[mapguide-commits] r5039 - in sandbox/maestro-3.0: Generated
Maestro.Editors Maestro.Editors/FeatureSource
Maestro.Editors/FeatureSource/Extensions
Maestro.Editors/LayerDefinition/Vector
Maestro.Editors/MapDefinition Maestro.Editors/Properties
Maestro.Shared.UI OSGeo.MapGuide.MaestroAPI/Feature
svn_mapguide at osgeo.org
Mon Jul 19 12:58:26 EDT 2010
Author: jng
Date: 2010-07-19 16:58:26 +0000 (Mon, 19 Jul 2010)
New Revision: 5039
Added:
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx
sandbox/maestro-3.0/Maestro.Shared.UI/CheckBoxBinder.cs
sandbox/maestro-3.0/Maestro.Shared.UI/TextBoxBinder.cs
sandbox/maestro-3.0/Generated/FeatureSource-1.0.0.designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSourceDescription.cs
This submission includes the first cut of the redesigned feature source extension editor.
Modified: sandbox/maestro-3.0/Generated/FeatureSource-1.0.0.designer.cs
--- sandbox/maestro-3.0/Generated/FeatureSource-1.0.0.designer.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Generated/FeatureSource-1.0.0.designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -1220,6 +1220,7 @@
set {
if ((forceOneToOneField.Equals(value) != true)) {
this.forceOneToOneField = value;
+ this.ForceOneToOneSpecified = true;
this.OnPropertyChanged("ForceOneToOne");
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,112 @@
+namespace Maestro.Editors.FeatureSource.Extensions
+ partial class CalculationSettings
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Component Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.label1 = new System.Windows.Forms.Label();
+ this.label2 = new System.Windows.Forms.Label();
+ this.txtName = new System.Windows.Forms.TextBox();
+ this.txtExpression = new System.Windows.Forms.TextBox();
+ this.lnkEdit = new System.Windows.Forms.LinkLabel();
+ this.SuspendLayout();
+ // label1
+ this.label1.AutoSize = true;
+ this.label1.Location = new System.Drawing.Point(11, 13);
+ this.label1.Name = "label1";
+ this.label1.Size = new System.Drawing.Size(130, 13);
+ this.label1.TabIndex = 0;
+ this.label1.Text = "Calculated Property Name";
+ // label2
+ this.label2.AutoSize = true;
+ this.label2.Location = new System.Drawing.Point(11, 62);
+ this.label2.Name = "label2";
+ this.label2.Size = new System.Drawing.Size(58, 13);
+ this.label2.TabIndex = 1;
+ this.label2.Text = "Expression";
+ // txtName
+ this.txtName.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ | System.Windows.Forms.AnchorStyles.Right)));
+ this.txtName.Location = new System.Drawing.Point(14, 29);
+ this.txtName.Name = "txtName";
+ this.txtName.Size = new System.Drawing.Size(461, 20);
+ this.txtName.TabIndex = 2;
+ // txtExpression
+ this.txtExpression.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ | System.Windows.Forms.AnchorStyles.Left)
+ this.txtExpression.Location = new System.Drawing.Point(14, 78);
+ this.txtExpression.Multiline = true;
+ this.txtExpression.Name = "txtExpression";
+ this.txtExpression.ReadOnly = true;
+ this.txtExpression.Size = new System.Drawing.Size(461, 237);
+ this.txtExpression.TabIndex = 3;
+ // lnkEdit
+ this.lnkEdit.AutoSize = true;
+ this.lnkEdit.Location = new System.Drawing.Point(75, 62);
+ this.lnkEdit.Name = "lnkEdit";
+ this.lnkEdit.Size = new System.Drawing.Size(25, 13);
+ this.lnkEdit.TabIndex = 4;
+ this.lnkEdit.TabStop = true;
+ this.lnkEdit.Text = "Edit";
+ this.lnkEdit.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkEdit_LinkClicked);
+ // CalculationSettings
+ this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.lnkEdit);
+ this.Controls.Add(this.txtExpression);
+ this.Controls.Add(this.txtName);
+ this.Controls.Add(this.label2);
+ this.Controls.Add(this.label1);
+ this.Name = "CalculationSettings";
+ this.Size = new System.Drawing.Size(491, 330);
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.Label label1;
+ private System.Windows.Forms.Label label2;
+ private System.Windows.Forms.TextBox txtName;
+ private System.Windows.Forms.TextBox txtExpression;
+ private System.Windows.Forms.LinkLabel lnkEdit;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,63 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+using OSGeo.MapGuide.MaestroAPI;
+using Maestro.Shared.UI;
+ public partial class CalculationSettings : UserControl
+ private CalculationSettings()
+ InitializeComponent();
+ private IEditorService _edSvc;
+ private FeatureSourceDescription.FeatureSourceSchema _cls;
+ private FeatureSourceType _parent;
+ public CalculationSettings(IEditorService edSvc, FeatureSourceDescription.FeatureSourceSchema cls, FeatureSourceType parent, CalculatedPropertyType calc)
+ : this()
+ _edSvc = edSvc;
+ _cls = cls;
+ _parent = parent;
+ TextBoxBinder.BindText(txtExpression, calc, "Expression");
+ TextBoxBinder.BindText(txtName, calc, "Name");
+ private void lnkEdit_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ string expr = _edSvc.EditExpression(txtExpression.Text, _cls, _parent.Provider, _parent.ResourceID);
+ if (expr != null)
+ txtExpression.Text = expr;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/CalculationSettings.resx 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,97 @@
+ partial class ExtendedClassSettings
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ /// <summary>
+ /// </summary>
+ this.txtExtendedName = new System.Windows.Forms.TextBox();
+ this.cmbBaseClass = new System.Windows.Forms.ComboBox();
+ // label1
+ this.label1.Location = new System.Drawing.Point(14, 16);
+ this.label1.Size = new System.Drawing.Size(162, 13);
+ this.label1.Text = "Name of Extended Feature Class";
+ // txtExtendedName
+ this.txtExtendedName.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.txtExtendedName.Location = new System.Drawing.Point(17, 32);
+ this.txtExtendedName.Name = "txtExtendedName";
+ this.txtExtendedName.Size = new System.Drawing.Size(289, 20);
+ this.txtExtendedName.TabIndex = 1;
+ // label2
+ this.label2.Location = new System.Drawing.Point(14, 72);
+ this.label2.Size = new System.Drawing.Size(119, 13);
+ this.label2.TabIndex = 2;
+ this.label2.Text = "Feature Class to Extend";
+ // cmbBaseClass
+ this.cmbBaseClass.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.cmbBaseClass.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbBaseClass.FormattingEnabled = true;
+ this.cmbBaseClass.Location = new System.Drawing.Point(17, 89);
+ this.cmbBaseClass.Name = "cmbBaseClass";
+ this.cmbBaseClass.Size = new System.Drawing.Size(289, 21);
+ this.cmbBaseClass.TabIndex = 3;
+ // ExtendedClassSettings
+ this.Controls.Add(this.cmbBaseClass);
+ this.Controls.Add(this.txtExtendedName);
+ this.Name = "ExtendedClassSettings";
+ this.Size = new System.Drawing.Size(327, 212);
+ #endregion
+ private System.Windows.Forms.TextBox txtExtendedName;
+ private System.Windows.Forms.ComboBox cmbBaseClass;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,73 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+ public partial class ExtendedClassSettings : UserControl, IEditorBindable
+ private ExtendedClassSettings()
+ public ExtendedClassSettings(FeatureSourceDescription.FeatureSourceSchema[] classes, FeatureSourceTypeExtension ext)
+ : this()
+ cmbBaseClass.DisplayMember = "Fullname";
+ cmbBaseClass.ValueMember = "Fullname";
+ cmbBaseClass.DataSource = classes;
+ //txtExtendedName.DataBindings.Add("Text", ext, "Name");
+ TextBoxBinder.BindText(txtExtendedName, ext, "Name");
+ cmbBaseClass.DataBindings.Add("SelectedValue", ext, "FeatureClass");
+ ext.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+ //private void txtExtendedName_TextChanged(object sender, EventArgs e)
+ // txtExtendedName.DataBindings[0].WriteValue();
+ public void Bind(IEditorService service)
+ service.RegisterCustomNotifier(this);
+ private void OnResourceChanged()
+ var handler = this.ResourceChanged;
+ if (handler != null)
+ handler(this, EventArgs.Empty);
+ public event EventHandler ResourceChanged;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/ExtendedClassSettings.resx 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,120 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -41,9 +41,18 @@
this.rdRightOuter = new System.Windows.Forms.RadioButton();
this.rdLeftOuter = new System.Windows.Forms.RadioButton();
this.chkForceOneToOne = new System.Windows.Forms.CheckBox();
+ this.grdJoinKeys = new System.Windows.Forms.DataGridView();
+ this.groupBox1 = new System.Windows.Forms.GroupBox();
+ this.lnkDelete = new System.Windows.Forms.LinkLabel();
+ this.lnkAdd = new System.Windows.Forms.LinkLabel();
+ this.cmbSecondary = new System.Windows.Forms.ComboBox();
+ this.cmbPrimary = new System.Windows.Forms.ComboBox();
+ this.label6 = new System.Windows.Forms.Label();
this.label5 = new System.Windows.Forms.Label();
- this.grdJoinKeys = new System.Windows.Forms.DataGridView();
+ this.COL_PRIMARY = new System.Windows.Forms.DataGridViewTextBoxColumn();
+ this.COL_SECONDARY = new System.Windows.Forms.DataGridViewTextBoxColumn();
((System.ComponentModel.ISupportInitialize)(this.grdJoinKeys)).BeginInit();
+ this.groupBox1.SuspendLayout();
// label1
@@ -70,7 +79,7 @@
this.txtJoinName.Location = new System.Drawing.Point(144, 12);
this.txtJoinName.Name = "txtJoinName";
- this.txtJoinName.Size = new System.Drawing.Size(195, 20);
+ this.txtJoinName.Size = new System.Drawing.Size(296, 20);
this.txtJoinName.TabIndex = 2;
// txtFeatureSource
@@ -79,18 +88,20 @@
this.txtFeatureSource.Location = new System.Drawing.Point(144, 38);
this.txtFeatureSource.Name = "txtFeatureSource";
- this.txtFeatureSource.Size = new System.Drawing.Size(162, 20);
+ this.txtFeatureSource.ReadOnly = true;
+ this.txtFeatureSource.Size = new System.Drawing.Size(263, 20);
this.txtFeatureSource.TabIndex = 3;
// btnBrowse
this.btnBrowse.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Right)));
- this.btnBrowse.Location = new System.Drawing.Point(312, 36);
+ this.btnBrowse.Location = new System.Drawing.Point(413, 36);
this.btnBrowse.Name = "btnBrowse";
this.btnBrowse.Size = new System.Drawing.Size(27, 23);
this.btnBrowse.TabIndex = 4;
this.btnBrowse.Text = "...";
this.btnBrowse.UseVisualStyleBackColor = true;
+ this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
// label3
@@ -105,11 +116,15 @@
this.cmbFeatureClass.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.cmbFeatureClass.DisplayMember = "Fullname";
+ this.cmbFeatureClass.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
this.cmbFeatureClass.FormattingEnabled = true;
this.cmbFeatureClass.Location = new System.Drawing.Point(144, 65);
this.cmbFeatureClass.Name = "cmbFeatureClass";
- this.cmbFeatureClass.Size = new System.Drawing.Size(195, 21);
+ this.cmbFeatureClass.Size = new System.Drawing.Size(296, 21);
this.cmbFeatureClass.TabIndex = 6;
+ this.cmbFeatureClass.ValueMember = "Fullname";
+ this.cmbFeatureClass.SelectionChangeCommitted += new System.EventHandler(this.cmbFeatureClass_SelectedIndexChanged);
// label4
@@ -122,55 +137,56 @@
// rdAssociation
- this.rdAssociation.AutoSize = true;
this.rdAssociation.Image = global::Maestro.Editors.Properties.Resources.databases_relation;
- this.rdAssociation.Location = new System.Drawing.Point(243, 122);
+ this.rdAssociation.Location = new System.Drawing.Point(243, 115);
this.rdAssociation.Name = "rdAssociation";
- this.rdAssociation.Size = new System.Drawing.Size(95, 17);
+ this.rdAssociation.Size = new System.Drawing.Size(105, 24);
this.rdAssociation.TabIndex = 11;
this.rdAssociation.TabStop = true;
this.rdAssociation.Text = "Association";
this.rdAssociation.TextImageRelation = System.Windows.Forms.TextImageRelation.ImageBeforeText;
this.rdAssociation.UseVisualStyleBackColor = true;
+ this.rdAssociation.CheckedChanged += new System.EventHandler(this.rdJoinTypeChanged);
// rdInner
- this.rdInner.AutoSize = true;
this.rdInner.Image = global::Maestro.Editors.Properties.Resources.sql_join_inner;
- this.rdInner.Location = new System.Drawing.Point(144, 122);
+ this.rdInner.Location = new System.Drawing.Point(144, 115);
this.rdInner.Name = "rdInner";
- this.rdInner.Size = new System.Drawing.Size(65, 17);
+ this.rdInner.Size = new System.Drawing.Size(75, 24);
this.rdInner.TabIndex = 10;
this.rdInner.TabStop = true;
this.rdInner.Text = "Inner";
this.rdInner.TextImageRelation = System.Windows.Forms.TextImageRelation.ImageBeforeText;
this.rdInner.UseVisualStyleBackColor = true;
+ this.rdInner.CheckedChanged += new System.EventHandler(this.rdJoinTypeChanged);
// rdRightOuter
- this.rdRightOuter.AutoSize = true;
this.rdRightOuter.Image = global::Maestro.Editors.Properties.Resources.sql_join_right;
- this.rdRightOuter.Location = new System.Drawing.Point(243, 99);
+ this.rdRightOuter.Location = new System.Drawing.Point(243, 92);
this.rdRightOuter.Name = "rdRightOuter";
- this.rdRightOuter.Size = new System.Drawing.Size(95, 17);
+ this.rdRightOuter.Size = new System.Drawing.Size(105, 24);
this.rdRightOuter.TabIndex = 9;
this.rdRightOuter.TabStop = true;
this.rdRightOuter.Text = "Right Outer";
this.rdRightOuter.TextImageRelation = System.Windows.Forms.TextImageRelation.ImageBeforeText;
this.rdRightOuter.UseVisualStyleBackColor = true;
+ this.rdRightOuter.CheckedChanged += new System.EventHandler(this.rdJoinTypeChanged);
// rdLeftOuter
- this.rdLeftOuter.AutoSize = true;
+ this.rdLeftOuter.Checked = true;
this.rdLeftOuter.Image = global::Maestro.Editors.Properties.Resources.sql_join_left;
- this.rdLeftOuter.Location = new System.Drawing.Point(144, 99);
+ this.rdLeftOuter.Location = new System.Drawing.Point(144, 92);
this.rdLeftOuter.Name = "rdLeftOuter";
- this.rdLeftOuter.Size = new System.Drawing.Size(88, 17);
+ this.rdLeftOuter.Size = new System.Drawing.Size(98, 24);
this.rdLeftOuter.TabIndex = 8;
this.rdLeftOuter.TabStop = true;
this.rdLeftOuter.Text = "Left Outer";
this.rdLeftOuter.TextImageRelation = System.Windows.Forms.TextImageRelation.ImageBeforeText;
this.rdLeftOuter.UseVisualStyleBackColor = true;
+ this.rdLeftOuter.CheckedChanged += new System.EventHandler(this.rdJoinTypeChanged);
// chkForceOneToOne
@@ -182,29 +198,129 @@
this.chkForceOneToOne.Text = "Force 1-to-1";
this.chkForceOneToOne.UseVisualStyleBackColor = true;
+ // grdJoinKeys
+ this.grdJoinKeys.AllowUserToAddRows = false;
+ this.grdJoinKeys.AllowUserToDeleteRows = false;
+ this.grdJoinKeys.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.grdJoinKeys.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
+ this.grdJoinKeys.Columns.AddRange(new System.Windows.Forms.DataGridViewColumn[] {
+ this.COL_PRIMARY,
+ this.COL_SECONDARY});
+ this.grdJoinKeys.Location = new System.Drawing.Point(6, 76);
+ this.grdJoinKeys.Name = "grdJoinKeys";
+ this.grdJoinKeys.ReadOnly = true;
+ this.grdJoinKeys.Size = new System.Drawing.Size(418, 138);
+ this.grdJoinKeys.TabIndex = 14;
+ this.grdJoinKeys.CellClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdJoinKeys_CellClick);
+ this.grdJoinKeys.CellContentClick += new System.Windows.Forms.DataGridViewCellEventHandler(this.grdJoinKeys_CellClick);
+ // groupBox1
+ this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)((((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Bottom)
+ this.groupBox1.Controls.Add(this.lnkDelete);
+ this.groupBox1.Controls.Add(this.lnkAdd);
+ this.groupBox1.Controls.Add(this.cmbSecondary);
+ this.groupBox1.Controls.Add(this.cmbPrimary);
+ this.groupBox1.Controls.Add(this.label6);
+ this.groupBox1.Controls.Add(this.label5);
+ this.groupBox1.Controls.Add(this.grdJoinKeys);
+ this.groupBox1.Location = new System.Drawing.Point(10, 145);
+ this.groupBox1.Name = "groupBox1";
+ this.groupBox1.Size = new System.Drawing.Size(430, 220);
+ this.groupBox1.TabIndex = 15;
+ this.groupBox1.TabStop = false;
+ this.groupBox1.Text = "Join Properties (Must specify at least one)";
+ // lnkDelete
+ this.lnkDelete.BackColor = System.Drawing.Color.Transparent;
+ this.lnkDelete.Enabled = false;
+ this.lnkDelete.Location = new System.Drawing.Point(61, 49);
+ this.lnkDelete.Name = "lnkDelete";
+ this.lnkDelete.Size = new System.Drawing.Size(60, 13);
+ this.lnkDelete.TabIndex = 20;
+ this.lnkDelete.TabStop = true;
+ this.lnkDelete.Text = "Delete Pair";
+ this.lnkDelete.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkDelete_LinkClicked);
+ // lnkAdd
+ this.lnkAdd.BackColor = System.Drawing.Color.Transparent;
+ this.lnkAdd.Enabled = false;
+ this.lnkAdd.Location = new System.Drawing.Point(7, 49);
+ this.lnkAdd.Name = "lnkAdd";
+ this.lnkAdd.Size = new System.Drawing.Size(48, 13);
+ this.lnkAdd.TabIndex = 19;
+ this.lnkAdd.TabStop = true;
+ this.lnkAdd.Text = "Add Pair";
+ this.lnkAdd.LinkClicked += new System.Windows.Forms.LinkLabelLinkClickedEventHandler(this.lnkAdd_LinkClicked);
+ // cmbSecondary
+ this.cmbSecondary.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+ this.cmbSecondary.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbSecondary.FormattingEnabled = true;
+ this.cmbSecondary.Location = new System.Drawing.Point(311, 17);
+ this.cmbSecondary.Name = "cmbSecondary";
+ this.cmbSecondary.Size = new System.Drawing.Size(113, 21);
+ this.cmbSecondary.TabIndex = 18;
+ this.cmbSecondary.SelectedIndexChanged += new System.EventHandler(this.CheckAddStatus);
+ // cmbPrimary
+ this.cmbPrimary.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+ this.cmbPrimary.FormattingEnabled = true;
+ this.cmbPrimary.Location = new System.Drawing.Point(95, 17);
+ this.cmbPrimary.Name = "cmbPrimary";
+ this.cmbPrimary.Size = new System.Drawing.Size(104, 21);
+ this.cmbPrimary.TabIndex = 17;
+ this.cmbPrimary.SelectedIndexChanged += new System.EventHandler(this.CheckAddStatus);
+ // label6
+ this.label6.AutoSize = true;
+ this.label6.Location = new System.Drawing.Point(205, 20);
+ this.label6.Name = "label6";
+ this.label6.Size = new System.Drawing.Size(100, 13);
+ this.label6.TabIndex = 16;
+ this.label6.Text = "Secondary Property";
// label5
this.label5.AutoSize = true;
- this.label5.Location = new System.Drawing.Point(10, 146);
+ this.label5.Location = new System.Drawing.Point(6, 20);
this.label5.Name = "label5";
- this.label5.Size = new System.Drawing.Size(202, 13);
- this.label5.TabIndex = 13;
- this.label5.Text = "Join Properties (Must specify at least one)";
+ this.label5.Size = new System.Drawing.Size(83, 13);
+ this.label5.TabIndex = 15;
+ this.label5.Text = "Primary Property";
- // grdJoinKeys
+ // COL_PRIMARY
- this.grdJoinKeys.ColumnHeadersHeightSizeMode = System.Windows.Forms.DataGridViewColumnHeadersHeightSizeMode.AutoSize;
- this.grdJoinKeys.Location = new System.Drawing.Point(13, 163);
- this.grdJoinKeys.Name = "grdJoinKeys";
- this.grdJoinKeys.Size = new System.Drawing.Size(325, 68);
- this.grdJoinKeys.TabIndex = 14;
+ this.COL_PRIMARY.DataPropertyName = "FeatureClassProperty";
+ this.COL_PRIMARY.HeaderText = "Primary";
+ this.COL_PRIMARY.Name = "COL_PRIMARY";
+ this.COL_PRIMARY.ReadOnly = true;
+ this.COL_PRIMARY.Width = 130;
+ // COL_SECONDARY
+ this.COL_SECONDARY.AutoSizeMode = System.Windows.Forms.DataGridViewAutoSizeColumnMode.Fill;
+ this.COL_SECONDARY.DataPropertyName = "AttributeClassProperty";
+ this.COL_SECONDARY.HeaderText = "Secondary";
+ this.COL_SECONDARY.Name = "COL_SECONDARY";
+ this.COL_SECONDARY.ReadOnly = true;
// JoinSettings
- this.Controls.Add(this.grdJoinKeys);
- this.Controls.Add(this.label5);
+ this.Controls.Add(this.groupBox1);
this.Controls.Add(this.chkForceOneToOne);
this.Controls.Add(this.rdAssociation);
this.Controls.Add(this.rdInner);
@@ -219,8 +335,10 @@
this.Name = "JoinSettings";
- this.Size = new System.Drawing.Size(354, 246);
+ this.Size = new System.Drawing.Size(455, 368);
((System.ComponentModel.ISupportInitialize)(this.grdJoinKeys)).EndInit();
+ this.groupBox1.ResumeLayout(false);
+ this.groupBox1.PerformLayout();
@@ -241,7 +359,15 @@
private System.Windows.Forms.RadioButton rdInner;
private System.Windows.Forms.RadioButton rdAssociation;
private System.Windows.Forms.CheckBox chkForceOneToOne;
+ private System.Windows.Forms.DataGridView grdJoinKeys;
+ private System.Windows.Forms.GroupBox groupBox1;
+ private System.Windows.Forms.LinkLabel lnkDelete;
+ private System.Windows.Forms.LinkLabel lnkAdd;
+ private System.Windows.Forms.ComboBox cmbSecondary;
+ private System.Windows.Forms.ComboBox cmbPrimary;
+ private System.Windows.Forms.Label label6;
private System.Windows.Forms.Label label5;
- private System.Windows.Forms.DataGridView grdJoinKeys;
+ private System.Windows.Forms.DataGridViewTextBoxColumn COL_PRIMARY;
+ private System.Windows.Forms.DataGridViewTextBoxColumn COL_SECONDARY;
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -24,14 +24,190 @@
using System.Data;
using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
- public partial class JoinSettings : UserControl
+ public partial class JoinSettings : UserControl, IEditorBindable
- public JoinSettings()
+ private JoinSettings()
+ private bool _init = false;
+ private AttributeRelateType _rel;
+ public JoinSettings(FeatureSetColumn [] primaryColumns, AttributeRelateType rel)
+ : this()
+ //FIXME: Initial load will set the correct secondary class, but not the correct
+ //secondary property list!!!
+ _init = true;
+ grdJoinKeys.AutoGenerateColumns = false;
+ _rel = rel;
+ TextBoxBinder.BindText(txtJoinName, _rel, "Name");
+ TextBoxBinder.BindText(txtFeatureSource, _rel, "ResourceId");
+ txtFeatureSource.TextChanged += new EventHandler(txtFeatureSource_TextChanged);
+ //rb.ReadValue();
+ UpdateJoinClass();
+ CheckBoxBinder.BindChecked(chkForceOneToOne, _rel, "ForceOneToOne");
+ var bin = cmbFeatureClass.DataBindings.Add("SelectedValue", _rel, "AttributeClass");
+ bin.ReadValue();
+ //UpdateSecondary();
+ _rel.PropertyChanged += (sender, e) => { OnResourceChanged(); };
+ cmbPrimary.DisplayMember = "Name";
+ cmbPrimary.ValueMember = "Name";
+ cmbPrimary.DataSource = primaryColumns;
+ grdJoinKeys.DataSource = rel.RelateProperty;
+ void txtFeatureSource_TextChanged(object sender, EventArgs e)
+ private void UpdateJoinClass()
+ try
+ var rt = ResourceIdentifier.GetResourceType(txtFeatureSource.Text);
+ if (rt == ResourceTypes.FeatureSource)
+ var fs = _edSvc.FeatureService.DescribeFeatureSource(txtFeatureSource.Text);
+ cmbFeatureClass.DataSource = fs.Schemas;
+ if (fs.Schemas.Length > 0)
+ cmbFeatureClass.SelectedIndex = 0;
+ UpdateSecondary();
+ catch
+ private void btnBrowse_Click(object sender, EventArgs e)
+ string resId = _edSvc.SelectResource(OSGeo.MapGuide.MaestroAPI.ResourceTypes.FeatureSource);
+ if (!string.IsNullOrEmpty(resId))
+ txtFeatureSource.Text = resId;
+ _edSvc = service;
+ _edSvc.RegisterCustomNotifier(this);
+ public RelateTypeEnum GetJoinType()
+ if (rdLeftOuter.Checked)
+ return RelateTypeEnum.LeftOuter;
+ else if (rdInner.Checked)
+ return RelateTypeEnum.Inner;
+ else if (rdRightOuter.Checked)
+ return RelateTypeEnum.RightOuter;
+ else if (rdAssociation.Checked)
+ return RelateTypeEnum.Association;
+ throw new InvalidOperationException();
+ protected override void OnLoad(EventArgs e)
+ _init = false;
+ base.OnLoad(e);
+ private void rdJoinTypeChanged(object sender, EventArgs e)
+ _rel.RelateType = GetJoinType();
+ private void cmbFeatureClass_SelectedIndexChanged(object sender, EventArgs e)
+ private void UpdateSecondary()
+ //Invalidate
+ if (!_init)
+ _rel.RelateProperty.Clear();
+ var item = cmbFeatureClass.SelectedItem as FeatureSourceDescription.FeatureSourceSchema;
+ if (item != null)
+ cmbSecondary.DisplayMember = "Name";
+ cmbSecondary.ValueMember = "Name";
+ cmbSecondary.DataSource = item.Columns;
+ private void lnkClear_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ private void CheckAddStatus(object sender, EventArgs e)
+ lnkAdd.Enabled = cmbPrimary.SelectedIndex >= 0 && cmbSecondary.SelectedIndex >= 0;
+ private void grdJoinKeys_CellClick(object sender, DataGridViewCellEventArgs e)
+ if (e.RowIndex >= 0)
+ grdJoinKeys.Rows[e.RowIndex].Selected = true;
+ lnkDelete.Enabled = true;
+ private void lnkAdd_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ if (cmbSecondary.SelectedIndex >= 0 && cmbSecondary.SelectedIndex >= 0)
+ string primary = ((FeatureSetColumn)cmbPrimary.SelectedItem).Name;
+ string secondary = ((FeatureSetColumn)cmbSecondary.SelectedItem).Name;
+ _rel.RelateProperty.Add(new RelatePropertyType() { FeatureClassProperty = primary, AttributeClassProperty = secondary });
+ private void lnkDelete_LinkClicked(object sender, LinkLabelLinkClickedEventArgs e)
+ if (grdJoinKeys.SelectedRows.Count == 1)
+ _rel.RelateProperty.Remove((RelatePropertyType)grdJoinKeys.SelectedRows[0].DataBoundItem);
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Extensions/JoinSettings.resx 2010-07-19 16:58:26 UTC (rev 5039)
@@ -117,4 +117,10 @@
</resheader>
+ <metadata name="COL_PRIMARY.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <value>True</value>
+ </metadata>
+ <metadata name="COL_SECONDARY.UserAddedColumn" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.Designer.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -71,8 +71,10 @@
this.trvExtensions.Location = new System.Drawing.Point(0, 25);
this.trvExtensions.Name = "trvExtensions";
this.trvExtensions.SelectedImageIndex = 0;
+ this.trvExtensions.ShowNodeToolTips = true;
this.trvExtensions.Size = new System.Drawing.Size(169, 267);
this.trvExtensions.TabIndex = 1;
+ this.trvExtensions.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.trvExtensions_AfterSelect);
// trvImages
@@ -104,6 +106,7 @@
this.btnNewExtension.Name = "btnNewExtension";
this.btnNewExtension.Size = new System.Drawing.Size(23, 22);
this.btnNewExtension.Text = "Add New Extension";
+ this.btnNewExtension.Click += new System.EventHandler(this.btnNewExtension_Click);
// btnNewCalculation
@@ -114,6 +117,7 @@
this.btnNewCalculation.Name = "btnNewCalculation";
this.btnNewCalculation.Size = new System.Drawing.Size(23, 22);
this.btnNewCalculation.Text = "Add New Calculated Property";
+ this.btnNewCalculation.Click += new System.EventHandler(this.btnNewCalculation_Click);
// btnNewJoin
@@ -124,6 +128,7 @@
this.btnNewJoin.Name = "btnNewJoin";
this.btnNewJoin.Size = new System.Drawing.Size(23, 22);
this.btnNewJoin.Text = "New Join";
+ this.btnNewJoin.Click += new System.EventHandler(this.btnNewJoin_Click);
// toolStripSeparator1
@@ -139,6 +144,7 @@
this.btnDelete.Name = "btnDelete";
this.btnDelete.Size = new System.Drawing.Size(23, 22);
this.btnDelete.Text = "Delete";
+ this.btnDelete.Click += new System.EventHandler(this.btnDelete_Click);
// ExtensionsCtrl
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/ExtensionsCtrl.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -25,6 +25,10 @@
using System.Text;
+using Maestro.Editors.FeatureSource.Extensions;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
@@ -35,11 +39,332 @@
+ const int IDX_EXTENSION = 0;
+ const int IDX_CALC = 1;
+ const int IDX_JOIN = 2;
+ private FeatureSourceType _fs;
+ private FeatureSourceDescription _cachedSchema;
+ _edSvc = service;
+ _fs = (FeatureSourceType)_edSvc.GetEditedResource();
+ _cachedSchema = _fs.Describe();
+ //Build tree
+ if (_fs.Extension != null)
+ foreach (var ext in _fs.Extension)
+ TreeNode node = new TreeNode();
+ node.Tag = ext;
+ node.ImageIndex = node.SelectedImageIndex = IDX_EXTENSION;
+ node.Text = ext.Name;
+ node.ToolTipText = string.Format(Properties.Resources.ExtendedClassTooltip, ext.FeatureClass);
+ ext.PropertyChanged += (s, evt) =>
+ if (evt.PropertyName == "Name")
+ else if (evt.PropertyName == "FeatureClass")
+ trvExtensions.Nodes.Add(node);
+ if (ext.CalculatedProperty != null)
+ foreach (var calc in ext.CalculatedProperty)
+ var cNode = new TreeNode();
+ cNode.ImageIndex = cNode.SelectedImageIndex = IDX_CALC;
+ cNode.Tag = calc;
+ cNode.Text = calc.Name;
+ cNode.ToolTipText = calc.Expression;
+ calc.PropertyChanged += (s, evt) =>
+ else if (evt.PropertyName == "Expression")
+ node.Nodes.Add(cNode);
+ if (ext.AttributeRelate != null)
+ foreach (var join in ext.AttributeRelate)
+ var jNode = new TreeNode();
+ jNode.Tag = join;
+ jNode.ImageIndex = jNode.SelectedImageIndex = IDX_JOIN;
+ jNode.Text = join.Name;
+ join.PropertyChanged += (s, evt) =>
+ node.Nodes.Add(jNode);
+ node.ExpandAll();
+ private void btnNewExtension_Click(object sender, EventArgs e)
+ if (_fs.Extension == null)
+ _fs.Extension = new BindingList<FeatureSourceTypeExtension>();
+ var ext = new FeatureSourceTypeExtension();
+ node.Tag = ext;
+ _fs.Extension.Add(ext);
+ trvExtensions.SelectedNode = node;
+ private void btnNewCalculation_Click(object sender, EventArgs e)
+ var node = trvExtensions.SelectedNode;
+ if (node != null)
+ var ext = node.Tag as FeatureSourceTypeExtension;
+ if (ext != null)
+ var calc = new CalculatedPropertyType();
+ cNode.Tag = calc;
+ node.Expand();
+ if (ext.CalculatedProperty == null)
+ ext.CalculatedProperty = new BindingList<CalculatedPropertyType>();
+ ext.CalculatedProperty.Add(calc);
+ trvExtensions.SelectedNode = cNode;
+ private void btnNewJoin_Click(object sender, EventArgs e)
+ if (node != null)
+ if (ext != null)
+ var join = new AttributeRelateType();
+ join.RelateProperty = new BindingList<RelatePropertyType>();
+ jNode.Tag = join;
+ node.Expand();
+ if (ext.AttributeRelate == null)
+ ext.AttributeRelate = new BindingList<AttributeRelateType>();
+ ext.AttributeRelate.Add(join);
+ trvExtensions.SelectedNode = jNode;
+ private void btnDelete_Click(object sender, EventArgs e)
+ if (node != null)
+ var join = node.Tag as AttributeRelateType;
+ var calc = node.Tag as CalculatedPropertyType;
+ if (ext != null)
+ _fs.Extension.Remove(ext);
+ if (_fs.Extension.Count == 0)
+ _fs.Extension = null; //To prevent empty element when saving
+ else if (join != null)
+ //Disassociate from parent
+ ext = node.Parent.Tag as FeatureSourceTypeExtension;
+ if (ext != null)
+ ext.AttributeRelate.Remove(join);
+ node.Parent.Nodes.Remove(node);
+ //To prevent writing empty elements when saving
+ if (ext.AttributeRelate.Count == 0)
+ ext.AttributeRelate = null;
+ else if (calc != null)
+ if (ext != null)
+ ext.CalculatedProperty.Remove(calc);
+ if (ext.CalculatedProperty.Count == 0)
+ ext.CalculatedProperty = null;
+ private bool IsValidExtension(FeatureSourceTypeExtension ext)
+ //TODO: Check class name and extended class name for validity
+ return !string.IsNullOrEmpty(ext.FeatureClass) && !string.IsNullOrEmpty(ext.Name);
+ private void trvExtensions_AfterSelect(object sender, TreeViewEventArgs e)
+ var ext = e.Node.Tag as FeatureSourceTypeExtension;
+ var join = e.Node.Tag as AttributeRelateType;
+ var calc = e.Node.Tag as CalculatedPropertyType;
+ if (ext != null)
+ var ctl = new ExtendedClassSettings(_cachedSchema.Schemas, ext);
+ ctl.Dock = DockStyle.Fill;
+ //If editing to something valid, update the toolbar
+ ctl.ResourceChanged += (s, evt) =>
+ btnNewJoin.Enabled = btnNewCalculation.Enabled = IsValidExtension(ext);
+ splitContainer1.Panel2.Controls.Clear();
+ splitContainer1.Panel2.Controls.Add(ctl);
+ btnNewCalculation.Enabled = btnNewJoin.Enabled = IsValidExtension(ext);
+ ext = e.Node.Parent.Tag as FeatureSourceTypeExtension;
+ if (ext != null)
+ FeatureSourceDescription.FeatureSourceSchema cls = null;
+ foreach (var c in _cachedSchema.Schemas)
+ if (c.Fullname == ext.FeatureClass)
+ cls = c;
+ break;
+ if (cls != null)
+ var ctl = new JoinSettings(cls.Columns, join);
+ ctl.Bind(_edSvc);
+ if (ext != null)
+ cls = c;
+ break;
+ if (cls != null)
+ var ctl = new CalculationSettings(_edSvc, cls, _fs, calc);
+ else
Modified: sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/LayerDefinition/Vector/VectorLayerSettingsSectionCtrl.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -52,12 +52,17 @@
var vl = res.Item as OSGeo.MapGuide.ObjectModels.LayerDefinition.VectorLayerDefinitionType;
Debug.Assert(vl != null);
- txtFeatureSource.DataBindings.Add("Text", vl, "ResourceId");
+ //txtFeatureSource.DataBindings.Add("Text", vl, "ResourceId");
+ TextBoxBinder.BindText(txtFeatureSource, vl, "ResourceId");
cmbSchema.DataBindings.Add("Text", vl, "FeatureName");
cmbGeometry.DataBindings.Add("Text", vl, "Geometry");
- txtFilter.DataBindings.Add("Text", vl, "Filter");
- txtHyperlink.DataBindings.Add("Text", vl, "Url");
- txtTooltip.DataBindings.Add("Text", vl, "ToolTip");
+ //txtFilter.DataBindings.Add("Text", vl, "Filter");
+ //txtHyperlink.DataBindings.Add("Text", vl, "Url");
+ //txtTooltip.DataBindings.Add("Text", vl, "ToolTip");
+ TextBoxBinder.BindText(txtFilter, vl, "Filter");
+ TextBoxBinder.BindText(txtHyperlink, vl, "Url");
+ TextBoxBinder.BindText(txtTooltip, vl, "ToolTip");
//This is not the root object so no change listeners have been subscribed
vl.PropertyChanged += (sender, e) => { OnResourceChanged(); };
@@ -154,7 +159,7 @@
txtFilter.Text = expr;
//HACK: Force databinding update
- txtFilter.DataBindings[0].WriteValue();
+ //txtFilter.DataBindings[0].WriteValue();
@@ -170,7 +175,7 @@
txtHyperlink.Text = expr;
- txtHyperlink.DataBindings[0].WriteValue();
+ //txtHyperlink.DataBindings[0].WriteValue();
@@ -186,7 +191,7 @@
txtTooltip.Text = expr;
- txtTooltip.DataBindings[0].WriteValue();
+ //txtTooltip.DataBindings[0].WriteValue();
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-07-19 16:58:26 UTC (rev 5039)
@@ -142,6 +142,18 @@
<Compile Include="FeatureSource\ExtensionsCtrl.Designer.cs">
<DependentUpon>ExtensionsCtrl.cs</DependentUpon>
</Compile>
+ <Compile Include="FeatureSource\Extensions\CalculationSettings.cs">
+ <SubType>UserControl</SubType>
+ </Compile>
+ <Compile Include="FeatureSource\Extensions\CalculationSettings.Designer.cs">
+ <DependentUpon>CalculationSettings.cs</DependentUpon>
+ </Compile>
+ <Compile Include="FeatureSource\Extensions\ExtendedClassSettings.cs">
+ </Compile>
+ <Compile Include="FeatureSource\Extensions\ExtendedClassSettings.Designer.cs">
+ <DependentUpon>ExtendedClassSettings.cs</DependentUpon>
+ </Compile>
<Compile Include="FeatureSource\Extensions\JoinSettings.cs">
</Compile>
@@ -497,6 +509,14 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="FeatureSource\Extensions\CalculationSettings.resx">
+ <SubType>Designer</SubType>
+ </EmbeddedResource>
+ <EmbeddedResource Include="FeatureSource\Extensions\ExtendedClassSettings.resx">
<EmbeddedResource Include="FeatureSource\Extensions\JoinSettings.resx">
<DependentUpon>JoinSettings.cs</DependentUpon>
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -67,7 +67,6 @@
this.chkSelectable.TabIndex = 15;
this.chkSelectable.Text = "Features on the layer are selectable (if visible)";
this.chkSelectable.UseVisualStyleBackColor = true;
- this.chkSelectable.CheckedChanged += new System.EventHandler(this.ForceUpdate);
// chkExpanded
@@ -78,7 +77,6 @@
this.chkExpanded.TabIndex = 14;
this.chkExpanded.Text = "Layer is expanded in the legend (if themed)";
this.chkExpanded.UseVisualStyleBackColor = true;
- this.chkExpanded.CheckedChanged += new System.EventHandler(this.ForceUpdate);
// chkLegendVisible
@@ -89,7 +87,6 @@
this.chkLegendVisible.TabIndex = 13;
this.chkLegendVisible.Text = "Layer is shown in the map legend";
this.chkLegendVisible.UseVisualStyleBackColor = true;
- this.chkLegendVisible.CheckedChanged += new System.EventHandler(this.ForceUpdate);
// chkVisible
@@ -100,7 +97,6 @@
this.chkVisible.TabIndex = 12;
this.chkVisible.Text = "Layer is visible at startup";
this.chkVisible.UseVisualStyleBackColor = true;
- this.chkVisible.CheckedChanged += new System.EventHandler(this.ForceUpdate);
// txtLegendLabel
@@ -110,7 +106,6 @@
this.txtLegendLabel.Name = "txtLegendLabel";
this.txtLegendLabel.Size = new System.Drawing.Size(277, 20);
this.txtLegendLabel.TabIndex = 11;
- this.txtLegendLabel.TextChanged += new System.EventHandler(this.ForceUpdate);
// txtName
@@ -120,7 +115,6 @@
this.txtName.Size = new System.Drawing.Size(277, 20);
this.txtName.TabIndex = 10;
- this.txtName.TextChanged += new System.EventHandler(this.ForceUpdate);
// label2
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/GroupPropertiesCtrl.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -6,6 +6,7 @@
using System.Text;
using OSGeo.MapGuide.ObjectModels.MapDefinition;
namespace Maestro.Editors.MapDefinition
@@ -23,12 +24,17 @@
group.PropertyChanged += new PropertyChangedEventHandler(OnGroupChanged);
- txtName.DataBindings.Add("Text", group, "Name");
- txtLegendLabel.DataBindings.Add("Text", group, "LegendLabel");
+ //txtName.DataBindings.Add("Text", group, "Name");
+ //txtLegendLabel.DataBindings.Add("Text", group, "LegendLabel");
+ TextBoxBinder.BindText(txtName, group, "Name");
+ TextBoxBinder.BindText(txtLegendLabel, group, "LegendLabel");
- chkExpanded.DataBindings.Add("Checked", group, "ExpandInLegend");
- chkLegendVisible.DataBindings.Add("Checked", group, "ShowInLegend");
- chkVisible.DataBindings.Add("Checked", group, "Visible");
+ //chkExpanded.DataBindings.Add("Checked", group, "ExpandInLegend");
+ //chkLegendVisible.DataBindings.Add("Checked", group, "ShowInLegend");
+ //chkVisible.DataBindings.Add("Checked", group, "Visible");
+ CheckBoxBinder.BindChecked(chkExpanded, group, "ExpandInLegend");
+ CheckBoxBinder.BindChecked(chkLegendVisible, group, "ShowInLegend");
+ CheckBoxBinder.BindChecked(chkVisible, group, "Visible");
void OnGroupChanged(object sender, PropertyChangedEventArgs e)
@@ -38,9 +44,9 @@
- void ForceUpdate(object sender, EventArgs e)
- ((Control)sender).DataBindings[0].WriteValue();
+ //void ForceUpdate(object sender, EventArgs e)
+ // ((Control)sender).DataBindings[0].WriteValue();
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -67,7 +67,6 @@
this.chkSelectable.TabIndex = 7;
// chkExpanded
@@ -78,7 +77,6 @@
this.chkExpanded.TabIndex = 6;
// chkLegendVisible
@@ -89,7 +87,6 @@
this.chkLegendVisible.TabIndex = 5;
// chkVisible
@@ -100,7 +97,6 @@
this.chkVisible.TabIndex = 4;
// txtLegendLabel
@@ -110,7 +106,6 @@
this.txtLegendLabel.Size = new System.Drawing.Size(285, 20);
this.txtLegendLabel.TabIndex = 3;
// txtName
@@ -120,7 +115,6 @@
this.txtName.Size = new System.Drawing.Size(285, 20);
// label2
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/LayerPropertiesCtrl.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -6,6 +6,7 @@
using System.Text;
@@ -21,13 +22,21 @@
public LayerPropertiesCtrl(MapLayerType layer) : this()
layer.PropertyChanged += new PropertyChangedEventHandler(OnLayerChanged);
- txtName.DataBindings.Add("Text", layer, "Name");
- txtLegendLabel.DataBindings.Add("Text", layer, "LegendLabel");
+ //txtName.DataBindings.Add("Text", layer, "Name");
+ //txtLegendLabel.DataBindings.Add("Text", layer, "LegendLabel");
- chkExpanded.DataBindings.Add("Checked", layer, "ExpandInLegend");
- chkLegendVisible.DataBindings.Add("Checked", layer, "ShowInLegend");
- chkVisible.DataBindings.Add("Checked", layer, "Visible");
- chkSelectable.DataBindings.Add("Checked", layer, "Selectable");
+ //chkExpanded.DataBindings.Add("Checked", layer, "ExpandInLegend");
+ //chkLegendVisible.DataBindings.Add("Checked", layer, "ShowInLegend");
+ //chkVisible.DataBindings.Add("Checked", layer, "Visible");
+ //chkSelectable.DataBindings.Add("Checked", layer, "Selectable");
+ TextBoxBinder.BindText(txtName, layer, "Name");
+ TextBoxBinder.BindText(txtLegendLabel, layer, "LegendLabel");
+ CheckBoxBinder.BindChecked(chkExpanded, layer, "ExpandInLegend");
+ CheckBoxBinder.BindChecked(chkLegendVisible, layer, "ShowInLegend");
+ CheckBoxBinder.BindChecked(chkVisible, layer, "Visible");
+ CheckBoxBinder.BindChecked(chkSelectable, layer, "Selectable");
void OnLayerChanged(object sender, PropertyChangedEventArgs e)
@@ -37,9 +46,9 @@
Modified: sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/MapDefinition/MapSettingsSectionCtrl.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -68,8 +68,10 @@
- txtDescription.DataBindings.Add(bmeta);
- txtCoordinateSystem.DataBindings.Add("Text", _map, "CoordinateSystem");
+ //txtDescription.DataBindings.Add(bmeta);
+ TextBoxBinder.BindText(txtDescription, bmeta);
+ //txtCoordinateSystem.DataBindings.Add("Text", _map, "CoordinateSystem");
+ TextBoxBinder.BindText(txtCoordinateSystem, _map, "CoordinateSystem");
//ColorComboBox requires custom databinding
cmbBackgroundColor.CurrentColor = _map.BackgroundColor;
@@ -111,7 +113,7 @@
//HACK: Force the binding to update
//http://stackoverflow.com/questions/1060080/databound-winforms-control-does-not-recognize-change-until-losing-focus
- txtCoordinateSystem.DataBindings[0].WriteValue();
+ //txtCoordinateSystem.DataBindings[0].WriteValue();
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -273,6 +273,15 @@
/// <summary>
+ /// Looks up a localized string similar to Extended class based on: {0}.
+ /// </summary>
+ internal static string ExtendedClassTooltip {
+ get {
+ return ResourceManager.GetString("ExtendedClassTooltip", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to File Downloaded.
/// </summary>
internal static string FileDownloaded {
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx 2010-07-19 16:58:26 UTC (rev 5039)
@@ -382,4 +382,7 @@
<data name="ruler" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\ruler.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
+ <data name="ExtendedClassTooltip" xml:space="preserve">
+ <value>Extended class based on: {0}</value>
+ </data>
</root>
Added: sandbox/maestro-3.0/Maestro.Shared.UI/CheckBoxBinder.cs
--- sandbox/maestro-3.0/Maestro.Shared.UI/CheckBoxBinder.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/CheckBoxBinder.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,54 @@
+#endregion
+using System;
+using System.Text;
+namespace Maestro.Shared.UI
+ /// <summary>
+ /// Helper class to bind object properties to <see cref="CheckBox"/> derived classes for
+ /// immediate updates as opposed to updates on loss of focus.
+ /// </summary>
+ public static class CheckBoxBinder
+ // We need to force WriteValue() on CheckedChanged otherwise it will only call WriteValue()
+ // on loss of focus.
+ // http://stackoverflow.com/questions/1060080/databound-winforms-control-does-not-recognize-change-until-losing-focus
+ public static Binding BindChecked(CheckBox chk, Binding b)
+ chk.DataBindings.Add(b);
+ chk.CheckedChanged += (sender, e) => { b.WriteValue(); };
+ return b;
+ public static Binding BindChecked(CheckBox chk, object dataSource, string dataMember)
+ var binding = chk.DataBindings.Add("Checked", dataSource, dataMember);
+ chk.CheckedChanged += (sender, e) => { binding.WriteValue(); };
+ return binding;
Modified: sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj 2010-07-19 16:58:26 UTC (rev 5039)
@@ -38,6 +38,7 @@
<Reference Include="System.Xml" />
</ItemGroup>
<ItemGroup>
+ <Compile Include="CheckBoxBinder.cs" />
<Compile Include="CollapsiblePanel.cs">
</Compile>
@@ -51,6 +52,7 @@
<DesignTime>True</DesignTime>
<DependentUpon>Resources.resx</DependentUpon>
</Compile>
+ <Compile Include="TextBoxBinder.cs" />
<Compile Include="WaitCursor.cs" />
<Service Include="{94E38DFF-614B-4cbd-B67C-F211BB35CE8B}" />
</ItemGroup>
Added: sandbox/maestro-3.0/Maestro.Shared.UI/TextBoxBinder.cs
--- sandbox/maestro-3.0/Maestro.Shared.UI/TextBoxBinder.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/TextBoxBinder.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -0,0 +1,53 @@
+#endregion
+using System;
+using System.Text;
+ /// <summary>
+ /// Helper class to bind object properties to <see cref="TextBoxBase"/> derived classes for
+ /// </summary>
+ public static class TextBoxBinder
+ // We need to force WriteValue() on TextChanged otherwise it will only call WriteValue()
+ public static Binding BindText(TextBoxBase txt, Binding b)
+ txt.DataBindings.Add(b);
+ txt.TextChanged += (sender, e) => { b.WriteValue(); };
+ return b;
+ public static Binding BindText(TextBoxBase txt, object dataSource, string dataMember)
+ var binding = txt.DataBindings.Add("Text", dataSource, dataMember);
+ txt.TextChanged += (sender, e) => { binding.WriteValue(); };
+ return binding;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSourceDescription.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSourceDescription.cs 2010-07-19 16:28:44 UTC (rev 5038)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Feature/FeatureSourceDescription.cs 2010-07-19 16:58:26 UTC (rev 5039)
@@ -135,6 +135,11 @@
public string Fullname { get { return m_schema == null ? m_name : m_schema + ":" + m_name; } }
public string FullnameDecoded { get { return Utility.DecodeFDOName(this.Fullname); } }
public FeatureSetColumn[] Columns { get { return m_columns; } }
+ public override string ToString()
+ return this.FullnameDecoded;
More information about the mapguide-commits
