[mapguide-commits] r5525 - trunk/MgDev/Common/Stylization
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Sat Feb 5 04:33:08 EST 2011
Author: waltweltonlair
Date: 2011-02-05 01:33:07 -0800 (Sat, 05 Feb 2011)
New Revision: 5525
   trunk/MgDev/Common/Stylization/SE_LineRenderer.cpp
   trunk/MgDev/Common/Stylization/SE_Renderer.cpp
Small label rendering fix - if a symbol doesn't contain any primitives then update the
last symbol extent assuming zero symbold extent.
Modified: trunk/MgDev/Common/Stylization/SE_LineRenderer.cpp
--- trunk/MgDev/Common/Stylization/SE_LineRenderer.cpp	2011-02-05 02:54:18 UTC (rev 5524)
+++ trunk/MgDev/Common/Stylization/SE_LineRenderer.cpp	2011-02-05 09:33:07 UTC (rev 5525)
@@ -260,7 +260,7 @@
         int maxChoppedSize = 0;
         choppedBuffers = (LineBuffer**)alloca(prims.size() * sizeof(LineBuffer*));
         memset(choppedBuffers, 0, prims.size() * sizeof(LineBuffer*));
-        for (unsigned cur_prim=0; cur_prim<prims.size(); ++cur_prim)
+        for (unsigned int cur_prim=0; cur_prim<prims.size(); ++cur_prim)
             SE_RenderPrimitive* primitive = prims[cur_prim];
@@ -451,7 +451,7 @@
                     double last_angleRad = 0.0;
                     // loop over the symbol's primitive elements - we will handle them one by one
@@ -989,7 +989,7 @@
     // free the chopped line buffers
     if (choppedBuffers)
             if (choppedBuffers[cur_prim] != NULL)
                 LineBufferPool::FreeLineBuffer(lbp, choppedBuffers[cur_prim]);
Modified: trunk/MgDev/Common/Stylization/SE_Renderer.cpp
--- trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2011-02-05 02:54:18 UTC (rev 5524)
+++ trunk/MgDev/Common/Stylization/SE_Renderer.cpp	2011-02-05 09:33:07 UTC (rev 5525)
@@ -407,8 +407,9 @@
                              bool excludeRegion)
     RS_Bounds extents(DBL_MAX, DBL_MAX, DBL_MAX, -DBL_MAX, -DBL_MAX, -DBL_MAX);
+    unsigned int nprims = symbol.size();
-    for (unsigned i=0; i<symbol.size(); ++i)
+    for (unsigned int i=0; i<nprims; ++i)
         SE_RenderPrimitive* primitive = symbol[i];
@@ -490,14 +491,25 @@
-    // always compute the last symbol extent
-    xform.transform(extents.minx, extents.miny, m_lastSymbolExtent[0].x, m_lastSymbolExtent[0].y);
-    xform.transform(extents.maxx, extents.miny, m_lastSymbolExtent[1].x, m_lastSymbolExtent[1].y);
-    xform.transform(extents.maxx, extents.maxy, m_lastSymbolExtent[2].x, m_lastSymbolExtent[2].y);
-    xform.transform(extents.minx, extents.maxy, m_lastSymbolExtent[3].x, m_lastSymbolExtent[3].y);
+    if (nprims > 0)
+        // always compute the last symbol extent
+        xform.transform(extents.minx, extents.miny, m_lastSymbolExtent[0].x, m_lastSymbolExtent[0].y);
+        xform.transform(extents.maxx, extents.miny, m_lastSymbolExtent[1].x, m_lastSymbolExtent[1].y);
+        xform.transform(extents.maxx, extents.maxy, m_lastSymbolExtent[2].x, m_lastSymbolExtent[2].y);
+        xform.transform(extents.minx, extents.maxy, m_lastSymbolExtent[3].x, m_lastSymbolExtent[3].y);
-    if (excludeRegion)
-        AddExclusionRegion(m_lastSymbolExtent, 4);
+        if (excludeRegion)
+            AddExclusionRegion(m_lastSymbolExtent, 4);
+    else
+        // symbol contains no primitives - update last symbol extent assuming
+        // zero symbol extent, but don't add any exclusion region
+        xform.transform(0.0, 0.0, m_lastSymbolExtent[0].x, m_lastSymbolExtent[0].y);
+        m_lastSymbolExtent[1].x = m_lastSymbolExtent[2].x = m_lastSymbolExtent[3].x = m_lastSymbolExtent[0].x;
+        m_lastSymbolExtent[1].y = m_lastSymbolExtent[2].y = m_lastSymbolExtent[3].y = m_lastSymbolExtent[0].y;
More information about the mapguide-commits mailing list
