[mapguide-commits] r5759 - in trunk/Tools/Maestro/SDK/Samples: . SchemaViewer SchemaViewer/Properties
svn_mapguide at osgeo.org svn_mapguide at osgeo.org
Thu May 5 09:20:41 EDT 2011
Author: jng
Date: 2011-05-05 06:20:41 -0700 (Thu, 05 May 2011)
New Revision: 5759
Added:
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.resx
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Program.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/AssemblyInfo.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.resx
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.settings
   trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
   trunk/Tools/Maestro/SDK/Samples/Samples.sln
#1676: Add a SchemaViewer example project.
Modified: trunk/Tools/Maestro/SDK/Samples/Samples.sln
--- trunk/Tools/Maestro/SDK/Samples/Samples.sln	2011-05-05 10:40:21 UTC (rev 5758)
+++ trunk/Tools/Maestro/SDK/Samples/Samples.sln	2011-05-05 13:20:41 UTC (rev 5759)
@@ -5,6 +5,8 @@
 EndProject
 Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "QueryFeatureSource", "QueryFeatureSource\QueryFeatureSource.csproj", "{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}"
 EndProject
+Project("{FAE04EC0-301F-11D3-BF4B-00C04F79EFBC}") = "SchemaViewer", "SchemaViewer\SchemaViewer.csproj", "{6105DB0C-65F5-47DF-B3AE-36A430EC16E0}"
+EndProject
 Global
 	GlobalSection(SolutionConfigurationPlatforms) = preSolution
 		Debug|Any CPU = Debug|Any CPU
@@ -19,6 +21,10 @@
 		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Debug|Any CPU.Build.0 = Debug|Any CPU
 		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Release|Any CPU.ActiveCfg = Release|Any CPU
 		{7C572B2A-5E77-4AB4-B8AD-1172D3E725EC}.Release|Any CPU.Build.0 = Release|Any CPU
+		{6105DB0C-65F5-47DF-B3AE-36A430EC16E0}.Debug|Any CPU.ActiveCfg = Debug|Any CPU
+		{6105DB0C-65F5-47DF-B3AE-36A430EC16E0}.Debug|Any CPU.Build.0 = Debug|Any CPU
+		{6105DB0C-65F5-47DF-B3AE-36A430EC16E0}.Release|Any CPU.ActiveCfg = Release|Any CPU
+		{6105DB0C-65F5-47DF-B3AE-36A430EC16E0}.Release|Any CPU.Build.0 = Release|Any CPU
 	EndGlobalSection
 	GlobalSection(SolutionProperties) = preSolution
 		HideSolutionNode = FALSE
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.Designer.cs	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,121 @@
+namespace SchemaViewer
+    partial class Form1
+        /// <summary>
+        /// Required designer variable.
+        /// </summary>
+        private System.ComponentModel.IContainer components = null;
+        /// <summary>
+        /// Clean up any resources being used.
+        /// </summary>
+        /// <param name="disposing">true if managed resources should be disposed; otherwise, false.</param>
+        protected override void Dispose(bool disposing)
+            if (disposing && (components != null))
+                components.Dispose();
+            base.Dispose(disposing);
+        #region Windows Form Designer generated code
+        /// <summary>
+        /// Required method for Designer support - do not modify
+        /// the contents of this method with the code editor.
+        /// </summary>
+        private void InitializeComponent()
+            this.groupBox1 = new System.Windows.Forms.GroupBox();
+            this.label1 = new System.Windows.Forms.Label();
+            this.txtFeatureSource = new System.Windows.Forms.TextBox();
+            this.btnBrowse = new System.Windows.Forms.Button();
+            this.treeView1 = new System.Windows.Forms.TreeView();
+            this.propertyGrid1 = new System.Windows.Forms.PropertyGrid();
+            this.groupBox1.SuspendLayout();
+            this.SuspendLayout();
+            // groupBox1
+            this.groupBox1.Controls.Add(this.btnBrowse);
+            this.groupBox1.Controls.Add(this.txtFeatureSource);
+            this.groupBox1.Controls.Add(this.label1);
+            this.groupBox1.Location = new System.Drawing.Point(12, 12);
+            this.groupBox1.Name = "groupBox1";
+            this.groupBox1.Size = new System.Drawing.Size(643, 81);
+            this.groupBox1.TabIndex = 0;
+            this.groupBox1.TabStop = false;
+            this.groupBox1.Text = "Feature Source";
+            // label1
+            this.label1.AutoSize = true;
+            this.label1.Location = new System.Drawing.Point(22, 34);
+            this.label1.Name = "label1";
+            this.label1.Size = new System.Drawing.Size(67, 13);
+            this.label1.TabIndex = 0;
+            this.label1.Text = "Resource ID";
+            // txtFeatureSource
+            this.txtFeatureSource.Location = new System.Drawing.Point(114, 31);
+            this.txtFeatureSource.Name = "txtFeatureSource";
+            this.txtFeatureSource.ReadOnly = true;
+            this.txtFeatureSource.Size = new System.Drawing.Size(413, 20);
+            this.txtFeatureSource.TabIndex = 1;
+            // btnBrowse
+            this.btnBrowse.Location = new System.Drawing.Point(546, 29);
+            this.btnBrowse.Name = "btnBrowse";
+            this.btnBrowse.Size = new System.Drawing.Size(75, 23);
+            this.btnBrowse.TabIndex = 2;
+            this.btnBrowse.Text = "Browse";
+            this.btnBrowse.UseVisualStyleBackColor = true;
+            this.btnBrowse.Click += new System.EventHandler(this.btnBrowse_Click);
+            // treeView1
+            this.treeView1.Location = new System.Drawing.Point(13, 100);
+            this.treeView1.Name = "treeView1";
+            this.treeView1.Size = new System.Drawing.Size(316, 361);
+            this.treeView1.TabIndex = 1;
+            this.treeView1.AfterSelect += new System.Windows.Forms.TreeViewEventHandler(this.treeView1_AfterSelect);
+            // propertyGrid1
+            this.propertyGrid1.HelpVisible = false;
+            this.propertyGrid1.Location = new System.Drawing.Point(336, 100);
+            this.propertyGrid1.Name = "propertyGrid1";
+            this.propertyGrid1.Size = new System.Drawing.Size(324, 361);
+            this.propertyGrid1.TabIndex = 2;
+            // Form1
+            this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
+            this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
+            this.ClientSize = new System.Drawing.Size(672, 473);
+            this.Controls.Add(this.propertyGrid1);
+            this.Controls.Add(this.treeView1);
+            this.Controls.Add(this.groupBox1);
+            this.Name = "Form1";
+            this.Text = "SchemaViewer Sample";
+            this.groupBox1.ResumeLayout(false);
+            this.groupBox1.PerformLayout();
+            this.ResumeLayout(false);
+        #endregion
+        private System.Windows.Forms.GroupBox groupBox1;
+        private System.Windows.Forms.Button btnBrowse;
+        private System.Windows.Forms.TextBox txtFeatureSource;
+        private System.Windows.Forms.Label label1;
+        private System.Windows.Forms.TreeView treeView1;
+        private System.Windows.Forms.PropertyGrid propertyGrid1;
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.cs	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,131 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
+#endregion
+using System;
+using System.Collections.Generic;
+using System.ComponentModel;
+using System.Data;
+using System.Drawing;
+using System.Text;
+using System.Windows.Forms;
+using Maestro.Editors.Generic;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Schema;
+    public partial class Form1 : Form
+        public Form1()
+            InitializeComponent();
+        private IServerConnection _conn;
+        protected override void OnLoad(EventArgs e)
+            //Anytime we work with the Maestro API, we require an IServerConnection
+            //reference. The Maestro.Login.LoginDialog provides a UI to obtain such a
+            //reference.
+            //If you need to obtain an IServerConnection reference programmatically and
+            //without user intervention, use the ConnectionProviderRegistry class
+            var login = new Maestro.Login.LoginDialog();
+            if (login.ShowDialog() == DialogResult.OK)
+                _conn = login.Connection;
+            else //This sample does not work without an IServerConnection
+                Application.Exit();
+        private void btnBrowse_Click(object sender, EventArgs e)
+            //The ResourcePicker class, functions like a file dialog allowing the user
+            //to easily select a given resource. In our case, we want the user to select
+            //a Map Definition
+            using (var picker = new ResourcePicker(_conn.ResourceService,
+                                                   ResourceTypes.FeatureSource,
+                                                   ResourcePickerMode.OpenResource))
+                if (picker.ShowDialog() == DialogResult.OK)
+                    LoadFeatureSource(picker.ResourceID);
+        private void LoadFeatureSource(string featureSourceId)
+            var desc = _conn.FeatureService.DescribeFeatureSource(featureSourceId);
+            treeView1.Nodes.Clear();
+            foreach (FeatureSchema schema in desc.Schemas)
+                var node = CreateSchemaNode(schema);
+                treeView1.Nodes.Add(node);
+        private TreeNode CreateSchemaNode(FeatureSchema schema)
+            var node = new TreeNode();
+            node.Name = schema.Name;
+            node.Text = schema.Name;
+            foreach (ClassDefinition cls in schema.Classes)
+                var clsNode = CreateClassNode(cls);
+                node.Nodes.Add(clsNode);
+            node.Tag = schema;
+            return node;
+        private TreeNode CreateClassNode(ClassDefinition cls)
+            node.Name = cls.Name;
+            node.Text = cls.Name;
+            foreach (PropertyDefinition prop in cls.Properties)
+                var pNode = new TreeNode();
+                pNode.Name = prop.Name;
+                pNode.Text = prop.Name;
+                pNode.Tag = prop;
+                node.Nodes.Add(pNode);
+            node.Tag = cls;
+            return node;
+        private void treeView1_AfterSelect(object sender, TreeViewEventArgs e)
+            propertyGrid1.SelectedObject = e.Node.Tag;
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.resx
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.resx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Form1.resx	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,120 @@
+<?xml version="1.0" encoding="utf-8"?>
+<root>
+    Microsoft ResX Schema
+    Version 2.0
+    The primary goals of this format is to allow a simple XML format
+    that is mostly human readable. The generation and parsing of the
+    various data types are done through the TypeConverter classes
+    associated with the data types.
+    Example:
+    ... ado.net/XML headers & schema ...
+    <resheader name="resmimetype">text/microsoft-resx</resheader>
+    <resheader name="version">2.0</resheader>
+    <resheader name="reader">System.Resources.ResXResourceReader, System.Windows.Forms, ...</resheader>
+    <resheader name="writer">System.Resources.ResXResourceWriter, System.Windows.Forms, ...</resheader>
+    <data name="Name1"><value>this is my long string</value><comment>this is a comment</comment></data>
+    <data name="Color1" type="System.Drawing.Color, System.Drawing">Blue</data>
+    <data name="Bitmap1" mimetype="application/x-microsoft.net.object.binary.base64">
+        <value>[base64 mime encoded serialized .NET Framework object]</value>
+    </data>
+    <data name="Icon1" type="System.Drawing.Icon, System.Drawing" mimetype="application/x-microsoft.net.object.bytearray.base64">
+        <value>[base64 mime encoded string representing a byte array form of the .NET Framework object]</value>
+        <comment>This is a comment</comment>
+    </data>
+    There are any number of "resheader" rows that contain simple
+    name/value pairs.
+    Each data row contains a name, and value. The row also contains a
+    type or mimetype. Type corresponds to a .NET class that support
+    text/value conversion through the TypeConverter architecture.
+    Classes that don't support this are serialized and stored with the
+    mimetype set.
+    The mimetype is used for serialized objects, and tells the
+    ResXResourceReader how to depersist the object. This is currently not
+    extensible. For a given mimetype the value must be set accordingly:
+    Note - application/x-microsoft.net.object.binary.base64 is the format
+    that the ResXResourceWriter will generate, however the reader can
+    read any of the formats listed below.
+    mimetype: application/x-microsoft.net.object.binary.base64
+    value   : The object must be serialized with
+            : System.Runtime.Serialization.Formatters.Binary.BinaryFormatter
+            : and then encoded with base64 encoding.
+    mimetype: application/x-microsoft.net.object.soap.base64
+            : System.Runtime.Serialization.Formatters.Soap.SoapFormatter
+    mimetype: application/x-microsoft.net.object.bytearray.base64
+    value   : The object must be serialized into a byte array
+            : using a System.ComponentModel.TypeConverter
+  <xsd:schema id="root" xmlns="" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
+    <xsd:import namespace="http://www.w3.org/XML/1998/namespace" />
+    <xsd:element name="root" msdata:IsDataSet="true">
+      <xsd:complexType>
+        <xsd:choice maxOccurs="unbounded">
+          <xsd:element name="metadata">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" />
+              </xsd:sequence>
+              <xsd:attribute name="name" use="required" type="xsd:string" />
+              <xsd:attribute name="type" type="xsd:string" />
+              <xsd:attribute name="mimetype" type="xsd:string" />
+              <xsd:attribute ref="xml:space" />
+            </xsd:complexType>
+          </xsd:element>
+          <xsd:element name="assembly">
+            <xsd:complexType>
+              <xsd:attribute name="alias" type="xsd:string" />
+              <xsd:attribute name="name" type="xsd:string" />
+          </xsd:element>
+          <xsd:element name="data">
+            <xsd:complexType>
+              <xsd:sequence>
+                <xsd:element name="value" type="xsd:string" minOccurs="0" msdata:Ordinal="1" />
+                <xsd:element name="comment" type="xsd:string" minOccurs="0" msdata:Ordinal="2" />
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" msdata:Ordinal="1" />
+              <xsd:attribute name="type" type="xsd:string" msdata:Ordinal="3" />
+              <xsd:attribute name="mimetype" type="xsd:string" msdata:Ordinal="4" />
+          </xsd:element>
+          <xsd:element name="resheader">
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" use="required" />
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+    <value>text/microsoft-resx</value>
+  </resheader>
+    <value>2.0</value>
+  </resheader>
+    <value>System.Resources.ResXResourceReader, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+    <value>System.Resources.ResXResourceWriter, System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089</value>
+  </resheader>
+</root>
\ No newline at end of file
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Program.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Program.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Program.cs	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,39 @@
+#endregion
+using System;
+    static class Program
+        /// <summary>
+        /// The main entry point for the application.
+        /// </summary>
+        [STAThread]
+        static void Main()
+            Application.EnableVisualStyles();
+            Application.SetCompatibleTextRenderingDefault(false);
+            Application.Run(new Form1());
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/AssemblyInfo.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/AssemblyInfo.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/AssemblyInfo.cs	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,36 @@
+using System.Reflection;
+using System.Runtime.CompilerServices;
+using System.Runtime.InteropServices;
+// General Information about an assembly is controlled through the following
+// set of attributes. Change these attribute values to modify the information
+// associated with an assembly.
+[assembly: AssemblyTitle("SchemaViewer")]
+[assembly: AssemblyDescription("")]
+[assembly: AssemblyConfiguration("")]
+[assembly: AssemblyCompany("")]
+[assembly: AssemblyProduct("SchemaViewer")]
+[assembly: AssemblyCopyright("Copyright ©  2011")]
+[assembly: AssemblyTrademark("")]
+[assembly: AssemblyCulture("")]
+// Setting ComVisible to false makes the types in this assembly not visible
+// to COM components.  If you need to access a type in this assembly from
+// COM, set the ComVisible attribute to true on that type.
+[assembly: ComVisible(false)]
+// The following GUID is for the ID of the typelib if this project is exposed to COM
+[assembly: Guid("7e625e94-570e-48ae-b40e-c2c455e1ea31")]
+// Version information for an assembly consists of the following four values:
+//      Major Version
+//      Minor Version
+//      Build Number
+//      Revision
+// You can specify all the values or you can default the Build and Revision Numbers
+// by using the '*' as shown below:
+// [assembly: AssemblyVersion("1.0.*")]
+[assembly: AssemblyVersion("1.0.0.0")]
+[assembly: AssemblyFileVersion("1.0.0.0")]
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.Designer.cs	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,71 @@
+// <auto-generated>
+//     This code was generated by a tool.
+//     Runtime Version:2.0.50727.4952
+//     Changes to this file may cause incorrect behavior and will be lost if
+//     the code is regenerated.
+// </auto-generated>
+namespace SchemaViewer.Properties
+    /// <summary>
+    ///   A strongly-typed resource class, for looking up localized strings, etc.
+    /// </summary>
+    // This class was auto-generated by the StronglyTypedResourceBuilder
+    // class via a tool like ResGen or Visual Studio.
+    // To add or remove a member, edit your .ResX file then rerun ResGen
+    // with the /str option, or rebuild your VS project.
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("System.Resources.Tools.StronglyTypedResourceBuilder", "2.0.0.0")]
+    [global::System.Diagnostics.DebuggerNonUserCodeAttribute()]
+    [global::System.Runtime.CompilerServices.CompilerGeneratedAttribute()]
+    internal class Resources
+        private static global::System.Resources.ResourceManager resourceMan;
+        private static global::System.Globalization.CultureInfo resourceCulture;
+        [global::System.Diagnostics.CodeAnalysis.SuppressMessageAttribute("Microsoft.Performance", "CA1811:AvoidUncalledPrivateCode")]
+        internal Resources()
+        /// <summary>
+        ///   Returns the cached ResourceManager instance used by this class.
+        /// </summary>
+        [global::System.ComponentModel.EditorBrowsableAttribute(global::System.ComponentModel.EditorBrowsableState.Advanced)]
+        internal static global::System.Resources.ResourceManager ResourceManager
+            get
+                if ((resourceMan == null))
+                    global::System.Resources.ResourceManager temp = new global::System.Resources.ResourceManager("SchemaViewer.Properties.Resources", typeof(Resources).Assembly);
+                    resourceMan = temp;
+                return resourceMan;
+        /// <summary>
+        ///   Overrides the current thread's CurrentUICulture property for all
+        ///   resource lookups using this strongly typed resource class.
+        /// </summary>
+        internal static global::System.Globalization.CultureInfo Culture
+            get
+                return resourceCulture;
+            set
+                resourceCulture = value;
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.resx
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.resx	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Resources.resx	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,117 @@
+<root>
+    Version 2.0
+    Example:
+    </data>
+    </data>
+    name/value pairs.
+    mimetype set.
+            : System.Serialization.Formatters.Binary.BinaryFormatter
+      <xsd:complexType>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+            <xsd:complexType>
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+              <xsd:attribute name="name" type="xsd:string" msdata:Ordinal="1" />
+          </xsd:element>
+            <xsd:complexType>
+              <xsd:sequence>
+              </xsd:sequence>
+          </xsd:element>
+        </xsd:choice>
+    </xsd:element>
+  </xsd:schema>
+  </resheader>
+  </resheader>
+  </resheader>
+  </resheader>
+</root>
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.Designer.cs	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,30 @@
+    [global::System.CodeDom.Compiler.GeneratedCodeAttribute("Microsoft.VisualStudio.Editors.SettingsDesigner.SettingsSingleFileGenerator", "9.0.0.0")]
+    internal sealed partial class Settings : global::System.Configuration.ApplicationSettingsBase
+        private static Settings defaultInstance = ((Settings)(global::System.Configuration.ApplicationSettingsBase.Synchronized(new Settings())));
+        public static Settings Default
+            get
+                return defaultInstance;
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.settings
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.settings	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/Properties/Settings.settings	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,7 @@
+<?xml version='1.0' encoding='utf-8'?>
+<SettingsFile xmlns="http://schemas.microsoft.com/VisualStudio/2004/01/settings" CurrentProfile="(Default)">
+  <Profiles>
+    <Profile Name="(Default)" />
+  </Profiles>
+  <Settings />
+</SettingsFile>
Added: trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj
--- trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj	                        (rev 0)
+++ trunk/Tools/Maestro/SDK/Samples/SchemaViewer/SchemaViewer.csproj	2011-05-05 13:20:41 UTC (rev 5759)
@@ -0,0 +1,102 @@
+<Project ToolsVersion="3.5" DefaultTargets="Build" xmlns="http://schemas.microsoft.com/developer/msbuild/2003">
+  <PropertyGroup>
+    <Configuration Condition=" '$(Configuration)' == '' ">Debug</Configuration>
+    <Platform Condition=" '$(Platform)' == '' ">AnyCPU</Platform>
+    <ProductVersion>9.0.30729</ProductVersion>
+    <SchemaVersion>2.0</SchemaVersion>
+    <ProjectGuid>{6105DB0C-65F5-47DF-B3AE-36A430EC16E0}</ProjectGuid>
+    <OutputType>WinExe</OutputType>
+    <AppDesignerFolder>Properties</AppDesignerFolder>
+    <RootNamespace>SchemaViewer</RootNamespace>
+    <AssemblyName>SchemaViewer</AssemblyName>
+    <TargetFrameworkVersion>v2.0</TargetFrameworkVersion>
+    <FileAlignment>512</FileAlignment>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Debug|AnyCPU' ">
+    <DebugSymbols>true</DebugSymbols>
+    <DebugType>full</DebugType>
+    <Optimize>false</Optimize>
+    <OutputPath>bin\Debug\</OutputPath>
+    <DefineConstants>DEBUG;TRACE</DefineConstants>
+    <ErrorReport>prompt</ErrorReport>
+    <WarningLevel>4</WarningLevel>
+  </PropertyGroup>
+  <PropertyGroup Condition=" '$(Configuration)|$(Platform)' == 'Release|AnyCPU' ">
+    <DebugType>pdbonly</DebugType>
+    <Optimize>true</Optimize>
+    <OutputPath>bin\Release\</OutputPath>
+    <DefineConstants>TRACE</DefineConstants>
+  </PropertyGroup>
+  <ItemGroup>
+    <Reference Include="Maestro.Editors, Version=3.0.0.5728, Culture=neutral, processorArchitecture=MSIL">
+      <SpecificVersion>False</SpecificVersion>
+      <HintPath>..\..\bin\Maestro.Editors.dll</HintPath>
+    </Reference>
+    <Reference Include="Maestro.Login, Version=3.0.0.5728, Culture=neutral, processorArchitecture=MSIL">
+      <HintPath>..\..\bin\Maestro.Login.dll</HintPath>
+    </Reference>
+    <Reference Include="OSGeo.MapGuide.MaestroAPI, Version=3.0.0.5728, Culture=neutral, PublicKeyToken=f526c48929fda856, processorArchitecture=MSIL">
+      <HintPath>..\..\bin\OSGeo.MapGuide.MaestroAPI.dll</HintPath>
+    </Reference>
+    <Reference Include="System" />
+    <Reference Include="System.Data" />
+    <Reference Include="System.Deployment" />
+    <Reference Include="System.Drawing" />
+    <Reference Include="System.Windows.Forms" />
+    <Reference Include="System.Xml" />
+  </ItemGroup>
+  <ItemGroup>
+    <Compile Include="Form1.cs">
+      <SubType>Form</SubType>
+    </Compile>
+    <Compile Include="Form1.Designer.cs">
+      <DependentUpon>Form1.cs</DependentUpon>
+    </Compile>
+    <Compile Include="Program.cs" />
+    <Compile Include="Properties\AssemblyInfo.cs" />
+    <EmbeddedResource Include="Form1.resx">
+    </EmbeddedResource>
+    <EmbeddedResource Include="Properties\Resources.resx">
+      <Generator>ResXFileCodeGenerator</Generator>
+      <LastGenOutput>Resources.Designer.cs</LastGenOutput>
+      <SubType>Designer</SubType>
+    <Compile Include="Properties\Resources.Designer.cs">
+      <AutoGen>True</AutoGen>
+      <DependentUpon>Resources.resx</DependentUpon>
+    </Compile>
+    <None Include="Properties\Settings.settings">
+      <Generator>SettingsSingleFileGenerator</Generator>
+      <LastGenOutput>Settings.Designer.cs</LastGenOutput>
+    </None>
+    <Compile Include="Properties\Settings.Designer.cs">
+      <DependentUpon>Settings.settings</DependentUpon>
+      <DesignTimeSharedInput>True</DesignTimeSharedInput>
+    </Compile>
+  </ItemGroup>
+  <ItemGroup>
+    <Content Include="..\..\bin\ConnectionProviders.xml">
+      <Link>ConnectionProviders.xml</Link>
+      <CopyToOutputDirectory>Always</CopyToOutputDirectory>
+    </Content>
+    <Content Include="..\..\bin\OSGeo.MapGuide.MaestroAPI.Http.dll">
+      <Link>OSGeo.MapGuide.MaestroAPI.Http.dll</Link>
+    </Content>
+  </ItemGroup>
+  <Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
+  <!-- To modify your build process, add your task inside one of the targets below and uncomment it.
+       Other similar extension points exist, see Microsoft.Common.targets.
+  <Target Name="BeforeBuild">
+  </Target>
+  <Target Name="AfterBuild">
+  </Target>
+</Project>
More information about the mapguide-commits mailing list
