[mapguide-commits] r4879 - sandbox/maestro-2.5/Maestro.Base/UI
svn_mapguide at osgeo.org
Fri May 14 04:57:31 EDT 2010
Author: jng
Date: 2010-05-14 04:57:30 -0400 (Fri, 14 May 2010)
New Revision: 4879
sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs
Mono stability fixes
Modified: sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs
--- sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs 2010-05-14 07:48:49 UTC (rev 4878)
+++ sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs 2010-05-14 08:57:30 UTC (rev 4879)
@@ -208,10 +208,19 @@
private void browser_ProgressChanged(object sender, WebBrowserProgressChangedEventArgs e)
- progressBar.Maximum = (int)e.MaximumProgress;
- progressBar.Value = (int)e.CurrentProgress;
- this.Title = browser.Document.Title;
- this.Description = browser.Document.Title + " - Embedded Web Browser"; //LOCALIZE
+ if (e.MaximumProgress > 0)
+ progressBar.Maximum = (int)e.MaximumProgress;
+ if (e.CurrentProgress >= progressBar.Minimum && e.CurrentProgress <= progressBar.Maximum)
+ progressBar.Value = (int)e.CurrentProgress;
+ if (browser.Document != null)
+ this.Title = browser.Document.Title;
+ this.Description = browser.Document.Title + " - Embedded Web Browser"; //LOCALIZE
private void txtUrl_KeyUp(object sender, KeyEventArgs e)
More information about the mapguide-commits
