[mapguide-commits] r4736 -
sandbox/adsk/2.2gp/Common/CoordinateSystem
svn_mapguide at osgeo.org
Thu Apr 1 18:14:07 EDT 2010
Author: NormOlsen
Date: 2010-04-01 18:14:05 -0400 (Thu, 01 Apr 2010)
New Revision: 4736
sandbox/adsk/2.2gp/Common/CoordinateSystem/CoordSysTransform.cpp
Under certain circumstances, the CoordinateSystem::Transform (MgEnvelope*) function would simply convert the two corners as points. Depending upon coordinate systems involved, this two point transform can be seriously in error. This submission corrects the transformation of an envelope so that the result is always representative of the largest rectangle which includes any and all points which may exist within the source envelope. NOTE: the algorithm in use approximates the complex curves often produced by coordinate conversions with multi-segment polylines. Thus, while more accurate, the solution presented in this submission is _NOT_ a perfect solution.
Modified: sandbox/adsk/2.2gp/Common/CoordinateSystem/CoordSysTransform.cpp
--- sandbox/adsk/2.2gp/Common/CoordinateSystem/CoordSysTransform.cpp 2010-04-01 20:37:16 UTC (rev 4735)
+++ sandbox/adsk/2.2gp/Common/CoordinateSystem/CoordSysTransform.cpp 2010-04-01 22:14:05 UTC (rev 4736)
@@ -25,7 +25,7 @@
using namespace CSLibrary;
-#ifdef WIN32
+#ifdef _WIN32
#ifdef GEOMETRY_EXPORTS
# define MG_GEOMETRY_API __declspec(dllexport)
#else
@@ -408,19 +408,55 @@
///<summary>
-/// Transforms the specified source envelope and returns a new envelope
-/// if the target envelope is NULL, otherwise updates and returns the
-/// target envelope with the values of the transformed source envelope.
+/// Transforms the specified source envelope and returns a new envelope.
///</summary>
///<param name="envelope">
-/// The input MgEnvelope to transform.
+/// The MgEnvelope to be transformed.
///</param>
///<returns>
/// A new MgEnvelope transformed from the specified envelope.
///</returns>
+///<remarks>
+///By its definition, an envelope is a rectangle whose sides are parallel
+///to the X and Y axes of the coordinate system to which the coordinate
+///values are reference the extents of which define the extents of the
+///collection of geometries associated with the envelope. The transformed
+///geometry is an approximation (a very good one we hope) of an envelope
+///in a new and different coordinate system. Since a transformation may
+///include some rotation (among other transofrmation affects), the resulting
+///envelop is often enlarged to meet the above described requirements.
+///</remarks>
MgEnvelope* CCoordinateSystemTransform::Transform(MgEnvelope* envelope)
- MgEnvelope* pEnvelope = NULL;
+ // The following value puts limit on the number of points generated
+ // by the GridLine function which is used below. The value is not an
+ // actual limit, but more a threshold which when exceeded the algorithm
+ // start a clean shut down. Thus, there may be as many as twice this
+ // number of points in a line returned by GridLine. To increase the
+ // accuracy of this function, increase the value of this constant. Of
+ // course, you'll pay a penalty in performance and memory usage.
+ static const INT32 maxPoints = 127;
+ INT32 dimension;
+ double tmpDbl;
+ double magnitude;
+ double xMax = -HUGE_VAL;
+ double yMax = -HUGE_VAL;
+ double zMax = -HUGE_VAL;
+ double xMin = HUGE_VAL;
+ double yMin = HUGE_VAL;
+ double zMin = HUGE_VAL;
+ Ptr<MgEnvelope> pEnvelope;
+ Ptr<MgCoordinate> xyPoint;
+ Ptr<MgLineString> lineString;
+ Ptr<MgCoordinateIterator> stringItr;
+ // Leave commented except for temporary debugging. The printf output gets
+ // sent to stdout and ends up being included in the web-tier HTTP response.
+ // printf("\nTransform(envelope) -- Source: %S Dest: %S\n", m_pCsSource->GetCode().c_str(), m_pCsTarget->GetCode().c_str());
MG_TRY()
if(NULL == envelope)
@@ -428,287 +464,123 @@
throw new MgNullArgumentException(L"MgCoordinateSystemTransform.Transform", __LINE__, __WFILE__, NULL, L"", NULL);
- Ptr<MgCoordinate> lowerLeft = envelope->GetLowerLeftCoordinate();
+ // Extract the two defining corners of this envelope.
+ Ptr<MgCoordinate> lowerLeft = envelope->GetLowerLeftCoordinate();
Ptr<MgCoordinate> upperRight = envelope->GetUpperRightCoordinate();
- Ptr<MgCoordinate> lowerLeftTarget;
- Ptr<MgCoordinate> upperRightTarget;
- // Leave commented except for temporary debugging. The printf output gets
- // sent to stdout and ends up being included in the web-tier HTTP response.
-// printf("\nTransform(envelope) -- Source: %S Dest: %S\n", m_pCsSource->GetCsCode().c_str(), m_pCsTarget->GetCsCode().c_str());
- if((m_pCsSource->GetType() == MgCoordinateSystemType::Projected) && (m_pCsTarget->GetType() == MgCoordinateSystemType::Geographic))
+ // Determine if this is a 3D envelope. Don't know that this is possible,
+ // but the code I modified handles 3D envelopes, so I will too.
+ dimension = upperRight->GetDimension();
+ if (dimension == MgCoordinateDimension::XYZ)
- // This is a projected to geographic transform.
- double ptUpperRightX = upperRight->GetX();
- double ptUpperRightY = upperRight->GetY();
- double ptUpperRightZ = upperRight->GetZ();
- double ptLowerLeftX = lowerLeft->GetX();
- double ptLowerLeftY = lowerLeft->GetY();
- double ptLowerLeftZ = lowerLeft->GetZ();
+ // Extract the Z minimum and maximum.
+ tmpDbl = lowerLeft->GetZ ();
+ if (tmpDbl < zMin) zMin = tmpDbl;
+ if (tmpDbl > zMax) zMax = tmpDbl;
- int dimension = upperRight->GetDimension();
+ tmpDbl = upperRight->GetZ ();
- double ptNWX = ptLowerLeftX;
- double ptNWY = ptUpperRightY;
- double ptSEX = ptUpperRightX;
- double ptSEY = ptLowerLeftY;
+ // Determine a value which represents a good tolerance value for the
+ // GridLine function. A smaller value will provide greater accuracy
+ // at the expense of performance.
+ xyPoint = Transform (lowerLeft);
+ magnitude = fabs (xyPoint->GetX ());
+ tmpDbl = fabs (xyPoint->GetY ());
+ if (tmpDbl > magnitude) magnitude = tmpDbl;
+ xyPoint = Transform (upperRight);
+ tmpDbl = fabs (xyPoint->GetX ());
+ magnitude *= 1.0E-07; // Make this constant even smaller if more accuracy is required.
- double xMax = -HUGE_VAL;
- double yMax = -HUGE_VAL;
- double xMin = HUGE_VAL;
- double yMin = HUGE_VAL;
+ // Extract the other two corners of the envelope.
+ Ptr<MgCoordinate> upperLeft = new MgCoordinateXY (lowerLeft->GetX (),upperRight->GetY ());
+ Ptr<MgCoordinate> lowerRight = new MgCoordinateXY (upperRight->GetX (),lowerLeft->GetY ());
- int i;
- // compute the max and min longitude along the top and bottom borders
- double xInc = (ptNWX - ptSEX) / 100.0;
- double tempX;
- double tempY;
- for (i = 0; i <= 100; i++)
- tempX = ptSEX + i * xInc;
- tempY = ptNWY;
- Transform(&tempX, &tempY);
- xMax = max(tempX, xMax);
- xMin = min(tempX, xMin);
- yMax = max(tempY, yMax);
- yMin = min(tempY, yMin);
- xInc = (ptNWX - ptSEX) / 100.0;
- tempY = ptSEY;
- // compute the max and min longitude along the left and right borders
- double yInc = (ptNWY - ptSEY) / 100.0;
- tempX = ptNWX;
- tempY = ptSEY + i * yInc;
- yInc = (ptNWY - ptSEY) / 100.0;
- tempX = ptSEX;
- if(dimension == MgCoordinateDimension::XYZ)
- double zMax = 0.0;
- double zMin = 0.0;
- zMax = max(ptUpperRightZ, ptLowerLeftZ);
- zMin = min(ptUpperRightZ, ptLowerLeftZ);
- lowerLeftTarget = new MgCoordinateXYZ(xMin, yMin, zMin);
- upperRightTarget = new MgCoordinateXYZ(xMax, yMax, zMax);
- else
- lowerLeftTarget = new MgCoordinateXY(xMin, yMin);
- upperRightTarget = new MgCoordinateXY(xMax, yMax);
- pEnvelope = new MgEnvelope(lowerLeftTarget, upperRightTarget);
- else if((m_pCsSource->GetType() == MgCoordinateSystemType::Geographic) && (m_pCsTarget->GetType() == MgCoordinateSystemType::Projected))
+ // Generate line strings from one corner to the next. Magnitude is the
+ // maximum distance between the real line and the multi-segment
+ // approximation returned by GridLine. Thus, this is a measure of the
+ // accuracy. To prevent a serious looping problem, the maxPoints
+ // argument sets an upper limit on the number of points generated in the
+ // the returned line string.
+ lineString = GridLine (lowerLeft,lowerRight,magnitude,maxPoints);
+ stringItr = lineString->GetCoordinates ();
+ while (stringItr->MoveNext ())
- // This is a geographic to projected transform.
+ xyPoint = stringItr->GetCurrent ();
+ if (xyPoint->GetX () < xMin) xMin = xyPoint->GetX ();
+ if (xyPoint->GetX () > xMax) xMax = xyPoint->GetX ();
+ if (xyPoint->GetY () < yMin) yMin = xyPoint->GetY ();
+ if (xyPoint->GetY () > yMax) yMax = xyPoint->GetY ();
- double lon = (ptSEX + ptNWX) / 2.0;
- double lat = (ptSEY + ptNWY) / 2.0;
- double xDist = ::fabs(ptSEX - ptNWX);
- double tempX = 0.0;
- double tempY = 0.0;
- // Bottom center
- tempX = lon;
- tempY = ptSEY;
- double xMax = tempX;
- double xMin = tempX;
- double yMax = tempY;
- double yMin = tempY;
- // Bottom right
- tempX = (lon + xDist / 2);
- tempY = ptSEY;
- // Bottom left
- tempX = (lon - xDist / 2);
- tempY = ptSEY;
- // Top center
- tempX = lon;
- tempY = ptNWY;
- // Top right
- tempY = ptNWY;
- // Top left
- tempY = ptNWY;
- // Middle center
- tempX = lon;
- tempY = lat;
- // Middle right
- tempY = lat;
- // Middle left
- tempY = lat;
- else
+ lineString = GridLine (lowerRight,upperRight,magnitude,maxPoints);
- else
+ lineString = GridLine (upperRight,upperLeft,magnitude,maxPoints);
- lowerLeftTarget = Transform(lowerLeft);
- upperRightTarget = Transform(upperRight);
+ lineString = GridLine (upperLeft,lowerLeft,magnitude,maxPoints);
- if (!pEnvelope)
+ // Construct an evelope of the appropriate dimensions.
+ if (dimension != MgCoordinateDimension::XYZ) // 2D
- throw new MgOutOfMemoryException(L"MgCoordinateSystemTransform.Transform", __LINE__, __WFILE__, NULL, L"", NULL);
+ Ptr<MgCoordinate> xyLowerLeft = new MgCoordinateXY (xMin,yMin);
+ Ptr<MgCoordinate> xyUpperRight = new MgCoordinateXY (xMax,yMax);
+ pEnvelope = new MgEnvelope (xyLowerLeft,xyUpperRight);
+ else // 3D
+ Ptr<MgCoordinate> xyzLowerLeft = new MgCoordinateXYZ (xMin,yMin,zMin);
+ Ptr<MgCoordinate> xyzUpperRight = new MgCoordinateXYZ (xMax,yMax,zMax);
+ pEnvelope = new MgEnvelope (xyzLowerLeft,xyzUpperRight);
MG_CATCH_AND_THROW(L"MgCoordinateSystemTransform.Transform")
- Ptr<MgCoordinate> ll = envelope->GetLowerLeftCoordinate();
- Ptr<MgCoordinate> ur = envelope->GetUpperRightCoordinate();
- printf("Transform(envelope) -- Source: %f,%f to %f,%f\n", ll->GetX(), ll->GetY(), ur->GetX(), ur->GetY());
+ Ptr<MgCoordinate> ll = envelope->GetLowerLeftCoordinate();
+ Ptr<MgCoordinate> ur = envelope->GetUpperRightCoordinate();
+ printf("Transform(envelope) -- Source: %f,%f to %f,%f\n", ll->GetX(), ll->GetY(), ur->GetX(), ur->GetY());
- ll = pEnvelope->GetLowerLeftCoordinate();
- ur = pEnvelope->GetUpperRightCoordinate();
- printf("Transform(envelope) -- Dest : %f,%f to %f,%f\n", ll->GetX(), ll->GetY(), ur->GetX(), ur->GetY());
+ ll = pEnvelope->GetLowerLeftCoordinate();
+ ur = pEnvelope->GetUpperRightCoordinate();
+ printf("Transform(envelope) -- Dest : %f,%f to %f,%f\n", ll->GetX(), ll->GetY(), ur->GetX(), ur->GetY());
- return pEnvelope;
+ // Return the computed envelope.
+ return pEnvelope.Detach ();
//MgDisposable
More information about the mapguide-commits
