[mapguide-commits] r4735 - in trunk/MgDev:
Common/MapGuideCommon/System Common/PlatformBase/MapLayer
Server/src/Core
svn_mapguide at osgeo.org
Thu Apr 1 16:37:17 EDT 2010
Author: brucedechant
Date: 2010-04-01 16:37:16 -0400 (Thu, 01 Apr 2010)
New Revision: 4735
trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
trunk/MgDev/Server/src/Core/serverconfig.ini
Fix for trac ticket 1303 - Selection of large number of features causes server to crash
http://trac.osgeo.org/mapguide/ticket/1303
Notes:
- Updated the GenerateFilters() API to restrict the filter text size when creating the collection of filters.
Modified: trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp
--- trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2010-04-01 20:04:21 UTC (rev 4734)
+++ trunk/MgDev/Common/MapGuideCommon/System/ConfigProperties.cpp 2010-04-01 20:37:16 UTC (rev 4735)
@@ -64,6 +64,9 @@
#define MG_CONFIG_MIN_JOIN_QUERY_BATCH_SIZE 1
#define MG_CONFIG_MAX_JOIN_QUERY_BATCH_SIZE 10000
+#define MG_CONFIG_MIN_RENDER_SELECTION_SIZE 1000
+#define MG_CONFIG_MAX_RENDER_SELECTION_SIZE 100000
/// Length ranges of string properties
@@ -293,7 +296,7 @@
const STRING MgConfigProperties::RenderingServicePropertyRasterGridSizeOverrideRatioForPlot = L"RasterGridSizeOverrideRatioForPlot";
const double MgConfigProperties::DefaultRenderingServicePropertyRasterGridSizeOverrideRatioForPlot = 0.10;
const STRING MgConfigProperties::RenderingServicePropertyRenderSelectionBatchSize = L"RenderSelectionBatchSize";
-const INT32 MgConfigProperties::DefaultRenderingServicePropertyRenderSelectionBatchSize = 10000;
+const INT32 MgConfigProperties::DefaultRenderingServicePropertyRenderSelectionBatchSize = 50000;
const STRING MgConfigProperties::RenderingServicePropertyClampPoints = L"ClampPoints";
const bool MgConfigProperties::DefaultRenderingServicePropertyClampPoints = false;
const STRING MgConfigProperties::RenderingServicePropertyGeneralizeData = L"GeneralizeData";
@@ -609,7 +612,7 @@
{ MgConfigProperties::RenderingServicePropertyRasterGridSizeForPlot , MgPropertyType::Int32 , 1 , MG_CONFIG_MAX_INT32 , L"" },
{ MgConfigProperties::RenderingServicePropertyMinRasterGridSizeForPlot , MgPropertyType::Int32 , 1 , MG_CONFIG_MAX_INT32 , L"" },
{ MgConfigProperties::RenderingServicePropertyRasterGridSizeOverrideRatioForPlot, MgPropertyType::Double , 0.0 , 1.0 , L"" },
- { MgConfigProperties::RenderingServicePropertyRenderSelectionBatchSize , MgPropertyType::Int32 , 0 , MG_CONFIG_MAX_INT32 , L"" },
+ { MgConfigProperties::RenderingServicePropertyRenderSelectionBatchSize , MgPropertyType::Int32 , MG_CONFIG_MIN_RENDER_SELECTION_SIZE , MG_CONFIG_MAX_RENDER_SELECTION_SIZE , L"" },
{ L"" , 0 , 0.0 , 0.0 , L"" }
Modified: trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp
--- trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2010-04-01 20:04:21 UTC (rev 4734)
+++ trunk/MgDev/Common/PlatformBase/MapLayer/SelectionBase.cpp 2010-04-01 20:37:16 UTC (rev 4735)
@@ -518,8 +518,8 @@
MgStringCollection* MgSelectionBase::GenerateFilters(MgLayerBase* layer,
CREFSTRING className, INT32 selectionSize)
+ const INT32 OR_TEXT_SIZE = 4; // ie: " OR "
Ptr<MgStringCollection> filters;
- INT32 selectionCount = 0;
STRING filter;
bool filterReserved = false;
@@ -542,14 +542,7 @@
m_stream->FromBase64(*sIter);
- if (bFirstSel)
- selText = L"(";
- else
- selText = L" OR (";
+ selText = L"(";
bool bFirstProp = true;
MgLayerBase::IdPropertyList::iterator idIter;
@@ -686,20 +679,24 @@
filterReserved = true;
- filter.append(selText);
- ++selectionCount;
- if (selectionSize > 0 && selectionCount >= selectionSize)
+ if ((selectionSize > 0) && ((filter.length() + selText.length() + OR_TEXT_SIZE) >= selectionSize))
- bFirstSel = true;
filters->Add(filter);
filter.clear();
- selectionCount = 0;
else
+ // Check if the "OR" needs to be added
+ if (!bFirstSel)
+ filter.append(L" OR ");
bFirstSel = false;
+ // Add the selection
+ filter.append(selText);
if (!filter.empty())
Modified: trunk/MgDev/Server/src/Core/serverconfig.ini
--- trunk/MgDev/Server/src/Core/serverconfig.ini 2010-04-01 20:04:21 UTC (rev 4734)
+++ trunk/MgDev/Server/src/Core/serverconfig.ini 2010-04-01 20:37:16 UTC (rev 4735)
@@ -333,7 +333,7 @@
RasterGridSizeForPlot = 50
MinRasterGridSizeForPlot = 5
-RenderSelectionBatchSize = 10000
+RenderSelectionBatchSize = 50000
ClampPoints = 0
GeneralizeData = 0
More information about the mapguide-commits
