[mapguide-commits] r5045 - in sandbox/maestro-3.0: . Maestro
Maestro.Base Maestro.Base/Commands/SiteExplorer
Maestro.Base/Properties Maestro.Base/UI Maestro.Editors
Maestro.ResourceValidation
Maestro.ResourceValidation/Properties Maestro.Shared.UI
OSGeo.MapGuide.MaestroAPI OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI/Properties
OSGeo.MapGuide.MaestroAPI/Resource OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Wed Jul 21 06:14:11 EDT 2010
Author: jng
Date: 2010-07-21 10:14:11 +0000 (Wed, 21 Jul 2010)
New Revision: 5045
Added:
sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs
sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs
sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx
sandbox/maestro-3.0/Maestro.ResourceValidation/
sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/LayerDefinitionValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj
sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/AssemblyInfo.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs
sandbox/maestro-3.0/Maestro.Shared.UI/CancelException.cs
sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.cs
sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.resx
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj
sandbox/maestro-3.0/Maestro/Maestro.csproj
sandbox/maestro-3.0/Maestro/Maestro.sln
sandbox/maestro-3.0/Maestro/Program.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
This submission includes the port of the resource validation framework from Maestro 2.1
with some changes:
- Validation is now done on a per-version basis. As a result, attempting to validate something like a LayerDefinition (v1.3.0) without a LayerDefinition 1.3.0 validation will result in the default "no registered validator" warning.
- Also as a result, some resource validation doesn't currently work as only v1.0.0 validators are included by default.
Also other changes:
- Fix the output of TestConnection API in the http implementation
- Add validate context menu command, because we now have a multi-select treeview this can now validate a *selection* of resources.
- Add more resource object interfaces, and flesh out existing ones. The idea is that although there may be multiple versions of a given resource, we should be able to access commmon properties through a common interface.
- Add extra APIs to the generated Envelope class.
Modified: sandbox/maestro-3.0/Maestro/Maestro.csproj
--- sandbox/maestro-3.0/Maestro/Maestro.csproj 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro/Maestro.csproj 2010-07-21 10:14:11 UTC (rev 5045)
@@ -3,7 +3,7 @@
<PropertyGroup>
<Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
<Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
- <ProductVersion>9.0.21022</ProductVersion>
+ <ProductVersion>9.0.30729</ProductVersion>
<SchemaVersion>2.0</SchemaVersion>
<ProjectGuid>{E0C36475-2B70-4F6D-ACE0-8943167806DC}</ProjectGuid>
<OutputType>WinExe</OutputType>
@@ -79,6 +79,10 @@
<Project>{F1E2F468-5030-4DBA-968C-9620284AFAA1}</Project>
<Name>Maestro.Base</Name>
</ProjectReference>
+ <ProjectReference Include="..\Maestro.ResourceValidation\Maestro.ResourceValidation.csproj">
+ <Project>{3B29C138-666C-46D0-A55D-824E5192C091}</Project>
+ <Name>Maestro.ResourceValidation</Name>
+ </ProjectReference>
<ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI.Http\OSGeo.MapGuide.MaestroAPI.Http.csproj">
<Project>{6EF1E775-444B-4E5F-87FB-D687C43A68D7}</Project>
<Name>OSGeo.MapGuide.MaestroAPI.Http</Name>
Modified: sandbox/maestro-3.0/Maestro/Maestro.sln
--- sandbox/maestro-3.0/Maestro/Maestro.sln 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro/Maestro.sln 2010-07-21 10:14:11 UTC (rev 5045)
@@ -66,6 +66,8 @@
EndProject
Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "OSGeo.MapGuide.MaestroAPI.Native-2.0.2", "..\OSGeo.MapGuide.MaestroAPI.Native\OSGeo.MapGuide.MaestroAPI.Native-2.0.2.csproj", "{A6F27323-28A7-4F65-A54A-337B09962C0F}"
EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "Maestro.ResourceValidation", "..\Maestro.ResourceValidation\Maestro.ResourceValidation.csproj", "{3B29C138-666C-46D0-A55D-824E5192C091}"
+EndProject
Global
GlobalSection(SolutionConfigurationPlatforms) = preSolution
Debug|Any CPU = Debug|Any CPU
@@ -168,6 +170,10 @@
{A6F27323-28A7-4F65-A54A-337B09962C0F}.Debug|Any CPU.Build.0 = Debug|Any CPU
{A6F27323-28A7-4F65-A54A-337B09962C0F}.Release|Any CPU.ActiveCfg = Release|Any CPU
{A6F27323-28A7-4F65-A54A-337B09962C0F}.Release|Any CPU.Build.0 = Release|Any CPU
+ {3B29C138-666C-46D0-A55D-824E5192C091}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+ {3B29C138-666C-46D0-A55D-824E5192C091}.Debug|Any CPU.Build.0 = Debug|Any CPU
+ {3B29C138-666C-46D0-A55D-824E5192C091}.Release|Any CPU.ActiveCfg = Release|Any CPU
+ {3B29C138-666C-46D0-A55D-824E5192C091}.Release|Any CPU.Build.0 = Release|Any CPU
EndGlobalSection
GlobalSection(SolutionProperties) = preSolution
HideSolutionNode = FALSE
@@ -185,6 +191,7 @@
{CFD19053-2172-41D3-8460-0FD2123A1E88} = {CCF50F7F-DD89-41C1-843C-1BFA2375EEE0}
{5AD2CDBA-952E-4148-98A1-31D2E0D540D5} = {CCF50F7F-DD89-41C1-843C-1BFA2375EEE0}
{07588440-5F9F-4C30-AA06-9CF30BA6DDE6} = {CCF50F7F-DD89-41C1-843C-1BFA2375EEE0}
+ {3B29C138-666C-46D0-A55D-824E5192C091} = {CCF50F7F-DD89-41C1-843C-1BFA2375EEE0}
{E9BDFC13-1555-4050-869C-D2C44B7ED447} = {FCC83861-96C6-43CA-B33B-DB1D0DEC8E79}
{AF9E8895-0B12-4265-B3C9-89E319B49E70} = {FCC83861-96C6-43CA-B33B-DB1D0DEC8E79}
{F4420153-9DF3-4407-AD65-E8ABED2B6E25} = {FCC83861-96C6-43CA-B33B-DB1D0DEC8E79}
Modified: sandbox/maestro-3.0/Maestro/Program.cs
--- sandbox/maestro-3.0/Maestro/Program.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro/Program.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -28,6 +28,7 @@
using Maestro.Base.UI;
using OSGeo.MapGuide.MaestroAPI;
using ICSharpCode.Core.WinForms;
+using Maestro.ResourceValidation;
namespace Maestro
@@ -61,6 +62,9 @@
LoggingService.Info(Properties.Resources.Warn_Mono);
+ //Init our default set of resource validators
+ ResourceValidatorLoader.LoadStockValidators();
AppDomain.CurrentDomain.AssemblyLoad += new AssemblyLoadEventHandler(CurrentDomain_AssemblyLoad);
// Get a reference to the entry assembly (Startup.exe)
Added: sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SiteExplorer/ValidateCommand.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,149 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using Maestro.Shared.UI;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using System.ComponentModel;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
+using OSGeo.MapGuide.ObjectModels.Common;
+namespace Maestro.Base.Commands.SiteExplorer
+ internal class ValidateCommand : AbstractMenuCommand
+ private IServerConnection _conn;
+ public override void Run()
+ var wb = Workbench.Instance;
+ var items = wb.ActiveSiteExplorer.SelectedItems;
+ var connMgr = ServiceRegistry.GetService<ServerConnectionManager>();
+ _conn = connMgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+ if (items.Length > 0)
+ var pdlg = new ProgressDialog();
+ pdlg.CancelAbortsThread = true;
+ string[] args = new string[items.Length];
+ for (int i = 0; i < items.Length; i++)
+ args[i] = items[i].ResourceId;
+ var issues = (ValidationIssue[])pdlg.RunOperationAsync(wb, new ProgressDialog.DoBackgroundWork(BackgroundValidate), items[0].ResourceId);
+ if (issues != null)
+ if (issues.Length > 0)
+ //Sigh! LINQ would've made this code so simple...
+ var sort = new Dictionary<string, List<ValidationIssue>>();
+ foreach (var issue in issues)
+ string resId = issue.Resource.ResourceID;
+ if (!sort.ContainsKey(resId))
+ sort[resId] = new List<ValidationIssue>();
+ sort[resId].Add(issue);
+ var groupedIssues = new List<KeyValuePair<string, ValidationIssue[]>>();
+ foreach (var kvp in sort)
+ groupedIssues.Add(
+ new KeyValuePair<string, ValidationIssue[]>(
+ kvp.Key,
+ kvp.Value.ToArray()));
+ var resDlg = new ValidationResultsDialog(groupedIssues);
+ resDlg.ShowDialog(wb);
+ else
+ MessageService.ShowMessage(Properties.Resources.ValidationNoIssues);
+ private object BackgroundValidate(BackgroundWorker worker, DoWorkEventArgs e, params object[] args)
+ //Collect all documents to be validated. Some of these selected items
+ //may be folders.
+ var documents = new List<string>();
+ foreach (object a in args)
+ string rid = a.ToString();
+ if (ResourceIdentifier.Validate(rid))
+ var resId = new ResourceIdentifier(rid);
+ if (resId.IsFolder)
+ foreach (IRepositoryItem o in _conn.ResourceService.GetRepositoryResources((string)args[0]).Children)
+ if (!o.IsFolder)
+ documents.Add(o.ResourceId);
+ else
+ documents.Add(rid);
+ worker.ReportProgress(0);
+ var issues = new List<ValidationIssue>();
+ int i = 0;
+ foreach (string s in documents)
+ worker.ReportProgress((int)((i / (double)documents.Count) * 100), s);
+ IResource item = null;
+ try
+ //TODO: This will validate resources multiple times, if they are referenced by
+ //resources inside the folder
+ item = _conn.ResourceService.GetResource(s);
+ issues.AddRange(ResourceValidatorSet.Validate(item, true));
+ catch (Exception ex)
+ string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ issues.Add(new ValidationIssue(item, ValidationStatus.Error, string.Format(Properties.Resources.ValidationResourceLoadFailed, msg)));
+ i++;
+ return issues.ToArray();
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.addin 2010-07-21 10:14:11 UTC (rev 5045)
@@ -285,6 +285,9 @@
<MenuItem id="Paste"
label="${res:SiteExplorer_SelectedFolder_Paste}"
class="Maestro.Base.Commands.NotImplementedCommand" />
+ <MenuItem id="Validate"
+ label="${res:SiteExplorer_ValidateResources}"
+ class="Maestro.Base.Commands.SiteExplorer.ValidateCommand" />
</Condition>
</Path>
@@ -304,6 +307,9 @@
<MenuItem id="Cut"
label="${res:SiteExplorer_SelectedItem_Cut}"
</Condition>
</Path>
@@ -329,6 +335,9 @@
<MenuItem type="Separator" />
<MenuItem id="Properties"
label="${res:SiteExplorer_SelectedItem_Properties}"
@@ -352,6 +361,9 @@
<MenuItem id="Cut"
</Condition>
</Path>
@@ -375,6 +387,9 @@
<MenuItem id="Cut"
</Condition>
</Path>
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-07-21 10:14:11 UTC (rev 5045)
@@ -66,6 +66,7 @@
<Compile Include="Commands\SiteExplorer\OpenResourceCommand.cs" />
<Compile Include="Commands\SiteExplorer\RefreshCommand.cs" />
<Compile Include="Commands\SiteExplorer\ResourcePropertiesCommand.cs" />
+ <Compile Include="Commands\SiteExplorer\ValidateCommand.cs" />
<Compile Include="Commands\StartupCommand.cs" />
<Compile Include="Commands\Test\OpenCoordinateSystemPickerCommand.cs" />
<Compile Include="Commands\Test\OpenResourceCommand.cs" />
@@ -216,6 +217,12 @@
<DependentUpon>SiteExplorer.cs</DependentUpon>
</Compile>
<Compile Include="TabFactory.cs" />
+ <Compile Include="UI\ValidationResultsDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="UI\ValidationResultsDialog.designer.cs">
+ <DependentUpon>ValidationResultsDialog.cs</DependentUpon>
+ </Compile>
<Compile Include="UI\WelcomeScreen.cs">
<SubType>UserControl</SubType>
</Compile>
@@ -352,6 +359,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="UI\ValidationResultsDialog.resx">
+ </EmbeddedResource>
<EmbeddedResource Include="UI\WelcomeScreen.resx">
<DependentUpon>WelcomeScreen.cs</DependentUpon>
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -1040,6 +1040,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Validate.
+ /// </summary>
+ internal static string SiteExplorer_ValidateResources {
+ get {
+ return ResourceManager.GetString("SiteExplorer_ValidateResources", resourceCulture);
internal static System.Drawing.Bitmap tick {
get {
object obj = ResourceManager.GetObject("tick", resourceCulture);
@@ -1271,5 +1280,68 @@
return ResourceManager.GetString("TPL_WL_NAME", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Building resource list....
+ /// </summary>
+ internal static string ValidationBuildingList {
+ get {
+ return ResourceManager.GetString("ValidationBuildingList", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to save file: {0}.
+ /// </summary>
+ internal static string ValidationFailedError {
+ get {
+ return ResourceManager.GetString("ValidationFailedError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No issues found during validation.
+ /// </summary>
+ internal static string ValidationNoIssues {
+ get {
+ return ResourceManager.GetString("ValidationNoIssues", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Validating resource: {0}.
+ /// </summary>
+ internal static string ValidationProgressMessage {
+ get {
+ return ResourceManager.GetString("ValidationProgressMessage", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to load resource: {0}.
+ /// </summary>
+ internal static string ValidationResourceLoadFailed {
+ get {
+ return ResourceManager.GetString("ValidationResourceLoadFailed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} - {1}: {2}.
+ /// </summary>
+ internal static string ValidationResultFormat {
+ get {
+ return ResourceManager.GetString("ValidationResultFormat", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Validating ....
+ /// </summary>
+ internal static string ValidationValidating {
+ get {
+ return ResourceManager.GetString("ValidationValidating", resourceCulture);
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-07-21 10:14:11 UTC (rev 5045)
@@ -580,4 +580,37 @@
<data name="TPL_CSD_NAME" xml:space="preserve">
<value>Compound Symbol Definition</value>
</data>
+ <data name="ValidationBuildingList" xml:space="preserve">
+ <value>Building resource list...</value>
+ <comment>A message that is displayed while building the list of resources to validate</comment>
+ </data>
+ <data name="ValidationResourceLoadFailed" xml:space="preserve">
+ <value>Failed to load resource: {0}</value>
+ <comment>An error message that is displayed if an error occurs while validating the resource</comment>
+ </data>
+ <data name="SiteExplorer_ValidateResources" xml:space="preserve">
+ <value>Validate</value>
+ </data>
+ <data name="ValidationValidating" xml:space="preserve">
+ <value>Validating ...</value>
+ <comment>A message that is displayed while the validator runs</comment>
+ </data>
+ <data name="ValidationFailedError" xml:space="preserve">
+ <value>Failed to save file: {0}</value>
+ <comment>An error message that is displayed if the log was not saved</comment>
+ </data>
+ <data name="ValidationProgressMessage" xml:space="preserve">
+ <value>Validating resource: {0}</value>
+ <comment>The header text for a resource in the validation log</comment>
+ </data>
+ <data name="ValidationResultFormat" xml:space="preserve">
+ <value>{0} - {1}: {2}</value>
+ <comment>The format used to write the results into the log file.
+{0} is the status, eg. warning
+{1} is the resource id
+{2} is the validation message</comment>
+ </data>
+ <data name="ValidationNoIssues" xml:space="preserve">
+ <value>No issues found during validation</value>
+ </data>
</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,123 @@
+// Copyright (C) 2009, Kenneth Skovhede
+// http://www.hexad.dk, opensource at hexad.dk
+#endregion
+using System;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+ public partial class ValidationResultsDialog : Form
+ private List<KeyValuePair<string, ValidationIssue[]>> m_issues = new List<KeyValuePair<string, ValidationIssue[]>>();
+ public ValidationResultsDialog(string resourceId, ValidationIssue[] issues)
+ : this(
+ new List<KeyValuePair<string, ValidationIssue[]>>(
+ new KeyValuePair<string, ValidationIssue[]>[] {
+ new KeyValuePair<string, ValidationIssue[]>(resourceId, issues)
+ public ValidationResultsDialog(List<KeyValuePair<string, ValidationIssue[]>> issues)
+ : this()
+ listView1.Items.Clear();
+ m_issues = issues;
+ foreach (KeyValuePair<string, ValidationIssue[]> e in issues)
+ foreach (ValidationIssue issue in e.Value)
+ if (issue == null || issue.Resource == null || string.IsNullOrEmpty(issue.Message) || string.IsNullOrEmpty(issue.Resource.ResourceID))
+ continue;
+ ListViewItem lvi = new ListViewItem(issue.Resource.ResourceID);
+ switch (issue.Status)
+ case ValidationStatus.Information:
+ lvi.ImageIndex = 0;
+ break;
+ case ValidationStatus.Warning:
+ lvi.ImageIndex = 1;
+ break;
+ case ValidationStatus.Error:
+ lvi.ImageIndex = 2;
+ break;
+ default:
+ lvi.ImageIndex = -1;
+ break;
+ lvi.SubItems.Add(issue.Message);
+ listView1.Items.Add(lvi);
+ private ValidationResultsDialog()
+ InitializeComponent();
+ private void CancelBtn_Click(object sender, EventArgs e)
+ this.Close();
+ private void SaveReportBtn_Click(object sender, EventArgs e)
+ try
+ if (saveFileDialog.ShowDialog(this) == DialogResult.OK)
+ using (System.IO.StreamWriter sw = new System.IO.StreamWriter(saveFileDialog.FileName, false))
+ foreach (KeyValuePair<string, ValidationIssue[]> p in m_issues)
+ if (p.Value.Length > 0)
+ sw.WriteLine(new string('*', 80));
+ sw.WriteLine(string.Format(Properties.Resources.ValidationProgressMessage, p.Key));
+ foreach (ValidationIssue i in p.Value)
+ sw.WriteLine(string.Format(Properties.Resources.ValidationResultFormat, i.Status, i.Resource, i.Message));
+ sw.WriteLine();
+ MessageBox.Show(this, string.Format(Properties.Resources.ValidationFailedError, msg), Application.ProductName, MessageBoxButtons.OK, MessageBoxIcon.Error);
Added: sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.designer.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,124 @@
+ partial class ValidationResultsDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ this.components = new System.ComponentModel.Container();
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ValidationResultsDialog));
+ this.panel1 = new System.Windows.Forms.Panel();
+ this.SaveReportBtn = new System.Windows.Forms.Button();
+ this.CancelBtn = new System.Windows.Forms.Button();
+ this.listView1 = new System.Windows.Forms.ListView();
+ this.columnHeader1 = new System.Windows.Forms.ColumnHeader();
+ this.columnHeader2 = new System.Windows.Forms.ColumnHeader();
+ this.imageList1 = new System.Windows.Forms.ImageList(this.components);
+ this.saveFileDialog = new System.Windows.Forms.SaveFileDialog();
+ this.panel1.SuspendLayout();
+ this.SuspendLayout();
+ // panel1
+ this.panel1.Controls.Add(this.SaveReportBtn);
+ this.panel1.Controls.Add(this.CancelBtn);
+ resources.ApplyResources(this.panel1, "panel1");
+ this.panel1.Name = "panel1";
+ // SaveReportBtn
+ resources.ApplyResources(this.SaveReportBtn, "SaveReportBtn");
+ this.SaveReportBtn.Name = "SaveReportBtn";
+ this.SaveReportBtn.UseVisualStyleBackColor = true;
+ this.SaveReportBtn.Click += new System.EventHandler(this.SaveReportBtn_Click);
+ // CancelBtn
+ resources.ApplyResources(this.CancelBtn, "CancelBtn");
+ this.CancelBtn.DialogResult = System.Windows.Forms.DialogResult.Cancel;
+ this.CancelBtn.Name = "CancelBtn";
+ this.CancelBtn.UseVisualStyleBackColor = true;
+ this.CancelBtn.Click += new System.EventHandler(this.CancelBtn_Click);
+ // listView1
+ this.listView1.Columns.AddRange(new System.Windows.Forms.ColumnHeader[] {
+ this.columnHeader1,
+ this.columnHeader2});
+ resources.ApplyResources(this.listView1, "listView1");
+ this.listView1.GridLines = true;
+ this.listView1.Name = "listView1";
+ this.listView1.SmallImageList = this.imageList1;
+ this.listView1.UseCompatibleStateImageBehavior = false;
+ this.listView1.View = System.Windows.Forms.View.Details;
+ // columnHeader1
+ resources.ApplyResources(this.columnHeader1, "columnHeader1");
+ // columnHeader2
+ resources.ApplyResources(this.columnHeader2, "columnHeader2");
+ // imageList1
+ this.imageList1.ImageStream = ((System.Windows.Forms.ImageListStreamer)(resources.GetObject("imageList1.ImageStream")));
+ this.imageList1.TransparentColor = System.Drawing.Color.Transparent;
+ this.imageList1.Images.SetKeyName(0, "Information.ico");
+ this.imageList1.Images.SetKeyName(1, "Warning.ico");
+ this.imageList1.Images.SetKeyName(2, "Error.ico");
+ // saveFileDialog1
+ this.saveFileDialog.DefaultExt = "txt";
+ resources.ApplyResources(this.saveFileDialog, "saveFileDialog1");
+ // ValidationResults
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.CancelButton = this.CancelBtn;
+ this.Controls.Add(this.listView1);
+ this.Controls.Add(this.panel1);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.SizableToolWindow;
+ this.Name = "ValidationResults";
+ this.panel1.ResumeLayout(false);
+ this.ResumeLayout(false);
+ #endregion
+ private System.Windows.Forms.Panel panel1;
+ private System.Windows.Forms.Button CancelBtn;
+ private System.Windows.Forms.ListView listView1;
+ private System.Windows.Forms.ColumnHeader columnHeader1;
+ private System.Windows.Forms.ColumnHeader columnHeader2;
+ private System.Windows.Forms.ImageList imageList1;
+ private System.Windows.Forms.Button SaveReportBtn;
+ private System.Windows.Forms.SaveFileDialog saveFileDialog;
Added: sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx
--- sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/UI/ValidationResultsDialog.resx 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,365 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="SaveReportBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom, Right</value>
+ </data>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="SaveReportBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>488, 8</value>
+ </data>
+ <data name="SaveReportBtn.Size" type="System.Drawing.Size, System.Drawing">
+ <value>91, 23</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="SaveReportBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="SaveReportBtn.Text" xml:space="preserve">
+ <value>Save as file...</value>
+ </data>
+ <data name=">>SaveReportBtn.Name" xml:space="preserve">
+ <value>SaveReportBtn</value>
+ </data>
+ <data name=">>SaveReportBtn.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>SaveReportBtn.Parent" xml:space="preserve">
+ <value>panel1</value>
+ </data>
+ <data name=">>SaveReportBtn.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <data name="CancelBtn.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
+ <value>Bottom</value>
+ </data>
+ <data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>256, 8</value>
+ </data>
+ <data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="CancelBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name="CancelBtn.Text" xml:space="preserve">
+ <value>Close</value>
+ </data>
+ <data name=">>CancelBtn.Name" xml:space="preserve">
+ <value>CancelBtn</value>
+ </data>
+ <data name=">>CancelBtn.Type" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="panel1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ </data>
+ <data name="panel1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 232</value>
+ </data>
+ <data name="panel1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>595, 42</value>
+ </data>
+ <data name="panel1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>panel1.Name" xml:space="preserve">
+ </data>
+ <data name=">>panel1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Panel, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>panel1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>panel1.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <data name="columnHeader1.Text" xml:space="preserve">
+ <value>Resource</value>
+ </data>
+ <data name="columnHeader1.Width" type="System.Int32, mscorlib">
+ <value>240</value>
+ </data>
+ <data name="columnHeader2.Text" xml:space="preserve">
+ <value>Message</value>
+ </data>
+ <data name="columnHeader2.Width" type="System.Int32, mscorlib">
+ <value>324</value>
+ </data>
+ <data name="listView1.Dock" type="System.Windows.Forms.DockStyle, System.Windows.Forms">
+ <value>Fill</value>
+ </data>
+ <data name="listView1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>0, 0</value>
+ </data>
+ <data name="listView1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>595, 232</value>
+ </data>
+ <metadata name="imageList1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="imageList1.ImageStream" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>
+ AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
+ LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAADy
+ DgAAAk1TRnQBSQFMAgEBAwEAAQwBAAEMAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
+ AwABEAMAAQEBAAEgBgABEC4AAwwBEAMVAR0kAAEQAg8BFQMRARcDEQEXAxEBFwMRARcDEQEXAxEBFwMR
+ ARcDEQEXAxEBFwMRARcDFQEdHAADCQEMAxYBHwMWAR8DFgEfAxYBHwMWAR9kAAMSARgBgAEsARoB9wHE
+ AUcBLgH/Ac0BSwExAf8BzgFLATEB/wHKAUoBMAH/AaQBOwEmAf8BSQI0AYYUAAFNATMBNgHNAQIBuwHr
+ Af8BAgG9AewB/wECAcEB7gH/AQIBxAHwAf8BAgHFAfAB/wECAcUB8AH/AQIBxQHwAf8BAgHFAfAB/wEC
+ AcUB8AH/AQIBwwHvAf8BAgG/Ae0B/wECAbsB6wH/AQYBlwG+Af8UAAFSATABMwGrASoBPAG2Af8BLAE/
+ AcAB/wEtAUEBxgH/AS0BQQHHAf8BLAFAAcMB/wErAT4BuwH/ASMBKgGBAf9cAAFKAjQBigHGAUgBLwH/
+ AdcBTgEzAf8B4wFSATYB/wHpAVQBNwH/AeoBVAE3Af8B5gFTATYB/wHdAVABNAH/Ac8BSwExAf8BhQEr
+ ASIB/BAAAQgBggGjAf8BAgG8AewB/wECAcUB8AH/AQIBywHzAf8BAgHOAfUB/wECAdAB9gH/AQIB0AH2
+ Af8BAgHQAfYB/wECAdAB9gH/AQIBzwH2Af8BAgHNAfQB/wECAcgB8gH/AQIBwAHuAf8BAgG7AesB/wMS
+ ARgMAAFSATABMwGrASwBQAHBAf8BLwFEAdAB/wExAUcB2QH/ATIBSQHeAf8BMgFJAd8B/wEyAUgB3AH/
+ ATABRgHVAf8BLQFCAcgB/wEkASwBhAH/VAABOwIyAWMBygFJATAB/wHfAVEBNQH/Ae8BVgE5Af8B+wHx
+ Ae8B/wH9AvkB/wHhAWcBUAH/AfwBWwE8Af8B9QFYAToB/wHnAVMBNwH/AdMBTQEyAf8BhQErASIB/AwA
+ AT4CMwFrAQIBvwHtAf8BAgHJAfIB/wECAdAB9gH/AQIB1AH5Af8BAgHUAfcB/wGFAdwB6wH/AYEB2wHq
+ Af8BAgHQAfMB/wECAdYB+gH/AQIB0gH4Af8BAgHNAfQB/wECAcMB7wH/AQkBgAGdAf8MAAFSATABMwGr
+ ASwBQAHDAf8BMQFGAdYB/wE0AUsB5AH/ATUBTQHsAf8BNgFOAe8B/wE2AU8B8AH/ATYBTgHuAf8BNAFM
+ AeYB/wEyAUkB3QH/AS4BQwHMAf8BJAEsAYQB/1AAAbcBQgErAf8B3QFQATQB/wHyAVcBOQH/Af4BXgFA
+ Cf8B4wGJAXkB/wHoAZsBjQL/AWIBRAH/AfkBWgE7Af8B5wFTATcB/wHPAUsBMQH/AUkCNAGGDAABEgGO
+ Aa4B/wE9AdYB9QH/AUMB3QH5Af8BOQHgAfsB/wEeAc0B6Qn/ASwBygHjAf8BAgHZAfsB/wECAdQB+QH/
+ AQIBzQH1Af8BAgHDAe8B/wEvAisBSQgAAVABMQEzAZ8BKwE/Ab0B/wEwAUYB1QH/ATQBTAHmAf8BqgGz
+ AesB/wGcAaYB6QH/ATkBUgH6Af8BOQFSAfsB/wFZAWsB4AH/AeUB6AH4Af8BNQFMAegB/wEyAUkB3QH/
+ AS0BQgHIAf8BIwEqAYEB/0gAAUcCNAGBAdEBTAEyAf8B6wFUATgB/wH+AVwBPgL/AWgBSwH/AewBsQGl
+ Bf8B8wHMAcQB/wHhAXIBWwH/AfwBagFOAv8BYgFEAf8B9QFYAToB/wHdAVABNAH/AaQBOwEmAf8MAAE9
+ AjMBaAFLAdYB9QH/AVIB3gH5Af8BWAHkAfsB/wFfAegB/QH/AXQB2QHpAf8BgQHeAesB/wELAdsB+wH/
+ AQIB2AH7Af8BAgHTAfgB/wECAcoB8wH/AQkBgQGeAf8MAAEkASwBgwH/AS4BQgHKAf8BMwFKAeAB/wGI
+ AZQB4gn/AZwBpwHsAf8BWgFtAeQJ/wHeAeEB9wH/ATQBTAHoAf8BMAFGAdUB/wErAT4BuwH/AxYBH0QA
+ AYMBJwEfAfsB2gFPATQB/wH0AVcBOQL/AWYBSgL/AXUBWgH/AewBcAFXCf8B+AF2AVsC/wF3AVwC/wFv
+ AVQB/wH8AVsBPAH/AeYBUwE2Af8BygFKATAB/xAAATABlgGwAf8BYAHeAfgB/wFnAeUB+wH/AW4B6QH9
+ Cf8BgQHoAfkB/wFYAeQB+wH/AQIBzwH2Af8BAgHFAfAB/wEuAioBRwwAASUBLgGJAf8BOAFNAdQB/wFG
+ AVwB6QH/AVIBZwH1Af8B1wHbAfcR/wH3AfgB/QH/ATYBTwHwAf8BNgFOAe4B/wEyAUgB3AH/ASwBQAHD
+ Af8DFgEfRAABngE4ASUB/wHfAVEBNQH/AfcBZwFLAv8BeQFgAf8B+AGAAWcB/wHsAXwBZQH/AfwB8wHx
+ Bf8B5gGLAXsC/wGBAWoC/wF9AWUB/wH+AXIBWAH/AeoBVAE3Af8BzgFLATEB/wMVAR0MAAE8AjMBZgFv
+ Ad4B9wH/AXYB5QH6Af8BfQHqAfwJ/wGPAeoB+QH/AZYB7QH8Af8BXQHdAfcB/wEJAYEBngH/EAABMQE5
+ AY8B/wFMAV4B2wH/AVUBaQHtAf8BXgFzAfgB/wFmAXkB/AH/Ad8B4gH5Cf8B/AH9Af4B/wGFAZQB+QH/
+ AXMBgwH8Af8BNgFPAfAB/wEyAUkB3wH/AS0BQQHHAf8DFgEfRAABlwE2ASMB/wHeAVEBNQH/AfgBgAFn
+ Av8BhQFxAf8B/gGNAXkB/wH1AdgB0gH/AecBmwGNBf8B+QHnAeQC/wGOAXoC/wGJAXUB/wH+AYEBagH/
+ Ae0BdgFfAf8BzQFLATEB/wMMARAQAAFAAZoBsQH/AYMB5gH5Af8BigHrAfwJ/wGeAewB+QH/AaQB7gH7
+ Af8BqgHsAfoB/wEtAioBRhAAATYBPQGQAf8BVgFoAdwB/wFgAXMB7QH/AWkBfAH4Af8BhgGTAeoR/wHJ
+ Ac8B9AH/AZkBpgH8Af8BoAGrAfcB/wFYAWsB5AH/AS0BQQHGAf8DFgEfRAABZQEnASMB1QHcAWgBUQH/
+ AfUBjQF8Av8BkwGBAv8BmwGIAf8B/gGeAYoB/wHtAbEBpgH/AfwB9gH0Af8B7wG8AbIC/wGdAYoC/wGX
+ AYQB/wH7AY8BfQH/AewBigF5Af8BxAFHAS4B/xQAATsCMgFlAZIB5gH5Af8BmQHsAfsJ/wGsAe4B+QH/
+ AbIB7wH7Af8BRAGOAaIB/xQAATsBQQGPAf8BYAFwAdoB/wFrAXwB6wH/AYkBlQHmCf8B+gH7Af4B/wHk
+ AecB+gn/AdMB1wH1Af8BrAG1AfcB/wGxAbkB8QH/AWMBcQHPAf8DFgEfRAABHwIeAS0B1AFrAVYB/wHx
+ AZ4BjgH/AfwBogGRAv8BpwGXAv8BqwGbAv8BrQGdAf8B7wG2AasB/wH+Af0B/AH/AfEBpQGXAf8B/gGk
+ AZMB/wH2AZ8BjwH/AekBmwGMAf8BgAEsARoB9xgAAVABnQGyAf8BpwHtAfsJ/wG5Ae8B+QH/Ab4B8AH7
+ Af8BLQIpAUUUAAEyATUBegH/AWsBeQHWAf8BdgGDAecB/wF+AYoB6QH/A/4B/wL7Af4B/wGVAaIB+QH/
+ AZ0BqQH9Af8B6QHrAfoF/wG2Ab0B8AH/AbcBvwH1Af8BvAHDAfAB/wHBAcYB6gH/AwkBDEgAAYQBLQEZ
+ AfkB7AGuAaIB/wH1AbEBpAH/AfwBtAGmAv8BtgGpAv8BuAGrAf8B9wHdAdkF/wH1AdUBzwH/AfkBsgGl
+ Af8B8AGwAaMB/wHeAZgBigH/AxIBGBgAATsCMgFkAbQB7QH6Cf8BxQHwAfoB/wFJAY8BogH/GAADCAEL
+ AVkBYQGqAf8BgQGLAeEB/wGIAZYB7QH/AZABnAHtAf8BmQGkAfQB/wGhAa0B+wH/AagBswH7Af8BrwG5
+ AfoB/wG5AcAB8QH/AbwBwwH3Af8BwQHIAfMB/wHHAcwB7gH/AVMBMAEzAatPAAEBAb4BeQFrAf8B8AHB
+ AbcB/wH2AcIBuQH/AfoBxAG6Af8B/AHEAboB/wH7AcQBugH/AfIBxgG9Af8B9gHCAbkB/wHzAcIBuAH/
+ AewBvgG1Af8BSgI0AYogAAFdAZ8BsgH/AcYB8QH7Af8BywHyAfwB/wHQAfMB/AH/ASwCKQFEHAADCAEL
+ AWgBbwGwAf8BkwGeAeYB/wGcAacB7gH/AaUBrwHzAf8BrAG2AfYB/wGzAbwB9wH/AboBwgH3Af8BwAHH
+ AfUB/wHGAcwB8wH/AcsB0AHwAf8BUwEwATMBq1cAAQEBjAE+ATYB+QHyAdAByQH/AfQB0QHKAf8B9gHS
+ AcoB/wH2AdIBygH/AfUB0QHKAf8B8wHQAcoB/wHUAZ4BkwH/ATsCMgFjJAABOwIyAWQB0QHyAfsB/wHV
+ AfQB/AH/AU8BkAGjAf8kAAMIAQsBdgF7AbMB/wGnAa8B5wH/Aa8BtwHtAf8BtgG+AfAB/wG9AcQB8gH/
+ AcQBygHyAf8BygHPAfEB/wHPAdMB8AH/AVMBMAEzAatgAAEfAh4BLQFmAScBJAHVAakBbQFiAf8BtAF9
+ AXIB/wGMAUYBNQH7AUcCNAGBMAABSQE3AUAB3AFRAZEBpAH/ARYCFQEeKAADCAELAUoBSwGBAf8BbQFv
+ AZ8B/wFwAXMBogH/AXQBdgGkAf8BdwF4AaQB/wF1AXYBoAH/AVABMgEzAZ//AFEAAUIBTQE+BwABPgMA
+ ASgDAAFAAwABEAMAAQEBAAEBBQABgBcAA/8BAAH+AX8BwAEDAfgBHwIAAfABDwGAAQEB8AEPAgAB4AEH
+ AYABAAHgAQcCAAHAAQMBgAEBAcABAwIAAcABAQHAAQEBgAEBAgABgAEBAcABAwGAAwABgAEBAeABAwGA
+ AwABgAEAAeABBwGAAwABgAEAAfABBwGAAwABgAEBAfABDwGAAwABgAEBAfgBDwGAAwABwAEBAfgBHwGA
+ AQECAAHAAQMB/AEfAcABAwIAAeABBwH8AT8B4AEHAgAB+AEfAf4BPwHwAQ8CAAb/AgAL
+</value>
+ </data>
+ <data name="listView1.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name=">>listView1.Name" xml:space="preserve">
+ <value>listView1</value>
+ </data>
+ <data name=">>listView1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ListView, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>listView1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>listView1.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="saveFileDialog1.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>122, 17</value>
+ </metadata>
+ <data name="saveFileDialog1.Filter" xml:space="preserve">
+ <value>Text files (*.txt)|*.txt|All files (*.*)|*.*</value>
+ </data>
+ <data name="saveFileDialog1.Title" xml:space="preserve">
+ <value>Select the filename to write the report to</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ <value>True</value>
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>595, 274</value>
+ </data>
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Validation Results</value>
+ </data>
+ <data name=">>columnHeader1.Name" xml:space="preserve">
+ <value>columnHeader1</value>
+ </data>
+ <data name=">>columnHeader1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ColumnHeader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>columnHeader2.Name" xml:space="preserve">
+ <value>columnHeader2</value>
+ </data>
+ <data name=">>columnHeader2.Type" xml:space="preserve">
+ </data>
+ <data name=">>imageList1.Name" xml:space="preserve">
+ <value>imageList1</value>
+ </data>
+ <data name=">>imageList1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ImageList, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>saveFileDialog1.Name" xml:space="preserve">
+ <value>saveFileDialog1</value>
+ </data>
+ <data name=">>saveFileDialog1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.SaveFileDialog, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>ValidationResults</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj 2010-07-21 10:14:11 UTC (rev 5045)
@@ -3,7 +3,7 @@
<PropertyGroup>
<ProjectGuid>{5AD2CDBA-952E-4148-98A1-31D2E0D540D5}</ProjectGuid>
<OutputType>Library</OutputType>
Property changes on: sandbox/maestro-3.0/Maestro.ResourceValidation
___________________________________________________________________
Added: svn:ignore
+ obj
bin
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/ApplicationDefinitionValidator.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,92 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
+namespace Maestro.ResourceValidation
+ public class ApplicationDefinitionValidator : IResourceValidator
+ public ValidationIssue[] Validate(IResource resource, bool recurse)
+ if (resource.ResourceType != OSGeo.MapGuide.MaestroAPI.ResourceTypes.ApplicationDefinition)
+ return null;
+ List<ValidationIssue> issues = new List<ValidationIssue>();
+ ApplicationDefinitionType fusionApp = resource as ApplicationDefinitionType;
+ if (fusionApp.MapSet == null || fusionApp.MapSet.Count == 0)
+ issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, string.Format(Properties.Resources.ADF_MapMissingError)));
+ else
+ if (recurse)
+ foreach (MapGroupType mapGroup in fusionApp.MapSet)
+ foreach (OSGeo.MapGuide.ObjectModels.ApplicationDefinition.MapType map in mapGroup.Map)
+ try
+ if (map.Extension == null || map.Extension.GetElement("ResourceId") == null)
+ issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, string.Format(Properties.Resources.ADF_MapInvalidError, mapGroup.id)));
+ else
+ MapDefinition mdef = (MapDefinition)fusionApp.CurrentConnection.ResourceService.GetResource(map.Extension.GetElement("ResourceId").InnerText);
+ issues.AddRange(ResourceValidatorSet.Validate(mdef, true));
+ Envelope mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
+ if (mapGroup.InitialView != null)
+ if (!mapEnv.Contains(mapGroup.InitialView.CenterX, mapGroup.InitialView.CenterY))
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, string.Format(Properties.Resources.ADF_ViewOutsideMapExtents)));
+ issues.Add(new ValidationIssue(fusionApp, ValidationStatus.Error, string.Format(Properties.Resources.ADF_MapValidationError, mapGroup.id, msg)));
+ public ResourceTypeDescriptor SupportedResourceAndVersion
+ get { return new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.ApplicationDefinition, "1.0.0"); }
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,109 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+ public class FeatureSourceValidator : IResourceValidator
+ if (resource.ResourceType != ResourceTypes.FeatureSource)
+ return null;
+ FeatureSourceType feature = (FeatureSourceType)resource;
+ //Note: Must be saved!
+ string s = feature.CurrentConnection.FeatureService.TestConnection(feature.ResourceID);
+ if (s.Trim().ToUpper() != true.ToString().ToUpper())
+ return new ValidationIssue[] { new ValidationIssue(feature, ValidationStatus.Error, Properties.Resources.FS_ConnectionTestFailed) };
+ try
+ System.Globalization.CultureInfo ci = System.Globalization.CultureInfo.InvariantCulture;
+ FdoSpatialContextList lst = feature.GetSpatialInfo();
+ if (lst == null || lst.SpatialContext == null || lst.SpatialContext.Count == 0)
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Properties.Resources.FS_NoSpatialContextWarning));
+ else
+ foreach (FdoSpatialContextListSpatialContext c in lst.SpatialContext)
+ if (c.Extent == null || c.Extent.LowerLeftCoordinate == null || c.Extent.UpperRightCoordinate == null)
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Properties.Resources.FS_EmptySpatialContextWarning));
+ else if (double.Parse(c.Extent.LowerLeftCoordinate.X, ci) <= -1000000 && double.Parse(c.Extent.LowerLeftCoordinate.Y, ci) <= -1000000 && double.Parse(c.Extent.UpperRightCoordinate.X, ci) >= 1000000 && double.Parse(c.Extent.UpperRightCoordinate.Y, ci) >= 1000000)
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Properties.Resources.FS_DefaultSpatialContextWarning));
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Error, string.Format(Properties.Resources.FS_SpatialContextReadError, msg)));
+ List<string> classes = new List<string>();
+ try
+ FeatureSourceDescription fsd = feature.Describe();
+ if (fsd == null || fsd.Schemas == null || fsd.Schemas.Length == 0)
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Properties.Resources.FS_SchemasMissingWarning));
+ else
+ foreach (FeatureSourceDescription.FeatureSourceSchema scm in fsd.Schemas)
+ classes.Add(scm.FullnameDecoded);
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Error, string.Format(Properties.Resources.FS_SchemaReadError, msg)));
+ foreach (string cl in classes)
+ try
+ string[] ids = feature.GetIdentityProperties(cl);
+ //According to my tests, this code path never gets reached because the
+ //MG server will incorrectly throw MgClassNotFoundException when querying
+ //a class with no identity properties. Nevertheless we'll leave this in, if/when
+ //this logic is fixed server-side.
+ if (ids == null || ids.Length == 0)
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Information, string.Format(Properties.Resources.FS_PrimaryKeyMissingInformation, cl)));
+ issues.Add(new ValidationIssue(feature, ValidationStatus.Error, string.Format(Properties.Resources.FS_PrimaryKeyReadError, msg)));
+ get { return new ResourceTypeDescriptor(ResourceTypes.FeatureSource, "1.0.0"); }
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/LayerDefinitionValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/LayerDefinitionValidator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/LayerDefinitionValidator.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,175 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+ public class LayerDefinitionValidator : IResourceValidator
+ if (resource.ResourceType != OSGeo.MapGuide.MaestroAPI.ResourceTypes.LayerDefinition)
+ return null;
+ if (resource.ResourceVersion != new Version(1, 0, 0))
+ return null;
+ LayerDefinition ldef = resource as LayerDefinition;
+ VectorLayerDefinitionType vldef = ldef.Item as VectorLayerDefinitionType;
+ GridLayerDefinitionType gldef = ldef.Item as GridLayerDefinitionType;
+ DrawingLayerDefinitionType dldef = ldef.Item as DrawingLayerDefinitionType;
+ if (ldef.Item == null)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, Properties.Resources.LDF_LayerNullError));
+ else if (vldef == null && gldef == null)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LDF_DrawingLayerDefinitionNotSupportedWarning));
+ if (vldef != null)
+ if (string.IsNullOrEmpty(vldef.FeatureName))
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, Properties.Resources.LDF_MissingFeatureSourceError));
+ if (string.IsNullOrEmpty(vldef.Geometry))
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, Properties.Resources.LDF_MissingGeometryError));
+ if (vldef.VectorScaleRange == null || vldef.VectorScaleRange.Count == 0)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, Properties.Resources.LDF_MissingScaleRangesError));
+ else
+ //Test for overlapping scale ranges
+ List<KeyValuePair<double, double>> ranges = new List<KeyValuePair<double, double>>();
+ foreach (VectorScaleRangeType vsr in vldef.VectorScaleRange)
+ ranges.Add(new KeyValuePair<double, double>(
+ vsr.MaxScaleSpecified ? vsr.MaxScale : double.PositiveInfinity,
+ vsr.MinScaleSpecified ? vsr.MinScale : double.NegativeInfinity));
+ double min = double.PositiveInfinity;
+ double max = double.NegativeInfinity;
+ foreach (KeyValuePair<double, double> sr in ranges)
+ min = Math.Min(min, sr.Value);
+ max = Math.Max(max, sr.Key);
+ if (sr.Key < sr.Value)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, string.Format(Properties.Resources.LDF_MinAndMaxScaleSwappedError, sr.Value, sr.Key)));
+ //TODO: Detect gaps in scale ranges
+ for (int i = 0; i < ranges.Count; i++)
+ for (int j = i + 1; j < ranges.Count; j++)
+ if (ranges[i].Key > ranges[j].Value || ranges[i].Value > ranges[j].Value)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Information, string.Format(Properties.Resources.LDF_ScaleRangesOverlapInformation, ranges[i].Value, ranges[i].Key, ranges[j].Value, ranges[j].Key)));
+ else if (gldef != null)
+ if (gldef.GridScaleRange == null || gldef.GridScaleRange.Count == 0)
+ else if (gldef.GridScaleRange.Count != 1)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LDF_MultipleScaleRangesWarning));
+ else if (dldef != null)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LDF_DrawingLayerNotSupportedWarning));
+ else
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Warning, Properties.Resources.LDF_UnsupportedLayerTypeWarning));
+ if (recurse)
+ try
+ FeatureSourceType fs = (FeatureSourceType)ldef.CurrentConnection.ResourceService.GetResource(ldef.Item.ResourceId);
+ issues.AddRange(ResourceValidatorSet.Validate(fs, recurse));
+ try
+ if (vldef != null || gldef != null)
+ string schema = vldef == null ? gldef.FeatureName : vldef.FeatureName;
+ string geometry = vldef == null ? gldef.Geometry : vldef.Geometry;
+ bool foundSchema = false;
+ bool foundGeometry = false;
+ FeatureSourceDescription desc = fs.Describe();
+ foreach (FeatureSourceDescription.FeatureSourceSchema scm in desc.Schemas)
+ if (scm.FullnameDecoded == schema)
+ foundSchema = true;
+ foreach (FeatureSetColumn col in scm.Columns)
+ if (col.Name == geometry)
+ foundGeometry = true;
+ break;
+ if (vldef != null && vldef.PropertyMapping != null)
+ foreach (NameStringPairType s in vldef.PropertyMapping)
+ bool found = false;
+ if (col.Name == s.Name)
+ found = true;
+ break;
+ if (!found)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, string.Format(Properties.Resources.LDF_SchemaMissingError, schema, fs.ResourceID)));
+ break;
+ if (!foundSchema)
+ else if (!foundGeometry)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, string.Format(Properties.Resources.LDF_GeometryMissingError, geometry, schema, fs.ResourceID)));
+ catch (Exception)
+ issues.Add(new ValidationIssue(fs, ValidationStatus.Error, string.Format(Properties.Resources.LDF_SchemaAndColumnReadFailedError)));
+ catch (Exception)
+ issues.Add(new ValidationIssue(resource, ValidationStatus.Error, string.Format(Properties.Resources.LDF_FeatureSourceLoadError)));
+ get { return new ResourceTypeDescriptor(ResourceTypes.LayerDefinition, "1.0.0"); }
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Maestro.ResourceValidation.csproj 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,72 @@
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+ <PropertyGroup>
+ <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+ <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+ <SchemaVersion>2.0</SchemaVersion>
+ <ProjectGuid>{3B29C138-666C-46D0-A55D-824E5192C091}</ProjectGuid>
+ <OutputType>Library</OutputType>
+ <AppDesignerFolder>Properties</AppDesignerFolder>
+ <RootNamespace>Maestro.ResourceValidation</RootNamespace>
+ <AssemblyName>Maestro.ResourceValidation</AssemblyName>
+ <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+ <FileAlignment>512</FileAlignment>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+ <DebugSymbols>true</DebugSymbols>
+ <DebugType>full</DebugType>
+ <Optimize>false</Optimize>
+ <OutputPath>bin\Debug\</OutputPath>
+ <DefineConstants>DEBUG;TRACE</DefineConstants>
+ <ErrorReport>prompt</ErrorReport>
+ <WarningLevel>4</WarningLevel>
+ </PropertyGroup>
+ <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+ <DebugType>pdbonly</DebugType>
+ <Optimize>true</Optimize>
+ <OutputPath>bin\Release\</OutputPath>
+ <DefineConstants>TRACE</DefineConstants>
+ </PropertyGroup>
+ <ItemGroup>
+ <Reference Include="System" />
+ <Reference Include="System.Data" />
+ <Reference Include="System.Xml" />
+ </ItemGroup>
+ <ItemGroup>
+ <Compile Include="ApplicationDefinitionValidator.cs" />
+ <Compile Include="FeatureSourceValidator.cs" />
+ <Compile Include="LayerDefinitionValidator.cs" />
+ <Compile Include="MapDefinitionValidator.cs" />
+ <Compile Include="Properties\AssemblyInfo.cs" />
+ <Compile Include="Properties\Resources.Designer.cs">
+ <AutoGen>True</AutoGen>
+ <DesignTime>True</DesignTime>
+ <DependentUpon>Resources.resx</DependentUpon>
+ </Compile>
+ <Compile Include="ResourceValidatorLoader.cs" />
+ <Compile Include="WebLayoutValidator.cs" />
+ </ItemGroup>
+ <ItemGroup>
+ <ProjectReference Include="..\OSGeo.MapGuide.MaestroAPI\OSGeo.MapGuide.MaestroAPI.csproj">
+ <Project>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</Project>
+ <Name>OSGeo.MapGuide.MaestroAPI</Name>
+ </ItemGroup>
+ <ItemGroup>
+ <EmbeddedResource Include="Properties\Resources.resx">
+ <Generator>ResXFileCodeGenerator</Generator>
+ <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+ </ItemGroup>
+ <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+ <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+ Other similar extension points exist, see Microsoft.Common.targets.
+ <Target Name="BeforeBuild">
+ </Target>
+ <Target Name="AfterBuild">
+ </Target>
+</Project>
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,164 @@
+#endregion
+using System;
+using System.Text;
+ public class MapDefinitionValidator : IResourceValidator
+ if (resource.ResourceType != ResourceTypes.MapDefinition)
+ return null;
+ MapDefinition mdef = resource as MapDefinition;
+ foreach (MapLayerGroupType g in mdef.MapLayerGroup)
+ if (g.ShowInLegend && (g.LegendLabel == null || g.LegendLabel.Trim().Length == 0))
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Information, string.Format(Properties.Resources.MDF_GroupMissingLabelInformation, g.Name)));
+ else if (g.ShowInLegend && g.LegendLabel.Trim().ToLower() == "layer group")
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Information, string.Format(Properties.Resources.MDF_GroupHasDefaultLabelInformation, g.Name)));
+ List<BaseMapLayerType> layers = new List<BaseMapLayerType>();
+ foreach (BaseMapLayerType l in mdef.MapLayer)
+ layers.Add(l);
+ if (mdef.BaseMapDefinition != null && mdef.BaseMapDefinition.BaseMapLayerGroup != null)
+ foreach (BaseMapLayerGroupCommonType g in mdef.BaseMapDefinition.BaseMapLayerGroup)
+ foreach (BaseMapLayerType l in g.BaseMapLayer)
+ layers.Add(l);
+ Dictionary<string, BaseMapLayerType> nameCounter = new Dictionary<string, BaseMapLayerType>();
+ foreach (BaseMapLayerType l in layers)
+ if (nameCounter.ContainsKey(l.Name))
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, string.Format(Properties.Resources.MDF_LayerNameDuplicateWarning, l.Name, l.ResourceId, nameCounter[l.Name].ResourceId)));
+ else
+ nameCounter.Add(l.Name, l);
+ if (l.ShowInLegend && (string.IsNullOrEmpty(l.LegendLabel) || l.LegendLabel.Trim().Length == 0))
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Information, string.Format(Properties.Resources.MDF_LayerMissingLabelInformation, l.Name)));
+ if (recurse)
+ var mapEnv = ObjectFactory.CreateEnvelope(mdef.Extents.MinX, mdef.Extents.MaxX, mdef.Extents.MinY, mdef.Extents.MaxY);
+ try
+ ILayerDefinition layer = null;
+ IResource res = mdef.CurrentConnection.ResourceService.GetResource(l.ResourceId);
+ if (!ResourceValidatorSet.HasValidator(res.ResourceType, res.ResourceVersion))
+ //Need to trap the no registered validator message
+ issues.AddRange(ResourceValidatorSet.Validate(res, true));
+ continue;
+ layer = (ILayerDefinition)res;
+ issues.AddRange(ResourceValidatorSet.Validate(layer, true));
+ IVectorLayerDefinition vl = null;
+ if (layer.SubLayer.LayerType == LayerType.Vector)
+ vl = (IVectorLayerDefinition)layer.SubLayer;
+ if (vl != null)
+ try
+ FeatureSourceType fs = (FeatureSourceType)layer.CurrentConnection.ResourceService.GetResource(vl.FeatureSourceID);
+ //The layer recurses on the FeatureSource
+ //issues.AddRange(Validation.Validate(fs, true));
+ try
+ FdoSpatialContextList context = fs.GetSpatialInfo();
+ if (context.SpatialContext == null || context.SpatialContext.Count == 0)
+ issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, string.Format(Properties.Resources.MDF_MissingSpatialContextWarning, fs.ResourceID)));
+ else
+ if (context.SpatialContext.Count > 1)
+ issues.Add(new ValidationIssue(fs, ValidationStatus.Information, string.Format(Properties.Resources.MDF_MultipleSpatialContextsInformation, fs.ResourceID)));
+ bool skipGeomCheck = false;
+ //TODO: Switch to the correct version (2.1), once released
+ if (context.SpatialContext[0].CoordinateSystemWkt != mdef.CoordinateSystem)
+ if (layer.SubLayer.LayerType == LayerType.Raster && mdef.CurrentConnection.SiteVersion <= SiteVersions.GetVersion(OSGeo.MapGuide.MaestroAPI.KnownSiteVersions.MapGuideOS2_0_2))
+ issues.Add(new ValidationIssue(fs, ValidationStatus.Error, string.Format(Properties.Resources.MDF_RasterReprojectionError, fs.ResourceID)));
+ else
+ issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, string.Format(Properties.Resources.MDF_DataReprojectionWarning, fs.ResourceID)));
+ skipGeomCheck = true;
+ if (vl.GeometryProperty != null && !skipGeomCheck)
+ var env = fs.GetSpatialExtent(vl.FullQualifiedClassName, vl.GeometryProperty);
+ if (!env.Intersects(mapEnv))
+ issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, string.Format(Properties.Resources.MDF_DataOutsideMapWarning, fs.ResourceID)));
+ issues.Add(new ValidationIssue(layer, ValidationStatus.Error, string.Format(Properties.Resources.MDF_ResourceReadError, fs.ResourceID, msg)));
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, string.Format(Properties.Resources.MDF_FeatureSourceReadError, l.ResourceId, msg)));
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Error, string.Format(Properties.Resources.MDF_LayerReadError, l.ResourceId, msg)));
+ get { return new ResourceTypeDescriptor(ResourceTypes.MapDefinition, "1.0.0"); }
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/AssemblyInfo.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/AssemblyInfo.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/AssemblyInfo.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("Maestro.ResourceValidation")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("Microsoft")]
+[assembly: AssemblyProduct("Maestro.ResourceValidation")]
+[assembly: AssemblyCopyright("Copyright © Microsoft 2010")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components. If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("ffa594f1-d7e3-403c-9eb4-3565007f4209")]
+// Version information for an assembly consists of the following four values:
+// Major Version
+// Minor Version
+// Build Number
+// Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.Designer.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,477 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:2.0.50727.4927
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace Maestro.ResourceValidation.Properties {
+ using System;
+ /// <summary>
+ /// A strongly-typed resource class, for looking up localized strings, etc.
+ /// </summary>
+ // This class was auto-generated by the StronglyTypedResourceBuilder
+ // class via a tool like ResGen or Visual Studio.
+ // To add or remove a member, edit your .ResX file then rerun ResGen
+ // with the /str option, or rebuild your VS project.
+ [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+ [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+ [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+ internal class Resources {
+ private static global::System.Resources.ResourceManager resourceMan;
+ private static global::System.Globalization.CultureInfo resourceCulture;
+ [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+ internal Resources() {
+ /// <summary>
+ /// Returns the cached ResourceManager instance used by this class.
+ /// </summary>
+ [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
+ global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("Maestro.ResourceValidation.Properties.Resources", typeof(Resources).Assembly);
+ resourceMan = temp;
+ return resourceMan;
+ /// <summary>
+ /// Overrides the current thread's CurrentUICulture property for all
+ /// resource lookups using this strongly typed resource class.
+ /// </summary>
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
+ return resourceCulture;
+ set {
+ resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to Map with ID {0} does not point to a valid map.
+ /// </summary>
+ internal static string ADF_MapInvalidError {
+ get {
+ return ResourceManager.GetString("ADF_MapInvalidError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Fusion application does not specify a map.
+ /// </summary>
+ internal static string ADF_MapMissingError {
+ get {
+ return ResourceManager.GetString("ADF_MapMissingError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Error validating MapDefinition {0}, message: {1}.
+ /// </summary>
+ internal static string ADF_MapValidationError {
+ get {
+ return ResourceManager.GetString("ADF_MapValidationError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Fusion application specifies a start view that is outside the map's initial extents.
+ /// </summary>
+ internal static string ADF_ViewOutsideMapExtents {
+ get {
+ return ResourceManager.GetString("ADF_ViewOutsideMapExtents", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Connection test failed.
+ /// </summary>
+ internal static string FS_ConnectionTestFailed {
+ get {
+ return ResourceManager.GetString("FS_ConnectionTestFailed", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Spatial context extent appears to be invalid (or default).
+ /// </summary>
+ internal static string FS_DefaultSpatialContextWarning {
+ get {
+ return ResourceManager.GetString("FS_DefaultSpatialContextWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Empty spatial context extent detected.
+ /// </summary>
+ internal static string FS_EmptySpatialContextWarning {
+ get {
+ return ResourceManager.GetString("FS_EmptySpatialContextWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Could not obtain identity properties for {0}. This class either has no identity properties and/or is derived from a view with no uniquely identifiable columns. Attempting to create feature joins from this class may produce unexpected results..
+ /// </summary>
+ internal static string FS_NoPrimaryKeyOrView {
+ get {
+ return ResourceManager.GetString("FS_NoPrimaryKeyOrView", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No spatial contexts found. If this feature source is strictly used for Feature Joins, this warning can be safely ignored.
+ /// </summary>
+ internal static string FS_NoSpatialContextWarning {
+ get {
+ return ResourceManager.GetString("FS_NoSpatialContextWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No primary key defined for class: {0}, features will not be selectable and feature joins on this class may produce unexpected results.
+ /// </summary>
+ internal static string FS_PrimaryKeyMissingInformation {
+ get {
+ return ResourceManager.GetString("FS_PrimaryKeyMissingInformation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to read identity properties: {0}.
+ /// </summary>
+ internal static string FS_PrimaryKeyReadError {
+ get {
+ return ResourceManager.GetString("FS_PrimaryKeyReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to read schema description: {0}.
+ /// </summary>
+ internal static string FS_SchemaReadError {
+ get {
+ return ResourceManager.GetString("FS_SchemaReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No schemas found in datasource.
+ /// </summary>
+ internal static string FS_SchemasMissingWarning {
+ get {
+ return ResourceManager.GetString("FS_SchemasMissingWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to read spatial context: {0}.
+ /// </summary>
+ internal static string FS_SpatialContextReadError {
+ get {
+ return ResourceManager.GetString("FS_SpatialContextReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Only vector layers and raster layers are currently validated.
+ /// </summary>
+ internal static string LDF_DrawingLayerDefinitionNotSupportedWarning {
+ get {
+ return ResourceManager.GetString("LDF_DrawingLayerDefinitionNotSupportedWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Maestro does not support DrawingLayers.
+ /// </summary>
+ internal static string LDF_DrawingLayerNotSupportedWarning {
+ get {
+ return ResourceManager.GetString("LDF_DrawingLayerNotSupportedWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to load featuresource.
+ /// </summary>
+ internal static string LDF_FeatureSourceLoadError {
+ get {
+ return ResourceManager.GetString("LDF_FeatureSourceLoadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to find geometry column {0} in schema {1} on featuresource {2}.
+ /// </summary>
+ internal static string LDF_GeometryMissingError {
+ get {
+ return ResourceManager.GetString("LDF_GeometryMissingError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer is missing core information.
+ /// </summary>
+ internal static string LDF_LayerNullError {
+ get {
+ return ResourceManager.GetString("LDF_LayerNullError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The minimum scale ({0}) is larger than the maximum scale ({1}).
+ /// </summary>
+ internal static string LDF_MinAndMaxScaleSwappedError {
+ get {
+ return ResourceManager.GetString("LDF_MinAndMaxScaleSwappedError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No FeatureSource is assigned to the layer.
+ /// </summary>
+ internal static string LDF_MissingFeatureSourceError {
+ get {
+ return ResourceManager.GetString("LDF_MissingFeatureSourceError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No Geometry is assigned to the layer.
+ /// </summary>
+ internal static string LDF_MissingGeometryError {
+ get {
+ return ResourceManager.GetString("LDF_MissingGeometryError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to No scale ranges are defined, no data can be displayed.
+ /// </summary>
+ internal static string LDF_MissingScaleRangesError {
+ get {
+ return ResourceManager.GetString("LDF_MissingScaleRangesError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to More than one scale ranges is defined, this is valid, but unsupported by Maestro.
+ /// </summary>
+ internal static string LDF_MultipleScaleRangesWarning {
+ get {
+ return ResourceManager.GetString("LDF_MultipleScaleRangesWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The scale range {0}-{1} overlaps the range {2}-{3}.
+ /// </summary>
+ internal static string LDF_ScaleRangesOverlapInformation {
+ get {
+ return ResourceManager.GetString("LDF_ScaleRangesOverlapInformation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to validate column and schema.
+ /// </summary>
+ internal static string LDF_SchemaAndColumnReadFailedError {
+ get {
+ return ResourceManager.GetString("LDF_SchemaAndColumnReadFailedError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Failed to find schema {0} in featuresource {1}.
+ /// </summary>
+ internal static string LDF_SchemaMissingError {
+ get {
+ return ResourceManager.GetString("LDF_SchemaMissingError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The layer has no type, or the type is unsupported by Maestro.
+ /// </summary>
+ internal static string LDF_UnsupportedLayerTypeWarning {
+ get {
+ return ResourceManager.GetString("LDF_UnsupportedLayerTypeWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Data from {0} is not visible in the map's start extent.
+ /// </summary>
+ internal static string MDF_DataOutsideMapWarning {
+ get {
+ return ResourceManager.GetString("MDF_DataOutsideMapWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} has a different coordinate system than the map, this will impact performance as the coordinates are transformed while rendering the map. Maestro cannot validate the extent of the data..
+ /// </summary>
+ internal static string MDF_DataReprojectionWarning {
+ get {
+ return ResourceManager.GetString("MDF_DataReprojectionWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer {0}'s FeatureSource could not be read: {1}.
+ /// </summary>
+ internal static string MDF_FeatureSourceReadError {
+ get {
+ return ResourceManager.GetString("MDF_FeatureSourceReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Group {0} has the default legend label.
+ /// </summary>
+ internal static string MDF_GroupHasDefaultLabelInformation {
+ get {
+ return ResourceManager.GetString("MDF_GroupHasDefaultLabelInformation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Group {0} does not have a legend label.
+ /// </summary>
+ internal static string MDF_GroupMissingLabelInformation {
+ get {
+ return ResourceManager.GetString("MDF_GroupMissingLabelInformation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer {0} does not have a legend label.
+ /// </summary>
+ internal static string MDF_LayerMissingLabelInformation {
+ get {
+ return ResourceManager.GetString("MDF_LayerMissingLabelInformation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to The layer name {0} is used for both "{1}" and "{2}".
+ /// </summary>
+ internal static string MDF_LayerNameDuplicateWarning {
+ get {
+ return ResourceManager.GetString("MDF_LayerNameDuplicateWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer {0} could not be read: {1}.
+ /// </summary>
+ internal static string MDF_LayerReadError {
+ get {
+ return ResourceManager.GetString("MDF_LayerReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer {0} has no geometry column.
+ /// </summary>
+ internal static string MDF_MissingLayerGeometryColumnError {
+ get {
+ return ResourceManager.GetString("MDF_MissingLayerGeometryColumnError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer {0} has an invalid Schema.
+ /// </summary>
+ internal static string MDF_MissingLayerSchemaError {
+ get {
+ return ResourceManager.GetString("MDF_MissingLayerSchemaError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} has no spatial context (eg. no coordinate system).
+ /// </summary>
+ internal static string MDF_MissingSpatialContextWarning {
+ get {
+ return ResourceManager.GetString("MDF_MissingSpatialContextWarning", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} has more than one spatial context, the following test results may be inacurate.
+ /// </summary>
+ internal static string MDF_MultipleSpatialContextsInformation {
+ get {
+ return ResourceManager.GetString("MDF_MultipleSpatialContextsInformation", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} is a raster layer, and in another coordinate system than the map. No data will be displayed by the layer.
+ /// </summary>
+ internal static string MDF_RasterReprojectionError {
+ get {
+ return ResourceManager.GetString("MDF_RasterReprojectionError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to {0} could not be processed for spatial info: {1}.
+ /// </summary>
+ internal static string MDF_ResourceReadError {
+ get {
+ return ResourceManager.GetString("MDF_ResourceReadError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layer {0} is a type that is unsupported by Maestro.
+ /// </summary>
+ internal static string MDF_UnsupportedLayerTypeWarning {
+ get {
+ return ResourceManager.GetString("MDF_UnsupportedLayerTypeWarning", resourceCulture);
+ /// <summary>
+ /// </summary>
+ internal static string WL_MapValidationError {
+ get {
+ return ResourceManager.GetString("WL_MapValidationError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layout does not specify a map.
+ /// </summary>
+ internal static string WL_MissingMapError {
+ get {
+ return ResourceManager.GetString("WL_MissingMapError", resourceCulture);
+ /// <summary>
+ /// Looks up a localized string similar to Layout specifies a start view that is outside the map's initial extents.
+ /// </summary>
+ internal static string WL_StartViewOutsideExtentsWarning {
+ get {
+ return ResourceManager.GetString("WL_StartViewOutsideExtentsWarning", resourceCulture);
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/Properties/Resources.resx 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,304 @@
+<root>
+ Version 2.0
+ Example:
+ </data>
+ </data>
+ name/value pairs.
+ mimetype set.
+ <xsd:complexType>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ </resheader>
+ </resheader>
+ </resheader>
+ </resheader>
+ <data name="ADF_MapInvalidError" xml:space="preserve">
+ <value>Map with ID {0} does not point to a valid map</value>
+ <comment>An error message that is displayed if there is a MapID that does not reference a valid map</comment>
+ </data>
+ <data name="ADF_MapMissingError" xml:space="preserve">
+ <value>Fusion application does not specify a map</value>
+ <comment>An error message that is displayed if the map is missing</comment>
+ </data>
+ <data name="ADF_MapValidationError" xml:space="preserve">
+ <value>Error validating MapDefinition {0}, message: {1}</value>
+ <comment>An error message that is displayed if an error occurs while validating a map</comment>
+ </data>
+ <data name="ADF_ViewOutsideMapExtents" xml:space="preserve">
+ <value>Fusion application specifies a start view that is outside the map's initial extents</value>
+ <comment>An error message that is displayed if the start view is outside the defined map</comment>
+ </data>
+ <data name="FS_ConnectionTestFailed" xml:space="preserve">
+ <value>Connection test failed</value>
+ <comment>An error message that is displayed if a connection test on the feature source failed</comment>
+ </data>
+ <data name="FS_DefaultSpatialContextWarning" xml:space="preserve">
+ <value>Spatial context extent appears to be invalid (or default)</value>
+ <comment>A warning message that is displayed if the spatial context has the default extent</comment>
+ </data>
+ <data name="FS_EmptySpatialContextWarning" xml:space="preserve">
+ <value>Empty spatial context extent detected</value>
+ <comment>A warning message that is displayed when the spatial context is empty</comment>
+ </data>
+ <data name="FS_NoPrimaryKeyOrView" xml:space="preserve">
+ <value>Could not obtain identity properties for {0}. This class either has no identity properties and/or is derived from a view with no uniquely identifiable columns. Attempting to create feature joins from this class may produce unexpected results.</value>
+ <comment>A warning message that is displayed when we can't obtain identity properties from a class because it is a view</comment>
+ </data>
+ <data name="FS_NoSpatialContextWarning" xml:space="preserve">
+ <value>No spatial contexts found. If this feature source is strictly used for Feature Joins, this warning can be safely ignored</value>
+ <comment>A warning message that is displayed when the featuresource fails to report its spatial context</comment>
+ </data>
+ <data name="FS_PrimaryKeyMissingInformation" xml:space="preserve">
+ <value>No primary key defined for class: {0}, features will not be selectable and feature joins on this class may produce unexpected results</value>
+ <comment>An information message that is displayed if the schema has no primary key defined</comment>
+ </data>
+ <data name="FS_PrimaryKeyReadError" xml:space="preserve">
+ <value>Failed to read identity properties: {0}</value>
+ <comment>An error message that is displayed if the primary key information could not be read</comment>
+ </data>
+ <data name="FS_SchemaReadError" xml:space="preserve">
+ <value>Failed to read schema description: {0}</value>
+ <comment>An error message that is displayed if the schema information could not be read</comment>
+ </data>
+ <data name="FS_SchemasMissingWarning" xml:space="preserve">
+ <value>No schemas found in datasource</value>
+ <comment>A warning message that is displayed if the featuresource has no schemas</comment>
+ </data>
+ <data name="FS_SpatialContextReadError" xml:space="preserve">
+ <value>Failed to read spatial context: {0}</value>
+ <comment>An error message that is displayed if the spatial context could not be read</comment>
+ </data>
+ <data name="LDF_DrawingLayerDefinitionNotSupportedWarning" xml:space="preserve">
+ <value>Only vector layers and raster layers are currently validated</value>
+ <comment>A warning message that is displayed if the layer is not Grid or Vector</comment>
+ </data>
+ <data name="LDF_DrawingLayerNotSupportedWarning" xml:space="preserve">
+ <value>Maestro does not support DrawingLayers</value>
+ <comment>A warning message that is displayed if the layer is a DrawingLayer type</comment>
+ </data>
+ <data name="LDF_FeatureSourceLoadError" xml:space="preserve">
+ <value>Failed to load featuresource</value>
+ <comment>An error message that is displayed if the featuresource fails to load</comment>
+ </data>
+ <data name="LDF_GeometryMissingError" xml:space="preserve">
+ <value>Failed to find geometry column {0} in schema {1} on featuresource {2}</value>
+ <comment>An error message that is displayed if the geometry is not present in the selected schema</comment>
+ </data>
+ <data name="LDF_LayerNullError" xml:space="preserve">
+ <value>Layer is missing core information</value>
+ <comment>An error message that is displayed if the layer has a null reference</comment>
+ </data>
+ <data name="LDF_MinAndMaxScaleSwappedError" xml:space="preserve">
+ <value>The minimum scale ({0}) is larger than the maximum scale ({1})</value>
+ <comment>An error message that is displayed if the scale ranges are reversed</comment>
+ </data>
+ <data name="LDF_MissingFeatureSourceError" xml:space="preserve">
+ <value>No FeatureSource is assigned to the layer</value>
+ <comment>An error message that is displayed if the layer has no FeatureSource</comment>
+ </data>
+ <data name="LDF_MissingGeometryError" xml:space="preserve">
+ <value>No Geometry is assigned to the layer</value>
+ <comment>An error message that is displayed if the layer has no geometry column selected</comment>
+ </data>
+ <data name="LDF_MissingScaleRangesError" xml:space="preserve">
+ <value>No scale ranges are defined, no data can be displayed</value>
+ <comment>An error message that is displayed if there are no scale ranges defined</comment>
+ </data>
+ <data name="LDF_MultipleScaleRangesWarning" xml:space="preserve">
+ <value>More than one scale ranges is defined, this is valid, but unsupported by Maestro</value>
+ <comment>A warning message that is displayed if a raster layer has multiple scale ranges defined</comment>
+ </data>
+ <data name="LDF_ScaleRangesOverlapInformation" xml:space="preserve">
+ <value>The scale range {0}-{1} overlaps the range {2}-{3}</value>
+ <comment>A warning message that is displayed if two scaleranges overlap</comment>
+ </data>
+ <data name="LDF_SchemaAndColumnReadFailedError" xml:space="preserve">
+ <value>Failed to validate column and schema</value>
+ <comment>An error message that is displayed if the schema and column read fails</comment>
+ </data>
+ <data name="LDF_SchemaMissingError" xml:space="preserve">
+ <value>Failed to find schema {0} in featuresource {1}</value>
+ <comment>An error message that is displayed if the selected schema is not present in the FeatureSource</comment>
+ </data>
+ <data name="LDF_UnsupportedLayerTypeWarning" xml:space="preserve">
+ <value>The layer has no type, or the type is unsupported by Maestro</value>
+ <comment>A warning message that is displayed if the layer type is unknown</comment>
+ </data>
+ <data name="MDF_DataOutsideMapWarning" xml:space="preserve">
+ <value>Data from {0} is not visible in the map's start extent</value>
+ <comment>A warning message that is displayed if a layer reports an extent that is outside the map's extent</comment>
+ </data>
+ <data name="MDF_DataReprojectionWarning" xml:space="preserve">
+ <value>{0} has a different coordinate system than the map, this will impact performance as the coordinates are transformed while rendering the map. Maestro cannot validate the extent of the data.</value>
+ <comment>A warning message that is displayed if a layer reports a coordinate system that differs from the map's.</comment>
+ </data>
+ <data name="MDF_FeatureSourceReadError" xml:space="preserve">
+ <value>Layer {0}'s FeatureSource could not be read: {1}</value>
+ <comment>An error message that is displayed if a FeatureSource fails to load</comment>
+ </data>
+ <data name="MDF_GroupHasDefaultLabelInformation" xml:space="preserve">
+ <value>Group {0} has the default legend label</value>
+ <comment>An information message that is displayed if a group is assigned the default group label</comment>
+ </data>
+ <data name="MDF_GroupMissingLabelInformation" xml:space="preserve">
+ <value>Group {0} does not have a legend label</value>
+ <comment>An information message that is displayed if a group has a blank legend label</comment>
+ </data>
+ <data name="MDF_LayerMissingLabelInformation" xml:space="preserve">
+ <value>Layer {0} does not have a legend label</value>
+ <comment>An information message that is displayed if a layer has a blank legend label</comment>
+ </data>
+ <data name="MDF_LayerNameDuplicateWarning" xml:space="preserve">
+ <value>The layer name {0} is used for both "{1}" and "{2}"</value>
+ <comment>A warning message that is displayed if two layers share the same layer name</comment>
+ </data>
+ <data name="MDF_LayerReadError" xml:space="preserve">
+ <value>Layer {0} could not be read: {1}</value>
+ <comment>An error message that is displayed if a LayerDefinition fails to load</comment>
+ </data>
+ <data name="MDF_MissingLayerGeometryColumnError" xml:space="preserve">
+ <value>Layer {0} has no geometry column</value>
+ <comment>An error message that is displayed if a layer has no geometry column specified</comment>
+ </data>
+ <data name="MDF_MissingLayerSchemaError" xml:space="preserve">
+ <value>Layer {0} has an invalid Schema</value>
+ <comment>An error message that is displayed if the layer has no schema specified</comment>
+ </data>
+ <data name="MDF_MissingSpatialContextWarning" xml:space="preserve">
+ <value>{0} has no spatial context (eg. no coordinate system)</value>
+ <comment>A warning message that is displayed if the FeatureSource reports no spatial context</comment>
+ </data>
+ <data name="MDF_MultipleSpatialContextsInformation" xml:space="preserve">
+ <value>{0} has more than one spatial context, the following test results may be inacurate</value>
+ <comment>An information message that is displayed if a FeatureSource reports multiple spatial contexts</comment>
+ </data>
+ <data name="MDF_RasterReprojectionError" xml:space="preserve">
+ <value>{0} is a raster layer, and in another coordinate system than the map. No data will be displayed by the layer</value>
+ <comment>An error message that is displayed if a raster layer reports a different projection than the map, and the MapGuide server version does not support raster reprojection</comment>
+ </data>
+ <data name="MDF_ResourceReadError" xml:space="preserve">
+ <value>{0} could not be processed for spatial info: {1}</value>
+ <comment>An error message that is displayed if a resource fails to load</comment>
+ </data>
+ <data name="MDF_UnsupportedLayerTypeWarning" xml:space="preserve">
+ <value>Layer {0} is a type that is unsupported by Maestro</value>
+ <comment>A warning message that is displayed if a layer has a type that is not supported by Maestro</comment>
+ </data>
+ <data name="WL_MapValidationError" xml:space="preserve">
+ <comment>An error message that is displayed if the map validation fails</comment>
+ </data>
+ <data name="WL_MissingMapError" xml:space="preserve">
+ <value>Layout does not specify a map</value>
+ <comment>An error message that is displayed if no map is specified in the layout</comment>
+ </data>
+ <data name="WL_StartViewOutsideExtentsWarning" xml:space="preserve">
+ <value>Layout specifies a start view that is outside the map's initial extents</value>
+ <comment>A warning message that is displayed if the layout specifies a start center point that is outside the map's specified extents</comment>
+ </data>
+</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/ResourceValidatorLoader.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,48 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+ /// <summary>
+ /// Utility class that initializes the default set of resource validators
+ /// </summary>
+ public static class ResourceValidatorLoader
+ private static bool m_initialized = false;
+ public static void LoadStockValidators()
+ if (m_initialized)
+ return;
+ ResourceValidatorSet.RegisterValidator(new FeatureSourceValidator());
+ ResourceValidatorSet.RegisterValidator(new LayerDefinitionValidator());
+ ResourceValidatorSet.RegisterValidator(new MapDefinitionValidator());
+ ResourceValidatorSet.RegisterValidator(new WebLayoutValidator());
+ ResourceValidatorSet.RegisterValidator(new ApplicationDefinitionValidator());
+ m_initialized = true;
Added: sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/WebLayoutValidator.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,77 @@
+#endregion
+using System;
+using System.Text;
+using OSGeo.MapGuide.ObjectModels.WebLayout;
+using OSGeo.MapGuide.MaestroAPI.Exceptions;
+ public class WebLayoutValidator : IResourceValidator
+ if (resource.ResourceType != OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout)
+ return null;
+ WebLayoutType layout = resource as WebLayoutType;
+ if (layout.Map == null || layout.Map.ResourceId == null)
+ issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Properties.Resources.WL_MissingMapError)));
+ else
+ if (recurse)
+ try
+ MapDefinition mdef = (MapDefinition)layout.CurrentConnection.ResourceService.GetResource(layout.Map.ResourceId);
+ if (layout.Map.InitialView != null)
+ if (!mapEnv.Contains(layout.Map.InitialView.CenterX, layout.Map.InitialView.CenterY))
+ issues.Add(new ValidationIssue(mdef, ValidationStatus.Warning, string.Format(Properties.Resources.WL_StartViewOutsideExtentsWarning)));
+ catch (Exception ex)
+ string msg = NestedExceptionMessageProcessor.GetFullMessage(ex);
+ issues.Add(new ValidationIssue(layout, ValidationStatus.Error, string.Format(Properties.Resources.WL_MapValidationError, layout.Map.ResourceId, msg)));
+ return issues.ToArray();
+ get { return new ResourceTypeDescriptor(OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, "1.0.0"); }
Added: sandbox/maestro-3.0/Maestro.Shared.UI/CancelException.cs
--- sandbox/maestro-3.0/Maestro.Shared.UI/CancelException.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/CancelException.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,25 @@
+using System;
+using System.Text;
+namespace Maestro.Shared.UI
+ [global::System.Serializable]
+ public class CancelException : Exception
+ // For guidelines regarding the creation of new exception types, see
+ // http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpgenref/html/cpconerrorraisinghandlingguidelines.asp
+ // and
+ // http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dncscol/html/csharp07192001.asp
+ public CancelException() { }
+ public CancelException(string message) : base(message) { }
+ public CancelException(string message, Exception inner) : base(message, inner) { }
+ protected CancelException(
+ System.Runtime.Serialization.SerializationInfo info,
+ System.Runtime.Serialization.StreamingContext context)
+ : base(info, context) { }
Modified: sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj
--- sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/Maestro.Shared.UI.csproj 2010-07-21 10:14:11 UTC (rev 5045)
@@ -3,7 +3,7 @@
<PropertyGroup>
- <ProductVersion>9.0.21022</ProductVersion>
+ <ProductVersion>9.0.30729</ProductVersion>
<ProjectGuid>{CFD19053-2172-41D3-8460-0FD2123A1E88}</ProjectGuid>
@@ -38,6 +38,7 @@
</ItemGroup>
<ItemGroup>
+ <Compile Include="CancelException.cs" />
<Compile Include="CheckBoxBinder.cs" />
<Compile Include="CollapsiblePanel.cs">
<SubType>UserControl</SubType>
@@ -54,6 +55,12 @@
</Compile>
<Compile Include="TextBoxBinder.cs" />
<Compile Include="WaitCursor.cs" />
+ <Compile Include="ProgressDialog.cs">
+ <SubType>Form</SubType>
+ </Compile>
+ <Compile Include="ProgressDialog.designer.cs">
+ <DependentUpon>ProgressDialog.cs</DependentUpon>
+ </Compile>
<Service Include="{94E38DFF-614B-4cbd-B67C-F211BB35CE8B}" />
</ItemGroup>
<ItemGroup>
@@ -66,6 +73,9 @@
<SubType>Designer</SubType>
</EmbeddedResource>
+ <EmbeddedResource Include="ProgressDialog.resx">
+ </EmbeddedResource>
</ItemGroup>
<ItemGroup>
<None Include="Resources\minus-white.png" />
Added: sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.Designer.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.Designer.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,88 @@
+ partial class ProgressDialog
+ /// <summary>
+ /// Required designer variable.
+ /// </summary>
+ private System.ComponentModel.IContainer components = null;
+ /// <summary>
+ /// Clean up any resources being used.
+ /// </summary>
+ /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+ protected override void Dispose(bool disposing)
+ if (disposing && (components != null))
+ components.Dispose();
+ base.Dispose(disposing);
+ #region Windows Form Designer generated code
+ /// <summary>
+ /// Required method for Designer support - do not modify
+ /// the contents of this method with the code editor.
+ /// </summary>
+ private void InitializeComponent()
+ System.ComponentModel.ComponentResourceManager resources = new System.ComponentModel.ComponentResourceManager(typeof(ProgressDialog));
+ this.progressBar1 = new System.Windows.Forms.ProgressBar();
+ this.CancelBtn = new System.Windows.Forms.Button();
+ this.BackgroundWorker = new System.ComponentModel.BackgroundWorker();
+ this.label1 = new System.Windows.Forms.Label();
+ this.SuspendLayout();
+ // progressBar1
+ resources.ApplyResources(this.progressBar1, "progressBar1");
+ this.progressBar1.Name = "progressBar1";
+ // CancelBtn
+ resources.ApplyResources(this.CancelBtn, "CancelBtn");
+ this.CancelBtn.Name = "CancelBtn";
+ this.CancelBtn.UseVisualStyleBackColor = true;
+ this.CancelBtn.Click += new System.EventHandler(this.CancelBtn_Click);
+ // BackgroundWorker
+ this.BackgroundWorker.WorkerReportsProgress = true;
+ this.BackgroundWorker.WorkerSupportsCancellation = true;
+ this.BackgroundWorker.DoWork += new System.ComponentModel.DoWorkEventHandler(this.BackgroundWorker_DoWork);
+ this.BackgroundWorker.RunWorkerCompleted += new System.ComponentModel.RunWorkerCompletedEventHandler(this.BackgroundWorker_RunWorkerCompleted);
+ this.BackgroundWorker.ProgressChanged += new System.ComponentModel.ProgressChangedEventHandler(this.BackgroundWorker_ProgressChanged);
+ // label1
+ resources.ApplyResources(this.label1, "label1");
+ this.label1.Name = "label1";
+ // WaitForOperation
+ resources.ApplyResources(this, "$this");
+ this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+ this.Controls.Add(this.label1);
+ this.Controls.Add(this.CancelBtn);
+ this.Controls.Add(this.progressBar1);
+ this.FormBorderStyle = System.Windows.Forms.FormBorderStyle.FixedToolWindow;
+ this.KeyPreview = true;
+ this.Name = "WaitForOperation";
+ this.Load += new System.EventHandler(this.WaitForOperation_Load);
+ this.KeyPress += new System.Windows.Forms.KeyPressEventHandler(this.WaitForOperation_KeyPress);
+ this.FormClosing += new System.Windows.Forms.FormClosingEventHandler(this.WaitForOperation_FormClosing);
+ this.ResumeLayout(false);
+ this.PerformLayout();
+ #endregion
+ private System.Windows.Forms.ProgressBar progressBar1;
+ private System.ComponentModel.BackgroundWorker BackgroundWorker;
+ private System.Windows.Forms.Label label1;
+ public System.Windows.Forms.Button CancelBtn;
Added: sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.cs
--- sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,163 @@
+// Copyright (C) 2009, Kenneth Skovhede
+// http://www.hexad.dk, opensource at hexad.dk
+#endregion
+using System;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+ public partial class ProgressDialog : Form
+ public delegate object DoBackgroundWork(BackgroundWorker worker, DoWorkEventArgs e, params object[] args);
+ private DoBackgroundWork m_method;
+ private object[] m_args;
+ private object m_result;
+ private bool m_cancelAborts = false;
+ private System.Threading.Thread m_worker;
+ public ProgressDialog()
+ InitializeComponent();
+ /// <summary>
+ /// A value indicating if the cancel button attempts to abort the thread, rather than simply flag it for cancellation
+ /// </summary>
+ public bool CancelAbortsThread
+ get { return m_cancelAborts; }
+ set { m_cancelAborts = value; }
+ public object RunOperationAsync(Form owner, DoBackgroundWork method, params object[] arguments)
+ m_method = method;
+ m_args = arguments;
+ if (this.Visible)
+ this.Hide();
+ if (this.ShowDialog(owner) == DialogResult.OK)
+ return m_result;
+ else
+ throw new CancelException();
+ private void BackgroundWorker_DoWork(object sender, DoWorkEventArgs e)
+ try
+ m_worker = System.Threading.Thread.CurrentThread;
+ e.Result = m_method(BackgroundWorker, e, m_args);
+ catch (System.Threading.ThreadAbortException)
+ e.Cancel = true;
+ e.Result = null;
+ //We exit, but hide the abort details from the BackgroundWorker, so it processes events as it should
+ System.Threading.Thread.ResetAbort();
+ finally
+ m_worker = null;
+ private void BackgroundWorker_ProgressChanged(object sender, ProgressChangedEventArgs e)
+ if (e.ProgressPercentage < 0)
+ progressBar1.Style = ProgressBarStyle.Marquee;
+ else
+ if (progressBar1.Style == ProgressBarStyle.Marquee)
+ progressBar1.Style = ProgressBarStyle.Blocks;
+ progressBar1.Value = Math.Min(Math.Max(progressBar1.Minimum, e.ProgressPercentage), progressBar1.Maximum);
+ if (e.UserState != null)
+ label1.Text = e.UserState.ToString();
+ private void BackgroundWorker_RunWorkerCompleted(object sender, RunWorkerCompletedEventArgs e)
+ if (e.Cancelled)
+ this.DialogResult = DialogResult.Cancel;
+ this.Close();
+ else if (e.Error != null)
+ throw e.Error;
+ else
+ m_result = e.Result;
+ this.DialogResult = DialogResult.OK;
+ this.Close();
+ private void WaitForOperation_Load(object sender, EventArgs e)
+ BackgroundWorker.WorkerSupportsCancellation = !m_cancelAborts;
+ BackgroundWorker.RunWorkerAsync();
+ private void CancelBtn_Click(object sender, EventArgs e)
+ CancelBtn.Enabled = false;
+ if (!BackgroundWorker.CancellationPending && BackgroundWorker.WorkerSupportsCancellation)
+ BackgroundWorker.CancelAsync();
+ if (m_cancelAborts)
+ try
+ //Protected, because threading can make it null after the check
+ if (m_worker != null && m_worker.IsAlive)
+ m_worker.Abort();
+ catch
+ private void WaitForOperation_FormClosing(object sender, FormClosingEventArgs e)
+ if (e.CloseReason == CloseReason.UserClosing)
+ CancelBtn_Click(sender, e);
+ private void WaitForOperation_KeyPress(object sender, KeyPressEventArgs e)
+ if (e.KeyChar == (char)Keys.Escape && CancelBtn.Enabled)
Added: sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.resx
--- sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.resx (rev 0)
+++ sandbox/maestro-3.0/Maestro.Shared.UI/ProgressDialog.resx 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,225 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+ Microsoft ResX Schema
+ Version 2.0
+ The primary goals of this format is to allow a simple XML format
+ that is mostly human readable. The generation and parsing of the
+ various data types are done through the TypeConverter classes
+ associated with the data types.
+ Example:
+ ... ado.net/XML headers & schema ...
+ <resheader name="resmimetype">text/microsoft-resx</resheader>
+ <resheader name="version">2.0</resheader>
+ <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+ <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+ <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+ <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+ <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+ <value>[base64 mime encoded serialized .NET Framework object]</value>
+ </data>
+ <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+ <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+ <comment>This is a comment</comment>
+ </data>
+ There are any number of "resheader" rows that contain simple
+ name/value pairs.
+ Each data row contains a name, and value. The row also contains a
+ type or mimetype. Type corresponds to a .NET class that support
+ text/value conversion through the TypeConverter architecture.
+ Classes that don't support this are serialized and stored with the
+ mimetype set.
+ The mimetype is used for serialized objects, and tells the
+ ResXResourceReader how to depersist the object. This is currently not
+ extensible. For a given mimetype the value must be set accordingly:
+ Note - application/x-microsoft.net.object.binary.base64 is the format
+ that the ResXResourceWriter will generate, however the reader can
+ read any of the formats listed below.
+ mimetype: application/x-microsoft.net.object.binary.base64
+ value : The object must be serialized with
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+ : and then encoded with base64 encoding.
+ mimetype: application/x-microsoft.net.object.soap.base64
+ : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+ mimetype: application/x-microsoft.net.object.bytearray.base64
+ value : The object must be serialized into a byte array
+ : using a System.ComponentModel.TypeConverter
+ <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+ <xsd:element name="root" msdata:IsDataSet="true">
+ <xsd:complexType>
+ <xsd:choice maxOccurs="unbounded">
+ <xsd:element name="metadata">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" />
+ </xsd:sequence>
+ <xsd:attribute name="name" use="required" type="xsd:string" />
+ <xsd:attribute name="type" type="xsd:string" />
+ <xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
+ </xsd:complexType>
+ </xsd:element>
+ <xsd:element name="assembly">
+ <xsd:complexType>
+ <xsd:attribute name="alias" type="xsd:string" />
+ <xsd:attribute name="name" type="xsd:string" />
+ </xsd:element>
+ <xsd:element name="data">
+ <xsd:complexType>
+ <xsd:sequence>
+ <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+ <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+ <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+ <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+ </xsd:element>
+ <xsd:element name="resheader">
+ <xsd:complexType>
+ <xsd:sequence>
+ </xsd:sequence>
+ <xsd:attribute name="name" type="xsd:string" use="required" />
+ </xsd:element>
+ </xsd:choice>
+ </xsd:element>
+ </xsd:schema>
+ <value>text/microsoft-resx</value>
+ </resheader>
+ <value>2.0</value>
+ </resheader>
+ <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </resheader>
+ <assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
+ <data name="progressBar1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>24, 40</value>
+ </data>
+ <data name="progressBar1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>360, 23</value>
+ </data>
+ <assembly alias="mscorlib" name="mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="progressBar1.TabIndex" type="System.Int32, mscorlib">
+ <value>0</value>
+ </data>
+ <data name=">>progressBar1.Name" xml:space="preserve">
+ <value>progressBar1</value>
+ </data>
+ <data name=">>progressBar1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.ProgressBar, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>progressBar1.Parent" xml:space="preserve">
+ <value>$this</value>
+ </data>
+ <data name=">>progressBar1.ZOrder" xml:space="preserve">
+ <value>2</value>
+ </data>
+ <data name="CancelBtn.Location" type="System.Drawing.Point, System.Drawing">
+ <value>168, 72</value>
+ </data>
+ <data name="CancelBtn.Size" type="System.Drawing.Size, System.Drawing">
+ <value>75, 23</value>
+ </data>
+ <data name="CancelBtn.TabIndex" type="System.Int32, mscorlib">
+ <value>1</value>
+ </data>
+ <data name="CancelBtn.Text" xml:space="preserve">
+ <value>Cancel</value>
+ </data>
+ <data name=">>CancelBtn.Name" xml:space="preserve">
+ <value>CancelBtn</value>
+ </data>
+ <data name=">>CancelBtn.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Button, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>CancelBtn.Parent" xml:space="preserve">
+ </data>
+ <data name=">>CancelBtn.ZOrder" xml:space="preserve">
+ <value>1</value>
+ </data>
+ <metadata name="BackgroundWorker.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
+ <data name="label1.AutoSize" type="System.Boolean, mscorlib">
+ <value>True</value>
+ </data>
+ <data name="label1.Location" type="System.Drawing.Point, System.Drawing">
+ <value>24, 16</value>
+ </data>
+ <data name="label1.Size" type="System.Drawing.Size, System.Drawing">
+ <value>56, 13</value>
+ </data>
+ <data name="label1.TabIndex" type="System.Int32, mscorlib">
+ <value>2</value>
+ </data>
+ <data name="label1.Text" xml:space="preserve">
+ <value>Working...</value>
+ </data>
+ <data name=">>label1.Name" xml:space="preserve">
+ <value>label1</value>
+ </data>
+ <data name=">>label1.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Label, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>label1.Parent" xml:space="preserve">
+ </data>
+ <data name=">>label1.ZOrder" xml:space="preserve">
+ <value>0</value>
+ </data>
+ <metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
+ </metadata>
+ <data name="$this.AutoScaleDimensions" type="System.Drawing.SizeF, System.Drawing">
+ <value>6, 13</value>
+ </data>
+ <data name="$this.ClientSize" type="System.Drawing.Size, System.Drawing">
+ <value>412, 103</value>
+ </data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
+ <data name="$this.StartPosition" type="System.Windows.Forms.FormStartPosition, System.Windows.Forms">
+ <value>CenterParent</value>
+ </data>
+ <data name="$this.Text" xml:space="preserve">
+ <value>Wait for operation to complete</value>
+ </data>
+ <data name=">>BackgroundWorker.Name" xml:space="preserve">
+ <value>BackgroundWorker</value>
+ </data>
+ <data name=">>BackgroundWorker.Type" xml:space="preserve">
+ <value>System.ComponentModel.BackgroundWorker, System, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+ <data name=">>$this.Name" xml:space="preserve">
+ <value>WaitForOperation</value>
+ </data>
+ <data name=">>$this.Type" xml:space="preserve">
+ <value>System.Windows.Forms.Form, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ </data>
+</root>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-07-21 10:14:11 UTC (rev 5045)
@@ -3,7 +3,7 @@
<PropertyGroup>
<ProjectGuid>{80FA3158-8B5F-48D1-A393-0378AFE48A7E}</ProjectGuid>
@@ -213,11 +213,13 @@
<Compile Include="Resource\Conversion\ResourceConverter.cs" />
<Compile Include="Resource\Conversion\ResourceUpgrader.cs" />
<Compile Include="Resource\IResource.cs" />
+ <Compile Include="Resource\IResourceValidator.cs" />
<Compile Include="Resource\IVersionedEntity.cs" />
<Compile Include="Resource\ResourceIdentifier.cs" />
<Compile Include="Resource\ResourceSchemaChain.cs" />
<Compile Include="Resource\ResourceTypeDescriptor.cs" />
<Compile Include="Resource\ResourceContentVersionChecker.cs" />
+ <Compile Include="Resource\ResourceValidatorSet.cs" />
<Compile Include="Serialization\Enums.cs" />
<Compile Include="Serialization\IBinarySerializeable.cs" />
<Compile Include="Serialization\MgBinaryDeserializer.cs" />
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -23,9 +23,27 @@
using System.Xml.Serialization;
using OSGeo.MapGuide.MaestroAPI;
+using System.Xml;
namespace OSGeo.MapGuide.ObjectModels.ApplicationDefinition
+ partial class CustomContentType
+ public XmlElement GetElement(string name)
+ if (this.anyField == null)
+ return null;
+ foreach(XmlElement el in this.anyField)
+ if (el.Name == name)
+ return el;
+ return null;
partial class ApplicationDefinitionType : IResource
internal ApplicationDefinitionType() { }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/Envelope.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -81,5 +81,32 @@
if (env.MaxY > this.MaxY)
this.MaxY = env.MaxY;
+ /// <summary>
+ /// Indicates whether the specified coordinates are within this instance
+ /// </summary>
+ /// <param name="x"></param>
+ /// <param name="y"></param>
+ /// <returns></returns>
+ public bool Contains(double x, double y)
+ return this.MinX <= x &&
+ this.MaxX >= x &&
+ this.MinY <= y &&
+ this.MaxY >= y;
+ /// <summary>
+ /// Indicates whether the specified envelope intersects this instance
+ /// </summary>
+ /// <param name="other"></param>
+ public bool Intersects(Envelope other)
+ if (other == null)
+ return false;
+ return !(other.MinX > this.MaxX || other.MaxX < this.MinX || other.MinY > this.MaxY || other.MaxY < this.MinY);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -23,6 +23,7 @@
+using OSGeo.MapGuide.ObjectModels.Common;
namespace OSGeo.MapGuide.ObjectModels.FeatureSource
@@ -263,5 +264,51 @@
return this.CurrentConnection.FeatureService.DescribeFeatureSource(this.ResourceID);
+ /// <summary>
+ /// Convenience method to retrieve the spatial context information of this feature source
+ /// </summary>
+ public OSGeo.MapGuide.ObjectModels.Common.FdoSpatialContextList GetSpatialInfo()
+ return this.CurrentConnection.FeatureService.GetSpatialContextInfo(this.ResourceID, false);
+ /// <summary>
+ /// Convenience methods to get the identity properties of a given feature class (name)
+ /// </summary>
+ /// <param name="className"></param>
+ public string[] GetIdentityProperties(string className)
+ try
+ return this.CurrentConnection.FeatureService.GetIdentityProperties(this.ResourceID, className);
+ //MgClassNotFoundException is thrown for classes w/ no identity properties
+ //when the correct server response should be an empty array
+ if (ex.Message.IndexOf("MgClassNotFoundException") >= 0)
+ return new string[0];
+ else
+ throw;
+ /// <summary>
+ /// Convenience method to get the spatial extents of a given feature class
+ /// </summary>
+ /// <param name="geomProperty"></param>
+ public Envelope GetSpatialExtent(string className, string geomProperty)
+ return this.CurrentConnection.FeatureService.GetSpatialExtent(this.ResourceID, className, geomProperty);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -24,14 +24,164 @@
namespace OSGeo.MapGuide.ObjectModels.LayerDefinition
+ public enum LayerType
+ Drawing,
+ Vector,
+ Raster
public interface ILayerDefinition : IResource
Envelope GetSpatialExtent(bool allowFallbackToContextInformation);
+ ISubLayerDefinition SubLayer { get; }
+ public interface ISubLayerDefinition
+ LayerType LayerType { get; }
+ abstract partial class BaseLayerDefinitionType : ISubLayerDefinition
+ [XmlIgnore]
+ public abstract LayerType LayerType { get; }
+ public interface IVectorLayerDefinition : ISubLayerDefinition
+ string FeatureSourceID { get; set; }
+ string FullQualifiedClassName { get; set; }
+ string GeometryProperty { get; set; }
+ string Url { get; set; }
+ string ToolTip { get; set; }
+ string Filter { get; set; }
+ public interface IRasterLayerDefinition : ISubLayerDefinition
+ public interface IDrawingLayerDefinition : ISubLayerDefinition
+ string DrawingSourceID { get; set; }
+ partial class VectorLayerDefinitionType : IVectorLayerDefinition
+ public override LayerType LayerType
+ get { return LayerType.Vector; }
+ [XmlIgnore]
+ string IVectorLayerDefinition.FeatureSourceID
+ get { return this.ResourceId; }
+ set { this.ResourceId = value; }
+ [XmlIgnore]
+ string IVectorLayerDefinition.FullQualifiedClassName
+ get { return this.FeatureName; }
+ set { this.FeatureName = value; }
+ [XmlIgnore]
+ string IVectorLayerDefinition.GeometryProperty
+ get { return this.Geometry; }
+ set { this.Geometry = value; }
+ [XmlIgnore]
+ string IVectorLayerDefinition.Url
+ get { return this.Url; }
+ set { this.Url = value; }
+ [XmlIgnore]
+ string IVectorLayerDefinition.ToolTip
+ get { return this.ToolTip; }
+ set { this.ToolTip = value; }
+ [XmlIgnore]
+ string IVectorLayerDefinition.Filter
+ get { return this.Filter; }
+ set { this.Filter = value; }
+ partial class GridLayerDefinitionType : IRasterLayerDefinition
+ get { return LayerType.Raster; }
+ [XmlIgnore]
+ string IRasterLayerDefinition.FeatureSourceID
+ partial class DrawingLayerDefinitionType : IDrawingLayerDefinition
+ get { return LayerType.Drawing; }
+ string IDrawingLayerDefinition.DrawingSourceID
+ partial class VectorScaleRangeType
+ #region Missing generated stuff
+ [EditorBrowsable(EditorBrowsableState.Never)]
+ private bool minScaleFieldSpecified;
+ [System.Xml.Serialization.XmlIgnoreAttribute()]
+ public bool MinScaleSpecified
+ get
+ return this.minScaleFieldSpecified;
+ set
+ if ((minScaleFieldSpecified.Equals(value) != true))
+ this.minScaleFieldSpecified = value;
+ this.OnPropertyChanged("MinScaleSpecified");
+ #endregion
partial class LayerDefinition : ILayerDefinition
internal LayerDefinition() { }
@@ -125,5 +275,10 @@
else
return null;
+ public ISubLayerDefinition SubLayer
+ get { return this.Item; }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.Designer.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -124,6 +124,15 @@
/// <summary>
+ /// Looks up a localized string similar to There is no registered validator for {0} v{1}. Validation cannot be performed.
+ /// </summary>
+ internal static string ERR_NO_REGISTERED_VALIDATOR {
+ get {
+ return ResourceManager.GetString("ERR_NO_REGISTERED_VALIDATOR", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Could not find matching serializer for this resource: .
/// </summary>
internal static string ERR_NO_SERIALIZER {
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Properties/Resources.resx 2010-07-21 10:14:11 UTC (rev 5045)
@@ -138,6 +138,10 @@
<data name="ERR_NO_DOWNGRADE_PATH" xml:space="preserve">
<value>There is no downgrade path to the desired resource version</value>
</data>
+ <data name="ERR_NO_REGISTERED_VALIDATOR" xml:space="preserve">
+ <value>There is no registered validator for {0} v{1}. Validation cannot be performed</value>
+ <comment>A warning message that is displayed if there is no registered validator for the specified resource and version</comment>
+ </data>
<data name="ERR_NO_SERIALIZER" xml:space="preserve">
<value>Could not find matching serializer for this resource: </value>
</data>
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResourceValidator.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,79 @@
+#endregion
+using System;
+using System.Text;
+namespace OSGeo.MapGuide.MaestroAPI.Resource
+ public interface IResourceValidator
+ ResourceTypeDescriptor SupportedResourceAndVersion { get; }
+ ValidationIssue[] Validate(IResource resource, bool recurse);
+ /// <summary>
+ /// Represents a validation issue collected during validation
+ /// </summary>
+ public class ValidationIssue
+ public ValidationIssue(IResource res, ValidationStatus stat, string msg)
+ this.Resource = res;
+ this.Status = stat;
+ this.Message = msg;
+ /// <summary>
+ /// Gets the message for the validation issue
+ /// </summary>
+ public string Message { get; private set; }
+ /// <summary>
+ /// Gets the status of the validation issue
+ /// </summary>
+ public ValidationStatus Status { get; private set; }
+ /// <summary>
+ /// Gets the resource this issue pertains to
+ /// </summary>
+ public IResource Resource { get; private set; }
+ /// <summary>
+ /// All possible states a validation issue may have
+ /// </summary>
+ public enum ValidationStatus
+ /// <summary>
+ /// Indicates that the issue is non-vital, eg. a performance problem
+ /// </summary>
+ Information,
+ /// <summary>
+ /// Indicates that the issue is likely to cause problems
+ /// </summary>
+ Warning,
+ /// <summary>
+ /// Indicates that the issue will prevent correct operation of the map
+ /// </summary>
+ Error
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ResourceValidatorSet.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -0,0 +1,92 @@
+#endregion
+using System;
+using System.Text;
+ /// <summary>
+ /// A collection of resource validators
+ /// </summary>
+ public static class ResourceValidatorSet
+ private static List<IResourceValidator> m_validators = new List<IResourceValidator>();
+ public static void RegisterValidator(IResourceValidator v)
+ if (!m_validators.Contains(v))
+ m_validators.Add(v);
+ public static ValidationIssue[] Validate(IEnumerable<IResource> items, bool recurse)
+ var issues = new List<ValidationIssue>();
+ foreach (var item in items)
+ issues.AddRange(Validate(item, true));
+ public static ValidationIssue[] Validate(IResource item, bool recurse)
+ List<ValidationIssue> issues = new List<ValidationIssue>();
+ if (!HasValidator(item.ResourceType, item.ResourceVersion))
+ issues.Add(new ValidationIssue(item, ValidationStatus.Warning, string.Format(Properties.Resources.ERR_NO_REGISTERED_VALIDATOR, item.ResourceType, item.ResourceVersion)));
+ else
+ foreach (IResourceValidator v in m_validators)
+ try
+ ValidationIssue[] tmp = v.Validate(item, recurse);
+ if (tmp != null)
+ issues.AddRange(tmp);
+ issues.Add(new ValidationIssue(item, ValidationStatus.Error, "Failed in validator: " + msg));
+ public static bool HasValidator(ResourceTypes resourceTypes, Version version)
+ bool found = false;
+ var find = new ResourceTypeDescriptor(resourceTypes, version.ToString());
+ foreach (var v in m_validators)
+ if (v.SupportedResourceAndVersion.Equals(find))
+ found = true;
+ break;
+ return found;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-07-21 07:04:30 UTC (rev 5044)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-07-21 10:14:11 UTC (rev 5045)
@@ -36,6 +36,8 @@
using OSGeo.MapGuide.MaestroAPI.Http;
using System.IO;
using OSGeo.MapGuide.ObjectModels.Capabilities;
+using System.Text;
@@ -259,19 +261,32 @@
public override string TestConnection(string featuresource)
- string req = m_reqBuilder.TestConnection(featuresource);
- try
- byte[] x = this.DownloadData(req);
- catch (WebException wex)
+ string req = m_reqBuilder.TestConnection(featuresource);
+ string result = string.Empty;
+ try
+ byte[] x = this.DownloadData(req);
+ //UGLY: Prune out the '\0' chars
+ List<byte> bytes = new List<byte>();
+ for (int i = 0; i < x.Length; i++)
+ if (x[i] > 0)
+ bytes.Add(x[i]);
+ else
+ break;
+ result = Encoding.UTF8.GetString(bytes.ToArray());
+ catch (WebException wex)
if (wex.Response != null)
try
- string result = "";
using (System.IO.MemoryStream ms = new System.IO.MemoryStream())
Utility.CopyStream(wex.Response.GetResponseStream(), ms);
@@ -291,35 +306,35 @@
- if (wex.InnerException == null)
- return wex.Message;
- else
- return wex.InnerException.Message;
- catch (Exception ex)
- return NestedExceptionMessageProcessor.GetFullMessage(ex);
+ if (wex.InnerException == null)
+ return wex.Message;
+ else
+ return wex.InnerException.Message;
+ result = NestedExceptionMessageProcessor.GetFullMessage(ex);
- return string.Empty;
+ return result;
public string TestConnection(string providername, NameValueCollection parameters)
- string req = m_reqBuilder.TestConnection(providername, parameters);
- //System.IO.MemoryStream msx = new System.IO.MemoryStream();
- //System.Net.WebRequest reqp = m_reqBuilder.TestConnectionPost(providername, parameters, msx);
- try
- /*msx.Position = 0;
- Utility.CopyStream(msx, reqp.GetRequestStream());
- reqp.GetRequestStream().Flush();
- int f = reqp.GetResponse().GetResponseStream().ReadByte();*/
+ string req = m_reqBuilder.TestConnection(providername, parameters);
+ //System.IO.MemoryStream msx = new System.IO.MemoryStream();
+ //System.Net.WebRequest reqp = m_reqBuilder.TestConnectionPost(providername, parameters, msx);
+ try
+ /*msx.Position = 0;
+ Utility.CopyStream(msx, reqp.GetRequestStream());
+ reqp.GetRequestStream().Flush();
+ int f = reqp.GetResponse().GetResponseStream().ReadByte();*/
try
@@ -344,17 +359,17 @@
- else
+ else
+ return string.Empty;
/// <summary>
More information about the mapguide-commits
