[mapguide-commits] r5316 - sandbox/maestro-3.0/Maestro.Base/UI
svn_mapguide at osgeo.org
Thu Oct 21 07:29:14 EDT 2010
Author: jng
Date: 2010-10-21 04:29:14 -0700 (Thu, 21 Oct 2010)
New Revision: 5316
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs
sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
Fix #1484: When user double clicks a template in the New Resource Dialog, make it the selected template to create a new item from.
Modified: sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs 2010-10-21 11:13:17 UTC (rev 5315)
+++ sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.Designer.cs 2010-10-21 11:29:14 UTC (rev 5316)
@@ -49,6 +49,7 @@
this.lstTemplates.TabIndex = 0;
this.lstTemplates.UseCompatibleStateImageBehavior = false;
this.lstTemplates.View = System.Windows.Forms.View.Tile;
+ this.lstTemplates.MouseDoubleClick += new System.Windows.Forms.MouseEventHandler(this.lstTemplates_MouseDoubleClick);
this.lstTemplates.SelectedIndexChanged += new System.EventHandler(this.lstTemplates_SelectedIndexChanged);
// lstCategories
Modified: sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs
--- sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-10-21 11:13:17 UTC (rev 5315)
+++ sandbox/maestro-3.0/Maestro.Base/UI/NewResourceDialog.cs 2010-10-21 11:29:14 UTC (rev 5316)
@@ -153,5 +153,17 @@
return null;
+ private void lstTemplates_MouseDoubleClick(object sender, MouseEventArgs e)
+ var item = lstTemplates.GetItemAt(e.X, e.Y);
+ if (item != null)
+ lstTemplates.SelectedItems.Clear();
+ item.Selected = true;
+ this.DialogResult = DialogResult.OK;
More information about the mapguide-commits
