[mapguide-commits] r4842 - in trunk/Tools/Maestro:
Maestro/ResourceEditors MaestroAPI MaestroAPI/Generated
svn_mapguide at osgeo.org
Wed May 5 22:11:15 EDT 2010
Author: jng
Date: 2010-05-05 22:11:14 -0400 (Wed, 05 May 2010)
New Revision: 4842
trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs
trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs
Adding support for WebLayout 1.1.0 schema broke the existing 1.0.0 support (as I feared). This submission restores the 1.0.0 support.
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs 2010-05-05 22:56:51 UTC (rev 4841)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs 2010-05-06 02:11:14 UTC (rev 4842)
@@ -23,6 +23,7 @@
using System.Drawing;
using System.Data;
using System.Windows.Forms;
+using OSGeo.MapGuide.MaestroAPI;
namespace OSGeo.MapGuide.Maestro.ResourceEditors
@@ -156,15 +157,19 @@
: this()
m_editor = editor;
- m_layout = new OSGeo.MapGuide.MaestroAPI.WebLayout();
- m_tempResource = new MaestroAPI.ResourceIdentifier(Guid.NewGuid().ToString(), OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, m_editor.CurrentConnection.SessionID);
//HACK: There's gotta be a cleaner way
if (editor.CurrentConnection.SiteVersion >= new Version(2, 2))
+ m_layout = new OSGeo.MapGuide.MaestroAPI.WebLayout1_1();
chkPing.Enabled = true;
+ else
+ m_layout = new OSGeo.MapGuide.MaestroAPI.WebLayout();
+ m_tempResource = new MaestroAPI.ResourceIdentifier(Guid.NewGuid().ToString(), OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, m_editor.CurrentConnection.SessionID);
UpdateDisplay();
@@ -172,15 +177,32 @@
: this()
m_editor = editor;
- m_layout = editor.CurrentConnection.GetWebLayout(resourceID);
+ m_layout = null;
- if (editor.CurrentConnection.SiteVersion >= new Version(2, 2))
+ byte [] content = editor.CurrentConnection.GetResourceXmlData(resourceID);
+ using (var ms = new System.IO.MemoryStream(content))
- chkPing.Enabled = true;
+ try
+ m_layout = editor.CurrentConnection.DeserializeObject<WebLayout>(ms);
+ catch
+ m_layout = null;
+ if (m_layout == null) //Retry as 1.1.0
+ ms.Position = 0;
+ m_layout = editor.CurrentConnection.DeserializeObject<WebLayout1_1>(ms);
+ m_layout.ResourceId = resourceID;
UpdateDisplay();
@@ -223,9 +245,10 @@
TitleText.Text = m_layout.Title;
//HACK: There's gotta be a better way
- if (m_editor.CurrentConnection.SiteVersion >= new Version(2, 2))
+ WebLayout1_1 wl = m_layout as WebLayout1_1;
+ if (wl != null)
- chkPing.Checked = m_layout.EnablePingServer;
+ chkPing.Checked = wl.EnablePingServer;
MapResource.Text = m_layout.Map.ResourceId;
@@ -1313,12 +1336,13 @@
private void chkPing_CheckedChanged(object sender, EventArgs e)
//HACK: Gotta be a better way
+ var wl = m_layout as WebLayout1_1;
+ if (wl != null)
if (m_isUpdating)
return;
- m_layout.EnablePingServer = chkPing.Checked;
+ wl.EnablePingServer = chkPing.Checked;
m_editor.HasChanged();
@@ -1546,12 +1570,14 @@
LoadedImageList.Images.Add(FixedImages.Images[1]);
string path = System.IO.Path.Combine(Application.StartupPath, "stdicons");
- if (System.IO.Directory.Exists(path))
- foreach(string s in System.IO.Directory.GetFiles(path, "*.gif"))
- LoadedImageList.Images.Add(Image.FromFile(s));
- LoadedImages.Add("../stdicons/" + System.IO.Path.GetFileName(s), LoadedImageList.Images.Count - 1);
+ if (System.IO.Directory.Exists(path))
+ foreach (string s in System.IO.Directory.GetFiles(path, "*.gif"))
+ LoadedImageList.Images.Add(System.Drawing.Image.FromFile(s));
+ LoadedImages.Add("../stdicons/" + System.IO.Path.GetFileName(s), LoadedImageList.Images.Count - 1);
using (System.IO.StringReader sr = new System.IO.StringReader(Properties.Resources.CommandTypesDataset))
Modified: trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs
--- trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs 2010-05-05 22:56:51 UTC (rev 4841)
+++ trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs 2010-05-06 02:11:14 UTC (rev 4842)
@@ -21,23 +21,153 @@
using System.Xml.Serialization;
namespace OSGeo.MapGuide.MaestroAPI
+ [System.Xml.Serialization.XmlRootAttribute("WebLayout", Namespace = "", IsNullable = false)]
+ public class WebLayout1_1 : WebLayout
+ public WebLayout1_1()
+ this.XsdSchema = "WebLayout-1.1.0.xsd";
+ public override string Title
+ get
+ return base.Title;
+ set
+ base.Title = value;
+ public override MapType Map
+ get
+ return base.Map;
+ set
+ base.Map = value;
+ //HACK: We can't bolt on extra properties as new schema versions are published. There's gotta be a cleaner way.
+ //Having ech version as its own class is not pretty either, but it looks like a cleaner way
+ [XmlElement]
+ public bool EnablePingServer
+ get;
+ set;
+ public override ToolBarType ToolBar
+ get
+ return base.ToolBar;
+ set
+ base.ToolBar = value;
+ public override InformationPaneType InformationPane
+ get
+ return base.InformationPane;
+ set
+ base.InformationPane = value;
+ public override ContextMenuType ContextMenu
+ get
+ return base.ContextMenu;
+ set
+ base.ContextMenu = value;
+ public override TaskPaneType TaskPane
+ get
+ return base.TaskPane;
+ set
+ base.TaskPane = value;
+ public override StatusBarType StatusBar
+ get
+ return base.StatusBar;
+ set
+ base.StatusBar = value;
+ public override ZoomControlType ZoomControl
+ get
+ return base.ZoomControl;
+ set
+ base.ZoomControl = value;
+ public override CommandTypeCollection CommandSet
+ get
+ return base.CommandSet;
+ set
+ base.CommandSet = value;
/// <remarks/>
[System.Xml.Serialization.XmlRootAttribute("WebLayout", Namespace="", IsNullable=false)]
public class WebLayout {
- public static readonly string DefaultSchemaName = "WebLayout-1.0.0.xsd";
- private string SchemaName = DefaultSchemaName;
- [System.Xml.Serialization.XmlAttribute("noNamespaceSchemaLocation", Namespace="http://www.w3.org/2001/XMLSchema-instance")]
- public string XsdSchema
- get { return SchemaName; }
- set { SchemaName = value; }
+ // All top-level properties are virtual because newer versions (eg. 1.1.0) introduce new elements
+ // at certain positions in the xml document. XML documents are unfortunately sensitive to ordering/position
+ // and our classes must follow the same order.
+ public WebLayout()
+ this.XsdSchema = "WebLayout-1.0.0.xsd";
+ [System.Xml.Serialization.XmlAttribute("noNamespaceSchemaLocation", Namespace = "http://www.w3.org/2001/XMLSchema-instance")]
+ public string XsdSchema
+ get;
+ set;
private string m_resourceId;
[System.Xml.Serialization.XmlIgnore()]
public string ResourceId
@@ -69,7 +199,7 @@
private CommandTypeCollection m_commandSet;
/// <remarks/>
- public string Title {
+ public virtual string Title {
get {
return this.m_title;
@@ -79,7 +209,7 @@
/// <remarks/>
- public MapType Map {
+ public virtual MapType Map {
get {
return this.m_map;
@@ -88,16 +218,8 @@
- //HACK: We can't bolt on extra properties as new schema versions are published. There's gotta be a cleaner way.
- [XmlElement]
- public bool EnablePingServer
- get;
- set;
/// <remarks/>
- public ToolBarType ToolBar {
+ public virtual ToolBarType ToolBar {
get {
return this.m_toolBar;
@@ -107,7 +229,7 @@
/// <remarks/>
- public InformationPaneType InformationPane {
+ public virtual InformationPaneType InformationPane {
get {
return this.m_informationPane;
@@ -117,7 +239,8 @@
/// <remarks/>
- public ContextMenuType ContextMenu {
+ public virtual ContextMenuType ContextMenu
get {
return this.m_contextMenu;
@@ -127,7 +250,8 @@
/// <remarks/>
- public TaskPaneType TaskPane {
+ public virtual TaskPaneType TaskPane
get {
return this.m_taskPane;
@@ -137,7 +261,8 @@
/// <remarks/>
- public StatusBarType StatusBar {
+ public virtual StatusBarType StatusBar
get {
return this.m_statusBar;
@@ -147,7 +272,8 @@
/// <remarks/>
- public ZoomControlType ZoomControl {
+ public virtual ZoomControlType ZoomControl
get {
return this.m_zoomControl;
@@ -158,7 +284,8 @@
/// <remarks/>
[System.Xml.Serialization.XmlArrayItemAttribute("Command", IsNullable=false)]
- public CommandTypeCollection CommandSet {
+ public virtual CommandTypeCollection CommandSet
get {
return this.m_commandSet;
Modified: trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs
--- trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs 2010-05-05 22:56:51 UTC (rev 4841)
+++ trunk/Tools/Maestro/MaestroAPI/ServerConnectionBase.cs 2010-05-06 02:11:14 UTC (rev 4842)
@@ -1580,11 +1580,6 @@
WebLayout wl = resource as WebLayout;
if (wl != null)
- if (this.SiteVersion >= new Version(2, 2))
- wl.XsdSchema = "WebLayout-1.1.0.xsd";
if (wl.CommandSet != null)
foreach(CommandType cmd in wl.CommandSet)
More information about the mapguide-commits
