[mapguide-commits] r4841 - sandbox/adsk/2.1/Oem/LinuxApt
svn_mapguide at osgeo.org
Wed May 5 18:56:52 EDT 2010
Author: brucedechant
Date: 2010-05-05 18:56:51 -0400 (Wed, 05 May 2010)
New Revision: 4841
Added:
sandbox/adsk/2.1/Oem/LinuxApt/apache-tomcat-6.0.24.tar.gz
Removed:
sandbox/adsk/2.1/Oem/LinuxApt/apache-tomcat-6.0.14.tar.gz
sandbox/adsk/2.1/Oem/LinuxApt/build_apt.sh
sandbox/adsk/2.1/Oem/LinuxApt/server.xml
Upgrade to Tomcat 6.0.24
- Added Tomcat 6.0.24
- Removed Tomcat 6.0.14
- Restored change to server.xml file. ie: Added Java memory leak fix back
- Updated build script
Deleted: sandbox/adsk/2.1/Oem/LinuxApt/apache-tomcat-6.0.14.tar.gz
(Binary files differ)
Added: sandbox/adsk/2.1/Oem/LinuxApt/apache-tomcat-6.0.24.tar.gz
Property changes on: sandbox/adsk/2.1/Oem/LinuxApt/apache-tomcat-6.0.24.tar.gz
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: sandbox/adsk/2.1/Oem/LinuxApt/build_apt.sh
--- sandbox/adsk/2.1/Oem/LinuxApt/build_apt.sh 2010-05-05 15:01:25 UTC (rev 4840)
+++ sandbox/adsk/2.1/Oem/LinuxApt/build_apt.sh 2010-05-05 22:56:51 UTC (rev 4841)
@@ -230,10 +230,10 @@
if [ "$TOMCAT" = "1" ]; then
echo Tomcat install started
-tar -zxf apache-tomcat-6.0.14.tar.gz -C $INSTALLWEB
+tar -zxf apache-tomcat-6.0.24.tar.gz -C $INSTALLWEB
check_tomcat_install
pushd $INSTALLWEB
-mv apache-tomcat-6.0.14 tomcat
+mv apache-tomcat-6.0.24 tomcat
popd
echo Tomcat install completed
Modified: sandbox/adsk/2.1/Oem/LinuxApt/server.xml
--- sandbox/adsk/2.1/Oem/LinuxApt/server.xml 2010-05-05 15:01:25 UTC (rev 4840)
+++ sandbox/adsk/2.1/Oem/LinuxApt/server.xml 2010-05-05 22:56:51 UTC (rev 4841)
@@ -1,3 +1,20 @@
+<?xml version='1.0' encoding='utf-8'?>
+ Licensed to the Apache Software Foundation (ASF) under one or more
+ contributor license agreements. See the NOTICE file distributed with
+ this work for additional information regarding copyright ownership.
+ The ASF licenses this file to You under the Apache License, Version 2.0
+ (the "License"); you may not use this file except in compliance with
+ the License. You may obtain a copy of the License at
+ http://www.apache.org/licenses/LICENSE-2.0
+ Unless required by applicable law or agreed to in writing, software
+ distributed under the License is distributed on an "AS IS" BASIS,
+ WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ See the License for the specific language governing permissions and
+ limitations under the License.
<!-- Note: A "Server" is not itself a "Container", so you may not
define subcomponents such as "Valves" at this level.
Documentation at /docs/config/server.html
@@ -8,6 +25,8 @@
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
<!--Initialize Jasper prior to webapps are loaded. Documentation at /docs/jasper-howto.html -->
<Listener className="org.apache.catalina.core.JasperListener" />
+ <!-- Prevent memory leaks due to use of particular java/javax APIs-->
+ <Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
<!-- JMX Support for the Tomcat server. Documentation at /docs/non-existent.html -->
<Listener className="org.apache.catalina.mbeans.ServerLifecycleListener" />
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
@@ -78,7 +97,7 @@
Documentation at /docs/config/engine.html -->
<!-- You should set jvmRoute to support load-balancing via AJP ie :
- <Engine name="Standalone" defaultHost="localhost" jvmRoute="jvm1">
+ <Engine name="Catalina" defaultHost="localhost" jvmRoute="jvm1">
<Engine name="Catalina" defaultHost="localhost">
More information about the mapguide-commits
