[mapguide-commits] r5849 - in
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb: . Tasks
svn_mapguide at osgeo.org
Tue May 24 13:42:07 EDT 2011
Author: jng
Date: 2011-05-24 10:42:07 -0700 (Tue, 24 May 2011)
New Revision: 5849
Added:
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.designer.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx
trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config
#1676: Update the web sample with an example to add a layer to the runtime map
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs 2011-05-24 16:27:00 UTC (rev 5848)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Default.aspx.cs 2011-05-24 17:42:07 UTC (rev 5849)
@@ -48,6 +48,9 @@
var mdfId = "Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition";
if (conn.ResourceService.ResourceExists(mdfId))
+ //Here's an example of pre-processing the WebLayout before loading it
+ //in the AJAX viewer.
//Create a WebLayout. By default the version created will be
//the latest supported one on the mapguide server we've connected to. For example
//connecting to MGOS 2.2 will create a version 1.1.0 WebLayout. All the known
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj 2011-05-24 16:27:00 UTC (rev 5848)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/SamplesWeb.csproj 2011-05-24 17:42:07 UTC (rev 5849)
@@ -84,6 +84,7 @@
<Content Include="Default.aspx" />
<Content Include="Global.asax" />
<Content Include="readme.txt" />
+ <Content Include="Tasks\AddTracksLayer.aspx" />
<Content Include="Tasks\ToggleParcelsLayer.aspx" />
<Content Include="Tasks\Home.aspx" />
<Content Include="Web.config" />
@@ -100,6 +101,13 @@
<DependentUpon>Global.asax</DependentUpon>
</Compile>
<Compile Include="Properties\AssemblyInfo.cs" />
+ <Compile Include="Tasks\AddTracksLayer.aspx.cs">
+ <DependentUpon>AddTracksLayer.aspx</DependentUpon>
+ <SubType>ASPXCodeBehind</SubType>
+ </Compile>
+ <Compile Include="Tasks\AddTracksLayer.aspx.designer.cs">
+ </Compile>
<Compile Include="Tasks\ToggleParcelsLayer.aspx.cs">
<DependentUpon>ToggleParcelsLayer.aspx</DependentUpon>
@@ -132,12 +140,11 @@
<VisualStudio>
<FlavorProperties GUID="{349c5851-65df-11da-9384-00065b846f21}">
<WebProjectProperties>
- <UseIIS>False</UseIIS>
+ <UseIIS>True</UseIIS>
<AutoAssignPort>True</AutoAssignPort>
<DevelopmentServerPort>49241</DevelopmentServerPort>
<DevelopmentServerVPath>/</DevelopmentServerVPath>
- <IISUrl>
- </IISUrl>
+ <IISUrl>http://localhost/mapguide/SamplesWeb/</IISUrl>
<NTLMAuthentication>False</NTLMAuthentication>
<SaveServerSettingsInUserFile>False</SaveServerSettingsInUserFile>
</WebProjectProperties>
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx 2011-05-24 17:42:07 UTC (rev 5849)
@@ -0,0 +1,21 @@
+<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="AddTracksLayer.aspx.cs" Inherits="SamplesWeb.Tasks.AddTracksLayer" %>
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" >
+<head runat="server">
+ <title>Untitled Page</title>
+</head>
+<body>
+ <form id="form1" runat="server">
+ <div>
+ <asp:Label ID="lblMessage" runat="server"></asp:Label>
+ <br />
+ <a href="javascript:history.go(-1)">Go back</a>
+ <br />
+ <div id="debug" runat="server">
+ </div>
+ </div>
+ </form>
+</body>
+</html>
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.cs 2011-05-24 17:42:07 UTC (rev 5849)
@@ -0,0 +1,170 @@
+#region Disclaimer / License
+// Copyright (C) 2011, Jackie Ng
+// http://trac.osgeo.org/mapguide/wiki/maestro, jumpinjackie at gmail.com
+// This library is free software; you can redistribute it and/or
+// modify it under the terms of the GNU Lesser General Public
+// License as published by the Free Software Foundation; either
+// version 2.1 of the License, or (at your option) any later version.
+// This library is distributed in the hope that it will be useful,
+// but WITHOUT ANY WARRANTY; without even the implied warranty of
+// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
+// Lesser General Public License for more details.
+// You should have received a copy of the GNU Lesser General Public
+// License along with this library; if not, write to the Free Software
+// Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
+#endregion
+using System;
+using System.Collections;
+using System.Configuration;
+using System.Data;
+using System.Web;
+using System.Web.Security;
+using System.Web.UI;
+using System.Web.UI.HtmlControls;
+using System.Web.UI.WebControls;
+using System.Web.UI.WebControls.WebParts;
+using OSGeo.MapGuide.MaestroAPI.Mapping;
+using System.Text;
+using OSGeo.MapGuide.MaestroAPI;
+using OSGeo.MapGuide.MaestroAPI.Services;
+using OSGeo.MapGuide.ObjectModels.LayerDefinition;
+using OSGeo.MapGuide.ObjectModels;
+using System.Drawing;
+namespace SamplesWeb.Tasks
+ public partial class AddTracksLayer : System.Web.UI.Page
+ protected void Page_Load(object sender, EventArgs e)
+ string agent = ConfigurationManager.AppSettings["MapAgentUrl"];
+ IServerConnection conn = ConnectionProviderRegistry.CreateConnection(
+ "Maestro.Http",
+ "Url", agent,
+ "SessionId", Request.Params["SESSION"]);
+ IMappingService mpSvc = (IMappingService)conn.GetService((int)ServiceType.Mapping);
+ string rtMapId = "Session:" + conn.SessionID + "//" + Request.Params["MAPNAME"] + ".Map";
+ RuntimeMap rtMap = mpSvc.OpenMap(rtMapId);
+ RuntimeMapLayer tracks = rtMap.GetLayerByName("Tracks");
+ if (tracks != null)
+ lblMessage.Text = "Tracks layer already added";
+ else
+ RuntimeMapGroup group = rtMap.GetGroupByName("Transportation");
+ if (group == null)
+ group = rtMap.AddGroup("Transportation");
+ throw new Exception("Layer group not found");
+ //For some reason, the Sheboygan sample data does not have a Rail
+ //Layer Definition, so what better time to show how to create a
+ //layer dynamically :)
+ //Our Feature Source
+ string fsId = "Library://Samples/Sheboygan/Data/Rail.FeatureSource";
+ //The place we'll store the layer definition
+ string layerId = "Session:" + conn.SessionID + "//Rail.LayerDefinition";
+ CreateTracksLayer(conn, fsId, layerId);
+ RuntimeMapLayer layer = rtMap.CreateLayer(layerId, group);
+ layer.LegendLabel = "Tracks";
+ layer.ShowInLegend = true;
+ layer.ExpandInLegend = true;
+ layer.Selectable = true;
+ layer.Visible = true;
+ //Set it to be drawn above districts.
+ //In terms of draw order, it goes [0...n] -> [TopMost ... Bottom]
+ //So for a layer to be drawn above something else, its draw order must be
+ //less than that particular layer.
+ int index = rtMap.IndexOfLayer("Districts");
+ rtMap.InsertLayer(index, layer);
+ rtMap.Save();
+ Page.ClientScript.RegisterStartupScript(
+ this.GetType(),
+ "load",
+ "<script type=\"text/javascript\"> window.onload = function() { parent.parent.Refresh(); } </script>");
+ lblMessage.Text = "Parcels layer added again";
+ rtMap = mpSvc.OpenMap(rtMapId);
+ DumpMap(rtMap);
+ private static void CreateTracksLayer(IServerConnection conn, string resId, string layerId)
+ //We use the ObjectFactory class to create our layer
+ ILayerDefinition ldf = ObjectFactory.CreateDefaultLayer(conn, LayerType.Vector);
+ IVectorLayerDefinition vldf = (IVectorLayerDefinition)ldf.SubLayer;
+ //Set feature source
+ vldf.ResourceId = resId;
+ //Set the feature class
+ vldf.FeatureName = "SHP_Schema:Rail";
+ //Set the designated geometry
+ vldf.Geometry = "SHPGEOM";
+ //Get the first vector scale range. This will have been created for us and is 0 to infinity
+ IVectorScaleRange vsr = vldf.GetScaleRangeAt(0);
+ //Get the line style
+ ILineVectorStyle lstyle = vsr.LineStyle;
+ //Get the first rule (a created one will only have one)
+ ILineRule rule = lstyle.GetRuleAt(0);
+ //There's only one stroke here, but iteration is the only
+ //way to go through
+ foreach (var stroke in rule.Strokes)
+ //Set color to red
+ stroke.Color = "ffff0000";
+ //Now save it
+ conn.ResourceService.SaveResourceAs(ldf, layerId);
+ //This method dumps the runtime state of the map. I personally
+ //used this method to debug this sample as I was developing it.
+ //It's been kept here for reference.
+ private void DumpMap(RuntimeMap rtMap)
+ StringBuilder sb = new StringBuilder();
+ sb.Append("<p>Debugging</p>");
+ sb.Append("Name: " + rtMap.Name + "<br/>");
+ sb.Append("Layers: <br/>");
+ sb.Append("<ul>");
+ foreach (var layer in rtMap.Layers)
+ sb.Append("<li>Name: " + layer.Name + " (Selectable: " + layer.Selectable + ", Visible: " + layer.Visible + ")<br/>");
+ sb.Append("Group: " + layer.Group + "<br/>");
+ sb.Append("Draw Order: " + layer.DisplayOrder + "</li>");
+ sb.Append("</ul>");
+ debug.InnerHtml = sb.ToString();
Added: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.designer.cs
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.designer.cs (rev 0)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/AddTracksLayer.aspx.designer.cs 2011-05-24 17:42:07 UTC (rev 5849)
@@ -0,0 +1,43 @@
+// <auto-generated>
+// This code was generated by a tool.
+// Runtime Version:2.0.50727.4952
+// Changes to this file may cause incorrect behavior and will be lost if
+// the code is regenerated.
+// </auto-generated>
+namespace SamplesWeb.Tasks {
+ public partial class AddTracksLayer {
+ /// <summary>
+ /// form1 control.
+ /// </summary>
+ /// <remarks>
+ /// Auto-generated field.
+ /// To modify move field declaration from designer file to code-behind file.
+ /// </remarks>
+ protected global::System.Web.UI.HtmlControls.HtmlForm form1;
+ /// <summary>
+ /// lblMessage control.
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ protected global::System.Web.UI.WebControls.Label lblMessage;
+ /// <summary>
+ /// debug control.
+ /// </summary>
+ /// <remarks>
+ /// </remarks>
+ protected global::System.Web.UI.HtmlControls.HtmlGenericControl debug;
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx 2011-05-24 16:27:00 UTC (rev 5848)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Tasks/Home.aspx 2011-05-24 17:42:07 UTC (rev 5849)
@@ -5,13 +5,27 @@
<title>Home</title>
+ <script type="text/javascript">
+ function Go(url)
+ var map = parent.parent.GetMapFrame();
+ url += "?SESSION=" + map.GetSessionId();
+ url += "&MAPNAME=" + map.GetMapName();
+ window.location = url;
+ </script>
</head>
<body>
<p>At any time, click the <strong>home button</strong> in the task bar to return to this list of samples.</p>
<p>Samples</p>
<ul>
- <li><a href="ToggleParcelsLayer.aspx?SESSION=<%=Request.Params["SESSION"] %>&MAPNAME=<%=Request.Params["MAPNAME"] %>">Toggle Parcels Layer</a></li>
+ <li><a href="#" onclick="Go('ToggleParcelsLayer.aspx')">Toggle Parcels Layer</a></li>
+ <li><a href="#" onclick="Go('AddTracksLayer.aspx')">Add Tracks Layer</a></li>
</ul>
</body>
</html>
Modified: trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config
--- trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config 2011-05-24 16:27:00 UTC (rev 5848)
+++ trunk/Tools/Maestro/SDK/SamplesWeb/SamplesWeb/Web.config 2011-05-24 17:42:07 UTC (rev 5849)
@@ -1,29 +1,25 @@
-<?xml version="1.0"?>
+<?xml version="1.0"?>
<configuration>
- <appSettings>
- <add key="MapAgentUrl" value="http://localhost/mapguide/mapagent/mapagent.fcgi"/>
- </appSettings>
- <connectionStrings/>
- <system.web>
+ <appSettings>
+ <add key="MapAgentUrl" value="http://localhost/mapguide/mapagent/mapagent.fcgi"/>
+ </appSettings>
+ <connectionStrings/>
+ <system.web>
Set compilation debug="true" to insert debugging
symbols into the compiled page. Because this
affects performance, set this value to true only
during development.
- <compilation debug="false">
- </compilation>
+ <compilation debug="true">
+ </compilation>
The <authentication> section enables configuration
of the security authentication mode used by
ASP.NET to identify an incoming user.
- <authentication mode="Windows" />
+ <authentication mode="Windows"/>
The <customErrors> section enables configuration
of what to do if/when an unhandled error occurs
during the execution of a request. Specifically,
@@ -35,7 +31,5 @@
<error statusCode="404" redirect="FileNotFound.htm" />
</customErrors>
- </system.web>
+ </system.web>
</configuration>
More information about the mapguide-commits
