp aCC CC cxx cc++ cl FCC KCC RCC xlC_r xlC
+  do
+if test "${ac_cv_prog_CXX+set}" = set; then
+else
+  if test -n "$CXX"; then
+  ac_cv_prog_CXX="$CXX" # Let the user override the test.
+else
+as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_CXX="$ac_tool_prefix$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+CXX=$ac_cv_prog_CXX
+if test -n "$CXX"; then
+  echo "$as_me:$LINENO: result: $CXX" >&5
+echo "${ECHO_T}$CXX" >&6
+else
+fi
+    test -n "$CXX" && break
+  done
+fi
+if test -z "$CXX"; then
+  ac_ct_CXX=$CXX
+do
+if test "${ac_cv_prog_ac_ct_CXX+set}" = set; then
+else
+  if test -n "$ac_ct_CXX"; then
+  ac_cv_prog_ac_ct_CXX="$ac_ct_CXX" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_CXX="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+ac_ct_CXX=$ac_cv_prog_ac_ct_CXX
+if test -n "$ac_ct_CXX"; then
+  echo "$as_me:$LINENO: result: $ac_ct_CXX" >&5
+echo "${ECHO_T}$ac_ct_CXX" >&6
+else
+fi
+  test -n "$ac_ct_CXX" && break
+done
+test -n "$ac_ct_CXX" || ac_ct_CXX="g++"
+  CXX=$ac_ct_CXX
+fi
+     "checking for C++ compiler version" >&5
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+echo "$as_me:$LINENO: checking whether we are using the GNU C++ compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU C++ compiler... $ECHO_C" >&6
+if test "${ac_cv_cxx_compiler_gnu+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+#ifndef __GNUC__
+       choke me
+#endif
+  return 0;
+_ACEOF
+  ac_status=$?
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+  ac_status=$?
+  ac_status=$?
+else
+ac_compiler_gnu=no
+fi
+ac_cv_cxx_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_cxx_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_cxx_compiler_gnu" >&6
+GXX=`test $ac_compiler_gnu = yes && echo yes`
+ac_test_CXXFLAGS=${CXXFLAGS+set}
+ac_save_CXXFLAGS=$CXXFLAGS
+CXXFLAGS="-g"
+echo "$as_me:$LINENO: checking whether $CXX accepts -g" >&5
+echo $ECHO_N "checking whether $CXX accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_cxx_g+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_cxx_g=yes
+else
+ac_cv_prog_cxx_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_cxx_g" >&5
+echo "${ECHO_T}$ac_cv_prog_cxx_g" >&6
+if test "$ac_test_CXXFLAGS" = set; then
+  CXXFLAGS=$ac_save_CXXFLAGS
+elif test $ac_cv_prog_cxx_g = yes; then
+  if test "$GXX" = yes; then
+    CXXFLAGS="-g -O2"
+  else
+    CXXFLAGS="-g"
+  fi
+else
+    CXXFLAGS="-O2"
+  else
+    CXXFLAGS=
+  fi
+fi
+for ac_declaration in \
+do
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+$ac_declaration
+int
+main ()
+exit (42);
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  break
+else
+fi
+done
+rm -f conftest*
+fi
+ac_ext=cc
+depcc="$CXX"  am_compiler_list=
+if test "${am_cv_CXX_dependencies_compiler_type+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  # in D'.
+  cd conftest.dir
+  # directory.
+  mkdir sub
+  am_cv_CXX_dependencies_compiler_type=none
+  fi
+    done
+    case $depmode in
+    nosideeffect)
+	continue
+      else
+	break
+      fi
+    none) break ;;
+    esac
+        am_cv_CXX_dependencies_compiler_type=$depmode
+        break
+      fi
+    fi
+  done
+  cd ..
+else
+fi
+fi
+echo "$as_me:$LINENO: result: $am_cv_CXX_dependencies_compiler_type" >&5
+echo "${ECHO_T}$am_cv_CXX_dependencies_compiler_type" >&6
+CXXDEPMODE=depmode=$am_cv_CXX_dependencies_compiler_type
+if
+  && test "$am_cv_CXX_dependencies_compiler_type" = gcc3; then
+  am__fastdepCXX_TRUE=
+  am__fastdepCXX_FALSE='#'
+else
+  am__fastdepCXX_TRUE='#'
+fi
+if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+    (test "X$CXX" != "Xg++"))) ; then
+  ac_ext=cc
+echo "$as_me:$LINENO: checking how to run the C++ preprocessor" >&5
+echo $ECHO_N "checking how to run the C++ preprocessor... $ECHO_C" >&6
+if test -z "$CXXCPP"; then
+  if test "${ac_cv_prog_CXXCPP+set}" = set; then
+else
+      # Double quotes because CXXCPP needs to be expanded
+    for CXXCPP in "$CXX -E" "/lib/cpp"
+    do
+for ac_cxx_preproc_warn_flag in '' yes
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+    ac_cpp_err=$ac_cxx_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_cxx_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+  break
+fi
+    done
+    ac_cv_prog_CXXCPP=$CXXCPP
+fi
+  CXXCPP=$ac_cv_prog_CXXCPP
+else
+fi
+echo "$as_me:$LINENO: result: $CXXCPP" >&5
+echo "${ECHO_T}$CXXCPP" >&6
+do
+/* confdefs.h.  */
+_ACEOF
+#ifdef __STDC__
+#else
+#endif
+		     Syntax error
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+else
+continue
+fi
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  ac_status=$?
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+continue
+else
+ac_preproc_ok=:
+break
+fi
+done
+else
+  { { echo "$as_me:$LINENO: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+echo "$as_me: error: C++ preprocessor \"$CXXCPP\" fails sanity check
+fi
+ac_ext=cc
+fi
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+  for ac_prog in g77 f77 xlf frt pgf77 fort77 fl32 af77 f90 xlf90 pgf90 epcf90 f95 fort xlf95 ifc efc pgf95 lf95 gfortran
+  do
+if test "${ac_cv_prog_F77+set}" = set; then
+else
+  if test -n "$F77"; then
+  ac_cv_prog_F77="$F77" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+  for ac_exec_ext in '' $ac_executable_extensions; do
+    ac_cv_prog_F77="$ac_tool_prefix$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+F77=$ac_cv_prog_F77
+if test -n "$F77"; then
+  echo "$as_me:$LINENO: result: $F77" >&5
+echo "${ECHO_T}$F77" >&6
+else
+fi
+    test -n "$F77" && break
+  done
+fi
+if test -z "$F77"; then
+  ac_ct_F77=$F77
+do
+if test "${ac_cv_prog_ac_ct_F77+set}" = set; then
+else
+  if test -n "$ac_ct_F77"; then
+  ac_cv_prog_ac_ct_F77="$ac_ct_F77" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_F77="$ac_prog"
+    break 2
+  fi
+done
+done
+fi
+fi
+ac_ct_F77=$ac_cv_prog_ac_ct_F77
+if test -n "$ac_ct_F77"; then
+  echo "$as_me:$LINENO: result: $ac_ct_F77" >&5
+echo "${ECHO_T}$ac_ct_F77" >&6
+else
+fi
+  test -n "$ac_ct_F77" && break
+done
+  F77=$ac_ct_F77
+fi
+echo "$as_me:5417:" \
+     "checking for Fortran 77 compiler version" >&5
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+rm -f a.out
+# If we don't use `.F' as extension, the preprocessor is not run on the
+# input file.  (Note that this only needs to work for GNU compilers.)
+ac_save_ext=$ac_ext
+ac_ext=F
+echo "$as_me:$LINENO: checking whether we are using the GNU Fortran 77 compiler" >&5
+echo $ECHO_N "checking whether we are using the GNU Fortran 77 compiler... $ECHO_C" >&6
+if test "${ac_cv_f77_compiler_gnu+set}" = set; then
+else
+      program main
+#ifndef __GNUC__
+       choke me
+#endif
+      end
+_ACEOF
+  ac_status=$?
+	 { ac_try='test -z "$ac_f77_werror_flag"
+  ac_status=$?
+  ac_status=$?
+else
+ac_compiler_gnu=no
+fi
+ac_cv_f77_compiler_gnu=$ac_compiler_gnu
+fi
+echo "$as_me:$LINENO: result: $ac_cv_f77_compiler_gnu" >&5
+echo "${ECHO_T}$ac_cv_f77_compiler_gnu" >&6
+ac_ext=$ac_save_ext
+ac_test_FFLAGS=${FFLAGS+set}
+ac_save_FFLAGS=$FFLAGS
+FFLAGS=
+echo "$as_me:$LINENO: checking whether $F77 accepts -g" >&5
+echo $ECHO_N "checking whether $F77 accepts -g... $ECHO_C" >&6
+if test "${ac_cv_prog_f77_g+set}" = set; then
+else
+  FFLAGS=-g
+      program main
+      end
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_prog_f77_g=yes
+else
+ac_cv_prog_f77_g=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_prog_f77_g" >&5
+echo "${ECHO_T}$ac_cv_prog_f77_g" >&6
+if test "$ac_test_FFLAGS" = set; then
+  FFLAGS=$ac_save_FFLAGS
+elif test $ac_cv_prog_f77_g = yes; then
+  if test "x$ac_cv_f77_compiler_gnu" = xyes; then
+    FFLAGS="-g -O2"
+  else
+    FFLAGS="-g"
+  fi
+else
+    FFLAGS="-O2"
+  else
+    FFLAGS=
+  fi
+fi
+G77=`test $ac_compiler_gnu = yes && echo yes`
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+# Autoconf 2.13's AC_OBJEXT and AC_EXEEXT macros only works for C compilers!
+# find the maximum length of command line arguments
+echo "$as_me:$LINENO: checking the maximum length of command line arguments" >&5
+echo $ECHO_N "checking the maximum length of command line arguments... $ECHO_C" >&6
+if test "${lt_cv_sys_max_cmd_len+set}" = set; then
+else
+    i=0
+  teststring="ABCD"
+  case $build_os in
+  msdosdjgpp*)
+    # On DJGPP, this test can blow up pretty badly due to problems in libc
+    # (any single argument exceeding 2000 bytes causes a buffer overrun
+    # during glob expansion).  Even if it were fixed, the result of this
+    # check would be larger than it should be.
+    lt_cv_sys_max_cmd_len=12288;    # 12K is about right
+  gnu*)
+    # Under GNU Hurd, this test is not required because there is
+    # no limit to the length of command line arguments.
+    # Libtool will interpret -1 as no limit whatsoever
+    lt_cv_sys_max_cmd_len=-1;
+  cygwin* | mingw*)
+    # On Win9x/ME, this test blows up -- it succeeds, but takes
+    # about 5 minutes as the teststring grows exponentially.
+    # Worse, since 9x/ME are not pre-emptively multitasking,
+    # you end up with a "frozen" computer, even though with patience
+    # the test eventually succeeds (with a max line length of 256k).
+    # Instead, let's just punt: use the minimum linelength reported by
+    # all of the supported platforms: 8192 (on NT/2K/XP).
+    lt_cv_sys_max_cmd_len=8192;
+  amigaos*)
+    # On AmigaOS with pdksh, this test takes hours, literally.
+    # So we just punt and use a minimum line length of 8192.
+  netbsd* | freebsd* | openbsd* | darwin* | dragonfly*)
+    # This has been around since 386BSD, at least.  Likely further.
+    if test -x /sbin/sysctl; then
+      lt_cv_sys_max_cmd_len=`/sbin/sysctl -n kern.argmax`
+    elif test -x /usr/sbin/sysctl; then
+      lt_cv_sys_max_cmd_len=`/usr/sbin/sysctl -n kern.argmax`
+    else
+      lt_cv_sys_max_cmd_len=65536	# usable default for all BSDs
+    fi
+    # And add a safety zone
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 4`
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \* 3`
+  interix*)
+    # We know the value 262144 and hardcode it with a safety zone (like BSD)
+    lt_cv_sys_max_cmd_len=196608
+  osf*)
+    # Dr. Hans Ekkehard Plesser reports seeing a kernel panic running configure
+    # due to this test when exec_disable_arg_limit is 1 on Tru64. It is not
+    # nice to cause kernel panics so lets avoid the loop below.
+    # First set a reasonable default.
+    lt_cv_sys_max_cmd_len=16384
+    if test -x /sbin/sysconfig; then
+      case `/sbin/sysconfig -q proc exec_disable_arg_limit` in
+        *1*) lt_cv_sys_max_cmd_len=-1 ;;
+      esac
+    fi
+  sco3.2v5*)
+    lt_cv_sys_max_cmd_len=102400
+  sysv5* | sco5v6* | sysv4.2uw2*)
+    kargmax=`grep ARG_MAX /etc/conf/cf.d/stune 2>/dev/null`
+    if test -n "$kargmax"; then
+      lt_cv_sys_max_cmd_len=`echo $kargmax | sed 's/.*[ 	]//'`
+    else
+      lt_cv_sys_max_cmd_len=32768
+    fi
+    # If test is not a shell built-in, we'll probably end up computing a
+    # maximum length that is only half of the actual maximum length, but
+    # we can't tell.
+    SHELL=${SHELL-${CONFIG_SHELL-/bin/sh}}
+    while (test "X"`$SHELL $0 --fallback-echo "X$teststring" 2>/dev/null` \
+	       = "XX$teststring") >/dev/null 2>&1 &&
+	    new_result=`expr "X$teststring" : ".*" 2>&1` &&
+	    lt_cv_sys_max_cmd_len=$new_result &&
+	    test $i != 17 # 1/2 MB should be enough
+    do
+      i=`expr $i + 1`
+      teststring=$teststring$teststring
+    done
+    teststring=
+    # Add a significant safety factor because C++ compilers can tack on massive
+    # amounts of additional arguments before passing them to the linker.
+    # It appears as though 1/2 is a usable value.
+    lt_cv_sys_max_cmd_len=`expr $lt_cv_sys_max_cmd_len \/ 2`
+  esac
+fi
+if test -n $lt_cv_sys_max_cmd_len ; then
+  echo "$as_me:$LINENO: result: $lt_cv_sys_max_cmd_len" >&5
+echo "${ECHO_T}$lt_cv_sys_max_cmd_len" >&6
+else
+  echo "$as_me:$LINENO: result: none" >&5
+echo "${ECHO_T}none" >&6
+fi
+# Check for command to grab the raw symbol name followed by C symbol from nm.
+echo "$as_me:$LINENO: checking command to parse $NM output from $compiler object" >&5
+echo $ECHO_N "checking command to parse $NM output from $compiler object... $ECHO_C" >&6
+if test "${lt_cv_sys_global_symbol_pipe+set}" = set; then
+else
+# These are sane defaults that work on at least a few old systems.
+# [They come from Ultrix.  What could be older than Ultrix?!! ;)]
+# Character class describing NM global symbol codes.
+symcode='[BCDEGRST]'
+# Regexp to match symbols that can be accessed directly from C.
+sympat='\([_A-Za-z][_A-Za-z0-9]*\)'
+# Transform an extracted symbol line into a proper C declaration
+lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^. .* \(.*\)$/extern int \1;/p'"
+# Transform an extracted symbol line into symbol name and symbol address
+lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
+# Define system-specific variables.
+case $host_os in
+aix*)
+  symcode='[BCDT]'
+cygwin* | mingw* | pw32*)
+  symcode='[ABCDGISTW]'
+hpux*) # Its linker distinguishes data from code symbols
+  if test "$host_cpu" = ia64; then
+    symcode='[ABCDEGRST]'
+  fi
+  lt_cv_sys_global_symbol_to_cdecl="sed -n -e 's/^T .* \(.*\)$/extern int \1();/p' -e 's/^$symcode* .* \(.*\)$/extern char \1;/p'"
+  lt_cv_sys_global_symbol_to_c_name_address="sed -n -e 's/^: \([^ ]*\) $/  {\\\"\1\\\", (lt_ptr) 0},/p' -e 's/^$symcode* \([^ ]*\) \([^ ]*\)$/  {\"\2\", (lt_ptr) \&\2},/p'"
+linux*)
+    symcode='[ABCDGIRSTW]'
+  fi
+irix* | nonstopux*)
+  symcode='[BCDEGRST]'
+osf*)
+  symcode='[BCDEGQRST]'
+solaris*)
+  symcode='[BDRT]'
+sco3.2v5*)
+  symcode='[DT]'
+sysv4.2uw2*)
+  symcode='[DT]'
+sysv5* | sco5v6* | unixware* | OpenUNIX*)
+  symcode='[ABDT]'
+sysv4)
+  symcode='[DFNSTU]'
+esac
+# Handle CRLF in mingw tool chain
+opt_cr=
+case $build_os in
+mingw*)
+  opt_cr=`echo 'x\{0,1\}' | tr x '\015'` # option cr in regexp
+esac
+# If we're using GNU nm, then use its standard symbol codes.
+case `$NM -V 2>&1` in
+  symcode='[ABCDGIRSTW]' ;;
+esac
+# Try without a prefix undercore, then with it.
+for ac_symprfx in "" "_"; do
+  # Transform symcode, sympat, and symprfx into a raw symbol and a C symbol.
+  symxfrm="\\1 $ac_symprfx\\2 \\2"
+  # Write the raw and C identifiers.
+  lt_cv_sys_global_symbol_pipe="sed -n -e 's/^.*[ 	]\($symcode$symcode*\)[ 	][ 	]*$ac_symprfx$sympat$opt_cr$/$symxfrm/p'"
+  # Check to see that the pipe works correctly.
+  pipe_works=no
+  rm -f conftest*
+  cat > conftest.$ac_ext <<EOF
+#ifdef __cplusplus
+extern "C" {
+#endif
+char nm_test_var;
+void nm_test_func(){}
+#ifdef __cplusplus
+#endif
+int main(){nm_test_var='a';nm_test_func();return(0);}
+EOF
+  ac_status=$?
+    # Now try to grab the symbols.
+    nlist=conftest.nm
+    if { (eval echo "$as_me:$LINENO: \"$NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist\"") >&5
+  (eval $NM conftest.$ac_objext \| $lt_cv_sys_global_symbol_pipe \> $nlist) 2>&5
+  ac_status=$?
+  (exit $ac_status); } && test -s "$nlist"; then
+      # Try sorting and uniquifying the output.
+      if sort "$nlist" | uniq > "$nlist"T; then
+	mv -f "$nlist"T "$nlist"
+      else
+	rm -f "$nlist"T
+      fi
+      # Make sure that we snagged all the symbols we need.
+      if grep ' nm_test_var$' "$nlist" >/dev/null; then
+	if grep ' nm_test_func$' "$nlist" >/dev/null; then
+	  cat <<EOF > conftest.$ac_ext
+#ifdef __cplusplus
+extern "C" {
+#endif
+EOF
+	  # Now generate the symbol file.
+	  eval "$lt_cv_sys_global_symbol_to_cdecl"' < "$nlist" | grep -v main >> conftest.$ac_ext'
+	  cat <<EOF >> conftest.$ac_ext
+#if defined (__STDC__) && __STDC__
+# define lt_ptr_t void *
+#else
+# define lt_ptr_t char *
+# define const
+#endif
+/* The mapping between symbol names and symbols. */
+const struct {
+  const char *name;
+  lt_ptr_t address;
+lt_preloaded_symbols[] =
+EOF
+	  $SED "s/^$symcode$symcode* \(.*\) \(.*\)$/  {\"\2\", (lt_ptr_t) \&\2},/" < "$nlist" | grep -v main >> conftest.$ac_ext
+	  cat <<\EOF >> conftest.$ac_ext
+  {0, (lt_ptr_t) 0}
+#ifdef __cplusplus
+#endif
+EOF
+	  # Now try linking the two files.
+	  mv conftest.$ac_objext conftstm.$ac_objext
+	  lt_save_LIBS="$LIBS"
+	  lt_save_CFLAGS="$CFLAGS"
+	  LIBS="conftstm.$ac_objext"
+	  CFLAGS="$CFLAGS$lt_prog_compiler_no_builtin_flag"
+	  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  ac_status=$?
+  (exit $ac_status); } && test -s conftest${ac_exeext}; then
+	    pipe_works=yes
+	  fi
+	  LIBS="$lt_save_LIBS"
+	  CFLAGS="$lt_save_CFLAGS"
+	else
+	  echo "cannot find nm_test_func in $nlist" >&5
+	fi
+      else
+	echo "cannot find nm_test_var in $nlist" >&5
+      fi
+    else
+      echo "cannot run $lt_cv_sys_global_symbol_pipe" >&5
+    fi
+  else
+    echo "$progname: failed program was:" >&5
+    cat conftest.$ac_ext >&5
+  fi
+  rm -f conftest* conftst*
+  # Do not use the global_symbol_pipe unless it works.
+  if test "$pipe_works" = yes; then
+    break
+  else
+  fi
+done
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe"; then
+fi
+if test -z "$lt_cv_sys_global_symbol_pipe$lt_cv_sys_global_symbol_to_cdecl"; then
+  echo "$as_me:$LINENO: result: failed" >&5
+echo "${ECHO_T}failed" >&6
+else
+  echo "$as_me:$LINENO: result: ok" >&5
+echo "${ECHO_T}ok" >&6
+fi
+echo "$as_me:$LINENO: checking for objdir" >&5
+echo $ECHO_N "checking for objdir... $ECHO_C" >&6
+if test "${lt_cv_objdir+set}" = set; then
+else
+  rm -f .libs 2>/dev/null
+mkdir .libs 2>/dev/null
+if test -d .libs; then
+  lt_cv_objdir=.libs
+else
+  # MS-DOS does not allow filenames that begin with a dot.
+  lt_cv_objdir=_libs
+fi
+rmdir .libs 2>/dev/null
+fi
+echo "$as_me:$LINENO: result: $lt_cv_objdir" >&5
+echo "${ECHO_T}$lt_cv_objdir" >&6
+objdir=$lt_cv_objdir
+case $host_os in
+aix3*)
+  # AIX sometimes has problems with the GCC collect2 program.  For some
+  # reason, if we set the COLLECT_NAMES environment variable, the problems
+  # vanish in a puff of smoke.
+  if test "X${COLLECT_NAMES+set}" != Xset; then
+    COLLECT_NAMES=
+    export COLLECT_NAMES
+  fi
+esac
+# Sed substitution that helps us do robust quoting.  It backslashifies
+# metacharacters that are still active within double-quoted strings.
+Xsed='sed -e 1s/^X//'
+sed_quote_subst='s/\([\\"\\`$\\\\]\)/\\\1/g'
+# Same as above, but do not quote variable references.
+double_quote_subst='s/\([\\"\\`\\\\]\)/\\\1/g'
+# Sed substitution to delay expansion of an escaped shell variable in a
+# double_quote_subst'ed string.
+delay_variable_subst='s/\\\\\\\\\\\$/\\\\\\$/g'
+# Sed substitution to avoid accidental globbing in evaled expressions
+no_glob_subst='s/\*/\\\*/g'
+# Constants:
+rm="rm -f"
+# Global variables:
+default_ofile=libtool
+can_build_shared=yes
+# All known linkers require a `.a' archive for static linking (except MSVC,
+# which needs '.lib').
+libext=a
+ltmain="$ac_aux_dir/ltmain.sh"
+ofile="$default_ofile"
+with_gnu_ld="$lt_cv_prog_gnu_ld"
+if test -n "$ac_tool_prefix"; then
+  # Extract the first word of "${ac_tool_prefix}ar", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ar; ac_word=$2
+echo "$as_me:$LINENO: checking for $ac_word" >&5
+echo $ECHO_N "checking for $ac_word... $ECHO_C" >&6
+if test "${ac_cv_prog_AR+set}" = set; then
+else
+  if test -n "$AR"; then
+  ac_cv_prog_AR="$AR" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+  if $as_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+    ac_cv_prog_AR="${ac_tool_prefix}ar"
+    echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
+    break 2
+  fi
+done
+done
+fi
+fi
+AR=$ac_cv_prog_AR
+if test -n "$AR"; then
+  echo "$as_me:$LINENO: result: $AR" >&5
+echo "${ECHO_T}$AR" >&6
+else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+fi
+if test -z "$ac_cv_prog_AR"; then
+  ac_ct_AR=$AR
+  # Extract the first word of "ar", so it can be a program name with args.
+set dummy ar; ac_word=$2
+if test "${ac_cv_prog_ac_ct_AR+set}" = set; then
+else
+  if test -n "$ac_ct_AR"; then
+  ac_cv_prog_ac_ct_AR="$ac_ct_AR" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_AR="ar"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_AR" && ac_cv_prog_ac_ct_AR="false"
+fi
+fi
+ac_ct_AR=$ac_cv_prog_ac_ct_AR
+if test -n "$ac_ct_AR"; then
+  echo "$as_me:$LINENO: result: $ac_ct_AR" >&5
+echo "${ECHO_T}$ac_ct_AR" >&6
+else
+fi
+  AR=$ac_ct_AR
+else
+  AR="$ac_cv_prog_AR"
+fi
+  # Extract the first word of "${ac_tool_prefix}ranlib", so it can be a program name with args.
+set dummy ${ac_tool_prefix}ranlib; ac_word=$2
+if test "${ac_cv_prog_RANLIB+set}" = set; then
+else
+  if test -n "$RANLIB"; then
+  ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_RANLIB="${ac_tool_prefix}ranlib"
+    break 2
+  fi
+done
+done
+fi
+fi
+RANLIB=$ac_cv_prog_RANLIB
+if test -n "$RANLIB"; then
+  echo "$as_me:$LINENO: result: $RANLIB" >&5
+echo "${ECHO_T}$RANLIB" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_RANLIB"; then
+  ac_ct_RANLIB=$RANLIB
+  # Extract the first word of "ranlib", so it can be a program name with args.
+set dummy ranlib; ac_word=$2
+if test "${ac_cv_prog_ac_ct_RANLIB+set}" = set; then
+else
+  if test -n "$ac_ct_RANLIB"; then
+  ac_cv_prog_ac_ct_RANLIB="$ac_ct_RANLIB" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_RANLIB="ranlib"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_RANLIB" && ac_cv_prog_ac_ct_RANLIB=":"
+fi
+fi
+ac_ct_RANLIB=$ac_cv_prog_ac_ct_RANLIB
+if test -n "$ac_ct_RANLIB"; then
+  echo "$as_me:$LINENO: result: $ac_ct_RANLIB" >&5
+echo "${ECHO_T}$ac_ct_RANLIB" >&6
+else
+fi
+  RANLIB=$ac_ct_RANLIB
+else
+  RANLIB="$ac_cv_prog_RANLIB"
+fi
+  # Extract the first word of "${ac_tool_prefix}strip", so it can be a program name with args.
+set dummy ${ac_tool_prefix}strip; ac_word=$2
+if test "${ac_cv_prog_STRIP+set}" = set; then
+else
+  if test -n "$STRIP"; then
+  ac_cv_prog_STRIP="$STRIP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_STRIP="${ac_tool_prefix}strip"
+    break 2
+  fi
+done
+done
+fi
+fi
+STRIP=$ac_cv_prog_STRIP
+if test -n "$STRIP"; then
+  echo "$as_me:$LINENO: result: $STRIP" >&5
+echo "${ECHO_T}$STRIP" >&6
+else
+fi
+fi
+if test -z "$ac_cv_prog_STRIP"; then
+  ac_ct_STRIP=$STRIP
+  # Extract the first word of "strip", so it can be a program name with args.
+set dummy strip; ac_word=$2
+if test "${ac_cv_prog_ac_ct_STRIP+set}" = set; then
+else
+  if test -n "$ac_ct_STRIP"; then
+  ac_cv_prog_ac_ct_STRIP="$ac_ct_STRIP" # Let the user override the test.
+else
+do
+  IFS=$as_save_IFS
+    ac_cv_prog_ac_ct_STRIP="strip"
+    break 2
+  fi
+done
+done
+  test -z "$ac_cv_prog_ac_ct_STRIP" && ac_cv_prog_ac_ct_STRIP=":"
+fi
+fi
+ac_ct_STRIP=$ac_cv_prog_ac_ct_STRIP
+if test -n "$ac_ct_STRIP"; then
+  echo "$as_me:$LINENO: result: $ac_ct_STRIP" >&5
+echo "${ECHO_T}$ac_ct_STRIP" >&6
+else
+fi
+  STRIP=$ac_ct_STRIP
+else
+  STRIP="$ac_cv_prog_STRIP"
+fi
+old_CC="$CC"
+old_CFLAGS="$CFLAGS"
+# Set sane defaults for various variables
+test -z "$AR" && AR=ar
+test -z "$AR_FLAGS" && AR_FLAGS=cru
+test -z "$AS" && AS=as
+test -z "$CC" && CC=cc
+test -z "$LTCC" && LTCC=$CC
+test -z "$LTCFLAGS" && LTCFLAGS=$CFLAGS
+test -z "$DLLTOOL" && DLLTOOL=dlltool
+test -z "$LD" && LD=ld
+test -z "$LN_S" && LN_S="ln -s"
+test -z "$MAGIC_CMD" && MAGIC_CMD=file
+test -z "$NM" && NM=nm
+test -z "$SED" && SED=sed
+test -z "$OBJDUMP" && OBJDUMP=objdump
+test -z "$RANLIB" && RANLIB=:
+test -z "$STRIP" && STRIP=:
+test -z "$ac_objext" && ac_objext=o
+# Determine commands to create old-style static archives.
+old_archive_cmds='$AR $AR_FLAGS $oldlib$oldobjs$old_deplibs'
+old_postinstall_cmds='chmod 644 $oldlib'
+old_postuninstall_cmds=
+  case $host_os in
+  openbsd*)
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB -t \$oldlib"
+    old_postinstall_cmds="$old_postinstall_cmds~\$RANLIB \$oldlib"
+  esac
+  old_archive_cmds="$old_archive_cmds~\$RANLIB \$oldlib"
+fi
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# Only perform the check for file, if the check method requires it
+case $deplibs_check_method in
+file_magic*)
+  if test "$file_magic_cmd" = '$MAGIC_CMD'; then
+    echo "$as_me:$LINENO: checking for ${ac_tool_prefix}file" >&5
+echo $ECHO_N "checking for ${ac_tool_prefix}file... $ECHO_C" >&6
+if test "${lt_cv_path_MAGIC_CMD+set}" = set; then
+else
+  case $MAGIC_CMD in
+  lt_cv_path_MAGIC_CMD="$MAGIC_CMD" # Let the user override the test with a path.
+  lt_save_MAGIC_CMD="$MAGIC_CMD"
+  ac_dummy="/usr/bin$PATH_SEPARATOR$PATH"
+  for ac_dir in $ac_dummy; do
+    if test -f $ac_dir/${ac_tool_prefix}file; then
+      lt_cv_path_MAGIC_CMD="$ac_dir/${ac_tool_prefix}file"
+      if test -n "$file_magic_test_file"; then
+	case $deplibs_check_method in
+	"file_magic "*)
+	  file_magic_regex=`expr "$deplibs_check_method" : "file_magic \(.*\)"`
+	  MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+	  if eval $file_magic_cmd \$file_magic_test_file 2> /dev/null |
+	    $EGREP "$file_magic_regex" > /dev/null; then
+	  else
+	    cat <<EOF 1>&2
+*** Warning: the command libtool uses to detect shared libraries,
+*** $file_magic_cmd, produces output that libtool cannot recognize.
+*** The result is that libtool may fail to recognize shared libraries
+*** as such.  This will affect the creation of libtool libraries that
+*** depend on shared libraries, but programs linked with such libtool
+*** libraries will work regardless of this problem.  Nevertheless, you
+*** may want to report the problem to your system manager and/or to
+*** bug-libtool at gnu.org
+EOF
+	  fi ;;
+	esac
+      fi
+      break
+    fi
+  done
+  MAGIC_CMD="$lt_save_MAGIC_CMD"
+esac
+fi
+MAGIC_CMD="$lt_cv_path_MAGIC_CMD"
+if test -n "$MAGIC_CMD"; then
+  echo "$as_me:$LINENO: result: $MAGIC_CMD" >&5
+echo "${ECHO_T}$MAGIC_CMD" >&6
+else
+fi
+if test -z "$lt_cv_path_MAGIC_CMD"; then
+  if test -n "$ac_tool_prefix"; then
+    echo "$as_me:$LINENO: checking for file" >&5
+echo $ECHO_N "checking for file... $ECHO_C" >&6
+else
+    if test -f $ac_dir/file; then
+      lt_cv_path_MAGIC_CMD="$ac_dir/file"
+	"file_magic "*)
+	  else
+	    cat <<EOF 1>&2
+EOF
+	  fi ;;
+	esac
+      fi
+      break
+    fi
+  done
+esac
+fi
+else
+fi
+  else
+    MAGIC_CMD=:
+  fi
+fi
+  fi
+esac
+enable_dlopen=no
+enable_win32_dll=no
+fi;
+# Check whether --with-pic or --without-pic was given.
+if test "${with_pic+set}" = set; then
+  withval="$with_pic"
+  pic_mode="$withval"
+else
+  pic_mode=default
+fi;
+test -z "$pic_mode" && pic_mode=default
+# Use C for the default configuration in the libtool script
+tagname=
+lt_save_CC="$CC"
+ac_ext=c
+# Source file extension for C test sources.
+ac_ext=c
+# Object file extension for compiled C test sources.
+objext=o
+objext=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(){return(0);}\n'
+LTCC=${LTCC-"$CC"}
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_prog_compiler_no_builtin_flag=
+  lt_prog_compiler_no_builtin_flag=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+else
+  lt_cv_prog_compiler_rtti_exceptions=no
+  ac_outfile=conftest.$ac_objext
+   printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+   lt_compiler_flag="-fno-rtti -fno-exceptions"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:6480: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:6484: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_rtti_exceptions=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+    lt_prog_compiler_no_builtin_flag="$lt_prog_compiler_no_builtin_flag -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl=
+lt_prog_compiler_pic=
+lt_prog_compiler_static=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+  if test "$GCC" = yes; then
+    lt_prog_compiler_wl='-Wl,'
+    lt_prog_compiler_static='-static'
+    case $host_os in
+      aix*)
+      # All AIX code is PIC.
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | pw32* | os2*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared=no
+      enable_shared=no
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	lt_prog_compiler_pic=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic='-qnocommon'
+       esac
+    hpux9* | hpux10* | hpux11*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static='${wl}-a ${wl}archive'
+    irix5* | irix6* | nonstopux*)
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic='-KPIC'
+    linux*)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+    osf3* | osf4* | osf5*)
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl='-Qoption ld ';;
+	lt_prog_compiler_wl='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+      if test -d /usr/nec ;then
+	lt_prog_compiler_pic='-Kconform_pic'
+      fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works+set}" = set; then
+else
+  lt_prog_compiler_pic_works=no
+   lt_compiler_flag="$lt_prog_compiler_pic -DPIC"
+   (eval echo "\"\$as_me:6748: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:6752: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works" >&6
+if test x"$lt_prog_compiler_pic_works" = xyes; then
+    case $lt_prog_compiler_pic in
+     *) lt_prog_compiler_pic=" $lt_prog_compiler_pic" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic="$lt_prog_compiler_pic -DPIC"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl eval lt_tmp_static_flag=\"$lt_prog_compiler_static\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works+set}" = set; then
+else
+  lt_prog_compiler_static_works=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works" >&6
+if test x"$lt_prog_compiler_static_works" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:6852: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:6856: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag=
+  enable_shared_with_static_runtimes=no
+  archive_cmds=
+  archive_expsym_cmds=
+  old_archive_From_new_cmds=
+  old_archive_from_expsyms_cmds=
+  export_dynamic_flag_spec=
+  whole_archive_flag_spec=
+  thread_safe_flag_spec=
+  hardcode_libdir_flag_spec=
+  hardcode_libdir_flag_spec_ld=
+  hardcode_libdir_separator=
+  hardcode_direct=no
+  hardcode_minus_L=no
+  hardcode_shlibpath_var=unsupported
+  link_all_deplibs=unknown
+  hardcode_automatic=no
+  module_cmds=
+  module_expsym_cmds=
+  always_export_symbols=no
+  export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+      if test "$host_cpu" != ia64; then
+	ld_shlibs=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec='-L$libdir'
+      hardcode_minus_L=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, ) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes=yes
+      export_symbols_cmds='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var=no
+      hardcode_libdir_flag_spec='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    linux*)
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+      else
+	ld_shlibs=no
+      fi
+    netbsd*)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct=yes
+      else
+	ld_shlibs=no
+      fi
+    esac
+    if test "$ld_shlibs" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols=yes
+      archive_expsym_cmds='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	# If we're using GNU nm, then we don't want the "-C" option.
+	# -C means demangle to AIX nm, but means don't demangle with GNU nm
+	if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+	  export_symbols_cmds='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds=''
+      hardcode_libdir_separator=':'
+      link_all_deplibs=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag="-z nodefs"
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag=' ${wl}-bernotok'
+	  allow_undefined_flag=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec='$convenience'
+	  archive_cmds_need_lc=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs=no
+    bsdi[45]*)
+      export_dynamic_flag_spec=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      shrext_cmds=".dll"
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc=no
+      hardcode_automatic=yes
+      whole_archive_flag_spec=''
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs=no
+      esac
+    fi
+    dgux*)
+      archive_cmds='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | kfreebsd*-gnu | dragonfly*)
+      archive_cmds='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld='+b $libdir'
+	esac
+      fi
+	archive_cmds='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec='${wl}-rpath ${wl}$libdir'
+    netbsd*)
+	archive_cmds='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag=' -expect_unresolved \*'
+	archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag=' -z text'
+	wlarc='${wl}'
+	archive_cmds='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+      case $host_vendor in
+	sni)
+	  hardcode_direct=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec='-Bexport'
+    sysv4*MP*)
+	hardcode_runpath_var=yes
+	ld_shlibs=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag='${wl}-z,text'
+	archive_cmds='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec='${wl}-Bexport'
+	archive_cmds='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs" >&5
+echo "${ECHO_T}$ld_shlibs" >&6
+test "$ld_shlibs" = no && can_build_shared=no
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl
+	pic_flag=$lt_prog_compiler_pic
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag=$lt_save_allow_undefined_flag
+      else
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc" >&5
+echo "${ECHO_T}$archive_cmds_need_lc" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+library_names_spec=
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+postuninstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+  version_type=windows
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action=
+if test -n "$hardcode_libdir_flag_spec" || \
+   test -n "$runpath_var" || \
+   test "X$hardcode_automatic" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, )" != no &&
+     test "$hardcode_minus_L" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action" >&5
+echo "${ECHO_T}$hardcode_action" >&6
+if test "$hardcode_action" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+striplib=
+old_striplib=
+echo "$as_me:$LINENO: checking whether stripping libraries is possible" >&5
+echo $ECHO_N "checking whether stripping libraries is possible... $ECHO_C" >&6
+if test -n "$STRIP" && $STRIP -V 2>&1 | grep "GNU strip" >/dev/null; then
+  test -z "$old_striplib" && old_striplib="$STRIP --strip-debug"
+  test -z "$striplib" && striplib="$STRIP --strip-unneeded"
+  echo "$as_me:$LINENO: result: yes" >&5
+echo "${ECHO_T}yes" >&6
+else
+# FIXME - insert some real tests, host_os isn't really good enough
+  case $host_os in
+   darwin*)
+       if test -n "$STRIP" ; then
+         striplib="$STRIP -x"
+       else
+  echo "$as_me:$LINENO: result: no" >&5
+echo "${ECHO_T}no" >&6
+fi
+  esac
+fi
+if test "x$enable_dlopen" != xyes; then
+  enable_dlopen=unknown
+  enable_dlopen_self=unknown
+  enable_dlopen_self_static=unknown
+else
+  lt_cv_dlopen=no
+  lt_cv_dlopen_libs=
+  case $host_os in
+  beos*)
+    lt_cv_dlopen="load_add_on"
+    lt_cv_dlopen_self=yes
+  mingw* | pw32*)
+    lt_cv_dlopen="LoadLibrary"
+  cygwin*)
+    lt_cv_dlopen="dlopen"
+  darwin*)
+  # if libdl is installed we need to link against it
+    echo "$as_me:$LINENO: checking for dlopen in -ldl" >&5
+echo $ECHO_N "checking for dlopen in -ldl... $ECHO_C" >&6
+if test "${ac_cv_lib_dl_dlopen+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-ldl  $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  (exit $ac_status); } &&
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dl_dlopen=yes
+else
+ac_cv_lib_dl_dlopen=no
+fi
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dl_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_dl_dlopen" >&6
+if test $ac_cv_lib_dl_dlopen = yes; then
+  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-ldl"
+else
+    lt_cv_dlopen="dyld"
+fi
+    echo "$as_me:$LINENO: checking for shl_load" >&5
+echo $ECHO_N "checking for shl_load... $ECHO_C" >&6
+if test "${ac_cv_func_shl_load+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define shl_load to an innocuous variant, in case <limits.h> declares shl_load.
+   For example, HP-UX 11i <limits.h> declares gettimeofday.  */
+#define shl_load innocuous_shl_load
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char shl_load (); below.
+    Prefer <limits.h> to <assert.h> if __STDC__ is defined, since
+    <limits.h> exists even on freestanding compilers.  */
+#ifdef __STDC__
+# include <limits.h>
+#else
+# include <assert.h>
+#endif
+#undef shl_load
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_shl_load) || defined (__stub___shl_load)
+choke me
+#else
+char (*f) () = shl_load;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != shl_load;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_shl_load=yes
+else
+ac_cv_func_shl_load=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_shl_load" >&5
+echo "${ECHO_T}$ac_cv_func_shl_load" >&6
+if test $ac_cv_func_shl_load = yes; then
+  lt_cv_dlopen="shl_load"
+else
+  echo "$as_me:$LINENO: checking for shl_load in -ldld" >&5
+echo $ECHO_N "checking for shl_load in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_shl_load+set}" = set; then
+else
+LIBS="-ldld  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char shl_load ();
+int
+main ()
+shl_load ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dld_shl_load=yes
+else
+ac_cv_lib_dld_shl_load=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_shl_load" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_shl_load" >&6
+if test $ac_cv_lib_dld_shl_load = yes; then
+  lt_cv_dlopen="shl_load" lt_cv_dlopen_libs="-dld"
+else
+  echo "$as_me:$LINENO: checking for dlopen" >&5
+echo $ECHO_N "checking for dlopen... $ECHO_C" >&6
+if test "${ac_cv_func_dlopen+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+/* Define dlopen to an innocuous variant, in case <limits.h> declares dlopen.
+#define dlopen innocuous_dlopen
+    which can conflict with char dlopen (); below.
+#ifdef __STDC__
+#else
+#endif
+#undef dlopen
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+#if defined (__stub_dlopen) || defined (__stub___dlopen)
+choke me
+#else
+char (*f) () = dlopen;
+#endif
+#ifdef __cplusplus
+#endif
+int
+main ()
+return f != dlopen;
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_func_dlopen=yes
+else
+ac_cv_func_dlopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_func_dlopen" >&5
+echo "${ECHO_T}$ac_cv_func_dlopen" >&6
+if test $ac_cv_func_dlopen = yes; then
+else
+else
+LIBS="-ldl  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+else
+fi
+fi
+else
+  echo "$as_me:$LINENO: checking for dlopen in -lsvld" >&5
+echo $ECHO_N "checking for dlopen in -lsvld... $ECHO_C" >&6
+if test "${ac_cv_lib_svld_dlopen+set}" = set; then
+else
+LIBS="-lsvld  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dlopen ();
+int
+main ()
+dlopen ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_svld_dlopen=yes
+else
+ac_cv_lib_svld_dlopen=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_svld_dlopen" >&5
+echo "${ECHO_T}$ac_cv_lib_svld_dlopen" >&6
+if test $ac_cv_lib_svld_dlopen = yes; then
+  lt_cv_dlopen="dlopen" lt_cv_dlopen_libs="-lsvld"
+else
+  echo "$as_me:$LINENO: checking for dld_link in -ldld" >&5
+echo $ECHO_N "checking for dld_link in -ldld... $ECHO_C" >&6
+if test "${ac_cv_lib_dld_dld_link+set}" = set; then
+else
+LIBS="-ldld  $LIBS"
+/* confdefs.h.  */
+_ACEOF
+#ifdef __cplusplus
+extern "C"
+#endif
+char dld_link ();
+int
+main ()
+dld_link ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  cat conftest.err >&5
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_dld_dld_link=yes
+else
+ac_cv_lib_dld_dld_link=no
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_dld_dld_link" >&5
+echo "${ECHO_T}$ac_cv_lib_dld_dld_link" >&6
+if test $ac_cv_lib_dld_dld_link = yes; then
+  lt_cv_dlopen="dld_link" lt_cv_dlopen_libs="-dld"
+fi
+fi
+fi
+fi
+fi
+fi
+  esac
+  if test "x$lt_cv_dlopen" != xno; then
+    enable_dlopen=yes
+  else
+    enable_dlopen=no
+  fi
+  case $lt_cv_dlopen in
+  dlopen)
+    save_CPPFLAGS="$CPPFLAGS"
+    test "x$ac_cv_header_dlfcn_h" = xyes && CPPFLAGS="$CPPFLAGS -DHAVE_DLFCN_H"
+    wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $export_dynamic_flag_spec\"
+    save_LIBS="$LIBS"
+    LIBS="$lt_cv_dlopen_libs $LIBS"
+    echo "$as_me:$LINENO: checking whether a program can dlopen itself" >&5
+echo $ECHO_N "checking whether a program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self+set}" = set; then
+else
+  	  if test "$cross_compiling" = yes; then :
+  lt_cv_dlopen_self=cross
+else
+  lt_dlunknown=0; lt_dlno_uscore=1; lt_dlneed_uscore=2
+  lt_status=$lt_dlunknown
+  cat > conftest.$ac_ext <<EOF
+#line 9197 "configure"
+#include "confdefs.h"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+#  define LT_DLGLOBAL		RTLD_GLOBAL
+#else
+#  ifdef DL_GLOBAL
+#    define LT_DLGLOBAL		DL_GLOBAL
+#  else
+#    define LT_DLGLOBAL		0
+#  endif
+#endif
+/* We may have to define LT_DLLAZY_OR_NOW in the command line if we
+   find out it does not work in some platform. */
+#ifndef LT_DLLAZY_OR_NOW
+#  ifdef RTLD_LAZY
+#    define LT_DLLAZY_OR_NOW		RTLD_LAZY
+#  else
+#    ifdef DL_LAZY
+#      define LT_DLLAZY_OR_NOW		DL_LAZY
+#    else
+#      ifdef RTLD_NOW
+#        define LT_DLLAZY_OR_NOW	RTLD_NOW
+#      else
+#        ifdef DL_NOW
+#          define LT_DLLAZY_OR_NOW	DL_NOW
+#        else
+#          define LT_DLLAZY_OR_NOW	0
+#        endif
+#      endif
+#    endif
+#  endif
+#endif
+#ifdef __cplusplus
+extern "C" void exit (int);
+#endif
+void fnord() { int i=42;}
+int main ()
+  void *self = dlopen (0, LT_DLGLOBAL|LT_DLLAZY_OR_NOW);
+  int status = $lt_dlunknown;
+  if (self)
+      if (dlsym (self,"fnord"))       status = $lt_dlno_uscore;
+      else if (dlsym( self,"_fnord")) status = $lt_dlneed_uscore;
+      /* dlclose (self); */
+  else
+    puts (dlerror ());
+    exit (status);
+EOF
+  if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  (exit $ac_status); } && test -s conftest${ac_exeext} 2>/dev/null; then
+    (./conftest; exit; ) >&5 2>/dev/null
+    lt_status=$?
+    case x$lt_status in
+      x$lt_dlno_uscore) lt_cv_dlopen_self=yes ;;
+      x$lt_dlneed_uscore) lt_cv_dlopen_self=yes ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self=no ;;
+    esac
+  else :
+    # compilation failed
+    lt_cv_dlopen_self=no
+  fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self" >&6
+    if test "x$lt_cv_dlopen_self" = xyes; then
+      wl=$lt_prog_compiler_wl eval LDFLAGS=\"\$LDFLAGS $lt_prog_compiler_static\"
+      echo "$as_me:$LINENO: checking whether a statically linked program can dlopen itself" >&5
+echo $ECHO_N "checking whether a statically linked program can dlopen itself... $ECHO_C" >&6
+if test "${lt_cv_dlopen_self_static+set}" = set; then
+else
+  lt_cv_dlopen_self_static=cross
+else
+#line 9297 "configure"
+#if HAVE_DLFCN_H
+#include <dlfcn.h>
+#endif
+#include <stdio.h>
+#ifdef RTLD_GLOBAL
+#else
+#  ifdef DL_GLOBAL
+#  else
+#  endif
+#endif
+#  ifdef RTLD_LAZY
+#  else
+#    ifdef DL_LAZY
+#    else
+#      ifdef RTLD_NOW
+#      else
+#        ifdef DL_NOW
+#        else
+#        endif
+#      endif
+#    endif
+#  endif
+#endif
+#ifdef __cplusplus
+#endif
+int main ()
+  if (self)
+  else
+    exit (status);
+EOF
+  ac_status=$?
+    lt_status=$?
+      x$lt_dlno_uscore) lt_cv_dlopen_self_static=yes ;;
+      x$lt_dlneed_uscore) lt_cv_dlopen_self_static=yes ;;
+      x$lt_dlunknown|x*) lt_cv_dlopen_self_static=no ;;
+    esac
+  else :
+    lt_cv_dlopen_self_static=no
+  fi
+fi
+rm -fr conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_dlopen_self_static" >&5
+echo "${ECHO_T}$lt_cv_dlopen_self_static" >&6
+    fi
+    CPPFLAGS="$save_CPPFLAGS"
+    LIBS="$save_LIBS"
+  esac
+  case $lt_cv_dlopen_self in
+  yes|no) enable_dlopen_self=$lt_cv_dlopen_self ;;
+  *) enable_dlopen_self=unknown ;;
+  esac
+  case $lt_cv_dlopen_self_static in
+  yes|no) enable_dlopen_self_static=$lt_cv_dlopen_self_static ;;
+  *) enable_dlopen_self_static=unknown ;;
+  esac
+fi
+# Report which library types will actually be built
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+  test "$enable_shared" = yes && enable_static=no
+  if test -n "$RANLIB"; then
+    archive_cmds="$archive_cmds~\$RANLIB \$lib"
+    postinstall_cmds='$RANLIB $lib'
+  fi
+aix4* | aix5*)
+  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+  fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler \
+    CC \
+    LD \
+    lt_prog_compiler_wl \
+    lt_prog_compiler_pic \
+    lt_prog_compiler_static \
+    lt_prog_compiler_no_builtin_flag \
+    export_dynamic_flag_spec \
+    thread_safe_flag_spec \
+    whole_archive_flag_spec \
+    enable_shared_with_static_runtimes \
+    old_archive_cmds \
+    old_archive_from_new_cmds \
+    predep_objects \
+    postdep_objects \
+    predeps \
+    postdeps \
+    compiler_lib_search_path \
+    archive_cmds \
+    archive_expsym_cmds \
+    postinstall_cmds \
+    postuninstall_cmds \
+    old_archive_from_expsyms_cmds \
+    allow_undefined_flag \
+    no_undefined_flag \
+    export_symbols_cmds \
+    hardcode_libdir_flag_spec \
+    hardcode_libdir_flag_spec_ld \
+    hardcode_libdir_separator \
+    hardcode_automatic \
+    module_cmds \
+    module_expsym_cmds \
+    lt_cv_prog_compiler_c_o \
+    exclude_expsyms \
+    include_expsyms; do
+    case $var in
+    old_archive_cmds | \
+    old_archive_from_new_cmds | \
+    archive_cmds | \
+    archive_expsym_cmds | \
+    module_cmds | \
+    module_expsym_cmds | \
+    old_archive_from_expsyms_cmds | \
+    export_symbols_cmds | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="${ofile}T"
+  trap "$rm \"$cfgfile\"; exit 1" 1 2 15
+  $rm -f "$cfgfile"
+  { echo "$as_me:$LINENO: creating $ofile" >&5
+echo "$as_me: creating $ofile" >&6;}
+  cat <<__EOF__ >> "$cfgfile"
+#! $SHELL
+# `$echo "$cfgfile" | sed 's%^.*/%%'` - Provide generalized library-building support services.
+# Generated automatically by $PROGRAM (GNU $PACKAGE $VERSION$TIMESTAMP)
+# NOTE: Changes made to this file will be lost: look at ltmain.sh.
+# Copyright (C) 1996, 1997, 1998, 1999, 2000, 2001
+# Free Software Foundation, Inc.
+# This file is part of GNU Libtool:
+# Originally by Gordon Matzigkeit <gord at gnu.ai.mit.edu>, 1996
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful, but
+# WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+# General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301, USA.
+# As a special exception to the GNU General Public License, if you
+# distribute this file as part of a program that contains a
+# configuration script generated by Autoconf, you may include it under
+# the same distribution terms that you use for the rest of that program.
+# A sed program that does not truncate output.
+SED=$lt_SED
+# Sed that helps us avoid accidentally triggering echo(1) options like -n.
+Xsed="$SED -e 1s/^X//"
+# The HP-UX ksh and POSIX shell print the target directory to stdout
+# if CDPATH is set.
+(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
+# The names of the tagged configurations supported by this script.
+available_tags=
+# ### BEGIN LIBTOOL CONFIG
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds
+archive_expsym_cmds=$lt_archive_expsym_cmds
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds
+module_expsym_cmds=$lt_module_expsym_cmds
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects
+# shared library.
+predeps=$lt_predeps
+# shared library.
+postdeps=$lt_postdeps
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms
+# ### END LIBTOOL CONFIG
+__EOF__
+  case $host_os in
+  aix3*)
+    cat <<\EOF >> "$cfgfile"
+# AIX sometimes has problems with the GCC collect2 program.  For some
+# reason, if we set the COLLECT_NAMES environment variable, the problems
+# vanish in a puff of smoke.
+if test "X${COLLECT_NAMES+set}" != Xset; then
+  COLLECT_NAMES=
+  export COLLECT_NAMES
+fi
+EOF
+  esac
+  # We use sed instead of cat because bash on DJGPP gets confused if
+  # if finds mixed CR/LF and LF-only lines.  Since sed operates in
+  # text mode, it properly converts lines to CR/LF.  This bash problem
+  # is reportedly fixed, but why not run on old versions too?
+  sed '$q' "$ltmain" >> "$cfgfile" || (rm -f "$cfgfile"; exit 1)
+  mv -f "$cfgfile" "$ofile" || \
+    (rm -f "$ofile" && cp "$cfgfile" "$ofile" && rm -f "$cfgfile")
+  chmod +x "$ofile"
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC="$lt_save_CC"
+# Check whether --with-tags or --without-tags was given.
+if test "${with_tags+set}" = set; then
+  withval="$with_tags"
+  tagnames="$withval"
+fi;
+if test -f "$ltmain" && test -n "$tagnames"; then
+  if test ! -f "${ofile}"; then
+    { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not exist" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not exist" >&2;}
+  fi
+  if test -z "$LTCC"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCC='`"
+      { echo "$as_me:$LINENO: WARNING: output file \`$ofile' does not look like a libtool script" >&5
+echo "$as_me: WARNING: output file \`$ofile' does not look like a libtool script" >&2;}
+    else
+      { echo "$as_me:$LINENO: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&5
+echo "$as_me: WARNING: using \`LTCC=$LTCC', extracted from \`$ofile'" >&2;}
+    fi
+  fi
+  if test -z "$LTCFLAGS"; then
+    eval "`$SHELL ${ofile} --config | grep '^LTCFLAGS='`"
+  fi
+  # Extract list of available tagged configurations in $ofile.
+  # Note that this assumes the entire list is on one line.
+  available_tags=`grep "^available_tags=" "${ofile}" | $SED -e 's/available_tags=\(.*$\)/\1/' -e 's/\"//g'`
+  lt_save_ifs="$IFS"; IFS="${IFS}$PATH_SEPARATOR,"
+  for tagname in $tagnames; do
+    IFS="$lt_save_ifs"
+    # Check whether tagname contains only valid characters
+    case `$echo "X$tagname" | $Xsed -e 's:[-_ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz1234567890,/]::g'` in
+    *)  { { echo "$as_me:$LINENO: error: invalid tag name: $tagname" >&5
+echo "$as_me: error: invalid tag name: $tagname" >&2;}
+   { (exit 1); exit 1; }; }
+    esac
+    if grep "^# ### BEGIN LIBTOOL TAG CONFIG: $tagname$" < "${ofile}" > /dev/null
+    then
+      { { echo "$as_me:$LINENO: error: tag name \"$tagname\" already exists" >&5
+echo "$as_me: error: tag name \"$tagname\" already exists" >&2;}
+    fi
+    # Update the list of available tags.
+    if test -n "$tagname"; then
+      echo appending configuration tag \"$tagname\" to $ofile
+      case $tagname in
+      CXX)
+	if test -n "$CXX" && ( test "X$CXX" != "Xno" &&
+	    ( (test "X$CXX" = "Xg++" && `g++ -v >/dev/null 2>&1` ) ||
+	    (test "X$CXX" != "Xg++"))) ; then
+	  ac_ext=cc
+ac_cpp='$CXXCPP $CPPFLAGS'
+ac_compile='$CXX -c $CXXFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CXX -o conftest$ac_exeext $CXXFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_cxx_compiler_gnu
+archive_cmds_need_lc_CXX=no
+allow_undefined_flag_CXX=
+always_export_symbols_CXX=no
+archive_expsym_cmds_CXX=
+export_dynamic_flag_spec_CXX=
+hardcode_direct_CXX=no
+hardcode_libdir_flag_spec_CXX=
+hardcode_libdir_flag_spec_ld_CXX=
+hardcode_libdir_separator_CXX=
+hardcode_minus_L_CXX=no
+hardcode_shlibpath_var_CXX=unsupported
+hardcode_automatic_CXX=no
+module_cmds_CXX=
+module_expsym_cmds_CXX=
+link_all_deplibs_CXX=unknown
+old_archive_cmds_CXX=$old_archive_cmds
+no_undefined_flag_CXX=
+whole_archive_flag_spec_CXX=
+enable_shared_with_static_runtimes_CXX=no
+# Dependencies to place before and after the object being linked:
+predep_objects_CXX=
+postdep_objects_CXX=
+predeps_CXX=
+postdeps_CXX=
+compiler_lib_search_path_CXX=
+# Source file extension for C++ test sources.
+ac_ext=cpp
+# Object file extension for compiled C++ test sources.
+objext=o
+objext_CXX=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="int some_variable = 0;\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='int main(int, char *[]) { return(0); }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC=$CC
+lt_save_LD=$LD
+lt_save_GCC=$GCC
+GCC=$GXX
+lt_save_with_gnu_ld=$with_gnu_ld
+lt_save_path_LD=$lt_cv_path_LD
+if test -n "${lt_cv_prog_gnu_ldcxx+set}"; then
+  lt_cv_prog_gnu_ld=$lt_cv_prog_gnu_ldcxx
+else
+  $as_unset lt_cv_prog_gnu_ld
+fi
+if test -n "${lt_cv_path_LDCXX+set}"; then
+  lt_cv_path_LD=$lt_cv_path_LDCXX
+else
+  $as_unset lt_cv_path_LD
+fi
+test -z "${LDCXX+set}" || LD=$LDCXX
+CC=${CXX-"c++"}
+compiler=$CC
+compiler_CXX=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# We don't want -fno-exception wen compiling C++ code, so set the
+# no_builtin_flag separately
+if test "$GXX" = yes; then
+  lt_prog_compiler_no_builtin_flag_CXX=' -fno-builtin'
+else
+fi
+  # Set up default GNU C++ configuration
+# Check whether --with-gnu-ld or --without-gnu-ld was given.
+if test "${with_gnu_ld+set}" = set; then
+  withval="$with_gnu_ld"
+  test "$withval" = no || with_gnu_ld=yes
+else
+  with_gnu_ld=no
+fi;
+ac_prog=ld
+  # Check if gcc -print-prog-name=ld gives a path.
+  echo "$as_me:$LINENO: checking for ld used by $CC" >&5
+echo $ECHO_N "checking for ld used by $CC... $ECHO_C" >&6
+  case $host in
+  *-*-mingw*)
+    # gcc leaves a trailing carriage return which upsets mingw
+    ac_prog=`($CC -print-prog-name=ld) 2>&5 | tr -d '\015'` ;;
+    ac_prog=`($CC -print-prog-name=ld) 2>&5` ;;
+  esac
+  case $ac_prog in
+    # Accept absolute paths.
+      re_direlt='/[^/][^/]*/\.\./'
+      # Canonicalize the pathname of ld
+      ac_prog=`echo $ac_prog| $SED 's%\\\\%/%g'`
+      while echo $ac_prog | grep "$re_direlt" > /dev/null 2>&1; do
+	ac_prog=`echo $ac_prog| $SED "s%$re_direlt%/%"`
+      done
+      test -z "$LD" && LD="$ac_prog"
+    # If it fails, then pretend we aren't using GCC.
+    ac_prog=ld
+    # If it is relative, then search for the first ld in PATH.
+    with_gnu_ld=unknown
+  esac
+elif test "$with_gnu_ld" = yes; then
+  echo "$as_me:$LINENO: checking for GNU ld" >&5
+echo $ECHO_N "checking for GNU ld... $ECHO_C" >&6
+else
+  echo "$as_me:$LINENO: checking for non-GNU ld" >&5
+echo $ECHO_N "checking for non-GNU ld... $ECHO_C" >&6
+fi
+if test "${lt_cv_path_LD+set}" = set; then
+else
+  if test -z "$LD"; then
+  lt_save_ifs="$IFS"; IFS=$PATH_SEPARATOR
+  for ac_dir in $PATH; do
+    test -z "$ac_dir" && ac_dir=.
+    if test -f "$ac_dir/$ac_prog" || test -f "$ac_dir/$ac_prog$ac_exeext"; then
+      lt_cv_path_LD="$ac_dir/$ac_prog"
+      # Check to see if the program is GNU ld.  I'd rather use --version,
+      # but apparently some variants of GNU ld only accept -v.
+      # Break only if it was the GNU/non-GNU ld that we prefer.
+      case `"$lt_cv_path_LD" -v 2>&1 </dev/null` in
+      *GNU* | *'with BFD'*)
+	test "$with_gnu_ld" != no && break
+	test "$with_gnu_ld" != yes && break
+      esac
+    fi
+  done
+else
+  lt_cv_path_LD="$LD" # Let the user override the test with a path.
+fi
+fi
+LD="$lt_cv_path_LD"
+if test -n "$LD"; then
+  echo "$as_me:$LINENO: result: $LD" >&5
+echo "${ECHO_T}$LD" >&6
+else
+fi
+test -z "$LD" && { { echo "$as_me:$LINENO: error: no acceptable ld found in \$PATH" >&5
+echo "$as_me: error: no acceptable ld found in \$PATH" >&2;}
+echo "$as_me:$LINENO: checking if the linker ($LD) is GNU ld" >&5
+echo $ECHO_N "checking if the linker ($LD) is GNU ld... $ECHO_C" >&6
+if test "${lt_cv_prog_gnu_ld+set}" = set; then
+else
+  # I'd rather use --version here, but apparently some GNU lds only accept -v.
+case `$LD -v 2>&1 </dev/null` in
+*GNU* | *'with BFD'*)
+  lt_cv_prog_gnu_ld=yes
+  lt_cv_prog_gnu_ld=no
+esac
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_gnu_ld" >&5
+echo "${ECHO_T}$lt_cv_prog_gnu_ld" >&6
+with_gnu_ld=$lt_cv_prog_gnu_ld
+  # Check if GNU C++ uses GNU ld as the underlying linker, since the
+  # archiving commands below assume that GNU ld is being used.
+  if test "$with_gnu_ld" = yes; then
+    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    archive_expsym_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+    hardcode_libdir_flag_spec_CXX='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_CXX='${wl}--export-dynamic'
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    # XXX I think wlarc can be eliminated in ltcf-cxx, but I need to
+    #     investigate it a little bit more. (MM)
+    wlarc='${wl}'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if eval "`$CC -print-prog-name=ld` --help 2>&1" | \
+	grep 'no-whole-archive' > /dev/null; then
+      whole_archive_flag_spec_CXX="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+    else
+    fi
+  else
+    with_gnu_ld=no
+    wlarc=
+    # A generic and very simple default shared library creation
+    # command for GNU C++ for the case where it uses the native
+    # linker, instead of GNU ld.  If possible, this setting should
+    # overridden to take advantage of the native linker features on
+    # the platform it is being used on.
+    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+  fi
+  # Commands to make compiler produce verbose output that lists
+  # what "hidden" libraries, object files and flags are used when
+  # linking a shared library.
+  output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "\-L"'
+else
+  GXX=no
+  with_gnu_ld=no
+  wlarc=
+fi
+# PORTME: fill in a description of your system's C++ link characteristics
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+ld_shlibs_CXX=yes
+case $host_os in
+  aix3*)
+    # FIXME: insert proper C++ library support
+    ld_shlibs_CXX=no
+  aix4* | aix5*)
+    if test "$host_cpu" = ia64; then
+      # On IA64, the linker does run time linking by default, so we don't
+      # have to do anything special.
+      aix_use_runtimelinking=no
+      exp_sym_flag='-Bexport'
+      no_entry_flag=""
+    else
+      # Test if we are trying to use run time linking or normal
+      # AIX style linking. If -brtl is somewhere in LDFLAGS, we
+      # need to do runtime linking.
+      case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	for ld_flag in $LDFLAGS; do
+	  case $ld_flag in
+	  *-brtl*)
+	    aix_use_runtimelinking=yes
+	    break
+	  esac
+	done
+      esac
+      exp_sym_flag='-bexport'
+      no_entry_flag='-bnoentry'
+    fi
+    # When large executables or shared objects are built, AIX ld can
+    # have problems creating the table of contents.  If linking a library
+    # or program results in "error TOC overflow" add -mminimal-toc to
+    # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+    # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+    archive_cmds_CXX=''
+    hardcode_direct_CXX=yes
+    hardcode_libdir_separator_CXX=':'
+    link_all_deplibs_CXX=yes
+    if test "$GXX" = yes; then
+      case $host_os in aix4.[012]|aix4.[012].*)
+      # We only want to do this on AIX 4.2 and lower, the check
+      # below for broken collect2 doesn't work under 4.3+
+	collect2name=`${CC} -print-prog-name=collect2`
+	if test -f "$collect2name" && \
+	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	then
+	  # We have reworked collect2
+	else
+	  # We have old collect2
+	  hardcode_direct_CXX=unsupported
+	  # It fails to find uninstalled libraries when the uninstalled
+	  # path is not listed in the libpath.  Setting hardcode_minus_L
+	  # to unsupported forces relinking
+	  hardcode_minus_L_CXX=yes
+	  hardcode_libdir_flag_spec_CXX='-L$libdir'
+	fi
+      esac
+      shared_flag='-shared'
+      if test "$aix_use_runtimelinking" = yes; then
+	shared_flag="$shared_flag "'${wl}-G'
+      fi
+    else
+      # not using gcc
+	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+	# chokes on -Wl,-G. The following line is correct:
+	shared_flag='-G'
+      else
+	  shared_flag='${wl}-G'
+	else
+	  shared_flag='${wl}-bM:SRE'
+	fi
+      fi
+    fi
+    # It seems that -bexpall does not export symbols beginning with
+    # underscore (_), so it is better to generate a list of symbols to export.
+    always_export_symbols_CXX=yes
+      # Warning - without using the other runtime loading flags (-brtl),
+      # -berok will link without error, but may produce a broken library.
+      allow_undefined_flag_CXX='-berok'
+      # Determine the default libpath from the value encoded in an empty executable.
+      cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+	 { ac_try='test -z "$ac_cxx_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+      hardcode_libdir_flag_spec_CXX='${wl}-blibpath:$libdir:'"$aix_libpath"
+      archive_expsym_cmds_CXX="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+     else
+	hardcode_libdir_flag_spec_CXX='${wl}-R $libdir:/usr/lib:/lib'
+	allow_undefined_flag_CXX="-z nodefs"
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+      else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	# Warning - without using the other run time loading flags,
+	no_undefined_flag_CXX=' ${wl}-bernotok'
+	allow_undefined_flag_CXX=' ${wl}-berok'
+	# Exported symbols can be pulled into shared objects from archives
+	whole_archive_flag_spec_CXX='$convenience'
+	archive_cmds_need_lc_CXX=yes
+	# This is similar to how AIX traditionally builds its shared libraries.
+	archive_expsym_cmds_CXX="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+      fi
+    fi
+  beos*)
+    if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      allow_undefined_flag_CXX=unsupported
+      # Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+      # support --undefined.  This deserves some investigation.  FIXME
+      archive_cmds_CXX='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
+  chorus*)
+    case $cc_basename in
+	ld_shlibs_CXX=no
+    esac
+  cygwin* | mingw* | pw32*)
+    # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, CXX) is actually meaningless,
+    # as there is no search path for DLLs.
+    always_export_symbols_CXX=no
+    enable_shared_with_static_runtimes_CXX=yes
+    if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+      archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      # If the export-symbols file already is a .def file (1st line
+      # is EXPORTS), use it as is; otherwise, prepend...
+      archive_expsym_cmds_CXX='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	cp $export_symbols $output_objdir/$soname.def;
+      else
+	echo EXPORTS > $output_objdir/$soname.def;
+	cat $export_symbols >> $output_objdir/$soname.def;
+      fi~
+      $CC -shared -nostdlib $output_objdir/$soname.def $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+    else
+      ld_shlibs_CXX=no
+    fi
+      darwin* | rhapsody*)
+        case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_CXX='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_CXX='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_CXX='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+        esac
+      archive_cmds_need_lc_CXX=no
+      hardcode_direct_CXX=no
+      hardcode_automatic_CXX=yes
+      hardcode_shlibpath_var_CXX=unsupported
+      whole_archive_flag_spec_CXX=''
+    if test "$GXX" = yes ; then
+      lt_int_apple_cc_single_mod=no
+      output_verbose_link_cmd='echo'
+      if $CC -dumpspecs 2>&1 | $EGREP 'single_module' >/dev/null ; then
+       lt_int_apple_cc_single_mod=yes
+      fi
+      if test "X$lt_int_apple_cc_single_mod" = Xyes ; then
+       archive_cmds_CXX='$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      else
+          archive_cmds_CXX='$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+        fi
+        module_cmds_CXX='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+        # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+            archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib -single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+          else
+            archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -r -keep_private_externs -nostdlib -o ${lib}-master.o $libobjs~$CC -dynamiclib $allow_undefined_flag -o $lib ${lib}-master.o $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+          fi
+            module_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      else
+        xlc*)
+          archive_cmds_CXX='$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+          archive_expsym_cmds_CXX='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj ${wl}-single_module $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_CXX=no
+      esac
+      fi
+  dgux*)
+      ec++*)
+	ld_shlibs_CXX=no
+      ghcx*)
+	# Green Hills C++ Compiler
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  freebsd[12]*)
+    # C++ shared libraries reported to be fairly broken before switch to ELF
+    ld_shlibs_CXX=no
+  freebsd-elf*)
+  freebsd* | kfreebsd*-gnu | dragonfly*)
+    # FreeBSD 3 and later use GNU C++ and GNU ld with standard ELF
+    # conventions
+    ld_shlibs_CXX=yes
+  gnu*)
+  hpux9*)
+    hardcode_libdir_flag_spec_CXX='${wl}+b ${wl}$libdir'
+    hardcode_libdir_separator_CXX=:
+    export_dynamic_flag_spec_CXX='${wl}-E'
+    hardcode_minus_L_CXX=yes # Not in the search PATH,
+				# but as the default
+				# location of the library.
+    CC*)
+      ld_shlibs_CXX=no
+    aCC*)
+      archive_cmds_CXX='$rm $output_objdir/$soname~$CC -b ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      # There doesn't appear to be a way to prevent this compiler from
+      # explicitly linking system object files so we need to strip them
+      # from the output so that they don't get included in the library
+      # dependencies.
+      output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "[-]L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+        archive_cmds_CXX='$rm $output_objdir/$soname~$CC -shared -nostdlib -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+        ld_shlibs_CXX=no
+      fi
+    esac
+  hpux10*|hpux11*)
+    if test $with_gnu_ld = no; then
+      case $host_cpu in
+      hppa*64*|ia64*)
+	hardcode_libdir_flag_spec_ld_CXX='+b $libdir'
+      esac
+    fi
+    case $host_cpu in
+    hppa*64*|ia64*)
+      hardcode_shlibpath_var_CXX=no
+    esac
+      CC*)
+	ld_shlibs_CXX=no
+      aCC*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	ia64*)
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	  archive_cmds_CXX='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	esac
+	# dependencies.
+	output_verbose_link_cmd='templist=`($CC -b $CFLAGS -v conftest.$objext 2>&1) | grep "\-L"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	    case $host_cpu in
+	    hppa*64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    ia64*)
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	      archive_cmds_CXX='$CC -shared -nostdlib -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	    esac
+	  fi
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  interix3*)
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath,$libdir'
+    # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+    # Instead, shared libraries are loaded at an image base (0x10000000 by
+    # default) and relocated if they conflict, which is a slow very memory
+    # consuming and fragmenting process.  To avoid this, we pick a random,
+    # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+    # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+    archive_cmds_CXX='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    archive_expsym_cmds_CXX='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+  irix5* | irix6*)
+      CC*)
+	# SGI C++
+	archive_cmds_CXX='$CC -shared -all -multigot $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	# Archives containing C++ object files must be created using
+	# "CC -ar", where "CC" is the IRIX C++ compiler.  This is
+	# necessary to make sure instantiated templates are included
+	# in the archive.
+	old_archive_cmds_CXX='$CC -ar -WR,-u -o $oldlib $oldobjs'
+	  if test "$with_gnu_ld" = no; then
+	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	  else
+	    archive_cmds_CXX='$CC -shared -nostdlib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` -o $lib'
+	  fi
+	fi
+    esac
+    hardcode_libdir_flag_spec_CXX='${wl}-rpath ${wl}$libdir'
+  linux*)
+      KCC*)
+	# Kuck and Associates, Inc. (KAI) C++ Compiler
+	# KCC will only create a shared library if the output file
+	# ends with ".so" (or ".sl" for HP-UX), so rename the library
+	# to its proper name (with version) after linking.
+	archive_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib; mv \$templib $lib'
+	archive_expsym_cmds_CXX='tempext=`echo $shared_ext | $SED -e '\''s/\([^()0-9A-Za-z{}]\)/\\\\\1/g'\''`; templib=`echo $lib | $SED -e "s/\${tempext}\..*/.so/"`; $CC $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags --soname $soname -o \$templib ${wl}-retain-symbols-file,$export_symbols; mv \$templib $lib'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC $CFLAGS -v conftest.$objext -o libconftest$shared_ext 2>&1 | grep "ld"`; rm -f libconftest$shared_ext; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	hardcode_libdir_flag_spec_CXX='${wl}--rpath,$libdir'
+	# "CC -Bstatic", where "CC" is the KAI C++ compiler.
+	old_archive_cmds_CXX='$CC -Bstatic -o $oldlib $oldobjs'
+      icpc*)
+	# Intel C++
+	with_gnu_ld=yes
+	# version 8.0 and above of icpc choke on multiply defined symbols
+	# if we add $predep_objects and $postdep_objects, however 7.1 and
+	# earlier do not add the objects themselves.
+	case `$CC -V 2>&1` in
+	*"Version 7."*)
+  	  archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname -o $lib'
+  	  archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+	*)  # Version 8.0 or newer
+	  tmp_idyn=
+	  case $host_cpu in
+	    ia64*) tmp_idyn=' -i_dynamic';;
+	  esac
+  	  archive_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	  archive_expsym_cmds_CXX='$CC -shared'"$tmp_idyn"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+	esac
+	whole_archive_flag_spec_CXX='${wl}--whole-archive$convenience ${wl}--no-whole-archive'
+      pgCC*)
+        # Portland Group C++ compiler
+	archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname -o $lib'
+  	archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname ${wl}-retain-symbols-file ${wl}$export_symbols -o $lib'
+	whole_archive_flag_spec_CXX='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+      cxx*)
+	# Compaq C++
+	archive_expsym_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $wl$soname  -o $lib ${wl}-retain-symbols-file $wl$export_symbols'
+	runpath_var=LD_RUN_PATH
+	hardcode_libdir_flag_spec_CXX='-rpath $libdir'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld .*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+    esac
+  lynxos*)
+    ld_shlibs_CXX=no
+  m88k*)
+    ld_shlibs_CXX=no
+  mvs*)
+      cxx*)
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  netbsd*)
+    if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+      archive_cmds_CXX='$LD -Bshareable  -o $lib $predep_objects $libobjs $deplibs $postdep_objects $linker_flags'
+      wlarc=
+      hardcode_libdir_flag_spec_CXX='-R$libdir'
+    fi
+    # Workaround some broken pre-1.5 toolchains
+    output_verbose_link_cmd='$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep conftest.$objext | $SED -e "s:-lgcc -lc -lgcc::"'
+  openbsd2*)
+    # C++ shared libraries are fairly broken
+    ld_shlibs_CXX=no
+  openbsd*)
+    archive_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -o $lib'
+    if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+      archive_expsym_cmds_CXX='$CC -shared $pic_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-retain-symbols-file,$export_symbols -o $lib'
+    fi
+  osf3*)
+      KCC*)
+      RCC*)
+	# Rational C++ 2.4.1
+	ld_shlibs_CXX=no
+      cxx*)
+	allow_undefined_flag_CXX=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname $soname `test -n "$verstring" && echo ${wl}-set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	# dependencies.
+	output_verbose_link_cmd='templist=`$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep "ld" | grep -v "ld:"`; templist=`echo $templist | $SED "s/\(^.*ld.*\)\( .*ld.*$\)/\1/"`; list=""; for z in $templist; do case $z in conftest.$objext) list="$list $z";; *.$objext);; *) list="$list $z";;esac; done; echo $list'
+	if test "$GXX" = yes && test "$with_gnu_ld" = no; then
+	  archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  osf4* | osf5*)
+      KCC*)
+	# the KAI C++ compiler.
+	old_archive_cmds_CXX='$CC -o $oldlib $oldobjs'
+      RCC*)
+	ld_shlibs_CXX=no
+      cxx*)
+	allow_undefined_flag_CXX=' -expect_unresolved \*'
+	archive_cmds_CXX='$CC -shared${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_CXX='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done~
+	  echo "-hidden">> $lib.exp~
+	  $CC -shared$allow_undefined_flag $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags -msym -soname $soname -Wl,-input -Wl,$lib.exp  `test -n "$verstring" && echo -set_version	$verstring` -update_registry ${output_objdir}/so_locations -o $lib~
+	  $rm $lib.exp'
+	# dependencies.
+	 archive_cmds_CXX='$CC -shared -nostdlib ${allow_undefined_flag} $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+	else
+	  ld_shlibs_CXX=no
+	fi
+    esac
+  psos*)
+    ld_shlibs_CXX=no
+  sunos4*)
+      CC*)
+	# Sun C++ 4.x
+	ld_shlibs_CXX=no
+      lcc*)
+	# Lucid
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  solaris*)
+      CC*)
+	# Sun C++ 4.2, 5.x and Centerline C++
+	no_undefined_flag_CXX=' -zdefs'
+	archive_cmds_CXX='$CC -G${allow_undefined_flag}  -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags'
+	archive_expsym_cmds_CXX='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	$CC -G${allow_undefined_flag}  ${wl}-M ${wl}$lib.exp -h$soname -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	case $host_os in
+	  solaris2.[0-5] | solaris2.[0-5].*) ;;
+	    # The C++ compiler is used as linker so we must use $wl
+	    # flag to pass the commands to the underlying system
+	    # linker. We must also pass each convience library through
+	    # to the system linker between allextract/defaultextract.
+	    # The C++ compiler will combine linker options so we
+	    # cannot just pass the convience library names through
+	    # without $wl.
+	    # Supported since Solaris 2.6 (maybe 2.5.1?)
+	    whole_archive_flag_spec_CXX='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract'
+	esac
+	# "CC -xar", where "CC" is the Sun C++ compiler.  This is
+	# in the archive.
+	old_archive_cmds_CXX='$CC -xar -o $oldlib $oldobjs'
+      gcx*)
+	archive_cmds_CXX='$CC -shared $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+	# The C++ compiler must be used to create the archive.
+	old_archive_cmds_CXX='$CC $LDFLAGS -archive -o $oldlib $oldobjs'
+	# GNU C++ compiler with Solaris linker
+	  no_undefined_flag_CXX=' ${wl}-z ${wl}defs'
+	  if $CC --version | grep -v '^2\.7' > /dev/null; then
+	    archive_cmds_CXX='$CC -shared -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+		$CC -shared -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	    output_verbose_link_cmd="$CC -shared $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+	  else
+	    # g++ 2.7 appears to require `-G' NOT `-shared' on this
+	    # platform.
+	    archive_cmds_CXX='$CC -G -nostdlib $LDFLAGS $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags ${wl}-h $wl$soname -o $lib'
+		$CC -G -nostdlib ${wl}-M $wl$lib.exp -o $lib $predep_objects $libobjs $deplibs $postdep_objects $compiler_flags~$rm $lib.exp'
+	    output_verbose_link_cmd="$CC -G $CFLAGS -v conftest.$objext 2>&1 | grep \"\-L\""
+	  fi
+	  hardcode_libdir_flag_spec_CXX='${wl}-R $wl$libdir'
+	fi
+    esac
+  sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7* | sco3.2v5.0.[024]*)
+    no_undefined_flag_CXX='${wl}-z,text'
+    runpath_var='LD_RUN_PATH'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+  sysv5* | sco3.2v5* | sco5v6*)
+    # Note: We can NOT use -z defs as we might desire, because we do not
+    # link with -lc, and that would cause any symbols used from libc to
+    # always be unresolved, which means just about no library would
+    # ever link correctly.  If we're not using GNU ld we use -z text
+    # though, which does catch some bad symbols but isn't as heavy-handed
+    # as -z defs.
+    # For security reasons, it is highly recommended that you always
+    # use absolute paths for naming shared libraries, and exclude the
+    # DT_RUNPATH tag from executables and libraries.  But doing so
+    # requires that you compile everything twice, which is a pain.
+    # So that behaviour is only enabled if SCOABSPATH is set to a
+    # non-empty value in the environment.  Most likely only useful for
+    # creating official distributions of packages.
+    # This is a hack until libtool officially supports absolute path
+    # names for shared libraries.
+    allow_undefined_flag_CXX='${wl}-z,nodefs'
+    hardcode_libdir_flag_spec_CXX='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+    export_dynamic_flag_spec_CXX='${wl}-Bexport'
+      CC*)
+	archive_cmds_CXX='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_cmds_CXX='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_CXX='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+    esac
+  tandem*)
+      NCC*)
+	# NonStop-UX NCC 3.20
+	ld_shlibs_CXX=no
+	ld_shlibs_CXX=no
+    esac
+  vxworks*)
+    ld_shlibs_CXX=no
+    ld_shlibs_CXX=no
+esac
+echo "$as_me:$LINENO: result: $ld_shlibs_CXX" >&5
+echo "${ECHO_T}$ld_shlibs_CXX" >&6
+test "$ld_shlibs_CXX" = no && can_build_shared=no
+GCC_CXX="$GXX"
+LD_CXX="$LD"
+cat > conftest.$ac_ext <<EOF
+class Foo
+public:
+  Foo (void) { a = 0; }
+private:
+  int a;
+EOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; then
+  # Parse the compiler output and extract the necessary
+  # objects, libraries and library flags.
+  # Sentinel used to keep track of whether or not we are before
+  # the conftest object file.
+  pre_test_object_deps_done=no
+  # The `*' in the case matches for architectures that use `case' in
+  # $output_verbose_cmd can trigger glob expansion during the loop
+  # eval without this substitution.
+  output_verbose_link_cmd=`$echo "X$output_verbose_link_cmd" | $Xsed -e "$no_glob_subst"`
+  for p in `eval $output_verbose_link_cmd`; do
+    case $p in
+    -L* | -R* | -l*)
+       # Some compilers place space between "-{L,R}" and the path.
+       # Remove the space.
+       if test $p = "-L" \
+	  || test $p = "-R"; then
+	 prev=$p
+	 continue
+       else
+	 prev=
+       fi
+       if test "$pre_test_object_deps_done" = no; then
+	 case $p in
+	 -L* | -R*)
+	   # Internal compiler library paths should come after those
+	   # provided the user.  The postdeps already come after the
+	   # user supplied libs so there is no need to process them.
+	   if test -z "$compiler_lib_search_path_CXX"; then
+	     compiler_lib_search_path_CXX="${prev}${p}"
+	   else
+	     compiler_lib_search_path_CXX="${compiler_lib_search_path_CXX} ${prev}${p}"
+	   fi
+	 # The "-l" case would never come before the object being
+	 # linked, so don't bother handling this case.
+	 esac
+       else
+	 if test -z "$postdeps_CXX"; then
+	   postdeps_CXX="${prev}${p}"
+	 else
+	   postdeps_CXX="${postdeps_CXX} ${prev}${p}"
+	 fi
+       fi
+    *.$objext)
+       # This assumes that the test object file only shows up
+       # once in the compiler output.
+       if test "$p" = "conftest.$objext"; then
+	 pre_test_object_deps_done=yes
+	 continue
+       fi
+	 if test -z "$predep_objects_CXX"; then
+	   predep_objects_CXX="$p"
+	 else
+	   predep_objects_CXX="$predep_objects_CXX $p"
+	 fi
+       else
+	 if test -z "$postdep_objects_CXX"; then
+	   postdep_objects_CXX="$p"
+	 else
+	   postdep_objects_CXX="$postdep_objects_CXX $p"
+	 fi
+       fi
+    *) ;; # Ignore the rest.
+    esac
+  done
+  # Clean up.
+  rm -f a.out a.exe
+else
+  echo "libtool.m4: error: problem compiling CXX test program"
+fi
+$rm -f confest.$objext
+# PORTME: override above test on systems where it is broken
+case $host_os in
+interix3*)
+  # Interix 3.5 installs completely hosed .la files for C++, so rather than
+  # hack all around it, let's just trust "g++" to DTRT.
+  postdeps_CXX=
+solaris*)
+  CC*)
+    # Adding this requires a known-good setup of shared libraries for
+    # Sun compiler versions before 5.6, else PIC objects from an old
+    # archive will be linked into the output, leading to subtle bugs.
+    postdeps_CXX='-lCstd -lCrun'
+  esac
+esac
+case " $postdeps_CXX " in
+*" -lc "*) archive_cmds_need_lc_CXX=no ;;
+esac
+lt_prog_compiler_wl_CXX=
+lt_prog_compiler_pic_CXX=
+lt_prog_compiler_static_CXX=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+  # C++ specific cases for pic, static, wl, etc.
+    lt_prog_compiler_wl_CXX='-Wl,'
+    lt_prog_compiler_static_CXX='-static'
+    case $host_os in
+    aix*)
+      # All AIX code is PIC.
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static_CXX='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic_CXX='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | os2* | pw32*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic_CXX='-DDLL_EXPORT'
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic_CXX='-fno-common'
+    *djgpp*)
+      # DJGPP does not support shared libraries at all
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	lt_prog_compiler_pic_CXX=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	lt_prog_compiler_pic_CXX='-fPIC'
+      esac
+    esac
+  else
+    case $host_os in
+      aix4* | aix5*)
+	else
+	  lt_prog_compiler_static_CXX='-bnso -bI:/lib/syscalls.exp'
+	fi
+      chorus*)
+	cxch68*)
+	  # _LT_AC_TAGVAR(lt_prog_compiler_static, CXX)="--no_auto_instantiation -u __main -u __premain -u _abort -r $COOL_DIR/lib/libOrb.a $MVME_DIR/lib/CC/libC.a $MVME_DIR/lib/classix/libcx.s.a"
+	esac
+       darwin*)
+           xlc*)
+           lt_prog_compiler_pic_CXX='-qnocommon'
+         esac
+      dgux*)
+	  ec++*)
+	    lt_prog_compiler_pic_CXX='-KPIC'
+	  ghcx*)
+	    lt_prog_compiler_pic_CXX='-pic'
+	esac
+	# FreeBSD uses GNU C++
+      hpux9* | hpux10* | hpux11*)
+	  CC*)
+	    lt_prog_compiler_static_CXX='${wl}-a ${wl}archive'
+	    if test "$host_cpu" != ia64; then
+	      lt_prog_compiler_pic_CXX='+Z'
+	    fi
+	  aCC*)
+	    case $host_cpu in
+	    hppa*64*|ia64*)
+	      # +Z the default
+	    esac
+	esac
+      interix*)
+	# This is c89, which is MS Visual C++ (no shared libs)
+	# Anyone wants to do a port?
+      irix5* | irix6* | nonstopux*)
+	  CC*)
+	    lt_prog_compiler_static_CXX='-non_shared'
+	    # CC pic flag -KPIC is the default.
+	esac
+      linux*)
+	  KCC*)
+	    # KAI C++ Compiler
+	    lt_prog_compiler_wl_CXX='--backend -Wl,'
+	  icpc* | ecpc*)
+	    # Intel C++
+	  pgCC*)
+	    # Portland Group C++ compiler.
+	    lt_prog_compiler_pic_CXX='-fpic'
+	  cxx*)
+	    # Compaq C++
+	    # Make sure the PIC flag is empty.  It appears that all Alpha
+	    # Linux and Compaq Tru64 Unix objects are PIC.
+	esac
+      lynxos*)
+      m88k*)
+      mvs*)
+	  cxx*)
+	    lt_prog_compiler_pic_CXX='-W c,exportall'
+	esac
+      netbsd*)
+      osf3* | osf4* | osf5*)
+	  KCC*)
+	  RCC*)
+	  cxx*)
+	    # Digital/Compaq C++
+	esac
+      psos*)
+      solaris*)
+	  CC*)
+	    lt_prog_compiler_wl_CXX='-Qoption ld '
+	  gcx*)
+	    lt_prog_compiler_pic_CXX='-PIC'
+	esac
+      sunos4*)
+	  CC*)
+	    # Sun C++ 4.x
+	  lcc*)
+	    # Lucid
+	esac
+      tandem*)
+	  NCC*)
+	esac
+      sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+	  CC*)
+	esac
+      vxworks*)
+	lt_prog_compiler_can_build_shared_CXX=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_CXX" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic_CXX"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_CXX works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_CXX+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_prog_compiler_pic_works_CXX=no
+  ac_outfile=conftest.$ac_objext
+   printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+   lt_compiler_flag="$lt_prog_compiler_pic_CXX -DPIC"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:11637: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:11641: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_prog_compiler_pic_works_CXX=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_CXX" >&6
+if test x"$lt_prog_compiler_pic_works_CXX" = xyes; then
+    case $lt_prog_compiler_pic_CXX in
+     *) lt_prog_compiler_pic_CXX=" $lt_prog_compiler_pic_CXX" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic_CXX="$lt_prog_compiler_pic_CXX -DPIC"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl_CXX eval lt_tmp_static_flag=\"$lt_prog_compiler_static_CXX\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_CXX+set}" = set; then
+else
+  lt_prog_compiler_static_works_CXX=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       cat conftest.err 1>&5
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_CXX=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_CXX" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_CXX" >&6
+if test x"$lt_prog_compiler_static_works_CXX" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_CXX+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_CXX=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:11741: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:11745: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o_CXX=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_CXX" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_CXX" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_CXX" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+  export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  case $host_os in
+  aix4* | aix5*)
+    # If we're using GNU nm, then we don't want the "-C" option.
+    # -C means demangle to AIX nm, but means don't demangle with GNU nm
+    if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+      export_symbols_cmds_CXX='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+    else
+      export_symbols_cmds_CXX='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+    fi
+  pw32*)
+    export_symbols_cmds_CXX="$ltdll_cmds"
+  cygwin* | mingw*)
+    export_symbols_cmds_CXX='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/;/^.* __nm__/s/^.* __nm__\([^ ]*\) [^ ]*/\1 DATA/;/^I /d;/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+  esac
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_CXX" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_CXX in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_CXX
+	pic_flag=$lt_prog_compiler_pic_CXX
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_CXX
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_CXX 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_CXX=$lt_save_allow_undefined_flag
+      else
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_CXX" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_CXX" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+  if test "$GCC" = yes; then
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_CXX=
+if test -n "$hardcode_libdir_flag_spec_CXX" || \
+   test -n "$runpath_var_CXX" || \
+   test "X$hardcode_automatic_CXX" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_CXX" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, CXX)" != no &&
+     test "$hardcode_minus_L_CXX" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_CXX=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_CXX=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_CXX=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_CXX" >&5
+echo "${ECHO_T}$hardcode_action_CXX" >&6
+if test "$hardcode_action_CXX" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_CXX \
+    CC_CXX \
+    LD_CXX \
+    lt_prog_compiler_wl_CXX \
+    lt_prog_compiler_pic_CXX \
+    lt_prog_compiler_static_CXX \
+    lt_prog_compiler_no_builtin_flag_CXX \
+    export_dynamic_flag_spec_CXX \
+    thread_safe_flag_spec_CXX \
+    whole_archive_flag_spec_CXX \
+    enable_shared_with_static_runtimes_CXX \
+    old_archive_cmds_CXX \
+    old_archive_from_new_cmds_CXX \
+    predep_objects_CXX \
+    postdep_objects_CXX \
+    predeps_CXX \
+    postdeps_CXX \
+    compiler_lib_search_path_CXX \
+    archive_cmds_CXX \
+    archive_expsym_cmds_CXX \
+    postinstall_cmds_CXX \
+    postuninstall_cmds_CXX \
+    old_archive_from_expsyms_cmds_CXX \
+    allow_undefined_flag_CXX \
+    no_undefined_flag_CXX \
+    export_symbols_cmds_CXX \
+    hardcode_libdir_flag_spec_CXX \
+    hardcode_libdir_flag_spec_ld_CXX \
+    hardcode_libdir_separator_CXX \
+    hardcode_automatic_CXX \
+    module_cmds_CXX \
+    module_expsym_cmds_CXX \
+    lt_cv_prog_compiler_c_o_CXX \
+    exclude_expsyms_CXX \
+    include_expsyms_CXX; do
+    case $var in
+    old_archive_cmds_CXX | \
+    old_archive_from_new_cmds_CXX | \
+    archive_cmds_CXX | \
+    archive_expsym_cmds_CXX | \
+    module_cmds_CXX | \
+    module_expsym_cmds_CXX | \
+    old_archive_from_expsyms_cmds_CXX | \
+    export_symbols_cmds_CXX | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_CXX
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_CXX
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_CXX
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_CXX
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_CXX
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_CXX
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_CXX
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_CXX
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_CXX
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_CXX
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_CXX
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_CXX
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_CXX
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_CXX
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_CXX
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_CXX
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_CXX
+archive_expsym_cmds=$lt_archive_expsym_cmds_CXX
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_CXX
+module_expsym_cmds=$lt_module_expsym_cmds_CXX
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_CXX
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_CXX
+# shared library.
+predeps=$lt_predeps_CXX
+# shared library.
+postdeps=$lt_postdeps_CXX
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_CXX
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_CXX
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_CXX
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_CXX
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_CXX
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_CXX
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_CXX
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_CXX
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_CXX
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_CXX
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_CXX
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_CXX
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_CXX"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_CXX
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_CXX
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_CXX
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_CXX
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC=$lt_save_CC
+LDCXX=$LD
+LD=$lt_save_LD
+GCC=$lt_save_GCC
+with_gnu_ldcxx=$with_gnu_ld
+with_gnu_ld=$lt_save_with_gnu_ld
+lt_cv_path_LDCXX=$lt_cv_path_LD
+lt_cv_path_LD=$lt_save_path_LD
+lt_cv_prog_gnu_ldcxx=$lt_cv_prog_gnu_ld
+lt_cv_prog_gnu_ld=$lt_save_with_gnu_ld
+	else
+	  tagname=""
+	fi
+      F77)
+	if test -n "$F77" && test "X$F77" != "Xno"; then
+ac_ext=f
+ac_compile='$F77 -c $FFLAGS conftest.$ac_ext >&5'
+ac_link='$F77 -o conftest$ac_exeext $FFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_f77_compiler_gnu
+archive_cmds_need_lc_F77=no
+allow_undefined_flag_F77=
+always_export_symbols_F77=no
+archive_expsym_cmds_F77=
+export_dynamic_flag_spec_F77=
+hardcode_direct_F77=no
+hardcode_libdir_flag_spec_F77=
+hardcode_libdir_flag_spec_ld_F77=
+hardcode_libdir_separator_F77=
+hardcode_minus_L_F77=no
+hardcode_automatic_F77=no
+module_cmds_F77=
+module_expsym_cmds_F77=
+link_all_deplibs_F77=unknown
+old_archive_cmds_F77=$old_archive_cmds
+no_undefined_flag_F77=
+whole_archive_flag_spec_F77=
+enable_shared_with_static_runtimes_F77=no
+# Source file extension for f77 test sources.
+ac_ext=f
+# Object file extension for compiled f77 test sources.
+objext=o
+objext_F77=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="      subroutine t\n      return\n      end\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code="      program t\n      end\n"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${F77-"f77"}
+compiler=$CC
+compiler_F77=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+echo "$as_me:$LINENO: checking if libtool supports shared libraries" >&5
+echo $ECHO_N "checking if libtool supports shared libraries... $ECHO_C" >&6
+echo "$as_me:$LINENO: result: $can_build_shared" >&5
+echo "${ECHO_T}$can_build_shared" >&6
+echo "$as_me:$LINENO: checking whether to build shared libraries" >&5
+echo $ECHO_N "checking whether to build shared libraries... $ECHO_C" >&6
+test "$can_build_shared" = "no" && enable_shared=no
+# On AIX, shared libraries and static libraries use the same namespace, and
+# are all built from PIC.
+case $host_os in
+aix3*)
+  test "$enable_shared" = yes && enable_static=no
+  if test -n "$RANLIB"; then
+    archive_cmds="$archive_cmds~\$RANLIB \$lib"
+    postinstall_cmds='$RANLIB $lib'
+  fi
+aix4* | aix5*)
+  if test "$host_cpu" != ia64 && test "$aix_use_runtimelinking" = no ; then
+  fi
+esac
+echo "$as_me:$LINENO: result: $enable_shared" >&5
+echo "${ECHO_T}$enable_shared" >&6
+echo "$as_me:$LINENO: checking whether to build static libraries" >&5
+echo $ECHO_N "checking whether to build static libraries... $ECHO_C" >&6
+# Make sure either enable_shared or enable_static is yes.
+test "$enable_shared" = yes || enable_static=yes
+echo "$as_me:$LINENO: result: $enable_static" >&5
+echo "${ECHO_T}$enable_static" >&6
+GCC_F77="$G77"
+LD_F77="$LD"
+lt_prog_compiler_wl_F77=
+lt_prog_compiler_pic_F77=
+lt_prog_compiler_static_F77=
+    lt_prog_compiler_wl_F77='-Wl,'
+    lt_prog_compiler_static_F77='-static'
+    case $host_os in
+      aix*)
+      if test "$host_cpu" = ia64; then
+	lt_prog_compiler_static_F77='-Bstatic'
+      fi
+    amigaos*)
+      # like `-m68040'.
+      lt_prog_compiler_pic_F77='-m68020 -resident32 -malways-restore-a4'
+    mingw* | pw32* | os2*)
+      lt_prog_compiler_pic_F77='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      lt_prog_compiler_pic_F77='-fno-common'
+    interix3*)
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared_F77=no
+      enable_shared=no
+    sysv4*MP*)
+	lt_prog_compiler_pic_F77=-Kconform_pic
+      fi
+    hpux*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_F77='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static_F77='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic_F77='-qnocommon'
+       esac
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_F77='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static_F77='${wl}-a ${wl}archive'
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static_F77='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic_F77='-KPIC'
+    linux*)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic_F77='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl_F77='-Qoption ld ';;
+	lt_prog_compiler_wl_F77='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic_F77='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+	lt_prog_compiler_pic_F77='-Kconform_pic'
+      fi
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic_F77='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_F77" >&6
+if test -n "$lt_prog_compiler_pic_F77"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_F77 works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_F77+set}" = set; then
+else
+  lt_prog_compiler_pic_works_F77=no
+   lt_compiler_flag="$lt_prog_compiler_pic_F77"
+   (eval echo "\"\$as_me:13311: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:13315: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works_F77=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_F77" >&6
+if test x"$lt_prog_compiler_pic_works_F77" = xyes; then
+    case $lt_prog_compiler_pic_F77 in
+     *) lt_prog_compiler_pic_F77=" $lt_prog_compiler_pic_F77" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  *djgpp*)
+    lt_prog_compiler_pic_F77="$lt_prog_compiler_pic_F77"
+esac
+wl=$lt_prog_compiler_wl_F77 eval lt_tmp_static_flag=\"$lt_prog_compiler_static_F77\"
+if test "${lt_prog_compiler_static_works_F77+set}" = set; then
+else
+  lt_prog_compiler_static_works_F77=no
+         lt_prog_compiler_static_works_F77=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_F77" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_F77" >&6
+if test x"$lt_prog_compiler_static_works_F77" = xyes; then
+else
+fi
+if test "${lt_cv_prog_compiler_c_o_F77+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_F77=no
+   mkdir conftest
+   cd conftest
+   mkdir out
+   (eval echo "\"\$as_me:13415: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:13419: \$? = $ac_status" >&5
+   then
+       lt_cv_prog_compiler_c_o_F77=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_F77" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_F77" >&6
+if test "$lt_cv_prog_compiler_c_o_F77" = no && test "$need_locks" != no; then
+  hard_links=yes
+  $rm conftest*
+  touch conftest.a
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag_F77=
+  enable_shared_with_static_runtimes_F77=no
+  archive_cmds_F77=
+  archive_expsym_cmds_F77=
+  old_archive_From_new_cmds_F77=
+  old_archive_from_expsyms_cmds_F77=
+  export_dynamic_flag_spec_F77=
+  whole_archive_flag_spec_F77=
+  thread_safe_flag_spec_F77=
+  hardcode_libdir_flag_spec_F77=
+  hardcode_libdir_flag_spec_ld_F77=
+  hardcode_libdir_separator_F77=
+  hardcode_direct_F77=no
+  hardcode_minus_L_F77=no
+  hardcode_shlibpath_var_F77=unsupported
+  link_all_deplibs_F77=unknown
+  hardcode_automatic_F77=no
+  module_cmds_F77=
+  module_expsym_cmds_F77=
+  always_export_symbols_F77=no
+  export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms_F77=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms_F77="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs_F77=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec_F77='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_F77='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec_F77="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+	ld_shlibs_F77=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds_F77='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec_F77='-L$libdir'
+      hardcode_minus_L_F77=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs_F77=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag_F77=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds_F77='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs_F77=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, F77) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes_F77=yes
+      export_symbols_cmds_F77='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds_F77='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs_F77=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var_F77=no
+      hardcode_libdir_flag_spec_F77='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_F77='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_F77='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_F77='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    linux*)
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec_F77='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds_F77='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds_F77='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+      else
+	ld_shlibs_F77=no
+      fi
+    netbsd*)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds_F77='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs_F77=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs_F77=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_F77=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_F77=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds_F77='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct_F77=yes
+      else
+	ld_shlibs_F77=no
+      fi
+    esac
+    if test "$ld_shlibs_F77" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols_F77=yes
+      archive_expsym_cmds_F77='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct_F77=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	  export_symbols_cmds_F77='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds_F77='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds_F77=''
+      hardcode_libdir_separator_F77=':'
+      link_all_deplibs_F77=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag_F77='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+      program main
+      end
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_f77_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec_F77='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds_F77="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec_F77='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag_F77="-z nodefs"
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+      program main
+      end
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag_F77=' ${wl}-bernotok'
+	  allow_undefined_flag_F77=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec_F77='$convenience'
+	  archive_cmds_need_lc_F77=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_F77="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs_F77=no
+    bsdi[45]*)
+      export_dynamic_flag_spec_F77=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec_F77=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds_F77='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds_F77='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds_F77='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path_F77='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_F77='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_F77='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_F77='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc_F77=no
+      hardcode_automatic_F77=yes
+      whole_archive_flag_spec_F77=''
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds_F77='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds_F77='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds_F77='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds_F77='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_F77=no
+      esac
+    fi
+    dgux*)
+      archive_cmds_F77='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs_F77=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec_F77='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | kfreebsd*-gnu | dragonfly*)
+      archive_cmds_F77='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds_F77='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds_F77='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec_F77='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_F77=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds_F77='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds_F77='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld_F77='+b $libdir'
+	esac
+      fi
+    irix5* | irix6* | nonstopux*)
+	archive_cmds_F77='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_F77='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld_F77='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec_F77='${wl}-rpath ${wl}$libdir'
+    netbsd*)
+	archive_cmds_F77='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds_F77='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds_F77='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds_F77='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag_F77=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag_F77=' -expect_unresolved \*'
+	archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds_F77='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_F77='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_F77='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec_F77='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag_F77=' -z text'
+	wlarc='${wl}'
+	archive_cmds_F77='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds_F77='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec_F77='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec_F77='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds_F77='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+	sni)
+	  hardcode_direct_F77=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds_F77='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds_F77='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct_F77=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec_F77='-Bexport'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs_F77=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_F77='${wl}-z,text'
+	archive_cmds_F77='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_F77='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_F77='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec_F77='${wl}-Bexport'
+	archive_cmds_F77='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_F77='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_F77='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs_F77=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs_F77" >&5
+echo "${ECHO_T}$ld_shlibs_F77" >&6
+test "$ld_shlibs_F77" = no && can_build_shared=no
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_F77" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_F77 in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_F77
+	pic_flag=$lt_prog_compiler_pic_F77
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_F77
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_F77 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_F77=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_F77" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_F77" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  shlibpath_var=LD_LIBRARY_PATH
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+  if test "$GCC" = yes; then
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_F77=
+if test -n "$hardcode_libdir_flag_spec_F77" || \
+   test -n "$runpath_var_F77" || \
+   test "X$hardcode_automatic_F77" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_F77" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, F77)" != no &&
+     test "$hardcode_minus_L_F77" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_F77=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_F77=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_F77=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_F77" >&5
+echo "${ECHO_T}$hardcode_action_F77" >&6
+if test "$hardcode_action_F77" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_F77 \
+    CC_F77 \
+    LD_F77 \
+    lt_prog_compiler_wl_F77 \
+    lt_prog_compiler_pic_F77 \
+    lt_prog_compiler_static_F77 \
+    lt_prog_compiler_no_builtin_flag_F77 \
+    export_dynamic_flag_spec_F77 \
+    thread_safe_flag_spec_F77 \
+    whole_archive_flag_spec_F77 \
+    enable_shared_with_static_runtimes_F77 \
+    old_archive_cmds_F77 \
+    old_archive_from_new_cmds_F77 \
+    predep_objects_F77 \
+    postdep_objects_F77 \
+    predeps_F77 \
+    postdeps_F77 \
+    compiler_lib_search_path_F77 \
+    archive_cmds_F77 \
+    archive_expsym_cmds_F77 \
+    postinstall_cmds_F77 \
+    postuninstall_cmds_F77 \
+    old_archive_from_expsyms_cmds_F77 \
+    allow_undefined_flag_F77 \
+    no_undefined_flag_F77 \
+    export_symbols_cmds_F77 \
+    hardcode_libdir_flag_spec_F77 \
+    hardcode_libdir_flag_spec_ld_F77 \
+    hardcode_libdir_separator_F77 \
+    hardcode_automatic_F77 \
+    module_cmds_F77 \
+    module_expsym_cmds_F77 \
+    lt_cv_prog_compiler_c_o_F77 \
+    exclude_expsyms_F77 \
+    include_expsyms_F77; do
+    case $var in
+    old_archive_cmds_F77 | \
+    old_archive_from_new_cmds_F77 | \
+    archive_cmds_F77 | \
+    archive_expsym_cmds_F77 | \
+    module_cmds_F77 | \
+    module_expsym_cmds_F77 | \
+    old_archive_from_expsyms_cmds_F77 | \
+    export_symbols_cmds_F77 | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_F77
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_F77
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_F77
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_F77
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_F77
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_F77
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_F77
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_F77
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_F77
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_F77
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_F77
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_F77
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_F77
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_F77
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_F77
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_F77
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_F77
+archive_expsym_cmds=$lt_archive_expsym_cmds_F77
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_F77
+module_expsym_cmds=$lt_module_expsym_cmds_F77
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_F77
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_F77
+# shared library.
+predeps=$lt_predeps_F77
+# shared library.
+postdeps=$lt_postdeps_F77
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_F77
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_F77
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_F77
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_F77
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_F77
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_F77
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_F77
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_F77
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_F77
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_F77
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_F77
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_F77
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_F77"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_F77
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_F77
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_F77
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_F77
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC="$lt_save_CC"
+	else
+	  tagname=""
+	fi
+      GCJ)
+	if test -n "$GCJ" && test "X$GCJ" != "Xno"; then
+# Source file extension for Java test sources.
+ac_ext=java
+# Object file extension for compiled Java test sources.
+objext=o
+objext_GCJ=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code="class foo {}\n"
+# Code to be used in simple link tests
+lt_simple_link_test_code='public class conftest { public static void main(String[] argv) {}; }\n'
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${GCJ-"gcj"}
+compiler=$CC
+compiler_GCJ=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+# GCJ did not exist at the time GCC didn't implicitly link libc in.
+archive_cmds_need_lc_GCJ=no
+old_archive_cmds_GCJ=$old_archive_cmds
+lt_prog_compiler_no_builtin_flag_GCJ=
+  lt_prog_compiler_no_builtin_flag_GCJ=' -fno-builtin'
+echo "$as_me:$LINENO: checking if $compiler supports -fno-rtti -fno-exceptions" >&5
+echo $ECHO_N "checking if $compiler supports -fno-rtti -fno-exceptions... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_rtti_exceptions+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  lt_cv_prog_compiler_rtti_exceptions=no
+  ac_outfile=conftest.$ac_objext
+   lt_compiler_flag="-fno-rtti -fno-exceptions"
+   # Insert the option either (1) after the last *FLAGS variable, or
+   # (2) before a word containing "conftest.", or (3) at the end.
+   # Note that $ac_compile itself does not contain backslashes and begins
+   # with a dollar sign (not a hyphen), so the echo should work correctly.
+   # The option is referenced via a variable to avoid confusing sed.
+   lt_compile=`echo "$ac_compile" | $SED \
+   -e 's:.*FLAGS}\{0,1\} :&$lt_compiler_flag :; t' \
+   -e 's: [^ ]*conftest\.: $lt_compiler_flag&:; t' \
+   -e 's:$: $lt_compiler_flag:'`
+   (eval echo "\"\$as_me:15618: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>conftest.err)
+   ac_status=$?
+   cat conftest.err >&5
+   echo "$as_me:15622: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s "$ac_outfile"; then
+     # The compiler can only warn and ignore the option if not recognized
+     # So say no if there are warnings other than the usual output.
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' >conftest.exp
+     $SED '/^$/d; /^ *+/d' conftest.err >conftest.er2
+     if test ! -s conftest.er2 || diff conftest.exp conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_rtti_exceptions=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_rtti_exceptions" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_rtti_exceptions" >&6
+if test x"$lt_cv_prog_compiler_rtti_exceptions" = xyes; then
+    lt_prog_compiler_no_builtin_flag_GCJ="$lt_prog_compiler_no_builtin_flag_GCJ -fno-rtti -fno-exceptions"
+else
+fi
+fi
+lt_prog_compiler_wl_GCJ=
+lt_prog_compiler_pic_GCJ=
+lt_prog_compiler_static_GCJ=
+echo "$as_me:$LINENO: checking for $compiler option to produce PIC" >&5
+echo $ECHO_N "checking for $compiler option to produce PIC... $ECHO_C" >&6
+    lt_prog_compiler_wl_GCJ='-Wl,'
+    lt_prog_compiler_static_GCJ='-static'
+    case $host_os in
+      aix*)
+      # All AIX code is PIC.
+      if test "$host_cpu" = ia64; then
+	# AIX 5 now supports IA64 processor
+	lt_prog_compiler_static_GCJ='-Bstatic'
+      fi
+    amigaos*)
+      # FIXME: we need at least 68020 code to build shared libraries, but
+      # adding the `-m68020' flag to GCC prevents building anything better,
+      # like `-m68040'.
+      lt_prog_compiler_pic_GCJ='-m68020 -resident32 -malways-restore-a4'
+    beos* | cygwin* | irix5* | irix6* | nonstopux* | osf3* | osf4* | osf5*)
+      # PIC is the default for these OSes.
+    mingw* | pw32* | os2*)
+      # This hack is so that the source file can tell whether it is being
+      # built for inclusion in a dll (and should export symbols for example).
+      lt_prog_compiler_pic_GCJ='-DDLL_EXPORT'
+    darwin* | rhapsody*)
+      # PIC is the default on this platform
+      # Common symbols not allowed in MH_DYLIB files
+      lt_prog_compiler_pic_GCJ='-fno-common'
+    interix3*)
+      # Interix 3.x gcc -fpic/-fPIC options generate broken code.
+      # Instead, we relocate shared libraries at runtime.
+    msdosdjgpp*)
+      # Just because we use GCC doesn't mean we suddenly get shared libraries
+      # on systems that don't support them.
+      lt_prog_compiler_can_build_shared_GCJ=no
+      enable_shared=no
+    sysv4*MP*)
+	lt_prog_compiler_pic_GCJ=-Kconform_pic
+      fi
+    hpux*)
+      # PIC is the default for IA64 HP-UX and 64-bit HP-UX, but
+      # not for PA HP-UX.
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_GCJ='-fPIC'
+      esac
+    esac
+  else
+    # PORTME Check for flag to pass linker flags through the system compiler.
+    case $host_os in
+    aix*)
+      else
+	lt_prog_compiler_static_GCJ='-bnso -bI:/lib/syscalls.exp'
+      fi
+      darwin*)
+       case $cc_basename in
+         xlc*)
+         lt_prog_compiler_pic_GCJ='-qnocommon'
+       esac
+    hpux9* | hpux10* | hpux11*)
+      case $host_cpu in
+      hppa*64*|ia64*)
+	# +Z the default
+	lt_prog_compiler_pic_GCJ='+Z'
+      esac
+      # Is there a better lt_prog_compiler_static that works with the bundled CC?
+      lt_prog_compiler_static_GCJ='${wl}-a ${wl}archive'
+      # PIC (with -KPIC) is the default.
+      lt_prog_compiler_static_GCJ='-non_shared'
+    newsos6)
+      lt_prog_compiler_pic_GCJ='-KPIC'
+    linux*)
+      icc* | ecc*)
+      pgcc* | pgf77* | pgf90* | pgf95*)
+        # Portland Group compilers (*not* the Pentium gcc compiler,
+	# which looks to be a dead project)
+	lt_prog_compiler_pic_GCJ='-fpic'
+      ccc*)
+        # All Alpha code is PIC.
+      esac
+    osf3* | osf4* | osf5*)
+      # All OSF/1 code is PIC.
+    solaris*)
+      f77* | f90* | f95*)
+	lt_prog_compiler_wl_GCJ='-Qoption ld ';;
+	lt_prog_compiler_wl_GCJ='-Wl,';;
+      esac
+    sunos4*)
+      lt_prog_compiler_pic_GCJ='-PIC'
+    sysv4 | sysv4.2uw2* | sysv4.3*)
+    sysv4*MP*)
+	lt_prog_compiler_pic_GCJ='-Kconform_pic'
+      fi
+    sysv5* | unixware* | sco3.2v5* | sco5v6* | OpenUNIX*)
+    unicos*)
+    uts4*)
+      lt_prog_compiler_pic_GCJ='-pic'
+    esac
+  fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_GCJ" >&6
+# Check to make sure the PIC flag actually works.
+if test -n "$lt_prog_compiler_pic_GCJ"; then
+echo "$as_me:$LINENO: checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works" >&5
+echo $ECHO_N "checking if $compiler PIC flag $lt_prog_compiler_pic_GCJ works... $ECHO_C" >&6
+if test "${lt_prog_compiler_pic_works_GCJ+set}" = set; then
+else
+  lt_prog_compiler_pic_works_GCJ=no
+   lt_compiler_flag="$lt_prog_compiler_pic_GCJ"
+   (eval echo "\"\$as_me:15886: $lt_compile\"" >&5)
+   ac_status=$?
+   echo "$as_me:15890: \$? = $ac_status" >&5
+       lt_prog_compiler_pic_works_GCJ=yes
+     fi
+   fi
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_pic_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_pic_works_GCJ" >&6
+if test x"$lt_prog_compiler_pic_works_GCJ" = xyes; then
+    case $lt_prog_compiler_pic_GCJ in
+     *) lt_prog_compiler_pic_GCJ=" $lt_prog_compiler_pic_GCJ" ;;
+     esac
+else
+fi
+fi
+case $host_os in
+  # For platforms which do not support PIC, -DPIC is meaningless:
+  *djgpp*)
+    lt_prog_compiler_pic_GCJ="$lt_prog_compiler_pic_GCJ"
+esac
+# Check to make sure the static flag actually works.
+wl=$lt_prog_compiler_wl_GCJ eval lt_tmp_static_flag=\"$lt_prog_compiler_static_GCJ\"
+echo "$as_me:$LINENO: checking if $compiler static flag $lt_tmp_static_flag works" >&5
+echo $ECHO_N "checking if $compiler static flag $lt_tmp_static_flag works... $ECHO_C" >&6
+if test "${lt_prog_compiler_static_works_GCJ+set}" = set; then
+else
+  lt_prog_compiler_static_works_GCJ=no
+   save_LDFLAGS="$LDFLAGS"
+   LDFLAGS="$LDFLAGS $lt_tmp_static_flag"
+   printf "$lt_simple_link_test_code" > conftest.$ac_ext
+   if (eval $ac_link 2>conftest.err) && test -s conftest$ac_exeext; then
+     # The linker can only warn and ignore the option if not recognized
+     if test -s conftest.err; then
+       # Append any errors to the config.log.
+       $echo "X$_lt_linker_boilerplate" | $Xsed -e '/^$/d' > conftest.exp
+       if diff conftest.exp conftest.er2 >/dev/null; then
+         lt_prog_compiler_static_works_GCJ=yes
+       fi
+     else
+     fi
+   fi
+   $rm conftest*
+   LDFLAGS="$save_LDFLAGS"
+fi
+echo "$as_me:$LINENO: result: $lt_prog_compiler_static_works_GCJ" >&5
+echo "${ECHO_T}$lt_prog_compiler_static_works_GCJ" >&6
+if test x"$lt_prog_compiler_static_works_GCJ" = xyes; then
+else
+fi
+echo "$as_me:$LINENO: checking if $compiler supports -c -o file.$ac_objext" >&5
+echo $ECHO_N "checking if $compiler supports -c -o file.$ac_objext... $ECHO_C" >&6
+if test "${lt_cv_prog_compiler_c_o_GCJ+set}" = set; then
+else
+  lt_cv_prog_compiler_c_o_GCJ=no
+   $rm -r conftest 2>/dev/null
+   mkdir conftest
+   cd conftest
+   mkdir out
+   lt_compiler_flag="-o out/conftest2.$ac_objext"
+   (eval echo "\"\$as_me:15990: $lt_compile\"" >&5)
+   (eval "$lt_compile" 2>out/conftest.err)
+   ac_status=$?
+   cat out/conftest.err >&5
+   echo "$as_me:15994: \$? = $ac_status" >&5
+   if (exit $ac_status) && test -s out/conftest2.$ac_objext
+   then
+     $echo "X$_lt_compiler_boilerplate" | $Xsed -e '/^$/d' > out/conftest.exp
+     $SED '/^$/d; /^ *+/d' out/conftest.err >out/conftest.er2
+     if test ! -s out/conftest.er2 || diff out/conftest.exp out/conftest.er2 >/dev/null; then
+       lt_cv_prog_compiler_c_o_GCJ=yes
+     fi
+   fi
+   chmod u+w . 2>&5
+   $rm conftest*
+   # SGI C++ compiler will create directory out/ii_files/ for
+   # template instantiation
+   test -d out/ii_files && $rm out/ii_files/* && rmdir out/ii_files
+   $rm out/* && rmdir out
+   cd ..
+   rmdir conftest
+   $rm conftest*
+fi
+echo "$as_me:$LINENO: result: $lt_cv_prog_compiler_c_o_GCJ" >&5
+echo "${ECHO_T}$lt_cv_prog_compiler_c_o_GCJ" >&6
+hard_links="nottested"
+if test "$lt_cv_prog_compiler_c_o_GCJ" = no && test "$need_locks" != no; then
+  # do not overwrite the value of need_locks provided by the user
+  echo "$as_me:$LINENO: checking if we can lock with hard links" >&5
+echo $ECHO_N "checking if we can lock with hard links... $ECHO_C" >&6
+  hard_links=yes
+  $rm conftest*
+  ln conftest.a conftest.b 2>/dev/null && hard_links=no
+  touch conftest.a
+  ln conftest.a conftest.b 2>&5 || hard_links=no
+  echo "$as_me:$LINENO: result: $hard_links" >&5
+echo "${ECHO_T}$hard_links" >&6
+  if test "$hard_links" = no; then
+    { echo "$as_me:$LINENO: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&5
+echo "$as_me: WARNING: \`$CC' does not support \`-c -o', so \`make -j' may be unsafe" >&2;}
+    need_locks=warn
+  fi
+else
+  need_locks=no
+fi
+echo "$as_me:$LINENO: checking whether the $compiler linker ($LD) supports shared libraries" >&5
+echo $ECHO_N "checking whether the $compiler linker ($LD) supports shared libraries... $ECHO_C" >&6
+  runpath_var=
+  allow_undefined_flag_GCJ=
+  enable_shared_with_static_runtimes_GCJ=no
+  archive_cmds_GCJ=
+  archive_expsym_cmds_GCJ=
+  old_archive_From_new_cmds_GCJ=
+  old_archive_from_expsyms_cmds_GCJ=
+  export_dynamic_flag_spec_GCJ=
+  whole_archive_flag_spec_GCJ=
+  thread_safe_flag_spec_GCJ=
+  hardcode_libdir_flag_spec_GCJ=
+  hardcode_libdir_flag_spec_ld_GCJ=
+  hardcode_libdir_separator_GCJ=
+  hardcode_direct_GCJ=no
+  hardcode_minus_L_GCJ=no
+  hardcode_shlibpath_var_GCJ=unsupported
+  link_all_deplibs_GCJ=unknown
+  hardcode_automatic_GCJ=no
+  module_cmds_GCJ=
+  module_expsym_cmds_GCJ=
+  always_export_symbols_GCJ=no
+  export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED '\''s/.* //'\'' | sort | uniq > $export_symbols'
+  # include_expsyms should be a list of space-separated symbols to be *always*
+  # included in the symbol list
+  include_expsyms_GCJ=
+  # exclude_expsyms can be an extended regexp of symbols to exclude
+  # it will be wrapped by ` (' and `)$', so one must not match beginning or
+  # end of line.  Example: `a|bc|.*d.*' will exclude the symbols `a' and `bc',
+  # as well as any symbol that contains `d'.
+  exclude_expsyms_GCJ="_GLOBAL_OFFSET_TABLE_"
+  # Although _GLOBAL_OFFSET_TABLE_ is a valid symbol C name, most a.out
+  # platforms (ab)use it in PIC code, but their linkers get confused if
+  # the symbol is explicitly referenced.  Since portable code cannot
+  # rely on this symbol name, it's probably fine to never include it in
+  # preloaded symbol tables.
+  extract_expsyms_cmds=
+  # Just being paranoid about ensuring that cc_basename is set.
+  for cc_temp in $compiler""; do
+  case $cc_temp in
+    *) break;;
+  esac
+done
+  case $host_os in
+  cygwin* | mingw* | pw32*)
+    # FIXME: the MSVC++ port hasn't been tested in a loooong time
+    # When not using gcc, we currently assume that we are using
+    # Microsoft Visual C++.
+    if test "$GCC" != yes; then
+      with_gnu_ld=no
+    fi
+  interix*)
+    # we just hope/assume this is gcc and not c89 (= MSVC++)
+    with_gnu_ld=yes
+  openbsd*)
+    with_gnu_ld=no
+  esac
+  ld_shlibs_GCJ=yes
+  if test "$with_gnu_ld" = yes; then
+    # If archive_cmds runs LD, not CC, wlarc should be empty
+    wlarc='${wl}'
+    # Set some defaults for GNU ld with shared library support. These
+    # are reset later if shared libraries are not supported. Putting them
+    # here allows them to be overridden if necessary.
+    runpath_var=LD_RUN_PATH
+    hardcode_libdir_flag_spec_GCJ='${wl}--rpath ${wl}$libdir'
+    export_dynamic_flag_spec_GCJ='${wl}--export-dynamic'
+    # ancient GNU ld didn't support --whole-archive et. al.
+    if $LD --help 2>&1 | grep 'no-whole-archive' > /dev/null; then
+	whole_archive_flag_spec_GCJ="$wlarc"'--whole-archive$convenience '"$wlarc"'--no-whole-archive'
+      else
+    fi
+    supports_anon_versioning=no
+    case `$LD -v 2>/dev/null` in
+      *\ [01].* | *\ 2.[0-9].* | *\ 2.10.*) ;; # catch versions < 2.11
+      *\ 2.11.93.0.2\ *) supports_anon_versioning=yes ;; # RH7.3 ...
+      *\ 2.11.92.0.12\ *) supports_anon_versioning=yes ;; # Mandrake 8.2 ...
+      *\ 2.11.*) ;; # other 2.11 versions
+      *) supports_anon_versioning=yes ;;
+    esac
+    # See if GNU ld supports shared libraries.
+    case $host_os in
+    aix3* | aix4* | aix5*)
+      # On AIX/PPC, the GNU linker is very broken
+      if test "$host_cpu" != ia64; then
+	ld_shlibs_GCJ=no
+	cat <<EOF 1>&2
+*** Warning: the GNU linker, at least up to release 2.9.1, is reported
+*** to be unable to reliably create shared libraries on AIX.
+*** Therefore, libtool is disabling shared libraries support.  If you
+*** really care for shared libraries, you may want to modify your PATH
+*** so that a non-GNU linker is found, and then restart.
+EOF
+      fi
+    amigaos*)
+      archive_cmds_GCJ='$rm $output_objdir/a2ixlibrary.data~$echo "#define NAME $libname" > $output_objdir/a2ixlibrary.data~$echo "#define LIBRARY_ID 1" >> $output_objdir/a2ixlibrary.data~$echo "#define VERSION $major" >> $output_objdir/a2ixlibrary.data~$echo "#define REVISION $revision" >> $output_objdir/a2ixlibrary.data~$AR $AR_FLAGS $lib $libobjs~$RANLIB $lib~(cd $output_objdir && a2ixlibrary -32)'
+      hardcode_libdir_flag_spec_GCJ='-L$libdir'
+      hardcode_minus_L_GCJ=yes
+      # Samuel A. Falvo II <kc5tja at dolphin.openprojects.net> reports
+      # that the semantics of dynamic libraries on AmigaOS, at least up
+      # to version 4, is to share data among multiple programs linked
+      # with the same dynamic library.  Since this doesn't match the
+      # behavior of shared libraries on other platforms, we can't use
+      # them.
+      ld_shlibs_GCJ=no
+    beos*)
+      if $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+	allow_undefined_flag_GCJ=unsupported
+	# Joseph Beckenbach <jrb3 at best.com> says some releases of gcc
+	# support --undefined.  This deserves some investigation.  FIXME
+	archive_cmds_GCJ='$CC -nostart $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+      else
+	ld_shlibs_GCJ=no
+      fi
+      # _LT_AC_TAGVAR(hardcode_libdir_flag_spec, GCJ) is actually meaningless,
+      # as there is no search path for DLLs.
+      enable_shared_with_static_runtimes_GCJ=yes
+      export_symbols_cmds_GCJ='$NM $libobjs $convenience | $global_symbol_pipe | $SED -e '\''/^[BCDGRS] /s/.* \([^ ]*\)/\1 DATA/'\'' | $SED -e '\''/^[AITW] /s/.* //'\'' | sort | uniq > $export_symbols'
+      if $LD --help 2>&1 | grep 'auto-import' > /dev/null; then
+        archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+	# If the export-symbols file already is a .def file (1st line
+	# is EXPORTS), use it as is; otherwise, prepend...
+	archive_expsym_cmds_GCJ='if test "x`$SED 1q $export_symbols`" = xEXPORTS; then
+	  cp $export_symbols $output_objdir/$soname.def;
+	else
+	  echo EXPORTS > $output_objdir/$soname.def;
+	  cat $export_symbols >> $output_objdir/$soname.def;
+	fi~
+	$CC -shared $output_objdir/$soname.def $libobjs $deplibs $compiler_flags -o $output_objdir/$soname ${wl}--enable-auto-image-base -Xlinker --out-implib -Xlinker $lib'
+      else
+	ld_shlibs_GCJ=no
+      fi
+    interix3*)
+      hardcode_shlibpath_var_GCJ=no
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath,$libdir'
+      export_dynamic_flag_spec_GCJ='${wl}-E'
+      # Hack: On Interix 3.x, we cannot compile PIC because of a broken gcc.
+      # Instead, shared libraries are loaded at an image base (0x10000000 by
+      # default) and relocated if they conflict, which is a slow very memory
+      # consuming and fragmenting process.  To avoid this, we pick a random,
+      # 256 KiB-aligned image base between 0x50000000 and 0x6FFC0000 at link
+      # time.  Moving up from 0x10000000 also allows more sbrk(2) space.
+      archive_cmds_GCJ='$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+      archive_expsym_cmds_GCJ='sed "s,^,_," $export_symbols >$output_objdir/$soname.expsym~$CC -shared $pic_flag $libobjs $deplibs $compiler_flags ${wl}-h,$soname ${wl}--retain-symbols-file,$output_objdir/$soname.expsym ${wl}--image-base,`expr ${RANDOM-$$} % 4096 / 2 \* 262144 + 1342177280` -o $lib'
+    linux*)
+	tmp_addflag=
+	case $cc_basename,$host_cpu in
+	pgcc*)				# Portland Group C compiler
+	  whole_archive_flag_spec_GCJ='${wl}--whole-archive`for conv in $convenience\"\"; do test  -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}--no-whole-archive'
+	  tmp_addflag=' $pic_flag'
+	pgf77* | pgf90* | pgf95*)	# Portland Group f77 and f90 compilers
+	  tmp_addflag=' $pic_flag -Mnomain' ;;
+	ecc*,ia64* | icc*,ia64*)		# Intel C compiler on ia64
+	  tmp_addflag=' -i_dynamic' ;;
+	efc*,ia64* | ifort*,ia64*)	# Intel Fortran compiler on ia64
+	  tmp_addflag=' -i_dynamic -nofor_main' ;;
+	ifc* | ifort*)			# Intel Fortran compiler
+	  tmp_addflag=' -nofor_main' ;;
+	esac
+	archive_cmds_GCJ='$CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	if test $supports_anon_versioning = yes; then
+	  archive_expsym_cmds_GCJ='$echo "{ global:" > $output_objdir/$libname.ver~
+  cat $export_symbols | sed -e "s/\(.*\)/\1;/" >> $output_objdir/$libname.ver~
+  $echo "local: *; };" >> $output_objdir/$libname.ver~
+	  $CC -shared'"$tmp_addflag"' $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-version-script ${wl}$output_objdir/$libname.ver -o $lib'
+	fi
+      else
+	ld_shlibs_GCJ=no
+      fi
+    netbsd*)
+      if echo __ELF__ | $CC -E - | grep __ELF__ >/dev/null; then
+	archive_cmds_GCJ='$LD -Bshareable $libobjs $deplibs $linker_flags -o $lib'
+	wlarc=
+      else
+	archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname -o $lib'
+	archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname $wl$soname ${wl}-retain-symbols-file $wl$export_symbols -o $lib'
+      fi
+    solaris*)
+      if $LD -v 2>&1 | grep 'BFD 2\.8' > /dev/null; then
+	ld_shlibs_GCJ=no
+	cat <<EOF 1>&2
+*** Warning: The releases 2.8.* of the GNU linker cannot reliably
+*** create shared libraries on Solaris systems.  Therefore, libtool
+*** is disabling shared libraries support.  We urge you to upgrade GNU
+*** binutils to release 2.9.1 or newer.  Another option is to modify
+*** your PATH or compiler configuration so that the native linker is
+*** used, and then restart.
+EOF
+      elif $LD --help 2>&1 | grep ': supported targets:.* elf' > /dev/null; then
+      else
+	ld_shlibs_GCJ=no
+      fi
+    sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX*)
+      case `$LD -v 2>&1` in
+        *\ [01].* | *\ 2.[0-9].* | *\ 2.1[0-5].*)
+	ld_shlibs_GCJ=no
+	cat <<_LT_EOF 1>&2
+*** Warning: Releases of the GNU linker prior to 2.16.91.0.3 can not
+*** reliably create shared libraries on SCO systems.  Therefore, libtool
+*** binutils to release 2.16.91.0.3 or newer.  Another option is to modify
+_LT_EOF
+	    hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-rpath,$libdir`'
+	    archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib'
+	    archive_expsym_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname,\${SCOABSPATH:+${install_libdir}/}$soname,-retain-symbols-file,$export_symbols -o $lib'
+	  else
+	    ld_shlibs_GCJ=no
+	  fi
+      esac
+    sunos4*)
+      archive_cmds_GCJ='$LD -assert pure-text -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+      wlarc=
+      hardcode_direct_GCJ=yes
+      else
+	ld_shlibs_GCJ=no
+      fi
+    esac
+    if test "$ld_shlibs_GCJ" = no; then
+      runpath_var=
+    fi
+  else
+    # PORTME fill in a description of your system's linker (not GNU ld)
+    case $host_os in
+    aix3*)
+      always_export_symbols_GCJ=yes
+      archive_expsym_cmds_GCJ='$LD -o $output_objdir/$soname $libobjs $deplibs $linker_flags -bE:$export_symbols -T512 -H512 -bM:SRE~$AR $AR_FLAGS $lib $output_objdir/$soname'
+      # Note: this linker hardcodes the directories in LIBPATH if there
+      # are no directories specified by -L.
+      if test "$GCC" = yes && test -z "$lt_prog_compiler_static"; then
+	# Neither direct hardcoding nor static linking is supported with a
+	# broken collect2.
+	hardcode_direct_GCJ=unsupported
+      fi
+    aix4* | aix5*)
+	# On IA64, the linker does run time linking by default, so we don't
+	# have to do anything special.
+	aix_use_runtimelinking=no
+	exp_sym_flag='-Bexport'
+	no_entry_flag=""
+      else
+	# If we're using GNU nm, then we don't want the "-C" option.
+	# -C means demangle to AIX nm, but means don't demangle with GNU nm
+	if $NM -V 2>&1 | grep 'GNU' > /dev/null; then
+	  export_symbols_cmds_GCJ='$NM -Bpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	else
+	  export_symbols_cmds_GCJ='$NM -BCpg $libobjs $convenience | awk '\''{ if (((\$2 == "T") || (\$2 == "D") || (\$2 == "B")) && (substr(\$3,1,1) != ".")) { print \$3 } }'\'' | sort -u > $export_symbols'
+	fi
+	# Test if we are trying to use run time linking or normal
+	# AIX style linking. If -brtl is somewhere in LDFLAGS, we
+	# need to do runtime linking.
+	case $host_os in aix4.[23]|aix4.[23].*|aix5*)
+	  for ld_flag in $LDFLAGS; do
+  	  if (test $ld_flag = "-brtl" || test $ld_flag = "-Wl,-brtl"); then
+  	    aix_use_runtimelinking=yes
+  	    break
+  	  fi
+	  done
+	esac
+	exp_sym_flag='-bexport'
+	no_entry_flag='-bnoentry'
+      fi
+      # When large executables or shared objects are built, AIX ld can
+      # have problems creating the table of contents.  If linking a library
+      # or program results in "error TOC overflow" add -mminimal-toc to
+      # CXXFLAGS/CFLAGS for g++/gcc.  In the cases where that is not
+      # enough to fix the problem, add -Wl,-bbigtoc to LDFLAGS.
+      archive_cmds_GCJ=''
+      hardcode_libdir_separator_GCJ=':'
+      link_all_deplibs_GCJ=yes
+	case $host_os in aix4.[012]|aix4.[012].*)
+	# We only want to do this on AIX 4.2 and lower, the check
+	# below for broken collect2 doesn't work under 4.3+
+	  collect2name=`${CC} -print-prog-name=collect2`
+	  if test -f "$collect2name" && \
+  	   strings "$collect2name" | grep resolve_lib_name >/dev/null
+	  then
+  	  # We have reworked collect2
+	  else
+  	  # We have old collect2
+  	  # It fails to find uninstalled libraries when the uninstalled
+  	  # path is not listed in the libpath.  Setting hardcode_minus_L
+  	  # to unsupported forces relinking
+	  fi
+	esac
+	shared_flag='-shared'
+	if test "$aix_use_runtimelinking" = yes; then
+	  shared_flag="$shared_flag "'${wl}-G'
+	fi
+      else
+	# not using gcc
+  	# VisualAge C++, Version 5.5 for AIX 5L for IA-64, Beta 3 Release
+  	# chokes on -Wl,-G. The following line is correct:
+	  shared_flag='-G'
+	else
+	    shared_flag='${wl}-G'
+	  else
+	    shared_flag='${wl}-bM:SRE'
+	  fi
+	fi
+      fi
+      # It seems that -bexpall does not export symbols beginning with
+      # underscore (_), so it is better to generate a list of symbols to export.
+	# Warning - without using the other runtime loading flags (-brtl),
+	# -berok will link without error, but may produce a broken library.
+	allow_undefined_flag_GCJ='-berok'
+       # Determine the default libpath from the value encoded in an empty executable.
+       cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
+/* end confdefs.h.  */
+int
+main ()
+  return 0;
+_ACEOF
+rm -f conftest.$ac_objext conftest$ac_exeext
+if { (eval echo "$as_me:$LINENO: \"$ac_link\"") >&5
+  (eval $ac_link) 2>conftest.er1
+  ac_status=$?
+  grep -v '^ *+' conftest.er1 >conftest.err
+  rm -f conftest.er1
+  echo "$as_me:$LINENO: \$? = $ac_status" >&5
+  (exit $ac_status); } &&
+	 { ac_try='test -z "$ac_c_werror_flag"
+			 || test ! -s conftest.err'
+  { (eval echo "$as_me:$LINENO: \"$ac_try\"") >&5
+  (eval $ac_try) 2>&5
+  ac_status=$?
+  (exit $ac_status); }; } &&
+	 { ac_try='test -s conftest$ac_exeext'
+  ac_status=$?
+  (exit $ac_status); }; }; then
+aix_libpath=`dump -H conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+# Check for a 64-bit object if we didn't find anything.
+if test -z "$aix_libpath"; then aix_libpath=`dump -HX64 conftest$ac_exeext 2>/dev/null | $SED -n -e '/Import File Strings/,/^$/ { /^0/ { s/^0  *\(.*\)$/\1/; p; }
+}'`; fi
+else
+  echo "$as_me: failed program was:" >&5
+sed 's/^/| /' conftest.$ac_ext >&5
+fi
+rm -f conftest.err conftest.$ac_objext \
+      conftest$ac_exeext conftest.$ac_ext
+if test -z "$aix_libpath"; then aix_libpath="/usr/lib:/lib"; fi
+       hardcode_libdir_flag_spec_GCJ='${wl}-blibpath:$libdir:'"$aix_libpath"
+	archive_expsym_cmds_GCJ="\$CC"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags `if test "x${allow_undefined_flag}" != "x"; then echo "${wl}${allow_undefined_flag}"; else :; fi` '"\${wl}$exp_sym_flag:\$export_symbols $shared_flag"
+       else
+	  hardcode_libdir_flag_spec_GCJ='${wl}-R $libdir:/usr/lib:/lib'
+	  allow_undefined_flag_GCJ="-z nodefs"
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs '"\${wl}$no_entry_flag"' $compiler_flags ${wl}${allow_undefined_flag} '"\${wl}$exp_sym_flag:\$export_symbols"
+	else
+/* confdefs.h.  */
+_ACEOF
+int
+main ()
+  return 0;
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+}'`; fi
+else
+fi
+	  # Warning - without using the other run time loading flags,
+	  no_undefined_flag_GCJ=' ${wl}-bernotok'
+	  allow_undefined_flag_GCJ=' ${wl}-berok'
+	  # Exported symbols can be pulled into shared objects from archives
+	  whole_archive_flag_spec_GCJ='$convenience'
+	  archive_cmds_need_lc_GCJ=yes
+	  # This is similar to how AIX traditionally builds its shared libraries.
+	  archive_expsym_cmds_GCJ="\$CC $shared_flag"' -o $output_objdir/$soname $libobjs $deplibs ${wl}-bnoentry $compiler_flags ${wl}-bE:$export_symbols${allow_undefined_flag}~$AR $AR_FLAGS $output_objdir/$libname$release.a $output_objdir/$soname'
+	fi
+      fi
+    amigaos*)
+      # see comment about different semantics on the GNU ld section
+      ld_shlibs_GCJ=no
+    bsdi[45]*)
+      export_dynamic_flag_spec_GCJ=-rdynamic
+      # hardcode_libdir_flag_spec is actually meaningless, as there is
+      # no search path for DLLs.
+      hardcode_libdir_flag_spec_GCJ=' '
+      # Tell ltmain to make .lib files, not .a files.
+      libext=lib
+      # Tell ltmain to make .dll files, not .so files.
+      # FIXME: Setting linknames here is a bad hack.
+      archive_cmds_GCJ='$CC -o $lib $libobjs $compiler_flags `echo "$deplibs" | $SED -e '\''s/ -lc$//'\''` -link -dll~linknames='
+      # The linker will automatically build a .lib file if we build a DLL.
+      old_archive_From_new_cmds_GCJ='true'
+      # FIXME: Should let the user specify the lib program.
+      old_archive_cmds_GCJ='lib /OUT:$oldlib$oldobjs$old_deplibs'
+      fix_srcfile_path_GCJ='`cygpath -w "$srcfile"`'
+      case $host_os in
+        rhapsody* | darwin1.[012])
+         allow_undefined_flag_GCJ='${wl}-undefined ${wl}suppress'
+       *) # Darwin 1.3 on
+         if test -z ${MACOSX_DEPLOYMENT_TARGET} ; then
+           allow_undefined_flag_GCJ='${wl}-flat_namespace ${wl}-undefined ${wl}suppress'
+         else
+           case ${MACOSX_DEPLOYMENT_TARGET} in
+             10.[012])
+             10.*)
+               allow_undefined_flag_GCJ='${wl}-undefined ${wl}dynamic_lookup'
+           esac
+         fi
+      esac
+      archive_cmds_need_lc_GCJ=no
+      hardcode_automatic_GCJ=yes
+      whole_archive_flag_spec_GCJ=''
+    if test "$GCC" = yes ; then
+    	output_verbose_link_cmd='echo'
+        archive_cmds_GCJ='$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring'
+      module_cmds_GCJ='$CC $allow_undefined_flag -o $lib -bundle $libobjs $deplibs$compiler_flags'
+      # Don't fix this by using the ld -exported_symbols_list flag, it doesn't exist in older darwin lds
+      archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -dynamiclib $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags -install_name $rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+      module_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC $allow_undefined_flag  -o $lib -bundle $libobjs $deplibs$compiler_flags~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+    else
+        xlc*)
+         archive_cmds_GCJ='$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}`echo $rpath/$soname` $verstring'
+         archive_expsym_cmds_GCJ='sed -e "s,#.*,," -e "s,^[    ]*,," -e "s,^\(..*\),_&," < $export_symbols > $output_objdir/${libname}-symbols.expsym~$CC -qmkshrobj $allow_undefined_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-install_name ${wl}$rpath/$soname $verstring~nmedit -s $output_objdir/${libname}-symbols.expsym ${lib}'
+         ld_shlibs_GCJ=no
+      esac
+    fi
+    dgux*)
+      archive_cmds_GCJ='$LD -G -h $soname -o $lib $libobjs $deplibs $linker_flags'
+    freebsd1*)
+      ld_shlibs_GCJ=no
+    # FreeBSD 2.2.[012] allows us to include c++rt0.o to get C++ constructor
+    # support.  Future versions do this automatically, but an explicit c++rt0.o
+    # does not break anything, and helps significantly (at the cost of a little
+    # extra space).
+    freebsd2.2*)
+      archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags /usr/lib/c++rt0.o'
+      hardcode_libdir_flag_spec_GCJ='-R$libdir'
+    # Unfortunately, older versions of FreeBSD 2 do not have this feature.
+    freebsd2*)
+      archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'
+    # FreeBSD 3 and greater uses gcc -shared to do shared libraries.
+    freebsd* | kfreebsd*-gnu | dragonfly*)
+      archive_cmds_GCJ='$CC -shared -o $lib $libobjs $deplibs $compiler_flags'
+    hpux9*)
+	archive_cmds_GCJ='$rm $output_objdir/$soname~$CC -shared -fPIC ${wl}+b ${wl}$install_libdir -o $output_objdir/$soname $libobjs $deplibs $compiler_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      else
+	archive_cmds_GCJ='$rm $output_objdir/$soname~$LD -b +b $install_libdir -o $output_objdir/$soname $libobjs $deplibs $linker_flags~test $output_objdir/$soname = $lib || mv $output_objdir/$soname $lib'
+      fi
+      hardcode_libdir_flag_spec_GCJ='${wl}+b ${wl}$libdir'
+      hardcode_libdir_separator_GCJ=:
+      # hardcode_minus_L: Not really in the search PATH,
+      # but as the default location of the library.
+    hpux10*)
+      if test "$GCC" = yes -a "$with_gnu_ld" = no; then
+	archive_cmds_GCJ='$CC -shared -fPIC ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -b +h $soname +b $install_libdir -o $lib $libobjs $deplibs $linker_flags'
+      fi
+      if test "$with_gnu_ld" = no; then
+      fi
+    hpux11*)
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -shared ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      else
+	case $host_cpu in
+	hppa*64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	ia64*)
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+nodefaultrpath -o $lib $libobjs $deplibs $compiler_flags'
+	  archive_cmds_GCJ='$CC -b ${wl}+h ${wl}$soname ${wl}+b ${wl}$install_libdir -o $lib $libobjs $deplibs $compiler_flags'
+	esac
+      fi
+	case $host_cpu in
+	hppa*64*|ia64*)
+	  hardcode_libdir_flag_spec_ld_GCJ='+b $libdir'
+	esac
+      fi
+    irix5* | irix6* | nonstopux*)
+	archive_cmds_GCJ='$CC -shared $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_GCJ='$LD -shared $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	hardcode_libdir_flag_spec_ld_GCJ='-rpath $libdir'
+      fi
+      hardcode_libdir_flag_spec_GCJ='${wl}-rpath ${wl}$libdir'
+    netbsd*)
+	archive_cmds_GCJ='$LD -Bshareable -o $lib $libobjs $deplibs $linker_flags'  # a.out
+      else
+	archive_cmds_GCJ='$LD -shared -o $lib $libobjs $deplibs $linker_flags'      # ELF
+      fi
+    newsos6)
+    openbsd*)
+      if test -z "`echo __ELF__ | $CC -E - | grep __ELF__`" || test "$host_os-$host_cpu" = "openbsd2.8-powerpc"; then
+	archive_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared $pic_flag -o $lib $libobjs $deplibs $compiler_flags ${wl}-retain-symbols-file,$export_symbols'
+      else
+       case $host_os in
+	 openbsd[01].* | openbsd2.[0-7] | openbsd2.[0-7].*)
+       esac
+      fi
+    os2*)
+      archive_cmds_GCJ='$echo "LIBRARY $libname INITINSTANCE" > $output_objdir/$libname.def~$echo "DESCRIPTION \"$libname\"" >> $output_objdir/$libname.def~$echo DATA >> $output_objdir/$libname.def~$echo " SINGLE NONSHARED" >> $output_objdir/$libname.def~$echo EXPORTS >> $output_objdir/$libname.def~emxexp $libobjs >> $output_objdir/$libname.def~$CC -Zdll -Zcrtdll -o $lib $libobjs $deplibs $compiler_flags $output_objdir/$libname.def'
+      old_archive_From_new_cmds_GCJ='emximp -o $output_objdir/$libname.a $output_objdir/$libname.def'
+    osf3*)
+	allow_undefined_flag_GCJ=' ${wl}-expect_unresolved ${wl}\*'
+	archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	allow_undefined_flag_GCJ=' -expect_unresolved \*'
+	archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+      fi
+    osf4* | osf5*)	# as osf3* with the addition of -msym flag
+	archive_cmds_GCJ='$CC -shared${allow_undefined_flag} $libobjs $deplibs $compiler_flags ${wl}-msym ${wl}-soname ${wl}$soname `test -n "$verstring" && echo ${wl}-set_version ${wl}$verstring` ${wl}-update_registry ${wl}${output_objdir}/so_locations -o $lib'
+      else
+	archive_cmds_GCJ='$LD -shared${allow_undefined_flag} $libobjs $deplibs $linker_flags -msym -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib'
+	archive_expsym_cmds_GCJ='for i in `cat $export_symbols`; do printf "%s %s\\n" -exported_symbol "\$i" >> $lib.exp; done; echo "-hidden">> $lib.exp~
+	$LD -shared${allow_undefined_flag} -input $lib.exp $linker_flags $libobjs $deplibs -soname $soname `test -n "$verstring" && echo -set_version $verstring` -update_registry ${output_objdir}/so_locations -o $lib~$rm $lib.exp'
+	# Both c and cxx compiler support -rpath directly
+	hardcode_libdir_flag_spec_GCJ='-rpath $libdir'
+      fi
+    solaris*)
+      no_undefined_flag_GCJ=' -z text'
+	wlarc='${wl}'
+	archive_cmds_GCJ='$CC -shared ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$echo "{ global:" > $lib.exp~cat $export_symbols | $SED -e "s/\(.*\)/\1;/" >> $lib.exp~$echo "local: *; };" >> $lib.exp~
+	  $CC -shared ${wl}-M ${wl}$lib.exp ${wl}-h ${wl}$soname -o $lib $libobjs $deplibs $compiler_flags~$rm $lib.exp'
+      else
+	wlarc=''
+	archive_cmds_GCJ='$LD -G${allow_undefined_flag} -h $soname -o $lib $libobjs $deplibs $linker_flags'
+  	$LD -G${allow_undefined_flag} -M $lib.exp -h $soname -o $lib $libobjs $deplibs $linker_flags~$rm $lib.exp'
+      fi
+      case $host_os in
+      solaris2.[0-5] | solaris2.[0-5].*) ;;
+ 	# The compiler driver will combine linker options so we
+ 	# cannot just pass the convience library names through
+ 	# without $wl, iff we do not link with $LD.
+ 	# Luckily, gcc supports the same syntax we need for Sun Studio.
+ 	# Supported since Solaris 2.6 (maybe 2.5.1?)
+ 	case $wlarc in
+ 	  whole_archive_flag_spec_GCJ='-z allextract$convenience -z defaultextract' ;;
+ 	  whole_archive_flag_spec_GCJ='${wl}-z ${wl}allextract`for conv in $convenience\"\"; do test -n \"$conv\" && new_convenience=\"$new_convenience,$conv\"; done; $echo \"$new_convenience\"` ${wl}-z ${wl}defaultextract' ;;
+ 	esac ;;
+      esac
+    sunos4*)
+      if test "x$host_vendor" = xsequent; then
+	# Use $CC to link under sequent, because it throws in some extra .o
+	# files that make .init and .fini sections work.
+	archive_cmds_GCJ='$CC -G ${wl}-h $soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$LD -assert pure-text -Bstatic -o $lib $libobjs $deplibs $linker_flags'
+      fi
+    sysv4)
+	sni)
+	  hardcode_direct_GCJ=yes # is this really true???
+	siemens)
+	  ## LD is ld it makes a PLAMLIB
+	  ## CC just makes a GrossModule.
+	  archive_cmds_GCJ='$LD -G -o $lib $libobjs $deplibs $linker_flags'
+	  reload_cmds_GCJ='$CC -r -o $output$reload_objs'
+	motorola)
+	  hardcode_direct_GCJ=no #Motorola manual says yes, but my tests say they lie
+      esac
+      runpath_var='LD_RUN_PATH'
+    sysv4.3*)
+      export_dynamic_flag_spec_GCJ='-Bexport'
+    sysv4*MP*)
+      if test -d /usr/nec; then
+	hardcode_runpath_var=yes
+	ld_shlibs_GCJ=yes
+      fi
+    sysv4*uw2* | sysv5OpenUNIX* | sysv5UnixWare7.[01].[10]* | unixware7*)
+      no_undefined_flag_GCJ='${wl}-z,text'
+      if test "$GCC" = yes; then
+	archive_cmds_GCJ='$CC -shared ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    sysv5* | sco3.2v5* | sco5v6*)
+      # Note: We can NOT use -z defs as we might desire, because we do not
+      # link with -lc, and that would cause any symbols used from libc to
+      # always be unresolved, which means just about no library would
+      # ever link correctly.  If we're not using GNU ld we use -z text
+      # though, which does catch some bad symbols but isn't as heavy-handed
+      # as -z defs.
+      allow_undefined_flag_GCJ='${wl}-z,nodefs'
+      hardcode_libdir_flag_spec_GCJ='`test -z "$SCOABSPATH" && echo ${wl}-R,$libdir`'
+      export_dynamic_flag_spec_GCJ='${wl}-Bexport'
+	archive_cmds_GCJ='$CC -shared ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -shared ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      else
+	archive_cmds_GCJ='$CC -G ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+	archive_expsym_cmds_GCJ='$CC -G ${wl}-Bexport:$export_symbols ${wl}-h,\${SCOABSPATH:+${install_libdir}/}$soname -o $lib $libobjs $deplibs $compiler_flags'
+      fi
+    uts4*)
+      ld_shlibs_GCJ=no
+    esac
+  fi
+echo "$as_me:$LINENO: result: $ld_shlibs_GCJ" >&5
+echo "${ECHO_T}$ld_shlibs_GCJ" >&6
+test "$ld_shlibs_GCJ" = no && can_build_shared=no
+# Do we need to explicitly link libc?
+case "x$archive_cmds_need_lc_GCJ" in
+x|xyes)
+  # Assume -lc should be added
+  if test "$enable_shared" = yes && test "$GCC" = yes; then
+    case $archive_cmds_GCJ in
+      # FIXME: we may have to deal with multi-command sequences.
+    '$CC '*)
+      # Test whether the compiler implicitly links with -lc since on some
+      # systems, -lgcc has to come before -lc. If gcc already passes -lc
+      # to ld, don't add -lc before -lgcc.
+      echo "$as_me:$LINENO: checking whether -lc should be explicitly linked in" >&5
+echo $ECHO_N "checking whether -lc should be explicitly linked in... $ECHO_C" >&6
+      $rm conftest*
+      printf "$lt_simple_compile_test_code" > conftest.$ac_ext
+      if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>&5
+  ac_status=$?
+  (exit $ac_status); } 2>conftest.err; then
+        soname=conftest
+        lib=conftest
+        libobjs=conftest.$ac_objext
+        deplibs=
+        wl=$lt_prog_compiler_wl_GCJ
+	pic_flag=$lt_prog_compiler_pic_GCJ
+        compiler_flags=-v
+        linker_flags=-v
+        verstring=
+        output_objdir=.
+        libname=conftest
+        lt_save_allow_undefined_flag=$allow_undefined_flag_GCJ
+        if { (eval echo "$as_me:$LINENO: \"$archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1\"") >&5
+  (eval $archive_cmds_GCJ 2\>\&1 \| grep \" -lc \" \>/dev/null 2\>\&1) 2>&5
+  ac_status=$?
+        then
+        else
+        fi
+        allow_undefined_flag_GCJ=$lt_save_allow_undefined_flag
+      else
+        cat conftest.err 1>&5
+      fi
+      $rm conftest*
+      echo "$as_me:$LINENO: result: $archive_cmds_need_lc_GCJ" >&5
+echo "${ECHO_T}$archive_cmds_need_lc_GCJ" >&6
+    esac
+  fi
+esac
+echo "$as_me:$LINENO: checking dynamic linker characteristics" >&5
+echo $ECHO_N "checking dynamic linker characteristics... $ECHO_C" >&6
+libname_spec='lib$name'
+soname_spec=
+shrext_cmds=".so"
+postinstall_cmds=
+finish_cmds=
+finish_eval=
+shlibpath_var=
+shlibpath_overrides_runpath=unknown
+version_type=none
+dynamic_linker="$host_os ld.so"
+sys_lib_dlsearch_path_spec="/lib /usr/lib"
+if test "$GCC" = yes; then
+  sys_lib_search_path_spec=`$CC -print-search-dirs | grep "^libraries:" | $SED -e "s/^libraries://" -e "s,=/,/,g"`
+  if echo "$sys_lib_search_path_spec" | grep ';' >/dev/null ; then
+    # if the path contains ";" then we assume it to be the separator
+    # otherwise default to the standard path separator (i.e. ":") - it is
+    # assumed that no part of a normal pathname contains ";" but that should
+    # okay in the real world where ";" in dirpaths is itself problematic.
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED -e 's/;/ /g'`
+  else
+    sys_lib_search_path_spec=`echo "$sys_lib_search_path_spec" | $SED  -e "s/$PATH_SEPARATOR/ /g"`
+  fi
+else
+  sys_lib_search_path_spec="/lib /usr/lib /usr/local/lib"
+fi
+need_lib_prefix=unknown
+hardcode_into_libs=no
+# when you set need_version to no, make sure it does not cause -set_version
+# flags to be left without arguments
+need_version=unknown
+case $host_os in
+aix3*)
+  version_type=linux
+  library_names_spec='${libname}${release}${shared_ext}$versuffix $libname.a'
+  shlibpath_var=LIBPATH
+  # AIX 3 has no versioning support, so we append a major version to the name.
+  soname_spec='${libname}${release}${shared_ext}$major'
+aix4* | aix5*)
+  need_lib_prefix=no
+  need_version=no
+  hardcode_into_libs=yes
+    # AIX 5 supports IA64
+    library_names_spec='${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext}$versuffix $libname${shared_ext}'
+    shlibpath_var=LD_LIBRARY_PATH
+  else
+    # With GCC up to 2.95.x, collect2 would create an import file
+    # for dependence libraries.  The import file would start with
+    # the line `#! .'.  This would cause the generated library to
+    # depend on `.', always an invalid library.  This was fixed in
+    # development snapshots of GCC prior to 3.0.
+    case $host_os in
+      aix4 | aix4.[01] | aix4.[01].*)
+      if { echo '#if __GNUC__ > 2 || (__GNUC__ == 2 && __GNUC_MINOR__ >= 97)'
+	   echo ' yes '
+	   echo '#endif'; } | ${CC} -E - | grep yes > /dev/null; then
+      else
+	can_build_shared=no
+      fi
+    esac
+    # AIX (on Power*) has no versioning support, so currently we can not hardcode correct
+    # soname into executable. Probably we can add versioning support to
+    # collect2, so additional links can be useful in future.
+      # If using run time linking (on AIX 4.2 or later) use lib<name>.so
+      # instead of lib<name>.a to let people know that these are not
+      # typical AIX shared libraries.
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname${shared_ext}'
+    else
+      # We preserve .a as extension for shared libraries through AIX4.2
+      # and later when we are not doing run time linking.
+      library_names_spec='${libname}${release}.a $libname.a'
+    fi
+  fi
+amigaos*)
+  library_names_spec='$libname.ixlibrary $libname.a'
+  # Create ${libname}_ixlibrary.a entries in /sys/libs.
+  finish_eval='for lib in `ls $libdir/*.ixlibrary 2>/dev/null`; do libname=`$echo "X$lib" | $Xsed -e '\''s%^.*/\([^/]*\)\.ixlibrary$%\1%'\''`; test $rm /sys/libs/${libname}_ixlibrary.a; $show "cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a"; cd /sys/libs && $LN_S $lib ${libname}_ixlibrary.a || exit 1; done'
+beos*)
+  library_names_spec='${libname}${shared_ext}'
+  dynamic_linker="$host_os ld.so"
+  shlibpath_var=LIBRARY_PATH
+bsdi[45]*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig $libdir'
+  sys_lib_search_path_spec="/shlib /usr/lib /usr/X11/lib /usr/contrib/lib /lib /usr/local/lib"
+  sys_lib_dlsearch_path_spec="/shlib /usr/lib /usr/local/lib"
+  # the default ld.so.conf also contains /usr/contrib/lib and
+  # /usr/X11R6/lib (/usr/X11 is a link to /usr/X11R6), but let us allow
+  # libtool to hard-code these into programs
+cygwin* | mingw* | pw32*)
+  version_type=windows
+  shrext_cmds=".dll"
+  need_version=no
+  case $GCC,$host_os in
+  yes,cygwin* | yes,mingw* | yes,pw32*)
+    library_names_spec='$libname.dll.a'
+    # DLL is installed to $(libdir)/../bin by postinstall_cmds
+    postinstall_cmds='base_file=`basename \${file}`~
+      dlpath=`$SHELL 2>&1 -c '\''. $dir/'\''\${base_file}'\''i;echo \$dlname'\''`~
+      dldir=$destdir/`dirname \$dlpath`~
+      test -d \$dldir || mkdir -p \$dldir~
+      $install_prog $dir/$dlname \$dldir/$dlname~
+      chmod a+x \$dldir/$dlname'
+    postuninstall_cmds='dldll=`$SHELL 2>&1 -c '\''. $file; echo \$dlname'\''`~
+      dlpath=$dir/\$dldll~
+       $rm \$dlpath'
+    shlibpath_overrides_runpath=yes
+    case $host_os in
+    cygwin*)
+      # Cygwin DLLs use 'cyg' prefix rather than 'lib'
+      soname_spec='`echo ${libname} | sed -e 's/^lib/cyg/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      sys_lib_search_path_spec="/usr/lib /lib/w32api /lib /usr/local/lib"
+    mingw*)
+      # MinGW DLLs use traditional 'lib' prefix
+      soname_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+      if echo "$sys_lib_search_path_spec" | grep ';[c-zC-Z]:/' >/dev/null; then
+        # It is most probably a Windows format PATH printed by
+        # mingw gcc, but we are running on Cygwin. Gcc prints its search
+        # path with ; separators, and with drive letters. We can handle the
+        # drive letters (cygwin fileutils understands them), so leave them,
+        # especially as we might pass files found there to a mingw objdump,
+        # which wouldn't understand a cygwinified path. Ahh.
+      else
+      fi
+    pw32*)
+      # pw32 DLLs use 'pw' prefix rather than 'lib'
+      library_names_spec='`echo ${libname} | sed -e 's/^lib/pw/'``echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext}'
+    esac
+    library_names_spec='${libname}`echo ${release} | $SED -e 's/[.]/-/g'`${versuffix}${shared_ext} $libname.lib'
+  esac
+  dynamic_linker='Win32 ld.exe'
+  # FIXME: first we should search . and the directory the executable is in
+  shlibpath_var=PATH
+darwin* | rhapsody*)
+  dynamic_linker="$host_os dyld"
+  version_type=darwin
+  need_version=no
+  library_names_spec='${libname}${release}${versuffix}$shared_ext ${libname}${release}${major}$shared_ext ${libname}$shared_ext'
+  soname_spec='${libname}${release}${major}$shared_ext'
+  shlibpath_var=DYLD_LIBRARY_PATH
+  shrext_cmds='`test .$module = .yes && echo .so || echo .dylib`'
+  # Apple's gcc prints 'gcc -print-search-dirs' doesn't operate the same.
+    sys_lib_search_path_spec=`$CC -print-search-dirs | tr "\n" "$PATH_SEPARATOR" | sed -e 's/libraries:/@libraries:/' | tr "@" "\n" | grep "^libraries:" | sed -e "s/^libraries://" -e "s,=/,/,g" -e "s,$PATH_SEPARATOR, ,g" -e "s,.*,& /lib /usr/lib /usr/local/lib,g"`
+  else
+    sys_lib_search_path_spec='/lib /usr/lib /usr/local/lib'
+  fi
+  sys_lib_dlsearch_path_spec='/usr/local/lib /lib /usr/lib'
+dgux*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major $libname$shared_ext'
+freebsd1*)
+  dynamic_linker=no
+kfreebsd*-gnu)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${shared_ext}'
+  shlibpath_overrides_runpath=no
+  dynamic_linker='GNU ld.so'
+freebsd* | dragonfly*)
+  # DragonFly does not have aout.  When/if they implement a new
+  # versioning mechanism, adjust this.
+  if test -x /usr/bin/objformat; then
+    objformat=`/usr/bin/objformat`
+  else
+    case $host_os in
+    freebsd[123]*) objformat=aout ;;
+    *) objformat=elf ;;
+    esac
+  fi
+  version_type=freebsd-$objformat
+  case $version_type in
+    freebsd-elf*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext} $libname${shared_ext}'
+      need_version=no
+    freebsd-*)
+      library_names_spec='${libname}${release}${shared_ext}$versuffix $libname${shared_ext}$versuffix'
+      need_version=yes
+  esac
+  case $host_os in
+  freebsd2*)
+  freebsd3.[01]* | freebsdelf3.[01]*)
+  freebsd3.[2-9]* | freebsdelf3.[2-9]* | \
+  freebsd4.[0-5] | freebsdelf4.[0-5] | freebsd4.1.1 | freebsdelf4.1.1)
+  freebsd*) # from 4.6 on
+  esac
+gnu*)
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}${major} ${libname}${shared_ext}'
+hpux9* | hpux10* | hpux11*)
+  # Give a soname corresponding to the major version so that dld.sl refuses to
+  # link against other versions.
+  version_type=sunos
+  need_version=no
+  case $host_cpu in
+  ia64*)
+    shrext_cmds='.so'
+    dynamic_linker="$host_os dld.so"
+    shlibpath_overrides_runpath=yes # Unless +noenvvar is specified.
+    if test "X$HPUX_IA64_MODE" = X32; then
+      sys_lib_search_path_spec="/usr/lib/hpux32 /usr/local/lib/hpux32 /usr/local/lib"
+    else
+      sys_lib_search_path_spec="/usr/lib/hpux64 /usr/local/lib/hpux64"
+    fi
+    sys_lib_dlsearch_path_spec=$sys_lib_search_path_spec
+   hppa*64*)
+     shrext_cmds='.sl'
+     dynamic_linker="$host_os dld.sl"
+     shlibpath_var=LD_LIBRARY_PATH # How should we handle SHLIB_PATH
+     sys_lib_search_path_spec="/usr/lib/pa20_64 /usr/ccs/lib/pa20_64"
+    shrext_cmds='.sl'
+    shlibpath_var=SHLIB_PATH
+    shlibpath_overrides_runpath=no # +s is required to enable SHLIB_PATH
+  esac
+  # HP-UX runs *really* slowly unless shared libraries are mode 555.
+  postinstall_cmds='chmod 555 $lib'
+interix3*)
+  need_version=no
+  dynamic_linker='Interix 3.x ld.so.1 (PE, like ELF)'
+irix5* | irix6* | nonstopux*)
+  case $host_os in
+    nonstopux*) version_type=nonstopux ;;
+	if test "$lt_cv_prog_gnu_ld" = yes; then
+	else
+		version_type=irix
+	fi ;;
+  esac
+  need_version=no
+  library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${release}${shared_ext}$major ${libname}${release}${shared_ext} $libname${shared_ext}'
+  case $host_os in
+  irix5* | nonstopux*)
+    libsuff= shlibsuff=
+    case $LD in # libtool.m4 will add one of these switches to LD
+    *-32|*"-32 "|*-melf32bsmip|*"-melf32bsmip ")
+      libsuff= shlibsuff= libmagic=32-bit;;
+    *-n32|*"-n32 "|*-melf32bmipn32|*"-melf32bmipn32 ")
+      libsuff=32 shlibsuff=N32 libmagic=N32;;
+    *-64|*"-64 "|*-melf64bmip|*"-melf64bmip ")
+      libsuff=64 shlibsuff=64 libmagic=64-bit;;
+    *) libsuff= shlibsuff= libmagic=never-match;;
+    esac
+  esac
+  shlibpath_var=LD_LIBRARY${shlibsuff}_PATH
+  sys_lib_search_path_spec="/usr/lib${libsuff} /lib${libsuff} /usr/local/lib${libsuff}"
+  sys_lib_dlsearch_path_spec="/usr/lib${libsuff} /lib${libsuff}"
+# No shared lib support for Linux oldld, aout, or coff.
+linux*oldld* | linux*aout* | linux*coff*)
+  dynamic_linker=no
+# This must be Linux ELF.
+linux*)
+  need_version=no
+  finish_cmds='PATH="\$PATH:/sbin" ldconfig -n $libdir'
+  # This implies no fast_install, which is unacceptable.
+  # Some rework will be needed to allow for fast_install
+  # before this can be enabled.
+  # Append ld.so.conf contents to the search path
+  if test -f /etc/ld.so.conf; then
+    lt_ld_extra=`awk '/^include / { system(sprintf("cd /etc; cat %s", \$2)); skip = 1; } { if (!skip) print \$0; skip = 0; }' < /etc/ld.so.conf | $SED -e 's/#.*//;s/[:,	]/ /g;s/=[^=]*$//;s/=[^= ]* / /g;/^$/d' | tr '\n' ' '`
+    sys_lib_dlsearch_path_spec="/lib /usr/lib $lt_ld_extra"
+  fi
+  # We used to test for /lib/ld.so.1 and disable shared libraries on
+  # powerpc, because MkLinux only supported shared libraries with the
+  # GNU dynamic linker.  Since this was broken with cross compilers,
+  # most powerpc-linux boxes support dynamic linking these days and
+  # people can always --disable-shared, the test was removed, and we
+  # assume the GNU/Linux dynamic linker is in use.
+  dynamic_linker='GNU/Linux ld.so'
+knetbsd*-gnu)
+  need_version=no
+netbsd*)
+  need_version=no
+    library_names_spec='${libname}${release}${shared_ext}$versuffix ${libname}${shared_ext}$versuffix'
+    finish_cmds='PATH="\$PATH:/sbin" ldconfig -m $libdir'
+    dynamic_linker='NetBSD (a.out) ld.so'
+  else
+    dynamic_linker='NetBSD ld.elf_so'
+  fi
+newsos6)
+nto-qnx*)
+  need_version=no
+openbsd*)
+  sys_lib_dlsearch_path_spec="/usr/lib"
+  # Some older versions of OpenBSD (3.3 at least) *do* need versioned libs.
+  case $host_os in
+    openbsd3.3 | openbsd3.3.*) need_version=yes ;;
+    *)                         need_version=no  ;;
+  esac
+    case $host_os in
+      openbsd2.[89] | openbsd2.[89].*)
+      esac
+  else
+  fi
+os2*)
+  libname_spec='$name'
+  library_names_spec='$libname${shared_ext} $libname.a'
+  dynamic_linker='OS/2 ld.exe'
+osf3* | osf4* | osf5*)
+  version_type=osf
+  need_version=no
+  sys_lib_search_path_spec="/usr/shlib /usr/ccs/lib /usr/lib/cmplrs/cc /usr/lib /usr/local/lib /var/shlib"
+  sys_lib_dlsearch_path_spec="$sys_lib_search_path_spec"
+solaris*)
+  need_version=no
+  # ldd complains unless libraries are executable
+  postinstall_cmds='chmod +x $lib'
+sunos4*)
+  finish_cmds='PATH="\$PATH:/usr/etc" ldconfig $libdir'
+  fi
+  need_version=yes
+sysv4 | sysv4.3*)
+  case $host_vendor in
+    sni)
+      export_dynamic_flag_spec='${wl}-Blargedynsym'
+    siemens)
+    motorola)
+      need_version=no
+      sys_lib_search_path_spec='/lib /usr/lib /usr/ccs/lib'
+  esac
+sysv4*MP*)
+  if test -d /usr/nec ;then
+    library_names_spec='$libname${shared_ext}.$versuffix $libname${shared_ext}.$major $libname${shared_ext}'
+    soname_spec='$libname${shared_ext}.$major'
+  fi
+sysv5* | sco3.2v5* | sco5v6* | unixware* | OpenUNIX* | sysv4*uw2*)
+  version_type=freebsd-elf
+  need_version=no
+    sys_lib_search_path_spec='/usr/local/lib /usr/gnu/lib /usr/ccs/lib /usr/lib /lib'
+  else
+    sys_lib_search_path_spec='/usr/ccs/lib /usr/lib'
+    case $host_os in
+      sco3.2v5*)
+        sys_lib_search_path_spec="$sys_lib_search_path_spec /lib"
+    esac
+  fi
+  sys_lib_dlsearch_path_spec='/usr/lib'
+uts4*)
+  dynamic_linker=no
+esac
+echo "$as_me:$LINENO: result: $dynamic_linker" >&5
+echo "${ECHO_T}$dynamic_linker" >&6
+test "$dynamic_linker" = no && can_build_shared=no
+variables_saved_for_relink="PATH $shlibpath_var $runpath_var"
+  variables_saved_for_relink="$variables_saved_for_relink GCC_EXEC_PREFIX COMPILER_PATH LIBRARY_PATH"
+fi
+echo "$as_me:$LINENO: checking how to hardcode library paths into programs" >&5
+echo $ECHO_N "checking how to hardcode library paths into programs... $ECHO_C" >&6
+hardcode_action_GCJ=
+if test -n "$hardcode_libdir_flag_spec_GCJ" || \
+   test -n "$runpath_var_GCJ" || \
+   test "X$hardcode_automatic_GCJ" = "Xyes" ; then
+  # We can hardcode non-existant directories.
+  if test "$hardcode_direct_GCJ" != no &&
+     # If the only mechanism to avoid hardcoding is shlibpath_var, we
+     # have to relink, otherwise we might link with an installed library
+     # when we should be linking with a yet-to-be-installed one
+     ## test "$_LT_AC_TAGVAR(hardcode_shlibpath_var, GCJ)" != no &&
+     test "$hardcode_minus_L_GCJ" != no; then
+    # Linking always hardcodes the temporary library directory.
+    hardcode_action_GCJ=relink
+  else
+    # We can link without hardcoding, and we can hardcode nonexisting dirs.
+    hardcode_action_GCJ=immediate
+  fi
+else
+  # We cannot hardcode anything, or else we can only hardcode existing
+  # directories.
+  hardcode_action_GCJ=unsupported
+fi
+echo "$as_me:$LINENO: result: $hardcode_action_GCJ" >&5
+echo "${ECHO_T}$hardcode_action_GCJ" >&6
+if test "$hardcode_action_GCJ" = relink; then
+  # Fast installation is not supported
+  enable_fast_install=no
+elif test "$shlibpath_overrides_runpath" = yes ||
+     test "$enable_shared" = no; then
+  # Fast installation is not necessary
+  enable_fast_install=needless
+fi
+# The else clause should only fire when bootstrapping the
+# libtool distribution, otherwise you forgot to ship ltmain.sh
+# with your package, and you will get complaints that there are
+# no rules to generate ltmain.sh.
+if test -f "$ltmain"; then
+  # See if we are running on zsh, and set the options which allow our commands through
+  # without removal of \ escapes.
+  if test -n "${ZSH_VERSION+set}" ; then
+    setopt NO_GLOB_SUBST
+  fi
+  # Now quote all the things that may contain metacharacters while being
+  # careful not to overquote the AC_SUBSTed values.  We take copies of the
+  # variables and quote the copies for generation of the libtool script.
+  for var in echo old_CC old_CFLAGS AR AR_FLAGS EGREP RANLIB LN_S LTCC LTCFLAGS NM \
+    SED SHELL STRIP \
+    libname_spec library_names_spec soname_spec extract_expsyms_cmds \
+    old_striplib striplib file_magic_cmd finish_cmds finish_eval \
+    deplibs_check_method reload_flag reload_cmds need_locks \
+    lt_cv_sys_global_symbol_pipe lt_cv_sys_global_symbol_to_cdecl \
+    lt_cv_sys_global_symbol_to_c_name_address \
+    sys_lib_search_path_spec sys_lib_dlsearch_path_spec \
+    old_postinstall_cmds old_postuninstall_cmds \
+    compiler_GCJ \
+    CC_GCJ \
+    LD_GCJ \
+    lt_prog_compiler_wl_GCJ \
+    lt_prog_compiler_pic_GCJ \
+    lt_prog_compiler_static_GCJ \
+    lt_prog_compiler_no_builtin_flag_GCJ \
+    export_dynamic_flag_spec_GCJ \
+    thread_safe_flag_spec_GCJ \
+    whole_archive_flag_spec_GCJ \
+    enable_shared_with_static_runtimes_GCJ \
+    old_archive_cmds_GCJ \
+    old_archive_from_new_cmds_GCJ \
+    predep_objects_GCJ \
+    postdep_objects_GCJ \
+    predeps_GCJ \
+    postdeps_GCJ \
+    compiler_lib_search_path_GCJ \
+    archive_cmds_GCJ \
+    archive_expsym_cmds_GCJ \
+    postinstall_cmds_GCJ \
+    postuninstall_cmds_GCJ \
+    old_archive_from_expsyms_cmds_GCJ \
+    allow_undefined_flag_GCJ \
+    no_undefined_flag_GCJ \
+    export_symbols_cmds_GCJ \
+    hardcode_libdir_flag_spec_GCJ \
+    hardcode_libdir_flag_spec_ld_GCJ \
+    hardcode_libdir_separator_GCJ \
+    hardcode_automatic_GCJ \
+    module_cmds_GCJ \
+    module_expsym_cmds_GCJ \
+    lt_cv_prog_compiler_c_o_GCJ \
+    exclude_expsyms_GCJ \
+    include_expsyms_GCJ; do
+    case $var in
+    old_archive_cmds_GCJ | \
+    old_archive_from_new_cmds_GCJ | \
+    archive_cmds_GCJ | \
+    archive_expsym_cmds_GCJ | \
+    module_cmds_GCJ | \
+    module_expsym_cmds_GCJ | \
+    old_archive_from_expsyms_cmds_GCJ | \
+    export_symbols_cmds_GCJ | \
+    extract_expsyms_cmds | reload_cmds | finish_cmds | \
+    postinstall_cmds | postuninstall_cmds | \
+    old_postinstall_cmds | old_postuninstall_cmds | \
+    sys_lib_search_path_spec | sys_lib_dlsearch_path_spec)
+      # Double-quote double-evaled strings.
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$double_quote_subst\" -e \"\$sed_quote_subst\" -e \"\$delay_variable_subst\"\`\\\""
+      eval "lt_$var=\\\"\`\$echo \"X\$$var\" | \$Xsed -e \"\$sed_quote_subst\"\`\\\""
+    esac
+  done
+  case $lt_echo in
+  *'\$0 --fallback-echo"')
+    lt_echo=`$echo "X$lt_echo" | $Xsed -e 's/\\\\\\\$0 --fallback-echo"$/$0 --fallback-echo"/'`
+  esac
+cfgfile="$ofile"
+  cat <<__EOF__ >> "$cfgfile"
+# ### BEGIN LIBTOOL TAG CONFIG: $tagname
+# Libtool was configured on host `(hostname || uname -n) 2>/dev/null | sed 1q`:
+# Shell to use when invoking shell scripts.
+SHELL=$lt_SHELL
+# Whether or not to build shared libraries.
+build_libtool_libs=$enable_shared
+# Whether or not to build static libraries.
+build_old_libs=$enable_static
+# Whether or not to add -lc for building shared libraries.
+build_libtool_need_lc=$archive_cmds_need_lc_GCJ
+# Whether or not to disallow shared libs when runtime libs are static
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_GCJ
+# Whether or not to optimize for fast installation.
+fast_install=$enable_fast_install
+# The host system.
+host_alias=$host_alias
+host=$host
+host_os=$host_os
+# The build system.
+build_alias=$build_alias
+build=$build
+build_os=$build_os
+# An echo program that does not interpret backslashes.
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+AR_FLAGS=$lt_AR_FLAGS
+# A C compiler.
+LTCC=$lt_LTCC
+# LTCC compiler flags.
+LTCFLAGS=$lt_LTCFLAGS
+# A language-specific compiler.
+CC=$lt_compiler_GCJ
+# Is the compiler the GNU C compiler?
+with_gcc=$GCC_GCJ
+# An ERE matcher.
+EGREP=$lt_EGREP
+# The linker used to build libraries.
+LD=$lt_LD_GCJ
+# Whether we need hard or soft links.
+LN_S=$lt_LN_S
+# A BSD-compatible nm program.
+NM=$lt_NM
+# A symbol stripping program
+STRIP=$lt_STRIP
+# Used to examine libraries when file_magic_cmd begins "file"
+MAGIC_CMD=$MAGIC_CMD
+# Used on cygwin: DLL creation program.
+DLLTOOL="$DLLTOOL"
+# Used on cygwin: object dumper.
+OBJDUMP="$OBJDUMP"
+# Used on cygwin: assembler.
+AS="$AS"
+# The name of the directory that contains temporary libtool files.
+objdir=$objdir
+# How to create reloadable object files.
+reload_flag=$lt_reload_flag
+reload_cmds=$lt_reload_cmds
+# How to pass a linker flag through the compiler.
+wl=$lt_lt_prog_compiler_wl_GCJ
+# Object file suffix (normally "o").
+objext="$ac_objext"
+# Old archive suffix (normally "a").
+libext="$libext"
+# Shared library suffix (normally ".so").
+shrext_cmds='$shrext_cmds'
+# Executable file suffix (normally "").
+exeext="$exeext"
+# Additional compiler flags for building library objects.
+pic_flag=$lt_lt_prog_compiler_pic_GCJ
+pic_mode=$pic_mode
+# What is the maximum length of a command?
+max_cmd_len=$lt_cv_sys_max_cmd_len
+# Does compiler simultaneously support -c and -o options?
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_GCJ
+# Must we lock files when doing compilation?
+need_locks=$lt_need_locks
+# Do we need the lib prefix for modules?
+need_lib_prefix=$need_lib_prefix
+# Do we need a version for libraries?
+need_version=$need_version
+# Whether dlopen is supported.
+dlopen_support=$enable_dlopen
+# Whether dlopen of programs is supported.
+dlopen_self=$enable_dlopen_self
+# Whether dlopen of statically linked programs is supported.
+dlopen_self_static=$enable_dlopen_self_static
+# Compiler flag to prevent dynamic linking.
+link_static_flag=$lt_lt_prog_compiler_static_GCJ
+# Compiler flag to turn off builtin functions.
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_GCJ
+# Compiler flag to allow reflexive dlopens.
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_GCJ
+# Compiler flag to generate shared objects directly from archives.
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_GCJ
+# Compiler flag to generate thread-safe objects.
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_GCJ
+# Library versioning type.
+version_type=$version_type
+# Format of library name prefix.
+libname_spec=$lt_libname_spec
+# List of archive names.  First name is the real one, the rest are links.
+# The last name is the one that the linker finds with -lNAME.
+library_names_spec=$lt_library_names_spec
+# The coded name of the library, if different from the real name.
+soname_spec=$lt_soname_spec
+# Commands used to build and install an old-style archive.
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_GCJ
+old_postinstall_cmds=$lt_old_postinstall_cmds
+old_postuninstall_cmds=$lt_old_postuninstall_cmds
+# Create an old-style archive from a shared archive.
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_GCJ
+# Create a temporary old-style archive to link instead of a shared archive.
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_GCJ
+# Commands used to build and install a shared archive.
+archive_cmds=$lt_archive_cmds_GCJ
+archive_expsym_cmds=$lt_archive_expsym_cmds_GCJ
+postinstall_cmds=$lt_postinstall_cmds
+postuninstall_cmds=$lt_postuninstall_cmds
+# Commands used to build a loadable module (assumed same as above if empty)
+module_cmds=$lt_module_cmds_GCJ
+module_expsym_cmds=$lt_module_expsym_cmds_GCJ
+# Commands to strip libraries.
+old_striplib=$lt_old_striplib
+striplib=$lt_striplib
+# Dependencies to place before the objects being linked to create a
+# shared library.
+predep_objects=$lt_predep_objects_GCJ
+# Dependencies to place after the objects being linked to create a
+# shared library.
+postdep_objects=$lt_postdep_objects_GCJ
+# shared library.
+predeps=$lt_predeps_GCJ
+# shared library.
+postdeps=$lt_postdeps_GCJ
+# The library search path used internally by the compiler when linking
+# a shared library.
+compiler_lib_search_path=$lt_compiler_lib_search_path_GCJ
+# Method to check whether dependent libraries are shared objects.
+deplibs_check_method=$lt_deplibs_check_method
+# Command to use when deplibs_check_method == file_magic.
+file_magic_cmd=$lt_file_magic_cmd
+# Flag that allows shared libraries with undefined symbols to be built.
+allow_undefined_flag=$lt_allow_undefined_flag_GCJ
+# Flag that forces no undefined symbols.
+no_undefined_flag=$lt_no_undefined_flag_GCJ
+# Commands used to finish a libtool library installation in a directory.
+finish_cmds=$lt_finish_cmds
+# Same as above, but a single script fragment to be evaled but not shown.
+finish_eval=$lt_finish_eval
+# Take the output of nm and produce a listing of raw symbols and C names.
+global_symbol_pipe=$lt_lt_cv_sys_global_symbol_pipe
+# Transform the output of nm in a proper C declaration
+global_symbol_to_cdecl=$lt_lt_cv_sys_global_symbol_to_cdecl
+# Transform the output of nm in a C name address pair
+global_symbol_to_c_name_address=$lt_lt_cv_sys_global_symbol_to_c_name_address
+# This is the shared library runtime path variable.
+runpath_var=$runpath_var
+# This is the shared library path variable.
+shlibpath_var=$shlibpath_var
+# Is shlibpath searched before the hard-coded library search path?
+shlibpath_overrides_runpath=$shlibpath_overrides_runpath
+# How to hardcode a shared library path into an executable.
+hardcode_action=$hardcode_action_GCJ
+# Whether we should hardcode library paths into libraries.
+hardcode_into_libs=$hardcode_into_libs
+# Flag to hardcode \$libdir into a binary during linking.
+# This must work even if \$libdir does not exist.
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_GCJ
+# If ld is used when linking, flag to hardcode \$libdir into
+# a binary during linking. This must work even if \$libdir does
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_GCJ
+# Whether we need a single -rpath flag with a separated argument.
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_GCJ
+# Set to yes if using DIR/libNAME${shared_ext} during linking hardcodes DIR into the
+# resulting binary.
+hardcode_direct=$hardcode_direct_GCJ
+# Set to yes if using the -LDIR flag during linking hardcodes DIR into the
+hardcode_minus_L=$hardcode_minus_L_GCJ
+# Set to yes if using SHLIBPATH_VAR=DIR during linking hardcodes DIR into
+# the resulting binary.
+hardcode_shlibpath_var=$hardcode_shlibpath_var_GCJ
+# Set to yes if building a shared library automatically hardcodes DIR into the library
+# and all subsequent libraries and executables linked against it.
+hardcode_automatic=$hardcode_automatic_GCJ
+# Variables whose values should be saved in libtool wrapper scripts and
+# restored at relink time.
+variables_saved_for_relink="$variables_saved_for_relink"
+# Whether libtool must link a program against all its dependency libraries.
+link_all_deplibs=$link_all_deplibs_GCJ
+# Compile-time system search path for libraries
+sys_lib_search_path_spec=$lt_sys_lib_search_path_spec
+# Run-time system search path for libraries
+sys_lib_dlsearch_path_spec=$lt_sys_lib_dlsearch_path_spec
+# Fix the shell variable \$srcfile for the compiler.
+fix_srcfile_path="$fix_srcfile_path_GCJ"
+# Set to yes if exported symbols are required.
+always_export_symbols=$always_export_symbols_GCJ
+# The commands to list exported symbols.
+export_symbols_cmds=$lt_export_symbols_cmds_GCJ
+# The commands to extract the exported symbol list from a shared archive.
+extract_expsyms_cmds=$lt_extract_expsyms_cmds
+# Symbols that should not be listed in the preloaded symbols.
+exclude_expsyms=$lt_exclude_expsyms_GCJ
+# Symbols that must always be exported.
+include_expsyms=$lt_include_expsyms_GCJ
+# ### END LIBTOOL TAG CONFIG: $tagname
+__EOF__
+else
+  # If there is no Makefile yet, we rely on a make rule to execute
+  # `config.status --recheck' to rerun these tests and create the
+  # libtool script then.
+  ltmain_in=`echo $ltmain | sed -e 's/\.sh$/.in/'`
+  if test -f "$ltmain_in"; then
+    test -f Makefile && make "$ltmain"
+  fi
+fi
+ac_ext=c
+ac_cpp='$CPP $CPPFLAGS'
+ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
+ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
+ac_compiler_gnu=$ac_cv_c_compiler_gnu
+CC="$lt_save_CC"
+	else
+	  tagname=""
+	fi
+      RC)
+# Source file extension for RC test sources.
+ac_ext=rc
+# Object file extension for compiled RC test sources.
+objext=o
+objext_RC=$objext
+# Code to be used in simple compile tests
+lt_simple_compile_test_code='sample MENU { MENUITEM "&Soup", 100, CHECKED }\n'
+# Code to be used in simple link tests
+lt_simple_link_test_code="$lt_simple_compile_test_code"
+# ltmain only uses $CC for tagged configurations so make sure $CC is set.
+# If no C compiler was specified, use CC.
+LTCC=${LTCC-"$CC"}
+# If no C compiler flags were specified, use CFLAGS.
+LTCFLAGS=${LTCFLAGS-"$CFLAGS"}
+# Allow CC to be a program name with arguments.
+compiler=$CC
+# save warnings/boilerplate of simple test code
+ac_outfile=conftest.$ac_objext
+printf "$lt_simple_compile_test_code" >conftest.$ac_ext
+eval "$ac_compile" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_compiler_boilerplate=`cat conftest.err`
+$rm conftest*
+printf "$lt_simple_link_test_code" >conftest.$ac_ext
+eval "$ac_link" 2>&1 >/dev/null | $SED '/^$/d; /^ *+/d' >conftest.err
+_lt_linker_boilerplate=`cat conftest.err`
+$rm conftest*
+lt_save_CC="$CC"
+CC=${RC-"windres"}
+compiler=$CC
+compiler_RC=$CC
+for cc_temp in $compiler""; do
+  case $cc_temp in
+    compile | *[\\/]compile | ccache | *[\\/]ccache ) ;;
+    distcc | *[\\/]distcc | purify | *[\\/]purify ) ;;
+    *) break;;
+  esac
+done
+cc_basename=`$echo "X$cc_temp" | $Xsed -e 's%.*/%%' -e "s%^$host_alias-%%"`
+lt_cv_prog_compiler_c_o_RC=yes
+  fi
+    SED SHELL STRIP \
+    compiler_RC \
+    CC_RC \
+    LD_RC \
+    lt_prog_compiler_wl_RC \
+    lt_prog_compiler_pic_RC \
+    lt_prog_compiler_static_RC \
+    lt_prog_compiler_no_builtin_flag_RC \
+    export_dynamic_flag_spec_RC \
+    thread_safe_flag_spec_RC \
+    whole_archive_flag_spec_RC \
+    enable_shared_with_static_runtimes_RC \
+    old_archive_cmds_RC \
+    old_archive_from_new_cmds_RC \
+    predep_objects_RC \
+    postdep_objects_RC \
+    predeps_RC \
+    postdeps_RC \
+    compiler_lib_search_path_RC \
+    archive_cmds_RC \
+    archive_expsym_cmds_RC \
+    postinstall_cmds_RC \
+    postuninstall_cmds_RC \
+    old_archive_from_expsyms_cmds_RC \
+    allow_undefined_flag_RC \
+    no_undefined_flag_RC \
+    export_symbols_cmds_RC \
+    hardcode_libdir_flag_spec_RC \
+    hardcode_libdir_flag_spec_ld_RC \
+    hardcode_libdir_separator_RC \
+    hardcode_automatic_RC \
+    module_cmds_RC \
+    module_expsym_cmds_RC \
+    lt_cv_prog_compiler_c_o_RC \
+    exclude_expsyms_RC \
+    include_expsyms_RC; do
+    case $var in
+    old_archive_cmds_RC | \
+    old_archive_from_new_cmds_RC | \
+    archive_cmds_RC | \
+    archive_expsym_cmds_RC | \
+    module_cmds_RC | \
+    module_expsym_cmds_RC | \
+    old_archive_from_expsyms_cmds_RC | \
+    export_symbols_cmds_RC | \
+    esac
+  done
+  case $lt_echo in
+  esac
+cfgfile="$ofile"
+SHELL=$lt_SHELL
+build_libtool_need_lc=$archive_cmds_need_lc_RC
+allow_libtool_libs_with_static_runtimes=$enable_shared_with_static_runtimes_RC
+# The host system.
+host=$host
+host_os=$host_os
+build=$build
+build_os=$build_os
+echo=$lt_echo
+# The archiver.
+AR=$lt_AR
+# A C compiler.
+LTCC=$lt_LTCC
+CC=$lt_compiler_RC
+with_gcc=$GCC_RC
+# An ERE matcher.
+EGREP=$lt_EGREP
+LD=$lt_LD_RC
+LN_S=$lt_LN_S
+NM=$lt_NM
+STRIP=$lt_STRIP
+DLLTOOL="$DLLTOOL"
+OBJDUMP="$OBJDUMP"
+AS="$AS"
+objdir=$objdir
+wl=$lt_lt_prog_compiler_wl_RC
+libext="$libext"
+exeext="$exeext"
+pic_flag=$lt_lt_prog_compiler_pic_RC
+pic_mode=$pic_mode
+compiler_c_o=$lt_lt_cv_prog_compiler_c_o_RC
+link_static_flag=$lt_lt_prog_compiler_static_RC
+no_builtin_flag=$lt_lt_prog_compiler_no_builtin_flag_RC
+export_dynamic_flag_spec=$lt_export_dynamic_flag_spec_RC
+whole_archive_flag_spec=$lt_whole_archive_flag_spec_RC
+thread_safe_flag_spec=$lt_thread_safe_flag_spec_RC
+RANLIB=$lt_RANLIB
+old_archive_cmds=$lt_old_archive_cmds_RC
+old_archive_from_new_cmds=$lt_old_archive_from_new_cmds_RC
+old_archive_from_expsyms_cmds=$lt_old_archive_from_expsyms_cmds_RC
+archive_cmds=$lt_archive_cmds_RC
+archive_expsym_cmds=$lt_archive_expsym_cmds_RC
+module_cmds=$lt_module_cmds_RC
+module_expsym_cmds=$lt_module_expsym_cmds_RC
+# shared library.
+predep_objects=$lt_predep_objects_RC
+# shared library.
+postdep_objects=$lt_postdep_objects_RC
+# shared library.
+predeps=$lt_predeps_RC
+# shared library.
+postdeps=$lt_postdeps_RC
+compiler_lib_search_path=$lt_compiler_lib_search_path_RC
+allow_undefined_flag=$lt_allow_undefined_flag_RC
+no_undefined_flag=$lt_no_undefined_flag_RC
+hardcode_action=$hardcode_action_RC
+hardcode_libdir_flag_spec=$lt_hardcode_libdir_flag_spec_RC
+# not exist.
+hardcode_libdir_flag_spec_ld=$lt_hardcode_libdir_flag_spec_ld_RC
+hardcode_libdir_separator=$lt_hardcode_libdir_separator_RC
+hardcode_direct=$hardcode_direct_RC
+hardcode_minus_L=$hardcode_minus_L_RC
+hardcode_shlibpath_var=$hardcode_shlibpath_var_RC
+hardcode_automatic=$hardcode_automatic_RC
+link_all_deplibs=$link_all_deplibs_RC
+fix_srcfile_path="$fix_srcfile_path_RC"
+always_export_symbols=$always_export_symbols_RC
+export_symbols_cmds=$lt_export_symbols_cmds_RC
+exclude_expsyms=$lt_exclude_expsyms_RC
+include_expsyms=$lt_include_expsyms_RC
+__EOF__
+else
+  fi
+fi
+ac_ext=c
+CC="$lt_save_CC"
+	{ { echo "$as_me:$LINENO: error: Unsupported tag name: $tagname" >&5
+echo "$as_me: error: Unsupported tag name: $tagname" >&2;}
+   { (exit 1); exit 1; }; }
+      esac
+      # Append the new tag name to the list of available tags.
+      if test -n "$tagname" ; then
+      available_tags="$available_tags $tagname"
+    fi
+    fi
+  done
+  IFS="$lt_save_ifs"
+  # Now substitute the updated list of available tags.
+  if eval "sed -e 's/^available_tags=.*\$/available_tags=\"$available_tags\"/' \"$ofile\" > \"${ofile}T\""; then
+    mv "${ofile}T" "$ofile"
+    chmod +x "$ofile"
+  else
+    rm -f "${ofile}T"
+    { { echo "$as_me:$LINENO: error: unable to update list of available tagged configurations." >&5
+echo "$as_me: error: unable to update list of available tagged configurations." >&2;}
+  fi
+fi
+# This can be used to rebuild libtool when needed
+LIBTOOL_DEPS="$ac_aux_dir/ltmain.sh"
+# Always use our own libtool.
+LIBTOOL='$(SHELL) $(top_builddir)/libtool'
+# Prevent multiple expansion
+echo "$as_me:$LINENO: checking for exp in -lm" >&5
+echo $ECHO_N "checking for exp in -lm... $ECHO_C" >&6
+if test "${ac_cv_lib_m_exp+set}" = set; then
+  echo $ECHO_N "(cached) $ECHO_C" >&6
+else
+  ac_check_lib_save_LIBS=$LIBS
+LIBS="-lm  $LIBS"
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h.  */
+_ACEOF
+/* Override any gcc2 internal prototype to avoid an error.  */
+#ifdef __cplusplus
+extern "C"
+#endif
+/* We use char because int might match the return type of a gcc2
+   builtin and then its argument prototype would still apply.  */
+char exp ();
+int
+main ()
+exp ();
+  return 0;
+_ACEOF
+  ac_status=$?
+  cat conftest.err >&5
+  ac_status=$?
+  ac_status=$?
+  ac_cv_lib_m_exp=yes
+else
+ac_cv_lib_m_exp=no
+fi
+LIBS=$ac_check_lib_save_LIBS
+fi
+echo "$as_me:$LINENO: result: $ac_cv_lib_m_exp" >&5
+echo "${ECHO_T}$ac_cv_lib_m_exp" >&6
+if test $ac_cv_lib_m_exp = yes; then
+  cat >>confdefs.h <<_ACEOF
+#define HAVE_LIBM 1
+_ACEOF
+  LIBS="-lm $LIBS"
+fi
+echo "$as_me:$LINENO: checking for ANSI C header files" >&5
+echo $ECHO_N "checking for ANSI C header files... $ECHO_C" >&6
+if test "${ac_cv_header_stdc+set}" = set; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <stdlib.h>
+#include <stdarg.h>
+#include <string.h>
+#include <float.h>
+int
+main ()
+  return 0;
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_compile\"") >&5
+  (eval $ac_compile) 2>conftest.er1
+  ac_status=$?
+  ac_status=$?
+	 { ac_try='test -s conftest.$ac_objext'
+  ac_status=$?
+  ac_cv_header_stdc=yes
+else
+ac_cv_header_stdc=no
+fi
+rm -f conftest.err conftest.$ac_objext conftest.$ac_ext
+if test $ac_cv_header_stdc = yes; then
+  # SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
+  $EGREP "memchr" >/dev/null 2>&1; then
+else
+  ac_cv_header_stdc=no
+fi
+rm -f conftest*
+fi
+  # ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+  $EGREP "free" >/dev/null 2>&1; then
+else
+fi
+rm -f conftest*
+fi
+  # /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
+  if test "$cross_compiling" = yes; then
+else
+/* confdefs.h.  */
+_ACEOF
+#include <ctype.h>
+#if ((' ' & 0x0FF) == 0x020)
+# define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
+# define TOUPPER(c) (ISLOWER(c) ? 'A' + ((c) - 'a') : (c))
+#else
+# define ISLOWER(c) \
+		   (('a' <= (c) && (c) <= 'i') \
+		     || ('j' <= (c) && (c) <= 'r') \
+		     || ('s' <= (c) && (c) <= 'z'))
+# define TOUPPER(c) (ISLOWER(c) ? ((c) | 0x40) : (c))
+#endif
+#define XOR(e, f) (((e) && !(f)) || (!(e) && (f)))
+int
+main ()
+  int i;
+  for (i = 0; i < 256; i++)
+    if (XOR (islower (i), ISLOWER (i))
+	|| toupper (i) != TOUPPER (i))
+      exit(2);
+  exit (0);
+_ACEOF
+rm -f conftest$ac_exeext
+  (eval $ac_link) 2>&5
+  ac_status=$?
+  (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+  ac_status=$?
+else
+  echo "$as_me: program exited with status $ac_status" >&5
+echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+fi
+rm -f core *.core gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
+fi
+fi
+fi
+echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
+echo "${ECHO_T}$ac_cv_header_stdc" >&6
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
+fi
+JNI_INCLUDE=
+export JNI_INCLUDE
+# Check whether --with-jni or --without-jni was given.
+if test "${with_jni+set}" = set; then
+  withval="$with_jni"
+fi;
+if test "$with_jni" = "yes" ; then
+#define JNI_ENABLED 1
+_ACEOF
+  echo "$as_me:$LINENO: checking whether to enable Java/JNI support" >&5
+echo $ECHO_N "checking whether to enable Java/JNI support... $ECHO_C" >&6
+  echo "$as_me:$LINENO: result: enabled" >&5
+echo "${ECHO_T}enabled" >&6
+elif test "$with_jni" != "no" -a "$with_jni" != "" ; then
+  if test \! -r "$with_jni/jni.h" ; then
+    { { echo "$as_me:$LINENO: error: Did not find $with_jni/jni.h" >&5
+echo "$as_me: error: Did not find $with_jni/jni.h" >&2;}
+  fi
+_ACEOF
+  JNI_INCLUDE="-I$with_jni"
+elif test "$with_jni" = "" ; then
+for ac_header in jni.h
+do
+as_ac_Header=`echo "ac_cv_header_$ac_header" | $as_tr_sh`
+if eval "test \"\${$as_ac_Header+set}\" = set"; then
+  echo "$as_me:$LINENO: checking for $ac_header" >&5
+echo $ECHO_N "checking for $ac_header... $ECHO_C" >&6
+fi
+echo "$as_me:$LINENO: result: `eval echo '${'$as_ac_Header'}'`" >&5
+echo "${ECHO_T}`eval echo '${'$as_ac_Header'}'`" >&6
+else
+  # Is the header compilable?
+echo "$as_me:$LINENO: checking $ac_header usability" >&5
+echo $ECHO_N "checking $ac_header usability... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+  ac_status=$?
+  ac_status=$?
+  ac_status=$?
+  ac_header_compiler=yes
+else
+ac_header_compiler=no
+fi
+echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+echo "${ECHO_T}$ac_header_compiler" >&6
+# Is the header present?
+echo "$as_me:$LINENO: checking $ac_header presence" >&5
+echo $ECHO_N "checking $ac_header presence... $ECHO_C" >&6
+/* confdefs.h.  */
+_ACEOF
+_ACEOF
+if { (eval echo "$as_me:$LINENO: \"$ac_cpp conftest.$ac_ext\"") >&5
+  (eval $ac_cpp conftest.$ac_ext) 2>conftest.er1
+  ac_status=$?
+  (exit $ac_status); } >/dev/null; then
+  if test -s conftest.err; then
+    ac_cpp_err=$ac_c_preproc_warn_flag
+    ac_cpp_err=$ac_cpp_err$ac_c_werror_flag
+  else
+    ac_cpp_err=
+  fi
+else
+  ac_cpp_err=yes
+fi
+if test -z "$ac_cpp_err"; then
+  ac_header_preproc=yes
+else
+  ac_header_preproc=no
+fi
+rm -f conftest.err conftest.$ac_ext
+echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+echo "${ECHO_T}$ac_header_preproc" >&6
+# So?  What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+  yes:no: )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+  no:yes:* )
+    { echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     check for missing prerequisite headers?" >&5
+echo "$as_me: WARNING: $ac_header:     check for missing prerequisite headers?" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&5
+echo "$as_me: WARNING: $ac_header:     section \"Present But Cannot Be Compiled\"" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+    { echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+      cat <<\_ASBOX
+## Report this to warmerdam at pobox.com ##
+_ASBOX
+      sed "s/^/$as_me: WARNING:     /" >&2
+esac
+echo "$as_me:$LINENO: checking for $ac_header" >&5
+else
+  eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
+if test `eval echo '${'$as_ac_Header'}'` = yes; then
+#define `echo "HAVE_$ac_header" | $as_tr_cpp` 1
+_ACEOF
+fi
+done
+  if test "$ac_cv_header_jni_h" = "no" ; then
+    echo "$as_me:$LINENO: result: disabled" >&5
+echo "${ECHO_T}disabled" >&6
+  else
+_ACEOF
+  fi
+else
+fi
+JNI_INCLUDE=$JNI_INCLUDE
+        ac_config_files="$ac_config_files Makefile src/Makefile man/Makefile man/man1/Makefile man/man3/Makefile nad/Makefile jniwrap/Makefile jniwrap/org/Makefile jniwrap/org/proj4/Makefile"
+cat >confcache <<\_ACEOF
+# This file is a shell script that caches the results of configure
+# tests run on this system so they can be shared between configure
+# scripts and configure runs, see configure's option --config-cache.
+# It is not useful on other systems.  If it contains results you don't
+# want to keep, you may remove or edit it.
+# config.status only pays attention to the cache file if you give it
+# the --recheck option to rerun configure.
+# `ac_cv_env_foo' variables (set or unset) will be overridden when
+# loading this file, other *unset* `ac_cv_foo' will be assigned the
+# following values.
+_ACEOF
+# The following way of writing the cache mishandles newlines in values,
+# but we know of no workaround that is simple, portable, and efficient.
+# So, don't put newlines in cache variables' values.
+# Ultrix sh set writes to stderr and can't be redirected directly,
+# and sets the high bit in the cache file unless we assign to the vars.
+  (set) 2>&1 |
+    case `(ac_space=' '; set | grep ac_space) 2>&1` in
+    *ac_space=\ *)
+      # `set' does not quote correctly, so add quotes (double-quote
+      # substitution turns \\\\ into \\, and sed turns \\ into \).
+      sed -n \
+	"s/'/'\\\\''/g;
+	  s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
+      # `set' quotes correctly as required by POSIX, so do not add quotes.
+      sed -n \
+	"s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1=\\2/p"
+    esac;
+  sed '
+     t clear
+     : clear
+     s/^\([^=]*\)=\(.*[{}].*\)$/test "${\1+set}" = set || &/
+     t end
+     /^ac_cv_env/!s/^\([^=]*\)=\(.*\)$/\1=${\1=\2}/
+     : end' >>confcache
+if diff $cache_file confcache >/dev/null 2>&1; then :; else
+  if test -w $cache_file; then
+    test "x$cache_file" != "x/dev/null" && echo "updating cache $cache_file"
+    cat confcache >$cache_file
+  else
+    echo "not updating unwritable cache $cache_file"
+  fi
+fi
+rm -f confcache
+test "x$prefix" = xNONE && prefix=$ac_default_prefix
+# Let make expand exec_prefix.
+test "x$exec_prefix" = xNONE && exec_prefix='${prefix}'
+# VPATH may cause trouble with some makes, so we remove $(srcdir),
+# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
+# trailing colons and then remove the whole line if VPATH becomes empty
+# (actually we leave an empty line to preserve line numbers).
+if test "x$srcdir" = x.; then
+  ac_vpsub='/^[	 ]*VPATH[	 ]*=/{
+s/:*\$(srcdir):*/:/;
+s/:*\${srcdir}:*/:/;
+s/:*@srcdir@:*/:/;
+s/^\([^=]*=[	 ]*\):*/\1/;
+s/:*$//;
+s/^[^=]*=[	 ]*$//;
+fi
+DEFS=-DHAVE_CONFIG_H
+ac_libobjs=
+ac_ltlibobjs=
+for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
+  # 1. Remove the extension, and $U if already installed.
+  ac_i=`echo "$ac_i" |
+	 sed 's/\$U\././;s/\.o$//;s/\.obj$//'`
+  # 2. Add them.
+  ac_libobjs="$ac_libobjs $ac_i\$U.$ac_objext"
+  ac_ltlibobjs="$ac_ltlibobjs $ac_i"'$U.lo'
+done
+LIBOBJS=$ac_libobjs
+LTLIBOBJS=$ac_ltlibobjs
+if test -z "${MAINTAINER_MODE_TRUE}" && test -z "${MAINTAINER_MODE_FALSE}"; then
+  { { echo "$as_me:$LINENO: error: conditional \"MAINTAINER_MODE\" was never defined.
+Usually this means the macro was only invoked conditionally." >&5
+echo "$as_me: error: conditional \"MAINTAINER_MODE\" was never defined.
+Usually this means the macro was only invoked conditionally." >&2;}
+fi
+if test -z "${AMDEP_TRUE}" && test -z "${AMDEP_FALSE}"; then
+  { { echo "$as_me:$LINENO: error: conditional \"AMDEP\" was never defined.
+echo "$as_me: error: conditional \"AMDEP\" was never defined.
+fi
+if test -z "${am__fastdepCC_TRUE}" && test -z "${am__fastdepCC_FALSE}"; then
+  { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCC\" was never defined.
+echo "$as_me: error: conditional \"am__fastdepCC\" was never defined.
+fi
+if test -z "${am__fastdepCXX_TRUE}" && test -z "${am__fastdepCXX_FALSE}"; then
+  { { echo "$as_me:$LINENO: error: conditional \"am__fastdepCXX\" was never defined.
+echo "$as_me: error: conditional \"am__fastdepCXX\" was never defined.
+fi
+: ${CONFIG_STATUS=./config.status}
+ac_clean_files_save=$ac_clean_files
+ac_clean_files="$ac_clean_files $CONFIG_STATUS"
+{ echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
+echo "$as_me: creating $CONFIG_STATUS" >&6;}
+cat >$CONFIG_STATUS <<_ACEOF
+#! $SHELL
+# Generated by $as_me.
+# Run this file to recreate the current configuration.
+# Compiler output produced by configure, useful for debugging
+# configure, is in config.log if it exists.
+debug=false
+ac_cs_recheck=false
+ac_cs_silent=false
+SHELL=\${CONFIG_SHELL-$SHELL}
+_ACEOF
+cat >>$CONFIG_STATUS <<\_ACEOF
+## M4sh Initialization.  ##
+# Be Bourne compatible
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
+  emulate sh
+  NULLCMD=:
+  # Zsh 3.x and 4.x performs word splitting on ${1+"$@"}, which
+  # is contrary to our usage.  Disable this feature.
+  alias -g '${1+"$@"}'='"$@"'
+elif test -n "${BASH_VERSION+set}" && (set -o posix) >/dev/null 2>&1; then
+  set -o posix
+fi
+DUALCASE=1; export DUALCASE # for MKS sh
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+  as_unset=unset
+else
+  as_unset=false
+fi
+# Work around bugs in pre-3.0 UWIN ksh.
+$as_unset ENV MAIL MAILPATH
+PS1='$ '
+PS2='> '
+PS4='+ '
+# NLS nuisances.
+for as_var in \
+  LANG LANGUAGE LC_ADDRESS LC_ALL LC_COLLATE LC_CTYPE LC_IDENTIFICATION \
+  LC_MEASUREMENT LC_MESSAGES LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER \
+  LC_TELEPHONE LC_TIME
+do
+  if (set +x; test -z "`(eval $as_var=C; export $as_var) 2>&1`"); then
+    eval $as_var=C; export $as_var
+  else
+    $as_unset $as_var
+  fi
+done
+# Required to use basename.
+if expr a : '\(a\)' >/dev/null 2>&1; then
+  as_expr=expr
+else
+  as_expr=false
+fi
+if (basename /) >/dev/null 2>&1 && test "X`basename / 2>&1`" = "X/"; then
+  as_basename=basename
+else
+  as_basename=false
+fi
+# Name of the executable.
+as_me=`$as_basename "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+	 X"$0" : 'X\(//\)$' \| \
+	 X"$0" : 'X\(/\)$' \| \
+	 .     : '\(.\)' 2>/dev/null ||
+echo X/"$0" |
+    sed '/^.*\/\([^/][^/]*\)\/*$/{ s//\1/; q; }
+  	  /^X\/\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\/\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+# PATH needs CR, and LINENO needs CR and PATH.
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
+# The user is always right.
+if test "${PATH_SEPARATOR+set}" != set; then
+  echo "#! /bin/sh" >conf$$.sh
+  echo  "exit 0"   >>conf$$.sh
+  chmod +x conf$$.sh
+  if (PATH="/nonexistent;."; conf$$.sh) >/dev/null 2>&1; then
+    PATH_SEPARATOR=';'
+  else
+    PATH_SEPARATOR=:
+  fi
+  rm -f conf$$.sh
+fi
+  as_lineno_1=$LINENO
+  as_lineno_2=$LINENO
+  as_lineno_3=`(expr $as_lineno_1 + 1) 2>/dev/null`
+  test "x$as_lineno_1" != "x$as_lineno_2" &&
+  test "x$as_lineno_3"  = "x$as_lineno_2"  || {
+  # Find who we are.  Look in the path if we contain no path at all
+  # relative or not.
+  case $0 in
+    *[\\/]* ) as_myself=$0 ;;
+    *) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in $PATH
+do
+  IFS=$as_save_IFS
+  test -z "$as_dir" && as_dir=.
+  test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
+  esac
+  # We did not find ourselves, most probably we were run as `sh COMMAND'
+  # in which case we are not to be found in the path.
+  if test "x$as_myself" = x; then
+    as_myself=$0
+  fi
+  if test ! -f "$as_myself"; then
+    { { echo "$as_me:$LINENO: error: cannot find myself; rerun with an absolute path" >&5
+echo "$as_me: error: cannot find myself; rerun with an absolute path" >&2;}
+  fi
+  case $CONFIG_SHELL in
+    as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
+for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
+do
+  IFS=$as_save_IFS
+  for as_base in sh bash ksh sh5; do
+	 case $as_dir in
+	   if ("$as_dir/$as_base" -c '
+  test "x$as_lineno_3"  = "x$as_lineno_2" ') 2>/dev/null; then
+	     $as_unset BASH_ENV || test "${BASH_ENV+set}" != set || { BASH_ENV=; export BASH_ENV; }
+	     $as_unset ENV || test "${ENV+set}" != set || { ENV=; export ENV; }
+	     CONFIG_SHELL=$as_dir/$as_base
+	     export CONFIG_SHELL
+	     exec "$CONFIG_SHELL" "$0" ${1+"$@"}
+	   fi;;
+	 esac
+       done
+done
+  esac
+  # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+  # uniformly replaced by the line number.  The first 'sed' inserts a
+  # line-number line before each line; the second 'sed' does the real
+  # work.  The second script uses 'N' to pair each line-number line
+  # with the numbered line, and appends trailing '-' during
+  # substitution so that $LINENO is not a special case at line end.
+  # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+  # second 'sed' script.  Blame Lee E. McMahon for sed's syntax.  :-)
+  sed '=' <$as_myself |
+    sed '
+      N
+      s,$,-,
+      : loop
+      s,^\(['$as_cr_digits']*\)\(.*\)[$]LINENO\([^'$as_cr_alnum'_]\),\1\2\1\3,
+      t loop
+      s,-$,,
+      s,^['$as_cr_digits']*\n,,
+    ' >$as_me.lineno &&
+  chmod +x $as_me.lineno ||
+    { { echo "$as_me:$LINENO: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&5
+echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2;}
+  # Don't try to exec as it changes $[0], causing all sort of problems
+  # (the dirname of $[0] is not the place where we might find the
+  # original and so on.  Autoconf is especially sensible to this).
+  . ./$as_me.lineno
+  # Exit status is that of the last command.
+  exit
+case `echo "testing\c"; echo 1,2,3`,`echo -n testing; echo 1,2,3` in
+  *c*,-n*) ECHO_N= ECHO_C='
+' ECHO_T='	' ;;
+  *c*,*  ) ECHO_N=-n ECHO_C= ECHO_T= ;;
+  *)       ECHO_N= ECHO_C='\c' ECHO_T= ;;
+esac
+  as_expr=expr
+else
+  as_expr=false
+fi
+rm -f conf$$ conf$$.exe conf$$.file
+echo >conf$$.file
+if ln -s conf$$.file conf$$ 2>/dev/null; then
+  # We could just check for DJGPP; but this test a) works b) is more generic
+  # and c) will remain valid once DJGPP supports symlinks (DJGPP 2.04).
+  if test -f conf$$.exe; then
+    # Don't use ln at all; we don't have any links
+    as_ln_s='cp -p'
+  else
+    as_ln_s='ln -s'
+  fi
+elif ln conf$$.file conf$$ 2>/dev/null; then
+  as_ln_s=ln
+else
+  as_ln_s='cp -p'
+fi
+if mkdir -p . 2>/dev/null; then
+  as_mkdir_p=:
+else
+  test -d ./-p && rmdir ./-p
+  as_mkdir_p=false
+fi
+as_executable_p="test -f"
+# Sed expression to map a string onto a valid CPP name.
+as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
+# Sed expression to map a string onto a valid variable name.
+as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
+# IFS
+# We need space, tab and new line, in precisely that order.
+as_nl='
+IFS=" 	$as_nl"
+# CDPATH.
+$as_unset CDPATH
+exec 6>&1
+# Open the log real soon, to keep \$[0] and so on meaningful, and to
+# report actual input values of CONFIG_FILES etc. instead of their
+# values after options handling.  Logging --version etc. is OK.
+exec 5>>config.log
+  echo
+  sed 'h;s/./-/g;s/^.../## /;s/...$/ ##/;p;x;p;x' <<_ASBOX
+## Running $as_me. ##
+_ASBOX
+} >&5
+cat >&5 <<_CSEOF
+This file was extended by PROJ.4 Projections $as_me 4.5.0, which was
+generated by GNU Autoconf 2.59.  Invocation command line was
+  CONFIG_FILES    = $CONFIG_FILES
+  CONFIG_HEADERS  = $CONFIG_HEADERS
+  CONFIG_LINKS    = $CONFIG_LINKS
+  CONFIG_COMMANDS = $CONFIG_COMMANDS
+  $ $0 $@
+_CSEOF
+echo "on `(hostname || uname -n) 2>/dev/null | sed 1q`" >&5
+echo >&5
+_ACEOF
+# Files that config.status was made for.
+if test -n "$ac_config_files"; then
+  echo "config_files=\"$ac_config_files\"" >>$CONFIG_STATUS
+fi
+if test -n "$ac_config_headers"; then
+  echo "config_headers=\"$ac_config_headers\"" >>$CONFIG_STATUS
+fi
+if test -n "$ac_config_links"; then
+  echo "config_links=\"$ac_config_links\"" >>$CONFIG_STATUS
+fi
+if test -n "$ac_config_commands"; then
+  echo "config_commands=\"$ac_config_commands\"" >>$CONFIG_STATUS
+fi
+ac_cs_usage="\
+\`$as_me' instantiates files from templates according to the
+current configuration.
+Usage: $0 [OPTIONS] [FILE]...
+  -h, --help       print this help, then exit
+  -V, --version    print version number, then exit
+  -q, --quiet      do not print progress messages
+  -d, --debug      don't remove temporary files
+      --recheck    update $as_me by reconfiguring in the same conditions
+  --file=FILE[:TEMPLATE]
+		   instantiate the configuration file FILE
+  --header=FILE[:TEMPLATE]
+		   instantiate the configuration header FILE
+Configuration files:
+$config_files
+Configuration headers:
+$config_headers
+Configuration commands:
+$config_commands
+Report bugs to <bug-autoconf at gnu.org>."
+_ACEOF
+cat >>$CONFIG_STATUS <<_ACEOF
+ac_cs_version="\\
+PROJ.4 Projections config.status 4.5.0
+configured by $0, generated by GNU Autoconf 2.59,
+  with options \\"`echo "$ac_configure_args" | sed 's/[\\""\`\$]/\\\\&/g'`\\"
+Copyright (C) 2003 Free Software Foundation, Inc.
+This config.status script is free software; the Free Software Foundation
+gives unlimited permission to copy, distribute and modify it."
+srcdir=$srcdir
+INSTALL="$INSTALL"
+_ACEOF
+# If no file are specified by the user, then we need to provide default
+# value.  By we need to know if files were specified by the user.
+ac_need_defaults=:
+while test $# != 0
+do
+  case $1 in
+    ac_option=`expr "x$1" : 'x\([^=]*\)='`
+    ac_optarg=`expr "x$1" : 'x[^=]*=\(.*\)'`
+    ac_shift=:
+    ac_option=$1
+    ac_optarg=$2
+    ac_shift=shift
+  *) # This is not an option, so the user has probably given explicit
+     # arguments.
+     ac_option=$1
+     ac_need_defaults=false;;
+  esac
+  case $ac_option in
+  # Handling of the options.
+_ACEOF
+  -recheck | --recheck | --rechec | --reche | --rech | --rec | --re | --r)
+    ac_cs_recheck=: ;;
+  --version | --vers* | -V )
+    echo "$ac_cs_version"; exit 0 ;;
+  --he | --h)
+    # Conflict between --help and --header
+    { { echo "$as_me:$LINENO: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&5
+echo "$as_me: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&2;}
+   { (exit 1); exit 1; }; };;
+  --help | --hel | -h )
+    echo "$ac_cs_usage"; exit 0 ;;
+  --debug | --d* | -d )
+    debug=: ;;
+  --file | --fil | --fi | --f )
+    $ac_shift
+    CONFIG_FILES="$CONFIG_FILES $ac_optarg"
+  --header | --heade | --head | --hea )
+    $ac_shift
+    CONFIG_HEADERS="$CONFIG_HEADERS $ac_optarg"
+  -q | -quiet | --quiet | --quie | --qui | --qu | --q \
+  | -silent | --silent | --silen | --sile | --sil | --si | --s)
+    ac_cs_silent=: ;;
+  # This is an error.
+  -*) { { echo "$as_me:$LINENO: error: unrecognized option: $1
+echo "$as_me: error: unrecognized option: $1
+   { (exit 1); exit 1; }; } ;;
+  *) ac_config_targets="$ac_config_targets $1" ;;
+  esac
+  shift
+done
+ac_configure_extra_args=
+if $ac_cs_silent; then
+  exec 6>/dev/null
+  ac_configure_extra_args="$ac_configure_extra_args --silent"
+fi
+_ACEOF
+if \$ac_cs_recheck; then
+  echo "running $SHELL $0 " $ac_configure_args \$ac_configure_extra_args " --no-create --no-recursion" >&6
+  exec $SHELL $0 $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+fi
+_ACEOF
+# INIT-COMMANDS section.
+AMDEP_TRUE="$AMDEP_TRUE" ac_aux_dir="$ac_aux_dir"
+_ACEOF
+for ac_config_target in $ac_config_targets
+do
+  case "$ac_config_target" in
+  # Handling of arguments.
+  "Makefile" ) CONFIG_FILES="$CONFIG_FILES Makefile" ;;
+  "src/Makefile" ) CONFIG_FILES="$CONFIG_FILES src/Makefile" ;;
+  "man/Makefile" ) CONFIG_FILES="$CONFIG_FILES man/Makefile" ;;
+  "man/man1/Makefile" ) CONFIG_FILES="$CONFIG_FILES man/man1/Makefile" ;;
+  "man/man3/Makefile" ) CONFIG_FILES="$CONFIG_FILES man/man3/Makefile" ;;
+  "nad/Makefile" ) CONFIG_FILES="$CONFIG_FILES nad/Makefile" ;;
+  "jniwrap/Makefile" ) CONFIG_FILES="$CONFIG_FILES jniwrap/Makefile" ;;
+  "jniwrap/org/Makefile" ) CONFIG_FILES="$CONFIG_FILES jniwrap/org/Makefile" ;;
+  "jniwrap/org/proj4/Makefile" ) CONFIG_FILES="$CONFIG_FILES jniwrap/org/proj4/Makefile" ;;
+  "depfiles" ) CONFIG_COMMANDS="$CONFIG_COMMANDS depfiles" ;;
+  "src/proj_config.h" ) CONFIG_HEADERS="$CONFIG_HEADERS src/proj_config.h" ;;
+  *) { { echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
+echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
+  esac
+done
+# If the user did not use the arguments to specify the items to instantiate,
+# then the envvar interface is used.  Set only those that are not.
+# We use the long form for the default assignment because of an extremely
+# bizarre bug on SunOS 4.1.3.
+if $ac_need_defaults; then
+  test "${CONFIG_FILES+set}" = set || CONFIG_FILES=$config_files
+  test "${CONFIG_HEADERS+set}" = set || CONFIG_HEADERS=$config_headers
+  test "${CONFIG_COMMANDS+set}" = set || CONFIG_COMMANDS=$config_commands
+fi
+# Have a temporary directory for convenience.  Make it in the build tree
+# simply because there is no reason to put it here, and in addition,
+# creating and moving files from /tmp can sometimes cause problems.
+# Create a temporary directory, and hook for its removal unless debugging.
+$debug ||
+  trap 'exit_status=$?; rm -rf $tmp && exit $exit_status' 0
+  trap '{ (exit 1); exit 1; }' 1 2 13 15
+# Create a (secure) tmp directory for tmp files.
+  tmp=`(umask 077 && mktemp -d -q "./confstatXXXXXX") 2>/dev/null` &&
+  test -n "$tmp" && test -d "$tmp"
+  tmp=./confstat$$-$RANDOM
+  (umask 077 && mkdir $tmp)
+   echo "$me: cannot create a temporary directory in ." >&2
+_ACEOF
+# CONFIG_FILES section.
+# No need to generate the scripts if there are no CONFIG_FILES.
+# This happens for instance when ./config.status config.h
+if test -n "\$CONFIG_FILES"; then
+  # Protect against being on the right side of a sed subst in config.status.
+  sed 's/,@/@@/; s/@,/@@/; s/,;t t\$/@;t t/; /@;t t\$/s/[\\\\&,]/\\\\&/g;
+   s/@@/,@/; s/@@/@,/; s/@;t t\$/,;t t/' >\$tmp/subs.sed <<\\CEOF
+s, at SHELL@,$SHELL,;t t
+s, at PATH_SEPARATOR@,$PATH_SEPARATOR,;t t
+s, at PACKAGE_NAME@,$PACKAGE_NAME,;t t
+s, at PACKAGE_TARNAME@,$PACKAGE_TARNAME,;t t
+s, at PACKAGE_VERSION@,$PACKAGE_VERSION,;t t
+s, at PACKAGE_STRING@,$PACKAGE_STRING,;t t
+s, at PACKAGE_BUGREPORT@,$PACKAGE_BUGREPORT,;t t
+s, at exec_prefix@,$exec_prefix,;t t
+s, at prefix@,$prefix,;t t
+s, at program_transform_name@,$program_transform_name,;t t
+s, at bindir@,$bindir,;t t
+s, at sbindir@,$sbindir,;t t
+s, at libexecdir@,$libexecdir,;t t
+s, at datadir@,$datadir,;t t
+s, at sysconfdir@,$sysconfdir,;t t
+s, at sharedstatedir@,$sharedstatedir,;t t
+s, at localstatedir@,$localstatedir,;t t
+s, at libdir@,$libdir,;t t
+s, at includedir@,$includedir,;t t
+s, at oldincludedir@,$oldincludedir,;t t
+s, at infodir@,$infodir,;t t
+s, at mandir@,$mandir,;t t
+s, at build_alias@,$build_alias,;t t
+s, at host_alias@,$host_alias,;t t
+s, at target_alias@,$target_alias,;t t
+s, at DEFS@,$DEFS,;t t
+s, at ECHO_C@,$ECHO_C,;t t
+s, at ECHO_N@,$ECHO_N,;t t
+s, at ECHO_T@,$ECHO_T,;t t
+s, at LIBS@,$LIBS,;t t
+s, at INSTALL_PROGRAM@,$INSTALL_PROGRAM,;t t
+s, at INSTALL_SCRIPT@,$INSTALL_SCRIPT,;t t
+s, at INSTALL_DATA@,$INSTALL_DATA,;t t
+s, at CYGPATH_W@,$CYGPATH_W,;t t
+s, at PACKAGE@,$PACKAGE,;t t
+s, at VERSION@,$VERSION,;t t
+s, at ACLOCAL@,$ACLOCAL,;t t
+s, at AUTOCONF@,$AUTOCONF,;t t
+s, at AUTOMAKE@,$AUTOMAKE,;t t
+s, at AUTOHEADER@,$AUTOHEADER,;t t
+s, at MAKEINFO@,$MAKEINFO,;t t
+s, at install_sh@,$install_sh,;t t
+s, at STRIP@,$STRIP,;t t
+s, at ac_ct_STRIP@,$ac_ct_STRIP,;t t
+s, at INSTALL_STRIP_PROGRAM@,$INSTALL_STRIP_PROGRAM,;t t
+s, at mkdir_p@,$mkdir_p,;t t
+s, at AWK@,$AWK,;t t
+s, at SET_MAKE@,$SET_MAKE,;t t
+s, at am__leading_dot@,$am__leading_dot,;t t
+s, at AMTAR@,$AMTAR,;t t
+s, at am__tar@,$am__tar,;t t
+s, at am__untar@,$am__untar,;t t
+s, at MAINTAINER_MODE_TRUE@,$MAINTAINER_MODE_TRUE,;t t
+s, at MAINTAINER_MODE_FALSE@,$MAINTAINER_MODE_FALSE,;t t
+s, at MAINT@,$MAINT,;t t
+s, at CC@,$CC,;t t
+s, at CFLAGS@,$CFLAGS,;t t
+s, at LDFLAGS@,$LDFLAGS,;t t
+s, at CPPFLAGS@,$CPPFLAGS,;t t
+s, at ac_ct_CC@,$ac_ct_CC,;t t
+s, at EXEEXT@,$EXEEXT,;t t
+s, at OBJEXT@,$OBJEXT,;t t
+s, at DEPDIR@,$DEPDIR,;t t
+s, at am__include@,$am__include,;t t
+s, at am__quote@,$am__quote,;t t
+s, at AMDEP_TRUE@,$AMDEP_TRUE,;t t
+s, at AMDEP_FALSE@,$AMDEP_FALSE,;t t
+s, at AMDEPBACKSLASH@,$AMDEPBACKSLASH,;t t
+s, at CCDEPMODE@,$CCDEPMODE,;t t
+s, at am__fastdepCC_TRUE@,$am__fastdepCC_TRUE,;t t
+s, at am__fastdepCC_FALSE@,$am__fastdepCC_FALSE,;t t
+s, at LN_S@,$LN_S,;t t
+s, at build@,$build,;t t
+s, at build_cpu@,$build_cpu,;t t
+s, at build_vendor@,$build_vendor,;t t
+s, at build_os@,$build_os,;t t
+s, at host@,$host,;t t
+s, at host_cpu@,$host_cpu,;t t
+s, at host_vendor@,$host_vendor,;t t
+s, at host_os@,$host_os,;t t
+s, at EGREP@,$EGREP,;t t
+s, at ECHO@,$ECHO,;t t
+s, at AR@,$AR,;t t
+s, at ac_ct_AR@,$ac_ct_AR,;t t
+s, at RANLIB@,$RANLIB,;t t
+s, at ac_ct_RANLIB@,$ac_ct_RANLIB,;t t
+s, at CPP@,$CPP,;t t
+s, at CXX@,$CXX,;t t
+s, at CXXFLAGS@,$CXXFLAGS,;t t
+s, at ac_ct_CXX@,$ac_ct_CXX,;t t
+s, at CXXDEPMODE@,$CXXDEPMODE,;t t
+s, at am__fastdepCXX_TRUE@,$am__fastdepCXX_TRUE,;t t
+s, at am__fastdepCXX_FALSE@,$am__fastdepCXX_FALSE,;t t
+s, at CXXCPP@,$CXXCPP,;t t
+s, at F77@,$F77,;t t
+s, at FFLAGS@,$FFLAGS,;t t
+s, at ac_ct_F77@,$ac_ct_F77,;t t
+s, at LIBTOOL@,$LIBTOOL,;t t
+s, at JNI_INCLUDE@,$JNI_INCLUDE,;t t
+s, at LIBOBJS@,$LIBOBJS,;t t
+s, at LTLIBOBJS@,$LTLIBOBJS,;t t
+CEOF
+_ACEOF
+  cat >>$CONFIG_STATUS <<\_ACEOF
+  # Split the substitutions into bite-sized pieces for seds with
+  # small command number limits, like on Digital OSF/1 and HP-UX.
+  ac_max_sed_lines=48
+  ac_sed_frag=1 # Number of current file.
+  ac_beg=1 # First line for current file.
+  ac_end=$ac_max_sed_lines # Line after last line for current file.
+  ac_more_lines=:
+  ac_sed_cmds=
+  while $ac_more_lines; do
+    if test $ac_beg -gt 1; then
+      sed "1,${ac_beg}d; ${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
+    else
+      sed "${ac_end}q" $tmp/subs.sed >$tmp/subs.frag
+    fi
+    if test ! -s $tmp/subs.frag; then
+      ac_more_lines=false
+    else
+      # The purpose of the label and of the branching condition is to
+      # speed up the sed processing (if there are no `@' at all, there
+      # is no need to browse any of the substitutions).
+      # These are the two extra sed commands mentioned above.
+      (echo ':t
+  /@[a-zA-Z_][a-zA-Z_0-9]*@/!b' && cat $tmp/subs.frag) >$tmp/subs-$ac_sed_frag.sed
+      if test -z "$ac_sed_cmds"; then
+	ac_sed_cmds="sed -f $tmp/subs-$ac_sed_frag.sed"
+      else
+	ac_sed_cmds="$ac_sed_cmds | sed -f $tmp/subs-$ac_sed_frag.sed"
+      fi
+      ac_sed_frag=`expr $ac_sed_frag + 1`
+      ac_beg=$ac_end
+      ac_end=`expr $ac_end + $ac_max_sed_lines`
+    fi
+  done
+    ac_sed_cmds=cat
+  fi
+fi # test -n "$CONFIG_FILES"
+_ACEOF
+for ac_file in : $CONFIG_FILES; do test "x$ac_file" = x: && continue
+  # Support "outfile[:infile[:infile...]]", defaulting infile="outfile.in".
+  case $ac_file in
+  - | *:- | *:-:* ) # input from stdin
+	cat >$tmp/stdin
+	ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
+	ac_file=`echo "$ac_file" | sed 's,:.*,,'` ;;
+  *:* ) ac_file_in=`echo "$ac_file" | sed 's,[^:]*:,,'`
+  * )   ac_file_in=$ac_file.in ;;
+  esac
+  # Compute @srcdir@, @top_srcdir@, and @INSTALL@ for subdirectories.
+  ac_dir=`(dirname "$ac_file") 2>/dev/null ||
+$as_expr X"$ac_file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$ac_file" : 'X\(//\)[^/]' \| \
+	 X"$ac_file" : 'X\(//\)$' \| \
+	 X"$ac_file" : 'X\(/\)' \| \
+echo X"$ac_file" |
+    sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{ s//\1/; q; }
+  	  /^X\(\/\/\)[^/].*/{ s//\1/; q; }
+  	  /^X\(\/\/\)$/{ s//\1/; q; }
+  	  /^X\(\/\).*/{ s//\1/; q; }
+  	  s/.*/./; q'`
+  { if $as_mkdir_p; then
+    mkdir -p "$ac_dir"
+  else
+    as_dir="$ac_dir"
+    as_dirs=
+    while test ! -d "$as_dir"; do
+      as_dirs="$as_dir $as_dirs"
+      as_dir=`(dirname "$as_dir") 2>/dev/null ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$as_dir" : 'X\(//\)[^/]' \| \
+	 X"$as_dir" : 'X\(//\)$' \| \
+	 X"$as_dir" : 'X\(/\)' \| \
+echo X"$as_dir" |
+  	  s/.*/./; q'`
+    done
+    test ! -n "$as_dirs" || mkdir $as_dirs
+  fi || { { echo "$as_me:$LINENO: error: cannot create directory \"$ac_dir\"" >&5
+echo "$as_me: error: cannot create directory \"$ac_dir\"" >&2;}
+   { (exit 1); exit 1; }; }; }
+  ac_builddir=.
+if test "$ac_dir" != .; then
+  ac_dir_suffix=/`echo "$ac_dir" | sed 's,^\.[\\/],,'`
+  # A "../" for each directory in $ac_dir_suffix.
+  ac_top_builddir=`echo "$ac_dir_suffix" | sed 's,/[^\\/]*,../,g'`
+else
+  ac_dir_suffix= ac_top_builddir=
+fi
+case $srcdir in
+  .)  # No --srcdir option.  We are building in place.
+    ac_srcdir=.
+    if test -z "$ac_top_builddir"; then
+       ac_top_srcdir=.
+    else
+       ac_top_srcdir=`echo $ac_top_builddir | sed 's,/$,,'`
+    fi ;;
+  [\\/]* | ?:[\\/]* )  # Absolute path.
+    ac_srcdir=$srcdir$ac_dir_suffix;
+    ac_top_srcdir=$srcdir ;;
+  *) # Relative path.
+    ac_srcdir=$ac_top_builddir$srcdir$ac_dir_suffix
+    ac_top_srcdir=$ac_top_builddir$srcdir ;;
+esac
+# Do not use `cd foo && pwd` to compute absolute paths, because
+# the directories may not exist.
+case `pwd` in
+.) ac_abs_builddir="$ac_dir";;
+  case "$ac_dir" in
+  .) ac_abs_builddir=`pwd`;;
+  [\\/]* | ?:[\\/]* ) ac_abs_builddir="$ac_dir";;
+  *) ac_abs_builddir=`pwd`/"$ac_dir";;
+  esac;;
+esac
+case $ac_abs_builddir in
+.) ac_abs_top_builddir=${ac_top_builddir}.;;
+  case ${ac_top_builddir}. in
+  .) ac_abs_top_builddir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_builddir=${ac_top_builddir}.;;
+  *) ac_abs_top_builddir=$ac_abs_builddir/${ac_top_builddir}.;;
+  esac;;
+esac
+.) ac_abs_srcdir=$ac_srcdir;;
+  case $ac_srcdir in
+  .) ac_abs_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_srcdir=$ac_srcdir;;
+  *) ac_abs_srcdir=$ac_abs_builddir/$ac_srcdir;;
+  esac;;
+esac
+.) ac_abs_top_srcdir=$ac_top_srcdir;;
+  case $ac_top_srcdir in
+  .) ac_abs_top_srcdir=$ac_abs_builddir;;
+  [\\/]* | ?:[\\/]* ) ac_abs_top_srcdir=$ac_top_srcdir;;
+  *) ac_abs_top_srcdir=$ac_abs_builddir/$ac_top_srcdir;;
+  esac;;
+esac
+  case $INSTALL in
+  [\\/$]* | ?:[\\/]* ) ac_INSTALL=$INSTALL ;;
+  *) ac_INSTALL=$ac_top_builddir$INSTALL ;;
+  esac
+  if test x"$ac_file" != x-; then
+    { echo "$as_me:$LINENO: creating $ac_file" >&5
+echo "$as_me: creating $ac_file" >&6;}
+    rm -f "$ac_file"
+  fi
+  # Let's still pretend it is `configure' which instantiates (i.e., don't
+  # use $as_me), people would be surprised to read:
+  #    /* config.h.  Generated by config.status.  */
+  if test x"$ac_file" = x-; then
+    configure_input=
+  else
+    configure_input="$ac_file.  "
+  fi
+  configure_input=$configure_input"Generated from `echo $ac_file_in |
+				     sed 's,.*/,,'` by configure."
+  # First look for the input files in the build tree, otherwise in the
+  # src tree.
+  ac_file_inputs=`IFS=:
+    for f in $ac_file_in; do
+      case $f in
+      -) echo $tmp/stdin ;;
+	 # Absolute (can't be DOS-style, as IFS=:)
+	 test -f "$f" || { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+echo "$as_me: error: cannot find input file: $f" >&2;}
+	 echo "$f";;
+      *) # Relative
+	 if test -f "$f"; then
+	   # Build tree
+	   echo "$f"
+	 elif test -f "$srcdir/$f"; then
+	   # Source tree
+	   echo "$srcdir/$f"
+	 else
+	   # /dev/null tree
+	   { { echo "$as_me:$LINENO: error: cannot find input file: $f" >&5
+	 fi;;
+      esac
+    done` || { (exit 1); exit 1; }
+_ACEOF
+  sed "$ac_vpsub
+$extrasub
+_ACEOF
+:t
+/@[a-zA-Z_][a-zA-Z_0-9]*@/!b
+s, at configure_input@,$configure_input,;t t
+s, at srcdir@,$ac_srcdir,;t t
+s, at abs_srcdir@,$ac_abs_srcdir,;t t
+s, at top_srcdir@,$ac_top_srcdir,;t t
+s, at abs_top_srcdir@,$ac_abs_top_srcdir,;t t
+s, at builddir@,$ac_builddir,;t t
+s, at abs_builddir@,$ac_abs_builddir,;t t
+s, at top_builddir@,$ac_top_builddir,;t t
+s, at abs_top_builddir@,$ac_abs_top_builddir,;t t
+s, at INSTALL@,$ac_INSTALL,;t t
+" $ac_file_inputs | (eval "$ac_sed_cmds") >$tmp/out
+  rm -f $tmp/stdin
+    mv $tmp/out $ac_file
+  else
+    cat $tmp/out
+    rm -f $tmp/out
+  fi
+done
+_ACEOF
+# CONFIG_HEADER section.
+# These sed commands are passed to sed as "A NAME B NAME C VALUE D", where
+# NAME is the cpp macro being defined and VALUE is the value it is being given.
+# ac_d sets the value in "#define NAME VALUE" lines.
+ac_dA='s,^\([	 ]*\)#\([	 ]*define[	 ][	 ]*\)'
+ac_dB='[	 ].*$,\1#\2'
+ac_dC=' '
+ac_dD=',;t'
+# ac_u turns "#undef NAME" without trailing blanks into "#define NAME VALUE".
+ac_uA='s,^\([	 ]*\)#\([	 ]*\)undef\([	 ][	 ]*\)'
+ac_uB='$,\1#\2define\3'
+ac_uC=' '
+ac_uD=',;t'
+for ac_file in : $CONFIG_HEADERS; do test "x$ac_file" = x: && continue
+  case $ac_file in
+	cat >$tmp/stdin
+  esac
+  test x"$ac_file" != x- && { echo "$as_me:$LINENO: creating $ac_file" >&5
+  # src tree.
+      case $f in
+	 # Do quote $f, to prevent DOS paths from being IFS'd.
+	 echo "$f";;
+      *) # Relative
+	   # Build tree
+	   echo "$f"
+	   # Source tree
+	   echo "$srcdir/$f"
+	 else
+	   # /dev/null tree
+	 fi;;
+      esac
+  # Remove the trailing spaces.
+  sed 's/[	 ]*$//' $ac_file_inputs >$tmp/in
+_ACEOF
+# Transform confdefs.h into two sed scripts, `conftest.defines' and
+# `conftest.undefs', that substitutes the proper values into
+# config.h.in to produce config.h.  The first handles `#define'
+# templates, and the second `#undef' templates.
+# And first: Protect against being on the right side of a sed subst in
+# config.status.  Protect against being in an unquoted here document
+# in config.status.
+rm -f conftest.defines conftest.undefs
+# Using a here document instead of a string reduces the quoting nightmare.
+# Putting comments in sed scripts is not portable.
+# `end' is used to avoid that the second main sed command (meant for
+# 0-ary CPP macros) applies to n-ary macro definitions.
+# See the Autoconf documentation for `clear'.
+cat >confdef2sed.sed <<\_ACEOF
+s/[\\&,]/\\&/g
+s,[\\$`],\\&,g
+t clear
+: clear
+s,^[	 ]*#[	 ]*define[	 ][	 ]*\([^	 (][^	 (]*\)\(([^)]*)\)[	 ]*\(.*\)$,${ac_dA}\1${ac_dB}\1\2${ac_dC}\3${ac_dD},gp
+t end
+s,^[	 ]*#[	 ]*define[	 ][	 ]*\([^	 ][^	 ]*\)[	 ]*\(.*\)$,${ac_dA}\1${ac_dB}\1${ac_dC}\2${ac_dD},gp
+: end
+_ACEOF
+# If some macros were called several times there might be several times
+# the same #defines, which is useless.  Nevertheless, we may not want to
+# sort them, since we want the *last* AC-DEFINE to be honored.
+uniq confdefs.h | sed -n -f confdef2sed.sed >conftest.defines
+sed 's/ac_d/ac_u/g' conftest.defines >conftest.undefs
+rm -f confdef2sed.sed
+# This sed command replaces #undef with comments.  This is necessary, for
+# example, in the case of _POSIX_SOURCE, which is predefined and required
+# on some systems where configure will not decide to define it.
+cat >>conftest.undefs <<\_ACEOF
+s,^[	 ]*#[	 ]*undef[	 ][	 ]*[a-zA-Z_][a-zA-Z_0-9]*,/* & */,
+_ACEOF
+# Break up conftest.defines because some shells have a limit on the size
+# of here documents, and old seds have small limits too (100 cmds).
+echo '  # Handle all the #define templates only if necessary.' >>$CONFIG_STATUS
+echo '  if grep "^[	 ]*#[	 ]*define" $tmp/in >/dev/null; then' >>$CONFIG_STATUS
+echo '  # If there are no defines, we may have an empty if/fi' >>$CONFIG_STATUS
+echo '  :' >>$CONFIG_STATUS
+rm -f conftest.tail
+while grep . conftest.defines >/dev/null
+do
+  # Write a limited-size here document to $tmp/defines.sed.
+  echo '  cat >$tmp/defines.sed <<CEOF' >>$CONFIG_STATUS
+  # Speed up: don't consider the non `#define' lines.
+  echo '/^[	 ]*#[	 ]*define/!b' >>$CONFIG_STATUS
+  # Work around the forget-to-reset-the-flag bug.
+  echo 't clr' >>$CONFIG_STATUS
+  echo ': clr' >>$CONFIG_STATUS
+  sed ${ac_max_here_lines}q conftest.defines >>$CONFIG_STATUS
+  echo 'CEOF
+  sed -f $tmp/defines.sed $tmp/in >$tmp/out
+  rm -f $tmp/in
+  mv $tmp/out $tmp/in
+' >>$CONFIG_STATUS
+  sed 1,${ac_max_here_lines}d conftest.defines >conftest.tail
+  rm -f conftest.defines
+  mv conftest.tail conftest.defines
+done
+echo '  fi # grep' >>$CONFIG_STATUS
+echo >>$CONFIG_STATUS
+# Break up conftest.undefs because some shells have a limit on the size
+echo '  # Handle all the #undef templates' >>$CONFIG_STATUS
+while grep . conftest.undefs >/dev/null
+do
+  # Write a limited-size here document to $tmp/undefs.sed.
+  echo '  cat >$tmp/undefs.sed <<CEOF' >>$CONFIG_STATUS
+  # Speed up: don't consider the non `#undef'
+  echo '/^[	 ]*#[	 ]*undef/!b' >>$CONFIG_STATUS
+  sed ${ac_max_here_lines}q conftest.undefs >>$CONFIG_STATUS
+  echo 'CEOF
+  sed -f $tmp/undefs.sed $tmp/in >$tmp/out
+  rm -f $tmp/in
+' >>$CONFIG_STATUS
+  sed 1,${ac_max_here_lines}d conftest.undefs >conftest.tail
+  rm -f conftest.undefs
+  mv conftest.tail conftest.undefs
+done
+rm -f conftest.undefs
+    echo "/* Generated by configure.  */" >$tmp/config.h
+  else
+    echo "/* $ac_file.  Generated by configure.  */" >$tmp/config.h
+  fi
+  cat $tmp/in >>$tmp/config.h
+  rm -f $tmp/in
+    if diff $ac_file $tmp/config.h >/dev/null 2>&1; then
+      { echo "$as_me:$LINENO: $ac_file is unchanged" >&5
+echo "$as_me: $ac_file is unchanged" >&6;}
+    else
+echo X"$ac_file" |
+  	  s/.*/./; q'`
+  else
+    as_dir="$ac_dir"
+    as_dirs=
+echo X"$as_dir" |
+  	  s/.*/./; q'`
+    done
+      rm -f $ac_file
+      mv $tmp/config.h $ac_file
+    fi
+  else
+    cat $tmp/config.h
+    rm -f $tmp/config.h
+  fi
+# Compute $ac_file's index in $config_headers.
+_am_stamp_count=1
+for _am_header in $config_headers :; do
+  case $_am_header in
+    $ac_file | $ac_file:* )
+      break ;;
+      _am_stamp_count=`expr $_am_stamp_count + 1` ;;
+  esac
+done
+echo "timestamp for $ac_file" >`(dirname $ac_file) 2>/dev/null ||
+$as_expr X$ac_file : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X$ac_file : 'X\(//\)[^/]' \| \
+	 X$ac_file : 'X\(//\)$' \| \
+	 X$ac_file : 'X\(/\)' \| \
+echo X$ac_file |
+  	  s/.*/./; q'`/stamp-h$_am_stamp_count
+done
+_ACEOF
+# CONFIG_COMMANDS section.
+for ac_file in : $CONFIG_COMMANDS; do test "x$ac_file" = x: && continue
+  ac_dest=`echo "$ac_file" | sed 's,:.*,,'`
+  ac_source=`echo "$ac_file" | sed 's,[^:]*:,,'`
+  ac_dir=`(dirname "$ac_dest") 2>/dev/null ||
+$as_expr X"$ac_dest" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$ac_dest" : 'X\(//\)[^/]' \| \
+	 X"$ac_dest" : 'X\(//\)$' \| \
+	 X"$ac_dest" : 'X\(/\)' \| \
+echo X"$ac_dest" |
+  	  s/.*/./; q'`
+  else
+    as_dir="$ac_dir"
+    as_dirs=
+echo X"$as_dir" |
+  	  s/.*/./; q'`
+    done
+  ac_builddir=.
+else
+fi
+case $srcdir in
+    ac_srcdir=.
+       ac_top_srcdir=.
+    else
+    fi ;;
+esac
+case `pwd` in
+  case "$ac_dir" in
+  esac;;
+esac
+  esac;;
+esac
+  esac;;
+esac
+  esac;;
+esac
+  { echo "$as_me:$LINENO: executing $ac_dest commands" >&5
+echo "$as_me: executing $ac_dest commands" >&6;}
+  case $ac_dest in
+    depfiles ) test x"$AMDEP_TRUE" != x"" || for mf in $CONFIG_FILES; do
+  # Strip MF so we end up with the name of the file.
+  mf=`echo "$mf" | sed -e 's/:.*$//'`
+  # Check whether this is an Automake generated Makefile or not.
+  # We used to match only the files named `Makefile.in', but
+  # some people rename them; so instead we look at the file content.
+  # Grep'ing the first line is not enough: some people post-process
+  # each Makefile.in and add a new line on top of each file to say so.
+  # So let's grep whole file.
+  if grep '^#.*generated by automake' $mf > /dev/null 2>&1; then
+    dirpart=`(dirname "$mf") 2>/dev/null ||
+$as_expr X"$mf" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$mf" : 'X\(//\)[^/]' \| \
+	 X"$mf" : 'X\(//\)$' \| \
+	 X"$mf" : 'X\(/\)' \| \
+echo X"$mf" |
+  	  s/.*/./; q'`
+  else
+    continue
+  fi
+  # Extract the definition of DEPDIR, am__include, and am__quote
+  # from the Makefile without running `make'.
+  DEPDIR=`sed -n 's/^DEPDIR = //p' < "$mf"`
+  test -z "$DEPDIR" && continue
+  am__include=`sed -n 's/^am__include = //p' < "$mf"`
+  test -z "am__include" && continue
+  am__quote=`sed -n 's/^am__quote = //p' < "$mf"`
+  # When using ansi2knr, U may be empty or an underscore; expand it
+  U=`sed -n 's/^U = //p' < "$mf"`
+  # Find all dependency output files, they are included files with
+  # $(DEPDIR) in their names.  We invoke sed twice because it is the
+  # simplest approach to changing $(DEPDIR) to its actual value in the
+  # expansion.
+  for file in `sed -n "
+    s/^$am__include $am__quote\(.*(DEPDIR).*\)$am__quote"'$/\1/p' <"$mf" | \
+       sed -e 's/\$(DEPDIR)/'"$DEPDIR"'/g' -e 's/\$U/'"$U"'/g'`; do
+    # Make sure the directory exists.
+    test -f "$dirpart/$file" && continue
+    fdir=`(dirname "$file") 2>/dev/null ||
+$as_expr X"$file" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+	 X"$file" : 'X\(//\)[^/]' \| \
+	 X"$file" : 'X\(//\)$' \| \
+	 X"$file" : 'X\(/\)' \| \
+echo X"$file" |
+  	  s/.*/./; q'`
+    mkdir -p $dirpart/$fdir
+  else
+    as_dir=$dirpart/$fdir
+    as_dirs=
+echo X"$as_dir" |
+  	  s/.*/./; q'`
+    done
+  fi || { { echo "$as_me:$LINENO: error: cannot create directory $dirpart/$fdir" >&5
+echo "$as_me: error: cannot create directory $dirpart/$fdir" >&2;}
+    # echo "creating $dirpart/$file"
+    echo '# dummy' > "$dirpart/$file"
+  done
+done
+  esac
+done
+_ACEOF
+{ (exit 0); exit 0; }
+_ACEOF
+chmod +x $CONFIG_STATUS
+ac_clean_files=$ac_clean_files_save
+# configure is writing to config.log, and then calls config.status.
+# config.status does its own redirection, appending to config.log.
+# Unfortunately, on DOS this fails, as config.log is still kept open
+# by configure, so config.status won't be able to write to it; its
+# output is simply discarded.  So we exec the FD to /dev/null,
+# effectively closing config.log, so it can be properly (re)opened and
+# appended to by config.status.  When coming back to configure, we
+# need to make the FD available again.
+if test "$no_create" != yes; then
+  ac_cs_success=:
+  ac_config_status_args=
+  test "$silent" = yes &&
+    ac_config_status_args="$ac_config_status_args --quiet"
+  exec 5>/dev/null
+  $SHELL $CONFIG_STATUS $ac_config_status_args || ac_cs_success=false
+  exec 5>>config.log
+  # Use ||, not &&, to avoid exiting from the if with $? = 1, which
+  # would make configure fail if this is the last instruction.
+  $ac_cs_success || { (exit 1); exit 1; }
+fi
Property changes on: trunk/MgDev/Oem/proj-4.5.0/configure
___________________________________________________________________
Added: trunk/MgDev/Oem/proj-4.5.0/install-sh
--- trunk/MgDev/Oem/proj-4.5.0/install-sh	                        (rev 0)
+++ trunk/MgDev/Oem/proj-4.5.0/install-sh	2007-03-21 21:36:34 UTC (rev 1330)
@@ -0,0 +1,251 @@
+#!/bin/sh
+# install - install a program, script, or datafile
+# This comes from X11R5 (mit/util/scripts/install.sh).
+# Copyright 1991 by the Massachusetts Institute of Technology
+# Permission to use, copy, modify, distribute, and sell this software and its
+# documentation for any purpose is hereby granted without fee, provided that
+# the above copyright notice appear in all copies and that both that
+# copyright notice and this permission notice appear in supporting
+# documentation, and that the name of M.I.T. not be used in advertising or
+# publicity pertaining to distribution of the software without specific,
+# written prior permission.  M.I.T. makes no representations about the
+# suitability of this software for any purpose.  It is provided "as is"
+# without express or implied warranty.
+# Calling this script install-sh is preferred over install.sh, to prevent
+# `make' implicit rules from creating a file called install from it
+# when there is no Makefile.
+# This script is compatible with the BSD install script, but was written
+# from scratch.  It can only install one file at a time, a restriction
+# shared with many OS's install programs.
+# set DOITPROG to echo to test this script
+# Don't use :- since 4.3BSD and earlier shells don't like it.
+doit="${DOITPROG-}"
+# put in absolute paths if you don't have them in your path; or use env. vars.
+mvprog="${MVPROG-mv}"
+cpprog="${CPPROG-cp}"
+chmodprog="${CHMODPROG-chmod}"
+chownprog="${CHOWNPROG-chown}"
+chgrpprog="${CHGRPPROG-chgrp}"
+stripprog="${STRIPPROG-strip}"
+rmprog="${RMPROG-rm}"
+mkdirprog="${MKDIRPROG-mkdir}"
+transformbasename=""
+transform_arg=""
+instcmd="$mvprog"
+chmodcmd="$chmodprog 0755"
+chowncmd=""
+chgrpcmd=""
+stripcmd=""
+rmcmd="$rmprog -f"
+mvcmd="$mvprog"
+src=""
+dst=""
+dir_arg=""
+while [ x"$1" != x ]; do
+    case $1 in
+	-c) instcmd="$cpprog"
+	    shift
+	    continue;;
+	-d) dir_arg=true
+	    shift
+	    continue;;
+	-m) chmodcmd="$chmodprog $2"
+	    shift
+	    shift
+	    continue;;
+	-o) chowncmd="$chownprog $2"
+	    shift
+	    shift
+	    continue;;
+	-g) chgrpcmd="$chgrpprog $2"
+	    shift
+	    shift
+	    continue;;
+	-s) stripcmd="$stripprog"
+	    shift
+	    continue;;
+	-t=*) transformarg=`echo $1 | sed 's/-t=//'`
+	    shift
+	    continue;;
+	-b=*) transformbasename=`echo $1 | sed 's/-b=//'`
+	    shift
+	    continue;;
+	*)  if [ x"$src" = x ]
+	    then
+		src=$1
+	    else
+		# this colon is to work around a 386BSD /bin/sh bug
+		dst=$1
+	    fi
+	    shift
+	    continue;;
+    esac
+done
+if [ x"$src" = x ]
+then
+	echo "install:	no input file specified"
+	exit 1
+else
+	true
+fi
+if [ x"$dir_arg" != x ]; then
+	dst=$src
+	src=""
+	if [ -d $dst ]; then
+		instcmd=:
+		chmodcmd=""
+	else
+		instcmd=mkdir
+	fi
+else
+# Waiting for this to be detected by the "$instcmd $src $dsttmp" command
+# might cause directories to be created, which would be especially bad
+# if $src (and thus $dsttmp) contains '*'.
+	if [ -f $src -o -d $src ]
+	then
+		true
+	else
+		echo "install:  $src does not exist"
+		exit 1
+	fi
+	if [ x"$dst" = x ]
+	then
+		echo "install:	no destination specified"
+		exit 1
+	else
+		true
+	fi
+# If destination is a directory, append the input filename; if your system
+# does not like double slashes in filenames, you may need to add some logic
+	if [ -d $dst ]
+	then
+		dst="$dst"/`basename $src`
+	else
+		true
+	fi
+fi
+## this sed command emulates the dirname command
+dstdir=`echo $dst | sed -e 's,[^/]*$,,;s,/$,,;s,^$,.,'`
+# Make sure that the destination directory exists.
+#  this part is taken from Noah Friedman's mkinstalldirs script
+# Skip lots of stat calls in the usual case.
+if [ ! -d "$dstdir" ]; then
+defaultIFS='
+IFS="${IFS-${defaultIFS}}"
+oIFS="${IFS}"
+# Some sh's can't handle IFS=/ for some reason.
+IFS='%'
+set - `echo ${dstdir} | sed -e 's@/@%@g' -e 's@^%@/@'`
+IFS="${oIFS}"
+pathcomp=''
+while [ $# -ne 0 ] ; do
+	pathcomp="${pathcomp}${1}"
+	shift
+	if [ ! -d "${pathcomp}" ] ;
+        then
+		$mkdirprog "${pathcomp}"
+	else
+		true
+	fi
+	pathcomp="${pathcomp}/"
+done
+fi
+then
+	$doit $instcmd $dst &&
+	if [ x"$chowncmd" != x ]; then $doit $chowncmd $dst; else true ; fi &&
+	if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dst; else true ; fi &&
+	if [ x"$stripcmd" != x ]; then $doit $stripcmd $dst; else true ; fi &&
+	if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dst; else true ; fi
+else
+# If we're going to rename the final executable, determine the name now.
+	if [ x"$transformarg" = x ]
+	then
+		dstfile=`basename $dst`
+	else
+		dstfile=`basename $dst $transformbasename |
+			sed $transformarg`$transformbasename
+	fi
+# don't allow the sed command to completely eliminate the filename
+	if [ x"$dstfile" = x ]
+	then
+	else
+		true
+	fi
+# Make a temp file name in the proper directory.
+	dsttmp=$dstdir/#inst.$$#
+# Move or copy the file name to the temp name
+	$doit $instcmd $src $dsttmp &&
+	trap "rm -f ${dsttmp}" 0 &&
+# and set any options; do chmod last to preserve setuid bits
+# If any of these fail, we abort the whole thing.  If we want to
+# ignore errors from any of these, just make sure not to ignore
+# errors from the above "$doit $instcmd $src $dsttmp" command.
+	if [ x"$chowncmd" != x ]; then $doit $chowncmd $dsttmp; else true;fi &&
+	if [ x"$chgrpcmd" != x ]; then $doit $chgrpcmd $dsttmp; else true;fi &&
+	if [ x"$stripcmd" != x ]; then $doit $stripcmd $dsttmp; else true;fi &&
+	if [ x"$chmodcmd" != x ]; then $doit $chmodcmd $dsttmp; else true;fi &&
+# Now rename the file to the real destination.
+	$doit $rmcmd -f $dstdir/$dstfile &&
+	$doit $mvcmd $dsttmp $dstdir/$dstfile
+fi &&
+exit 0
Property changes on: trunk/MgDev/Oem/proj-4.5.0/install-sh
More information about the mapguide-commits mailing list
