[mapguide-commits] r5249 - in
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI: . ObjectModels
Resource
svn_mapguide at osgeo.org
Wed Oct 6 02:08:52 EDT 2010
Author: jng
Date: 2010-10-06 06:08:52 +0000 (Wed, 06 Oct 2010)
New Revision: 5249
Added:
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs
Add new interface for dynamic invocation. This will be used for resource upgrades
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-10-06 04:54:26 UTC (rev 5248)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/OSGeo.MapGuide.MaestroAPI.csproj 2010-10-06 06:08:52 UTC (rev 5249)
@@ -189,6 +189,7 @@
<Compile Include="Mapping\RuntimeMapBase.cs" />
<Compile Include="ObjectModels\ApplicationDefinition.cs" />
<Compile Include="ObjectModels\DrawingSource.cs" />
+ <Compile Include="ObjectModels\IDynamicInvokable.cs" />
<Compile Include="ObjectModels\Envelope.cs" />
<Compile Include="ObjectModels\FeatureSource.cs" />
<Compile Include="ObjectModels\LayerDefinition.cs" />
Added: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs (rev 0)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/ObjectModels/IDynamicInvokable.cs 2010-10-06 06:08:52 UTC (rev 5249)
@@ -0,0 +1,133 @@
+#region Disclaimer / License
+// Copyright (C) 2010, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using System.Reflection;
+using System.ComponentModel;
+namespace OSGeo.MapGuide.MaestroAPI.ObjectModels
+ /// <summary>
+ /// Interface allowing for dynamic invocation of public properties and methods.
+ /// </summary>
+ public interface IDynamicInvokable
+ //Nothing here. All done through extension methods baby!
+ public static class DynamicInvokableExtensions
+ /// <summary>
+ /// Gets the value of the specified property
+ /// </summary>
+ /// <param name="idi"></param>
+ /// <param name="name"></param>
+ /// <returns></returns>
+ /// <exception cref="MissingMemberException">Thrown if the specified property could not be found</exception>
+ public static object InvokeGetProperty(this IDynamicInvokable idi, string name)
+ var prop = idi.GetType().GetProperty(name);
+ if (prop != null)
+ return prop.GetValue(idi, null);
+ throw new MissingMemberException(name);
+ /// <summary>
+ /// Attempts to get the value of the specified property. Returns the specified default value if the named
+ /// property could not be found
+ /// </summary>
+ /// <param name="defaultValue"></param>
+ public static object TryInvokeGetProperty(this IDynamicInvokable idi, string name, object defaultValue)
+ if (prop != null)
+ return defaultValue;
+ /// <summary>
+ /// Sets the value of the specified property
+ /// </summary>
+ /// <param name="value"></param>
+ /// <exception cref="MissingMemberException">thrown if the specified property could not be found</exception>
+ public static void InvokeSetProperty(this IDynamicInvokable idi, string name, object value)
+ if (prop != null)
+ prop.SetValue(idi, value, null);
+ /// <summary>
+ /// Attempts to set the value of the specified property. Does nothing if the named property
+ /// could not be found
+ /// </summary>
+ public static void TryInvokeSetProperty(this IDynamicInvokable idi, string name, object value)
+ if (prop != null)
+ /// <summary>
+ /// Invokes a method of the specified name with the specified arguments. If the method returns
+ /// a value, it is discarded. If you require the return value, use <see cref="InvokeMethodWithReturnValue"/>
+ /// instead
+ /// </summary>
+ /// <param name="args"></param>
+ public static void InvokeMethod(this IDynamicInvokable idi, string name, params object[] args)
+ var method = idi.GetType().GetMethod(name);
+ if (method != null)
+ method.Invoke(idi, args);
+ throw new MissingMethodException(name);
+ /// <summary>
+ /// </summary>
+ public static object InvokeMethodWithReturnValue(this IDynamicInvokable idi, string name, params object[] args)
+ return method.Invoke(idi, args);
Modified: sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs
--- sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs 2010-10-06 04:54:26 UTC (rev 5248)
+++ sandbox/maestro-3.0/OSGeo.MapGuide.MaestroAPI/Resource/IResource.cs 2010-10-06 06:08:52 UTC (rev 5249)
@@ -24,10 +24,11 @@
using System.IO;
using OSGeo.MapGuide.ObjectModels.Common;
+using OSGeo.MapGuide.MaestroAPI.ObjectModels;
namespace OSGeo.MapGuide.MaestroAPI.Resource
- public interface IResource : IVersionedEntity, ICloneable, INotifyPropertyChanged
+ public interface IResource : IVersionedEntity, ICloneable, INotifyPropertyChanged, IDynamicInvokable
IServerConnection CurrentConnection { get; set; }
More information about the mapguide-commits
