[mapguide-commits] r5315 - in sandbox/maestro-3.0/Maestro.Base:
Properties UI
svn_mapguide at osgeo.org
Thu Oct 21 07:13:17 EDT 2010
Author: jng
Date: 2010-10-21 04:13:17 -0700 (Thu, 21 Oct 2010)
New Revision: 5315
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
Fix #1483: Change "New Item" to "New Resource" to match the New Resource Dialog. Fix New Resource Dialog to invalidate the current template selection when changing categories
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-21 10:10:48 UTC (rev 5314)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.Designer.cs 2010-10-21 11:13:17 UTC (rev 5315)
@@ -720,7 +720,7 @@
/// <summary>
- /// Looks up a localized string similar to New Item.
+ /// Looks up a localized string similar to New Resource.
/// </summary>
internal static string Menu_File_NewResource {
get {
Modified: sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx
--- sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-21 10:10:48 UTC (rev 5314)
+++ sandbox/maestro-3.0/Maestro.Base/Properties/Resources.resx 2010-10-21 11:13:17 UTC (rev 5315)
@@ -242,7 +242,7 @@
<value>..\Resources\navigation-180.png;System.Drawing.Bitmap, System.Drawing, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a</value>
</data>
<data name="Menu_File_NewResource" xml:space="preserve">
- <value>New Item</value>
+ <value>New Resource</value>
</data>
<data name="Browser_Complete" xml:space="preserve">
<value>Done</value>
Modified: sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-10-21 10:10:48 UTC (rev 5314)
+++ sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-10-21 11:13:17 UTC (rev 5315)
@@ -68,6 +68,9 @@
string cat = lstCategories.SelectedItem.ToString();
LoadTemplates(_nits.GetItemTemplates(cat, _siteVersion));
+ txtDescription.Text = string.Empty;
+ btnOK.Enabled = false;
More information about the mapguide-commits
