[mapguide-commits] r4781 - in trunk/Tools/Maestro/Maestro: .
ResourceEditors ResourceEditors/Icons
ResourceEditors/LoadProcedureEditors
ResourceEditors/Templates Strings
svn_mapguide at osgeo.org
Mon Apr 12 09:54:24 EDT 2010
Author: jng
Date: 2010-04-12 09:54:24 -0400 (Mon, 12 Apr 2010)
New Revision: 4781
Added:
trunk/Tools/Maestro/Maestro/ResourceEditors/Icons/Unknown.ico
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ILoadProcedureEditor.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.Designer.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Sdf Load Procedure.LoadProcedure
trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Shp Load Procedure.LoadProcedure
trunk/Tools/Maestro/Maestro/EditorMap.xml
trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceEditors.csproj
trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx
#579: This submission adds specialized editor support for Load Procedures. Only SDF/SHP load procedures are supported, certain load procedures features are not supported and are disabled in the UI, and ignored in the API
Modified: trunk/Tools/Maestro/Maestro/EditorMap.xml
--- trunk/Tools/Maestro/Maestro/EditorMap.xml 2010-04-12 13:44:33 UTC (rev 4780)
+++ trunk/Tools/Maestro/Maestro/EditorMap.xml 2010-04-12 13:54:24 UTC (rev 4781)
@@ -85,6 +85,17 @@
<ResourceInstanceClass>OSGeo.MapGuide.MaestroAPI.WebLayout</ResourceInstanceClass>
</ResourceEditorEntry>
+ <ResourceEditorEntry>
+ <DisplayName>Load Procedure</DisplayName>
+ <ResourceExtension>LoadProcedure</ResourceExtension>
+ <ImageAssembly>OSGeo.MapGuide.Maestro.ResourceEditors.dll</ImageAssembly>
+ <ImageResourceName>OSGeo.MapGuide.Maestro.ResourceEditors.Icons.Unknown.ico</ImageResourceName>
+ <ResourceEditorAssembly>OSGeo.MapGuide.Maestro.ResourceEditors.dll</ResourceEditorAssembly>
+ <ResourceEditorClass>OSGeo.MapGuide.Maestro.ResourceEditors.LoadProcedureEditors.LoadProcedureCtrl</ResourceEditorClass>
+ <ResourceInstanceAssembly>OSGeo.MapGuide.MaestroAPI.dll</ResourceInstanceAssembly>
+ <ResourceInstanceClass>OSGeo.MapGuide.MaestroAPI.LoadProcedure</ResourceInstanceClass>
+ </ResourceEditorEntry>
<DisplayName>Print layout</DisplayName>
<ResourceExtension>PrintLayout</ResourceExtension>
@@ -129,4 +140,4 @@
<ResourceInstanceClass>OSGeo.MapGuide.MaestroAPI.ApplicationDefinition.ApplicationDefinitionType</ResourceInstanceClass>
-</ResourceEditors>
\ No newline at end of file
+</ResourceEditors>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/Icons/Unknown.ico
(Binary files differ)
Property changes on: trunk/Tools/Maestro/Maestro/ResourceEditors/Icons/Unknown.ico
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,92 @@
+namespace OSGeo.MapGuide.Maestro.ResourceEditors.LoadProcedureEditors
+ partial class AffectedResourceIdsDlg
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.label1 = new System.Windows.Forms.Label();
+ this.lstResources = new System.Windows.Forms.ListBox();
+ this.btnOK = new System.Windows.Forms.Button();
+ this.SuspendLayout();
+ // label1
+ this.label1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.label1.Location = new System.Drawing.Point(12, 9);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(268, 40);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "The load procedure will create or update the following resources when executed";
+ // lstResources
+ this.lstResources.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.lstResources.FormattingEnabled = true;
+ this.lstResources.HorizontalScrollbar = true;
+ this.lstResources.Location = new System.Drawing.Point(13, 53);
+ this.lstResources.Name = "lstResources";
+ this.lstResources.Size = new System.Drawing.Size(267, 147);
+ this.lstResources.TabIndex = 1;
+ // btnOK
+ this.btnOK.Location = new System.Drawing.Point(109, 215);
+ this.btnOK.Name = "btnOK";
+ this.btnOK.Size = new System.Drawing.Size(75, 23);
+ this.btnOK.TabIndex = 2;
+ this.btnOK.Text = "OK";
+ this.btnOK.UseVisualStyleBackColor = true;
+ this.btnOK.Click += new System.EventHandler(this.btnOK_Click);
+ // AffectedResourceIdsDlg
+ this.AcceptButton = this.btnOK;
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.ClientSize = new System.Drawing.Size(292, 251);
+ this.Controls.Add(this.btnOK);
+ this.Controls.Add(this.lstResources);
+ this.Controls.Add(this.label1);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedDialog;
+ this.MaximizeBox = false;
+ this.MinimizeBox = false;
+ this.Name = "AffectedResourceIdsDlg";
+ this.StartPosition = System.Windows.Forms.FormStartPosition.CenterParent;
+ this.Text = "Affected Resources";
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.ListBox lstResources;
+ private System.Windows.Forms.Button btnOK;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,48 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+ public partial class AffectedResourceIdsDlg : Form
+ public AffectedResourceIdsDlg()
+ InitializeComponent();
+ public AffectedResourceIdsDlg(string[] values)
+ : this()
+ lstResources.DataSource = values;
+ private void btnOK_Click(object sender, EventArgs e)
+ this.DialogResult = DialogResult.OK;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/AffectedResourceIdsDlg.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,37 @@
+ partial class BaseFileLoadProcedureCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ #region Component Designer generated code
+ /// <summary>
+ /// </summary>
+ components = new System.ComponentModel.Container();
+ #endregion
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/BaseFileLoadProcedureCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,126 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class BaseFileLoadProcedureCtrl : UserControl, ILoadProcedureEditor
+ protected EditorInterface _ed;
+ private string _resourceID;
+ public event EventHandler ResourceModified;
+ public BaseFileLoadProcedureCtrl()
+ public BaseFileLoadProcedureCtrl(EditorInterface ed)
+ : this()
+ _ed = ed;
+ public BaseFileLoadProcedureCtrl(EditorInterface ed, string resourceID)
+ : base()
+ _ed = ed;
+ _resourceID = resourceID;
+ public virtual bool CanExecute
+ get { return true; }
+ public object Resource
+ get;
+ set;
+ public virtual void UpdateDisplay()
+ public string ResourceId
+ get;
+ set;
+ public virtual bool Preview()
+ return false;
+ public virtual bool ValidateResource(bool recursive)
+ return false;
+ public virtual bool Profile()
+ return false;
+ public virtual bool SupportsPreview
+ get { return false; }
+ public virtual bool SupportsValidate
+ public virtual bool SupportsProfiling
+ public virtual bool Save(string savename)
+ return false;
+ protected virtual void RaiseModified()
+ var handler = this.ResourceModified;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
+ public virtual string[] GetAffectedResourceIds()
+ return new string[0];
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,37 @@
+ partial class DefaultLoadProcedureCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ #endregion
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/DefaultLoadProcedureCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,58 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class DefaultLoadProcedureCtrl : XmlEditorControl, ILoadProcedureEditor
+ public DefaultLoadProcedureCtrl(EditorInterface ed)
+ : base(ed)
+ public DefaultLoadProcedureCtrl(EditorInterface ed, string resourceID)
+ : base(ed, resourceID)
+ public bool CanExecute
+ public string[] GetAffectedResourceIds()
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ILoadProcedureEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ILoadProcedureEditor.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ILoadProcedureEditor.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,34 @@
+#endregion
+using System;
+using System.Text;
+ public interface ILoadProcedureEditor : IResourceEditorControl
+ bool CanExecute { get; }
+ event EventHandler ResourceModified;
+ string[] GetAffectedResourceIds();
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,88 @@
+ partial class LoadProcedureCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.childPanel = new System.Windows.Forms.Panel();
+ this.btnLoadResources = new System.Windows.Forms.Button();
+ this.btnListAffected = new System.Windows.Forms.Button();
+ // childPanel
+ this.childPanel.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ | System.Windows.Forms.AnchorStyles.Left)
+ this.childPanel.AutoScroll = true;
+ this.childPanel.Location = new System.Drawing.Point(4, 4);
+ this.childPanel.Name = "childPanel";
+ this.childPanel.Size = new System.Drawing.Size(573, 424);
+ this.childPanel.TabIndex = 0;
+ // btnLoadResources
+ this.btnLoadResources.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left)));
+ this.btnLoadResources.Location = new System.Drawing.Point(16, 443);
+ this.btnLoadResources.Name = "btnLoadResources";
+ this.btnLoadResources.Size = new System.Drawing.Size(138, 23);
+ this.btnLoadResources.TabIndex = 1;
+ this.btnLoadResources.Text = "Load Resources";
+ this.btnLoadResources.UseVisualStyleBackColor = true;
+ this.btnLoadResources.Click += new System.EventHandler(this.btnLoadResources_Click);
+ // btnListAffected
+ this.btnListAffected.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left)));
+ this.btnListAffected.Location = new System.Drawing.Point(160, 443);
+ this.btnListAffected.Name = "btnListAffected";
+ this.btnListAffected.Size = new System.Drawing.Size(138, 23);
+ this.btnListAffected.TabIndex = 2;
+ this.btnListAffected.Text = "List Affected Resources";
+ this.btnListAffected.UseVisualStyleBackColor = true;
+ this.btnListAffected.Click += new System.EventHandler(this.btnListAffected_Click);
+ // LoadProcedureCtrl
+ this.Controls.Add(this.btnListAffected);
+ this.Controls.Add(this.btnLoadResources);
+ this.Controls.Add(this.childPanel);
+ this.Name = "LoadProcedureCtrl";
+ this.Size = new System.Drawing.Size(580, 481);
+ #endregion
+ private System.Windows.Forms.Panel childPanel;
+ private System.Windows.Forms.Button btnLoadResources;
+ private System.Windows.Forms.Button btnListAffected;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,225 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ internal enum LoadProcType
+ SDF,
+ SHP,
+ SQLite,
+ Other
+ public partial class LoadProcedureCtrl : UserControl, IResourceEditorControl
+ private ILoadProcedureEditor _childEditor;
+ private EditorInterface _ed;
+ private bool _isNew;
+ internal LoadProcedureCtrl()
+ public LoadProcedureCtrl(EditorInterface ed)
+ : this()
+ _ed = ed;
+ _isNew = true;
+ InitChildEditor();
+ public LoadProcedureCtrl(EditorInterface ed, string resourceID)
+ : this()
+ _ed = ed;
+ _isNew = false;
+ private void InitChildEditor()
+ if (_isNew)
+ var dlg = new LoadProcedurePicker();
+ if (dlg.ShowDialog() == DialogResult.OK)
+ switch (dlg.LoadProcedureType)
+ case LoadProcType.SDF:
+ _childEditor = new SdfLoadProcedureCtrl(_ed);
+ break;
+ case LoadProcType.SHP:
+ _childEditor = new ShpLoadProcedureCtrl(_ed);
+ break;
+ default:
+ _childEditor = new DefaultLoadProcedureCtrl(_ed);
+ break;
+ else
+ else
+ MaestroAPI.LoadProcedure proc = (MaestroAPI.LoadProcedure)_ed.CurrentConnection.GetResource(_resourceID);
+ if (proc.Item.GetType() == typeof(MaestroAPI.SdfLoadProcedureType))
+ _childEditor = new SdfLoadProcedureCtrl(_ed, _resourceID);
+ else if (proc.Item.GetType() == typeof(MaestroAPI.ShpLoadProcedureType))
+ _childEditor = new ShpLoadProcedureCtrl(_ed, _resourceID);
+ else
+ _childEditor = new DefaultLoadProcedureCtrl(_ed, _resourceID);
+ _childEditor.Resource = proc;
+ UpdateDisplay();
+ if (_childEditor != null)
+ _childEditor.ResourceModified += (sender, e) => { _ed.HasChanged(); };
+ Control c = ((Control)_childEditor);
+ c.Dock = DockStyle.Fill;
+ childPanel.Controls.Add(c);
+ btnLoadResources.Enabled = _childEditor.CanExecute;
+ get
+ return _childEditor.Resource;
+ set
+ _childEditor.Resource = value;
+ public void UpdateDisplay()
+ _childEditor.UpdateDisplay();
+ get
+ return _childEditor.ResourceId;
+ set
+ _childEditor.ResourceId = value;
+ public bool Preview()
+ return _childEditor.Preview();
+ public bool ValidateResource(bool recursive)
+ return _childEditor.ValidateResource(recursive);
+ public bool Profile()
+ return _childEditor.Profile();
+ public bool SupportsPreview
+ get { return _childEditor.SupportsPreview; }
+ public bool SupportsValidate
+ get { return _childEditor.SupportsValidate; }
+ public bool SupportsProfiling
+ get { return _childEditor.SupportsProfiling; }
+ public bool Save(string savename)
+ return _childEditor.Save(savename);
+ private void btnLoadResources_Click(object sender, EventArgs e)
+ WaitForOperation dlg = new WaitForOperation();
+ dlg.CancelAbortsThread = true;
+ Form ownerForm = this.ParentForm;
+ WaitForOperation.DoBackgroundWork worker = new WaitForOperation.DoBackgroundWork(ExecuteLoadProcedure);
+ try
+ dlg.RunOperationAsync(ownerForm, worker, _ed.CurrentConnection, _resourceID);
+ catch (CancelException)
+ MessageBox.Show("Operation Cancelled");
+ private object ExecuteLoadProcedure(BackgroundWorker worker, DoWorkEventArgs de, params object[] args)
+ MaestroAPI.LengthyOperationProgressCallBack cb = (s, cbArgs) =>
+ worker.ReportProgress(cbArgs.Progress, cbArgs.StatusMessage);
+ MaestroAPI.ServerConnectionI conn = (MaestroAPI.ServerConnectionI)args[0];
+ string lpID = (string)args[1];
+ conn.ExecuteLoadProcedure(lpID, true, cb);
+ return true;
+ private void btnListAffected_Click(object sender, EventArgs e)
+ new AffectedResourceIdsDlg(_childEditor.GetAffectedResourceIds()).ShowDialog();
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedureCtrl.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,132 @@
+ partial class LoadProcedurePicker
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.rdSdf = new System.Windows.Forms.RadioButton();
+ this.rdShp = new System.Windows.Forms.RadioButton();
+ this.rdSqlite = new System.Windows.Forms.RadioButton();
+ this.rdOther = new System.Windows.Forms.RadioButton();
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(13, 13);
+ this.label1.Size = new System.Drawing.Size(220, 13);
+ this.label1.Text = "Choose the type of Load Procedure to create";
+ // rdSdf
+ this.rdSdf.AutoSize = true;
+ this.rdSdf.Checked = true;
+ this.rdSdf.Location = new System.Drawing.Point(43, 51);
+ this.rdSdf.Name = "rdSdf";
+ this.rdSdf.Size = new System.Drawing.Size(46, 17);
+ this.rdSdf.TabIndex = 1;
+ this.rdSdf.TabStop = true;
+ this.rdSdf.Text = "SDF";
+ this.rdSdf.UseVisualStyleBackColor = true;
+ // rdShp
+ this.rdShp.AutoSize = true;
+ this.rdShp.Location = new System.Drawing.Point(43, 74);
+ this.rdShp.Name = "rdShp";
+ this.rdShp.Size = new System.Drawing.Size(47, 17);
+ this.rdShp.TabIndex = 2;
+ this.rdShp.Text = "SHP";
+ this.rdShp.UseVisualStyleBackColor = true;
+ // rdSqlite
+ this.rdSqlite.AutoSize = true;
+ this.rdSqlite.Location = new System.Drawing.Point(43, 97);
+ this.rdSqlite.Name = "rdSqlite";
+ this.rdSqlite.Size = new System.Drawing.Size(57, 17);
+ this.rdSqlite.TabIndex = 3;
+ this.rdSqlite.Text = "SQLite";
+ this.rdSqlite.UseVisualStyleBackColor = true;
+ // rdOther
+ this.rdOther.AutoSize = true;
+ this.rdOther.Location = new System.Drawing.Point(43, 120);
+ this.rdOther.Name = "rdOther";
+ this.rdOther.Size = new System.Drawing.Size(233, 17);
+ this.rdOther.TabIndex = 4;
+ this.rdOther.Text = "Other (will use XML Editor, may not execute)";
+ this.rdOther.UseVisualStyleBackColor = true;
+ // btnOK
+ this.btnOK.Location = new System.Drawing.Point(109, 165);
+ this.btnOK.TabIndex = 5;
+ // LoadProcedurePicker
+ this.ClientSize = new System.Drawing.Size(292, 200);
+ this.ControlBox = false;
+ this.Controls.Add(this.rdOther);
+ this.Controls.Add(this.rdSqlite);
+ this.Controls.Add(this.rdShp);
+ this.Controls.Add(this.rdSdf);
+ this.Name = "LoadProcedurePicker";
+ this.Text = "Load Procedure Type";
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.RadioButton rdSdf;
+ private System.Windows.Forms.RadioButton rdShp;
+ private System.Windows.Forms.RadioButton rdSqlite;
+ private System.Windows.Forms.RadioButton rdOther;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,57 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ internal partial class LoadProcedurePicker : Form
+ public LoadProcedurePicker()
+ internal LoadProcType LoadProcedureType
+ get
+ LoadProcType lt = LoadProcType.Other;
+ if (rdSdf.Checked)
+ lt = LoadProcType.SDF;
+ else if (rdShp.Checked)
+ lt = LoadProcType.SHP;
+ else if (rdSqlite.Checked)
+ lt = LoadProcType.SQLite;
+ return lt;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadProcedurePicker.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,230 @@
+ partial class LoadSettingsCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.label6 = new System.Windows.Forms.Label();
+ this.label5 = new System.Windows.Forms.Label();
+ this.label4 = new System.Windows.Forms.Label();
+ this.txtLayerFolderName = new System.Windows.Forms.TextBox();
+ this.txtFeatureSourceFolderName = new System.Windows.Forms.TextBox();
+ this.btnBrowseLayerRoot = new System.Windows.Forms.Button();
+ this.txtLayerRoot = new System.Windows.Forms.TextBox();
+ this.btnBrowseFsRoot = new System.Windows.Forms.Button();
+ this.txtFeatureSourceRoot = new System.Windows.Forms.TextBox();
+ this.chkLoadFeatureSources = new System.Windows.Forms.CheckBox();
+ this.chkLoadLayers = new System.Windows.Forms.CheckBox();
+ this.btnBrowseResourceRoot = new System.Windows.Forms.Button();
+ this.txtRootPath = new System.Windows.Forms.TextBox();
+ this.label3 = new System.Windows.Forms.Label();
+ // label6
+ this.label6.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.label6.AutoSize = true;
+ this.label6.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.label6.Location = new System.Drawing.Point(375, 27);
+ this.label6.Name = "label6";
+ this.label6.Size = new System.Drawing.Size(78, 13);
+ this.label6.TabIndex = 32;
+ this.label6.Text = "Folder Name";
+ // label5
+ this.label5.AutoSize = true;
+ this.label5.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.label5.Location = new System.Drawing.Point(142, 27);
+ this.label5.Name = "label5";
+ this.label5.Size = new System.Drawing.Size(71, 13);
+ this.label5.TabIndex = 31;
+ this.label5.Text = "In this path";
+ // label4
+ this.label4.AutoSize = true;
+ this.label4.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Bold, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
+ this.label4.Location = new System.Drawing.Point(1, 27);
+ this.label4.Name = "label4";
+ this.label4.Size = new System.Drawing.Size(44, 13);
+ this.label4.TabIndex = 30;
+ this.label4.Text = "Create";
+ // txtLayerFolderName
+ this.txtLayerFolderName.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtLayerFolderName.Location = new System.Drawing.Point(378, 73);
+ this.txtLayerFolderName.Name = "txtLayerFolderName";
+ this.txtLayerFolderName.Size = new System.Drawing.Size(107, 20);
+ this.txtLayerFolderName.TabIndex = 29;
+ // txtFeatureSourceFolderName
+ this.txtFeatureSourceFolderName.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtFeatureSourceFolderName.Location = new System.Drawing.Point(378, 50);
+ this.txtFeatureSourceFolderName.Name = "txtFeatureSourceFolderName";
+ this.txtFeatureSourceFolderName.Size = new System.Drawing.Size(107, 20);
+ this.txtFeatureSourceFolderName.TabIndex = 28;
+ // btnBrowseLayerRoot
+ this.btnBrowseLayerRoot.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseLayerRoot.Location = new System.Drawing.Point(346, 71);
+ this.btnBrowseLayerRoot.Name = "btnBrowseLayerRoot";
+ this.btnBrowseLayerRoot.Size = new System.Drawing.Size(26, 23);
+ this.btnBrowseLayerRoot.TabIndex = 27;
+ this.btnBrowseLayerRoot.Text = "...";
+ this.btnBrowseLayerRoot.UseVisualStyleBackColor = true;
+ this.btnBrowseLayerRoot.Click += new System.EventHandler(this.btnBrowseLayerRoot_Click);
+ // txtLayerRoot
+ this.txtLayerRoot.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtLayerRoot.Location = new System.Drawing.Point(145, 73);
+ this.txtLayerRoot.Name = "txtLayerRoot";
+ this.txtLayerRoot.ReadOnly = true;
+ this.txtLayerRoot.Size = new System.Drawing.Size(195, 20);
+ this.txtLayerRoot.TabIndex = 26;
+ // btnBrowseFolderRoot
+ this.btnBrowseFsRoot.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseFsRoot.Location = new System.Drawing.Point(346, 48);
+ this.btnBrowseFsRoot.Name = "btnBrowseFolderRoot";
+ this.btnBrowseFsRoot.Size = new System.Drawing.Size(26, 23);
+ this.btnBrowseFsRoot.TabIndex = 25;
+ this.btnBrowseFsRoot.Text = "...";
+ this.btnBrowseFsRoot.UseVisualStyleBackColor = true;
+ this.btnBrowseFsRoot.Click += new System.EventHandler(this.btnBrowseFolderRoot_Click);
+ // txtFeatureSourceRoot
+ this.txtFeatureSourceRoot.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtFeatureSourceRoot.Location = new System.Drawing.Point(145, 50);
+ this.txtFeatureSourceRoot.Name = "txtFeatureSourceRoot";
+ this.txtFeatureSourceRoot.ReadOnly = true;
+ this.txtFeatureSourceRoot.Size = new System.Drawing.Size(195, 20);
+ this.txtFeatureSourceRoot.TabIndex = 24;
+ // chkLoadFeatureSources
+ this.chkLoadFeatureSources.AutoSize = true;
+ this.chkLoadFeatureSources.Location = new System.Drawing.Point(4, 52);
+ this.chkLoadFeatureSources.Name = "chkLoadFeatureSources";
+ this.chkLoadFeatureSources.Size = new System.Drawing.Size(104, 17);
+ this.chkLoadFeatureSources.TabIndex = 23;
+ this.chkLoadFeatureSources.Text = "Feature Sources";
+ this.chkLoadFeatureSources.UseVisualStyleBackColor = true;
+ this.chkLoadFeatureSources.CheckedChanged += new System.EventHandler(this.chkLoadFeatureSources_CheckedChanged);
+ // chkLoadLayers
+ this.chkLoadLayers.AutoSize = true;
+ this.chkLoadLayers.Location = new System.Drawing.Point(4, 75);
+ this.chkLoadLayers.Name = "chkLoadLayers";
+ this.chkLoadLayers.Size = new System.Drawing.Size(104, 17);
+ this.chkLoadLayers.TabIndex = 22;
+ this.chkLoadLayers.Text = "Layer Definitions";
+ this.chkLoadLayers.UseVisualStyleBackColor = true;
+ this.chkLoadLayers.CheckedChanged += new System.EventHandler(this.chkLoadLayers_CheckedChanged);
+ // btnBrowseResourceRoot
+ this.btnBrowseResourceRoot.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseResourceRoot.Location = new System.Drawing.Point(459, 0);
+ this.btnBrowseResourceRoot.Name = "btnBrowseResourceRoot";
+ this.btnBrowseResourceRoot.Size = new System.Drawing.Size(26, 23);
+ this.btnBrowseResourceRoot.TabIndex = 21;
+ this.btnBrowseResourceRoot.Text = "...";
+ this.btnBrowseResourceRoot.UseVisualStyleBackColor = true;
+ this.btnBrowseResourceRoot.Click += new System.EventHandler(this.btnBrowseResourceRoot_Click);
+ // txtRootPath
+ this.txtRootPath.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtRootPath.Location = new System.Drawing.Point(145, 2);
+ this.txtRootPath.Name = "txtRootPath";
+ this.txtRootPath.ReadOnly = true;
+ this.txtRootPath.Size = new System.Drawing.Size(308, 20);
+ this.txtRootPath.TabIndex = 20;
+ // label3
+ this.label3.AutoSize = true;
+ this.label3.Location = new System.Drawing.Point(1, 5);
+ this.label3.Name = "label3";
+ this.label3.Size = new System.Drawing.Size(138, 13);
+ this.label3.TabIndex = 19;
+ this.label3.Text = "Load Resources Into Folder";
+ // LoadSettingsCtrl
+ this.Controls.Add(this.label6);
+ this.Controls.Add(this.label5);
+ this.Controls.Add(this.label4);
+ this.Controls.Add(this.txtLayerFolderName);
+ this.Controls.Add(this.txtFeatureSourceFolderName);
+ this.Controls.Add(this.btnBrowseLayerRoot);
+ this.Controls.Add(this.txtLayerRoot);
+ this.Controls.Add(this.btnBrowseFsRoot);
+ this.Controls.Add(this.txtFeatureSourceRoot);
+ this.Controls.Add(this.chkLoadFeatureSources);
+ this.Controls.Add(this.chkLoadLayers);
+ this.Controls.Add(this.btnBrowseResourceRoot);
+ this.Controls.Add(this.txtRootPath);
+ this.Controls.Add(this.label3);
+ this.Name = "LoadSettingsCtrl";
+ this.Size = new System.Drawing.Size(488, 96);
+ #endregion
+ protected System.Windows.Forms.Label label6;
+ protected System.Windows.Forms.Label label5;
+ protected System.Windows.Forms.Label label4;
+ protected System.Windows.Forms.TextBox txtLayerFolderName;
+ protected System.Windows.Forms.TextBox txtFeatureSourceFolderName;
+ protected System.Windows.Forms.Button btnBrowseLayerRoot;
+ protected System.Windows.Forms.TextBox txtLayerRoot;
+ protected System.Windows.Forms.Button btnBrowseFsRoot;
+ protected System.Windows.Forms.TextBox txtFeatureSourceRoot;
+ protected System.Windows.Forms.CheckBox chkLoadFeatureSources;
+ protected System.Windows.Forms.CheckBox chkLoadLayers;
+ protected System.Windows.Forms.Button btnBrowseResourceRoot;
+ protected System.Windows.Forms.TextBox txtRootPath;
+ protected System.Windows.Forms.Label label3;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,186 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class LoadSettingsCtrl : UserControl
+ public event EventHandler Modified;
+ public LoadSettingsCtrl()
+ this.LoadFeatureSources = false;
+ this.LoadLayers = false;
+ public EditorInterface Editor
+ get;
+ set;
+ private void RaiseModified()
+ var handler = this.Modified;
+ public string ResourceRootPath
+ get { return txtRootPath.Text; }
+ set
+ string oldValue = txtRootPath.Text;
+ txtRootPath.Text = value;
+ if (this.FeatureSourceRootPath == oldValue || string.IsNullOrEmpty(this.FeatureSourceRootPath))
+ this.FeatureSourceRootPath = value;
+ if (this.LayerRootPath == oldValue || string.IsNullOrEmpty(this.LayerRootPath))
+ this.LayerRootPath = value;
+ RaiseModified();
+ public string LayerRootPath
+ get { return txtLayerRoot.Text; }
+ set
+ txtLayerRoot.Text = value;
+ RaiseModified();
+ public string FeatureSourceRootPath
+ get { return txtFeatureSourceRoot.Text; }
+ set
+ txtFeatureSourceRoot.Text = value;
+ RaiseModified();
+ public string LayerFolderName
+ get { return txtLayerFolderName.Text; }
+ set
+ txtLayerFolderName.Text = value;
+ RaiseModified();
+ public string FeatureSourceFolderName
+ get { return txtFeatureSourceFolderName.Text; }
+ set
+ txtFeatureSourceFolderName.Text = value;
+ RaiseModified();
+ public bool LoadFeatureSources
+ get { return chkLoadFeatureSources.Checked; }
+ set
+ chkLoadFeatureSources.Checked = value;
+ RaiseModified();
+ public bool LoadLayers
+ get { return chkLoadLayers.Checked; }
+ set
+ chkLoadLayers.Checked = value;
+ RaiseModified();
+ private void chkLoadFeatureSources_CheckedChanged(object sender, EventArgs e)
+ txtFeatureSourceFolderName.Enabled = txtFeatureSourceRoot.Enabled = btnBrowseFsRoot.Enabled = chkLoadFeatureSources.Checked;
+ RaiseModified();
+ private void chkLoadLayers_CheckedChanged(object sender, EventArgs e)
+ txtLayerFolderName.Enabled = txtLayerRoot.Enabled = btnBrowseLayerRoot.Enabled = chkLoadLayers.Checked;
+ RaiseModified();
+ private string GetFolderPath()
+ if (this.Editor != null)
+ string value = this.Editor.BrowseResource("Folder");
+ if (value != null)
+ return value;
+ return null;
+ private void btnBrowseResourceRoot_Click(object sender, EventArgs e)
+ string value = GetFolderPath();
+ this.ResourceRootPath = value;
+ private void btnBrowseFolderRoot_Click(object sender, EventArgs e)
+ private void btnBrowseLayerRoot_Click(object sender, EventArgs e)
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/LoadSettingsCtrl.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,221 @@
+ partial class SdfLoadProcedureCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.sourceFilesCtrl1 = new OSGeo.MapGuide.Maestro.ResourceEditors.LoadProcedureEditors.SourceFilesCtrl();
+ this.groupBox2 = new System.Windows.Forms.GroupBox();
+ this.cmbSdfDuplicateStrategy = new System.Windows.Forms.ComboBox();
+ this.numGeneralize = new System.Windows.Forms.NumericUpDown();
+ this.label2 = new System.Windows.Forms.Label();
+ this.btnBrowseCS = new System.Windows.Forms.Button();
+ this.txtDefaultCs = new System.Windows.Forms.TextBox();
+ this.groupBox3 = new System.Windows.Forms.GroupBox();
+ this.loadSettingsCtrl1 = new OSGeo.MapGuide.Maestro.ResourceEditors.LoadProcedureEditors.LoadSettingsCtrl();
+ this.groupBox1.SuspendLayout();
+ this.groupBox2.SuspendLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numGeneralize)).BeginInit();
+ this.groupBox3.SuspendLayout();
+ // groupBox1
+ this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.groupBox1.Controls.Add(this.sourceFilesCtrl1);
+ this.groupBox1.Location = new System.Drawing.Point(3, 3);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(592, 130);
+ this.groupBox1.TabIndex = 0;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Source Files";
+ // sourceFilesCtrl1
+ this.sourceFilesCtrl1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.sourceFilesCtrl1.FileFilter = global::OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.Strings.BasicCommand.DuplicateRenameError;
+ this.sourceFilesCtrl1.Location = new System.Drawing.Point(3, 16);
+ this.sourceFilesCtrl1.Name = "sourceFilesCtrl1";
+ this.sourceFilesCtrl1.Size = new System.Drawing.Size(586, 111);
+ this.sourceFilesCtrl1.SourceFiles = new string[0];
+ this.sourceFilesCtrl1.TabIndex = 0;
+ // groupBox2
+ this.groupBox2.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.groupBox2.Controls.Add(this.cmbSdfDuplicateStrategy);
+ this.groupBox2.Controls.Add(this.label3);
+ this.groupBox2.Controls.Add(this.numGeneralize);
+ this.groupBox2.Controls.Add(this.label2);
+ this.groupBox2.Controls.Add(this.btnBrowseCS);
+ this.groupBox2.Controls.Add(this.txtDefaultCs);
+ this.groupBox2.Controls.Add(this.label1);
+ this.groupBox2.Location = new System.Drawing.Point(3, 139);
+ this.groupBox2.Name = "groupBox2";
+ this.groupBox2.Size = new System.Drawing.Size(592, 142);
+ this.groupBox2.TabIndex = 1;
+ this.groupBox2.TabStop = false;
+ this.groupBox2.Text = "Transformation";
+ // cmbSdfDuplicateStrategy
+ this.cmbSdfDuplicateStrategy.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.cmbSdfDuplicateStrategy.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbSdfDuplicateStrategy.Enabled = false;
+ this.cmbSdfDuplicateStrategy.FormattingEnabled = true;
+ this.cmbSdfDuplicateStrategy.Location = new System.Drawing.Point(275, 74);
+ this.cmbSdfDuplicateStrategy.Name = "cmbSdfDuplicateStrategy";
+ this.cmbSdfDuplicateStrategy.Size = new System.Drawing.Size(311, 21);
+ this.cmbSdfDuplicateStrategy.TabIndex = 26;
+ // label3
+ this.label3.Enabled = false;
+ this.label3.Location = new System.Drawing.Point(6, 77);
+ this.label3.Size = new System.Drawing.Size(252, 13);
+ this.label3.TabIndex = 25;
+ this.label3.Text = "For SDF files that contain records with the same key";
+ // numGeneralize
+ this.numGeneralize.Enabled = false;
+ this.numGeneralize.Location = new System.Drawing.Point(275, 48);
+ this.numGeneralize.Name = "numGeneralize";
+ this.numGeneralize.Size = new System.Drawing.Size(58, 20);
+ this.numGeneralize.TabIndex = 24;
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Enabled = false;
+ this.label2.Location = new System.Drawing.Point(6, 50);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(171, 13);
+ this.label2.TabIndex = 23;
+ this.label2.Text = "Generalize data by this percentage";
+ // btnBrowseCS
+ this.btnBrowseCS.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
+ this.btnBrowseCS.Location = new System.Drawing.Point(560, 20);
+ this.btnBrowseCS.Name = "btnBrowseCS";
+ this.btnBrowseCS.Size = new System.Drawing.Size(26, 23);
+ this.btnBrowseCS.TabIndex = 22;
+ this.btnBrowseCS.Text = "...";
+ this.btnBrowseCS.UseVisualStyleBackColor = true;
+ this.btnBrowseCS.Click += new System.EventHandler(this.btnBrowseCS_Click);
+ // txtDefaultCs
+ this.txtDefaultCs.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtDefaultCs.Location = new System.Drawing.Point(275, 22);
+ this.txtDefaultCs.Name = "txtDefaultCs";
+ this.txtDefaultCs.ReadOnly = true;
+ this.txtDefaultCs.Size = new System.Drawing.Size(281, 20);
+ this.txtDefaultCs.TabIndex = 1;
+ // label1
+ this.label1.Location = new System.Drawing.Point(6, 25);
+ this.label1.Size = new System.Drawing.Size(250, 13);
+ this.label1.Text = "Use the following Coordinate System (if none found)";
+ // groupBox3
+ this.groupBox3.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Left)
+ this.groupBox3.Controls.Add(this.loadSettingsCtrl1);
+ this.groupBox3.Location = new System.Drawing.Point(3, 287);
+ this.groupBox3.Name = "groupBox3";
+ this.groupBox3.Size = new System.Drawing.Size(592, 121);
+ this.groupBox3.TabIndex = 2;
+ this.groupBox3.TabStop = false;
+ this.groupBox3.Text = "Load Settings";
+ // loadSettingsCtrl1
+ this.loadSettingsCtrl1.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.loadSettingsCtrl1.Editor = null;
+ this.loadSettingsCtrl1.FeatureSourceFolderName = "";
+ this.loadSettingsCtrl1.FeatureSourceRootPath = "";
+ this.loadSettingsCtrl1.LayerFolderName = "";
+ this.loadSettingsCtrl1.LayerRootPath = "";
+ this.loadSettingsCtrl1.LoadFeatureSources = false;
+ this.loadSettingsCtrl1.LoadLayers = false;
+ this.loadSettingsCtrl1.Location = new System.Drawing.Point(3, 16);
+ this.loadSettingsCtrl1.Name = "loadSettingsCtrl1";
+ this.loadSettingsCtrl1.ResourceRootPath = "";
+ this.loadSettingsCtrl1.Size = new System.Drawing.Size(586, 102);
+ this.loadSettingsCtrl1.TabIndex = 0;
+ // SdfLoadProcedureCtrl
+ this.Controls.Add(this.groupBox3);
+ this.Controls.Add(this.groupBox2);
+ this.Controls.Add(this.groupBox1);
+ this.Name = "SdfLoadProcedureCtrl";
+ this.Size = new System.Drawing.Size(598, 411);
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox2.ResumeLayout(false);
+ this.groupBox2.PerformLayout();
+ ((System.ComponentModel.ISupportInitialize)(this.numGeneralize)).EndInit();
+ this.groupBox3.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.GroupBox groupBox1;
+ private SourceFilesCtrl sourceFilesCtrl1;
+ private System.Windows.Forms.GroupBox groupBox2;
+ private System.Windows.Forms.GroupBox groupBox3;
+ private LoadSettingsCtrl loadSettingsCtrl1;
+ private System.Windows.Forms.TextBox txtDefaultCs;
+ protected System.Windows.Forms.Button btnBrowseCS;
+ private System.Windows.Forms.Label label3;
+ private System.Windows.Forms.NumericUpDown numGeneralize;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.ComboBox cmbSdfDuplicateStrategy;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,143 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
+ //NOTE: Except for Default CS, all transformation settings are disabled because
+ //backend support for those features does not exist for this load procedure yet.
+ public partial class SdfLoadProcedureCtrl : BaseFileLoadProcedureCtrl
+ public SdfLoadProcedureCtrl()
+ cmbSdfDuplicateStrategy.DataSource = Enum.GetValues(typeof(SdfKeyTreatmentType));
+ public SdfLoadProcedureCtrl(EditorInterface ed)
+ : base(ed)
+ public SdfLoadProcedureCtrl(EditorInterface ed, string resourceID)
+ protected override void OnLoad(EventArgs e)
+ loadSettingsCtrl1.Editor = _ed;
+ sourceFilesCtrl1.FileFilter = "SDF Files (*.sdf)|*.sdf"; //TODO: Localize
+ loadSettingsCtrl1.Modified += (sender, evt) => { if (!_isUpdating) base.RaiseModified(); };
+ sourceFilesCtrl1.Modified += (sender, evt) => { if (!_isUpdating) base.RaiseModified(); };
+ private bool _isUpdating;
+ public override void UpdateDisplay()
+ LoadProcedure lp = this.Resource as LoadProcedure;
+ if (lp != null)
+ SdfLoadProcedureType sdfl = lp.Item as SdfLoadProcedureType;
+ if (sdfl != null)
+ _isUpdating = true;
+ sourceFilesCtrl1.SourceFiles = (sdfl.SourceFile != null) ? sdfl.SourceFile : new string[0];
+ txtDefaultCs.Text = sdfl.CoordinateSystem;
+ numGeneralize.Value = (decimal)sdfl.Generalization;
+ cmbSdfDuplicateStrategy.SelectedItem = sdfl.SdfKeyTreatment;
+ loadSettingsCtrl1.LoadFeatureSources = sdfl.GenerateSpatialDataSources;
+ loadSettingsCtrl1.LoadLayers = sdfl.GenerateLayers;
+ loadSettingsCtrl1.FeatureSourceFolderName = sdfl.SpatialDataSourcesFolder;
+ loadSettingsCtrl1.FeatureSourceRootPath = sdfl.SpatialDataSourcesPath;
+ loadSettingsCtrl1.LayerFolderName = sdfl.LayersFolder;
+ loadSettingsCtrl1.LayerRootPath = sdfl.LayersPath;
+ loadSettingsCtrl1.ResourceRootPath = sdfl.RootPath;
+ _isUpdating = false;
+ public override bool Save(string savename)
+ if (lp != null)
+ if (sdfl != null)
+ sdfl.SourceFile = sourceFilesCtrl1.SourceFiles;
+ sdfl.CoordinateSystem = txtDefaultCs.Text;
+ sdfl.Generalization = (double)numGeneralize.Value;
+ sdfl.SdfKeyTreatment = (SdfKeyTreatmentType)cmbSdfDuplicateStrategy.SelectedItem;
+ sdfl.GenerateSpatialDataSources = loadSettingsCtrl1.LoadFeatureSources;
+ sdfl.GenerateLayers = loadSettingsCtrl1.LoadLayers;
+ sdfl.SpatialDataSourcesFolder = loadSettingsCtrl1.FeatureSourceFolderName;
+ sdfl.SpatialDataSourcesPath = loadSettingsCtrl1.FeatureSourceRootPath;
+ sdfl.LayersFolder = loadSettingsCtrl1.LayerFolderName;
+ sdfl.LayersPath = loadSettingsCtrl1.LayerRootPath;
+ sdfl.RootPath = loadSettingsCtrl1.ResourceRootPath;
+ return false;
+ private void btnBrowseCS_Click(object sender, EventArgs e)
+ SelectCoordinateSystem dlg = new SelectCoordinateSystem(_ed.CurrentConnection);
+ dlg.SetWKT(txtDefaultCs.Text);
+ if (dlg.ShowDialog(this) == DialogResult.OK)
+ txtDefaultCs.Text = dlg.SelectedCoordSys.Projection;
+ public override string[] GetAffectedResourceIds()
+ List<string> affected = new List<string>();
+ foreach (string f in sourceFilesCtrl1.SourceFiles)
+ string name = System.IO.Path.GetFileNameWithoutExtension(f);
+ if (loadSettingsCtrl1.LoadFeatureSources)
+ affected.Add(loadSettingsCtrl1.FeatureSourceRootPath + loadSettingsCtrl1.FeatureSourceFolderName + "/" + name + ".FeatureSource");
+ if (loadSettingsCtrl1.LoadLayers)
+ affected.Add(loadSettingsCtrl1.LayerRootPath + loadSettingsCtrl1.LayerFolderName + "/" + name + ".LayerDefinition");
+ return affected.ToArray();
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SdfLoadProcedureCtrl.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,207 @@
+ partial class ShpLoadProcedureCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.chkConvertSdf = new System.Windows.Forms.CheckBox();
+ // groupBox3
+ this.groupBox3.Location = new System.Drawing.Point(3, 275);
+ this.groupBox3.Size = new System.Drawing.Size(527, 121);
+ this.groupBox3.TabIndex = 5;
+ this.loadSettingsCtrl1.Size = new System.Drawing.Size(521, 102);
+ // groupBox2
+ this.groupBox2.Controls.Add(this.chkConvertSdf);
+ this.groupBox2.Size = new System.Drawing.Size(527, 130);
+ this.groupBox2.TabIndex = 4;
+ // chkConvertSdf
+ this.chkConvertSdf.AutoSize = true;
+ this.chkConvertSdf.Enabled = false;
+ this.chkConvertSdf.Location = new System.Drawing.Point(340, 41);
+ this.chkConvertSdf.Name = "chkConvertSdf";
+ this.chkConvertSdf.Size = new System.Drawing.Size(99, 17);
+ this.chkConvertSdf.TabIndex = 30;
+ this.chkConvertSdf.Text = "Convert to SDF";
+ this.chkConvertSdf.UseVisualStyleBackColor = true;
+ // btnBrowseCS
+ this.btnBrowseCS.Location = new System.Drawing.Point(495, 11);
+ this.btnBrowseCS.TabIndex = 29;
+ // numGeneralize
+ this.numGeneralize.Location = new System.Drawing.Point(275, 39);
+ this.numGeneralize.TabIndex = 28;
+ // label2
+ this.label2.Location = new System.Drawing.Point(6, 41);
+ this.label2.TabIndex = 27;
+ // txtDefaultCs
+ this.txtDefaultCs.Location = new System.Drawing.Point(275, 13);
+ this.txtDefaultCs.Size = new System.Drawing.Size(215, 20);
+ this.txtDefaultCs.TabIndex = 26;
+ // label1
+ this.label1.Location = new System.Drawing.Point(6, 16);
+ this.label1.TabIndex = 25;
+ // groupBox1
+ this.groupBox1.Size = new System.Drawing.Size(527, 130);
+ this.groupBox1.TabIndex = 3;
+ this.sourceFilesCtrl1.Size = new System.Drawing.Size(521, 111);
+ // ShpLoadProcedureCtrl
+ this.Name = "ShpLoadProcedureCtrl";
+ this.Size = new System.Drawing.Size(533, 399);
+ #endregion
+ private System.Windows.Forms.CheckBox chkConvertSdf;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,140 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class ShpLoadProcedureCtrl : BaseFileLoadProcedureCtrl
+ public ShpLoadProcedureCtrl()
+ public ShpLoadProcedureCtrl(EditorInterface ed)
+ : base(ed)
+ public ShpLoadProcedureCtrl(EditorInterface ed, string resourceID)
+ sourceFilesCtrl1.FileFilter = "SHP Files (*.shp)|*.shp"; //TODO: Localize
+ if (lp != null)
+ ShpLoadProcedureType shpl = lp.Item as ShpLoadProcedureType;
+ if (shpl != null)
+ sourceFilesCtrl1.SourceFiles = (shpl.SourceFile != null) ? shpl.SourceFile : new string[0];
+ txtDefaultCs.Text = shpl.CoordinateSystem;
+ numGeneralize.Value = (decimal)shpl.Generalization;
+ chkConvertSdf.Checked = shpl.ConvertToSdf;
+ loadSettingsCtrl1.LoadFeatureSources = shpl.GenerateSpatialDataSources;
+ loadSettingsCtrl1.LoadLayers = shpl.GenerateLayers;
+ loadSettingsCtrl1.FeatureSourceFolderName = shpl.SpatialDataSourcesFolder;
+ loadSettingsCtrl1.FeatureSourceRootPath = shpl.SpatialDataSourcesPath;
+ loadSettingsCtrl1.LayerFolderName = shpl.LayersFolder;
+ loadSettingsCtrl1.LayerRootPath = shpl.LayersPath;
+ loadSettingsCtrl1.ResourceRootPath = shpl.RootPath;
+ if (lp != null)
+ if (shpl != null)
+ shpl.SourceFile = sourceFilesCtrl1.SourceFiles;
+ shpl.CoordinateSystem = txtDefaultCs.Text;
+ shpl.Generalization = (double)numGeneralize.Value;
+ shpl.ConvertToSdf = chkConvertSdf.Checked;
+ shpl.GenerateSpatialDataSources = loadSettingsCtrl1.LoadFeatureSources ;
+ shpl.GenerateLayers = loadSettingsCtrl1.LoadLayers;
+ shpl.SpatialDataSourcesFolder = loadSettingsCtrl1.FeatureSourceFolderName;
+ shpl.SpatialDataSourcesPath = loadSettingsCtrl1.FeatureSourceRootPath;
+ shpl.LayersFolder = loadSettingsCtrl1.LayerFolderName;
+ shpl.LayersPath = loadSettingsCtrl1.LayerRootPath;
+ shpl.RootPath = loadSettingsCtrl1.ResourceRootPath;
+ return false;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/ShpLoadProcedureCtrl.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.Designer.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.Designer.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.Designer.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,107 @@
+ partial class SourceFilesCtrl
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(SourceFilesCtrl));
+ this.lstSourceFiles = new System.Windows.Forms.ListBox();
+ this.toolStrip1 = new System.Windows.Forms.ToolStrip();
+ this.btnAddFiles = new System.Windows.Forms.ToolStripButton();
+ this.btnRemoveFiles = new System.Windows.Forms.ToolStripButton();
+ this.openFileDlg = new System.Windows.Forms.OpenFileDialog();
+ this.toolStrip1.SuspendLayout();
+ // lstSourceFiles
+ this.lstSourceFiles.Dock = System.Windows.Forms.DockStyle.Fill;
+ this.lstSourceFiles.FormattingEnabled = true;
+ this.lstSourceFiles.Location = new System.Drawing.Point(0, 25);
+ this.lstSourceFiles.Name = "lstSourceFiles";
+ this.lstSourceFiles.Size = new System.Drawing.Size(316, 121);
+ this.lstSourceFiles.TabIndex = 3;
+ this.lstSourceFiles.SelectedIndexChanged += new System.EventHandler(this.lstSourceFiles_SelectedIndexChanged);
+ // toolStrip1
+ this.toolStrip1.Items.AddRange(new System.Windows.Forms.ToolStripItem[] {
+ this.btnAddFiles,
+ this.btnRemoveFiles});
+ this.toolStrip1.Location = new System.Drawing.Point(0, 0);
+ this.toolStrip1.Name = "toolStrip1";
+ this.toolStrip1.Size = new System.Drawing.Size(316, 25);
+ this.toolStrip1.TabIndex = 2;
+ this.toolStrip1.Text = "toolStrip1";
+ // btnAddFiles
+ this.btnAddFiles.Image = ((System.Drawing.Image)(resources.GetObject("btnAddFiles.Image")));
+ this.btnAddFiles.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnAddFiles.Name = "btnAddFiles";
+ this.btnAddFiles.Size = new System.Drawing.Size(70, 22);
+ this.btnAddFiles.Text = "Add Files";
+ this.btnAddFiles.Click += new System.EventHandler(this.btnAddFiles_Click);
+ // btnRemoveFiles
+ this.btnRemoveFiles.Enabled = false;
+ this.btnRemoveFiles.Image = ((System.Drawing.Image)(resources.GetObject("btnRemoveFiles.Image")));
+ this.btnRemoveFiles.ImageTransparentColor = System.Drawing.Color.Magenta;
+ this.btnRemoveFiles.Name = "btnRemoveFiles";
+ this.btnRemoveFiles.Size = new System.Drawing.Size(90, 22);
+ this.btnRemoveFiles.Text = "Remove Files";
+ this.btnRemoveFiles.Click += new System.EventHandler(this.btnRemoveFiles_Click);
+ // openFileDlg
+ this.openFileDlg.Multiselect = true;
+ // SourceFilesCtrl
+ this.Controls.Add(this.lstSourceFiles);
+ this.Controls.Add(this.toolStrip1);
+ this.Name = "SourceFilesCtrl";
+ this.Size = new System.Drawing.Size(316, 150);
+ this.toolStrip1.ResumeLayout(false);
+ this.toolStrip1.PerformLayout();
+ #endregion
+ protected System.Windows.Forms.ListBox lstSourceFiles;
+ protected System.Windows.Forms.ToolStrip toolStrip1;
+ protected System.Windows.Forms.ToolStripButton btnAddFiles;
+ protected System.Windows.Forms.ToolStripButton btnRemoveFiles;
+ private System.Windows.Forms.OpenFileDialog openFileDlg;
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.cs (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.cs 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,114 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+namespace OSGeo.MapGuide.Maestro.ResourceEditors.LoadProcedureEditors
+ public partial class SourceFilesCtrl : UserControl
+ public SourceFilesCtrl()
+ public string FileFilter
+ get { return openFileDlg.Filter; }
+ set { openFileDlg.Filter = value; }
+ public string[] SourceFiles
+ get
+ List<string> files = new List<string>();
+ foreach (object item in lstSourceFiles.Items)
+ files.Add(item.ToString());
+ return files.ToArray();
+ set
+ lstSourceFiles.Items.Clear();
+ foreach (string str in value)
+ if (!string.IsNullOrEmpty(str))
+ lstSourceFiles.Items.Add(str);
+ RaiseModified();
+ private void btnAddFiles_Click(object sender, EventArgs e)
+ if (openFileDlg.ShowDialog() == DialogResult.OK)
+ foreach (string f in openFileDlg.FileNames)
+ if (!string.IsNullOrEmpty(f))
+ lstSourceFiles.Items.Add(f);
+ RaiseModified();
+ private void btnRemoveFiles_Click(object sender, EventArgs e)
+ List<object> selected = new List<object>();
+ foreach (object obj in lstSourceFiles.SelectedItems)
+ selected.Add(obj);
+ if (selected.Count > 0)
+ foreach (object obj in selected)
+ lstSourceFiles.Items.Remove(obj);
+ RaiseModified();
+ private void lstSourceFiles_SelectedIndexChanged(object sender, EventArgs e)
+ btnRemoveFiles.Enabled = (lstSourceFiles.SelectedItems.Count > 0);
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.resx (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LoadProcedureEditors/SourceFilesCtrl.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,157 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <metadata name="toolStrip1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="btnAddFiles.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+ iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
+ YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAgxJREFUOE+lkvtL
+ U2EYx+0PEbtpFwnBKPGKiJImGP0gYhIYs1E5GF5gIxkpA00JRSmMEF0ohMh+GaRWYlqabMVcNdS2QpaI
+ VqiDIYhk397vA6fXhCjyhYdzeM/5fp7vczkAdeL2cwho7v/wWzT1zcN+Pwhr51uY2/y41PQaF+wzKKiZ
+ QvaN58g0jyLd5KEUcQbg+84P/Cm2tncQjW3j68YWIqubCC3FcOJc478BAuGoZM6zvoRnakXEruEIjhc4
+ /g5gZop9c+voGAyLbQIfeBZxLL9BA1jzXvuGbWamuKh+GmmVbswE19A59FEBbmoAG7YbsLtm2mZmiml9
+ cvabNDwpz6YB7LYBoMXCumkJr7LOmnnHzBQ/9X2Bo2cOibm1GsBREbAQiYmw/8lnuCeWkVzcgnZlnw1j
+ 3HV/wuNXK6i/9x5Hc6wawDlTXHbLJ+LZUBQPRyKwdQdxutwl1h+NLXHh5Ht1ewBHsiwawCW57HyDAfWR
+ dvl0uhZQ1eqX8aVc7EKLqrum651ATLf9OJx5XQM4KmY0xPzZ0hFAiQJnXB0WwME0E3IsL5B17ZlADqWb
+ NYDrOepdlcysmTWWOrxqbceRWtaLk0VO1XW72D5Vckd2gMBfq8zdpmUG62NJvKM4+XyziDk24xmfWoGE
+ s1c0gHPmbrPTpHNJKOCo2G1mZs20zcwUJ5yp1AB5+8/zEwgF5GMVDxh4AAAAAElFTkSuQmCC
+</value>
+ </data>
+ <data name="btnRemoveFiles.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>
+</value>
+ </data>
+ <metadata name="openFileDlg.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>116, 17</value>
+ </metadata>
+</root>
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceEditors.csproj
--- trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceEditors.csproj 2010-04-12 13:44:33 UTC (rev 4780)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/ResourceEditors.csproj 2010-04-12 13:54:24 UTC (rev 4781)
@@ -551,6 +551,61 @@
<Compile Include="LayoutEditor.cs">
<SubType>UserControl</SubType>
</Compile>
+ <Compile Include="LoadProcedureEditors\AffectedResourceIdsDlg.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\AffectedResourceIdsDlg.Designer.cs">
+ <DependentUpon>AffectedResourceIdsDlg.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\BaseFileLoadProcedureCtrl.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\BaseFileLoadProcedureCtrl.Designer.cs">
+ <DependentUpon>BaseFileLoadProcedureCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\DefaultLoadProcedureCtrl.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\DefaultLoadProcedureCtrl.Designer.cs">
+ <DependentUpon>DefaultLoadProcedureCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\ILoadProcedureEditor.cs" />
+ <Compile Include="LoadProcedureEditors\LoadProcedureCtrl.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\LoadProcedureCtrl.Designer.cs">
+ <DependentUpon>LoadProcedureCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\LoadProcedurePicker.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\LoadProcedurePicker.Designer.cs">
+ <DependentUpon>LoadProcedurePicker.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\LoadSettingsCtrl.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\LoadSettingsCtrl.Designer.cs">
+ <DependentUpon>LoadSettingsCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\SdfLoadProcedureCtrl.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\SdfLoadProcedureCtrl.Designer.cs">
+ <DependentUpon>SdfLoadProcedureCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\ShpLoadProcedureCtrl.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\ShpLoadProcedureCtrl.Designer.cs">
+ <DependentUpon>ShpLoadProcedureCtrl.cs</DependentUpon>
+ </Compile>
+ <Compile Include="LoadProcedureEditors\SourceFilesCtrl.cs">
+ </Compile>
+ <Compile Include="LoadProcedureEditors\SourceFilesCtrl.Designer.cs">
+ <DependentUpon>SourceFilesCtrl.cs</DependentUpon>
+ </Compile>
<Compile Include="MapEditor.cs">
</Compile>
@@ -1082,24 +1137,30 @@
<ItemGroup>
<EmbeddedResource Include="FeatureSourceEditors\Filebased\FilebasedFeatureSourceEditor.resx">
<DependentUpon>FilebasedFeatureSourceEditor.cs</DependentUpon>
+ <SubType>Designer</SubType>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\Filebased\Managed.resx">
<DependentUpon>Managed.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\Filebased\Unmanaged.resx">
<DependentUpon>Unmanaged.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\Gdal\Strings\Composite.resx">
<Generator>ResXFileCodeGenerator</Generator>
<LastGenOutput>Composite.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\Gdal\Strings\ConfigUpdater.resx">
<LastGenOutput>ConfigUpdater.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\Gdal\Strings\Simple.resx">
<LastGenOutput>Simple.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\King.Informix\FeatureSourceEditorKingInformix.resx">
<DependentUpon>FeatureSourceEditorKingInformix.cs</DependentUpon>
@@ -1119,27 +1180,34 @@
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\ODBC\DSNPicker.resx">
<DependentUpon>DSNPicker.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\ODBC\Strings\FeatureSourceEditorODBC.resx">
<LastGenOutput>FeatureSourceEditorODBC.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\OGR\Strings\Managed.resx">
<LastGenOutput>Managed.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\SDF\FeatureSourceEditorSDF.resx">
<DependentUpon>FeatureSourceEditorSDF.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\SHP\FeatureSourceEditorSHP.resx">
<DependentUpon>FeatureSourceEditorSHP.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceEditors\SQLite\FeatureSourceEditorSQLite.resx">
<DependentUpon>FeatureSourceEditorSQLite.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="FeatureSourceExtensions\Strings\FeatureSourceExtension.resx">
<LastGenOutput>FeatureSourceExtension.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="FiniteDisplayScales.resx">
@@ -1147,18 +1215,22 @@
</EmbeddedResource>
<EmbeddedResource Include="GeometryStyleEditors\ColorComboWithTransparency.resx">
<DependentUpon>ColorComboWithTransparency.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="GeometryStyleEditors\Strings\ColorComboBox.resx">
<LastGenOutput>ColorComboBox.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="GeometryStyleEditors\Strings\FontStyleEditor.resx">
<LastGenOutput>FontStyleEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="GeometryStyleEditors\Strings\PointFeatureStyleEditor.resx">
<LastGenOutput>PointFeatureStyleEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="LayerEditorControls\EditScales.resx">
@@ -1167,82 +1239,126 @@
<EmbeddedResource Include="LayerEditorControls\Strings\SchemaSelector.resx">
<LastGenOutput>SchemaSelector.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="LayerEditorControls\Strings\VectorLayer.resx">
<LastGenOutput>VectorLayer.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="LayoutControls\Strings\BasicCommand.resx">
<LastGenOutput>BasicCommand.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="LayoutControls\Strings\InvokeURL.resx">
<LastGenOutput>InvokeURL.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="LayoutControls\Strings\SearchCommand.resx">
<LastGenOutput>SearchCommand.Designer.cs</LastGenOutput>
</EmbeddedResource>
+ <EmbeddedResource Include="LoadProcedureEditors\LoadProcedureCtrl.resx">
+ </EmbeddedResource>
+ <EmbeddedResource Include="LoadProcedureEditors\LoadProcedurePicker.resx">
+ <EmbeddedResource Include="LoadProcedureEditors\LoadSettingsCtrl.resx">
+ <EmbeddedResource Include="LoadProcedureEditors\SdfLoadProcedureCtrl.resx">
+ <EmbeddedResource Include="LoadProcedureEditors\ShpLoadProcedureCtrl.resx">
+ <EmbeddedResource Include="LoadProcedureEditors\SourceFilesCtrl.resx">
<EmbeddedResource Include="Preview layout.ApplicationDefinition" />
<EmbeddedResource Include="Strings\ColorBrewer.resx">
<LastGenOutput>ColorBrewer.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\Common.resx">
<LastGenOutput>Common.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\CoordinateSystemOverride.resx">
<LastGenOutput>CoordinateSystemOverride.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\CoordinateSystemOverrideDialog.resx">
<LastGenOutput>CoordinateSystemOverrideDialog.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\FeatureSourceEditorBase.resx">
<LastGenOutput>FeatureSourceEditorBase.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\FeatureSourceEditorGeneric.resx">
<LastGenOutput>FeatureSourceEditorGeneric.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\FiniteDisplayScales.resx">
<LastGenOutput>FiniteDisplayScales.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\LayerEditor.resx">
<LastGenOutput>LayerEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\LayoutEditor.resx">
<LastGenOutput>LayoutEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\MapEditor.resx">
<LastGenOutput>MapEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\ResourceDataEditor.resx">
<LastGenOutput>ResourceDataEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\ThemeCreator.resx">
<LastGenOutput>ThemeCreator.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\XmlEditor.resx">
<LastGenOutput>XmlEditor.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="Strings\XmlEditorControl.resx">
<LastGenOutput>XmlEditorControl.Designer.cs</LastGenOutput>
</EmbeddedResource>
<EmbeddedResource Include="ThemeCreator.resx">
<DependentUpon>ThemeCreator.cs</DependentUpon>
</EmbeddedResource>
<EmbeddedResource Include="WaitForOperation.resx">
<DependentUpon>WaitForOperation.cs</DependentUpon>
@@ -1250,6 +1366,7 @@
</EmbeddedResource>
<EmbeddedResource Include="XmlEditor.resx">
<DependentUpon>XmlEditor.cs</DependentUpon>
</EmbeddedResource>
</ItemGroup>
<ItemGroup>
@@ -1264,6 +1381,13 @@
<ItemGroup>
<None Include="Resources\GeometryStyleComboDataset.xml" />
</ItemGroup>
+ <ItemGroup>
+ <EmbeddedResource Include="Icons\Unknown.ico" />
+ <EmbeddedResource Include="LoadProcedureEditors\AffectedResourceIdsDlg.resx">
+ </ItemGroup>
<Import Project="$(MSBuildBinPath)\Microsoft.CSharp.targets" />
<PropertyGroup>
<PreBuildEvent>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Sdf Load Procedure.LoadProcedure
--- trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Sdf Load Procedure.LoadProcedure (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Sdf Load Procedure.LoadProcedure 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,16 @@
+<?xml version="1.0" encoding="utf-8" ?>
+<LoadProcedure xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xsi:noNamespaceSchemaLocation="LoadProcedure-1.0.0.xsd">
+ <SdfLoadProcedure>
+ <SourceFile />
+ <RootPath>Library://</RootPath>
+ <CoordinateSystem>LOCAL_CS["Non-Earth (Meter)",LOCAL_DATUM["Local Datum",0],UNIT["Meter", 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystem>
+ <GenerateSpatialDataSources>true</GenerateSpatialDataSources>
+ <SpatialDataSourcesPath />
+ <SpatialDataSourcesFolder>Data</SpatialDataSourcesFolder>
+ <GenerateLayers>true</GenerateLayers>
+ <LayersPath />
+ <LayersFolder>Layers</LayersFolder>
+ <Generalization>100</Generalization>
+ <SdfKeyTreatment>AutogenerateAll</SdfKeyTreatment>
+ </SdfLoadProcedure>
+</LoadProcedure>
Added: trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Shp Load Procedure.LoadProcedure
--- trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Shp Load Procedure.LoadProcedure (rev 0)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/Templates/Shp Load Procedure.LoadProcedure 2010-04-12 13:54:24 UTC (rev 4781)
@@ -0,0 +1,16 @@
+<?xml version="1.0" encoding="utf-8"?>
+ <ShpLoadProcedure>
+ <SourceFile />
+ <LayersPath />
+ <ConvertToSdf>false</ConvertToSdf>
+ </ShpLoadProcedure>
+</LoadProcedure>
Modified: trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx
--- trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx 2010-04-12 13:44:33 UTC (rev 4780)
+++ trunk/Tools/Maestro/Maestro/Strings/TemplateNames.resx 2010-04-12 13:54:24 UTC (rev 4781)
@@ -145,6 +145,14 @@
<value>Print Layout</value>
<comment>The name of the default Print Layout template</comment>
</data>
+ <data name="Sdf_Load_Procedure" xml:space="preserve">
+ <value>SDF Load Procedure</value>
+ <comment>The name of the default SDF Load Procedure template</comment>
+ </data>
+ <data name="Shp_Load_Procedure" xml:space="preserve">
+ <value>SHP Load Procedure</value>
+ <comment>The name of the default SHP Load Procedure template</comment>
+ </data>
<data name="Symbol_Definition" xml:space="preserve">
<value>Symbol Definition</value>
<comment>The name of the default Symbol Definition template</comment>
@@ -153,4 +161,4 @@
<value>Symbol Library</value>
<comment>The name of the default Symbol Library template</comment>
</data>
-</root>
\ No newline at end of file
+</root>
More information about the mapguide-commits
