[mapguide-commits] r5038 - in trunk/MgDev/Common: CoordinateSystem
Geometry/CoordinateSystem
svn_mapguide at osgeo.org
Mon Jul 19 12:28:44 EDT 2010
Author: NormOlsen
Date: 2010-07-19 16:28:44 +0000 (Mon, 19 Jul 2010)
New Revision: 5038
trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
trunk/MgDev/Common/CoordinateSystem/CoordSys.h
trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
RFC 98, MapGuide Trac # 1405
This submission exposes the new EPSG, SRID, and EPSG Quadrant information added to the CS-MAP dictionaries by CS-MAP RFC 3. There is no change to any existing API. The new API's will return zero if the requested information is not known; thus no exceptions are thrown.
The trhee new API's are all members of the MgCoordinateSystem interface and are as follows:
INT32 GetEpsgCode (void);
INT32 GetSridCode (void);
INT16 GetEpsgQuadrant (void);
__NOTE__ Following this submission, version #1868 of CS-MAP is required in order to achieve a successful build.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-07-19 13:36:22 UTC (rev 5037)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.cpp 2010-07-19 16:28:44 UTC (rev 5038)
@@ -1268,7 +1268,37 @@
return m_pEllipsoid->GetDescription();
+/// <summary>
+/// Returns the EPSG code for this system, else zero.
+/// </summary>
+INT32 CCoordinateSystem::GetEpsgCode (void)
+ return static_cast<INT32>(m_csprm.csdef.epsgNbr);
+/// <summary>
+/// Returns the Oracle SRID code for this system, else zero.
+/// </summary>
+INT32 CCoordinateSystem::GetSridCode (void)
+ return static_cast<INT32>(m_csprm.csdef.srid);
+/// <summary>
+/// Returns the quadrant specification in the EPSG data set for
+/// this definition. The returned value is zero if the system
+/// does not have an EPSG equivalent. The format of the
+/// returned value is in the same form as the CS-MAP quad value,
+/// but the value may be different. CS-MAP definitions often
+/// ignore the swapping of axes as is indicated in the EPSG
+/// database. Not doing so produces rotated and mirroed displays
+/// which are _NOT_ what the customer desires or expects.
+/// </summary>
+INT16 CCoordinateSystem::GetEpsgQuadrant (void)
+ return static_cast<INT16>(m_csprm.csdef.epsg_qd);
MgStringCollection* CCoordinateSystem::GetCategories()
@@ -3025,7 +3055,7 @@
m_csprm.csdef.quad = 1;
m_csprm.csdef.order = m_csprm.csdef.zones = 0;
- m_csprm.csdef.auto_geoid = m_csprm.csdef.elev_tech = 0;
+ m_csprm.csdef.epsgNbr = m_csprm.csdef.srid = m_csprm.csdef.epsg_qd = 0;
//Set defaults specifically according to the current projection
//type. If the current projection type is undefined, set to zero.
Modified: trunk/MgDev/Common/CoordinateSystem/CoordSys.h
--- trunk/MgDev/Common/CoordinateSystem/CoordSys.h 2010-07-19 13:36:22 UTC (rev 5037)
+++ trunk/MgDev/Common/CoordinateSystem/CoordSys.h 2010-07-19 16:28:44 UTC (rev 5038)
@@ -72,6 +72,10 @@
virtual STRING GetEllipsoid(); /// __get
virtual STRING GetEllipsoidDescription(); /// __get
+ virtual INT32 GetEpsgCode (void); /// __get
+ virtual INT32 GetSridCode (void); /// __get
+ virtual INT16 GetEpsgQuadrant (void); /// __get
virtual MgCoordinateSystemMeasure* GetMeasure();
virtual MgStringCollection* GetCategories();
virtual MgCoordinateSystemCatalog* GetCatalog();
Modified: trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h
--- trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h 2010-07-19 13:36:22 UTC (rev 5037)
+++ trunk/MgDev/Common/Geometry/CoordinateSystem/CoordinateSystem.h 2010-07-19 16:28:44 UTC (rev 5038)
@@ -58,6 +58,10 @@
virtual STRING GetEllipsoid()=0; /// __get
virtual STRING GetEllipsoidDescription()=0; /// __get
+ virtual INT32 GetEpsgCode (void)=0; /// __get
+ virtual INT32 GetSridCode (void)=0; /// __get
+ virtual INT16 GetEpsgQuadrant (void)=0; /// __get
virtual MgCoordinateSystemMeasure* GetMeasure()=0;
virtual MgStringCollection* GetCategories()=0;
virtual MgCoordinateSystemCatalog* GetCatalog()=0;
More information about the mapguide-commits
