[mapguide-commits] r4844 - in trunk/Tools/Maestro:
Maestro/ResourceEditors Maestro/ResourceEditors/Strings
MaestroAPI/Generated
svn_mapguide at osgeo.org
Fri May 7 08:35:11 EDT 2010
Author: jng
Date: 2010-05-07 08:35:09 -0400 (Fri, 07 May 2010)
New Revision: 4844
trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx
trunk/Tools/Maestro/Maestro/ResourceEditors/Strings/LayoutEditor.resx
trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs
This submission undoes the work for #1296. We need a cleaner way to handle different versions of a given resource type
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs 2010-05-06 13:53:15 UTC (rev 4843)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.cs 2010-05-07 12:35:09 UTC (rev 4844)
@@ -23,7 +23,6 @@
using System.Drawing;
using System.Data;
using System.Windows.Forms;
-using OSGeo.MapGuide.MaestroAPI;
namespace OSGeo.MapGuide.Maestro.ResourceEditors
@@ -139,7 +138,6 @@
private ToolStripMenuItem AddSeperatorItem;
private ContextMenuStrip CreateCommandMenu;
private ImageList FixedImages;
- private CheckBox chkPing;
private string m_tempResource;
private enum ListViewColumns : int
@@ -157,52 +155,17 @@
: this()
m_editor = editor;
- //HACK: There's gotta be a cleaner way
- if (editor.CurrentConnection.SiteVersion >= new Version(2, 2))
- m_layout = new OSGeo.MapGuide.MaestroAPI.WebLayout1_1();
- chkPing.Enabled = true;
- else
- m_layout = new OSGeo.MapGuide.MaestroAPI.WebLayout();
+ m_layout = new OSGeo.MapGuide.MaestroAPI.WebLayout();
m_tempResource = new MaestroAPI.ResourceIdentifier(Guid.NewGuid().ToString(), OSGeo.MapGuide.MaestroAPI.ResourceTypes.WebLayout, m_editor.CurrentConnection.SessionID);
- UpdateDisplay();
+ UpdateDisplay();
public LayoutEditor(EditorInterface editor, string resourceID)
: this()
m_editor = editor;
- m_layout = null;
- byte [] content = editor.CurrentConnection.GetResourceXmlData(resourceID);
- using (var ms = new System.IO.MemoryStream(content))
- try
- m_layout = editor.CurrentConnection.DeserializeObject<WebLayout>(ms);
- catch
- m_layout = null;
- if (m_layout == null) //Retry as 1.1.0
- ms.Position = 0;
- m_layout = editor.CurrentConnection.DeserializeObject<WebLayout1_1>(ms);
- m_layout.ResourceId = resourceID;
+ m_layout = editor.CurrentConnection.GetWebLayout(resourceID);
UpdateDisplay();
@@ -244,13 +207,6 @@
TitleText.Text = m_layout.Title;
- //HACK: There's gotta be a better way
- WebLayout1_1 wl = m_layout as WebLayout1_1;
- if (wl != null)
- chkPing.Checked = wl.EnablePingServer;
MapResource.Text = m_layout.Map.ResourceId;
OverrideDisplayExtents.Checked = m_layout.Map.InitialView != null;
if (m_layout.Map.InitialView != null)
@@ -557,6 +513,7 @@
this.dataColumn8 = new System.Data.DataColumn();
this.dataColumn9 = new System.Data.DataColumn();
this.MenuBox = new System.Windows.Forms.GroupBox();
+ this.commandEditor = new OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor();
this.splitter2 = new System.Windows.Forms.Splitter();
this.MenuTabs = new System.Windows.Forms.TabControl();
this.ToolbarTab = new System.Windows.Forms.TabPage();
@@ -599,8 +556,6 @@
this.AddSeperatorItem = new System.Windows.Forms.ToolStripMenuItem();
this.CreateCommandMenu = new System.Windows.Forms.ContextMenuStrip(this.components);
this.FixedImages = new System.Windows.Forms.ImageList(this.components);
- this.chkPing = new System.Windows.Forms.CheckBox();
- this.commandEditor = new OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor();
this.overriddenMapExtents.SuspendLayout();
this.groupBox2.SuspendLayout();
this.groupBox3.SuspendLayout();
@@ -940,6 +895,11 @@
this.MenuBox.Name = "MenuBox";
this.MenuBox.TabStop = false;
+ // commandEditor
+ resources.ApplyResources(this.commandEditor, "commandEditor");
+ this.commandEditor.Name = "commandEditor";
// splitter2
resources.ApplyResources(this.splitter2, "splitter2");
@@ -1249,22 +1209,9 @@
this.FixedImages.Images.SetKeyName(0, "FolderOpen.ico");
this.FixedImages.Images.SetKeyName(1, "Seperator.ico");
- // chkPing
- resources.ApplyResources(this.chkPing, "chkPing");
- this.chkPing.Name = "chkPing";
- this.chkPing.UseVisualStyleBackColor = true;
- this.chkPing.CheckedChanged += new System.EventHandler(this.chkPing_CheckedChanged);
- // commandEditor
- resources.ApplyResources(this.commandEditor, "commandEditor");
- this.commandEditor.Name = "commandEditor";
// LayoutEditor
resources.ApplyResources(this, "$this");
- this.Controls.Add(this.chkPing);
this.Controls.Add(this.ShowInBrowser);
this.Controls.Add(this.browserURL);
this.Controls.Add(this.label12);
@@ -1272,15 +1219,15 @@
this.Controls.Add(this.FeatureLinkTargetType);
this.Controls.Add(this.FeatureLinkTarget);
this.Controls.Add(this.HomePageURL);
- this.Controls.Add(this.groupBox2);
- this.Controls.Add(this.TitleText);
+ this.Controls.Add(this.SelectMapButton);
this.Controls.Add(this.MapResource);
+ this.Controls.Add(this.groupBox2);
this.Controls.Add(this.OverrideDisplayExtents);
- this.Controls.Add(this.SelectMapButton);
this.Controls.Add(this.overriddenMapExtents);
- this.Controls.Add(this.label10);
+ this.Controls.Add(this.TitleText);
this.Controls.Add(this.label2);
this.Controls.Add(this.label1);
+ this.Controls.Add(this.label10);
this.Controls.Add(this.label11);
this.Name = "LayoutEditor";
this.overriddenMapExtents.ResumeLayout(false);
@@ -1333,20 +1280,6 @@
- private void chkPing_CheckedChanged(object sender, EventArgs e)
- //HACK: Gotta be a better way
- var wl = m_layout as WebLayout1_1;
- if (wl != null)
- if (m_isUpdating)
- return;
- wl.EnablePingServer = chkPing.Checked;
- m_editor.HasChanged();
private void OverrideDisplayExtents_CheckedChanged(object sender, System.EventArgs e)
overriddenMapExtents.Enabled = OverrideDisplayExtents.Checked;
@@ -1570,14 +1503,12 @@
LoadedImageList.Images.Add(FixedImages.Images[1]);
string path = System.IO.Path.Combine(Application.StartupPath, "stdicons");
- if (System.IO.Directory.Exists(path))
- foreach (string s in System.IO.Directory.GetFiles(path, "*.gif"))
- LoadedImageList.Images.Add(System.Drawing.Image.FromFile(s));
- LoadedImages.Add("../stdicons/" + System.IO.Path.GetFileName(s), LoadedImageList.Images.Count - 1);
+ if (System.IO.Directory.Exists(path))
+ foreach(string s in System.IO.Directory.GetFiles(path, "*.gif"))
+ LoadedImageList.Images.Add(Image.FromFile(s));
+ LoadedImages.Add("../stdicons/" + System.IO.Path.GetFileName(s), LoadedImageList.Images.Count - 1);
using (System.IO.StringReader sr = new System.IO.StringReader(Properties.Resources.CommandTypesDataset))
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx 2010-05-06 13:53:15 UTC (rev 4843)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/LayoutEditor.resx 2010-05-07 12:35:09 UTC (rev 4844)
@@ -117,13 +117,9 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
- <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
- <data name="label1.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- <value>NoControl</value>
- </data>
<assembly alias="System.Drawing" name="System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a" />
<data name="label1.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 3</value>
+ <value>0, 0</value>
</data>
<data name="label1.Size" type="System.Drawing.Size, System.Drawing">
<value>144, 16</value>
@@ -145,13 +141,10 @@
<value>$this</value>
</data>
<data name=">>label1.ZOrder" xml:space="preserve">
- <value>18</value>
+ <value>16</value>
</data>
- <data name="label2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label2.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 25</value>
+ <value>0, 24</value>
</data>
<data name="label2.Size" type="System.Drawing.Size, System.Drawing">
@@ -172,14 +165,12 @@
</data>
<data name=">>label2.ZOrder" xml:space="preserve">
- <value>17</value>
+ <value>15</value>
</data>
+ <assembly alias="System.Windows.Forms" name="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" />
<data name="overriddenMapExtents.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Left, Right</value>
</data>
- <data name="label6.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label6.Location" type="System.Drawing.Point, System.Drawing">
<value>336, 24</value>
</data>
@@ -213,6 +204,9 @@
<data name="overrideScale.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
</data>
+ <data name="overrideScale.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>overrideScale.Name" xml:space="preserve">
<value>overrideScale</value>
</data>
@@ -234,6 +228,9 @@
<data name="overrideY.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
</data>
+ <data name="overrideY.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>overrideY.Name" xml:space="preserve">
<value>overrideY</value>
</data>
@@ -255,6 +252,9 @@
<data name="overrideX.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
</data>
+ <data name="overrideX.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>overrideX.Name" xml:space="preserve">
<value>overrideX</value>
</data>
@@ -267,9 +267,6 @@
<data name=">>overrideX.ZOrder" xml:space="preserve">
<value>3</value>
</data>
- <data name="label5.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label5.Location" type="System.Drawing.Point, System.Drawing">
<value>296, 24</value>
</data>
@@ -294,9 +291,6 @@
<data name=">>label5.ZOrder" xml:space="preserve">
<value>4</value>
</data>
- <data name="label4.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label4.Location" type="System.Drawing.Point, System.Drawing">
<value>160, 24</value>
</data>
@@ -321,9 +315,6 @@
<data name=">>label4.ZOrder" xml:space="preserve">
<value>5</value>
</data>
- <data name="label3.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label3.Location" type="System.Drawing.Point, System.Drawing">
<value>16, 24</value>
</data>
@@ -352,7 +343,7 @@
<value>False</value>
</data>
<data name="overriddenMapExtents.Location" type="System.Drawing.Point, System.Drawing">
- <value>3, 69</value>
+ <value>0, 56</value>
</data>
<data name="overriddenMapExtents.Size" type="System.Drawing.Size, System.Drawing">
<value>544, 56</value>
@@ -370,16 +361,13 @@
</data>
<data name=">>overriddenMapExtents.ZOrder" xml:space="preserve">
- <value>15</value>
+ <value>13</value>
</data>
<data name="OverrideDisplayExtents.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
<value>System</value>
</data>
- <data name="OverrideDisplayExtents.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="OverrideDisplayExtents.Location" type="System.Drawing.Point, System.Drawing">
- <value>11, 69</value>
+ <value>8, 56</value>
</data>
<data name="OverrideDisplayExtents.Size" type="System.Drawing.Size, System.Drawing">
<value>216, 16</value>
@@ -400,7 +388,7 @@
</data>
<data name=">>OverrideDisplayExtents.ZOrder" xml:space="preserve">
- <value>13</value>
+ <value>12</value>
</data>
<data name="groupBox2.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -414,6 +402,9 @@
<data name="LeftPaneWidth.TabIndex" type="System.Int32, mscorlib">
<value>3</value>
</data>
+ <data name="LeftPaneWidth.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>LeftPaneWidth.Name" xml:space="preserve">
<value>LeftPaneWidth</value>
</data>
@@ -426,9 +417,6 @@
<data name=">>LeftPaneWidth.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="label7.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label7.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 104</value>
</data>
@@ -456,9 +444,6 @@
<data name="ItemPropertiesCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="ItemPropertiesCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="ItemPropertiesCheck.Location" type="System.Drawing.Point, System.Drawing">
<value>16, 48</value>
</data>
@@ -486,9 +471,6 @@
<data name="LayerControlCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="LayerControlCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="LayerControlCheck.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -537,9 +519,6 @@
<data name=">>groupBox3.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="label9.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label9.Location" type="System.Drawing.Point, System.Drawing">
<value>24, 112</value>
</data>
@@ -567,9 +546,6 @@
<data name="ZoomControlCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="ZoomControlCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="ZoomControlCheck.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 96</value>
</data>
@@ -597,9 +573,6 @@
<data name="StatusBarCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="StatusBarCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="StatusBarCheck.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 72</value>
</data>
@@ -627,9 +600,6 @@
<data name="ContextMenuCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="ContextMenuCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="ContextMenuCheck.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 48</value>
</data>
@@ -657,9 +627,6 @@
<data name="ToolbarCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="ToolbarCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="ToolbarCheck.Location" type="System.Drawing.Point, System.Drawing">
<value>8, 24</value>
</data>
@@ -708,9 +675,6 @@
<data name=">>groupBox4.ZOrder" xml:space="preserve">
<value>1</value>
</data>
- <data name="label8.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label8.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -738,9 +702,6 @@
<data name="EditTaskBarBtn.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="EditTaskBarBtn.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="EditTaskBarBtn.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -774,6 +735,9 @@
<data name="RightPaneWidth.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
</data>
+ <data name="RightPaneWidth.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>RightPaneWidth.Name" xml:space="preserve">
<value>RightPaneWidth</value>
</data>
@@ -789,9 +753,6 @@
<data name="TaskBarCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="TaskBarCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="TaskBarCheck.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -819,9 +780,6 @@
<data name="TaskPaneCheck.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="TaskPaneCheck.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="TaskPaneCheck.Location" type="System.Drawing.Point, System.Drawing">
</data>
@@ -871,10 +829,10 @@
<value>2</value>
</data>
<data name="groupBox2.Location" type="System.Drawing.Point, System.Drawing">
- <value>0, 131</value>
+ <value>0, 120</value>
</data>
<data name="groupBox2.Size" type="System.Drawing.Size, System.Drawing">
- <value>544, 175</value>
+ <value>544, 184</value>
</data>
<data name="groupBox2.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
@@ -892,7 +850,7 @@
</data>
<data name=">>groupBox2.ZOrder" xml:space="preserve">
- <value>10</value>
+ <value>11</value>
</data>
<data name="TitleText.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -901,11 +859,14 @@
<value>160, 0</value>
</data>
<data name="TitleText.Size" type="System.Drawing.Size, System.Drawing">
- <value>382, 20</value>
+ <value>376, 20</value>
</data>
<data name="TitleText.TabIndex" type="System.Int32, mscorlib">
<value>4</value>
</data>
+ <data name="TitleText.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>TitleText.Name" xml:space="preserve">
<value>TitleText</value>
</data>
@@ -916,13 +877,13 @@
</data>
<data name=">>TitleText.ZOrder" xml:space="preserve">
- <value>11</value>
+ <value>14</value>
</data>
<data name="MapResource.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
<data name="MapResource.Location" type="System.Drawing.Point, System.Drawing">
- <value>160, 21</value>
+ <value>160, 24</value>
</data>
<data name="MapResource.Size" type="System.Drawing.Size, System.Drawing">
<value>352, 20</value>
@@ -930,6 +891,9 @@
<data name="MapResource.TabIndex" type="System.Int32, mscorlib">
<value>5</value>
</data>
+ <data name="MapResource.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>MapResource.Name" xml:space="preserve">
<value>MapResource</value>
</data>
@@ -940,7 +904,7 @@
</data>
<data name=">>MapResource.ZOrder" xml:space="preserve">
- <value>12</value>
+ <value>10</value>
</data>
<data name="SelectMapButton.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
<value>Top, Right</value>
@@ -948,11 +912,8 @@
<data name="SelectMapButton.FlatStyle" type="System.Windows.Forms.FlatStyle, System.Windows.Forms">
</data>
- <data name="SelectMapButton.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="SelectMapButton.Location" type="System.Drawing.Point, System.Drawing">
- <value>518, 21</value>
+ <value>520, 24</value>
</data>
<data name="SelectMapButton.Size" type="System.Drawing.Size, System.Drawing">
<value>24, 20</value>
@@ -973,7 +934,7 @@
</data>
<data name=">>SelectMapButton.ZOrder" xml:space="preserve">
- <value>14</value>
+ <value>9</value>
</data>
<data name="FeatureLinkTarget.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -990,6 +951,9 @@
<data name="FeatureLinkTarget.TabIndex" type="System.Int32, mscorlib">
<value>11</value>
</data>
+ <data name="FeatureLinkTarget.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>FeatureLinkTarget.Name" xml:space="preserve">
<value>FeatureLinkTarget</value>
</data>
@@ -1000,11 +964,8 @@
</data>
<data name=">>FeatureLinkTarget.ZOrder" xml:space="preserve">
- <value>8</value>
+ <value>7</value>
</data>
- <data name="label10.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label10.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 336</value>
</data>
@@ -1027,11 +988,8 @@
</data>
<data name=">>label10.ZOrder" xml:space="preserve">
- <value>16</value>
+ <value>17</value>
</data>
- <data name="label11.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label11.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 312</value>
</data>
@@ -1054,7 +1012,7 @@
</data>
<data name=">>label11.ZOrder" xml:space="preserve">
- <value>19</value>
+ <value>18</value>
</data>
<data name="HomePageURL.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -1068,6 +1026,9 @@
<data name="HomePageURL.TabIndex" type="System.Int32, mscorlib">
<value>10</value>
</data>
+ <data name="HomePageURL.Text" xml:space="preserve">
+ <value></value>
+ </data>
<data name=">>HomePageURL.Name" xml:space="preserve">
<value>HomePageURL</value>
</data>
@@ -1078,7 +1039,7 @@
</data>
<data name=">>HomePageURL.ZOrder" xml:space="preserve">
- <value>9</value>
+ <value>8</value>
</data>
<data name="FeatureLinkTargetType.Items" xml:space="preserve">
<value>Task pane</value>
@@ -1108,7 +1069,7 @@
</data>
<data name=">>FeatureLinkTargetType.ZOrder" xml:space="preserve">
- <value>7</value>
+ <value>6</value>
</data>
<metadata name="CommandTypesDataset.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>131, 17</value>
@@ -1141,7 +1102,7 @@
<value>commandEditor</value>
</data>
<data name=">>commandEditor.Type" xml:space="preserve">
- <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=2.1.0.4814, Culture=neutral, PublicKeyToken=null</value>
+ <value>OSGeo.MapGuide.Maestro.ResourceEditors.LayoutControls.CommandEditor, OSGeo.MapGuide.Maestro.ResourceEditors, Version=1.1.0.4358, Culture=neutral, PublicKeyToken=null</value>
</data>
<data name=">>commandEditor.Parent" xml:space="preserve">
<value>MenuBox</value>
@@ -1149,9 +1110,6 @@
<data name=">>commandEditor.ZOrder" xml:space="preserve">
<value>0</value>
</data>
- <data name="splitter2.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="splitter2.Location" type="System.Drawing.Point, System.Drawing">
<value>259, 16</value>
</data>
@@ -1203,16 +1161,16 @@
<data name="ToolbarAddButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAAAAXNSR0IArs4c6QAAAARnQU1BAACxjwv8
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAgNJREFUOE+Nk99L
- WmEYxw3/kqRFQYxaF60fjIxGNKLdjK5G3UTK6aqgRotqFdEYrNi0iwqqbUlFCGFBEWLkPBCSFFnmikoz
- Dgs026GcOvS7Pa8c50nHeuHLeQ/nOZ/3+3zPc7IUf5bDsYNwOEJb2YrFYgqlUqmgK61oNKKorq7KSivk
- +S3E43Hc3EaTCkd+ye7pmdlsgdG4hIwAKghcR/4pfzAMi2UTx0fH6RBycF+AaXmVAWRO7gvwCUG4j87h
- 8QqsnWQrqQDh+w9WlCrXNy8kEUTKIwmwWnlQaJTB/wCX/lBmgJRBJoB9bx+jKzp0LHSizzgAm8sub4Ec
- SACvcCOzb1hfRI1ejTe215g4GMN7xzBezNZDq9P8zSAVIAVFGdDJpSPFaOc5DDl74RIOMOf+jK7tNlTN
- lGUGSA4otMH5YZQZCqHZakSXnUNADDBAq70Zz1bUeK57moBIDmhYyAG9vOfyQjvFoXg+H7zHyl6maRVD
- IttrzE0oeJuTANCEUQb+4E+c+a6w6zxjav/0CkWGXHb6uHsQ16ErbPhMGHX2oXb5CWtP5oDsk04vRKYl
- /ise6lWot+VC687HpejDtKcbDdt5KJl7gJ7F3nQH5IK+tSQqqviSDe4wG9PCS/SflKNuTYXKd4/lIVIb
- JBrRuxqY7GeBlX5UQf3hETh9C4ymxF/5Gz+dzDj10EpxAAAAAElFTkSuQmCC
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHzSURBVDhPlZPbSxtBGMX9VwwaFETa+uAVMQUpLcW+iE9F
+ X8SE9cmAFi3GqhRLoRVN+qCC9xBFAhIDioQUYxYkJLSYmqZKNWlkqZCLLhq1Qk77Tdg060bUgcPO7n7z
+ mzNnZvLy/jWf7wt4fkshl4tn3+hJcjicoHpFo6JUKoXTsz8ZXVxeyd7pHwGs1mUlhABUEDu+vFHRxAWc
+ zg3s7e4pIfcB2FZWGUDm5K6AiJBAcPcXQmFBnkc2QPh9woqyFfgRhiSCSHlkwqSEKTTK4DbAUTSZGyCF
+ mAvg2f6GYbsRnYtd6LMOwB3wyJdADiRAWDiV2TevL+GJSYM37h6M73zCB98QGucboDNq/29nNkAKijKg
+ mSs/lkHPc3jrNyAg7MASnEW3twOPp6tyAyQHFNrgwhCqzA+g3WpGt4dDTIwxQLunFc/sGrww1qchkgM6
+ LOSABm8HwtBNcihbKAYfcrHBdFrFpMj6WkcLSt4VpAF0wiiDaOIcB5E4vvoPmPQzr/DQrGazjwUHcZyM
+ 43PEhmF/H56u1LLlyRyQfdL+oci0zG+i1KRCg1sNXbAYR2IEU6HXaPIWodxSiN4lg9IBuaC9lkRFNXP5
+ 4L7nY0p4if6f1Xi+pkLd+wp5iLQMEt246xqY6GeBVY6qoBl5BM7UBqstfSv/AtxW4JLSgfLrAAAAAElF
+ TkSuQmCC
</value>
</data>
<data name="ToolbarAddButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1227,16 +1185,15 @@
<data name="ToolbarDeleteButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAedJREFUOE+Nk9Fr
- UmEYxh3+KYMRJAitIBoMHOKNk0VEGOtqN1GNsVpCF5KwnFhGErsQ1q42BlFI0goRTZhywMZkI0NKI2eK
- WJpm0+kx9ZnvdzjmUSM/+HE8+Pk7z/uczxFZe4XD+6jVePooWc1mUyaXy2V0pVWv8zK1emqkbyPHhVDj
- /6BcqXfovafvfD4/nE4XBgpow89f/D/JF2vw+3cQj8X7JZRgWMHrbTcTSJIMK0hlivgU+4bDZIaN0xml
- W5DJltimXqKfkyBIIvbREQQCHCuROvif4Hv+eLBA7GCQIBL+CM7hQNBkRNBqxZf3e9IRKIEoSGbKkvjB
- F068u6xF1raMo811FBx27M/p8fL2rb8ddAvEoqgDerJHewElkwHN1YdorT1l16rFiMglzWCBmIAK89hs
- SExPonFvHq1HJrSemAXuLyE3q4Pv6owgERPQYaEE9OMP0bbgziKymvMoBvyo5HMSfhhuwjuhFAR0wqiD
- fLGKRKqAg0iC4TYakdScwZH5Lo437AJbbZ49ZgloPEkCik98Tf9mhDwcdieVqF4ZR+vG2Q6Na+eYmFsx
- 9SegFPSuRQKWB4hoFKjMnUJjYRT89TGkLyrg0qqkJdIYBB3RXp5bzHir18GrOs1i0yt880r4V54A9yLT
- m2S2FSIAAAAASUVORK5CYII=
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAHOSURBVDhPlZPdK0NhHMf9L0qKWnkpUWo3uxmRJOJqN/KS
+ vJaLZcUsTCQXK1yREi3ykpZZ2TqFLDLJW2ZoDWNmZsbsa7/ndMbZmXDq0+mc85zP+T7f5zwpKbHDbt8F
+ x21KsFo5do/OhNlsAY2XHDToNfyO5+BbnMRrekYCo3FBKiEBDbh/DP+I1/cKi2UDpyenUsl/BItLq0wg
+ SvJXwZXbh6OTS1y43OI+vgvcHj8blMjhsQsESYQ+4mVSw1QadfCb4Mb7klwglJhM4LAfgDMYYNOoYevr
+ w9nWjngKlEAQuNzPovi2WSPWy5Xw6LsRmJrAg2EYu6pKzLU0fC3nd4FQFHVAXzYp8+HXdOBjtB/RsRF2
+ DunUcJQpkguEBFSYSa+Hs6gQkc5GRAc0iA5pebracFddDHNVCS8REtDPQgno5f3DmKC1GR5FHnxWC4Le
+ OxG3HfVYK5DxAvrDqAOvLwTn1QP2HE7GqloNlyILAW07XiaHeaZjjA+yBDQ9UQKKT5xfPzE2TRy2C2UI
+ VWQjWpcTJ1KTy8Rcr0aagFLQWgtYdT1wKDIRVKUj0pSKcG0arkszsaCUi0ukaRC04xKZ0WmxUlmMNXkG
+ i01LuDzP78pPk+rn9YbBWMIAAAAASUVORK5CYII=
</value>
</data>
<data name="ToolbarDeleteButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1254,15 +1211,14 @@
<data name="ToolbarUpButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAbZJREFUOE+NkstL
- AlEYxRX/r3ZF0aJNEEVQREQYFAT2gMBF0iaI/oNWrSJRBNMIqcRXSZqJYpY2okahTYSPHsipc2NGJsfq
- wuHOvTPf737n3DEavkb0IoVGTTaYTCYu1dFqtcQeZ45Go27o7+8zaj7iIhAI4/XtA7X6+686OvLB4XBB
- F8Di6vNbhypyU+xx9vlOkL3Owm53aiHsQAEUSk/I3BSRykiQyjX1mWuerkgD0QMQwlOZD6F56VHATk8D
- uJPKoB3VSjcAC2OJjGqrIr8ikkiLbjUAUhkivSoWeBotKIDYfQbOnLc74GcGBBBGC9eFEpaSM7CkR+AM
- HwprHR3oAR4qDeF7LbyC7eo8rOVpmENj4P6/AEx+53IXNmkSm7IFS8UpmK8GYYuu/g1gsTfmx2iwF+v5
- CWw9twHj/h7Y9jbat8AQaYEp0zeLk2lJBOY6O4YlZFYB0/5BhG5T2D9wtAH8w74BTeQKVcSv8kLR+C0i
- FzdYCy5qALwd3Qz4gsoVX4SSWVnIGlnuAHg8h/odsAumrIhAhqZkQAu610gbFFv7qUX3HBbOhzEbGsKI
- awBur1e18AnBRdHxkrLkPgAAAABJRU5ErkJggg==
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGoSURBVDhPjZNNSwJRGIX9Ze1aRIs2gRRBERJhUBBoBUGL
+ pE0Q/YNWrSJRBEsJqcRGS9JUlMnURtQotImw7GNx6tyY0Wmmj4HDvXNn3ue+59wZm+3zSp7ncXwcQywW
+ N0hb40jt74fB900XC19e39F+evtVBwcR+HwBM4QAFrceXk1qqh2xxjESOULxsgiv12+E9AKq9XvIVzXk
+ ZQVKo63Pec/dNRkgVgBCuCvzIbSi3AkYs7hWGqAdPYufACxMZWTdVlN9QSJTEHYNAFIZIr1qFrgbLWiA
+ 1I0Mfzn0M0ALsRfAOS1cVutw56bgKtjhj4eFNVMHVoDb5rPwvRxfxGZrFisNB5zSKLj+LwCT37rYhkeZ
+ wLrqgrs2CWd2EJ7k0t8AFodSUYyc9GO1Mo6Nhy5gLNoHz85a9xQYIi0wZfpmca6giMACp4dwSU4d4IgO
+ Qirlsbvn6wL4hX0BOihXW0hnK0LJdAmJ8yssn8wbADwdywz4gCrXHoVyRVVoJbFgAhh+rN4O2AVT1kQg
+ Q9MyoAXLYySEYmvfNR+cwdzZMKalIdgDAwiGQrqFDye15j0ss3xfAAAAAElFTkSuQmCC
</value>
</data>
<data name="ToolbarUpButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1277,15 +1233,14 @@
<data name="ToolbarDownButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAaJJREFUOE+Nks1L
- AlEUxRX/s3DVxzJIaFNSEBQRpSAUIkEbQeo/aNHGjTFQISFCxkjCZCo5fqU5olKgKWF+hdw6t2bUNPHB
- 4fLevPvj3PNGr/teUlimZqOmMxgM2Gqr1+vxGSpWt9vRGY0z+qFL2IjiHbU7n9T46E6Uz+cnj0egsQA0
- V+sdTZVai/4KgEw6MwqBAxVQKL1R6qnIAgBVTiqsi6tLblalOfkPABjyQc0VqgwLBETKK2WCm6kAsfgz
- O8F4qOFIgt0OAUBFiLg0OMJLpckNp5kzciYdrAPRzvdGAOMyUEc4erTRSX2XbCUzbT7MTg+AA8x9GLWS
- q24ha3GV1kILPMpUDtT0HWHLEADgiQC1ERUh2qU9DbAuzrMDr/e6/woIERlUam0OkRtlhYR7H60EF8km
- mzQAMsDZgdveB/j9N7+AFr83mqVIloXUnaUNctasPxnE52jrdpl/Ku0/UB0o5QZBueI7K5GrUyT9SttB
- s/YKGCGUTQxnMOgA8yEkVQBK+RRZoybaTy+ROyaMzwAQCOmOk0s4Jsv5jvZNDfELUGvRcbvlWMQAAAAA
- SUVORK5CYII=
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGQSURBVDhPjZJNSwJRFIb9fX0sg4Q2JQVBEVEOCIlI0EaQ
+ +gct2rgxBiokRMgYSTBTyfErzRGVAk0JS63FqffUHWcaEwdeDszc83DOM9dm+34SSZWiUYUU5cYU8Q4V
+ CYcjhPOWB42D4Sf13j4mBoBgULZCAEBzuzvU0+r06W8AKBVLVogRUGu8UOGhzgEAVc1rnLOLc24W0Vf5
+ DwAY/KBWam2GwUVVa5p9TAJkso88CdZDTaZyvK5JKKiQiEPGFZ5a79xwXDohX97LcSsePmcBCIlGgFjh
+ 4N5FR90dcjUctHE3Mz0AE2Dv/bRE/q6TpPoKrcbneZWpJhD2vUmnCQDwRIBoRIVET2JXB6wpczxBKHQ5
+ ulCQCAetzoAlcqOqkXwbpuXYArlUuw6AA7xzBzwjQCRy9Qvo8/9GcyJV5sC6r7FOvo704yA7S5vXS3yp
+ 9IskJtCaPUIq9VdOrtKlVPGZtmIO/S9ghXg5Z3ZgnAD7QZIIgIlqgaS0nfaKixTIyOMdAILA7rj45UNy
+ nm7r34TEL+U05clBT2lYAAAAAElFTkSuQmCC
</value>
</data>
<data name="ToolbarDownButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1303,14 +1258,14 @@
<data name="ToolbarCreateButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgAABdwnLpRPAAAAZRJREFUOE+Fk19L
- wmAUxifo5+mLRH6BPkLddNMH6KLL6KbLEASJEAok2EBoBWmpCYbpsjn/NTd1iqSlonDyOfQuzZWDh3d7
- 9z6/85wz5pO+r2w2R6NRhp8CgQ3J7w9Is9lUvJYsy5aCwU2fu7F4E4sd0mA4pFb7lOX0PqneOKf+YOIq
- kbgnRZHJExCPh6jj7LAJwn3DVBja7Y9Z12qSjKpFqnq7CpHlKL2ZGleGdKNIjeYLGwTkKW/QxeUVKxyO
- /EBU9YDS6S2OLqqZVoi6vW2y7H0GAsJtmV2WZwq7dcJVC1qKjMoRaa8mH8Za0MruChjmsTQLRdmldkfm
- FHr5mEp6dB5/j00CVKp0CW2gLQ+ATOPJlAGiOqpCSCFayxerBNAKAHEAsDs9Ny4qiero32x/0FoAKonY
- AMAgTFgfsjo//5lgEQCQXnXYACN0lyr93wKiwggTBvaYKy+ZASjojneC0Xjq9pl7rq0YYb5Jzj/zOgCG
- VWsOSa+/u9KMPglh33MGqVSGfgsHvRSJnHn/VJ5/2prNL7BzbCZeoKfiAAAAAElFTkSuQmCC
+ YQUAAAAJcEhZcwAADsMAAA7DAcdvqGQAAAGESURBVDhPhZNfS8JgFMb9hH2CPkLddNMH6KLL6Ka7QhAk
+ QiixYAOhGag1SzBMl73Of81/20TSSvHi5HPoXcq2FB7Opu/zO8858kYiv59isUTZ7ClL1x8J76hSyeQ1
+ ybO+mkod0mQ6pcHwjOWMvqjduaDxZO4pl7snVVWCIel0lGxnh00QnjuWylB3PGPdankymz3StDs/RFES
+ 9G4Z3BkSZpU63Vc2SMhz2aTLqxtWLBb/g2jaARUKWxxddrN6UXJH29Tr7zMQEB7LclmBKfqDE+5aMXQy
+ G0dkvFl8GLVi1L0KGPaxtkhV3aWhrXAKUT+mmkgs4++xSYJqDZcwBsYKACg0my8YILujK4QUcrRytUkA
+ +QCIA0DfHnlx0Ul2x/zW8JM2AtBJxgYABmlCfSgKfg9NsAoASDQdNsAIZfXa/yMgKowwYWFPpfqaGYCK
+ cIITfM8W3pyll5bPCHMmv/ybNwGwrFZ3SqL94ckwxySF7wN3sHrz5DMOBikePw+/maFXNuSHH7+ofNrE
+ clL/AAAAAElFTkSuQmCC
</value>
</data>
<data name="ToolbarCreateButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1397,16 +1352,16 @@
<data name="ContextAddButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ TkSuQmCC
</value>
</data>
<data name="ContextAddButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1421,16 +1376,15 @@
<data name="ContextDeleteButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="ContextDeleteButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1448,15 +1402,14 @@
<data name="ContextUpButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="ContextUpButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1471,15 +1424,14 @@
<data name="ContextDownButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- SUVORK5CYII=
</value>
</data>
<data name="ContextDownButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1497,14 +1449,14 @@
<data name="ContextCreateButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="ContextCreateButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1594,16 +1546,16 @@
<data name="TaskAddButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
+ TkSuQmCC
</value>
</data>
<data name="TaskAddButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1618,16 +1570,15 @@
<data name="TaskDeleteButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="TaskDeleteButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1645,15 +1596,14 @@
<data name="TaskUpButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="TaskUpButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1668,15 +1618,14 @@
<data name="TaskDownButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
- SUVORK5CYII=
</value>
</data>
<data name="TaskDownButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1694,14 +1643,14 @@
<data name="TaskCreateButton.Image" type="System.Drawing.Bitmap, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
<value>
</value>
</data>
<data name="TaskCreateButton.ImageTransparentColor" type="System.Drawing.Color, System.Drawing">
@@ -1807,7 +1756,7 @@
</data>
<data name=">>MenuBox.ZOrder" xml:space="preserve">
- <value>6</value>
+ <value>5</value>
</data>
<data name="browserURL.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
@@ -1831,11 +1780,8 @@
</data>
<data name=">>browserURL.ZOrder" xml:space="preserve">
- <value>4</value>
+ <value>3</value>
</data>
- <data name="label12.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="label12.Location" type="System.Drawing.Point, System.Drawing">
<value>0, 360</value>
</data>
@@ -1858,14 +1804,11 @@
</data>
<data name=">>label12.ZOrder" xml:space="preserve">
- <value>5</value>
+ <value>4</value>
</data>
<data name="ShowInBrowser.Anchor" type="System.Windows.Forms.AnchorStyles, System.Windows.Forms">
</data>
- <data name="ShowInBrowser.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
<data name="ShowInBrowser.Location" type="System.Drawing.Point, System.Drawing">
<value>408, 360</value>
</data>
@@ -1888,19 +1831,19 @@
</data>
<data name=">>ShowInBrowser.ZOrder" xml:space="preserve">
- <value>3</value>
+ <value>2</value>
</data>
<metadata name="AddItemMenu.TrayLocation" type="System.Drawing.Point, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a">
<value>300, 17</value>
</metadata>
<data name="AddBuiltInFunctionMenu.Size" type="System.Drawing.Size, System.Drawing">
- <value>147, 22</value>
+ <value>159, 22</value>
</data>
<data name="AddBuiltInFunctionMenu.Text" xml:space="preserve">
<value>Built in function</value>
</data>
<data name="AddCustomItemMenu.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="AddCustomItemMenu.Text" xml:space="preserve">
<value>Custom item</value>
@@ -1918,7 +1861,7 @@
</value>
</data>
<data name="AddSubMenuItem.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="AddSubMenuItem.Text" xml:space="preserve">
<value>Submenu</value>
@@ -1932,13 +1875,13 @@
</value>
</data>
<data name="AddSeperatorItem.Size" type="System.Drawing.Size, System.Drawing">
</data>
<data name="AddSeperatorItem.Text" xml:space="preserve">
<value>Seperator</value>
</data>
<data name="AddItemMenu.Size" type="System.Drawing.Size, System.Drawing">
- <value>148, 92</value>
+ <value>160, 92</value>
</data>
<data name=">>AddItemMenu.Name" xml:space="preserve">
<value>AddItemMenu</value>
@@ -1965,69 +1908,35 @@
<value>
AAEAAAD/////AQAAAAAAAAAMAgAAAFdTeXN0ZW0uV2luZG93cy5Gb3JtcywgVmVyc2lvbj0yLjAuMC4w
LCBDdWx0dXJlPW5ldXRyYWwsIFB1YmxpY0tleVRva2VuPWI3N2E1YzU2MTkzNGUwODkFAQAAACZTeXN0
- ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAY
+ ZW0uV2luZG93cy5Gb3Jtcy5JbWFnZUxpc3RTdHJlYW1lcgEAAAAERGF0YQcCAgAAAAkDAAAADwMAAAAE
BgAAAk1TRnQBSQFMAgEBAgEAARQBAAEUAQABEAEAARABAAT/ASEBAAj/AUIBTQE2BwABNgMAASgDAAFA
- AwABEAMAAQEBAAEgBgABEP8AFwABTQICAZIBTQICAZMBTQICAZMBTQICAZMBTQICAZMBTQICAZMBTQIC
- AZMBTQICAZMBTQICAZMBTQICAZMBTQICAZMBTQICAZIBBQIBAQXIAAEzAgEBTwGUAckB+gH/ATUB0AL/
- ATMBzwL/ATEBzgL/AS8BzQL/ASwBzAL/ASoBywL/ASgBygL/ASYByQL/ASQBxwL/ASEBxgL/AR8BxQH+
- Af8BYgILAdTIAAEzAgEBTwFdAakB9AH/AVMB3QL/AUkB2wL/AUgB2gL/AUYB2QL/AUQB2AL/AUIB1wL/
- AUAB1gL/AT4B1QL/ATwB1AL/AToB0gL/ATgB0QH+Af8BYAIOAdrIAAEzAgEBTwFtAcwB+QH/Ab4B9AH+
- Af8BXgHkAv8BXAHjAv8BWgHiAv8BWQHiAv8BVwHhAv8BVQHgAv8BUwHfAv8BUQHeAv8BTwHdAv8BTgHc
- Af4B/wFbAgUBvwEiAgEBMMQAATMCAQFPAWkB0wL/AZABxwH5Af8BbQHsAv8BbAHrAv8BawHrAv8BaQHq
- Av8BaAHqAv8BZwHpAv8BZQHoAv8BZAHoAv8BYwHnAv8BYQHmAf4B/wFbAgUBvwFiAgsB1AgAAVkCBAG4
- AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5AVoCBAG5
- AVoCBAG5AVoCBAG5AVoCBAG5AT0CAQFmgAABMwIBAU8BcwHZAv8BLgGfAfUB/wGHAfAC/wGBAfAC/wGB
- AfAC/wGAAfAC/wF9AfAC/wF6AfAC/wF4AfAC/wF2Ae8C/wF0Ae8C/wFzAe8B/gH/AVsCBQG/AWACDgHa
- CAADgQH/A6EB/wOqAf8DsQH/A7MB/wOsAf8DogH/A54B/wOeAf8DngH/A54B/wOeAf8DngH/A6EB/wFc
- AgUBxoAAATMCAQFPAYEB4wL/ATkBygH6Af8B4QH0Af4B/wHbAfcB/gH/AdsB9wH+Af8B2gH3Af4B/wHY
- AfkB/gH/AZkB9AL/AZYB9AL/AZMB9AL/AZAB9AL/AY0B8wH+Af8BWwIFAb8BWwIFAb8BJQIBATQEAAOB
- Af8DgQH/A5AB/wOjAf8DsQH/A7EB/wOhAf8DjAH/A4cB/wOHAf8DhwH/A4cB/wOHAf8DnAH/AVwCBQHG
- gAABMwIBAU8BkgHuAv8BWwHkAv8BWwHkAv8BWwHkAv8BWwHkAv8BWwHkAv8BTAHGAfcB/wHqAfkB/gH/
- AeYB+QH+Af8B5QH5Af4B/wHkAfkB/gH/AeMB+QH+Af8BegI1Ae8BegI1Ae8BXgIMAdcEAAOBAf8DgQH/
- A4MB/wOUAf8DpgH/A7IB/wOwAf8DnwH/A4wB/wOIAf8DiAH/A4gB/wOIAf8DnAH/AVwCBQHGgAABMwIB
- AU8BpwH4Av8BfQH1Av8BfQH1Av8BfQH1Av8BfQH1Av8BfQH1Av8BfQH1Av8BfQH1Av8BfQH1Av8BfQH1
- Av8BfQH1Av8BegHxAf4B/xAAA4EB/wOBAf8DgQH/A4IB/wODAf8DgwH/A4IB/wOBAf8DgQH/A4EB/wOB
- Af8DgAH/A34B/wN7Af8BXAIFAcaAAAEzAgEBTwHBA/8BnAP/AZwD/wGcA/8B1gH9Af4B/wHfAfkB/gH/
- Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/Ad8B+QH+Af8B3wH5Af4B/wHQAfIB/QH/zAABMwIBAU8B6QP/
- AdwD/wHcA/8B3QP/AVoCBAG57AABQQIBAW8BQQIBAW8BQQIBAW8BQQIBAW8BCgIBAQv/AP8A/wDrAAFC
- AU0BPgcAAT4DAAEoAwABQAMAARADAAEBAQABAQUAAYAXAAP/AQAE/wQAAYABAwL/BQABAwL/BQABAwL/
- BQABAQL/BQABAQGABgABAQGABwABgAcAAYAGAAEHAYAGAAEHAv8EAAEDA/8EAAGDA/8EAAT/BAAE/wQA
- BP8EAAs=
+ AwABEAMAAQEBAAEgBgABEP8AFwABTAJDAZIBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJD
+ AZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZMBTAJDAZIDBAEFyAADMQFPAZQByQH6Af8BMAHQAv8BLgHP
+ Av8BLAHOAv8BKgHNAv8BJwHMAv8BJQHLAv8BIwHKAv8BIQHJAv8BHwHHAv8BHAHGAv8BGgHFAf4B/wFc
+ ATYBOwHUyAADMQFPAVgBqQH0Af8BTgHdAv8BRAHbAv8BQwHaAv8BQQHZAv8BPwHYAv8BPQHXAv8BOwHW
+ Av8BOQHVAv8BNwHUAv8BNQHSAv8BMwHRAf4B/wFeATcBOgHayAADMQFPAWgBzAH5Af8BvgH0Af4B/wFZ
+ AeQC/wFXAeMC/wFVAeIC/wFUAeIC/wFSAeEC/wFQAeAC/wFOAd8C/wFMAd4C/wFKAd0C/wFJAdwB/gH/
+ AVkCPgG/AyEBMMQAAzEBTwFkAdMC/wGQAccB+QH/AWgB7AL/AWcB6wL/AWYB6wL/AWQB6gL/AWMB6gL/
+ AWIB6QL/AWAB6AL/AV8B6AL/AV4B5wL/AVwB5gH+Af8BWQI+Ab8BXAE2ATsB1AgAAVcCPwG4AVgCPwG5
+ AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5AVgCPwG5
+ AVgCPwG5AVgCPwG5ATwCOgFmgAADMQFPAW4B2QL/ASkBnwH1Af8BhwHwAv8BgQHwAv8BgAHwAv8BewHw
+ Av8BeAHwAv8BdQHwAv8BcwHwAv8BcQHvAv8BbwHvAv8BbgHvAf4B/wFZAj4BvwFeAjoB2ggAA4EB/wOh
+ Af8DqgH/A7EB/wOzAf8DrAH/A6IB/wOeAf8DngH/A54B/wOeAf8DngH/A54B/wOhAf8BWwI6AcaAAAMx
+ AU8BgQHjAv8BNAHKAfoB/wHhAfQB/gH/AdsB9wH+Af8B2wH3Af4B/wHaAfcB/gH/AdgB+QH+Af8BmQH0
+ Av8BlgH0Av8BkwH0Av8BkAH0Av8BjQHzAf4B/wFZAj4BvwFZAj4BvwMjATQEAAOBAf8DgQH/A5AB/wOj
+ Af8DsQH/A7EB/wOhAf8DjAH/A4cB/wOHAf8DhwH/A4cB/wOHAf8DnAH/AVsCOgHGgAADMQFPAZIB7gL/
+ AVYB5AL/AVYB5AL/AVYB5AL/AVYB5AL/AVYB5AL/AUcBxgH3Af8B6gH5Af4B/wHmAfkB/gH/AeUB+QH+
+ Af8B5AH5Af4B/wHjAfkB/gH/AYwCZQHvAYwCZQHvAV0BNQE5AdcEAAOBAf8DgQH/A4MB/wOUAf8DpgH/
+ A7IB/wOwAf8DnwH/A4wB/wOIAf8DiAH/A4gB/wOIAf8DnAH/AVsCOgHGgAADMQFPAacB+AL/AXgB9QL/
+ AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXgB9QL/AXUB8QH+
+ Af8QAAOAAf8DgQH/A4EB/wOCAf8DgwH/A4MB/wOCAf8DgQH/A4EB/wOBAf8DfQH/A3sB/wN5Af8DdgH/
+ AVsCOgHGgAADMQFPAcED/wGcA/8BnAP/AZwD/wHWAf0B/gH/Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/
+ Ad8B+QH+Af8B3wH5Af4B/wHfAfkB/gH/AdAB8gH9Af/MAAMxAU8B6QP/AdwD/wHcA/8B3QP/AVgCQQG5
+ 7AABQAI9AW8BQAI9AW8BQAI9AW8BQAI9AW8DCAEL/wD/AP8A6wABQgFNAT4HAAE+AwABKAMAAUADAAEQ
+ AwABAQEAAQEFAAGAFwAD/wEABP8EAAGAAQMC/wUAAQMC/wUAAQMC/wUAAQEC/wUAAQEBgAYAAQEBgAcA
+ AYAHAAGABgABBwGABgABBwL/BAABAwP/BAABgwP/BAAE/wQABP8EAAT/BAAL
</value>
</data>
- <data name="chkPing.AutoSize" type="System.Boolean, mscorlib">
- <value>True</value>
- </data>
- <data name="chkPing.Enabled" type="System.Boolean, mscorlib">
- <value>False</value>
- </data>
- <data name="chkPing.ImeMode" type="System.Windows.Forms.ImeMode, System.Windows.Forms">
- </data>
- <data name="chkPing.Location" type="System.Drawing.Point, System.Drawing">
- <value>11, 46</value>
- </data>
- <data name="chkPing.Size" type="System.Drawing.Size, System.Drawing">
- <value>235, 17</value>
- </data>
- <data name="chkPing.TabIndex" type="System.Int32, mscorlib">
- <value>18</value>
- </data>
- <data name="chkPing.Text" xml:space="preserve">
- <value>Enable Server Ping (prevents session expiry)</value>
- </data>
- <data name=">>chkPing.Name" xml:space="preserve">
- <value>chkPing</value>
- </data>
- <data name=">>chkPing.Type" xml:space="preserve">
- <value>System.Windows.Forms.CheckBox, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
- </data>
- <data name=">>chkPing.Parent" xml:space="preserve">
- <value>$this</value>
- </data>
- <data name=">>chkPing.ZOrder" xml:space="preserve">
- <value>2</value>
- </data>
<metadata name="$this.Localizable" type="System.Boolean, mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089">
<value>True</value>
</metadata>
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/Strings/LayoutEditor.resx
--- trunk/Tools/Maestro/Maestro/ResourceEditors/Strings/LayoutEditor.resx 2010-05-06 13:53:15 UTC (rev 4843)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/Strings/LayoutEditor.resx 2010-05-07 12:35:09 UTC (rev 4844)
@@ -149,4 +149,4 @@
<value>The Web Layout has unsaved changes. If you do not save, the original version of the Web Layout will be shown. Save first before viewing?</value>
<comment>en "View in browser" is clicked with unsaved changes</comment>
</data>
-</root>
\ No newline at end of file
+</root>
Modified: trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs
--- trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs 2010-05-06 13:53:15 UTC (rev 4843)
+++ trunk/Tools/Maestro/MaestroAPI/Generated/WebLayout-1.0.0.cs 2010-05-07 12:35:09 UTC (rev 4844)
@@ -18,156 +18,23 @@
#endregion
-using System.Xml.Serialization;
namespace OSGeo.MapGuide.MaestroAPI
- [System.Xml.Serialization.XmlRootAttribute("WebLayout", Namespace = "", IsNullable = false)]
- public class WebLayout1_1 : WebLayout
- public WebLayout1_1()
- this.XsdSchema = "WebLayout-1.1.0.xsd";
- public override string Title
- get
- return base.Title;
- set
- base.Title = value;
- public override MapType Map
- get
- return base.Map;
- set
- base.Map = value;
- //HACK: We can't bolt on extra properties as new schema versions are published. There's gotta be a cleaner way.
- //Having ech version as its own class is not pretty either, but it looks like a cleaner way
- [XmlElement]
- public bool EnablePingServer
- get;
- set;
- public override ToolBarType ToolBar
- get
- return base.ToolBar;
- set
- base.ToolBar = value;
- public override InformationPaneType InformationPane
- get
- return base.InformationPane;
- set
- base.InformationPane = value;
- public override ContextMenuType ContextMenu
- get
- return base.ContextMenu;
- set
- base.ContextMenu = value;
- public override TaskPaneType TaskPane
- get
- return base.TaskPane;
- set
- base.TaskPane = value;
- public override StatusBarType StatusBar
- get
- return base.StatusBar;
- set
- base.StatusBar = value;
- public override ZoomControlType ZoomControl
- get
- return base.ZoomControl;
- set
- base.ZoomControl = value;
- public override CommandTypeCollection CommandSet
- get
- return base.CommandSet;
- set
- base.CommandSet = value;
/// <remarks/>
[System.Xml.Serialization.XmlRootAttribute("WebLayout", Namespace="", IsNullable=false)]
public class WebLayout {
+ public static readonly string SchemaName = "WebLayout-1.0.0.xsd";
+ [System.Xml.Serialization.XmlAttribute("noNamespaceSchemaLocation", Namespace="http://www.w3.org/2001/XMLSchema-instance")]
+ public string XsdSchema
+ get { return SchemaName; }
+ set { if (value != SchemaName) throw new System.Exception("Cannot set the schema name"); }
- // All top-level properties are virtual because newer versions (eg. 1.1.0) introduce new elements
- // at certain positions in the xml document. XML documents are unfortunately sensitive to ordering/position
- // and our classes must follow the same order.
- public WebLayout()
- this.XsdSchema = "WebLayout-1.0.0.xsd";
- [System.Xml.Serialization.XmlAttribute("noNamespaceSchemaLocation", Namespace = "http://www.w3.org/2001/XMLSchema-instance")]
- public string XsdSchema
- get;
- set;
private string m_resourceId;
[System.Xml.Serialization.XmlIgnore()]
public string ResourceId
@@ -197,9 +64,9 @@
private StatusBarType m_statusBar;
private ZoomControlType m_zoomControl;
private CommandTypeCollection m_commandSet;
/// <remarks/>
- public virtual string Title {
+ public string Title {
get {
return this.m_title;
@@ -209,7 +76,7 @@
/// <remarks/>
- public virtual MapType Map {
+ public MapType Map {
get {
return this.m_map;
@@ -217,9 +84,9 @@
this.m_map = value;
/// <remarks/>
- public virtual ToolBarType ToolBar {
+ public ToolBarType ToolBar {
get {
return this.m_toolBar;
@@ -229,7 +96,7 @@
/// <remarks/>
- public virtual InformationPaneType InformationPane {
+ public InformationPaneType InformationPane {
get {
return this.m_informationPane;
@@ -239,8 +106,7 @@
/// <remarks/>
- public virtual ContextMenuType ContextMenu
+ public ContextMenuType ContextMenu {
get {
return this.m_contextMenu;
@@ -250,8 +116,7 @@
/// <remarks/>
- public virtual TaskPaneType TaskPane
+ public TaskPaneType TaskPane {
get {
return this.m_taskPane;
@@ -261,8 +126,7 @@
/// <remarks/>
- public virtual StatusBarType StatusBar
+ public StatusBarType StatusBar {
get {
return this.m_statusBar;
@@ -272,8 +136,7 @@
/// <remarks/>
- public virtual ZoomControlType ZoomControl
+ public ZoomControlType ZoomControl {
get {
return this.m_zoomControl;
@@ -284,8 +147,7 @@
/// <remarks/>
[System.Xml.Serialization.XmlArrayItemAttribute("Command", IsNullable=false)]
- public virtual CommandTypeCollection CommandSet
+ public CommandTypeCollection CommandSet {
get {
return this.m_commandSet;
More information about the mapguide-commits
