[mapguide-commits] r4843 - trunk/Tools/Maestro/MaestroAPI/Schemas
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 6 09:53:16 EDT 2010
Author: jng
Date: 2010-05-06 09:53:15 -0400 (Thu, 06 May 2010)
New Revision: 4843
Added:
   trunk/Tools/Maestro/MaestroAPI/Schemas/LoadProcedure-2.2.0.xsd
   trunk/Tools/Maestro/MaestroAPI/Schemas/SiteInformation-2.2.0.xsd
   trunk/Tools/Maestro/MaestroAPI/Schemas/SiteStatus-2.2.0.xsd
   trunk/Tools/Maestro/MaestroAPI/Schemas/SiteVersion-2.2.0.xsd
   trunk/Tools/Maestro/MaestroAPI/Schemas/SymbolDefinition-1.0.0.xsd
   trunk/Tools/Maestro/MaestroAPI/Schemas/WebLayout-1.1.0.xsd
Add missing xml schema files
Added: trunk/Tools/Maestro/MaestroAPI/Schemas/LoadProcedure-2.2.0.xsd
--- trunk/Tools/Maestro/MaestroAPI/Schemas/LoadProcedure-2.2.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Schemas/LoadProcedure-2.2.0.xsd	2010-05-06 13:53:15 UTC (rev 4843)
@@ -0,0 +1,391 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="2.2.0">
+  <xs:element name="LoadProcedure">
+    <xs:annotation>
+      <xs:documentation>Specification of a load procedure</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+      <xs:complexContent>
+        <xs:extension base="LoadProcedureTypeType">
+          <xs:attribute name="version" type="xs:string" fixed="2.2.0"/>
+        </xs:extension>
+      </xs:complexContent>
+    </xs:complexType>
+  </xs:element>
+  <xs:complexType name="LoadProcedureTypeType">
+    <xs:annotation>
+    </xs:annotation>
+    <xs:choice>
+      <xs:element name="SdfLoadProcedure" type="SdfLoadProcedureType">
+        <xs:annotation>
+          <xs:documentation>Load procedure for SDFs</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DwfLoadProcedure" type="DwfLoadProcedureType">
+        <xs:annotation>
+          <xs:documentation>Load procedure for DWFs</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ShpLoadProcedure" type="ShpLoadProcedureType">
+        <xs:annotation>
+          <xs:documentation>Load procedure for SHPs</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DwgLoadProcedure" type="DwgLoadProcedureType"/>
+      <xs:element name="RasterLoadProcedure" type="RasterLoadProcedureType"/>
+      <xs:element name="SQLiteLoadProcedure" type="SQLiteLoadProcedureType">
+        <xs:annotation>
+          <xs:documentation>Load procedure for SQLites</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:choice>
+  </xs:complexType>
+  <xs:complexType name="LoadProcedureType">
+    <xs:annotation>
+      <xs:documentation>Base type of the load procedures</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="SourceFile" type="xs:string" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>The list of input files for the load procedure</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="RootPath" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The path in the site repository where the resources are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="CoordinateSystem" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The default coordinate system to assign to the resulting data resources if none is found</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="GenerateSpatialDataSources" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Indicates whether or not to generate spatial data sources</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="SpatialDataSourcesPath" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The path to the folder in the site repository where the spatial data sources are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="SpatialDataSourcesFolder" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The folder in the site repository under the Spatial Data Sources Path where the spatial data sources are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="GenerateLayers" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Indicates whether or not to generate layers</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LayersPath" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The path to the folder in the site repository where the layers are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LayersFolder" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The folder in the site repository under the Layers Path where the layers are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="GenerateMaps" type="xs:boolean" minOccurs="0" maxOccurs="1">
+        <xs:annotation>
+          <xs:documentation>Indicates whether or not to generate maps</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MapsPath" type="xs:string" minOccurs="0" maxOccurs="1">
+        <xs:annotation>
+          <xs:documentation>The path to the folder in the site repository where the maps are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="MapsFolder" type="xs:string" minOccurs="0" maxOccurs="1">
+        <xs:annotation>
+          <xs:documentation>The folder in the site repository under the Maps Path where the maps are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="GenerateSymbolLibraries" type="xs:boolean" minOccurs="0" maxOccurs="1">
+        <xs:annotation>
+          <xs:documentation>Indicates whether or not to generate symbol libraries</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="SymbolLibrariesPath" type="xs:string" minOccurs="0" maxOccurs="1">
+        <xs:annotation>
+          <xs:documentation>The path to the folder in the site repository where the symbol libraries are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="SymbolLibrariesFolder" type="xs:string" minOccurs="0" maxOccurs="1">
+        <xs:annotation>
+          <xs:documentation>The folder in the site repository under the Symbol Libraries Path where the symbol libraries are created</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ResourceId" type="xs:string" minOccurs="0" maxOccurs="unbounded">
+        <xs:annotation>
+          <xs:documentation>Zero or more ResourceIds that were created from the execution of the load procedure</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="SdfLoadProcedureType">
+    <xs:annotation>
+      <xs:documentation>Extension of LoadProcedure for SDFs</xs:documentation>
+    </xs:annotation>
+      <xs:extension base="LoadProcedureType">
+        <xs:sequence>
+          <xs:element name="Generalization" type="PercentageType">
+            <xs:annotation>
+              <xs:documentation>Reduces the point (or vertex) count of each map feature to the specified percentage of the original count</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="SdfKeyTreatment" type="SdfKeyTreatmentType">
+            <xs:annotation>
+              <xs:documentation>Specifies how the Sdf conversion step of an SdfLoadProcedure treats keys</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:simpleType name="SdfKeyTreatmentType">
+    <xs:annotation>
+    </xs:annotation>
+    <xs:restriction base="xs:string">
+      <xs:enumeration value="AutogenerateAll">
+        <xs:annotation>
+          <xs:documentation>All keys in the original Sdf file are replaced in the converted Sdf file by an automatically generated unique key</xs:documentation>
+        </xs:annotation>
+      </xs:enumeration>
+      <xs:enumeration value="DiscardDuplicates">
+        <xs:annotation>
+          <xs:documentation>The keys in the original Sdf file are maintaind in the converted Sdf file, and only the first occurance of a feature associated with a duplicate key in the original Sdf file will be written to the converted Sdf file</xs:documentation>
+        </xs:annotation>
+      </xs:enumeration>
+      <xs:enumeration value="MergeDuplicates">
+        <xs:annotation>
+          <xs:documentation>The keys in the original Sdf file are maintaind in the converted Sdf file, and all of the features associated with a duplicate key in the original Sdf file will be merged into a single feature in the converted Sdf file</xs:documentation>
+        </xs:annotation>
+      </xs:enumeration>
+    </xs:restriction>
+  </xs:simpleType>
+    <xs:complexType name="SQLiteLoadProcedureType">
+        <xs:annotation>
+            <xs:documentation>Extension of LoadProcedure for SQLites</xs:documentation>
+        </xs:annotation>
+                <xs:sequence>
+                        <xs:annotation>
+                        </xs:annotation>
+                    </xs:element>
+                </xs:sequence>
+            </xs:extension>
+    </xs:complexType>
+    <xs:simpleType name="OverlapTreatmentType">
+    <xs:annotation>
+      <xs:documentation>Specifies how to treat edge overlap when merging bitonal images.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="None">
+        <xs:annotation>
+          <xs:documentation>No bitonal merge.</xs:documentation>
+        </xs:annotation>
+      </xs:enumeration>
+      <xs:enumeration value="ForegroundOn">
+        <xs:annotation>
+          <xs:documentation>Forground pixels are the on bits.</xs:documentation>
+        </xs:annotation>
+      </xs:enumeration>
+      <xs:enumeration value="ForegroundOff">
+        <xs:annotation>
+          <xs:documentation>Forground pixels are the off bits.</xs:documentation>
+        </xs:annotation>
+      </xs:enumeration>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:complexType name="DwfLoadProcedureType">
+    <xs:annotation>
+      <xs:documentation>Extension of LoadProcedure for DWFs</xs:documentation>
+    </xs:annotation>
+      <xs:extension base="LoadProcedureType"/>
+  </xs:complexType>
+  <xs:complexType name="ShpLoadProcedureType">
+    <xs:annotation>
+      <xs:documentation>Extension of LoadProcedure for SHPs</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+            <xs:annotation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="ConvertToSdf" type="xs:boolean">
+            <xs:annotation>
+              <xs:documentation>Indicates whether or not to convert to an SDF feature source</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="GeoReferenceOverrideType">
+    <xs:annotation>
+      <xs:documentation>Override values to replace geo reference properties from the world file corresponding to the specified image source file.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="SourceFile" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The path of the source file to which these geo reference overrides apply.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LocationX" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>The X-coordinate override of the location specified in the world file corresponding to the specified source file.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LocationY" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>The Y-coordinate override of the location specified in the world file corresponding to the specified source file.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ScaleX" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>the X-scale override to replace that specified in the world file corresponding to the specified source file.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ScaleY" type="xs:double">
+        <xs:annotation>
+          <xs:documentation>the Y-scale override to replace that specified in the world file corresponding to the specified source file.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="RasterLoadProcedureType">
+    <xs:annotation>
+    </xs:annotation>
+        <xs:sequence>
+          <xs:element name="FeatureSourceName" type="xs:string">
+            <xs:annotation>
+              <xs:documentation>The base name of the FeatureSource to load.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="SubsampleFactor" type="xs:double">
+            <xs:annotation>
+              <xs:documentation>Subsample factor for reducing file size.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="OverlapTreatmentType" type="OverlapTreatmentType">
+            <xs:annotation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="GeoReferenceOverride" type="GeoReferenceOverrideType" minOccurs="0" maxOccurs="unbounded">
+            <xs:annotation>
+              <xs:documentation>The list of geo reference overrides.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:simpleType name="PercentageType">
+    <xs:annotation>
+      <xs:documentation>A percentage value</xs:documentation>
+    </xs:annotation>
+    <xs:restriction base="xs:double">
+      <xs:minInclusive value="0"/>
+      <xs:maxInclusive value="100"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:complexType name="DwgLoadProcedureType">
+    <xs:annotation>
+      <xs:documentation>Extension of LoadProcedure for DWGs and DXFs</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+          <xs:element name="FileComponents">
+            <xs:annotation>
+              <xs:documentation>List of DWG files and their layers to be extracted, whether selected or not.</xs:documentation>
+            </xs:annotation>
+            <xs:complexType>
+              <xs:sequence>
+                <xs:element name="FileComponent" type="DwgFileComponentType" maxOccurs="unbounded">
+                  <xs:annotation>
+                    <xs:documentation>One DWG file and its layers</xs:documentation>
+                  </xs:annotation>
+                </xs:element>
+              </xs:sequence>
+            </xs:complexType>
+          </xs:element>
+            <xs:annotation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="ClosedPolylinesToPolygons" type="xs:boolean">
+            <xs:annotation>
+              <xs:documentation>Indicates whether to convert closed polyline features to polygons</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="DwgFileComponentType">
+    <xs:annotation>
+      <xs:documentation>Specifies a DWG file and its list of layers</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="Name" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The name of the DWG file</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LayerComponents">
+        <xs:annotation>
+          <xs:documentation>List of DWG layers</xs:documentation>
+        </xs:annotation>
+        <xs:complexType>
+          <xs:sequence>
+            <xs:element name="LayerComponent" type="DwgLayerComponentType" maxOccurs="unbounded">
+              <xs:annotation>
+                <xs:documentation>One DWG layer</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+          </xs:sequence>
+        </xs:complexType>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="DwgLayerComponentType">
+    <xs:annotation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The name of the layer</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Selected" type="xs:boolean">
+        <xs:annotation>
+          <xs:documentation>Indicates whether this layer is to be extracted when executing the Load Procedure</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+</xs:schema>
Added: trunk/Tools/Maestro/MaestroAPI/Schemas/SiteInformation-2.2.0.xsd
--- trunk/Tools/Maestro/MaestroAPI/Schemas/SiteInformation-2.2.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Schemas/SiteInformation-2.2.0.xsd	2010-05-06 13:53:15 UTC (rev 4843)
@@ -0,0 +1,157 @@
+  <xs:element name="SiteInformation">
+    <xs:annotation>
+      <xs:documentation>Site Information</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="SiteInformationType">
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+    <xs:complexType name="SiteInformationType">
+      <xs:sequence>
+        <xs:element name="Server">
+          <xs:complexType>
+            <xs:sequence>
+              <xs:element name="IpAddress" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's Ip address.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="DisplayName" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's display name.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="Status" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's status. Either Online or Offline</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="Version" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's version.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="OperatingSystem">
+                <xs:complexType>
+                  <xs:sequence>
+                    <xs:element name="AvailablePhysicalMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The available physical memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalPhysicalMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total physical memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="AvailableVirtualMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The available virtual memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalVirtualMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total virtual memory for the operating system in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                      <xs:annotation>
+                          <xs:documentation>The operating system version.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                  </xs:sequence>
+                </xs:complexType>
+              </xs:element>
+              <xs:element name="Statistics">
+                <xs:complexType>
+                  <xs:sequence>
+                    <xs:element name="AdminOperationsQueueCount" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of operations in the Admin queue.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="ClientOperationsQueueCount" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of operations in the Client queue.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="SiteOperationsQueueCount" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of operations in the Site queue.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="AverageOperationTime" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The average time it takes to process an operation in milliseconds.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="CpuUtilization" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The cpu utilization as a percentage.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="WorkingSet" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The working set memory of the MapGuide server in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="VirtualMemory" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The virtual memory of the MapGuide server in bytes.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalOperationTime" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total operation time of the MapGuide server in seconds.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="ActiveConnections" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The number of active connections to the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalConnections" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of connections that have been made to the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalOperationsProcessed" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of operations processed by the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="TotalOperationsReceived" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of operations received by the MapGuide server.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="Uptime" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total time the MapGuide server has been running in seconds.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="CacheSize" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The current number of entries in the MapGuide server cache.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                    <xs:element name="CacheDroppedEntries" type="xs:integer">
+                      <xs:annotation>
+                        <xs:documentation>The total number of entries in the MapGuide server cache that have been dropped.</xs:documentation>
+                      </xs:annotation>
+                    </xs:element>
+                  </xs:sequence>
+                </xs:complexType>
+              </xs:element>
+            </xs:sequence>
+          </xs:complexType>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Added: trunk/Tools/Maestro/MaestroAPI/Schemas/SiteStatus-2.2.0.xsd
--- trunk/Tools/Maestro/MaestroAPI/Schemas/SiteStatus-2.2.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Schemas/SiteStatus-2.2.0.xsd	2010-05-06 13:53:15 UTC (rev 4843)
@@ -0,0 +1,40 @@
+    <xs:annotation>
+      <xs:documentation>Site Status</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="SiteStatusType">
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+    <xs:complexType name="SiteStatusType">
+      <xs:sequence>
+          <xs:complexType>
+            <xs:sequence>
+                <xs:annotation>
+                </xs:annotation>
+              </xs:element>
+                <xs:annotation>
+                </xs:annotation>
+              </xs:element>
+              <xs:element name="ApiVersion" type="xs:string">
+                <xs:annotation>
+                  <xs:documentation>The MapGuide server's API version.</xs:documentation>
+                </xs:annotation>
+              </xs:element>
+            </xs:sequence>
+          </xs:complexType>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Added: trunk/Tools/Maestro/MaestroAPI/Schemas/SiteVersion-2.2.0.xsd
--- trunk/Tools/Maestro/MaestroAPI/Schemas/SiteVersion-2.2.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Schemas/SiteVersion-2.2.0.xsd	2010-05-06 13:53:15 UTC (rev 4843)
@@ -0,0 +1,30 @@
+  <xs:element name="SiteVersion">
+    <xs:annotation>
+      <xs:documentation>Site Version</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="SiteVersionType">
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+    <xs:complexType name="SiteVersionType">
+      <xs:sequence>
+          <xs:complexType>
+            <xs:sequence>
+                <xs:annotation>
+                </xs:annotation>
+              </xs:element>
+            </xs:sequence>
+          </xs:complexType>
+        </xs:element>
+      </xs:sequence>
+    </xs:complexType>
+</xs:schema>
Added: trunk/Tools/Maestro/MaestroAPI/Schemas/SymbolDefinition-1.0.0.xsd
--- trunk/Tools/Maestro/MaestroAPI/Schemas/SymbolDefinition-1.0.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Schemas/SymbolDefinition-1.0.0.xsd	2010-05-06 13:53:15 UTC (rev 4843)
@@ -0,0 +1,763 @@
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified" version="1.0.0">
+  <xs:include schemaLocation="PlatformCommon-1.0.0.xsd"/>
+  <xs:element name="SimpleSymbolDefinition">
+    <xs:annotation>
+      <xs:documentation>A 2D simple symbol for stylization.</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="SimpleSymbolDefinition">
+          <xs:attribute name="version" type="xs:string" use="required" fixed="1.0.0"/>
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+  <xs:element name="CompoundSymbolDefinition">
+    <xs:annotation>
+      <xs:documentation>A 2D compound symbol for stylization.</xs:documentation>
+    </xs:annotation>
+    <xs:complexType>
+        <xs:extension base="CompoundSymbolDefinition">
+        </xs:extension>
+    </xs:complexType>
+  </xs:element>
+  <xs:complexType name="SymbolDefinitionBase">
+    <xs:annotation>
+      <xs:documentation>Base type used with all symbol definitions.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The name of the symbol.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Description" type="xs:string" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>An optional description of the symbol.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="ResizeBox">
+    <xs:annotation>
+      <xs:documentation>Defines a resize box used with SimpleSymbolDefinitions.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="SizeX" type="xs:string" default="1.0">
+        <xs:annotation>
+          <xs:documentation>The initial width of the resize box, in mm.  This must be greater than or equal to zero.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="SizeY" type="xs:string" default="1.0">
+        <xs:annotation>
+          <xs:documentation>The initial height of the resize box, in mm.  This must be greater than or equal to zero.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="PositionX" type="xs:string" default="0.0">
+        <xs:annotation>
+          <xs:documentation>The initial x-coordinate of the resize box center, in mm.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="PositionY" type="xs:string" default="0.0">
+        <xs:annotation>
+          <xs:documentation>The initial y-coordinate of the resize box center, in mm.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="GrowControl" type="xs:string" default="'GrowInXYMaintainAspect'">
+        <xs:annotation>
+          <xs:documentation>Specifies how the resize box grows in size.  This must evaluate to one of: GrowInX, GrowInY, GrowInXY, or GrowInXYMaintainAspect (default).</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ExtendedData1" type="ExtendedDataType" minOccurs="0"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="PointUsage">
+    <xs:annotation>
+      <xs:documentation>Specifies how a symbol is used in the context of point features.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="AngleControl" type="xs:string" default="'FromAngle'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies how the symbol angle is defined.  This must evaluate to one of: FromAngle (default) or FromGeometry.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Angle" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the symbol angle, in degrees.  Only applies if AngleControl evaluates to FromAngle.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OriginOffsetX" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the horizontal offset to apply to the symbol origin, in mm.  This offset is applied before the symbol is scaled and rotated.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OriginOffsetY" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the vertical offset to apply to the symbol origin, in mm.  This offset is applied before the symbol is scaled and rotated.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="LineUsage">
+    <xs:annotation>
+      <xs:documentation>Specifies how a symbol is used in the context of linear features.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="AngleControl" type="xs:string" default="'FromGeometry'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies how the symbol angle is defined.  This must evaluate to one of: FromAngle or FromGeometry (default).</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="UnitsControl" type="xs:string" default="'Absolute'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies whether the distribution parameters are interpreted as absolute values (in mm) or parametric values.  This must evaluate to one of: Absolute (default) or Parametric.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="VertexControl" type="xs:string" default="'OverlapNone'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the symbol behavior at vertices.  This must evaluate to one of: OverlapNone (default), OverlapDirect, OverlapNoWrap, or OverlapWrap.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="StartOffset" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies where the symbol distribution begins, relative to the start of the feature.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="EndOffset" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies where the symbol distribution ends, relative to the end of the feature.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="Repeat" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the separation between repeating symbols.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="VertexAngleLimit" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the limiting angle, in degrees, by a which the feature geometry can change before some of the VertexControl options take effect.  If specified this must be greater than or equal to zero.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="VertexJoin" type="xs:string" default="'Round'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the wrapping behavior at vertices for all graphic elements.  Only applies if VertexControl evaluates to OverlapWrap.  This must evaluate to one of: None, Bevel, Round (default), or Miter.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="VertexMiterLimit" type="xs:string" default="5.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The limit to use when drawing miter vertex joins.  A miter vertex join is trimmed if the ratio of the miter length to symbol height is greater than the miter limit.  If specified this must be greater than zero.  Defaults to 5.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DefaultPath" type="Path" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the default path attributes to use when drawing the symbol.  These apply to any centerline that gets drawn where the symbol can't draw, and to path elements that don't specify attributes.  The geometry contained in this path is ignored and should be empty.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="AreaUsage">
+    <xs:annotation>
+      <xs:documentation>Specifies how a symbol is used in the context of area features.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OriginControl" type="xs:string" default="'Global'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies how the symbol grid origin is defined.  This must evaluate to one of: Global (default), Local, or Centroid.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="ClippingControl" type="xs:string" default="'Clip'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies the clipping behavior of the symbol at polygon boundaries.  This must evaluate to one of: Clip (default), Inside, or Overlap.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>Specifies the angle of each repeating symbol, in degrees.  Only applies if AngleControl evaluates to FromAngle.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OriginX" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The x-coordinate of the symbol grid origin, in mm.  Only applies if OriginControl evaluates to Global or Local.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OriginY" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The y-coordinate of the symbol grid origin, in mm.  Only applies if OriginControl evaluates to Global or Local.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="RepeatX" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The horizontal separation between symbols, in mm.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="RepeatY" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The vertical separation between symbols, in mm.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="BufferWidth" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The width, in mm, of the buffer zone relative to the polygon boundary in which the symbol is rendered.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="Parameter">
+    <xs:annotation>
+      <xs:documentation>The metadata for a symbol parameter.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="Identifier" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The parameter identifier as used in the symbol.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DefaultValue" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The default value of the parameter if no override is defined in the symbol instance.  This can be an expression.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DisplayName" type="xs:string" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>An optional short description of the parameter.  This can be used, for example, to ask the user to specify a parameter value.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>An optional long description of the parameter.  This might include a description of useful values for this parameter.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="DataType" type="DataType" default="String" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>An optional data type declaration for the parameter.  This is a hint used by the UI when assigning a value to this parameter.  Defaults to String.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="ParameterDefinition">
+    <xs:annotation>
+      <xs:documentation>A collection of symbol parameters.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="Parameter" type="Parameter" minOccurs="0" maxOccurs="unbounded"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="SimpleSymbol">
+    <xs:annotation>
+      <xs:documentation>Defines a reference to a SimpleSymbolDefinition, either inlined or a library reference.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:choice>
+        <xs:element name="SimpleSymbolDefinition" type="SimpleSymbolDefinition">
+          <xs:annotation>
+            <xs:documentation>An inlined SimpleSymbolDefinition.</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+        <xs:element name="ResourceId" type="xs:string">
+          <xs:annotation>
+            <xs:documentation>A library reference to an existing SimpleSymbolDefinition.</xs:documentation>
+          </xs:annotation>
+        </xs:element>
+      </xs:choice>
+      <xs:element name="RenderingPass" type="xs:string" default="0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The optional rendering pass in which this symbol definition draws.  If specified this must be greater than or equal to zero.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="SimpleSymbolDefinition">
+    <xs:annotation>
+      <xs:documentation>A symbol definition containing a collection of graphic elements and information on how to use these in the context of different feature geometry types.</xs:documentation>
+    </xs:annotation>
+      <xs:extension base="SymbolDefinitionBase">
+        <xs:sequence>
+          <xs:element name="Graphics" type="Graphics">
+            <xs:annotation>
+              <xs:documentation>The collection of graphic elements defining this symbol.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="ResizeBox" type="ResizeBox" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The optional box used to resize and reposition select graphic elements.  The graphical extent of all elements with ResizeControl set to AddToResizeBox will be added to this box, potentially causing it to grow in size.  Any change in size causes all elements with ResizeControl set to AdjustToResizeBox to be proportionally resized and repositioned.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="PointUsage" type="PointUsage" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Specifies how the symbol is used in the context of point features.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineUsage" type="LineUsage" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Specifies how the symbol is used in the context of linear features.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="AreaUsage" type="AreaUsage" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Specifies how the symbol is used in the context of area features.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="ParameterDefinition" type="ParameterDefinition">
+            <xs:annotation>
+              <xs:documentation>The list of parameters used in this symbol.  If a parameter is not listed here this is considered a bug in the symbol definition.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="CompoundSymbolDefinition">
+    <xs:annotation>
+      <xs:documentation>A symbol definition specified using a collection of SimpleSymbolDefinition elements or references.</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+          <xs:element name="SimpleSymbol" type="SimpleSymbol" minOccurs="0" maxOccurs="unbounded"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="Graphics">
+    <xs:annotation>
+      <xs:documentation>A collection of graphic elements.</xs:documentation>
+    </xs:annotation>
+    <xs:choice minOccurs="0" maxOccurs="unbounded">
+      <xs:element name="Path" type="Path"/>
+      <xs:element name="Image" type="Image"/>
+      <xs:element name="Text" type="Text"/>
+    </xs:choice>
+  </xs:complexType>
+  <xs:complexType name="GraphicBase">
+    <xs:annotation>
+      <xs:documentation>Base type used with all graphic elements.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+      <xs:element name="ResizeControl" type="xs:string" default="'ResizeNone'" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>Specifies how this graphic element interacts with the resize box.  This must evaluate to one of: ResizeNone (default), AddToResizeBox, or AdjustToResizeBox.  AddToResizeBox means the element's graphical extent is added to the resize box, but the element is not resized or repositioned if the resize box grows.  AdjustToResizeBox means the element is resized and repositioned relative to the resize box, but its extent is not added to the box.  ResizeNone means the element does not interact with the resize box.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="Path">
+    <xs:annotation>
+      <xs:documentation>A 2D path defining vector geometry to include in the symbol definition.</xs:documentation>
+    </xs:annotation>
+      <xs:extension base="GraphicBase">
+        <xs:sequence>
+          <xs:element name="Geometry" type="xs:string">
+            <xs:annotation>
+              <xs:documentation>The path geometry.  The format is a sequence of segments, each represented by a letter indicating the segment type followed by one or more parameters.  Uppercase letters denote absolute values and lowercase letters denote relative values.  Segment types can be one of "M" (moveto), "L" (lineto), "H" (horizontal lineto), "V" (vertical lineto), "A" (arcto), or "Z" (close segment).</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="FillColor" type="xs:string" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The ARGB color used to fill the path.  If this element is missing or empty then no fill is applied to the path.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineColor" type="xs:string" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The ARGB color used to draw the path outline.  If this element is missing or empty then no path outline is drawn.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineWeight" type="xs:string" default="0.0" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The weight to use when drawing the path outline, in mm.  If specified this must be greater than or equal to zero.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineWeightScalable" type="xs:string" default="true" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Boolean value which specifies whether the line weight scales with the symbol.  This behavior is independent of the symbol's size context.  This must evaluate to True (default) or False.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineCap" type="xs:string" default="'Round'" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The cap type to use at the ends of each segment in the path outline.  This must evaluate to one of: None, Round (default), Triangle, or Square.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineJoin" type="xs:string" default="'Round'" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The join type to use at each vertex in the path outline.  This must evaluate to one of: None, Bevel, Round (default), or Miter.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineMiterLimit" type="xs:string" default="5.0" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The limit to use when drawing miter joins.  A miter join is trimmed if the ratio of the miter length to line weight is greater than the miter limit.  If specified this must be greater than zero.  Defaults to 5.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="ImageReference">
+    <xs:annotation>
+      <xs:documentation>Defines a library reference used with image elements.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The resource where the image data is stored.  For non-inlined symbol definitions this can be an empty string, in which case the resource is assumed to be the parent symbol definition resource.  For inlined symbol definitions this must point to a separate resource.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="LibraryItemName" type="xs:string">
+        <xs:annotation>
+          <xs:documentation>The name of the resource data storing the image.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="Image">
+    <xs:annotation>
+      <xs:documentation>An image to include in the symbol definition.</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+          <xs:choice>
+            <xs:element name="Content" type="xs:base64Binary">
+              <xs:annotation>
+                <xs:documentation>An embedded PNG image stored using base64 binary.</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+            <xs:element name="Reference" type="ImageReference">
+              <xs:annotation>
+                <xs:documentation>A library reference to a PNG image.</xs:documentation>
+              </xs:annotation>
+            </xs:element>
+          </xs:choice>
+            <xs:annotation>
+              <xs:documentation>The width of the image, in mm.  This must be greater than zero.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+            <xs:annotation>
+              <xs:documentation>The height of the image, in mm.  This must be greater than zero.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="SizeScalable" type="xs:string" default="true" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Boolean value which specifies whether the image sizes scale with the symbol.  This behavior is independent of the symbol's size context.  This must evaluate to True (default) or False.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+            <xs:annotation>
+              <xs:documentation>The angle of the image in symbol space, in degrees.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="PositionX" type="xs:string" default="0.0" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The x-coordinate of the image center in symbol space, in mm.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="PositionY" type="xs:string" default="0.0" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The y-coordinate of the image center in symbol space, in mm.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="TextFrame">
+    <xs:annotation>
+      <xs:documentation>Defines a frame used with text elements.</xs:documentation>
+    </xs:annotation>
+    <xs:sequence>
+        <xs:annotation>
+          <xs:documentation>The ARGB color used to draw the text frame border.  If this element is missing or empty then no frame border is drawn.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+        <xs:annotation>
+          <xs:documentation>The ARGB color used to fill the text frame.  If this element is missing or empty then no fill is drawn.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OffsetX" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The additional horizontal offset of the frame relative to the text box, in mm.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+      <xs:element name="OffsetY" type="xs:string" default="0.0" minOccurs="0">
+        <xs:annotation>
+          <xs:documentation>The additional vertical offset of the frame relative to the text box, in mm.  Defaults to 0.</xs:documentation>
+        </xs:annotation>
+      </xs:element>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="Text">
+    <xs:annotation>
+      <xs:documentation>A text string to include in the symbol definition.</xs:documentation>
+    </xs:annotation>
+        <xs:sequence>
+          <xs:element name="Content" type="xs:string">
+            <xs:annotation>
+              <xs:documentation>The string content for the text.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="FontName" type="xs:string" default="'Arial'">
+            <xs:annotation>
+              <xs:documentation>The name of the font to use for the text.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Bold" type="xs:string" default="false" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Specifies if the text should be drawn using a bold font.  This must evaluate to True or False (default).</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Italic" type="xs:string" default="false" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Specifies if the text should be drawn using an italic font.  This must evaluate to True or False (default).</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Underlined" type="xs:string" default="false" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Specifies if the text should be underlined.  This must evaluate to True or False (default).</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Height" type="xs:string" default="4.0" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The height of the text, in mm.  If specified this must be greater than zero.  Defaults to 4.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="HeightScalable" type="xs:string" default="true" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>Boolean value which specifies whether the font height scales with the symbol.  This behavior is independent of the symbol's size context.  This must evaluate to True (default) or False.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+            <xs:annotation>
+              <xs:documentation>The angle of the text in symbol space, in degrees.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+            <xs:annotation>
+              <xs:documentation>The x-coordinate of the text in symbol space, in mm.  Horizontal alignment of the text box is relative to this coordinate.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+            <xs:annotation>
+              <xs:documentation>The y-coordinate of the text in symbol space, in mm.  Vertical alignment of the text box is relative to this coordinate.  Defaults to 0.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="HorizontalAlignment" type="xs:string" default="'Center'" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The horizontal alignment of the text box relative to its position.  This must evaluate to one of: Left, Center (default), or Right.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="VerticalAlignment" type="xs:string" default="'Halfline'" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The vertical alignment of the text box relative to its position.  This must evaluate to one of: Bottom, Baseline, Halfline (default), Capline, or Top.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Justification" type="xs:string" default="'FromAlignment'" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The horizontal justification of individual lines of text in a multi-line text string.  This must evaluate to one of: Left, Center, Right, Justified, or FromAlignment (default).</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="LineSpacing" type="xs:string" default="1.05" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The spacing between individual lines of text in a multi-line text string, as a multiple of the font height.  If specified this must be greater than zero.  Defaults to 1.05.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="TextColor" type="xs:string" default="ff000000" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The ARGB color used to draw the text.  Defaults to black (ff000000).</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="GhostColor" type="xs:string" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>The ARGB color used to draw the ghosted text.  If this element is missing or empty then no ghosting is drawn.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+          <xs:element name="Frame" type="TextFrame" minOccurs="0">
+            <xs:annotation>
+              <xs:documentation>If specified, defines the kind of frame drawn around the text.</xs:documentation>
+            </xs:annotation>
+          </xs:element>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:simpleType name="GrowControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed GrowControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="GrowInX"/>
+      <xs:enumeration value="GrowInY"/>
+      <xs:enumeration value="GrowInXY"/>
+      <xs:enumeration value="GrowInXYMaintainAspect"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="AngleControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed AngleControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="FromAngle"/>
+      <xs:enumeration value="FromGeometry"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="UnitsControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed UnitsControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Absolute"/>
+      <xs:enumeration value="Parametric"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="VertexControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed VertexControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="OverlapNone"/>
+      <xs:enumeration value="OverlapDirect"/>
+      <xs:enumeration value="OverlapNoWrap"/>
+      <xs:enumeration value="OverlapWrap"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="VertexJoin">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed VertexJoin values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="None"/>
+      <xs:enumeration value="Bevel"/>
+      <xs:enumeration value="Round"/>
+      <xs:enumeration value="Miter"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="OriginControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed OriginControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Global"/>
+      <xs:enumeration value="Local"/>
+      <xs:enumeration value="Centroid"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="ClippingControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed ClippingControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Clip"/>
+      <xs:enumeration value="Inside"/>
+      <xs:enumeration value="Overlap"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="ResizeControl">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed ResizeControl values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="ResizeNone"/>
+      <xs:enumeration value="AddToResizeBox"/>
+      <xs:enumeration value="AdjustToResizeBox"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="LineCap">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed LineCap values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Triangle"/>
+      <xs:enumeration value="Square"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="LineJoin">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed LineJoin values.</xs:documentation>
+    </xs:annotation>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="HorizontalAlignment">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed HorizontalAlignment values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Left"/>
+      <xs:enumeration value="Center"/>
+      <xs:enumeration value="Right"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="VerticalAlignment">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed VerticalAlignment values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Bottom"/>
+      <xs:enumeration value="Baseline"/>
+      <xs:enumeration value="Halfline"/>
+      <xs:enumeration value="Capline"/>
+      <xs:enumeration value="Top"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="Justification">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed Justification values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="Justified"/>
+      <xs:enumeration value="FromAlignment"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:simpleType name="DataType">
+    <xs:annotation>
+      <xs:documentation>Enumerates the allowed DataType values.</xs:documentation>
+    </xs:annotation>
+      <xs:enumeration value="String"/>
+      <xs:enumeration value="Boolean"/>
+      <xs:enumeration value="Integer"/>
+      <xs:enumeration value="Real"/>
+      <xs:enumeration value="Color"/>
+    </xs:restriction>
+  </xs:simpleType>
+</xs:schema>
Added: trunk/Tools/Maestro/MaestroAPI/Schemas/WebLayout-1.1.0.xsd
--- trunk/Tools/Maestro/MaestroAPI/Schemas/WebLayout-1.1.0.xsd	                        (rev 0)
+++ trunk/Tools/Maestro/MaestroAPI/Schemas/WebLayout-1.1.0.xsd	2010-05-06 13:53:15 UTC (rev 4843)
@@ -0,0 +1,343 @@
+<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema" elementFormDefault="qualified" attributeFormDefault="unqualified">
+  <xs:element name="WebLayout" type="WebLayoutType"/>
+  <xs:complexType name="WebLayoutType">
+    <xs:sequence>
+      <xs:element name="Title" type="xs:string"/>
+      <xs:element name="Map" type="MapType"/>
+      <xs:element name="EnablePingServer" type="xs:boolean" minOccurs="0" />
+      <xs:element name="ToolBar" type="ToolBarType"/>
+      <xs:element name="InformationPane" type="InformationPaneType"/>
+      <xs:element name="ContextMenu" type="ContextMenuType"/>
+      <xs:element name="TaskPane" type="TaskPaneType"/>
+      <xs:element name="StatusBar" type="StatusBarType"/>
+      <xs:element name="ZoomControl" type="ZoomControlType"/>
+      <xs:element name="CommandSet" type="CommandSetType"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="ResourceReferenceType">
+    <xs:sequence>
+      <xs:element name="ResourceId" type="xs:string"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="MapType">
+      <xs:extension base="ResourceReferenceType">
+        <xs:sequence>
+          <xs:element name="InitialView" type="MapViewType" minOccurs="0"/>
+          <xs:element name="HyperlinkTarget" type="TargetType"/>
+          <xs:element name="HyperlinkTargetFrame" type="xs:string" minOccurs="0"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="WebLayoutControlType">
+    <xs:sequence>
+      <xs:element name="Visible" type="xs:boolean"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="WebLayoutResizableControlType">
+      <xs:extension base="WebLayoutControlType">
+        <xs:sequence>
+          <xs:element name="Width" type="xs:int"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="ToolBarType">
+        <xs:sequence>
+          <xs:element name="Button" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="ContextMenuType">
+        <xs:sequence>
+          <xs:element name="MenuItem" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="StatusBarType">
+      <xs:extension base="WebLayoutControlType"/>
+  </xs:complexType>
+  <xs:complexType name="ZoomControlType">
+  </xs:complexType>
+  <xs:complexType name="InformationPaneType">
+      <xs:extension base="WebLayoutResizableControlType">
+        <xs:sequence>
+          <xs:element name="LegendVisible" type="xs:boolean"/>
+          <xs:element name="PropertiesVisible" type="xs:boolean"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="TaskPaneType">
+        <xs:sequence>
+          <xs:element name="TaskBar" type="TaskBarType"/>
+          <xs:element name="InitialTask" type="xs:string" minOccurs="0"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="TaskButtonType">
+    <xs:sequence>
+      <xs:element name="Name" type="xs:string"/>
+      <xs:element name="Tooltip" type="xs:string" minOccurs="0"/>
+      <xs:element name="Description" type="xs:string" minOccurs="0"/>
+      <xs:element name="ImageURL" type="xs:string" minOccurs="0"/>
+      <xs:element name="DisabledImageURL" type="xs:string" minOccurs="0"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="TaskBarType">
+        <xs:sequence>
+          <xs:element name="Home" type="TaskButtonType"/>
+          <xs:element name="Forward" type="TaskButtonType"/>
+          <xs:element name="Back" type="TaskButtonType"/>
+          <xs:element name="Tasks" type="TaskButtonType"/>
+          <xs:element name="MenuButton" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="CommandSetType">
+    <xs:sequence>
+      <xs:element name="Command" type="CommandType" minOccurs="0" maxOccurs="unbounded"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="MapViewType">
+    <xs:sequence>
+      <xs:element name="CenterX" type="xs:double"/>
+      <xs:element name="CenterY" type="xs:double"/>
+      <xs:element name="Scale" type="xs:double"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="UIItemType">
+    <xs:sequence>
+      <xs:element name="Function" type="UIItemFunctionType"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:simpleType name="UIItemFunctionType">
+      <xs:enumeration value="Separator"/>
+      <xs:enumeration value="Command"/>
+      <xs:enumeration value="Flyout"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:complexType name="FlyoutItemType">
+      <xs:extension base="UIItemType">
+        <xs:sequence>
+          <xs:element name="Label" type="xs:string"/>
+          <xs:element name="SubItem" type="UIItemType" minOccurs="0" maxOccurs="unbounded"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="SeparatorItemType">
+      <xs:extension base="UIItemType"/>
+  </xs:complexType>
+  <xs:complexType name="CommandItemType">
+        <xs:sequence>
+          <xs:element name="Command" type="xs:string"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="CommandType" abstract="true">
+    <xs:sequence>
+      <xs:element name="TargetViewer" type="TargetViewerType"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:simpleType name="BasicCommandActionType">
+      <xs:enumeration value="Pan"/>
+      <xs:enumeration value="PanUp"/>
+      <xs:enumeration value="PanDown"/>
+      <xs:enumeration value="PanRight"/>
+      <xs:enumeration value="PanLeft"/>
+      <xs:enumeration value="Zoom"/>
+      <xs:enumeration value="ZoomIn"/>
+      <xs:enumeration value="ZoomOut"/>
+      <xs:enumeration value="ZoomRectangle"/>
+      <xs:enumeration value="ZoomToSelection"/>
+      <xs:enumeration value="FitToWindow"/>
+      <xs:enumeration value="PreviousView"/>
+      <xs:enumeration value="NextView"/>
+      <xs:enumeration value="RestoreView"/>
+      <xs:enumeration value="Select"/>
+      <xs:enumeration value="SelectRadius"/>
+      <xs:enumeration value="SelectPolygon"/>
+      <xs:enumeration value="ClearSelection"/>
+      <xs:enumeration value="Refresh"/>
+      <xs:enumeration value="CopyMap"/>
+      <xs:enumeration value="About"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:complexType name="BasicCommandType">
+    <xs:complexContent>
+      <xs:extension base="CommandType">
+        <xs:sequence>
+          <xs:element name="Action" type="BasicCommandActionType"/>
+        </xs:sequence>
+      </xs:extension>
+    </xs:complexContent>
+  </xs:complexType>
+  <xs:simpleType name="TargetViewerType">
+      <xs:enumeration value="Dwf"/>
+      <xs:enumeration value="Ajax"/>
+      <xs:enumeration value="All"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:complexType name="CustomCommandType" abstract="true">
+      <xs:extension base="CommandType"/>
+  </xs:complexType>
+  <xs:complexType name="TargetedCommandType" abstract="true">
+      <xs:extension base="CustomCommandType">
+        <xs:sequence>
+          <xs:element name="Target" type="TargetType"/>
+          <xs:element name="TargetFrame" type="xs:string" minOccurs="0"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:simpleType name="TargetType">
+      <xs:enumeration value="TaskPane"/>
+      <xs:enumeration value="NewWindow"/>
+      <xs:enumeration value="SpecifiedFrame"/>
+    </xs:restriction>
+  </xs:simpleType>
+  <xs:complexType name="SearchCommandType">
+      <xs:extension base="TargetedCommandType">
+        <xs:sequence>
+          <xs:element name="Layer" type="xs:string"/>
+          <xs:element name="Prompt" type="xs:string"/>
+          <xs:element name="ResultColumns" type="ResultColumnSetType"/>
+          <xs:element name="Filter" type="xs:string" minOccurs="0"/>
+          <xs:element name="MatchLimit" type="xs:integer"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="InvokeURLCommandType">
+        <xs:sequence>
+          <xs:element name="URL" type="xs:string"/>
+          <xs:element name="LayerSet" type="LayerSetType" minOccurs="0"/>
+          <xs:element name="AdditionalParameter" type="ParameterPairType" minOccurs="0" maxOccurs="unbounded"/>
+          <xs:element name="DisableIfSelectionEmpty" type="xs:boolean"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="BufferCommandType">
+      <xs:extension base="TargetedCommandType"/>
+  </xs:complexType>
+  <xs:complexType name="SelectWithinCommandType">
+  </xs:complexType>
+  <xs:complexType name="PrintCommandType">
+        <xs:sequence>
+          <xs:element name="PrintLayout" type="ResourceReferenceType" minOccurs="0" maxOccurs="unbounded"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="GetPrintablePageCommandType">
+  </xs:complexType>
+  <xs:complexType name="MeasureCommandType">
+  </xs:complexType>
+  <xs:complexType name="ViewOptionsCommandType">
+  </xs:complexType>
+  <xs:complexType name="HelpCommandType">
+        <xs:sequence>
+          <xs:element name="URL" type="xs:string" minOccurs="0"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="InvokeScriptCommandType">
+        <xs:sequence>
+          <xs:element name="Script" type="xs:string"/>
+        </xs:sequence>
+      </xs:extension>
+  </xs:complexType>
+  <xs:complexType name="ParameterPairType">
+    <xs:sequence>
+      <xs:element name="Key" type="xs:string"/>
+      <xs:element name="Value" type="xs:string"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="LayerSetType">
+    <xs:sequence>
+      <xs:element name="Layer" type="xs:string" minOccurs="0" maxOccurs="unbounded"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="ResultColumnType">
+    <xs:sequence>
+      <xs:element name="Property" type="xs:string"/>
+    </xs:sequence>
+  </xs:complexType>
+  <xs:complexType name="ResultColumnSetType">
+    <xs:sequence>
+      <xs:element name="Column" type="ResultColumnType" minOccurs="0" maxOccurs="unbounded"/>
+    </xs:sequence>
+  </xs:complexType>
+</xs:schema>
More information about the mapguide-commits mailing list
