[mapguide-commits] r4880 -
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/Aga.Controls/Properties
svn_mapguide at osgeo.org
Fri May 14 05:22:40 EDT 2010
Author: jng
Date: 2010-05-14 05:22:38 -0400 (Fri, 14 May 2010)
New Revision: 4880
sandbox/maestro-2.5/Thirdparty/TreeViewAdv/Aga.Controls/Properties/Resources.resx
Fix path casing, which is an issue if you want to build this in MonoDevelop
Modified: sandbox/maestro-2.5/Thirdparty/TreeViewAdv/Aga.Controls/Properties/Resources.resx
--- sandbox/maestro-2.5/Thirdparty/TreeViewAdv/Aga.Controls/Properties/Resources.resx 2010-05-14 08:57:30 UTC (rev 4879)
+++ sandbox/maestro-2.5/Thirdparty/TreeViewAdv/Aga.Controls/Properties/Resources.resx 2010-05-14 09:22:38 UTC (rev 4880)
@@ -122,7 +122,7 @@
<value>..\Resources\check.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="DVSplit" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\resources\dvsplit.cur;System.Byte[], mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+ <value>..\Resources\DVSplit.cur;System.Byte[], mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</data>
<data name="Folder" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\Folder.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
@@ -131,7 +131,7 @@
<value>..\Resources\FolderClosed.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="Leaf" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\resources\leaf.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <value>..\Resources\Leaf.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="loading_icon" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\loading_icon;System.Byte[], mscorlib, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
@@ -146,6 +146,6 @@
<value>..\Resources\uncheck.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="unknown" type="System.Resources.ResXFileRef, System.Windows.Forms">
- <value>..\resources\unknown.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
+ <value>..\Resources\unknown.bmp;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
</root>
\ No newline at end of file
More information about the mapguide-commits
