[mapguide-commits] r5245 - in trunk/Tools/Maestro: Installer
Localization/ConvertResX/ConvertResX/Properties Maestro
Maestro/FusionEditor Maestro/LoginForm/Properties
Maestro/MaestroEditorInterface
Maestro/ResourceBrowser/Properties Maestro/ResourceEditors
Maestro/ResourceValidators MaestroAPI
MaestroAPI/PackageBuilder/Properties MaestroAPI/XsdGenerator
new w generics/Properties
MgCooker/MgCookerCommandline/Properties MgCooker/Properties
svn_mapguide at osgeo.org
Tue Oct 5 02:28:44 EDT 2010
Author: jng
Date: 2010-10-05 06:28:43 +0000 (Tue, 05 Oct 2010)
New Revision: 5245
trunk/Tools/Maestro/Installer/UpgradeData.wxi
trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
Lock in 2.1.4 release
Modified: trunk/Tools/Maestro/Installer/UpgradeData.wxi
--- trunk/Tools/Maestro/Installer/UpgradeData.wxi 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Installer/UpgradeData.wxi 2010-10-05 06:28:43 UTC (rev 5245)
@@ -3,7 +3,7 @@
<?define UpgradeCode="A7C2ECB3-1991-47B9-A22E-8844BB95CAE2" ?>
<!-- Remember to change product version on each install -->
- <?define ProductVersion="2.1.3.5165" ?>
+ <?define ProductVersion="2.1.4.5245" ?>
<?define Manufacturer="Open Source Geospatial Foundation" ?>
Modified: trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Localization/ConvertResX/ConvertResX/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -32,5 +32,5 @@
// You can specify all the values or you can default the Build and Revision Numbers
// by using the '*' as shown below:
// [assembly: AssemblyVersion("1.0.*")]
-[assembly: AssemblyVersion("2.1.3.5165")]
-[assembly: AssemblyFileVersion("2.1.3.5165")]
+[assembly: AssemblyVersion("2.1.4.5245")]
+[assembly: AssemblyFileVersion("2.1.4.5245")]
Modified: trunk/Tools/Maestro/Maestro/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -45,7 +45,7 @@
// You can specify all the values or you can default the Revision and Build Numbers
// In order to sign your assembly you must specify a key to use. Refer to the
@@ -75,4 +75,4 @@
[assembly: AssemblyDelaySign(false)]
[assembly: AssemblyKeyFile("")]
[assembly: AssemblyKeyName("")]
-[assembly: AssemblyFileVersionAttribute("2.1.3.5165")]
+[assembly: AssemblyFileVersionAttribute("2.1.4.5245")]
Modified: trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/FusionEditor/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/LoginForm/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -32,5 +32,5 @@
Modified: trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/MaestroEditorInterface/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -45,7 +45,7 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/ResourceBrowser/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -50,5 +50,5 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/ResourceEditors/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs
--- trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/Maestro/ResourceValidators/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
Modified: trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/MaestroAPI/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -45,7 +45,7 @@
@@ -75,4 +75,4 @@
[assembly: AssemblyKeyFile("..\\..\\maestroapi.key")]
Modified: trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/MaestroAPI/PackageBuilder/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/MaestroAPI/XsdGenerator new w generics/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/MgCooker/MgCookerCommandline/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -48,5 +48,5 @@
// Build Number
// Revision
Modified: trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs 2010-10-05 06:23:06 UTC (rev 5244)
+++ trunk/Tools/Maestro/MgCooker/Properties/AssemblyInfo.cs 2010-10-05 06:28:43 UTC (rev 5245)
@@ -48,5 +48,5 @@
// Build Number
// Revision
More information about the mapguide-commits
