[mapguide-commits] r5524 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org
Fri Feb 4 21:54:18 EST 2011
Author: waltweltonlair
Date: 2011-02-04 18:54:18 -0800 (Fri, 04 Feb 2011)
New Revision: 5524
trunk/MgDev/Common/Stylization/LineBuffer.cpp
This submission is a follow-up to changeset r5436.
The same fix for dimensionality made for non-curve geometry types needs to be also made for curve types.
Modified: trunk/MgDev/Common/Stylization/LineBuffer.cpp
--- trunk/MgDev/Common/Stylization/LineBuffer.cpp 2011-02-05 00:33:43 UTC (rev 5523)
+++ trunk/MgDev/Common/Stylization/LineBuffer.cpp 2011-02-05 02:54:18 UTC (rev 5524)
@@ -1070,9 +1070,9 @@
FdoDimensionality dim = (FdoDimensionality)*ireader++;
// ensure that all dimensionalities of each geometry are the same
- _ASSERT(q==0 || m_dimensionality == dim);
+ _ASSERT(q==0 || m_dimensionality == (dim & ~FdoDimensionality_M));
- m_dimensionality = dim;
+ m_dimensionality = dim & ~FdoDimensionality_M; //LineBuffer doesn't support M
m_bProcessZ = (m_dimensionality & FdoDimensionality_Z) && !m_bIgnoreZ;
skip = 0;
More information about the mapguide-commits
