[mapguide-commits] r4401 - trunk/MgDev/Common/Geometry/CoordinateSystem
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Dec 9 14:55:59 EST 2009
Author: NormOlsen
Date: 2009-12-09 14:55:58 -0500 (Wed, 09 Dec 2009)
New Revision: 4401
   trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h
RFC 76 --> Fix the build of the DotNet Interfaces in the GIS Platform
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h	2009-12-09 19:34:24 UTC (rev 4400)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystemMgrsGridSquarePosition.h	2009-12-09 19:55:58 UTC (rev 4401)
@@ -31,7 +31,7 @@
     // MENTOR_MAINTENANCE --> These enumeration values are assumed to be the
     // same as those used by CS-MAP.
-public:
+PUBLISHED_API:
     ///<summary>
     /// Specifies the grid square position is not set as yet.
More information about the mapguide-commits mailing list
