[mapguide-commits] r5231 - in trunk/MgDev/Web/src:
localized/help/en/style viewerfiles
svn_mapguide at osgeo.org
Sat Oct 2 02:07:46 EDT 2010
Author: waltweltonlair
Date: 2010-10-02 06:07:46 +0000 (Sat, 02 Oct 2010)
New Revision: 5231
trunk/MgDev/Web/src/localized/help/en/style/adsk.cpm.css
trunk/MgDev/Web/src/viewerfiles/jxtheme.css
Just run my regular tab/cleanup script...
Modified: trunk/MgDev/Web/src/localized/help/en/style/adsk.cpm.css
--- trunk/MgDev/Web/src/localized/help/en/style/adsk.cpm.css 2010-10-02 06:04:47 UTC (rev 5230)
+++ trunk/MgDev/Web/src/localized/help/en/style/adsk.cpm.css 2010-10-02 06:07:46 UTC (rev 5231)
@@ -21,11 +21,11 @@
div.body_content {
-margin: 0 12pt;
+margin: 0 12pt;
- Link styles
+ Link styles
a:link, a:active {color: #00289C; text-decoration: none;}
@@ -33,7 +33,7 @@
a:hover {color: #CE9E08; text-decoration: underline;}
- Table styles
+ Table styles
table {
@@ -65,24 +65,24 @@
} /*Body cells*/
-table.ruled, table.ruled-wide {
-width: 97%;
-margin: 1.4em 0;
-border-bottom: 3px solid #3D3D3D;
-border-top: 4px solid #3D3D3D;
-background-color: #F2F2F2;
+table.ruled, table.ruled-wide {
+width: 97%;
+margin: 1.4em 0;
+border-bottom: 3px solid #3D3D3D;
+border-top: 4px solid #3D3D3D;
+background-color: #F2F2F2;
-table.ruled th, table.ruled-wide th {
-color: white;
-background-color: #3D3D3D;
-padding: 4px 10px 7px 12px;
+table.ruled th, table.ruled-wide th {
+color: white;
+background-color: #3D3D3D;
+padding: 4px 10px 7px 12px;
vertical-align: middle;
-table.ruled td, table.ruled-wide td {
-padding: 6px 10px 7px 12px;
+table.ruled td, table.ruled-wide td {
+padding: 6px 10px 7px 12px;
border-bottom: 1px solid #3D3D3D;
vertical-align: baseline;
@@ -106,26 +106,26 @@
color: #3D3D3D;
-/* Unruled Tables */
+/* Unruled Tables */
-table.not-ruled, table.not-ruled-wide {
+table.not-ruled, table.not-ruled-wide {
width: 97%;
-margin: 1em 0;
+margin: 1em 0;
-table.not-ruled th, table.not-ruled-wide th {
+table.not-ruled th, table.not-ruled-wide th {
color: #338;
padding: 4px 20px 2px 0;
vertical-align: text-bottom;
-table.not-ruled td, table.not-ruled-wide td {
+table.not-ruled td, table.not-ruled-wide td {
vertical-align: top;
-table.not-ruled td div.figure-anchor,
+table.not-ruled td div.figure-anchor,
table.not-ruled-wide td div.figure-anchor {
-margin-top: 5pt;
+margin-top: 5pt;
@@ -141,9 +141,9 @@
/* div.note_xx within tables */
-table.ruled div.note-note,
-table.ruled-wide div.note-note,
-table.not-ruled div.note-note,
+table.ruled div.note-note,
+table.ruled-wide div.note-note,
+table.not-ruled div.note-note,
table.not-ruled-wide div.note-note {
margin: 2pt 0;
@@ -207,7 +207,7 @@
- List styles
+ List styles
ul {
@@ -441,25 +441,25 @@
cursor: pointer;
- Note styles
+ Note styles
-div.note-note,
-div.note-warning,
-div.note-tip,
-div.note-related,
-div.note-important,
+div.note-note,
+div.note-warning,
+div.note-tip,
+div.note-related,
+div.note-important,
div.note-bestpractice {
margin-top: 10pt;
margin-bottom: 0px;
/* Notes within table */
-table.table div.note-note,
-table.table div.note-warning,
-table.table div.note-tip,
-table.table div.note-related,
-table.table div.note-important,
+table.table div.note-note,
+table.table div.note-warning,
+table.table div.note-tip,
+table.table div.note-related,
+table.table div.note-important,
table.table div.note-bestpractice {
padding-top: 5px;
padding-bottom: 5px;
@@ -467,11 +467,11 @@
/* Notes within lists */
-li div.note-note,
-li div.note-warning,
-li div.note-tip,
-li div.note-related,
-li div.note-important,
+li div.note-note,
+li div.note-warning,
+li div.note-tip,
+li div.note-related,
+li div.note-important,
li div.note-bestpractice {
margin-left: 0pt;
margin-top: 2pt;
@@ -531,10 +531,10 @@
Code elements
-span.code,
-div.codeBlock,
-p.codeLine,
-p.codeComment,
+span.code,
+div.codeBlock,
+p.codeLine,
+p.codeComment,
span.codeLiteral {
font-family: "Courier New", Courier, monospace;
font-size: 10pt;
@@ -548,7 +548,7 @@
margin-left: 30pt;
} /* Only descendant code blocks should have indents */
-p.codeLine,
+p.codeLine,
p.codeComment {
padding: 1px;
margin: 1px;
@@ -591,7 +591,7 @@
- Charspan
+ Charspan
span.charspan-keyboardEntry {}
@@ -607,7 +607,7 @@
- Emphasis
+ Emphasis
em, em.mild {
font-style: italic;
@@ -624,7 +624,7 @@
- UIString
+ UIString
span.uis-promptMessage {
font-style: normal;
@@ -648,7 +648,7 @@
span.uis-unspecified {}
- Comments
+ Comments
div.comments-editor {
font-weight: bold;
@@ -672,9 +672,9 @@
- Misc
+ Misc
-.title,
+.title,
.list-intro {
font-weight: bold;
color: #990000;
@@ -787,7 +787,7 @@
p.summary {}
- Topic heading elements
+ Topic heading elements
/* head region */
@@ -967,7 +967,7 @@
} /* @media print */
/* collapse-expand block */
-/* contains the collapse block () and the expand block (), only
+/* contains the collapse block () and the expand block (), only
one of which is visible depending on collapse-expand state */
div.collapse-expand {
width: 200px;
@@ -1116,7 +1116,7 @@
background-color: #fff;
cursor: default;
-background-image: url(../images/tab-bkg-xn.gif);
+background-image: url(../images/tab-bkg-xn.gif);
background-repeat: repeat;
@@ -1183,7 +1183,7 @@
- Topic footing (comments section) elements
+ Topic footing (comments section) elements
div.footer-block {
@@ -1205,7 +1205,7 @@
- Art related elements
+ Art related elements
p.figure-title {
Modified: trunk/MgDev/Web/src/viewerfiles/jxtheme.css
--- trunk/MgDev/Web/src/viewerfiles/jxtheme.css 2010-10-02 06:04:47 UTC (rev 5230)
+++ trunk/MgDev/Web/src/viewerfiles/jxtheme.css 2010-10-02 06:07:46 UTC (rev 5231)
@@ -20,7 +20,7 @@
.jxDialog {
/* Base setup */
display: block;
- /* starting default z-index for dialogs. Multiple dialogs will get
+ /* starting default z-index for dialogs. Multiple dialogs will get
* incremental values starting from this value
z-index: 1000;
More information about the mapguide-commits
