[mapguide-commits] r4823 - in trunk/Tools/Maestro: MaestroAPI
MgCooker
svn_mapguide at osgeo.org
Tue May 4 00:57:34 EDT 2010
Author: jng
Date: 2010-05-04 00:57:34 -0400 (Tue, 04 May 2010)
New Revision: 4823
trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs
trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs
trunk/Tools/Maestro/MgCooker/Program.cs
trunk/Tools/Maestro/MgCooker/RenderThread.cs
trunk/Tools/Maestro/MgCooker/SetupRun.cs
This submission includes two fixes:
#1342: Propagate login to MgCooker UI, previously only the mapagent URL was only propagated.
#1334: Support sessionID-less GetTile requests for HttpServerConnection. This request method is only used when the connection is initialised with the Anonymous login. If initialised any other way, it will use a sessionID-based method. The thread setup has also been updated so that the sessionID-less method is used for all rendering threads.
Modified: trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs
--- trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs 2010-05-04 04:51:52 UTC (rev 4822)
+++ trunk/Tools/Maestro/MaestroAPI/HttpServerConnection.cs 2010-05-04 04:57:34 UTC (rev 4823)
@@ -38,6 +38,8 @@
private Hashtable m_cachedProviderCapabilities = null;
private Version m_siteVersion;
+ private bool mAnonymousUser = false;
internal HttpServerConnection()
: base()
@@ -46,6 +48,12 @@
+ /// <summary>
+ /// Gets whether this connection was initialised with an Anonymous login. If it was, it will return true.
+ /// If this was not, or it was initialised from an existing session id, then it will return false.
+ /// </summary>
+ public bool IsAnonymous { get { return mAnonymousUser; } }
public const string PARAM_URL = "Url";
public const string PARAM_SESSION = "SessionId";
public const string PARAM_LOCALE = "Locale";
@@ -100,6 +108,8 @@
m_username = username;
m_password = password;
+ mAnonymousUser = (username == "Anonymous");
try
this.RestartSession();
@@ -1437,7 +1447,11 @@
public override System.IO.Stream GetTile(string mapdefinition, string baselayergroup, int col, int row, int scaleindex, string format)
- string req = m_reqBuilder.GetTile(mapdefinition, baselayergroup, row, col, scaleindex, format, m_wc.Credentials == null);
+ string req = string.Empty;
+ if (mAnonymousUser)
+ req = m_reqBuilder.GetTileAnonymous(mapdefinition, baselayergroup, row, col, scaleindex, format);
+ else
+ req = m_reqBuilder.GetTile(mapdefinition, baselayergroup, row, col, scaleindex, format, m_wc.Credentials == null);
return this.OpenRead(req);
Modified: trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs
--- trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs 2010-05-04 04:51:52 UTC (rev 4822)
+++ trunk/Tools/Maestro/MaestroAPI/RequestBuilder.cs 2010-05-04 04:57:34 UTC (rev 4823)
@@ -1151,6 +1151,24 @@
return m_hosturi + "?" + EncodeParameters(param);
+ public string GetTileAnonymous(string mapdefinition, string groupname, int row, int col, int scaleindex, string format)
+ NameValueCollection param = new NameValueCollection();
+ param.Add("OPERATION", "GETTILEIMAGE");
+ param.Add("VERSION", "1.2.0");
+ param.Add("USERNAME", "Anonymous");
+ param.Add("PASSWORD", "");
+ param.Add("SCALEINDEX", scaleindex.ToString());
+ param.Add("MAPDEFINITION", mapdefinition);
+ param.Add("FORMAT", format);
+ param.Add("BASEMAPLAYERGROUPNAME", groupname);
+ param.Add("TILECOL", row.ToString());
+ param.Add("TILEROW", col.ToString());
+ param.Add("CLIENTAGENT", m_userAgent);
+ return m_hosturi + "?" + EncodeParameters(param);
public System.Net.WebRequest ApplyPackage(System.IO.Stream filestream, Utility.StreamCopyProgressDelegate callback)
if (m_sessionID == null)
Modified: trunk/Tools/Maestro/MgCooker/Program.cs
--- trunk/Tools/Maestro/MgCooker/Program.cs 2010-05-04 04:51:52 UTC (rev 4822)
+++ trunk/Tools/Maestro/MgCooker/Program.cs 2010-05-04 04:57:34 UTC (rev 4823)
@@ -160,6 +160,9 @@
MaestroAPI.ServerConnectionI connection = null;
+ string[] maps = mapdefinitions.Split(',');
+ SetupRun sr = null;
if (!opts.ContainsKey("username") || (!opts.ContainsKey("mapagent")))
if (largs.IndexOf("/commandline") < 0 && largs.IndexOf("commandline") < 0)
@@ -170,6 +173,8 @@
connection = frm.Connection;
mapagent = ((MaestroAPI.HttpServerConnection)connection).ServerURI;
+ sr = new SetupRun(frm.Username, frm.Password, connection, maps, opts);
@@ -184,11 +189,13 @@
- string[] maps = mapdefinitions.Split(',');
if (largs.IndexOf("batch") < 0 && largs.IndexOf("/batch") < 0)
- SetupRun sr = new SetupRun(connection, maps, opts);
+ if (sr == null)
+ sr = new SetupRun(connection, maps, opts);
sr.ShowDialog();
return;
Modified: trunk/Tools/Maestro/MgCooker/RenderThread.cs
--- trunk/Tools/Maestro/MgCooker/RenderThread.cs 2010-05-04 04:51:52 UTC (rev 4822)
+++ trunk/Tools/Maestro/MgCooker/RenderThread.cs 2010-05-04 04:57:34 UTC (rev 4823)
@@ -256,9 +256,17 @@
System.Threading.AutoResetEvent ev = new System.Threading.AutoResetEvent(false);
if (Parent.Connection is HttpServerConnection)
- con = ConnectionFactory.CreateHttpConnection(new Uri(((HttpServerConnection)Parent.Connection).ServerURI), Parent.Connection.SessionID, null, true);
+ HttpServerConnection hc = Parent.Connection as HttpServerConnection;
+ if (hc.IsAnonymous)
+ con = ConnectionFactory.CreateHttpConnection(new Uri(hc.ServerURI), "Anonymous", "", null, true);
+ else
+ con = ConnectionFactory.CreateHttpConnection(new Uri(hc.ServerURI), Parent.Connection.SessionID, null, true);
else
con = ConnectionFactory.CreateLocalNativeConnection(Parent.Connection.SessionID);
while (!Parent.Cancel)
Modified: trunk/Tools/Maestro/MgCooker/SetupRun.cs
--- trunk/Tools/Maestro/MgCooker/SetupRun.cs 2010-05-04 04:51:52 UTC (rev 4822)
+++ trunk/Tools/Maestro/MgCooker/SetupRun.cs 2010-05-04 04:57:34 UTC (rev 4823)
@@ -39,6 +39,12 @@
InitializeComponent();
+ internal SetupRun(string userName, string password, MaestroAPI.ServerConnectionI connection, string[] maps, Dictionary<string, string> args)
+ : this(connection, maps, args)
+ Username.Text = userName;
+ Password.Text = password;
public SetupRun(MaestroAPI.ServerConnectionI connection, string[] maps, Dictionary<string, string> args)
: this()
More information about the mapguide-commits
