[mapguide-commits] r5248 - trunk/Tools/Maestro/MaestroAPI
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Wed Oct 6 00:54:26 EDT 2010
Author: jng
Date: 2010-10-06 04:54:26 +0000 (Wed, 06 Oct 2010)
New Revision: 5248
   trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs
When I said that this new server monitoring window was experimental, I meant it. This fixes GetSiteInformation() for the LocalNativeConnection impl allowing the window to work in a local native connection context
Modified: trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs
--- trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs	2010-10-05 17:57:37 UTC (rev 5247)
+++ trunk/Tools/Maestro/MaestroAPI/LocalNativeConnection.cs	2010-10-06 04:54:26 UTC (rev 5248)
@@ -895,7 +895,10 @@
             get
                 if (_admin == null)
                     _admin = new MgServerAdmin();
+                    _admin.Open(new MgUserInformation(this.SessionID));
                 return _admin;
@@ -911,70 +914,65 @@
             var props = this.ServerAdmin.GetInformationProperties();
             var prop = props.GetItem(MgServerInformationProperties.DisplayName);
-            info.SiteServer.DisplayName = GetValue(prop);
+            info.SiteServer.DisplayName = ((MgStringProperty)prop).GetValue();
             prop = props.GetItem(MgServerInformationProperties.OperatingSystemVersion);
-            info.SiteServer.OperatingSystem.Version = GetValue(prop);
+            info.SiteServer.OperatingSystem.Version = ((MgStringProperty)prop).GetValue();
             prop = props.GetItem(MgServerInformationProperties.TotalPhysicalMemory);
-            info.SiteServer.OperatingSystem.TotalPhysicalMemory = GetValue(prop);
+            info.SiteServer.OperatingSystem.TotalPhysicalMemory = ((MgInt64Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.TotalVirtualMemory);
-            info.SiteServer.OperatingSystem.TotalVirtualMemory = GetValue(prop);
+            info.SiteServer.OperatingSystem.TotalVirtualMemory = ((MgInt64Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.AvailablePhysicalMemory);
-            info.SiteServer.OperatingSystem.AvailablePhysicalMemory = GetValue(prop);
+            info.SiteServer.OperatingSystem.AvailablePhysicalMemory = ((MgInt64Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.AvailableVirtualMemory);
-            info.SiteServer.OperatingSystem.AvailableVirtualMemory = GetValue(prop);
+            info.SiteServer.OperatingSystem.AvailableVirtualMemory = ((MgInt64Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.Status);
-            info.SiteServer.Status = GetValue(prop);
+            info.SiteServer.Status = ((MgBooleanProperty)prop).GetValue() ? "Online" : "Offline";
             prop = props.GetItem(MgServerInformationProperties.ServerVersion);
-            info.SiteServer.Version = GetValue(prop);
+            info.SiteServer.Version = ((MgStringProperty)prop).GetValue();
             prop = props.GetItem(MgServerInformationProperties.TotalActiveConnections);
-            info.Statistics.ActiveConnections = GetValue(prop);
+            info.Statistics.ActiveConnections = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.AdminOperationsQueueCount);
-            info.Statistics.AdminOperationsQueueCount = GetValue(prop);
+            info.Statistics.AdminOperationsQueueCount = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.AverageOperationTime);
-            info.Statistics.AverageOperationTime = GetValue(prop);
+            info.Statistics.AverageOperationTime = ((MgInt64Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.ClientOperationsQueueCount);
-            info.Statistics.ClientOperationsQueueCount = GetValue(prop);
+            info.Statistics.ClientOperationsQueueCount = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.CpuUtilization);
-            info.Statistics.CpuUtilization = GetValue(prop);
+            info.Statistics.CpuUtilization = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.SiteOperationsQueueCount);
-            info.Statistics.SiteOperationsQueueCount = GetValue(prop);
+            info.Statistics.SiteOperationsQueueCount = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.TotalConnections);
-            info.Statistics.TotalConnections = GetValue(prop);
+            info.Statistics.TotalConnections = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.TotalProcessedOperations);
-            info.Statistics.TotalOperationsProcessed = GetValue(prop);
+            info.Statistics.TotalOperationsProcessed = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.TotalReceivedOperations);
-            info.Statistics.TotalOperationsReceived = GetValue(prop);
+            info.Statistics.TotalOperationsReceived = ((MgInt32Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.TotalOperationTime);
-            info.Statistics.TotalOperationTime = GetValue(prop);
+            info.Statistics.TotalOperationTime = ((MgInt64Property)prop).GetValue().ToString();
             prop = props.GetItem(MgServerInformationProperties.Uptime);
-            info.Statistics.Uptime = GetValue(prop);
+            info.Statistics.Uptime = ((MgInt64Property)prop).GetValue().ToString();
             return info;
-        private string GetValue(MgProperty prop)
-            throw new NotImplementedException();
 		#endregion
         public bool SupportsResourcePreviews
More information about the mapguide-commits mailing list
