[mapguide-commits] r5230 - trunk/MgDev/Web/src/mapviewerphp
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Oct 2 02:04:47 EDT 2010
Author: waltweltonlair
Date: 2010-10-02 06:04:47 +0000 (Sat, 02 Oct 2010)
New Revision: 5230
   trunk/MgDev/Web/src/mapviewerphp/buffer.php
   trunk/MgDev/Web/src/mapviewerphp/common.php
   trunk/MgDev/Web/src/mapviewerphp/getselectedfeatures.php
   trunk/MgDev/Web/src/mapviewerphp/mainframe.php
   trunk/MgDev/Web/src/mapviewerphp/mapframe.php
   trunk/MgDev/Web/src/mapviewerphp/measureui.php
   trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
   trunk/MgDev/Web/src/mapviewerphp/quickplotpreviewinner.php
   trunk/MgDev/Web/src/mapviewerphp/selectwithin.php
   trunk/MgDev/Web/src/mapviewerphp/taskframe.php
Just run my regular tab/cleanup script...
Modified: trunk/MgDev/Web/src/mapviewerphp/buffer.php
--- trunk/MgDev/Web/src/mapviewerphp/buffer.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/buffer.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -377,7 +377,7 @@
     $foretrans = GetDoubleParameter($params, 'FORETRANS');
     $thickness = GetDoubleParameter($params, 'THICKNESS');
     $bufferName = GetParameter($params, 'BUFFER');
     $layersParam = GetParameter($params, 'LAYERS');
     $units = GetParameter($params, 'UNITS');
     $linestyle = GetParameter($params, 'LINESTYLE');
Modified: trunk/MgDev/Web/src/mapviewerphp/common.php
--- trunk/MgDev/Web/src/mapviewerphp/common.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/common.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -252,33 +252,33 @@
 function GetParameter($params, $paramName)
-	$paramValue = "";
+    $paramValue = "";
-	if(isset($params[$paramName]))
-		$paramValue = $params[$paramName];
-	return $paramValue;
+    if(isset($params[$paramName]))
+        $paramValue = $params[$paramName];
+    return $paramValue;
 function GetIntParameter($params, $paramName)
-	$paramValue = 0;
-	if(isset($params[$paramName]) && is_numeric($params[$paramName]))
-		$paramValue = intval($params[$paramName]);
+    $paramValue = 0;
+    if(isset($params[$paramName]) && is_numeric($params[$paramName]))
+        $paramValue = intval($params[$paramName]);
 function GetDoubleParameter($params, $paramName)
-	$paramValue = 0.0;
-		$paramValue = doubleval($params[$paramName]);
+    $paramValue = 0.0;
+        $paramValue = doubleval($params[$paramName]);
Modified: trunk/MgDev/Web/src/mapviewerphp/getselectedfeatures.php
--- trunk/MgDev/Web/src/mapviewerphp/getselectedfeatures.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/getselectedfeatures.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -4,9 +4,9 @@
 TODO:
-- Use the property mapping. This will have to be old-fashioned parsing the <PropertyMapping> elements
+- Use the property mapping. This will have to be old-fashioned parsing the <PropertyMapping> elements
 of the layer definition. I really wanted to use MgSelection::GetSelectedFeatures(layer, class, true) but realised
-that unless the geometry is mapped, you're not going to see it in the Feature Reader (ie. No zoom point). Right now
+that unless the geometry is mapped, you're not going to see it in the Feature Reader (ie. No zoom point). Right now
 it is returning all properties.
 - I know of a few features in the Sheboygan Dataset that trip up the JSON response. Need to find out of addslashes() fixes this.
@@ -24,31 +24,31 @@
 class SelectionSet
     private $layers;
     public function __construct()
         $this->layers = array();
     public function AddFeature($feat)
         $layerName = $feat->layerName;
         if(!array_key_exists($layerName, $this->layers))
             $this->layers[$layerName] = array();
         array_push($this->layers[$layerName], $feat);
     public function GetLayers()
         return array_keys($this->layers);
     public function GetFeatures($layerName)
         if(array_key_exists($layerName, $this->layers))
             return $this->layers[$layerName];
         return null;
@@ -75,27 +75,27 @@
     public $layerName;
     public $zoom;
     private $properties;
     public function __construct($layerName)
         $this->layerName = $layerName;
         $this->properties = array();
     public function AddProperty($prop)
         $this->properties[$prop->name] = $prop;
     public function GetProperties()
         return $this->properties;
-	include 'common.php';
+    include 'common.php';
     include 'constants.php';
     $mapName = "";
@@ -103,17 +103,17 @@
     $locale = "";
     GetRequestParameters();
     if (null == $locale || strlen($locale) == 0)
         $locale = GetDefaultLocale();
     setlocale(LC_ALL, $locale);
-	try
-		InitializeWebTier();
-		$cred = new MgUserInformation($sessionId);
+    try
+        InitializeWebTier();
+        $cred = new MgUserInformation($sessionId);
         $cred->SetClientIp(GetClientIp());
         $cred->SetClientAgent(GetClientAgent());
@@ -127,30 +127,30 @@
         $map = new MgMap($site);
         $map->Open($mapName);
-		// Create the selection set
+        // Create the selection set
         $selection = new MgSelection($map);
         $selection->Open($resourceSrvc, $mapName);
-		$layers = $selection->GetLayers();
+        $layers = $selection->GetLayers();
         if($layers != null)
             $nLayers = $layers->GetCount();
             $agfRW = new MgAgfReaderWriter();
             $selectionSet = new SelectionSet();
             for ($i = 0; $i < $nLayers; $i++) {
                 $lyr = $layers->GetItem($i);
                 $layerName = $lyr->GetName();
                 //FB::log("Layer Name: " . $lyr->GetName());
                 $featResId = new MgResourceIdentifier($lyr->GetFeatureSourceId());
                 $class = $lyr->GetFeatureClassName();
                 $queryOptions = new MgFeatureQueryOptions();
                 $mappings = GetLayerPropertyMappings($resourceSrvc, $lyr);
                 //FB::log("Property Mappings for Layer: $layerName");
                 foreach($mappings as $name => $value) {
@@ -159,27 +159,27 @@
                 $geomName = $lyr->GetFeatureGeometryName();
                 $queryOptions->AddFeatureProperty($geomName);
                 $filter = $selection->GenerateFilter($lyr, $class);
                 $queryOptions->SetFilter($filter);
                 $fr = $lyr->SelectFeatures($queryOptions);
                 $clsDef = $fr->GetClassDefinition();
                 $props = $clsDef->GetProperties();
                 //FB::log("Geometry: $geomName");
                 while($fr->ReadNext())
                     $feat = new Feature($layerName);
                     $zoom = null;
                     for ($k = 0; $k < $props->GetCount(); $k++)
                         $prop = $props->GetItem($k);
                         $propName = $prop->GetName();
                         $propType = $fr->GetPropertyType($propName);
                         //We only care about mapped properties or geometry properties
                         if (array_key_exists($propName, $mappings) || $propType == MgPropertyType::Geometry)
@@ -192,11 +192,11 @@
                                     $agf = $fr->GetGeometry($propName);
                                     $geom = $agfRW->Read($agf);
                                     $pt = $geom->GetCentroid()->GetCoordinate();
                                     $zoom = new ZoomPoint();
                                     $zoom->x = $pt->GetX();
                                     $zoom->y = $pt->GetY();
                                     $feat->zoom = $zoom;
                                     //FB::log("zoom: (".$zoom->x.",".$zoom->y.")");
@@ -205,28 +205,28 @@
                                     $value = GetPropertyValueFromFeatureReader($fr, $agfRW, $propType, $propName);
                             if (array_key_exists($propName, $mappings))
                                 $fp = new FeatureProperty();
                                 $fp->name = $mappings[$propName];
                                 $fp->value = $value;
                                 $feat->AddProperty($fp);
                     $c = count($feat->GetProperties());
                     //FB::log("Selected feature processed ($c)");
                     $selectionSet->AddFeature($feat);
                 $fr->Close();
             //Now output the selection set
             header("Content-Type: application/json");
             header("X-JSON: true");
             echo GetJson($selectionSet);
@@ -238,7 +238,7 @@
         echo JsonifyError($e->getMessage(), $e->getTraceAsString());
-	catch(MgException $e)
+    catch(MgException $e)
@@ -249,60 +249,60 @@
     if($selectionSet == null)
         return "";
     //FB::log("Processing JSON response");
-	A sample of the JSON output this method will produce:
-		"Layer1" : [
-				'values' { "name" : "name1" , "value" : "value1" },
-				'zoom' : { x: num1, y: num2 }
-		"Layer2" : [
-				'values' { "name" : "name2" , "value" : "value2" },
+    A sample of the JSON output this method will produce:
+        "Layer1" : [
+                'values' { "name" : "name1" , "value" : "value1" },
+                'zoom' : { x: num1, y: num2 }
+        "Layer2" : [
+                'values' { "name" : "name2" , "value" : "value2" },
     $layers = $selectionSet->GetLayers();
     $totalLayers = array(); //The data portion of the JSON response
     //FB::log("Layers in selection set: ".count($layers));
     for ($i = 0; $i < count($layers); $i++)
         $layerName = $layers[$i];
         $features = $selectionSet->GetFeatures($layerName);
         //FB::log("Features: ".$features);
         if($features != null)
             //FB::log("Processing layer: $layerName");
             $totalFeaturesOnLayer = array();
             if (count($features) > 0)
                 for ($j = 0; $j < count($features); $j++)
                     $feat = $features[$j];
                     $featureProperties = array();
                     $fps = $feat->GetProperties();
                     foreach($fps as $fp)
@@ -316,18 +316,18 @@
                         array_push($totalFeaturesOnLayer, "{\"values\" : [".join(",", $featureProperties)."], \"zoom\" : { \"x\": ".$feat->zoom->x.", \"y\": ".$feat->zoom->y." } }");
                     else
                         array_push($totalFeaturesOnLayer, "{\"values\" : [".join(",", $featureProperties)."], \"zoom\" : null }");
                     //FB::log("Feature processed on layer: $layerName");
             array_push($totalLayers, "\"$layerName\" : [" . join(", ", $totalFeaturesOnLayer) . "]");
             //FB::log("Selected features on layer added to final JSON response");
     //FB::log("Selection layer count: ".count($totalLayers));
     $result = "{" . join(",",$totalLayers) . "}";
     //return json_encode($result);
     return $result;
@@ -482,4 +482,4 @@
         GetParameters($_GET);
\ No newline at end of file
Modified: trunk/MgDev/Web/src/mapviewerphp/mainframe.php
--- trunk/MgDev/Web/src/mapviewerphp/mainframe.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/mainframe.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -581,7 +581,7 @@
     global $debug, $webLayoutDefinition;
     global $sessionId, $username, $password, $orgSessionId, $locale;
-	$sessionId = ValidateSessionId(GetParameter($params, 'SESSION'));
+    $sessionId = ValidateSessionId(GetParameter($params, 'SESSION'));
     $locale = ValidateLocaleString(GetParameter($params, 'LOCALE'));
     $webLayoutDefinition = ValidateResourceId(GetParameter($params, 'WEBLAYOUT'));
Modified: trunk/MgDev/Web/src/mapviewerphp/mapframe.php
--- trunk/MgDev/Web/src/mapviewerphp/mapframe.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/mapframe.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -173,7 +173,7 @@
     $hlTgt = ValidateHyperlinkTargetValue(GetParameter($params, 'HLTGT'));
     $hlTgtName = ValidateFrameName(GetParameter($params, 'HLTGTNAME'));
     $mapDefinition = ValidateResourceId(GetParameter($params, 'MAPDEFINITION'));
-	$showLegend = (GetIntParameter($params, 'SHOWLEGEND') == 1);
+    $showLegend = (GetIntParameter($params, 'SHOWLEGEND') == 1);
     $showProperties = (GetIntParameter($params, 'SHOWPROP') == 1);
     $showSlider = (GetIntParameter($params, 'SHOWSLIDER') == 1);
     $infoWidth = GetIntParameter($params, 'INFOWIDTH');
Modified: trunk/MgDev/Web/src/mapviewerphp/measureui.php
--- trunk/MgDev/Web/src/mapviewerphp/measureui.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/measureui.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -44,8 +44,8 @@
-    $mapName = ValidateMapName(GetParameter($params, 'MAPNAME'));
-	$target = GetIntParameter($params, 'TGT');
+    $mapName = ValidateMapName(GetParameter($params, 'MAPNAME'));
+    $target = GetIntParameter($params, 'TGT');
     $popup = GetIntParameter($params, 'POPUP');
     $cmdIndex = GetIntParameter($params, 'CMDINDEX');
     $clientWidth = GetIntParameter($params, 'WIDTH');
Modified: trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php
--- trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/quickplotgeneratepicture.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -2,7 +2,7 @@
     $sessionID = "";
     $mapName   = "";
     $rotation  = 0.0;
@@ -12,12 +12,12 @@
     $normalizedCapture;
     $printSize;
     $paperSize;
     GetParameters();
     GenerateMap($printSize);
-<?php
+<?php
     function GetParameters()
         global $sessionID, $mapName, $printDpi, $rotation, $paperSize, $captureBox, $printSize, $scaleDenominator, $normalizedCapture;
@@ -26,8 +26,8 @@
             $args = $_POST;
-        // Not necessary to validate the parameters
+        // Not necessary to validate the parameters
         $sessionID   = $args["session_id"];
         $mapName     = $args["map_name"];
         $rotation    = floatval($args["rotation"]);
@@ -38,49 +38,49 @@
         $array       = explode(",", $args["paper_size"]);
         $paperSize   = new Size(floatval($array[0]), floatval($array[1]));
         $printSize   = new Size($paperSize->width / 25.4 * $printDpi, $paperSize->height / 25.4 * $printDpi);
         $array       = explode(",", $args["box"]);
         $captureBox  = CreatePolygon($array);
         $array       = explode(",", $args["normalized_box"]);
         $normalizedCapture = CreatePolygon($array);
     function CreatePolygon($coordinates)
         $geometryFactory      = new MgGeometryFactory();
         $coordinateCollection = new MgCoordinateCollection();
         $linearRingCollection = new MgLinearRingCollection();
         for ($index = 0; $index < count($coordinates); ++$index)
             $coordinate = $geometryFactory->CreateCoordinateXY(floatval($coordinates[$index]), floatval($coordinates[++$index]));
             $coordinateCollection->Add($coordinate);
         $coordinateCollection->Add($geometryFactory->CreateCoordinateXY(floatval($coordinates[0]), floatval($coordinates[1])));
         $linearRingCollection = $geometryFactory->CreateLinearRing($coordinateCollection);
         $captureBox           = $geometryFactory->CreatePolygon($linearRingCollection, null);
         return $captureBox;
     function GenerateMap($size)
         global $sessionID, $mapName, $captureBox, $printSize, $normalizedCapture, $rotation, $scaleDenominator, $printDpi;
         $userInfo         = new MgUserInformation($sessionID);
         $siteConnection   = new MgSiteConnection();
         $siteConnection->Open($userInfo);
         $resourceService  = $siteConnection->CreateService(MgServiceType::ResourceService);
         $renderingService = $siteConnection->CreateService(MgServiceType::RenderingService);
         $map = new MgMap();
         $map->Open($resourceService, $mapName);
         // Calculate the generated picture size
         $envelope         = $captureBox->Envelope();
         $normalizedE      = $normalizedCapture->Envelope();
@@ -88,7 +88,7 @@
         $size2            = new Size($normalizedE->getWidth(), $normalizedE->getHeight());
         $toSize           = new Size($size1->width / $size2->width * $size->width, $size1->height / $size2->height * $size->height);
         $center           = $captureBox->GetCentroid()->GetCoordinate();
         // Get the map agent url
         // Get the correct http protocal
         $mapAgent = "http";
@@ -98,20 +98,20 @@
         // Get the correct port number
         // Just use the 127.0.0.1 specificly to point to localhost. Because the WebExtension will
-        // be always on the same server with map agent.
+        // be always on the same server with map agent.
         $mapAgent .= "://127.0.0.1:" . $_SERVER["SERVER_PORT"];
         // Get the correct virtual directory
         $mapAgent .= substr($_SERVER["REQUEST_URI"], 0, strpos($_SERVER["REQUEST_URI"], "/", 1));
         $mapAgent .="/mapagent/mapagent.fcgi?VERSION=1.0.0&OPERATION=GETMAPIMAGE" .
-                    "&SESSION=$sessionID" .
+                    "&SESSION=$sessionID" .
                     "&MAPNAME=$mapName" .
                     "&FORMAT=PNG" .
                     "&SETVIEWCENTERX=" . $center->GetX() .
                     "&SETVIEWCENTERY=" . $center->GetY() .
-                    "&SETVIEWSCALE=$scaleDenominator" .
-                    "&SETDISPLAYDPI=$printDpi" .
-                    "&SETDISPLAYWIDTH=$toSize->width" .
-                    "&SETDISPLAYHEIGHT=$toSize->height" .
+                    "&SETVIEWSCALE=$scaleDenominator" .
+                    "&SETDISPLAYDPI=$printDpi" .
+                    "&SETDISPLAYWIDTH=$toSize->width" .
+                    "&SETDISPLAYHEIGHT=$toSize->height" .
                     "&CLIP=0";
         $image = imagecreatefrompng($mapAgent);
@@ -127,15 +127,15 @@
         // Draw the north arrow on the map
         DrawNorthArrow($croppedImg);
-        header ("Content-type: image/png");
+        header ("Content-type: image/png");
         imagepng($croppedImg);
         imagedestroy($croppedImg);
     function DrawNorthArrow($map)
         global $paperSize, $rotation;
         // Load the north arrow image which has a 300 dpi resolution
         $na         = imagecreatefrompng("../viewerfiles/quickplotnortharrow.png");
         // Rotate the north arrow according to the capture rotation
@@ -162,21 +162,21 @@
         // Draw the north arrow on the map picture
         imagecopyresized($map, $rotatedNa, $mapWidth - $drawWidth - $margin, $mapHeight - $drawHeight - $margin, 0, 0, $drawWidth, $drawHeight, $naWidth, $naHeight);
         // Free the north arrow image
-        imagedestroy($rotatedNa);
+        imagedestroy($rotatedNa);
-<?php
+<?php
     class Size
         public $width;
         public $height;
         public function __construct($width, $height)
             $this->width  = $width;
             $this->height = $height;
Modified: trunk/MgDev/Web/src/mapviewerphp/quickplotpreviewinner.php
--- trunk/MgDev/Web/src/mapviewerphp/quickplotpreviewinner.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/quickplotpreviewinner.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -17,20 +17,20 @@
     $scaleDenominator;
     $annotations;
     $args = GetRequestMethod();
     GetParameters($args);
     $templ = file_get_contents("../viewerfiles/QuickPlotPreviewInner.templ");
     SetLocalizedFilesPath(GetLocalizationPath());
     // Localize the page
     $templ = Localize($templ, $locale, GetClientOS());
     // Set some annotation labels in the page by replacing the placeholders in the html code
     $templ = str_replace(array_keys($annotations), array_values($annotations), $templ);
     // Set the date annotation according to its format mask
@@ -42,7 +42,7 @@
         $date  = date($mask);
         $templ = preg_replace($pattern, $date, $templ);
     $jsPath    = "../viewerfiles/";
     print sprintf($templ, $jsPath);
@@ -51,10 +51,10 @@
 function GetParameters($params)
     global $scaleDenominator, $annotations;
     $scaleDenominator = intval($params["scale_denominator"]);
     $annotations = array();
     // The parameters whose name matches this pattern will be treated as annotation
     $pattern = "/^\{field:.+\}$/i";
     foreach ($params as $key => $value)
@@ -64,7 +64,7 @@
             $annotations[$key] = htmlspecialchars(urlDecode($value), ENT_QUOTES);
     // The scale annotation
     $annotations["{scale}"] = "1 : " . $scaleDenominator;
Modified: trunk/MgDev/Web/src/mapviewerphp/selectwithin.php
--- trunk/MgDev/Web/src/mapviewerphp/selectwithin.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/selectwithin.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -148,8 +148,8 @@
     $dwf = GetIntParameter($params, 'DWF');
-	$inputSel = UnescapeMagicQuotes(GetParameter($params, 'SELECTION'));
+    $inputSel = UnescapeMagicQuotes(GetParameter($params, 'SELECTION'));
     $layers = GetParameter($params, 'LAYERS');
Modified: trunk/MgDev/Web/src/mapviewerphp/taskframe.php
--- trunk/MgDev/Web/src/mapviewerphp/taskframe.php	2010-10-02 06:01:25 UTC (rev 5229)
+++ trunk/MgDev/Web/src/mapviewerphp/taskframe.php	2010-10-02 06:04:47 UTC (rev 5230)
@@ -30,27 +30,27 @@
 try
-	$cred->SetClientIp(GetClientIp());
-	$cred->SetClientAgent(GetClientAgent());
+    $cred->SetClientIp(GetClientIp());
+    $cred->SetClientAgent(GetClientAgent());
-	//Connect to the site
-	$site = new MgSiteConnection();
-	$site->Open($cred);
+    //Connect to the site
+    $site = new MgSiteConnection();
+    $site->Open($cred);
-	//Get the MgWebLayout object
-	$resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
-	$webLayoutResId = new MgResourceIdentifier($webLayoutId);
-	$webLayout = new MgWebLayout($resourceSrvc, $webLayoutResId);
-	$taskPane = $webLayout->GetTaskPane();
-	$taskPaneUrl = $taskPane->GetInitialTaskUrl();
-	$vpath = GetSurroundVirtualPath();
-	if ($taskPaneUrl == null || strlen($taskPaneUrl) == 0)
-		$taskPaneUrl = "gettingstarted.php";
+    //Get the MgWebLayout object
+    $resourceSrvc = $site->CreateService(MgServiceType::ResourceService);
+    $webLayoutResId = new MgResourceIdentifier($webLayoutId);
+    $webLayout = new MgWebLayout($resourceSrvc, $webLayoutResId);
+    $taskPane = $webLayout->GetTaskPane();
+    $taskPaneUrl = $taskPane->GetInitialTaskUrl();
+    $vpath = GetSurroundVirtualPath();
+    if ($taskPaneUrl == null || strlen($taskPaneUrl) == 0)
+        $taskPaneUrl = "gettingstarted.php";
     //If there is an initial url, it will be encoded, so parse the decoded url.
     $comp = parse_url(urldecode($taskPaneUrl));
More information about the mapguide-commits mailing list
