[mapguide-commits] r4780 - in trunk/Tools/Maestro/MaestroAPI: .
Generated
svn_mapguide at osgeo.org
Mon Apr 12 09:44:34 EDT 2010
Author: jng
Date: 2010-04-12 09:44:33 -0400 (Mon, 12 Apr 2010)
New Revision: 4780
trunk/Tools/Maestro/MaestroAPI/Generated/LoadProcedure-1.0.0.cs
trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs
trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs
#579: This submission adds API support for the basic execution of Load Procedures.
Modified: trunk/Tools/Maestro/MaestroAPI/Generated/LoadProcedure-1.0.0.cs
--- trunk/Tools/Maestro/MaestroAPI/Generated/LoadProcedure-1.0.0.cs 2010-04-12 00:41:31 UTC (rev 4779)
+++ trunk/Tools/Maestro/MaestroAPI/Generated/LoadProcedure-1.0.0.cs 2010-04-12 13:44:33 UTC (rev 4780)
@@ -94,9 +94,9 @@
[System.Xml.Serialization.XmlIncludeAttribute(typeof(DwgLoadProcedureType))]
[System.Xml.Serialization.XmlIncludeAttribute(typeof(ShpLoadProcedureType))]
public class LoadProcedureType {
+ private string[] m_sourceFile;
- private StringCollection m_sourceFile;
private string m_rootPath;
private string m_coordinateSystem;
@@ -129,11 +129,11 @@
private string m_symbolLibrariesFolder;
- private StringCollection m_resourceId;
+ private string[] m_resourceId;
/// <remarks/>
[System.Xml.Serialization.XmlElementAttribute("SourceFile")]
- public StringCollection SourceFile {
+ public string[] SourceFile {
get {
return this.m_sourceFile;
@@ -306,7 +306,7 @@
/// <remarks/>
[System.Xml.Serialization.XmlElementAttribute("ResourceId")]
- public StringCollection ResourceId {
+ public string[] ResourceId {
get {
return this.m_resourceId;
Modified: trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs
--- trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs 2010-04-12 00:41:31 UTC (rev 4779)
+++ trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs 2010-04-12 13:44:33 UTC (rev 4780)
@@ -100,8 +100,8 @@
m_resourceTypeLookup.Add("ApplicationDefinition", typeof(ApplicationDefinition.ApplicationDefinitionType));
m_resourceTypeLookup.Add("SymbolLibrary", typeof(SymbolLibraryType));
m_resourceTypeLookup.Add("PrintLayout", typeof(PrintLayout));
+ m_resourceTypeLookup.Add("LoadProcedure", typeof(LoadProcedure));
m_schemasPath = System.IO.Path.Combine(System.IO.Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location), "Schemas");
m_username = null;
m_password = null;
@@ -2117,6 +2117,445 @@
+ /// <summary>
+ /// Executes the specified load procedure. Only SDF and SHP load procedures are supported.
+ /// Also note that the following load procedure features are ignored during execution:
+ /// - Generalization of data
+ /// - Conversion from SHP to SDF
+ /// - SDF2 to SDF3 conversion
+ /// - SDF3 duplicate key handling
+ /// </summary>
+ /// <param name="resourceID"></param>
+ /// <param name="ignoreUnsupportedFeatures">If false, will throw exceptions when executing a load procedure containing unsupported features.</param>
+ /// <param name="callback"></param>
+ /// <returns>A list of resource IDs that were created from the execution of this load procedure</returns>
+ public string[] ExecuteLoadProcedure(string resourceID, bool ignoreUnsupportedFeatures, LengthyOperationProgressCallBack callback)
+ //TODO: Localize callback messages
+ //TODO: Localize exception messages
+ //TODO: This would currently overwrite everything. In reality, the load procedure has
+ //a list of resource ids which are overwritable, anything not on the list is untouchable.
+ //I presume if this list is empty, then everything is overwritten and the resource list
+ //list is then assigned to the load procedure, which is then updated so that on subsequent runs,
+ //only resources in the list are overwritten instead of everything.
+ string[] resourcesCreatedOrUpdated = null;
+ if (!ResourceIdentifier.Validate(resourceID))
+ throw new ArgumentException("Invalid resource id: " + resourceID);
+ if (ResourceIdentifier.GetExtension(resourceID) != "LoadProcedure")
+ throw new ArgumentException("Not a load procedure resource id: " + resourceID);
+ LengthyOperationProgressCallBack cb = callback;
+ //Assign dummy callback if none specified
+ if (cb == null)
+ cb = delegate { };
+ LoadProcedure proc = (LoadProcedure)GetResource(resourceID);
+ //bool loadProcedureUpdated = false;
+ //bool updateGeneratedResourceIds = false;
+ //TODO: SDF and SHP load procedures share lots of common logic. Merge the two
+ //once everything's all good.
+ SdfLoadProcedureType sdfl = proc.Item as SdfLoadProcedureType;
+ ShpLoadProcedureType shpl = proc.Item as ShpLoadProcedureType;
+ if (sdfl != null)
+ if (!ignoreUnsupportedFeatures)
+ //Anything less than 100% implies use of generalization
+ if (sdfl.Generalization < 100.0)
+ throw new NotSupportedException("Generalization of data is not supported");
+ resourcesCreatedOrUpdated = ExecuteSdfLoadProcedure(cb, sdfl);
+ else if (shpl != null)
+ if (shpl.Generalization < 100.0)
+ //Can't do this because we don't have a portable .net FDO/MG Feature Service
+ if (shpl.ConvertToSdf)
+ throw new NotSupportedException("Conversion of SHP files to SDF files is not supported");
+ resourcesCreatedOrUpdated = ExecuteShpLoadProcedure(cb, shpl);
+ else //We don't support anything else (and probably never will)
+ throw new NotSupportedException("Unsupported load procedure type");
+ proc.Item.ResourceId = resourcesCreatedOrUpdated;
+ this.SaveResourceAs(proc, resourceID);
+ return resourcesCreatedOrUpdated;
+ private string[] ExecuteShpLoadProcedure(LengthyOperationProgressCallBack cb, ShpLoadProcedureType shpl)
+ List<string> resCreatedOrUpdated = new List<string>();
+ string[] shpFiles = shpl.SourceFile;
+ int pcPerFile = (int)(100 / shpFiles.Length);
+ int current = 0;
+ string fsRoot = shpl.SpatialDataSourcesPath + shpl.SpatialDataSourcesFolder;
+ string layerRoot = shpl.LayersPath + shpl.LayersFolder;
+ if (!fsRoot.EndsWith("/"))
+ fsRoot += "/";
+ if (!layerRoot.EndsWith("/"))
+ layerRoot += "/";
+ Dictionary<string, List<string>> extraFiles = new Dictionary<string, List<string>>();
+ //Unlike SDF, a SHP file actually consists of multiple files
+ foreach (string shp in shpFiles)
+ if (!extraFiles.ContainsKey(shp))
+ extraFiles[shp] = new List<string>();
+ //we want to preserve casing for everything before the extension
+ string prefix = shp.Substring(0, shp.LastIndexOf(".") + 1);
+ extraFiles[shp].Add(prefix + "shx");
+ extraFiles[shp].Add(prefix + "dbf");
+ extraFiles[shp].Add(prefix + "idx");
+ extraFiles[shp].Add(prefix + "prj");
+ extraFiles[shp].Add(prefix + "cpg");
+ //TODO: Are we missing anything else?
+ foreach (string file in shpFiles)
+ bool success = false;
+ if (System.IO.File.Exists(file))
+ string resName = System.IO.Path.GetFileNameWithoutExtension(file);
+ string dataName = System.IO.Path.GetFileName(file);
+ string fsId = fsRoot + resName + ".FeatureSource";
+ string lyrId = layerRoot + resName + ".LayerDefinition";
+ if (shpl.GenerateSpatialDataSources)
+ //Process is as follows:
+ // 1. Create and save feature source document.
+ // 2. Upload sdf file as resource data for this document.
+ // 3. Test the connection, it should check out.
+ // 4. If no spatial contexts are detected, assign a default one from the load procedure and save the modified feature source.
+ //Step 1: Create feature source document
+ FeatureSource fs = new FeatureSource();
+ fs.ResourceId = fsId;
+ fs.Provider = "OSGeo.SHP";
+ fs.Parameter = new NameValuePairTypeCollection();
+ fs.Parameter.Add(new NameValuePairType() { Name = "DefaultFileLocation", Value = "%MG_DATA_FILE_PATH%" + dataName });
+ this.SaveResource(fs);
+ resCreatedOrUpdated.Add(fsId);
+ cb(this, new LengthyOperationProgressArgs("Created: " + fsId, current));
+ //TODO: When the infrastructure is available to us (ie. A portable .net FDO/MG Feature Service API wrapper)
+ //Maybe then we can actually implement the generalization and conversion properties. Until then, we skip
+ //these options
+ //Step 2: Load resource data for document
+ this.SetResourceData(fsId, dataName, ResourceDataType.File, System.IO.File.OpenRead(file));
+ cb(this, new LengthyOperationProgressArgs("Loaded: " + file, current));
+ //Load supplementary files
+ foreach (string extraFile in extraFiles[file])
+ string dn = System.IO.Path.GetFileName(extraFile);
+ if (System.IO.File.Exists(extraFile))
+ this.SetResourceData(fsId, dn, ResourceDataType.File, System.IO.File.OpenRead(extraFile));
+ cb(this, new LengthyOperationProgressArgs("Loaded: " + extraFile, current));
+ //Step 3: Test to make sure we're all good so far
+ string result = this.TestConnection(fsId);
+ //LocalNativeConnection returns this string, so I'm assuming this is the "success" result
+ if (result == "No errors")
+ //Step 4: Test to see if default cs needs to be specified
+ FdoSpatialContextList spatialContexts = this.GetSpatialContextInfo(fsId, false);
+ if (spatialContexts.SpatialContext.Count == 0 && !string.IsNullOrEmpty(shpl.CoordinateSystem))
+ //Register the default CS from the load procedure
+ fs.SupplementalSpatialContextInfo = new SpatialContextTypeCollection();
+ fs.SupplementalSpatialContextInfo.Add(new SpatialContextType()
+ Name = "Default",
+ CoordinateSystem = shpl.CoordinateSystem
+ //Update this feature source
+ cb(this, new LengthyOperationProgressArgs("Set default spatial context for: " + fsId, current));
+ if (shpl.GenerateLayers)
+ // 1. Describe the schema of the feature source
+ // 2. If it contains at least one feature class, create a layer definition
+ // 3. Set the following layer definition properties:
+ // - Feature Source: the feature source id
+ // - Feature Class: the first feature class in the schema
+ // - Geometry: the first geometry property in the first feature class
+ // 4. Infer the supported geometry types for this feature class. Toggle supported styles accordingly.
+ //Step 1: Describe the schema
+ FeatureSourceDescription desc = DescribeFeatureSource(fsId);
+ if (desc.Schemas.Length > 0)
+ //Step 2: Find the first feature class with a geometry property
+ FeatureSourceDescription.FeatureSourceSchema clsDef = null;
+ FeatureSetColumn geom = null;
+ bool done = false;
+ foreach (FeatureSourceDescription.FeatureSourceSchema cls in desc.Schemas)
+ if (done) break;
+ foreach (FeatureSetColumn prop in cls.Columns)
+ if (done) break;
+ if (typeof(Topology.Geometries.IGeometry).IsAssignableFrom(prop.Type))
+ clsDef = cls;
+ geom = prop;
+ done = true;
+ if (clsDef != null && geom != null)
+ LayerDefinition ld = CreateResourceObject<LayerDefinition>();
+ //Step 3: Assign default properties
+ ld.ResourceId = lyrId;
+ VectorLayerDefinitionType vld = ld.Item as VectorLayerDefinitionType;
+ vld.ResourceId = fsId;
+ vld.FeatureName = clsDef.Fullname;
+ vld.Geometry = geom.Name;
+ this.SaveResource(ld);
+ resCreatedOrUpdated.Add(lyrId);
+ cb(this, new LengthyOperationProgressArgs("Created: " + lyrId, current));
+ //Step 4: Infer geometry storage support and remove unsupported styles
+ //TODO: There doesn't seem to be a MaestroAPI way to figure out geometry storage types atm
+ success = true;
+ else
+ cb(this, new LengthyOperationProgressArgs("File not found: " + file, current));
+ //This file is now fully processed, so increment progress
+ current += pcPerFile;
+ if (success)
+ cb(this, new LengthyOperationProgressArgs("Success: " + file, current));
+ return resCreatedOrUpdated.ToArray();
+ private string[] ExecuteSdfLoadProcedure(LengthyOperationProgressCallBack cb, SdfLoadProcedureType sdfl)
+ string[] files = sdfl.SourceFile;
+ int pcPerFile = (int)(100 / files.Length);
+ int current = 0;
+ string fsRoot = sdfl.SpatialDataSourcesPath + sdfl.SpatialDataSourcesFolder;
+ string layerRoot = sdfl.LayersPath + sdfl.LayersFolder;
+ fsRoot += "/";
+ layerRoot += "/";
+ foreach (string file in files)
+ //GOTCHA: We are assuming these SDF files are not SDF2 files. This is
+ //because there is no multi-platform solution to convert SDF2 files to SDF3
+ if (sdfl.GenerateSpatialDataSources)
+ fs.Provider = "OSGeo.SDF";
+ fs.Parameter.Add(new NameValuePairType() { Name = "File", Value = "%MG_DATA_FILE_PATH%" + dataName });
+ //Maybe then we can actually implement the generalization and duplicate record handling properties. Until then, we skip
+ //these options
+ if (spatialContexts.SpatialContext.Count == 0 && !string.IsNullOrEmpty(sdfl.CoordinateSystem))
+ Name = "Default",
+ CoordinateSystem = sdfl.CoordinateSystem
+ if (sdfl.GenerateLayers)
+ if (done) break;
+ if (done) break;
+ clsDef = cls;
+ geom = prop;
+ done = true;
+ success = true;
+ else
+ if (success)
+ cb(this, new LengthyOperationProgressArgs("File processed: " + file, current));
Modified: trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs
--- trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs 2010-04-12 00:41:31 UTC (rev 4779)
+++ trunk/Tools/Maestro/MaestroAPI/ServerConnectionI.cs 2010-04-12 13:44:33 UTC (rev 4780)
@@ -398,5 +398,14 @@
/// <typeparam name="T">The type of the object to create</typeparam>
/// <returns>A new instance of the object</returns>
T CreateResourceObject<T>();
+ /// <summary>
+ /// </summary>
+ /// <param name="ignoreUnsupportedFeatures"></param>
+ string[] ExecuteLoadProcedure(string resourceID, bool ignoreUnsupportedFeatures, LengthyOperationProgressCallBack callback);
More information about the mapguide-commits
