[mapguide-commits] r5238 - in sandbox/maestro-3.0: Maestro.Base/Commands Maestro.Base/UI Maestro.Editors Maestro.Editors/FeatureSource Maestro.Editors/FeatureSource/Providers/Rdbms Maestro.Editors/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Oct 4 00:39:35 EDT 2010
Author: jng
Date: 2010-10-04 04:39:35 +0000 (Mon, 04 Oct 2010)
New Revision: 5238
Added:
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FsEditorMap.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.resx
   sandbox/maestro-3.0/Maestro.Editors/FsEditorMap.xml
   sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs
   sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
   sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FeatureSourceEditorCtrl.cs
   sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
   sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
   sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
3.0 sandbox changes:
 - Add specialized RDBMS feature source editors (MySQL, PostgreSQL, SQL Server 2008)
 - Add a FsEditorMap.xml file that allows the Feature Source Editor to resolve to a specialized implementation. If resolution fails, the generic one will be used.
 - Suppress NRE when refreshing the Site Explorer that hasn't been expanded for the first time. The side-effects of doing this is minor (Site Explorer not auto-expanding to where the resource was created).
Modified: sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs
--- sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs	2010-10-03 08:47:23 UTC (rev 5237)
+++ sandbox/maestro-3.0/Maestro.Base/Commands/SaveResourceAsCommand.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -49,8 +49,19 @@
                             ed.EditorService.SaveAs(picker.ResourceID);
-                            var rid = new ResourceIdentifier(picker.ResourceID);
-                            exp.RefreshModel(rid.ParentFolder);
+                            try
+                                var rid = new ResourceIdentifier(picker.ResourceID);
+                                exp.RefreshModel(rid.ParentFolder);
+                            catch (NullReferenceException)
+                                //HACK/FIXME: This can NRE if we created a new resource and
+                                //we haven't expanded the Site Explorer for the first
+                                //time. Muffling this NRE will just mean that the Site
+                                //Explorer won't auto-expand to the folder where this
+                                //resource was created. So nothing major.
Modified: sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs	2010-10-03 08:47:23 UTC (rev 5237)
+++ sandbox/maestro-3.0/Maestro.Base/UI/SiteExplorer.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -241,6 +241,9 @@
         public void ExpandNode(string folderId)
+            if ("Library://".Equals(folderId))
+                return;
             var path = _model.GetPathFromResourceId(folderId);
             if (path != null)
Modified: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FeatureSourceEditorCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FeatureSourceEditorCtrl.cs	2010-10-03 08:47:23 UTC (rev 5237)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FeatureSourceEditorCtrl.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -48,7 +48,7 @@
             service.RegisterCustomNotifier(this);
             Debug.Assert(_fs != null);
-            CollapsiblePanel panel = ResolveTopPanel(_fs.Provider);
+            CollapsiblePanel panel = FsEditorMap.GetPanel(_fs.Provider);
             var b = panel as IEditorBindable;
             if (b != null)
                 b.Bind(service);
@@ -69,18 +69,5 @@
             this.Controls.Add(ov);
             this.Controls.Add(panel);
-        private static CollapsiblePanel ResolveTopPanel(string provider)
-            //TODO: Define specialized editors via the addin registry
-            string name = provider.ToUpper();
-            if (name.StartsWith("OSGEO.SDF"))
-                return new SdfFileCtrl();
-            else if (name.StartsWith("OSGEO.SHP"))
-                return new ShpFileCtrl();
-            else //TODO: Add support for other providers
-                return new GenericCtrl();
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FsEditorMap.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FsEditorMap.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/FsEditorMap.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,73 @@
+using System;
+using System.Collections.Generic;
+using System.Text;
+using Maestro.Shared.UI;
+using Maestro.Editors.FeatureSource.Providers;
+using System.Xml;
+namespace Maestro.Editors.FeatureSource
+    public static class FsEditorMap
+        static Dictionary<string, Type> _editors;
+        static FsEditorMap()
+            _editors = new Dictionary<string, Type>();
+            if (System.IO.File.Exists("FsEditorMap.xml"))
+                var doc = new XmlDocument();
+                doc.Load("FsEditorMap.xml");
+                var list = doc.SelectNodes("//FeatureSourceEditorMap/Editor");
+                foreach (XmlNode node in list)
+                    try
+                        string provider = node.Attributes["provider"].Value.ToUpper();
+                        string typeName = node.Attributes["type"].Value;
+                        _editors[provider] = Type.GetType(typeName);
+                    catch { }
+        static string Normalize(string provider)
+            string[] tokens = provider.Split('.');
+            if (tokens.Length == 2)
+                return provider;
+            else
+                return tokens[0] + "." + tokens[1];
+        public static CollapsiblePanel GetPanel(string provider)
+            CollapsiblePanel panel = null;
+            provider = Normalize(provider);
+            //Try to obtain a specialized editor if possible, otherwise
+            //fall back to the generic one
+            string name = provider.ToUpper();
+            try
+                if (_editors.ContainsKey(name))
+                    panel = (CollapsiblePanel)Activator.CreateInstance(_editors[name]);
+                else
+                    panel = new GenericCtrl();
+            finally
+                if (panel == null)
+            return panel;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.Designer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.Designer.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,37 @@
+namespace Maestro.Editors.FeatureSource.Providers.Rdbms
+    partial class MySqlCtrl
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Component Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            components = new System.ComponentModel.Container();
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+        #endregion
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/MySqlCtrl.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,53 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.ComponentModel;
+using System.Drawing;
+using System.Data;
+using System.Text;
+using System.Windows.Forms;
+    public partial class MySqlCtrl : RdbmsBaseCtrl
+        public MySqlCtrl()
+            InitializeComponent();
+        public override string Provider
+            get
+                return "OSGeo.MySQL";
+        public override string Title
+            get
+                return Properties.Resources.FsMySql;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.Designer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.Designer.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,37 @@
+    partial class PostgreSqlCtrl
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        #endregion
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/PostgreSqlCtrl.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,53 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+    public partial class PostgreSqlCtrl : RdbmsBaseCtrl
+        public PostgreSqlCtrl()
+            get
+                return "OSGeo.PostgreSQL";
+            get
+                return Properties.Resources.FsPostgreSql;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.Designer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.Designer.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,198 @@
+    partial class RdbmsBaseCtrl
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            this.label1 = new System.Windows.Forms.Label();
+            this.txtService = new System.Windows.Forms.TextBox();
+            this.txtUsername = new System.Windows.Forms.TextBox();
+            this.label2 = new System.Windows.Forms.Label();
+            this.txtPassword = new System.Windows.Forms.TextBox();
+            this.label3 = new System.Windows.Forms.Label();
+            this.groupBox1 = new System.Windows.Forms.GroupBox();
+            this.btnConnect = new System.Windows.Forms.Button();
+            this.groupBox2 = new System.Windows.Forms.GroupBox();
+            this.cmbDataStore = new System.Windows.Forms.ComboBox();
+            this.label4 = new System.Windows.Forms.Label();
+            this.contentPanel.SuspendLayout();
+            this.groupBox1.SuspendLayout();
+            this.groupBox2.SuspendLayout();
+            this.SuspendLayout();
+            // contentPanel
+            this.contentPanel.Controls.Add(this.groupBox2);
+            this.contentPanel.Controls.Add(this.groupBox1);
+            this.contentPanel.Size = new System.Drawing.Size(449, 228);
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(13, 22);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(43, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Service";
+            // txtService
+            this.txtService.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+                        | System.Windows.Forms.AnchorStyles.Right)));
+            this.txtService.Location = new System.Drawing.Point(80, 19);
+            this.txtService.Name = "txtService";
+            this.txtService.Size = new System.Drawing.Size(315, 20);
+            this.txtService.TabIndex = 1;
+            // txtUsername
+            this.txtUsername.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.txtUsername.Location = new System.Drawing.Point(80, 45);
+            this.txtUsername.Name = "txtUsername";
+            this.txtUsername.Size = new System.Drawing.Size(315, 20);
+            this.txtUsername.TabIndex = 3;
+            // label2
+            this.label2.AutoSize = true;
+            this.label2.Location = new System.Drawing.Point(13, 48);
+            this.label2.Name = "label2";
+            this.label2.Size = new System.Drawing.Size(55, 13);
+            this.label2.TabIndex = 2;
+            this.label2.Text = "Username";
+            // txtPassword
+            this.txtPassword.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.txtPassword.Location = new System.Drawing.Point(80, 71);
+            this.txtPassword.Name = "txtPassword";
+            this.txtPassword.Size = new System.Drawing.Size(315, 20);
+            this.txtPassword.TabIndex = 5;
+            // label3
+            this.label3.AutoSize = true;
+            this.label3.Location = new System.Drawing.Point(13, 74);
+            this.label3.Name = "label3";
+            this.label3.Size = new System.Drawing.Size(53, 13);
+            this.label3.TabIndex = 4;
+            this.label3.Text = "Password";
+            // groupBox1
+            this.groupBox1.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.groupBox1.Controls.Add(this.btnConnect);
+            this.groupBox1.Controls.Add(this.txtService);
+            this.groupBox1.Controls.Add(this.txtPassword);
+            this.groupBox1.Controls.Add(this.label1);
+            this.groupBox1.Controls.Add(this.label3);
+            this.groupBox1.Controls.Add(this.label2);
+            this.groupBox1.Controls.Add(this.txtUsername);
+            this.groupBox1.Location = new System.Drawing.Point(15, 17);
+            this.groupBox1.Name = "groupBox1";
+            this.groupBox1.Size = new System.Drawing.Size(421, 128);
+            this.groupBox1.TabIndex = 6;
+            this.groupBox1.TabStop = false;
+            this.groupBox1.Text = "Connection Properties";
+            // btnConnect
+            this.btnConnect.Anchor = ((System.Windows.Forms.AnchorStyles)((System.Windows.Forms.AnchorStyles.Bottom | System.Windows.Forms.AnchorStyles.Right)));
+            this.btnConnect.Location = new System.Drawing.Point(320, 97);
+            this.btnConnect.Name = "btnConnect";
+            this.btnConnect.Size = new System.Drawing.Size(75, 23);
+            this.btnConnect.TabIndex = 6;
+            this.btnConnect.Text = "Connect";
+            this.btnConnect.UseVisualStyleBackColor = true;
+            this.btnConnect.Click += new System.EventHandler(this.btnConnect_Click);
+            // groupBox2
+            this.groupBox2.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.groupBox2.Controls.Add(this.cmbDataStore);
+            this.groupBox2.Controls.Add(this.label4);
+            this.groupBox2.Location = new System.Drawing.Point(15, 151);
+            this.groupBox2.Name = "groupBox2";
+            this.groupBox2.Size = new System.Drawing.Size(421, 62);
+            this.groupBox2.TabIndex = 7;
+            this.groupBox2.TabStop = false;
+            this.groupBox2.Text = "Other Options";
+            // cmbDataStore
+            this.cmbDataStore.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
+            this.cmbDataStore.DropDownStyle = System.Windows.Forms.ComboBoxStyle.DropDownList;
+            this.cmbDataStore.FormattingEnabled = true;
+            this.cmbDataStore.Location = new System.Drawing.Point(80, 24);
+            this.cmbDataStore.Name = "cmbDataStore";
+            this.cmbDataStore.Size = new System.Drawing.Size(315, 21);
+            this.cmbDataStore.TabIndex = 1;
+            // label4
+            this.label4.AutoSize = true;
+            this.label4.Location = new System.Drawing.Point(13, 27);
+            this.label4.Name = "label4";
+            this.label4.Size = new System.Drawing.Size(58, 13);
+            this.label4.TabIndex = 0;
+            this.label4.Text = "Data Store";
+            // RdbmsBaseCtrl
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.Name = "RdbmsBaseCtrl";
+            this.Size = new System.Drawing.Size(449, 255);
+            this.contentPanel.ResumeLayout(false);
+            this.groupBox1.ResumeLayout(false);
+            this.groupBox1.PerformLayout();
+            this.groupBox2.ResumeLayout(false);
+            this.groupBox2.PerformLayout();
+            this.ResumeLayout(false);
+        #endregion
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.GroupBox groupBox2;
+        private System.Windows.Forms.ComboBox cmbDataStore;
+        private System.Windows.Forms.Label label4;
+        private System.Windows.Forms.GroupBox groupBox1;
+        private System.Windows.Forms.TextBox txtService;
+        private System.Windows.Forms.TextBox txtPassword;
+        private System.Windows.Forms.Label label3;
+        private System.Windows.Forms.Label label2;
+        private System.Windows.Forms.TextBox txtUsername;
+        private System.Windows.Forms.Button btnConnect;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,155 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+using Maestro.Editors.Common;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
+    public partial class RdbmsBaseCtrl : EditorBindableCollapsiblePanel
+        public RdbmsBaseCtrl()
+        protected override void OnLoad(EventArgs e)
+            this.HeaderText = this.Title;
+        private IEditorService _edsvc;
+        private FeatureSourceType _fs;
+        public override void Bind(IEditorService service)
+            _edsvc = service;
+            _edsvc.RegisterCustomNotifier(this);
+            _fs = _edsvc.GetEditedResource() as FeatureSourceType;
+            //Set the field values
+            txtService.Text = _fs.GetConnectionProperty("Service");
+            txtUsername.Text = _fs.GetConnectionProperty("Username");
+            txtPassword.Text = _fs.GetConnectionProperty("Password");
+            UpdateDataStoreValues(true);
+            //Set initial value of data store if possible
+            var dstore = _fs.GetConnectionProperty("DataStore");
+            if (!string.IsNullOrEmpty(dstore) && cmbDataStore.Items.Count > 0)
+                var idx = cmbDataStore.Items.IndexOf(dstore);
+                if (idx >= 0)
+                    cmbDataStore.SelectedIndex = idx;
+            //As our connection properties are not CLR properties,
+            //"manually" bind these fields
+            txtService.TextChanged += (s, e) =>
+                _fs.SetConnectionProperty("Service", txtService.Text);
+            txtUsername.TextChanged += (s, e) =>
+                _fs.SetConnectionProperty("Username", txtUsername.Text);
+            txtPassword.TextChanged += (s, e) =>
+                _fs.SetConnectionProperty("Password", txtPassword.Text);
+            cmbDataStore.SelectedIndexChanged += (s, e) =>
+                if (cmbDataStore.SelectedItem != null)
+                    _fs.SetConnectionProperty("DataStore", cmbDataStore.SelectedItem.ToString());
+        public virtual string Title
+            get { return Properties.Resources.RdbmsFeatureSource; }
+        //MUST OVERRIDE
+        public virtual string Provider
+            get { throw new NotImplementedException(); }
+        private string GetPartialConnectionString()
+            var builder = new System.Data.Common.DbConnectionStringBuilder();
+            builder["Service"] = _fs.GetConnectionProperty("Service");
+            builder["Username"] = _fs.GetConnectionProperty("Username");
+            builder["Password"] = _fs.GetConnectionProperty("Password");
+            return builder.ToString();
+        private void btnConnect_Click(object sender, EventArgs e)
+            UpdateDataStoreValues(false);
+        private void UpdateDataStoreValues(bool silent)
+            using (new WaitCursor(this))
+                string[] values = null;
+                string reason = string.Empty;
+                try
+                    var dstore = _edsvc.FeatureService.EnumerateDataStores(this.Provider, GetPartialConnectionString());
+                    values = ConvertToArray(dstore);
+                catch (Exception ex) { reason = ex.ToString(); }
+                if (values != null && values.Length > 0)
+                    cmbDataStore.DataSource = values;
+                else
+                    if (!silent)
+                        MessageBox.Show(string.Format(Properties.Resources.FailEnumDataStores, reason));
+                    cmbDataStore.DataSource = null;
+        private static string[] ConvertToArray(OSGeo.MapGuide.ObjectModels.Common.DataStoreList dstore)
+            List<string> values = new List<string>();
+            foreach (var ds in dstore.DataStore)
+                values.Add(ds.Name);
+            return values.ToArray();
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/RdbmsBaseCtrl.resx	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
\ No newline at end of file
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.Designer.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.Designer.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,45 @@
+    partial class SqlServerSpatialCtrl
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+        /// <summary>
+        /// </summary>
+            // SqlServerSpatialCtrl
+            this.HeaderText = "SQL Server Spatial Feature Source";
+            this.Name = "SqlServerSpatialCtrl";
+        #endregion
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.cs
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.cs	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,53 @@
+#endregion
+using System;
+using System.Data;
+using System.Text;
+    public partial class SqlServerSpatialCtrl : RdbmsBaseCtrl
+        public SqlServerSpatialCtrl()
+            get
+                return "OSGeo.SQLServerSpatial";
+            get
+                return Properties.Resources.FsSqlServerSpatial;
Added: sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.resx
--- sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.resx	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FeatureSource/Providers/Rdbms/SqlServerSpatialCtrl.resx	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,120 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: sandbox/maestro-3.0/Maestro.Editors/FsEditorMap.xml
--- sandbox/maestro-3.0/Maestro.Editors/FsEditorMap.xml	                        (rev 0)
+++ sandbox/maestro-3.0/Maestro.Editors/FsEditorMap.xml	2010-10-04 04:39:35 UTC (rev 5238)
@@ -0,0 +1,14 @@
+<?xml version="1.0" encoding="utf-8" ?>
+This file allows the feature source editor to resolve the correct specialized
+editor based on the given provider name of the feature source. If the editor
+cannot locate this file or fails to parse the entries defined here, the default
+generic editor will be used
+<FeatureSourceEditorMap>
+    <Editor provider="OSGeo.SDF" type="Maestro.Editors.FeatureSource.Providers.Sdf.SdfFileCtrl" />
+    <Editor provider="OSGeo.SHP" type="Maestro.Editors.FeatureSource.Providers.Shp.ShpFileCtrl" />
+    <Editor provider="OSGeo.SQLServerSpatial" type="Maestro.Editors.FeatureSource.Providers.Rdbms.SqlServerSpatialCtrl" />
+    <Editor provider="OSGeo.MySQL" type="Maestro.Editors.FeatureSource.Providers.Rdbms.MySqlCtrl" />
+    <Editor provider="OSGeo.PostgreSQL" type="Maestro.Editors.FeatureSource.Providers.Rdbms.PostgreSqlCtrl" />
+</FeatureSourceEditorMap>
Modified: sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj
--- sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj	2010-10-03 08:47:23 UTC (rev 5237)
+++ sandbox/maestro-3.0/Maestro.Editors/Maestro.Editors.csproj	2010-10-04 04:39:35 UTC (rev 5238)
@@ -176,6 +176,7 @@
     <Compile Include="FeatureSource\FeatureSourceEditorCtrl.Designer.cs">
       <DependentUpon>FeatureSourceEditorCtrl.cs</DependentUpon>
     </Compile>
+    <Compile Include="FeatureSource\FsEditorMap.cs" />
     <Compile Include="FeatureSource\Preview\LocalFeatureSourcePreviewCtrl.cs">
       <SubType>UserControl</SubType>
     </Compile>
@@ -212,6 +213,30 @@
     <Compile Include="FeatureSource\Providers\GenericCtrl.Designer.cs">
       <DependentUpon>GenericCtrl.cs</DependentUpon>
     </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\MySqlCtrl.cs">
+      <SubType>UserControl</SubType>
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\MySqlCtrl.Designer.cs">
+      <DependentUpon>MySqlCtrl.cs</DependentUpon>
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\PostgreSqlCtrl.cs">
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\PostgreSqlCtrl.Designer.cs">
+      <DependentUpon>PostgreSqlCtrl.cs</DependentUpon>
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\RdbmsBaseCtrl.cs">
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\RdbmsBaseCtrl.Designer.cs">
+      <DependentUpon>RdbmsBaseCtrl.cs</DependentUpon>
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\SqlServerSpatialCtrl.cs">
+    </Compile>
+    <Compile Include="FeatureSource\Providers\Rdbms\SqlServerSpatialCtrl.Designer.cs">
+      <DependentUpon>SqlServerSpatialCtrl.cs</DependentUpon>
+    </Compile>
     <Compile Include="FeatureSource\Providers\Sdf\SdfFileCtrl.cs">
     </Compile>
@@ -627,6 +652,12 @@
       <SubType>Designer</SubType>
     </EmbeddedResource>
+    <EmbeddedResource Include="FeatureSource\Providers\Rdbms\RdbmsBaseCtrl.resx">
+    </EmbeddedResource>
+    <EmbeddedResource Include="FeatureSource\Providers\Rdbms\SqlServerSpatialCtrl.resx">
     <EmbeddedResource Include="FeatureSource\Providers\Sdf\SdfFileCtrl.resx">
       <DependentUpon>SdfFileCtrl.cs</DependentUpon>
@@ -1290,8 +1321,12 @@
     <None Include="Resources\question.png" />
   </ItemGroup>
   <ItemGroup>
+    <Content Include="FsEditorMap.xml">
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
+  </ItemGroup>
+  <ItemGroup>
     <Folder Include="DrawingSource\Preview\" />
-    <Folder Include="FeatureSource\Providers\Rdbms\" />
     <Folder Include="LayerDefinition\Raster\" />
     <Folder Include="PrintLayout\Logos\" />
     <Folder Include="PrintLayout\Text\" />
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs	2010-10-03 08:47:23 UTC (rev 5237)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.Designer.cs	2010-10-04 04:39:35 UTC (rev 5238)
@@ -442,6 +442,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Failed to enumerate data stores. Reason: {0}.
+        /// </summary>
+        internal static string FailEnumDataStores {
+            get {
+                return ResourceManager.GetString("FailEnumDataStores", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to An error occured while copying file: {0}.
         /// </summary>
         internal static string FileCopyError {
@@ -597,6 +606,33 @@
+        /// <summary>
+        ///   Looks up a localized string similar to MySQL Feature Source.
+        /// </summary>
+        internal static string FsMySql {
+            get {
+                return ResourceManager.GetString("FsMySql", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to PostgreSQL/PostGIS Feature Source.
+        /// </summary>
+        internal static string FsPostgreSql {
+            get {
+                return ResourceManager.GetString("FsPostgreSql", resourceCulture);
+        /// <summary>
+        ///   Looks up a localized string similar to SQL Server Spatial Feature Source.
+        /// </summary>
+        internal static string FsSqlServerSpatial {
+            get {
+                return ResourceManager.GetString("FsSqlServerSpatial", resourceCulture);
         internal static System.Drawing.Bitmap function {
             get {
                 object obj = ResourceManager.GetObject("function", resourceCulture);
@@ -1635,6 +1671,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to RDBMS Feature Source.
+        /// </summary>
+        internal static string RdbmsFeatureSource {
+            get {
+                return ResourceManager.GetString("RdbmsFeatureSource", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to You have selected to restore the package at the root.
         ///You have also selected to delete the target before restoring.
         ///This will result in the entire repository being deleted and replaced with this package.
Modified: sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx	2010-10-03 08:47:23 UTC (rev 5237)
+++ sandbox/maestro-3.0/Maestro.Editors/Properties/Resources.resx	2010-10-04 04:39:35 UTC (rev 5238)
@@ -897,4 +897,19 @@
   <data name="InvalidResourceIdNotSpecifiedType" xml:space="preserve">
     <value>Invalid Resource Identifier. Not the specified type</value>
   </data>
+  <data name="FailEnumDataStores" xml:space="preserve">
+    <value>Failed to enumerate data stores. Reason: {0}</value>
+  </data>
+  <data name="RdbmsFeatureSource" xml:space="preserve">
+    <value>RDBMS Feature Source</value>
+  </data>
+  <data name="FsMySql" xml:space="preserve">
+    <value>MySQL Feature Source</value>
+  </data>
+  <data name="FsPostgreSql" xml:space="preserve">
+    <value>PostgreSQL/PostGIS Feature Source</value>
+  </data>
+  <data name="FsSqlServerSpatial" xml:space="preserve">
+    <value>SQL Server Spatial Feature Source</value>
+  </data>
 </root>
More information about the mapguide-commits mailing list
