[mapguide-commits] r4822 - trunk/Tools/Maestro/Maestro/LoginForm
svn_mapguide at osgeo.org
Tue May 4 00:51:53 EDT 2010
Author: jng
Date: 2010-05-04 00:51:52 -0400 (Tue, 04 May 2010)
New Revision: 4822
trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs
trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.resx
Fix #1339: Allow empty passwords in login dialog (required for Anonymous login)
Modified: trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs 2010-04-30 23:00:23 UTC (rev 4821)
+++ trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.cs 2010-05-04 04:51:52 UTC (rev 4822)
@@ -428,8 +428,11 @@
private void txtPassword_TextChanged(object sender, EventArgs e)
- btnOK.Enabled = txtPassword.Text.Trim().Length > 0 && cmbServerUrl.Text.Length > 0 && txtUsername.Text.Length > 0;
+ btnOK.Enabled = cmbServerUrl.Text.Length > 0 && txtUsername.Text.Length > 0;
+ public string Username { get { return txtUsername.Text; } }
+ public string Password { get { return txtPassword.Text; } }
Modified: trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.resx
--- trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.resx 2010-04-30 23:00:23 UTC (rev 4821)
+++ trunk/Tools/Maestro/Maestro/LoginForm/FormLogin.resx 2010-05-04 04:51:52 UTC (rev 4822)
@@ -143,6 +143,9 @@
<data name=">>label1.ZOrder" xml:space="preserve">
<value>13</value>
</data>
+ <metadata name="toolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
+ <value>17, 17</value>
+ </metadata>
<data name="cmbServerUrl.Location" type="System.Drawing.Point, System.Drawing">
<value>96, 16</value>
</data>
@@ -155,9 +158,6 @@
<data name="cmbServerUrl.Text" xml:space="preserve">
<value>http://localhost/mapguide/mapagent/mapagent.fcgi</value>
</data>
- <metadata name="toolTip.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
- <value>17, 17</value>
- </metadata>
<data name="cmbServerUrl.ToolTip" xml:space="preserve">
<value>Enter the full URL of the MapAgent service here</value>
</data>
@@ -456,6 +456,9 @@
<data name=">>chkSavePassword.ZOrder" xml:space="preserve">
<value>2</value>
</data>
+ </metadata>
<data name="cmbLanguage.Location" type="System.Drawing.Point, System.Drawing">
<value>96, 144</value>
</data>
More information about the mapguide-commits
