[mapguide-commits] r5246 - in trunk/MgDev: Common/MapGuideCommon/Services Common/PlatformBase/Services Server/src/Services/Feature
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Tue Oct 5 11:46:37 EDT 2010
Author: waltweltonlair
Date: 2010-10-05 15:46:37 +0000 (Tue, 05 Oct 2010)
New Revision: 5246
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
   trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
   trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
   trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
Minor clean up
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp	2010-10-05 06:28:43 UTC (rev 5245)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.cpp	2010-10-05 15:46:37 UTC (rev 5246)
@@ -281,6 +281,8 @@
     return GetCapabilities(providerName, connectionString);
 MgByteReader* MgProxyFeatureService::GetCapabilities(CREFSTRING providerName, CREFSTRING connectionString)
     Ptr<MgUserInformation> userInfo = m_connProp->GetUserInfo();
@@ -301,6 +303,7 @@
     return (MgByteReader*)cmd.GetReturnValue().val.m_obj;
 /// <summary>
 /// Creates or updates a feature schema within the specified feature source.
@@ -317,7 +320,6 @@
 void MgProxyFeatureService::ApplySchema(MgResourceIdentifier* resource, MgFeatureSchema* schema)
     MgCommand cmd;
     cmd.ExecuteCommand(m_connProp,                                  // Connection
                        MgCommand::knVoid,                           // Return type expected
                        MgFeatureServiceOpId::ApplySchema_Id,        // Command Code
@@ -331,6 +333,7 @@
     SetWarning(cmd.GetWarningObject());
 /// \brief
 /// Gets the definitions of one or more schemas contained in the
@@ -338,10 +341,10 @@
 /// a class name does not exist, this method will throw an exception.
 MgFeatureSchemaCollection* MgProxyFeatureService::DescribeSchema(MgResourceIdentifier* resource,
-    CREFSTRING schemaName, MgStringCollection* classNames)
+        CREFSTRING schemaName,
+        MgStringCollection* classNames)
     MgCommand cmd;
                        MgCommand::knObject,                         // Return type expected
                        MgFeatureServiceOpId::DescribeSchema_Id,     // Command Code
@@ -358,15 +361,17 @@
     return (MgFeatureSchemaCollection*)cmd.GetReturnValue().val.m_obj;
 /// This method has been deprecated. Use the above method.
-    CREFSTRING schemaName)
+        CREFSTRING schemaName)
     return DescribeSchema(resource, schemaName, NULL);
 /// \brief
 /// Gets the definitions in XML format of one or more schemas contained in the
@@ -374,10 +379,10 @@
 STRING MgProxyFeatureService::DescribeSchemaAsXml(MgResourceIdentifier* resource,
     MgCommand cmd;
                        MgCommand::knString,                         // Return type expected
                        MgFeatureServiceOpId::DescribeSchemaAsXml_Id,// Command Code
@@ -397,15 +402,17 @@
     return retVal;
     return DescribeSchemaAsXml(resource, schemaName, NULL);
 /// <summary>
 /// This method returns the Fdo schema information in XML format
@@ -508,9 +515,9 @@
 ///    filter text.
 /// 2. Interrogation of class definition would allow to determine properties of classes
 ///    which can be used for filter text.
-MgFeatureReader*  MgProxyFeatureService::SelectFeatures(MgResourceIdentifier* resource,
-                                                        CREFSTRING className,
-                                                        MgFeatureQueryOptions* options)
+MgFeatureReader* MgProxyFeatureService::SelectFeatures(MgResourceIdentifier* resource,
+                                                       CREFSTRING className,
+                                                       MgFeatureQueryOptions* options)
     MgCommand cmd;
@@ -572,10 +579,10 @@
 ///    filter text.
-                                                        MgFeatureQueryOptions* options,
-                                                        CREFSTRING coordinateSystem)
+                                                       MgFeatureQueryOptions* options,
+                                                       CREFSTRING coordinateSystem)
     throw new MgNotImplementedException(
         L"MgProxyFeatureService::SelectFeatures",
@@ -609,7 +616,7 @@
 /// </param>
 /// <returns>
 /// MgDataReader pointer which operates on the instance of actual reader returned from the
-/// FdoProvider ( OR NULL ).
+/// FdoProvider (OR NULL).
 /// </returns>
 /// EXCEPTIONS:
 /// MgFeatureSourceException
@@ -712,6 +719,7 @@
     return SAFE_ADDREF((MgPropertyCollection*)propCol);
 /// <summary>
 /// It executes all the commands specified in command collection
@@ -782,6 +790,7 @@
 /// <summary>
 /// Gets the locked features
@@ -806,9 +815,9 @@
 /// EXCEPTIONS:
 /// MgFeatureServiceException
 /// MgInvalidArgumentException
-MgFeatureReader* MgProxyFeatureService::GetLockedFeatures( MgResourceIdentifier* resource,
-                                                MgFeatureQueryOptions* options )
+MgFeatureReader* MgProxyFeatureService::GetLockedFeatures(MgResourceIdentifier* resource,
         L"MgProxyFeatureService::GetLockedFeatures",
@@ -817,6 +826,7 @@
     return NULL; // to make some compiler happy
 /// <summary>
 /// Starts a transaction on the specified feature source
@@ -837,7 +847,7 @@
 /// MgInvalidOperationException
 /// MgFdoException
-MgTransaction* MgProxyFeatureService::BeginTransaction( MgResourceIdentifier* resource )
+MgTransaction* MgProxyFeatureService::BeginTransaction(MgResourceIdentifier* resource)
     MgCommand cmd;
@@ -858,6 +868,7 @@
     return SAFE_ADDREF((MgProxyFeatureTransaction*)featTransaction);
 /// <summary>
 /// This method executes the SELECT SQL statement specified and returns a pointer to
@@ -910,6 +921,7 @@
     return SAFE_ADDREF((MgProxySqlDataReader*)sqlReader);
 /// <summary>
 /// This method executes the SELECT SQL statement specified within a given transaction
@@ -948,7 +960,7 @@
 MgSqlDataReader* MgProxyFeatureService::ExecuteSqlQuery(MgResourceIdentifier* resource,
                                                         CREFSTRING sqlStatement,
                                                         MgParameterCollection* params,
-                                                        MgTransaction* transaction )
+                                                        MgTransaction* transaction)
     STRING transactionId = L"";
     MgProxyFeatureTransaction* proxyTransaction = dynamic_cast<MgProxyFeatureTransaction*>(transaction);
@@ -979,6 +991,7 @@
 /// <summary>
@@ -1067,6 +1080,7 @@
 /// <summary>
 /// This method executes all SQL statements supported by providers except SELECT.
@@ -1105,6 +1119,7 @@
     return cmd.GetReturnValue().val.m_i32;
 /// <summary>
@@ -1263,7 +1278,8 @@
 /// MgInvalidResourceIdentifer
 /// NOTE:
 /// Subject to change in FDO R2
-MgLongTransactionReader* MgProxyFeatureService::GetLongTransactions(MgResourceIdentifier* resource, bool bActiveOnly)
+MgLongTransactionReader* MgProxyFeatureService::GetLongTransactions(MgResourceIdentifier* resource,
+        bool bActiveOnly)
     MgCommand cmd;
@@ -1304,8 +1320,8 @@
 /// MgNullArgumentException
 /// MgInvalidResourceTypeException
 /// MgSessionNotFoundException
-bool MgProxyFeatureService::SetLongTransaction( MgResourceIdentifier* featureSourceId,
-                                                CREFSTRING longTransactionName)
+bool MgProxyFeatureService::SetLongTransaction(MgResourceIdentifier* featureSourceId,
+                                               CREFSTRING longTransactionName)
     MgCommand cmd;
@@ -1345,6 +1361,7 @@
 // Retrieves WFS schema information for the specified feature classes with specified format
 MgByteReader* MgProxyFeatureService::DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId,
@@ -1368,6 +1385,7 @@
 // Retrieves feature information in WFS format, based on the specified criteria
 MgByteReader* MgProxyFeatureService::GetWfsFeature(MgResourceIdentifier* featureSourceId,
@@ -1397,6 +1415,7 @@
 // Retrieves feature information in with specified WFS format, based on the specified criteria
@@ -1436,6 +1455,7 @@
 MgBatchPropertyCollection* MgProxyFeatureService::GetFeatures(CREFSTRING featureReader)
@@ -1656,8 +1676,8 @@
 // Returns the collection of identity properties for the specified class.
 // If schemaName is empty, then className needs to be fully qualified.
 MgClassDefinitionCollection* MgProxyFeatureService::GetIdentityProperties(MgResourceIdentifier* resource,
-        MgStringCollection* classNames)
     MgCommand cmd;
@@ -1695,6 +1715,7 @@
 MgByteReader* MgProxyFeatureService::GetSchemaMapping(CREFSTRING providerName,
                                                       CREFSTRING partialConnString)
@@ -1714,6 +1735,7 @@
 /// \brief
 /// Sets the connection properties for the Proxy Service.  This
@@ -1727,6 +1749,7 @@
     m_connProp = SAFE_ADDREF(connProp);
 /// <summary>
 /// Get the FDO cache information.
@@ -1753,6 +1776,7 @@
     return retVal;
 MgClassDefinition* MgProxyFeatureService::GetClassDefinition(MgResourceIdentifier* resource,
@@ -1777,6 +1801,8 @@
     return (MgClassDefinition*)cmd.GetReturnValue().val.m_obj;
 bool MgProxyFeatureService::CommitTransaction(CREFSTRING transactionId)
     MgCommand cmd;
@@ -1794,6 +1820,8 @@
     return (bool)cmd.GetReturnValue().val.m_i8;
 bool MgProxyFeatureService::RollbackTransaction(CREFSTRING transactionId)
     MgCommand cmd;
Modified: trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h
--- trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h	2010-10-05 06:28:43 UTC (rev 5245)
+++ trunk/MgDev/Common/MapGuideCommon/Services/ProxyFeatureService.h	2010-10-05 15:46:37 UTC (rev 5246)
@@ -147,9 +147,9 @@
     /// \return
     /// String Collection or NULL if nothing is found
-    MgStringCollection* GetConnectionPropertyValues( CREFSTRING providerName,
-                                                     CREFSTRING propertyName,
-                                                     CREFSTRING partialConnString );
+    MgStringCollection* GetConnectionPropertyValues(CREFSTRING providerName,
+                                                    CREFSTRING propertyName,
+                                                    CREFSTRING partialConnString);
     /// \brief
@@ -252,7 +252,7 @@
     /// \exception MgInvalidResourceIdentifier
-    MgStringCollection* GetSchemas( MgResourceIdentifier* resource );
+    MgStringCollection* GetSchemas(MgResourceIdentifier* resource);
     /// \brief
@@ -271,7 +271,7 @@
-    MgStringCollection* GetClasses( MgResourceIdentifier* resource, CREFSTRING schemaName );
+    MgStringCollection* GetClasses(MgResourceIdentifier* resource, CREFSTRING schemaName);
     /// \brief
@@ -292,9 +292,9 @@
-    MgClassDefinition* GetClassDefinition(  MgResourceIdentifier* resource,
-                                            CREFSTRING className);
+    MgClassDefinition* GetClassDefinition(MgResourceIdentifier* resource,
+                                          CREFSTRING className);
     /// \brief
@@ -370,13 +370,14 @@
     /// schema and classes.
     MgFeatureSchemaCollection* DescribeSchema(MgResourceIdentifier* resource,
-        CREFSTRING schemaName, MgStringCollection* classNames);
+                                              MgStringCollection* classNames);
-        CREFSTRING schemaName);
+                                              CREFSTRING schemaName);
     /// \brief
@@ -427,13 +428,14 @@
     /// \exception MgFdoException
     STRING DescribeSchemaAsXml(MgResourceIdentifier* resource,
     /// \brief
@@ -503,9 +505,9 @@
-    MgFeatureReader*  SelectFeatures(   MgResourceIdentifier* resource,
-                                        MgFeatureQueryOptions* options );
+    MgFeatureReader* SelectFeatures(MgResourceIdentifier* resource,
+                                    MgFeatureQueryOptions* options);
     /// \brief
@@ -550,10 +552,10 @@
     /// \exception MgInvalidArgumentException
-    virtual MgFeatureReader*  SelectFeatures(   MgResourceIdentifier* resource,
-                                                CREFSTRING coordinateSystem );
+    virtual MgFeatureReader* SelectFeatures(MgResourceIdentifier* resource,
+                                            CREFSTRING coordinateSystem);
     /// \brief
@@ -580,7 +582,7 @@
     /// \return
-    /// FdoProvider ( OR NULL ).
+    /// FdoProvider (OR NULL).
     /// \exception MgFeatureServiceException
@@ -598,9 +600,9 @@
     /// 4. Interrogation of class definition would allow to determine properties of classes
-    MgDataReader*  SelectAggregate( MgResourceIdentifier* resource,
-                                    MgFeatureAggregateOptions* options );
+    MgDataReader* SelectAggregate(MgResourceIdentifier* resource,
+                                  MgFeatureAggregateOptions* options);
     /// \brief
@@ -624,9 +626,9 @@
-    MgPropertyCollection* UpdateFeatures( MgResourceIdentifier* resource,
-                                     MgFeatureCommandCollection* commands,
-                                     bool useTransaction );
+    MgPropertyCollection* UpdateFeatures(MgResourceIdentifier* resource,
+                                         MgFeatureCommandCollection* commands,
+                                         bool useTransaction);
     /// \brief
@@ -653,9 +655,9 @@
     /// Index of commandCollection and index of IntCollection would match the result.
-                                          MgTransaction* transaction );
+                                         MgTransaction* transaction);
     /// \brief
@@ -692,9 +694,9 @@
     /// \exception ...
-    virtual MgFeatureReader* GetLockedFeatures( MgResourceIdentifier* resource,
+    virtual MgFeatureReader* GetLockedFeatures(MgResourceIdentifier* resource,
     /// <summary>
@@ -716,7 +718,7 @@
     /// MgFdoException
-    MgTransaction* BeginTransaction( MgResourceIdentifier* resource );
+    MgTransaction* BeginTransaction(MgResourceIdentifier* resource);
     /// \brief
@@ -746,8 +748,8 @@
     /// \exception MgInvalidSqlStatement
     /// \exception MgSqlNotSupported
-    MgSqlDataReader* ExecuteSqlQuery( MgResourceIdentifier* resource,
-                                      CREFSTRING sqlStatement );
+    MgSqlDataReader* ExecuteSqlQuery(MgResourceIdentifier* resource,
+                                     CREFSTRING sqlStatement);
     /// \brief
@@ -783,10 +785,10 @@
-                                      CREFSTRING sqlStatement,
-                                      MgParameterCollection* params,
+                                     CREFSTRING sqlStatement,
+                                     MgParameterCollection* params,
     /// \brief
@@ -826,11 +828,11 @@
-                                      MgTransaction* transaction,
-                                      INT32 fetchSize);
+                                     MgTransaction* transaction,
+                                     INT32 fetchSize);
     /// \brief
@@ -853,8 +855,8 @@
-    INT32 ExecuteSqlNonQuery( MgResourceIdentifier* resource,
-                              CREFSTRING sqlNonSelectStatement );
+    INT32 ExecuteSqlNonQuery(MgResourceIdentifier* resource,
+                             CREFSTRING sqlNonSelectStatement);
     /// \brief
@@ -883,10 +885,10 @@
-                              CREFSTRING sqlNonSelectStatement,
+                             CREFSTRING sqlNonSelectStatement,
     /// \brief
@@ -926,8 +928,8 @@
     /// \note
-    MgSpatialContextReader* GetSpatialContexts( MgResourceIdentifier* resource,
-                                                bool bActiveOnly);
+    MgSpatialContextReader* GetSpatialContexts(MgResourceIdentifier* resource,
+                                               bool bActiveOnly);
     /// \brief
@@ -965,8 +967,8 @@
     /// \note
-    MgLongTransactionReader* GetLongTransactions( MgResourceIdentifier* resource,
+    MgLongTransactionReader* GetLongTransactions(MgResourceIdentifier* resource,
     /// \brief
@@ -989,8 +991,8 @@
     /// \exception MgInvalidResourceTypeException
     /// \exception MgSessionNotFoundException
-    bool SetLongTransaction( MgResourceIdentifier* featureSourceId,
-                             CREFSTRING longTransactionName);
+    bool SetLongTransaction(MgResourceIdentifier* featureSourceId,
+                            CREFSTRING longTransactionName);
     /// \brief
@@ -1026,7 +1028,8 @@
     /// \return
     /// Returns an MgByteReader containing the XML schema.
-    MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses);
+    MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId,
+                                         MgStringCollection* featureClasses);
     /// \brief
@@ -1060,7 +1063,9 @@
     /// \return
-    virtual MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses,CREFSTRING outputFormat);
+    virtual MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId,
+                                                 MgStringCollection* featureClasses,
+                                                 CREFSTRING outputFormat);
     /// \brief
@@ -1097,8 +1102,12 @@
     /// \return
     /// Returns an MgByteReader containing the requested feature information.
-    MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId, CREFSTRING featureClass,
-        MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures);
+    MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId,
+                                CREFSTRING featureClass,
+                                MgStringCollection* requiredProperties,
+                                CREFSTRING srs,
+                                CREFSTRING filter,
+                                INT32 maxFeatures);
     /// \brief
@@ -1151,8 +1160,17 @@
-        MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING namespaceUrl);
+                                CREFSTRING srs,
+                                INT32 maxFeatures,
+                                CREFSTRING wfsVersion,
+                                CREFSTRING outputFormat,
+                                CREFSTRING sortCriteria,
+                                CREFSTRING namespacePrefix,
+                                CREFSTRING namespaceUrl);
     /// \brief
@@ -1256,10 +1274,10 @@
-                                            bool serialize);
+                                          bool serialize);
     // Commit the transaction specified by the transaction id.
     bool CommitTransaction(CREFSTRING transactionId);
Modified: trunk/MgDev/Common/PlatformBase/Services/FeatureService.h
--- trunk/MgDev/Common/PlatformBase/Services/FeatureService.h	2010-10-05 06:28:43 UTC (rev 5245)
+++ trunk/MgDev/Common/PlatformBase/Services/FeatureService.h	2010-10-05 15:46:37 UTC (rev 5246)
@@ -203,9 +203,9 @@
-    virtual MgStringCollection* GetConnectionPropertyValues( CREFSTRING providerName,
-                                                             CREFSTRING partialConnString    ) = 0;
+    virtual MgStringCollection* GetConnectionPropertyValues(CREFSTRING providerName,
+                                                            CREFSTRING partialConnString) = 0;
     /// \brief
@@ -461,7 +461,8 @@
     virtual MgFeatureSchemaCollection* DescribeSchema(MgResourceIdentifier* resource,
-        CREFSTRING schemaName, MgStringCollection* classNames) = 0;
+                                                      MgStringCollection* classNames) = 0;
     /// \brief
@@ -505,7 +506,7 @@
-        CREFSTRING schemaName) = 0;
+                                                      CREFSTRING schemaName) = 0;
     /// \brief
@@ -556,7 +557,8 @@
     virtual STRING DescribeSchemaAsXml(MgResourceIdentifier* resource,
     /// \brief
@@ -599,7 +601,7 @@
     /// \brief
@@ -715,9 +717,9 @@
-                                                MgFeatureQueryOptions* options ) = 0;
+                                            MgFeatureQueryOptions* options) = 0;
     /// \brief
@@ -765,10 +767,10 @@
-                                                CREFSTRING coordinateSystem ) = 0;
+                                            CREFSTRING coordinateSystem) = 0;
     /// \brief
@@ -811,9 +813,9 @@
-    virtual MgDataReader*  SelectAggregate( MgResourceIdentifier* resource,
-                                            MgFeatureAggregateOptions* options ) = 0;
+    virtual MgDataReader* SelectAggregate(MgResourceIdentifier* resource,
+                                          MgFeatureAggregateOptions* options) = 0;
     /// \brief
@@ -878,9 +880,9 @@
     /// \exception MgInvalidOperationException
-    virtual MgPropertyCollection* UpdateFeatures( MgResourceIdentifier* resource,
-                                                  bool useTransaction ) = 0;
+    virtual MgPropertyCollection* UpdateFeatures(MgResourceIdentifier* resource,
+                                                 bool useTransaction) = 0;
     /// \brief
@@ -951,9 +953,9 @@
-                                                  MgTransaction* transaction ) = 0;
+                                                 MgTransaction* transaction) = 0;
     /// \brief
@@ -990,9 +992,9 @@
     /// \exception ...
     /// \brief
@@ -1023,7 +1025,7 @@
-    virtual MgTransaction* BeginTransaction( MgResourceIdentifier* resource ) = 0;
+    virtual MgTransaction* BeginTransaction(MgResourceIdentifier* resource) = 0;
     /// \brief
@@ -1071,8 +1073,8 @@
-    virtual MgSqlDataReader* ExecuteSqlQuery( MgResourceIdentifier* resource,
-                                              CREFSTRING sqlStatement ) = 0;
+    virtual MgSqlDataReader* ExecuteSqlQuery(MgResourceIdentifier* resource,
+                                             CREFSTRING sqlStatement) = 0;
     /// \brief
@@ -1131,10 +1133,10 @@
-                                              MgParameterCollection* parameters,
+                                             MgParameterCollection* parameters,
     /// \brief
@@ -1179,8 +1181,8 @@
-    virtual INT32 ExecuteSqlNonQuery( MgResourceIdentifier* resource,
-                                      CREFSTRING sqlNonSelectStatement ) = 0;
+    virtual INT32 ExecuteSqlNonQuery(MgResourceIdentifier* resource,
+                                     CREFSTRING sqlNonSelectStatement) = 0;
     /// \brief
@@ -1237,10 +1239,10 @@
     /// \brief
@@ -1277,8 +1279,8 @@
-    virtual MgSpatialContextReader* GetSpatialContexts( MgResourceIdentifier* resource,
-                                                        bool bActiveOnly) = 0;
+    virtual MgSpatialContextReader* GetSpatialContexts(MgResourceIdentifier* resource,
+                                                       bool bActiveOnly) = 0;
     /// \brief
@@ -1315,8 +1317,8 @@
-    virtual MgLongTransactionReader* GetLongTransactions( MgResourceIdentifier* resource,
+    virtual MgLongTransactionReader* GetLongTransactions(MgResourceIdentifier* resource,
     /// \brief
@@ -1352,8 +1354,8 @@
-    virtual bool SetLongTransaction( MgResourceIdentifier* featureSourceId,
-                                     CREFSTRING longTransactionName) = 0;
+    virtual bool SetLongTransaction(MgResourceIdentifier* featureSourceId,
+                                    CREFSTRING longTransactionName) = 0;
     /// \brief
@@ -1383,7 +1385,7 @@
-    virtual MgStringCollection* GetSchemas( MgResourceIdentifier* resource ) = 0;
+    virtual MgStringCollection* GetSchemas(MgResourceIdentifier* resource) = 0;
     /// \brief
@@ -1416,7 +1418,7 @@
-    virtual MgStringCollection* GetClasses( MgResourceIdentifier* resource, CREFSTRING schemaName ) = 0;
+    virtual MgStringCollection* GetClasses(MgResourceIdentifier* resource, CREFSTRING schemaName) = 0;
     /// \brief
@@ -1449,9 +1451,9 @@
-    virtual MgClassDefinition* GetClassDefinition(  MgResourceIdentifier* resource,
-                                                    CREFSTRING className) = 0;
+    virtual MgClassDefinition* GetClassDefinition(MgResourceIdentifier* resource,
+                                                  CREFSTRING className) = 0;
     /// \brief
@@ -1524,7 +1526,8 @@
     /// \return
-    virtual MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses) = 0;
+                                                 MgStringCollection* featureClasses) = 0;
     /// \brief
@@ -1560,7 +1563,9 @@
     /// \return
-    virtual MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses,CREFSTRING outputFormat) = 0;
+                                                 CREFSTRING outputFormat) = 0;
     /// \brief
@@ -1599,8 +1604,12 @@
     /// \return
-    virtual MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId, CREFSTRING featureClass,
-        MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures) = 0;
+    virtual MgByteReader* GetWfsFeature(MgResourceIdentifier* featureSourceId,
+                                        CREFSTRING srs,
+                                        INT32 maxFeatures) = 0;
     /// \brief
@@ -1654,8 +1663,17 @@
-        MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures,CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING namespaceUrl) = 0;
+                                        CREFSTRING srs,
+                                        CREFSTRING namespaceUrl) = 0;
     /// \brief
@@ -1727,10 +1745,10 @@
     virtual STRING GetFdoCacheInfo() = 0;
-                                                    bool serialize) = 0;
+                                                  bool serialize) = 0;
     virtual bool CommitTransaction(CREFSTRING transactionId) = 0;
@@ -1803,11 +1821,11 @@
-                                              INT32 fetchSize ) = 0;
+                                             INT32 fetchSize) = 0;
 protected:
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2010-10-05 06:28:43 UTC (rev 5245)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.cpp	2010-10-05 15:46:37 UTC (rev 5246)
@@ -64,6 +64,7 @@
 /// <summary>
 /// Destructor
@@ -171,9 +172,9 @@
 /// <returns>
 /// </returns>
-MgStringCollection* MgServerFeatureService::GetConnectionPropertyValues( CREFSTRING providerName,
+MgStringCollection* MgServerFeatureService::GetConnectionPropertyValues(CREFSTRING providerName,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetConnectionPropertyValues()");
@@ -219,7 +220,7 @@
 /// <returns>
 /// True if connection was successful
 /// </returns>
-bool MgServerFeatureService::TestConnection( MgResourceIdentifier* resource )
+bool MgServerFeatureService::TestConnection(MgResourceIdentifier* resource)
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::TestConnection()");
@@ -261,7 +262,7 @@
 /// NOTE:
 /// Subject to change with FDO R2
-MgByteReader* MgServerFeatureService::GetCapabilities( CREFSTRING providerName )
+MgByteReader* MgServerFeatureService::GetCapabilities(CREFSTRING providerName)
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetCapabilities()");
@@ -277,7 +278,9 @@
     return msgpc.GetProviderCapabilities();
-MgByteReader* MgServerFeatureService::GetCapabilities( CREFSTRING providerName, CREFSTRING connectionString )
+MgByteReader* MgServerFeatureService::GetCapabilities(CREFSTRING providerName, CREFSTRING connectionString)
@@ -285,7 +288,8 @@
 /// \brief
@@ -297,6 +301,7 @@
     msas.ApplySchema(resource, schema);
 /// \brief
@@ -304,7 +309,8 @@
 MgFeatureSchemaCollection* MgServerFeatureService::DescribeSchema(MgResourceIdentifier* resource,
     Ptr<MgFeatureSchemaCollection> schemas;
@@ -330,15 +336,17 @@
     return schemas.Detach();
 /// \brief
@@ -346,7 +354,8 @@
 STRING MgServerFeatureService::DescribeSchemaAsXml(MgResourceIdentifier* resource,
     STRING schemaXml;
@@ -372,15 +381,17 @@
     return schemaXml;
 /// <summary>
 /// Select features returns feature information from an Fdo Provider.  An MgFeatureReader
@@ -414,9 +425,9 @@
 ///    filter text.
-MgFeatureReader* MgServerFeatureService::SelectFeatures( MgResourceIdentifier* resource,
+MgFeatureReader* MgServerFeatureService::SelectFeatures(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::SelectFeatures()");
@@ -482,10 +493,10 @@
 ///    filter text.
         L"MgServerFeatureService::SelectFeatures",
@@ -534,9 +545,9 @@
 /// 3. Interrogation of provider capabilities will inform list of operations supported
-MgDataReader* MgServerFeatureService::SelectAggregate( MgResourceIdentifier* resource,
+MgDataReader* MgServerFeatureService::SelectAggregate(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::SelectAggregate()");
@@ -574,9 +585,9 @@
 /// EXCEPTIONS:
-MgPropertyCollection* MgServerFeatureService::UpdateFeatures( MgResourceIdentifier* resource,
+MgPropertyCollection* MgServerFeatureService::UpdateFeatures(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::UpdateFeatures()");
@@ -584,6 +595,7 @@
     return asuf.Execute(resource, commands, useTransaction);
 /// <summary>
@@ -606,9 +618,9 @@
 /// EXCEPTIONS:
@@ -616,6 +628,7 @@
     return asuf.Execute(resource, commands, transaction);
 /// <summary>
@@ -640,9 +653,9 @@
 /// EXCEPTIONS:
-MgFeatureReader* MgServerFeatureService::GetLockedFeatures( MgResourceIdentifier* resource,
+MgFeatureReader* MgServerFeatureService::GetLockedFeatures(MgResourceIdentifier* resource,
         L"MgServerFeatureService::GetLockedFeatures",
@@ -651,6 +664,7 @@
 /// <summary>
@@ -671,7 +685,7 @@
 /// MgFdoException
-MgTransaction* MgServerFeatureService::BeginTransaction( MgResourceIdentifier* resource )
+MgTransaction* MgServerFeatureService::BeginTransaction(MgResourceIdentifier* resource)
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::BeginTransaction()");
@@ -689,6 +703,7 @@
     return transaction.Detach();
 /// <summary>
@@ -718,8 +733,8 @@
 /// MgInvalidSqlStatement
 /// MgSqlNotSupported
-MgSqlDataReader* MgServerFeatureService::ExecuteSqlQuery( MgResourceIdentifier* resource,
+MgSqlDataReader* MgServerFeatureService::ExecuteSqlQuery(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::ExecuteSqlQuery()");
@@ -727,6 +742,7 @@
     return sqlCommand.ExecuteQuery(resource, sqlStatement, NULL, NULL);
 /// <summary>
@@ -762,10 +778,10 @@
@@ -773,6 +789,7 @@
     return sqlCommand.ExecuteQuery(resource, sqlStatement, params, transaction);
 /// <summary>
@@ -812,18 +829,19 @@
-                                                          INT32 fetchSize )
+                                                         INT32 fetchSize)
     MgServerSqlCommand sqlCommand;
-    return sqlCommand.ExecuteQuery(resource, sqlStatement, params, transaction, fetchSize );
+    return sqlCommand.ExecuteQuery(resource, sqlStatement, params, transaction, fetchSize);
 /// <summary>
@@ -843,8 +861,8 @@
 /// EXCEPTIONS:
-INT32 MgServerFeatureService::ExecuteSqlNonQuery( MgResourceIdentifier* resource,
+INT32 MgServerFeatureService::ExecuteSqlNonQuery(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::ExecuteSqlNonQuery()");
@@ -852,6 +870,7 @@
     return sqlCommand.ExecuteNonQuery(resource, sqlNonSelectStatement, NULL, NULL);
 /// <summary>
@@ -879,10 +898,10 @@
 /// EXCEPTIONS:
@@ -890,6 +909,7 @@
     return sqlCommand.ExecuteNonQuery(resource, sqlNonSelectStatement, params, transaction);
 /// <summary>
 /// This method executes the SELECT statement to return all available spatial context
@@ -925,7 +945,7 @@
 /// NOTE:
-MgSpatialContextReader* MgServerFeatureService::GetSpatialContexts( MgResourceIdentifier* resource,
+MgSpatialContextReader* MgServerFeatureService::GetSpatialContexts(MgResourceIdentifier* resource,
        bool bActiveOnly)
     Ptr<MgSpatialContextReader> reader;
@@ -985,7 +1005,8 @@
 /// NOTE:
-MgLongTransactionReader* MgServerFeatureService::GetLongTransactions(MgResourceIdentifier* resource, bool bActiveOnly)
+MgLongTransactionReader* MgServerFeatureService::GetLongTransactions(MgResourceIdentifier* resource,
+        bool bActiveOnly)
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetLongTransactions()");
@@ -1015,8 +1036,8 @@
-bool MgServerFeatureService::SetLongTransaction( MgResourceIdentifier* featureSourceId,
+bool MgServerFeatureService::SetLongTransaction(MgResourceIdentifier* featureSourceId,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::SetLongTransaction()");
@@ -1045,6 +1066,7 @@
 // Just a simple hashing algorithm
 unsigned MgServerFeatureService::StringHasher(FdoString* pszString)
@@ -1063,6 +1085,7 @@
   return uRet;
 /// \brief
 /// Find a class definition from the specified schemas.
@@ -1130,6 +1153,7 @@
 /// \brief
 /// Retrieves schema information about a set of feature classes for a given feature source.
@@ -1157,7 +1181,8 @@
 /// \return
-MgByteReader* MgServerFeatureService::DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses)
+MgByteReader* MgServerFeatureService::DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::DescribeWfsFeatureType()");
@@ -1294,7 +1319,9 @@
 /// \return
-MgByteReader* MgServerFeatureService::DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses,CREFSTRING outputFormat)
     L"MgServerFeatureService::DescribeWfsFeatureType",
@@ -1430,9 +1457,9 @@
-MgClassDefinition* MgServerFeatureService::GetClassDefinition(  MgResourceIdentifier* resource,
+MgClassDefinition* MgServerFeatureService::GetClassDefinition(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetClassDefinition()");
@@ -1440,11 +1467,12 @@
     return msds.GetClassDefinition(resource, schemaName, className, true);
-        bool serialize)
+                                                              bool serialize)
@@ -1684,8 +1712,8 @@
 MgClassDefinitionCollection* MgServerFeatureService::GetIdentityProperties(MgResourceIdentifier* resource,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetIdentityProperties()");
@@ -1693,6 +1721,7 @@
     return msds.GetIdentityProperties(resource, schemaName, classNames);
 /// \brief
 /// Retrieves feature information based on the supplied criteria with specified format.
@@ -1745,16 +1774,16 @@
 /// EXCEPTIONS:
 MgByteReader* MgServerFeatureService::GetWfsFeature(MgResourceIdentifier* fs,
-                                                     CREFSTRING featureClass,
-                                                     MgStringCollection* propNames,
-                                                     CREFSTRING srs,
-                                                     CREFSTRING wfsFilter,
-                                                     INT32 maxFeatures,
-                                                     CREFSTRING wfsVersion,
-                                                     CREFSTRING outputFormat,
-                                                     CREFSTRING sortCriteria,
-                                                     CREFSTRING namespacePrefix,
-                                                     CREFSTRING namespaceUrl)
+                                                    MgStringCollection* propNames,
+                                                    CREFSTRING srs,
+                                                    CREFSTRING wfsFilter,
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::GetWfsFeature()");
@@ -1940,8 +1969,6 @@
         flags->SetDefaultNamespace(L"http://www.mynamespace.com/myns");
     //create the FDO xml serializer stack and write out the features
     FdoPtr<FdoXmlWriter> xmlWriter = FdoXmlWriter::Create(fileName.c_str(), false);
     FdoPtr<FdoXmlFeaturePropertyWriter> propWriter = FdoXmlFeaturePropertyWriter::Create(xmlWriter,flags);
@@ -1973,11 +2000,11 @@
-                                                     CREFSTRING srs,
-                                                     INT32 maxFeatures)
+                                                    CREFSTRING srs,
     return GetWfsFeature(fs, featureClass, propNames, srs, wfsFilter, maxFeatures, L"1.0.0", L"text/xml; subtype=gml/2.1.2", L"", L"", L"");
@@ -2003,6 +2030,7 @@
     return mseds.EnumerateDataStores(providerName, partialConnString);
 /// \brief
 /// This method returns all of the logical to physical schema mappings for
@@ -2023,12 +2051,15 @@
     return msgsm.GetSchemaMapping(providerName, partialConnString);
 void MgServerFeatureService::SetConnectionProperties(MgConnectionProperties*)
     // Do nothing.  No connection properties are required for Server-side service objects.
 bool MgServerFeatureService::CommitTransaction(CREFSTRING transactionId)
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::CommitTransaction()");
@@ -2047,6 +2078,8 @@
     return bResult;
 bool MgServerFeatureService::RollbackTransaction(CREFSTRING transactionId)
     MG_LOG_TRACE_ENTRY(L"MgServerFeatureService::RollbackTransaction()");
@@ -2065,6 +2098,7 @@
     return bResult;
 /// <summary>
 /// Gets the FDO cache information for the server
@@ -2087,6 +2121,7 @@
     return info;
 /// \brief
 /// Handle the Resource Change Notification event.
@@ -2131,6 +2166,7 @@
     return success;
 /// \brief
Modified: trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h
--- trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h	2010-10-05 06:28:43 UTC (rev 5245)
+++ trunk/MgDev/Server/src/Services/Feature/ServerFeatureService.h	2010-10-05 15:46:37 UTC (rev 5246)
@@ -132,9 +132,9 @@
     /// <returns>
     /// </returns>
     /// <summary>
@@ -227,7 +227,7 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -246,7 +246,7 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -267,9 +267,9 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -290,10 +290,10 @@
     /// EXCEPTIONS:
-                                            bool serialize);
+                                          bool serialize);
     /// \brief
@@ -308,13 +308,14 @@
     /// \brief
@@ -323,13 +324,14 @@
     /// <summary>
@@ -364,9 +366,9 @@
     ///    filter text.
     /// <summary>
@@ -405,10 +407,10 @@
     ///    filter text.
     /// <summary>
@@ -434,7 +436,7 @@
     /// </param>
     /// <returns>
     /// </returns>
     /// EXCEPTIONS:
@@ -449,9 +451,9 @@
     /// <summary>
@@ -474,9 +476,9 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -500,9 +502,9 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -528,9 +530,9 @@
     /// EXCEPTIONS:
-    MgFeatureReader* GetLockedFeatures( MgResourceIdentifier* resource,
+    MgFeatureReader* GetLockedFeatures(MgResourceIdentifier* resource,
     /// <summary>
@@ -552,7 +554,7 @@
     /// MgFdoException
     /// <summary>
@@ -583,8 +585,8 @@
     /// <summary>
@@ -624,10 +626,10 @@
     /// <summary>
@@ -671,11 +673,11 @@
-                                      INT32 fetchSize );
+                                     INT32 fetchSize);
     /// <summary>
@@ -696,8 +698,8 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -729,10 +731,10 @@
     /// EXCEPTIONS:
     /// <summary>
@@ -769,8 +771,8 @@
     /// NOTE:
     /// <summary>
@@ -805,8 +807,8 @@
     /// NOTE:
     /// <summary>
@@ -830,8 +832,8 @@
     /// <summary>
@@ -851,7 +853,8 @@
     /// </returns>
     /// <summary>
@@ -876,7 +879,9 @@
     /// </returns>
-    MgByteReader* DescribeWfsFeatureType(MgResourceIdentifier* featureSourceId, MgStringCollection* featureClasses, CREFSTRING outputFormat);
     /// <summary>
@@ -927,14 +932,27 @@
     /// EXCEPTIONS:
-        MgStringCollection* requiredProperties, CREFSTRING srs, CREFSTRING filter, INT32 maxFeatures, CREFSTRING wfsVersion, CREFSTRING outputFormat, CREFSTRING sortCriteria, CREFSTRING namespacePrefix, CREFSTRING namespaceUrl);
+                                CREFSTRING srs,
+                                CREFSTRING srs,
     /// <summary>
@@ -1015,10 +1033,8 @@
-    virtual bool NotifyResourcesChanged(const set<STRING>& resources,
-        bool strict = true);
-    virtual bool NotifyResourcesChanged(MgSerializableCollection* resources,
+    virtual bool NotifyResourcesChanged(const set<STRING>& resources, bool strict = true);
+    virtual bool NotifyResourcesChanged(MgSerializableCollection* resources, bool strict = true);
     STRING GetFdoCacheInfo();
More information about the mapguide-commits mailing list
