[mapguide-commits] r5044 - in sandbox/maestro-3.0: Maestro.Base Maestro.Base/Commands Maestro.Base/Editor Maestro.Base/Properties Maestro.Base/Services Maestro.Base/Templates Maestro.Base/UI Maestro.Editors/Common OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/Properties OSGeo.MapGuide.MaestroAPI/Resource
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Jul 21 03:04:30 EDT 2010
Author: jng
Date: 2010-07-21 07:04:30 +0000 (Wed, 21 Jul 2010)
New Revision: 5044
Added:
   sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs
   sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
   sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
   sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
   sandbox/maestro-3.0/Maestro.Base/Services/NewItemTemplateService.cs
   sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
   sandbox/maestro-3.0/Maestro.Base/Services/ViewContentManager.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/DrawingSourceItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/LayerDefinitionItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/PrintLayoutItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/UserItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/Templates/WebLayoutItemTemplate.cs
   sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
   sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs
   sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
   sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs
   sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs
   sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
This submission includes the following changes:
 - Added busy cursors to the Site Explorer and Folder browser
 - Use the more efficient resource service API for Site Explorer and Folder browser
 - Make the new item templates driven from the addin registry
 - Make the editors driven from the addin registry. If no registered editor is found for a given resource, it defaults to the XML editor.
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/NewItemCommand.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -40,9 +40,12 @@
             if (dlg.ShowDialog() == System.Windows.Forms.DialogResult.OK)
                 var tpl = dlg.SelectedTemplate;
-                tpl.CreateItem(conn.ResourceService, dlg.ResourceID);
-                var ri = new IRepositoryItemImpl(dlg.ResourceID);
-                orm.Open(new RepositoryItem(ri), conn, false);
+                var res = tpl.CreateItem(conn);
+                res.ResourceID = "Session:" + conn.SessionID + "//" + Guid.NewGuid().ToString() + "." + res.ResourceType.ToString();
+                conn.ResourceService.SaveResource(res);
+                orm.Open(res.ResourceID, conn, false);
Added: sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/IEditorFactory.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -0,0 +1,160 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+namespace Maestro.Base.Editor
+    public interface IEditorFactory
+        /// <summary>
+        /// Gets the type of resource (and version) this editor can edit
+        /// </summary>
+        ResourceTypeDescriptor ResourceTypeAndVersion { get; }
+        /// <summary>
+        /// Creates an instance of this resource editor
+        /// </summary>
+        /// <returns></returns>
+        IEditorViewContent Create();
+    internal class DrawingSourceEditorFactory : IEditorFactory
+        public ResourceTypeDescriptor ResourceTypeAndVersion { get; private set; }
+        public DrawingSourceEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.DrawingSource, "1.0.0");
+        public IEditorViewContent Create()
+            return new DrawingSourceEditor();
+    internal class FeatureSourceEditorFactory : IEditorFactory
+        public FeatureSourceEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.FeatureSource, "1.0.0");
+            return new FeatureSourceEditor();
+    internal class LayerDefinitionEditorFactory : IEditorFactory
+        public LayerDefinitionEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.LayerDefinition, "1.0.0");
+            return new LayerDefinitionEditor();
+    internal class LoadProcedureEditorFactory : IEditorFactory
+        public LoadProcedureEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.LoadProcedure, "1.0.0");
+            return new LoadProcedureEditor();
+    internal class MapDefinitionEditorFactory : IEditorFactory
+        public MapDefinitionEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.MapDefinition, "1.0.0");
+            return new MapDefinitionEditor();
+    internal class PrintLayoutEditorFactory : IEditorFactory
+        public PrintLayoutEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.PrintLayout, "1.0.0");
+            return new PrintLayoutEditor();
+    internal class SymbolDefinitionEditorFactory : IEditorFactory
+        public SymbolDefinitionEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.SymbolDefinition, "1.0.0");
+            return new SymbolDefinitionEditor();
+    internal class WebLayoutEditorFactory : IEditorFactory
+        public WebLayoutEditorFactory()
+            this.ResourceTypeAndVersion = new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, "1.0.0");
+            return new WebLayoutEditor();
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin	2010-07-21 07:04:30 UTC (rev 5044)
@@ -20,6 +20,33 @@
             <ConditionEvaluator name="MultipleSelected" class="Maestro.Base.Commands.Conditions.MultipleSelectedItemConditionEvaluator" />
         </Import>
     </Runtime>
+    <!-- Registered editors -->
+    <Path name="/Maestro/Editors">
+        <Class id="DrawingSourceEditor100" class="Maestro.Base.Editor.DrawingSourceEditorFactory" />
+        <Class id="FeatureSourceEditor100" class="Maestro.Base.Editor.FeatureSourceEditorFactory" />
+        <Class id="LayerDefinitionEditor100" class="Maestro.Base.Editor.LayerDefinitionEditorFactory" />
+        <Class id="LoadProcedureEditor100" class="Maestro.Base.Editor.LoadProcedureEditorFactory" />
+        <Class id="MapDefinitionEditor100" class="Maestro.Base.Editor.MapDefinitionEditorFactory" />
+        <Class id="PrintLayoutEditor100" class="Maestro.Base.Editor.PrintLayoutEditorFactory" />
+        <Class id="SymbolDefinitionEditor100" class="Maestro.Base.Editor.SymbolDefinitionEditorFactory" />
+        <Class id="WebLayoutEditor100" class="Maestro.Base.Editor.WebLayoutEditorFactory" />
+    </Path>
+    <!-- Registered System Templates -->
+    <Path name="/Maestro/NewItemTemplates">
+        <Class id="FlexLayout100" class="Maestro.Base.Templates.ApplicationDefinitionItemTemplate" />
+        <Class id="DrawingSource100" class="Maestro.Base.Templates.DrawingSourceItemTemplate" />
+        <Class id="FeatureSource100" class="Maestro.Base.Templates.FeatureSourceItemTemplate" />
+        <Class id="LayerDefinition100" class="Maestro.Base.Templates.LayerDefinitionItemTemplate" />
+        <Class id="MapDefinition100" class="Maestro.Base.Templates.MapDefinitionItemTemplate" />
+        <Class id="PrintLayout100" class="Maestro.Base.Templates.PrintLayoutItemTemplate" />
+        <Class id="SdfLoadProcedure100" class="Maestro.Base.Templates.SdfLoadProcedureItemTemplate" />
+        <Class id="ShpLoadProcedure100" class="Maestro.Base.Templates.ShpLoadProcedureItemTemplate" />
+        <Class id="SimpleSymbol100" class="Maestro.Base.Templates.SimpleSymbolDefinitionItemTemplate" />
+        <Class id="CompoundSymbol100" class="Maestro.Base.Templates.CompoundSymbolDefinitionItemTemplate" />
+        <Class id="WebLayout100" class="Maestro.Base.Templates.WebLayoutItemTemplate" />
+    </Path>
     <!-- Main Menu Definition -->
     <Path name="/Maestro/Shell/MainMenu">
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj	2010-07-21 07:04:30 UTC (rev 5044)
@@ -3,7 +3,7 @@
   <PropertyGroup>
     <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
     <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
-    <ProductVersion>9.0.21022</ProductVersion>
+    <ProductVersion>9.0.30729</ProductVersion>
     <SchemaVersion>2.0</SchemaVersion>
     <ProjectGuid>{F1E2F468-5030-4DBA-968C-9620284AFAA1}</ProjectGuid>
     <OutputType>Library</OutputType>
@@ -87,6 +87,7 @@
     <Compile Include="Editor\FeatureSourceEditor.Designer.cs">
       <DependentUpon>FeatureSourceEditor.cs</DependentUpon>
     </Compile>
+    <Compile Include="Editor\IEditorFactory.cs" />
     <Compile Include="Editor\LayerDefinitionEditor.cs">
       <SubType>UserControl</SubType>
     </Compile>
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -1,7 +1,7 @@
 // <auto-generated>
 //     This code was generated by a tool.
-//     Runtime Version:2.0.50727.3053
+//     Runtime Version:2.0.50727.4927
 //     Changes to this file may cause incorrect behavior and will be lost if
 //     the code is regenerated.
@@ -387,6 +387,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Registered Editor: {0}.
+        /// </summary>
+        internal static string EditorRegistered {
+            get {
+                return ResourceManager.GetString("EditorRegistered", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Singleton view content cannot be closed by users. The AllowUserClose property must return false.
         /// </summary>
         internal static string Error_Closeable_Singleton_Content {
@@ -699,6 +708,15 @@
+        /// <summary>
+        ///   Looks up a localized string similar to Skipping registration of editor: {0} because an existing editor is already registered to handle {1} v{2}.
+        /// </summary>
+        internal static string OpenResourceManager_SkipEditorRegistration {
+            get {
+                return ResourceManager.GetString("OpenResourceManager_SkipEditorRegistration", resourceCulture);
         internal static System.Drawing.Bitmap plug__arrow {
             get {
                 object obj = ResourceManager.GetObject("plug__arrow", resourceCulture);
@@ -1066,6 +1084,24 @@
         /// <summary>
+        ///   Looks up a localized string similar to Create a new Compund Symbol Definition.
+        /// </summary>
+        internal static string TPL_CSD_DESC {
+            get {
+                return ResourceManager.GetString("TPL_CSD_DESC", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to Compound Symbol Definition.
+        /// </summary>
+        internal static string TPL_CSD_NAME {
+            get {
+                return ResourceManager.GetString("TPL_CSD_NAME", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Create a new Drawing Source.
         /// </summary>
         internal static string TPL_DS_DESC {
@@ -1192,24 +1228,33 @@
         /// <summary>
-        ///   Looks up a localized string similar to Create a new Symbol Definition.
+        ///   Looks up a localized string similar to Create a new Simple Symbol Definition.
         /// </summary>
-        internal static string TPL_SDF_DESC {
+        internal static string TPL_SSD_DESC {
             get {
-                return ResourceManager.GetString("TPL_SDF_DESC", resourceCulture);
+                return ResourceManager.GetString("TPL_SSD_DESC", resourceCulture);
         /// <summary>
-        ///   Looks up a localized string similar to Symbol Definition.
+        ///   Looks up a localized string similar to Simple Symbol Definition.
         /// </summary>
-        internal static string TPL_SDF_NAME {
+        internal static string TPL_SSD_NAME {
             get {
-                return ResourceManager.GetString("TPL_SDF_NAME", resourceCulture);
+                return ResourceManager.GetString("TPL_SSD_NAME", resourceCulture);
         /// <summary>
+        ///   Looks up a localized string similar to User Defined Resource Template.
+        /// </summary>
+        internal static string TPL_USER_DEFINED {
+            get {
+                return ResourceManager.GetString("TPL_USER_DEFINED", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Create a new Web Layout.
         /// </summary>
         internal static string TPL_WL_DESC {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx	2010-07-21 07:04:30 UTC (rev 5044)
@@ -448,11 +448,11 @@
   <data name="TPL_PL_NAME" xml:space="preserve">
     <value>Print Layout</value>
   </data>
-  <data name="TPL_SDF_DESC" xml:space="preserve">
-    <value>Create a new Symbol Definition</value>
+  <data name="TPL_SSD_DESC" xml:space="preserve">
+    <value>Create a new Simple Symbol Definition</value>
   </data>
-  <data name="TPL_SDF_NAME" xml:space="preserve">
-    <value>Symbol Definition</value>
+  <data name="TPL_SSD_NAME" xml:space="preserve">
+    <value>Simple Symbol Definition</value>
   </data>
   <data name="TPL_WL_DESC" xml:space="preserve">
     <value>Create a new Web Layout</value>
@@ -565,4 +565,19 @@
   <data name="SiteExplorer_SelectedItem_Properties" xml:space="preserve">
     <value>Properties</value>
   </data>
+  <data name="EditorRegistered" xml:space="preserve">
+    <value>Registered Editor: {0}</value>
+  </data>
+  <data name="OpenResourceManager_SkipEditorRegistration" xml:space="preserve">
+    <value>Skipping registration of editor: {0} because an existing editor is already registered to handle {1} v{2}</value>
+  </data>
+  <data name="TPL_USER_DEFINED" xml:space="preserve">
+    <value>User Defined Resource Template</value>
+  </data>
+  <data name="TPL_CSD_DESC" xml:space="preserve">
+    <value>Create a new Compund Symbol Definition</value>
+  </data>
+  <data name="TPL_CSD_NAME" xml:space="preserve">
+    <value>Compound Symbol Definition</value>
+  </data>
 </root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Services/NewItemTemplateService.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/NewItemTemplateService.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Services/NewItemTemplateService.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -29,15 +29,59 @@
     using Res = Properties.Resources;
     using Maestro.Base.Templates;
+using System.IO;
     public class NewItemTemplateService : ServiceBase
+        private List<ItemTemplate> _systemTemplates;
+        private List<ItemTemplate> _userTemplates;
         public override void Initialize()
             base.Initialize();
+            _systemTemplates = new List<ItemTemplate>();
+            _userTemplates = new List<ItemTemplate>();
+            var tpls = AddInTree.BuildItems<ItemTemplate>("/Maestro/NewItemTemplates", this);
+            foreach (var tp in tpls)
+                _systemTemplates.Add(tp);
+                LoggingService.Info("Registered default template: " + tp.GetType()); //LOCALIZE
+            UserItemTemplate [] utpls = ScanUserTemplates();
+            foreach (var ut in utpls)
+                _userTemplates.Add(ut);
+                LoggingService.Info("Adding user template: " + ut.TemplatePath);
             LoggingService.Info("Initialized: New Item Template Service"); //LOCALIZE
+        private UserItemTemplate[] ScanUserTemplates()
+            List<UserItemTemplate> tpls = new List<UserItemTemplate>();
+            //TODO: Store path in preferences
+            string userTplPath = Path.Combine(FileUtility.ApplicationRootPath, "UserTemplates");
+            if (Directory.Exists(userTplPath))
+                foreach (string file in Directory.GetFiles(userTplPath))
+                    try
+                        var tpl = new UserItemTemplate(file);
+                        tpls.Add(tpl);
+                    catch (Exception ex)
+                        LoggingService.Info("Could not load user template: " + file); //LOCALIZE
+            return tpls.ToArray();
         public string[] GetCategories()
             return new string[] {
@@ -50,22 +94,11 @@
             if (category == Res.TPL_CATEGORY_DEFAULT)
-                return new ItemTemplate[]
-                    new SdfLoadProcedureItemTemplate(),
-                    new ShpLoadProcedureItemTemplate(),
-                    new FeatureSourceItemTemplate(),
-                    new LayerDefinitionItemTemplate(),
-                    new MapDefinitionItemTemplate(),
-                    new WebLayoutItemTemplate(),
-                    new ApplicationDefinitionItemTemplate(),
-                    new PrintLayoutItemTemplate(),
-                    new SymbolDefinitionItemTemplate()
+                return _systemTemplates.ToArray();
             else
-                return new ItemTemplate[0];
+                return _userTemplates.ToArray();
Modified: sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Services/OpenResourceManager.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -32,41 +32,51 @@
         private Dictionary<string, IEditorViewContent> _openItems;
+        private Dictionary<ResourceTypeDescriptor, IEditorFactory> _factories;
             base.Initialize();
             _openItems = new Dictionary<string, IEditorViewContent>();
-            LoggingService.Info(Properties.Resources.Service_Init_Open_Resource_Manager);
+            _factories = new Dictionary<ResourceTypeDescriptor, IEditorFactory>();
-        /// <summary>
-        /// Opens the specified resource using its assigned editor. If the resource is already
-        /// open, the the existing editor view is activated instead. If the resource has no assigned
-        /// editor or <see cref="useXmlEditor"/> is true, the resource will be opened in the default
-        /// XML editor.
-        /// </summary>
-        /// <param name="item"></param>
-        /// <param name="conn"></param>
-        /// <param name="useXmlEditor"></param>
-        public void Open(RepositoryItem item, IServerConnection conn, bool useXmlEditor)
-            if (item.IsFolder)
-                return;
-            if (!_openItems.ContainsKey(item.ResourceId))
+            var facts = AddInTree.BuildItems<IEditorFactory>("/Maestro/Editors", this);
+            foreach (var fact in facts)
-                var svc = ServiceRegistry.GetService<ViewContentManager>();
-                IResource res = null;
-                try
+                if (_factories.ContainsKey(fact.ResourceTypeAndVersion))
-                    res = (IResource)conn.ResourceService.GetResource(item.ResourceId);
+                    LoggingService.Info(string.Format(Properties.Resources.OpenResourceManager_SkipEditorRegistration, fact.ResourceTypeAndVersion.ResourceType, fact.ResourceTypeAndVersion.Version));
-                catch (Exception ex)
+                else
-                    MessageService.ShowError(ex);
-                    return;
+                    _factories.Add(fact.ResourceTypeAndVersion, fact);
+                    LoggingService.Info(string.Format(Properties.Resources.EditorRegistered, fact.GetType()));
+            LoggingService.Info(Properties.Resources.Service_Init_Open_Resource_Manager);
+        private IEditorFactory GetRegisteredEditor(ResourceTypeDescriptor rtd)
+            if (_factories.ContainsKey(rtd))
+                return _factories[rtd];
+            else
+                return null;
+        private IEditorFactory GetRegisteredEditor(ResourceTypes type, string version)
+            var rtd = new ResourceTypeDescriptor(type, version);
+            return GetRegisteredEditor(rtd);
+        public void Open(IResource res, IServerConnection conn, bool useXmlEditor)
+            string resourceId = res.ResourceID;
+            if (!_openItems.ContainsKey(resourceId))
+                var svc = ServiceRegistry.GetService<ViewContentManager>();
                 IEditorViewContent ed = null;
                 if (useXmlEditor || !res.IsStronglyTyped)
@@ -77,64 +87,55 @@
                     ed = FindEditor(svc, res.GetResourceTypeDescriptor());
                 var launcher = ServiceRegistry.GetService<UrlLauncher>();
-                var editorSvc = new ResourceEditorService(item.ResourceId, conn, launcher);
+                var editorSvc = new ResourceEditorService(resourceId, conn, launcher);
                 ed.EditorService = editorSvc;
-                _openItems[item.ResourceId] = ed;
+                _openItems[resourceId] = ed;
                 ed.ViewContentClosing += (sender, e) =>
-                    _openItems.Remove(item.ResourceId);
+                    _openItems.Remove(resourceId);
-            _openItems[item.ResourceId].Activate();
+            _openItems[resourceId].Activate();
+        /// <summary>
+        /// Opens the specified resource using its assigned editor. If the resource is already
+        /// open, the the existing editor view is activated instead. If the resource has no assigned
+        /// editor or <see cref="useXmlEditor"/> is true, the resource will be opened in the default
+        /// XML editor.
+        /// </summary>
+        /// <param name="resourceId"></param>
+        /// <param name="conn"></param>
+        /// <param name="useXmlEditor"></param>
+        public void Open(string resourceId, IServerConnection conn, bool useXmlEditor)
+            IResource res = null;
+            try
+                res = (IResource)conn.ResourceService.GetResource(resourceId);
+                Open(res, conn, useXmlEditor);
+                MessageService.ShowError(ex);
+                return;
         private IEditorViewContent FindEditor(ViewContentManager svc, ResourceTypeDescriptor rtd)
-            //TODO: Editors should be registered in the addin registry and we should be
-            //interrogate from that.
-            Version rv = new Version(rtd.Version);
-            if (rv > new Version(1, 0, 0))
+            IEditorFactory fact = GetRegisteredEditor(rtd);
+            //No registered editor, use the xml editor fallback
+            if (fact == null)
                 ed = svc.OpenContent<XmlEditor>(ViewRegion.Document);
-            else //Is a 1.0.0 resource
+            else
-                ResourceTypes rt = (ResourceTypes)Enum.Parse(typeof(ResourceTypes), rtd.ResourceType);
-                switch (rt)
-                    case ResourceTypes.ApplicationDefinition:
-                        break;
-                    case ResourceTypes.DrawingSource:
-                        ed = svc.OpenContent<DrawingSourceEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.FeatureSource:
-                        ed = svc.OpenContent<FeatureSourceEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.LayerDefinition:
-                        ed = svc.OpenContent<LayerDefinitionEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.LoadProcedure:
-                        ed = svc.OpenContent<LoadProcedureEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.MapDefinition:
-                        ed = svc.OpenContent<MapDefinitionEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.PrintLayout:
-                        //ed = svc.OpenContent<PrintLayoutEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.SymbolDefinition:
-                        //ed = svc.OpenContent<SymbolDefinitionEditor>(ViewRegion.Document);
-                        break;
-                    case ResourceTypes.SymbolLibrary:
-                        break;
-                    case ResourceTypes.WebLayout:
-                        //ed = svc.OpenContent<WebLayoutEditor>(ViewRegion.Document);
-                        break;
-                    default:
-                        ed = svc.OpenContent<XmlEditor>(ViewRegion.Document);
-                        break;
+                //I LOVE ANONYMOUS DELEGATES!
+                ed = svc.OpenContent(ViewRegion.Document, () => { return fact.Create(); });
             if (ed == null)
@@ -142,14 +143,5 @@
             return ed;
-        public void Open(RepositoryItem[] items, IServerConnection conn)
-            foreach (var item in items)
-                if (!item.IsFolder)
-                    Open(item, conn, false);
Modified: sandbox/maestro-3.0/Maestro.Base/Services/ViewContentManager.cs
--- sandbox/maestro-3.0/Maestro.Base/Services/ViewContentManager.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Services/ViewContentManager.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -128,6 +128,11 @@
+        public T OpenContent<T>(ViewRegion region, CreateFunc<T> method) where T : IViewContent
+            return OpenContent<T>(null, null, region, method);
         public T OpenContent<T>(ViewRegion region) where T : IViewContent
             return OpenContent<T>(null, null, region);
@@ -135,6 +140,11 @@
         public T OpenContent<T>(string title, string description, ViewRegion region) where T : IViewContent
+            return OpenContent<T>(title, description, region, () => { return (T)Activator.CreateInstance(typeof(T), true); });
+        public T OpenContent<T>(string title, string description, ViewRegion region, CreateFunc<T> method) where T : IViewContent
             var type = typeof(T);
             var wb = Workbench.Instance;
             if (_singletonViewContentTypes.ContainsKey(type.Name))
@@ -149,7 +159,7 @@
-            T obj = (T)Activator.CreateInstance(type, true);
+            T obj = method(); //(T)Activator.CreateInstance(type, true);
             SingletonViewContent svc = obj as SingletonViewContent;
             if (svc != null)
                 throw new InvalidOperationException(string.Format(Properties.Resources.Error_ViewContent_Not_Registered, type.Name));
@@ -160,4 +170,6 @@
             return obj;
+    public delegate T CreateFunc<T>();
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/ApplicationDefinitionItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
 using OSGeo.MapGuide.MaestroAPI;
 using OSGeo.MapGuide.MaestroAPI.Services;
 using Res = Maestro.Base.Properties.Resources;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
 namespace Maestro.Base.Templates
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.ApplicationDefinition.ToString();
-        public override void CreateItem(IResourceService resSvc, string resourceID)
+        public override IResource CreateItem(IServerConnection conn)
-            throw new NotImplementedException();
+            return ObjectFactory.CreateFlexibleLayout(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/DrawingSourceItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/DrawingSourceItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/DrawingSourceItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.DrawingSource.ToString();
+            return ObjectFactory.CreateDrawingSource(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/FeatureSourceItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,10 @@
             ResourceType = ResourceTypes.FeatureSource.ToString();
+            string provider = "";
+            return ObjectFactory.CreateFeatureSource(conn, provider);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/ItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
 using System.Drawing;
+using OSGeo.MapGuide.MaestroAPI;
@@ -38,6 +40,6 @@
         public Image Icon { get; protected set; }
-        public abstract void CreateItem(IResourceService resSvc, string resourceID);
+        public abstract IResource CreateItem(IServerConnection conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/LayerDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/LayerDefinitionItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/LayerDefinitionItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.LayerDefinition.ToString();
+            return ObjectFactory.CreateLayerDefinition(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.MapDefinition.ToString();
+            return ObjectFactory.CreateMapDefinition(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/PrintLayoutItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/PrintLayoutItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/PrintLayoutItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.PrintLayout.ToString();
+            return ObjectFactory.CreatePrintLayout(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/SdfLoadProcedureItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.LoadProcedure.ToString();
+            return ObjectFactory.CreateLoadProcedure(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/ShpLoadProcedureItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/SymbolDefinitionItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,23 +23,42 @@
-    public class SymbolDefinitionItemTemplate : ItemTemplate
+    public class SimpleSymbolDefinitionItemTemplate : ItemTemplate
-        public SymbolDefinitionItemTemplate()
+        public SimpleSymbolDefinitionItemTemplate()
             Category = Res.TPL_CATEGORY_DEFAULT;
             Icon = Res.images_stack;
-            Description = Res.TPL_SDF_DESC;
-            Name = Res.TPL_SDF_NAME;
+            Description = Res.TPL_SSD_DESC;
+            Name = Res.TPL_SSD_NAME;
             ResourceType = ResourceTypes.SymbolDefinition.ToString();
+            return ObjectFactory.CreateSimpleSymbol(conn);
+    public class CompoundSymbolDefinitionItemTemplate : ItemTemplate
+        public CompoundSymbolDefinitionItemTemplate()
+            Category = Res.TPL_CATEGORY_DEFAULT;
+            Icon = Res.images_stack;
+            Description = Res.TPL_CSD_DESC;
+            Name = Res.TPL_CSD_NAME;
+            ResourceType = ResourceTypes.SymbolDefinition.ToString();
+            return ObjectFactory.CreateCompoundSymbol(conn);
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/UserItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/UserItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/UserItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,14 +23,47 @@
+using System.IO;
     public class UserItemTemplate : ItemTemplate
+        private IResource _res;
+        public UserItemTemplate(string templatePath)
+            : this(Res.TPL_USER_DEFINED, templatePath)
+        public UserItemTemplate(string description, string templatePath)
+            : this(Path.GetFileNameWithoutExtension(templatePath), description, templatePath)
+        public string TemplatePath
+            get;
+            private set;
+        public UserItemTemplate(string name, string description, string templatePath)
+            this.Description = description;
+            this.Category = Res.TPL_CATEGORY_DEFAULT;
+            this.Icon = Res.document;
+            this.Name = name;
+            this.TemplatePath = templatePath;
+            _res = ResourceTypeRegistry.Deserialize(File.ReadAllText(templatePath));
+            this.ResourceType = _res.ResourceType.ToString();
+            IResource res = (IResource)_res.Clone();
+            res.CurrentConnection = conn;
+            return res;
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/WebLayoutItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/WebLayoutItemTemplate.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/WebLayoutItemTemplate.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -23,6 +23,8 @@
@@ -37,9 +39,9 @@
             ResourceType = ResourceTypes.WebLayout.ToString();
+            return ObjectFactory.CreateWebLayout(conn, string.Empty);
Modified: sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/UI/RepositoryTreeModel.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -30,61 +30,6 @@
 namespace Maestro.Base.UI
     /// <summary>
-    /// Stub implementation
-    /// </summary>
-    internal class IRepositoryItemImpl : IRepositoryItem
-        private ResourceIdentifier _rid;
-        public IRepositoryItemImpl(string resourceid)
-            this.ResourceId = resourceid;
-            _rid = new ResourceIdentifier(resourceid);
-        public string Name
-            get { return _rid.Name; }
-        public string ResourceId
-            get;
-            private set;
-        public ResourceTypes ResourceType
-            get { return _rid.ResourceType; }
-        public bool IsFolder
-            get { return _rid.IsFolder; }
-        public bool HasChildren
-            get { return false; }
-        public string Owner
-            get { return string.Empty; }
-        public DateTime CreatedDate
-            get { return DateTime.Now; }
-        public DateTime ModifiedDate
-    /// <summary>
     /// Models an object in the repository
     /// </summary>
     public class RepositoryItem
@@ -235,7 +180,7 @@
                 var node = treePath.LastNode as RepositoryItem;
                 if (node != null && node.IsFolder) //Can't enumerate children of documents
-                    var list = _conn.ResourceService.GetRepositoryResources(node.ResourceId, 1);
+                    var list = _conn.ResourceService.GetRepositoryResources(node.ResourceId, "", 1, false);
                     return GetSorted(list);
                 else
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.Designer.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -64,6 +64,8 @@
             this.trvResources.TabIndex = 2;
             this.trvResources.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.trvResources_MouseDoubleClick);
             this.trvResources.MouseClick += new System.Windows.Forms.MouseEventHandler(this.trvResources_MouseClick);
+            this.trvResources.Expanding += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvResources_Expanding);
+            this.trvResources.Expanded += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvResources_Expanded);
             // rdResourceIcon
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -110,7 +110,7 @@
                 if (item != null && !item.IsFolder)
                     var resMgr = ServiceRegistry.GetService<OpenResourceManager>();
-                    resMgr.Open(item, _conn, false);
+                    resMgr.Open(item.ResourceId, _conn, false);
@@ -174,5 +174,35 @@
                 return items.ToArray();
+        private void trvResources_Expanding(object sender, TreeViewAdvEventArgs e)
+            if (this.InvokeRequired)
+                this.Invoke(new MethodInvoker(() =>
+                    this.Cursor = Cursors.WaitCursor;
+            else
+        private void trvResources_Expanded(object sender, TreeViewAdvEventArgs e)
+                    this.Cursor = Cursors.Default;
+            else
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.Designer.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -68,8 +68,9 @@
             this.trvFolders.SelectedNode = null;
             this.trvFolders.Size = new System.Drawing.Size(168, 237);
             this.trvFolders.TabIndex = 0;
-            this.trvFolders.Text = "treeViewAdv1";
             this.trvFolders.SelectionChanged += new System.EventHandler(this.trvFolders_SelectionChanged);
+            this.trvFolders.Expanding += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvFolders_Expanding);
+            this.trvFolders.Expanded += new System.EventHandler<Aga.Controls.Tree.TreeViewAdvEventArgs>(this.trvFolders_Expanded);
             // nodeIcon1
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -267,6 +267,36 @@
+        private void trvFolders_Expanding(object sender, TreeViewAdvEventArgs e)
+            else
+        private void trvFolders_Expanded(object sender, TreeViewAdvEventArgs e)
+            else
     internal class RepositoryFolder
@@ -341,7 +371,7 @@
                 var node = treePath.LastNode as RepositoryFolder;
                 if (node.HasChildren)
-                    var list = _resSvc.GetRepositoryResources(node.ResourceId, 1);
+                    var list = _resSvc.GetRepositoryResources(node.ResourceId, ResourceTypes.Folder.ToString(), 1, true);
                 else
Modified: sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx
--- sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/Maestro.Editors/Common/ResourcePicker.resx	2010-07-21 07:04:30 UTC (rev 5044)
@@ -125,7 +125,7 @@
         AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
         LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
         ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADQ
-        EQAAAk1TRnQBSQFMAgEBCQEAAWABAAFgAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
+        EQAAAk1TRnQBSQFMAgEBCQEAAWgBAAFoAQABEAEAARABAAT/AQkBAAj/AUIBTQE2AQQGAAE2AQQCAAEo
         AwABQAMAATADAAEBAQABCAYAAQwYAAGAAgABgAMAAoABAAGAAwABgAEAAYABAAKAAgADwAEAAcAB3AHA
         AQAB8AHKAaYBAAEzBQABMwEAATMBAAEzAQACMwIAAxYBAAMcAQADIgEAAykBAANVAQADTQEAA0IBAAM5
         AQABgAF8Af8BAAJQAf8BAAGTAQAB1gEAAf8B7AHMAQABxgHWAe8BAAHWAucBAAGQAakBrQIAAf8BMwMA
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -1,7 +1,7 @@
 // <auto-generated>
@@ -61,6 +61,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Bad Document: Expected attributes at the root level node.
+        /// </summary>
+        internal static string ERR_BAD_DOCUMENT_NO_ROOT_ATTRIBUTES {
+            get {
+                return ResourceManager.GetString("ERR_BAD_DOCUMENT_NO_ROOT_ATTRIBUTES", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Resource cannot be downgraded. It is already older than the version this converter can downgrade to.
         /// </summary>
         internal static string ERR_CANNOT_DOWNGRADE_OLDER_RESOURCE {
@@ -115,6 +124,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Could not find matching serializer for this resource: .
+        /// </summary>
+        internal static string ERR_NO_SERIALIZER {
+            get {
+                return ResourceManager.GetString("ERR_NO_SERIALIZER", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to There is no upgrade path to the desired resource version.
         /// </summary>
         internal static string ERR_NO_UPGRADE_PATH {
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx	2010-07-21 07:04:30 UTC (rev 5044)
@@ -117,6 +117,9 @@
   <resheader name="writer">
     <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
   </resheader>
+  <data name="ERR_BAD_DOCUMENT_NO_ROOT_ATTRIBUTES" xml:space="preserve">
+    <value>Bad Document: Expected attributes at the root level node</value>
+  </data>
   <data name="ERR_CANNOT_DOWNGRADE_OLDER_RESOURCE" xml:space="preserve">
     <value>Resource cannot be downgraded. It is already older than the version this converter can downgrade to</value>
   </data>
@@ -135,6 +138,9 @@
   <data name="ERR_NO_DOWNGRADE_PATH" xml:space="preserve">
     <value>There is no downgrade path to the desired resource version</value>
   </data>
+  <data name="ERR_NO_SERIALIZER" xml:space="preserve">
+    <value>Could not find matching serializer for this resource: </value>
+  </data>
   <data name="ERR_NO_UPGRADE_PATH" xml:space="preserve">
     <value>There is no upgrade path to the desired resource version</value>
   </data>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceContentVersionChecker.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -47,17 +47,35 @@
         /// <summary>
+        /// Alternate constructor
+        /// </summary>
+        /// <param name="xmlContent"></param>
+        public ResourceContentVersionChecker(string xmlContent)
+            _reader = new XmlTextReader(new StringReader(xmlContent));
+        private ResourceTypeDescriptor _rtd;
+        /// <summary>
         /// Gets the resource content version
         /// </summary>
-        public Version GetVersion()
+        public ResourceTypeDescriptor GetVersion()
-            Version v = new Version(1, 0, 0);
+            if (_rtd == null)
+                _reader.Read();
-            //Inspect the stream up to the version attribute
-            //Parse this attribute and return it
+                if (!_reader.HasAttributes)
+                    throw new XmlException(Properties.Resources.ERR_BAD_DOCUMENT_NO_ROOT_ATTRIBUTES);
-            return v;
+                ResourceTypes rt = (ResourceTypes)Enum.Parse(typeof(ResourceTypes), _reader.Name);
+                string version = _reader.GetAttribute("version");
+                _rtd = new ResourceTypeDescriptor(rt, version);
+            return _rtd;
         /// <summary>
@@ -65,8 +83,11 @@
         /// </summary>
         public void Dispose()
-            _reader.Close();
-            _stream.Dispose();
+            if (_stream != null)
+                _stream.Dispose();
+            if (_reader != null)
+                _reader.Close();
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs	2010-07-20 16:45:02 UTC (rev 5043)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ResourceTypeRegistry.cs	2010-07-21 07:04:30 UTC (rev 5044)
@@ -185,7 +185,7 @@
                     xr.MoveToContent();
                     if (!xr.HasAttributes)
-                        throw new SerializationException("Bad Document: Expected attributes at the root level node");
+                        throw new SerializationException();
                     //Resources post-1.0.0 have a version attribute, those without are assumed to be 1.0.0 version
                     try
@@ -222,9 +222,19 @@
             var rd = res.GetResourceTypeDescriptor();
             if (!_serializers.ContainsKey(rd))
-                throw new SerializationException("Could not find matching serializer for this resource: " + rd.ToString()); //LOCALIZE
+                throw new SerializationException(Properties.Resources.ERR_NO_SERIALIZER + rd.ToString());
             return _serializers[rd].Serialize(res);
+        public static IResource Deserialize(string xml)
+            var checker = new ResourceContentVersionChecker(xml);
+            var rd = checker.GetVersion();
+            if (!_serializers.ContainsKey(rd))
+            return _serializers[rd].Deserialize(xml);
More information about the mapguide-commits mailing list
