[mapguide-commits] r5647 - trunk/Tools/Maestro/Maestro.Editors/MapDefinition
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 21 07:58:26 EDT 2011
Author: jng
Date: 2011-03-21 04:58:26 -0700 (Mon, 21 Mar 2011)
New Revision: 5647
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
   trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs
#1631: Fix Drag/drop of an existing layer reference or group into a group ("Layers by Group" tab) does nothing.
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 11:43:48 UTC (rev 5646)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapLayersSectionCtrl.cs	2011-03-21 11:58:26 UTC (rev 5647)
@@ -680,39 +680,101 @@
         private void trvLayersGroup_DragDrop(object sender, DragEventArgs e)
             var rids = e.Data.GetData(typeof(ResourceIdentifier[])) as ResourceIdentifier[];
-            if (rids == null || rids.Length == 0)
-                return;
+            var nodes = e.Data.GetData(typeof(TreeNodeAdv[])) as TreeNodeAdv[];
+            if (rids != null && rids.Length > 0)
+                IMapLayerGroup parent = null;
+                var node = trvLayersGroup.GetNodeAt(trvLayersGroup.PointToClient(new Point(e.X, e.Y)));
+                if (node != null)
+                    var gi = node.Tag as GroupItem;
+                    if (gi != null)
+                        parent = gi.Tag;
-            IMapLayerGroup parent = null;
-            var node = trvLayersGroup.GetNodeAt(trvLayersGroup.PointToClient(new Point(e.X, e.Y)));
-            if (node != null)
-                var gi = node.Tag as GroupItem;
-                if (gi != null)
-                    parent = gi.Tag;
+                int added = 0;
+                foreach (var rid in rids)
+                    if (rid.ResourceType == ResourceTypes.LayerDefinition)
+                        var name = GenerateLayerName(rid.ToString(), _map);
+                        var layer = _map.AddLayer(parent == null ? null : parent.Name, name, rid.ToString());
+                        added++;
+                if (added > 0)
+                    //TODO: Fine-grain invalidation
+                    RefreshModels();
-            int added = 0;
-            foreach (var rid in rids)
+            else if (nodes != null && nodes.Length > 0)
-                if (rid.ResourceType == ResourceTypes.LayerDefinition)
-                    var name = GenerateLayerName(rid.ToString(), _map);
-                    var layer = _map.AddLayer(parent == null ? null : parent.Name, name, rid.ToString());
-                    added++;
+                if (node != null)
+                    var li = node.Tag as LayerItem;
+                    if (gi != null)
+                        parent = gi.Tag;
+                    else if (li != null)
+                        parent = _map.GetGroupByName(li.Tag.Group);
-            if (added > 0)
-                //TODO: Fine-grain invalidation
-                RefreshModels();
+                if (parent != null)
+                    int moved = 0;
+                    //Add to this group
+                    foreach (var n in nodes)
+                        var gi = n.Tag as GroupItem;
+                        var li = n.Tag as LayerItem;
+                        //Re-assign parent
+                        if (gi != null)
+                            gi.Tag.Group = parent.Name;
+                            moved++;
+                            li.Tag.Group = parent.Name;
+                            moved++;
+                    if (moved > 0)
+                        RefreshModels();
         private void trvLayersGroup_DragOver(object sender, DragEventArgs e)
-            HandleDragOver(e);
+            var data = e.Data.GetData(typeof(TreeNodeAdv[])) as TreeNodeAdv[];
+            if (data == null)
+                HandleDragOver(e);
+            else
+                var li = data[0].Tag as LayerItem;
+                var gi = data[0].Tag as GroupItem;
+                if (li == null && gi == null)
+                    e.Effect = DragDropEffects.None;
+                    return;
+                else
+                    e.Effect = DragDropEffects.Move;
         private static void HandleDragOver(DragEventArgs e)
@@ -887,7 +949,24 @@
         private void trvBaseLayers_DragOver(object sender, DragEventArgs e)
+            if (data == null)
+            else
+                var li = data[0].Tag as BaseLayerItem;
+                if (li == null)
+                    return;
+                else
Modified: trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs
--- trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs	2011-03-21 11:43:48 UTC (rev 5646)
+++ trunk/Tools/Maestro/Maestro.Editors/MapDefinition/MapTreeModels.cs	2011-03-21 11:58:26 UTC (rev 5647)
@@ -217,7 +217,8 @@
                 foreach (var group in _map.MapLayerGroup)
-                    yield return new GroupItem(group);
+                    if (string.IsNullOrEmpty(group.Group))
+                        yield return new GroupItem(group);
                 foreach (var layer in _map.GetLayersWithoutGroups())
More information about the mapguide-commits mailing list
