[mapguide-commits] r4881 - in sandbox/maestro-2.5: Maestro
Maestro/Properties Maestro.Base/Properties Maestro.Base/UI
OSGeo.MapGuide.MaestroAPI
svn_mapguide at osgeo.org
Fri May 14 05:44:44 EDT 2010
Author: jng
Date: 2010-05-14 05:44:44 -0400 (Fri, 14 May 2010)
New Revision: 4881
sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx
sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs
sandbox/maestro-2.5/Maestro/Maestro.csproj
sandbox/maestro-2.5/Maestro/Program.cs
sandbox/maestro-2.5/Maestro/Properties/Resources.Designer.cs
sandbox/maestro-2.5/Maestro/Properties/Resources.resx
sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs
Fix the platform check, which was incorrect. Also tweak the Web Browser title (it wasn't showing in Mono)
Modified: sandbox/maestro-2.5/Maestro/Maestro.csproj
--- sandbox/maestro-2.5/Maestro/Maestro.csproj 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro/Maestro.csproj 2010-05-14 09:44:44 UTC (rev 4881)
@@ -52,6 +52,7 @@
<Compile Include="Properties\Resources.Designer.cs">
<AutoGen>True</AutoGen>
<DependentUpon>Resources.resx</DependentUpon>
+ <DesignTime>True</DesignTime>
</Compile>
<None Include="Maestro.sh">
<CopyToOutputDirectory>Always</CopyToOutputDirectory>
Modified: sandbox/maestro-2.5/Maestro/Program.cs
--- sandbox/maestro-2.5/Maestro/Program.cs 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro/Program.cs 2010-05-14 09:44:44 UTC (rev 4881)
@@ -26,6 +26,7 @@
using System.Reflection;
using ICSharpCode.Core.Services;
using Maestro.Base.UI;
+using OSGeo.MapGuide.MaestroAPI;
namespace Maestro
@@ -52,6 +53,11 @@
// to System.Diagnostics.Trace.
LoggingService.Info("Application start");
+ if (!Platform.IsWindows)
+ LoggingService.Info(Properties.Resources.Warn_Mono);
AppDomain.CurrentDomain.AssemblyLoad += new AssemblyLoadEventHandler(CurrentDomain_AssemblyLoad);
// Get a reference to the entry assembly (Startup.exe)
Modified: sandbox/maestro-2.5/Maestro/Properties/Resources.Designer.cs
--- sandbox/maestro-2.5/Maestro/Properties/Resources.Designer.cs 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro/Properties/Resources.Designer.cs 2010-05-14 09:44:44 UTC (rev 4881)
@@ -8,10 +8,10 @@
// </auto-generated>
-namespace Maestro.Properties
+namespace Maestro.Properties {
+ using System;
/// <summary>
/// A strongly-typed resource class, for looking up localized strings, etc.
/// </summary>
@@ -22,50 +22,51 @@
[global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
[global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
[global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
- internal class Resources
+ internal class Resources {
private static global::System.Resources.ResourceManager resourceMan;
private static global::System.Globalization.CultureInfo resourceCulture;
[global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
- internal Resources()
+ internal Resources() {
/// <summary>
/// Returns the cached ResourceManager instance used by this class.
/// </summary>
[global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
- internal static global::System.Resources.ResourceManager ResourceManager
- get
- if ((resourceMan == null))
+ internal static global::System.Resources.ResourceManager ResourceManager {
+ get {
+ if (object.ReferenceEquals(resourceMan, null)) {
global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("Maestro.Properties.Resources", typeof(Resources).Assembly);
resourceMan = temp;
return resourceMan;
/// <summary>
/// Overrides the current thread's CurrentUICulture property for all
/// resource lookups using this strongly typed resource class.
/// </summary>
- internal static global::System.Globalization.CultureInfo Culture
- get
+ internal static global::System.Globalization.CultureInfo Culture {
+ get {
return resourceCulture;
- set
+ set {
resourceCulture = value;
+ /// <summary>
+ /// Looks up a localized string similar to It seems you're not running Windows. I assume you must be running Mono then. Please take note that some things may not work as intended in Mono. .
+ /// </summary>
+ internal static string Warn_Mono {
+ get {
+ return ResourceManager.GetString("Warn_Mono", resourceCulture);
Modified: sandbox/maestro-2.5/Maestro/Properties/Resources.resx
--- sandbox/maestro-2.5/Maestro/Properties/Resources.resx 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro/Properties/Resources.resx 2010-05-14 09:44:44 UTC (rev 4881)
@@ -46,7 +46,7 @@
mimetype: application/x-microsoft.net.object.binary.base64
value : The object must be serialized with
- : System.Serialization.Formatters.Binary.BinaryFormatter
+ : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
: and then encoded with base64 encoding.
mimetype: application/x-microsoft.net.object.soap.base64
@@ -60,6 +60,7 @@
<xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+ <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
<xsd:element name="root" msdata:IsDataSet="true">
<xsd:complexType>
<xsd:choice maxOccurs="unbounded">
@@ -68,9 +69,10 @@
<xsd:sequence>
<xsd:element name="value" type="xsd:string" minOccurs="0" />
</xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" />
+ <xsd:attribute name="name" use="required" type="xsd:string" />
<xsd:attribute name="type" type="xsd:string" />
<xsd:attribute name="mimetype" type="xsd:string" />
+ <xsd:attribute ref="xml:space" />
</xsd:complexType>
</xsd:element>
<xsd:element name="assembly">
@@ -85,9 +87,10 @@
<xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
<xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
</xsd:sequence>
- <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
+ <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
<xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
<xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
</xsd:complexType>
</xsd:element>
<xsd:element name="resheader">
@@ -114,4 +117,7 @@
<resheader name="writer">
<value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
</resheader>
+ <data name="Warn_Mono" xml:space="preserve">
+ <value>It seems you're not running Windows. I assume you must be running Mono then. Please take note that some things may not work as intended in Mono. </value>
+ </data>
</root>
\ No newline at end of file
Modified: sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro.Base/Properties/Resources.Designer.cs 2010-05-14 09:44:44 UTC (rev 4881)
@@ -1,7 +1,7 @@
// <auto-generated>
// This code was generated by a tool.
-// Runtime Version:2.0.50727.4927
+// Runtime Version:2.0.50727.3053
// Changes to this file may cause incorrect behavior and will be lost if
// the code is regenerated.
@@ -194,7 +194,7 @@
/// <summary>
- /// Looks up a localized string similar to Web Browser.
+ /// Looks up a localized string similar to Embedded Web Browser.
/// </summary>
internal static string Content_WebBrowser {
get {
Modified: sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro.Base/Properties/Resources.resx 2010-05-14 09:44:44 UTC (rev 4881)
@@ -257,7 +257,7 @@
<value>..\Resources\arrow-circle-045-left.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="Content_WebBrowser" xml:space="preserve">
- <value>Web Browser</value>
+ <value>Embedded Web Browser</value>
</data>
<data name="cross_script" type="System.Resources.ResXFileRef, System.Windows.Forms">
<value>..\Resources\cross-script.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
Modified: sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs
--- sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/Maestro.Base/UI/EmbeddedWebBrowser.cs 2010-05-14 09:44:44 UTC (rev 4881)
@@ -37,7 +37,6 @@
public EmbeddedWebBrowser()
InitializeComponent();
- this.Title = Properties.Resources.Content_WebBrowser;
_presenter = new WebBrowserPresenter(this);
@@ -55,6 +54,7 @@
protected override void OnLoad(EventArgs e)
base.OnLoad(e);
+ this.Title = Properties.Resources.Content_WebBrowser;
if (!string.IsNullOrEmpty(_initUrl))
txtUrl.Text = _initUrl;
@@ -208,7 +208,7 @@
private void browser_ProgressChanged(object sender, WebBrowserProgressChangedEventArgs e)
- if (e.MaximumProgress > 0)
+ if (e.MaximumProgress > 0) //Mono WebBrowser stability
progressBar.Maximum = (int)e.MaximumProgress;
@@ -216,7 +216,7 @@
progressBar.Value = (int)e.CurrentProgress;
- if (browser.Document != null)
+ if (browser.Document != null) //Mono WebBrowser stability
this.Title = browser.Document.Title;
this.Description = browser.Document.Title + " - Embedded Web Browser"; //LOCALIZE
Modified: sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs
--- sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs 2010-05-14 09:22:38 UTC (rev 4880)
+++ sandbox/maestro-2.5/OSGeo.MapGuide.MaestroAPI/Platform.cs 2010-05-14 09:44:44 UTC (rev 4881)
@@ -27,7 +27,7 @@
public static bool IsWindows
- get { return Environment.OSVersion.Platform != PlatformID.Unix || Environment.OSVersion.Platform != PlatformID.MacOSX; }
+ get { return Environment.OSVersion.Platform != PlatformID.Unix && Environment.OSVersion.Platform != PlatformID.MacOSX; }
More information about the mapguide-commits
