[mapguide-commits] r4402 - in trunk/MgDev: Common Common/MapGuideCommon/Services Common/Schema Server/src/Common/Manager Server/src/Core Server/src/Services/ServerAdmin UnitTest/WebTier/MapAgent/MapAgentForms Web/src/ApacheAgent Web/src/CgiAgent Web/src/HttpHandler Web/src/IsapiAgent Web/src/viewerfiles
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Dec 9 16:05:10 EST 2009
Author: brucedechant
Date: 2009-12-09 16:05:09 -0500 (Wed, 09 Dec 2009)
New Revision: 4402
Added:
   trunk/MgDev/Common/Schema/SiteInformation-2.2.0.xsd
   trunk/MgDev/Common/Schema/SiteStatus-2.2.0.xsd
   trunk/MgDev/Common/Schema/SiteVersion-2.2.0.xsd
   trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp
   trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.h
   trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp
   trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.h
   trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html
   trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.h
   trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h
   trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h
   trunk/MgDev/Common/ProductVersion.h
   trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
   trunk/MgDev/Server/src/Common/Manager/ServerManager.h
   trunk/MgDev/Server/src/Common/Manager/ServerManager.vcproj
   trunk/MgDev/Server/src/Core/OperationThread.cpp
   trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am
   trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp
   trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp
   trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h
   trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj
   trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp
   trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html
   trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html
   trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html
   trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp
   trunk/MgDev/Web/src/CgiAgent/CgiAgent.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.h
   trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.h
   trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj
   trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
   trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
   trunk/MgDev/Web/src/HttpHandler/Makefile.am
   trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp
   trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
Fix for trac ticket 1195 - Implement RFC 87 - SiteInformation enhancements
http://trac.osgeo.org/mapguide/ticket/1195
Notes:
- Implemented RFC 87
- Made the GetSiteVersion HTTP operation an actual operation instead of using the existing GetInformationProperties. This was mostly done for speed as GetInformationProperties returns way more information then needed for GetSiteVersion.
- Added GetSiteStatus HTTP operation
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -622,6 +622,63 @@
 /// <summary>
+/// Gets the site version.
+/// </summary>
+/// <returns>
+/// The site version.
+/// </returns>
+/// EXCEPTIONS:
+/// MgConnectionNotOpenException
+STRING MgServerAdmin::GetSiteVersion()
+    MgCommand cmd;
+    cmd.ExecuteCommand(m_connProp,                                // Connection
+                        MgCommand::knString,                      // Return type expected
+                        MgServerAdminServiceOpId::GetSiteVersion, // Command Code
+                        0,                                        // No of arguments
+                        ServerAdmin_Service,                      // Service Id
+                        BUILD_VERSION(1,0,0),                     // Operation version
+                        MgCommand::knNone);
+    SetWarning(cmd.GetWarningObject());
+    STRING retVal = *(cmd.GetReturnValue().val.m_str);
+    delete cmd.GetReturnValue().val.m_str;
+    return retVal;
+/// <summary>
+/// Gets the status properties for the server.
+/// </summary>
+/// <returns>
+/// The collection of status properties.
+/// </returns>
+/// EXCEPTIONS:
+MgPropertyCollection* MgServerAdmin::GetSiteStatus()
+    MgCommand cmd;
+                        MgCommand::knObject,                     // Return type expected
+                        MgServerAdminServiceOpId::GetSiteStatus, // Command Code
+                        BUILD_VERSION(2,2,0),                    // Operation version
+    return (MgPropertyCollection*)cmd.GetReturnValue().val.m_obj;
+/// <summary>
 /// Delete the specified package, if able.
 /// </summary>
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdmin.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -365,6 +365,28 @@
     /// \brief
+    /// Gets the site version.
+    /// \return
+    /// The site version.
+    /// \exception MgConnectionNotOpenException
+    STRING GetSiteVersion();
+    /// \brief
+    /// Gets the status properties for the server.
+    /// \return
+    /// The collection of status properties.
+    MgPropertyCollection* GetSiteStatus();
+    /// \brief
     /// \param packageName
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -76,3 +76,9 @@
 const STRING MgServerInformationProperties::TotalConnections            = L"TotalConnections";
 const STRING MgServerInformationProperties::TotalActiveConnections      = L"TotalActiveConnections";
 const STRING MgServerInformationProperties::OperatingSystemVersion      = L"OperatingSystemVersion";
+const STRING MgServerInformationProperties::ApiVersion                  = L"ApiVersion";
+const STRING MgServerInformationProperties::MachineIp                   = L"MachineIp";
+const STRING MgServerInformationProperties::WorkingSet                  = L"WorkingSet";
+const STRING MgServerInformationProperties::VirtualMemory               = L"VirtualMemory";
+const STRING MgServerInformationProperties::CacheSize                   = L"CacheSize";
+const STRING MgServerInformationProperties::CacheDroppedEntries         = L"CacheDroppedEntries";
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ServerAdminDefs.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -114,6 +114,8 @@
     /// The server's version
     static const STRING ServerVersion;              /// value("ServerVersion")
+    /// The API version
+    static const STRING ApiVersion;                 /// value("ApiVersion")
     /// STATISTIC PROPERTIES SECTION -----------------------------------------------------------------------------------
@@ -156,6 +158,9 @@
     /// Gets the server display name
     static const STRING DisplayName;                /// value("DisplayName")
+    /// Gets the server machine Ip
+    static const STRING MachineIp;                  /// value("MachineIp")
     /// Gets the total operations received
     static const STRING TotalReceivedOperations;    /// value("TotalReceivedOperations")
@@ -170,6 +175,18 @@
     /// Gets the operating system version
     static const STRING OperatingSystemVersion;     /// value("OperatingSystemVersion")
+    /// Gets the process working set memory
+    static const STRING WorkingSet;                 /// value("WorkingSet")
+    /// Gets the process virtual memory
+    static const STRING VirtualMemory;              /// value("VirtualMemory")
+    /// Gets the current size of the server cache
+    static const STRING CacheSize;                  /// value("CacheSize")
+    /// Gets the number of dropped cache entries
+    static const STRING CacheDroppedEntries;        /// value("CacheDroppedEntries")
@@ -209,6 +226,8 @@
     static const int NotifyResourcesChanged         = 0x1111EA1A;
     static const int MakePackage                    = 0x1111EA1B;
     static const int RemoveConfigurationProperties  = 0x1111EA1C;
+    static const int GetSiteVersion                 = 0x1111EA1D;
+    static const int GetSiteStatus                  = 0x1111EA1E;
 /// \endcond
Modified: trunk/MgDev/Common/ProductVersion.h
--- trunk/MgDev/Common/ProductVersion.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Common/ProductVersion.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -19,5 +19,6 @@
 #define PRODUCTVERSION_H_
 const STRING ProductVersion = L"2.2.0.0";
+const STRING ApiVersion     = L"2.2";  // Major.Minor only
 #endif // PRODUCTVERSION_H_
Added: trunk/MgDev/Common/Schema/SiteInformation-2.2.0.xsd
--- trunk/MgDev/Common/Schema/SiteInformation-2.2.0.xsd	                        (rev 0)
+++ trunk/MgDev/Common/Schema/SiteInformation-2.2.0.xsd	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,157 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2.2.0">
+  <xs:element name="SiteInformation">
+    <xs:annotation>
+      <xs:documentation>Site Information</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+      <xs:complexContent>
+        <xs:extension base="SiteInformationType">
+          <xs:attribute name="version" type="xs:string" fixed="2.2.0"/>
+        </xs:extension>
+      </xs:complexContent>
+    </xs:complexType>
+  </xs:element>
+    <xs:complexType name="SiteInformationType">
+      <xs:sequence>
+        <xs:element name="Server">
+          <xs:complexType>
+            <xs:sequence>
+              <xs:element name="IpAddress" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's Ip address.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="DisplayName" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's display name.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="Status" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's status. Either Online or Offline</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="Version" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's version.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="OperatingSystem">
+                <xs:complexType>
+                  <xs:sequence>
+                    <xs:element name="AvailablePhysicalMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The available physical memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalPhysicalMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total physical memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="AvailableVirtualMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The available virtual memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalVirtualMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total virtual memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                      <xs:annotation>
+                          <xs:documentation>The operating system version.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                  </xs:sequence>
+                </xs:complexType>
+              </xs:element>
+              <xs:element name="Statistics">
+                <xs:complexType>
+                  <xs:sequence>
+                    <xs:element name="AdminOperationsQueueCount" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of operations in the Admin queue.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="ClientOperationsQueueCount" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of operations in the Client queue.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="SiteOperationsQueueCount" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of operations in the Site queue.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="AverageOperationTime" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The average time it takes to process an operation in milliseconds.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="CpuUtilization" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The cpu utilization as a percentage.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="WorkingSet" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The working set memory of the MapGuide server in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="VirtualMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The virtual memory of the MapGuide server in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalOperationTime" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total operation time of the MapGuide server in seconds.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="ActiveConnections" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of active connections to the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalConnections" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of connections that have been made to the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalOperationsProcessed" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of operations processed by the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalOperationsReceived" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of operations received by the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="Uptime" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total time the MapGuide server has been running in seconds.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="CacheSize" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The current number of entries in the MapGuide server cache.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="CacheDroppedEntries" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of entries in the MapGuide server cache that have been dropped.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                  </xs:sequence>
+                </xs:complexType>
+              </xs:element>
+            </xs:sequence>
+          </xs:complexType>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Property changes on: trunk/MgDev/Common/Schema/SiteInformation-2.2.0.xsd
___________________________________________________________________
Added: svn:eol-style
   + native
Added: trunk/MgDev/Common/Schema/SiteStatus-2.2.0.xsd
--- trunk/MgDev/Common/Schema/SiteStatus-2.2.0.xsd	                        (rev 0)
+++ trunk/MgDev/Common/Schema/SiteStatus-2.2.0.xsd	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,40 @@
+    <xs:annotation>
+      <xs:documentation>Site Status</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="SiteStatusType">
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+    <xs:complexType name="SiteStatusType">
+      <xs:sequence>
+          <xs:complexType>
+            <xs:sequence>
+                <xs:annotation>
+                </xs:annotation>
+              </xs:element>
+                <xs:annotation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="ApiVersion" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's API version.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+            </xs:sequence>
+          </xs:complexType>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Property changes on: trunk/MgDev/Common/Schema/SiteStatus-2.2.0.xsd
   + native
Added: trunk/MgDev/Common/Schema/SiteVersion-2.2.0.xsd
--- trunk/MgDev/Common/Schema/SiteVersion-2.2.0.xsd	                        (rev 0)
+++ trunk/MgDev/Common/Schema/SiteVersion-2.2.0.xsd	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,30 @@
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+  <xs:element name="SiteVersion">
+    <xs:annotation>
+      <xs:documentation>Site Version</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="SiteVersionType">
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+    <xs:complexType name="SiteVersionType">
+      <xs:sequence>
+          <xs:complexType>
+            <xs:sequence>
+                <xs:annotation>
+                </xs:annotation>
+              </xs:element>
+            </xs:sequence>
+          </xs:complexType>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Property changes on: trunk/MgDev/Common/Schema/SiteVersion-2.2.0.xsd
   + native
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -23,6 +23,14 @@
 #include "WorkerThread.h"
 #include "WorkerThreadData.h"
+#ifdef _WIN32
+#include <Psapi.h>
+#else
+#include <sys/time.h>
+#include <sys/resource.h>
+#include <unistd.h>
+#endif
 const STRING MgServerManager::DocumentExtension = L".awd";
 const STRING MgServerManager::DocumentPath      = L"DocumentPath";
@@ -444,8 +452,8 @@
     pProperties->Add(pProperty);
     // Add the Uptime
-    INT32 nUptime = GetUptime();
-    pProperty = new MgInt32Property(MgServerInformationProperties::Uptime, nUptime);
+    time_t nUptime = GetUptime();
+    pProperty = new MgInt64Property(MgServerInformationProperties::Uptime, nUptime);
     // Add the TotalPhysicalMemory
@@ -469,13 +477,13 @@
     // Add the TotalOperationTime
-    INT32 nTotalOperationTime = GetTotalOperationTime();
-    pProperty = new MgInt32Property(MgServerInformationProperties::TotalOperationTime, nTotalOperationTime);
+    time_t nTotalOperationTime = GetTotalOperationTime();
+    pProperty = new MgInt64Property(MgServerInformationProperties::TotalOperationTime, nTotalOperationTime);
     // Add the AverageOperationTime
-    INT32 nAverageOperationTime = GetAverageOperationTime();
-    pProperty = new MgInt32Property(MgServerInformationProperties::AverageOperationTime, nAverageOperationTime);
+    time_t nAverageOperationTime = GetAverageOperationTime();
+    pProperty = new MgInt64Property(MgServerInformationProperties::AverageOperationTime, nAverageOperationTime);
     // Add the server Version
@@ -486,6 +494,10 @@
     pProperty = new MgStringProperty(MgServerInformationProperties::DisplayName, m_displayName);
+    // Add the MachineIp
+    pProperty = new MgStringProperty(MgServerInformationProperties::MachineIp, m_localServerAddress);
+    pProperties->Add(pProperty);
      // Add the Operations info
     INT32 nTotalReceivedOperations = GetTotalReceivedOperations();
     pProperty = new MgInt32Property(MgServerInformationProperties::TotalReceivedOperations, nTotalReceivedOperations);
@@ -509,11 +521,105 @@
     pProperty = new MgStringProperty(MgServerInformationProperties::OperatingSystemVersion, osVersion);
+#ifdef _WIN32
+    HANDLE procHandle = GetCurrentProcess();
+    PROCESS_MEMORY_COUNTERS counters;
+    counters.cb = sizeof(counters);
+    BOOL ok = GetProcessMemoryInfo(procHandle, &counters, sizeof(counters));
+    if (ok)
+        pProperty = new MgInt64Property(MgServerInformationProperties::WorkingSet, counters.WorkingSetSize);
+        pProperty = new MgInt64Property(MgServerInformationProperties::VirtualMemory, counters.PagefileUsage);
+#else
+    // getrusage does not work on Linux so pull information directly
+    // from proc filesystem.
+    int pageSize = getpagesize();
+    char procName[256];
+    sprintf(procName,"/proc/%d/status",getpid());
+    FILE* fp = fopen(procName,"rb");
+    if (NULL != fp)
+        char buf[1024];
+        memset(buf,0,1024);
+        fread(buf, 1024, 1, fp);
+        fclose(fp);
+        char* strRss = "VmRSS:";
+        char* end = NULL;
+        char* loc = strstr(buf, strRss);
+        if (NULL != loc)
+            long kbytes = strtol(loc + strlen(strRss) + 1, &end, 10);
+            INT64 workingSet = kbytes * 1000;
+            pProperty = new MgInt64Property(MgServerInformationProperties::WorkingSet, workingSet);
+        char* strSize = "VmSize:";
+        loc = strstr(buf, strSize);
+        if (NULL != loc)
+            long kbytes = strtol(loc + strlen(strSize) + 1, &end, 10);
+            pProperty = new MgInt64Property(MgServerInformationProperties::VirtualMemory, workingSet);
+#endif
     MG_CATCH_AND_THROW(L"MgServerManager.GetInformationProperties")
     return pProperties.Detach();
+/// <summary>
+/// </summary>
+STRING MgServerManager::GetSiteVersion()
+    return ProductVersion;
+/// <summary>
+/// </summary>
+MgPropertyCollection* MgServerManager::GetSiteStatus()
+    Ptr<MgPropertyCollection> pProperties;
+    pProperties = NULL;
+    MG_TRY()
+    MG_LOG_TRACE_ENTRY(L"MgServerManager::GetSiteStatus()");
+    pProperties = new MgPropertyCollection();
+    // Add the information properties
+    Ptr<MgProperty> pProperty;
+    // Add the DisplayName
+    pProperty = new MgStringProperty(MgServerInformationProperties::DisplayName, m_displayName);
+    // Add the Status
+    bool bOnline = IsOnline();
+    pProperty = new MgBooleanProperty(MgServerInformationProperties::Status, bOnline);
+    // Add the API Version
+    pProperty = new MgStringProperty(MgServerInformationProperties::ApiVersion, ApiVersion);
+    MG_CATCH_AND_THROW(L"MgServerManager.GetSiteStatus")
+    return pProperties.Detach();
 MgByteReader* MgServerManager::GetDocument(CREFSTRING identifier)
     Ptr<MgByteReader> pByteReader;
@@ -711,12 +817,12 @@
     return m_totalProcessedOperations.value();
-INT32 MgServerManager::GetTotalOperationTime()
+time_t MgServerManager::GetTotalOperationTime()
     return m_totalOperationTime.value();
-void MgServerManager::IncrementOperationTime(INT32 operationTime)
+void MgServerManager::IncrementOperationTime(time_t operationTime)
     m_totalOperationTime += operationTime;
@@ -1022,7 +1128,7 @@
 /// EXCEPTIONS:
-INT32 MgServerManager::GetUptime()
+time_t MgServerManager::GetUptime()
     ACE_Time_Value upTime(0);
@@ -1032,7 +1138,7 @@
     MG_CATCH_AND_THROW(L"MgServerManager.GetUptime");
-    return (INT32)upTime.sec();
+    return upTime.sec();
@@ -1045,7 +1151,7 @@
 /// EXCEPTIONS:
-INT32 MgServerManager::GetAverageOperationTime()
+time_t MgServerManager::GetAverageOperationTime()
     double avgTime = 0.0;
@@ -1059,7 +1165,7 @@
     MG_CATCH_AND_THROW(L"MgServerManager.GetAverageOperationTime")
-    return (INT32)avgTime;
+    return time_t(avgTime);
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.h
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -36,6 +36,7 @@
 class MgWorkerThread;
 typedef ACE_Atomic_Op<ACE_Thread_Mutex, INT32>  SAFE_INT32;
+typedef ACE_Atomic_Op<ACE_Thread_Mutex, time_t>  SAFE_TIME_T;
 class MG_SERVER_MANAGER_API MgServerManager : public MgGuardDisposable
@@ -60,6 +61,8 @@
     void RemoveConfigurationProperties(CREFSTRING propertySection, MgPropertyCollection* properties);
     MgPropertyCollection* GetInformationProperties();
     MgByteReader* GetDocument(CREFSTRING identifier);
     void SetDocument(CREFSTRING identifier, MgByteReader* data);
@@ -97,9 +100,9 @@
     ACE_Time_Value GetStartTime();
     INT32 GetTotalReceivedOperations();
     INT32 GetTotalProcessedOperations();
-    INT32 GetTotalOperationTime();
+    time_t GetTotalOperationTime();
-    void IncrementOperationTime(INT32 operationTime);
+    void IncrementOperationTime(time_t operationTime);
     void IncrementReceivedOperations();
     void IncrementProcessedOperations();
@@ -114,8 +117,8 @@
     INT32 GetClientOperationsQueueCount();
     INT32 GetSiteOperationsQueueCount();
-    INT32 GetUptime();
-    INT32 GetAverageOperationTime();
+    time_t GetUptime();
+    time_t GetAverageOperationTime();
     INT64 GetTotalPhysicalMemory();
     INT64 GetAvailablePhysicalMemory();
@@ -173,7 +176,7 @@
     INT32 m_nSiteThreads;
     ACE_Time_Value m_startTime;
-    SAFE_INT32 m_totalOperationTime;        // This value is tracked in seconds
+    SAFE_TIME_T m_totalOperationTime;        // This value is tracked in seconds
     SAFE_INT32 m_totalReceivedOperations;
     SAFE_INT32 m_totalProcessedOperations;
Modified: trunk/MgDev/Server/src/Common/Manager/ServerManager.vcproj
--- trunk/MgDev/Server/src/Common/Manager/ServerManager.vcproj	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Common/Manager/ServerManager.vcproj	2009-12-09 21:05:09 UTC (rev 4402)
@@ -65,7 +65,7 @@
 			<Tool
 				Name="VCLinkerTool"
-				AdditionalDependencies="ACEd.lib FDO.lib FDOCommon.lib pdh.lib"
+				AdditionalDependencies="ACEd.lib FDO.lib FDOCommon.lib pdh.lib  psapi.lib"
 				OutputFile="$(OutDir)\MgServerManagerd.dll"
 				LinkIncremental="2"
 				AdditionalLibraryDirectories="..\..\..\..\Oem\ACE\ACE_wrappers\lib;..\..\..\..\Oem\FDO\lib"
@@ -147,7 +147,7 @@
 			<Tool
 				Name="VCLinkerTool"
 				LinkIncremental="2"
 				AdditionalLibraryDirectories="..\..\..\..\Oem\ACE\ACE_wrappers\lib64;..\..\..\..\Oem\FDO\lib64"
@@ -225,7 +225,7 @@
 			<Tool
 				Name="VCLinkerTool"
-				AdditionalDependencies="ACE.lib FDO.lib FDOCommon.lib pdh.lib"
+				AdditionalDependencies="ACE.lib FDO.lib FDOCommon.lib pdh.lib  psapi.lib"
 				OutputFile="$(OutDir)\MgServerManager.dll"
 				LinkIncremental="1"
@@ -306,7 +306,7 @@
 			<Tool
 				Name="VCLinkerTool"
 				LinkIncremental="1"
Modified: trunk/MgDev/Server/src/Core/OperationThread.cpp
--- trunk/MgDev/Server/src/Core/OperationThread.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Core/OperationThread.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -408,7 +408,7 @@
             // We increment operations processed for successful operations only.
             if (IMgServiceHandler::mpsDone == stat)
-                INT32 opTime = operationTime.sec();
+                time_t opTime = operationTime.sec();
                 pConnection->IncrementProcessedOperations();
                 pConnection->SetCurrentOperationTime(opTime);
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am
--- trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/Makefile.am	2009-12-09 21:05:09 UTC (rev 4402)
@@ -35,6 +35,8 @@
   OpGetLogFile.cpp \
   OpGetPackageLog.cpp \
   OpGetPackageStatus.cpp \
+  OpGetSiteStatus.cpp \
+  OpGetSiteVersion.cpp \
   OpIsMaximumLogSizeEnabled.cpp \
   OpIsOnline.cpp \
   OpLoadPackage.cpp \
@@ -69,6 +71,8 @@
   OpGetLogFile.h \
   OpGetPackageLog.h \
   OpGetPackageStatus.h \
+  OpGetSiteStatus.h \
+  OpGetSiteVersion.h \
   OpIsMaximumLogSizeEnabled.h \
   OpIsOnline.h \
   OpLoadPackage.h \
Added: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp	                        (rev 0)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,117 @@
+//  Copyright (C) 2004-2009 by Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+#include "MapGuideCommon.h"
+#include "ServerAdminService.h"
+#include "OpGetSiteStatus.h"
+#include "LogManager.h"
+/// <summary>
+/// Constructs the object.
+/// </summary>
+MgOpGetSiteStatus::MgOpGetSiteStatus()
+/// <summary>
+/// Destructs the object.
+/// </summary>
+MgOpGetSiteStatus::~MgOpGetSiteStatus()
+/// <summary>
+/// Gets the role(s) required to perform this operation.
+/// </summary>
+MgStringCollection* MgOpGetSiteStatus::GetRoles() const
+    return NULL; // for anonymous/everyone
+/// <summary>
+/// Executes the operation.
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpGetSiteStatus::Execute()
+    ACE_DEBUG((LM_DEBUG, ACE_TEXT("  (%t) MgOpGetSiteStatus::Execute()\n")));
+    MG_LOG_OPERATION_MESSAGE(L"MgOpGetSiteStatus");
+    MG_TRY()
+    MG_LOG_OPERATION_MESSAGE_INIT(m_packet.m_OperationVersion, m_packet.m_NumArguments);
+    ACE_ASSERT(m_stream != NULL);
+    if (0 == m_packet.m_NumArguments)
+        BeginExecution();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_START();
+        MG_LOG_OPERATION_MESSAGE_PARAMETERS_END();
+        // Authentication not required for this operation
+        //Validate();
+        Ptr<MgPropertyCollection> propertyCollection = m_service->GetSiteStatus();
+        EndExecution(propertyCollection);
+    else
+    if (!m_argsRead)
+        throw new MgOperationProcessingException(L"MgOpGetSiteStatus.Execute",
+            __LINE__, __WFILE__, NULL, L"", NULL);
+    // Successful operation
+    MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Success.c_str());
+    MG_CATCH(L"MgOpGetSiteStatus.Execute")
+    if (mgException != NULL)
+        // Failed operation
+        MG_LOG_OPERATION_MESSAGE_ADD_STRING(MgResources::Failure.c_str());
+    // Add admin log entry for operation
+    MG_LOG_OPERATION_MESSAGE_ADMIN_ENTRY();
+    MG_THROW()
Property changes on: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.cpp
   + native
Added: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.h
--- trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.h	                        (rev 0)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,36 @@
+#ifndef MGOPGETSITESTATUS_H_
+#define MGOPGETSITESTATUS_H_
+#include "ServerAdminOperation.h"
+class MgOpGetSiteStatus : public MgServerAdminOperation
+    public:
+        MgOpGetSiteStatus();
+        virtual ~MgOpGetSiteStatus();
+    public:
+        virtual void Execute();
+    protected:
+        virtual MgStringCollection* GetRoles() const;
+#endif
Property changes on: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteStatus.h
   + native
Added: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp	                        (rev 0)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,116 @@
+#include "OpGetSiteVersion.h"
+/// <summary>
+/// </summary>
+MgOpGetSiteVersion::MgOpGetSiteVersion()
+/// <summary>
+/// </summary>
+MgOpGetSiteVersion::~MgOpGetSiteVersion()
+/// <summary>
+/// </summary>
+MgStringCollection* MgOpGetSiteVersion::GetRoles() const
+/// <summary>
+/// </summary>
+/// <exceptions>
+/// MgException
+/// </exceptions>
+void MgOpGetSiteVersion::Execute()
+    ACE_DEBUG((LM_DEBUG, ACE_TEXT("  (%t) MgOpGetSiteVersion::Execute()\n")));
+    MG_LOG_OPERATION_MESSAGE(L"MgOpGetSiteVersion");
+    MG_TRY()
+        BeginExecution();
+        Validate();
+        STRING version = m_service->GetSiteVersion();
+        EndExecution(version);
+    else
+    if (!m_argsRead)
+        throw new MgOperationProcessingException(L"MgOpGetSiteVersion.Execute",
+    MG_CATCH(L"MgOpGetSiteVersion.Execute")
+    MG_THROW()
Property changes on: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.cpp
   + native
Added: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.h
--- trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.h	                        (rev 0)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,36 @@
+#ifndef MGOPGETSITEVERSION_H_
+#define MGOPGETSITEVERSION_H_
+class MgOpGetSiteVersion : public MgServerAdminOperation
+    public:
+        MgOpGetSiteVersion();
+        virtual ~MgOpGetSiteVersion();
+    public:
+    protected:
+#endif
Property changes on: trunk/MgDev/Server/src/Services/ServerAdmin/OpGetSiteVersion.h
   + native
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminOperationFactory.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -35,6 +35,8 @@
 #include "OpGetLogFile.h"
 #include "OpGetPackageLog.h"
 #include "OpGetPackageStatus.h"
 #include "OpIsMaximumLogSizeEnabled.h"
 #include "OpIsOnline.h"
 #include "OpLoadPackage.h"
@@ -301,6 +303,28 @@
         break;
+    case MgServerAdminServiceOpId::GetSiteVersion:
+        switch (VERSION_NO_PHASE(operationVersion))
+        case VERSION_SUPPORTED(1,0):    // Original 1.0 operation actually called GetInformationProperties
+            handler.reset(new MgOpGetSiteVersion());
+            break;
+        default:
+            break;
+        break;
+    case MgServerAdminServiceOpId::GetSiteStatus:
+        case VERSION_SUPPORTED(2,2):
+            handler.reset(new MgOpGetSiteStatus());
+            break;
+        default:
+            break;
+        break;
     case MgServerAdminServiceOpId::RegisterServicesOnServers :
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -550,6 +550,57 @@
+/// <summary>
+/// </summary>
+STRING MgServerAdminService::GetSiteVersion()
+    STRING version = L"";
+    MG_TRY()
+    MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetSiteVersion()");
+    MgServerManager* pMan = MgServerManager::GetInstance();
+    if (NULL == pMan)
+        throw new MgNullReferenceException(L"MgServerAdminService::GetSiteVersion", __LINE__, __WFILE__, NULL, L"", NULL);
+    version = pMan->GetSiteVersion();
+    MG_CATCH_AND_THROW(L"MgServerAdminService.GetSiteVersion");
+    return version;
+/// <summary>
+/// </summary>
+MgPropertyCollection* MgServerAdminService::GetSiteStatus()
+    MG_TRY()
+    MG_LOG_TRACE_ENTRY(L"MgServerAdminService::GetSiteStatus()");
+    if (NULL == pMan)
+        throw new MgNullReferenceException(L"MgServerAdminService::GetSiteStatus", __LINE__, __WFILE__, NULL, L"", NULL);
+    pProperties = pMan->GetSiteStatus();
+    MG_CATCH_AND_THROW(L"MgServerAdminService.GetSiteStatus");
 /// <summary>
 /// Registers services on the specified servers.
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -62,6 +62,8 @@
     // Service Management Methods
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminService.vcproj	2009-12-09 21:05:09 UTC (rev 4402)
@@ -951,6 +951,86 @@
 			</File>
 			<File
+				RelativePath=".\OpGetSiteStatus.cpp"
+				<FileConfiguration
+					Name="Debug|Win32"
+					ExcludedFromBuild="true"
+					<Tool
+						Name="VCCLCompilerTool"
+				</FileConfiguration>
+					Name="Debug|x64"
+					<Tool
+					Name="Release|Win32"
+					<Tool
+					Name="Release|x64"
+					<Tool
+			</File>
+			<File
+				RelativePath=".\OpGetSiteStatus.h"
+			</File>
+			<File
+				RelativePath=".\OpGetSiteVersion.cpp"
+					<Tool
+					Name="Debug|x64"
+					<Tool
+					<Tool
+					<Tool
+			</File>
+			<File
+				RelativePath=".\OpGetSiteVersion.h"
+			</File>
+			<File
 				RelativePath=".\OpIsMaximumLogSizeEnabled.cpp"
 				<FileConfiguration
Modified: trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp
--- trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Server/src/Services/ServerAdmin/ServerAdminServiceBuild.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -32,6 +32,8 @@
 #include "OpGetLogFile.cpp"
 #include "OpGetPackageLog.cpp"
 #include "OpGetPackageStatus.cpp"
+#include "OpGetSiteStatus.cpp"
+#include "OpGetSiteVersion.cpp"
 #include "OpIsOnline.cpp"
 #include "OpIsMaximumLogSizeEnabled.cpp"
 #include "OpLoadPackage.cpp"
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteinfoform.html	2009-12-09 21:05:09 UTC (rev 4402)
@@ -13,7 +13,7 @@
         <b>Operation:</b>
         <input type="text" name="OPERATION" value="GETSITEINFO" size="50" ID="Text1">
         <p> Version:
-        <input type="text" name="VERSION" value="1.0.0" size="10" ID="Text2">
+        <input type="text" name="VERSION" value="2.2.0" size="10" ID="Text2">
         <p> Locale:
         <input type="text" name="LOCALE" value="en" size="10" ID="Text4">
         <p> Client Agent:
Added: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html	                        (rev 0)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,25 @@
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
+<html>
+    <head>
+        <title></title>
+        <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
+        <meta name="GENERATOR" content="Microsoft Visual Studio .NET 7.1">
+        <meta name="vs_targetSchema" content="http://schemas.microsoft.com/intellisense/ie5">
+        <script type="text/javascript" src="setactiontarget.js" >
+        </script>
+    </head>
+    <body>
+        <form name="input" action="" method="get" ID="Form1">
+        <b>Operation:</b>
+        <input type="text" name="OPERATION" value="GETSITESTATUS" size="50" ID="Text1">
+        <p> Version:
+        <input type="text" name="VERSION" value="2.1.0" size="10" ID="Text2">
+        <p> Locale:
+        <input type="text" name="LOCALE" value="en" size="10" ID="Text4">
+        <p> Client Agent:
+        <input type="text" name="CLIENTAGENT" value="MapGuide Developer" size="100">
+        <p>
+        <input type="submit" value="Submit" onclick="SetActionTarget()"> <input type="reset">
+        </form>
+    </body>
+</html>
Property changes on: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsitestatusform.html
   + native
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/getsiteversionform.html	2009-12-09 21:05:09 UTC (rev 4402)
@@ -13,7 +13,7 @@
         <b>Operation:</b>
         <input type="text" name="OPERATION" value="GETSITEVERSION" size="50" ID="Text1">
         <p> Version:
         <p> Locale:
         <p> Client Agent:
Modified: trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html
--- trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/UnitTest/WebTier/MapAgent/MapAgentForms/siteserviceapi.html	2009-12-09 21:05:09 UTC (rev 4402)
@@ -10,8 +10,9 @@
 <ul>
 <li><a href="enumerateusersform.html" target="showform">EnumerateUsers</a>
 <li><a href="enumerategroupsform.html" target="showform">EnumerateGroups</a>
+<li><a href="getsiteinfoform.html" target="showform">GetSiteInfo</a>
+<li><a href="getsitestatusform.html" target="showform">GetSiteStatus</a>
 <li><a href="getsiteversionform.html" target="showform">GetSiteVersion</a>
-<li><a href="getsiteinfoform.html" target="showform">GetSiteInfo</a>
 </ul>
 </body>
Modified: trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp
--- trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/ApacheAgent/ApacheAgent.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -202,6 +202,13 @@
         if (!bValid)
             bValid = params->GetXmlPostData().length() != 0;
+        // Certain operations do not require authentication
+        STRING operation = params->GetParameterValue(L"OPERATION");
+        if((_wcsicmp(operation.c_str(), L"GETSITESTATUS") == 0))
+            bValid = true;
         if (!bValid)
             // Invalid authentication information is not fatal, we should continue.
Modified: trunk/MgDev/Web/src/CgiAgent/CgiAgent.cpp
--- trunk/MgDev/Web/src/CgiAgent/CgiAgent.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/CgiAgent/CgiAgent.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -210,6 +210,13 @@
             if (!bValid)
+                bValid = true;
             if (!bValid)
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -52,14 +52,79 @@
     // Check common parameters
     ValidateCommonParameters();
-    // Create ServerAdmin object
-    Ptr<MgServerAdmin> serverAdmin = new MgServerAdmin();
-    serverAdmin->Open(m_userInfo);
+    STRING xml;
+    xml += BeginXml();
-    // call the C++ APIs
-    Ptr<MgPropertyCollection> properties = serverAdmin->GetInformationProperties();
-    STRING xml = GetXml(properties);
+    if (m_userInfo->GetApiVersion() >= MG_API_VERSION(2,2,0))
+        MgSiteManager* siteManager = MgSiteManager::GetInstance();
+        if(siteManager)
+            MgSiteVector* sites = siteManager->GetSites();
+            if(sites)
+                for(size_t i=0;i<sites->size();i++)
+                    MgSiteInfo* siteInfo = sites->at(i);
+                    // Check the server status - though this status could be out of date and an exception might be thrown
+                    bool bHaveSiteInfo = false;
+                    STRING message = MgResources::Unknown;
+                    if (MgSiteInfo::Ok == siteInfo->GetStatus())
+                        MG_HTTP_HANDLER_TRY()
+                        // Create ServerAdmin object
+                        Ptr<MgServerAdmin> serverAdmin = new MgServerAdmin();
+                        serverAdmin->Open(siteInfo->GetTarget(), m_userInfo);
+                        // call the C++ APIs
+                        Ptr<MgPropertyCollection> properties = serverAdmin->GetInformationProperties();
+                        xml += GetXml(properties);
+                        bHaveSiteInfo = true;
+                        MG_HTTP_HANDLER_CATCH(L"MgHttpGetSiteInfo.Execute")
+                            message = mgException->GetMessage();
+                    if(!bHaveSiteInfo)
+                        // This server is not available
+                        xml += L"\t<Server>\n";
+                        xml += L"\t\t<IpAddress>";
+                        xml += siteInfo->GetTarget();
+                        xml += L"</IpAddress>\n";
+                        xml += L"\t\t<DisplayName></DisplayName>\n";
+                        xml += L"\t\t<Status>";
+                        xml += message;
+                        xml += L"</Status>\n";
+                        xml += L"\t\t<Version></Version>\n";
+                        xml += L"\t\t<OperatingSystem></OperatingSystem>\n";
+                        xml += L"\t\t<Statistics></Statistics>\n";
+                        xml += L"\t</Server>\n";
+    else
+        serverAdmin->Open(m_userInfo);
+    xml += EndXml();
     Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(xml);
     if(!value)
         throw new MgOutOfMemoryException(L"", __LINE__, __WFILE__, NULL, L"", NULL);
@@ -69,6 +134,32 @@
     MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteInfo.Execute")
+STRING MgHttpGetSiteInfo::BeginXml()
+    STRING xml = L"";
+    xml += L"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
+        xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-2.2.0.xsd\">\n";
+    else
+        xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-1.0.0.xsd\">\n";
+    return xml;
+STRING MgHttpGetSiteInfo::EndXml()
+    STRING xml = L"";
+    xml = L"</SiteInformation>\n";
+    return xml;
 STRING MgHttpGetSiteInfo::GetXml(MgPropertyCollection* properties)
     STRING xml;
@@ -78,11 +169,23 @@
     Ptr<MgInt32Property> int32Prop;
     Ptr<MgBooleanProperty> boolProp;
-    // this XML follows the SiteInformation-1.0.0.xsd schema
-    xml += L"<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n";
-    xml += L"<SiteInformation xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteInformation-1.0.0.xsd\">\n";
-    xml += L"\t<SiteServer>\n";
+    else
+        xml += L"\t<SiteServer>\n";
+        strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::MachineIp);
+        xml += strProp->GetValue();
     xml += L"\t\t<DisplayName>";
     strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::DisplayName);
@@ -131,7 +234,10 @@
     xml += L"\t\t</OperatingSystem>\n";
-    xml += L"\t</SiteServer>\n";
+    if (m_userInfo->GetApiVersion() == MG_API_VERSION(1,0,0))
+        xml += L"\t</SiteServer>\n";
     xml += L"\t<Statistics>\n";
@@ -165,6 +271,21 @@
     xml += MgUtil::MultiByteToWideChar(tmpStr);
     xml += L"</CpuUtilization>\n";
+        xml += L"\t\t<WorkingSet>";
+        int64Prop = (MgInt64Property*)properties->GetItem(MgServerInformationProperties::WorkingSet);
+        MgUtil::Int64ToString(int64Prop->GetValue(), tmpStr);
+        xml += MgUtil::MultiByteToWideChar(tmpStr);
+        xml += L"</WorkingSet>\n";
+        xml += L"\t\t<VirtualMemory>";
+        int64Prop = (MgInt64Property*)properties->GetItem(MgServerInformationProperties::VirtualMemory);
+        xml += L"</VirtualMemory>\n";
     xml += L"\t\t<TotalOperationTime>";
     int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::TotalOperationTime);
     MgUtil::Int32ToString(int32Prop->GetValue(), tmpStr);
@@ -201,9 +322,27 @@
     xml += L"</Uptime>\n";
+        xml += L"\t\t<CacheSize>";
+        int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::CacheSize);
+        MgUtil::Int32ToString(int32Prop->GetValue(), tmpStr);
+        xml += L"</CacheSize>\n";
+        xml += L"\t\t<CacheDroppedEntries>";
+        int32Prop = (MgInt32Property*)properties->GetItem(MgServerInformationProperties::CacheDroppedEntries);
+        xml += L"</CacheDroppedEntries>\n";
     xml += L"\t</Statistics>\n";
-    xml += L"</SiteInformation>\n";
     return xml;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteInfo.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -46,6 +46,8 @@
 private:
     STRING GetXml(MgPropertyCollection* properties);
+    STRING BeginXml();
+    STRING EndXml();
 #endif
Added: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp	                        (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,163 @@
+#include "HttpHandler.h"
+#include "HttpGetSiteStatus.h"
+HTTP_IMPLEMENT_CREATE_OBJECT(MgHttpGetSiteStatus)
+/// <summary>
+/// Initializes the common parameters and parameters specific to this request.
+/// </summary>
+/// <param name="name">Input
+/// MgHttpRequest
+/// This contains all the parameters of the request.
+/// </param>
+/// <returns>
+/// nothing
+/// </returns>
+MgHttpGetSiteStatus::MgHttpGetSiteStatus(MgHttpRequest *hRequest)
+    InitializeCommonParameters(hRequest);
+/// <summary>
+/// Executes the specific request.
+/// </summary>
+/// <returns>
+/// MgHttpResponse
+/// This contains the response (including MgHttpResult and StatusCode) from the server.
+/// </returns>
+void MgHttpGetSiteStatus::Execute(MgHttpResponse& hResponse)
+    Ptr<MgHttpResult> hResult = hResponse.GetResult();
+    // Check common parameters
+    ValidateCommonParameters();
+    STRING xml = BeginXml();
+    if(siteManager)
+        if(sites)
+                bool bHaveSiteStatus = false;
+                    Ptr<MgPropertyCollection> properties = serverAdmin->GetSiteStatus();
+                    bHaveSiteStatus = true;
+                    MG_HTTP_HANDLER_CATCH(L"MgHttpGetSiteStatus.Execute")
+                if(!bHaveSiteStatus)
+                    xml += message;
+                    xml += L"\t\t<ApiVersion></ApiVersion>\n";
+    xml += EndXml();
+    Ptr<MgHttpPrimitiveValue> value = new MgHttpPrimitiveValue(xml);
+    if(!value)
+        throw new MgOutOfMemoryException(L"", __LINE__, __WFILE__, NULL, L"", NULL);
+    hResult->SetResultObject(value, MgMimeType::Xml);
+    MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteStatus.Execute")
+STRING MgHttpGetSiteStatus::BeginXml()
+    STRING xml = L"";
+    // this XML follows the SiteStatus-2.2.0.xsd schema
+    xml += L"<SiteStatus xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteStatus-2.2.0.xsd\">\n";
+    return xml;
+STRING MgHttpGetSiteStatus::EndXml()
+    STRING xml = L"";
+    xml = L"</SiteStatus>\n";
+    return xml;
+STRING MgHttpGetSiteStatus::GetXml(MgPropertyCollection* properties)
+    STRING xml = L"";
+    Ptr<MgStringProperty> strProp;
+    Ptr<MgBooleanProperty> boolProp;
+    xml += L"\t\t<DisplayName>";
+    strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::DisplayName);
+    xml += L"</DisplayName>\n";
+    boolProp = (MgBooleanProperty*)properties->GetItem(MgServerInformationProperties::Status);
+    xml += boolProp->GetValue() ? L"Online" : L"Offline";
+    xml += L"\t\t<ApiVersion>";
+    strProp = (MgStringProperty*)properties->GetItem(MgServerInformationProperties::ApiVersion);
+    xml += L"</ApiVersion>\n";
+    return xml;
Property changes on: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.cpp
   + native
Added: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.h	                        (rev 0)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -0,0 +1,52 @@
+#ifndef _S_GET_SITE_STATUS_H
+#define _S_GET_SITE_STATUS_H
+class MgHttpGetSiteStatus : public MgHttpRequestResponseHandler
+HTTP_DECLARE_CREATE_OBJECT()
+public:
+    /// <summary>
+    /// Initializes the common parameters of the request.
+    /// </summary>
+    /// <param name="name">Input
+    /// MgHttpRequest
+    /// This contains all the parameters of the request.
+    /// </param>
+    /// <returns>
+    /// nothing
+    /// </returns>
+    MgHttpGetSiteStatus(MgHttpRequest *hRequest);
+    /// <summary>
+    /// Executes the specific request.
+    /// </summary>
+    /// <param name="hResponse">Input
+    /// This contains the response (including MgHttpResult and StatusCode) from the server.
+    /// </param>
+    void Execute(MgHttpResponse& hResponse);
+private:
+    STRING GetXml(MgPropertyCollection* properties);
+    STRING EndXml();
+#endif
Property changes on: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteStatus.h
   + native
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -51,14 +51,72 @@
+    STRING xml;
+        if(siteManager)
+            if(sites)
+                    bool bHaveSiteVersion = false;
+                        STRING version = serverAdmin->GetSiteVersion();
+                        xml += GetXml(version);
+                        bHaveSiteVersion = true;
+                    if(!bHaveSiteVersion)
+                        xml += L"\t\t<Version>";
+                        xml += message;
+                        xml += L"</Version>\n";
+    else
+    xml += EndXml();
     if(!value)
@@ -68,18 +126,49 @@
     MG_HTTP_HANDLER_CATCH_AND_THROW_EX(L"MgHttpGetSiteVersion.Execute")
-STRING MgHttpGetSiteVersion::GetXml(MgPropertyCollection* properties)
+STRING MgHttpGetSiteVersion::BeginXml()
-    Ptr<MgStringProperty> property = (MgStringProperty*)properties->GetItem(L"ServerVersion");
     STRING xml = L"";
-    // this XML follows the SiteVersion-1.0.0.xsd schema
-    xml += L"<SiteVersion xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteVersion-1.0.0.xsd\">\n";
+        xml += L"<SiteVersion xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteVersion-2.2.0.xsd\">\n";
+    else
+        xml += L"<SiteVersion xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xsi:noNamespaceSchemaLocation=\"SiteVersion-1.0.0.xsd\">\n";
+    return xml;
+STRING MgHttpGetSiteVersion::EndXml()
+    STRING xml = L"";
+    xml += L"</SiteVersion>\n";
+    return xml;
+STRING MgHttpGetSiteVersion::GetXml(CREFSTRING version)
+    STRING xml = L"";
     xml += L"\t<Version>";
-    xml += property->GetValue();
+    xml += version;
     return xml;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.h
--- trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpGetSiteVersion.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -44,7 +44,9 @@
 private:
-    STRING GetXml(MgPropertyCollection* properties);
+    STRING GetXml(CREFSTRING version);
+    STRING EndXml();
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj
--- trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandler.vcproj	2009-12-09 21:05:09 UTC (rev 4402)
@@ -2723,6 +2723,46 @@
 			</File>
 			<File
+				RelativePath=".\HttpGetSiteStatus.cpp"
+					<Tool
+					Name="Debug|x64"
+					<Tool
+					<Tool
+					<Tool
+			</File>
+			<File
+				RelativePath=".\HttpGetSiteStatus.h"
+			</File>
+			<File
 				RelativePath=".\HttpGetSiteVersion.cpp"
 				<FileConfiguration
Modified: trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpHandlerBuild.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -85,6 +85,7 @@
 #include "HttpGetIdentityProperties.cpp"
 #include "HttpGetSchemaMapping.cpp"
 #include "HttpGetSiteInfo.cpp"
+#include "HttpGetSiteStatus.cpp"
 #include "HttpGetSiteVersion.cpp"
 #include "HttpGetSpatialContexts.cpp"
 #include "HttpGetTileImage.cpp"
Modified: trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpRequest.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -353,6 +353,7 @@
     httpClassCreators[MgHttpResourceStrings::opEnumerateGroups] = MgHttpEnumerateGroups::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetSiteVersion] = MgHttpGetSiteVersion::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetSiteInfo] = MgHttpGetSiteInfo::CreateObject;
+    httpClassCreators[MgHttpResourceStrings::opGetSiteStatus] = MgHttpGetSiteStatus::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetDrawingCoordinateSpace] = MgHttpGetDrawingCoordinateSpace::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opCreateSession] = MgHttpCreateSession::CreateObject;
     httpClassCreators[MgHttpResourceStrings::opGetSessionTimeout] = MgHttpGetSessionTimeout::CreateObject;
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -322,6 +322,7 @@
 const STRING MgHttpResourceStrings::opEnumerateGroups = L"ENUMERATEGROUPS";
 const STRING MgHttpResourceStrings::opGetSiteVersion = L"GETSITEVERSION";
 const STRING MgHttpResourceStrings::opGetSiteInfo = L"GETSITEINFO";
+const STRING MgHttpResourceStrings::opGetSiteStatus = L"GETSITESTATUS";
 // Other requests
 const STRING MgHttpResourceStrings::opCreateSession = L"CREATESESSION";
Modified: trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h
--- trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/HttpResourceStrings.h	2009-12-09 21:05:09 UTC (rev 4402)
@@ -327,6 +327,7 @@
     static const STRING opEnumerateGroups;
     static const STRING opGetSiteVersion;
     static const STRING opGetSiteInfo;
+    static const STRING opGetSiteStatus;
     // Other requests
     static const STRING opCreateSession;
Modified: trunk/MgDev/Web/src/HttpHandler/Makefile.am
--- trunk/MgDev/Web/src/HttpHandler/Makefile.am	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/HttpHandler/Makefile.am	2009-12-09 21:05:09 UTC (rev 4402)
@@ -86,6 +86,7 @@
   HttpGetSessionTimeout.cpp \
   HttpGetSiteInfo.cpp \
   HttpGetSiteVersion.cpp \
+  HttpGetSiteStatus.cpp \
   HttpGetSpatialContexts.cpp \
   HttpGetTileImage.cpp \
   HttpGetVisibleMapExtent.cpp \
@@ -207,6 +208,7 @@
   HttpGetSessionTimeout.h \
   HttpGetSiteInfo.h \
   HttpGetSiteVersion.h \
+  HttpGetSiteStatus.h \
   HttpGetSpatialContexts.h \
   HttpGetTileImage.h \
   HttpGetVisibleMapExtent.h \
Modified: trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp
--- trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/IsapiAgent/IsapiAgent.cpp	2009-12-09 21:05:09 UTC (rev 4402)
@@ -169,6 +169,13 @@
         if (!bValid)
+            bValid = true;
         if (!bValid)
Modified: trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ
--- trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ	2009-12-09 19:55:58 UTC (rev 4401)
+++ trunk/MgDev/Web/src/viewerfiles/ajaxmappane.templ	2009-12-09 21:05:09 UTC (rev 4402)
@@ -1737,7 +1737,7 @@
     url = webAgent + "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=" + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeComponent(clientAgent) + "&BEHAVIOR=2";
     url += viewParams;
     document.getElementById("overlay").innerHTML =
-            '<img class="mapImage" name="' + reqId + '" id="mapImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnMapOverlayImageLoaded(event)">';
+            '<img class="mapImage" name="' + reqId + '" id="mapImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnMapOverlayImageLoaded(event)" onerror="return OnMapOverlayImageLoadedError(event)">';
     if (opera)
         document.getElementById("mapImage").src = document.getElementById("mapImage").src;
@@ -1747,7 +1747,7 @@
     url = webAgent + "?OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=2.1.0&SESSION=" + sessionId + "&MAPNAME=" + encodeComponent(mapName) + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeComponent(clientAgent) + "&BEHAVIOR=5&SELECTIONCOLOR=" + selectionColor;
     url += viewParams;
     document.getElementById('selOverlay').innerHTML =
-        '<img class="mapImage" name="' + reqId + '" id="selectionImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnSelectionOverlayImageLoaded(event)">';
+        '<img class="mapImage" name="' + reqId + '" id="selectionImage" src="' + url + '" width=' + mapDevW + ' height=' + mapDevH + ' border=0 vspace=0 hspace=0 style="visibility: hidden; width: ' + mapDevW + 'px; height: ' + mapDevH + 'px;" onload="return OnSelectionOverlayImageLoaded(event)" onerror="return OnSelectionOverlayImageLoadedError(event)">';
     if (opera)
         document.getElementById("selectionImage").src = document.getElementById("selectionImage").src;
@@ -1806,6 +1806,28 @@
     return false;
+function OnMapOverlayImageLoadedError(e)
+    var frmParent = parent.frames["tbFrame"];
+    var objDivRefresh = frmParent.document.getElementById("divRefresh");
+    if(objDivRefresh != null)
+        objDivRefresh.style.display='none';
+    mapLoading = false;
+    var text = this.req.responseText;
+    var startPos = text.indexOf("<h2>");
+    startPos = startPos + 4;
+    var endPos = text.indexOf("</h2>", startPos);
+    var message = text.substring(startPos, endPos);
+    alert(message);
+    return false;
 function OnSelectionOverlayImageLoaded(e)
     if(msie)
@@ -1854,6 +1876,20 @@
     return false;
+function OnSelectionOverlayImageLoadedError(e)
+    alert(message);
+    return false;
 function OnAlternateImageLoaded()
     altimg = document.getElementById(curimg == "mapImage1"? "mapImage2": "mapImage1");
@@ -1890,7 +1926,12 @@
 function RequestFailed(text)
-    //placeholder for debugging output
+    alert(message);
 function DraggingShape(e)
@@ -2928,7 +2969,7 @@
     dr.setRequestHeader("Content-Type", "application/x-www-form-urlencoded");
     dr.send(reqParams);
-    if(dr.responseXML)
+    if(dr.status == 200)
         var env = ParseEnvelope(dr.responseXML.documentElement);
         if(env != null)
@@ -2941,6 +2982,8 @@
             GotoView(centerX, centerY, scale, true, true);
+    else
+        RequestFailed(dr.responseText);
 function ParseEnvelope(xmlRoot)
More information about the mapguide-commits mailing list
