[mapguide-commits] r5240 - in sandbox/maestro-3.0:
ExtendedModels/LayerDefinition-1.1.0
ExtendedModels/LayerDefinition-1.2.0
ExtendedModels/LayerDefinition-1.3.0 Maestro.Base
Maestro.Base/Editor Maestro.Base/Properties
Maestro.Base/Templates Maestro.ResourceValidation
MaestroAPITests OSGeo.MapGuide.MaestroAPI/ObjectModels
OSGeo.MapGuide.MaestroAPI/Resource OSGeo.MapGuide.MaestroAPI.Http
svn_mapguide at osgeo.org
Mon Oct 4 07:44:04 EDT 2010
Author: jng
Date: 2010-10-04 11:44:03 +0000 (Mon, 04 Oct 2010)
New Revision: 5240
Added:
sandbox/maestro-3.0/Maestro.Base/Editor/ResourcePreviewEngine.cs
sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.1.0/LayerDefinition.cs
sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.2.0/LayerDefinition.cs
sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.3.0/LayerDefinition.cs
sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs
sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs
sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs
sandbox/maestro-3.0/Maestro.Base/Editor/WebLayoutEditor.cs
sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs
sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs
sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs
sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs
sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs
This submission includes the following changes:
- Add AJAX viewer previewing support (in specialized editor and XML editor) for:
- Feature Sources
- Layer Definition
- Map Definition
- Web Layout
- Update ValidationResultSet to allow querying by issue type (info, warning, error)
- Extend IEditorViewContent to support cancellation of view closing
- Fix some ObjectFactory methods which would create incomplete objects when saved as XML
- Update pre-save logic to be as follows:
- Validate edited resources for errors (not info or warnings)
- If errors found show them in Validation dialog and cancel save
Modified: sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.1.0/LayerDefinition.cs
--- sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.1.0/LayerDefinition.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.1.0/LayerDefinition.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -98,6 +98,32 @@
get { return this.ResourceId; }
set { this.ResourceId = value; }
+ [XmlIgnore]
+ string Ldf.IRasterLayerDefinition.FullQualifiedClassName
+ get
+ return this.FeatureName;
+ set
+ this.FeatureName = value;
+ [XmlIgnore]
+ string Ldf.IRasterLayerDefinition.GeometryProperty
+ get
+ return this.Geometry;
+ set
+ this.Geometry = value;
partial class DrawingLayerDefinitionType : Ldf.IDrawingLayerDefinition
Modified: sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.2.0/LayerDefinition.cs
--- sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.2.0/LayerDefinition.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.2.0/LayerDefinition.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -98,6 +98,32 @@
+ [XmlIgnore]
+ get
+ set
+ [XmlIgnore]
+ get
+ set
Modified: sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.3.0/LayerDefinition.cs
--- sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.3.0/LayerDefinition.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/ExtendedModels/LayerDefinition-1.3.0/LayerDefinition.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -98,6 +98,32 @@
+ [XmlIgnore]
+ get
+ set
+ [XmlIgnore]
+ get
+ set
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/EditorContentBase.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -49,11 +49,25 @@
- protected virtual string GetXmlContent()
+ /// <summary>
+ /// Gets the XML content of the edited resource
+ /// </summary>
+ /// <returns></returns>
+ public virtual string GetXmlContent()
return this.Resource.Serialize();
+ /// <summary>
+ /// Performs any pre-save validation logic. The base implementation performs
+ /// a <see cref="ResourceValidatorSet"/> validation (non-casccading) on the
+ /// edited resource before attempting a save into the session repository
+ /// (triggering any errors relating to invalid XML content). Override this
+ /// method if the base implementation just described does not cover your
+ /// validation needs.
+ /// </summary>
+ /// <param name="sender"></param>
+ /// <param name="e"></param>
protected virtual void OnBeforeSave(object sender, CancelEventArgs e)
//We've been editing an in-memory model of the session copy
@@ -61,9 +75,19 @@
//commits the changes back to the original resource
try
- ValidateEditedResource();
- _svc.UpdateResourceContent(GetXmlContent());
- e.Cancel = false;
+ var errors = new List<ValidationIssue>(ValidateEditedResource()).ToArray();
+ if (errors.Length > 0)
+ MessageService.ShowError(Properties.Resources.FixErrorsBeforeSaving);
+ ValidationResultsDialog diag = new ValidationResultsDialog(this.Resource.ResourceID, errors);
+ diag.ShowDialog(Workbench.Instance);
+ e.Cancel = true;
+ else
+ _svc.UpdateResourceContent(GetXmlContent());
+ e.Cancel = false;
catch (Exception ex)
@@ -73,10 +97,20 @@
/// <summary>
- /// Performs any pre-save validation on the currently edited resource
+ /// Performs any pre-save validation on the currently edited resource, by default
+ /// this returns the results of a non-cascading <see cref="ResourceValidatorSet"/>
+ /// validation run. Override this if you have a custom method of validation.
/// </summary>
- protected virtual void ValidateEditedResource() { }
+ protected virtual ICollection<ValidationIssue> ValidateEditedResource()
+ //Don't recurse as we only want to validate the current resource
+ var issues = ResourceValidatorSet.Validate(this.Resource, false);
+ var set = new ValidationResultSet(issues);
+ var errors = set.GetIssuesForResource(this.Resource.ResourceID, ValidationStatus.Error);
+ return errors;
void OnSaved(object sender, EventArgs e)
UpdateTitle();
@@ -109,7 +143,8 @@
/// <summary>
/// Binds the specified resource to this control. This effectively initializes
- /// all the fields in this control and sets up databinding on all fields.
+ /// all the fields in this control and sets up databinding on all fields. All
+ /// subclasses *must* override this method
/// </summary>
/// <param name="value"></param>
protected virtual void Bind(IEditorService service)
@@ -117,15 +152,6 @@
throw new NotImplementedException();
- private static ResourceTypes[] PREVIEWABLE_RESOURCE_TYPES = new ResourceTypes[]
- ResourceTypes.FeatureSource,
- ResourceTypes.ApplicationDefinition,
- ResourceTypes.LayerDefinition,
- ResourceTypes.MapDefinition,
- ResourceTypes.WebLayout
public virtual bool CanBePreviewed
get
@@ -134,7 +160,7 @@
if (res != null)
var rt = res.ResourceType;
- return Array.IndexOf(PREVIEWABLE_RESOURCE_TYPES, rt) >= 0 && res.CurrentConnection.Capabilities.SupportsResourcePreviews;
+ return ResourcePreviewEngine.IsPreviewableType(rt) && res.CurrentConnection.Capabilities.SupportsResourcePreviews;
return false;
@@ -178,7 +204,7 @@
public virtual string SetupPreviewUrl(string mapguideRootUrl)
- throw new NotSupportedException();
+ return new ResourcePreviewEngine(mapguideRootUrl, this.EditorService).GeneratePreviewUrl(this.Resource);
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/FeatureSourceEditor.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -46,18 +46,5 @@
_res = _edsvc.GetEditedResource();
fsEditorCtrl.Bind(service);
- public override string SetupPreviewUrl(string mapguideRootUrl)
- string url = mapguideRootUrl;
- if (!url.EndsWith("/"))
- url += "/";
- var resId = this.EditorService.GetEditedResource().ResourceID;
- var sessionId = this.EditorService.SessionID;
- url += "schemareport/describeschema.php?viewer=basic&resId=" + resId + "&sessionId=" + sessionId;
- return url;
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/IEditorViewContent.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -39,6 +39,12 @@
IResource Resource { get; }
/// <summary>
+ /// </summary>
+ string GetXmlContent();
+ /// <summary>
/// Indicates whether this current resource is a newly created resource
/// </summary>
bool IsNew { get; }
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/LayerDefinitionEditor.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -30,6 +30,8 @@
using OSGeo.MapGuide.MaestroAPI.Resource;
using Maestro.Editors;
using ICSharpCode.Core;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
+using Maestro.Base.UI.Preferences;
namespace Maestro.Base.Editor
Added: sandbox/maestro-3.0/Maestro.Base/Editor/ResourcePreviewEngine.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/ResourcePreviewEngine.cs (rev 0)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/ResourcePreviewEngine.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -0,0 +1,206 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using Maestro.Editors;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.MaestroAPI.Resource;
+using ICSharpCode.Core;
+using OSGeo.MapGuide.ObjectModels.MapDefinition;
+using OSGeo.MapGuide.ObjectModels.WebLayout;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.ObjectModels.ApplicationDefinition;
+namespace Maestro.Base.Editor
+ internal class ResourcePreviewEngine
+ private string _rootUrl;
+ private IEditorService _edSvc;
+ public ResourcePreviewEngine(string rootUrl, IEditorService edSvc)
+ _rootUrl = rootUrl;
+ _edSvc = edSvc;
+ private string GenerateFeatureSourcePreviewUrl(IResource res)
+ string url = _rootUrl;
+ if (!url.EndsWith("/"))
+ url += "/";
+ var resId = res.ResourceID;
+ var sessionId = _edSvc.SessionID;
+ url += "schemareport/describeschema.php?viewer=basic&resId=" + resId + "&sessionId=" + sessionId;
+ return url;
+ private string GenerateLayerPreviewUrl(IResource res)
+ url += "/";
+ var ldf = (ILayerDefinition)res;
+ var conn = res.CurrentConnection;
+ //Create temp map definition to house our current layer
+ var mdfId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".MapDefinition";
+ var mdf = ObjectFactory.CreateMapDefinition(conn, "Preview Map", ldf.GetCoordinateSystemWkt(), ldf.GetSpatialExtent(true)); //LOCALIZEME
+ mdf.AddLayer(null, ResourceIdentifier.GetName(ldf.ResourceID), ldf.ResourceID);
+ conn.ResourceService.SaveResourceAs(mdf, mdfId);
+ if (PropertyService.Get(ConfigProperties.PreviewViewerType, "AJAX").Equals("AJAX"))
+ //Create temp web layout to house this map
+ var wl = ObjectFactory.CreateWebLayout(_edSvc.GetEditedResource().CurrentConnection, mdfId);
+ var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".WebLayout";
+ conn.ResourceService.SaveResourceAs(wl, resId);
+ url += "mapviewerajax/?WEBLAYOUT=" + resId + "&SESSION=" + sessionId;
+ else
+ throw new NotImplementedException();
+ ////Create temp flex layout
+ //var appDef = ObjectFactory.CreatePreviewFlexLayout(conn);
+ //var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".ApplicationDefinition";
+ //appDef.AddMapGroup("previewmap", true, mdfId);
+ //conn.ResourceService.SaveResourceAs(appDef, resId);
+ //url += "fusion/templates/mapguide/preview/index.html?Session=" + sessionId + "&ApplicationDefinition=" + resId;
+ return url;
+ private string GenerateMapPreviewUrl(IResource res)
+ url += "/";
+ var mdf = (MapDefinition)res;
+ var conn = mdf.CurrentConnection;
+ else
+ //var appDef = ObjectFactory.CreateFlexibleLayout(conn);
+ return url;
+ private string GenerateWebLayoutPreviewUrl(IResource res)
+ url += "/";
+ var wl = (WebLayoutType)res;
+ var conn = wl.CurrentConnection;
+ return url;
+ private string GenerateFlexLayoutPreviewUrl(IResource res)
+ url += "/";
+ //Create temp flex layout
+ var appDef = (ApplicationDefinitionType)res;
+ var conn = appDef.CurrentConnection;
+ var resId = "Session:" + sessionId + "//" + Guid.NewGuid() + ".ApplicationDefinition";
+ conn.ResourceService.SaveResourceAs(appDef, resId);
+ url += "fusion/templates/mapguide/preview/index.html?Session=" + sessionId + "&ApplicationDefinition=" + resId;
+ return url;
+ public string GeneratePreviewUrl(IResource res)
+ switch (res.ResourceType)
+ case ResourceTypes.FeatureSource:
+ return GenerateFeatureSourcePreviewUrl(res);
+ case ResourceTypes.ApplicationDefinition:
+ return GenerateFlexLayoutPreviewUrl(res);
+ case ResourceTypes.LayerDefinition:
+ return GenerateLayerPreviewUrl(res);
+ case ResourceTypes.MapDefinition:
+ return GenerateMapPreviewUrl(res);
+ case ResourceTypes.WebLayout:
+ return GenerateWebLayoutPreviewUrl(res);
+ default:
+ throw new InvalidOperationException("This resource type cannot be previewed"); //LOCALIZEME
+ private static ResourceTypes[] PREVIEWABLE_RESOURCE_TYPES = new ResourceTypes[]
+ ResourceTypes.FeatureSource,
+ ResourceTypes.ApplicationDefinition,
+ ResourceTypes.LayerDefinition,
+ ResourceTypes.MapDefinition,
+ ResourceTypes.WebLayout
+ internal static bool IsPreviewableType(OSGeo.MapGuide.MaestroAPI.ResourceTypes rt)
+ return Array.IndexOf(PREVIEWABLE_RESOURCE_TYPES, rt) >= 0;
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/WebLayoutEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/WebLayoutEditor.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/WebLayoutEditor.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -34,8 +34,11 @@
InitializeComponent();
+ private Maestro.Editors.IEditorService _edSvc;
protected override void Bind(Maestro.Editors.IEditorService service)
+ _edSvc = service;
webLayoutEditorCtrl.Bind(service);
Modified: sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs
--- sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Editor/XmlEditor.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -31,6 +31,7 @@
using System.Xml;
@@ -85,16 +86,40 @@
warnings = warn.ToArray();
protected override void Bind(IEditorService service)
- service.RegisterCustomNotifier(editor);
- editor.Bind(service);
+ _edSvc = service;
+ _edSvc.RegisterCustomNotifier(editor);
+ editor.Bind(_edSvc);
editor.ReadyForEditing(); //This turns on event broadcasting
this.Title = "XML Editor: " + ResourceIdentifier.GetName(this.EditorService.ResourceID); //LOCALIZE
- protected override string GetXmlContent()
+ protected override ICollection<ValidationIssue> ValidateEditedResource()
+ string[] warnings;
+ string[] errors;
+ ValidateXml(out errors, out warnings);
+ var issues = new List<ValidationIssue>();
+ foreach (string err in errors)
+ issues.Add(new ValidationIssue(this.Resource, ValidationStatus.Error, err));
+ foreach (string warn in warnings)
+ issues.Add(new ValidationIssue(this.Resource, ValidationStatus.Warning, warn));
+ //Put through ValidationResultSet to weed out redundant messages
+ return set.GetAllIssues();
+ public override string GetXmlContent()
return this.XmlContent;
@@ -111,5 +136,22 @@
return false; //We're already in the XML editor!
+ public override string SetupPreviewUrl(string mapguideRootUrl)
+ //This one's a bit different, the current state of the edited resource
+ //is in the XML text area. We need to save this to another temp session
+ //copy before attempting to generate a preview url
+ string resId = "Session:" + _edSvc.SessionID + "//" + Guid.NewGuid() + "." + this.Resource.ResourceType.ToString();
+ _edSvc.ResourceService.SetResourceXmlData(resId, this.Resource.SerializeToStream());
+ //Copy any resource data
+ var previewCopy = _edSvc.ResourceService.GetResource(resId);
+ this.Resource.CopyResourceDataTo(previewCopy);
+ //Now feed it to the preview engine
+ return new ResourcePreviewEngine(mapguideRootUrl, _edSvc).GeneratePreviewUrl(previewCopy);
Modified: sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj
--- sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Maestro.Base.csproj 2010-10-04 11:44:03 UTC (rev 5240)
@@ -129,6 +129,7 @@
<DependentUpon>PrintLayoutEditor.cs</DependentUpon>
</Compile>
<Compile Include="Editor\ResourceEditorService.cs" />
+ <Compile Include="Editor\ResourcePreviewEngine.cs" />
<Compile Include="Editor\SymbolDefinitionEditor.cs">
<SubType>UserControl</SubType>
</Compile>
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -485,6 +485,15 @@
+ /// <summary>
+ /// Looks up a localized string similar to Validation detected errors in your resource, please fix them before saving this resource.
+ /// </summary>
+ internal static string FixErrorsBeforeSaving {
+ get {
+ return ResourceManager.GetString("FixErrorsBeforeSaving", resourceCulture);
internal static System.Drawing.Bitmap folder__plus {
get {
object obj = ResourceManager.GetObject("folder__plus", resourceCulture);
@@ -500,6 +509,15 @@
/// <summary>
+ /// Looks up a localized string similar to Error.
+ /// </summary>
+ internal static string Global_ErrorText {
+ get {
+ return ResourceManager.GetString("Global.ErrorText", resourceCulture);
+ /// <summary>
/// Looks up a localized string similar to Question.
/// </summary>
internal static string Global_QuestionText {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-04 11:44:03 UTC (rev 5240)
@@ -676,4 +676,10 @@
<data name="CloseUnsavedResource" xml:space="preserve">
<value>This resource has unsaved changes. Close and discard these changes?</value>
</data>
+ <data name="FixErrorsBeforeSaving" xml:space="preserve">
+ <value>Validation detected errors in your resource, please fix them before saving this resource</value>
+ </data>
+ <data name="Global.ErrorText" xml:space="preserve">
+ <value>Error</value>
+ </data>
</root>
\ No newline at end of file
Modified: sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs
--- sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.Base/Templates/MapDefinitionItemTemplate.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -41,7 +41,7 @@
public override IResource CreateItem(IServerConnection conn)
- return ObjectFactory.CreateMapDefinition(conn);
+ return ObjectFactory.CreateMapDefinition(conn, "New Map"); //LOCALIZEME
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/FeatureSourceValidator.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -46,7 +46,7 @@
try
System.Globalization.CultureInfo ci = System.Globalization.CultureInfo.InvariantCulture;
- FdoSpatialContextList lst = feature.GetSpatialInfo();
+ FdoSpatialContextList lst = feature.GetSpatialInfo(false);
if (lst == null || lst.SpatialContext == null || lst.SpatialContext.Count == 0)
issues.Add(new ValidationIssue(feature, ValidationStatus.Warning, Properties.Resources.FS_NoSpatialContextWarning));
else
Modified: sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs
--- sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/Maestro.ResourceValidation/MapDefinitionValidator.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -101,7 +101,7 @@
try
- FdoSpatialContextList context = fs.GetSpatialInfo();
+ FdoSpatialContextList context = fs.GetSpatialInfo(false);
if (context.SpatialContext == null || context.SpatialContext.Count == 0)
issues.Add(new ValidationIssue(fs, ValidationStatus.Warning, string.Format(Properties.Resources.MDF_MissingSpatialContextWarning, fs.ResourceID)));
else
Modified: sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/MaestroAPITests/ResourceTests.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -158,7 +158,7 @@
#endregion
- res = ObjectFactory.CreateMapDefinition(conn);
+ res = ObjectFactory.CreateMapDefinition(conn, "Test Map");
#region Map Definition
try
@@ -477,7 +477,7 @@
var ld2 = conv.Upgrade(ld, targetVer);
Assert.AreSame(ld, ld2);
- var md = ObjectFactory.CreateMapDefinition(conn);
+ var md = ObjectFactory.CreateMapDefinition(conn, "Test Map");
var md2 = conv.Upgrade(md, targetVer);
Assert.AreSame(md, md2);
Modified: sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs
--- sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/MaestroAPITests/ValidationTests.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -88,6 +88,7 @@
var totalIssues = set.GetAllIssues();
Assert.AreEqual(totalIssues.Length, 2);
Assert.AreEqual(set.ResourceIDs.Length, 1);
+ Assert.AreEqual(set.GetIssuesForResource("Library://Test.FeatureSource", ValidationStatus.Error).Count, 2);
[Test]
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ApplicationDefinition.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -44,12 +44,90 @@
+ /// <summary>
+ /// Defines the stock fusion template names that come with a standard MapGuide installation
+ /// </summary>
+ public static class FusionTemplateNames
+ /// <summary>
+ /// The preview template. Used for previewing other resources
+ /// </summary>
+ public const string Preview = "Preview";
+ /// <summary>
+ /// The Aqua template
+ /// </summary>
+ public const string Aqua = "Aqua";
+ /// <summary>
+ /// The Maroon template
+ /// </summary>
+ public const string Maroon = "Maroon";
+ /// <summary>
+ /// The Slate template
+ /// </summary>
+ public const string Slate = "Slate";
+ /// <summary>
+ /// The LimeGold template
+ /// </summary>
+ public const string LimeGold = "LimeGold";
+ /// <summary>
+ /// The TurquoiseYellow template
+ /// </summary>
+ public const string TurquoiseYellow = "TurquoiseYellow";
partial class ApplicationDefinitionType : IResource
internal ApplicationDefinitionType() { }
private static readonly Version RES_VERSION = new Version(1, 0, 0);
+ private XmlDocument _doc;
+ internal XmlDocument Doc
+ get
+ if (_doc == null)
+ _doc = new XmlDocument();
+ return _doc;
+ public MapGroupType AddMapGroup(string id, bool singleTile, string mapDefinitionId)
+ var map = new MapGroupType()
+ id = id,
+ Map = new System.ComponentModel.BindingList<MapType>()
+ new MapType()
+ Type = "MapGuide",
+ SingleTile = singleTile.ToString(),
+ Extension = new CustomContentType()
+ Any = new XmlElement[1]
+ map.Map[0].Extension.Any[0] = Doc.CreateElement("ResourceId");
+ map.Map[0].Extension.Any[0].InnerText = mapDefinitionId;
+ this.MapSet.Add(map);
+ return map;
+ public MapGroupType AddMapGroup(string id, bool singleTile, string mapDefinitionId, double centerX, double centerY, double scale)
+ var map = AddMapGroup(id, singleTile, mapDefinitionId);
+ map.InitialView = new MapViewType() { CenterX = centerX, CenterY = centerY, Scale = scale };
+ return map;
[XmlIgnore]
public OSGeo.MapGuide.MaestroAPI.IServerConnection CurrentConnection
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/FeatureSource.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -269,9 +269,9 @@
/// Convenience method to retrieve the spatial context information of this feature source
/// </summary>
- public OSGeo.MapGuide.ObjectModels.Common.FdoSpatialContextList GetSpatialInfo()
+ public OSGeo.MapGuide.ObjectModels.Common.FdoSpatialContextList GetSpatialInfo(bool activeOnly)
- return this.CurrentConnection.FeatureService.GetSpatialContextInfo(this.ResourceID, false);
+ return this.CurrentConnection.FeatureService.GetSpatialContextInfo(this.ResourceID, activeOnly);
/// <summary>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/LayerDefinition.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -25,6 +25,9 @@
using OSGeo.MapGuide.ObjectModels.Common;
using System.ComponentModel;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels.FeatureSource;
namespace OSGeo.MapGuide.ObjectModels.LayerDefinition
@@ -37,11 +40,100 @@
public interface ILayerDefinition : IResource
- Envelope GetSpatialExtent(bool allowFallbackToContextInformation);
ISubLayerDefinition SubLayer { get; }
+ public static class LayerDefinitionExtensions
+ public static string GetCoordinateSystemWkt(this ILayerDefinition layer)
+ Check.NotNull(layer, "layer");
+ if (layer.CurrentConnection == null)
+ throw new System.Exception("No server set for object");
+ var conn = layer.CurrentConnection;
+ switch (layer.SubLayer.LayerType)
+ case LayerType.Raster:
+ var rl = (IRasterLayerDefinition)layer.SubLayer;
+ var fs = (FeatureSourceType)conn.ResourceService.GetResource(rl.FeatureSourceID);
+ var scList = fs.GetSpatialInfo(true);
+ if (scList.SpatialContext.Count > 0)
+ return scList.SpatialContext[0].CoordinateSystemWkt;
+ break;
+ case LayerType.Vector:
+ var vl = (IVectorLayerDefinition)layer.SubLayer;
+ var fs = (FeatureSourceType)conn.ResourceService.GetResource(vl.FeatureSourceID);
+ break;
+ case LayerType.Drawing:
+ int[] services = conn.Capabilities.SupportedServices;
+ if (Array.IndexOf(services, (int)ServiceType.Drawing) >= 0)
+ var sheet = ((IDrawingLayerDefinition)layer.SubLayer).Sheet;
+ var dws = (DrawingSource)conn.ResourceService.GetResource(((IDrawingLayerDefinition)layer.SubLayer).DrawingSourceID);
+ var csCat = conn.CoordinateSystemCatalog;
+ return csCat.ConvertCoordinateSystemCodeToWkt(dws.CoordinateSpace);
+ break;
+ return string.Empty;
+ /// <summary>
+ /// Returns the spatial extent of the data.
+ /// This is calculated by asking the underlying featuresource for the minimum rectangle that
+ /// contains all the features in the specified table. If the <paramref name="allowFallbackToContextInformation"/>
+ /// is set to true, and the query fails, the code will attempt to read this information
+ /// from the spatial context information instead.
+ /// </summary>
+ /// <param name="allowFallbackToContextInformation">True to allow reading spatial extents from the spatial context information, if the spatial query fails.</param>
+ /// <returns>The envelope for the data in the table</returns>
+ public static Envelope GetSpatialExtent(this ILayerDefinition layer, bool allowFallbackToContextInformation)
+ return conn.FeatureService.GetSpatialExtent(((IVectorLayerDefinition)layer.SubLayer).FeatureSourceID, ((IVectorLayerDefinition)layer.SubLayer).FullQualifiedClassName, ((IVectorLayerDefinition)layer.SubLayer).GeometryProperty);
+ return conn.FeatureService.GetSpatialExtent(((IRasterLayerDefinition)layer.SubLayer).FeatureSourceID, ((IRasterLayerDefinition)layer.SubLayer).FullQualifiedClassName, ((IRasterLayerDefinition)layer.SubLayer).GeometryProperty);
+ default:
+ //find matching sheet
+ foreach (var sht in dws.Sheet)
+ if (sheet.Equals(sht.Name))
+ return ObjectFactory.CreateEnvelope(sht.Extent.MinX, sht.Extent.MinY, sht.Extent.MaxX, sht.Extent.MaxY);
+ return null;
public interface ISubLayerDefinition
LayerType LayerType { get; }
@@ -80,11 +172,23 @@
public interface IRasterLayerDefinition : ISubLayerDefinition
+ string FullQualifiedClassName { get; set; }
+ string GeometryProperty { get; set; }
string FeatureSourceID { get; set; }
public interface IDrawingLayerDefinition : ISubLayerDefinition
+ string Sheet { get; set; }
+ string LayerFilter { get; set; }
+ double MinScale { get; set; }
+ double MaxScale { get; set; }
string DrawingSourceID { get; set; }
@@ -164,6 +268,32 @@
+ [XmlIgnore]
+ string IRasterLayerDefinition.FullQualifiedClassName
+ get
+ set
+ [XmlIgnore]
+ string IRasterLayerDefinition.GeometryProperty
+ get
+ set
partial class DrawingLayerDefinitionType : IDrawingLayerDefinition
@@ -365,28 +495,6 @@
get { return true; }
- /// <summary>
- /// Returns the spatial extent of the data.
- /// This is calculated by asking the underlying featuresource for the minimum rectangle that
- /// contains all the features in the specified table. If the <paramref name="allowFallbackToContextInformation"/>
- /// is set to true, and the query fails, the code will attempt to read this information
- /// from the spatial context information instead.
- /// </summary>
- /// <param name="allowFallbackToContextInformation">True to allow reading spatial extents from the spatial context information, if the spatial query fails.</param>
- /// <returns>The envelope for the data in the table</returns>
- public Envelope GetSpatialExtent(bool allowFallbackToContextInformation)
- if (this.CurrentConnection == null)
- throw new System.Exception("No server set for object");
- if (this.Item as VectorLayerDefinitionType != null)
- return this.CurrentConnection.FeatureService.GetSpatialExtent(this.Item.ResourceId, (this.Item as VectorLayerDefinitionType).FeatureName, (this.Item as VectorLayerDefinitionType).Geometry, allowFallbackToContextInformation);
- else if (this.Item as GridLayerDefinitionType != null)
- return this.CurrentConnection.FeatureService.GetSpatialExtent(this.Item.ResourceId, (this.Item as GridLayerDefinitionType).FeatureName, (this.Item as GridLayerDefinitionType).Geometry, allowFallbackToContextInformation);
- else
- return null;
public ISubLayerDefinition SubLayer
get { return this.Item; }
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/MapDefinition.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -119,10 +119,48 @@
+ public MapLayerGroupType AddGroup(string groupName)
+ if (this.MapLayerGroup == null)
+ this.MapLayerGroup = new System.ComponentModel.BindingList<MapLayerGroupType>();
+ var group = new MapLayerGroupType()
+ Parent = this,
+ ExpandInLegend = true,
+ LegendLabel = groupName,
+ Name = groupName,
+ ShowInLegend = true,
+ Visible = true
+ this.MapLayerGroup.Add(group);
+ return group;
+ public MapLayerType AddLayer(string groupName, string layerName, string resourceId)
+ var layer = new MapLayerType() {
+ Parent = this,
+ LegendLabel = layerName,
+ Name = layerName,
+ ResourceId = resourceId,
+ Visible = true,
+ Selectable = true
+ //TODO: Throw exception if adding to non-existent group?
+ layer.Group = string.IsNullOrEmpty(groupName) ? string.Empty : groupName;
+ this.MapLayer.Add(layer);
+ return layer;
partial class MapLayerType
+ [XmlIgnore]
public MapDefinition Parent
get;
@@ -132,6 +170,7 @@
partial class BaseMapLayerType
+ [XmlIgnore]
get;
@@ -141,6 +180,7 @@
partial class MapLayerGroupType
+ [XmlIgnore]
get;
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/ObjectFactory.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -32,6 +32,7 @@
using OSGeo.MapGuide.ObjectModels.LoadProcedure;
using System.Drawing;
namespace OSGeo.MapGuide.MaestroAPI.ObjectModels
@@ -103,29 +104,31 @@
return fs;
- public static MapDefinition CreateMapDefinition(IServerConnection owner)
+ public static MapDefinition CreateMapDefinition(IServerConnection owner, string name)
Check.NotNull(owner, "owner");
return new MapDefinition() {
CurrentConnection = owner,
+ Name = name,
+ BackgroundColor = Color.White,
MapLayer = new System.ComponentModel.BindingList<MapLayerType>(),
- MapLayerGroup = new System.ComponentModel.BindingList<MapLayerGroupType>(),
+ //MapLayerGroup = new System.ComponentModel.BindingList<MapLayerGroupType>(),
- public static MapDefinition CreateMapDefinition(IServerConnection owner, string coordinateSystemWkt)
+ public static MapDefinition CreateMapDefinition(IServerConnection owner, string name, string coordinateSystemWkt)
- var map = CreateMapDefinition(owner);
+ var map = CreateMapDefinition(owner, name);
map.CoordinateSystem = coordinateSystemWkt;
return map;
- public static MapDefinition CreateMapDefinition(IServerConnection owner, string coordinateSystemWkt, Envelope env)
+ public static MapDefinition CreateMapDefinition(IServerConnection owner, string name, string coordinateSystemWkt, Envelope env)
- var map = CreateMapDefinition(owner, coordinateSystemWkt);
- map.Extents = new Box2DType() { MinX = env.MinY, MaxX = env.MaxX, MinY = env.MinY, MaxY = env.MaxY };
+ var map = CreateMapDefinition(owner, name, coordinateSystemWkt);
+ map.Extents = new Box2DType() { MinX = env.MinX, MaxX = env.MaxX, MinY = env.MinY, MaxY = env.MaxY };
return map;
@@ -568,13 +571,89 @@
return new SymbolLibraryType() { CurrentConnection = conn };
+ //TODO: Just deserialize from an embedded resource. The content model for a fusion
+ //flexible layout is just too loose to programmatically build reliably.
public static ApplicationDefinitionType CreateFlexibleLayout(IServerConnection owner)
- return new ApplicationDefinitionType() { CurrentConnection = owner };
+ return new ApplicationDefinitionType()
+ CurrentConnection = owner,
+ MapSet = new System.ComponentModel.BindingList<MapGroupType>(),
+ WidgetSet = CreateStandardWidgetSet()
+ private static System.ComponentModel.BindingList<WidgetSetType> CreateStandardWidgetSet()
+ return new System.ComponentModel.BindingList<WidgetSetType>();
+ private static System.ComponentModel.BindingList<WidgetSetType> CreatePreviewWidgetSet()
+ public static ApplicationDefinitionType CreateFlexibleLayout(IServerConnection owner, string title)
+ Check.NotNull(owner, "owner");
+ var appDef = CreateFlexibleLayout(owner);
+ appDef.Title = title;
+ return appDef;
+ public static ApplicationDefinitionType CreatePreviewFlexLayout(IServerConnection owner)
+ var appDef = new ApplicationDefinitionType()
+ Title = "Preview",
+ WidgetSet = CreatePreviewWidgetSet()
+ appDef.TemplateUrl = "fusion/templates/mapguide/preview/index.html";
+ return appDef;
+ /// <summary>
+ /// Creates a fusion flexible layout
+ /// </summary>
+ /// <param name="owner"></param>
+ /// <param name="title"></param>
+ /// <param name="templateName">The name of the template. Consult <see cref="FusionTemplateNames"/> for a list of stock templates</param>
+ public static ApplicationDefinitionType CreateFlexibleLayout(IServerConnection owner, string title, string templateName)
+ string url = string.Empty;
+ int[] services = owner.Capabilities.SupportedServices;
+ if (Array.IndexOf(services, (int)ServiceType.Fusion) >= 0)
+ IFusionService fsvc = (IFusionService)owner.GetService((int)ServiceType.Fusion);
+ var templates = fsvc.GetApplicationTemplates();
+ foreach (var tpl in templates.TemplateInfo)
+ if (tpl.Name.ToUpper().Equals(templateName.ToUpper()))
+ url = tpl.LocationUrl;
+ continue;
+ if (string.IsNullOrEmpty(url))
+ throw new InvalidOperationException("Could not find template url for template: " + templateName); //LOCALIZEME
+ var appDef = CreateFlexibleLayout(owner, title);
+ appDef.TemplateUrl = url;
+ return appDef;
public static PrintLayout CreatePrintLayout(IServerConnection owner)
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -60,6 +60,19 @@
return new ResourceTypeDescriptor(res.ResourceType, res.ResourceVersion.ToString());
+ public static void CopyResourceDataTo(this IResource source, IResource target)
+ Check.NotNull(source, "source");
+ Check.NotNull(target, "target");
+ foreach (var res in source.EnumerateResourceData())
+ var data = source.GetResourceData(res.Name);
+ data.Position = 0L; //Reset
+ target.SetResourceData(res.Name, res.Type, data);
/// <summary>
/// Convenience method for enumerating resource data of this resource
/// </summary>
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/ValidationResultSet.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -39,7 +39,7 @@
_issues = new Dictionary<string, Dictionary<ValidationIssue, ValidationIssue>>();
- public ValidationResultSet(List<ValidationIssue> issues) : this()
+ public ValidationResultSet(IEnumerable<ValidationIssue> issues) : this()
Check.NotNull(issues, "issues");
@@ -58,6 +58,17 @@
return _issues[resourceId].Keys;
+ public ICollection<ValidationIssue> GetIssuesForResource(string resourceId, ValidationStatus statType)
+ foreach (var issue in GetIssuesForResource(resourceId))
+ if (issue.Status == statType)
+ issues.Add(issue);
+ return issues;
public ValidationIssue[] GetAllIssues()
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-10-04 05:51:06 UTC (rev 5239)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI.Http/HttpServerConnection.cs 2010-10-04 11:44:03 UTC (rev 5240)
@@ -513,8 +513,15 @@
Utility.CopyStream(outStream, rs);
rs.Flush();
- using (System.IO.Stream resp = req.GetResponse().GetResponseStream())
+ var wresp = req.GetResponse();
+ if (wresp is HttpWebResponse)
+ HttpWebResponse httpresp = (HttpWebResponse)wresp;
+ LogResponse(httpresp);
+ using (System.IO.Stream resp = wresp.GetResponseStream())
//Do nothing... there is no return value
@@ -540,6 +547,11 @@
#endif
+ private void LogResponse(HttpWebResponse httpresp)
+ OnRequestDispatched(string.Format("{0:d} {1} {2} {3}", httpresp.StatusCode, httpresp.StatusDescription, httpresp.Method, new Uri(this.BaseURL).MakeRelativeUri(httpresp.ResponseUri)));
public FeatureSetReader ExecuteSqlQuery(string featureSourceID, string sql)
ResourceIdentifier.Validate(featureSourceID, ResourceTypes.FeatureSource);
@@ -1243,7 +1255,7 @@
var httpreq = HttpWebRequest.Create(req);
var httpresp = (HttpWebResponse)httpreq.GetResponse();
- OnRequestDispatched(string.Format("{0:d} {1} {2} {3}", httpresp.StatusCode, httpresp.StatusDescription, httpresp.Method, httpresp.ResponseUri));
using (var st = httpresp.GetResponseStream())
using (var ms = new MemoryStream())
@@ -1297,7 +1309,7 @@
if (_cred != null)
httpreq.Credentials = _cred;
return httpresp.GetResponseStream();
@@ -1736,7 +1748,12 @@
ApplicationDefinitionTemplateInfoSet IFusionService.GetApplicationTemplates()
- throw new NotImplementedException();
+ string req = m_reqBuilder.EnumerateApplicationTemplates();
+ using (var s = this.OpenRead(req))
+ var list = this.DeserializeObject<OSGeo.MapGuide.ObjectModels.ApplicationDefinition.ApplicationDefinitionTemplateInfoSet>(s);
+ return list;
ApplicationDefinitionWidgetInfoSet IFusionService.GetApplicationWidgets()
More information about the mapguide-commits
