[mapguide-commits] r5665 - in trunk/Tools/Maestro/Maestro.Base: . Commands Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Mon Mar 28 09:40:36 EDT 2011
Author: jng
Date: 2011-03-28 06:40:36 -0700 (Mon, 28 Mar 2011)
New Revision: 5665
Added:
   trunk/Tools/Maestro/Maestro.Base/Commands/SiteAdministratorCommand.cs
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
   trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
Add missing Site Administrator command that was in the previous version but not this one
Added: trunk/Tools/Maestro/Maestro.Base/Commands/SiteAdministratorCommand.cs
--- trunk/Tools/Maestro/Maestro.Base/Commands/SiteAdministratorCommand.cs	                        (rev 0)
+++ trunk/Tools/Maestro/Maestro.Base/Commands/SiteAdministratorCommand.cs	2011-03-28 13:40:36 UTC (rev 5665)
@@ -0,0 +1,47 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.Text;
+using ICSharpCode.Core;
+using Maestro.Base.Services;
+using System.Diagnostics;
+namespace Maestro.Base.Commands
+    internal class SiteAdministratorCommand : AbstractMenuCommand
+        public override void Run()
+            var wb = Workbench.Instance;
+            var mgr = ServiceRegistry.GetService<ServerConnectionManager>();
+            var conn = mgr.GetConnection(wb.ActiveSiteExplorer.ConnectionName);
+            if (conn.ProviderName.ToUpper() == "MAESTRO.HTTP")
+                string baseUrl = conn.GetCustomProperty("BaseUrl").ToString();
+                if (!baseUrl.EndsWith("/"))
+                    baseUrl += "/";
+                Process.Start(baseUrl + "mapadmin/login.php");
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin	2011-03-28 12:23:13 UTC (rev 5664)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.addin	2011-03-28 13:40:36 UTC (rev 5665)
@@ -183,6 +183,9 @@
         <MenuItem id="Menu_Tools"
                   type="Menu"
                   label="${res:Menu_Tools}">
+            <MenuItem id="SiteAdmin"
+                      label="${res:SiteAdministrator}"
+                      class="Maestro.Base.Commands.SiteAdministratorCommand"/>
             <MenuItem id="MgCooker"
                       label="${res:MgCooker}"
                       class="Maestro.Base.Commands.MgCookerCommand"/>
Modified: trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj
--- trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-03-28 12:23:13 UTC (rev 5664)
+++ trunk/Tools/Maestro/Maestro.Base/Maestro.Base.csproj	2011-03-28 13:40:36 UTC (rev 5665)
@@ -101,6 +101,7 @@
     <Compile Include="Commands\SaveResourceAsCommand.cs" />
     <Compile Include="Commands\SaveResourceCommand.cs" />
     <Compile Include="Commands\ServerMonitorCommand.cs" />
+    <Compile Include="Commands\SiteAdministratorCommand.cs" />
     <Compile Include="Commands\SiteExplorer\DeleteSelectedItemsCommand.cs" />
     <Compile Include="Commands\SiteExplorer\DisconnectCommand.cs" />
     <Compile Include="Commands\SiteExplorer\CopyMoveToAnotherServerCommand.cs" />
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-03-28 12:23:13 UTC (rev 5664)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.Designer.cs	2011-03-28 13:40:36 UTC (rev 5665)
@@ -1553,6 +1553,15 @@
         /// <summary>
+        ///   Looks up a localized string similar to Site Administrator.
+        /// </summary>
+        internal static string SiteAdministrator {
+            get {
+                return ResourceManager.GetString("SiteAdministrator", resourceCulture);
+        /// <summary>
         ///   Looks up a localized string similar to Copy/Move selected items to another server.
         /// </summary>
         internal static string SiteExplorer_CopyMoveToServer {
Modified: trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx
--- trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-03-28 12:23:13 UTC (rev 5664)
+++ trunk/Tools/Maestro/Maestro.Base/Properties/Resources.resx	2011-03-28 13:40:36 UTC (rev 5665)
@@ -877,4 +877,7 @@
   <data name="NoFiniteDisplayScalesSpecified" xml:space="preserve">
     <value>This Map Definition has tiled layers but has no finite display scales defined. Define some display scales.</value>
   </data>
+  <data name="SiteAdministrator" xml:space="preserve">
+    <value>Site Administrator</value>
+  </data>
 </root>
\ No newline at end of file
More information about the mapguide-commits mailing list
