[mapguide-commits] r5760 - in trunk/Tools/Maestro/SDK/Samples: .
SchemaViewer
svn_mapguide at osgeo.org
Thu May 5 09:23:06 EDT 2011
Author: jng
Date: 2011-05-05 06:23:06 -0700 (Thu, 05 May 2011)
New Revision: 5760
trunk/Tools/Maestro/SDK/Samples/SchemaViewer/
trunk/Tools/Maestro/SDK/Samples/readme.txt
#1674: Update readme.txt
Property changes on: trunk/Tools/Maestro/SDK/Samples/SchemaViewer
___________________________________________________________________
Added: svn:ignore
+ bin
obj
Modified: trunk/Tools/Maestro/SDK/Samples/readme.txt
--- trunk/Tools/Maestro/SDK/Samples/readme.txt 2011-05-05 13:20:41 UTC (rev 5759)
+++ trunk/Tools/Maestro/SDK/Samples/readme.txt 2011-05-05 13:23:06 UTC (rev 5760)
@@ -12,4 +12,10 @@
NOTE: Due to a long-standing bug on the mapagent operation which this underlying sample relies on (http://trac.osgeo.org/mapguide/ticket/708)
this sample may not fully work for MapGuide Open Source 2.1 or older releases. This problem is only applicable if you're connecting to this
-sample via http.
\ No newline at end of file
+sample via http.
+SchemaViewer
+This sample demonstrates using the Maestro API to describe and present the schema(s) of a feature source in a WinForms TreeView. Each
+selected node can be shown in the WinForms PropertyGrid beside it.
More information about the mapguide-commits
